05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesFS SeriesFS5500V2-EI SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C FS5500V2-EI iOptic Switch Series Configuration Guides-R8307Pxx-6W10005-Layer 3—IP Routing Configuration Guide
02-Static routing configuration
02-Static routing configuration 264.08 KB
Configuring static routing
About static routes
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
2.     Configure a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } { next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] | vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address [ nexthop-index index-string ] track-arp [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
You can associate Track with a static route to monitor the reachability of the next hops. For more information about Track, see High Availability Configuration Guide.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
3.     (Optional.) Enable periodic sending of ARP requests to the next hops of static routes.
ip route-static arp-request interval interval
By default, the device does not send ARP requests to the next hops of static routes.
4.     (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default setting is 60.
Configuring a static route group
This task allows you to batch create static routes with different prefixes but the same output interface and next hop.
You can create a static route group, and specify the static group in the ip route-static command. All prefixes in the static route group will be assigned the next hop and output interface specified in the ip route-static command.
2.     Create a static route group and enter its view.
ip route-static-group group-name
By default, no static route group is configured.
3.     Add a static route prefix to the static route group.
prefix dest-address { mask-length | mask }
By default, no static route prefix is added to the static route group.
4.     Return to system view.
5.     Configure a static route.
Public network:
ip route-static group group-name interface-type interface-number [ next-hop-address ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name { next-hop-address [ recursive-lookup host-route ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name vpn-instance d-vpn-instance-name [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static group group-name interface-type interface-number next-hop-address track-arp [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ next-hop-address ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name { next-hop-address [ recursive-lookup host-route ] [ public ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name { public | vpn-instance d-vpn-instance-name } [ track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number next-hop-address track-arp [ preference preference ] [ tag tag-value ] [ description text ]
If you specify a destination VPN instance without specifying a next hop address, the destination VPN instance cannot be the same as the source VPN instance.
Configuring floating static routes
Perform this task to configure route backup to improve network reliability.
When a static or dynamic route to a destination address already exists on the device, you configure another static route with a lower priority as the backup route to improve the network reliability. This backup static route is called a floating static route and is activated only when the primary route fails. After the primary route recovers from failure, the floating static route becomes inactive and data forwarding switches back to the primary route.
A floating static route can be configured in either of the following ways
·     Configure different priorities for multiple static routes to the same destination address. The route with the lower priority automatically becomes the floating static route.
·     When a route to a destination address already exists on the device, configure a static route with a lower priority to the same destination address.
When you configure a floating static route, the priority value of the route must be larger than then priority value of the primary route. For more information, see "Configuring a static route."
Deleting static routes
To delete a static route, use the undo ip route-static command. To delete all static routes including the default route, use the delete static-routes all command.
2.     Delete all static routes.
Public network:
VPN:
delete vpn-instance vpn-instance-name static-routes all
CAUTION
CAUTION:
Deleting all static routes with caution. This operation might cause network connectivity failure and packet forwarding failure.
Configuring BFD for static routes
IMPORTANT
IMPORTANT:
Enabling BFD for a flapping route could worsen the situation.
About BFD
BFD provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols.
For more information about BFD, see High Availability Configuration Guide.
Configuring BFD control packet mode
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to static routes with a direct next hop or with an indirect next hop.
Restrictions and guidelines for BFD control packet mode
If you use BFD control packet mode at the local end, you must use this mode also at the peer end.
Configuring BFD control packet mode for a static route (direct next hop)
2.     Configure BFD control packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd control-packet [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for a static route is not configured.
Configuring BFD control packet mode for a static route (indirect next hop)
Public network:
ip route-static dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd control-packet bfd-source ip-address } [ preference preference ] [ tag tag-value ] [ description text ]
Configuring static route FRR
About static route FRR
A link or router failure on a path can cause packet loss. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
Figure 1 Network diagram
As shown in Figure 1, upon a link failure, packets are directed to the backup next hop to avoid traffic interruption. You can either specify a backup next hop for FRR or enable FRR to automatically select a backup next hop (which must be configured in advance).
Restrictions and guidelines for static route FRR
·     Do not use static route FRR and BFD (for a static route) at the same time.
·     Equal-cost routes do not support static route FRR.
·     Besides the configured static route for FRR, the device must have another route to reach the destination.
When the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down, static route FRR quickly redirects traffic to the backup next hop. When the Layer 3 interfaces of the primary link are down, static route FRR temporarily redirects traffic to the backup next hop. In addition, the device searches for another route to reach the destination and redirects traffic to the new path if a route is found. If no route is found, traffic interruption occurs.
Configuring static route FRR by specifying a backup next hop
A static route does not take effect when the backup output interface is unavailable.
