10-ACL and QoS Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10010-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 889.29 KB
QoS policy commands· 4
Traffic class commands· 4
description· 4
display traffic classifier 4
if-match· 6
traffic classifier 12
Traffic behavior commands· 13
accounting· 13
car 14
display traffic behavior 15
filter 16
nest top-most 17
packet-rate· 18
redirect 19
remark customer-vlan-id· 21
remark dot1p· 21
remark drop-precedence· 22
remark dscp· 23
remark ip-precedence· 25
remark local-precedence· 25
remark qos-local-id· 26
remark service-vlan-id· 27
remark source-mac· 28
traffic behavior 29
QoS policy commands· 29
classifier behavior 29
control-plane· 30
control-plane management 31
display qos policy· 31
display qos policy control-plane· 34
display qos policy control-plane management 36
display qos policy control-plane management pre-defined· 37
display qos policy control-plane pre-defined· 38
display qos policy control-plane rule-statistics· 40
display qos policy global 42
display qos policy global rule-statistics· 45
display qos policy interface· 48
display qos policy interface rule-statistics· 53
display qos policy l2vpn-ac· 56
display qos policy l2vpn-ac rule-statistics· 57
display qos vlan-policy· 60
display qos vlan-policy rule-statistics· 62
qos apply policy (Ethernet service instance view, interface view, control plane view, control-plane management view) 64
qos apply policy global 68
qos policy· 69
qos vlan-policy· 71
reset qos policy control-plane· 72
reset qos policy control-plane management 72
reset qos policy global 73
reset qos policy l2vpn-ac· 73
reset qos vlan-policy· 74
QoS SNMP notification commands· 75
snmp-agent trap enable qos· 75
Priority mapping commands· 76
Priority map commands· 76
display qos map-table· 76
display qos map-table color 77
import 79
qos map-table· 79
qos map-table color 80
Priority trust mode commands· 81
display qos trust interface· 81
qos trust 82
qos trust tunnel-dscp (system view) 82
Port priority commands· 83
qos priority· 83
GTS, and rate limit commands· 85
GTS commands· 85
display qos gts interface· 85
qos gts· 85
Rate limit commands· 86
display qos lr interface· 86
qos lr 87
Congestion management commands· 89
Common commands· 89
display qos queue interface· 89
SP commands· 90
display qos queue sp interface· 90
qos sp (interface view) 90
WRR commands· 91
display qos queue wrr interface· 91
qos wrr (interface view) 92
qos wrr { byte-count | weight } 93
qos wrr group sp· 94
WFQ commands· 95
display qos queue wfq interface· 95
qos bandwidth queue· 96
qos wfq (interface view) 97
qos wfq { byte-count | weight } 97
qos wfq group sp· 98
Queue scheduling profile commands· 99
bandwidth queue· 99
display qos qmprofile configuration· 100
display qos qmprofile interface· 101
qos apply qmprofile· 102
qos qmprofile· 103
queue· 104
Congestion avoidance commands· 107
WRED commands· 107
display qos wred fabric· 107
display qos wred interface· 109
display qos wred table· 110
qos wred apply· 111
qos wred apply fabric· 112
qos wred ecn enable· 113
qos wred queue· 114
qos wred queue table· 116
qos wred queue weighting-constant 117
queue (WRED table view) 118
queue weighting-constant 119
Global CAR commands· 121
car name· 121
display qos car name· 121
qos car (system view) 123
reset qos car name· 124
Elephant and mice flows distinguishing commands· 126
elephant-flow action· 126
elephant-flow rate· 127
agile-buffer enable· 127
qos mice-elephant-flow· 130
Traffic Matrix commands· 131
display traffic-matrix· 131
ip source destination· 134
ipv6 source destination· 135
traffic-matrix· 137
Interface packet accounting commands· 139
display qos packet-statistics interface· 139
qos packet-statistics· 139
reset qos packet-statistics interface· 140
Queue-based accounting commands· 142
display qos queue-statistics interface outbound· 142
qos queue-statistics byte-count 143
QoS policy commands
Type-LSCM2 cards refer to interface modules and MPUs with the silkscreens starting with LSCM2.
description
Use description to configure a description for a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the traffic classes for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic classes for the global active MPU. (In IRF mode.)
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac ] { acl-number | name acl-name } [ inner ]
Matches an ACL.
The value range for the acl-number argument is as follows:
·     2000 to 3999 for IPv4 ACLs.
·     2000 to 3999 for IPv6 ACLs.
·     4000 to 4999 for Layer 2 MAC ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
If you use the rule [ rule-id ] { deny | permit } command to match packets, the inner keyword matches the inner header information of VXLAN packets. If you do not specify this keyword, the ACL matches the header information of non-encapsulated packets or the outer header information of VXLAN packets.
If you use the rule [ rule-id ] { deny | permit } vxlan command to match inner header information of VXLAN packets, you cannot specify the inner keyword in the if-match acl command.
If no VPN instance is specified in an ACL rule, the ACL rule takes effect on both non-VPN packets and VPN packets.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
destination-mac mac-address [ mac-address-mask ]
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
forwarding-layer { bridge | route }
Matches Layer 2 forwarded packets or Layer 3 forwarded packets.
·     bridge—Matches Layer 2 forwarded packets.
·     route—Matches Layer 3 forwarded packets.
inbound-interface interface-type interface-number
Only the SC modules prefixed with LSCM2, SD interface modules, and SF interface modules support this option.
Matches an input interface specified by its type and number.
If this option is configured in a traffic class with logic AND operator, the traffic class is no longer in effect after the card or subcard where the input interface resides is removed. After the removed card or subcard is reinserted, the traffic class takes effect again. If you do not reinsert the card or subcard and add other match criteria to the traffic class, the traffic class does not take effect again.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
outbound-interface interface-type interface-number
Matches an output interface specified by its type and number.
This option take effects only on outgoging packets of Layer 2 Ethernet interfaces and Layer 3 Ethernet interfaces.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 384 on an SF interface module or 1 to 32 on an SC module prefixed with LSCM2 or an SD interface module.
This option is supported only in the inbound direction.
This option is not supported in the VXLAN M-LAG environment.
qos-local-id egress-active local-id-value
Matches a local QoS ID in the outbound direction, in the range of 1 to 128.
·     If you use the remark qos-local-id egress-active command to mark packets and the command takes effect only in the outbound direction, you must use the if-match egress-active qos-local-id command to match the packets in the outbound direction.
·     If you use the remark qos-local-id command to mark packets and the command takes effect on both directions, you must use the if-match egress-active qos-local-id command to match packets.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
tunnel-id tunnel-id
Matches a tunnel ID.
For SF interface cards:
·     Only VXLAN tunnel IDs can be matched.
·     A QoS policy containing this option cannot be applied to Ethernet service instances or tunnel interfaces.
·     A DSCP marking action is not supported if this option is configured.
Cards other than SF interface cards support applying a QoS policy containing this option to only the inbound direction.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
arp-snooping
ARP snooping packets
bfd
BFD packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
icmp
ICMP packets
icmp6
ICMPv6 packets
isis
IS-IS packets
lacp
LACP packets
ldp
LDP packets
ldp6
IPv6 LDP packets
lldp
LLDP packets
mld
MLD packets
msdp
MSDP packets
mvrp
MVRP packets (including GVRP packets)
nd
ND packets
ntp
NTP packets
oam
OAM packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
pim-multicast
PIM multicast packets
pim-unicast
PIM unicast packets
pim6-multicast
IPv6 PIM multicast packets
pim6-unicast
IPv6 PIM unicast packets
portal
Portal packets
pvst
PVST packets
rip
RIP packets
ripng
RIPng packets
rrpp
RRPP packets
rsvp
RSVP packets
smart-link
SmartLink packets
snmp
SNMP packets
stp
STP packets
udp-helper
UDP helper packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
If a Layer 2 ACL rule contains a MAC address match criterion, the ACL rule cannot match IPv6 packets in a QoS policy applied to the outbound direction.
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·     You can specify up to eight values for any of the following match criteria in one if-match command:
¡     802.1p priority.
¡     DSCP.
¡     IP precedence.
¡     VLAN ID.
·     If a packet matches one of the specified values, it matches the if-match command.
·     To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·     The ACL must already exist.
·     The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
For a QoS policy to match IPv6 packets in the outbound direction of interfaces on an SF interface card or IPv6 packets on an SE interface card, you must specify IPv6 packet match criteria (for example, configure a rule to match the IPv6 protocol type) in the corresponding traffic classes.
For a QoS policy to match MPLS packets on an LSCM1GT48SC0 card, you must specify MPLS packet match criteria (for example, configure an ACL to match the MPLS protocol type) in the corresponding traffic classes.
On an SF interface card:
·     For passing VXLAN packets, a QoS policy applied in the inbound direction cannot match the source MAC address, customer-vlan-id , or customer-dot1p.
·     For passing GRE and NVGRE packets, a QoS policy applied in the inbound direction cannot match the source MAC or customer-vlan-id.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match the packets with tunnel ID 2.
[Sysname-classifier-class1] if-match tunnel-id 2
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting [ byte | packet ]
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
If you do not specify the byte or packet keyword, the device counts traffic in both bytes and packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 16 to 100000000, which must be a multiple of 8.
cbs committee-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 67092480, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 67092480 is converted to 67092480.
ebs excess-burst-size: Specifies the excess burst size (EBS) in the range of 512 to 67092480 bytes. The value must be an integral multiple of 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 16 to 100000000 kbps, in increments of 8. The PIR and CIR must be configured in the same measurement unit.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
# Configure a CAR action in traffic behavior database:
·     Set the CIR to 256 kbps, CBS to 51200 bytes, and EBS to 0.
[Sysname-behavior-database] car cir 256 cbs 51200
Use display traffic behavior to display traffic behaviors.
