H3C S6526XE-HI[EI] Switch Series Hardware Information and Specifications-6W101
HomeSupportProduct LiteratureHardware Information & SpecificationsH3C S6526XE-HI[EI] Switch Series Hardware Information and Specifications-6W101
01-Hardware Information and Specifications
01-Hardware Information and Specifications 1.89 MB
1 Product models and technical specifications· 1-3
Product models· 1-3
Technical specifications· 1-3
S6526XE-HI switch series· 1-3
S6526XE-EI switch series· 1-6
2 Chassis views· 2-9
S6526XE-HI switch series· 2-9
S6526XE-32X6CC-HI 2-9
S6526XE-48X6CC-HI 2-10
S6526XE-EI switch series· 2-11
S6526XE-32X4CC-EI 2-11
S6526XE-48X4CC-EI 2-12
3 Removable components and compatibility matrixes· 3-14
4 Removable power supplies· 4-15
450W power supplies (PSR450-12A and PSR450-12A1) 4-15
450W DC power supply (PSR450-12D) 4-16
5 Removable fan trays· 5-18
Removable fan trays available for the S6526XE-HI switch series· 5-18
LSPM1FANSA-SN· 5-18
LSPM1FANSB-SN· 5-19
Removable fan trays available for the S6526XE-EI switch series· 5-20
FAN-40B-1-A· 5-20
FAN-40F-1-A· 5-21
6 Expansion cards· 6-22
LSWM2SP8P/LSWM2SP8PM·· 6-22
LSWM2QP2P· 6-23
LSWM2ZQP2P· 6-23
LSWM2ZSP8P· 6-24
LSPM6FWD·· 6-25
LSWM2XMGT4PM·· 6-26
7 Ports and LEDs· 7-27
Ports· 7-27
Console port 7-27
Management Ethernet port 7-28
USB port 7-28
10G/5G/2.5G/1G autosensing Ethernet port 7-28
SFP+ port 7-29
SFP28 port 7-34
QSFP+ port 7-36
QSFP28 ports· 7-37
Ports on an LSPM6FWD firewall module· 7-39
LEDs· 7-40
System status LED·· 7-40
Power status LED·· 7-40
Management Ethernet port LED·· 7-41
SFP+ port LED·· 7-41
SFP28 port LED·· 7-41
QSFP+ port LED·· 7-41
QSFP28 port LED·· 7-42
Expansion card status LED·· 7-42
Fan tray status LED on a fan tray· 7-42
LEDs on an LSPM6FWD firewall module· 7-43
10G/5G/2.5G/1000BASE-T LEDs on an LSWM2XMGT4PM·· 7-43
8 Cooling system·· 8-44
Unless otherwise stated, interface modules and interface cards are used interchangeably in this document.
Product models
Table1-1 Switch series and models
Switch series
Model
Product code (PID)
S6526XE-32X6CC-HI
LS-6526XE-32X6CC-HI
S6526XE-48X6CC-HI
LS-6526XE-48X6CC-HI
S6526XE-32X4CC-EI
LS-6526XE-32X4CC-EI
S6526XE-48X4CC-EI
LS-6526XE-48X4CC-EI
·     To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/.
·     For information about product and software compatibility, see the release notes.
Table1-2 Technical specifications
Item
S6526XE-32X6CC-HI
S6526XE-48X6CC-HI
Physical specifications
Dimensions (H × W × D)
44 × 440 × 400 mm (1.73 × 17.32 × 15.75 in)
Dimensions (H × W × D, with package materials)
150 × 556 × 528 mm (5.91 × 21.89 × 20.79 in)
Weight (fully configured with power supplies, fan trays, and expansion cards)
≤ 7.9 kg (17.42 lb)
≤ 8.1 kg (17.86 lb)
Memory (RAM)
4 GB
Flash
4 GB
Port types and quantity
Console port
·     1 × Type-C USB console port
·     1 × serial console port
Only the Type-C USB console port is available when you connect both ports.
USB port
1
1
SFP+ port
32
48
QSFP28 port
6
IRF physical port
The following ports support IRF connection:
·     SFP+ ports and QSFP28 ports on the front panel
·     Ports that can be provided by the expansion card on the rear panel:
¡     SFP+ ports
¡     SFP28 ports
¡     QSFP+ ports
¡     QSFP28 ports
Fan tray, power supply, and expansion card slots
Expansion slot
1
Power supply slot
2
Fan tray slot
4
Power supply specifications
Power input
AC input, DC input
Note:
For DC input, you can use a –48 VDC power source in the equipment room or an RPS (H3C RPS1600-A).
