05-Layer 3—IP Routing Command Reference
HomeSupportRouters5G IPRAN Access RoutersReference GuidesCommand ReferencesH3C RA5100-G Routers Command Reference-R7752-6W10105-Layer 3—IP Routing Command Reference
07-OSPF commands
07-OSPF commands 1.48 MB
OSPF commands· 1
abr-summary· 1
area· 1
asbr-summary· 2
authentication-mode· 3
bandwidth-reference· 5
database-filter peer 6
default 7
default-cost 8
default-route-advertise· 8
description· 10
discard-route· 10
display ospf 11
display ospf abr-asbr 22
display ospf abr-summary· 24
display ospf asbr-summary· 26
display ospf attribute· 28
display ospf event-log· 29
display ospf event-log hello· 34
display ospf fast-reroute lfa-candidate· 40
display ospf global-statistics· 41
display ospf graceful-restart 42
display ospf hostname-table· 45
display ospf interface· 46
display ospf interface hello· 52
display ospf lsdb· 53
display ospf nexthop· 66
display ospf non-stop-routing status· 67
display ospf peer 68
display ospf peer statistics· 75
display ospf request-queue· 76
display ospf retrans-queue· 77
display ospf routing· 78
display ospf spf-tree· 82
display ospf statistics· 87
display ospf topology-info· 91
display ospf troubleshooting· 95
display ospf vlink· 99
display router id· 100
distribute bgp-ls· 100
dscp· 101
enable link-local-signaling· 102
enable out-of-band-resynchronization· 102
event-log· 103
fast-reroute· 104
fast-reroute remote-lfa maximum-cost 105
fast-reroute remote-lfa prefix-list 106
fast-reroute remote-lfa tunnel ldp· 107
fast-reroute tiebreaker 107
filter 109
filter-policy export 110
filter-policy import 112
graceful-restart 113
graceful-restart helper enable· 114
graceful-restart helper strict-lsa-checking· 115
graceful-restart interval 115
host-advertise· 116
hostname· 117
import-route· 117
import-route no-inherit-tag· 120
isolate enable· 121
ispf enable· 122
log-peer-change· 123
lsa-arrival-interval 123
lsa-arrival-interval suppress-flapping· 125
lsa-generation-interval 126
lsa-generation-interval suppress-flapping· 127
lsdb-overflow-interval 128
lsdb-overflow-limit 128
maxage-lsa route-calculate-delay· 129
maximum load-balancing· 129
metric-bandwidth advertisement enable· 130
metric-bandwidth suppression· 131
metric-delay advertisement enable· 132
metric-delay suppression· 133
network· 134
non-stop-routing· 135
nssa· 135
opaque-capability enable· 137
ospf 138
ospf area· 139
ospf authentication-mode· 139
ospf bfd adjust-cost 141
ospf bfd adjust-cost suppress-flapping· 142
ospf bfd enable· 143
ospf cost 144
ospf cost-fallback· 145
ospf database-filter 146
ospf dr-priority· 147
ospf fast-reroute lfa-backup· 148
ospf fast-reroute remote-lfa disable· 148
ospf link-delay· 149
ospf link-quality adjust-cost 150
ospf lsu-flood-control 152
ospf mib-binding· 153
ospf mtu-enable· 154
ospf multi-area· 154
ospf multi-area authentication-mode· 156
ospf multi-area cost 158
ospf multi-area link-quality adjust-cost 159
ospf multi-area mtu-enable· 161
ospf multi-area packet-size· 162
ospf multi-area timer dead· 163
ospf multi-area timer hello· 164
ospf multi-area timer retransmit 165
ospf multi-area trans-delay· 167
ospf network-type· 168
ospf packet-size· 169
ospf peer hold-max-cost duration· 169
ospf peer suppress-flapping· 170
ospf peer suppress-flapping hold-down· 172
ospf peer suppress-flapping hold-max-cost 173
ospf prefix-suppression· 174
ospf primary-path-detect bfd· 175
ospf silent 176
ospf timer dead· 177
ospf timer hello· 177
ospf timer poll 178
ospf timer retransmit 179
ospf trans-delay· 179
ospf troubleshooting max-number 180
ospf ttl-security· 181
ospf virtual-system·· 182
peer 183
pic· 184
preference· 185
prefix-priority· 186
prefix-suppression· 186
reset ospf event-log· 187
reset ospf event-log hello· 188
reset ospf process· 188
reset ospf redistribution· 189
reset ospf statistics· 189
reset ospf troubleshooting· 190
rfc1583 compatible· 190
router id· 191
shutdown process· 192
silent-interface· 193
snmp trap rate-limit 194
snmp-agent trap enable ospf 194
snmp-agent trap ospf neighbor-state-change extended· 196
spf-schedule-interval 197
stub· 198
stub-router 199
transmit-pacing· 200
ttl-security· 201
virtual-system enable· 203
vlink-peer 204
OSPF commands
abr-summary
Use abr-summary to configure route summarization on an ABR.
Use undo abr-summary to remove the configuration.
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost-value ]
undo abr-summary ip-address { mask-length | mask }
Route summarization is not configured on an ABR.
OSPF area view
ip-address: Specifies the destination IP address of the summary route in dotted decimal notation.
mask-length: Specifies the mask length in the range of 1 to 32.
mask: Specifies the mask of the IP address, in dotted decimal notation.
advertise | not-advertise: Advertises the summary route or not. By default, the command advertises the summary route.
cost cost-value: Specifies the cost of the summary route, in the range of 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
This command applies only to an ABR to summarize multiple contiguous networks into one network.
