03-Interface Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9827 & S9857 Switch Series Command References-R932x-6W10003-Interface Command Reference
03-Ethernet interface commands
03-Ethernet interface commands 679.66 KB
Ethernet interface commands· 1
Common Ethernet interface commands· 1
dampening· 1
display ethernet statistics· 2
display fdr-statistics interface· 4
display ifmonitor buffer statistics· 6
display ifmonitor buffer status· 8
display interface· 9
display lbn-group status· 22
display link-flap protection· 23
display link-state-change statistics interface· 24
display packet-drop· 25
duplex· 26
flow-control 27
flow-control receive enable· 27
flow-interval 28
group-member interface· 29
ifmonitor buffer mode· 30
ifmonitor crc-error 31
ifmonitor input-error 32
ifmonitor input-usage· 33
ifmonitor output-error 34
ifmonitor output-usage· 35
ifmonitor rx-pause· 36
ifmonitor tx-pause· 37
interface· 39
itf number 39
jumboframe enable· 40
lbn-group· 41
link-delay· 41
link-flap protect enable· 43
loadbalance ecmp lbn-group enable· 44
loadbalance ecmp lbn-group mode· 44
loadbalance link-aggregation lbn-group enable· 45
loopback· 46
multicast-suppression· 47
port ifmonitor buffer queue enable· 48
port ifmonitor buffer queue threshold· 49
port ifmonitor crc-error 51
port ifmonitor input-error 52
port ifmonitor input-usage· 54
port ifmonitor output-error 55
port ifmonitor output-usage· 56
port ifmonitor rx-pause· 57
port ifmonitor sdh-b1-error 58
port ifmonitor sdh-b2-error 60
port ifmonitor sdh-error 61
port ifmonitor tx-pause· 62
port link-flap protect 63
port link-mode· 64
port up-mode· 65
reset ethernet statistics· 66
reset link-state-change statistics interface· 66
reset packet-drop interface· 67
shutdown all-interfaces· 67
shutdown all-physical-interface· 68
shutdown-interval link-flap· 69
snmp-agent trap enable ifmonitor 70
speed· 71
speed auto-reduction enable· 72
speed auto-reduction restore· 73
sub-interface rate-statistic· 73
using eighthundredgige· 74
using fourhundredgige· 75
using hundredgige· 76
using twohundredgige· 80
Layer 2 Ethernet interface commands· 83
display storm-constrain· 83
storm-constrain· 85
storm-constrain control 87
storm-constrain enable log· 87
storm-constrain enable trap· 88
storm-constrain interval 88
Layer 3 Ethernet interface or subinterface commands· 89
mac-address· 89
mtu· 90
dampening
Use dampening to enable the device to dampen an interface when the interface is flapping.
Use undo dampening to restore the default.
undo dampening
Interface dampening is disabled on Ethernet interfaces.
Ethernet interface view
half-life: Specifies the amount of time after which a penalty is decreased, in the range of 1 to 120 seconds. The default value is 54 seconds.
reuse: Specifies the reuse threshold in the range of 200 to 20000. The default value is 750. The reuse threshold must be less than the suppression threshold.
suppress: Specifies the suppression threshold in the range of 200 to 20000. The default value is 2000.
max-suppress-time: Specifies the maximum amount of time the interface can be dampened, in the range of 1 to 255 seconds. The default value is 162 seconds (three times the half-life timer).
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2 (Max-suppress-time/Decay) × reuse-limits. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
This command, the link-delay command, and the port link-flap protect enable command are mutually exclusive on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
Do not enable the dampening function on an interface with MSTP enabled.
After an interface in down state is dampened, the interface state displayed through the display interface command is always down.
# Enable interface dampening on FourHundredGigE 1/0/1.
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] dampening
# Enable interface dampening on FourHundredGigE 1/0/1, and set the following parameters:
·     Half life time to 2 seconds.
·     Reuse value to 800.
·     Suppression threshold to 3000.
·     Maximum suppression interval to 5 seconds.
[Sysname-FourHundredGigE1/0/1] dampening 2 800 3000 5
display interface
link-delay
Use display ethernet statistics to display the Ethernet module statistics.
display ethernet statistics slot slot-number
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display the Ethernet module statistics for the specified slot.
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
    Totalnum        : 10447          ETHIINum     : 4459
    SNAPNum         : 0              RAWNum       : 0
    LLCNum          : 0              UnknownNum   : 0
    ForwardNum      : 4459           ARP          : 0
    MPLS            : 0              ISIS         : 0
    ISIS2           : 0              IP           : 0
    IPV6            : 0
ETH receive error statistics:
    NullPoint       : 0              ErrIfindex   : 0
    ErrIfcb         : 0              IfShut       : 0
    ErrAnalyse      : 5988           ErrSrcMAC    : 5988
    ErrHdrLen       : 0
ETH send packet statistics:
    L3OutNum        : 211            VLANOutNum   : 0
    FastOutNum      : 155            L2OutNum     : 0
ETH send error statistics:
    MbufRelayNum    : 0              NullMbuf     : 0
    ErrAdjFwd       : 0              ErrPrepend   : 0
    ErrHdrLen       : 0              ErrPad       : 0
    ErrQoSTrs       : 0              ErrVLANTrs   : 0
    ErrEncap        : 0              ErrTagVLAN   : 0
    IfShut          : 0              IfErr        : 0
Table 1 Output description
Statistics about the Ethernet packets received by the Ethernet module:
·     Totalnum—Total number of received packets.
·     ETHIINum—Number of packets encapsulated by using Ethernet II.
·     SNAPNum—Number of packets encapsulated by using SNAP.
·     RAWNum—Number of packets encapsulated by using RAW.
·     ISISNum—Number of packets encapsulated by using ISIS.
·     LLCNum—Number of packets encapsulated by using LLC.
·     UnknownNum—Number of packets encapsulated by using unknown methods.
·     ForwardNum—Number of packets forwarded at Layer 2 or sent to the CPU.
·     ARP—Number of ARP packets. ‌
·     MPLS—Number of MPLS packets. This parameter is not supported in the current software version.
·     ISIS—Number of IS-IS packets.
·     ISIS2—Number of large 802.3/802.2 frames encapsulated by using IS-IS.
·     IP—Number of IP packets.
·     IPv6—Number of IPv6 packets.
Statistics about the error Ethernet packets in the inbound direction on the Ethernet module. Errors might be included in packets or occur during the receiving process. The items include:
·     NullPoint—Number of packets that include null pointers.
·     ErrIfindex—Number of packets that include incorrect interface indexes.
·     ErrIfcb—Number of packets that include incorrect interface control blocks.
·     IfShut—Number of packets that are being received when the interface is shut down.
·     ErrAnalyse—Number of packets that include packet parsing errors.
·     ErrSrcMAC—Number of packets that include incorrect source MAC addresses.
·     ErrHdrLen—Number of packets that include header length errors.
Statistics about the Ethernet packets sent by the Ethernet module:
·     L3OutNum—Number of packets sent out of Layer 3 Ethernet interfaces.
·     VLANOutNum—Number of packets sent out of VLAN interfaces.
·     FastOutNum—Number of packets fast forwarded.
·     L2OutNum—Number of packets sent out of Layer 2 Ethernet interfaces.
Statistics about the error Ethernet packets in the outbound direction on the Ethernet module:
·     MbufRelayNum—Number of packets transparently sent.
·     NullMbuf—Number of packets with null pointers.
·     ErrAdjFwd—Number of packets with adjacency table errors.
·     ErrPrepend—Number of packets with extension errors.
·     ErrHdrLen—Number of packets with header length errors.
·     ErrPad—Number of packets with padding errors.
·     ErrQoSTrs—Number of packets that failed to be sent by QoS.
·     ErrVLANTrs—Number of packets that failed to be sent in VLANs.
·     ErrEncap—Number of packets that failed to be sent due to link header encapsulation failures.
·     ErrTagVLAN—Number of packets that failed to be sent due to VLAN tag encapsulation failures.
·     IfShut—Number of packets that are being sent when the interface is shut down.
·     IfErr—Number of packets with incorrect outgoing interfaces.
Use display fdr-statistics interface to display Flight Data Recorder (FDR) statistics for an interface.
display fdr-statistics interface [ interface-type [ interface-number ] ]
You can execute this command to display FDR statistics for interfaces. FDR collects FEC information, which can help you evaluate the robustness and quality for a link.
If you do not specify an interface type and interface number, this command displays FDR statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command displays FDR statistics for all interfaces of the specified type.
# Display FDR statistics for Layer 3 Ethernet interface FourHundredGigE 1/0/1.
<Sysname> display fdr-statistics interface FourHundredGigE 1/0/1
Collecting Data ...
FDR start to collect data timestamp: 8267.762672128 sec
FDR end to collect data timestamp: 12137.849311488 sec
Number of Uncorrected codewords:                            4                               0
Number of codewords:                            2476043710513                       585958921
Symbol errors:                                             32                               0
code words err S0:                              2476043710422                       585958930
code words err S1:                                          0                               0
code words err S2:                                          0                               0
code words err S3:                                          0                               0
code words err S4:                                          0                               0
code words err S5:                                          0                               0
code words err S6:                                          0                               0
code words err S7:                                          0                               0
code words err S8:                                          4                               0
code words err S9:                                          0                               0
code words err S10:                                         0                               0
code words err S11:                                         0                               0
code words err S12:                                         0                               0
code words err S13:                                         0                               0
code words err S14:                                         0                               0
code words err S15:                                         0                               0
code words err S16:                                         0                               0
Collecting Data
Data collected by FDR.
PRE-FEC is not work now
PRE-FEC is not operating.
Time when FDR started to collect data.
Time when FDR stopped collecting data.
Number of uncorrectable codewords.
The data in column 2 represents cumulative interface statistics.
The data in column 3 represents the most recent interface statistics.
Number of codewords
Number of codewords processed by FEC.
Symbol errors
Total number of error symbols processed by FEC, and each symbol in an FEC packet contains 10 bits.
code words err Sn
Number of codewords that have the specified entries for error symbols. Each codeword has multiple symbols.
Use display ifmonitor buffer statistics to display monitoring and data collection statistics for the buffer on an interface.
display ifmonitor buffer statistics interface interface-type interface-number [ queue queue-index ] [ last number ]
interface interface-type interface-number: Specifies an interface by its type and number. The interface-type argument represents the interface type and the interface-number argument represents the interface number.
queue queue-index: Specifies a queue by its index. If you do not specify a queue, this command displays statistics about all queues.
last number: Displays the most recently generated statistic entries. If you do not specify this keyword, this command displays the statistics within the last 24 hours.
# Display the monitoring and data collection statistics for the buffer on FourHundredGigE1/0/1.
<Sysname> display ifmonitor buffer statistics interface fourhundredgige 1/0/1
Queue: 1
 Time: 2021-06-02 14:54:43
  Input:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
  Output:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
 Time: 2021-06-02 14:49:43
  Input:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
  Output:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
Queue: 2
  Input:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
  Output:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
  Input:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
  Output:
   A-Rate: 840385600
   P-Rate: 845712000
   Discard: 29956755
   A-Buffer: 2503
   P-Buffer: 2507
   Buffer Rate: 12%
Queue
Queue number.
Time
Time when statistics collection started.
Input
Input interface.
Output
Output interface.
A-Rate
Average rate of the packet, in bps.
P-Rate
Peak rate of the packet, in bps.
Discard
Number of dropped packets.
A-Buffer
Average buffer usage, in bytes.
P-Buffer
Peak buffer usage, in bytes.