Power specifications
See "Removable power supplies"
Power consumption
Power consumption (static)
Data collection standard: no load
Single AC input: 89 W
Dual AC inputs: 90 W
Single DC input: 86 W
Dual DC inputs: 98 W
Single AC input: 85 W
Dual AC inputs: 89 W
Single DC input: 83 W
Dual DC inputs: 96 W
Power consumption (typical)
Data collection standard: fully configured with copper cables or network cables, at 30% load
Single AC input: 117 W
Dual AC inputs: 125 W
Single DC input: 123 W
Dual DC inputs: 126 W
Single AC input: 118 W
Dual AC inputs: 129 W
Single DC input: 124 W
Dual DC inputs: 131 W
Power consumption (full load)
Data collection standard: fully configured with transceiver modules or network cables, at 100% load
Single AC input: 237 W
Dual AC inputs: 242 W
Single DC input: 249 W
Dual DC inputs: 256 W
Single AC input: 251 W
Dual AC inputs: 255 W
Single DC input: 262 W
Dual DC inputs: 265 W
Thermal consumption
Thermal consumption (static)
Single AC input: 304 BTU/h
Dual AC inputs: 307 BTU/h
Single DC input: 294 BTU/h
Dual DC inputs: 335 BTU/h
Single AC input: 290 BTU/h
Dual AC inputs: 304 BTU/h
Single DC input: 284 BTU/h
Dual DC inputs: 328 BTU/h
Thermal consumption (typical)
Single AC input: 399 BTU/h
Dual AC inputs: 427 BTU/h
Single DC input: 420 BTU/h
Dual DC inputs: 430 BTU/h
Single AC input: 403 BTU/h
Dual AC inputs: 440 BTU/h
Single DC input: 423 BTU/h
Dual DC inputs: 447 BTU/h
Thermal consumption (full load)
Single AC input: 809 BTU/h
Dual AC inputs: 826 BTU/h
Single DC input: 850 BTU/h
Dual DC inputs: 872 BTU/h
Single AC input: 856 BTU/h
Dual AC inputs: 870 BTU/h
Single DC input: 894 BTU/h
Dual DC inputs: 904 BTU/h
Heat dissipation
Heat dissipation method
Air cooling
Ventilation aisle
Front-to-rear or rear-to-front airflow, determined by the selected fan tray model
Reliability and availability
Power supply redundancy
1+1
Fan tray redundancy
You must fully configure the switch with fan trays.
Hot swapping
Power supplies and fan trays support hot swapping.
Expansion cards (except for the LSWM2XMGT4PM and LSWM2SP8PM) support hot swapping. Do not hot swap an expansion card when the switch is starting up.
Mean Time Between Failure (MTBF) (year)
116.18
110.03
Mean Time To Repair (MTTR) (hour)
1
1
Availability
99.99990%
99.99990%
Environment specifications
Sound pressure level at 27°C (80.6°F)
53.0 dBA
53.0 dBA
Altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
Operating temperature
–5°C to +45°C (23°F to 113°F)
Note:
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft).
