03-Layer 2—LAN Switching Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5100[S5500]-D-G&S5130S-G[-V2] Configuration Guides-R8336Pxx-6W10003-Layer 2—LAN Switching Configuration Guide
13-Layer 2 forwarding configuration
13-Layer 2 forwarding configuration 35.95 KB
Configuring cut-through Layer 2 forwarding
About cut-through Layer 2 forwarding
A cut-through forwarding-enabled device forwards a frame after it receives the first 64 bytes of the frame. This feature reduces the transmission time of a frame and enhances forwarding performance.
Restrictions and guidelines for cut-through Layer 2 forwarding configuration
With cut-through forwarding, the device forwards CRC-error frames because it starts forwarding frames before their CRC field is received.
In an IRF fabric, cut-through Layer 2 forwarding does not take effect for traffic where the ingress and egress interfaces are not on the same member device.
Cut-through Layer 2 forwarding takes effect only on multicast packets.
2.     Enable cut-through forwarding.
cut-through enable
By default, cut-through forwarding is disabled.
