03-SRv6 OAM commands | 74.35 KB |
SRv6 OAM commands
ping ipv6-sid
Use ping ipv6-sid to detect connectivity of an SRv6 path.
ping ipv6-sid [ -a source-ipv6 | -c count | -m interval | -q | -s packet-size | -t timeout | -tc traffic-class | -v ] * [ segment-by-segment ] sid &<1-11>
-a source-ipv6: Specifies an IPv6 address of the device as the source IP address of ICMP echo requests. If you do not specify this option, the source address specified in the encapsulation source-address command applies. If the encapsulation source-address command is not configured, the IPv6 address of the outbound interface for the ICMP echo requests applies.
-c count: Specifies the number of ICMPv6 echo requests to be sent to the destination. The value range is 1 to 4294967295, and the default is 5.
-m interval: Specifies the interval (in milliseconds) to send ICMPv6 echo requests. The value range is 1 to 65535, and the default is 1000.
-q: Displays only the summary statistics. If you do not specify this keyword, the system displays all the ping statistics.
-s packet-size: Specifies the length (in bytes) of ICMPv6 echo requests (excluding the IPv6 packet header and the ICMPv6 packet header). The value range is 20 to 9600, and the default is 56.
-t timeout: Specifies the timeout time (in milliseconds) of an ICMPv6 echo reply. The value range is 0 to 65535, and the default is 2000.
-tc traffic-class: Specifies the traffic class value in ICMPv6 packets. The value range is 0 to 255 and the default is 0.
-v: Displays detailed information about ICMPv6 echo replies. If you do not specify this keyword, the system only displays brief information about ICMPv6 echo replies.
segment-by-segment: Performs segment-by-segment ping. If you do not specify this keyword, end-to-end ping is performed.
sid&<1-11>: Specifies a space-separated list of up to 11 SRv6 SIDs.
To identify one of the multiple SRv6 paths between the source and destination nodes, you can specify the SRv6 SIDs of multiple nodes on the specific path.
You can perform SRv6 SID-based ping operations for only DX4, DX6, DT4, DT6, DT46, DX2, DT2U, and DT2M SIDs.
To abort the SRv6 SID-based ping operation during the execution of the command, press Ctrl+C.
# Perform end-to-end ping to detect the SRv6 path connectivity (the SRv6 SID of the intermediate node is 1010::1:0:1b, and the SRv6 SID of the destination node is 1020::1:0:3).
<sysname> ping ipv6-sid 1010::1:0:1b 1020::1:0:3
Ping SRv6(56 data bytes) 1::1 --> 1010::1:0:1b 1020::1:0:3, press CTRL_C to break
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=64 time=62.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=64 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=64 time=20.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=64 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=64 time=16.000 ms
--- Ping6 SRv6 statistics ---
round-trip min/avg/max/std-dev = 4.000/25.000/62.000/20.000 ms
# Perform segment-by-segment ping to detect the SRv6 path connectivity (the SRv6 SID of the intermediate node is 1010::1:0:1b and the SRv6 SID of the destination node is 1020::1:0:3).
<sysname> ping ipv6-sid segment-by-segment 1010::1:0:1b 1020::1:0:3
56 bytes from 1010::1:0:1b, icmp_seq=0 ttl=64 time=36.000 ms
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=63 time=62.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=1 ttl=64 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=63 time=43.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=2 ttl=64 time=10.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=63 time=20.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=3 ttl=64 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=63 time=12.000 ms
56 bytes from 1010::1:0:1b, icmp_seq=4 ttl=64 time=7.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=63 time=16.000 ms
5 packet(s) transmitted, 10 packet(s) received
round-trip min/avg/max/std-dev = 4.000/23.000/62.000/20.000 ms
# Detect reachability of the node whose SRv6 SID is 1020::1:0:3. Only summary statistics are displayed.
<Sysname> ping ipv6-sid –q 1010::1:0:1b 1020::1:0:3
Ping SRv6 (56 data bytes) 1::1 --> 1010::1:0:1b 1020::1:0:3, press CTRL_C to break
# Detect reachability of the node whose SRv6 SID is 1020::1:0:3. Detailed ping statistics are displayed.
<Sysname> ping ipv6-sid –v 1010::1:0:1b 1020::1:0:3
56 bytes from 1020::1:0:3, icmp_seq=0 ttl=64 dst=1010::1:0:1a idx=129 time=62.000 ms
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=64 dst=1010::1:0:1a idx=129 time=23.000 ms
56 bytes from 1020::1:0:3, icmp_seq=2 ttl=64 dst=1010::1:0:1a idx=129 time=20.000 ms
56 bytes from 1020::1:0:3, icmp_seq=3 ttl=64 dst=1010::1:0:1a idx=129 time=4.000 ms
56 bytes from 1020::1:0:3, icmp_seq=4 ttl=64 dst=1010::1:0:1a idx=129 time=16.000 ms
Ping SRv6 1::1 --> 1010::1:0:1b 1020::1:0:3, 56 data bytes, press CTRL_C to break |
ICMPv6 echo requests with a data length of 56 bytes are sent through an intermediate SRv6 node with SID 1010::1:0:1b to the destination node with SRv6 SID 1020::1:0:3. Press Ctrl+C to abort the ping operation. |
56 bytes from 1020::1:0:3, icmp_seq=1 ttl=64 dst=12::1 idx=129 time=62.000 ms |
Received ICMPv6 echo replies from the SRv6 node whose SID is 1020::1:0:3. · The number of data bytes is 56. · The SRv6 SID of the destination node is 1020::1:0:3. · The packet sequence is 1. · The hop limit value is 64. · The destination address is 12::1. Specify the -v keyword to display this field. · The index for the packet inbound interface is 129. Specify the -v keyword to display this field. · The response time is 62 milliseconds. |
--- Ping6 SRv6 statistics --- |
Statistics on data received and sent in a ping operation. |
5 packet(s) transmitted |
Number of ICMPv6 echo requests sent. |
5 packet(s) received |
Number of ICMPv6 echo replies received. |
0.0% packet loss |
Percentage of unacknowledged requests to the total requests sent. |
round-trip min/avg/max/ std-dev =4.000/25.000/62.000/20.000 ms |
Minimum/average/maximum/standard deviation response time, in milliseconds. |
Opcode
tracert ipv6-sid
Use tracert ipv6-sid to display the path that the IPv6 packets containing the specified SRv6 SID list traverse from the source node to the destination node.