Buffer Rate
Buffer usage, in percentage.
Use display ifmonitor buffer status to display the status of the buffer statistics monitoring and collection feature on an interface.
display ifmonitor buffer status [ interface interface-type interface-number ]
To clear interface statistics, execute the reset counters interface command.
# Display the status of the buffer statistics monitoring and collection feature.
<Sysname> display ifmonitor buffer status
Slot 1              Mode: standard
Interface/Queue     Interval(ms)     InputDiscard       OutputDiscard
400GE1/0/1          -                0                  0
queue1              10               0                  0
queue2              5                0                  0
queue3              10               0                  0
queue4              10               0                  0
queue5              10               0                  0
queue6              10               0                  0
400GE1/0/2          -                0                  0
queue1              10               0                  0
queue2              5                0                  0
queue3              10               0                  0
queue4              10               0                  0
queue5              10               0                  0
queue6              10               0                  0
Chassis
Member ID.
Slot
Slot number of the card.
Mode
Modes of the buffer statistics monitoring and collection feature:
·     Standard mode
·     Enhanced mode
Interface/Queue
Interface name or interface queue number.
Interval
Collection interval.
InputDiscard
Number of dropped packets in the incoming queue.
OutputDiscard
Number of dropped packets in the outgoing queue.
display interface
Use display interface to display interface information.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber: Specifies a subinterface number. The interface-number argument is an interface number. The subnumber argument is the number of a subinterface created under the interface. The value range for the subnumber argument is 1 to 4094.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
This command only counts payload data.
# Display information about Layer 3 interface FourHundredGigE 1/0/1.
<Sysname> display interface fourhundredgige 1/0/1
Line protocol state: DOWN
Description: FourHundredGigE1/0/1 Interface
Bandwidth: 400000000 kbps
Link delay (up): 10 msec. Link delay (down): 1 msec
Fec counter Last 15mins uncorr errors: 0, corr errors: 0
Peak1 Fec counter uncorr errors: 0, corr errors: 0 00/00/0000 00:00:00:000000
Peak2 Fec counter uncorr errors: 0, corr errors: 0 00/00/0000 00:00:00:000000
PRE-FEC is not work now. PRE-FEC Last 30 seconds BER: <0.00e+00
   SER[0]: <0.00e+00   SER[1]: <0.00e+00   SER[2]: <0.00e+00   SER[3]: <0.00e+00
      SER[4]: <0.00e+00   SER[5]: <0.00e+00   SER[6]: <0.00e+00   SER[7]: <0.00e
+00
Each serdes rate is:53.125 Gbps
Packets received of length [Byte]:
  [64]: 0        [65-127]: 0     [128-255]: 0
  [256-511]: 0   [512-1023]: 0   [1024-1518]: 0
  [1519-2047]: 0 [2048-4095]: 0  [4096-9216]: 0  [9217-16383]: 0
Packets transmitted of length [Byte]:
Allow jumbo frames to pass
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Media type is not sure, port hardware type is No connector
Port power is 12W
Port priority: 2
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 6 hours 39 minutes 28 seconds
Last hardware down reason: PHY line side is down
Current system time:2019-01-08 14:50:06
Last time when physical state changed to up:2019-01-08 14:49:45
Last time when physical state changed to down:2019-01-08 14:49:45
 Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
 Last 300 seconds input:  0 packets/sec 0 bytes/sec  0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec  0%
Traffic statistic: Not include Inter-frame Gaps and Preambles
 Input  (total): 0 packets, 0 bytes
          0 unicasts, 0 broadcasts, 0 multicasts, - pauses
 Input  (normal): 0 packets, 0 bytes
 Input: 0 input errors, 0 runts, 0 giants, 0 throttles
          - ignored, - parity errors
 Output  (total): 0 packets, 0 bytes
 Output  (normal): 0 packets, 0 bytes
          - lost carrier, - no carrier
IPv4 traffic statistics:
 Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 0 packets, 0 bytes
 Output: 0 packets, 0 bytes
IPv6 traffic statistics:
# Display detailed information about Layer 2 interface FourHundredGigE 1/0/1.
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Loopback is not set
Port power is 12W
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Unknown-multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
Table 5 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN (up-delay)—The interface up event is delayed on the interface, because the port up-delay command is executed on the interface.
·     DOWN ( Link-Aggregation interface down )—The aggregate interface to which the interface belongs has been shut down by using the shutdown command.
·     DOWN ( Tunnel-Bundle administratively down )—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command.
·     DOWN (Monitor-Link uplink down)—The interface has been shut down by Monitor Link.
·     Link-Flap DOWN—The interface has been shut down by the link flapping protection feature.
·     mac-address moving down—The interface has been shut down by the MAC address move suppression feature.
·     OFP DOWN—The interface has been shut down by OpenFlow.
·     Storm-Constrain—The interface has been shut down because the storm control feature detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
·     STP DOWN—The interface has been shut down by the BPDU guard feature.
·     M-LAG MAD Shutdown—The interface was set to the M-LAG MAD DOWN state when the M-LAG system split.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
·     DOWN (protocols)—The data link layer has been shut down by protocols included in the parentheses. Available protocols include:
¡     LAGG—Shuts down the data link layer when it detects that the aggregate interface does not have Selected ports.
¡     BFD—Shuts down the data link layer when it detects a link failure.
¡     MACSEC—Shuts down the data link layer when it fails to negotiate the encryption parameters.
Bandwidth
Expected bandwidth of the interface.
Physical connection status suppression time of the interface, in milliseconds.
MTU of the interface.
IP packet processing capability of the interface when the interface is not assigned an IP address:
·     Disabled—The interface cannot process IP packets.
·     Enabled—The interface can process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
IPv4 packet framing format.
hardware address
MAC address of the interface.
IPv6 packet framing format.
Port priority
Port priority of the interface.
FEC data is collected every 15 minutes. This field displays the most recently saved data.
This field records the peak value and time based on the correctable errors.
This field records the peak value and time based on the uncorrectable errors.
Loopback is set internal
An internal loopback test is running on the interface. This field depends on your configuration.
Loopback is set external
An external loopback test is running on the interface. This field depends on your configuration.
Loopback is not set
No loopback test is running on the interface. This field depends on your configuration.
100Gbps-speed mode
The interface is operating at 100 Gbps. This field depends on your configuration and the link parameter negotiation result.
200Gbps-speed mode
The interface is operating at 200 Gbps. This field depends on your configuration and the link parameter negotiation result.
400Gbps-speed mode
The interface is operating at 400 Gbps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
The interface is configured with the speed auto command.
Link speed type is force link
The interface is manually configured with a speed by using the speed command.
The interface is configured with the duplex auto command.
link duplex type is force link
The interface is manually configured with a duplex mode(for example, full) by using the duplex command.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Maximum length of Ethernet frames allowed to pass through the interface.
The interface allows jumbo frames to pass through.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
MDI type
MDIX mode of the interface:
·     automdix.
·     mdi.
·     mdix.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
Untagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
VLAN Passing
VLANs whose packets can be forwarded by the port. The VLANs must have been created.
VLAN permitted
VLANs whose packets are permitted by the port.
Trunk port encapsulation
Encapsulation protocol type for the trunk port.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Reason for which the interface hardware went down:
·     PHY line side is down.
·     PHY system side is down.
·     No optical signal has been received at the optical port.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system date and time, which is displayed in the YYYY-MM-DD hh:mm:ss format by default.
If the time zone is configured, this field is in the YYYY-MM-DD hh:mm:ss zone-name±hh:mm:ss format, where the zone-name argument is the local time zone name.
Last date and time when the physical state of the interface changed to up, which is displayed in the YYYY-MM-DD hh:mm:ss format by default.
If the physical state of the interface has never changed to up, this field displays a hyphen (-).
Last date and time when the physical state of the interface changed to down, which is displayed in the YYYY-MM-DD hh:mm:ss format by default.
If the physical state of the interface has never changed to down, this field displays a hyphen (-).
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics of incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants. Giants refer to frames larger than the maximum frame length supported on the interface.
For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
·     1518 bytes (without VLAN tags).
·     1522 bytes (with VLAN tags).
For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length).
¡     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags).
¡     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
IPv4 packet statistics.
IPv6 packet statistics.
Average inbound traffic rate (in pps and Bps) in the last 300 seconds.
Average outbound traffic rate (in pps and Bps) in the last 300 seconds.
Inbound traffic statistics (in packets and bytes) for the interface.
Outbound traffic statistics (in packets and bytes) for the interface.
# Display brief information about all interfaces.
Protocol: (s) – spoofing
Interface            Link Protocol Primary IP      Description
400GE1/0/1           DOWN DOWN     --
Loop0                UP   UP(s)    2.2.2.9
NULL0                UP   UP(s)    --
Vlan1                UP   DOWN     --
Vlan999              UP   UP       192.168.1.42
Speed: (a) - auto
400GE1/0/2           DOWN auto    A      A    1
400GE1/0/3           UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about FourHundredGigE 1/0/3, including the complete description of the interface.
<Sysname> display interface fourhundredgige 1/0/3 brief description
Speed: (a) - auto
400GE1/0/3           UP   auto    F(a)   A    1    aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
400GE1/0/1           DOWN Not connected
Vlan2                DOWN Not connected
400GE1/0/2           DOWN Not connected
Table 6 Command output
Brief information about Layer 3 interfaces.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Brief information of interfaces in bridge mode:
Brief information about Layer 2 interfaces.
Speed: (a) - auto
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode.
·     A(a)—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     H—Half duplex.
Type: A - access; T - trunk; H – hybrid
Link type options for interfaces.
Speed
Speed of the interface, in bps.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     DOWN ( Link-Aggregation interface down )—The interface is a member port of an aggregate interface, and the aggregate interface is down.
·     DOWN (Loopback detection down)—The loopback detection module has detected loops.
·     DOWN ( Monitor-Link uplink down )—The monitor link module has detected that the uplink is down.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
·     Storm-Constrain—The storm control feature has detected that unknown unicast traffic, multicast traffic, or broadcast traffic exceeded the upper threshold.
·     Port Security Disabled—The interface has been shut down by the intrusion detection mechanism, because the interface received illegal packets.
Use display lbn-group status to display rail group information.
Example
# Display LBN group information.
<System> display lbn-group status
Global lbn-group configuration: Enable
GroupName      GroupIndex    Index       Interface
Leaf1          1             0           FourHundredGigE1/0/2
Leaf           2             0           FourHundredGigE1/0/3
                                         FourHundredGigE1/0/4
Table 7 Command output
Status of the LBN group feature:
·     Disable
·     Enable
GroupName
Name of the LBN group.
GroupIndex
Index of an interface in the LBN group.
Index
Index of the LBN group.
Name of the interface.
Use display link-flap protection to display information about link flapping protection on an interface.
display link-flap protection [ interface interface-type [ interface-number ] ]
interface-type: Specifies an interface type. If you do not specify an interface type, the command displays information about link flapping protection on all interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, the command displays information about link flapping protection on all interfaces of the specified type.
# Display information about link flapping protection on an interface.
<Sysname> display link-flap protection
Link-flap protection: Enabled
Interface            Link-flap  Status  Interval  Threshold
400GE1/0/1           Enabled    Down    10        5
400GE1/0/2           Disabled   N/A     --        --
Table 8 Command output
Status of link flapping protection on all interfaces:
·     Enabled—Link flapping protection is enabled on all interfaces.
·     Disabled—Link flapping protection is disabled on all interfaces.
