05-Layer 2—WAN Access Configuration Guide
HomeSupportRoutersH3C SR8800-F Router SeriesConfigure & DeployConfiguration GuidesH3C SR8800-F Routers Configuration Guides-R8530Pxx-6W10205-Layer 2—WAN Access Configuration Guide
01-PPP configuration
01-PPP configuration 673.33 KB
Configuring PPP·· 1
About PPP· 1
PPP protocols· 1
Basic concepts of PPP· 1
PPP link establishment process· 4
PPP authentication· 10
PPP for IPv4· 10
PPP for IPv6· 11
Protocols and standards· 13
PPP tasks at a glance· 13
Enabling PPP encapsulation on an interface· 14
Configuring a VT interface· 14
Creating a VT interface· 14
Restoring the default settings for the VT interface· 15
Configuring PPP authentication· 15
About PPP authentication· 15
Configuring PAP authentication· 15
Configuring CHAP authentication (authenticator name is configured) 16
Configuring CHAP authentication (authenticator name is not configured) 17
Configuring MS-CHAP or MS-CHAP-V2 authentication· 18
Configuring the polling feature· 19
Configuring a VT interface not to perform keepalive detection when the uplink traffic of PPP users is updated  20
Enabling fast reply for keepalive packets· 20
Configuring PPP negotiation· 21
Configuring the PPP negotiation timeout time· 21
Configuring IPv4 address negotiation on the client 22
Configuring IPv4 address negotiation on the server 22
Configuring IPv6 address negotiation on the server 24
Configuring a BRAS to allow a remote user to come online by using a self-configured static IP address  26
Enabling IP segment match· 28
Configuring DNS server IP address negotiation on the client 28
Configuring DNS server IP address negotiation on the server 28
Setting the delay for transmitting Configure-Ack packets· 29
Enabling PPP link quality monitoring· 29
Configuring magic number check for PPP· 30
Enabling MRU check for PPP packets· 31
Specifying that PPP users cannot come online successfully if the online requests do not carry usernames  31
Enabling PPP user blocking· 32
Enabling per-username PPP user blocking· 32
Configuration per-MAC PPP user blocking· 32
Setting the online PPP session count alarm thresholds on the device· 33
Enabling SNMP notifications for the PPP module· 34
Display and maintenance commands for PPP· 35
PPP configuration examples· 36
Example: Configuring one-way PAP authentication· 36
Example: Configuring two-way PAP authentication· 37
Example: Configuring one-way CHAP authentication· 39
Example: Specifying an IP address for the client on the server interface· 42
Example: Specifying an IP address pool on the server interface· 43
Example: Using the IP address pool associated with an ISP domain· 44
Configuring MP·· 47
About MP· 47
Benefit 47
Interface type· 47
Restrictions and guidelines: MP configuration· 47
MP tasks at a glance· 47
Configuring MP through an MP-group interface· 47
About MP-group interfaces· 47
Tasks at a glance· 47
Creating an MP-group interface· 48
Assigning a physical interface to the MP-group interface· 48
Configuring the polling feature on the MP-group interface· 49
Configuring MP parameters· 49
Restoring the default settings for the MP-group interface· 50
Configuring short sequence number header format negotiation· 50
Configuring the MP endpoint descriptor 51
Configuring an MP-group interface to check the endpoint option when a new physical link joins a bundle· 52
Enabling SNMP notifications for MP packet loss· 52
Display and maintenance commands for MP· 53
MP configuration examples· 54
Example: Configuring an MP-group interface· 54
Configuring PPP
About PPP
Point-to-Point Protocol (PPP) is a point-to-point link layer protocol. It provides user authentication, supports synchronous/asynchronous communication, and allows for easy extension.
PPP protocols
PPP includes the following protocols:
·     Link control protocol (LCP)—Establishes, tears down, and monitors data links.
·     Network control protocol (NCP)—Negotiates the packet format and type for data links.
·     Authentication protocols—Authenticate users. Protocols include the following:
¡     Password Authentication Protocol (PAP).
¡     Challenge Handshake Authentication Protocol (CHAP).
¡     Microsoft CHAP (MS-CHAP).
¡     Microsoft CHAP Version 2 (MS-CHAP-V2).
Basic architecture of PPP
The PPP protocol is in the data link layer of TCP/IP. It is mainly used to support full-duplex synchronous and asynchronous links for point-to-point data transmission.
Figure 1 Position of PPP in the protocol stack
PPP mainly contains the following protocol families:
·     Link Control Protocol (LCP) family—Mainly used to establish, terminate, and monitor a PPP data link.
·     Network Control Protocol (NCP) family—Mainly used to negotiate the format and type of data packets transmitted on a data link.
·     PPP extension protocol family—Mainly used to provide further support for PPP functionality. For example, PPP provides authentication protocols CHAP and PAP for network security.
Frame format of PPP packet encapsulation
The PPP packet encapsulation format is as shown in Figure 2.
Figure 2 PPP packet format
The fields are described as follows:
·     Flag field
The flag field identifies the start and end of a physical frame, and this byte is 0x7E.
·     Address field
The address field can uniquely identify the peer end. The PPP protocol is used on point-to-point links, so two communicating devices interconnected by using the PPP protocol do not need to know each other's data link layer address. According to the protocol, the byte is filled with the all-1 broadcast address, which has no practical meaning for the PPP protocol.
·     Control field
The default value for this field is 0x03, indicating unnumbered frame. By default, PPP does not use sequence numbers and acknowledgment mechanism to achieve reliable transmission.
The address and control fields together identify this packet as a PPP packet. Therefore, the PPP packet header is FF03.
·     Protocol field
The protocol field distinguishes the packet types carried in the information field of PPP frames.
The contents of the protocol field must conform to the provisions of the address extension mechanism provided by ISO 3309. The mechanism specifies that the contents filled in the protocol field must be odd, which means the lowest significant bit in the lowest significant byte should be 1 and the lowest significant bit in the highest significant byte should be 0.
If the protocol field of the PPP frame sent by the sender does not meet the preceding requirements, the receiver will consider this frame unrecognizable. The receiver sends a Protocol-Reject packet to the sender, including the rejected protocol number at the end of the packet.
Table 1 Common protocol codes
Protocol code
Protocol type
0021
Internet Protocol
002b
Novell IPX
002d
Van Jacobson Compressed TCP/IP
002f
Van Jacobson Uncompressed TCP/IP
8021
Internet Protocol Control Protocol
802b
Novell IPX Control Protocol
8031
Bridging NC
C021
C023
C223
·     Information field
The maximum length of the information field is 1500 bytes, including the content of the padding field. The maximum length of the information field is called the Maximum Receive Unit (MRU). The default MRU is 1500 bytes. In actual applications, you can negotiate the MRU as needed.
If the information field length is insufficient, it can be padded, which is not required. If padding is applied, both ends of the communication must be able to distinguish between the padded information and the actual information that needs to be transmitted to communicate properly.
·     FCS field
The main purpose of the FCS field is to check the correctness of PPP frame transmission.
Introducing some transmission assurance mechanisms into the frame will introduce more overhead, which might increase the latency of application layer interaction.
Frame format of LCP packet encapsulation
The LCP packet encapsulation format is as shown in Figure 2.
During the link establishment phase, the PPP protocol establishes and negotiates the link through LCP packets. At this time, an LCP packet is encapsulated as the payload of PPP in the information field of the PPP frame, and the protocol field of the PPP frame is padded with a fixed value of 0xC021.
During the entire process of link establishment, the content of the information field is variable, including many types of packets. These packets also need to be distinguished through the corresponding fields.
·     Code field
The code field is one byte long and is mainly used to identify the type of LCP data packets.
During the link establishment phase, the receiver receives the LCP data packets. When the value of their code field is invalid, the receiver will send a Code-Reject packet to the peer end.
Table 2 Common code values
Code value
Packet type
0x01
Configure-Request
0x02
Configure-Ack
0x03
Configure-Nak
0x04
Configure-Reject
0x05
Terminate-Request
0x06
Terminate-Ack
0x07
Code-Reject
0x08
Protocol-Reject
0x09
Echo-Request
0x0A
Echo-Reply
0x0B
Discard-Request
0x0C
Reserved
·     Identifier field
The identifier field is 1 byte long, and it is used to match requests and replies. When the identifier field value of a packet is illegal, the packet will be dropped.
Typically, the ID of a Configure-Request packet starts at 0x01 and increases gradually by 1. When the peer end receives the Configure-Request packet, the ID in the response packet must be the same as the ID in the received packet no matter what kind of packet is used to respond.
·     Length field
The value of the length field is the total number of bytes in the LCP packet. It is the sum of the lengths of the four fields: code, identifier, length, and data fields.
Bytes beyond the number indicated by the length field will be treated as padded bytes and ignored, and the content of the length field cannot exceed the MRU.
·     Data field
The data field contains the content of the negotiation packet, including the following fields.
¡     The type field indicates the negotiation option type.
¡     The length field indicates the negotiation option length, which is the total length of the data field, including type, length, and data.
¡     The data field contains details of the negotiation option.
Table 3 Common negotiation type values in the type field
Negotiation type value
Negotiation packet type
0x01
Maximum-Receive-Unit
0x02
Async-Control-Character-Map
0x03
Authentication-Protocol
0x04
Quality-Protocol
0x05
Magic-Number
0x06
RESERVED
0x07
Protocol-Field-Compression
0x08
Address-and-Control-Field-Compression
Basic process
Figure 3 shows the PPP link establishment process.
Figure 3 PPP link establishment process
1.     Initially, PPP is in Link Dead phase. After the physical layer goes up, PPP enters the Link Establishment phase (Establish).
2.     In the Link Establishment phase, the LCP negotiation is performed. The LCP configuration options include Authentication-Protocol, Async-Control-Character-Map (ACCM), Maximum-Receive-Unit (MRU), Magic-Number, Protocol-Field-Compression (PFC), Address-and-Control-Field-Compression (ACFC), and MP.
¡     If the negotiation fails, LCP reports a Fail event, and PPP returns to the Dead phase.
