17-VXLAN Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10017-VXLAN Command Reference
Table of Contents
Related Documents
01-VXLAN commands
01-VXLAN commands 712.65 KB
VXLAN commands· 1
Basic VXLAN commands· 1
ac statistics enable· 1
arp suppression enable· 2
arp suppression mode· 3
description· 4
display arp suppression vsi 4
display ipv6 nd suppression vsi 6
display l2vpn m-lag arp· 7
display l2vpn m-lag arp suppression· 8
display l2vpn m-lag mac-address· 9
display l2vpn m-lag nd· 11
display l2vpn m-lag nd suppression· 12
display l2vpn mac-address· 13
display l2vpn mac-address mac-move· 15
display l2vpn service-instance· 16
display l2vpn split-group· 19
display l2vpn vsi 20
display vxlan tunnel 24
display vxlan tunnel-interface· 25
display vxlan tunnel termination· 27
encapsulation· 28
flooding disable· 30
ipv6 nd suppression enable· 31
ipv6 nd suppression mode· 32
l2vpn enable· 33
l2vpn statistics interval 33
mac-address static vsi 34
mac-based ac· 35
overlay oam enable· 36
ping vxlan· 37
ping vxlan ipv6· 39
private-vsi 43
private-vsi secondary· 43
reserved vxlan· 44
reset arp suppression vsi 45
reset ipv6 nd suppression vsi 45
reset l2vpn mac-address· 46
reset l2vpn mac-address mac-move· 46
reset l2vpn statistics ac· 47
reset l2vpn statistics tunnel 47
reset l2vpn statistics vsi 48
restrain· 48
selective-flooding mac-address· 49
service-instance· 50
shutdown· 51
split-group· 51
statistics enable (Ethernet service instance view) 52
statistics enable (tunnel interface view) 53
statistics enable (VSI view) 54
tracert vxlan· 54
tracert vxlan ipv6· 57
tunnel 59
tunnel global source-address· 60
tunnel statistics enable· 61
tunnel statistics vxlan auto· 62
vsi 63
vxlan· 63
vxlan default-decapsulation enable· 64
vxlan default-decapsulation source· 65
vxlan invalid-vlan-tag discard· 66
vxlan ipv6 default-decapsulation enable· 66
vxlan ipv6 default-decapsulation source· 67
vxlan local-mac report 68
vxlan multicast-group member enable· 68
vxlan tunnel mac-learning disable· 70
vxlan udp-port 70
vxlan vlan-based· 71
vxlan vni 72
vxlan-dci-tunnel outer dscp· 73
vxlan-tunnel outer dscp· 74
xconnect vsi 75
VXLAN IP gateway commands· 77
arp distributed-gateway dynamic-entry synchronize· 77
arp send-rate· 77
bandwidth· 78
default 79
description· 79
display interface vsi-interface· 80
distributed-gateway local 83
gateway subnet 84
gateway vsi-interface· 85
interface vsi-interface· 86
ipv6 nd distributed-gateway dynamic-entry synchronize· 86
mac-address· 87
mtu· 88
reset counters interface vsi-interface· 88
shutdown· 89
vtep group member local 89
vtep group member remote· 90
vxlan tunnel arp-learning disable· 91
vxlan tunnel nd-learning disable· 91
OVSDB commands· 92
ovsdb server bootstrap ca-certificate· 92
ovsdb server enable· 93
ovsdb server pki domain· 94
ovsdb server pssl 94
ovsdb server ptcp· 95
ovsdb server ssl 96
ovsdb server tcp· 97
vtep access port 98
vtep acl disable· 99
vtep enable· 99
VXLAN commands
The VXLAN feature is available only when the system operating mode is expert. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
Only the following interfaces support the VXLAN feature:
·     Service interfaces on the LSCM2SRP6C4Y06A0 MPUs.
·     Service interfaces on the LSCM3SRP6C4Y06A0 MPUs.
·     All interfaces on the SF interface modules.
·     All interfaces on the SD interface modules.
Use ac statistics enable to enable packet statistics for Ethernet service instances of a VLAN.
Use undo ac statistics enable to disable packet statistics for Ethernet service instances of a VLAN.
The packet statistics feature is disabled for Ethernet service instances of a VLAN.
VLAN view
This command enables packet statistics for the Ethernet service instances automatically created for VLAN-based VXLAN assignment.
Before you enable this feature, you must use the vxlan vlan-based command to enable VLAN-based VXLAN assignment.
# Map VLAN 10 to VXLAN 100, and enable packet statistics for Ethernet service instances of VLAN 10.
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
vxlan vlan-based
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
VSI view:
arp suppression enable [ no-broadcast ]
VLAN view:
ARP flood suppression is disabled.
VSI view
VLAN view
no-broadcast: Disables flooding the ARP requests that do not match any ARP flood suppression entries.
Application scenarios
ARP flood suppression reduces ARP request broadcasts and saves CPU resources by enabling the VTEP to reply to ARP requests on behalf of VMs.
Operating mechanism
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found and the no-broadcast keyword is not specified, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression and disable flooding the ARP requests that do not match any ARP flood suppression entries for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable no-broadcast
# Enable ARP flood suppression for VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] arp suppression enable
Use arp suppression mode to set the ARP flood suppression mode.
Use undo arp suppression mode to restore the default.
arp suppression mode { proxy-reply | unicast-forward } [  mismatch-discard ]
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device replies to the ARP request on behalf of the target IP address. The ARP reply carries the following information:
·     Sender IP address—Target IP address in the ARP request.
·     Sender MAC address—MAC address in the matching ARP flood suppression entry.
·     Source MAC address—MAC address in the matching ARP flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device acts as follows:
1.     Replaces the target MAC address and destination MAC address in the ARP request with the MAC address in the entry.
2.     Unicasts the ARP request.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an ARP request that is not targeted at the device and does not match any ARP flood suppression entry. If you do not specify this keyword, the device will broadcast such an ARP request.
The device does not forward ARP requests in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ARP entry learning errors caused by the delay in refreshing ARP flood suppression entries at the expense of high system resource usage.
# Enable ARP flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
In standalone mode:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                    Link ID    Aging(min)
1.1.1.2         000f-e201-0101 vsi1                        0x70000    14
1.1.1.3         000f-e201-0202 vsi1                        0x80000    18
1.1.1.4         000f-e201-0203 vsi2                        0x90000    10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging(min)
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted.
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
In standalone mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI name         Link ID    Aging (min)
1000::2                 000f-e201-0101  vsi1             0x70000    5
1000::3                 000f-e201-0202  vsi1             0x80000    5
1000::4                 000f-e201-0203  vsi2             0x90000    5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID
Aging (min)
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted.
Use display l2vpn m-lag arp to display L2VPN ARP entries on an M-LAG member device.
display l2vpn m-lag arp [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ count | ip-address ] ]
local: Specifies locally learned L2VPN ARP entries.
remote: Specifies M-LAG-synchronized L2VPN ARP entries.
count: Displays the number of L2VPN ARP entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ARP entries for the public instance and all VPN instances.
# Display all L2VPN ARP entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp
Flags: D – Dynamic   L - Local   R – Remote   S – Static   I - Invalid
       G - Gateway   V - MLAG Virtual
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address      VSI index      Link ID       Flags
10.1.1.1        0003-0003-0003   0              0x1           DL
10.1.1.11       0001-0001-0001   0              0x1           DL
10.1.1.12       0001-0001-0011   0              0x2           DR
10.1.1.13       0001-0001-0021   0              0x2           DR
10.1.1.101      0001-0011-0101   0              0x1           SL
10.1.1.102      0001-0011-0102   0              0x1           SL
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033   0              0x1           DL
11.1.1.11       0011-0011-0011   0              0x1           DL
# Display the total number of L2VPN ARP entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp count
Total number of entries: 8
VSI interface.
Link ID
Flags
ARP entry type:
·     D—The entry is a valid dynamically learned entry.
·     L—The entry is a valid local entry.
·     R—The entry is a valid M-LAG-synchronized entry.
·     S—The entry is a valid static entry.
·     I—The entry is invalid. Possible reasons:
¡     The VSI has been administratively shut down by using the shutdown command.
¡     The outgoing tunnel interface does not exist.
·     G—The entry is for a gateway.
·     V—The entry is for the M-LAG virtual IPv4 address of a gateway interface.
Use display l2vpn m-lag arp suppression to display L2VPN ARP flood suppression entries on an M-LAG member device.
display l2vpn m-lag arp suppression [ local | remote ] [ count | vsi vsi-name [ count | ip-address ] ]
local: Specifies L2VPN ARP flood suppression entries that are learned locally.
remote: Specifies L2VPN ARP flood suppression entries that are synchronized by M-LAG.
count: Displays the number of L2VPN ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ARP flood suppression entries for all VSIs.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ARP flood suppression entries.
# Display all L2VPN ARP flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp suppression
Flags: D - Dynamic   L – Local   R – Remote   S - Static   I – Invalid
VSI name: vpna
IP address      MAC address     Link ID         Flags
10.1.1.12       0002-0002-0002  0x1             DL
10.1.1.13       0002-0002-0002  0x2             RI
10.1.1.101      0001-0011-0101  0x2             SR
# Display the total number of L2VPN ARP flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp suppression count
Total number of entries: 3
Link ID
Flags
ARP flood suppression entry type:
Use display l2vpn m-lag mac-address to display L2VPN MAC address entries on an M-LAG member device.
display l2vpn m-lag mac-address [ local | remote ] [ count | vsi vsi-name [ count | mac-address ] ]
local: Specifies L2VPN MAC address entries that are learned locally.
remote: Specifies L2VPN MAC address entries that are synchronized by M-LAG.
count: Displays the number of L2VPN MAC address entries. If you do not specify this keyword, the command displays detailed information about L2VPN MAC address entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN MAC address entries for all VSIs.
mac-address: Specifies a MAC address. The MAC address is in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays all L2VPN MAC address entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN MAC address entries.
