- 13-Security Configuration Guide
- 01-Public key management
- 02-PKI configuration
- 03-Crypto engine configuration
- 04-SSH configuration
- 05-SSL configuration
- 06-Packet filter configuration
- 07-DHCP snooping configuration
- 08-DHCPv6 snooping configuration
- 09-ARP attack protection configuration
- 10-ND attack defense configuration
- 11-Attack detection and prevention configuration
- 12-IP-based attack prevention configuration
- 13-IP source guard configuration
- 14-Microsegmentation configuration
| 06-Packet filter configuration | 101.60 KB |
About packet filtering with ACLs
Packet filter tasks at a glance
Applying an ACL to filter packets globally
Applying an ACL to an interface for packet filtering
Configuring logging and SNMP notifications for packet filtering
Setting the packet filtering default action
Verifying and maintaining packet filter
Verifying the packet filter running status
Displaying packet filter statistics
Clearing packet filter statistics
Packet filter configuration examples
Example: Configuring interface-based packet filter
Configuring packet filter
This section describes procedures for using an ACL to filtering packets. For example, you can apply an ACL to an interface to filter incoming or outgoing packets.
To configure packet filtering, perform the following tasks:
· Configure packet filtering with ACLs.
¡ Applying an ACL to filter packets globally
¡ Applying an ACL to an interface for packet filtering
· (Optional.) Configuring logging and SNMP notifications for packet filtering
· (Optional.) Setting the packet filtering default action
You can apply a maximum of three ACLs to the inbound direction globally: one IPv4 or one IPv6 ACL, one Layer 2 ACL, and one user-defined ACL. You can apply a maximum of three ACLs to the outbound direction globally: one IPv4 or one IPv6 ACL and one Layer 2 ACL.
Dynamically adding or modifying a rule in an ACL with the in depth-first order specified will cause the ACL to mistakenly drop or permit packets. For the match order of ACL rules, see ACL configuration in ACL and QoS Configuration Guide.
If you do not specify the ipv6 keyword for a basic or advanced ACL, you specify an IPv4 ACL.
1. Enter system view.
2. (Optional.) Enable the packet filtering continuous mode.
packet-filter continuous enable
By default, the packet filtering continuous mode is disabled.
3. Apply an ACL globally.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ] [ share-mode ]
By default, global packet filtering is not configured.
You can apply a maximum of three ACLs to the inbound direction of an interface: one IPv4 or one IPv6 ACL, one Layer 2 ACL, and one user-defined ACL. You can apply a maximum of three ACLs to the outbound direction of an interface: one IPv4 or one IPv6 ACL and one Layer 2 ACL.
3. Enter interface view.
4. Apply an ACL to the interface to filter packets.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ] [ share-mode ]
By default, an interface does not filter packets.
You can configure the ACL module to generate log entries or SNMP notifications for packet filtering. The log entry or notification records the number of matching packets and the matched ACL rules. When the first packet of a flow matches an ACL rule, the output interval starts, and the device immediately outputs a log entry or notification for this packet. When the output interval ends, the device outputs a log entry or notification for subsequent matching packets of the flow.
The log entries are sent to the information center. For more information about the information center, see Network Management and Monitoring Configuration Guide.
The SNMP notifications are sent to SNMP. For more information about SNMP, see Network Management and Monitoring Configuration Guide.
2. Set the interval for outputting packet filtering logs or notifications.
acl { logging | trap } interval interval
The default setting is 0 minutes. By default, the device does not generate log entries or SNMP notifications for packet filtering.
The packet filtering default action does not take effect on zone pair packet filtering. The default action for zone pair packet filtering is always deny.
2. Set the packet filtering default action to deny.
packet-filter default deny
By default, the packet filter permits packets that do not match any ACL rule to pass.
· Display ACL application information for packet filtering.
display packet-filter { global | interface [ interface-type interface-number ] } [ inbound | outbound ] [ slot slot-number ]
· Display detailed ACL packet filtering information.
display packet-filter verbose { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ slot slot-number ]
· Display match statistics for packet filtering ACLs.
display packet-filter statistics { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ brief ]
· Display the accumulated statistics for packet filtering ACLs.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ brief ]
To clear match statistics for packet filtering ACLs, execute the following command in user view:
reset packet-filter statistics { global | interface [ interface-type interface-number ] } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ]
A company interconnects its departments through the device. Configure a packet filter to:
· Permit access from the President's office at any time to the financial database server.
· Permit access from the Finance department to the database server only during working hours (from 8:00 to 18:00) on working days.
· Deny access from any other department to the database server.
Figure 1 Network diagram
# Create a periodic time range from 8:00 to 18:00 on working days.
[Device] time-range work 08:0 to 18:00 working-day
# Create an IPv4 advanced ACL numbered 3000.
[Device] acl advanced 3000
# Configure a rule to permit access from the President's office to the financial database server.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
# Configure a rule to permit access from the Finance department to the database server during working hours.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work
# Configure a rule to deny access to the financial database server.
[Device-acl-ipv4-adv-3000] rule deny ip source any destination 192.168.0.100 0
# Apply IPv4 advanced ACL 3000 to filter outgoing packets on interface FourHundredGigE 1/0/1.
[Device] interface fourhundredgige 1/0/1
[Device-FourHundredGigE1/0/1] packet-filter 3000 outbound
[Device-FourHundredGigE1/0/1] quit
# Verify that a PC in the Finance department can ping the database server during working hours. (All PCs in this example use Windows XP).
C:\> ping 192.168.0.100
Pinging 192.168.0.100 with 32 bytes of data:
Reply from 192.168.0.100: bytes=32 time=1ms TTL=255
Reply from 192.168.0.100: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.0.100:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
# Verify that a PC in the Marketing department cannot ping the database server during working hours.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
# Display configuration and match statistics for IPv4 advanced ACL 3000 on the device during working hours.
[Device] display acl 3000
Advanced IPv4 ACL 3000, 3 rules,
ACL's step is 5
rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
rule 5 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work (Active)
rule 10 deny ip destination 192.168.0.100 0
The output shows that rule 5 is active. Rule 5 and rule 10 have been matched four times as the result of the ping operations.
