- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Multichassis configuration sync commands
- 08-Software upgrade commands
- 09-ISSU commands
- 10-GIR commands
- 11-Automatic configuration commands
- 12-Target configuration management commands
- 13-Device management commands
- 14-Tcl commands
- 15-Python commands
- 16-License management commands
- 17-Preprovisioning commands
12-Target configuration management commands | 147.04 KB |
configuration commit auto-save path
configuration commit max-number
display configuration commit diff
display configuration commit list
display configuration sessions
commit
Use commit to commit the target configuration command lines.
commit [ best-effort ] [ force ] [ label labelname ] [ save-running filename ] [ confirmed [ seconds | minutes minutes ] ] [ show-error ] [ clear-error ] [ description text ]
Private-mode system view and its lower-level views
Exclusive-mode system view and its lower-level views
best-effort: Skips incorrect command lines in the target configuration. If you do not specify this keyword, the system checks for incorrect command lines. If an incorrect command line is found, the commit operation fails, and the system continues to use the original running configuration.
force: Skips memory check. If you do not specify this keyword, the system checks the memory before committing the target configuration command lines. If any memory problem exists, the commit operation fails, and the system continues to use the original running configuration.
label labelname: Assigns a label to the rollback point, a case-sensitive string of 1 to 20 characters. The label must be globally unique and begin with a letter. When using the configuration replace command to roll back the running configuration, you can use a label to identify the configuration to roll back to.
save-running filename: Saves the running configuration to a configuration file before committing the target configuration command lines. The filename argument represents the file name, a case-insensitive string of 1 to 255 characters. The file name must use the .cfg extension.
confirmed: Starts a configuration rollback timer for the commit operation. If you do not execute the commit command again to confirm the commit operation before the timer expires, the system automatically restores the original running configuration. If you do not specify this keyword, the command commits the target configuration command lines without requiring for a confirmation.
seconds: Sets the configuration rollback timer in seconds. The value range is 30 to 65535. The default is 600.
minutes minutes: Sets the configuration rollback timer in minutes. The value range is 1 to 1024. The default is 10.
show-error: Displays incorrect command lines in the target configuration if the commit operation fails. If you do not specify this keyword, the command does not display the incorrect command lines.
clear-error: Clears all incorrect command lines from the target configuration if the commit operation fails.
description text: Specifies a description for the rollback point, a case-sensitive string of 1 to 60 characters.
As a best practice, do not execute this command frequently. The system creates a configuration rollback point after each successful commit operation. Executing this command frequently increases device load and might cause commit failures.
If you execute the commit command in IRF interface view, the device returns to system view after the target configuration is committed.
The target configuration cannot be automatically saved. If the connection with the device is interrupted during configuration before you execute the commit command, you must configure the setting again.
When you issue all target configurations in bulk, a command might fail to be issued due to resource insufficiency. In this situation, the device will ignore that command and continue to issue the remaining target configurations.
# Commit the target configuration command lines, skipping incorrect command lines.
<Sysname> system-view private
~[Sysname] sysname aaa
*[Sysname] commit
Wait for the configuration commit: Done.
~[aaa]
Use configuration commit auto-save path to enable the automatic saving feature for the target configuration command lines and configure the related parameters. This feature automatically saves the running configuration each time the target configuration command lines are committed.
Use undo configuration commit auto-save path to disable the automatic saving feature for the target configuration command lines.
configuration commit auto-save path directory filename-prefix filename-prefix [ user user-name [ password { cipher | simple } string ] | vpn-instance vpn-instance-name ] *
The automatic saving feature is disabled for the target configuration command lines.
directory: Specifies the path or URL of the .cfg configuration files to which the running configuration is automatically saved. This argument is a case-insensitive string of 1 to 63 characters. A local file path must be in the format of storage-medium-name:/[folder-name]/subfolder-name. The path must already exist on the active MPU and cannot contain a slot number. To save the configuration files to an FTP or TFTP server, specify the URL of the server. For more information about the URL formats, see the usage guidelines for this command. (In standalone mode.)