# Display all L2VPN MAC address entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag mac-address
Flags: D – Dynamic   L - Local   R – Remote   S – Static   A - MAC-authentication
VSI name: bbb
MAC address           Link ID       Interface       Flags
0000-0000-000a        0x1           BAGG10          DL
0000-0000-0009        0x1           Tunnel1         DL
# Display the total number of L2VPN MAC address entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag mac-address count
Total number of entries: 2
Table 5 Command output
Link ID
Outgoing interface.
Flags
MAC address entry type:
·     A—The entry is learned by MAC authentication.
Use display l2vpn m-lag nd to display L2VPN ND entries on an M-LAG member device.
display l2vpn m-lag nd [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ ipv6-address | count ] ]
local: Specifies locally learned L2VPN ND entries.
remote: Specifies M-LAG-synchronized L2VPN ND entries.
count: Displays the number of L2VPN ND entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND entries.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ND entries for the public instance and all VPN instances.
# Display all L2VPN ND entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd
Flags: D - Dynamic   L – Local  R – Remote   S - Static   I - Invalid
VPN instance: vpna                            Interface: Vsi-interface1
IPv6 address :   20::2
MAC address  :   0001-0001-0001          Flags        :   DL
VSI index    :   0                       Link ID      :   0x1
# Display the total number of L2VPN ND entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd count
Total number of entries: 1
Table 6 Command output
VSI interface.
Flags
ND entry type:
·     V—The entry is for the M-LAG virtual IPv6 address of a gateway interface.
Link ID
Use display l2vpn m-lag nd suppression to display L2VPN ND flood suppression entries on an M-LAG member device.
display l2vpn m-lag nd suppression [ local | remote ] [ count | vsi vsi-name [ ipv6-address | count ] ]
local: Specifies L2VPN ND flood suppression entries that are learned locally.
remote: Specifies L2VPN ND flood suppression entries that are synchronized by M-LAG.
count: Displays the number of L2VPN ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ND flood suppression entries for all VSIs.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ND flood suppression entries.
# Display all L2VPN ND flood suppression entries on the local M-LAG member device.
[Sysname]display l2vpn m-lag nd suppression
VSI name: vpna
IPv6 address                            MAC address     Link ID   Flags
11::8                                   72cb-ce9b-0a06  0x1       DL
11::9                                   0001-0001-0001  0x2       SR
# Display the total number of L2VPN ND flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd suppression count
Table 7 Command output
Link ID
Flags
ND flood suppression entry type:
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
·     Remote-MAC entries advertised through BGP EVPN.
·     Manually added static remote-MAC entries.
·     Remote-MAC entries issued through OpenFlow.
·     Remote-MAC entries issued through OVSDB.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
* - The output interface is issued to another VSI
MAC Address    State     VSI Name                        Link ID/Name   Aging
0001-0001-0001 Static    aaa                             Tunnel10       NotAging
52f6-bc1e-0d06 Dynamic   vpna                            XGE3/0/1       Aging
0000-0000-000c Dynamic   TTP_vxlan10                     XGE3/0/1*       Aging
--- 3 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
2 mac address(es) found
Table 8 Command output
Entry state:
·     Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
·     Static—Static remote-MAC entry.
·     EVPN—Remote-MAC entry advertised through BGP EVPN.
·     OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow.
·     OVSDB—Remote-MAC entry issued by a remote controller through OVSDB.
Link ID/Name
For a local MAC address, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address.
For a remote MAC address, this field displays the tunnel interface name.
The asterisk suffix (*) indicates that the MAC address belongs to another VSI and is issued by the controller through TTP.
Aging
Entry aging state:
·     Aging.
·     NotAging.
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address      : 0000-0000-000b
VSI Name         : vpn1
VXLAN ID         : 123
Interface        : XGE3/0/1
Link ID          : 1
State            : Dynamic
Aging            : Aging
MAC address      : 0000-0000-abcd
VSI name         : TTP_vxlan10
VXLAN ID         : 10
Link ID(VSI name): 1(TTP_vxlan20)
State            : Openflow
Aging            : Aging
Table 9 Command output
VSI Name
VSI name in one of the following formats:
·     vsi-name—VSI name for the MAC address entry.
·     vsi1 (vsi2)—The MAC address belongs to vsi1 and has been issued to vsi2 by the controller.
Link ID
Entry state:
·     Openflow—Remote-MAC entry issued by a remote controller through OpenFlow.
Aging
Entry aging state:
·     Aging.
·     NotAging.
Use display l2vpn mac-address mac-move to display MAC move records for VSIs.
In standalone mode:
display l2vpn mac-address mac-move [ slot slot-number ]
In IRF mode:
display l2vpn mac-address mac-move [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays MAC move records on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays MAC move records on the global active MPU. (In IRF mode.)
When a MAC address frequently moves between two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
This command displays the MAC move events that have occurred on VSIs since startup of the device. The MAC move records with the same MAC address, VSI name, source port, and current port are considered to be one record.
(In standalone mode.) A card can generate a maximum of 200 MAC address move records.
(In IRF mode.) A card on an IRF member device can generate a maximum of 200 MAC address move records.
# Display MAC move records for all VSIs.
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7      VSI name   : 3
Current port: XGE3/0/1 srv2       Source port: XGE3/0/2 srv3
Last time   : 2019-02-19 20:44:15 Move count : 1
---  1 MAC address moving records found  ---
Table 10 Command output
Current port
Interface to which the MAC address was moved.
Source port
Interface from which the MAC address was moved.
Last time
Last time when the MAC address was moved.
Move count
Number of times that the MAC address has moved.
Use display l2vpn service-instance to display information about Ethernet service instances.
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 2, 2 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                ID    Owner                           LinkID State Type
XGE1/0/1                 3     vsi12                           1      Up    VSI
XGE1/0/1                 4     vsi13                           1      Up    VSI
Table 11 Command output
Total number of ACs
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down).
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface.
ID
Ethernet service instance ID.
Owner
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI.
LinkID
Ethernet service instance's link ID on the VSI.
Ethernet service instance state:
·     Up.
·     Down.
L2VPN type of the Ethernet service instance:
·     VSI.
·     VPWS.
# Display detailed information about all Ethernet service instances on Ten-GigabitEthernet 3/0/1.
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 3/0/1 verbose
Interface: XGE3/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    Bandwidth     : -
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
Table 12 Command output
Service Instance
Type and traffic match mode of the Ethernet service instance:
·     Dynamic (M-LAG)—Dynamic Ethernet service instance created on the peer link, in VLAN-based traffic match mode.
·     Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode.
·     Manual—Static Ethernet service instance in VLAN-based traffic match mode.
Encapsulation
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a frame match criterion, the command does not display this field.
Bandwidth
Bandwidth limit in kbps. If no bandwidth limit is set for the Ethernet service instance, Unlimited is displayed.
Link ID
·     Up.
·     Down.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the Ethernet service instance.
·     Disabled—The packet statistics feature is disabled for the Ethernet service instance.
Input Statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
Output Statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
service-instance
Use display l2vpn split-group to display split horizon group information.
display l2vpn split-group [ id group-id | name split-group-name ] [ vsi vsi-name ]
id group-id: Specifies a split horizon group by its ID in the range of 1 to 4. The ID must be a digit.
name split-group-name: Specifies a split horizon group by its name, a case-sensitive string of 1 to 31 characters.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays split horizon group information for all VSIs.
If the id and name keywords are not specified, this command displays information about all split horizon groups.
# Display information about all split horizon groups.
<Sysname> display l2vpn split-group
Total number of split horizon groups: 2
Split horizon group name: aa
Split horizon group ID: 1
Tun1
Tun2
Tun3
Split horizon group name: bb
Split horizon group ID: 2
Tun4
# Display information about the split horizon group with group ID 1.
Tun1
Tun2
Tun3
Tun4
# Display information about the split horizon group named aa.
<Sysname> display l2vpn split-group name aa
Tun1
Tun2
Tun3
# Display split horizon group information for VSI vsi1.
<Sysname> display l2vpn split-group vsi vsi1
Interface                 VSI name                        Link ID
Tun1                      vsi1                            1
Tun2                      vsi1                            2
Tun3                      vsi1                            1
Table 13 Command output
Name of the VXLAN tunnel interface.
Link ID
Link ID assigned to the VXLAN tunnel within the VSI.
split-group
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
Table 14 Command output
MTU
MTU on the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Input statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Input Rate              :
    Bytes per second   : 0
    Packets per second : 0
  Output Rate             :
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy      SG ID
    Tunnel1              0x5000001  Up     Manual    Disabled         1
    Tunnel2              0x5000002  Up     Manual    Disabled         2
    MTunnel0             0x6002710  Up     Auto      Disabled         -
  ACs:
    AC                               Link ID    State    Type
    XGE3/0/1 srv1000                 0          Up       Manual
Table 15 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Bandwidth
If no bandwidth limit is set for the VSI, Unlimited is displayed.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
Multicast Restrain
Multicast restraint bandwidth (in kbps).
Unknown unicast restraint bandwidth (in kbps).
MAC Learning
State of the MAC learning feature.
MAC Table Limit
Maximum number of MAC address entries on the VSI.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI.
·     Disabled—Flooding is disabled on the VSI.
Statistics
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input statistics
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output statistics
Input Rate
Incoming traffic rate for the VSI, in bps and pps.
Output Rate
Outgoing traffic rate for the VSI, in bps and pps.
Gateway Interface
VSI interface name.
VLAN ID
VLAN mapped to the VXLAN. If the VXLAN is not mapped to a VLAN, this field displays a hyphen (-).
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Blocked—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. ‌
·     Down—The tunnel interface is down.
Tunnel assignment method:
·     Auto—The tunnel was automatically assigned to the VXLAN:
¡     For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs.