Link-flap
Status of link flapping protection on an interface:
·     Enabled—Link flapping protection is enabled on an interface.
·     Disabled—Link flapping protection is disabled on an interface.
·     Unconfig—Link flapping protection is not configured on an interface.
Status
Status of an interface:
·     Down—The interface has been shut down by the link flapping protection feature.
·     N/A—The interface status is not affected by the link flapping protection feature.
Interval
Link flapping detection interval for an interface.
Threshold
Link flapping detection threshold for an interface.
Use display link-state-change statistics interface to display the physical link state change statistics of interfaces.
display link-state-change statistics interface [ interface-type [ interface-number ]
If you do not specify an interface type, this command displays the link state change statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command displays the link state change statistics for all interfaces of the specified type.
# Display the link state change statistics of all interfaces.
<Sysname> display link-state-change statistics interface
Interface              Change-times  Last-change-time     Reset link-state time
                                     Link-flap-begin      Link-flap-end
400GE1/0/1             0             Never                Never
                                     Never                Never
Table 9 Command output
Abbreviated interface name.
Change-times
Number of physical state changes.
Last-change-time
Last time when the physical state changed.
Time when the physical link state change statistics were cleared.
Link-flap-begin
Last time when a physical link state flapping began. If no link state flapping has occurred, this field displays Never.
Link-flap-end
Last time when a physical link state flapping ended. If no link state flapping has occurred, this field displays Never.
display packet-drop
Use display packet-drop to display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
summary: Displays the summary of dropped packets on only interfaces that support this command.
If you do not specify an interface type, this command displays information about dropped packets on only interfaces that support this command on the device.
If you specify an interface type but do not specify an interface number, this command displays information about dropped packets on only interfaces of the specified type that support this command.
# Display information about dropped packets on FourHundredGigE 1/0/1.
<Sysname> display packet-drop interface fourhundredgige 1/0/1
FourHundredGigE1/0/1:
  Packets dropped due to full GBP or insufficient bandwidth: 301
  Packets dropped due to Fast Filter Processor (FFP): 261
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0 Output dropped:0
# Display the summary of dropped packets on only interfaces that support this command.
<Sysname> display packet-drop summary
All interfaces:
Table 10 Command output
Packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Packets that are filtered out.
Packets that are dropped because STP is in the non-forwarding state.
Inbound and outbound packets that are dropped due to insufficient data buffer.
duplex
Use duplex to set the duplex mode for an Ethernet interface.
Use undo duplex to restore the default.
duplex { auto | full }
undo duplex
Ethernet interfaces operate in autonegotiation mode.
auto: Configures the interface to autonegotiate the duplex mode with the peer.
full: Configures the interface to operate in full duplex mode. In this mode, the interface can receive and transmit packets simultaneously.
# Configure FourHundredGigE 1/0/1 to operate in full duplex mode.
[Sysname-FourHundredGigE1/0/1] duplex full
flow-control
Use flow-control to enable TxRx-mode generic flow control on an Ethernet interface.
Use undo flow-control to disable TxRx-mode generic flow control on the Ethernet interface.
flow-control
undo flow-control
TxRx-mode generic flow control is disabled on an Ethernet interface.
With TxRx-mode generic flow control configured, an interface can both send and receive flow control frames:
·     When congested, the interface sends a flow control frame to its peer.
·     Upon receiving a flow control frame from the peer, the interface suspends sending packets.
To implement flow control on a link, enable generic flow control at both ends of the link.
# Enable TxRx-mode generic flow control on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] flow-control
Use flow-control receive enable to enable Rx-mode generic flow control on an Ethernet port.
Use undo flow-control to disable Rx-mode generic flow control on an Ethernet port.
undo flow-control
Rx-mode generic flow control is disabled on Ethernet interfaces.
With Rx-mode flow control enabled, an interface can receive but cannot send flow control frames.
·     When the interface receives a flow control frame from its peer, it suspends sending packets to the peer.
·     When traffic congestion occurs on the interface, it cannot send flow control frames to the peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end, and the flow-control command at the other. To enable both ends of the link to handle traffic congestion, configure the flow-control command at both ends.
# Enable Rx-mode generic flow control on FourHundredGigE 1/0/1.
[Sysname-fourhundredgige 1/0/1] flow-control receive enable
flow-control
flow-interval
Use flow-interval to set the statistics polling interval.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is300 seconds.
interval: Sets the statistics polling interval in seconds. In system view, the interval is in the range of 5 to 300 and must be a multiple of 5. In Ethernet interface view, the interval is in the range of 1 to 300 and must be a multiple of 1.
You can use this command in system view or interface view.
·     In system view, the command takes effect on all interfaces.
·     In interface view, the command takes effect only on the specified interface.
The statistics polling interval configured in Ethernet interface view takes precedence over the statistics polling interval configured in system view. The interval configured in system view takes effect on an Ethernet interface only when no interval is configured or the default interval is configured for the Ethernet interface.
As a best practice, use the default value for the flow-interval command in system view. A short static polling interval in system view might decrease the system performance and result in inaccurate statistics.
# Set the statistics polling interval to 100 seconds on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] flow-interval 100
Use group-member interface to assign interfaces to an LBN group.
Use undo group-member interface to remove interfaces from an LBN group.
group-member interface interface-type interface-number [ to interface-type interface-number ]
undo group-member interface interface-type interface-number [ to interface-type interface-number ]
group-member interface interface-type interface-number index index-value
undo   group-member interface interface-type interface-number index index-value
LBN group view
An LBN group does not contain any interfaces.
to: Specifies the end member interface number.
index-value: Specifies an interface by its index, in the range of 0 to 63.
You can specify an index to assign an interface with the specified index to an LBN group or specify a list of interfaces to allow the device to automatically assign indexes to the interfaces and assign the interfaces in bulk to an LBN group.
As a best practice, do not manually specify an index. If you specify a list of non-contiguous interface indexes, the traffic outgoing interfaces will become discontinuous, causing unbalanced traffic. If you have to manually specify an index, do that under guidance of professionals.
You can assign only physical interfaces to an LBN group, and the interfaces must be incoming interfaces.
If you specify a list of interfaces, make sure the two interfaces before and after the to keyword are the same type.
Using the port link-mode command to change the link mode of a member interface or splitting a member interface will remove that interface from the LBN group.
Example
# Assign interfaces FourHundredGigE 1/0/1 through FourHundredGigE 1/0/4 to LBN group Leaf1.
[Sysname] lbn-group Leaf1
[Sysname-lbn-group-Leaf1] group-member interface FourHundredGigE1/0/1 to FourHundredGigE1/0/4
# Assign interface FourHundredGigE 1/0/1 with index 3 to LBN group Leaf1.
[Sysname-lbn-group-Leaf1] group-member interface FourHundredGigE1/0/1 index 3
User ifmonitor buffer mode to set the buffer data monitoring mode.
Use undo ifmonitor buffer mode to restore the default.
ifmonitor buffer mode  standardslot slot-number
undo ifmonitor buffer mode slot slot-number
No buffer data monitoring mode is configured.
standard: Specifies the standard mode.
Operating mechanism
Buffer data monitoring can operate in the following modes:
·     Standard—In this mode, a card supports monitoring and collecting queue buffer data from multiple interfaces, and the data collection interval can be set to 5 ms, 10 ms, 20 ms, 50 ms, or 100 ms.
·     Enhanced—In this mode, a card supports monitoring and collecting queue buffer data from only one interface, and the data collection interval is fixed at 1 ms.
To disable or change the buffer data monitoring mode for a card, you must first execute the undo port ifmonitor buffer queue enable command.
# Set the buffer data monitoring mode to standard.
[Sysname] ifmonitor buffer mode standard slot 1
ifmonitor crc-error
Use ifmonitor crc-error to configure global CRC error packet alarm parameters.
Use undo ifmonitor crc-error to restore the default.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packet alarms.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for CRC error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming CRC error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming CRC error packets exceeds the upper threshold on the interface.
With the CRC error packet alarm function enabled, when the number of incoming CRC error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming CRC error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the CRC error packet alarm parameters in system view and interface view.
·     The configuration in system view takes effect on all interfaces. The configuration in interface view takes effect only on the current interface. (Devices that do not support the slot keyword.)
·     The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface. (Devices that support the slot keyword.)
·     For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
When you execute this command multiple times, the most recent configuration takes effect.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms.
[Sysname] ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
Use ifmonitor input-error to configure global input error packet alarm parameters.
Use undo ifmonitor input-error to restore the default.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packet alarms.
high-threshold high-value: Specifies the upper threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for input error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for input error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of input error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of input error packets exceeds the upper threshold on the interface.
With the input error packet alarm function enabled, when the number of input error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of input error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the input error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms.
[Sysname] ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
Use ifmonitor input-usage to configure global input bandwidth usage alarm parameters.
Use undo ifmonitor input-usage to restore the default.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
The upper threshold is 90, and the lower threshold is 80.
high-threshold high-value: Specifies the upper threshold for input bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for input bandwidth usage alarms, in the range of 1 to 100.
With the input bandwidth usage alarm function enabled, when the input bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the input bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
The statistics polling interval varies by device model:
·     On a device that does not support the flow-interval command, the statistics polling interval is 5 minutes.
·     On a device that supports the flow-interval command, you can use the flow-interval command to set the statistics polling interval.
You can configure the input bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the input bandwidth usage alarm function.
# Set the upper threshold to 95 and lower threshold to 80 for input bandwidth usage alarms.
[Sysname] ifmonitor input-usage high-threshold 95 low-threshold 80
flow-interval
Use ifmonitor output-error to configure global output error packet alarm parameters.
Use undo ifmonitor output-error to restore the default.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
The upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packet alarms.
high-threshold high-value: Specifies the upper threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for output error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for output error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of output error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of output error packets exceeds the upper threshold on the interface.
With the output error packet alarm function enabled, when the number of output error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of output error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output error packet alarm parameters in system view and interface view.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms.
[Sysname] ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
Use ifmonitor output-usage to configure global output bandwidth usage alarm parameters.
Use undo ifmonitor output-usage to restore the default.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
high-threshold high-value: Specifies the upper threshold for output bandwidth usage alarms, in the range of 1 to 100.
low-threshold low-value: Specifies the lower threshold for output bandwidth usage alarms, in the range of 1 to 100.
With the output bandwidth usage alarm function enabled, when the output bandwidth usage on an interface in normal state within the most recent statistics polling interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the output bandwidth usage on an interface in the alarm state within the most recent statistics polling interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the output bandwidth usage alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the output bandwidth usage alarm function.
# Set the upper threshold to 95 and lower threshold to 80 for output bandwidth usage alarms.
[Sysname] ifmonitor output-usage high-threshold 95 low-threshold 80
flow-interval
ifmonitor rx-pause
Use ifmonitor rx-pause to configure global received pause frame alarm parameters.
Use undo ifmonitor rx-pause to restore the default.
ifmonitor rx-pause  slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frame alarms.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for received pause frames, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the received pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the received pause frame alarm function.
# Set the upper threshold to 30, lower threshold to 20, and statistics collection and comparison interval to 4 seconds for received pause frame alarms.
[Sysname] ifmonitor rx-pause high-threshold 30 low-threshold 20 interval 4
ifmonitor tx-pause
Use ifmonitor tx-pause to configure global sent pause frame alarm parameters.
Use undo ifmonitor tx-pause to restore the default.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor tx-pause slot slot-number
The upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frame alarms.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for sent pause frames, in the range of 1 to 65535 seconds.