¡     If the negotiation succeeds, LCP enters the Opened state and reports an Up event, indicating that the underlying layer link has been established. At this time, the PPP link is not established for the network layer, and network layer packets cannot be transmitted over the link.
3.     If authentication is configured, the PPP link enters the Authentication phase, where PAP, CHAP, MS-CHAP, or MS-CHAP-V2 authentication is performed.
¡     If the client fails to pass the authentication, LCP reports a Fail event and enters the Link Termination phase. In this phase, the link is torn down and LCP goes down.
¡     If the client passes the authentication, LCP reports a Success event.
4.     If a network layer protocol is configured, the PPP link enters the Network-Layer Protocol phase for NCP negotiation, such as IPCP negotiation and IPv6CP negotiation.
¡     If the NCP negotiation succeeds, the link goes up and becomes ready to carry negotiated network-layer protocol packets.
¡     If the NCP negotiation fails, NCP reports a Down event and enters the Link Termination phase.
If the interface is configured with an IP address, the IPCP negotiation is performed. IPCP configuration options include IP addresses and DNS server IP addresses. After the IPCP negotiation succeeds, the link can carry IP packets.
5.     After the NCP negotiation is performed, the PPP link remains active until either of the following events occurs:
¡     Explicit LCP or NCP frames close the link.
¡     Some external events take place (for example, the intervention of a user).
Dead phase (physical-layer not ready phase)
The dead phase is also known as the physical-layer not ready phase. A PPP link necessarily begins and ends with this phase.
When both ends of the communication detect the physical line activation (usually the carrier signal on the link), they will transition from the dead phase to link establishment phase.
The link will return to the physical-layer not ready phase after it is disconnected.
Establish phase (link establishment phase)
During the establish phase, a PPP link undergoes LCP negotiation. The negotiation content includes options such as single-link PPP (SP) or multilink PPP (MP), maximum receive unit (MRU), authentication method, and magic number. When the exchange of configuration packets is completed, the link will proceed to the next phase.
After the link is established, the next phase can be selected based on the configuration of the devices at both ends of the link. The next phase can be either the authentication phase or the network layer protocol phase. This selection depends on the configuration made by the user on the devices at both ends of the link.
During the establish phase, the LCP state machine will undergo the following changes.
·     When the link is in physical-layer not ready phase, the LCP state machine is in the Initial or Starting state. When the physical layer detects that the link is available, it will send an Up event to the link layer. Upon receiving this event, the link layer will change the LCP state machine from the current state to Request-Sent state. Then, LCP will take corresponding actions to send a Configure-Request packet to configure the data link.
·     If the local device receives the Configure-Ack packet first, the LCP state machine will change from Request-Sent state to Ack-Received state. After the local end sends the Configure-Ack packet to the peer end, the LCP state machine will change from Ack-Received state to Open state.
·     If the local device sends a Configure-Ack packet to the peer end first, the LCP state machine will change from Request-Sent state to Ack-Sent state. After the local end receives the Configure-Ack packet from the peer end, the LCP state machine will change from Ack-Sent state to Open state.
·     Once the LCP state machine enters Open state, the link completes the current negotiation phase and proceeds to the next phase.
Authenticate phase (authentication phase)
By default, a PPP link does not perform authentication. If authentication is required, the authentication protocol must be specified during the link establishment phase.
PPP provides two authentication methods: Password Authentication Protocol (PAP) and Challenge Handshake Authentication Protocol (CHAP).
PPP authentication methods include one-way authentication and two-way authentication.
·     One-way authentication refers to one end acting as the authenticator and the other end as the authenticatee.
·     Two-way authentication is a simple overlay of one-way authentication, where both ends act as both the authenticator and the authenticatee.
PAP authentication process
PAP authentication is two-way handshake authentication, and uses simple passwords.
The process of PAP authentication is shown in Figure 4.
Figure 4 PAP authentication process
1.     The authenticatee sends the local username and password to the authenticator.
2.     The authenticator checks the local user table to identify whether the authenticatee's username exists.
¡     If yes, the authenticator identifies whether the password is correct.
-     If the password is correct, the authentication will succeed.
-     If the password is incorrect, the authentication will fail.
¡     If not, the authentication will fail.
Frame format of a PAP authentication packet
A PAP packet is encapsulated with a protocol field of 0xC023 in the information field of the PPP data link layer frame. The frame format of a PAP packet is as shown in Figure 5.
Figure 5 Frame format of a PAP authentication packet
In the frame format of a PAP authentication packet, the meaning of each field is described in Table 4.
Table 4 Fields in the frame format of a PAP authentication packet
Length (bytes)
Code
1
Identifier
1
Length
2
Data
0 or more bytes
CHAP authentication process
CHAP authentication is a three-way handshake authentication protocol. CHAP transmits only the username rather than the user password over the network, so it is more secure than PAP.
The authentication process of CHAP is as shown in Figure 6.
Figure 6 CHAP authentication process
The CHAP one-way authentication process supports two cases: the authenticator has configured a username and the authenticator has not configured a username. As a best practice, use the method of configuring the username on the authenticator, so that the username of the authenticator can be confirmed.
·     Authentication process when the authenticator has configured a username
a.     The authenticator initiates the authentication request, constructs a packet containing a random number, and at the same time sends the local username to the authenticatee. (Challenge.)
b.     When the authenticatee receives the authentication request from the authenticator, the authenticatee first identifies whether a CHAP password is configured on the local interface.
-     If the interface is configured with a CHAP password, the authenticatee uses the hash algorithm to calculate a hash value based on the packet ID, CHAP password, and random number in the packet. Then, the authenticatee sends the obtained hash value and the username of the authenticatee back to the authenticator. (Response.)
-     If the interface is not configured with a CHAP password, the authenticatee searches for the password corresponding to the user in the local user table based on the authenticator username in the packet. The authenticatee uses the hash algorithm to calculate a hash value based on the packet ID, user password, and the random number in the packet, and sends the obtained hash value and the username of the authenticatee back to the authenticator. (Response).
c.     The authenticator first looks up the password corresponding to the user in the local end based on the username of the authenticatee in the received packet. Then, the authenticator uses the hash algorithm to calculate a hash value based on the packet ID, the password of the authenticatee, and the random number in the Challenge packet, and compares the obtained hash value with the hash value in the Response packet. If the comparison result is consistent, the authentication succeeds. If the comparison result is inconsistent, the authentication fails.
·     Authentication process when the authenticator has not configured a username
d.     The authenticator initiates an authentication request, and sends a packet containing a random number to the authenticatee. (Challenge.)
e.     After receiving the authentication request from the authenticator, the authenticatee uses the hash algorithm to calculate a hash value based on the packet ID, configured CHAP password, and random number in the packet. Then, the authenticatee sends the obtained hash value and its own username back to the authenticator. (Response).
f.     The authenticator first looks up the password corresponding to the username of the authenticatee in the local send based on the received packet. Then, the authenticator calculates the hash value by using a hash algorithm based on the packet ID, the password of the authenticatee, and the random number in the packet, and compares it with the hash value in the Response packet. If the comparison result is consistent, the authentication succeeds. If the comparison result is inconsistent, the authentication fails.
Frame format of a CHAP authentication packet
A CHAP packet is encapsulated with a protocol field of 0xC223 in the information field of the PPP data link layer frame. The frame format of a CHAP packet is as shown in Figure 7.
Figure 7 Frame format of a CHAP authentication packet
In the frame format of a CHAP authentication packet, the meaning of each field is described in Table 5.
Table 5 Fields in the frame format of a CHAP authentication packet
Length (bytes)
Code
1
Identifier
1
Length
2
Data
0 or more bytes
The differences between CHAP and PAP authentication methods are as follows:
·     PAP authentication involves sending a simple password on the link. After the PPP link is established, the authenticatee continuously sends the username and password on the link until the authentication process ends. Therefore, PAP authentication is not very secure. When the security requirements are not high in practical applications, you can use PAP authentication to establish a PPP connection.
·     In CHAP authentication, the authentication protocol is a three-way handshake authentication protocol. CHAP transmits only the username rather than the user password over the network, so it is more secure than PAP. When the security requirements are high in practical applications, you can use CHAP authentication to establish a PPP connection.
Network phase (network layer protocol phase)
After PPP completes the previous phase, PPP selects and configures a network layer protocol and negotiates network layer parameters through NCP negotiation. Each NCP protocol can be enabled and disabled at any time. When the state machine of an NCP protocol becomes Open, PPP can begin network layer data transmission on the link.
Terminate phase (link termination phase)
PPP can terminate the link at any time. When the carrier is lost, authentication fails, or the administrator manually closes the link, the link will be terminated.
PPP authentication
PPP supports the following authentication methods:
PAP
PAP is a two-way handshake authentication protocol using the username and password. PAP sends username/password pairs in plain text over the network. If authentication packets are intercepted in transit, network security might be threatened. For this reason, it is suitable only for low-security environments.
CHAP
CHAP is a three-way handshake authentication protocol.
CHAP transmits usernames but not passwords over the network. It transmits the result calculated from the password and random packet ID by using the MD5 algorithm.
CHAP is more secure than PAP. The authenticator may or may not be configured with a username. As a best practice, configure a username for the authenticator, which makes it easier for the peer to verify the identity of the authenticator.
MS-CHAP
MS-CHAP is a three-way handshake authentication protocol. MS-CHAP differs from CHAP in that MS-CHAP provides authentication retry. If the peer fails authentication, it is allowed to retransmit authentication information to the authenticator for reauthentication. The authenticator allows a peer to retransmit a maximum of three times.
MS-CHAP-V2
MS-CHAP-V2 is a three-way handshake authentication protocol.
MS-CHAP-V2 differs from CHAP as follows:
·     MS-CHAP-V2 provides two-way authentication by piggybacking a peer challenge on the Response packet and an authenticator response on the Acknowledge packet.
·     MS-CHAP-V2 supports authentication retry. If the peer fails authentication, it is allowed to retransmit authentication information to the authenticator for reauthentication. The authenticator allows a peer to retransmit a maximum of three times.