¡     For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic.
·     Manual—The tunnel was manually assigned to the VXLAN.
Flood proxy
Flood proxy state.
ACs
ACs that are bound to the VSI.
Link ID
AC's link ID on the VSI.
AC state:
·     Up.
·     Down.
SG ID
Split horizon group ID. For default split horizon group IDs, this field displays a hyphen (-).
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 1 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
tunnel tunnel-number: Specifies a tunnel number. The value range for the tunnel-number argument is 1 to 5120.  If you do not specify this option, the command displays information for all tunnels of the specified VXLAN.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
Total number of VXLAN tunnels: 1
VXLAN ID: 10, VSI name: aaa, Total tunnels: 1 (1 up, 0 down, 0 defect, 0 blocked)
Tunnel name Source          Destination     State   Type   Flood proxy Out VNI
Tun1        1.1.1.1         3.3.3.3         UP      Manual Disabled    -
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
# Display information for Tunnel 17 of VXLAN 77.
<Sysname> display vxlan tunnel vxlan-id 17 tunnel 77
Interface: Tun77
  Source     : -
  Destination: -
  State      : Down
  Type       : Manual
  Flood proxy: Disabled
  Out VNI    : -
Table 16 Command output
Tunnel state:
Flood proxy
Flood proxy state. This field is not supported in the current software version.
Out VNI
Remote VXLAN ID mapped to the local VXLAN ID.
tunnel
vxlan
Use display vxlan tunnel-interface to display information about VXLAN tunnel interfaces.
display vxlan tunnel-interface [ tunnel number [ verbose ] ]
tunnel number: Specifies an existing tunnel interface number. If you do not specify a VXLAN tunnel interface, this command displays information about all VXLAN tunnel interfaces.
verbose: Displays detailed information about VXLAN tunnel interfaces. If you do not specify this keyword, the command displays brief information about VXLAN tunnel interfaces.
# Display brief information about all VXLAN tunnel interfaces.
<Sysname> display vxlan tunnel-interface
Tunnel name Source          Destination     State    Type    Uptime
Tunnel10    192.2.2.2       192.5.5.5       Up       Manual  00:00:27
# Display detailed information about VXLAN tunnel interface 10.
<Sysname> display vxlan tunnel-interface tunnel 10 verbose
Tunnel Name     : Tunnel10
Source          : 192.2.2.2
Destination     : 192.5.5.5
State           : Up
Type            : Manual
MAC learning    : Enabled
Down reason     : -
Uptime          : 00:00:19
Table 17 Command output
Source
Tunnel source address.
Destination
Tunnel destination address.
Tunnel interface state:
·     Up.
·     Down.
·     Auto—The tunnel was automatically assigned to VXLANs by EVPN.
·     Manual—The tunnel was manually assigned to VXLANs.
MAC learning
Remote-MAC address learning state:
·     Enabled.
·     Disabled.
Uptime
Uptime of the VXLAN tunnel:
·     hh:mm:ss—The tunnel has been up for less than 24 hours.
·     xxxxhxxm—The tunnel has been up for more than 24 hours and less than 9999 hours.
·     ****hxxm—The tunnel has been up for more than 9999 hours.
·     -—The tunnel is down.
tunnel
vxlan
Use display vxlan tunnel termination to display IP addresses terminated by VXLAN tunnels.
Use this command to view the IP addresses terminated by the current VXLAN tunnels after you enable default VXLAN decapsulation. VXLAN tunnels can terminate the following types of IP addresses:
·     Virtual VTEP or ED address configured by using the evpn m-lag group command.
·     Local M-LAG address configured by using the evpn m-lag local command.
·     Peer-link interface IP address.
·     Virtual ED address configured by using the evpn edge group command.
·     BGP peer addresses.
# Display the IP addresses terminated by VXLAN tunnels.
<Sysname> display vxlan tunnel termination
Flags: G - Mlag Group address        L - Mlag Local address
       P - Peer-link source address  E - Edge Group address
       B - BGP Local address
Total number of tunnel terminations: 1
IPV4 address     Flags
1.1.1.1          G
Table 18 Command output
Total number of all IP addresses terminated by VXLAN tunnels.
Flags
Flag:
·     G—Virtual VTEP address.
·     L—Local M-LAG address.
·     P—Peer-link interface IP address.
·     E—Virtual ED address.
·     B—BGP peer address.
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid { vlan-id | vlan-id-list } [ only-tagged ]
encapsulation s-vid { vlan-id | vlan-id-list } c-vid { vlan-id-list | all }
encapsulation c-vid { vlan-id | vlan-id-list }
encapsulation { tagged | untagged }
undo encapsulation
An Ethernet service instance does not contain a frame match criterion.
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
c-vid: Matches frames that are tagged with the specified inner 802.1Q VLAN IDs.
vlan-id: Specifies an 802.1Q VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged frames, specify the only-tagged keyword.
·     To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
all: Specifies all 802.1Q VLAN IDs.
tagged: Matches any frames that have an 802.1Q VLAN tag.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
The encapsulation s-vid vlan-id [ only-tagged ] and encapsulation s-vid vlan-id c-vid { vlan-id | all } commands can specify the same outer VLAN ID for two Ethernet service instances on an interface. Frames that match both Ethernet service instances are assigned to the Ethernet service instance configured by using the encapsulation s-vid vlan-id c-vid { vlan-id | all } command.
When you create an Ethernet service instance that matches single VLAN tags and an Ethernet service instance that matches multiple VLAN tags on the same interface, follow these restrictions and guidelines:
·     If you execute both the encapsulation c-vid vlan-id and encapsulation c-vid vlan-id-list commands and the vlan-id argument value falls within the vlan-id-list argument value, packets with the vlan-id argument value cannot be matched.
·     If you execute both the encapsulation s-vid vlan-id and encapsulation s-vid vlan-id-list commands and the vlan-id argument value falls within the vlan-id-list argument value, packets with the vlan-id argument value cannot be matched.
If you configure the encapsulation tagged criterion for an Ethernet service instance, you must map the Ethernet service instance in Ethernet access mode to a VSI.
When you configure frame match criteria of different Ethernet service instances on an interface, follow these restrictions and guidelines:
·     When you configure s-vid and c-vid by using the vlan-id to vlan-id format, the s-vid vlan-id to vlan-id or c-vid vlan-id to vlan-id options can be the same but cannot overlap across different Ethernet service instances with different match specifications.
·     If both the encapsulation s-vid and encapsulation s-vid c-vid criteria exist on different Ethernet service instances, the specified outer VLAN IDs of different criteria can be identical.
·     If both the encapsulation s-vid and encapsulation c-vid criteria exist on different Ethernet service instances, the specified inner VLAN IDs and outer VLAN IDs cannot be identical.
·     If multiple Ethernet service instances match both the inner and outer VLAN IDs, the following restrictions apply:
¡     If the matching outer VLAN IDs are different, the inner VLAN IDs can be identical.
¡     If the matching inner VLAN IDs are different, the outer VLAN IDs can be identical.
·     Ethernet service instances matching only the outer VLAN IDs conflict with those matching only the inner VLAN IDs. Do not configure both types of Ethernet service instances.
An Ethernet service instance can contain only one frame match criterion. To change the frame match criterion, first execute the undo encapsulation command to remove the original criterion. When you remove the frame match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
If you specify the vlan-id-list or tagged parameter in this command for an Ethernet service instance, the Ethernet service instance does not support MAC authentication and can only be mapped to a VSI in Ethernet access mode.
For Ethernet service instances on the SC cards prefixed with LSCM2 and the SD interface modules, this command does not support specifying both s-vid vlan-id to vlan-id and c-vid vlan-id to vlan-id.
# Configure Ethernet service instance 1 on Ten-GigabitEthernet 3/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet3/0/1-srv1] encapsulation s-vid 111
flooding disable
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces of the VSI.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
You must specify the unknown-multicast, broadcast, and unknown-unicast keywords simultaneously when you execute this command. You cannot specify only one or two of them.
If you execute both the flooding disable all all-direction and selective-flooding mac-address commands in VSI view, the selective-flooding mac-address command does not take effect.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ipv6 nd suppression enable [ no-broadcast ]
ND flood suppression is disabled.
VSI view
no-broadcast: Disables flooding the ND requests that do not match any ND flood suppression entries.
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found and the no-broadcast keyword is not specified, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression and disable flooding the ND requests that do not match any ND flood suppression entries for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable no-broadcast
Use ipv6 nd suppression mode to set the ND flood suppression mode.
Use undo ipv6 nd suppression mode to restore the default.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device replies to the NS packet on behalf of the target IP address. The replied NA packet carries the following information:
·     Sender IP address—Target IP address in the NS packet.
·     Source MAC address—MAC address in the matching ND flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device acts as follows:
1.     Replaces the destination MAC address in the NS packet with the MAC address in the entry.
2.     Unicasts the NS packet.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an NS packet that is not targeted at the device and does not match any ND flood suppression entry. If you do not specify this keyword, the device will broadcast such an NS packet.
The device does not forward NS packets in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ND entry learning errors caused by the delay in refreshing ND flood suppression entries at the expense of high system resource usage.
# Enable ND flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
Use l2vpn statistics interval to set the L2VPN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The L2VPN statistics collection interval is 15 minutes.
Interval: Sets the L2VPN statistics collection interval in seconds, in the range of 5 to 65535.
# Set the L2VPN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address interface tunnel tunnel-number vsi vsi-name
undo mac-address static [ mac-address ] interface tunnel tunnel-number vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface tunnel tunnel-number: Specifies a VXLAN or VXLAN-DCI tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
·     EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
mac-based ac
Use mac-based ac to enable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
Use undo mac-based ac to disable MAC-based traffic match mode for dynamic Ethernet service instances on an interface.
mac-based ac
undo mac-based ac
MAC-based traffic match mode is disabled for dynamic Ethernet service instances. Dynamic Ethernet service instances use VLAN-based traffic match mode.
