11-Security Configuration Guide
HomeSupportSwitchesS7500X-G SeriesConfigure & DeployConfiguration GuidesH3C S7500X-G Switch Series Configuration Guides-R7761Pxx-6W10011-Security Configuration Guide
32-SAVI configuration
32-SAVI configuration 110.99 KB
Configuring SAVI
About SAVI
Source Address Validation Improvement (SAVI) checks the validity of the source addresses of global unicast IPv6 packets. It implements the validity check by using the ND snooping, DHCPv6 snooping, ND attack detection, and IP source guard features. SAVI checks only global unicast addresses and forwards the packets that pass the validity check. Packets sourced from an invalid address are dropped.
SAVI application scenarios
DHCPv6-only
The hosts connected to the SAVI-enabled device obtain addresses only through DHCPv6. DHCPv6 messages, ND messages (RA and RR messages excluded), and IPv6 data packets are checked based on DHCPv6 snooping entries and static IPv6 source guard binding entries.
SLAAC-only
The hosts connected to the SAVI-enabled device obtain addresses only through Stateless Address Autoconfiguration (SLAAC). In this scenario, SAVI drops all DHCPv6 messages. Only ND messages and IPv6 data packets are checked based on DHCPv6 snooping entries and static IPv6 source guard binding entries.
DHCPv6+SLAAC
The hosts connected to the SAVI-enabled device obtain addresses through DHCPv6 and SLAAC. In this scenario, SAVI checks all DHCPv6 messages, ND messages, and IPv6 data packets based on DHCPv6 snooping entries, ND snooping entries, and static IPv6 source guard binding entries.
Restrictions and guidelines: SAVI
SE interface modules and the LSCM1GT48SC0 interface module do not support SAVI.
SAVI tasks at a glance
To configure SAVI, perform the following tasks:
1.     Enabling SAVI
2.     Configuring IPv6 source guard
3.     Configuring DHCPv6 snooping
4.     Configuring ND parameters
5.     (Optional.) Setting the entry deletion delay
6.     (Optional.) Enabling packet spoofing logging and filtering entry logging
Enabling SAVI
2.     Enable SAVI.
ipv6 savi strict
By default, SAVI is disabled.
1.     Enable IPv6 source guard on an interface.
2.     (Optional.) Configure static IPv6SG bindings.
For more information about IPv6 source guard configuration, see "Configuring IP source guard."
Enable only DHCPv6 snooping for the SLAAC-only scenario.
1.     Enable DHCPv6 snooping.
2.     Specify DHCPv6 snooping trusted ports.
3.     Enable recording client information in DHCPv6 snooping entries.
For more information about DHCPv6 snooping configuration, see Layer 3—IP Services Configuration Guide.
Enable only ND attack detection for the DHCPv6-only scenario.
1.     Enable ND snooping for global unicast addresses.
For more information about ND snooping, see IPv6 basics in Layer 3—IP Services Configuration Guide.
2.     Enable ND attack detection.
For more information about ND attack detection, see "Configuring ND attack defense."
3.     Specify ND trusted ports.
For more information about ND trusted ports, see "Configuring ND attack defense."
The entry deletion delay is the period of time that the device waits before deleting the DHCPv6 snooping entries and ND snooping entries for a down port.
2.     Set the entry deletion delay.
ipv6 savi down-delay delay-time
By default, the entry deletion delay is 30 seconds.
Packet spoofing logging enables the device to generate log messages for the spoofed packets detected by SAVI.
Filtering entries are effective bindings used for filtering IPv6 packets by the source IPv6 address. Filtering entry logging enables the device to generate log messages for filtering entries. A log message contains the IPv6 address, MAC address, VLAN, and interface of a filtering entry.
The device sends packet spoofing and filtering entry log messages to the information center. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
2.     Enable packet spoofing logging.
ipv6 savi log enable spoofing-packet [ interval interval | total-number number ] *
By default, packet spoofing logging is disabled.
3.     Enable filtering entry logging.
ipv6 savi log enable filter-entry
By default, filtering entry logging is disabled.
SAVI configuration examples
Example: Configuring DHCPv6-only SAVI
As shown in Figure 1, configure SAVI on the switch to meet the following requirements:
·     Clients obtain IPv6 addresses only through DHCPv6.
·     SAVI checks the source addresses of DHCPv6 messages, ND messages (RA and RR messages excluded), and IPv6 data packets on Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3.
