08-ACL and QoS Command Reference
HomeSupportSwitchesS6812 & S6813 SeriesReference GuidesCommand ReferencesH3C S6812 & S6813 Switch Series Command References-R68xx-6W10008-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 583.13 KB
QoS policy commands· 1
Traffic class commands· 1
description· 1
display traffic classifier 1
if-match· 2
traffic classifier 8
Traffic behavior commands· 8
accounting· 8
car 9
display traffic behavior 10
filter 12
nest top-most 12
packet-rate· 13
redirect 14
remark customer-vlan-id· 15
remark dot1p· 15
remark drop-precedence· 16
remark dscp· 17
remark local-precedence· 18
remark service-vlan-id· 20
traffic behavior 20
QoS policy commands· 21
classifier behavior 21
control-plane· 22
display qos policy· 22
display qos policy control-plane· 24
display qos policy global 25
display qos policy interface· 27
display qos policy l2vpn-ac· 30
display qos policy user-profile· 32
display qos policy vsi 33
display qos vlan-policy· 34
qos apply policy (Ethernet service instance view, interface view, VSI view) 36
qos apply policy (user profile view) 37
qos apply policy global 38
qos policy· 39
qos vlan-policy· 40
reset qos policy control-plane· 41
reset qos policy global 41
reset qos policy l2vpn-ac· 42
reset qos vlan-policy· 42
QoS SNMP notification commands· 43
snmp-agent trap enable qos· 43
Priority mapping commands· 44
Priority map commands· 44
display qos map-table· 44
import 45
qos map-table· 45
Priority trust mode commands· 46
display qos trust interface· 46
qos trust 47
qos trust (system view) 47
Port priority commands· 48
qos priority· 48
Traffic policing, GTS, and rate limit commands· 50
Traffic policing commands· 50
display qos car control-plane whitelist 50
display qos car interface· 51
display qos overhead compensation-length· 52
qos car any· 53
qos car whitelist enable· 54
qos overhead compensation-length· 55
GTS commands· 56
display qos gts interface· 56
qos gts· 57
Rate limit commands· 58
display qos lr interface· 58
qos lr 58
Congestion management commands· 60
Common commands· 60
display qos queue interface· 60
SP commands· 61
display qos queue sp interface· 61
qos sp (interface view) 61
WRR commands· 62
display qos queue wrr interface· 62
qos wrr (interface view) 63
qos wrr weight 64
qos wrr group sp· 65
Queue scheduling profile commands· 65
display qos qmprofile configuration· 65
display qos qmprofile interface· 67
qos apply qmprofile· 67
qos qmprofile· 68
queue· 69
Congestion avoidance commands· 70
WRED commands· 70
display qos wred interface· 70
display qos wred table· 71
qos wred apply· 72
qos wred queue table· 73
queue· 74
queue ecn· 75
queue weighting-constant 76
Global CAR commands· 77
car name· 77
display qos car name· 77
qos car 78
reset qos car name· 80
Queue-based accounting commands· 81
display qos queue-statistics interface outbound· 81
QoS policy commands
description
Use description to configure a description for a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic classes for the master device.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac ] { acl-number | name acl-name }
Matches an ACL.
The value range for the acl-number argument is as follows:
·     2000 to 3999 for IPv4 ACLs.
·     2000 to 3999 for IPv6 ACLs.
·     4000 to 4999 for Layer 2 MAC ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
If the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public network and private network packets.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
To use the nesting action to add an outer VLAN tag to packets, you must use the if-match customer-vlan-id vlan-id-list command to match single-tagged packets.
destination-mac mac-address [ mac-address-mask ]
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets except when you use the nesting action to add outer VLAN tag to packets.
source-mac mac-address [ mac-address-mask ]
Matches a source MAC address.
tunnel-id tunnel-id
Matches a VXLAN tunnel ID. For the traffic class to take effect, the tunnel must be a VXLAN tunnel.
vxlan { any | vxlan-id }
Matches a VXLAN ID.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
IPv6 DHCP packets
dldp
DLDP packets
icmp
ICMP packets
igmp
IGMP packets
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
mvrp
MVRP packets (including GVRP packets)
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
stp
STP packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·     You can specify up to eight values for any of the following match criteria in one if-match command:
¡     DSCP.
¡     802.1p priority.
¡     IP precedence.
¡     VLAN ID.
·     If a packet matches one of the specified values, it matches the if-match command.
·     To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·     The ACL must already exist.
·     The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
If a traffic class in a QoS policy includes the customer-vlan-id match criterion, the QoS policy can be applied only to interfaces.