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Relative humidity
5% RH to 95% RH, noncondensing
Compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental and eco-friendly standards
Table1-3 Technical specifications
Item
S6526XE-32X4CC-EI
S6526XE-48X4CC-EI
≤ 8.1 kg (17.86 lb)
≤ 8.2 kg (18.08 lb)
Memory (RAM)
4 GB
Flash
4 GB
Console port
USB port
1
1
SFP+ port
32
48
QSFP28 port
4
IRF physical port
¡     SFP+ ports
¡     SFP28 ports
¡     QSFP+ ports
¡     QSFP28 ports
Expansion slot
2
Power supply slot
2
Fan tray slot
2
Power input
AC input, DC input
Note:
Power consumption
Single AC input: 75 W
Dual AC inputs: 83 W
Single DC input: 74 W
Dual DC inputs: 82 W
Single AC input: 72 W
Dual AC inputs: 82 W
Single DC input: 72 W
Dual DC inputs: 81 W
Single AC input: 91 W
Dual AC inputs: 98 W
Single DC input: 94 W
Dual DC inputs: 101 W
Single AC input: 100 W
Dual AC inputs: 108 W
Single DC input: 103 W
Dual DC inputs: 112 W
Single AC input: 239 W
Dual AC inputs: 243 W
Dual DC inputs: 250 W
Single AC input: 275 W
Dual AC inputs: 277 W
Single DC input: 279 W
Dual DC inputs: 283 W
Thermal consumption
Single AC input: 256 TU/h
Dual AC inputs: 284 TU/h
Single DC input: 253 TU/h
Dual DC inputs: 280 TU/h
Single AC input: 246 TU/h
Dual AC inputs: 280 TU/h
Single DC input: 246 TU/h
Dual DC inputs: 277 TU/h
Single AC input: 316 TU/h
Dual AC inputs: 311 TU/h
Single DC input: 321 TU/h
Dual DC inputs: 345 TU/h
Single AC input: 341 TU/h
Dual AC inputs: 367 TU/h
Single DC input: 352 TU/h
Dual DC inputs: 382 TU/h
Single AC input: 815 TU/h
Dual AC inputs: 829 TU/h
Single DC input: 850 TU/h
Dual DC inputs: 853 TU/h
Single AC input: 938 TU/h
Dual AC inputs: 945 TU/h
Single DC input: 952 TU/h
Dual DC inputs: 966 TU/h
Heat dissipation
Air cooling
Ventilation aisle
1+1
Fan tray redundancy
Hot swapping
41.02
39.98
1
1
Availability
99.99971%
99.99972%
48.5 dBA
Altitude
Note:
Storage temperature
Relative humidity
Compliance
Product compliance
·     Safety standards
·     EMC standards
2 Chassis views
S6526XE-32X6CC-HI
Figure2-1 Front panel
(1) SFP+ port
(2) SFP+ port LED
(3) QSFP28 port
(4) QSFP28 port LED
(5) Type-C USB console port
(6) System status LED (SYS)
(7) Expansion card status LED (SLOT)
The Type-C USB console port is used for device management only, and cannot be used for storage.
Figure2-2 Rear panel
(1) Management Ethernet port LED (ACT)
(2) Management Ethernet port (MGMT)
(3) Management Ethernet port LED (LINK)
(4) Reset button (RESET)
(5) Serial console port
(6) Expansion card
(7) Fan tray 1
(8) Fan tray 2
(9) Fan tray 3
(10) Fan tray 4
(11) Power supply 1
(12) Power supply 2
(13) USB port
(14) Serial label pull tab
(15) Grounding screw
The S6526XE-32X6CC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two PSR450-12A1 AC power supplies are installed in the power supply slots.
The S6526XE-32X6CC-HI switch came with four fan tray slots empty. You must install four fan trays of the same model for the switch. In Figure2-2, four LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6526XE-32X6CC-HI switch came with the expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-2, an LSWM2SP8P interface card is installed in the expansion slot.
The S6526XE-32X6CC-HI switch supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
The S6526XE-32X6CC-HI switch has a reset button on the rear panel. The system LED flashes when the reset button is being pressed. To reboot the switch, press and hold the button for 1 to 5 seconds. To restore the switch to the factory defaults and reboot it, press and hold the reset button for more than 5 seconds.
S6526XE-48X6CC-HI
Figure2-3 Front panel
(1) SFP+ port
(2) SFP+ port LED
(3) QSFP28 port
(4) QSFP28 port LED
Figure2-4 Rear panel
(6) Expansion card
(7) Fan tray 1
(8) Fan tray 2
(9) Fan tray 3
(10) Fan tray 4
(11) Power supply 1
(12) Power supply 2
(13) USB port
The S6526XE-48X6CC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR450-12A1 AC power supplies are installed in the power supply slots.
The S6526XE-48X6CC-HI switch came with four fan tray slots empty. You must install four fan trays of the same model for the switch. In Figure2-4, four LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S6526XE-48X6CC-HI switch came with the expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-4, an LSWM2SP8P interface card is installed in the expansion slot.
The S6526XE-48X6CC-HI switch supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
The S6526XE-48X6CC-HI switch has a reset button on the rear panel. The system LED flashes when the reset button is being pressed. To reboot the switch, press and hold the button for 1 to 5 seconds. To restore the switch to the factory defaults and reboot it, press and hold the reset button for more than 5 seconds.
