- 05-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-DHCPv6 commands
- 13-IPv6 fast forwarding commands
- 14-Tunneling commands
- 15-HTTP redirect commands
- 16-mDNS gateway commands
- 17-mDNS relay commands
- 18-WS-Discovery gateway commands
- 19-GRE commands
16-mDNS gateway commands | 171.17 KB |
display mdns gateway statistics
mdns gateway permit service-type
mdns gateway permit source-port-forward enable
mdns gateway proxy-forward enable
Use display mdns gateway to display mDNS gateway configuration.
# Display mDNS gateway configuration.
<Sysname> display mdns gateway
mDNS gateway status: Enabled
mDNS gateway source IP:
VLAN 1: 1.1.1.1
VLAN 2: Ten-GigabitEthernet3/0/1 (1.1.1.3)
mDNS gateway probe is enabled in the following VLANs: 1-2, 4-5
mDNS gateway status |
mDNS gateway status. Options include: · Enabled. · Disabled. |
mDNS gateway source IP |
Source IP address of mDNS packets for each VLAN. · If an IP address is specified as the source IP address, this field displays this IP address. · If the primary IP address of the VLAN interface is used as the source IP address, this field displays the interface name and IP address in the format of interface-name (ip-address), for example, Ten-GigabitEthernet3/0/1 (1.1.1.3). · If the primary IP address of the VLAN interface is used as the source IP address but no IP address is configured for the interface, this field displays the interface name in the format of interface-name (--). |
mDNS gateway probe is enabled in the following VLANs |
Comma-separated IDs of VLANs enabled with mDNS gateway periodic probing. This field is empty if no VLAN is enabled with mDNS gateway periodic probing. Second-VLANs indicates inner VLANs in QinQ scenarios. |
mDNS gateway probe is enabled in the following Policys |
Comma-separated names of mDNS gateway policies enabled with mDNS gateway periodic probing. This field is empty if no mDNS gateway policy is enabled with mDNS gateway periodic probing. |
mdns gateway enable
display mdns gateway policy
Use display mdns gateway policy to display mDNS gateway policy information, including policy name, user VLANs, and service VLANs.
display mdns gateway policy [ policy-name ]
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a policy name, the command displays information about all policies.
# Display mDNS gateway policy information.
<Sysname> display mdns gateway policy
Total mDNS gateway policies: 2
mDNS policy name : test1
User VLANs : 4-5
User VSIs :
Service VLANs : 6-7
Service VSIs :
mDNS policy name : test2
User VLANs : 10-11
User VSIs :
Service VLANs : 12-13
Service VSIs :
Total mDNS gateway policies |
Total number of mDNS gateway policies. |
User VLANs : xx Second-VLANs : yy |
User VLANs indicates user VLANs and xx indicates user VLAN IDs. The VLAN IDs are separated by commas. This field is empty if no user VLAN is specified. User VLANs indicates outer user VLANs in QinQ scenarios. Second-VLANs indicates inner user VLANs and yy indicates IDs of the inner user VLANs in QinQ scenarios. |
User VSIs |
Comma-separated names of user VSIs. This field is empty if no user VSI is specified. |
Service VLANs : xx Second-VLANs : yy |
Service VLANs indicates service VLANs and xx indicates service VLAN IDs. The VLAN IDs are separated by commas. This field is empty if no service VLAN is specified. Service VLANs indicates outer service VLANs in QinQ scenarios. Second-VLANs indicates inner service VLANs and yy indicates IDs of the inner service VLANs in QinQ scenarios. |
Service VSIs |
Comma-separated names of service VSIs. This field is empty if no service VSI is specified. |
mdns gateway policy
service vlan
user vlan
display mdns gateway service
Use display mdns gateway service to display information about services learned by the mDNS gateway.
display mdns gateway service { all | predefined-service-type | user-defined user-defined-service-type | vlan vlan-id [ second-vlan vlan-id ] } [ verbose ]
all: Specifies all service types.
predefined-service-type: Specifies a pre-defined service type.
user-defined user-defined-service-type: Specifies a user-defined service type. The user-defined-service-type argument represents the service type name, a case-insensitive string of 13 to 27 characters.
vlan vlan-id: Specifies information in a specific VLAN. In QinQ scenarios, this option specifies information in a specific outer VLAN. The vlan-id argument represents the VLAN ID in the range of 1 to 4094.
second-vlan vlan-id: Specifies information in a specific inner VLAN. The vlan-id argument represents the VLAN ID in the range of 1 to 4094.
verbose: Specifies detailed service information. If you do not specify this keyword, this field displays brief service information.
