05-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9827 & S9857 Switch Series Command References-R932x-6W10005-Layer 3—IP Services Command Reference
06-Multi-CPU packet distribution commands
06-Multi-CPU packet distribution commands 35.24 KB
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow | per-packet }
The flow-based policy is used.
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. This policy takes the first-in first-out rule.
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs. This policy does not ensure packet order.
# Specify the packet-based policy.
[Sysname] forwarding policy per-packet
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