S6526XE-32X4CC-EI
Figure2-5 Front panel
(1) SFP+ port
(2) SFP+ port LED
(3) QSFP28 port
(4) QSFP28 port LED
(5) Management Ethernet port (MGMT)
(6) Management Ethernet port LED (ACT)
(7) Management Ethernet port LED (LINK)
(8) USB port
(9) Type-C USB console port
(10) Reset button (RESET)
(11) Serial console port
(12) System status LED (SYS)
(13) Expansion card status LED 2 (SLOT2)
(14) Expansion card status LED 1 (SLOT1)
Figure2-6 Rear panel
(1) Grounding screw
(2) Fan tray 1
(3) Expansion card 1
(4) Expansion card 2
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
(8) Serial label pull tab
The S6526XE-32X4CC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two PSR450-12A1 AC power supplies are installed in the power supply slots.
The S6526XE-32X4CC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two FAN-40B-1-A fan trays are installed in the fan tray slots.
The S6526XE-32X4CC-EI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-6, two LSWM2SP8P interface cards are installed in the expansion slots.
The S6526XE-32X4CC-EI switch supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
The S6526XE-32X4CC-EI switch has a reset button on the rear panel. The system LED flashes when the reset button is being pressed. To reboot the switch, press and hold the button for 1 to 5 seconds. To restore the switch to the factory defaults and reboot it, press and hold the reset button for more than 5 seconds.
S6526XE-48X4CC-EI
Figure2-7 Front panel
(1) SFP+ port
(2) SFP+ port LED
(3) QSFP28 port
(4) QSFP28 port LED
(8) USB port
Figure2-8 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S6526XE-48X4CC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two PSR450-12A1 AC power supplies are installed in the power supply slots.
The S6526XE-48X4CC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-8, two FAN-40B-1-A fan trays are installed in the fan tray slots.
The S6526XE-48X4CC-EI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-8, two LSWM2SP8P interface cards are installed in the expansion slots.
The S6526XE-48X4CC-EI switch supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
The S6526XE-48X4CC-EI switch has a reset button on the rear panel. The system LED flashes when the reset button is being pressed. To reboot the switch, press and hold the button for 1 to 5 seconds. To restore the switch to the factory defaults and reboot it, press and hold the reset button for more than 5 seconds.
The switch supports removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
FRU model
S6526XE-32X6CC-HI
S6526XE-48X6CC-HI
S6526XE-32X4CC-EI
S6526XE-48X4CC-EI
PSR450-12D
Supported
PSR450-12A
Supported
PSR450-12A1
Supported
Removable fan trays
LSPM1FANSA-SN
Supported
Not supported
LSPM1FANSB-SN
Supported
Not supported
FAN-40B-1-A
Not supported
Supported
FAN-40F-1-A
Not supported
Supported
Expansion cards
LSPM6FWD
Supported
LSWM4SP8PM
Supported
LSWM2SP8P
Supported
LSWM2QP2P
Supported
LSWM2ZSP8P
Supported
LSWM2ZQP2P
Supported
LSWM2XMGT4PM
Supported
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supply you have installed on the switch.
You can install one power supply, or two power supplies for 1+1 redundancy on the switch.
The switch uses removable fan trays. Do not power on the switch if it is not fully configured with fan trays of the same model.
To install two expansion cards on an S6526XE-EI switch, make sure one of the two expansion cards is an LSWM2QP2P, LSWM2ZQP2P, or LSPM6FWD.
The expansion cards (except for the LSWM2XMGT4PM and LSWM2SP8PM) support hot swapping. Do not install or remove an expansion card during the startup of the switch.
View
Figure4-1 PSR450-12A1 AC power supply view
The views of the PSR450-12A and PSR450-12A1 AC power supplies are similar, with only differences in the latch color and identifier.
LEDs
For information about the status LED, see "Power status LED."
Features
PSR450-12A and PSR450-12A1 are AC power supplies with AC or HVDC input and DC output. Table4-1 describes the features provided by the PSR450-12A and PSR450-12A1 power supplies.
Table4-1 Features provided by the PSR450-12A and PSR450-12A1 power supplies
Feature
Protection function
Protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating correctly.
Table4-2 Technical specifications
Item
Specification
40.2 × 50.5 × 246 mm (1.58 × 1.99 × 9.69 in), including the handle
Weight
0.7 kg (1.54 lb)
Rated AC input voltage range
AC input: 100 to 240 VAC @ 50 or 60 Hz
HVDC input: 240 VDC
Max AC input voltage range
AC input: 90 to 290 VAC @ 47 to 63 Hz
HVDC input: 180 to 320 VDC
Rated input current
AC input: 6 A
HVDC input: 3 A
Rated output current
AC input: 37.5 A
HVDC input: 2 A
Rated output voltage
AC input: 12 V
HVDC input: 3.3 V
Rated output power
450 W
Melting current of power supply fuse
15 A/250 V
View
Figure4-2 PSR450-12D DC power supply view
LEDs
Features
PSR450-12D is a DC power supply with DC input and DC output. Table4-3 describes the features provided by the PSR450-12D power supply.
