- H3C Wi-Fi7 Indoor Access Points Installation Guide-5W109
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
- 08-Appendix F RED Declaration of Conformity
| 03-Appendix A AP views and technical specifications | 1.63 MB |
3 Appendix A AP views and technical specifications
WA7130
AP views
Figure3-1 WA7130
Ports
The AP provides the following ports:
· One 2.5GE/PoE+ port.
· One CONSOLE port.
· One power port.
The AP also has a reset button and a security slot. The security slot is 7 × 3 mm (0.28 × 0.12 in) in size.
Figure3-2 Ports on the WA7130 (1)
(1) Power port |
(2) 2.5GE/PoE+ port |
(3) Console port |
(4) Security slot |
Figure3-3 Ports on the WA7130 AP (2)
(1) Reset button |
Technical specifications
Table3-1 Technical specifications
Item |
Dimensions (H × W × D) (without the mounting bracket) |
46.2 × 240 × 240 mm (1.82 × 9.45 × 9.45 in) |
Weight |
0.8 kg (1.76 lb) |
Power consumption |
Support for local DC power supply and PoE power supply: · Local power supply:≤21.5W · PoE power reception compliant with 802.3at:≤21.5W |
Antenna |
Built-in antenna |
Standard compliance |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3at |
Powering option |
IEEE802.3at powering standard-compliant: · Power adapter · PoE |
Operating temperature |
-10°C to 50°C (14°F to 122°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
5%RH to 95%RH, non-condensing |
Storage humidity |
Operating altitude |
–60 m to +5000 m (–196.85 ft to +16404.20 ft) |
Console port |
Control port, used for debugging by the maintenance personnel |
2.5GE/PoE+ port |
100M/1000M/2.5GEthernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time. When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and smartrate-ethernet 1 for configuration on the AC |
Power port (54VDC) |
Used for receiving power from a local power source. |
Reset button |
For more information, see "Appendix B LEDs and buttons." |
WA7220-HI
AP views
Figure3-4 WA7220-HI
Ports
· One 2.5GE2/PSE port.
· One 2.5GE1/PoE+ port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-5 Ports on the WA7220-HI AP (1)
(1) Power port |
(2) 2.5GE1/PoE+ port |
(3) 2.5GE2/PSE port |
(4) Console port |
(5) USB port |
(6) Security slot |
Figure3-6 Ports on theWA7220-HI AP (2)
(1) Reset button |
Table3-2 Technical specifications
Item |
40 × 220 × 220 mm (1.57 × 8.66 × 8.66 in) |
Weight |
0.67 kg (1.48 lb) |
Power consumption |
Support for local DC power supply and PoE power supply: · Local power supply: ¡ ≤ 33.9 W (including PoE_OUT/USB) ¡ ≤ 16.4 W (excluding PoE_OUT/USB) · PoE power reception compliant with 802.3at: ¡ ≤ 26.1 W (PoE_OUT port supplying power, radios in 1×1 MIMO mode, and excluding USB) ¡ ≤ 18.9 W (PoE_OUT port not supplying power and including USB) · PoE power reception compliant with 802.3af: ≤ 13.6 W (PoE_OUT port not supplying power, radios in 1×1 MIMO mode, and including USB) |
Antenna |
Built-in antenna |
· IEEE802.11a/b/g/n/ac/ax/be · 802.3af/at |
Powering option |
IEEE802.3af/at powering standard-compliant: · Power adapter · PoE(802.3at) · PoE(802.3af) |
Storage humidity |
Console port |
2.5GE/PoE+ port |
2.5GE2/PSE port |
100/1000/2500M Ethernet copper port,that can act as the device downlink port to supply power for a standard PD. When the AP operates in fit AP mode, the port is represented by interface number Smartrate-Ethernet1/0/2 in the MAP file and gigabitethernet 2 for configuration on the AC |
USB port |
USB-compliant USB2.0 port. NOTE: By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view. |