tracert ipv6-sid [ -a source-ipv6 | -f first-hop | -i interface-type interface-number | -m max-hops | -p port | -q packet-number | -s packet-size | -t traffic-class | -w timeout ] * [ overlay ] sid &<1-11>
-a source-ipv6: Specifies a valid IPv6 address on the device as the source IPv6 address of the probe packets. If you do not specify this option, the source address specified in the encapsulation source-address command applies. If the encapsulation source-address command is not configured, the IPv6 address of the outbound interface for the probe packets applies.
-f first-hop: Specifies the TTL value of the first packet. The value range is 1 to 255, and the default is 1. The value must be no greater than the value of the max-hops argument.
-i interface-type interface-number: Specifies the outbound interface by its type and number. You must specify this option if the next hop address is a multicast address or link-local address. If you do not specify this option, the device determines the outbound interface for probe packets by looking up the forwarding table according to their destination IPv6 addresses.
-m max-hops: Specifies the maximum number of hops allowed for a packet. The value range is 1 to 255, and the default is 30. The value must be no smaller than the value of the first-hop argument.
-p port: Specifies an invalid UDP port of the destination. The value range is 1 to 65535, and the default is 33434.
-q packet-number: Specifies the number of probe packets sent each time. The value range is 1 to 65535, and the default is 3.
-s packet-size: Specifies the length (in bytes) of probe packets (excluding the IPv6 packet header and the ICMPv6 packet header), in the range of 20 to 9600, and the default is 56.
-t traffic-class: Specifies the traffic class value in an IPv6 probe packet. The value range is 0 to 255, and the default is 0.
-w timeout: Specifies the timeout time (in milliseconds) of the reply packet of a probe packet. The value range is 1 to 65535, and the default is 5000.
overlay: Performs overlay tracert. If you do not specify this keyword, hop-by-hop tracert is performed. If you specify this keyword, you cannot specify the -f or -m keyword.
After identifying network failure with the ping ipv6-sid command, you can use the tracert ipv6-sid command to locate failed nodes.
The output from the tracert ipv6-sid command includes SRv6 SIDs of all the devices that the packets traverse from source to destination. Asterisks (* * *) are displayed if the device cannot reply with an ICMP error message. The reason might be the destination is unreachable or sending ICMP timeout/destination unreachable packets is disabled.
Before starting a tracert operation, you must enable sending of ICMPv6 destination unreachable messages on the intermediate devices between the source and destination. The tracert operation stops if any of the following ICMPv6 destination unreachable messages is received:
· !N—No route to destination.
· !P—Communication with destination administratively prohibited by filtering policies.
· !A—Address unreachable. The unreachable reason is unknown.
· !S—Beyond scope of source address. This message is displayed if the probe packet has a link-local source address and a non-link-local destination address. Such a packet cannot be delivered to the destination without leaving the scope of the source address.
To abort the tracert operation during the execution of the command, press Ctrl+C.
# Perform hop-by-hop tracert to display information about the SRv6 path (the SRv6 SID of the intermediate node is 1010::1:0:1b, and the SRv6 SID of the destination node is 1020::1:0:3).
<Sysname> tracert ipv6-sid 1010::1:0:1b 1020::1:0:3
Traceroute SRv6 1010::1:0:1b 1020::1:0:3 from 1::1, 30 hops at most, 60 bytes packets, press CTRL_C to break
1 15::1 [SRH: 1020::1:0:3, 1010::1:0:1b, SL=1] 0.661 ms 0.618ms 0.579ms
2 12::2 [SRH: 1020::1:0:3, 1010::1:0:1b, SL=0] 0.861 ms 0.718ms 0.679ms
Traceroute SRv6 1010::1:0:1b 1020::1:0:3 from 1::1 |
Display the SRv6 path that the IPv6 packets traverse through the intermediate node (whose SRv6 SID is 1010::1:0:1b) to the destination node (whose SRv6 SID is 1020::1:0:3). |
hops at most |
Maximum number of hops of the probe packets. |
byte packets |
Number of bytes of a probe packet (including the IPv6 basic header, transport layer packet header, and payload, and excluding the IPv6 extension header, such as SRH and HBH). |
2 12::2 [SRH: 1020::1:0:3, 1010::1:0:1b, SL=0] 0.861 ms 0.718ms 0.679ms |
Probe result of the probe packets that contain a hop limit value of 2, including the following information about the second hop: · IPv6 address of the hop. · SRH information in the ICMPv6 reply message, including the SRv6 SID list and number of remaining SRv6 SIDs (SL). · The round-trip time of the probe packets, in milliseconds. |
ipv6 unreachables enable (Layer 3—IP Services Command Reference)
opcode
ping ipv6-sid