directory: Specifies the path or URL of the .cfg configuration files to which the running configuration is automatically saved. This argument is a case-insensitive string of 1 to 63 characters. A local file path must be in the format of storage-medium-name:/[folder-name]/subfolder-name. The path must already exist on the global active MPU and cannot contain an IRF member ID or slot number. To save the configuration files to an FTP or TFTP server, specify the URL of the server. For more information about the URL formats, see the usage guidelines for this command. (In IRF mode.)
filename-prefix filename-prefix: Specifies a file name prefix for the .cfg configuration files to which the running configuration is automatically saved. The total length of the file directory and file name cannot exceed 255 characters.
user user-name: Specifies the username used for accessing the directory. You can specify this option only when the URL of an FTP server is specified.
password: Specifies the password used for accessing the directory. You can specify this option only when the URL of an FTP server is specified.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters and its encrypted form is a case-sensitive string of 33 to 117 characters.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the remote server belongs. The vpn-instance-name argument represents the VPN instance name, which is a case-sensitive string of 1 to 31 characters. If the remote server belongs to the public network, do not specify this option.
To save the running configuration while committing the target configuration command lines, you can use one of the following methods:
· Specify the save-running filename option when you use the commit command to commit the target configuration command lines. The system saves the running configuration to the specified file while committing the target configuration command lines.
· Use the configuration commit auto-save path command to enable automatic saving for the target configuration command lines. This command enables the device to automatically save the running configuration to a configuration file in the specified directory each time the commit command is executed. The directory is specified by using the directory argument. The prefix for the configuration file is specified by using the filename-prefix filename-prefix option.
The automatic saving feature takes effect if you do not specify the save-running filename option when executing the commit command. If you specify this option when executing the commit command, the automatic saving feature cannot take effect. The target configuration command lines are saved to the file specified by using this option.
If the directory specified by using the configuration commit auto-save path command belongs to an FTP or TFTP server, the directory URL formats are shown in Table 1.
Table 1 URL formats for FTP and TFTP servers
Protocol |
URL format |
Remarks |
FTP |
ftp://server-address[:port-number]/file-path |
For example, to specify folder file on FTP server 1.1.1.1, enter ftp://1.1.1.1/file. |
TFTP |
tftp://server-address[:port-number]/file-path |
For example, to specify folder file on TFTP server 1.1.1.1, enter tftp://1.1.1.1/file. |
To specify an IPv6 address, enclose the IPv6 address in square brackets ([ ]), for example, ftp://test:test@[2001::1]:21/test.cfg.
If the URL of an FTP server is specified, you must specify the user user-name option. If you do not specify this option, execution of the configuration commit auto-save path command will fail.
If the URL of a TFTP server is specified, you do not need to specify the user user-name option. If you specify this option, the system automatically ignores this option. Execution of the configuration commit auto-save path command can succeed.
# Enable automatic saving for the target configuration command lines, and save the running configuration to configuration files in directory ftp://1.1.1.1/BackupFile/ each time the commit command is executed. Set the prefix for the configuration files to backupcfg. Set the username and password used for accessing the FTP server to admin and plaintext string 123456, respectively.
~[Sysname] configuration commit auto-save path ftp://1.1.1.1/BackupFile/ filename-prefix backupcfg user admin password simple 123456
# Enable automatic saving for the target configuration command lines, and save the running configuration to configuration files in directory flash:/BackupFile/ each time the commit command is executed. Set the prefix for the configuration files to save.
~[Sysname] configuration commit auto-save path flash:/BackupFile/ filename-prefix save
commit
Use configuration commit max-number to set the maximum number of rollback points.
Use undo configuration commit max-number to restore the default.
configuration commit max-number max-number
The maximum number of rollback points is 100.
max-number: Specifies the maximum number of rollback points, in the range of 1 to 65535.
To store a new rollback point when the number of rollback points reaches the maximum, the system deletes the oldest rollback point.
# Set the maximum number of rollback points to 10.
[Sysname] configuration commit max-number 10
Use configuration replace to roll back the running configuration based on a rollback point.
configuration replace { last number | commit-id commit-id | label labelname }
last number: Specifies a rollback point by its number counting from the most recent rollback point.
commit-id commit-id: Specifies a rollback point by its commit ID. The value range for the commit-id argument depends on the number of existing rollback points.
label labelname: Specifies a rollback point by its label, a case-sensitive string of 1 to 20 characters. The label is globally unique and must begin with a letter.