For the customer-vlan-id and service-vlan-id match criteria, you can configure multiple values in one if-match command.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the packets with a source MAC address of 0050-ba27-bed3 and a MAC address mask of ffff-ffff-0000.
[Sysname-classifier-class1] if-match destination-mac 0050-ba27-bed3 ffff-ffff-0000
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2 and a MAC address mask of ffff-ffff-0000.
[Sysname-classifier-class2] if-match source-mac 0050-ba27-bed2 ffff-ffff-0000
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match the VXLAN packets with tunnel ID 2.
[Sysname-classifier-class1] if-match tunnel-id 2
 # Define a match criterion for traffic class class1 to match the packets with VXLAN 10.
[Sysname-classifier-class1] if-match vxlan 10
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting { byte | packet }
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 1 to 160000000 kbps.
cbs committee-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
·     ebs excess-burst-size: Specifies the excess burst size (EBS). If you do not specify the pps keyword, the EBS is specified in bytes. If you specify the pps keyword, the EBS is specified in packets. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 1 to 160000000 kbps.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
·     Set the CIR to 256 kbps, CBS to 51200 bytes, and EBS to 0.
·     Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 256 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the traffic behaviors for the master device.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Accounting enable
Class-based accounting action.
Filter enable
Traffic filtering action.
Remark mpls-exp
Action of setting the MPLS EXP value for packets.
Redirecting
Information about traffic redirecting.
none
No other traffic behavior is configured.
Packet rate
Protocol packet rate limit.
attack defense threshold
Attack defense threshold for protocol packets.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets. The permitted packets can be processed by other class-behavior associations in the same QoS policy.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
If a QoS policy contains an outer VLAN tag adding action, apply it only to the incoming traffic of an interface.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
An outer VLAN tag adding action takes effect only when the QoS policy is applied to the inbound direction of an interface, VLANs, or globally.
This command does not take effect on packets forwarded by a VXLAN overlay network.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
packet-rate
Use packet-rate to configure a protocol packet rate limiting action in a traffic behavior.
Use undo packet-rate to restore the default.
packet-rate { value | attack-defense-threshold threshold-value } *
undo packet-rate
No protocol packet rate limiting action is configured.
value: Specifies the protocol packet rate in pps. The value range for this argument is 1 to 2000.
attack-defense-threshold threshold-value: Specifies the attack defense threshold for protocol packets, in pps. The value range for the threshold-value argument is 1 to 2000.
Protocol packet rate limiting can protect the CPU against protocol packet attacks.
By default, the device uses  to limit the packets of each protocol to the CPU.
The device automatically enables rate limiting on the interface that sends the packets to the CPU if both of the following conditions exist:
·     The packet rate of a protocol reaches or exceeds the rate limit.
·     The configured attack defense threshold is greater than the configured protocol packet rate.
If you execute the packet-rate command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior copp to rate limit the protocol packets sent to the CPU to 1600 pps.
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
# Configure traffic behavior copp1 to rate limit the protocol packets sent to the CPU to 1600 pps and configure the attack defense threshold for protocol packets as 1400 pps.
[Sysname] traffic behavior copp1
[Sysname-behavior-copp1] packet-rate 1600 attack-defense-threshold 1400
display qos policy
display qos policy control-plane pre-defined
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
A traffic redirecting action takes effect only when the QoS policy is applied to the inbound direction.
If a QoS policy applied to a user profile contains the redirect interface action, make sure the redirected-to interface and the incoming interface of packets are in the same VLAN.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
classifier behavior
qos policy
traffic behavior
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
An 802.1p priority marking action is supported only in the inbound direction.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior. The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
If you do not specify a color, packets of all colors are marked.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
If you execute the remark drop-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark [ green | red | yellow ] local-precedence local-precedence-value [ green | red | yellow ]
undo remark [ green | red | yellow ] local-precedence [ green | red | yellow ]
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
green: Marks packets as green packets.
red: Marks packets as red packets.
yellow: Marks packets as yellow packets.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
If no traffic policing action is configured in the traffic behavior, the local precedence marking action takes effect on all packets, regardless of the packet color.
Operating mechanism
A local precedence marking action assigns packets matching a traffic class to the specified queue, implementing differentiated services for packets. You can use the command to view outbound traffic statistics for queues.
When using this command to mark the local precedence for packets, you can also assign colors to the packets. By combining 16 different local precedence values with red, yellow, and green, you can use a total of 48 different markings for packets.
You can apply a QoS policy containing this command to mark the local precedence and color for packets on the input interface. Then, you can use the qos map-table color lp-tunnel-dscp command to modify the outer DSCP value of the packets on the output interface.
