- 01-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-CE1 Interface Connection Configuration Examples
- 52-General QoS Configuration Examples
- 53-GRE Tunnel Establishment Using OSPF Configuration Examples
- 54-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 55-QoS Configuration Examples for the Financial Industry
53-GRE Tunnel Establishment Using OSPF Configuration Examples | 93.94 KB |
Introduction
The following information provides an example of configuring GRE tunnels using OSPF.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of GRE.
Configuration examples
As shown in Figure 1, Device A, Device B, and Device C on a backbone network are running OSPF. Establish a directly connected link between Device A and Device B so that Host A and Host B can communicate with each other. The specific requirements are as follows:
· Configure Device A as the default gateway for Host A, and Device B as the default gateway for Host B.
· Establish a directly connected link between Device A and Device B. Enable OSPF on the tunnel interfaces.
· Use OSPF process 1 on the backbone network, and OSPF process 2 in the user access areas.
Analysis
To meet the network requirements, perform the following tasks:
· To ensure interconnectivity within the backbone network, complete OSPF configurations on Device A, Device B, and Device C.
· To establish a GRE tunnel between Device A and Device B, complete GRE-related configurations.
Procedures
Configuring Device A
1. Assign an IP address to each interface, as shown in Figure 1. (Details not shown.)
2. Configure OSPF process 1.
[DeviceA] ospf 1
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
3. Configure OSPF process 2.
[DeviceA] ospf 2
[DeviceA-ospf-2] area 0
[DeviceA-ospf-2-area-0.0.0.0] network 2.2.2.0 0.0.0.255
[DeviceA-ospf-2-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-2-area-0.0.0.0] quit
[DeviceA-ospf-2] quit
4. Configure a GRE tunnel:
# Create tunnel interface Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 0 mode gre
# Assign an IP address to interface Tunnel 0.
[DeviceA-Tunnel0] ip address 2.2.2.1 255.255.255.0
# Configure the source address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device A).
[DeviceA-Tunnel0] source 11.1.1.1
# Configure the destination address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device B).
[DeviceA-Tunnel0] destination 11.2.1.2
[DeviceA-Tunnel0] quit
Configuring Device B
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
[DeviceB] ospf 2
[DeviceB-ospf-2] area 0
[DeviceB-ospf-2-area-0.0.0.0] network 2.2.2.0 0.0.0.255
[DeviceB-ospf-2-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[DeviceB-ospf-2-area-0.0.0.0] quit
[DeviceB-ospf-2] quit
[DeviceB] interface tunnel 0 mode gre
[DeviceB-Tunnel0] ip address 2.2.2.2 255.255.255.0
# Configure the source address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device B).
[DeviceB-Tunnel0] source 11.2.1.2
# Configure the destination address of interface Tunnel 0 (as the IP address of Ten-GigabitEthernet3/1/1 on Device A).
[DeviceB-Tunnel0] destination 11.1.1.1
[DeviceB-Tunnel0] quit
Configuring Device C
2. Configure basic OSPF functions.
<DeviceC> system-view
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
# Execute the display ip routing-table command on Device A. Verify that the OSPF route from Device A to the subnet where Host B resides goes through interface Tunnel 0.
<DeviceA>display ip routing-table
Destinations : 15 Routes : 15
2.2.2.0/24 Direct 0 0 2.2.2.1 Tun0
2.2.2.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.255/32 Direct 0 0 2.2.2.1 Tun0
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/1/2
10.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/1/2
10.2.1.0/24 O_INTRA 10 1563 2.2.2.2 Tun0
11.1.1.0/24 Direct 0 0 11.1.1.1 XGE3/1/1
11.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
11.1.1.255/32 Direct 0 0 11.1.1.1 XGE3/1/1
11.2.1.0/24 O_INTRA 10 2 11.1.1.2 XGE3/1/1
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Execute the display ip routing-table command on Device B. Verify that the OSPF route from Device B to the subnet where Host A resides goes through interface Tunnel 0.
2.2.2.0/24 Direct 0 0 2.2.2.2 Tun0
2.2.2.2/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.255/32 Direct 0 0 2.2.2.2 Tun0
10.1.1.0/24 O_INTRA 10 1563 2.2.2.1 Tun0
10.2.1.0/24 Direct 0 0 10.2.1.2 XGE3/1/2
10.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.255/32 Direct 0 0 10.2.1.2 XGE3/1/2
11.1.1.0/24 O_INTRA 10 2 11.2.1.1 XGE3/1/1
11.2.1.0/24 Direct 0 0 11.2.1.2 XGE3/1/1
11.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
11.2.1.255/32 Direct 0 0 11.2.1.2 XGE3/1/1
# Execute the display interface brief command on Device A. Verify that the status of interface Tunnel 0 on Device A is up.
<DeviceA>display interface brief
Protocol: (s) - spoofing
XGE3/1/1 UP UP 11.1.1.1
XGE3/1/2 UP UP 10.1.1.2
InLoop0 UP UP(s) --
NULL0 UP UP(s) --
Tun0 UP UP 2.2.2.1
# Execute the display interface brief command on Device B. Verify that the status of interface Tunnel 0 on Device B is up.
<DeviceB>display interface brief
XGE3/1/1 UP UP 11.2.1.2
XGE3/1/2 UP UP 10.2.1.2
InLoop0 UP UP(s) --
NULL0 UP UP(s) --
Tun0 UP UP 2.2.2.2
# Verify that the private IP of Device A can ping the private IP of Device B.
<DeviceA>ping -a 10.1.1.2 10.2.1.2
Ping 10.2.1.2 (10.2.1.2) from 10.1.1.2: 56 data bytes, press CTRL+C to break
56 bytes from 10.2.1.2: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=2 ttl=255 time=2.000 ms
56 bytes from 10.2.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.2.1.2: icmp_seq=4 ttl=255 time=1.000 ms
--- Ping statistics for 10.2.1.2 ---
round-trip min/avg/max/std-dev = 1.000/1.200/2.000/0.400 ms
# Verify that Host A can ping the private IP of Host B.
<HostA>ping 10.2.1.1
Ping 10.2.1.1 (10.2.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=253 time=2.000 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
Configuration files
· Device A:
ospf 1
area 0.0.0.0
ospf 2
area 0.0.0.0
interface Ten-GigabitEthernet3/1/1
port link-mode route
ip address 11.1.1.1 255.255.255.0
interface Ten-GigabitEthernet3/1/2
interface Tunnel0 mode gre
source 11.1.1.1
return
· Device B:
ospf 1
area 0.0.0.0
ospf 2
area 0.0.0.0
ip address 11.2.1.2 255.255.255.0
ip address 10.2.1.2 255.255.255.0
source 11.2.1.2
return
· Device C:
ospf 1
area 0.0.0.0
ip address 11.1.1.2 255.255.255.0
ip address 11.2.1.1 255.255.255.0
return
Related documentation
· Layer 3—IP Services Configuration Guide
· Layer 3—IP Routing Configuration Guide
· Layer 3—IP Services Command Reference
· Layer 3—IP Routing Command Reference