·     MS-CHAP-V2 supports password change. If the peer fails authentication because of an expired password, it will send the new password entered by the user to the authenticator for reauthentication.
PPP for IPv4
On IPv4 networks, PPP negotiates the IP address and DNS server address during IPCP negotiation.
IP address negotiation enables one end to assign an IP address to the other.
An interface can act as a client or a server during IP address negotiation:
·     Client—Obtains an IP address from the server. Use the client mode when the device accesses the Internet through an ISP.
·     Server—Assigns an IP address to the client. Before you configure the IP address of the server, you must perform one of the following tasks:
¡     Configure a local address pool and associate the pool with the ISP domain.
¡     Specify an IP address or an IP address pool for the client on the interface.
When IP address negotiation is enabled on a client, the server selects an IP address for the client in the following sequence:
1.     If the AAA server configures an IP address or address pool for the client, the server selects that IP address or an IP address from the pool. The IP address or address pool is configured on the AAA server instead of the PPP server. ‍For information about AAA, see BRAS Services Configuration Guide.
2.     If an address pool is associated with the ISP domain used during client authentication, the server selects an IP address from the pool.
3.     If an IP address or address pool is specified for the client on the interface of the server, the server selects that IP address or an IP address from that pool.
DNS server address negotiation
IPCP negotiation can determine the DNS server IP address.
When the device is connected to a host, configure the device as the server to assign the DNS server IP address to the host.
When the device is connected to an ISP access server, configure the device as the client. Then, the device can obtain the DNS server IP address from the ISP access server.
PPP for IPv6
On IPv6 networks, PPP negotiates only the IPv6 interface identifier instead of the IPv6 address and IPv6 DNS server address during IPv6CP negotiation. PPP users have to obtain IPv6 global unicast addresses and IPv6 DNS server addresses by using ND or DHCPv6 protocols.
IPv6 address assignment
A host can get an IPv6 global unicast address through the following methods:
·     NDRA—The host obtains an IPv6 prefix in an RA message. The host then generates an IPv6 global unicast address by combining the IPv6 prefix and the negotiated IPv6 interface identifier. The IPv6 prefix in the RA message is determined in the following sequence:
a.     IPv6 prefix authorized by an AAA server through the Framed-IPv6-Prefix attribute.
b.     IPv6 prefix authorized in an ISP domain.
c.     Prefix in the ND prefix pool authorized in an ISP domain.
d.     Prefix in the 128-bit IPv6 global unicast address authorized by an AAA server through the Framed-IPv6-Address attribute. If an interface identifier has been authorized by an AAA server through the Framed-Interface-Id attribute, skip this step and go to step f.
e.     Prefix in the 128-bit IPv6 global unicast address authorized by using the authorization-attribute ipv6 command in local user view. If an interface identifier has been authorized by an AAA server through the Framed-Interface-Id attribute, skip this step and go to step f.
f.     RA prefix configured on the interface.
g.     Prefix in the IPv6 global unicast address configured on the interface.
The method of authorizing an ND prefix pool in an ISP domain applies to the scenario of one prefix per user. In this scenario, each user has an exclusive IPv6 prefix. Other methods apply to the prefix sharing scenario, in which multiple users can share the same IPv6 prefix.
The negotiated IPv6 interface identifiers are determined in the following sequence:
a.     Interface identifier authorized by an AAA server through the Framed-Interface-Id attribute.
b.     Interface identifier in the 128-bit IPv6 global unicast address authorized by an AAA server through the Framed-IPv6-Address attribute. If an IPv6 prefix has been authorized by an AAA server through the Framed-IPv6-Prefix attribute, skip this step and go to step d.
c.     Interface identifier in the 128-bit IPv6 global unicast address authorized by using the authorization-attribute ipv6 command in local user view. If an IPv6 prefix has been authorized by an AAA server through the Framed-IPv6-Prefix attribute, skip this step and go to step d.
d.     Interface identifier automatically generated for the PPP user when the ipv6cp assign-interface-id command is executed in an ISP domain.
e.     Non-zero interface identifier that is carried by the user and does not conflict with any other interface identifier.
f.     Interface identifier automatically generated for the PPP user when the interface identifier carried by the user is invalid.
The ND prefix pool authorized by AAA and the IA_NA method are mutually exclusive. For information about the ND protocol, see Layer 3—IP Services Configuration Guide.
·     DHCPv6 (IA_NA)—The host requests an IPv6 global unicast address through DHCPv6. The server assigns an IPv6 address to the host from the address pool authorized by AAA. If no AAA-authorized address pool exists, DHCPv6 uses the address pool that matches the server's IPv6 address to assign an IPv6 address to the host. For information about DHCPv6, see BRAS Services Configuration Guide.
After an IPv6 address pool is authorized to users, IA_NA also supports authorizing the specified 128-bit IPv6 global unicast addresses to PPP users through the following methods:
¡     Authorizing 128-bit IPv6 global unicast addresses by an AAA server through the Framed-IPv6-Address attribute.
¡     Authorizing 128-bit IPv6 global unicast addresses by using the authorization-attribute ipv6 command in local user view.
Make sure the 128-bit IPv6 global unicast addresses authorized by using the two methods above are within the authorized IPv6 address pool. Otherwise, the 128-bit IPv6 global unicast addresses authorized by using the two methods above are not used, and IPv6 addresses in the IPv6 address pool are randomly allocated to users.
·     DHCPv6 (IA_PD)—A client-side device requests prefixes through DHCPv6 and assigns them to downstream hosts. The hosts then use the prefixes to generate global IPv6 addresses. This method uses the same principle of selecting address pools as the DHCPv6 (IA_NA) method.
The device can assign a host an IPv6 address in either of the following ways:
·     When the host connects to the device directly or through a bridge device, the device can use the NDRA method or the IA_NA method.
·     When the host accesses the device through a router, the device can use the IA_PD method to assign an IPv6 prefix to the router. The router assigns the prefix to the host to generate an IPv6 global unicast address.
·     You can use the NDRA+IA_PD combination or the IA_NA+IA_PD combination as needed to meet address assignment requirements in different scenarios.
IPv6 DNS server address assignment
On IPv6 networks, two methods are available for the IPv6 DNS server address assignment:
·     The client obtains the IPv6 DNS server address from the DNS server options carried in ND RA packets. The DNS server option carried in RA packets can be authorized by AAA or configured by using the ipv6 nd ra dns server command on an interface. If both the IPv6 DNS server option authorized by AAA and the IPv6 DNS server option configured on an interface are available, the RA packets carry both options, with the AAA-authorized one in the front. If the two options conflict, the AAA-authorized one applies. For more information about the ipv6 nd ra dns server command, see Layer 3—IP Services Command Reference.
·     The DHCPv6 client requests an IPv6 DNS server address from the DHCPv6 server.
RFC 1661: The Point-to-Point Protocol (PPP)
To configure PPP, perform the following tasks:
1.     Enabling PPP encapsulation on an interface
2.     Configuring a VT interface
¡     Creating a VT interface
In a PPPoE or L2TP network, you must configure VT interfaces. For more information about PPPoE and L2TP, see BRAS Services Configuration Guide.
¡     (Optional.) Restoring the default settings for the VT interface
3.     Configuring PPP authentication
¡     Configuring PAP authentication
¡     Configuring CHAP authentication (authenticator name is configured)
¡     Configuring CHAP authentication (authenticator name is not configured)
¡     Configuring MS-CHAP or MS-CHAP-V2 authentication
Configure PPP authentication for high-security environments.
4.     (Optional.) Configuring the polling feature
5.     (Optional.) Configuring a VT interface not to perform keepalive detection when the uplink traffic of PPP users is updated
6.     (Optional.) Enabling fast reply for keepalive packets
7.     (Optional.) Configuring PPP negotiation
¡     Configuring the PPP negotiation timeout time
¡     Configuring IPv4 address negotiation on the client
¡     Configuring IPv4 address negotiation on the server
¡     Configuring IPv6 address negotiation on the server
¡     Configuring a BRAS to allow a remote user to come online by using a self-configured static IP address
¡     Enabling IP segment match
¡     Configuring DNS server IP address negotiation on the client
¡     Configuring DNS server IP address negotiation on the server
¡     Setting the delay for transmitting Configure-Ack packets
8.     (Optional.) Enabling PPP link quality monitoring
9.     (Optional.) Configuring magic number check for PPP
10.     (Optional.) Enabling MRU check for PPP packets
11.     (Optional.) Specifying that PPP users cannot come online successfully if the online requests do not carry usernames
12.     (Optional.) Enabling PPP user blocking
¡     Enabling per-username PPP user blocking
¡     Configuration per-MAC PPP user blocking
13.     (Optional.) Setting the online PPP session count alarm thresholds on the device
14.     (Optional.) Enabling SNMP notifications for the PPP module
2.     Enter interface view.
3.     Enable PPP encapsulation on the interface.
link-protocol ppp
By default, all interfaces except Ethernet interfaces, VLAN interfaces, and ATM interfaces use PPP as the link layer protocol.
About VT interfaces
Virtual-template (VT) interfaces are logical interfaces manually created on devices. A VT interface can implement the functionality of a physical WAN interface with PPP encapsulation enabled.
In PPPoE and L2TP applications, you can use VT interfaces to implement related functions of PPP. For more information about PPPoE and L2TP, see "Configuring PPPoE" and "Configuring L2TP."
In standard system operating mode, VT interfaces are supported.
In SDN-WAN system operating mode, VT interfaces are not supported.
2.     Create a VT interface and enter its view.
interface virtual-template number
3.     (Optional.) Set the interface description.
By default, the description of a VT interface is interface name Interface, for example, Virtual-Template1 Interface.
4.     (Optional.) Set the MTU size of the interface.
mtu size
By default, the MTU of a VT interface varies by interface card.
5.     (Optional.) Set the expected bandwidth of the VT interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you execute it on a live network.