Figure 1 Network diagram
# Enable SAVI.
<Switch> system-view
[Switch] ipv6 savi strict
# Assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/3 to VLAN 2.
[Switch] vlan 2
[Switch-vlan2] port ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2 ten-gigabitethernet 3/0/3
[Switch-vlan2] quit
# Enable DHCPv6 snooping.
[Switch] ipv6 dhcp snooping enable
# Configure Ten-GigabitEthernet 3/0/1 as a DHCPv6 snooping trusted port.
[Switch] interface ten-gigabitethernet 3/0/1
[Switch-Ten-GigabitEthernet3/0/1] ipv6 dhcp snooping trust
[Switch-Ten-GigabitEthernet3/0/1] quit
# Enable recording DHCPv6 snooping entries on Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3.
[Switch] interface ten-gigabitethernet 3/0/2
[Switch-Ten-GigabitEthernet3/0/2] ipv6 dhcp snooping binding record
[Switch-Ten-GigabitEthernet3/0/2] quit
[Switch] interface ten-gigabitethernet 3/0/3
[Switch-Ten-GigabitEthernet3/0/3] ipv6 dhcp snooping binding record
[Switch-Ten-GigabitEthernet3/0/3] quit
# Enable ND attack detection.
[Switch] vlan 2
[Switch-vlan2] ipv6 nd detection enable
[Switch-vlan2] quit
# Enable IPv6 source guard on Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/3.
[Switch-Ten-GigabitEthernet3/0/2] ipv6 verify source ip-address mac-address
[Switch-Ten-GigabitEthernet3/0/3] ipv6 verify source ip-address mac-address
Example: Configuring SLAAC-only SAVI
As shown in Figure 2, configure SAVI on Switch B to meet the following requirements:
·     Hosts obtain IPv6 addresses only through SLAAC.
·     DHCPv6 messages are dropped on Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/3 in VLAN 2.
·     SAVI checks the source addresses of ND messages and IPv6 data packets on Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2.
Figure 2 Network diagram
# Enable SAVI.
[SwitchB] ipv6 savi strict
[SwitchB] vlan 2
[SwitchB-vlan2] port ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2 ten-gigabitethernet 3/0/3
[SwitchB-vlan2] quit
# Enable ND snooping for global unicast addresses in VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] ipv6 nd snooping enable global
# Enable ND attack detection for VLAN 2.
[SwitchB-vlan2] ipv6 nd detection enable
[SwitchB] ipv6 dhcp snooping enable
# Configure Ten-GigabitEthernet 3/0/3 as an ND trusted port.
[SwitchB] interface ten-gigabitethernet 3/0/3
[SwitchB-Ten-GigabitEthernet3/0/3] ipv6 nd detection trust
[SwitchB-Ten-GigabitEthernet3/0/3] quit
# Enable IPv6 source guard on Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2.
[SwitchB] interface ten-gigabitethernet 3/0/1
[SwitchB-Ten-GigabitEthernet3/0/1] ipv6 verify source ip-address mac-address
[SwitchB-Ten-GigabitEthernet3/0/1] quit
[SwitchB] interface ten-gigabitethernet 3/0/2
[SwitchB-Ten-GigabitEthernet3/0/2] ipv6 verify source ip-address mac-address
[SwitchB-Ten-GigabitEthernet3/0/2] quit
Example: Configuring DHCPv6+SLAAC SAVI
As shown in Figure 3, configure SAVI on Switch B to meet the following requirements:
·     Hosts obtain IP addresses through DHCPv6 or SLAAC.
·     SAVI checks the source addresses of DHCPv6 messages, ND messages, and IPv6 data packets on Ten-GigabitEthernet 3/0/3 through Ten-GigabitEthernet 3/0/5.
Figure 3 Network diagram
# Enable SAVI.
# Assign Ten-GigabitEthernet 3/0/1 through Ten-GigabitEthernet 3/0/5 to VLAN 2.
[SwitchB] vlan 2
[SwitchB-vlan2] port ten-gigabitethernet 3/0/1 ten-gigabitethernet 3/0/2 ten-gigabitethernet 3/0/3 ten-gigabitethernet 3/0/4 ten-gigabitethernet 3/0/5
# Enable recording DHCPv6 snooping entries on Ten-GigabitEthernet 3/0/3 through Ten-GigabitEthernet 3/0/5.
[SwitchB-Ten-GigabitEthernet3/0/3] ipv6 dhcp snooping binding record
[SwitchB] interface ten-gigabitethernet 3/0/4
[SwitchB-Ten-GigabitEthernet3/0/4] ipv6 dhcp snooping binding record
[SwitchB-Ten-GigabitEthernet3/0/4] quit
[SwitchB] interface ten-gigabitethernet 3/0/5
[SwitchB-Ten-GigabitEthernet3/0/5] ipv6 dhcp snooping binding record
[SwitchB-Ten-GigabitEthernet3/0/5] quit
[SwitchB-Ten-GigabitEthernet3/0/1] ipv6 dhcp snooping trust
[SwitchB] vlan 2
# Configure Ten-GigabitEthernet 3/0/2 as an ND trusted port.
[SwitchB-Ten-GigabitEthernet3/0/2] ipv6 nd detection trust
# Enable IPv6 source guard on Ten-GigabitEthernet 3/0/3 through Ten-GigabitEthernet 3/0/5.
[SwitchB-Ten-GigabitEthernet3/0/3] ipv6 verify source ip-address mac-address
[SwitchB-Ten-GigabitEthernet3/0/4] ipv6 verify source ip-address mac-address
[SwitchB-Ten-GigabitEthernet3/0/5] ipv6 verify source ip-address mac-address