With the sent pause frame alarm function enabled, when the number of sent pause frames on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frames on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the sent pause frame alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the sent pause frame alarm function.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 5 seconds for sent pause frame alarms.
[Sysname] ifmonitor tx-pause high-threshold 20 low-threshold 10 interval 5
interface
Use interface to enter interface view, create a subinterface and enter its view, or enter the view of an existing subinterface.
# Enter the view of FourHundredGigE 1/0/1.
# Create Ethernet subinterface FourHundredGigE 1/0/1.1 and enter its view.
[Sysname] interface fourhundredgige 1/0/1.1
[Sysname-FourHundredGigE1/0/1.1]
itf number
Use itf number to set the number of interframe padding tags.
Use undo itf number to restore the default.
itf number number
undo itf number
The default varies by device model.
number: Sets the number of interframe padding tags, in the range of 0 to 14.
Ethernet frames are separated by the interframe gaps. By adjusting the interframe gap size for an interface, you can adjust the packet forwarding rate and the forwarding capability of the interface. When rate limit is configured for an interface, to ensure smooth communication, you might need to adjust the interframe gap size. You must set the same interframe gap size for interfaces on both ends of a link.
Typically, use the default interframe gap size. To modify the interframe gap size, consult the professionals. An improper interframe gap size setting might cause packet loss or even interface failure.
This command might cause interface flapping.
# Set the number of interframe padding tags to 9 for GigabitEthernet 1/0/1.
<Sysname> system view
[Sysname] interface gigabitethernet 1/0/1
[Sysname-GigabitEthernet1/0/1] itf number 9
Itf number will be set. Continue? [Y/N]:y
jumboframe enable
Use jumboframe enable to allow jumbo frames within the specified length to pass through.
Use undo jumboframe enable to prevent jumbo frames from passing through.
Use undo jumboframe enable size to restore the default.
jumboframe enable [ size ]
The device allows jumbo frames within a length of 9216 bytes to pass through.
size: Sets the maximum length (in bytes) of Ethernet frames that are allowed to pass through. The value range is 1536 to 9216.
# Allow jumbo frames to pass through FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] jumboframe enable
lbn-group
Use lbn-group to create an LBN group and enter its view.
Use undo lbn-group to delete an LBN group.
lbn-group group-name
undo lbn-group group-name
No LBN group exists.
group-name: Specifies an LBN group name, a case-sensitive string of 1 to 31 characters.
The LBN group feature assigns different incoming interfaces on the device to an LBN group and assigns indexes to these interfaces. The device distributes traffic across various interfaces based on their configured index values by using a specific algorithm. Traffic that arrives at different incoming interfaces is then forwarded through different outgoing interfaces, achieving traffic load sharing.
Changing the link type for an interface in an LBN group between Layer 2 and Layer 3 will remove that interface from the LBN group.
In the primary/backup scenario, if the ECMP mode is eligible, an interface is added to an LBN group, and LBN is enabled globally, traffic will be forwarded through the backup link.
You must add both the incoming and outgoing interfaces to an LBN group and make sure the number of incoming interfaces is an integer multiple of the number of outgoing interfaces.
# Create an LBN group named test and enter its view.
[Sysname] lbn-group test
[Sysname-lbn-group-test]
link-delay
Use link-delay to set the physical state change suppression interval on an Ethernet interface.
Use undo link-delay to restore the default.
undo link-delay { down | up }
Physical state change suppression is disabled.
down: Suppresses link-down events.
up: Suppresses link-up events.
msec: Enables the physical state change suppression interval to be accurate to milliseconds. If you do not specify this keyword, the suppression interval is accurate to seconds.
delay-time: Sets the physical state change suppression interval on the Ethernet interface. A value of 0 means that physical state changes are immediately reported to the CPU and are not suppressed.
·     If you do not specify the msec keyword, the value range is 0 to 30 seconds.
·     If you specify the msec keyword, the value range is 0 to 10000 milliseconds, and the value must be a multiple of 100.
You can configure this feature to suppress only link-down events, only link-up events, or both events. If an event of the specified type still exists when the suppression interval expires, the system reports the event.
When you configure this feature, follow these guidelines:
·     To suppress link-down events, execute the link-delay down command.
·     To suppress link-up events, execute the link-delay up command.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times on an interface, the following rules apply:
·     You can configure the suppression intervals for link-up and link-down events separately.
·     If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
Do not execute this command on an interface that has spanning tree protocols enabled.
This command and the port link-flap protect enable command are mutually exclusive on an Ethernet interface.
# Set the link-down event suppression interval to 8 seconds on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] link-delay down 8
# Set the link-up event suppression interval to 800 milliseconds on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] link-delay up msec 800
Use link-flap protect enable to enable link flapping protection globally.
Use undo link-flap protect enable to disable link flapping protection globally.
link-flap protect enable [ batch [ interval interval | threshold threshold ] * ]
undo link-flap protect enable [ batch [ interval | threshold ] ]
Link flapping protection is disabled globally.
batch: Enables link flapping protection both globally and on all interfaces, and sets the default link flapping detection interval and link flapping detection threshold. If you do not specify this keyword, this command enables link flapping protection only globally.
interval interval: Specifies the link flapping detection interval in seconds. The value range for this argument is 5 to 86400. The default value for this argument is 10.
threshold threshold: Specifies the link flapping detection threshold in the range of 2 to 1200. The default value for this argument is 5.
Link flapping on any interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when the interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, execute this command.
With link flapping protection enabled on an interface, when the interface goes down, the system enables link flapping detection on the interface. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
Link flapping protection takes effect only when it is enabled in both the system view and interface view.
Any of the following operations can enable link flapping protection:
·     Execute the link-flap protect enable batch command in system view, and do not configure link flapping protection on interfaces.
·     Execute the link-flap protect enable batch command in system view, and execute the port link-flap protect enable command in interface view.
·     Execute the link-flap protect enable command in system view, and execute the port link-flap protect enable command in interface view.
The undo link-flap protect enable command works different depending on the keywords specified as follows:
·     If the batch keyword is not specified, this command disables link flapping protection globally.
·     If the batch keyword is specified but the interval or threshold keyword is not specified, this command restores the default for the interval and threshold keywords.
·     If the interval or threshold keyword is specified, this command restores the default for the interval or threshold keyword.
If an interface is already configured with the link-delay or dampening command, the link-delay or dampening command applies when you execute the link-flap protect enable batch command.
# Enable link flapping protection on all interfaces.
[Sysname] link-flap protect enable
loadbalance ecmp lbn-group enable
Use loadbalance ecmp lbn-group enable to enable the ECMP-mode LBN group feature.
Use undo loadbalance ecmp lbn-group enable to disable the ECMP-mode LBN group feature.
The ECMP-mode LBN group feature is disabled.
This command takes effect only on a network configured with ECMP.
Example
# Enable the ECMP-mode LBN group feature.
[Sysname] loadbalance ecmp lbn-group enable
loadbalance link-aggregation lbn-group enable
loadbalance ecmp lbn-group mode
Use loadbalance ecmp lbn-group mode to set a mode for the ECMP-mode LBN group feature.
Use undo loadbalance ecmp lbn-group mode to restore the default.
loadbalance ecmp lbn-group mode enhanced-fixed
The mode for the ECMP-mode LBN group feature is common. If the incoming and outgoing interfaces for the traffic are both in an LBN group and the number of incoming interfaces is an integer number of outgoing interfaces, the mode for the ECMP-mode LBN group feature is enhanced.
enhanced-fixed: Specifies the fixed enhanced mode the ECMP-mode LBN group feature.
Operating mechanism
The ECMP-mode LBN group feature supports the following modes:
·     Normal mode—When a link fault occurs on an outgoing interface that implements load sharing by using the LBN group feature, traffic from its incoming interface will be distributed to one of other ECMP route outgoing interfaces. The forwarding outgoing interfaces for the other incoming interfaces will also be re-calculated.
·     Enhanced mode—When a link fault occurs on an outgoing interface that implements load sharing by using the LBN group feature, traffic from its incoming interface will be load-shared to other ECMP route outgoing interfaces through a hash algorithm. The forwarding outgoing interfaces for the other incoming interfaces will also be re-calculated.
·     Fixed enhanced mode—When a link fault occurs on an outgoing interface that implements load sharing by using the LBN group feature, traffic from its incoming interface will be load-shared to other ECMP route outgoing interfaces through a hash algorithm. The forwarding outgoing interfaces for the other incoming interfaces are not changed.
To execute this command, you must first execute the loadbalance ecmp lbn-group enable command.
# Set the fixed enhanced mode for the ECMP-mode LBN group feature.
[Sysname] loadbalance ecmp lbn-group mode enhanced-fixed
Use loadbalance link-aggregation lbn-group enable to enable the Ethernet link aggregation mode LBN group feature.
Use undo loadbalance link-aggregation lbn-group enable to disable the Ethernet link aggregation mode LBN group feature.
The Ethernet link aggregation mode LBN group feature is disabled.
This command takes effect only on a network configured with Ethernet link aggregation.
Example
# Enable the Ethernet link aggregation mode LBN group feature.
[Sysname] loadbalance link-aggregation lbn-group enable
Relate commands
loopback
CAUTION
CAUTION:
After you enable loopback testing on an Ethernet interface, the interface does not forward data traffic.
Use loopback to enable loopback testing on an Ethernet interface.
Use undo loopback to disable loopback testing on an Ethernet interface.
loopback internal
undo loopback
Loopback testing is disabled on an Ethernet interface.
internal: Enables internal loopback testing on the Ethernet interface.
After you enable loopback testing on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable loopback testing, the Ethernet interface restores to its duplex setting.
The shutdown, port up-mode, and loopback commands are mutually exclusive.
# Enable internal loopback testing on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] loopback internal
multicast-suppression
Use multicast-suppression to enable multicast storm suppression and set the multicast storm suppression threshold.
Use undo multicast-suppression to disable multicast storm suppression.
Ethernet interfaces do not suppress multicast traffic.
ratio: Sets the multicast suppression threshold as a percentage of the interface bandwidth. The value range for this argument (in percentage) is 0 to 100. A smaller value means that less multicast traffic is allowed to pass through.
pps max-pps: Specifies the maximum number of multicast packets that the interface can forward per second. The value range for the max-pps argument (in pps) is 0 to 1.4881 × the interface bandwidth.
kbps max-kbps: Specifies the maximum number of kilobits of multicast traffic that the Ethernet interface can forward per second. The value range for this argument (in kbps) is 0 to the interface bandwidth.
The multicast storm suppression feature limits the size of multicast traffic to a threshold on an interface. When the multicast traffic on the interface exceeds this threshold, the system drops packets until the traffic drops below this threshold.
Both the storm-constrain command and the multicast-suppression command can suppress multicast storms on a port. The multicast-suppression command uses the chip to physically suppress multicast traffic. It has less influence on the device performance than the storm-constrain command, which uses software to suppress multicast traffic.
For the traffic suppression result to be determined, do not configure both the storm-constrain multicast command and the multicast-suppression command on an interface.
The configured suppression threshold value in pps or kbps might be converted into a multiple of a step supported by the chip. As a result, the effective suppression threshold might be different from the configured one. To determine the suppression threshold that takes effect, see the prompts on the device.
# Set the multicast storm suppression threshold to 10000 kbps on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] multicast-suppression kbps 10000
The actual value is 10048 on port FourHundredGigE1/0/1 currently.
