01-text | 4.02 MB |
Examining the installation site
Installing the switch in a 19-inch rack
Installation methods and rack requirements
Rack-mounting the switch by using front mounting brackets
Rack-mounting the switch by using front and rear mounting brackets
Mounting the switch on a workbench
Grounding the switch by using a grounding strip
Grounding the switch by using a grounding conductor buried in the earth ground
Verifying the connection after grounding the switch
Installing/removing power supplies
Connecting the power cord for a PSR450-12A/PSR450-12A1 power supply
Connecting the power cord for a PSR450-12AHD power supply
Connecting the DC power cord for a PSR450-12D power supply
Installing/removing expansion modules
Installing an expansion module
3 Accessing the switch for the first time
Connecting the switch to a configuration terminal
Connecting a DB9-to-RJ45 console cable
Connecting a USB-to-RJ45 console cable
Planning IRF fabric size and the installation site
Identifying the master switch and planning IRF member IDs
Planning IRF topology and connections
Identifying physical IRF ports on the member switches
Configuring basic IRF settings
Connecting the physical IRF ports
Verifying the IRF fabric setup
5 Maintenance and troubleshooting
Configuration terminal display issues
1 Preparing for installation
The S6550X-HI switch series includes the following models:
Product code |
Product model |
LS-6550X-32H-HI |
S6550X-32H-HI |
LS-6550X-32Q-HI |
S6550X-32Q-HI |
LS-6550X-56HF-HI |
S6550X-56HF-HI |
Safety recommendations
To avoid any equipment damage or bodily injury, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
· Before cleaning the switch, remove all power cords from the switch. Do not clean the switch with wet cloth or liquid.
· Do not place the switch near water or in a damp environment. Prevent water or moisture from entering the switch chassis.
· Do not place the switch on an unstable case or desk. The switch might be severely damaged in case of a fall.
· Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the switch free of obstruction.
· Make sure the operating voltage is in the required range.
· To avoid electrical shocks, do not open the chassis while the switch is operating or when the switch is just powered off.
· To avoid ESD damage, always wear an ESD wrist strap when replacing a power supply or fan tray.
Safety labels
Carefully identify the safety labels on the device before you use the device, and follow the instructions on the labels to operate the device.
Table1-1 Safety label description
Label |
Name |
ESD |
ESD sensitive device. |
Grounding |
Grounding point of the device. If a separate grounding point is available, you must connect the grounding point to the earth permanently. |
Fan tray alarm label |
· Do not touch rotating fan blades before a fan tray stops. · Hazardous rotating component. · Stay away from rotating fan blades. · Operate this component 1 minute after this component is removed or the device is powered off. |
Hot surface |
· The surface is of high temperature. · Hot surface. Do not touch it. · Operate this component 1 minute after this component is removed or the device is powered off. |
Altitude |
The device can operate correctly in an area with an altitude lower than 2000 m (6561.68 ft). |
Non-tropical climate |
The device can operate correctly only in a non-tropical climate. |
Read instruction manual |
Read the instruction manual for how to operate the device. |
Weight-supporting handle |
To lift a chassis with a weight higher than 100 kg (220.46 lb), read the instruction manual and use tools. |
Laser safety |
Invisible laser radiation with a hazard class of 1M. Do not view directly or with non-attenuating optical instruments. |
Multiple power sources |
· The device has multiple power sources. · To power off the device, you must shut down all power sources. · Disconnect all power cables, including RPS. |
High leakage current |
High leakage current. You must ground the device before you connect it to the power source. |
The safety labels vary depending on the device model. The labels in this section are for illustration only.
You must install the switch indoors and make sure the following requirements are met:
· Adequate clearance is reserved at the air inlet and outlet vents for ventilation.
· The rack has a good ventilation system.
· Identify the hot aisle and cold aisle at the installation site, and make sure ambient air flows into the switch from the cold aisle and exhausts to the hot aisle.
· Identify the airflow designs of neighboring devices, and prevent hot air flowing out of the neighboring devices from entering the top device.
· The rack is sturdy enough to support the switch and its accessories.
· The rack is reliably grounded.
To ensure correct operation and long service life of your switch, install it in an environment that meets the requirements described in the following subsections.
Temperature/humidity
Maintain temperature and humidity in the equipment room at acceptable ranges.
· Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
· Lasting low relative humidity can cause washer contraction and ESD and cause issues including loose mounting screws and circuit failure.
· High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the switch.
For the temperature and humidity requirements, see hardware information and specifications for the switch.
Cleanliness
Dust buildup on the chassis might cause electrostatic adsorption and dust corrosion, resulting in poor contact of metal connectors and contact points. This might shorten the device's lifetime and even cause device failure in the worst case. Table1-2 describes the dust concentration limits in the equipment room.