The default command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use the undo forms of these commands or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
2.     Enter VT interface view.
3.     Restore the default settings for the interface.
default
You can configure several authentication modes simultaneously. In LCP negotiation, the authenticator negotiates with the peer in the sequence of configured authentication modes until the LCP negotiation succeeds. If the response packet from the peer carries a recommended authentication mode, the authenticator directly uses the authentication mode if it finds the mode configured.
Restrictions and guidelines for PAP authentication
For local AAA authentication, the username and password of the peer must be configured on the authenticator.
For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
The username and password configured for the peer must be the same as those configured on the peer by using the ppp pap local-user command.
Configuring the authenticator
3.     Configure the authenticator to authenticate the peer by using PAP.
ppp authentication-mode pap [ domain { isp-name | default enable isp-name } ]
By default, PPP authentication is disabled.
4.     Configure local or remote AAA authentication.
Configuring the peer
3.     Configure the PAP username and password sent from the peer to the authenticator when the peer is authenticated by the authenticator by using PAP.
ppp pap local-user username password { cipher | simple } string
By default, when being authenticated by the authenticator by using PAP, the peer sends null username and password to the authenticator.
For security purposes, the password specified in plaintext form and ciphertext form will be stored in encrypted form.
Restrictions and guidelines for CHAP authentication (authenticator name is configured)
When you configure the authenticator, follow these guidelines:
·     For local AAA authentication, the username and password of the peer must be configured on the authenticator.
·     For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
·     The username and password configured for the peer must meet the following requirements:
¡     The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
¡     The passwords configured for the authenticator and peer must be the same.
When you configure the peer, follow these guidelines:
·     For local AAA authentication, the username and password of the authenticator must be configured on the peer.
·     For remote AAA authentication, the username and password of the authenticator must be configured on the remote AAA server.
·     The username and password configured for the authenticator must meet the following requirements:
¡     The username configured for the authenticator must be the same as that configured on the authenticator by using the ppp chap user command.
·     The peer does not support the CHAP authentication password configured by using the ppp chap password command. CHAP authentication (authenticator name is configured) will apply even if the authentication name is configured.
3.     Configure the authenticator to authenticate the peer by using CHAP.
ppp authentication-mode chap [ domain { isp-name | default enable isp-name } ]
4.     Configure a username for the CHAP authenticator.
ppp chap user username
The default setting is null.
5.     Configure local or remote AAA authentication.
3.     Configure a username for the CHAP peer.
Restrictions and guidelines for CHAP authentication (authenticator name is not configured)
·     The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
·     The password configured for the peer must be the same as that configured on the peer by using the ppp chap password command.
4.     Set the CHAP authentication password.
ppp chap password { cipher | simple } string
Restrictions and guidelines for MS-CHAP or MS-CHAP-V2 authentication
The device can only act as an authenticator for MS-CHAP or MS-CHAP-V2 authentication.
L2TP supports only MS-CHAP authentication.
MS-CHAP-V2 authentication supports password change only when using RADIUS.
As a best practice, do not set the authentication method for PPP users to none when MS-CHAP-V2 authentication is used.
For local AAA authentication, the username and password of the peer must be configured on the authenticator. For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server. The username and password of the peer configured on the authenticator or remote AAA server must be the same as those configured on the peer.
If authentication name is configured, the username configured for the authenticator on the peer must be the same as that configured on the authenticator by using the ppp chap user command.
Configuring MS-CHAP or MS-CHAP-V2 authentication (authenticator name is configured)
3.     Configure the authenticator to authenticate the peer by using MS-CHAP or MS-CHAP-V2.
ppp authentication-mode { ms-chap | ms-chap-v2 } [ domain { isp-name | default enable isp-name } ]
4.     Configure a username for the MS-CHAP or MS-CHAP-V2 authenticator.
Configuring MS-CHAP or MS-CHAP-V2 authentication (authenticator name is not configured)
The polling feature checks PPP link state.
On an interface that uses PPP encapsulation, the link layer sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface has received no response to keepalive packets when the keepalive retry limit is reached, it determines that the link has failed and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
The value 0 disables an interface from sending keepalive packets. In this case, the interface can respond to keepalive packets from the peer.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
The keepalive interval must be smaller than the negotiation timeout time.
3.     Set the keepalive interval.
timer-hold seconds
By default, the keepalive interval is 10 seconds for a POS or serial interface and 60 seconds for a VT interface.
4.     Set the keepalive retry limit.
timer-hold retry retries
By default, the keepalive retry limit is 5 for a POS or serial interface and 3 for a VT interface.
If the configured keepalive interval (timer-hold seconds) or keepalive retry limit (timer-hold retry retries) is small, users might go offline because the interface cannot receive keepalive packets from the peer when congestion occurs in the network. To prevent keepalive packets from making the congestion deteriorate or causing users to frequently go offline, configure this feature.
With this feature configured, the device will use the keepalive timer to monitor the user online state. If the device detects an update in the user's uplink traffic during the keepalive interval, the device will record this update. When the keepalive timer expires, the device will identify whether traffic is updated for the user during that period. If the traffic is updated, it means the user is online, and the device will not send keepalive detection packets. If the traffic is not updated, the device will send keepalive packets to detect the user online state. For example, the timer-hold command is executed to set the keepalive interval to 60 seconds. If the uplink traffic of the user is updated at the 5th second, the device will record this update, but the timer will continue to count to 60 seconds. The device checks for traffic update records at the 60th second. If the user's uplink traffic is updated within the 60 seconds, the device will not send keepalive packets. If traffic is not updated, the device will send detection packets to detect the user online state.
To balance the overall device performance and ensure that the device operates at the best performance, the device uses the periodical statistics collection mechanism to collect user traffic update conditions. When a large number of users are online, you can configure the device not to perform keepalive detection if the uplink traffic of a user is updated within one keepalive interval. In this case, as a best practice, increase the keepalive interval by using the timer-hold seconds command. If you do not do that, when the traffic of some users is updated within one keepalive interval, the device might fail to timely collect traffic update conditions of these users. As a result, the device considers that the traffic is not updated for these users, and sends detection packets to these users.
3.     Configure the VT interface not to perform keepalive detection when the uplink traffic of PPP users is updated.
ppp keepalive datacheck
By default, keepalive packets are sent to detect online users after the keepalive interval expires no matter whether the uplink traffic of PPP users is updated within a keepalive interval.
This feature allows the hardware to automatically identify and reply to incoming keepalive requests, which can prevent DDoS attacks.
In standard system operating mode, this feature is available only for the following cards:
Table 6 Card information
Card category
Cards
CSPEX
CSPEX-1304S, CSPEX-1404S, CSPEX-1504S
In SDN-WAN system operating mode, this feature is not supported.
2.     Enable fast reply for keepalive packets.
In standalone mode:
ppp keepalive fast-reply enable slot slot-number
In IRF mode:
ppp keepalive fast-reply enable chassis chassis-number slot slot-number
By default, fast reply is enabled for keepalive packets.
The device starts the PPP negotiation timeout timer after sending a packet. If no response is received before the timer expires, the device sends the packet again.
If two ends of a PPP link vary greatly in the LCP negotiation packet processing rate, configure the delay timer on the end with a higher processing rate. The LCP negotiation delay timer prevents frequent LCP negotiation packet retransmission. After the physical layer comes up, PPP starts LCP negotiation when the delay timer expires. If PPP receives LCP negotiation packets before the delay timer expires, it starts LCP negotiation immediately.
3.     (Optional.) Configure the LCP negotiation delay timer.
ppp lcp delay milliseconds
By default, PPP starts LCP negotiation after the physical layer comes up.
4.     Configure the negotiation timeout time.
ppp timer negotiate seconds
The default setting is 3 seconds.
3.     Enable IP address negotiation.
ip address ppp-negotiate
By default, IP address negotiation is not enabled.
If you execute this command and the ip address command multiple times, the most recent configuration takes effect. For more information about the ip address command, see Layer 3—IP Services Command Reference.
Configure the server to assign an IP address to a client by using the following methods:
·     Method 1: Specify an IP address for the client on the server interface.
·     Method 2: Specify an address pool on the server interface.
·     Method 3: Associate an address pool with an ISP domain.
·     Method 4: Authorize an IP address to a client by using the AAA server.
Restrictions and guidelines for IP address negotiation on the server
For clients requiring no authentication, you can use either method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
For clients requiring authentication, you can use one or more of the four methods. When multiple methods are configured, method 4 takes precedence over method 3, and method 3 takes precedence over method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
When you use method 4, enable DHCP on the AAA server by using the dhcp enable command and authorize an IP address to the client. For more information about the dhcp enable command, see BRAS Services Command Reference.
3.     Configure the interface to assign an IP address to the peer.
remote address ip-address
By default, an interface does not assign an IP address to the peer.
4.     Configure an IP address for the interface.
ip address ip-address
By default, no IP address is configured on an interface.
2.     Configure DHCP.
¡     If the server acts as a DHCP server, perform the following tasks:
-     Configure the DHCP server.
-     Configure an IP address pool on the server.
¡     If the server acts as a DHCP relay agent, perform the following tasks:
-     Configure the DHCP relay agent on the server.
-     Configure an IP address pool on the remote DHCP server.
-     Enable the DHCP relay agent to record relay entries.
-     Configure a DHCP relay address pool.
For information about configuring a DHCP server and a DHCP relay agent, see BRAS Services Configuration Guide.
3.     Enter interface view.
4.     Configure the interface to assign an IP address from the configured IP address pool to the peer.
remote address pool pool-name
5.     (Optional.) Configure the method of generating DHCP client IDs when PPP users act as DHCP clients.
remote address dhcp client-identifier { { callingnum | username } [ session-info ] | session-info }
By default, the method of generating DHCP client IDs when PPP users act as DHCP clients is not configured.
When DHCP client IDs are generated based on PPP usernames, make sure different users use different PPP usernames to come online.
6.     Configure an IP address for the interface.
Associating an IP address pool with an ISP domain
2.     Configure DHCP.
3.     Enter ISP domain view.
domain name isp-name
4.     Associate the ISP domain with the configured IP address pool or DHCP relay address pool for address assignment.
authorization-attribute ip-pool pool-name
By default, no IP address pool or DHCP relay address pool is associated.