The qos map-table color lp-tunnel-dscp command takes effect only on outgoing packets of VXLAN tunnels or VXLAN-DCI tunnels.
If you specify a local precedence value in the range of 8 to 15, you must specify a color to be marked for the packets.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
qos map-table color
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
An SVLAN marking action in a QoS policy takes effect only when it is applied to an interface.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [  insert-before before-classifier-name ]
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
# Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ remarking | tcp-erspan ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
remarking: Specifies marking-type QoS policies.
tcp-erspan: Specifies TCP ERSPAN-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the QoS policies for the master device.
If you do not specify the remarking or tcp-erspan keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
Table 6 Command output
Information about a user-defined QoS policy.
System-defined QoS policy information
Information about a system-defined QoS policy.
Policy
User-defined generic QoS policy name.
Marking policy
User-defined marking-type QoS policy name.
TCP ERSPAN policy
User-defined TCP ERSPAN-type QoS policy name.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Direction in which the QoS policy is applied.
Use display qos policy global to display QoS policies applied globally.
display qos [ remarking | tcp-erspan ] policy global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays global QoS policies for the master device.
If you do not specify the remarking or tcp-erspan keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both inbound and outbound global QoS policies.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display information about TCP ERSPAN-matching QoS policies applied globally.
<Sysname> display qos tcp-erspan policy global
  Direction: Inbound
  TCP ERSPAN policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/1
Table 8 Command output
Direction
Policy
Marking policy
TCP ERSPAN policy
Green packets
Statistics about green packets.
Yellow packets
Statistics about yellow packets.
Red packets
Statistics about red packets.
Use display qos policy interface to display the QoS policies applied to interfaces.
display qos [ remarking | tcp-erspan ] policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied to incoming traffic.
outbound: Specifies the QoS policy applied to outgoing traffic.
If you do not specify the remarking or tcp-erspan keyword, this command displays generic QoS policies applied.
If you do not specify a direction, this command displays the QoS policy applied to incoming traffic and the QoS policy applied to outgoing traffic.
# Display the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about the TCP ERSPAN-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos tcp-erspan policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/2
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: Ten-GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
        Green packets : 0(Packets)
Interface: Ten-GigabitEthernet1/0/4
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/5
        Green action  : pass
Table 9 Command output
Direction
Policy
Marking policy
TCP ERSPAN policy
Matched
Number of matching packets.
Forwarded
Average rate of successfully forwarded matching packets in a statistics collection period.
Dropped
Average rate of dropped matching packets in a statistics collection period.
Green packets
Traffic statistics for green packets.
Yellow packets
Traffic statistics for yellow packets.
Red packets
Traffic statistics for red packets.
Use display qos policy l2vpn-ac to display the QoS policies applied to Ethernet service instances.
display qos [ remarking ] policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] [ slot slot-number ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays QoS policies applied to all Ethernet service instances on an interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, this command displays QoS policy information for all member devices. Only Layer 2 aggregate interfaces support this option.
inbound: Specifies the QoS policies applied to incoming traffic. If you do not specify this keyword, the command execution results are the same.
# Display the QoS policy applied to the incoming traffic of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Interface: Ten-GigabitEthernet1/0/1    Service instance ID: 1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 88 (kbps), CBS 5632 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Table 10 Command output
Direction
Green packets
Yellow packets
Red packets
Use display qos policy user-profile to display QoS policies applied to user profiles.
display qos policy user-profile [ name profile-name ] [ user-id user-id ] [ slot slot-number ] [ inbound | outbound ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter and must be unique. If you do not specify a user profile, this command displays QoS policies applied to all user profiles.
user-id user-id: Specifies an online user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe. If you do not specify an online user, this command displays QoS policies applied to user profiles for all online users.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to user profiles for all member devices.
inbound: Specifies QoS policies applied to incoming traffic.
outbound: Specifies QoS policies applied to outgoing traffic.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to user profile abc for a global user.
<Sysname> display qos policy user-profile name abc user-id 30000000 inbound
User-Profile: abc
  User ID: 0x30000000(global)
    Direction: Inbound
    Policy: p1
     Classifier: default-class
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: be
        -none-
# Display the QoS policy applied to user profile abc for a local user.
<Sysname> display qos policy user-profile name abc user-id 30000001 inbound
User-Profile: abc
  slot 2:
    User ID: 0x30000001(local)
      Direction: Inbound
      Policy: p1
         Operator: AND
         Rule(s) :
          If-match any
         Behavior: be
          -none-
Table 11 Command output
global
Indicates a global user, who comes online from a global interface such as an aggregate interface.
local
Indicates a local user, who comes online from a physical interface.