Reset button |
WA7232
AP views
Figure3-7 WA7232
Ports
· One 10GE/P+SFP port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-8 Ports on the WA7232 AP (1)
(1) Power port |
(2) 10GE/P+SFP port |
(3) 2.5GE/PoE+ port |
(4) Console port |
(5) Security slot |
Figure3-9 Ports on theWA7232 AP (2)
(1) USB port |
(2) Reset button |
Table3-3 Technical specifications
Item |
Weight |
0.85 kg (1.87 lb) |
Power consumption |
Support for local DC power supply and PoE power supply: · Local power supply: ¡ ≤25.4W (including USB) ¡ ≤22.9W (excluding USB) · PoE power reception compliant with 802.3at: ¡ ≤25.4W (including USB) ¡ ≤22.9W (excluding USB) · Hybrid copper-fiber port power reception compliant with 802.3at: ¡ ≤25.4W (including USB) ¡ ≤22.9W (excluding USB) |
Antenna |
Built-in antenna |
Powering option |
IEEE802.3at powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
Storage humidity |
Console port |
10GE/P+SFP port |
100M/1000M/2.5G/5G/10G photoelectric hybrid port When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/2 in the MAP file and Ten-GigabitEthernet 2 for configuration on the AC. |
2.5GE/PoE+ port |
USB port |
Reset button |
WA7320
AP views
Figure3-10 WA7320
Ports
· One 5GE/P+SFP port
· One Power port
· One GE port.
· One CONSOLE port.
· One USB port.
Figure3-11 Ports on the WA7320 AP (1)
(1) 5GE/P+SFPport |
(2) Power port |
(4) GE port |
(5) Console port |
Figure3-12 Ports on the WA7320 AP (2)
(1) Security slot |
(2) USB port |
(3) Reset button |
Table3-4 Technical specifications
Item |
35 × 205 × 205 mm (1.38 × 8.07 × 8.07 in) |
Weight |
0.8 kg (1.76 lb) |
Power consumption |
18.5 W |
Antenna |
Built-in antenna |
Powering option |
Storage humidity |
Console port |
5GE2/P+SFP port |
1000M/2.5G/5G/10G photoelectric hybrid port When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/2 in the MAP file and smartrate-ethernet 2 for configuration on the AC |
2.5GE/PoE+ port |
100M/1000M/2.5G/5G/10G Ethernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time. When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and smartrate-ethernet 1 for configuration on the AC. |
GE port |
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
USB port |
USB2.0-compliant USB port. NOTE: By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view. |
Reset button |
WA7320i
AP views
Figure3-13 WA7320i
Ports
· One GE/PSE port.
· One 10GE/PoE+ port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-14 Ports on the WA7320i AP (1)
(1) Console port |
(2) GE/PSE port |
(3) 10GE1/PoE+ port |
(4) 10GE2/P+SFP port |
(5) Power port |
Figure3-15 Ports on the WA7320i AP (2)
(1) USB port |
(2) Reset button |
(3) Security slot |
Table3-5 Technical specifications
Item |
Weight |
0.8 kg (1.76 lb) |
Power consumption |
39 W |
Antenna |
Built-in antenna |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3at/af |
Powering option |
IEEE802.3at/af powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
0°C to 50°C (32°F to 122°F) |
Storage humidity |
Console port |
10GE2/P+SFP port |
10GE1/PoE+ port |
100M/1000M/2.5G/5G/10G Ethernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time. When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and Ten-GigabitEthernet 1 for configuration on the AC. |
GE/PSE port |
USB port |
Reset button |
WA7330i
AP views
Figure3-16 WA7330i
Ports
· One 2.5GE/PSE port.
· One 10GE/PoE++ port.
· One 10GE/P++SFP port.
· One console port.
· One power port.
· One USB port.
