- 06-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-DCN commands
- 14-Dual-stack PBR commands
- 15-Adaptive routing commands
11-IPv6 policy-based routing commands | 202.73 KB |
display ipv6 policy-based-route
display ipv6 policy-based-route global
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
ipv6 global policy-based-route
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
reset ipv6 policy-based-route statistics
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
NOTE: This command takes effect on only the SC modules prefixed with LSCM2, SD series interface modules, and SF series interface modules. |
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-4>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-4> ]
No default next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ipv6-address: Specifies the IPv6 address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
service-chain path-id service-path-id: Specifies a service chain by its path ID. A path ID uniquely identifies a service chain, and its value range is 1 to 65534 or 8388608 to 8454142.
path-index service-path-index: Specifies a node in the service chain as a default next hop by its index in the range of 1 to 255.
The service-chain path-id and path-index keywords take effect only when the device is operating in expert mode. For more information about device operating modes, see device management in Fundamentals Configuration Guide.
&<1-4>: Indicates that the argument before it can be entered up to four times in one command line. You can specify a maximum of eight default next hops for the IPv6 policy node.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
To set multiple default next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
· If the next hops are used in different service chains, use the apply default-next-hop command to specify the service chain parameters.
· If the next hops are used in the same service chain, use the apply service-chain command to specify the service chain parameters as a best practice.
· On an IPv6 policy node, you cannot configure both the apply default-next-hop command with the service chain parameters and the apply service-chain command.
· If you specify the service-chain keyword when executing the apply default-next-hop command, the apply loadshare { default-next-hop | next-hop } command does not take effect.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply loadshare
apply service-chain
apply loadshare
Use apply loadshare to enable load sharing among multiple next hopsor default output interfaces.
Use undo apply loadshare to restore the default.
NOTE: Only SC modules prefixed with LSCM2, SD series interface modules, and SF series interface modules support enabling load sharing among multiple default next hops. |
undo apply loadshare { default-next-hop | next-hop }
Multiple next hopsor default output interfaces operate in primary/backup mode.
default-next-hop: Enables load sharing among multiple default next hops.
next-hop: Enables load sharing among multiple next hops.
Application scenarios
Use this command to enable multiple next hops or default next hops specified for an IPv6 PBR policy to guide packet forwarding at the same time.
Operating mechanism
By default, multiple next hop or default next hop options operate in primary/backup mode. In primary/backup mode, one option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple output interfaces are configured, the first configured output interface is selected. When the selected output interface fails, the next available output interface takes over.
After you configure this command, multiple next hops, default next hops, output interfaces, or default output interfaces implement load sharing as follows:
· Multiple next hops implement load sharing as follows:
¡ If the apply loadshare-mode command is not configured, the next hops load share traffic in round robin manner, starting from the first configured next hop. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
¡ If the apply loadshare-mode command is configured, the load sharing mode depends on the setting in the apply loadshare-mode command.
· Multiple default next hops implement load sharing in the same way as multiple next hops.
Follow these restrictions and guidelines when you configure this command:
· If you configure both the apply service-chain and apply loadshare { default-next-hop | next-hop } command, the apply loadshare command does not take effect.
· If you configure the apply next-hop or apply default-next-hop command with service chain parameters, the configured apply loadshare { default-next-hop | next-hop } command does not take effect.
# Enable load sharing among multiple next hops.
[Sysname-pbr6-aa-11] apply next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare next-hop
# Enable load sharing among multiple default next hops.
[Sysname-pbr6-aa-11] apply default-next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare default-next-hop
apply next-hop
Use apply loadshare-mode to specify the load sharing mode for multiple next hops or default next hops.
Use undo apply loadshare-mode to restore the default.
NOTE: This command takes effect only on SC modules prefixed with LSCM2, SD series interface modules, and SF series interface modules. |
apply loadshare-mode { next-hop | default-next-hop } robin
undo apply loadshare-mode [ next-hop | default-next-hop ]
Multiple next hops load share traffic in round robin manner, starting from the first configured next hop. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
next-hop: Specifies the load sharing mode for next hops.
default-next-hop: Specifies the load sharing mode for default next hops.
robin: Selects load-shared links randomly based on packets.
This command takes effect as follows:
· To enable multiple next hops specified in the IPv6 PBR policy to operate in load sharing mode, you must execute the apply loadshare next-hop command.
· To enable multiple default next hops specified in the IPv6 PBR policy to operate in load sharing mode, you must execute the apply loadshare default-next-hop command.
If you configure this command, you cannot specify next hop addresses as VXLAN tunnels.
In an IPv6 policy node, if you configure per-packet forwarding with the apply loadshare-mode command, and apply the policy locally with the ip local policy-based-route command, per-packet forwarding does not take effect. Instead, per-flow forwarding still takes effect. As a best practice to have IPv6 PBR take effect correctly, configure other IPv6 PBR types with the policy.