The output shows that the value that takes effect is 10048 kbps (157 times of 64), because the chip only supports step 64.
broadcast-suppression
unicast-suppression
Use port ifmonitor buffer queue enable to enable buffer monitoring for a queue.
Use undo port ifmonitor buffer queue enable to restore the default.
port ifmonitor buffer queue queue-index enable [ interval interval ]
undo port ifmonitor buffer queue queue-index enable
Buffer monitoring is disabled for queues.
Interface view
queue-index: Specifies a queue index in the range of 0 to 7. The value range for this argument is 0 to 7.
interval interval: Specifies the data collection interval. The value is 5, 10, 20, 50, or 100 milliseconds. The default is 5 milliseconds when the buffer data monitoring mode is set to standard. In enhanced mode, this parameter is not supported, and the data monitoring collection interval is 1 millisecond.
Operating mechanism
After you configure this feature on an interface, the device will perform the following operations:
Collect buffer data for a queue periodically, and report the collected data at intervals of one second to the gRPC or NETCONF module.
Monitor the buffer usage and microbursts for a specified queue periodically. When a microburst event occurs, the device reports the event to the gRPC or NETCONF module. For more information about the buffer usage and microbursts, see the port ifmonitor buffer queue threshold command.
Before you configure this feature, execute the ifmonitor buffer mode command.
# Enable buffer data monitoring and collection for queue 1 on FourHundredGigE 1/0/1, and set the collection interval to 10 ms.
[Sysname-FourHundredGigE1/0/1] port ifmonitor buffer queue 1 enable interval 10
Use port ifmonitor buffer queue threshold to set the upper and lower buffer usage thresholds on a queue.
Use undo port ifmonitor buffer queue threshold to restore the default.
port ifmonitor buffer queue queue-index threshold high high-percent low low-percent
The upper and lower buffer usage thresholds on a queue are 80% and 30%, respectively.
Interface view
threshold high high-percent: Specifies the upper buffer usage threshold on a queue in the range 1 to 100 in percentage.
low low-percent: Specifies the lower buffer usage threshold on a queue in the range 0 to 100 in percentage.
The device periodically monitors the queue buffer usage every 100ms to detect and report microburst events.
Table 11 describes the conditions for triggering and reporting a microburst event.
Table 11 Conditions for triggering a microburst event
Scenario
Conditions for reporting a microburst event
Scenario 1
Both of the following conditions are met:
·     The queue buffer usage higher than the upper threshold or the lower threshold is 0%.
·     The queue buffer usage has increased by more than 2% compared to the last interval.
If microbursts occur more than 1 second after the last reported microburst event, the device will report a microburst event. If the time when the last microburst event was reported cannot be obtained, the device determines it as the first microburst event and reports it directly.
Scenario 2
·     The queue buffer usage is not higher than the upper threshold and not lower than the lower threshold.
·     Microbursts were detected in the last detection period.
·     If microbursts occur more than 1 second after the last reported microburst event, the device will report a microburst event. If the time when the last microburst event was reported cannot be obtained, the device determines it as the first microburst event and reports it directly.
As shown in Figure 1:
·     For scenario 1:
¡     Microbursts occurred at T0 for the first time. The device will directly report a microburst event.
¡     Microbursts occurred at T0+0.5s and T0+0.8s, but not more than 1 second after the last reported microburst event. The device will not report a microburst event.
¡     Microbursts occurred at T0+1.5s, more than 1 second after the last reported microburst event. The device will report a microburst event.
¡     Microbursts occurred at T0+1.6s, but not more than 1 second after the last reported microburst event. The device will not report a microburst event.
·     For scenario 2:
¡     Microbursts occurred at T0+1.5s, more than 1 second after the last reported microburst event. However, no microbursts occurred at T0+1.4s in the last period. The device will not report a microburst event.
¡     Microbursts occurred at T0+1.6s, more than 1 second after the last reported microburst event, and microbursts occurred at T0+1.5s in the last period. The device will report a microburst event.
Figure 1 Conditions for triggering a microburst event
# Set the upper and lower buffer usage thresholds to 60% and 30%, respectively, for queue 1 on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor buffer queue 1 threshold high 60 low 30
port ifmonitor crc-error
Use port ifmonitor crc-error to configure CRC error packet alarm parameters for an interface.
Use undo port ifmonitor crc-error to restore the default.
An interface uses the global CRC error packet alarm parameters.
ratio: Specifies the alarm thresholds in percentage. If you do not specify this keyword, you configure the alarm thresholds in absolute value.
high-threshold high-value: Specifies the upper threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for CRC error packet alarms. If you specify the ratio keyword, the value range is 1 to 100. If you do not specify the ratio keyword, the value range is 1 to 4294967295 packets.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for CRC error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-error
Use port ifmonitor input-error to configure input error packet alarm parameters for an interface.
Use undo port ifmonitor input-error to restore the default.
An interface uses the global input error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for input error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage
Use port ifmonitor input-usage to configure input bandwidth usage alarm parameters.
Use undo port ifmonitor input-usage to restore the default.
An interface uses the global input bandwidth usage alarm parameters.
Interface view
# Set the upper threshold to 80 and lower threshold to 60 for input bandwidth usage alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor input-usage high-threshold 80 low-threshold 60
flow-interval
port ifmonitor output-error
Use port ifmonitor output-error to configure output error packet alarm parameters for an interface.
Use undo port ifmonitor output-error to restore the default.
An interface uses the global output error packet alarm parameters.
# Set the upper threshold to 5000, lower threshold to 400, and statistics collection and comparison interval to 6 seconds for output error packet alarms on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage
Use port ifmonitor output-usage to configure output bandwidth usage alarm parameters.
Use undo port ifmonitor output-usage to restore the default.
An interface uses the global output bandwidth usage alarm parameters.
Interface view
# Set the upper threshold to 9 and lower threshold to 7 for output bandwidth usage alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor output-usage high-threshold 9 low-threshold 7
flow-interval
port ifmonitor rx-pause
Use port ifmonitor rx-pause to configure received pause frame alarm parameters for an interface.
Use undo port ifmonitor rx-pause to restore the default.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
An interface uses the global received pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for received pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for received pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for received pause frame packets, in the range of 1 to 65535 seconds.
With the received pause frame alarm function enabled, when the number of received pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of received pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 90, lower threshold to 50, and statistics collection and comparison interval to 5 seconds for received pause frame alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor sdh-b1-error
Use port ifmonitor sdh-b1-error to configure SDH-B1 error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-b1-error to restore the default.
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH-B1 error packet alarm parameters.
high-threshold high-value: Specifies the upper threshold for SDH-B1 error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH-B1 error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH-B1 error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH-B1 error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH-B1 error packets exceeds the upper threshold on the interface.
With the SDH-B1 error packet alarm function enabled, when the number of incoming SDH-B1 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH-B1 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH-B1 error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH-B1 error packet alarm function.
# Set the upper threshold to 20, lower threshold to 10, and statistics collection and comparison interval to 10 seconds for SDH-B1 error packet alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-b1-error high-threshold 20 low-threshold 10 interval 10
port ifmonitor sdh-b2-error
Use port ifmonitor sdh-b2-error to configure SDH-B2 error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-b2-error to restore the default.
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH-B2 error packet alarm parameters.
high-threshold high-value: Specifies the upper threshold for SDH-B2 error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH-B2 error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH-B2 error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH-B2 error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH-B2 error packets exceeds the upper threshold on the interface.
With the SDH-B2 error packet alarm function enabled, when the number of incoming SDH-B2 error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH-B2 error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH-B2 error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH-B2 error packet alarm function.
# Set the upper threshold to 10, lower threshold to 8, and statistics collection and comparison interval to 3 seconds for SDH-B2 error packet alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-b2-error high-threshold 10 low-threshold 8 interval 3
port ifmonitor sdh-error
Use port ifmonitor sdh-error to configure SDH error packet alarm parameters for an interface.
Use undo port ifmonitor sdh-error to restore the default.
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
An interface uses the global SDH error packet alarm parameters.
high-threshold high-value: Specifies the upper threshold for SDH error packet alarms, in the range of 1 to 4294967295 packets.
low-threshold low-value: Specifies the lower threshold for SDH error packet alarms, in the range of 1 to 4294967295 packets.
interval interval: Specifies the statistics collection and comparison interval for SDH error packets, in the range of 1 to 65535 seconds.
shutdown: Shuts down an interface when the number of incoming SDH error packets on the interface exceeds the upper threshold. Then, the interface stops forwarding all packets. To recover the interface, execute the undo shutdown command on the interface. If you do not specify this keyword, an upper threshold exceeding alarm is generated and the interface enters the alarm state when the number of incoming SDH error packets exceeds the upper threshold on the interface.
With the SDH error packet alarm function enabled, when the number of incoming SDH error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of incoming SDH error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the SDH error packet alarm parameters in system view and interface view.
For this command to take effect, you must use the snmp-agent trap enable ifmonitor command to enable the SDH error packet alarm function.
# Set the upper threshold to 50, lower threshold to 30, and statistics collection and comparison interval to 10 seconds for SDH error packet alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor sdh-error high-threshold 50 low-threshold 30 interval 10
port ifmonitor tx-pause
Use port ifmonitor tx-pause to configure sent pause frame alarm parameters for an interface.
Use undo port ifmonitor tx-pause to restore the default.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
An interface uses the global sent pause frame alarm parameters.
high-threshold high-value: Specifies the upper threshold for sent pause frame alarms, in the range of 1 to 4294967295.
low-threshold low-value: Specifies the lower threshold for sent pause frame alarms, in the range of 1 to 4294967295.
interval interval: Specifies the statistics collection and comparison interval for sent pause frame packets, in the range of 1 to 65535 seconds.
With the sent pause frame alarm function enabled, when the number of sent pause frame packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of sent pause frame packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
# Set the upper threshold to 50, lower threshold to 40, and statistics collection and comparison interval to 8 seconds for sent pause frame alarms on FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
Use port link-flap protect to configure link flapping protection on an interface.
Use undo port link-flap protect to restore the default.
port link-flap protect { disable | enable [ interval interval | threshold threshold ] * }
undo port link-flap protect { disable | enable [ interval | threshold ] }
Link flapping protection is not configured on an interface, and the global link flapping protection configuration applies on the interface.
disable: Disables link flapping protection on the interface.
enable: Enables link flapping protection on the interface.
If the interval or threshold keyword is not specified when you execute the port link-flap protect enable command, the command uses the default settings for the interval and threshold keywords.
The undo port link-flap protect command works different depending on the keywords specified as follows:
·     If the disable or enable keyword is not specified, this command restores the default for the link flapping protection function on the interface.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
This command and the link-delay command are mutually exclusive on an Ethernet interface.
# Enable link flapping protection on an interface. Set the link flapping detection interval to 10 seconds, and set the link flapping detection threshold to 5.
[Sysname-FourHundredGigE 1/0/1] port link-flap protect enable interval 10 threshold 5
link-delay
port link-mode
Use port link-mode to change the link mode of an Ethernet interface.
Use undo port link-mode to restore the default.
undo port link-mode
An interface operates in Layer 2 mode.
bridge: Specifies the Layer 2 mode.
route: Specifies the Layer 3 mode.
CAUTION
CAUTION:
Changing the link mode of an Ethernet interface also restores all commands (except description, duplex, jumboframe enable, speed, shutdown, combo enable, port fec mode, and port training) on the Ethernet interface to their defaults in the new link mode.
Ethernet interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can use this command to set the link mode to bridge (Layer 2) or route (Layer 3) for these Ethernet interfaces.