When you roll back the running configuration or commit target configuration command lines, the system creates a rollback point and assigns a unique commit ID to the rollback point.
# Roll back the running configuration based on rollback point 2.
[Sysname] configuration replace commit-id 2
Current configuration will be lost, Save running configuration? [Y/N]:n
Now rolling back the running configuration. Please wait...
Running configuration successfully rolled back.
Use display configuration commit diff to display configuration differences between a rollback point and the running configuration or between two rollback points.
display configuration commit diff [ at commit-id | last number | since commit-id ]
at commit-id: Displays the configuration differences between a rollback point and the next rollback point. The commit-id argument identifies a rollback point by its commit ID. The value range depends on the commit IDs of existing rollback points. If you specify the most recently created rollback point, this command displays configuration differences between the most recently created rollback point and the running configuration.
last number: Displays the configuration differences between a rollback point and the running configuration. The number argument specifies a rollback point by its number counting from the most recent rollback point.
since commit-id: Displays the configuration differences between a rollback point and the running configuration. The commit-id argument identifies a rollback point by its commit ID. The value range depends on the commit IDs of existing rollback points.
If you do not specify any parameters, this command displays the configuration differences between each two adjacent rollback points, and between the most recent rollback point and the running configuration.
If the at commit-id option specifies the most recent rollback point, this command displays the configuration differences between the most recent rollback point and the running configuration.
# Display the configuration differences between rollback point 2 and the next rollback point.
<Sysname> display configuration commit diff at 2
--- CommitId 2 configuration
+++ CommitId 3 configuration
@@ -3,4 +3,4 @@
Vlan1
- description test
+ description world
--- A +++ B |
· A represents the configuration for comparison, which can be the configuration of the specified rollback point. · B represents the configuration compared by the command, which can be the running configuration or configuration of the next rollback point. |
@@ -linenumber1,number1 +linenumber2,number2 @@ |
Location summary for sections that have command line differences: · -linenumber1,number1—Configuration A section that has command line differences. The linenumber1 argument represents the start line of the section. The number1 argument represents the number of lines between the start line and the end line of the section. · +linenumber2,number2—Configuration B section that has command line differences. The linenumber2 argument represents the start line of the section. The number2 argument represents the number of lines between the start line and the end line of the section. |
cmd1 - cmd2 + cmd3 cmd4 |
Displays command line differences. · cmd1 and cmd4—Command lines are contained in both configurations A and B if they are not prefixed with a minus (-) or plus (+) sign. They provide a context for locating command line differences. · - cmd2—Command lines are prefixed with a minus sign if they are contained in configuration A but not in configuration B. · + cmd3—Command lines are prefixed with a plus sign if they are contained in configuration B but not in configuration A. |
Use display configuration commit list to display rollback point information.
display configuration commit list [ number | label ] [ verbose ]
number: Displays the most recent rollback points. The number argument represents the number of the rollback points to be displayed.
label: Displays the rollback points that have labels.
verbose: Displays detailed rollback point information. If you do not specify this keyword, the command displays brief rollback point information.
If you do not specify any parameters, this command displays brief information about all rollback points.
# Display the most recent three rollback points.
<Sysname> display configuration commit list 3
Commit ID Label User Time stamp
3 conf3 - 2016-07-11 14:34:06
2 conf2 - 2016-07-11 14:33:06
1 - - 2016-07-11 14:32:19
Commit ID |
Commit ID of the rollback point. |
Label |
Label of the rollback point. This field displays a hyphen (-) if the rollback point does not have a label. |
User |
Username of the session. · For a NETCONF over SSH, NETCONF over Telnet, or NETCONF over console session that was established after scheme authentication, this field displays the username of the session. For other NETCONF sessions, this field displays a hyphen (-). · For SNMP and CWMP sessions, this field displays a hyphen (-). |
Time stamp |
Time when the rollback point was created. |
Use display configuration sessions to display device configuration sessions, such as CLI, NETCONF, CWMP, and SNMP sessions.