Table4-3 Features provided by the PSR450-12D power supply
Feature
Protection function
Table4-4 Technical specifications
Item
Specification
Weight
0.7 kg (1.54 lb)
Rated DC input voltage range
–48 to –60 VDC
Max DC input voltage range
–36 to –72 VDC
Rated input current
10 A to 12 A
2 A to 37.5 A
3.3 V to 12 V
Rated output power
450 W
15 A/250 V
LSPM1FANSA-SN
View
Figure5-1 LSPM1FANSA-SN fan tray view
LEDs
For information about the status LED, see "Fan tray status LED on a fan tray."
Features
The LSPM1FANSA-SN fan tray blows air from the power supply side to the port side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-1 Technical specifications
Item
Specification
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in), including the handle
Fan quantity
1
Weight
N/A
Airflow direction
Air drawn in from the fan tray faceplate
Fan speed
20000 R.P.M
Max airflow
20 CFM (0.57 m3/min)
Input voltage
12 V
Max power consumption
9.8 W
LSPM1FANSB-SN
View
Figure5-2 LSPM1FANSB-SN fan tray view
LEDs
Features
The LSPM1FANSB-SN fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-2 Technical specifications
Item
Specification
Fan quantity
1
Weight
N/A
Airflow direction
Air exhausted from the fan tray faceplate
Fan speed
20000 R.P.M
Max airflow
Input voltage
12 V
9.8 W
FAN-40B-1-A
View
Figure5-3 FAN-40B-1-A fan tray view
LEDs
Features
The FAN-40B-1-A fan tray blows air from the power supply side to the port side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-3 Technical specifications
Item
Specification
40.6 × 40 × 117 mm (1.60 × 1.57 × 4.61 in), including the handle
Fan quantity
1
Weight
N/A
Airflow direction
Fan speed
21000 R.P.M
Max airflow
26 CFM (0.74 m3/min)
Input voltage
12 V
27.72 W
FAN-40F-1-A
View
Figure5-4 FAN-40F-1-A fan tray view
LEDs
Features
The FAN-40F-1-A fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-4 Technical specifications
Item
Specification
Fan quantity
1
Weight
N/A
Airflow direction
Fan speed
21000 R.P.M
Max airflow
Input voltage
12 V
27.72 W
6 Expansion cards
CAUTION
CAUTION:
Do not hot swap the LSWM2XMGT4PM and LSWM2SP8PM expansion cards.
About LSWM2SP8P and LSWM2SP8PM
The LSWM2SP8PM and LSWM2SP8P interface cards each provide eight SFP+ ports. The SFP+ ports on the LSWM2SP8PM interface card support MACsec. The views of LSWM2SP8P and LSWM2SP8PM are the same. This figure uses the LSWM2SP8PM as an example.
Figure6-1 LSWM2SP8PM interface card view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP+ port."
For information about the LEDs, see "SFP+ port LED."
Table6-1 Technical specifications
Item
Specification
Product code
LSWM2SP8P
LSWM2SP8PM
40.1 × 95 × 147.5 mm (1.58 × 3.74 × 5.81 in)
Weight
0.4 kg (0.88 lb)
0.688 kg (1.52 lb)
9 W
N/A
10 W
N/A
14 W
50 W
LSWM2QP2P
About LSWM2QP2P
The LSWM2QP2P interface module provides two QSFP+ ports.
Figure6-2 LSWM2QP2P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP+ port."
For information about the LEDs, see "QSFP+ port LED."
Table6-2 Technical specifications
Item
Specification
Weight
0.4 kg (0.88 lb)
9 W
10 W
14 W
LSWM2ZQP2P
About LSWM2ZQP2P
The LSWM2ZQP2P interface module provides two QSFP28 ports.
Figure6-3 LSWM2ZQP2P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP28 ports."
For information about the LEDs, see "QSFP28 port LED."
LSWM2ZSP8P
About LSWM2ZSP8P
The LSWM2ZSP8P interface module provides eight SFP28 ports.
·     Ports 1, 2, 3, and 4 of the expansion card have the same transmission rate, as do ports 5, 6, 7, and 8.