In standalone mode:
In IRF mode:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays traffic behaviors for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic behaviors for the global active MPU. (In IRF mode.)
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets. The permitted packets can be processed by other class-behavior associations in the same QoS policy.
The keywords in the command have different meanings:
·     deny—If a packet matches a traffic class, it is directly dropped and will no longer be affected by actions from lower-priority features.
·     permit—If a packet matches a traffic class, the QoS policy does not affect the packet. If the packet is processed by other lower-priority features, whether it is dropped will depend on the actions of those lower-priority features.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
Do not apply a QoS policy contains an outer VLAN tag adding action to member ports of an aggregation group, VSIs, or VCs.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
For a packet added with an outer VLAN tag to be correctly forwarded, make sure the inner VLAN ID of the packet is also allowed by the output interface.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
packet-rate
Use packet-rate to configure a protocol packet rate limiting action in a traffic behavior.
Use undo packet-rate to restore the default.
packet-rate { value | attack-defense-threshold threshold-value } *
undo packet-rate
No protocol packet rate limiting action is configured.
value: Specifies the protocol packet rate in pps. The value range for this argument is 1 to 30000.
attack-defense-threshold threshold-value: Specifies the attack defense threshold for protocol packets, in pps. The value range for the threshold-value argument is 1 to 30000.
Only the SC modules prefixed with LSCM2, SD interface modules, and SF interface modules support this command.
Protocol packet rate limiting can protect the CPU against protocol packet attacks.
By default, the device uses the predefined QoS policy for the control plane to limit the packets of each protocol to the CPU.
The device automatically enables rate limiting on the interface that sends the packets to the CPU if both of the following conditions exist:
·     The packet rate of a protocol reaches or exceeds the rate limit.
·     The configured attack defense threshold is greater than the configured protocol packet rate.
If you execute the packet-rate command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior copp to rate limit the protocol packets sent to the CPU to 1600 pps.
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
# Configure traffic behavior copp1 to rate limit the protocol packets sent to the CPU to 1600 pps and configure the attack defense threshold for protocol packets as 1400 pps.
[Sysname] traffic behavior copp1
[Sysname-behavior-copp1] packet-rate 1600 attack-defense-threshold 1400
display qos policy
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number  | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
next-hop: Redirects traffic to a next hop. For successful traffic redirection, make sure the next hop IP address is reachable. If both primary and secondary next hop IP addresses are specified, make sure a minimum of one IP address is reachable. The redirection feature periodically looks up the routing table to verify the reachability of next hop IP addresses. If track entries are specified, the redirection feature verifies the reachability of the next hop IP addresses based on the Track detection result. If both primary and secondary next hop IP addresses are unreachable, traffic redirection to a next hop does not take effect.
ipv4-add1: Specifies the primary next hop IPv4 address. If traffic fails to be redirected to this IPv4 address, the traffic is redirected to the secondary IPv4 address.
ipv4-add2: Specifies the secondary next hop IPv4 address.
ipv6-add1: Specifies the primary next hop IPv6 address. If traffic fails to be redirected to this IPv6 address, the traffic is redirected to the secondary IPv6 address.
ipv6-add2: Specifies the secondary next hop IPv6 address.
track track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024. Different track entries can be specified for primary and secondary IP addresses. By specifying track entries, you can associate traffic redirection with detection modules, such as NQA and BFD (see High Availability Configuration Guide).
fail-action: Specifies the action to take on packets if the next hop IP address does not exist. Without this parameter configured, the device forwards packets if the next hop IP address does not exist.
discard: Discards packets.
forward: Forwards packets.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
A traffic redirecting action takes effect only when the QoS policy is applied to the inbound direction.
# Configure redirecting traffic to Ten-GigabitEthernet 3/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 3/0/1
# Configure redirecting traffic to a next hop in traffic behavior database.
[Sysname-behavior-database] redirect next-hop 10.55.66.1 track 1 10.55.88.1 track 2 fail-action discard
classifier behavior
qos policy
traffic behavior
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
A CVLAN marking action in a QoS policy takes effect only when it is applied to the inbound direction.
On the SC modules prefixed with LSCM2, SD interface modules, and SF interface modules, do not apply a QoS policy contains a CVLAN marking action to member ports of an aggregation group, VSIs, or VCs.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark dot1p dot1p-value
undo remark dot1p
No 802.1p priority marking action is configured.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
An 802.1p priority marking action in a QoS policy takes effect only when it is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
A QoS policy with a drop priority marking action takes effect only on the SC modules prefixed with LSCM2 and SE modules.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
remark dscp dscp-value
undo remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
On non-SF interface modules, a QoS policy with a DSCP marking action can be applied only in the inbound direction.
When you apply a QoS policy to the outbound direction on an SF interface module, follow these restrictions and guidelines:
·     The QoS policy is supported only when packets are forwarded within a chip.
·     The QoS policy is available only globally, for Layer 2 interfaces, and for Layer 3 Ethernet interfaces.
·     When you apply the QoS policy to a Layer 2 or Layer 3 Ethernet interface, it takes effect only on unicast packets.
·     When you apply the QoS policy to a Layer 3 Ethernet interface, it also takes effect on traffic of subinterfaces of the Layer 3 Ethernet interface.
·     If the packet characteristics change during forwarding and a traffic class matches the changing fields (for example, source MAC address), this feature does not take effect.
·     The local QoS ID match criterion is not supported.
The new DSCP value marked on the input interface for a packet does not take effect when it is forwarded out of the output interface if either of the following conditions exists:
·     The input interface and output interface are on different interface modules.
·     The input interface and output interface are on the same interface module but the values of the  LchipId field in the display hardware internal port mapping command output are different.
A DSCP marking action is not supported if the QoS policy is applied to a member port in an aggregation group or if the input interface match criterion is configured to match a member port in an aggregation group.
For SF interface modules:
·     A DSCP marking action does not take effect on ECMP traffic if the QoS policy is applied to the outbound direction or the if-match outbound-interface command is used in the traffic class.
·     A traffic behavior containing the remark dscp command does not take effect if either of the following conditions exist:
¡     The if-match outbound-interface command is used in the associated traffic class to match a member port of an aggregation group.
¡     The QoS policy is applied to a member port of an aggregation group.
·     A DSCP marking action does not take effect if the if-match egress-active qos-local-id command is used in the traffic class and the QoS policy is applied to the outbound direction.
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to restore the default.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark [ green | red | yellow ] local-precedence local-precedence-value [ green | red | yellow ]
undo remark [ green | red | yellow ] local-precedence [ green | red | yellow ]
No local precedence marking action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 15.
green: Marks packets as green packets.
red: Marks packets as red packets.
yellow: Marks packets as yellow packets.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
A local precedence marking action takes effect only on incoming packets on the SC modules prefixed with LSCM2.
Operating mechanism
A local precedence marking action assigns packets matching a traffic class to the specified queue, implementing differentiated services for packets. You can use the command to view outbound traffic statistics for queues.
When using this command to mark the local precedence for packets, you can also assign colors to the packets. By combining 16 different local precedence values with red, yellow, and green, you can use a total of 48 different markings for packets.
You can apply a QoS policy containing this command to mark the local precedence and color for packets on the input interface. Then, you can use the qos map-table color lp-tunnel-dscp command to modify the outer DSCP value of the packets on the output interface.
The qos map-table color lp-tunnel-dscp command takes effect only on outgoing packets of VXLAN tunnels or VXLAN-DCI tunnels.
If you specify a local precedence value in the range of 8 to 15, you must specify a color to be marked for the packets.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id [ egress-active ] local-id-value
undo remark qos-local-id [ egress-active ]
No local QoS ID marking action is configured.
egress-active: Specifies that the local QoS ID marking action takes effect only in the outbound direction.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095. If the egress-active keyword is specified, the value range is 1 to 128.
A local QoS ID marking action takes effect only when a OoS policy is applied to the inbound direction.
If you execute the remark qos-local-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
An SVLAN marking action in a QoS policy takes effect only when it is applied to the inbound direction.
For a packet with its SVLAN ID marked to be sent out of the output interface, make sure the SVLAN ID before marking is allowed on the output interface and the VLAN tag is not removed.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
remark source-mac
Use remark source-mac to configure a source MAC address marking action in a traffic behavior.
Use undo remark source-mac to restore the default.
remark source-mac mac-address
No source MAC address marking action is configured.
mac-address: Specifies the source MAC address to be marked for packets, in the format of H-H-H.
# Configure traffic behavior behavior1 to mark matching traffic with source MAC address 600b-038a-a395.
[Sysname-behavior-behavior1] remark source-mac 600b-038a-a395
traffic behavior
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode loose | insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode loose: Specifies that a class-behavior association is in loose mode. This mode takes effect only when a QoS policy is applied to a control plane.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# (In standalone mode.) Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
Use control-plane management to enter control-plane management view.
A QoS policy applied in control-plane management view takes effect on the packets sent from the management interface to the control plane.
# Enter control-plane management view.
[Sysname] control-plane management
[Sysname-cp-management]
display qos policy
Use display qos policy to display QoS policies.
In standalone mode:
display qos policy { user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] } [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
In IRF mode:
display qos policy { user-defined [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] } [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined QoS policies.
ipv6-matching: Specifies IPv6-matching QoS policies.
accounting: Specifies accounting-type QoS policies.
mirroring: Specifies mirroring-type QoS policies.
remarking: Specifies marking-type QoS policies.
tcp-erspan: Specifies TCP ERSPAN-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the QoS policies for the global active MPU. (In IRF mode.)
If you do not specify the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan keyword, this command displays generic QoS policies.
# Display all user-defined QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
# Display user-defined mirroring-type QoS policies.
<Sysname> display qos policy user-defined mirroring
  Mirroring policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
# Display user-defined TCP ERSPAN-type QoS policies.
<Sysname> display qos policy user-defined tcp-erspan
  TCP ERSPAN policy: 1 (ID 100)
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/0/1
Table 6 Command output
Information about a user-defined QoS policy.