Table1-2 Dust concentration limits in the equipment room for the switch
Dust |
Particle diameter |
Maximum allowable concentration |
Dust particles |
≥ 0.5 µm |
3.5 × 106 particles/m3 |
Dust particles |
≥ 5 µm |
3 × 104 particles/m3 |
Dust (suspension) |
≤ 75 µm |
0.2 mg/m3 |
Dust (sedimentation) |
75 µm to 150 µm |
1.5 mg/(m2h) |
To maintain cleanliness in the equipment room, follow these guidelines:
· Keep the equipment room away from pollution sources. Do not smoke, eat, or drink in the equipment room.
· Use double-glazed windows and seal doors and windows with dust-proof rubber strips. Use screen doors and window screens for doors and windows open to the outside and make sure the external windows are air tight.
· Use dustproof materials for floors, walls, and ceilings and use wallpaper or matt paint that does not produce powders.
· Clean the equipment room regularly and clean the air filters of the rack each month.
· Wear ESD clothing and shoe covers before entering the equipment room. Keep the ESD clothing and shoe covers clean and change them frequently.
Corrosive gas limit
Corrosive gases can accelerate corrosion and aging of metal components. Make sure the corrosive gases in the equipment room do not exceed the concentration limits as shown in Table1-3.
Table1-3 Corrosive gas concentration limits in the equipment room
Gas |
Average concentration (mg/m3) |
Maximum allowable concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
CAUTION: As a best practice, control the corrosive gas in the equipment room at the average concentration values. Make sure the corrosive gas will not be in their maximum allowable concentration values for over 30 minutes per day. |
To control corrosive gases, use the following guidelines:
· As a best practice, do not build the equipment room in a place with a high concentration of corrosive gases.
· Make sure the equipment room is not connected to sewer, vertical shaft, or septic tank pipelines and keep it far away from these pipelines. The air inlets in the equipment room must be away from such pollution sources.
· Use environmentally friendly materials to decorate the equipment room. Avoid using organic materials that contain harmful gases, such as sulfur or chlorine-containing insulation cottons, rubber mats, sound-proof cottons, and avoid using plasterboards with high sulfur concentration.
· Place fuel (diesel or gasoline) engines separately. Do not place them in the same equipment room with the device. Make sure the air exhausted from the engines will not flow into the equipment room or towards the air inlets of the air conditioners.
· Place batteries separately. Do not place them in the same room with the device.
· Employ a professional company to monitor and control corrosive gases in the equipment room regularly.
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the switch and application system, adversely affect the switch in the following ways:
· A conduction pattern of capacitance coupling.
· Inductance coupling.
· Electromagnetic wave radiation.
· Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
· If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
· Keep the switch far away from radio transmitting stations, radar stations, and high-frequency devices.
· Use electromagnetic shielding, for example, shielded interface cables, when necessary.
· To prevent signal ports from getting damaged by overvoltage or overcurrent caused by lightning strikes, route interface cables only indoors.
Laser safety
WARNING! · The switch is a Class 1 laser device. · Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the switch is operating. |
Installation tools
No installation tools are provided with the switch. Prepare the following tools yourself:
· Flat-head screwdriver.
· Phillips screwdriver.
· ESD wrist strap.
· Marker.
· Heat gun.
· Wire stripper.
· Diagonal pliers.
Installation accessories
Before installation, make sure you have all the required installation accessories. If any accessory is damaged or missing, use the part No. provided in this table to purchase a new one.
Table1-4 Installation accessories
Part No. |
Quantity |
Applicable device models |
2150A0JG |
Front mounting kit, including a pair of front mounting brackets and eight M4 screws |
1 kit, provided |
All S6550X-HI models |
2150A0AN |
1 kit, optional |
2150A0BP |
Rear mounting bracket kit, including a pair of rear mounting brackets and two shoulder screws |
1 kit, optional |
26020141 |
M6 screw |
User supplied |
26020075 |
Cage nut |
User supplied |
63200063 |
Rubber feet |
4, provided |
0404A0DT |
Grounding cable |
1, provided |
26010496 |
Grounding screw |
1, provided |
2114A09C |
Power supply filler panel |
1, provided |
2114A082 |
Interface module filler panel |
1, provided |
· 04041104 (PSR450-12A and PSR450-12A1) · 0404A0TA (PSR450-12AHD) |
AC/HVDC power cord The appearance and parameters for power cords vary by countries and regions. The power cord in this table is a standard AC power cord in China. |
PSR450-12A/PSR450-12A1/PSR450-12AHD: 1, provided |
0404A00E |
DC power cord |
PSR450-12D: 1, provided |
04042967 |
DB9-to-RJ45 console cable |
1, optional |
0404A1EE |
USB-to-RJ45 console cable |
1, optional |
2 Installing the switch
CAUTION: Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence caused thereby. |
Figure2-1 Hardware installation flow
The switch provides two installation positions for front mounting brackets. One is near the port side and the other is near the power supply side. Choose the installation position for front mounting brackets according to the installation environment.
The switch supports the following rack-mounting methods:
· Rack-mounting the switch by using front mounting brackets (product code: 2150A0JG). For more information about the installation procedure, see "Rack-mounting the switch by using front mounting brackets."