# Configure FourHundredGigE 1/0/1 to operate in Layer 2 mode.
[Sysname-FourHundredGigE1/0/1] port link-mode bridge
port up-mode
Use port up-mode to forcibly bring up a fiber Ethernet port.
Use undo port up-mode to restore the default.
port up-mode
undo port up-mode
A fiber Ethernet port is not forcibly brought up. The physical state of a fiber port depends on the physical state of the fibers.
This command forcibly brings up a fiber Ethernet port and enables the port to forward packets unidirectionally over a single link. In this way, transmission links are well utilized.
# Forcibly bring up fiber port FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] port up-mode
reset ethernet statistics
Use reset ethernet statistics to clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Clear the Ethernet module statistics for the specified slot.
<Sysname> reset ethernet statistics slot 1
display ethernet statistics
reset link-state-change statistics interface
Use reset link-state-change statistics interface to clear link state change statistics of interfaces.
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
Link state change statistics of an interface are not cleared.
If you do not specify an interface type, this command clears the link state change statistics for all up interfaces that have traffic counters.
If you specify an interface type but do not specify an interface number, this command clears the link state change statistics for all interfaces of the specified type.
# Clear the link state change statistics of FourHundredGigE 1/0/1.
<Sysname> reset link-state-change statistics interface fourhundredgige 1/0/1
display link-state-change statistics interface
reset packet-drop interface
Use reset packet-drop interface to clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type: Specify an interface type.
interface-number: Specify an interface number.
If you do not specify an interface type, this command clears dropped packet statistics for all interfaces on the device.
If you specify an interface type but do not specify an interface number, the command clears dropped packet statistics for all interfaces of the specified type.
# Clear dropped packet statistics for FourHundredGigE 1/0/1.
<Sysname> reset packet-drop interface fourhundredgige 1/0/1
# Clear dropped packet statistics for all interfaces.
display packet-drop
shutdown all-interfaces
Use shutdown all-interfaces to shut down all main interfaces except management interfaces, IRF physical interfaces, and interfaces excluded from shutdown.
Use undo shutdown all-interfaces to bring up all main interfaces except management interfaces, IRF physical interfaces, and interfaces excluded from shutdown.
shutdown all-interfaces exclude interface-list
undo shutdown all-interfaces exclude interface-list
A physical interface is up.
exclude interface-list: Specifies interfaces to be excluded from shutdown. With this option specified, this command will shut down all main interfaces except the management Ethernet interfaces, IRF physical interfaces, and the specified interfaces excluded from shutdown. Shutdown interfaces are in ADM state. Specify the interface list in the format of interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }. You can specify the interface-list parameter for any times. The interface-type interface-number argument specifies an interface by its type and number. The selected interfaces must reside on the same interface card or subcard. The value for the interface-number2 argument must be greater than the value for the interface-number1 argument. For the configuration to succeed, make sure the start interface and the end interface, which are before and after the to keyword respectively, are of the same type.
This command shuts down all interfaces except the management Ethernet interfaces, IRF physical interfaces, and interfaces excluded from shutdown on a device. For an interface that supports subinterfaces, only the main interface is shut down, and its subinterfaces will not be shut down by this command. In this case, if you execute the display this command on an interface that is shut down, the output shows that the shutdown command is automatically generated on the interface.
To bring up an interface shut down by using the shutdown all-interfaces command, you can execute the undo shutdown command in interface view or the undo shutdown all-interfaces command in system view.
# Shut down all main interfaces except management interfaces, IRF physical interfaces, and interfaces FourHundredGigE 1/0/1 through FourHundredGigE 1/0/4.
[Sysname] shutdown all-interfaces exclude fourhundredgige 1/0/1 to fourhundredgige 1/0/4
shutdown
shutdown all-physical-interfaces
Use shutdown all-physical-interfaces to shut down all physical interfaces.
Use undo shutdown all-physical-interfaces to bring up all physical interfaces.
With the shutdown all-physical-interfaces command, you can shut down all physical interfaces except the management Ethernet interfaces on the device. Physical interfaces shut down by using this command are in ADM state.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up a shutdown interface, execute the undo shutdown all-physical-interfaces command in system view and execute the undo shutdown command in interface view.
# Shut down all physical interfaces.
[Sysname] shutdown all-physical-interfaces
shutdown
shutdown-interval link-flap
Use shutdown-interval link-flap interval to set the port status detection timer for the ports that are shut down by the link flapping protection feature.
Use undo shutdown-interval link-flap interval to restore the default.
shutdown-interval [ link-flap ] interval
undo shutdown-interval [ link-flap ]
The port status detection timer is 30 seconds.
link-flap: Specifies the link flapping protection feature. If you do not specify this keyword, the port status detection timer configured by this command takes effect for all features that support the shutdown-interval command, for example, the CRC error packet alarm feature.
interval: Specifies the port status detection timer, in the range of 0 to 300 seconds. When the value is 0, the system does not automatically restore the interface status, and you must execute the undo shutdown command to manually restore the interface status.
Operating mechanism
When a port is shut down automatically by a feature, the device starts a port status detection timer. When the timer expires, the device restores the port status to its actual physical status automatically.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
·     If T < T1, the port will be brought up after T1 – T seconds.
·     If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
The ifmonitor crc-error command takes effect only if you specify the down-auto-recovery keyword.
# Set the port status detection timer to 100 seconds for the ports that are shut down by the link flapping protection feature.
[Sysname] shutdown-interval link-flap 100
Use snmp-agent trap enable ifmonitor to enable interface alarm functions.
Use undo snmp-agent trap enable ifmonitor to disable interface alarm functions.
snmp-agent trap enable ifmonitor [ crc-error | giant | input-error | input-usage | output-error | output-usage | rant | rx-pause | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
Interface alarm functions are enabled.
crc-error: Enables the CRC error packet alarm function for interfaces.
input-error: Enables the input error packet alarm function for interfaces.
input-usage: Enables the input bandwidth usage alarm function for interfaces.
output-error: Enables the output error packet alarm function for interfaces.
output-usage: Enables the output bandwidth usage alarm function for interfaces.
rx-pause: Enables the received pause frame alarm function for interfaces.
tx-pause: Enables the sent pause frame alarm function for interfaces.
buffer-usage: Enables the sent traffic congestion alarm function for interfaces. With the sent traffic congestion alarm function enabled, when the buffer usage of an interface in normal state reaches the upper threshold, the interface generates an upper threshold exceeding alarm and enters alarm state. When the buffer usage of an interface in the alarm state drops below the lower threshold, the interface generates a recovery alarm and restores to normal state.
# Enable the CRC error packet alarm function for interfaces.
[Sysname] snmp-agent trap enable ifmonitor crc-error
speed
Use speed to set the speed of an Ethernet interface.
Use undo speed to restore the default.
speed { 10000 | 200000 | 400000 | auto }
undo speed
The speed of an Ethernet interface is autonegotiated.
10000: Sets the interface speed to 10000 Mbps.
200000: Sets the interface speed to 200000 Mbps.
400000: Sets the interface speed to 400000 Mbps.
auto: Enables the interface to negotiate a speed with its peer.
For an Ethernet copper port, use the speed command to set its speed to match the speed of the peer interface. Support of copper ports for keywords of this command varies by copper port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a copper port, the copper port supports this speed. Otherwise, the copper port does not support this speed.
For a fiber port, use the speed command to set its speed to match the rate of a transceiver module. Support of fiber ports for keywords of this command varies by fiber port type. For more information, use the speed ? command in interface view. If the system does not prompt that operation failed when you configure a speed for a fiber port, the fiber port supports this speed. Otherwise, the fiber port does not support this speed. Additionally, you must select a speed for a fiber port according to the transceiver module installed to ensure that the transceiver module can be used properly. If the transceiver module installed in a fiber port does not support the speed for the fiber port, the transceiver module cannot be used.
The speed 10000 command is available only on the S9827-128DH and S9827-64EP switches.
# Configure FourHundredGigE 1/0/1 to autonegotiate the speed.
[Sysname-FourHundredGigE1/0/1] speed auto
speed auto
speed auto-reduction enable
Use speed auto-reduction enable to enable automatic speed reduction for an interface.
Use undo speed auto-reduction enable to disable automatic speed reduction for an interface.
Automatic speed reduction is disabled.
400-GE interface view
Operating mechanism
With this feature enabled, if an underlying data forwarding channel of an interface fails, the interface state will not change to down. Instead, it continues to use the remaining underlying data forwarding channels that are operating correctly and automatically decreases its speed, for example, from 400G to 200G.
After you execute this command, the interface speed decreases automatically only when an underlying data forwarding channel fails.
The undo speed auto-reduction enable command restore the speed of an interface. To restore the speed of an interface, execute the speed auto-reduction restore command.
You cannot configure the speed, port up-mode, loopback internal, link-delay, using hundred, or using twohundred command for an interface if the interface has been configured with RLM, and vice versa.
If the speed of an aggregate member port configured with the speed auto-reduction enable command decreases because of channel failure, the member port cannot be selected due to inconsistent speeds. To avoid this issue, execute the link-agge ignore speed command on the aggregate member port.
# Enable automatic speed reduction for an interface.
[Sysname-FourHundredGigE1/0/1] speed auto-reduction enable
Use speed auto-reduction restore to restore the speed of an interface that has automatically reduced its speed.
Before you execute this command on an interface, make sure the underlying data forwarding channel of that interface has recovered.
# Restore the speed of an interface that has automatically reduced its speed.
[Sysname-FourHundredGigE1/0/1] speed auto-reduction restore
sub-interface rate-statistic
Use sub-interface rate-statistic to enable rate statistics collection for the subinterfaces of an Ethernet interface.
Use undo sub-interface rate-statistic to disable rate statistics collection for the subinterfaces of an Ethernet interface.
The system does not collect rate statistics for the subinterfaces of an Ethernet interface.
This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance.
# Enable rate statistics collection for the subinterfaces of FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
using eighthundredgige
Use using eighthundredgige to combine breakout interfaces split from an 800-GE interface into an 800-GE interface or restore a low-bandwidth interface changed from an 800-GE interface to an 800-GE interface.
Use undo using eighthundredgige to cancel the operation of combining breakout interfaces or cancel restoring a low-bandwidth interface changed from an 800-GE interface to an 800-GE interface.
The breakout interfaces are not combined and operate as single interfaces.
400-GE breakout interface view
200-GE breakout interface view
100-GE breakout interface view
400-GE downrated interface view
If you need higher bandwidth on a single interface, you can combine two 400-GE breakout interfaces split from an 800-GE interface into an 800-GE interface. To do so, execute this command on any of these 400-GE breakout interfaces.
After executing this command, you do not need to reboot the device. To view the 400-GE breakout interfaces, execute the display interface brief command.
# Combine FourHundredGigE 1/0/1:1 and FourHundredGigE 1/0/1:2 into an 800-GE interface.
[Sysname] interface fourthundredgige 1/0/1:1
[Sysname-FourHundredGigE1/0/1:1] using eighthundredgige
The interfaces HundredGigE1/0/1:1 will be deleted. Continue? [Y/N]:y
using fourhundredgige
using tworhundredgige
using hundredgige
Use using fourhundredgige to combine 200-GE breakout interfaces split from a 400-GE interface into a 400-GE interface, split an 800-GE interface into multiple 400-GE breakout interfaces, change an 800-GE interface to a 400-GE interface, or restore a low-bandwidth interface to a 400-GE interface.
Use undo using fourhundredgige to cancel the operation of combining breakout interfaces, or cancel the operation of splitting an 800-GE interface.