The 802.1X or MAC authentication feature can use the authorization VSI, the guest VSI, the Auth-Fail VSI, and the critical VSI to control the access of users to network resources. When assigning a user to a VSI, 802.1X or MAC authentication sends the VXLAN feature the VSI information and the user's access information, including access interface, VLAN, and MAC address. Then the VXLAN feature creates a dynamic Ethernet service instance for the user and maps it to the VSI.
A dynamic Ethernet service instance supports the following traffic match modes:
·     VLAN-based mode—Matches frames by VLAN ID.
·     MAC-based mode—Matches frames by VLAN ID and source MAC address.
To use MAC-based traffic match mode for dynamic Ethernet service instances, you must enable MAC authentication or 802.1X authentication that uses MAC-based access control.
The mac-based ac command does not take effect on the following packets received by a hybrid port:
·     Untagged packets.
·     Packets that match the PVID of the hybrid port.
For more information about hybrid ports, see VLAN configuration in Layer 2—LAN Switching Configuration Guide.
MAC-based traffic match mode for dynamic Ethernet service instances is mutually exclusive with the Ethernet service instances matching both inner and outer VLAN IDs. Do not configure both features on an interface.
This command takes effect only on dynamic Ethernet service instances. Static Ethernet service instances created by using the service-instance command match traffic only by the VLAN IDs specified by using the encapsulation command.
You cannot change the traffic match mode when dynamic Ethernet service instances already exist on an interface.
# Enable MAC-based traffic match mode for dynamic Ethernet service instances on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] mac-based ac
overlay oam enable
Use overlay oam enable to enable overlay OAM.
Use undo overlay oam enable to disable overlay OAM.
overlay oam enable
Overlay OAM is disabled.
You must enable overlay OAM on the tunnel destination device for a VXLAN tunnel before you can use the ping vxlan or tracert vxlan command to test reachability of the VXLAN tunnel on the tunnel source device. To specify the -r 3 parameter in the ping vxlan or tracert vxlan command on the tunnel source device, you must also enable overlay OAM on the tunnel source device.
# Enable overlay OAM.
[Sysname] overlay oam enable
ping vxlan
tracert vxlan
ping vxlan
Use ping vxlan to ping a VXLAN tunnel destination.
ping vxlan [ -a inner-src-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-a inner-src-address: Specifies the source IP address in the inner IP header of VXLAN echo requests. If you do not specify this option, the primary IP address of the outgoing interface is used as the source IP address in the inner IP header of VXLAN echo requests. Make sure the tunnel destination device can reach this source IP address. For example, you can specify the tunnel source address as the source IP address in the inner IP header of VXLAN echo requests.
-c count: Specifies the number of VXLAN echo requests to send, in the range of 1 to 4294967295. The default value is 5.
-m interval: Specifies the interval for sending VXLAN echo requests, in milliseconds. The value range for the interval argument 1 to 10000, and the default is 200 milliseconds.
-r reply-mode: Sets the reply mode used by the receiver to reply to VXLAN echo requests. The value of the reply-mode argument can be 1, 2, or 3. The default value is 2.
·     1—Do not reply.
·     2—Look up the IP forwarding table for the destination IP address.
·     3—Perform VXLAN encapsulation.
-t timeout: Specifies the timeout time for receiving VXLAN echo replies, in milliseconds. The value range for the timeout argument is 0 to 65535, and the default is 2000 milliseconds.
-tos tos-value: Specifies the ToS value in the outer IP header of VXLAN echo requests. The value range for the tos-value argument is 0 to 255, and the default is 0.
vxlan-id vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
tunnel-source source-address: Specifies a VXLAN tunnel source IPv4 address.
tunnel-destination dest-address: Specifies a VXLAN tunnel destination IPv4 address.
destination-udpport dest-port: Specifies the destination UDP port number in the inner header of VXLAN echo requests. The value range for the dest-port argument is 1 to 65535, and the default is 50001. Specify this parameter if a specific port number is required to be used as the inner destination UDP port number.
vxlan-source-address vxlan-source-address: Specifies the source IPv4 address in the outer IP header of VXLAN echo requests. If you do not specify this option, the source IPv4 address is the address specified with the tunnel-source source-address parameter. On an M-LAG member device, specify the source IPv4 address as the local VTEP IP address.
load-balance: Configures load balancing parameters. If you do not specify this keyword, the command tests only one of the multiple paths to the VXLAN tunnel destination.
vxlan-source-udpport vxlan-source-udpport end-vxlan-src-udpport: Specifies a source UDP port range for VXLAN echo requests. The value range for UDP port numbers is 49152 to 65535. The default start UDP port number is 4789. If you do not specify an end UDP port number, the end UDP port number is the start UDP port number.
source-address lb-src-address: Specifies the source IPv4 address used for load balancing calculation.
destination-address lb-dest-address: Specifies the destination IPv4 address used for load balancing calculation.
protocol: Specifies the protocol used for load balancing calculation.
udp: Specifies UDP.
lb-protocol-id: Specifies a protocol number in the range of 1 to 255.
source-port lb-src-port: Specifies a source port number used for load balancing calculation, in the range of 1 to 65535.
destination-port lb-dest-port: Specifies a destination port number used for load balancing calculation, in the range of 1 to 65535.
source-mac lb-source-mac: Specifies a source MAC address used for load balancing calculation.
destination-mac lb-destination-mac: Specifies a destination MAC address used for load balancing calculation.
Use this command to test the connectivity of a VXLAN tunnel in a VXLAN or EVPN VXLAN network when the tunnel has traffic loss or interruption issues.
Before you execute this command for a VXLAN tunnel, you must enable overlay OAM on the tunnel destination device by using the overlay oam enable command.
The VTEP can distribute VXLAN echo requests among multiple paths to the destination based on the source UDP port. When a VXLAN tunnel has multiple paths on the transport network, you can configure load sharing parameters to ensure accuracy of the test result. You can use one of the following methods to configure source UDP ports for VXLAN echo requests:
·     Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the ping vxlan command only once.
·     Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the ping vxlan command multiple times to test connectivity of all paths.
The load balancing parameters change only the source UDP port number of VXLAN echo requests. Other fields of the requests will not be changed.
If you specify the vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] parameters, the number of VXLAN echo requests sourced from each UDP port in the UDP port range is determined by the -c count parameter.
# Test connectivity of VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> ping vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Ping VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
Press CTRL+C to break.
40 bytes from 30.0.0.2: sequence=1 time=6 ms
40 bytes from 30.0.0.2: sequence=2 time=4 ms
40 bytes from 30.0.0.2: sequence=3 time=3 ms
40 bytes from 30.0.0.2: sequence=4 time=3 ms
40 bytes from 30.0.0.2: sequence=5 time=2 ms
--- Ping statistics for VXLAN 1 source 11.11.11.11 destination 22.22.22.22 ---
Round-trip min/avg/max = 2/3/6 ms
Table 19 Command output
Press escape key Ctrl+C to abort the ping operation.
Received VXLAN echo replies from a device. If no echo reply is received within the timeout period, no information is displayed.
·     bytes—Number of bytes in the VXLAN echo reply.
·     sequence—Packet sequence number used to determine whether a packet is lost, disordered, or repeated.
·     time—Response time.
Return code
Return code:
·     0—No return code.
·     1—Echo request error.
·     2—The VXLAN does not exist.
·     3—The VXLAN does not have up tunnels.
The number in parentheses is a sub code fixed at 0.
Statistics about the data received and sent in the ping operation.
packets transmitted
Number of sent VXLAN echo requests.
packets received
Number of received VXLAN echo replies.
packet loss
Percentage of unacknowledged requests to the total requests sent.
Minimum/average/maximum deviation response time, in milliseconds.
overlay oam enable
tracert vxlan
ping vxlan ipv6
Use ping vxlan ipv6 to ping an IPv6 VXLAN tunnel destination.
ping vxlan [ -a inner-src-ipv6-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * ipv6 vxlan-id vxlan-id tunnel-source source-ipv6-address tunnel-destination dest-ipv6-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-ipv6-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-a inner-src-ipv6-address: Specifies the source IPv6 address in the inner IPv6 header of VXLAN echo requests. If you do not specify this option, the primary IPv6 address of the outgoing interface is used as the source IPv6 address in the inner IPv6 header of VXLAN echo requests. Make sure the tunnel destination device can reach this source IPv6 address. For example, you can specify the tunnel source address as the source IPv6 address in the inner IPv6 header of VXLAN echo requests.
·     1—Do not reply.
-tos tos-value: Specifies the ToS value in the outer IPv6 header of VXLAN echo requests. The value range for the tos-value argument is 0 to 255, and the default is 0.
ipv6: Specifies an IPv6 tunnel.
tunnel-source source-ipv6-address: Specifies a VXLAN tunnel source IPv6 address.
tunnel-destination dest-ipv6-address: Specifies a VXLAN tunnel destination IPv6 address.
vxlan-source-address vxlan-source-ipv6-address: Specifies the source IPv6 address in the outer IPv6 header of VXLAN echo requests. If you do not specify this option, the source IPv6 address is the address specified with the tunnel-source source-ipv6-address parameter. On an M-LAG member device, specify the source IPv6 address as the local VTEP IPv6 address.
udp: Specifies UDP.
·     Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the ping vxlan ipv6 command only once.
·     Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the ping vxlan ipv6 command multiple times to test connectivity of all paths.
# Test connectivity of VXLAN 1 that is sourced from 11::11 and destined for 22::22.
<Sysname> ping vxlan ipv6 vxlan-id 1 tunnel-source 11::11 tunnel-destination 22::22
Ping VXLAN: VXLAN ID 1 source 11::11 destination 22::22:
40 bytes from 100::2: sequence=1 time=6 ms
40 bytes from 100::2: sequence=2 time=4 ms
40 bytes from 100::2: sequence=3 time=3 ms
40 bytes from 100::2: sequence=4 time=3 ms
40 bytes from 100::2: sequence=5 time=2 ms
--- Ping statistics for VXLAN 1 source 11::11 destination 22::22 ---
Table 20 Command output
Return code
Return code:
·     0—No return code.