· Rack-mounting the switch by using both front mounting brackets (product code: 2150A0AN) and rear mounting brackets. For more information about the installation procedure, see "Rack-mounting the switch by using front and rear mounting brackets." For more information about the installation methods and rack requirements, see Table2-2.
NOTE: Some early shipped switches support this rack-mounting method. To use this rack-mounting method, prepare the corresponding installation accessories. |
Table2-2 Installation methods and rack requirements
Installation method |
Chassis dimensions |
Requirements for the distance between the front and rear rack posts |
Rack requirements |
Install the front mounting brackets at the port side |
Front mounting brackets and rear mounting brackets with the wide flange inside the rack |
· Height—44.0 mm (1.73 in)/1 RU · Width—440 mm (17.32 in) · Depth—425 mm (16.73 in) ¡ 25 mm (0.98 in) for the power supply handle ¡ 400 mm (15.75 in) for the chassis |
372 to 536 mm (14.65 to 21.10 in) |
To close the rack door easily after cabling the switch, make sure the rack meets the following requirements: · A minimum of 130 mm (5.12 in) between the front rack posts and the front door. · A minimum of 153 mm (6.02 in) between the rear rack posts to the inner surface of the rack door. |
Front mounting brackets and rear mounting brackets with the wide flange outside the rack |
214 to 378 mm (8.43 to 14.88 in) |
Install the front mounting brackets at the power supply side |
357 to 492 mm (14.06 to 19.37 in) |
200 to 335 mm (7.87 to 13.19 in) |
Figure2-2 and Figure2-3 show the rack-mounting procedures.
Figure2-2 Rack-mounting the switch by using front mounting brackets
Figure2-3 Rack-mounting the switch by using front and rear mounting brackets
NOTE: If a rack shelf is available, you can put the switch on the rack shelf, slide the switch to an appropriate location, and attach the switch to the rack by using the mounting brackets. |
Figure2-4 Front mounting brackets (product code: 2150A0JG)
Figure2-5 Front mounting brackets (product code: 2150A0AN)
Figure2-6 Rear mounting bracket and shoulder screw
(1) Shoulder screw |
(2) Attach the rear mounting bracket to the rack |
Attaching the front mounting brackets to the switch
In this section, the product code of the front mounting brackets is 2150A0JG.
To attach the front mounting brackets to the switch:
1. Align the round holes in the wide flange of one front mounting bracket with the screw holes in the chassis. See Figure2-7 and Figure2-8.
2. Use M4 screws (supplied with the switch) to attach the front mounting bracket to the chassis.
As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten the M4 screws.
3. Repeat the preceding two steps to attach the other front mounting bracket to the chassis.
Figure2-7 Attaching the front mounting brackets to the chassis (at the port side)
Figure2-8 Attaching the front mounting brackets to the chassis (at the power supply side)
Mounting the switch in the rack
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Verify that the front mounting brackets are securely attached to both sides of the switch. For more information, see Figure2-7 and Figure2-8.
3. Attach cage nuts (user supplied) to the front rack posts.
4. One person supports the chassis bottom and pushes the chassis into the rack.
5. The other person attaches the front mounting brackets by using M6 screws (user supplied) and cage nuts to the front rack posts. Make sure the switch is installed securely in the rack. See Figure2-9. As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten the M6 screws.
Figure2-9 Mounting the switch in the rack
Attaching the front mounting brackets and shoulder screws to the switch
In this section, the product code of the front mounting brackets is 2150A0AN.
To attach the front mounting brackets and shoulder screws to the switch:
1. Align the round holes in the wide flange of one front mounting bracket with the screw holes in the chassis. See Figure2-10 and Figure2-11.
2. Use M4 screws (supplied with the switch) to attach the mounting bracket to the chassis.
3. Repeat the preceding two steps to attach the other mounting bracket to the chassis.
4. Unpack the shoulder screw and attach it to the chassis. As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten the shoulder screw.
If you install the front mounting brackets at the port side, the switch provides two installation positions for the shoulder screw (red marked in Figure2-10).
If you install the front mounting brackets at the power supply side, the switch provides one installation position for the shoulder screw (red marked in Figure2-11).
The distance between the front and rear rack posts depends on the installation method of front mounting brackets. Choose one installation method according to the installation environment.
Figure2-10 Attaching the front mounting brackets and shoulder screws to the chassis (at the port side)
Attaching the rear mounting brackets to the rack
1. Determine the switch installation position in the rack.
2. Orient the rear mounting brackets with the wide flange inside or outside the rack as required, as shown in Figure2-12 and Figure2-13.
3. Use M6 screws and cage nuts to attach the rear mounting brackets to the rear rack posts. As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten the M6 screws.
Make sure the corresponding cage nuts on the left and right rear rack posts are at the same height.
Do not fully tighten the M6 screws before mounting the switch in the rack.
Figure2-12 Attaching the rear mounting brackets to the rack with the wide flange inside the rack
Figure2-13 Attaching the rear mounting brackets to the rack with the wide flange outside the rack
2. Verify that the front mounting brackets and shoulder screws are securely attached to both sides of the switch. For more information, see Figure2-10 and Figure2-11.