The mode 1-channel keyword is available only on the S9827-64E switches.
using fourhundredgige [ mode 1-channel ]
200-GE breakout interfaces are not combined and operate as single interfaces. An 800-GE interface is not split or changed and operates as a single interface. A 100-GE interface is not restored to a 400-GE interface.
100-GE downrated interface view
200-GE downrated interface view
800-GE interface view
mode 1-channel: Changes an 800-GE interface to a 400-GE interface. If you do not specify this keyword, this command splits an 800-GE interface into two 400-GE breakout interfaces.
If you need higher bandwidth on a single interface, you can split an 800-GE interface into two 400-GE interfaces. For example, you can split 800-GE interface EightHundredGigE 1/0/1 into two 400-GE interfaces FourHundredGigE 1/0/1:1 and FourHundredGigE 1/0/1:2. The 400-GE breakout interfaces support the same configuration and attributes as common 400-GE interfaces, except that they are numbered differently and cannot be split.
If you need higher bandwidth on a single interface, combine 200-GE breakout interfaces split from a 400-GE interface into a 400-GE interface. To do so, execute this command on any of these 200-GE breakout interfaces.
After executing this command, you do not need to reboot the device. To view the breakout interfaces, combined interfaces, or changed interfaces, execute the display interface brief command.
# Combine TwoHundredGigE 1/0/1:1 and TwoHundredGigE 1/0/1:2 into a 400-GE interface.
[Sysname] interface twohundredgige 1/0/1:1
[Sysname-TwoHundredGigE1/0/1:1] using fourhundredgige
The interfaces TwoHundredGigE1/0/1:1 and TwoHundredGigE1/0/1:2 will be deleted. Continue? [Y/N]:y
# Split EightHundredGigE 1/0/1 into two 400-GE interfaces.
[Sysname] interface eighthundredgige 1/0/1
[Sysname-EightHundredGigE1/0/1] using fourhundredgige
The interface EightHundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
# Restore HundredGigE 1/0/1 to a 400-GE interface.
[Sysname-HundredGigE1/0/1] using fourhundredgige
The interface HundredGigE1/0/1 and HundredGigE1/0/9 will be deleted. Continue? [Y/N]:y
using hundredgige
using hundredgige mode 1-channel
using hundredgige mode 2-channel
using twohundredgige
using twohundredgige mode 1-channel
using hundredgige
Use using hundredgige to split a 400-GE or 800-GE interface into multiple 100-GE breakout interfaces, or change a 400-GE or 800-GE interface to a 100-GE interface.
Use undo using hundredgige to cancel the operation of splitting a 400-GE or 800-GE interface, or cancel the operation of changing a 400-GE or 800-GE interface.
The mode 1-channel keyword is available only on 400-GE interfaces.
using hundredgige [ mode { 1-channel | 2-channel } ]
A 400-GE or 800-GE interface is used as a single interface, and is not split or not changed to a 100-GE interface.
mode 1-channel: Changes an 800-GE or 400-GE interface to a 100-GE interface. If you do not specify this keyword, this command splits an 800-GE interface into multiple 100-GE breakout interfaces or splits a 400-GE interface into four 100-GE breakout interfaces.
mode 2-channel: Splits an 800-GE or 400-GE interface into two 100-GE interfaces. If you do not specify this keyword, this command splits an 800-GE interface into multiple 100-GE breakout interfaces or splits a 400-GE interface into four 100-GE interfaces.
To improve port density, reduce costs, and improve network flexibility, you can split an 800-GE or 400-GE interface into multiple 100-GE breakout interfaces. For example, you can split the 400-GE interface FourHundredGigE 1/0/1 into four 100-GE breakout interfaces HundredGigE 1/0/1:1 through HundredGigE 1/0/1:4. The 100-GE breakout interfaces support the same configuration and attributes as common 100-GE interfaces, except that they are numbered differently and cannot be split.
Specify the mode 1-channel keyword to change a 400-GE interface to a 100-GE interface if the peer is a 100-GE interface or only 100-GE transceiver modules are available.
The device reports the transceiver module alarm information only for the first breakout interface.
The breakout interfaces split from an interface share the same transceiver module. If threshold settings are configured on one breakout interface, the other breakout interfaces will automatically load the threshold settings.
After executing this command, you do not need to reboot the device. To view the changed interfaces, execute the display interface brief command.
For an S9827-128DH switch, when a 400-GE interface is changed to a 100-GE interface, the 400-GE interfaces in the same interface group are also changed to 100-GE interfaces. When a 100-GE interface is restored to a 400-GE interface, the 100-GE interfaces in the same interface group are also restored to 400-GE interfaces. Table 12 shows interface groups of an S9827-128DH switch.
Table 12 Interface groups of an S9827-128DH switch
Interface group number
Interfaces
1
FourHundredGigE 1/0/1, FourHundredGigE 1/0/9
2
FourHundredGigE 1/0/2, FourHundredGigE 1/0/10
3
FourHundredGigE 1/0/3, FourHundredGigE 1/0/4
4
FourHundredGigE 1/0/5, FourHundredGigE 1/0/6
5
FourHundredGigE 1/0/7, FourHundredGigE 1/0/15
6
FourHundredGigE 1/0/8, FourHundredGigE 1/0/16
7
FourHundredGigE 1/0/11, FourHundredGigE 1/0/12
8
FourHundredGigE 1/0/13, FourHundredGigE 1/0/14
9
FourHundredGigE 1/0/17, FourHundredGigE 1/0/25
10
FourHundredGigE 1/0/18, FourHundredGigE 1/0/26
11
FourHundredGigE 1/0/19, FourHundredGigE 1/0/21
12
FourHundredGigE 1/0/20, FourHundredGigE 1/0/22
13
FourHundredGigE 1/0/23, FourHundredGigE 1/0/31
14
FourHundredGigE 1/0/24, FourHundredGigE 1/0/32
15
FourHundredGigE 1/0/27, FourHundredGigE 1/0/29
16
FourHundredGigE 1/0/28, FourHundredGigE 1/0/30
17
FourHundredGigE 1/0/33, FourHundredGigE 1/0/41
18
FourHundredGigE 1/0/34, FourHundredGigE 1/0/42
19
FourHundredGigE 1/0/35, FourHundredGigE 1/0/37
20
FourHundredGigE 1/0/36, FourHundredGigE 1/0/38
21
FourHundredGigE 1/0/39, FourHundredGigE 1/0/47
22
FourHundredGigE 1/0/40, FourHundredGigE 1/0/48
23
FourHundredGigE 1/0/43, FourHundredGigE 1/0/45
24
FourHundredGigE 1/0/44, FourHundredGigE 1/0/46
25
FourHundredGigE 1/0/49, FourHundredGigE 1/0/57
26
FourHundredGigE 1/0/50, FourHundredGigE 1/0/58
27
FourHundredGigE 1/0/51, FourHundredGigE 1/0/52
28
FourHundredGigE 1/0/53, FourHundredGigE 1/0/54
29
FourHundredGigE 1/0/55, FourHundredGigE 1/0/63
30
FourHundredGigE 1/0/56, FourHundredGigE 1/0/64
31
FourHundredGigE 1/0/59, FourHundredGigE 1/0/60
32
FourHundredGigE 1/0/61, FourHundredGigE 1/0/62
33
FourHundredGigE 1/0/65, FourHundredGigE 1/0/73
34
FourHundredGigE 1/0/66, FourHundredGigE 1/0/74
35
FourHundredGigE 1/0/67, FourHundredGigE 1/0/68
36
FourHundredGigE 1/0/69, FourHundredGigE 1/0/70
37
FourHundredGigE 1/0/71, FourHundredGigE 1/0/79
38
FourHundredGigE 1/0/72, FourHundredGigE 1/0/80
39
FourHundredGigE 1/0/75, FourHundredGigE 1/0/76
40
FourHundredGigE 1/0/77, FourHundredGigE 1/0/78
41
FourHundredGigE 1/0/81, FourHundredGigE 1/0/89
42
FourHundredGigE 1/0/82, FourHundredGigE 1/0/90
43
FourHundredGigE 1/0/83, FourHundredGigE 1/0/85
44
FourHundredGigE 1/0/84, FourHundredGigE 1/0/86
45
FourHundredGigE 1/0/87, FourHundredGigE 1/0/95
46
FourHundredGigE 1/0/88, FourHundredGigE 1/0/96
47
FourHundredGigE 1/0/91, FourHundredGigE 1/0/93
48
FourHundredGigE 1/0/92, FourHundredGigE 1/0/94
49
FourHundredGigE 1/0/97, FourHundredGigE 1/0/105
50
FourHundredGigE 1/0/98, FourHundredGigE 1/0/106
51
FourHundredGigE 1/0/99, FourHundredGigE 1/0/101
52
FourHundredGigE 1/0/100, FourHundredGigE 1/0/102
53
FourHundredGigE 1/0/103, FourHundredGigE 1/0/111
54
FourHundredGigE 1/0/104, FourHundredGigE 1/0/112
55
FourHundredGigE 1/0/107, FourHundredGigE 1/0/109
56
FourHundredGigE 1/0/108, FourHundredGigE 1/0/110
57
FourHundredGigE 1/0/113, FourHundredGigE 1/0/121
58
FourHundredGigE 1/0/114, FourHundredGigE 1/0/122
59
FourHundredGigE 1/0/115, FourHundredGigE 1/0/116
60
FourHundredGigE 1/0/117, FourHundredGigE 1/0/118
61
FourHundredGigE 1/0/119, FourHundredGigE 1/0/127
62
FourHundredGigE 1/0/120, FourHundredGigE 1/0/128
63
FourHundredGigE 1/0/123, FourHundredGigE 1/0/124
64
FourHundredGigE 1/0/125, FourHundredGigE 1/0/126
For an S9857-24DH8EP switch, when a 400-GE interface is changed to a 100-GE interface, the 400-GE interfaces in the same interface group are also changed to 100-GE interfaces. When a 100-GE interface is restored to a 400-GE interface, the adjacent 100-GE interfaces in the same interface group are also restored to 400-GE interfaces. Table 13 shows interface groups of an S9857-24DH8EP switch.
Table 13 Interface groups of an S9857-24DH8EP switch
Interfaces
1
FourHundredGigE 1/0/1, FourHundredGigE 1/0/2
2
3
4
FourHundredGigE 1/0/7, FourHundredGigE 1/0/8
5
FourHundredGigE 1/0/9, FourHundredGigE 1/0/10
6
7
8
FourHundredGigE 1/0/15, FourHundredGigE 1/0/16
9
FourHundredGigE 1/0/17, FourHundredGigE 1/0/18
10
FourHundredGigE 1/0/19, FourHundredGigE 1/0/20
11
FourHundredGigE 1/0/21, FourHundredGigE 1/0/22
12
FourHundredGigE 1/0/23, FourHundredGigE 1/0/24
# Split FourHundredGigE 1/0/1 into multiple 100-GE breakout interfaces.
[Sysname] interface fourhundredgige 1/0/1
[Sysname-FourHundredGigE1/0/1] using hundredgige
The interface FourHundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
# Change FourHundredGigE 1/0/1 to a 100-GE interface.
<System> system-view
[System] interface fourhundredgige 1/0/1
[System-FourHundredGigE1/0/1] using hundredgige mode 1-channel
The interface FourHundredGigE1/0/1 and FourHundredGigE1/0/9 will be deleted. Continue? [Y/N]:y
Use using twohundredgige to split a 400-GE interface into two 200-GE breakout interfaces, or change an 800-GE or 400-GE interface to a 200-GE interface.