Ping statistics for VXLAN 1 source 11::11 destination 22::22:
packets transmitted
packets received
packet loss
overlay oam enable
tracert vxlan ipv6
private-vsi
Use private-vsi to configure a VSI as a primary or secondary VSI and enable the private VSI feature.
Use undo private-vsi to disable the private VSI feature.
private-vsi { community | isolated | primary }
undo private-vsi
The private VSI feature is disabled.
VSI view
community: Specifies the VSI as a secondary VSI whose ACs have Layer 2 connectivity to one another.
isolated: Specifies the VSI as a secondary VSI whose ACs are isolated at Layer 2.
primary: Specifies the VSI as a primary VSI.
In a data center network, typically VMs on a server are assigned to the same subnet. For security purposes, you can configure private VSI on the attached VTEP and private VLAN on the server to isolate the VMs based on VM attributes, operating system, and VM name. The server will send inter-VM traffic to the VTEP, and the VTEP will isolate traffic of different VMs or apply security policies as configured.
An MPU prefixed with LSXM1 does not support the private VSI feature.
# Configure VSI vpn1 as a primary VSI, and enable the private VSI feature.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] private-vsi primary
private-vsi secondary
Use private-vsi secondary to associate a secondary VSI with a primary VSI.
Use undo private-vsi secondary to remove a secondary VSI from a primary VSI.
private-vsi secondary vsi-name&<1-8>
undo private-vsi secondary vsi-name&<1-8>
A primary VSI is not associated with any secondary VSIs.
VSI view
vsi-name: Specifies a space-separated list of up to eight VSI names. Each VSI name is a case-sensitive string of 1 to 31 characters.
Each primary VSI is associated with one or multiple secondary VSIs, and the secondary VSIs communicate at Layer 3 through the primary VSI.
# Associate secondary VSI vpn2 with primary VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] private-vsi secondary vpn2
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
reset arp suppression vsi
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
arp suppression enable
reset ipv6 nd suppression vsi
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
reset l2vpn mac-address
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
reset l2vpn mac-address mac-move
Use reset l2vpn mac-address mac-move to clear MAC move records for all VSIs.
# Clear MAC move records for all VSIs.
<Sysname> reset l2vpn mac-address mac-move
reset l2vpn statistics ac
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on an interface. The interface-type and interface-number arguments specify the interface type and number. The instance-id argument specifies an Ethernet service instance ID in the range of 1 to 4096.
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Ethernet service instance 1 on Ten-GigabitEthernet 3/0/1.
<Sysname> reset l2vpn statistics ac interface ten-gigabitethernet 3/0/1 service-instance 1
display l2vpn service-instance verbose
statistics enable (Ethernet service instance view)
reset l2vpn statistics tunnel
Use reset l2vpn statistics tunnel to clear packet statistics on VXLAN tunnel interfaces.
reset l2vpn statistics tunnel [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on VXLAN tunnel interfaces of all VSIs.
# Clear packet statistics on VXLAN tunnel interfaces of all VSIs.
<Sysname> reset l2vpn statistics tunnel
tunnel statistics enable
reset l2vpn statistics vsi
Use reset l2vpn statistics vsi to clear packet statistics on VSIs.
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on all VSIs.
# Clear packet statistics on all VSIs.
<Sysname> reset l2vpn statistics vsi
statistics enable (VSI view)
restrain
Use restrain to set broadcast, multicast, or unknown unicast restraint bandwidth for a VSI.
Use undo restrain to restore the default.
restrain { broadcast | multicast | unknown-unicast } bandwidth
undo restrain { broadcast | multicast | unknown-unicast }
A VSI's broadcast restraint bandwidth, unknown multicast restraint bandwidth, and unknown unicast restraint bandwidth are not set.
VSI view
broadcast: Specifies the broadcast restraint bandwidth.
multicast: Specifies the multicast restraint bandwidth.
unknown-unicast: Specifies the unknown unicast restraint bandwidth. Unknown unicast packets refer to the unicast packets whose destination MAC addresses are not in the MAC address table of the VSI.
bandwidth: Specifies the broadcast, multicast, or unknown unicast restraint bandwidth in kbps. The value for this argument can be 0 or in the range of 64 to 2147483647.  If you set this argument to 0, the command disables the specified kind of flood traffic.
When the bandwidth of incoming broadcast, multicast, or unknown unicast traffic on VXLAN tunnels of a VSI exceeds the configured restraint bandwidth, the VSI drops the exceeding traffic.
If you have executed the flooding disable unknown-multicast command, the multicast restraint bandwidth set for a VSI by using the restrain command does not take effect.
If you have executed the forwarding vxlan-packet inner-protocol command, the broadcast restraint bandwidth set for a VSI by using the restrain command does not take effect.
# Set the broadcast restraint bandwidth, multicast restraint bandwidth, and unknown unicast restraint bandwidth to 100 kbps for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] restrain broadcast 100
[Sysname-vsi-vpn1] restrain multicast 100
[Sysname-vsi-vpn1] restrain unknown-unicast 100
display l2vpn vsi
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
Do not configure selective flood entries for the MAC addresses assigned to Layer 3 interfaces. If you do so, selective flood might become unavailable.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable (VSI view)
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
# On Layer 2 Ethernet interface Ten-GigabitEthernet 3/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
split-group
Use split-group to assign a VXLAN tunnel interface to a split horizon group.
Use undo split-group to restore the default.
split-group split-group-name
undo split-group
VXLAN tunnel interfaces are in the default split horizon group.
VXLAN tunnel interface view
VXLAN-DCI tunnel interface view
Application scenarios
The split horizon function disables a VTEP from forwarding traffic received on a local VXLAN tunnel interface to other VXLAN tunnel interfaces of the same type within the same split horizon group. This function prevents traffic loops within VXLAN networks. If two VXLAN tunnel interfaces are of different types or belong to different split horizon groups, traffic forwarding between the two interfaces will not be blocked by the split horizon function.
In VXLAN networks where traffic needs to be forwarded among VXLAN tunnel interfaces of the same type, you can use this command to assign the related VXLAN tunnel interfaces to different split horizon groups. As a result, traffic forwarding among those VXLAN tunnel interfaces will not be blocked by the split horizon function.
Operating mechanism
By default, VXLAN tunnel interfaces belong to the default split horizon group. Within the default group, traffic forwarding among VXLAN tunnel interfaces of the same type is blocked by the split horizon function. VXLAN tunnel interfaces of different types can forward traffic to each other normally. After you add the VXLAN tunnel interfaces of the same type to different split horizon groups, they get rid of the blocking by the split horizon function and can forward traffic to each other normally.
Use this feature with caution in VXLAN networks to avoid causing network loops.
In VXLAN networks, the split horizon function takes effect on unicast, multicast, and broadcast traffic.
This feature does not take effect on VXLAN tunnel interfaces used as peer-link interfaces in VXLAN M-LAG networks. Such VXLAN tunnel interfaces are always subject to the split horizon function, regardless of whether they are in different split horizon groups.
# Assign VXLAN tunnel interface Tunnel10 to split horizon group group1.
[Sysname] interface tunnel 10
[Sysname-Tunnel10] split-group group1
Use statistics enable to enable packet statistics for an Ethernet service instance.
Use undo statistics enable to disable packet statistics for an Ethernet service instance.
statistics enable
The packet statistics feature is disabled for an Ethernet service instance.
For this command to take effect, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. If you modify the frame match criterion or VSI mapping, packet statistics of the instance is cleared.
# Enable packet statistics for Ethernet service instance 200 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] statistics enable
Related command
statistics enable (tunnel interface view)
Use statistics enable to enable packet statistics for a manually created VXLAN or VXLAN-DCI tunnel.
Use undo statistics enable to disable packet statistics for a manually created VXLAN or VXLAN-DCI tunnel.
statistics enable
The packet statistics feature is disabled for a manually created VXLAN or VXLAN-DCI tunnel.
# Enable packet statistics for VXLAN tunnel interface Tunnel 10.
[Sysname] interface tunnel 10 mode vxlan
[Sysname-Tunnel10] statistics enable
display interface tunnel (Layer 3—IP Services Command Reference)
reset counters interface tunnel (Layer 3—IP Services Command Reference)
tunnel statistics vxlan auto
Use statistics enable to enable packet statistics for a VSI.
Use undo statistics enable to disable packet statistics for a VSI.
statistics enable
The packet statistics feature is disabled for a VSI.
VSI view
# Enable packet statistics for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
tracert vxlan
Use tracert vxlan to trace the path to a VXLAN tunnel destination.
tracert vxlan [ -a inner-src-address | -h ttl-value | -r reply-mode | -t timeout ] * vxlan-id vxlan-id  tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-h ttl-value: Specifies the maximum TTL value in the outer IP header of VXLAN echo requests. The value range for the ttl-value argument is 1 to 255, and the default is 30.
·     1—Do not reply.
udp: Specifies UDP.
Use this command to locate failed nodes on the path for a VXLAN tunnel that has traffic loss or interruption issues in a VXLAN or EVPN VXLAN network.
·     Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the tracert vxlan command only once.
·     Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the tracert vxlan command multiple times to test connectivity of all paths.
# Trace the path for VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> tracert vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Tracert VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
  TTL   Replier            Time    InBound                OutBound
  1     20.0.0.1           2 ms    XGE3/0/1               XGE3/0/2
  2     30.0.0.2           4 ms    XGE3/0/1               --
Table 21 Command output
TTL
Number of hops.
Replier
Node IP address.
Time
Response time in milliseconds.
InBound
Incoming interface for the VXLAN echo request.