·     If you do not configure speed autonegotiation for a port, the actual port transmission rate depends on the setting of the speed command. For more information about the speed command, see the command reference for the switch.
Figure6-4 LSWM2ZSP8P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP28 port."
For information about the LEDs, see "SFP28 port LED."
LSPM6FWD
About LSPM6FWD
The LSPM6FWD is a fourth-generation high performance firewall module. It provides features including firewall, VPN, content filtering, content identification, URL filtering, and NAT. By using this module on a switch, you can enhance the switch security capabilities without changing the network topology.
Figure6-5 LSPM6FWD front panel
(1) Management Ethernet port LED (ACT/LINK)
(2) 10/100/1000BASE-T management Ethernet port
(3) System status LED (SYS)
(4) Console port (CONSOLE)
(5) Captive screw
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "Console port specifications (2)." and "Management Ethernet port specifications."
For information about the LEDs, see "LEDs on an LSPM6FWD firewall module."
Table6-3 Technical specifications
Item
Specification
44.1 × 95 × 197.8 mm (1.74 × 3.74 × 7.79 in)
Weight
0.688 kg (1.52 lb)
N/A
N/A
50 W
LSWM2XMGT4PM
About LSWM2XMGT4PM
The LSWM2XMGT4PM interface module provides four 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports that support MACsec.
Figure6-6 LSWM2XMGT4PM interface module view
(1) 10G/5G/2.5G/1000BASE-T Ethernet port
(2) Captive screw
(3) Ejector lever
(4) Ethernet port LED
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "10G/5G/2.5G/1G autosensing Ethernet port."
For information about the LEDs, see "10G/5G/2.5G/1000BASE-T LEDs on an LSWM2XMGT4PM."
Table6-4 Technical specifications
Item
Specification
Weight
≤ 0.29 kg (0.64 lb)
N/A
13 W
15 W
7 Ports and LEDs
Ports
Console port
Table7-1 Console port specifications (1)
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Port transmission rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible devices
All device models
Table7-2 Console port specifications (2)
Item
Specification
Connector type
RJ-45
Compliant standard
RS-232
Transmission medium and max transmission distance
≤ 15 m (49.21 ft) over a common asynchronous serial interface cable
Services
·     Supports command line interface (CLI)
Compatible devices
LSPM6FWD
Table7-3 Type-C USB console port specifications
Item
Specification
Connector type
USB Type-C
Compliant standard
USB2.0
Services
Compatible devices
All device models
Table7-4 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Rate, duplex mode, and auto-MDI/MDI-X
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i, 802.3u, and 802.3ab
Functions and services
Used for upgrading and managing applications and Boot ROM
Compatible devices
All device models
USB port
Table7-5 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHC
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
Compatible devices
All device models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
Table7-6 10G/5G/2.5G/1G autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     10 Gbps, full duplex
·     5 Gbps, full duplex
·     2.5 Gbps, full duplex
·     1 Gbps, full duplex
10G mode:
·     55 m (180.45 ft) over Category-5e twisted pair cable
·     55 m (180.45 ft) over Category-6 unshielded twisted pair cable
·     100 m (328.08 ft) over Category-6 or above shielded twisted pair cable
5G mode: 100 m (328.08 ft) over Category-5e or above twisted pair cable
2.5G mode: 200 m (656.17 ft) over Category-5e or above twisted pair cable
1G mode: 140 m (459.32 ft) over Category-5 or above twisted pair cable
Transmission medium
Compliant standard
IEEE 802.3an and IEEE 802.3ab
Compatible devices
LSWM2XMGT4PM
SFP+ port
Table7-7 SFP+ port specifications
Item
Specification
Port type
SFP+ port
Compatible transceiver modules and cables
·     GE SFP transceiver modules and cables in Table7-8
·     10GE SFP+ transceiver modules and cables in Table7-9, Table7-10, and Table7-11
Compatible devices
All device models, LSWM2SP8P, LSWM4SP8PM
Table7-8 GE SFP transceiver modules and cables available for the SFP+ ports
GE SFP transceiver module and cable
Central wavelength (nm)
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP optical transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-F
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX10-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-S
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LX-SM1310-BIDI-S
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI-S
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP copper cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
SFP-STACK-Kit-S
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The following transceiver modules must be used in pairs:
·     SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules.
·     SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules.
·     SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules.
·     SFP-GE-LX-SM1310-BIDI-S and SFP-GE-LX-SM1490-BIDI-S transceiver modules.