3. Attach cage nuts to the front rack posts and make sure the corresponding cage nuts on the front and rear rack posts are at the same height.
4. One person supports the chassis bottom and pushes the chassis into the rack. Make sure the shoulder screws rest firmly on the upper edge of the rear mounting brackets. See Figure2-14 and Figure2-15.
5. The other person attaches the front mounting brackets by using M6 screws and cage nuts to the front rack posts. Make sure the switch is installed securely in the rack. See Figure2-14 and Figure2-15. As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten the M6 screws.
Figure2-14 Mounting the switch in the rack (with the wide flange of the rear mounting brackets inside the rack)
IMPORTANT: · Reserve a minimum clearance of 10 cm (3.94 in) around the chassis for heat dissipation. · Do not place heavy objects on the switch. |
To mount the switch on a workbench:
1. Verify that the workbench is sturdy and reliably grounded.
2. Place the switch with bottom up, and clean the round holes in the chassis bottom with dry cloth.
3. Attach the rubber feet to the four round holes in the chassis bottom.
4. Place the switch with upside up on the workbench.
Figure2-16 Mounting the switch on a workbench
CAUTION: · Correctly connecting the grounding cable is crucial to lightning protection, ESD, and EMI protection. You must connect the grounding cable correctly and reliably for the switch. · For information about lightning protection for the switch, see H3C Network Devices Lightning Protection Guide. |
To protect against the following types of problems, use a grounding cable to connect the device to the earthing facility at the installation site:
· Bodily injury from electric shocks.
· Device and power and data line damages.
· Electrical fires, lightning strokes, electromagnetic coupling interferences, and ESD damages.
Choose an appropriate grounding method according to the installation environment.
NOTE: The grounding terminals in the following figures are for illustration only. |
CAUTION: · Connect the grounding cable to the grounding strip in the equipment room. Do not connect it to a fire main or lightning rod. · To guarantee the grounding effect and avoid switch damage, use the grounding cable provided with the switch to connect the switch to a grounding strip in the equipment room. |
Connecting the grounding cable to the chassis
1. Remove the grounding screw from the grounding hole in the chassis.
2. Use the grounding screw to attach the ring terminal of the grounding cable to the grounding hole and fasten the grounding screw.
As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten the grounding screw.
IMPORTANT: Orient the grounding cable as shown in Figure2-17 so that you can easily install or remove the fan trays. |
Figure2-17 Connecting the grounding cable to the chassis
(1) Grounding screw |
(2) Ring terminal |
(3) Grounding sign |
(4) Grounding hole |
(5) Grounding cable |
Connecting the grounding cable to a grounding strip
1. Remove a hex nut from the grounding strip.
2. Cut the grounding cable to a length according to the distance between the switch and the grounding strip.
3. Attach a ring terminal to the grounding cable:
a. Strip 5 mm (0.20 in) of insulation off the end of the grounding cable.
b. Slide the heat-shrink tubing onto the cable and insert the bare metal part into the end of the ring terminal.
c. Use a crimping tool to secure the metal part of the cable to the ring terminal.
d. Slide the heat-shrink tubing down the cable until the tube covers the joint.
e. Use a heat gun to shrink the tubing around the cable.
Figure2-18 Attaching a ring terminal to the grounding cable
4. Connect the ring terminal to the grounding post of the grounding strip, and fasten it with the removed hex nut.
Figure2-19 Connecting the grounding cable to a grounding strip
(1) Grounding post |
(2) Grounding strip |
(3) Grounding cable |
(4) Hex nut |
If the installation site does not have grounding strips, but earth ground is available, hammer a 2.5 m (8.20 ft) or longer angle iron or steel tube into the earth ground to act as a grounding conductor. Make sure a minimum of 0.7 m (2.30 ft) is left between the top of the grounding conductor and the ground. In cold areas, bury the grounding conductor below the frozen soil layer. In areas with thin soil or rocky gravel, determine the depth for burying the grounding conductor based on the actual condition.
If zinc-coated steel is used, the following dimensions requirements must be met:
· Angle iron—A minimum of 50 × 50 × 5 mm (1.97 × 1.97 × 0.20 in).
· Steel tube—A minimum of 3.5 mm (0.14 in) in thickness.
· Flat steel—A minimum of 40 × 4 mm (1.57 × 0.16 in).
· Round steel—A minimum of 10 mm (0.39 in).
Weld the yellow-green grounding cable to the angel iron or steel tube and treat the joint for corrosion protection.
Figure2-20 Grounding the switch by burying the grounding conductor into the earth ground
(2) Grounding cable |
(3) Earth |
(4) Welding point |
(5) Grounding conductor |
· If you ground the switch by using a grounding strip:
a. Use a multimeter to measure the resistance between the switch grounding terminal and grounding point, and make sure the resistance is less than 0.1W.
b. Use a grounding resistance tester to measure the grounding resistance of the grounding strip, and make sure the grounding resistance is less than 1W.