OutBound
Outgoing interface for the VXLAN echo request.
Return code
Return code:
·     0—No return code.
overlay oam enable
ping vxlan
tracert vxlan ipv6
Use tracert vxlan ipv6 to trace the path to an IPv6 VXLAN tunnel destination.
tracert vxlan [ -a inner-src-ipv6-address | -h hop-limit-value | -r reply-mode | -t timeout ] * ipv6 vxlan-id vxlan-id tunnel-source source-ipv6-address tunnel-destination dest-ipv6-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-ipv6-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-h hop-limit-value: Specifies the maximum hop limit value in the outer IP header of VXLAN echo requests. The value range for the hop-limit-value argument is 1 to 255, and the default is 30.
·     1—Do not reply.
udp: Specifies UDP.
# Trace the path for VXLAN 1 that is sourced from 11::11 and destined for 22::22.
<Sysname> tracert vxlan ipv6 vxlan-id 1 tunnel-source 11::11 tunnel-destination 22::22
Tracert VXLAN: VXLAN ID 1 source 11::11 destination 22::22:
  Hop Limit         Time    InBound         OutBound             Replier
  1                 2 ms    GE2/0/3         GE2/0/4              100::1
  2                 4 ms    GE2/0/4         --                   200::2
Table 22 Command output
Hop Limit
Number of hops.
Time
InBound
OutBound
Return code
Return code:
·     0—No return code.
Replier
Node IP address.
overlay oam enable
ping vxlan ipv6
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number [ backup-tunnel tunnel-number ] | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The tunnel must be an existing VXLAN tunnel.
backup-tunnel tunnel-number: Specifies a backup tunnel by its tunnel interface number. The tunnel must be an existing VXLAN tunnel.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
To assign a pair of primary and backup VXLAN tunnels to the VXLAN, specify the backup-tunnel tunnel-number option. When the primary VXLAN tunnel is operating correctly, the backup VXLAN tunnel does not forward traffic. When the primary VXLAN tunnel goes down, traffic is switched to the backup VXLAN tunnel.
You cannot use the tunnel all command for VXLAN-DCI tunnel assignment. Please assign VXLAN-DCI tunnels to a VXLAN one by one.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when executing the undo tunnel global source-address command, the command deletes the global source IPv4 address for VXLAN tunnels.
IMPORTANT
IMPORTANT:
For correct VXLAN deployment and VTEP management, do not manually specify tunnel-specific source addresses for VXLAN tunnels if OVSDB is used.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global source IPv4 address and IPv6 VXLAN tunnels use the global source IPv6 addresses.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
Use tunnel statistics enable to enable packet statistics for all VXLAN tunnels associated with a VSI.
Use undo tunnel statistics enable to disable packet statistics for all VXLAN tunnels associated with a VSI.
The packet statistics feature is disabled for the VXLAN tunnels associated with a VSI.
VSI view
This command enables packet statistics only for VXLAN tunnels. It does not take effect on VXLAN-DCI tunnels.
To view packet statistics about the VXLAN tunnels associated with a VSI, use the display vxlan tunnel command.
# Enable packet statistics for all VXLAN tunnels associated with VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] tunnel statistics enable
Use tunnel statistics vxlan auto to enable packet statistics for automatically created VXLAN tunnels.
Use undo tunnel statistics vxlan auto to disable packet statistics for automatically created VXLAN tunnels.
tunnel statistics vxlan auto [ destination ipv4-address ]
undo tunnel statistics vxlan auto [ destination ipv4-address ]
The packet statistics feature is disabled for automatically created VXLAN tunnels.
destination ipv4-address: Specifies a tunnel destination address. If you do not specify this option, the command enables packet statistics for all automatically created VXLAN tunnels.
This command enables the device to collect packet statistics for all automatically created VXLAN tunnels or a group of automatically created VXLAN tunnels that are destined for the specified address. This command takes effect on both existing VXLAN tunnels and VXLAN tunnels created after execution of this command.
VXLAN tunnels can be automatically created by EVPN or OVSDB.
# Enable packet statistics for automatically created VXLAN tunnels.
[Sysname] tunnel statistics vxlan auto
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan default-decapsulation enable
Use vxlan default-decapsulation enable to enable default IPv4 VXLAN decapsulation.
Use undo vxlan default-decapsulation enable to disable default IPv4 VXLAN decapsulation.
Default IPv4 VXLAN decapsulation is disabled.
If an IPv4 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv4 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from unidirectional IPv4 VXLAN tunnels, enable default IPv4 VXLAN decapsulation. The VTEP will decapsulate all the VXLAN packets destined for the following addresses:
# Enable default IPv4 VXLAN decapsulation.
[Sysname] vxlan default-decapsulation enable
vxlan default-decapsulation source
Use vxlan default-decapsulation source to enable default IPv4 VXLAN decapsulation for a tunnel source.
Use undo vxlan default-decapsulation source to disable default IPv4 VXLAN decapsulation for tunnel sources.
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
If an IPv4 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv4 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv4 VXLAN tunnel, enable default IPv4 VXLAN decapsulation on the interface whose IPv4 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv4 address of that interface.
This command takes effect only when the specified interface has an IPv4 address.
Default IPv4 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv4 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default IPv4 VXLAN decapsulation for a tunnel source.
[Sysname] vxlan default-decapsulation source interface ten-gigabitethernet 3/0/1
vxlan invalid-vlan-tag discard
Use vxlan invalid-vlan-tag discard to enable the device to drop the VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
Use undo vxlan invalid-vlan-tag discard to restore the default.
The device does not check whether a VXLAN packet has 802.1Q VLAN tags in the inner Ethernet header.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
To configure the access mode, use the xconnect vsi command.
# Enable the device to drop VXLAN packets that have 802.1Q VLAN tags.
[Sysname] vxlan invalid-vlan-tag discard
xconnect vsi
vxlan ipv6 default-decapsulation enable
Use vxlan ipv6 default-decapsulation enable to enable default IPv6 VXLAN decapsulation.
Use undo vxlan ipv6 default-decapsulation enable to disable default IPv6 VXLAN decapsulation.
Default IPv6 VXLAN decapsulation is disabled.
If an IPv6 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv6 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from unidirectional IPv6 VXLAN tunnels, enable default IPv6 VXLAN decapsulation. The VTEP will decapsulate all the VXLAN packets destined for the following addresses:
# Enable default IPv6 VXLAN decapsulation.
[Sysname] vxlan ipv6 default-decapsulation enable
vxlan ipv6 default-decapsulation source
Use vxlan ipv6 default-decapsulation source to enable default IPv6 VXLAN decapsulation for a tunnel source.
Use undo vxlan ipv6 default-decapsulation source to disable default IPv6 VXLAN decapsulation for tunnel sources.
vxlan ipv6 default-decapsulation source interface interface-type interface-number
undo vxlan ipv6 default-decapsulation source interface
If an IPv6 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv6 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv6 VXLAN tunnel, enable default IPv6 VXLAN decapsulation on the interface whose IPv6 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv6 address of that interface.
This command takes effect only when the specified interface has an IPv6 address.
Default IPv6 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv6 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
[Sysname] vxlan ipv6 default-decapsulation source interface ten-gigabitethernet 3/0/1
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to report the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
vxlan multicast-group member enable
Use vxlan multicast-group member enable to enable an interface to join a multicast group.
Use undo vxlan multicast-group member enable to disable an interface from joining a multicast group.
An interface is disabled from joining a multicast group.
VLAN interface view
In a VXLAN+M-LAG scenario, when VXLAN uses multicast routes to forward broadcast, unicast, and multicast (BUM) traffic, M-LAG member devices might forward the same multicast traffic simultaneously, which consumes network resources. To avoid this issue, M-LAG member devices use an odd/even address-based forwarding principle for load-sharing VXLAN packets encapsulated with multicast addresses. More specifically, one M-LAG member device forwards packets with odd-numbered multicast addresses (the destination multicast addresses encapsulated in VXLAN packets), and the other M-LAG member device forwards packets with even-numbered multicast addresses.
After an M-LAG member device receives Layer 2 BUM traffic locally, it synchronizes the traffic to the other M-LAG member device through the peer link. At the same time, the M-LAG member device adds VXLAN encapsulation to the BUM traffic.
·     If the multicast address in the VXLAN encapsulation added to the traffic is odd (or even), and the local M-LAG member device is responsible for forwarding packets with odd (or even) multicast addresses, the traffic can be normally forwarded through the M-LAG member device.
·     If the multicast address in the VXLAN encapsulation added to the traffic is odd (or even), but the local M-LAG member device is responsible for forwarding packets with even (or odd) multicast addresses, the local M-LAG member device will not forward the traffic through the VXLAN tunnel. Although the peer M-LAG member device receives the BUM traffic from the peer link, it does not forward the BUM traffic through the VXLAN tunnel because the BUM traffic received from the peer link is not sent to the VXLAN tunnel. As a result, traffic forwarding fails.
To address the traffic forwarding failure issue, use this command to synchronize encapsulated multicast VXLAN packets between M-LAG member devices through the peer link.
Operating mechanism
After you assign the peer link to a VLAN and execute this command on the VLAN interface for that VLAN, the VLAN interface will automatically join the multicast group specified by using the group command in VXLAN view. The peer link will then allow forwarding traffic for that multicast group. In this way, M-LAG member devices can synchronize VXLAN packets encapsulated with multicast addresses through the peer link.
After you execute this command, if the local M-LAG member device receives a multicast VXLAN packet from the peer M-LAG member device through the peer link, it will not decapsulate the packet or send the packet to the local AC. Instead, the local M-LAG member device will send the packet to the remote VTEP through the transport network.
On the same device, you can enable only one VLAN interface to join a multicast group. As a best practice to avoid traffic interference, do not deploy other services on that VLAN interface.
You cannot enable a VLAN interface bound to a VPN instance to join a multicast group.