Figure3-17 Ports on the WA7330i AP (1)
(1) Power port |
(2) 10GE/P++SFP port |
(3) 10GE/PoE++ port |
(4) 2.5GE/PSE port |
(5) Console port |
Figure3-18 Ports on the WA7330i AP (2)
(1) Reset button |
(2) USB port |
(3) Security slot |
Table3-6 Technical specifications
Item |
45 × 210× 210 mm (1.77 × 8.27 × 8.27in) |
Weight |
1 kg (2.2 lb) |
Power consumption |
42.12 W |
Antenna |
Built-in antenna |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3bt/at |
Powering option |
IEEE802.3bt/at powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
Storage humidity |
Console port |
10GE/P++SFP port |
100M/1000M/2.5G/5G/10G photoelectric hybrid port,which can also operate as a 10G copper port. When the AP operates in fit AP mode, the port is represented by interface number XGE1/0/1 in the MAP file and ten-gigabitEthernet 1 for configuration on the AC. NOTE: The 10GE/P++SFP fiber port and the 10GE/PoE++ copper port cannot be used simultaneously. |
10GE/PoE++ port |
100M/1000M/2.5G/5G/10G Ethernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time. When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and ten-gigabitEthernet 1 for configuration on the AC. |
2.5GE/PSE port |
100M/1000M/2.5G Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number Smartrate-Ethernet1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
USB port |
Reset button |
WA7338-HI
AP views
Figure3-19 WA7338-HI
Ports
· One GE/PSE port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-20 Ports on the WA7338-HI AP (1)
(1) Reset button |
(2) Console port |
(3) GE/PSE port |
(4) 10GE1/PoE++ port |
(5) 10GE2/P++SFP port |
(6) Power port |
(7) Security slot |
Figure3-21 Ports on the WA7338-HI AP (2)
(1) USB port |
Table3-7 Technical specifications
Item |
45 × 225 × 225 mm (1.77 × 8.86 × 8.86 in) |
Weight |
1.43 kg (3.15 lb) |
Power consumption |
≤ 41.8 W |
Antenna |
Built-in antenna |
Powering option |
Storage humidity |
Console port |
10GE2/P++SFP port |
10GE1/PoE++ port |
GE/PSE port |
USB port |
Reset button |
WA7539
AP views
Figure3-22 WA7539
Ports
· One GE/PSE port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-23 Ports on the WA7539 AP
(1) Power port |
(2) 10GE1/PoE++ port |
(3) GE/PSE port |
(4) USB port |
(6) Console port |
(7) Reset button |
(8) Security slot |
Table3-8 Technical specifications
Item |
40 × 225 × 225 mm (1.57 × 8.86 × 8.86 in) |
Weight |
1.5 kg (3.31 lb) |
Power consumption |
≤ 54 W |
Antenna |
Built-in antenna |
· IEEE802.11a/b/g/n/ac/ax/be · IEEE802.3at/bt |
Powering option |
IEEE802.3at/bt powering standard-compliant: · Power adapter · PoE · PoE optical transceiver module |
Storage humidity |
Console port |
10GE2/P++SFP port |
1000M/2.5G/5G/10G photoelectric hybrid port |
10GE1/PoE++ port |
GE/PSE port |
USB port |
USB-compliant USB port. NOTE: By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view. |
Reset button |
WA7638
AP views
Figure3-24 WA7638
Ports
· One GE/PSE port.
· One GE/PoE++ port.
· One CONSOLE port.
· One power port.
· One USB port.
Figure3-25 Ports on the WA7638 AP
(1) Power port |
(3) GE1/PoE++ port |
(4) GE2/PSE port |
(6) USB port |
(7) Console port |
(8) Reset button |
(9) Security slot |
Table3-9 Technical specifications
Item |
48 × 265 × 265 mm (1.89 × 10.43 × 10.43 in) |
Weight |
1.9 kg (4.19 lb) |
Power consumption in standby state |
57W |
Antenna |
Built-in antenna |
Powering option |
Storage humidity |
Console port |
10GE2/P++SFP |
GE1/PoE++ |
100M/1000M Ethernet copper port, which can act as the uplink interface to connect the device to Internet or the MAN or act as the standard PoE interface. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC. |
10GE1/PoE++ |
GE2/PSE |
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/2 in the MAP file and GigabitEthernet 2 for configuration on the AC. |
USB port |
Reset button |