Matched
Number of packets that meet match criteria.
Direction
Green packets
Yellow packets
Red packets
Use display qos policy vsi to display QoS policies applied to VSIs.
display qos policy vsi [ name vsi-name ] [ inbound ] [ slot slot-number ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays QoS policies applied to all VSIs.
inbound: Specifies the QoS policy applied to incoming traffic. Because a VSI does not support a QoS policy in the outbound direction, the command execution result is the same no matter whether you specify this keyword.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VSIs for all IRF member devices.
# Display QoS policies applied to all VSIs.
<Sysname> display qos policy vsi
VSI: vsi1
  Direction: Inbound
  Policy: p
   Classifier: c
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
Table 12 Command output
VSI
VSI name.
Direction
Policy
QoS policy name.
Classifier
Traffic class name.
Operator
Operator for match criteria in the traffic class.
Rule(s)
Match criteria.
Behavior
Behavior name.
Green action
Red action
Green packets
Number of green packets.
Yellow packets
Number of yellow packets.
Red packets
Number of red packets.
qos apply policy (VSI view)
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
inbound: Displays QoS policies applied to incoming traffic.
outbound: Displays QoS policies applied to outgoing traffic.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays QoS policies applied to VLANs for the master device.
If you do not specify a direction, this command displays QoS policies applied to VLANs in both the inbound and outbound directions.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Green packets : 0(Packets) 0(Bytes)
        Yellow packets: 0(Packets) 0(Bytes)
        Red packets   : 0(Packets) 0(Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 13 Command output
Direction
Green packets
Yellow packets
Red packets
Use qos apply policy to apply a QoS policy to an Ethernet service instance, interface, or VSI.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ remarking | tcp-erspan ] policy policy-name { inbound | outbound }
undo qos apply [ remarking | tcp-erspan ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Interface view
VSI view
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view or Ethernet service instance view.
tcp-erspan: Specifies a TCP ERSPAN-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in VSI view or Ethernet service instance view.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
·     if-match control-plane protocol
·     if-match control-plane protocol-group
·     if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡     The used ACL must be an advanced ACL.
¡     You must specify TCP or UDP for the protocol argument in the rule.
¡     You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
A QoS policy applied to a Layer 3 Ethernet interface can match only untagged packets.
A Layer 3 aggregate interface is not concerned about VLAN tagging. You can configure VLAN tagging as  needed.
A QoS policy applied to a Layer 3 aggregate subinterface or Layer 3 Ethernet subinterface can match only tagged packets.
# Apply QoS policy TEST1 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
# Apply marking-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy TEST4 outbound
# Apply TCP ERSPAN-type QoS policy TEST4 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply tcp-erspan policy TEST4 outbound
# Apply generic QoS policy TEST9 to the incoming traffic of Ethernet service instance 200.
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] qos apply policy TEST9 inbound
# Apply QoS policy TEST12 to the incoming traffic of VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] qos apply policy TEST12 inbound
Use qos apply policy to apply a QoS policy to a user profile.
Use undo qos apply policy to remove a QoS policy applied to a user profile.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied to a user profile.
User profile view
inbound: Applies the QoS policy to the incoming traffic of the device (traffic sent by online users).
outbound: Applies the QoS policy to the outgoing traffic of the device (traffic received by online users).
Deleting a user profile also removes the QoS policies applied to the user profile.
For a user profile to be active, the QoS policy applied in user profile view cannot be empty. A user profile supports only the car and accounting actions in a QoS policy.
# Apply QoS policy test to outgoing traffic for user profile user.
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
undo qos apply [ remarking | tcp-erspan ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
inbound: Applies the QoS policy to the incoming packets on all interfaces.
outbound: Applies the QoS policy to the outgoing packets on all interfaces.
A global QoS policy takes effect on all incoming or outgoing traffic depending on the direction in which the QoS policy is applied.
A maximum of three QoS policies (one generic, one marking-type, and one TCP ERSPAN-type) can be applied to one direction globally.
If both source and destination addresses exist in ACLs of different traffic classes, the system matches destination addresses before matching source addresses.
If you do not specify the remarking or tcp-erspan keyword, this command applies a generic QoS policy globally.