# Enable VLAN-interface 4094 to join a multicast group.
[Sysname] interface vlan-interface 4094
[Sysname-Vlan-interface14094] vxlan multicast-group member enable
group
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
This command takes effect only on manually created VXLAN tunnels. Remote-MAC address learning is always disabled for automatically created tunnels, and it is not controlled by this command.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
vxlan vlan-based
Use vxlan vlan-based to enable VLAN-based VXLAN assignment.
Use undo vxlan vlan-based to disable VLAN-based VXLAN assignment.
vxlan vlan-based
VLAN-based VXLAN assignment is disabled.
When you use Ethernet service instances as ACs, you can assign customer traffic to a VXLAN by using one of the following methods:
·     Ethernet service instance-to-VSI mapping—This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs on a site-facing Layer 2 interface. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
·     VLAN-based VXLAN assignmentThis method maps a VLAN to a VXLAN. When a VLAN is mapped to a VXLAN and VLAN-based VXLAN assignment is enabled, the device automatically performs the following operations:
a.     Creates an Ethernet service instance that uses the VLAN ID as its instance ID on each interface in the VLAN. The matching outer VLAN ID of the Ethernet service instances is the VLAN ID.
b.     Maps the Ethernet service instances to the VSI of the VXLAN.
Do not configure both Ethernet service instance-to-VSI mapping and VLAN-based VXLAN assignment.
# Enable VLAN-based VXLAN assignment.
[Sysname] vxlan vlan-based
vxlan vni
Use vxlan vni to map a VLAN to a VXLAN.
Use undo vxlan vni to remove the VXLAN mapping for a VLAN.
vxlan vni vxlan-id
undo vxlan vni
A VLAN is not mapped to a VXLAN.
VLAN view
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 1 to 16777215.
Before you map VLANs to VXLANs, enable VLAN-based VXLAN assignment by using the vxlan vlan-based command.
You cannot map VLAN 1 to any VXLAN.
Do not map a VLAN to the L3 VXLAN ID of EVPN.
If you map a VLAN to a nonexistent VXLAN, the configuration takes effect after the VXLAN is created.
# Map VLAN 10 to VXLAN 100.
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
vxlan vlan-based
vxlan-dci-tunnel outer dscp
Use vxlan-dci-tunnel outer dscp to configure the DSCP values in the outer headers of VXLAN DCI tunnel packets.
Use undo vxlan-dci-tunnel outer dscp to restore the default.
vxlan-dci-tunnel outer dscp { copy-from-inner | local-precedence-map }
The DSCP values in the outer headers of VXLAN DCI tunnel packets are copied from the DSCP values in the inner headers of the VXLAN DCI tunnel packets.
copy-from-inner: Copies the DSCP values in the inner headers of VXLAN DCI tunnel packets to the DSCP values in the outer headers of VXLAN DCI tunnel packets.
local-preference-map: Generates the DSCP values in the outer headers of the VXLAN DCI tunnel packets based on the QoS local precedence mappings.
Operating mechanism
VXLAN DCI QoS forwards VXLAN DCI tunnel packets based on the DSCP values in the outer headers. The DSCP values in the outer headers can be generated in the following ways:
·     copy-from-inner—Directly copies the DSCP values from the inner headers of VXLAN DCI tunnel packets to the DSCP values in the outer headers of the VXLAN DCI tunnel packets.
·     local-preference-map—Generates the DSCP values in the outer headers of VXLAN DCI tunnel packets based on the colored mapping table that maps the QoS local precedence values to the VXLAN DCI tunnel DSCP values.
Before configuring this feature, first configure the following QoS-related features:
·     Execute the remark local-precedence command to set the local precedence values of the packets, which specify the local precedence values and packet colors for generating the DSCP values in the outer headers of VXLAN DCI tunnel packets.
·     Execute the qos map-table color command with the lp-tunnel-dscp keyword specified to enable mappings from local preference values to VXLAN DCI tunnel DSCP values.
For more information about QoS local precedence values, see ACL and QoS Configuration Guide.
With this feature configured, the DSCP values in the outer headers of all VXLAN DCI tunnel packets will be affected.
# Copy the DSCP values in the inner headers of VXLAN DCI tunnel packets to the DSCP values in the outer headers of the VXLAN DCI tunnel packets.
<Sysname>system-view
[Sysname] vxlan-dci-tunnel outer dscp copy-from-inner
remark local-precedence (ACL and QoS Command Reference)
qos map-table color (ACL and QoS Command Reference)
vxlan-tunnel outer dscp
Use vxlan-tunnel outer dscp to configure the DSCP values in the outer headers of VXLAN tunnel packets.
Use undo vxlan-tunnel outer dscp to restore the default.
vxlan-tunnel outer dscp { copy-from-inner | local-precedence-map }
The DSCP values in the outer headers of VXLAN tunnel packets are copied from the DSCP values in the inner headers of the VXLAN tunnel packets.
copy-from-inner: Copies the DSCP values in the inner headers of VXLAN tunnel packets to the DSCP values in the outer headers of VXLAN tunnel packets.
local-preference-map: Generates the DSCP values in the outer headers of the VXLAN tunnel packets based on the QoS local precedence mappings.
Operating mechanism
VXLAN QoS forwards VXLAN tunnel packets based on the DSCP values in the outer headers. The DSCP values in the outer headers can be generated in the following ways:
·     copy-from-inner—Directly copies the DSCP values from the inner headers of VXLAN tunnel packets to the DSCP values in the outer headers of the VXLAN tunnel packets.
·     local-preference-map—Generates the DSCP values in the outer headers of VXLAN tunnel packets based on the colored mapping table that maps the QoS local precedence values to the VXLAN tunnel DSCP values.
·     Execute the remark local-precedence command to set the local precedence values of the packets, which specify the local precedence values and packet colors for generating the DSCP values in the outer headers of VXLAN tunnel packets.
·     Execute the qos map-table color command with the lp-tunnel-dscp keyword specified to enable mappings from local preference values to VXLAN tunnel DSCP values.
With this feature configured, the DSCP values in the outer headers of all VXLAN tunnel packets will be affected.
# Copy the DSCP values in the inner headers of VXLAN tunnel packets to the DSCP values in the outer headers of the VXLAN tunnel packets.
[Sysname] vxlan-tunnel outer dscp copy-from-inner
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | microsegment microsegment-id | on-demand ] * [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
microsegment microsegment-id: Specifies a microsegment ID in the range of 1 to 65535. If the AC is not associated with a microsegment, do not specify this option.
on-demand: Enables conversational learning for forwarding entries of the AC. This feature enables the device to issue AC forwarding entries to the hardware on demand. If you do not specify this keyword, the device issues AC forwarding entries to the hardware in real time.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
To monitor the status of an AC, associate it with track entries.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to add a frame match criterion to the service instance.
For traffic that matches the Ethernet service instance, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
·     VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
·     Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
When you map an AC to a VSI, you can associate the AC with a microsegment. You can associate multiple ACs with the same microsegment. For more information about microsegments, see Security Configuration Guide.
If you do not specify the on-demand keyword, the device issues AC forwarding entries to the hardware in real time. To save hardware resources, specify the on-demand keyword for the device to issue AC forwarding entries only when the entries are required for packet forwarding. If the MAC address entries for an AC have aged out when its forwarding entries are issued, the device deletes the forwarding entries to save hardware resources.
You can configure only the encapsulation s-vid vlan-id criterion for an AC with conversational learning enabled for AC forwarding entries, and the device issues only dynamic MAC address entries learned in the matching VLAN.
# On Ten-GigabitEthernet 3/0/1, configure Ethernet service instance 200 to match frames with an outer 802.1Q VLAN tag of 200, and map the instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] xconnect vsi vpn1
encapsulation
vsi
VXLAN IP gateway commands
Only the SF interface modules support VXLAN IP gateways.
arp distributed-gateway dynamic-entry synchronize
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp send-rate
Use arp send-rate to set an ARP packet sending rate limit for a VSI interface.
Use undo arp send-rate to remove the ARP packet sending rate limit for a VSI interface.
arp send-rate pps
undo arp send-rate
The ARP packet sending rate is not limited for a VSI interface.
VSI interface view
pps: Specifies a rate limit in the range of 1 to 500 pps.
VMs have limited capacity to process packets. To prevent packet processing from degrading VM performance, limit the ARP packet sending rate of the VSI interface for VMs. The VTEP will drop excess ARP packets if the rate limit is exceeded. This limit applies only to the ARP request packets sourced from the VSI interface.
# Set the ARP packet sending rate limit to 50 pps for VSI-interface 1.
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
bandwidth
Use bandwidth to set the expected bandwidth for a VSI interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) of a VSI interface equals the interface baud rate divided by 1000.
VSI interface view
# Set the expected bandwidth to 10000 kbps for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
default
Use default to restore the default settings for a VSI interface.
default
VSI interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1.     Use the display this command in interface view to identify these commands.
2.     Use their undo forms or follow the command reference to restore their default settings.
3.     If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface.
The description of a VSI interface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface
Use display interface vsi-interface to display information about VSI interfaces.
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces. Make sure the specified VSI interfaces have been created on the device.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
Only the SC cards prefixed with LSCM2, SD interface modules, and SF interface modules support this command.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Table 23 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface:
·     UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-AllocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
IPv4 packet framing format.
hardware address
MAC address.
IPv6 packet framing format.
Physical
Physical type of the interface, which is fixed at Unknown.
baudrate
Interface baudrate in kbps.
Last time when the reset counters interface vsi-interface command was used to clear interface statistics.
This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup.
Average input rate for the last 300 seconds.
Average output rate for the last 300 seconds.
Incoming traffic statistics on the interface:
·     Number of incoming packets.
·     Number of incoming bytes.
·     Number of dropped incoming packets.
Outgoing traffic statistics on the interface:
·     Number of outgoing packets.
·     Number of outgoing bytes.