# Display brief information about all services learned by the mDNS gateway.
<Sysname> display mdns gateway service all
Instance name Service type VLAN/VSI name TTL Pro IP
Apple TV airplay 1 4500 TCP 192.168.10.2
B8782E5101E 7@Apple TV raop 2 4500 TCP 192.168.10.2
Total mDNS gateway services: 2
Instance name |
Instance name of the service, the unique identifier of a service. |
Service type |
Service type. Options include: · afpovertcp—AppleTalkFiling Protocol. · airplay—Airplay. · airport—Airport Base Station. · apple-sasl—Apple Password Server. · daap—Digital Audio Access Protocol. · dacp—Digital Audio Control Protocol. · distcc—Distributed Compiler. · dpap—Digital Photo Access Protocol. · eppc—Remote AppleEvents. · ftp—File Transfer Protocol. · http—Hypertext Transfer Protocol. · ica-networking—Image Capture Sharing. · ichat—iChat Instant Messaging Protocol. · ipp—Internet Printing Protocol. · ipps—Internet Printing Protocol. · nfs—Network File System. · pdl-stream—PDL Data Stream. · printer—Line Printer Daemon. · raop—Remote Audio Output Protocol. · riousbprint—Remote I/O USB Printer Protocol. · servermgr—Server Admin. · ssh—Secure Shell. · telnet—Remote Login. · webdav—WebDav File System. · workstation—Workgroup Manager. · xserveraid—Xerver RAID. · user-defined—User-defined service types. |
VLAN/VSI name |
VLAN or VSI in which the service provider resides. |
TTL |
TTL of the service recorded by the mDNS gateway upon receiving the most recent service response, in seconds. |
IP |
IP address used by the service. |
Pro |
Service protocol. Options include: · TCP. · UDP. |
Total mDNS gateway services |
Total number of services learned by the mDNS gateway. |
# Display detailed information about all services learned by the mDNS gateway.
<Sysname> display mdns gateway service all verbose
mDNS gateway service Info:
Service name : Officejet Pro 8100 [C12FFA] (7)._printer._tcp.local
SRV Info:
Domain name : HPC12FFA-156.local
Port : 515
VLAN ID : 10
Second-VLAN ID : --
VSI name : test1
Cache : 1
Type : 1
TTL : 120
Aging time : 95
Data length : 264
Priority : 0
Weight : 0
A Info:
IP address : 10.1.1.254
VLAN ID : 10
Second-VLAN ID : --
VSI name : test2
Cache : 1
Type : 1
TTL : 120
Aging time : 115
TXT Info:
VLAN ID : 10
Second-VLAN ID : --
VSI name : test3
Data length : 297
Cache : 1
Type : 1
TTL : 4500
Aging time : 3400
Text : ***
Total mDNS gateway services: 1
mDNS gateway service Info |
Service information recorded by the mDNS gateway. |
Service name |
Name of a service. |
SRV Info |
SRV information, indicating service record information. |
Domain name |
Domain name corresponding to the service name. |
Port |
Number of the port that provides the service. |
A Info |
Type A information, which is the domain name-to-IPv4 address mapping information of the service provider. |
IPv4 address |
IPv4 address corresponding to the domain name of the service provider. |
AAAA Info |
Type AAAA information, which is the domain name-to-IPv6 address mapping information of the service provider. |
IPv6 address |
IPv6 address corresponding to the domain name of the service provider. |
Data length |
TXT type data length. |
PTR Info |
PTR information, indicating reverse lookup information. Reverse lookup refers to finding the service provider based on the service type. |
Total |
Total number of services recorded by the mDNS gateway. · If you query information about all services or services in a specific service VLAN recorded by the mDNS gateway, this field displays the total number of service names. · If you query information about a service with a specific service name recorded by the mDNS gateway, this field displays the total number of SRV, TXT, and PTR information records. Types A and AAAA information records are not included because they do not belong to service information. |
Cache |
Whether the information is cache information: · 1—The information is cache information. · 0—The information is not cache information. |
Type |
Service type: · 1—Internet. · 255—Any. |
TTL |
TTL value of the service. |
Priority |
Priority of the service. |
Weight |
Weight of the service. |
VLAN ID |
ID of the VLAN to which the service provider belongs. |
Second-VLAN ID |
ID of the inner VLAN to which the service provider belongs. This field displays two hyphens (--) if no inner VLAN exists. |
Use display mdns gateway statistics to display mDNS gateway packet statistics.