System-defined QoS policy information
Information about a system-defined QoS policy.
Policy
User-defined QoS policy name.
IPv6 Matching policy
User-defined IPv6-matching QoS policy name.
Accounting policy
User-defined accounting-type QoS policy name.
Mirroring policy
User-defined mirroring-type QoS policy name.
Marking policy
User-defined marking-type QoS policy name.
TCP ERSPAN policy
User-defined TCP ERSPAN-type QoS policy name.
For the description of other fields, see Table 1 .
Use display qos policy control-plane to display QoS policies applied to a control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets), 0 (Bytes)
        0 (pps), 0 (bps)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Direction in which the QoS policy is applied.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane management to display the QoS policies applied in control-plane management view.
# Display the QoS policy applied in control-plane management view.
<Sysname> display qos policy control-plane management
Control plane management
  Direction: Inbound
  Policy: a
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
      -none-
   Classifier: a
     Matched : 3 (Packets) 180 (Bytes)
     Operator: OR
     Rule(s) :
      If-match control-plane protocol arp
      If-match control-plane protocol rip
      If-match control-plane protocol-group critical
      If-match acl 3001
      If-match control-plane protocol bgp
      If-match control-plane protocol bgp4+
      If-match control-plane protocol ftp
      If-match control-plane protocol http https icmp icmp6 ripng snmp
     Behavior: a
        CIR 128 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 3 (Packets) 180 (Bytes)
Table 8 Command output
Direction
For the description of other fields, see the display traffic classifier and display traffic behavior commands.
Use display qos policy control-plane management pre-defined to display the predefined QoS policy applied in control-plane management view.
# Display the predefined QoS policy applied in control-plane management view.
<Sysname> display qos policy control-plane management pre-defined
Pre-defined control plane policy management
  Protocol          Priority   Bandwidth                 Group
  Default           N/A        100000 (bps)             N/A
  ARP               N/A        128 (bps)                normal
  BGP               N/A        256 (bps)                critical
  BGPv6             N/A        256 (bps)                critical
  HTTP              N/A        512 (bps)                management
  HTTPS             N/A        512 (bps)                management
  ICMP              N/A        128 (bps)                monitor
  ICMPv6            N/A        128 (bps)                monitor
  OSPF Multicast    N/A        256 (bps)                critical
  OSPF Unicast      N/A        256 (bps)                critical
  OSPFv3 Multicast  N/A        256 (bps)                critical
  OSFPv3 Unicast    N/A        256 (bps)                critical
  RIP               N/A        1024 (bps)               critical
  RIPng             N/A        256 (bps)                critical
  SNMP              N/A        512 (bps)                management
  SSH               N/A        512 (bps)                management
  TELNET            N/A        512 (bps)                management
  FTP               N/A        512 (bps)                management
  TFTP              N/A        512 (bps)                management
Table 9 Command output
Predefined QoS policy applied in control-plane management view.
Protocol
System-defined protocol packet type.
Group
Protocol group to which the protocol belongs.
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the predefined control plane QoS policies for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays predefined control plane QoS policies for all cards. (In IRF mode.)
# (In standalone mode.) Display the predefined control plane QoS policy of slot 1.
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Default           N/A        1000 (pps)         N/A
  IS-IS             18         1000 (pps)         critical
  VRRP              19         1000 (pps)         important
  OSPF Multicast    18         1000 (pps)         critical
  OSPF Unicast      18         1000 (pps)         critical
  IGMP              11         500 (pps)          important
  OSPFv3 Unicast    18         1000 (pps)         critical
  OSPFv3 Multicast  18         1000 (pps)         critical
  VRRPv6            19         1000 (pps)         important
  ARP               2          1000 (pps)         normal
  DHCP Snooping     10         300 (pps)          redirect
  DHCP              10         300 (pps)          normal
  802.1x            3          500 (pps)          important
  STP               17         300 (pps)          critical
  LACP              22         300 (pps)          critical
  MVRP              15         300 (pps)          critical
  BGP               16         1000 (pps)         critical
  ICMP              3          500 (pps)          monitor
  TTL Expires       5          300 (pps)          monitor
  IPOPTION          5          300 (pps)          normal
  BGPv6             16         1000 (pps)         critical
  Hop Limit Expires 5          300 (pps)          monitor
  IPOPTIONv6        5          300 (pps)          normal
  LLDP              14         300 (pps)          important
  DLDP              16         300 (pps)          critical
  TELNET            1          800 (pps)          management
  SSH               1          800 (pps)          management
  TACACS            1          800 (pps)          management
  RADIUS            1          800 (pps)          management
  HTTP              3          500 (pps)          management
  HTTPS             3          500 (pps)          management
  SNMP              4          800 (pps)          management
  ARP Snooping      2          1000 (pps)         redirect
  ICMPv6            3          300 (pps)          monitor
  DHCPv6            10         300 (pps)          normal
  BFD               21         1000 (pps)         critical
Table 10 Command output
Contents of the predefined control plane QoS policy.
Protocols other than those listed.
Group
Protocol group of the protocol.
For descriptions of other fields, see Table 4.
Use display qos policy control-plane rule-statistics to display statistics for the QoS policy applied to a control plane.
In standalone mode:
display qos policy control-plane slot slot-number rule-statistics
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number rule-statistics
In IRF mode:
This command displays traffic statistics for an ACL match criterion on a per-rule basis. To display the traffic statistics, you must execute the accounting command in the traffic behavior to configure a traffic accounting action.
# (In standalone mode.) Display statistics for the QoS policy applied to the control plane in slot 0.In standalone mode:
<Sysname> display qos policy control-plane slot 0 rule-statistics
Control plane slot 0
  Direction: Inbound, Policy: p1, Status: Succeed
   Classifier: c1, Operator: AND, Behavior: b1, State: Succeed
   Accounting: Enabled, Car: Enabled
    if-match source-mac 0001-0001-0001
    if-match local-precedence 1
    if-match acl 3000
    rule 0 permit ip source 1.1.1.1 0
    Passed packets                     500, Passed pps                         5
    Dropped packets                    500, Dropped pps                        5
    Passed bytes                      5000, Passed bps                        50
    Dropped bytes                     5000, Dropped bps                       50
    if-match acl 3000
    rule 5 permit ip destination 2.2.2.2 0
Table 11 Command output
Direction
Status
QoS policy application result:
·     Succeed—The QoS policy is applied successfully.
·     Failed—The QoS policy fails to be applied. The statistics cannot be displayed.
Operator
Logical relationship between match criteria. Options include:
·     AND—A packet is counted only if it matches all match criteria configured by using if-match commands in a traffic class. The logical relationship between ACL rules in an ACL match criterion configured by using an if-match acl command is OR.
·     OR—A packet is counted if it matches any one of the match criteria configured by using if-match commands in a traffic class.
State of the class-behavior association:
·     Succeed—The class-behavior association is normal.
·     Failed—The class-behavior association is abnormal. For example, the traffic class contains match criteria that cannot both take effect or the traffic behavior contains conflicting actions. If the class-behavior association is abnormal, the statistics cannot be displayed.
Accounting
Indicates whether a traffic accounting action is configured in the traffic behavior.
If a traffic accounting action is not configured, the traffic statistics cannot be displayed.
Car
Indicates whether a traffic policing action is configured in the traffic behavior.
If a traffic policing action is not configured, the traffic statistics cannot be displayed.
Passed packets
Total number of forwarded packets. This field is displayed only if the accounting packet command is executed in the traffic behavior.
Passed bytes
Total number of forwarded bytes. This field is displayed only if the accounting byte command is executed in the traffic behavior.
Passed pps
Number of packets forwarded per second. This field is displayed only if the accounting packet command is executed in the traffic behavior.
Passed bps
Number of bytes forwarded per second. This field is displayed only if the accounting byte command is executed in the traffic behavior.
Dropped packets
Total number of dropped packets. This field is displayed only if the accounting packet command is executed in the traffic behavior.
Dropped bytes
Dropped pps
Number of packets dropped per second. This field is displayed only if the accounting packet command is executed in the traffic behavior.
Dropped bps
Number of bytes dropped per second. This field is displayed only if the accounting byte command is executed in the traffic behavior.
accounting
qos apply policy (control plane view)
Use display qos policy global to display QoS policies applied globally.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays global QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays global QoS policies for the global active MPU. (In IRF mode.)
If you do not specify the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
# Display information about mirroring-type QoS policies applied globally.
<Sysname> display qos mirroring policy global
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display information about IPv6-matching QoS policies applied globally.
<Sysname> display qos ipv6-matching policy global
  Direction: Inbound
  IPv6 Matching policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl ipv6 3000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display information about TCP ERSPAN-matching QoS policies applied globally.
<Sysname> display qos tcp-erspan policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: 1
      Mirroring:
Table 12 Command output
Direction
Policy
Accounting policy
Mirroring policy
Marking policy
TCP ERSPAN policy
display qos policy global rule-statistics
Use display qos policy global rule-statistics to display statistics for QoS policies applied globally.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ] rule-statistics
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
ipv6-matching: Specifies the IPv6 matching-type QoS policy.
accounting: Specifies the accounting-type QoS policy.
mirroring: Specifies the mirroring-type QoS policy.
remarking: Specifies the marking-type QoS policy.
tcp-erspan: Specifies the TCP ERSPAN-type QoS policy.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays global QoS policy statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays global QoS policy statistics for the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays statistics for QoS policies applied in each direction.