To change the backup output interface or next hop, you must first remove the current setting. The backup output interface and next hop must be different from the primary output interface and next hop.
2.     Configure static route FRR.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, static route FRR is disabled.
Configuring static route FRR to automatically select a backup next hop
2.     Configure static route FRR to automatically select a backup next hop.
ip route-static fast-reroute auto
By default, static route FRR is disabled from automatically selecting a backup next hop.
Display and maintenance commands for static routing
Display static route information.
display ip routing-table protocol static [ inactive | verbose ]
Display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
Display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
Static route configuration examples
Example: Configuring basic static routes
As shown in Figure 2, configure static routes on the switches for interconnections between any two hosts.
Figure 2 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure static routes:
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Switch C.
[SwitchC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
3.     Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
# Display static routes on Switch A.
[SwitchA] display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 1
0.0.0.0/0           Static 60   0            1.1.4.2         Vlan500
Static Routing table status : <Inactive>
Summary count : 0
# Display static routes on Switch B.
[SwitchB] display ip routing-table protocol static
Summary count : 2
Summary count : 2
1.1.2.0/24          Static 60   0            1.1.4.1         Vlan500
Summary count : 0
# Use the ping command on Host B to test the reachability of Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test the reachability of Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
Example: Configuring BFD for static routes (direct next hop)
Configure the following, as shown in Figure 3:
·     Configure a static route to subnet 120.1.1.0/24 on Switch A.
·     Configure a static route to subnet 121.1.1.0/24 on Switch B.
·     Enable BFD for both routes.
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on Switch C.
When the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately. Switch A then communicates with Switch B through Switch C.
Figure 3 Network diagram
Device
IP address
Switch A
VLAN-interface 10
12.1.1.1/24
Switch A
VLAN-interface 11
10.1.1.102/24
Switch B
VLAN-interface 10
12.1.1.2/24
Switch B
VLAN-interface 13
13.1.1.1/24
Switch C
VLAN-interface 11
10.1.1.100/24
Switch C
VLAN-interface 13
13.1.1.2/24
1.     Configure IP addresses for the interfaces. (Details not shown.)
2.     Configure static routes and BFD:
# Configure static routes on Switch A and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[SwitchA-vlan-interface10] bfd min-control-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 10 12.1.1.2 bfd control-packet
[SwitchA] ip route-static 120.1.1.0 24 vlan-interface 11 10.1.1.100 preference 65
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[SwitchB-vlan-interface10] bfd min-control-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10] quit
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 10 12.1.1.1 bfd control-packet
[SwitchB] ip route-static 121.1.1.0 24 vlan-interface 13 13.1.1.2 preference 65
[SwitchB] quit
# Configure static routes on Switch C.
[SwitchC] ip route-static 120.1.1.0 24 13.1.1.1
[SwitchC] ip route-static 121.1.1.0 24 10.1.1.102
# Display BFD sessions on Switch A.
<SwitchA> display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 LD/RD            SourceAddr      DestAddr        State  Holdtime    Interface
 4/7              12.1.1.1        12.1.1.2        Up     2000ms      Vlan10
The output shows that the BFD session has been created.
# Display the static routes on Switch A.
<SwitchA> display ip routing-table protocol static
Summary count : 1
Summary count : 1
120.1.1.0/24        Static 60   0            12.1.1.2        Vlan10
Summary count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary count : 1
Summary count : 1
120.1.1.0/24        Static 65   0            10.1.1.100      Vlan11
Summary count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
Example: Configuring BFD for static routes (indirect next hop)
Figure 4 shows the network topology as follows:
·     Switch A has a route to interface Loopback 1 (2.2.2.9/32) on Switch B, with the output interface VLAN-interface 10.
·     Switch B has a route to interface Loopback 1 (1.1.1.9/32) on Switch A, with the output interface VLAN-interface 12.
·     Switch D has a route to 1.1.1.9/32, with the output interface VLAN-interface 10, and a route to 2.2.2.9/32, with the output interface VLAN-interface 12.
Configure the following:
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on both Switch C and Switch D.
When the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately. Switch A then communicates with Switch B through Switch C.