For more information about this command, see BRAS Services Command Reference.
5.     Return to system view.
6.     Enter interface view.
7.     (Optional.) Configure the method of generating DHCP client IDs when PPP users act as DHCP clients.
8.     Configure an IP address for the interface.
Assigning an IPv6 address by using the NDRA method
1.     Enter VT interface view.
interface virtual-template interface-number
2.     Enable the interface to advertise RA messages.
undo ipv6 nd ra halt
3.     Configure the prefix information in RA messages on the interface.
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix/prefix-length } [ valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] * ]
¡     IPv6 prefix authorized by AAA.
¡     Prefix in the ND prefix pool authorized by AAA.
¡     RA prefix configured on the interface.
¡     Prefix of the IPv6 global unicast address configured on the interface.
If the ipv6 nd ra prefix command is executed on both a user access interface and the VT interface bound to the interface, the command takes effect only on the VT interface.
4.     Set the other stateful configuration flag (O) to 1 in RA advertisements to be sent.
ipv6 nd autoconfig other-flag
You can also execute this command in ISP domain view. Execute this command in at least one of ISP domain view and interface view.
6.     Enter user access interface view.
7.     Configure the interface to automatically generate a link-local address.
ipv6 address auto link-local
8.     Enable the interface to advertise RA messages.
9.     Enable the DHCPv6 server.
ipv6 dhcp select server
10.     Return to system view.
11.     Create an ISP domain and enter its view.
12.     Configure an IPv6 prefix authorized to the user in the ISP domain.
authorization-attribute ipv6-prefix ipv6-prefix prefix-length
Assigning an IPv6 address by using the IA_NA method
3.     Set the managed address configuration flag (M) to 1 in RA advertisements to be sent.
11.     Configure an IPv6 address pool and configure an ISP domain to authorize the address pool to users.
For more information, see BRAS Services Configuration Guide.
Assigning an IPv6 address by using the IA_PD method
1.     Enter user access interface view.
2.     Configure the interface to automatically generate a link-local address.
3.     Enable the interface to advertise RA messages.
4.     Enable the DHCPv6 server.
6.     Create a prefix pool and specify the prefix and the assigned prefix length for the pool.
ipv6 dhcp prefix-pool prefix-pool-number prefix prefix/prefix-len assign-len assign-len
7.     Create an IPv6 address pool and enter its view.
8.     Apply a prefix pool to the IPv6 address pool, so the DHCPv6 server can dynamically select a prefix from the prefix pool for the client.
prefix-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ] [ export-route [ preference preference | tag tag ] * ]
9.     Return to system view.
10.     Create an ISP domain and enter its view.
11.     Configure the user authorization attribute in the ISP domain.
authorization-attribute ipv6-pool pool-name
By default, a PPPoE user must use an IP address dynamically allocated by the BRAS (PPPoE server) or authorized by the AAA server during the onboarding process, and a BRAS does not allow a user to come online by using a self-configured static IP address.
On some networks, for a user to come online by using a self-configured static IP address, you can configure this feature on the BRAS. With this feature configured, a BRAS to allow a remote user to come online by using a self-configured static IP address. After the user passes authentication and comes online, the BRAS will maintain session information for the user based on the static IP address.
This feature applies to only PPPoE users in the BRAS access scenario.
To avoid IP conflicts between users, plan the IP addresses reasonably. Make sure the dynamically allocated IP addresses do not contain static IP addresses used by access users and the static IP address of each access user is unique. If you cannot do that, the user cannot come online in the IPv4 or IPv6 protocol stack because of IP address conflicts.
When you configure this feature on an IPv4 network, follow these restrictions and guidelines:
·     You must use an IP address pool to deploy the gateway address information to the address management module. For example, specify the export-route keyword when executing the gateway-list command in a common IP address pool. Also, you must authorize the IP address pool in the authentication domain of the user.
·     You can specify the DNS server address for users in the authorized IP address pool.
When you configure this feature on an IPv6 network, follow these restrictions and guidelines:
·     For the access interface of an IPv6 static user, do not configure NDRA initiation on the interface. If both NDRA initiation and IPv6 static user access are configured on an interface, only the NDRA initiation method takes effect.
·     As a best practice to prevent an IPv6 static user from failing to come online because the NDRA initiation method is mistakenly configured, execute the ipv6 nd autoconfig managed-address-flag command to prevent the IPv6 static user from coming online through NDRA initiation on at least one of the VT interface of the IPv6 static user and the authentication domain of the user.
·     For the access interface of an IPv6 static user, some endpoints will first obtain addresses through IA_NA initiation if you also configure the IA_NA initiation method on the interface. After the endpoints obtain addresses through IA_NA initiation, the static addresses configured for the endpoints will not take effect. As a best practice, execute the undo ipv6 dhcp select command on the access interfaces of an IPv6 static user to prevent the IPv6 static user from obtaining an address through IA_NA. (The default configuration.)
·     The IPv6 DNS server address of a user must be manually configured, and cannot be obtained through any other method (for example, DHCPv6).
Table 7 Card information
Card category
Cards
CSPEX
3.     Configure the BRAS to allow a remote user to come online by using a self-configured static IP address.
ppp accept remote-ip-address
By default, a BRAS does not allow a remote user to come online by using a self-configured static IP address.
4.     Configure the BRAS to allow a remote user to come online by using a self-configured static IPv6 global unicast address.
ppp accept remote-ipv6-address
By default, a BRAS does not allow a remote user to come online by using a self-configured static IPv6 global unicast address.
This feature enables the local interface to check whether its IP address and the IP address of the remote interface are in the same network segment. If they are not, IPCP negotiation fails.
3.     Enable IP segment match.
ppp ipcp remote-address match
During PPP negotiation, the server will assign a DNS server IP address only for a client configured with the ppp ipcp dns request command. For some special devices to forcibly assign DNS server IP addresses to clients that do not initiate requests, configure the ppp ipcp dns admit-any command on these devices.
3.     Enable the device to request the peer for a DNS server IP address.
By default, a client does not request its peer for a DNS server IP address.
4.     Configure the device to accept the DNS server IP addresses assigned by the peer even though it does not request the peer for the DNS server IP addresses.
By default, a device does not accept the DNS server IP addresses assigned by the peer if it does not request the peer for the DNS server IP addresses.
This command is not necessary if the ppp ipcp dns request command is configured.
3.     Specify the primary and secondary DNS server IP addresses to be allocated to the peer in PPP negotiation.
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
By default, a device does not allocate DNS server IP addresses to its peer if the peer does not request them.
After this command is configured, the server allocate DNS server IP addresses to a client that initiates requests.
During the IPCP negotiation process, both ends of PPP exchange Configure-Ack packets by receiving and transmitting them. By default, when either device receives and transmits a Configure-Ack packet, it considers the negotiation complete and begins exchanging upper-layer service packets. However, in certain special conditions, the local device might receive packets from the remote device before it is ready to process upper-layer service packets (such as DNS request packets), resulting in packet drop. To resolve this issue, you can configure the delay for transmitting Configure-Ack packets on the local device to ensure that the device has enough time to prepare for processing upper-layer service packets.
After you set the delay for transmitting Configure-Ack packets on a device, the local device will transmit a Configure-Ack packet to the remote device after the specified delay in milliseconds upon receiving a Configure-Request packet from the remote device.
In PPPoE and L2TP networks, set a higher delay when a large number of users exist and a lower delay when a small number of users exist.
In real network environments, configure the delay appropriately based on the actual conditions. If you cannot do that, the following issues might occur:
·     If the configured delay is too long, PPP negotiation might fail.
·     If the configured delay is too short, the local device might not have enough time for preparing for upper-layer service packets, resulting in packet drop.
3.     Enable SNMP notifications for the PPP module.
ppp ipcp configure-ack delay milliseconds
By default, the device responds with a Configure-Ack packet immediately after receiving a Configure-Request packet.
PPP link quality monitoring (LQM) monitors the quality (packet loss ratio and packet error ratio) of PPP links (including those in MP bundles) in real time.
If PPP LQM is not enabled, each end of a PPP link periodically sends keepalives to its peer. If PPP LQM is enabled, Link Quality Reports (LQRs) packets replace keepalives to monitor the link.
The system uses received LQR packets to measure the link quality. If two consecutive measured results are below the close-percentage, the system shuts down the link. Then the system measures the link quality at an interval that is ten times the LQR interval. If three consecutive measured results are higher than the PPP LQM resume-percentage, the system brings up the link.
A shut-down link must experience a minimum of 30 keepalive intervals before it can come up again. As a best practice, do not set the keepalive interval to a large value.
If you enable PPP LQM on both sides of a PPP link, make sure both sides have the same PPP LQM settings. Typically, there is no need to enable PPP LQM on both sides of a PPP link.
This feature does not affect existing users.
3.     Enable PPP LQM.
ppp lqm close-percentage close-percentage [ resume-percentage resume-percentage ]
By default, PPP LQM is disabled.
In the PPP link establishment process, the magic number is negotiated. After the negotiation, both the local end and the peer end save their magic numbers locally.
The local end sends Echo-Request packets carrying its own magic number. When magic number check is enabled on both the local end and the peer end, the peer end will compare its own magic number with the magic number in the received Echo-Request packets. If they are the same, the link status is considered as normal, and the peer end replies with Echo-Reply packets carrying its own magic number. The local end also compares its own magic number with the magic number carried in the received Echo-Reply packets.
A link is disconnected and LCP negotiation is restarted when either of the following events occurs on either end:
·     When fast reply for keepalive packets is enabled:
¡     The magic number check fails for five Echo-Request packets in total.
¡     The magic number check fails for five consecutive Echo-Reply packets.
·     When fast reply for keepalive packets is disabled, the magic number check fails for five consecutive Echo-Request or Echo-Reply packets.
Only the end with magic number check enabled can check the magic number in received Echo-Request or Echo-Reply packets.