# (In standalone mode.) Display statistics for the QoS policies applied globally in the inbound direction in slot 0.In standalone mode:
<Sysname> display qos policy global slot 0 inbound rule-statistics
Slot 0
    if-match acl 3000
    if-match acl 3000
Table 13 Command output
Direction
Status
Operator
Accounting
Car
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
accounting
qos apply policy global
display qos policy interface
Use display qos policy interface to display the QoS policies applied to interfaces.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies on the active MPU. Only logical interfaces support this option. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays QoS policies on the global active MPU. Only logical interfaces support this option. (In IRF mode.)
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the QoS policy applied to the incoming traffic of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 3/0/1 inbound
Interface: Ten-GigabitEthernet3/0/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about the accounting-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos accounting policy interface ten-gigabitethernet 3/0/1 inbound
  Direction: Inbound
  Accounting Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (pps), 0 (bps)
# Display information about the marking-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos remarking policy interface ten-gigabitethernet 3/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display information about the mirroring-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos mirroring policy interface ten-gigabitethernet 3/0/1 inbound
  Direction: Inbound
  Mirroring policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the CPU
# Display information about the TCP ERSPAN-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos tcp-erspan policy interface ten-gigabitethernet 3/0/1 inbound
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/0/2
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: Ten-GigabitEthernet3/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
        Green packets : 0(Packets)
Interface: Ten-GigabitEthernet3/0/4
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/0/5
        Green action  : pass
Table 14 Command output
Direction
Policy
Accounting policy
Mirroring policy
Marking policy
TCP ERSPAN policy
Mode
Sharing mode for QoS and ACL resources.
This field appears only if a QoS policy is applied with the share-mode keyword.
Matched
Number of matching packets.
Forwarded
Average rate of successfully forwarded matching packets in a statistics collection period.
Dropped
Average rate of dropped matching packets in a statistics collection period.
Green packets
Traffic statistics are available only if an accounting action has been configured.
Traffic statistics for green packets.
Yellow packets
Traffic statistics for yellow packets.
Red packets
Traffic statistics for red packets.
display qos policy interface rule-statistics
Use display qos policy interface rule-statistics to display statistics for QoS policies applied to interfaces.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ] rule-statistics
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for QoS policies applied to each interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays interface-based QoS policy statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays interface-based QoS policy statistics for the global active MPU. (In IRF mode.)
# (In standalone mode.) Display statistics for the QoS policies applied to the inbound direction of each interface in slot 1.In standalone mode:
<Sysname> display qos policy global slot 1 inbound rule-statistics
Slot 1
    if-match acl 3000
    if-match acl 3000
Table 15 Command output
Direction
Status
Operator
Accounting
Car
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
accounting
qos apply policy (interface view)
display qos policy l2vpn-ac
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ chassis chassis-number slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policy information for all cards. Only Layer 2 aggregate interfaces support this option. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays QoS policy information for all cards. Only Layer 2 aggregate interfaces support this option. (In IRF mode.)
inbound: Specifies the QoS policies applied to incoming traffic. If you do not specify this keyword, the command execution results are the same.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 3/0/1.
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet3/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Table 16 Command output
Direction
Green packets
Yellow packets
Red packets
display qos policy l2vpn-ac rule-statistics
Use display qos policy l2vpn-ac rule-statistics to display statistics for QoS policies applied to Ethernet service instances.
In standalone mode:
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound | outbound ] rule-statistics
In IRF mode:
display qos [ ipv6-matching | accounting | mirroring | remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ chassis chassis-number slot slot-number ] ] [ inbound | outbound ] rule-statistics
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays statistics for QoS policies applied to Ethernet service instances on each interface.
service-instance instance-id:  Specifies an Ethernet service instance by its ID in the range of 1 to 4094. If you do not specify an Ethernet service instance, this command displays statistics for QoS policies applied to each Ethernet service instance.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays Ethernet service instance-based QoS policy statistics for each card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays Ethernet service instance-based QoS policy statistics for each card. (In IRF mode.)
# (In standalone mode.) Display statistics for QoS policies applied to each Ethernet service instance on Ten-GigabitEthernet 3/0/1 in slot 1Ten-GigabitEthernet3/0/1.In standalone mode:
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 slot 1 inbound rule-statistics
Slot 1
    if-match acl 3000
    if-match acl 3000
Table 17 Command output
Service instance ID
Ethernet service instance ID.
Direction
Status
Operator
·     OR— A packet is counted if it matches any one of the match criteria configured by using if-match commands in a traffic class.
Accounting
Car
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
accounting
qos apply policy (Ethernet service instance view)
display qos vlan-policy
Use display qos vlan-policy to display QoS policies applied to VLANs.
In standalone mode:
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied to VLANs for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays QoS policies applied to VLANs for the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
     Behavior: 2
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 18 Command output
Direction
display qos vlan-policy rule-statistics
Use display qos vlan-policy rule-statistics to display statistics for QoS policies applied to VLANs.
In standalone mode:
display qos vlan-policy vlan [ vlan-id ]  [ slot slot-number ] [ inbound | outbound ] rule-statistics
In IRF mode:
display qos vlan-policy vlan [ vlan-id ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ] rule-statistics
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays VLAN-based QoS policy statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays VLAN-based QoS policy statistics for the global active MPU. (In IRF mode.)
# (In standalone mode.) Display statistics for the QoS policy applied to the inbound direction of VLAN 10 in slot 1.In standalone mode:
<Sysname> display qos vlan-policy vlan 10 slot 1 inbound rule-statistics
Slot 0
Vlan 10
    if-match acl 3000
    if-match acl 3000
Table 19 Command output
Direction
Status
Operator
Accounting
Car
Passed packets
Passed bytes
Passed pps
Passed bps
Dropped packets
Dropped bytes
Dropped pps
Dropped bps
accounting
qos vlan-policy
qos apply policy (Ethernet service instance view, interface view, control plane view, control-plane management view)
Use qos apply policy to apply a QoS policy to a control plane, control-plane management view, Ethernet service instance or interface.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound } [ longest-match | share-mode ] *
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view/control-plane management view
Interface view
ipv6-matching: Specifies an IPv6-matching QoS policy. This keyword is supported only in interface view or Ethernet service instance view.
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view or Ethernet service instance view.
mirroring: Specifies a mirroring-type QoS policy. This keyword is supported only in interface view or Ethernet service instance view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view or Ethernet service instance view.
tcp-erspan: Specifies a TCP ERSPAN-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in Ethernet service instance view or VSI view.
longest-match: First matches the traffic class with a source or destination IP address with the longest mask and takes the actions in the associated traffic behavior if a match is found.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces with the same QoS policy applied in one direction share one QoS and ACL resource.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
·     if-match control-plane protocol
·     if-match control-plane protocol-group
·     if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡     The used ACL must be an advanced ACL.
¡     You must specify TCP or UDP for the protocol argument in the rule.
¡     You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
For configuration commands for Ethernet service instances, see MPLS L2VPN or VPLS in MPLS Command Reference or see VXLAN Command Reference.
If you do not specify the longest-match keyword, the system matches traffic against traffic classes in the order class-behavior associations are configured. When the traffic matches a traffic class, the matching process stops, and the actions in the associated traffic behavior are taken on the matching traffic.
If you specify the longest-match keyword, the system first matches the traffic class with a source or destination address with the longest mask and takes the actions in the associated traffic behavior. Suppose three class-behavior associations are configured in a QoS policy. ACL 3001 in the traffic class of the first class-behavior association is not configured with a source or destination address. ACL 3002 in the traffic class of the second class-behavior association is configured with destination address 10.10.10.0/24. ACL 3003 in the traffic class of the third class-behavior association is configured with destination address 10.10.10.10/32. The match order of the three class-behavior associations is the third class-behavior association, the second class-behavior association, the first class-behavior association. If both source and destination addresses exist in ACLs of different traffic classes, the system matches destination addresses before matching source addresses.
The longest-match keyword is supported only when a QoS policy is applied to an interface, a VSI, or the inbound direction of an Ethernet service instance.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
·     All interfaces on an interface module with the QoS policy applied in one direction share one QoS and ACL resource.
If the share-mode keyword is not specified, each interface uses one QoS and ACL resource in one direction.
·     All interfaces that share one QoS and ACL resource evenly share the set CIR if a traffic policing action is configured in the QoS policy.
If the share-mode keyword is not specified, the bandwidth of each interface can be limited to the CIR.
·     You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
·     Only SF interface modules support the share-mode keyword.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1.     Remove the QoS policy from the interface.
2.     Reapply the QoS policy with or without the share-mode keyword specified.
A maximum of six QoS policies (one for each type) can be applied to one direction of an interface. Different actions can be taken on the same traffic class if QoS policies of different types are applied to an interface.
For LSCM2XPG24SF0 and LSCM2XPT24SF0 cards, ONU interfaces do not support QoS policies and packet filtering, and OLT interfaces and ONU subinterfaces support QoS policies and packet filtering.
If you apply a QoS policy to a tunnel interface on an SF interface module, it takes effect only when the tunnel interface is one of the following tunnel modes:
·     IPv4 VXLAN.
·     IPv6 VXLAN.
·     IPv4 VXLAN-DCI.
·     IPv6 VXLAN-DCI.
# Apply QoS policy TEST1 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] qos apply policy TEST1 outbound
# Apply accounting-type QoS policy TEST2 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply accounting policy TEST2 outbound
# Apply mirroring-type QoS policy TEST3 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply mirroring policy TEST3 outbound
# Apply marking-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply remarking policy TEST4 outbound
# Apply TCP ERSPAN-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply tcp-erspan policy TEST4 outbound
# Apply QoS policy TEST5 to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy TEST5 inbound
# Apply generic QoS policy TEST9 to the incoming traffic of Ethernet service instance 200.
[Sysname-Ten-GigabitEthernet3/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet3/0/1-srv200] qos apply policy TEST9 inbound
# Apply IPv6-matching QoS policy TEST13 to the outgoing traffic of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply ipv6-matching policy TEST13 outbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ ipv6-matching |  accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound } [ longest-match ]
undo qos apply [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of six QoS policies (one generic, one IPv6-matching, one accounting-type, one mirroring-type, one marking-type, and one TCP ERSPAN-type) can be applied to one direction globally.