Use undo using twohundredgige to cancel the operation of splitting a 400-GE interface, or cancel the operation of changing an 800-GE or 400-GE interface to a 200-GE interface.
The mode 2-channel keyword is available only on the 800-GE interfaces.
using twohundredgige [ mode { 1-channel | 2-channel } ]
An 800-GE or 400-GE interface is not split and operates as a single interface.
mode 1-channel: Changes a 400-GE interface to a 200-GE interface. If you do not specify this keyword, this command splits a 400-GE interface into two 200-GE breakout interfaces.
mode 2-channel: Splits an 800-GE into two 200-GE interfaces. If you do not specify this keyword, this command splits an 800-GE interface into multiple 200-GE breakout interfaces or splits a 400-GE interface into two 200-GE interfaces.
To improve port density, reduce costs, and improve network flexibility, you can split a 400-GE interface into two 200-GE breakout interfaces. For example, you can split the 400-GE interface FourHundredGigE 1/0/1 into two 200-GE breakout interfaces TwoHundredGigE 1/0/1:1 and TwoHundredGigE 1/0/1:2.
The 200-GE breakout interfaces are numbered differently than common 200-GE interfaces, and you cannot use the speed command to change the speed for the 200-GE breakout interfaces.
Specify the mode 1-channel or mode 2-channel keywords to change an 800-GE or 400-GE interface to a 200-GE interface if the peer is a 200-GE interface or only 200-GE transceiver modules are available.
After executing this command, you do not need to reboot the device. To view the breakout interfaces or changed interfaces, execute the display interface brief command.
For an S9827-128DH switch, when a 400-GE interface is changed to a 200-GE interface, the 400-GE interfaces in the same interface group are also changed to 200-GE interfaces. When a 200-GE interface is restored to a 400-GE interface, the 200-GE interfaces in the same interface group are also restored to 400-GE interfaces. Table 14 shows interface groups of an S9827-128DH switch.
Table 14 Interface groups of an S9827-128DH switch
Interfaces
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
For an S9857-24DH8EP switch, when a 400-GE interface is changed to a 200-GE interface, the 400-GE interfaces in the same interface group are also changed to 200-GE interfaces. When a 200-GE interface is restored to a 400-GE interface, the adjacent 200-GE interfaces in the same interface group are also restored to 400-GE interfaces. Table 15 shows interface groups of an S9857-24DH8EP switch.
Table 15 Interface groups of an S9857-24DH8EP switch
Interfaces
1
2
3
4
5
6
7
8
9
10
11
12
# Split FourHundredGigE 1/0/1 into two 200-GE breakout interfaces.
[System-FourHundredGigE1/0/1] using twohundredgige
Layer 2 Ethernet interface commands
display storm-constrain
Use display storm-constrain to display storm control settings and statistics.
display storm-constrain [ broadcast | known-unicast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast: Displays broadcast storm control settings and statistics.
known-unicast: Displays known unicast storm control settings and statistics.
multicast: Displays multicast storm control settings and statistics.
unicast: Displays unknown unicast storm control settings and statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays storm control settings and statistics for all storm control-enabled interfaces.
If you do not specify any keywords, this command displays all storm control settings on all storm control-enabled interfaces.
# Display the storm control settings on all storm control-enabled ports.
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unknown unicast;
              KNUC - known unicast; FW - forwarding
 Flow Statistic Interval: 5 (in seconds)
Port          Type Lower     Upper     Unit  CtrlMode  Status   Trap Log SwitchNum
400GE1/0/1    MC   100       200       kbps  shutdown  shutdown off  on  10
Table 16 Command output
Traffic polling interval (in seconds) of the storm control module.
Port
Abbreviated interface name.
Type of traffic subjected to storm control:
·     BC—Broadcast packets.
·     MC—Multicast packets.
·     UC—Unknown unicast packets.
·     KNUC—Known unicast packets.
Lower
Lower storm control threshold, in pps, kbps, or percentage.
Upper
Upper storm control threshold, in pps, kbps, or percentage.
Unit
Storm control threshold unit:
·     pps.
·     kbps.
·     percentage.
CtrlMode
Action (block or shutdown) taken on the interface when the upper threshold is reached. N/A indicates that no action is configured.
Status
Packet forwarding status:
·     FW—The port is forwarding traffic correctly.
·     shutdown—The port has been shut down.
·     block—The port drops the type of traffic.
Trap
Status of the storm control threshold event trap switch:
·     on—The port sends threshold event traps.
·     off—The port does not send threshold event traps.
Log
Status of the storm control threshold event log switch:
·     on—The port sends threshold event log messages.
·     off—The port does not send threshold event log messages.
SwitchNum
Number of forwarding state changes of the interface.
When the SwitchNum field reaches 65535, it resets automatically.
storm-constrain
Use storm-constrain to enable storm control and set thresholds for broadcast, multicast, or unknown unicast packets on an Ethernet interface.
Use undo storm-constrain to disable storm control for broadcast, multicast, unknown unicast, or all types of traffic.
storm-constrain { broadcast | known-unicast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | known-unicast | multicast | unicast }
Traffic storm control is disabled.
all: Disables storm control for all types of traffic: unknown unicast, known unicast, multicast, and broadcast.
broadcast: Enables or disables broadcast storm control.
known-unicast: Enables or disables known unicast storm control.
multicast: Enables or disables multicast storm control.
unicast: Enables or disables unknown unicast storm control.
pps: Sets storm control thresholds in pps.
kbps: Sets storm control thresholds in kbps.
ratio: Sets storm control thresholds as a percentage of the transmission capacity of the interface.
upperlimit: Sets the upper threshold, in pps, kbps, or percentage.
·     If you specify the pps keyword, the value range for the upperlimit argument is 0 to 1.4881 × the interface bandwidth.
·     If you specify the kbps keyword, the value range for the upperlimit argument is 0 to the interface bandwidth.
·     If you specify the ratio keyword, the value range for the upperlimit argument is 0 to 100.
lowerlimit: Sets the lower threshold, in pps, kbps, or percentage.
·     If you specify the pps keyword, the value range for the lowerlimit argument is 0 to 1.4881 × the interface bandwidth.
·     If you specify the kbps keyword, the value range for the lowerlimit argument is 0 to the interface bandwidth.
·     If you specify the ratio keyword, the value range for the lowerlimit argument is 0 to 100.
After you configure storm control for a type of traffic, the device collects the statistics for the type of traffic at the interval configured by using the storm-constrain interval command. When the type of traffic exceeds its upper threshold, the interface takes an action configured by using the storm-constrain control command.
When configuring this command, make sure upperlimit is greater than lowerlimit.
# Enable unknown unicast storm control on FourHundredGigE 1/0/1 and set the upper and lower thresholds to 200 pps and 150 pps, respectively.
[Sysname-FourHundredGigE1/0/1] storm-constrain unicast pps 200 150
# Enable broadcast storm control on FourHundredGigE 1/0/2, and set the upper and lower thresholds to 2000 kbps and 1500 kbps, respectively.
[Sysname] interface fourhundredgige 1/0/2
[Sysname-FourHundredGigE1/0/2] storm-constrain broadcast kbps 2000 1500
# Enable multicast storm control on FourHundredGigE 1/0/3, and set the upper and lower thresholds to 80% and 15%, respectively.
[Sysname] interface fourhundredgige 1/0/3
[Sysname-FourHundredGigE1/0/3] storm-constrain multicast ratio 80 15
Use storm-constrain control to set the action to take on an Ethernet interface when a type of traffic (unknown unicast, multicast, or broadcast) exceeds the upper storm control threshold.
Use undo storm-constrain control to restore the default.
No action is taken on an Ethernet interface when a type of traffic exceeds the upper storm control threshold.
block: Blocks this type of traffic and forwards other types of traffic. Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the port begins to forward the traffic.
shutdown: Goes down automatically. The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not forward the traffic. To bring up the interface, use the undo shutdown command or disable storm control on the interface.
# Configure FourHundredGigE 1/0/1 to block a specific type of traffic when the type of traffic exceeds the upper storm control threshold.
[Sysname-FourHundredGigE1/0/1] storm-constrain control block
storm-constrain
storm-constrain enable log
Use storm-constrain enable log to enable an Ethernet interface to output log messages when it detects storm control threshold events.
Use undo storm-constrain enable log to disable an Ethernet interface from outputting log messages for storm control threshold events.
An Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable FourHundredGigE 1/0/1 to output log messages when it detects storm control threshold events.
[Sysname-FourHundredGigE1/0/1] storm-constrain enable log
storm-constrain enable trap
Use storm-constrain enable trap to enable an Ethernet interface to send storm control threshold event traps.
Use undo storm-constrain enable trap to disable an Ethernet interface from sending storm control threshold event traps.
An interface sends out storm control threshold event traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
# Enable FourHundredGigE 1/0/1 to send traps when it detects storm control threshold events.
[Sysname-FourHundredGigE1/0/1] storm-constrain enable trap
Use storm-constrain interval to set the traffic polling interval of the storm control module.
Use undo storm-constrain interval to restore the default.
storm-constrain interval interval
The storm control module polls traffic statistics every 10 seconds.
interval: Sets the traffic polling interval of the storm control module. The value range is 1 to 300 seconds. To ensure network stability, as a best practice, do not use a traffic polling interval shorter than 10 seconds.
The traffic polling interval set by using the storm-constrain interval command is specific to storm control. To set the statistics polling interval of an interface, use the flow-interval command.
# Set the traffic statistics polling interval of the storm control module to 60 seconds.
[Sysname] storm-constrain interval 60
storm-constrain
Layer 3 Ethernet interface or subinterface commands
mac-address
Use mac-address to set the MAC address of an Ethernet interface.
Use undo mac-address to restore the default.
mac-address mac-address
undo mac-address
No MAC address is configured for an Ethernet interface. The default MAC address for Layer 3 subinterface is the same as the MAC address of its main interface.
mac-address: Specifies a MAC address in the format of H-H-H.
Do not set a VRRP-reserved MAC address for a Layer 3 Ethernet subinterface.
When you set a MAC address, make sure the following requirements are met:
·     The MAC address must have the same highest 36 bits as the base MAC address.
·     The MAC address must be no lower than the base MAC address plus 160 (decimal).
For more information about base MAC address, see MAC address table in Layer 2—LAN Switching Configuration Guide.
# Set the MAC address of FourHundredGigE 1/0/1 to 0001-0001-0001.
[Sysname-FourHundredGigE1/0/1] mac-address 1-1-1
mtu
Use mtu to set the MTU for an Ethernet interface or subinterface.
mtu size
undo mtu
The MTU of an Ethernet interface or subinterface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument varies by interface type.
A smaller MTU size results in more fragments. When you set the MTU for an interface, consider QoS queue lengths, for example, consider that the default FIFO queue length is 75. To prevent a too small MTU from causing packet drops in QoS queuing, you can perform one of the following configurations:
·     Tune the MTU with the mtu command.
·     Tune QoS queue lengths with the qos fifo queue-length command.
For more information about the qos fifo queue-length command, see ACL and QoS Command Reference.
# Set the MTU to 1430 bytes for FourHundredGigE 1/0/1.
[Sysname-FourHundredGigE1/0/1] mtu 1430
# Set the MTU to 1430 bytes for FourHundredGigE 1/0/1.1.
[Sysname] interface fourhundredgige 1/0/1.1
[Sysname-FourHundredGigE1/0/1.1] mtu 1430