# Enable multiple next hops to operate in the robin load sharing mode.
[Sysname-pbr6-aa-11] apply loadshare-mode next-hop robin
# Enable multiple default next hops to operate in the spray load sharing mode.
[Sysname-pbr6-aa-11] apply loadshare-mode default-next-hop spray
apply loadshare
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name] { ipv6-address [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-patch-index ] ] } &<1-8>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-8> ]
No next hops are set.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
path-index service-path-index: Specifies a node in the service chain as a next hop by its index in the range of 1 to 255.
The service-chain path-id and path-index keywords take effect only on SF series interface modules.
&<1-8>: Indicates that the argument before it can be entered up to eight times.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
To set multiple next hops and specify their service chain parameters (service chain path ID and node index), follow these guidelines:
· If the next hops are used in different service chains, use the apply next-hop command to specify the service chain parameters.
· On an IPv6 policy node, you cannot configure both the apply next-hop command with the service chain parameters and the apply service-chain command.
If you specify service chain parameters for the apply next-hop command, the apply loadshare { default-next-hop | next-hop } command does not take effect.
If the next hop specified in the apply next-hop command becomes unreachable (for example, when the peer interface IPv6 address is deleted), the device might still have the ND entry associated with this next hop IPv6 addresses. In this case, the associated IPv6 PBR setting still takes effect, which redirects packets incorrectly. As a best practice to avoid this issue, configure Track to detect the next hop reachability. When the next hop becomes unreachable, the IPv6 PBR setting will not take effect.
# Set a directly-connected next hop of 1::1.
apply loadshare
apply service-chain
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface null 0
undo apply output-interface [ null 0 ]
No output interface is set.
null 0: Specifies Null 0 as the output interface.
# Specify Null 0 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface null 0
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
apply service-chain
Use apply service-chain to set service chain information.
Use undo apply service-chain to restore the default.
NOTE: · This command takes effect only on SF series interface modules. · This command takes effect only when the device is operating in expert mode. For more information about device operating modes, see device management in Fundamentals Configuration Guide. |
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 65534 and 8388608 to 8454142. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
When the device has SF series interface modules installed and is operating in expert mode, you cannot configure both the apply service-chain and apply statistics commands. For more information about device operating modes, see device management in Fundamentals Configuration Guide.
If you execute both the apply service-chain and apply loadshare { default-next-hop | next-hop } commands, the apply loadshare command does not take effect.
# Set service chain path ID 1 and node index 10.
[Sysname] ipv6 policy-based-route aa permit node 5
[Sysname-pbr6-aa-5] apply service-chain path-id 1 path-index 10
if-match service-chain
apply statistics
Use apply statistics to enable counting successful matches and matching bytes on a policy node.
Use undo apply statistics to restore the default.
apply statistics
Counting successful policy node matches and matching bytes are disabled.
To include the number of successful matches and matching bytes on an IPv6 policy node in the statistics displayed by a display command, execute this command. As a best practice to conserve hardware resources, disable this counting function.
# Enable counting successful matches and matching bytes on IPv6 policy node 1.
[Sysname] ipv6 policy-based-route 1 permit node 1
[Sysname-pbr6-1-1] apply statistics
description
Use description to configure a description for an IPv6 policy node.
No description is configured for an IPv6 policy node.
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for IPv6 policy node 1.
[Sysname-pbr6-1-1] description Officeuse
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
apply next-hop 1000::1
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares IPv6 packets with IPv6 ACL. |
apply next-hop |
Specifies a next hop for permitted IPv6 packets. |
Use display ipv6 policy-based-route global to display information about IPv6 global PBR, including its configuration and statistics.
In standalone mode:
display ipv6 policy-based-route global [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route global [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information about IPv6 global PBR on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information about IPv6 global PBR on the global active MPU. (In IRF mode.)
# Display information about IPv6 global PBR.
<Sysname> display ipv6 policy-based-route global
Global policy-based routing information:
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 1::1
node 5 permit:
if-match acl 3101
apply next-hop 2::2
Total matches: 0, total bytes: 0
Global policy-based routing information |
IPv6 global PBR configuration and statistics. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy and then apply it again. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
Matches |
Number of successful matches on the node. If match counting is disabled on the node, this field is not displayed. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. |
bytes |
Number of matching bytes on the node. This field is not displayed if match counting is disabled on the node. |
Total matches |
Total number of successful matches on all nodes. This field is not displayed if match counting is disabled on all nodes. |
total bytes |
Total number of matching bytes on all nodes. This field is not displayed if match counting is disabled on all nodes. |
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ipv6 policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-inerface2(failed):
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for interface XXXX |
IPv6 PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
Compares IPv6 packets with the IPv6 ACL. |
apply next-hop |
Matches |
Number of successful matches on the node. If match counting is disabled on the node, this field is not displayed. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
Total matches |
total bytes |
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics for the global active MPU. (In IRF mode.)