# Display mDNS gateway packet statistics.
<Sysname> display mdns gateway statistics
mDNS gateway packet statistics:
Total received : 100
Queries received : 20
Response received: 80
Total sent : 50
Queries sent : 30
Response sent : 20
Dropped : 10
Table 5 Command output
Total received |
Total number of received mDNS packets. |
Queries received |
Number of received service queries. |
Response received |
Number of received service responses. |
Total sent |
Total number of sent mDNS packets. |
Queries sent |
Number of sent service queries. |
Response sent |
Number of sent service responses. |
Dropped |
Number of dropped mDNS packets. |
reset mdns gateway statistics
mdns gateway enable
Use mdns gateway enable to enable mDNS gateway.
Use undo mdns gateway enable to disable mDNS gateway.
mdns gateway enable
mDNS gateway is disabled.
Destination multicast address 224.0.0.251 used by mDNS for packet exchanging can be used only in Layer 2 broadcast domains and intra-VLAN transmission. You can deploy an mDNS gateway in a large-scale network to enable inter-VLAN mDNS service discovery.
The gateway records a list of available services in the network, responds to service queries from mDNS clients, and performs mDNS service discovery as well as access control.
You cannot enable both mDNS gateway and mDNS relay on a device.
# Enable mDNS gateway.
[Sysname] mdns gateway enable
mdns gateway policy
mdns gateway probe interval
mdns gateway source ip
mdns gateway trust source ip
Use mdns gateway permit service-type to specify a permitted service type for entry learning.
Use undo mdns gateway permit service-type to remove a permitted service type for entry learning
mdns gateway permit service-type { predefined-service-type | user-defined user-defined-service-type } [ max-entry-count count ]
undo mdns gateway permit service-type { predefined-service-type | user-defined user-defined-service-type }
The mDNS gateway can learn all mDNS services of a predefined service type.
pre-defined-service-type: Specifies a pre-defined service type. Table 6 displays the available pre-defined service types.
Table 6 Pre-defined service types
Afpovertcp |
AppleTalkFiling Protocol |
Airplay |
Airplay |
Airport |
Airport Base Station |
apple-sasl |
Apple Password Server |
Daap |
Digital Audio Access Protocol |
Dacp |
Digital Audio Control Protocol |
Distcc |
Distributed Compiler |
Dpap |
Digital Photo Access Protocol |
Eppc |
Remote AppleEvents |
ftp |
File Transfer Protocol |
http |
Hypertext Transfer Protocol |
ica-networking |
Image Capture Sharing |
Ichat |
iChat Instant Messaging Protocol |
Ipp |
Internet Printing Protocol |
Ipps |
Nfs |
Network File System |
pdl-stream |
PDL Data Stream |
Printer |
Line Printer Daemon |
Raop |
Remote Audio Output Protocol |
Riousbprint |
Remote I/O USB Printer Protocol |
Servermgr |
Server Admin |
Ssh |
Secure Shell |
telnet |
Remote Login |
Webdav |
WebDav File System |
Workstation |
Workgroup Manager |
Xserveraid |
Xerver RAID |
user-defined user-defined-service-type: Specifies a user-defined service type. The user-defined-service-type argument represents the name of the type, a case-insensitive string of 1 to 15 characters in the _type._protocol.local format. Make sure the user-defined service type has a different name from any predefined service type.
max-entry-count count: Specifies the maximum number of entries that can be recorded for the service type. The value range for the count argument is 1 to 1024. If you do not specify this option, the command does not limit the number of entries that can be recorded for the service type.