3.     Enable magic number check for PPP.
ppp magic-number-check
By default, magic number check is disabled for PPP.
In PPP Link Establishment phase, the Maximum-Receive-Unit (MRU) value is negotiated in the LCP negotiation. When the MTUs of interfaces on the two end of a link are different, PPP uses the smaller MRU as the link MTU.
By default, the device does not perform MRU check if the MTU in a received PPP packet is larger than the negotiated MRU. With MRU check enabled, the device discards a received PPP packet if the MTU in the packet is larger than the negotiated MRU.
As a best practice to enhance system security, enable MRU check. Otherwise, a fake peer might attack the device by sending a large number of PPP packets with MTUs larger than the negotiated MRU.
In standard system operating mode, this feature is supported.
2.     Enable MRU check for PPP packets.
ppp mru-check enable
By default, MRU check for PPP packets is disabled.
The username format is userid@isp-name. A username is considered as empty when both the user ID and ISP domain name are empty. If the user ID is empty but the ISP domain name is not empty, the username is considered as non-empty.
By default, when PPP user online requests do not carry the usernames (the usernames are empty), the following rules apply:
·     For PPPoE users, the user MAC addresses in the requests are used as the usernames.
·     For L2TP users, the calling numbers in the requests are used as the usernames.
If the network environment needs strictly checking the username validity, you can configure this feature. With this feature configured, when the device receives online requests without usernames from PPPoE or L2TP users, the device does not use the user MAC addresses or calling numbers in the requests as usernames for AAA authentication, and the device directly returns authentication failure to users.
When the device uses the user MAC addresses or calling numbers in the requests as the usernames for AAA authentication, neither the contents nor the format of the information will be modified.
3.     Specify that PPP users cannot come online successfully if the online requests do not carry usernames on the VT interface.
ppp username check
By default, PPP users can come online successfully if the online requests do not carry usernames.
This feature blocks a PPP user for a period if the user fails authentication consecutively for the specified number of times within the detection period. This feature helps prevent illegal users from using the method of exhaustion to obtain the password, and reduces authentication packets sent to the authentication server. Packets from the blocked users will be discarded during the blocking period, and will be processed when the blocking period expires.
This feature uniquely identifies a blocked user by username and ISP domain name. (non-vBRAS-CPs.)
This feature identify users by username and domain name. Users that have the same username but belong to different domains are processes as different users.
2.     Enable PPP user blocking.
ppp authentication chasten auth-failure auth-period blocking-period
By default, a PPP user will be blocked for 300 seconds if the user fails authentication consecutively for six times within 60 seconds.
In addition to the per-username PPP user blocking, you can configure per-MAC PPP user blocking. This feature blocks PPP users using the same MAC address for a period if these users fail authentication consecutively for the specified number of times within the detection period. This feature helps prevent illegal users from using the method of exhaustion to obtain the password, and reduces authentication packets sent to the authentication server. Packets from the blocked users will be discarded during the blocking period, and will be processed when the blocking period expires. Packets from the blocked MAC address will be processed when the blocking period expires.
Compared with the per-username PPP user blocking, per-MAC PPP user blocking can effectively avoid issues that the username is automatically changed and one account establishes multiple sessions. Additionally, the two features can cooperate to perform attack prevention for PPP users in different perspectives.
This feature uniquely identifies a blocked user by its MAC address, inner VLAN, outer VLAN, and access interface. (non-vBRAS-CPs.)
For PPP users that use the same MAC address but are in different VLANs or use different access interfaces, the device will collect authentication failure statistics for them and block them separately.
2.     Enable per-MAC PPP user blocking.
ppp authentication chasten per-mac [ multi-sessions ] auth-failure auth-period blocking-period
By default, a user will be blocked for 300 seconds if the consecutive authentication failures of the user reach 6 times within 60 seconds.
When a MAC address can establish more than one PPP session, to enable per-MAC PPP user blocking, you must specify the multi-sessions keyword.
(In standalone mode.) The online PPP session count on the device refers to the total number of online PPP sessions on the device.
(In IRF mode.) The online PPP session count on the device refers to the total number of online PPP sessions on the whole IRF system.
You can use this command to set the upper alarm threshold and lower alarm threshold for the PPP session count. When the PPP session count exceeds the upper alarm threshold or drops below the lower threshold, an alarm is triggered automatically. Then, the administrator can promptly know the online user conditions of the network. Additionally, the administrator can use the display access-user command to view the total number of online PPP sessions.
The user session count alarm function counts only PPPoE user sessions that occupy session resources. Either a single-stack PPPoE user or dual-stack PPPoE user occupies one session resource.
Suppose the maximum number of online PPP sessions allowed is a, the upper alarm threshold is b, and the lower alarm threshold is c. The following rules apply:
·     When the online PPP session count exceeds a×b or drops below a×c, the corresponding alarm information is output.
·     When the online PPP session count returns between the upper alarm threshold and lower alarm threshold, the alarm clearing information is output.
In some special cases, the online PPP session count frequently changes in the critical range, which causes frequent output of alarm information and alarm clearing information. To avoid this problem, the system introduces a buffer area when the online PPP session count recovers from the upper or lower threshold. The buffer area size is 10% of the difference between the upper threshold and the lower threshold. Suppose the buffer area size is d. Then, d=a×(b-c)÷10. When the online PPP session count drops below a×b-d or exceeds a×c+d, the alarm clearing information is output.
For example, suppose a is 1000, b is 80%, and c is 20%. Then, d= a×(b-c)÷10=1000×(80%-20%)÷10=1000×60%÷10=600÷10=60.
When the online PPP session count exceeds the upper threshold a×b=1000×80%=800, the upper threshold alarm is output. When the online PPP session count restores to be smaller than a×b-d=800-60=740, the alarm clearing information is output.
When the online PPP session count drops below the lower threshold a×c=1000×20%=200, the lower threshold alarm is output. When the online PPP session count restores to be greater than a×c+d=200+60=260, the alarm clearing information is output.
The upper threshold alarm information output and the alarm clearing information output both contain logs and traps. For traps to be correctly sent to the NMS host, you must execute the snmp-agent trap enable user-warning-threshold command in addition to configuring the SNMP alarm feature correctly.
The upper alarm threshold must be greater than the lower alarm threshold.
2.     Configure the upper and lower online PPP session count alarm thresholds on the device.
ppp session-threshold { lower-limit lower-limit-value | upper-limit upper-limit-value }
By default, the upper online PPP session count alarm threshold is 100, and the lower online PPP session count alarm threshold is 0.
3.     Enable the device-level user count trap feature.
By default, the device-level user count trap feature is disabled.
With SNMP notifications enabled for the PPP module, traps will be generated when critical events of the specified type (for example, loops occur or are removed on both ends of a PPP link) occur to the PPP module. The generated traps are sent to the SNMP module of the device. You can specify how the traps are output through setting the trap output parameters in SNMP. For more information about traps, see SNMP configuration in Network Management and Monitoring Configuration Guide.
If you do not specify any keyword when enabling this feature, SNMP notifications are enabled for the PPP LCP, loop detection, and NCP modules.
2.     Enable SNMP notifications for the PPP module.
snmp-agent trap enable ppp [ lcp | loopback-detect | ncp ] *
By default, the SNMP notifications are disabled for the PPP module.
Display and maintenance commands for PPP
Display information about VT interfaces.
display interface [ virtual-template [ interface-number ] ] [ brief [ description | down ] ]
Display information about PPP access users.
display ppp access-user { interface interface-type interface-number | ip-address ipv4-address | mac-address mac-address | username username }
Display per-MAC blocking information about PPP users.
display ppp chasten per-mac { auth-failed | blocked } [ mac mac-address ] [ interface interface-type interface-number ]
Display statistics about PPP user blocking.
display ppp chasten statistics
Display blocking information about PPP users.
display ppp chasten user { auth-failed | blocked } [ username user-name ]
Display the packet loss ratio statistics for the PPP user detection packets.
In standalone mode:
display ppp keepalive packet-loss-ratio [ interface interface-type interface-number [ s-vlan svlan-id ] ] [ slot slot-number ]
In IRF mode:
display ppp keepalive packet-loss-ratio [ interface interface-type interface-number [ s-vlan svlan-id ] ] [ chassis chassis-number slot slot-number ]
Display PPP negotiation packet statistics.
In standalone mode:
display ppp packet statistics [ slot slot-number ]
In IRF mode:
display ppp packet statistics [ chassis chassis-number slot slot-number ]
Log off a PPP user.
reset ppp access-user { mac-address mac-address | ip-address ipv4-address | { interface interface-type interface-number | username user-name } * }
Unblock PPP users.
reset ppp chasten blocked-user [ username user-name ]
Unblock PPP users blocked by per-MAC PPP user blocking.
reset ppp chasten per-mac blocked [ mac mac-address [ s-vlan vlan-id [ c-vlan vlan-id ] ] ] [ interface interface-type interface-number ]
Clear the packet loss ratio statistics for the PPP user detection packets on the device.
In standalone mode:
reset ppp keepalive packet-loss-ratio [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset ppp keepalive packet-loss-ratio [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Clear PPP negotiation packet statistics.
In standalone mode:
reset ppp packet statistics [ slot slot-number ]
In IRF mode:
reset ppp packet statistics [ chassis chassis-number slot slot-number ]
PPP configuration examples
Example: Configuring one-way PAP authentication
As shown in Figure 8, configure Router A to authenticate Router B by using PAP, but Router B not to authenticate Router A.
Figure 8 Network diagram
1.     Configure Router A:
# Create a user account for Router B.
[RouterA] local-user userb class network
# Set a password for the user account.
[RouterA-luser-network-userb] password simple 123456TESTplat&!