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 1::1
node 5 permit:
if-match acl 3101
apply next-hop 2::2
Table 5 Command output
Policy based routing information for local |
IPv6 local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node, permit or deny. |
if-match acl |
apply next-hop |
Matches |
Number of successful matches on the node. This field is not displayed if match counting is disabled on the node. |
bytes |
Total matches |
total bytes |
ipv6 local policy-based-route
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface 2
pr02 Local N/A
pr03 Global N/A
Table 6 Command output
Policy name |
Policy name. |
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. · Global—Global PBR. |
Interface where the policy is applied. This field displays N/A for IPv6 local PBR and IPv6 global PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
NOTE: The user-defined keyword takes effect only on SC modules prefixed with LSCM2, SD series interface modules, and SF series interface modules. |
if-match acl [ user-defined ] { ipv6-acl-number | name ipv6-acl-name }
undo if-match acl
No ACL match criterion is set.
user-defined: Specifies a user-defined ACL.
ipv6-acl-number: Specifies an IPv6 ACL by its number. The value ranges for this argument are as follows:
· 2000 to 2999 for a basic ACL.
· 3000 to 3999 for an advanced ACL.
· 5000 to 5999 for a user-defined ACL.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic, user-defined, or advanced ACL.
If you do not specify the user-defined keyword, the specified ACL is an IPv6 basic or advanced ACL.
When specifying a user-defined ACL, you must first specify the user-defined keyword, and then specify the ACL number or name.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
For SE interface modules and LSCM1GT48SC0 modules, if the vpn-instance keyword is specified for an ACL rule, the rule does not take effect.
If the vpn-instance keyword is not specified for an ACL rule, the following situations will occur:
· In an IPv6 interface or global PBR policy, the rule applies to both public network and VPN packets.
· In an IPv6 local PBR policy, the rule applies to only public network packets.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
if-match qos-local-id
Use if-match qos-local-id to set a local QoS ID match criterion.
Use undo if-match qos-local-id to restore the default.
if-match qos-local-id local-id-value
No local QoS ID match criterion is set.
local-id-value: Specifies a local QoS ID in the range of 1 to 4095.
You cannot specify the same local QoS ID for both the if-match qos-local-id and if-match acl commands on an IPv6 policy node.
# Match packets with local QoS ID 200.
[Sysname-pbr6-aa-11] if-match qos-local-id 200
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain path-id service-path-id [ path-index service-path-index ]
undo if-match service-chain [ path-id service-path-id ]
No service chain match criteria are set.
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr6-aa-5] if-match service-chain path-id 1 path-index 10
apply service-chain
Use ipv6 global policy-based-route to specify a PBR policy as the IPv6 global PBR policy.
Use undo ipv6 global policy-based-route to restore the default.
ipv6 global policy-based-route policy-name [ exclude service-loopback-group ]
No policy is specified for IPv6 global PBR.
policy-name: Specifies a PBR policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
exclude service-loopback-group: Specifies IPv6 PBR to not take effect on packets forwarded by the interfaces added to a service loopback group. If you do not specify this keyword, IPv6 PBR applies to packets forwarded by all interfaces. For more information about service loopback groups, see Layer 2—LAN Switching Configuration Guide.
This command applies IPv6 PBR to the IPv6 packets forwarded by all interfaces on the device.
You can specify only one policy for IPv6 global PBR on the device. Before you apply a new policy, you must first remove the current policy.
To edit the configuration for the exclude service-loopback-group keyword, first execute the undo ipv6 global policy-based-route command to remove the IPv6 global PBR policy, and then execute the command to apply the policy again.
IPv6 interface PBR takes precedence over IPv6 global PBR on an interface. When they are both configured and packets fail to match the IPv6 interface PBR policy, IPv6 global PBR applies.
# Specify PBR policy aaa for IPv6 global PBR.
[Sysname] ipv6 global policy-based-route aaa
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
NOTE: The share-mode keyword takes effect only on SF series interface modules. |
ipv6 policy-based-route policy-name [ share-mode ]
No IPv6 policy is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
share-mode: Applies the IPv6 policy in resource sharing mode. In this mode, all interfaces on an interface card with the same IPv6 policy applied share one hardware resource. If you do not specify this keyword, each interface occupies one independent hardware resource. You can apply only one ACL, QoS policy, or PBR policy with the share-mode keyword specified to one direction of an interface. For information about ACL and QoS policies, see ACL commands and QoS policy commands in ACL and QoS Command Reference.
Typically, an IPv6 policy on different interfaces of a card uses different hardware resources. To avoid resource usage overhead, you can set the resource sharing mode when applying the policy to each interface. This mode allows the policy on different interfaces of the card to use the same hardware resources.
You can set only one mode for the policy on an interface. Before you change the mode of the policy, you must first remove the current policy from the interface.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