By default, the mDNS gateway can learn all services of a predefined type, which can be memory-consuming if a large number of service providers exist. You can perform this task to specify the permitted service types that can be learned by the mDNS gateway for the gateway to learn only required services.
This configuration takes effect only when mDNS gateway is enabled.
If the maximum number of entries for a service type has been reached, the system stops learning service information for the type.
Changes on the max-entry-count setting takes effect only on services learned afterward and will not affect recorded entries.
Removing a type from the permitted list clears all service entries for the type.
# Permit the mDNS gateway to learn services of the airport type and set the maximum number of recorded entries for the service type to 10.
[Sysname] mdns gateway permit service-type airport max-entry-count 10
mdns gateway enable
Use mdns gateway permit source-port-forward enable to enable the mDNS gateway to forward mDNS queries on the receiving port in a VLAN.
Use undo mdns gateway permit source-port-forward enable to disable the mDNS gateway from forwarding mDNS queries on the receiving port in a VLAN.
The mDNS gateway does not forward mDNS queries on the receiving port in a VLAN.
Use this feature in scenarios where the mDNS gateway must receive and forward mDNS queries on the same port. For example, on an EPON network, multiple ONUs are connected to a single port of an OLT via a POS. In this case, the OLT, serving as an mDNS gateway, must send both mDNS queries and mDNS requests from the port. If this feature is disabled, the OLT excludes the port connected to the ONUs when it sends mDNS queries and mDNS requests. As a result, mDNS endpoint users and mDNS service providers cannot discover each other. To resolve such an issue, enable this feature.
# Enable the mDNS gateway to forward mDNS queries on the receiving port in a VLAN.
[Sysname] mdns gateway permit source-port-forward enable
mdns gateway policy
Use mdns gateway policy to create an mDNS gateway policy and enter its view or enter the view of an existing mDNS gateway policy.
Use undo mdns gateway policy to delete an mDNS gateway policy.
mdns gateway policy policy-name
undo mdns gateway policy policy-name
No mDNS gateway policy exists.
policy-name: Specifies the policy name, a case-sensitive string of 1 to 31 characters.
An mDNS gateway policy defines user VLAN and service VLAN mappings to ensure that endpoint devices in specific VLANs can access only service providers in specific service VLANs.
You can execute this command multiple times to add multiple mDNS gateway policies.
# Create an mDNS gateway policy named test.
[Sysname] mdns gateway policy test
[Sysname-mdns-gateway-policy-test]
mdns gateway enable
Use mdns gateway probe interval to enable periodic probing on the mDNS gateway and set the probe interval.
Use undo mdns gateway probe interval to disable periodic probing on the mDNS gateway.
mdns gateway probe interval interval
Periodic probing is disabled on the mDNS gateway.
VLAN view
mDNS gateway policy view
interval: Specifies a probe interval in seconds. The value range is 60 to 38400.
Application scenarios
mDNS service providers broadcast their services at network association. For the mDNS gateway to discover services offered by service providers that accessed the network earlier than the gateway, enable mDNS gateway periodic probing.
This feature enables the mDNS gateway to send mDNS probe queries at intervals. Each mDNS service provider sends a response to the gateway after receiving the query. The mDNS gateway can learn the latest service information of all mDNS service providers in the network in a timely manner.
Recommended configuration
For an mDNS device, you can enable periodic probing on its directly connected mDNS gateway or mDNS relay.
As a best practice to control periodic probing in different VLANs or VSIs, configure multiple mDNS gateway policies and execute the mdns gateway probe interval command in the view of each mDNS gateway policy.
In a QinQ scenario, to avoid any impact on the device service networking capabilities due to too many mDNS multicast packets sent within a short period, configure the inner VLANs as accurately as possible.