# Display device configuration sessions.
<Sysname> display configuration sessions
Type Line User Time Lock
+ CLI VTY 0 admin May 04 09:13:33 -
CLI VTY 1 ad May 04 08:55:21 *
NETCONF VTY 1 user1 May 04 08:55:34 -
SNMP - - May 04 08:55:20 -
CWMP - - May 04 08:55:25 -
Type |
Type of the session. The plus sign (+) indicates the session you are using. For sessions established over Web or RESTful, this field displays NETCONF. |
Line |
CLI user line used by the session, identified by the user line type and relative number. For information about user lines, see "Configuring CLI login." · For a NETCONF over SSH, NETCONF over Telnet, or NETCONF over console session, this field displays the user line used by the session. For other NETCONF sessions, this field displays a hyphen (-). · For SNMP and CWMP sessions, this field displays a hyphen (-). |
User |
Time |
Time when the session was established. |
Lock |
Whether the user of the session is in an exclusive-mode or private-mode view. · Asterisk (*)—The user is in an exclusive-mode view. · Hyphen (-)—The user is in a private-mode view. |
display target-configuration
Use display target-configuration to display the target configuration command lines.
display target-configuration [ diff | failure [ brief ] | merge | success ]
diff: Display differences between the target configuration and the running configuration.
failure: Displays the configuration command lines that failed to be committed and the causes.
brief: Displays only the configuration command lines that failed to be committed.
merge: Displays the configuration that occurs if the target configuration command lines are committed to the running configuration.
success: Displays successfully committed configuration command lines and the messages output by the command lines. This keyword applies only to command lines that display messages after being executed.
If you do not specify any parameters, this command displays all target configuration command lines in the order they were configured.
The commit command does not display messages for command lines.
In real-time-mode views, some commands display messages to indicate the command execution results. When committed as a part of the target configuration, these commands do not display any messages. To display these commands and their respective messages, execute the display target-configuration success command after the commit operation is finished.
When you specify the diff or merge keyword in private/exclusive mode, the display of default configurations is consistent with the display of default configurations by the display current-configuration command in real-time-mode.
# Set the device name in private-mode system view and display the target configuration.
~[Sysname] sysname Device
*[Sysname] display target-configuration
sysname Device
# Enter in private-mode system view and display the differences between the target configuration and the running configuration.
*[Sysname] display target-configuration diff
--- Running configuration
+++ Target configuration
@@ -5,7 +5,7 @@
alias dh display hotkey
- sysname Sysname
+ sysname Device
local-user userA class manage
Table 5 Command output
· -linenumber1,number1—Start command line in the running configuration to display and the number of the command lines displayed. · +linenumber2,number2—End command line in the target configuration to display and the number of the command lines displayed. |
· cmdn1 and cmd4—Command lines exist in both the running configuration and the target configuration. They together represent the context of different configuration used for locating different command lines. · - cmd2—Command line that exists only in the running configuration. · + cmd3—Command line that exists only in the target configuration. |
refresh target-configuration
Use refresh target-configuration to refresh uncommitted target configuration.
Configuration commit fails if the running configuration has changed and the changes in the running configuration conflict with the target configuration.
Use this command to refresh uncommented target configuration to filter out command lines in target configuration that conflict with the running configuration.
# Refresh uncommitted target configuration.
~[Sysname] refresh target-configuration
Trying to refresh the target configuration. Please wait …
No conflicts detected.
reset configuration commit
Use reset configuration commit to clear old rollback points.
reset configuration commit number
number: Specifies the number of the oldest rollback points to be cleared. This argument must be equal to or less than the number of existing rollback points.
Clear rollback points that are not in use anymore to release the memory space used by the rollback points.
# Clear the oldest nine rollback points.
<Sysname> reset configuration commit 9
reset target-configuration
Use reset target-configuration to clear the target configuration command lines.
reset target-configuration [ command [ text ] ]
command: Clears a specific target configuration command line in the current view. If you do not specify this keyword, the command clears all target configuration command lines.
text: Specifies a target configuration command line. The entire length of this reset command can have a maximum of 512 characters. Whether this argument is case sensitive depends on the case sensitivity of the target configuration command line to be cleared. If you do not specify this argument, the command prompts you to enter the target configuration command line to be cleared.
# Clear the target configuration command lines.
~[Sysname] reset target-configuration
# Clear target configuration command line sysname S1.
~[Sysname] reset target-configuration command sysname S1