# Set the service type of the user account to PPP.
[RouterA-luser-network-userb] service-type ppp
[RouterA-luser-network-userb] quit
# Enable PPP encapsulation on Serial 3/1/1:0. By default, an interface uses PPP encapsulation.
[RouterA] interface serial 3/1/1:0
[RouterA-Serial3/1/1:0] link-protocol ppp
# Set the authentication mode to PAP.
[RouterA-Serial3/1/1:0] ppp authentication-mode pap domain system
# Assign an IP address to Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] ip address 200.1.1.1 16
[RouterA-Serial3/1/1:0] quit
# Configure local authentication for the PPP users in the default ISP domain (system).
[RouterA] domain name system
[RouterA-isp-system] authentication ppp local
[RouterA-isp-system] quit
2.     Configure Router B:
<RouterB> system-view
[RouterB] interface serial 3/1/1:0
[RouterB-Serial3/1/1:0] link-protocol ppp
# On Serial 3/1/1:0, configure the PAP username and password sent from Router B to Router A when Router B is authenticated by Router A using PAP.
[RouterB-Serial3/1/1:0] ppp pap local-user userb password simple 123456TESTplat&!
# Assign an IP address to Serial 3/1/1:0 of Router B.
[RouterB-Serial3/1/1:0] ip address 200.1.1.2 16
[RouterB-Serial3/1/1:0] quit
# Use the display interface serial command to display information about Serial 3/1/1:0 of Router B.
[RouterB] display interface serial 3/1/1:0
Serial3/1/1:0
Current state: UP
Line protocol state: UP
Description: Serial3/1/1:0 Interface
Bandwidth: 64kbps
Hold timer: 10 seconds, retry times: 5
Internet address: 200.1.1.2/16 (primary)
Link layer protocol: PPP
LCP: opened, IPCP: opened
The output shows that:
·     The physical layer status and link layer status of the interface are both up.
·     The states of LCP and IPCP are both Opened, indicating that PPP negotiation has succeeded.
# Verify that Router A and Router B can ping each other.
[RouterB] ping 200.1.1.1
5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss Ping 200.1.1.1 (200.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 200.1.1.1: icmp_seq=0 ttl=128 time=3.197 ms
56 bytes from 200.1.1.1: icmp_seq=1 ttl=128 time=2.594 ms
56 bytes from 200.1.1.1: icmp_seq=2 ttl=128 time=2.739 ms
56 bytes from 200.1.1.1: icmp_seq=3 ttl=128 time=1.738 ms
56 bytes from 200.1.1.1: icmp_seq=4 ttl=128 time=1.744 ms
--- Ping statistics for 200.1.1.1 ---
round-trip min/avg/max/std-dev = 1.738/2.402/3.197/0.576 ms
Example: Configuring two-way PAP authentication
As shown in Figure 9, configure Router A and Router B to authenticate each other.
Figure 9 Network diagram
# Configure the PAP username and password sent from Router A to Router B when Router A is authenticated by Router B using PAP.
[RouterA-Serial3/1/1:0] ppp pap local-user usera password simple 123456TESTplat&!
# Assign an IP address to Serial 3/1/1:0 of Router A.
# Create a user account for Router A on Router B.
[RouterB] local-user usera class network
[RouterB-luser-network-usera] password simple 123456TESTplat&!
[RouterB-luser-network-usera] service-type ppp
[RouterB-luser-network-usera] quit
# Set the authentication mode to PAP on Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ppp authentication-mode pap domain system
[RouterB] domain name system
[RouterB-isp-system] authentication ppp local
[RouterB-isp-system] quit
Serial3/1/1:0
Current state: UP
Bandwidth: 64kbps
LCP opened, IPCP opened
# Verify that Router B can successfully ping Router A.
Example: Configuring one-way CHAP authentication
As shown in Figure 10, configure Router A to authenticate Router B by using CHAP.
Figure 10 Network diagram
Procedure (authenticator name is configured)
# On Serial 3/1/1:0, configure the username for Router A when Router A authenticates Router B.
[RouterA-Serial3/1/1:0] ppp chap user usera
# Set the authentication mode to CHAP on Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] ppp authentication-mode chap domain system
# Configure the username for Router B when Router B is authenticated.
[RouterB-Serial3/1/1:0] ppp chap user userb
Procedure (authenticator name is not configured)
# On Serial 3/1/1:0, configure the username of Router B when Router B is authenticated.
# Set the default CHAP password on Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ppp chap password simple 123456TESTplat&!
Serial3/1/1:0
Current state: UP
Bandwidth: 64kbps
Example: Specifying an IP address for the client on the server interface
As shown in Figure 11, configure Router A to allocate an IP address to Serial 3/1/1:0 of Router B through PPP negotiation. The IP address is specified on an interface of Router A.
Figure 11 Network diagram
# Configure an IP address to be assigned to the peer interface on Serial 3/1/1:0.
[RouterA-Serial3/1/1:0] remote address 200.1.1.10
# Configure an IP address for Serial 3/1/1:0.
2.     Enable IP address negotiation on Serial 3/1/1:0 of Router B.
[RouterB-Serial3/1/1:0] ip address ppp-negotiate
# Display summary information about Serial 3/1/1:0 on Router B.
[RouterB] display interface serial 3/1/1:0 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Ser3/1/1:0             UP   UP       200.1.1.10
The output shows Serial 3/1/1:0 obtains IP address 200.1.1.10 through PPP negotiation.
# Verify that Router B can ping Serial 3/1/1:0 of Router A.
Example: Specifying an IP address pool on the server interface
As shown in Figure 12, configure Router A to allocate an IP address from the IP address pool on an interface of Router A to Serial 3/1/1:0 of Router B through PPP negotiation.
Figure 12 Network diagram
# Enable DHCP.
[RouterA] dhcp enable
# Create IP address pool pool1, and specify the subnet for dynamic allocation and a gateway address in the address pool.
[RouterA] ip pool pool1
[RouterA-ip-pool-pool1] network 200.1.1.0 24
[RouterA-ip-pool-pool1] gateway-list 200.1.1.1
# Exclude IP address 200.1.1.1 from dynamic allocation in the address pool.
[RouterA-ip-pool-pool1] forbidden-ip 200.1.1.1
[RouterA-ip-pool-pool1] quit
# Configure Serial 3/1/1:0 to assign an IP address from IP address pool pool1 to the peer interface.
[RouterA-Serial3/1/1:0] remote address pool pool1
Ser3/1/1:0             UP   UP       200.1.1.2
The output shows that Serial 3/1/1:0 has obtained IP address 200.1.1.2 through PPP negotiation.
# Display binding information about assigned IP addresses on Router A.
[RouterA] display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
200.1.1.2        0030-3030-302e-3030-  Unlimited             Auto(C)
                 3030-2e30-3030-362d
The output shows that one IP address of the IP address pool has been assigned.
Example: Using the IP address pool associated with an ISP domain
As shown in Figure 13, configure Router A to allocate an IP address from the IP address pool associated with the ISP domain to Serial 3/1/1:0 of Router B through PPP negotiation.
Figure 13 Network diagram
# Enable DHCP.
# Create a local user for Router B.
# Set a password for the local user.
# Set the service type to PPP for the local user.
# Create ISP domain dm1 and associate the ISP domain with IP address pool pool1.
[RouterA] domain name dm1
[RouterA-isp-dm1] authorization-attribute ip-pool pool1
[RouterA-isp-dm1] quit
# Configure Serial 3/1/1:0 to authenticate the peer interface in ISP domain dm1 by using PAP.
[RouterA-Serial3/1/1:0] ppp authentication-mode pap domain dm1
# On Serial 3/1/1:0, configure the username and password for PAP authentication by Router A.
# Enable IP address negotiation on Serial 3/1/1:0.
[RouterB-Serial3/1/1:0] ping 200.1.1.1
                 Hardware address
                 3030-2e30-3030-362d
Configuring MP
About MP
Multilink PPP (MP) allows you to bind multiple PPP links into one MP bundle for increasing bandwidth. If a packet is larger than the minimum packet size for fragmentation, MP fragments the packet and distributes the fragments across multiple PPP links to the peer. The peer reassembles them into one packet and passes the packet to the network layer.
Benefit
In addition to increasing bandwidth, MP also provides link-layer load sharing, which can implement backup. MP fragmentation can reduce transmission delay, especially on low-speed links.
Interface type
MP is available on all physical or virtual interfaces with PPP encapsulation enabled, including serial and PPPoX (PPPoE) interfaces. In MP configuration, however, as a best practice, include only one type of interfaces in an MP bundle.
Restrictions and guidelines: MP configuration
MP supports binding only interfaces on the same interface card.
Only MIC-ET16L, MIC-CLP2L, and MIC-CLP4L subcards support MP binding.
MP tasks at a glance
To configure MP, perform the following tasks:
1.     Configuring MP through an MP-group interface
2.     (Optional.) Configuring short sequence number header format negotiation
3.     (Optional.) Configuring the MP endpoint descriptor
4.     (Optional.) Configuring an MP-group interface to check the endpoint option when a new physical link joins a bundle
5.     (Optional.) Enabling SNMP notifications for MP packet loss
About MP-group interfaces
MP-group interfaces are intended only for MP. On an MP-group interface, only one bundle is allowed, and links cannot be bundled according to the peer descriptor.
Tasks at a glance
To configure MP by using through an MP-group interface, perform the following tasks:
1.     Creating an MP-group interface
2.     Assigning a physical interface to the MP-group interface
3.     (Optional.) Configuring the polling feature on the MP-group interface
4.     (Optional.) Configuring MP parameters
5.     (Optional.) Restoring the default settings for the MP-group interface
2.     Create an MP-group interface and enter its view.
interface mp-group mp-number
The default setting is interface name Interface, for example, MP-group3/1/1 Interface.
mtu size
The default setting is 1500 bytes.
Follow these guidelines when you set the MTU on the following cards:
¡     For MIC subcards in these cards, the maximum MTU is 4980 for MP-group interfaces.
¡     The outgoing interface uses the MTU of 1280 bytes if its MTU is smaller than 1280 bytes and the incoming interface is on the specified cards. As a best practice, set the MTU of the outgoing interface to a value greater than 1280 bytes when the device is installed with the cards mentioned above.
Table 8 Card information
Card category
Cards
CSPC
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E
CSPEX
‌CSPEX-1104-E, CSPEX-1204
5.     (Optional.) Set the expected bandwidth of the interface.
