20-GPON
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10020-GPON
03-GPON PoE commands
03-GPON PoE commands 39.57 KB
GPON PoE commands
onu poe enable
Use onu poe enable to enable PoE for all UNIs of an ONU.
Use undo onu poe enable to disable PoE for all UNIs of an ONU.
onu poe enable
undo onu poe enable
PoE is enabled for UNIs of an ONU.
ONU interface view
On an ONU interface, the onu poe enable and uni poe enable commands are mutually exclusive.
# Enable PoE for all UNIs of the ONU bound to ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] onu poe enable
uni poe enable
uni poe enable
Use uni poe enable to enable PoE for a single UNI.
Use undo uni poe enable to disable PoE for a single UNI.
uni uni-number poe enable
undo uni uni-number poe enable
PoE is disabled for a single UNI. The default of the onu poe enable command takes effect preferentially, and PoE is enabled for all UNIs of an ONU.
ONU interface view
uni-number: Specifies a UNI by its number in the range of 1 to the number of UNIs on the ONU. The maximum number of UNIs supported on an ONU is 32.
# Enable PoE for UNI 1.
[Sysname-Onu1/0/1:1] uni 1 poe enable
onu poe enable