# Globally apply QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ remarking | tcp-erspan ] policy policy-name
undo qos [ remarking | tcp-erspan ] policy policy-name
No QoS policies exist.
remarking: Identifies the QoS policy as a marking-type QoS policy.
tcp-erspan: Identifies the QoS policy as a TCP ERSPAN QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
# Create a TCP ERSPAN-matching QoS policy named user7.
[Sysname] qos tcp-erspan policy user7
[Sysname-qospolicy-user7]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
# Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
Use reset qos policy global to clear statistics for QoS policies applied globally.
reset qos [ remarking| tcp-erspan ] policy global [ inbound | outbound ]
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify a direction, this command clears statistics for the global QoS policies in both directions.
If you do not specify the remarking or tcp-erspan keyword, this command clears statistics for generic QoS policies.
# Clear statistics for the generic QoS policy applied to the inbound direction globally.
<Sysname> reset qos policy global inbound
Use reset qos policy l2vpn-ac to clear the QoS policies applied to Ethernet service instances.
reset qos [ remarking ]policy l2vpn-ac [ interface interface-type interface-number [ service-instance instance-id ] ] [ inbound ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears QoS policies applied to Ethernet service instances on all interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command clears QoS policies applied to all Ethernet service instances on an interface.
If you do not specify the remarking keyword, this command clears statistics for generic QoS policies.
# Clear the QoS policies applied to the inbound direction of Ethernet service instance 1 on Ten-GigabitEthernet 1/0/1.
<Sysname> reset qos policy l2vpn-ac interface ten-gigabitethernet 1/0/1 service-instance 1 inbound
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics of the QoS policies in both directions of the VLAN.
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Use snmp-agent trap enable qos to enable SNMP notifications for QoS.
Use undo snmp-agent trap enable qos to disable SNMP notifications for QoS.
SNMP notifications are disabled for QoS.
Execute this command to report critical QoS events by sending SNMP notifications.
For QoS notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for QoS.
[Sysname] snmp-agent trap enable qos
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp ]
The device provides the following types of priority map.
Table 14 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-exp
802.1p-EXP priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
exp-dot1p
EXP-802.1p priority map.
exp-dp
EXP-drop priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 15 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp }
For the description of other keywords, see Table 14.
# Enter 802.1p-local priority map view.
import
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
 Port priority information
  Port priority: 4
  Port dscp priority: -
  Port priority trust type: dscp
Table 16 Command output
Interface type and interface number.
Port priority
Port priority set for the interface.
Port dscp priority
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-).
Priority trust mode on the interface:
·     dot1p—Uses the 802.1p priority of received packets for mapping.
·     dscp—Uses the DSCP precedence of received IP packets for mapping.
·     none—Trusts no packet priority.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority and uses the port priority as the 802.1p priority for mapping.
Layer 2/Layer 3 Ethernet interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
qos trust (system view)
Use qos trust to configure the global priority trust mode for VXLAN packets.
qos trust tunnel-dscp
undo qos trust tunnel-dscp
The global priority trust mode for VXLAN packets is not configured.
tunnel-dscp: Trusts the DSCP value in the outer IP header of VXLAN packets for priority mapping.
For a VXLAN tunnel interface to trust the DSCP priority in the outer IP header of VXLAN packets, you must also configure the qos trust dscp command on its physical interface.
# Configure the switch to trust the DSCP priority in the outer IP header of VXLAN packets.
[Sysname] qos trust tunnel-dscp
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0.
priority-value: Specifies a priority value. If the dscp keyword is not specified, this argument specifies the port priority in the range of 0 to 7. If the dscp keyword is specified, this argument specifies the DSCP value to be set for packets, in the range of 0 to 63.
You can assign one value to each type of port priority on an interface. For each type of port priority, the most recent configuration takes effect.
# Set the port priority of Ten-GigabitEthernet 1/0/1 to 2.
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
Traffic policing, GTS, and rate limit commands
Traffic policing commands
display qos car control-plane whitelist
Use display qos car control-plane whitelist to display ACL whitelist-based control plane CAR configuration and statistics.
display qos car control-plane whitelist [ ipv6 ] slot slot-number
ipv6: Specifies the IPv6 ACL whitelist. If you do not specify this keyword, the command displays IPv4 ACL whitelist-based control plane CAR configuration and statistics.
To protect traffic matching the ACL whitelist, make sure ACL whitelist-based control plane CAR is enabled. This command displays ACL whitelist-based control plane CAR configuration and statistics by queue.
An ACL whitelist can be statically configured or dynamically generated according to existing BGP sessions.
To view ACL rules in an ACL whitelist, use the display acl whitelist command.