# Globally apply generic QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
# Globally apply mirroring-type QoS policy user2 to the incoming traffic.
[Sysname] qos apply mirroring policy user2 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
undo qos [ ipv6-matching | accounting | mirroring | remarking | tcp-erspan ] policy policy-name
No QoS policies exist.
ipv6-matching: Identifies the QoS policy as an IPv6-matching QoS policy.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
mirroring: Identifies the QoS policy as a mirroring-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
tcp-erspan: Identifies the QoS policy as a TCP ERSPAN QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
If you do not specify the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan keyword when creating a QoS policy, a generic QoS policy is created.
QoS policies of different types cannot use the same policy name.
Do not use the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan word or the first letters of any one of them as a policy name. If you do so, no information is displayed when you execute the display qos policy user-defined policy-name command, because the system will recognize such a policy name as a command keyword.
A generic QoS policy can be applied to all supported destinations and can contain all actions. An IPv6-matching QoS policy can be applied to only interfaces, Ethernet service instances, or globally and is used for traffic classes containing IPv6 ACL match criteria. An accounting-type QoS policy can be applied to only interfaces, Ethernet service instances, or globally and can contain only class-based accounting actions. A mirroring-type QoS policy can only be applied to interfaces, Ethernet service instances, or globally and can contain only mirroring actions. A marking-type QoS policy can be applied to only interfaces ,Ethernet service instances, or globally and can contain only marking actions. A TCP ERSPAN-type QoS policy can be applied to only interfaces or globally and can contain only ERSPAN actions.
In a TCP ERSPAN-type QoS policy, a traffic class matches TCP flags (including ACK, FIN, PSH, RST, SYN, and URG), and a traffic behavior contains an ERSPAN action. For more information about flow mirroring ERSPAN, see Network Management and Monitoring Configuration Guide.
To perform both flow mirroring and rate limiting for traffic, you can configure a generic QoS policy to rate limit traffic and configure a TCP ERSPAN-type QoS policy to perform flow mirroring for traffic. The two types of QoS policies are independent of each other in hardware resources.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# Create a mirroring-type QoS policy named user4.
[Sysname] qos mirroring policy user4
[Sysname-qospolicy-user4]
# Create an IPv6-matching QoS policy named user6.
[Sysname] qos ipv6-matching policy user6
[Sysname-qospolicy-user6]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound } [ longest-match ]
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
You can apply a QoS policy to one direction of a VLAN in either extended mode or common mode, but not both. A QoS policy applied in extended mode uses more hardware resources but supports limited parameters.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
reset qos policy control-plane management
Use reset qos policy control-plane management to clear the statistics of the QoS policy applied in control-plane management view.
# Clear the statistics of the QoS policy applied in control-plane management view.
<Sysname> reset qos policy control-plane management
reset qos policy global
Use reset qos policy global to clear statistics for QoS policies applied globally.
reset qos [ ipv6-matching | accounting | mirroring | remarking| tcp-erspan ] policy global [ inbound | outbound ]
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify a direction, this command clears statistics for the global QoS policies in both directions.
If you do not specify the ipv6-matching, accounting, mirroring, remarking, or tcp-erspan keyword, this command clears statistics for generic QoS policies.
# Clear statistics for the QoS policy applied to the inbound direction globally.
<Sysname> reset qos policy global inbound
# Clear statistics for the mirroring-type QoS policy applied to the inbound direction globally.
<Sysname> reset qos mirroring policy global inbound
reset qos policy l2vpn-ac
Use reset qos policy l2vpn-ac to clear the QoS policies applied to Ethernet service instances.
reset qos [ ipv6-matching | accounting | mirroring | remarking ]policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command clears QoS policies applied to all Ethernet service instances on an interface.
# Clear the QoS policies applied to the inbound direction of Ethernet service instance 1 on Ten-GigabitEthernet 3/0/1.
<Sysname> reset qos policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
# Clear the IPv6-matching QoS policy applied to the inbound direction of Ethernet service instance 1 on Ten-GigabitEthernet 3/0/1.
<Sysname> reset qos ipv6-matching policy l2vpn-ac interface ten-gigabitethernet 3/0/1 service-instance 1 inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
QoS SNMP notification commands
snmp-agent trap enable qos
Use snmp-agent trap enable qos to enable SNMP notifications for QoS.
Use undo snmp-agent trap enable qos to disable SNMP notifications for QoS.
SNMP notifications are disabled for QoS.
Execute this command to report critical QoS events by sending SNMP notifications.
For QoS notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for QoS.
[Sysname] snmp-agent trap enable qos
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dp | dscp-dscp | dscp-lp | exp-lp | lp-exp ]
The device provides the following types of priority map.
Table 20 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-lp
802.1p-local priority map.
dscp-dp
DSCP-drop priority map.
dscp-lp
DSCP-local priority map.
dscp-dscp
DSCP-DSCP priority map.
exp-lp
EXP-local priority map.
lp-exp
Local-EXP priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 21 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
display qos map-table color
Use display qos map-table color to display the configuration of a colored priority map.
display qos map-table color [ green | yellow | red ] [ lp-tunnel-dscp ]
green: Specifies green packets.
yellow: Specifies yellow packets.
red: Specifies red packets.
Table 22 Priority maps
Priority mapping
lp-tunnel-dscp
Local-outer DSCP priority map. This map is used for packets forwarded through a VXLAN tunnel or VXLAN-DCI tunnel.
This map must be used together with the qos vxlan-dci-tunnel outer dscp or vxlan-tunnel outer dscp command (see VXLAN Command Reference). After the command is executed, this map applies to all VXLAN packets.
Packets processed by traffic policing are colored green, yellow, or red. To perform priority mapping for packets in different colors, the device provides colored priority maps, each of which is a priority map specific to a color. For how traffic policing processes and colors packets, see ACL and QoS Configuration Guide.
If you do not specify a color, this command displays the configuration of priority maps for all three colors.
If you do not specify a direction, this command displays the configuration of the inbound and outbound priority maps.
If you do not specify a priority map, this command displays the configuration of all colored priority maps.
# Display the configuration of the local-outer DSCP priority map for green packets.
<Sysname> display qos map-table color green lp-tunnel-dscp
MAP-TABLE NAME: lp-tunnel-dscp   TYPE: pre-define   COLOR: green
IMPORT  :  EXPORT
   0    :    3
   1    :    7
   2    :   11
   3    :   15
   4    :   19
   5    :   23
   6    :   27
   7    :   31
   8    :   35
   9    :   39
  10    :   43
  11    :   47
  12    :   51
  13    :   55
  14    :   59
  15    :   63
Table 23 Command output
MAP-TABLE NAME
Priority map name.
TYPE
Priority map type.
COLOR
Priority map color.
DIRECTION
Direction of the priority map.
IMPORT
EXPORT
vxlan-dci-tunnel outer dscp (VXLAN Command Reference)
vxlan-tunnel outer dscp (VXLAN Command Reference)
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-lp | dscp-dp | dscp-dscp | dscp-lp | exp-lp | lp-exp }
For the description of keywords, see Table 20.
# Enter 802.1p-local priority map view.
import
qos map-table color
Use qos map-table color to enter the specified colored priority map view.
qos map-table color { green | yellow | red } lp-tunnel-dscp
Table 24 Priority maps
Priority mapping
lp-tunnel-dscp
For a type of colored priority mapping, the following priority maps exist:
·     One for inbound traffic.
·     One for outbound traffic.
·     One for traffic in both directions.
If you do not specify a direction, the priority map for traffic in both directions applies.
# Enter the view of the local-outer DSCP priority map for green packets.
[Sysname] qos map-table color green lp-tunnel-dscp
[Sysname-maptbl-green-lp-tunnel-dscp]
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 3/0/1
 Port priority information
  Port priority: 4
  Port dscp priority: -
  Port priority trust type: dscp
Table 25 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Port dscp priority
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-).
Priority trust mode on the interface:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface trusts the 802.1p priority in incoming packets.
Interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos trust dot1p
qos trust tunnel-dscp (system view)
Use qos trust tunnel-dscp to configure trusting the DSCP priority in the outer IP header of VXLAN packets.
Use undo qos trust tunnel-dscp to restore the default.
No priority trust mode is configured for VXLAN packets.
For a VXLAN tunnel interface to trust the DSCP priority in the outer IP header of VXLAN packets, you must also configure the qos trust dscp command on its physical interface.
The qos trust tunnel-dscp command is not supported when the system operating mode is standard. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
# Configure the switch to trust the DSCP priority in the outer IP header of VXLAN packets.
[Sysname] qos trust tunnel-dscp
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0.
Interface view
priority-value: Specifies a port priority value in the range of 0 to 7. If the device supports a DSCP port priority value, the value range is 0 to 63.
# Set the port priority of Ten-GigabitEthernet 3/0/1 to 2.
[Sysname-Ten-GigabitEthernet3/0/1] qos priority 2
GTS, and rate limit commands
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
Table 26 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
Interface view
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 10 to 1000000 for GE interfaces, 10 to 10000000 for 10-GE interfaces, 10 to 40000000 for 40-GE interfaces, and  10 to 100000000 for 100-GE interfaces. This value must be a multiple of 10.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 8355840, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 8355840 is converted to 8355840.
Only outgoing traffic on an interface is shaped.
# Shape the packets in queue 1 on Ten-GigabitEthernet 3/0/1. The GTS parameters are as follows:
·     The CIR is 260 kbps.
·     The CBS is 51200 bytes.
[Sysname-Ten-GigabitEthernet3/0/1] qos gts queue 1 cir 260 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration for all interfaces.
