- 01-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_ATM_Configuration_Examples
- 04-H3C_IGMP_Configuration_Examples
- 05-H3C_IP_Source_Guard_Configuration_Examples
- 06-H3C_Ethernet_OAM_Configuration_Examples
- 07-H3C_NQA_Configuration_Examples
- 08-H3C_QinQ_Configuration_Examples
- 09-H3C_OSPF_Configuration_Examples
- 10-H3C_MPLS_TE_Configuration_Examples
- 11-H3C_OpenFlow_Configuration_Examples
- 12-H3C_NAT_Configuration_Examples
- 13-H3C_RBAC_Configuration_Examples
- 14-H3C_IRF_Configuration_Examples
- 15-H3C_POS_Interface_Configuration_Examples
- 16-H3C_CPOS_Interface_Configuration_Examples
- 17-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 18-H3C_DLDP_Configuration_Examples
- 19-H3C_IS-IS_Configuration_Examples
- 20-H3C_MPLS_L3VPN_Configuration_Examples
- 21-H3C_SSH_Configuration_Examples
- 22-H3C_Login_Management_Configuration_Examples
- 23-H3C_SNMP_Configuration_Examples
- 24-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 25-H3C_Multicast_VPN_Configuration_Examples
- 26-H3C_BGP_Configuration_Examples
- 27-H3C_HoVPN_Configuration_Examples
- 28-H3C_L2TP_Configuration_Examples
- 29-H3C_VRRP_Configuration_Examples
- 30-H3C_Traffic_Filtering_Configuration_Examples
- 31-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 32-H3C_Software_Upgrade_Examples
- 33-H3C_MPLS_L2VPN_Configuration_Examples
- 34-H3C_NetStream_Configuration_Examples
- 35-H3C_Policy-Based_Routing_Configuration_Examples
- 36-H3C_Traffic_Policing_Configuration_Examples
- 37-H3C_BFD_Configuration_Examples
- 38-H3C_OSPFv3_Configuration_Examples
- 39-H3C_VPLS_Configuration_Examples
- 40-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 41-H3C_IPv6_IS-IS_Configuration_Examples
- 42-H3C_MPLS OAM_Configuration_Examples
- 43-H3C_BGP_Route_Selection_Configuration_Examples
- 44-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 45-H3C_SRv6 Configuration Examples
- 46-H3C_Attack_Protection_Configuration_Examples
- 47-H3C_OSPF_Multi-Process_Configuration_Examples
- 48-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 49-H3C_ARP_Attack_Protection_Configuration_Examples
- 50-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 51-CE1 Interface Connection Configuration Examples
- 52-General QoS Configuration Examples
- 53-GRE Tunnel Establishment Using OSPF Configuration Examples
- 54-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 55-OSPF over IPsec for Overseas Branch Access Configuration Examples
- 56-QoS Configuration Examples for the Financial Industry
16-H3C_CPOS_Interface_Configuration_Examples | 109.35 KB |
Introduction
This document provides CPOS-E1 channel configuration examples.
This document assumes that you have basic knowledge of CPOS interface, E1, and MP.
MP supports binding interfaces on the same LPU rather than on different LPUs. MP binding on different subcards on the same LPU is not supported.
Example: Configuring CPOS-E1 channels
As shown in Figure 1, branch nodes Router B through Router H are uplinked to the central node Router A through E1 links. Router A aggregates these E1 links by using a CPOS interface.
Add one additional E1 link on Router B to expand its capacity, and use an MP-group interface to bind the two E1 links.
For correct network synchronization, make sure the master clock mode is configured on the SONET/SDH devices connected to the routers.
Procedures
Configuring Router A
# Configure E1 channels 1 and 2 of the CPOS interface to operate in unframed mode.
[RouterA] controller cpos 3/1/4
[RouterA-Cpos3/1/4] e1 1 unframed
[RouterA-Cpos3/1/4] e1 2 unframed
# Create an MP-group interface and assign an IP address to it.
[RouterA] interface mp-group 3/1/1
[RouterA-Mp-group3/1/1] ip address 10.1.1.1 24
[RouterA-Mp-group3/1/1] quit
# Assign Serial 3/1/4/1:0 and Serial 3/1/4/2:0 to the MP-group interface.
[RouterA] interface serial3/1/4/1:0
[RouterA-Serial3/1/4/1:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/4/1:0] quit