For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
Table7-9 10GE SFP+ transceiver modules available for the SFP+ ports
Connector
Fiber diameter (µm)
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-F
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-CPRI-IR-SM1310
1310
LC
Single-mode, 9/125
N/A
1.4 km (0.87 miles)
SFP-XG-CPRI-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1270-BIDI-S
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI-S
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
·     SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules.
·     SFP-XG-LX-SM1270-BIDI-S and SFP-XG-LX-SM1330-BIDI-S transceiver modules.
·     SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules.
·     SFP-XG-LH80-SM1550-BIDI and SFP-XG-LH80-SM1490-BIDI transceiver modules.
For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table7-10 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table7-11 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
Cable length
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure7-1 SFP+ cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C transceiver modules and network cables for the switch.
·     The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide.
SFP28 port
Table7-12 SFP28 port specifications
Item
Specification
Port type
SFP28 port
·     SFP28 transceiver modules and cables in Table7-13 and Table7-14
Compatible devices
LSWM2ZSP8P
Table7-13 SFP28 transceiver modules available for the SFP28 ports
Connector
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310-I
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-LR-SM1310-F
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-CSR-MM850
850
MMF
Multi-mode, 50/125
2000
200 m (656.17 ft)
> 3500
300 m (984.25 ft)
> 5500
400 m (1312.34 ft)
Table7-14 SFP28 cables available for the SFP28 ports
SFP28 cable
Cable length
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-CAB-5M-A
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure7-2 SFP28 cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
QSFP+ port
Table7-15 QSFP+ port specifications
Item
Specification
Port type
QSFP+ port
·     QSFP+ transceiver modules and cables in Table7-16, Table7-17, and Table7-18
Compatible devices
LSWM2QP2P
You can use a QSFP-40G-SR4-MM850 or QSFP-40G-CSR4-MM850 transceiver module to connect one 40G port to four 10G ports. The QSFP+ transceiver module and SFP+ transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type.
Table7-16 40G QSFP+ transceiver modules available for the QSFP+ ports
Connector
QSFP-40G-SR4-MM850
850
MPO (PC end, 12 cores)
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-BIDI-SR-MM850
850
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LX4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Multi-mode, 50/125
2000
150 m (492.13 ft)
4700
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table7-17 40G QSFP+ copper cables available for the QSFP+ ports
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table7-18 40G QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
MPO connectors include physical contact (PC) connectors with a flat-polished face and angle-polished contact (APC) connectors with an angle-polished face (8°).
QSFP28 ports
Table7-19 QSFP28 port specifications
Item
Specification
Port type
QSFP28 port
·     QSFP28 transceiver modules and cables in Table7-20, Table7-21, and Table7-22
Compatible devices
All device models
On an S6526XE-48X6CC-HI switch with no expansion card installed, up to two ports each can be split into four breakout interfaces. You can select one port from each option:
·     Port 49, 50, or 51 on the switch.
·     Port 52, 53, or 54 on the switch.
On an S6526XE-48X4CC-EI switch with no expansion card installed, ports 49, 50, 51, and 52 on the switch each can be split into four breakout interfaces.
You can use a QSFP-100G-SR4-MM850 transceiver module to connect one 100G port to four 25G ports. The QSFP+ transceiver module and SFP28 transceiver modules to be connected must be the same in specifications, including central wavelength and fiber type.
Table7-20 100G QSFP28 transceiver modules available for the QSFP28 ports
Connector
Modal bandwidth (MHz*km)
Maximum transmission distance
QSFP-100G-SR4-MM850
850
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-eSR4-MM850
850
LC
Multi-mode, 50/125
4700
300 m (984.25 ft)
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
75 m (246.06 ft)
4700
100 m (328.08 ft)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295
·     1300
·     1304
·     1309
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-CWDM4-SM1300-A
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-ER4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-ZR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
QSFP-100G-FR1-SM1310
1310
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table7-21 100G QSFP28 copper cables available for the QSFP28 ports
QSFP28 fiber cable
Cable length
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
Table7-22 100G QSFP28 fiber cables available for the QSFP28 ports
QSFP28 copper cable
Cable length
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
Figure7-3 100G QSFP28 copper cable
(1) Connector
(2) Pull tab
Table7-23 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
RS-232
Services
·     Supports CLI
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table7-24 System status LED description
LED mark
Status
SYS
Steady green
The switch has started correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed the POST or is faulty.
Flashing red (1 Hz)
The system is faulty.