 Direction: Outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Table 27 Command output
Direction
Direction in which the rate limit configuration is applied.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
undo qos lr { inbound | outbound }
No rate limit is configured.
Interface view
inbound: Limits the rate of incoming packets.
outbound: Limits the rate of outgoing packets.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 10 to 1000000 for GE interfaces, 10 to 10000000 for 10-GE interfaces, 10 to 40000000 for 40-GE interfaces, and 10 to 100000000 for 100-GE interfaces. The value must be a multiple of 10.
cbs committee-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 8355840, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 8355840 is converted to 8355840.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 3/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet3/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet3/0/2
Table 28 Command output
Output queue
Type of the current output queue.
Group
Number of the group that holds the queue.
Byte-count
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 3/0/1
Table 29 Command output
Output queue
qos sp (interface view)
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
Interface view
# Enable SP queuing on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 3/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue name      Group           Byte count
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
Table 30 Command output
Output queue
Group
ID of the group a queue is assigned to.
Weight
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Byte count
Byte-count scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr (interface view)
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
Interface view
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
Interface view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 31.
Table 31 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group { 1 | 2 }: Specifies WRR group 1 or 2. If you do not specify a group, group 1 applies. Group 1 has higher scheduling priority than group 2. Queues in group 2 are serviced only when all queues in group 1 are empty.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 127.
# Enable byte-count WRR queuing on Ten-GigabitEthernet 3/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr 0 group 1 byte-count 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in WRR group 1.
Interface view
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 3/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet3/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos wfq interface ten-gigabitethernet 3/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               0
 1               af1             1               1               0
 2               af2             1               1               0
 3               af3             1               1               0
 4               af4             1               1               0
 5               ef              1               1               0
 6               cs6             1               1               0
 7               cs7             1               1               0
Table 32 Command output
Output queue
Group
ID of the group that holds the queue.
Byte-count
Weight
Packet-count queue scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Min Bandwidth
Minimum guaranteed bandwidth for the queue.
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth is not set.
Interface view
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The value range for committed-information-rate is 8 to 1000000 for GE interfaces, 8 to 10000000 for 10-GE interfaces, 8 to 40000000 for 40-GE interfaces, and  8 to 100000000 for 100-GE interfaces.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
For SE interface modules, only queue 5, queue 6, and queue 7 support the minimum guaranteed bandwidth.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 7 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq byte-count
[Sysname-Ten-GigabitEthernet3/0/1] qos bandwidth queue 7 min 100
qos wfq
qos wfq (interface view)
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
Interface view
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-count WFQ on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq weight
# Enable byte-count WFQ on Ten-GigabitEthernet 3/0/1.
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface are in WFQ group 1 and have a weight of 1.
Interface view
group { 1 | 2 }: Specifies WFQ group 1 or 2. If you do not specify a group, group 1 applies. Group 1 has higher scheduling priority than group 2. Queues in group 2 are serviced only when all queues in group 1 are empty.
schedule-value: Specifies a scheduling weight. The value range is 1 to 127.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 3/0/1, assign queue 0 to WFQ group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq 0 group 1 byte-count 10
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
All queues on a WFQ-enabled interface are in WFQ group 1.
Interface view
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on Ten-GigabitEthernet 3/0/1, and assign queue 7 to the SP group.
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq 7 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a WFQ queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 8 to 100000000.
You must configure a queue as a WFQ queue before you set the minimum guaranteed bandwidth for the queue.
On type-SE cards, you can set the minimum guaranteed bandwidth only for queues 5, 6, and 7.
# Configure queue 0 as a WFQ queue, and set the minimum guaranteed bandwidth to 100 kbps for queue 7.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 byte-count 1
[Sysname-qmprofile-myprofile] bandwidth queue 7 min 100
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
In standalone mode:
In IRF mode:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the queue scheduling profile configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the queue scheduling profile configuration for the global active MPU. (In IRF mode.)
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID  Type  Group   Schedule   Schedule  Min
                         unit       value     bandwidth
 be        WFQ   1       byte-count 1         0
 af1       SP    N/A     N/A        N/A       0
 af2       SP    N/A     N/A        N/A       0
 af3       SP    N/A     N/A        N/A       0
 af4       SP    N/A     N/A        N/A       0
 ef        SP    N/A     N/A        N/A       0
 cs6       SP    N/A     N/A        N/A       0
 cs7       SP    N/A     N/A        N/A       0
Table 33 Command output
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Priority group to which the queue belongs.
N/A indicates this field is ignored.
Schedule unit
Scheduling unit: weight or byte-count.
N/A indicates that this field is ignored.
Schedule value
This field indicates:
·     Number of packets for the weight scheduling unit.
·     Number of bytes for the byte-count scheduling unit.
Min bandwidth
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 3/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 3/0/1
Direction: Outbound
Table 34 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
Interface view
You can apply only one queue scheduling profile to one direction of an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can be 1 or 2.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 127.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 byte-count 10
qos qmprofile
Congestion avoidance commands
WRED commands
display qos wred fabric
Use display qos wred fabric to display the configuration of WRED tables applied to internal interfaces.
In standalone mode:
display qos wred fabric [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos wred fabric [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the configuration of the WRED table for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the configuration of the WRED table for the global active MPU. (In IRF mode.)
[ inbound | outbound ]: Specifies a WRED table applied to the inbound or outbound direction. If you do not specify a direction, this command displays the configuration of the WRED tables applied to the inbound and outbound directions. The direction from an interface card to a switching fabric module is the inbound direction. The reverse direction is the outbound direction.
# Display the configuration of the WRED table applied to internal interfaces for slot 1.
<Sysname> display qos wred fabric slot 1
Slot: 1
Inbound:
 Current WRED configuration:
  Applied WRED table name: q1                     Application status: Successful
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   100      1000     10   100      1000     10   100      1000     10   9   N
1   100      1000     10   100      1000     10   100      1000     10   9   N
2   100      1000     10   100      1000     10   100      1000     10   9   N
3   100      1000     10   100      1000     10   100      1000     10   9   N
4   100      1000     10   100      1000     10   100      1000     10   9   N
5   100      1000     10   100      1000     10   100      1000     10   9   N
6   100      1000     10   100      1000     10   100      1000     10   9   N
7   100      1000     10   100      1000     10   100      1000     10   9   N
Outbound:
Table 35 Command output
Application status
Application status: Successful or Failed.
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exp
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply fabric
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
Interface: Ten-GigabitEthernet3/0/3
Table 36 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
In standalone mode:
In IRF mode:
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the WRED table configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the WRED table configuration for the global active MPU. (In IRF mode.)
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
Table 37 Command output
Table name
Name of a WRED table.
Table type
QID
Queue ID.
gmin
gmax
gprob
ymin
ymax
yprob
rmin
rmax
rprob
exponent
ECN
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
Interface view
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wred apply table1
qos wred queue table
Use qos wred apply fabric to apply a WRED table to internal interfaces.
Use undo qos wred apply fabric to restore the default.
In standalone mode:
qos wred apply table-name fabric
In IRF mode:
qos wred apply [ table-name ] fabric [ chassis chassis-number slot slot-id { inbound | outbound } ]
undo qos wred apply fabric [ chassis chassis-number slot slot-id { inbound | outbound } ]
No WRED table is applied to internal interfaces, and tail drop is used on internal interfaces.
An interface module and a switching fabric module will use internal interfaces to exchange packets when necessary. Congestion might occur on internal interfaces. In this case, you can perform this task to address congestion issues.
For the S12500G-AF switch series, this command takes effect only on SF and SG interface modules and do not take effect on IRF ports. For more information about IRF, see Virtual Technologies Configuration Guide.
# Apply WRED table table1 to all internal interfaces.
[Sysname] qos wred apply table1 fabric
qos wred ecn enable
Use qos wred ecn enable to enable ECN globally.
Use undo qos wred ecn enable to disable ECN globally.
qos wred ecn enable
ECN is disabled globally.
This function enables ECN on all queues configured with WRED parameters. The queues can be queues configured with the qos wred queue commands in interface view and queues configured in a WRED table.
This command takes effect only on TCP packets and UDP packets on the following modules:
·     SC modules prefixed with LSCM2.
·     SD interface modules.
# Enable WRED on Ten-GigabitEthernet 3/0/1, and use the IP precedence for drop probability calculation.
[Sysname-Ten-GigabitEthernet3/0/1] qos wfq queue-length 100 queue-number 512
[Sysname-Ten-GigabitEthernet3/0/1] qos wred ip-precedence enable
queue
queue ecn
qos wred queue
qos wred queue ecn
qos wred smart-ecn enable
qos wred queue
Use qos wred queue to configure the WRED parameters for a queue.
Use undo qos wred queue to restore the default.
qos wred queue queue-id low-limit low-limit high-limit high-limit [ discard-probability discard-prob ] [ ecn ] [ weighting-constant exponent ]
qos wred queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo qos wred queue { queue-id [ drop-level drop-level ] | all }
The default for this command varies by device model.
Interface view
queue-id: Specifies a queue by its ID. The value range for this argument varies by device model.
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit varies by device model.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit varies by device model.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The default and the value range for discard-prob vary by device model.
ecn: Enables ECN.
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent varies by device model.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
all: Specifies all queues.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
Specifying the ecn keyword in this command has the same effect as executing the qos wred queue ecn command.
Specifying the weighting-constant exponent keyword in this command has the same effect as executing the qos wred queue weighting-constant command.
This command and the qos wred apply command are mutually exclusive.
# Configure the following WRED parameters for in queue 1 on Ten-GigabitEthernet 3/0/1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-Ten-GigabitEthernet3/0/1] qos wred queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred queue ecn
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
Use qos wred queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo qos wred queue weighting-constant to restore the default.
qos wred queue queue-id weighting-constant exponent
undo qos wred queue queue-id weighting-constant
The default for this command vary by device model.