6.     (Optional.) Bring up the interface.
By default, an interface is up.
3.     Assign the interface to a specified MP-group interface, and enable MP for the interface.
ppp mp mp-group mp-number
By default, an interface is enabled with PPP.
MP-group interfaces use the polling feature to check link state.
A MP-group interface sends keepalives at keepalive intervals to detect the availability of the peer. If the interface fails to receive keepalives when the keepalive retry limit is reached, it tears down the link and reports a link layer down event.
The keepalive interval of 0 disables sending of keepalives.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalives are delayed because a large packet is being transmitted on the link.
2.     Enter MP-group interface view.
timer-hold seconds
The default setting is 10 seconds.
The default setting is 5.
2.     Enter MP-group interface or dialer interface view.
3.     (Optional.) Set the maximum number of links in an MP bundle.
ppp mp max-bind max-bind-num
The default is 31.
The configuration takes effect after you execute the shutdown and undo shutdown command on the interface.
4.     (Optional.) Set the minimum size of MP fragments.
ppp mp min-fragment size
The default setting is 128 bytes.
5.     (Optional.) Configure the timer for MP to wait for the expected fragment.
ppp mp timer lost-fragment seconds
By default, the timer is 30 seconds.
6.     (Optional.) Disable MP fragmentation.
ppp mp fragment disable
By default, MP fragmentation is enabled.
7.     (Optional.) Enable the strict load sharing mode.
ppp mp load-sharing mode strict-round-robin
By default, an MP-group interface uses the smart load sharing mode.
default
By default, an MP bundle receives and transmits fragments with long sequence numbers.
Configure this feature on the local end or peer that receives fragments with short sequence numbers.
·     To receive fragments with short sequence numbers, the local end should request the peer to transmit short sequence numbers during LCP negotiation. After the negotiation succeeds, the peer transmits fragments with short sequence numbers.
·     To transmit fragments with short sequence numbers, the local end should ask the peer to send a request for receiving short sequence numbers during LCP negotiation. After the negotiation succeeds, the local end transmits fragments with short sequence numbers.
The sequence number format (long or short) of an MP bundle depends on the configuration of the first channel joining the MP bundle.
To negotiate the use of short sequence numbers on an MP bundle, configure this feature on all its channels.
Configuring this feature will cause PPP re-negotiation.
1.     Enter system view
3.     Trigger MP short sequence number header negotiation, specifying that the interface receive fragments with short sequence numbers after the negotiation succeeds.
ppp mp short-sequence
By default, long sequence number header format negotiation is performed.
When MP is configured by using a VT interface, physical links are bundled based on the endpoint option value, and physical links receiving the same endpoint option value from the peer can join the same bundle link. To change the endpoint option value sent by a physical interface, use this command to modify it.
When MP is configured by using an MP-group interface, physical links are not bundled based on the endpoint option value by default. After the ppp mp endpoint check command is executed, physical links are bundled based on the endpoint option value, allowing physical links receiving the same endpoint option value from the peer to join the same bundle link. To change the endpoint option value sent by a physical interface, use this command to modify it.
If the endpoint descriptor exceeds 20 bytes, the first 20 bytes are taken as the endpoint descriptor.
3.     Configure the MP endpoint descriptor.
ppp mp endpoint endpoint
By default:
¡     When you configure MP by using a VT interface:
-     If you configure MP by directly associating a physical interface with a VT interface, the interface sends an endpoint option value of an 8-bit random number-VT interface number during LCP negotiation.
-     If you configure MP by associating the username with the a VT interface, the interface sends an endpoint option value of the device name during LCP negotiation.
¡     When you configure MP by using an MP-group interface, the interface sends an endpoint option value of an 8-digit random number-MP-group interface number during LCP negotiation.
By default, different physical interfaces joining the same MP-group can join the same MP bundle link, even if they receive different endpoint option values from the peer. This mechanism ensures that the endpoint option values do not actually affect the bundling result of physical links on an MP-group interface.
To modify the behavior related to the endpoint option on the device, configure the MP-group interface to check the endpoint option when new physical links join the bundle link. This enables physical links to join the bundle link based on the endpoint option values.
After the ppp mp endpoint check command is executed on an MP-group interface, when a non-first physical interface joins, the endpoint option value it receives from the peer must match that received by the first physical interface. This match is necessary for the non-first physical interface's link to join the corresponding bundle link in the MP-group interface. This mechanism ensures that all physical links in a bundle link receive the same endpoint option value, achieving endpoint option consistency in the bundle link.
When the first physical interface joins the MP-group interface, it can join the bundle link without endpoint option value check.
If physical interfaces are already added to an MP-group interface, the ppp mp endpoint check command will take effect only after all physical interfaces have exited the MP-group interface. The check mechanism can only take effect when no physical interfaces exist in the MP-group interface.
3.     Configure the MP-group interface to check the endpoint option when a new physical link joins a bundle.
By default, an MP-group interface does not check the endpoint option when a new physical link joins a bundle.
With SNMP notifications enabled for MP packet loss, when the lost packets of all MP bundle links on the device meet the alarm threshold conditions, traps are generated. The generated traps are sent to the SNMP module of the device. You can specify how the traps are output through setting the trap output parameters in SNMP. For more information about traps, see SNMP configuration in Network Management and Monitoring Configuration Guide.
The alarm triggering threshold is calculated by using the xE-y formula, where E is 10.
For this feature, packet loss occurs when a packet received on the local end is dropped because the packet is invalid (for example, the packet fails to be reassembled because a fragment is dropped).
After you enable SNMP notifications for MP packet loss, the following rules apply within a statistics polling interval (configured by using the flow-interval command in system view):
·     When the packet loss ratio (total number of lost packets/total number of received packets) of all MP bundle links on the device is equal to or greater than the packet loss ratio alarm triggering threshold, traps are generated.
·     When the packet loss ratio (total number of lost packets/total number of received packets) of all MP bundle links on the device is equal to or less than the packet loss ratio alarm clearing threshold, alarm clearing traps are generated.
Both the snmp-agent trap enable mp command and the snmp-agent trap enable mp loss-packet-alarm command can enable SNMP notifications for MP packet loss.
Make sure the packet loss ratio alarm triggering threshold is greater than the packet loss ratio alarm clearing threshold.
2.     Enable SNMP notifications for MP packet loss.
snmp-agent trap enable mp [ loss-packet-alarm ]
By default, the SNMP notifications are disabled for MP packet loss.
3.     Set the MP packet loss ratio alarm thresholds.
ppp mp loss-packet-threshold alarm coefficient-value exponent-value resume resume-coefficient-value resume-exponent-value
By default, the packet loss ratio alarm triggering threshold is 3*10-5, and the packet loss ratio alarm clearing threshold is 1*10-5.
Display and maintenance commands for MP
Display information about one or all MP-group interfaces.
display interface [ mp-group [ interface-number ] ] [ brief [ description | down ] ]
Display MP information.
display ppp mp [ interface interface-type interface-number ]
Clear the statistics for MP-group interfaces.
reset counters interface [ mp-group [ interface-number ] ]
MP configuration examples
Example: Configuring an MP-group interface
As shown in Figure 14, to enable MP for Serial 3/1/1:0 and Serial3/1/2:0, configure an MP-group interface.
Figure 14 Network diagram
# Create an MP-group interface, and configure an IP address for it.
[RouterA] interface mp-group 3/1/1
[RouterA-MP-group3/1/1] ip address 1.1.1.1 24
# Configure interface Serial 3/1/1:0.
[RouterA-MP-group3/1/1] quit
[RouterA-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/1:0] shutdown
[RouterA-Serial3/1/1:0] undo shutdown
# Configure interface Serial3/1/2:0.
[RouterA] interface serial 3/1/2:0
[RouterA-Serial3/1/2:0] link-protocol ppp
[RouterA-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/2:0] shutdown
[RouterA-Serial3/1/2:0] undo shutdown
[RouterA-Serial3/1/2:0] quit
[RouterB] interface mp-group 3/1/1
[RouterB-MP-group3/1/1] ip address 1.1.1.2 24
[RouterB-MP-group3/1/1] quit
[RouterB-Serial3/1/1:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/1:0] shutdown
[RouterB-Serial3/1/1:0] undo shutdown
[RouterB] interface serial 3/1/2:0
[RouterB-Serial3/1/2:0] link-protocol ppp
[RouterB-Serial3/1/2:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/2:0] shutdown
[RouterB-Serial3/1/2:0] undo shutdown
[RouterB-Serial3/1/2:0] quit
# Display MP information on Router A.
[RouterA] display ppp mp
Template: MP-group3/1/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group3/1/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group3/1/1
Sequence format: short (rcv)/long (sent)
Bundle Up Time: 2019/11/04  09:03:16:612
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcvd)/0 (sent)
Active member channels: 2 members
      Serial3/1/1:0               Up-Time:2019/11/04  09:03:16:613
      Serial3/1/2:0               Up-Time:2019/11/04  09:03:42:945
# Display information about interface MP-group 3/1/1 on Router A.
[RouterA] display interface mp-group 3/1/1
MP-group3/1/1
Current state: UP
Description: MP-group3/1/1 Interface
Bandwidth: 2048kbps
Internet address: 1.1.1.1/24 (primary)
LCP: opened, MP: opened, IPCP: opened
Physical: MP, baudrate: 2048000 bps
Last link flapping: Never
Input: 2 packets, 80 bytes, 0 drops
Output: 2 packets, 24 bytes, 0 drops
# Ping Router B from Router A.
[RouterA] ping 1.1.1.2
Ping 1.1.1.2 (1.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 1.1.1.2: icmp_seq=0 ttl=255 time=4.000 ms
56 bytes from 1.1.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 1.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 1.1.1.2: icmp_seq=3 ttl=255 time=7.000 ms
56 bytes from 1.1.1.2: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 1.1.1.2 ---
round-trip min/avg/max/std-dev = 0.000/2.600/7.000/2.577 ms