· If you ground the switch by using a grounding conductor buried in the earth ground:
b. Use a grounding resistance tester to measure the grounding resistance of the angle iron in the ground, and make sure the grounding resistance is less than 10W. For locations with high soil resistivity, sprinkle some resistance reducer to reduce soil resistivity or replace soil around the grounding strip with soil with lower resistance.
For information about resistance measurement, see H3C Network Devices Lightning Protection Guide.
Installing/removing fan trays
CAUTION: The switch has multiple fan tray slots. To ensure good ventilation of the switch, follow these guidelines to install and remove fan trays: · The switch is provided with the fan tray slots empty. Before powering on the switch, make sure all fan tray slots have fan trays installed and the fan trays are the same model. · Make sure all slots have a module or filler panel installed when the switch is operating. · If multiple fan trays fail on an operating switch, do not remove the fan trays at the same time. Replace the fan trays one after another and finish replacing each fan tray within 3 minutes. |
The LSWM1FANSCBE-CP and FAN-40B-1-A-CP fan trays feature anticorrosion. As a best practice, use anticorrosion-capable fan trays in corridors, basements, areas near chemical factories, livestock farms, and coastal regions.
The installation and removal procedures are the same for fan trays. The following installation and removal procedures use the FAN-40B-1-A fan tray as an example.
Installing a fan tray
CAUTION: To prevent damage to the fan tray or the connectors on the backplane, insert the fan tray gently. If you encounter a hard resistance while inserting the fan tray, pull out the fan tray and insert it again. |
Select fan trays for the switch as needed. For the available fan trays and their specifications, see hardware information and specifications for the switch.
To install a fan tray:
2. Unpack the fan tray and verify that the fan tray model is correct.
3. Orient the fan tray with the "TOP" mark on top. Grasp the handle of the fan tray with one hand and support the fan tray bottom with the other, and slide the fan tray along the guide rails into the slot until the fan tray is fully seated in the slot and has a firm contact with the backplane. See Figure2-21.
Figure2-21 Installing a FAN-40B-1-A fan tray in the switch
Removing a fan tray
WARNING! · Ensure electricity safety and never touch the rotating fans when you hot-swap a fan tray. · To prevent a fan from causing loud noise, do not touch the fan blades and rotation axis, even if the fan is not rotating. |
To remove a fan tray:
2. Grasp the handle of the fan tray with one hand and pull the fan tray part way out of the slot. Support the fan tray bottom with the other and pull the fan tray completely out of the slot.
3. Put the removed fan tray in an antistatic bag.
Figure2-22 Removing a FAN-40B-1-A fan tray
WARNING! · To avoid bodily injury and device damage, strictly follow the procedures in Figure2-23 and Figure2-24 to install and remove a power supply. · Provide a separate circuit breaker for each power supply. |
Figure2-23 Installation procedure
The installation and removal procedures are the same for different models of power supplies. The following installation and removal procedures use a PSR450-12A1 power supply as an example.
Installing a power supply
CAUTION: · Follow the forward inertia of the power supply when inserting it into the chassis, and make sure the power supply has firm contact with the connectors on the backplane. · To prevent damage to the connectors inside the switch chassis, insert the power supply gently. If you encounter a hard resistance while inserting the power supply, pull out the power supply and insert it again. |
To install a power supply:
2. Remove the filler panel, if any, from the target power supply slot, as shown in Figure2-25.
Figure2-25 Removing a filler panel
3. Unpack the power supply and verify that the power supply model is correct.
4. Correctly orient the power supply with the words on the power supply upward. Grasp the handle of the power supply with one hand and support its bottom with the other, and slide the power supply slowly along the guide rails into the slot.
The slot is foolproof. If you cannot insert the power supply into the slot, re-orient the power supply rather than use excessive force to push it in.
Figure2-26 Installing a power supply
Removing a power supply
CAUTION: When the switch has two power supplies in 1+1 redundancy mode, removing one power supply does not affect the operation of the switch. When the switch has only one power supply installed, removing the power supply powers off the switch. |
To remove a power supply:
2. Disconnect the power cord from the power source and power supply.
3. Holding the handle on the power supply with one hand, press the latch on the power supply towards the handle direction with your thumb, and pull the power supply part way out of the slot. Supporting the power supply bottom with the other, slowly pull out the power supply.
4. Put the removed power supply on an antistatic mat or in its original package.
5. If you are not to install a new power supply, install a filler panel in the slot.
Figure2-27 Removing a power supply
Connecting the power cords
WARNING! Provide a circuit breaker for each power input. When you connect a power cord, make sure the circuit breaker is switched off. |
The power cord connection procedure is the same for the PSR450-12A and PSR450-12A1 power supplies. The following procedure uses a PSR450-12A1 power supply as an example.
To connect the power cord for a PSR450-12A1 power supply:
1. Insert the female connector of the power cord supplied with the power supply into the power receptacle on the power supply.