# Display ACL whitelist-based control plane CAR configuration and statistics for slot 1.
<Sysname> display qos car control-plane whitelist slot 1
Slot 1:
   Whitelist-based traffic policing: Enabled
   Failed rule ID: 101, 202
   Queue name: ftp
   CIR 128 (kbps), CBS 8000 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
   Queue name: http
   Queue name: default
Table 17 Command output
Whether ACL whitelist-based traffic policing for the control plane is enabled: Enabled or Disabled.
Failed rule ID
IDs of rules that failed to take effect.
Green packets
Yellow packets
Red packets
qos car whitelist enable
display qos car interface
Use display qos car interface to display the CAR information for interfaces.
display qos car interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CAR information for all interfaces.
# Display the CAR information for Ten-GigabitEthernet 1/0/1.
<Sysname> display qos car interface ten-gigabitethernet 1/0/1
 Direction: inbound
  Rule: If-match any
   CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
   Green action  : pass
# Display the CAR information on Ten-GigabitEthernet 1/0/2.
<Sysname> display qos car interface ten-gigabitethernet 1/0/2
Interface: Ten-GigabitEthernet1/0/2
 Direction: inbound
  Rule: If-match any
   CIR 50 (%), CBS 600 (ms), EBS 0 (ms), PIR 50 (%)
   Green action  : pass
Table 18 Command output
Interface name, including interface type and interface number.
Direction
Direction in which traffic policing is applied.
Rule
Match criteria.
CIR
CIR in kbps (if the CIR is specified in absolute value) or in percentage (if the CIR is specified in percentage).
CBS
CBS in bytes (if the CBS is specified in absolute value) or in ms (if the CBS is specified in milliseconds). When the CBS is specified in milliseconds, the actual CBS value is cbs-time × the actual CIR value.
EBS
EBS in bytes (if the EBS is specified in absolute value) or in ms (if the EBS is specified in milliseconds). When the EBS is specified in milliseconds, the actual EBS value is ebs-time × the actual CIR value.
PIR
PIR in kbps (if the PIR is specified in absolute value) or in percentage (if the PIR is specified in percentage).
Green action
Yellow action
Red action
display qos overhead compensation-length
Use display qos overhead compensation-length to display the packet compensation length configuration for QoS rate limiting and statistics.
display qos overhead compensation-length [ interface [ interface-type interface-number ] ]
interface: Displays the packet compensation length configuration for QoS rate limiting and statistics on interfaces. If you do not specify this keyword, this command displays the global packet compensation length configuration and the packet compensation length configuration for each interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the the packet compensation length configuration for each interface.
# Display the the global packet compensation length configuration and the packet compensation length configuration for each interface.
<Sysname> display qos overhead compensation-length
Overhead compensation length:
Global
  Inbound  : 23
  Outbound : 14
Interface  : Ten-GigabitEthernet1/0/1
  Inbound  : 33
  Outbound : 44
Interface  : Ten-GigabitEthernet1/0/2
  Inbound  : -22
  Outbound : -33
qos car any
Use qos car any to configure a CAR policy for all packets of a user profile.
Use undo qos car to delete a CAR policy from a user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound }
No CAR policy is configured.
User profile view
inbound: Performs CAR for incoming traffic.
outbound: Performs CAR for outgoing traffic.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 1 to 160000000.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The default value for excess-burst-size is 0 bytes. The value range for excess-burst-size is 0 to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 1 to 160000000.
To use two rates for traffic policing, configure the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
The conforming traffic is permitted to pass through, and the excess traffic is dropped.
If you execute the qos car command multiple times for the same user profile or session group profile, the most recent configuration takes effect.
# Perform CAR for packets received by user profile user. The CAR parameters are as follows:
·     The CIR is 256 kbps.
·     The CBS is 51200 bytes.
[Sysname-user-profile-user] qos car outbound any cir 256 cbs 51200
Use qos car whitelist enable to enable ACL whitelist-based traffic policing for the control plane.
Use undo qos car whitelist enable to disable ACL whitelist-based traffic policing for the control plane.
qos car whitelist [ ipv6 ] enable
undo qos car whitelist [ ipv6 ] enable
ACL whitelist-based traffic policing is enabled, and the device uses the default rate limit values to police matching traffic.
Control plane view
ipv6: Enables whitelist-based traffic policing for the IPv6 dynamic whitelist. If you do not specify this keyword, the command enables whitelist-based traffic policing for the IPv4 dynamic whitelist.
To perform ACL whitelist-based traffic policing, make sure ACL whitelist-based traffic policing is enabled.
# Enable ACL whitelist-based traffic policing for the control plane of slot 1.
[Sysname] control-plane slot 1
[Sysname-cp-slot1] qos car whitelist enable
qos car (control plane view)
Use qos overhead compensation-length to set the packet compensation length for QoS rate limiting and statistics.