Interface view
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
Executing this command has the same effect as specifying the weighting-constant exponent option in the qos wred queue command.
# Set the exponent for average queue length calculation to 12 for queue 1 on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] qos wred queue 1 weighting-constant 12
qos wred queue
queue (WRED table view)
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 69632. The value is in 288 bytes on the SC modules prefixed with LSCM2 and SE modules and in 256 bytes on LSCM1GT48SC0 cards.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 69632. The value is in 288 bytes on the SC modules prefixed with LSCM2 and SE modules and in 256 bytes on LSCM1GT48SC0 cards.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
The SC modules prefixed with LSCM2 and SD interface modules support only the range 0 to 10496 for the lower limit and upper limit for the average queue length. SE interface modules support only the range 0 to 22016. LSCM1GT48SC0 cards support only the range 0 to 10496.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Global CAR commands
car name
Use car name to use a global CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No global CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command displays information about all global CAR actions.
# (In standalone mode.) Display information about all global CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
   Yellow action : pass
   Red action    : discard
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
Table 38 Command output
Name
Name of the global CAR action.
Mode
Type of the CAR action, which can be aggregative.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Green packets
Statistics about green packets.
Yellow packets
Statistics about yellow packets.
Red packets
Statistics about red packets.
qos car (system view)
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the global CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 16 to 100000000, in increments of 8.
cbs committee-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 67092480, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 67092480 is converted to 67092480.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for excess-burst-size is 0 to 67092480, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 67092480 is converted to 67092480.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 16 to 100000000, in increments of 8.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7. This action takes effect only in the inbound direction on the SC modules prefixed with LSCM2.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is used in a QoS policy. A QoS policy containing an aggregate CAR action can be applied to only one direction in the same view.
If the action for yellow packets is configured as discard, the action for red packets can only be configured as discard.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command clears statistics for all global CAR actions.
# Clear the statistics about global CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Elephant and mice flows distinguishing commands
elephant-flow action
Use elephant-flow action to configure an action to take on elephant flows.
Use undo elephant-flow action to restore the default.
elephant-flow action { drop-precedence drop-precedence-value | dot1p dot1p-value | local-precedence local-precedence-value | none }
No action is configured. How elephant flows are processed depends on the device model.
Elephant/mice flow view
drop-precedence drop-precedence-value: Specifies a drop precedence value in the range of 0 to 2.
dot1p dot1p-value: Specifies an 802.1p priority value in the range of 0 to 7.
local-precedence local-precedence-value: Specifies a local precedence value in the range of 0 to 7.
none: Takes no action.
# Specify drop precedence 2 for elephant flows.
[Sysname] qos mice-elephant-flow
[Sysname-mice-elephant-flow] elephant-flow action drop-precedence 2
elephant-flow rate
elephant-flow rate
Use elephant-flow rate to configure the traffic thresholds to identify elephant flows.
Use undo elephant-flow rate to remove traffic threshold settings.
elephant-flow rate rate [ gbps | kbps | mbps ] [ size size [ bytes | kbytes | mbytes ] ]
No traffic thresholds are configured.
rate [ gbps | kbps | mbps ]: Specifies the traffic rate threshold in Gbps, kbps, or Mbps. The default unit is kbps. The value range for the rate argument is 1 to 1000.
size size [ bytes | kbytes | mbytes ]: Specifies the traffic size threshold in bytes, KB, or MB. The default unit is byte. The value range for the rate argument is 1 to 1000.
The device assigns the drop precedence value specified the elephant-flow action command to the identified elephant flows and keeps the drop precedence of mice flows unchanged. When congestion occurs, packets with a lower or no drop precedence are preferentially forwarded.
# Specify the traffic thresholds as 20 kbps and 100 KB for identifying elephant flows.
[Sysname-mice-elephant-flow] elephant-flow rate 20 kbps size 100 kbytes
agile-buffer enable
Use agile-buffer enable to enable the flexible buffer for elephant and mice flows.
Use undo agile-buffer enable to disable the flexible buffer for elephant and mice flows.
agile-buffer enable
The flexible buffer for elephant and mice flows is disabled.
For the flexible buffer for elephant and mice flows to take effect, you must configure the following features:
·     Enable the feature of distinguishing elephant and mice flows as follows:
a.     Execute the elephant-flow rate command to configure the parameters for identifying elephant flows.
b.     Execute the elephant-flow action command with the local-precedence keyword specified to configure the local precedence of elephant flows.
·     Create a flow group in mice-elephant-flow mode or apply a predefined flow group in mice-elephant-flow mode. For more information about flow groups in mice-elephant-flow mode, see flow group commands in Telemetry Command Reference
Application scenarios
The feature of distinguishing and scheduling elephant flows and mice flows statically configures parameters (for example, flow rate and size) to identify elephant flows in network traffic. Additionally, this feature specifies a lower drop priority, local priority, or 802.1p priority to these elephant flows. In the event of congestion, the device preferentially drops elephant flows based on the assigned priority to ensure fast forwarding of mice flows. The feature of distinguishing elephant and mice flows can partially resolve the issue that mice flows are blocked by elephant flows. However, in scenarios where the vast majority of traffic in the network contains mice flows or in scenarios of bursty traffic, the optimization effect of the elephant and mice flow distinguishing feature, which identifies flows through statically configured parameters, is not ideal. For example, in data center networks, where the majority of traffic contains mice flows that are more sensitive to delay. In the preceding scenarios, you can enable the flexible buffer for elephant and mice flows.
Operating mechanism
On the device, mice flow queues and elephant flow queues share a buffer space to schedule packets. This feature dynamically adjusts the size of the shared buffer space occupied by the mice flow queues and the elephant flow queues. When the network is congested and packets are dropped, the system dynamically reduces the upper limit of the shared buffer space available for elephant flow queues while ensuring high throughput of the elephant flows. In this case, the upper limit of the shared buffer space available for mice flow queues is increased, allowing the shared buffer space to accommodate as much mice flow traffic as possible, avoiding packet loss and reducing delay for mice flows. The device operates as follows after the flexible buffer for elephant and mice flows is enabled:
3.     By default, both the elephant flow queues and the mice flow queues use the tail-drop method to drop packets. In this case, when the length of either elephant flow queues or mice flow queues occupies the entire buffer space, all new packets entering the buffer space will be dropped.
4.     When the network is congested and packet loss occurs in the mice flow queues, the system triggers the flexible buffer feature for the elephant flows. In this case, the elephant flows use the WRED drop threshold. The system reduces the drop threshold of the elephant flow queues and uses the WRED method to drop elephant flow packets with a certain probability. As a result, the space for mice flow packets in the shared buffer increases.
5.     If the device still detects packet loss for mice flows after a certain detection period, this feature further lowers the WRED drop threshold for the elephant flow queues to increase the space for mice flow packets in the shared buffer.
6.     If no packet loss occurs in the mice flows during a detection period, this feature gradually restores the drop threshold of the elephant flow queues to the default tail drop method of the system.
With this feature enabled, the system will dynamically set the WRED drop threshold (the lower limit of the queue length) for the elephant flow queues. Therefore, this feature conflicts with the statically configured WRED parameters or a WRED table applied on an interface. If you both configure this feature and configure static WRED parameters or apply a WRED table, the static WRED parameters or applied WRED table takes precedence.
# Enable the flexible buffer for elephant and mice flows.
[Sysname-mice-elephant-flow] agile-buffer enable
elephant-flow rate
Use qos mice-elephant-flow to enter elephant/mice flow view.
# Enter elephant/mice flow view.
Traffic Matrix commands
display traffic-matrix
Use display traffic-matrix to display the flow tables of Traffic Matrix.
In standalone mode:
display traffic-matrix [ dynamic ] [ ip | ipv6 ] [ slot slot-number ]
In IRF mode:
display traffic-matrix [ dynamic ] [ ip | ipv6 ] [ chassis chassis-number slot slot-number ]
dynamic: Displays dynamically generated Traffic Matrix flow entries in adaptive routing scenarios. If you do not specify this keyword, the command displays statically configured Traffic Matrix flow entries.
ip: Specifies the IPv4 flow table. If you do not specify this keyword and the ipv6 keyword, the command displays both IPv4 and IPv6 flow tables.
ipv6: Specifies the IPv6 flow table. If you do not specify this keyword and the ip keyword, the command displays both IPv4 and IPv6 flow tables.
slot slot-number: Specifies a card by its slot number. The slot-number argument represents the slot number of the card. If you do not specify a card, the command displays Traffic Matrix flow entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, the command displays Traffic Matrix flow entries for all cards. (In IRF mode.)
Traffic Matrix flow entries can be statically configured or dynamically generated.
·     Static configuration—You can use the ipv6 source destination or ip source destination command to generate a Traffic Matrix flow entry.
·     Dynamic generation—In adaptive routing scenarios, the device automatically collects network node congestion data and dynamically generates Traffic Matrix flow entries.
# Display all statically configured flow entries.
<Sysname> display traffic-matrix
Slot : 0
Protocol    : 17
SPort       : 4791               SIP     : 1.1.1.1
DPort       : 4791               DIP     : 2.2.2.2
Traffic path: GE1/0/1            Next hop: 1.1.1.2
Status      : Active             Reason  : -
Protocol    : 17
SPort       : -                  SIP     : 1.1.1.1
DPort       : -                  DIP     : 2.2.2.2
Status      : Inactive           Reason  : Interface down
Protocol    : -
Status      : Inactive           Reason  : Destination unreachable
Slot : 1
Protocol    : 17
Protocol    : 17
Status      : Inactive           Reason  : ARP/ND unreachable
Protocol    : -
Status      : Inactive           Reason  : Remote path failure
# Display dynamically generated Traffic Matrix flow entries.
<Sysname> display traffic-matrix dynamic
Slot : 0
Protocol    : 17
Aging       : 5 minutes remaining
Table 39 Command output
Protocol
Protocol number,
SPort
Source port number.