2. Use a releasable cable tie to secure the power cord to the handle of the power supply, as shown in Figure2-28.
3. Connect the other end of the power cord to a power source.
Figure2-28 Connecting a power cord to the PSR450-12A1 power supply (1)
Figure2-29 Connecting a power cord to the PSR450-12A1 power supply (2)
1. Slide the cable clamp onto the tie mount on the power supply, as shown in Figure2-30.
2. Connect the female connector of the power cord to the power receptacle on the power supply. Close the cable clamp and slide it forward until it is flush against the edge of the female connector. See Figure2-31.
Figure2-30 Connecting the power cord for a PSR450-12AHD power supply (1)
Figure2-31 Connecting the power cord for a PSR450-12AHD power supply (2)
CAUTION: · To use a –48 VDC power source to supply power for the power supply, use the DC power cord supplied with the power supply. · When you use a –48 VDC power source to supply power, identify the positive (+) and negative (-) marks on the two wires to avoid connection mistakes. |
To connect the DC power cord for a PSR450-12D power supply:
2. As shown by callout 1 and callout 2 in Figure2-32, use a flat-head screwdriver to loosen the mounting screws on the receptacle cover, and then remove the receptacle cover.
3. As shown by callout 3 in Figure2-33, correctly orient the power cord connector and insert it into the power receptacle. The power receptacle and power cord connector have disorientation rejection designs. If you cannot insert the connector into the receptacle, re-orient the connector rather than use excessive force to push it in.
4. As shown by callout 4 in Figure2-33, use a flat-head screwdriver to fasten the screws on the power cord connector to secure the connector to the receptacle.
5. Connect the other end of the power cord to a –48 VDC power source.
Figure2-32 Connecting the DC power cord for a PSR450-12D power supply (1)
Figure2-33 Connecting the DC power cord for a PSR450-12D power supply (2)
CAUTION: When you install or remove an expansion module, follow these guidelines: · Never touch the components on the expansion module surface with bare hands. · Do not use excessive force. · If you are not to install a new expansion module after removing the original one, install a filler panel in the slot to prevent dust and ensure good ventilation in the switch. · Do not install or remove an expansion module during startup of the switch. Hot swapping an expansion module when the switch is operating correctly. |
The installation and removal procedures are the same for expansion modules. The following procedures are for illustration only.
1. Wear an ESD wrist strap and make sure the wrist strap makes good skin contact and is reliably grounded.
2. Use a Phillips screwdriver to loosen the screw on the filler panel and remove the filler panel. Keep the removed filler panel secure for future use.
Figure2-34 Removing the filler panel from the expansion slot
3. Unpack the expansion module. Insert the expansion module steadily into the slot along the guide rails until the expansion module snaps into place. See callout 1 in Figure2-35.
4. As shown by callout 2 in Figure2-35, use a Phillips screwdriver to fasten the mounting screw on the expansion module.
Figure2-35 Installing an interface module
Figure2-36 Interface module installation completed
NOTE: An interface module (including its handle) adds 75 mm (2.95 in) to the chassis depth. |
Removing an expansion module
2. Use a Phillips screwdriver to loosen the mounting screw on the expansion module.
3. Pull the expansion module slowly out of the slot along the guide rails.
Verifying the installation
After you complete the installation, verify that:
· There is enough space for heat dissipation around the switch, and the rack is stable.
· The grounding cable is securely connected.
· The correct power source is used.
· The power cords are correctly connected.
· All the interface cables are cabled indoors. If any cable is routed outdoors, verify that the socket strip with lightning protection and lightning arresters for network ports have been correctly connected.
You can connect the switch to a configuration terminal only by using the serial console port.
In Figure3-1, the switch is connected to a configuration terminal (PC as an example) from the serial console port.
Figure3-1 Connecting the switch to a configuration terminal
CAUTION: Follow these guidelines when you connect a DB9-to-RJ45 console cable: · Identify the mark on the serial console port and make sure you are connecting to the correct port. · The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end. |
A DB9-to-RJ45 serial console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the serial console port of the switch, and a DB-9 female connector at the other end for connecting to the serial port on a configuration terminal.
Figure3-2 DB9-to-RJ45 console cable
Table3-1 DB9-to-RJ45 console cable signal pinout
RJ-45 |
Signal |
DB-9 |
Signal |
1 |
RTS |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
SG |
5 |
SG |
5 |
SG |
5 |
SG |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
To connect the switch to a configuration terminal (for example, a PC) by using a DB9-to-RJ45 console cable:
1. Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2. Connect the RJ-45 connector to the serial console port on the switch.
IMPORTANT: · To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal. · If you have connected a USB-to-RJ45 console cable to the configuration terminal before installing the driver, remove and reconnect the USB-to-RJ45 console cable to the configuration terminal after driver installation. |
The following installs the driver on a Windows operating system. To install the driver on other operating systems, see the installation guide in the driver compression package named by using the corresponding operating system.
To connect the switch to a configuration terminal by using a USB-to-RJ45 console cable:
1. Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2. View the TXT file Read me in the Windows folder to identify whether the Windows operating system on the configuration terminal supports the driver.
3. If the Windows operating system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4. Click Next on the welcome page of the driver installation wizard.