Use undo qos overhead compensation-length restore the default.
qos overhead compensation-length [ inbound | outbound ] length
undo qos overhead compensation-length [ inbound | outbound ]
Whether the device includes the IFG, preamble, and start frame delimiter by default when performing QoS rate limiting and statistics depends on the device model.
Interface view
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
length: Specifies the packet compensation length in bytes. The value range for this argument varies by device model.
Operating mechanism
At the data link layer, Ethernet standards require the interframe gap (IFG), preamble, and start frame delimiter to exist between frames to allow the receiving device to prepare for the next frame. The minimum total length of the three parts is 20 bytes.
When the device performs QoS rate limiting (including rate limit, GTS, and traffic policing) and statistics on traffic, it calculates the packet rate and limit the rate based on the size of traffic passing through the interface per unit time. When the traffic size in the network is small, for example, when the average packet length is less than 100 bytes, the IFG significantly affects rate statistics. In this case, you must consider the IFG, preamble, and start frame delimiter when performing QoS rate limiting based on the calculated packet rate.
If the device does not include the IFG, preamble, and start frame delimiter when performing QoS rate limiting and statistics by default, you can set the compensation length to 20 bytes to obtain accurate rate limiting and statistics.
If the device includes the IFG, preamble, and start frame delimiter by default when performing QoS rate limiting and statistics, you can set the compensation length to -20 bytes to exclude the IFG, preamble, and start frame delimiter for performing QoS rate limiting and statistics.
If you do not specify the inbound or outbound keyword, this command configures the outbound packet compensation length.
If you configure the packet compensation length in both system view and interface view, the configuration in interface view takes effect.
# Set the global packet compensation length for outbound QoS rate limiting and statistics to 20 bytes.
[Sysname] qos overhead compensation-length outbound 20
# Set the packet compensation length on Ten-GigabitEthernet 1/0/1 for outbound QoS rate limiting and statistics to 20 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos overhead compensation-length outbound 20
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
Table 19 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 10485760 for 10-GE interfaces, 8 to 41943040 for 40-GE interfaces, and 8 to 104857600 for 100-GE interfaces.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 16777216, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 16777216 is converted to 16777216.
# Shape the packets of queue 1 on Ten-GigabitEthernet 1/0/1. The GTS parameters are as follows:
·     The CIR is 6400 kbps.
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr interface
Use display qos lr interface to display the rate limit configuration for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration for all interfaces.
# Display the rate limit configuration for all interfaces.
 Direction: Outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
Table 20 Command output
Direction
Direction in which the rate limit configuration is applied.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
undo qos lr { inbound | outbound }
No rate limit is configured.
inbound: Limits the rate of incoming packets.
outbound: Limits the rate of outgoing packets.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 1000 to 10485760 for 10-GE interfaces, 1000 to 41943040 for 40-GE interfaces, and 1000 to 104857600 for 100-GE interfaces.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 134217728, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be a multiple of 512. When the product is not a multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 134217728 is converted to 134217728.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 256 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
Congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
Table 21 Command output
Output queue
Type of the current output queue.
Group
Number of the group that holds the queue.
Weight
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
 Output queue: Strict Priority queuing
Table 22 Command output
Output queue
qos sp (interface view)
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses packet-count WRR queuing.
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
Table 23 Command output
Output queue
Group
ID of the group a queue is assigned to.
Weight
Packet-count queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr (interface view)
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr weight
undo qos wrr weight
weight: Allocates bandwidth to queues in packets.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
qos wrr weight
Use qos wrr weight to configure the WRR queuing parameters for a queue on an interface.
qos wrr queue-id group 1 weight schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1, and queues 0 through 7 have a weight of 1, 2, 3, 4, 5, 9, 13, and 15, respectively.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7 or keywords in Table 24.
Table 24 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group 1: Specifies WRR group 1. Only WRR group 1 is supported in the current software version.
schedule-value: Specifies a scheduling weight. The value range for this argument is 1 to 15.
# Enable packet-based WRR queuing on Ten-GigabitEthernet 1/0/1, assign queue 0 to WRR group 1, and specify scheduling weight 10 for queue 0.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues are in WRR group 1.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
Queue scheduling profile commands
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the queue scheduling profile configuration for the master device.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID  Type  Group   Schedule   Schedule  Min         Max
                        unit       value     bandwidth   bandwidth
be        SP    N/A     N/A        N/A       N/A         N/A
af1       SP    N/A     N/A        N/A       N/A         N/A
af2       SP    N/A     N/A        N/A       N/A         N/A
af3       SP    N/A     N/A        N/A       N/A         N/A
af4       SP    N/A     N/A        N/A       N/A         N/A
ef        SP    N/A     N/A        N/A       N/A         N/A
cs6       SP    N/A     N/A        N/A       N/A         N/A
cs7       SP    N/A     N/A        N/A       N/A         N/A
Table 25 Command output
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
Group
Priority group to which the queue belongs.