·     Number of dropped outgoing packets.
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
Table 24 Command output
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
·     DOWN—The data link layer protocol of the interface is down.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel.
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
This command does not prevent a VSI from learning ARP or ND entries for the subnets not assigned to the VSI. If the VSI shares a VSI interface with other VSIs, it can learn ARP or ND entries for the subnets assigned to those VSIs.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. The VSI interface must already exist.
When you delete a VSI interface by using the undo interface vsi-interface command, the gateway interface setting of the VSI interface is also deleted.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 16777215.
# Create VSI-interface 100 and enter VSI interface view.
ipv6 nd distributed-gateway dynamic-entry synchronize
Use ipv6 nd distributed-gateway dynamic-entry synchronize to enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Use undo ipv6 nd distributed-gateway dynamic-entry synchronize to disable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Dynamic ND entry synchronization is disabled for distributed VXLAN IP gateways.
When local ND proxy is enabled on distributed VXLAN IP gateways, each gateway learns ND information independently. A gateway does not forward ND packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ND entries, you must enable dynamic ND entry synchronization.
A controller or the EVPN feature can also synchronize ND entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ND entry synchronization.
# Enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
local-proxy-nd enable (Layer 3—IP Services Command Reference)
mac-address
Use mac-address to assign a MAC address to a VSI interface.
Use undo mac-address to restore the default.
undo mac-address
VSI interfaces use the MAC address of VLAN-interface 4094 on the device.
VSI interface view
mac-address: Specifies a MAC address in H-H-H format.
Do not enable selective flood for the MAC addresses assigned to VSI interfaces. If you do so, selective flood will become unavailable to use.
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The default MTU of a VSI interface is 1444 bytes.
VSI interface view
size: Specifies an MTU value  in the range of 46 to 10240 bytes.
This command applies only to protocol packets and does not affect forwarded data packets.
As a best practice, set the MTU of a VSI interface to 1422 in an IPv6 VXLAN tunnel scenario.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
Use reset counters interface vsi-interface to clear packet statistics on VSI interfaces.
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command clears packet statistics on the specified interface. If you specify only the vsi-interface keyword, this command clears packet statistics on all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command clears packet statistics on all interfaces. Make sure the specified VSI interfaces have been created on the device.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear packet statistics on VSI-interface 100.
<Sysname> reset counters interface vsi-interface 100
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface is up.
VSI interface view
CAUTION
CAUTION:
If you shut down a VSI interface, the VXLAN network using this VSI interface as the gateway will be unable to communicate with other networks at Layer 3. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
This command takes effect only on manually created VXLAN tunnels. Remote ARP learning is always disabled for automatically created tunnels, and it is not controlled by this command.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
Use vxlan tunnel nd-learning disable to disable remote ND learning for VXLANs.
Use undo vxlan tunnel nd-learning disable to enable remote ND learning for VXLANs.
Remote ND learning is enabled for VXLANs.
This command takes effect only on manually created VXLAN tunnels. Remote ND learning is always disabled for automatically created tunnels, and it is not controlled by this command.
By default, the device learns ND information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ND learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel nd-learning disable command to enable remote ND learning.
As a best practice, disable remote ND learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ND learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
OVSDB commands
ovsdb server bootstrap ca-certificate
Use ovsdb server bootstrap ca-certificate to specify a CA certificate file for establishing OVSDB SSL connections.
Use undo ovsdb server bootstrap ca-certificate to restore the default.
ovsdb server bootstrap ca-certificate ca-filename
SSL uses the CA certificate file in the PKI domain.
ca-filename: Specifies the CA certificate file name, a case-insensitive string. The file name cannot contain the slot string, and the file must be stored on the active MPU.
For the specified certificate to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
If the specified CA certificate file does not exist, the device obtains a self-signed certificate from the controller. The obtained file uses the name specified for the ca-filename argument.
# Specify CA certificate file ca-new for establishing OVSDB SSL connections.
[Sysname] ovsdb server bootstrap ca-certificate ca-new
ovsdb server enable
ovsdb server pki domain
ovsdb server pssl
ovsdb server ssl
ovsdb server enable
Use ovsdb server enable to enable the OVSDB server.
Use undo ovsdb server enable to disable the OVSDB server.
ovsdb server enable
The OVSDB server is disabled.
To obtain configuration data from controllers, you must enable the OVSDB server.
Before you enable the OVSDB server, you must establish an OVSDB SSL or TCP connection with a minimum of one controller.
# Enable the OVSDB server.
[Sysname] ovsdb server enable
Use ovsdb server pki domain to specify a PKI domain for establishing OVSDB SSL connections.
Use undo ovsdb bootstrap server pki domain to restore the default.
ovsdb server pki domain domain-name
undo ovsdb server pki domain
No PKI domain is specified for establishing OVSDB SSL connections.
domain-name: Specifies a PKI domain name, a case-sensitive string of 1 to 31 characters. The PKI domain must already exist and contain a complete certificate and key.
To communicate with controllers through SSL, you must specify a PKI domain.
For the specified PKI domain to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
For more information about PKI domains, see PKI in Security Configuration Guide.
# Specify PKI domain ovsdb_test for establishing OVSDB SSL connections.
[Sysname] ovsdb server pki domain ovsdb_test
ovsdb server enable
ovsdb server pssl
ovsdb server ssl
ovsdb server pssl
Use ovsdb server pssl to enable the device to listen for OVSDB SSL connection requests.
Use undo ovsdb server pssl to restore the default.
ovsdb server pssl [ port port-number ]
The device does not listen for OVSDB SSL connection requests.
port port-number: Specifies a port to listen for OVSDB SSL connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
Before you use this command, you must specify a PKI domain for SSL.
You can specify only one port to listen for OVSDB SSL connection requests. If you execute this command multiple times, the most recent configuration takes effect.
For the specified port setting to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
# Enable the device to listen for OVSDB SSL connection requests on port 6640.
[Sysname] ovsdb server pssl
ovsdb server enable
ovsdb server ssl
ovsdb server ptcp
Use ovsdb server ptcp to enable the device to listen for OVSDB TCP connection requests.
Use undo ovsdb server ptcp to restore the default.
ovsdb server ptcp [ port port-number ] [ acl acl-number ]
The device does not listen for OVSDB TCP connection requests.
port-number: Specifies a port to listen for OVSDB TCP connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
acl acl-number: Specifies a basic IPv4 ACL by its ACL number to filter OVSDB TCP connection requests. The value range for the acl-number argument is 2000 to 2999.
You can specify only one port to listen for OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
If you specify a basic IPv4 ACL for this command, the OVSDB server accepts only the OVSDB TCP connection requests that are permitted by the ACL. The OVSDB server rejects any OVSDB TCP connection requests that do not match the ACL or that are denied by the ACL.
The OVSDB server does not filter OVSDB TCP connection requests in any of the following situations:
·     No IPv4 ACL is specified for this command.
·     The specified IPv4 ACL does not exist.
·     The specified IPv4 ACL does not have rules.
If a rule of the specified IPv4 ACL uses the vpn-instance criterion, the rule takes effect only on traffic of the matching VPN instance. If the vpn-instance criterion is not configured for a rule, the rule takes effect on traffic of both the public network and VPN instances.
You can specify only one IPv4 ACL to filter OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
Modification to rules in the specified IPv4 ACL takes effect only on OVSDB TCP connection requests that are received after the modification. If you specify another IPv4 ACL, the IPv4 ACL also takes effect only on OVSDB TCP connection requests that are received after the modification.
# Enable the device to listen for OVSDB TCP connection requests on port 6640.
[Sysname] ovsdb server ptcp
ovsdb server enable
ovsdb server tcp
ovsdb server ssl
Use ovsdb server ssl to set up an active OVSDB SSL connection to a controller.
Use undo ovsdb server ssl to remove an OVSDB SSL connection from a controller.
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
The device does not have active OVSDB SSL connections to a controller.
ip ip-address: Specifies the destination IP address for the SSL connection.
port port-number: Specifies the destination port for the SSL connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active SSL connections.
To establish the connection, you must execute the ovsdb server enable command. You must disable and then re-enable the OVSDB server if it has been enabled.
# Set up an active SSL connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server pssl
ovsdb server tcp
Use ovsdb server tcp to set up an active OVSDB TCP connection to a controller.
Use undo ovsdb server tcp to remove an OVSDB TCP connection.
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
The device does not have active OVSDB TCP connections.
ip ip-address: Specifies the destination IP address for the TCP connection.
port port-number: Specifies the destination port for the TCP connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active OVSDB TCP connections.
# Set up an active OVSDB TCP connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server ptcp
vtep access port
Use vtep access port to specify a site-facing interface as a VTEP access port.
Use undo vtep access port to restore the default.
vtep access port
An interface is not a VTEP access port.
Layer 3 interface view
For controllers to manage a site-facing interface, you must specify the interface as a VTEP access port.
# Specify Ten-GigabitEthernet 3/0/1 as a VTEP access port.
[Sysname-Ten-GigabitEthernet3/0/1] vtep access port
vtep acl disable
Use vtep acl disable to disable the ACLs issued by the OVSDB controller.
Use undo vtep acl disable to enable the ACLs issued by the OVSDB controller.
vtep acl disable
The ACLs issued by the OVSDB controller are enabled on the device.
Before you use this command, you must use the vtep enable command to enable the OVSDB VTEP service.
Use the vtep acl disable command on a VTEP to disable all the ACLs issued by the OVSDB controller in order to save ACL resources on the VTEP.
# Disable the ACLs issued by the OVSDB controller.
[Sysname] vtep enable
[sysname] vtep acl disable
vtep enable
vtep enable
Use vtep enable to enable the OVSDB VTEP service.
Use undo vtep enable to disable the OVSDB VTEP service.
vtep enable
undo vtep enable
The OVSDB VTEP service is disabled.
# Enable the OVSDB VTEP service.