SIP
Source IP address.
DPort
Destination port number.
DIP
Destination IP address.
Traffic path
Output interface to which traffic is redirected.
Next hop
Next-hop address to which traffic is redirected.
Status
Effective state of a flow entry:
·     Active—The flow entry is effective.
·     Inactive—The flow entry is ineffective.
Reason
Reason why a flow entry fails to take effect:
·     Interface down—The output interface is down.
·     Destination Unreachable—The next-hop address is unreachable.
·     ARP/ND unreachable—The ARP or ND entry is unavailable.
·     Remote path failure—BGP detects a remote path failure.
·     Resource not enough—Resources are insufficient.
·     Not ready—The device driver is not ready. The device driver might be ready after a moment. You can execute the command later.
·     -—The flow entry takes effect.
Aging
Aging time of a dynamically generated Traffic Matrix flow entry:
·     x minutes remaining—Number of minutes remaining before the flow entry is aged out.
·     Aged—The flow entry has been aged out.
·     -—Traffic is continuously present before half of the aging time elapses.
Use ip source destination to configure an IPv4 flow entry for Traffic Matrix.
Use undo ip source destination to delete an IPv4 flow entry for Traffic Matrix.
ip [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ip [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix does not have an IPv4 flow entry.
Traffic Matrix View
protocol protocol: Specify a protocol type by its number in the range of 0 to 255. If you do not specify a protocol type, any protocol type can be matched.
source source-address: Specifies a source IPv4 address.
destination dest-address: Specifies a destination IPv4 address.
source-port port: Specifies a source port in the range of 0 to 65535. If you do not specify a source port, any source port can be matched.
destination-port port: Specifies a destination port in the range of 0 to 65535. If you do not specify a destination port, any destination port can be matched.
traffic-path interface interface-type interface-number: Redirect matching traffic to the specified interface for forwarding.
next-hop ip-address: Redirects matching traffic to the specified next-hop IP address. The next-hop IP address can be an IPv4 address or an IPv6 address.
Operating mechanism
Use this command to redirect traffic to the specified output interface and next hop for forwarding. The redirected traffic must match the source address, destination address, source port number, destination port number, and protocol type specified in this command.
Multiple IPv4 flow entries can be configured for Traffic Matrix. If you configure multiple IPv4 flow entries with the same 5-tuple, the most recent configuration takes effect.
In the Traffic Matrix feature, the source address, destination address, and next-hop address of an IPv4 flow entry must all be valid unicast addresses.
The Traffic Matrix feature regularly queries the routing table to identify whether the next-hop address specified in the ip source destination command is reachable in the routing table. If the next-hop address is unreachable, the ip source destination command will no longer be effective.
If the same flow can match multiple IPv4 flow entries in the Traffic Matrix feature, the priority order for IPv4 flow entries is as follows:
7.     The IPv4 flow entry that is configured with the 5-tuple has the highest priority.
8.     Other IPv4 flow entries are matched in their order of configuration. When a match is found, the matching process stops.
As a best practice to prevent the same flow from being forwarded through different paths before and after the device reboots or the interface flaps, do not configure two flow entries with the same source address and destination address and other overlapping match items. Suppose you configure one flow entry with a protocol, a source address, and a destination address, and the other flow entry with the same source address and destination address but without a protocol. The flow that can match the two entries might match different flow entries and is forwarded through different paths before and after the device reboots or the interface flaps.
# Configure an IPv4 flow entry.
[Sysname] traffic-matrix
[Sysname-traffic-matrix] ip protocol 80 source 1.1.1.1 destination 2.2.2.2 source-port 8080 destination-port 8080 traffic-path interface gigabitethernet 1/0/1 next-hop 3.3.3.3
Use ipv6 source destination to configure an IPv6 flow entry for Traffic Matrix.
Use undo ipv6 source destination to delete an IPv6 flow entry.
ipv6 [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ] traffic-path interface interface-type interface-number next-hop ip-address
undo ipv6 [ protocol protocol ] source source-address destination dest-address [ source-port port destination-port port ]
Traffic Matrix does not have an IPv6 flow entry.
Traffic Matrix view
protocol protocol: Specifies a protocol type by its number in the range of 0 to 255. If you do not specify a protocol type, any protocol type can be matched.
source source-address: Specifies a source IPv6 address.
destination dest-address: Specifies a destination IPv6 address.
traffic-path interface interface-type interface-number: Redirects matching traffic to the specified interface for forwarding.
Operating mechanism
Multiple IPv6 flow entries can be configured for Traffic Matrix. If you configure multiple IPv6 flow entries with the same 5-tuple, the most recent configuration takes effect.
In the Traffic Matrix feature, the source address, destination address, and next-hop address in an IPv6 flow entry must all be valid unicast addresses.
The Traffic Matrix feature regularly queries the routing table to identify whether the next-hop address specified in the ipv6 source destination command is reachable in the routing table. If the next-hop address is unreachable, the ipv6 source destination command will no longer be effective.
If the same flow can match multiple IPv6 flow entries in the Traffic Matrix feature, the priority order for IPv6 flow entries is as follows:
9.     The IPv6 flow entry that is configured with the 5-tuple has the highest priority.
10.     Other IPv6 flow entries are matched in their order of configuration. When a match is found, the matching process stops.
# Configure an IPv6 flow entry.
[Sysname-traffic-matrix] ipv6 protocol 80 source 1::1 destination 2::2 source-port 8080 destination-port 8080 traffic-path interface gigabitethernet 1/0/1 next-hop 3::3
traffic-matrix
Use traffic-matrix to enable the Traffic Matrix feature and enter Traffic Matrix view.
Use undo traffic-matrix to disable the Traffic Matrix feature and delete all its flow tables.
traffic-matrix
undo traffic-matrix
The Traffic Matrix feature is disabled.
In scenarios where AI model training occurs in data center networks or intelligent lossless networks, there are fewer traffic flows, but each flow has long transmission time and large data volumes. When traffic load sharing is conducted using the hash algorithm through equal-cost multi-path (ECMP), load imbalance can easily occur. To address uneven traffic load, enable the Traffic Matrix feature. The controller, based on the 5-tuple, deploys flow entries to leaf or spine devices to redirect traffic. Traffic is redirected to the specified path for forwarding, thus achieving manually controlled load sharing.
Operating mechanism
·     Static configuration—You can use the ipv6 source destination or ip source destination command to generate a Traffic Matrix flow entry. A flow that matches a flow entry is forwarded according to the specified output interface and next hop.
Statically configured Traffic Matrix flow entries have higher priority than dynamically generated ones.
The device forwards traffic first according to the path defined in the flow table. If the defined path is invalid (for example, the output interface fails or the next hop is unreachable), the traffic is then forwarded by looking up the routing table.
# Enable the Traffic Matrix feature and enter Traffic Matrix view.
Interface packet accounting commands
display qos packet-statistics interface
Use display qos packet-statistics interface to display interface packet statistics.
display qos packet-statistics interface interface-type interface-number { inbound | outbound }
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
# Display inbound packet statistics for Ten-GigabitEthernet 3/0/1.
<Sysname> display qos packet-statistics interface ten-gigabitethernet 3/0/1 inbound
Interface: Ten-GigabitEthernet3/0/1
 DSCP       ECN         Statistics
 0          0           1 packets, 100 bytes
 0          1           1 packets, 100 bytes
 0          2           1 packets, 100 bytes
 0          3           1 packets, 100 bytes
 63         3           1 packets, 100 bytes
Use qos packet-statistics to configure packet accounting on an interface.
Use undo qos packet-statistics to restore the default.
qos packet-statistics { inbound | outbound }  ecn
undo qos packet-statistics { inbound | outbound }
Packet accounting is disabled on an interface.
Interface view
ecn: Counts ECN packets.
# Enable packet accounting for ECN packets with the DSCP priority in the inbound direction of Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] qos packet-statistics inbound dscp ecn
reset qos packet-statistics interface
Use reset qos packet-statistics interface to clear interface packet statistics.
reset qos packet-statistics interface interface-type interface-number { inbound | outbound }
If you do not specify a direction, this command clears interface packet statistics for both directions.
# Clear inbound packet statistics for Ten-GigabitEthernet 3/0/1.
<Sysname> reset qos packet-statistics interface ten-gigabitethernet 3/0/1 inbound
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
The function of displaying queue-based outgoing traffic statistics is supported only on the SF interface modules.
To use the queue-based accounting feature, you must enable AI ECN.
If you enable AI ECN for the specified queue, byte statistics will be collected for all queues.
Queue-based byte accounting does not support IPv6 packets.
Queue-based byte accounting does not count inter-frame gaps. The smaller the byte count, the less the displayed bps value accurately reflects the actual traffic flow.
The queue-based byte statistics are refreshed every three seconds. If you obtain the statistics multiple times within the period, the byte count and bps value do not change.
# Display queue-based outgoing traffic statistics of Ten-GigabitEthernet 3/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 3/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Queue 0
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
Table 40 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic both in the number of packets and in the number of bytes.
Current number of packets in the queue.
reset counters interface (Interface Command Reference)
qos queue-statistics byte-count
Use qos queue-statistics byte-count to configure the unit for queue-based traffic accounting as byte count.
Use undo qos queue-statistics byte-count to restore the default.
Queue-based traffic accounting is not performed in bytes.
Interface view
After you execute this command, you can use the display qos queue-statistics interface command to view queue-based traffic statistics in bytes.
If you configure the unit for queue-based traffic accounting as byte count in system view, the configuration takes effect on all interfaces. Even if an interface is configured with the undo qos queue-statistics byte-count command, it can still perform queue-based traffic accounting in bytes.
Executing this command in system view will consume a large number of ACL resources. To save ACL resources, execute this command in interface view.
# Configure the unit for queue-based traffic accounting as byte count in system view.
[Sysname] qos queue-statistics byte-count