Off
The switch is powered off.
Power status LED
The two power status LEDs show the operating status of a power supply.
Table7-25 Power status LED description
LED status
Steady green
The power supply is operating correctly and is in primary state.
Flashing green
The power supply is operating correctly and is in standby state.
Steady red
The power supply is faulty or has entered a protection state.
Alternating between red and green
One of the following power supply conditions is present but the power supply has not entered a protection state: output overvoltage, output undervoltage, output overcurrent, output power overload, or overtemperature.
Flashing red
The current power supply does not have power input. If a device has two power supplies, one of which has power input but the other does not, the LED on the power supply without power input flashes red.
Off
No power input.
Table7-26 Management Ethernet port LED description
LED mark
Status
LINK
Off
No link is present on the port.
Steady green
The port is operating at 10/100/1000 Mbps.
ACT
Off
The port is not sending or receiving data.
Flashing yellow
The port is sending or receiving data.
SFP+ port LED
Table7-27 SFP+ port LED description
LED status
Steady green
A module has been installed and the port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A module has been installed and the port is operating at 1 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
No module has been installed or no link is present on the port.
SFP28 port LED
Table7-28 SFP28 port LED description
LED status
Steady green
The port is operating at 25 Gbps.
Flashing green
The port is sending or receiving data at 25 Gbps.
Steady yellow
The port is operating at 10 Gbps.
Flashing yellow
Off
QSFP+ port LED
Table7-29 QSFP+ port LED description
LED status
Steady green
A module has been installed and the port is operating at 40 Gbps.
Flashing green
The port is sending or receiving data at 40 Gbps.
Steady yellow
Flashing yellow
Off
QSFP28 port LED
Table7-30 QSFP28 port LED description
LED status
Steady green
A module has been installed and the port is operating at 100 Gbps.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
Flashing yellow
The port is sending or receiving data at 40 Gbps, 25 Gbps or 10 Gbps.
Off
The switch provides expansion slots at the rear. The expansion card status LED on the front panel indicates the operating status of the expansion card.
Table7-31 Expansion card status LED description
LED mark
Status
SLOT
Steady green
The expansion card is operating correctly.
Flashing yellow
The switch does not support the expansion card model, or the expansion card is faulty.
Off
The expansion slot is empty.
The LSPM1FANSA-SN and LSPM1FANSB-SN fan trays each have a LED to indicate the fan tray operating status.
Table7-32 Description for the status LED on the LSPM1FANSA-SN or LSPM1FANSB-SN fan tray
LED mark
Status
FAN
On
The fan tray is faulty.
Off
The fan tray is operating correctly.
The FAN-40B-1-A and FAN-40F-1-A fan trays each have a LED to indicate the fan tray operating status.
Table7-33 Description for the status LED on the FAN-40B-1-A or FAN-40F-1-A fan tray
LED mark
Status
FAN
Steady yellow
Flashing
The fan tray is operating incorrectly.
Off
The fan tray is not securely installed or has no power input.
Table7-34 Description for the LEDs on an LSPM6FWD firewall module
LED
Mark
Status
ACT/LINK
Off
Steady green
A link is present on the port.
Flashing green
System status LED
SYS
Off
No power is input or the firewall module has failed.
Slowly flashing green
The system has started up and is operating correctly.
Fast flashing green
The system is loading software.
Table7-35 Description for the 10G/5G/2.5G/1000BASE-T LEDs on an LSWM2XMGT4PM
LED status
Steady green
Flashing green
Steady yellow
The port is operating at 1 Gbps, 2.5 Gbps, or 5 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps, 2.5 Gbps, or 5 Gbps.
Off
8 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The switch uses removable fan trays and provides airflow from the port side to the power supply side or from the power supply side to the port side by using different types of fan trays. You must fully configure the switch with fan trays of the same model. Table8-1 describes the fan trays available for the switch.
Table8-1 Fan trays available for the switch
Switch model
Fan tray model
Airflow direction
S6526XE-32X6CC-HI
S6526XE-48X6CC-HI
LSPM1FANSA-SN
From the power supply side to the port side
LSPM1FANSB-SN
From the port side to the power supply side
S6526XE-32X4CC-EI
S6526XE-48X4CC-EI
FAN-40F-1-A
FAN-40B-1-A
Figure8-1 Airflow direction for LSPM1FANSA-SN or FAN-40F-1-A
Figure8-2 Airflow direction for LSPM1FANSB-SN or FAN-40B-1-A