Figure3-3 Driver installation wizard
5. Click Finish after the drive installation is completed.
Figure3-4 Finishing the driver installation
6. Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7. Connect the RJ-45 connector of the cable to the console port of the switch.
Setting terminal parameters
To configure and manage the switch through the console port, you must run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs
Configure the terminal parameters as follows:
· Bits per second—9600.
· Data bits—8.
· Stop bits—1.
· Parity—None.
· Flow control—None.
Powering on the switch
1. Before powering on the switch, verify that the following conditions are met:
¡ All the fan tray slots have a fan tray installed.
¡ The power cords are connected correctly.
¡ The input power voltage is as required by the switch.
¡ The console cable is connected correctly.
¡ The configuration terminal (a PC, for example) has started, and its serial port settings are consistent with the console port settings on the switch.
2. Power on the switch.
During the startup process, you can access BootWare menus to perform tasks such as software upgrade and file management. The BootWare interface and menu options vary by software version. For more information about BootWare menu options, see the software-matching release notes for the device.
3. After the startup completes, you can access the CLI to configure the switch.
For more information about the configuration commands and CLI, see the command references and configuration guides for the switch.
4 Setting up an IRF fabric
You can use H3C IRF technology to connect and virtualize S6550X-HI switches into a large virtual switch called an "IRF fabric" for flattened network topology, and high availability, scalability, and manageability.
An S6550X-HI switch can set up an IRF fabric only with switches from the same switch series.
IRF fabric setup flowchart
Figure4-1 IRF fabric setup flowchart
To set up an IRF fabric:
Step |
1. Plan IRF fabric setup |
Plan the installation site and IRF fabric setup parameters: · Planning IRF fabric size and the installation site · Identifying the master switch and planning IRF member IDs · Planning IRF topology and connections |
2. Install IRF member switches |
See "Installing the switch in a 19-inch rack" or "Mounting the switch on a workbench." |
3. Connect grounding cables and power cords |
See "Grounding the switch" and "Connecting the power cords." |
4. Power on the switches |
N/A |
5. Configure basic IRF settings |
See the virtual technologies configuration guide in the configuration guides for the switch series. |
6. Connect the physical IRF ports |
Connect physical IRF ports on switches. All switches except the master switch automatically reboot, and the IRF fabric is established. |
Planning IRF fabric setup
This section describes issues that an IRF fabric setup plan must cover.
Choose switch models and identify the number of required IRF member switches, depending on the user density and upstream bandwidth requirements. The switching capacity of an IRF fabric equals the total switching capacities of all member switches.
Plan the installation site depending on your network solution as follows:
· Place all IRF member switches in one rack for centralized high-density access.
· Distribute the IRF member switches in different racks to implement the top of rack (ToR) access solution for a data center.
NOTE: · An IRF fabric is highly scalable. You can easily add new member devices to an IRF fabric after the fabric is set up · For the maximum IRF member devices supported by the switch, see the release notes that come with the switch. |
Determine which switch you want to use as the master for managing all member switches in the IRF fabric.
An IRF fabric has only one master switch. You configure and manage all member switches in the IRF fabric at the CLI of the master switch. IRF member switches automatically elect a master.
You can affect the election result by assigning a high member priority to the intended master switch. For more information about master election, see H3C S6550X-HI Switch Series Virtual Technologies Configuration Guide.
Prepare an IRF member ID assignment scheme. An IRF fabric uses member IDs to uniquely identify and manage its members, and you must assign each IRF member switch a unique member ID.
You can create an IRF fabric in daisy chain topology or more reliable ring topology. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy chain topology. Instead, the IRF fabric changes to a daisy chain topology without interrupting network services.
You connect the IRF member switches through IRF ports, the logical interfaces for the connections between IRF member switches. Each IRF member switch has two IRF ports: IRF-port 1 and IRF-port 2. To use an IRF port, you must bind a minimum of one physical port to it.
When connecting two neighboring IRF member switches, you must connect the physical ports of IRF-port 1 on one switch to the physical ports of IRF-port 2 on the other switch.
The switch can provide 25GE/40GE/100GE IRF connections. See Table4-1 for the available IRF physical ports. You can bind several IRF physical ports to an IRF port for increased bandwidth and availability.
Figure4-2 and Figure4-3 show the topologies of an IRF fabric made up of three S6550X-HI switches. The IRF port connections in the two figures are for illustration only, and more connection methods are available.
Figure4-2 IRF fabric in daisy chain topology
Figure4-3 IRF fabric in ring topology
Identify the physical IRF ports on the member switches according to your topology and connection scheme.
Table4-1 shows the physical ports that can be used for IRF connection and the port use restrictions.