# Enable periodic probing and set the probe interval to 300 seconds in VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] mdns gateway probe interval 300
# Enable periodic probing and set the probe interval to 300 seconds in mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] mdns gateway probe interval 300
mdns gateway enable
Use mdns gateway proxy-forward enable to enable mDNS gateway proxy forwarding.
Use undo mdns gateway proxy-forward enable to disable mDNS gateway proxy forwarding.
mDNS gateway proxy forwarding is enabled.
By default, mDNS gateway proxy forwarding is enabled. The mDNS gateway can send probe queries to discover mDNS service providers on the network.
As a best practice to control proxy forwarding in different VLANs or VSIs, configure multiple mDNS gateway policies and execute the mdns gateway probe interval command in the view of each mDNS gateway policy.
In QinQ scenarios or scenarios with a lot of services VLANs or service VSIs, enable periodic probing on the mDNS gateway and disable mDNS gateway proxy forwarding.
# Disable mDNS gateway proxy forwarding in mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] undo mdns gateway proxy-forward enable
Use mdns gateway source ip to specify the source address for mDNS packets.
Use undo mdns gateway source ip to restore the default.
mdns gateway source ip { interface interface-type interface-number | ip-address }
The mDNS gateway uses the primary IP address of the VLAN interface for packet output as the source IP address of mDNS packets.
VLAN view
interface interface-type interface-number: Specifies an interface whose primary IP address will be used as the source address. The interface-type argument represents the interface type and the interface-number argument represents the interface number.
ip-address: Specifies the source IP address in dotted decimal notation.
For responses destined for endpoint devices and mDNS queries and probe queries sent within a VLAN, the default source IP address is the primary IP address of the VLAN interface. If no IP address is configured for the VLAN interface, the mDNS gateway cannot send out the queries.
If the mDNS gateway is connected to a large number of VLANs, configuring an IP address to each VLAN interface wastes IP address resources. You can use this command to specify a specific IP address for the mDNS gateway to use.
In QinQ scenarios, as a best practice to simplify configuration and prevent the mDNS gateway from sending multiple mDNS probe queries, configure this command in system view.
Make sure the specified source address already exists on the mDNS gateway. Otherwise, the gateway cannot receive responses.
If the specified interface does not have an IP address, the system uses the primary IP address of the packet output interface. If the packet output interface does not have an IP address, packets cannot be sent.
You can specify only one source address for a VLAN or VSI. If you execute this command in the same view multiple times, the most recent configuration takes effect.
When you configure the same source address for mDNS packets configured in different views, the configuration in the following views is in descending order of priority: VLAN view > system view > VSI view.
# Specify the source address for mDNS packets as 1.1.1.1 in VLAN 10.
[Sysname] vlan 10
[Sysname-vlan10] mdns gateway source ip 1.1.1.1
# Specify the source address for mDNS packets as 1.1.1.1 in system view.
[Sysname] mdns gateway source ip 1.1.1.1
mdns gateway enable
mdns gateway trust device-ip
Use mdns gateway trust device-ip to specify a trusted mDNS device.
Use undo mdns gateway trust device-ip to delete a trusted mDNS device.
mdns gateway trust device-ip ip-address [ vpn-instance vpn-instance-name ]
undo mdns gateway trust device-ip ip-address [ vpn-instance vpn-instance-name ]
No trusted device is specified.
ip-address: Specifies the IP address of a device, in dotted decimal notation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a device for the public network, do not specify this option.
To prevent security issues and resource waste caused by attacks performed by rogue mDNS devices, you can specify trustworthy mDNS relays as trusted mDNS devices. With trusted devices specified, the mDNS gateway processes only unicast queries from the trusted mDNS devices.
You can execute this command multiple times to add multiple trusted devices.
# Specify the mDNS device that uses IP address 1.1.1.1 as a trusted mDNS device.
[Sysname] mdns gateway trust device-ip 1.1.1.1
mdns gateway enable
reset mdns gateway service
Use reset mdns gateway service to clear information about services learned by the mDNS gateway.
reset mdns gateway service { all | predefined-service-type | user-defined user-defined-service-type | vlan vlan-id }
all: Specifies services of all types.
pre-defined-service-type: Specifies a predefined service type.
user-defined user-defined-service-type: Specifies a user-defined service type, a case-insensitive string of 1 to 15 characters.
vlan vlan-id: Specifies a VLAN by its ID, in the range of 1 to 4094.