Figure 4 Network diagram
Device
IP address
Switch A
VLAN-interface 10
12.1.1.1/24
Switch A
VLAN-interface 11
10.1.1.102/24
Switch A
Loopback 1
1.1.1.9/32
Switch B
VLAN-interface 12
11.1.1.1/24
Switch B
VLAN-interface 13
13.1.1.1/24
Switch B
Loopback 1
2.2.2.9/32
Switch C
VLAN-interface 11
10.1.1.100/24
Switch C
VLAN-interface 13
13.1.1.2/24
Switch D
VLAN-interface 10
12.1.1.2/24
Switch D
VLAN-interface 12
11.1.1.2/24
# Configure static routes on Switch A and enable BFD control packet mode for the static route that traverses Switch D.
[SwitchA] bfd multi-hop min-control-interval 500
[SwitchA] bfd multi-hop detect-multiplier 9
[SwitchA] ip route-static 2.2.2.9 32 12.1.1.2
[SwitchA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[SwitchA] quit
# Configure static routes on Switch B and enable BFD control packet mode for the static route that traverses Switch D.
[SwitchB] bfd multi-hop min-control-interval 500
[SwitchB] bfd multi-hop detect-multiplier 9
[SwitchB] ip route-static 1.1.1.9 32 11.1.1.2
[SwitchB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[SwitchB] quit
# Configure static routes on Switch D.
<SwitchD> system-view
[SwitchD] ip route-static 120.1.1.0 24 11.1.1.1
[SwitchD] ip route-static 121.1.1.0 24 12.1.1.1
 4/7              1.1.1.9         2.2.2.9         Up     2000ms      N/A
Summary count : 1
Summary count : 1
Summary count : 0
Summary count : 1
Summary count : 1
Summary count : 0
Example: Configuring static route FRR
As shown in Figure 5, configure static routes on Switch A, Switch B, and Switch C, and configure static route FRR. When Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 5 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Switch A
VLAN-interface 100
12.12.12.1/24
Switch A
VLAN-interface 200
13.13.13.1/24
Switch A
Loopback 0
1.1.1.1/32
Switch B
VLAN-interface 101
24.24.24.4/24
Switch B
VLAN-interface 200
13.13.13.2/24
Switch B
Loopback 0
4.4.4.4/32
Switch C
VLAN-interface 100
12.12.12.2/24
Switch C
VLAN-interface 101
24.24.24.2/24
2.     Configure static route FRR on link A:
Use one of the following methods:
¡     (Method 1.) Specify a backup next hop for static route FRR:
# Configure a static route on Switch A, and specify VLAN-interface 100 as the backup output interface and 12.12.12.2 as the backup next hop.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 200 13.13.13.2 backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
# Configure a static route on Switch B, and specify VLAN-interface 101 as the backup output interface and 24.24.24.2 as the backup next hop.
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 200 13.13.13.1 backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
¡     (Method 2.) Configure static route FRR to automatically select a backup next hop:
# Configure static routes on Switch A, and enable static route FRR.
[SwitchA] ip route-static 4.4.4.4 32 vlan-interface 100 12.12.12.2 preference 70
[SwitchA] ip route-static fast-reroute auto
# Configure static routes on Switch B, and enable static route FRR.
[SwitchB] ip route-static 1.1.1.1 32 vlan-interface 101 24.24.24.2 preference 70
[SwitchB] ip route-static fast-reroute auto
3.     Configure static routes on Switch C.
[SwitchC] ip route-static 4.4.4.4 32 vlan-interface 101 24.24.24.4
[SwitchC] ip route-static 1.1.1.1 32 vlan-interface 100 12.12.12.1
# Display route 4.4.4.4/32 on Switch A to view the backup next hop information.
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary count : 1
Destination: 4.4.4.4/32
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x26000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1008c        OrigNextHop: 13.13.13.2
      Label: NULL           RealNextHop: 13.13.13.2
    BkLabel: NULL             BkNextHop: 12.12.12.2
    SRLabel: NULL             BkSRLabel: NULL
   SIDIndex: NULL               InLabel: NULL
  Tunnel ID: Invalid          Interface: Vlan-interface200
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
   LinkCost: 0               MicroSegID: 0
RealFIRType: Normal           RealThres: 0
# Display route 1.1.1.1/32 on Switch B to view the backup next hop information.
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary count : 1
Destination: 1.1.1.1/32
   Protocol: Static
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 13.13.13.1
      Label: NULL           RealNextHop: 13.13.13.1
    BkLabel: NULL             BkNextHop: 24.24.24.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
Configuring a default route
A default route is used to forward packets that do not match any specific routing entry in the routing table. Without a default route, packets that do not match any routing entries are discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
·     The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see "Configuring static routing."
·     Some dynamic routing protocols (such as OSPF, IS-IS, and RIP) can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers. These routers install the default route with the next hop being the upstream router. For more information, see the respective chapters on these routing protocols in this configuration guide.
As shown in Figure 6, Device B is the next hop for packets from Device A to Device C, Device D, and Device E. You can configure a default route on Device A to replace the three static routes from Device A to Device C, Device D, and Device E, respectively. Then, packets that do not match any other routes will be forwarded based on the default route.
The next hop address, destination address, and subnet mask of the default route configured on Device A are 1.1.1.2, 0.0.0.0, and 0.0.0.0, respectively.
Figure 6 Configuring a default route