Table4-1 Candidate physical IRF ports and their use restrictions
Chassis |
Candidate physical IRF ports |
Use restrictions |
S6550X-32H-HI |
QSFP28 ports on the front panel |
· All physical ports to be bound to an IRF logical interface must have the same data rate. · A QSFP28 port can be used as an IRF physical port only when it operates at 100 Gbps. |
S6550X-32Q-HI |
QSFP28 ports and QSFP+ ports on the front panel |
· All physical ports to be bound to an IRF logical interface must have the same data rate. · A QSFP28 port can be used as an IRF physical port only when it operates in 100 Gbps. · A QSFP+ port can be used as a IRF physical port only when it operates at 40 Gbps. |
S6550X-56HF-HI |
QSFP28 ports and SFP28 ports on the front panel |
· All physical ports to be bound to an IRF logical interface must have the same data rate. · A QSFP28 port can be used as an IRF physical port only when it operates in 100 Gbps. · An SFP28 port can be used as a IRF physical port only when it operates at 25 Gbps. |
Planning the cabling scheme
Use the following cables to connect the IRF physical ports on the switch:
· QSFP28 ports—QSFP28 transceiver modules and optical fibers or QSFP28 cables.
· QSFP+ ports—QSFP+ transceiver modules and optical fibers or QSFP+ cables.
· SFP28 ports—SFP28 transceiver modules and optical fibers or SFP28 cables.
For a short-distance IRF connection in an equipment room, use a QSFP28/QSFP+/SFP28 cable.
For a long-distance IRF connection, use transceiver modules and optical fibers.
The following subsections describe several H3C recommended IRF connection schemes by using QSFP28 cables and QSFP28 transceiver modules and fibers. All these schemes use a ring topology.
Connecting the IRF member switches in one rack
Connect the IRF member switches (four switches in this example) in a rack as shown in Figure4-4. The switches in the ring topology (see Figure4-5) are in the same order as connected in the rack.
Figure4-4 Connecting the switches in one rack
Connecting the IRF member switches in a ToR solution
You can install IRF member switches in different racks side by side to deploy a ToR solution.
After you install the IRF member switches, power on the switches, and log in to each IRF member switch (see the fundamentals configuration guide in the configuration guides for the switch series) to configure their member IDs, member priorities, and IRF port bindings.
Follow these guidelines when you configure the switches:
· Assign the master switch higher member priority than any other switch.
· Bind physical ports to IRF port 1 on one switch and to IRF port 2 on the other switch. You perform IRF port binding before or after connecting IRF physical ports depending on the software release.
· To bind the ports on an interface module to an IRF port, you must install the interface module first.
· Execute the display irf configuration command to verify the basic IRF settings.
For more information about configuring basic IRF settings, see the virtual technologies configuration guide in the configuration guides for the switch series.
Connect the IRF member switches as planned.
Wear an ESD wrist strap when you connect cables or transceiver modules and fibers. For how to connect them, see H3C Transceiver Modules and Network Cables Installation Guide.
To verify the basic functionality of the IRF fabric after you finish configuring basic IRF settings and connecting IRF ports:
1. Log in to the IRF fabric through the console port of any member switch.
2. Create a Layer 3 interface, assign it an IP address, and make sure the IRF fabric and the remote network management station can reach each other.
3. Use Telnet or SNMP to access the IRF fabric from the network management station. (See the fundamentals configuration guide in the configuration guides for the switch series.)
4. Verify that you can manage all member switches as if they were one node.
5. Display the running status of the IRF fabric by using the commands in Table4-2.
Table4-2 Displaying and maintaining IRF configuration and running status
Task |
Command |
Display information about the IRF fabric. |
display irf |
Display all members’ IRF configurations that take effect at a reboot. |
display irf configuration |
Display IRF fabric topology information. |
display irf topology |
NOTE: To avoid IP address collision and network problems, configure a minimum of one multi-active detection (MAD) mechanism to detect the presence of multiple identical IRF fabrics and handle collisions. For more information about MAD detection, see the virtual technologies configuration guide in the configuration guides for the switch series. |
Power supply failure
Symptom
The power supply status LED on a power supply is not steady green.
For more information about the LEDs on a power supply, see H3C PSR450 Power Module Series User Manual.
Solution
To resolve the issue:
1. Verify that the power cord is connected correctly.
2. Verify that the power source is as required by the switch.
3. Verify that the operating temperature of the switch is in the acceptable range and the power supply has good ventilation.
4. If the issue persists, contact H3C Support.
To replace a power supply, see "Installing/removing power supplies."
Fan tray failure
CAUTION: If multiple fan trays fail when the switch is operating, do not remove the fan trays at the same time. Replace the fan trays one after another and finish replacing each fan tray within 3 minutes. |
The switch uses removable fan trays. Use the LED on a fan tray to identify the fan tray status. If a fan tray fails, see "Installing/removing fan trays" to replace the fan tray. If the issue persists, contact H3C Support.
No display
Symptom
The configuration terminal displays nothing when the switch is powered on.
Solution
1. Verify that the power system is operating correctly.
2. Verify that the console cable is connected correctly.
3. Verify that the console cable does not have any issues and the terminal settings are correct.
Garbled display
Symptom
The configuration terminal has a garbled display.
Solution
1. Verify that the following settings are configured for the terminal:
¡ Baud rate—9600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Flow control—None.
2. If the issue persists, contact H3C Support.