The value can only be 1. N/A indicates this field is ignored.
Schedule unit
Scheduling unit, which can only be weight.
N/A indicates that this field is ignored.
Schedule value
This field indicates the number of packets scheduled each time.
Min bandwidth
Minimum guaranteed bandwidth for the queue. N/A indicates that this field is ignored.
Max bandwidth
This field is not supported in the current software version. Maximum allowed bandwidth for the queue. N/A indicates that this field is ignored.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
Table 26 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to the outbound direction of an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wrr group group-id weight schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
Queue scheduling profile view
sp: Enables SP for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID. The group ID can only be 1.
schedule-value: Specifies the scheduling weight. The value range for this argument is 1 to 15.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling weight is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
qos qmprofile
Congestion avoidance commands
WRED commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   100      1000     10   100      1000     10   100      1000     10   9   N
1   100      1000     10   100      1000     10   100      1000     10   9   N
2   100      1000     10   100      1000     10   100      1000     10   9   N
3   100      1000     10   100      1000     10   100      1000     10   9   N
4   100      1000     10   100      1000     10   100      1000     10   9   N
5   100      1000     10   100      1000     10   100      1000     10   9   N
6   100      1000     10   100      1000     10   100      1000     10   9   N
7   100      1000     10   100      1000     10   100      1000     10   9   N
Table 27 Command output
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exp
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the WRED table configuration for the master device.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
Table 28 Command output
Table name
Name of a WRED table.
Table type
QID
Queue ID.
gmin
gmax
gprob
ymin
ymax
yprob
rmin
rmax
rprob
exponent
ECN
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 100, the upper limit is 1000, and the drop probability is 10%.
WRED table view
all: Specifies all queues.
queue-id: Specifies a queue by its ID. The value range for this argument is 0 to 7.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low-limit low-limit: Specifies the lower limit for the average queue length. The value range for low-limit is 0 to 16000 cell resources. A cell resource is 256 bytes.
high-limit high-limit: Specifies the upper limit for the average queue length. The upper limit must be greater than the lower limit. The value range for high-limit is 0 to 16000 cell resources. A cell resource is 256 bytes.
discard-probability discard-prob: Specifies the denominator for drop probability calculation. The greater the denominator, the greater the calculated drop probability. The value range for discard-prob is 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
To enable ECN, do not specify ToS field bit 6 or 7 as the flag bit in iNQA, and vice versa. For more information about iNQA, see Network Management and Monitoring Configuration Guide.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation. The value range for exponent is 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
Global CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
   Yellow action : pass
   Red action    : discard
  Slot 0:
  Slot 1:
  Slot 2:
   Apply failed
Table 29 Command output
Name
Name of the aggregate CAR action.
Mode
Type of the CAR action, which can be aggregative.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets:
·     discard—Drops the packets.
·     pass—Permits the packets to pass through.
Yellow action
Action to take on yellow packets:
Red action
Action to take on red packets:
Green packets
Statistics about green packets.
Yellow packets
Statistics about yellow packets.
Red packets
Statistics about red packets.
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 256000000, in increments of 512. If the PIR is configured, the default EBS is the product of 62.5 and the PIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 160000000.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
 Direction: outbound
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Dropped: 0 packets, 0 bytes
 Queue 7
Table 30 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic both in the number of packets, in the number of bytes, and in the number of packets or bits per second.
Dropped
Counts dropped traffic both in packets and in bytes.
Green forwarded
Number of green packets forwarded and number of bytes for the green packets forwarded.
Green dropped
Number of green packets dropped and number of bytes for the green packets dropped.
Yellow forwarded
Number of yellow packets forwarded and number of bytes for the yellow packets forwarded.
Yellow dropped
Number of yellow packets dropped and number of bytes for the yellow packets dropped.
Red forwarded
Number of red packets forwarded and number of bytes for the red packets forwarded.
Red dropped
Number of red packets dropped and number of bytes for the red packets dropped.
Total queue length
Total number of packets allowed in the queue.
use ratio
Utilization ratio of the queue.
reset counters interface (Layer 2—LAN Switching Command Reference)