# Clear information about services learned by the mDNS gateway in VLAN 10.
<Sysname> reset mdns gateway service vlan 10
# Clear information about services of predefined type printer.
<Sysname> reset mdns gateway service printer
Use reset mdns gateway service to clear packet statistics on the mDNS gateway.
IMPORTANT: The cleared statistics cannot be restored. |
For debugging or maintenance purposes, you can execute this command to restart the statistics collection period.
To view the collected packet statistics, execute the display mdns gateway statistics command.
# Clear packet statistics on the mDNS gateway.
<Sysname> reset mdns gateway statistics
service vlan
Use service vlan to specify service VLANs for an mDNS gateway policy.
Use undo service vlan to remove service VLANs for an mDNS gateway policy.
service vlan vlan-id-list [ second-vlan [ vlan-id-list ] ]
undo service vlan [ vlan-id-list ] [ second-vlan [ vlan-id-list ] ]
No service VLAN is specified for an mDNS gateway policy.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. In QinQ scenarios, this option specifies a space-separated list of up to 10 outer VLAN items.
second-vlan vlan-id-list: Specifies a space-separated list of up to 10 inner VLAN items. Each inner VLAN item specifies an inner VLAN by VLAN ID or specifies a range of inner VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. You must specify this option in QinQ scenarios.
Service VLANs isolate mDNS service providers and allows the mDNS gateway to control services accessible to users by VLANs, helping achieve refined service management.
On a QinQ network, packets sent from both the client and server to the mDNS gateway carry two layers of VLAN tags. The inner VLAN tag (also called CVLAN tag) identifies the VLAN to which the frame belongs when it is transmitted in the customer network. The outer VLAN tag (also called SVLAN tag) identifies the VLAN to which the QinQ frame belongs when it is transmitted in the service provider network. When you specify service VLANs and users VLANs for an mDNS gateway policy, you must specify inner VLANs. If you do not specify inner VLANs, the mDNS gateway does not generate service entries for mDNS packets carrying two layers of VLAN tags or respond to the client's requests.
When you specify service VLANs and user VLANs for an mDNS gateway policy on a QinQ network, you must specify both the outer VLANs and inner VLANs. A client can access services in the service VLANs only when both the two layers of VLAN tags of the packets sent by the client match the mDNS gateway policy.
You can specify the same service VLAN in multiple mDNS gateway policies and specify multiple service VLANs in the same mDNS gateway policy.
You can specify a maximum of 128 service VLANs for an mDNS gateway policy.
# Specify service VLANs 100 through 200 for mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] service vlan 100 to 200
# Specify outer service VLANs 10 through 20 and inner service VLANs 100 through 200 for mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] service vlan 10 to 20 second-vlan 100 to 200
user vlan
user vlan
Use user vlan to specify user VLANs for an mDNS gateway policy.
Use undo user vlan to remove user VLANs for an mDNS gateway policy.
user vlan vlan-id-list [ second-vlan [ vlan-id-list ] ]
undo user vlan [ vlan-id-list ] [ second-vlan [ vlan-id-list ] ]
No user VLAN is specified for an mDNS gateway policy.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument. In QinQ scenarios, this argument specifies a space-separated list of up to 10 outer VLAN items.
User VLANs isolate mDNS endpoint devices and allows the mDNS gateway to filter service queries of endpoint devices by VLANs. With mDNS gateway policies configured, the gateway processes only service queries from endpoint devices in a VLAN defined in a policy.
You can specify the same user VLAN in multiple mDNS gateway policies and specify multiple user VLANs in the same mDNS gateway policy.
You can specify a maximum of 128 user VLANs for an mDNS gateway policy.
# Specify user VLANs 100 through 200 for mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] user vlan 100 to 200
# Specify outer user VLANs 10 to 20 and inner user VLANs 100 to 200 for mDNS gateway policy test.
[Sysname-mdns-gateway-policy-test] user vlan 10 to 20 second-vlan 100 to 200
service vlan