[RouterA] interface serial3/1/4/2:0
[RouterA-Serial3/1/4/2:0] ppp mp mp-group 3/1/1
[RouterA-Serial3/1/4/2:0] quit
Configuring Router B
# Configure E1 3/1/10 to operate in E1 mode.
<RouterB> system-view
[RouterB] controller e1 3/1/10
[RouterB-E1 3/1/10] using e1
[RouterB-E1 3/1/10] quit
# Configure E1 3/1/8 to operate in E1 mode.
[RouterB] controller e1 3/1/8
[RouterB-E1 3/1/8] using e1
[RouterB-E1 3/1/8] quit
[RouterB] interface mp-group 3/1/1
[RouterB-Mp-group3/1/1] ip address 10.1.1.2 24
[RouterB-Mp-group3/1/1] quit
# Assign Serial 3/1/10:0 and Serial 3/1/8:0 to the MP-group interface.
[RouterB] interface serial3/1/10:0
[RouterB-Serial3/1/10:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/10:0] quit
[RouterB] interface serial3/1/8:0
[RouterB-Serial3/1/8:0] ppp mp mp-group 3/1/1
[RouterB-Serial3/1/8:0] quit
1. Verify that the MP-group interfaces on Router A and Router B can ping each other.
# Ping the MP-group interface on Router B from Router A.
[RouterA] ping 10.1.1.2
Ping 10.1.1.2 (10.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.2: icmp_seq=0 ttl=255 time=32.998 ms
56 bytes from 10.1.1.2: icmp_seq=1 ttl=255 time=27.632 ms
56 bytes from 10.1.1.2: icmp_seq=2 ttl=255 time=34.517 ms
56 bytes from 10.1.1.2: icmp_seq=3 ttl=255 time=45.058 ms
56 bytes from 10.1.1.2: icmp_seq=4 ttl=255 time=35.121 ms
--- Ping statistics for 10.1.1.2 ---
round-trip min/avg/max/std-dev = 27.632/35.065/45.058/5.651 ms
# Ping the MP-group interface on Router A from Router B.
[RouterB] ping 10.1.1.1
Ping 10.1.1.1 (10.1.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.1.1: icmp_seq=0 ttl=255 time=27.877 ms
56 bytes from 10.1.1.1: icmp_seq=1 ttl=255 time=27.616 ms
56 bytes from 10.1.1.1: icmp_seq=2 ttl=255 time=42.308 ms
56 bytes from 10.1.1.1: icmp_seq=3 ttl=255 time=36.238 ms
56 bytes from 10.1.1.1: icmp_seq=4 ttl=255 time=71.639 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 27.616/41.136/71.639/16.214 ms
The output shows that the MP-group interfaces on Router A and Router B can ping each other.
2. Verify the MP interface configuration and state on Router A and Router B.
# Display detailed information about the MP-group interface on Router A.
[RouterA] display interface mp-group 3/1/1
MP-group3/1/1
Current state: UP
Line protocol state: UP
Description: MP-group3/1/1 Interface
Bandwidth: 1024kbps
Maximum transmit unit: 1500
Hold timer: 10 seconds, retry times: 5
Internet Address is 10.1.1.1/24 (primary)
Link layer protocol: PPP
LCP: opened, MP: opened, IPCP: opened, OSICP: opened, MPLSCP: opened, IPv6CP: op
ened
Physical: MP, baudrate: 1024000 bps
Last link flapping: Never
Last 5 seconds input rate: 14 bytes/sec, 112 bits/sec, 0 packets/sec
Last 5 seconds output rate: 14 bytes/sec, 112 bits/sec, 0 packets/sec
Input: 73 packets, 24764 bytes, 0 drops
Output: 62 packets, 24882 bytes, 0 drops
The output shows that the MP-group interface on Router A is up.
# Display detailed information about the MP-group interface on Router B.
[RouterB] display interface mp-group 3/1/1
MP-group3/1/1
Current state: UP
Bandwidth: 1024kbps
Internet Address is 10.1.1.2/24 (primary)
LCP: opened, MP: opened, IPCP: opened, OSICP: opened, MPLSCP: opened, IPv6CP: opened
Last 10 seconds input rate: 374 bytes/sec, 2992 bits/sec, 1 packets/sec
Last 10 seconds output rate: 293 bytes/sec, 2344 bits/sec, 0 packets/sec
Input: 39 packets, 12301 bytes, 0 drops
Output: 37 packets, 11824 bytes, 0 drops
The output shows that the MP-group interface on Router B is up.
3. Verify that the MP-group interface configuration on Router A and Router B.
# Display MP information on the MP-group interface of Router A.
[RouterA] display ppp mp interface mp-group 3/1/1
Template: MP-group3/1/1
max-bind: 16, fragment: enabled, min-fragment: 128
Master link: MP-group3/1/1, Active members: 2, Bundle Multilink
Peer's endPoint descriptor: MP-group3/1/1
Sequence format: long (rcv)/long (sent)
Bundle Up Time: 2021/07/25 09:16:07:745
0 lost fragments, 0 reordered, 0 unassigned, 0 interleaved
Sequence: 0 (rcv)/0 (sent)
Active member channels: 16 members
Serial3/1/4/1:0 Up-Time:2021/07/25 09:16:07:747
Serial3/1/4/2:0 Up-Time:2021/07/25 09:16:07:746
The output shows that the MP-group interface has been correctly configured.
# Display MP information on the MP-group interface of Router B.
[RouterB] display ppp mp interface mp-group 3/1/1
Serial3/1/8:0 Up-Time:2021/07/25 09:16:07:747
Serial3/0/103/1/10:0 Up-Time:2021/07/25 09:16:07:746
Configuration files
· Router A:
e1 1 unframed
e1 2 unframed
· Router B:
using e1
controller e1 3/1/8
using e1
Related documentation
· H3C SR8800-X Routers Interface Configuration Guide
· H3C SR8800-X Routers Interface Command Reference
· H3C SR8800-X Routers Layer 2—WAN Access Configuration Guide
· H3C SR8800-X Routers Layer 2—WAN Access Command Reference