To enable ABR to advertise specific routes that have been summarized, use the undo abr-summary command.
# Summarize networks 36.42.10.0/24 and 36.42.110.0/24 in Area 1 into 36.42.0.0/16.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] network 36.42.10.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] network 36.42.110.0 0.0.0.255
[Sysname-ospf-100-area-0.0.0.1] abr-summary 36.42.0.0 255.255.0.0
area
Use area to create an OSPF area and enter OSPF area view.
Use undo area to remove an OSPF area.
In OSPF view:
area area-id
undo area area-id
No OSPF areas exist.
OSPF view
area-id: Specifies an area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format.
# Create Area 0 and enter Area 0 view.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0]
asbr-summary
Use asbr-summary to configure route summarization on an ASBR.
Use undo asbr-summary to remove the configuration.
asbr-summary ip-address { mask-length | mask } [ cost cost-value | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ip-address { mask-length | mask }
Route summarization is not configured on an ASBR.
OSPF view
ip-address: Specifies the destination IP address of the summary route.
mask: Specifies the mask in dotted decimal notation.
cost cost-value: Specifies the cost of the summary route, in the range of 1 to 16777214. If you do not specify this option, the largest cost among the summarized routes applies. If the routes in Type-5 LSAs translated from Type-7 LSAs are Type-2 external routes, the largest cost among the summarized routes plus 1 applies.
not-advertise: Disables advertising the summary route. If you do not specify this keyword, the command advertises the route.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. By default, the P-bit of Type-7 LSAs is set to 1. If the ASBR is also an ABR and FULL state neighbors exist in the backbone area, the P-bit of Type-7 LSAs originated by the ASBR is set to 0. This keyword applies to the NSSA ASBR.
tag tag: Specifies a tag for the summary route, in the range of 0 to 4294967295. The default is 1. The tag can be used by a routing policy to control summary route advertisement.
An ASBR can summarize routes in the following LSAs:
·     Type-5 LSAs.
·     Type-7 LSAs in an NSSA area.
·     Type-5 LSAs translated by the ASBR (also an ABR) from Type-7 LSAs in an NSSA area.
If the ASBR (ABR) is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
To enable ASBR to advertise specific routes that have been summarized, use the undo asbr-summary command.
# Summarize redistributed static routes into a single route, and specify a tag value of 2 and a cost of 100 for the summary route.
[Sysname] ip route-static 10.2.1.0 24 null 0
[Sysname] ip route-static 10.2.2.0 24 null 0
[Sysname] ospf 100
[Sysname-ospf-100] import-route static
[Sysname-ospf-100] asbr-summary 10.2.0.0 255.255.0.0 tag 2 cost 100
authentication-mode
Use authentication-mode to specify an authentication mode for an OSPF area.
Use undo authentication-mode to remove the configuration.
For MD5/HMAC-MD5/HMAC-SHA-256 authentication:
authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
undo authentication-mode [ { hmac-md5 | hmac-sha-256 | md5 } key-id ]
For simple authentication:
authentication-mode simple { cipher | plain } string
No authentication is performed for an area.
OSPF area view
hmac-md5: Specifies the HMAC-MD5 authentication mode.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
key-id: Specifies a key by its ID in the range of 0 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
·     In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
·     In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
·     In HMAC-SHA-256 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
Application scenarios
On networks with high security requirements, use this command to configure OSPF area authentication.
Key rollover mechanism
To modify the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication in an OSPF area, perform the following tasks:
1.     Configure a new MD5/HMAC-MD5/HMAC-SHA-256 authentication key for the OSPF area. If the new key is not configured on the neighbor device, MD5/HMAC-MD5/HMAC-SHA-256 authentication key rollover is triggered. During key rollover, OSPF sends multiple packets that contain both the new and old MD5/HMAC-MD5/HMAC-SHA-256 authentication keys to ensure that the neighbor device can pass the authentication.
2.     Configure the new MD5/HMAC-MD5/HMAC-SHA-256 authentication key on the neighbor device. When the local device receives packets with the new key from the neighbor device, it exits the key rollover.
3.     Delete the old MD5/HMAC-MD5/HMAC-SHA-256 authentication key from the local device and the neighbor. This step helps prevent attacks from devices that use the old key for communication and reduces system resources and bandwidth consumption caused by key rollover.
To establish or maintain adjacencies, routers in the same area must have the same authentication mode and key.
You can configure only one of the MD5, HMAC-MD5, HMAC-SHA-256, simple authentication. If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string.
The authentication-mode command takes effect for all multi-area adjacency interfaces in an area. If you configure OSPF authentication for both the area and a multi-area adjacency interface in that area, the interface authentication configured by using the ospf multi-area authentication-mode command takes effect.
# Configure OSPF Area 0 to use the MD5 authentication mode, and set the key ID to 15 and the key to abc in plaintext form.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] authentication-mode md5 15 plain abc
bandwidth-reference
Use bandwidth-reference to set a reference bandwidth value for link cost calculation.
Use undo bandwidth-reference to restore the default value.
bandwidth-reference value
The reference bandwidth value is 100 Mbps for link cost calculation.
OSPF view
value: Specifies the reference bandwidth value for link cost calculation, in the range of 1 to 4294967 Mbps.
Use this command to control route selection by affecting the cost values of interfaces.
Operating mechanism
If no cost values are configured for links, OSPF automatically calculates their cost values by using the following formula: Cost = Reference bandwidth value / Expected interface bandwidth. The expected bandwidth of an interface is configured with the bandwidth command (see Interface Command Reference). If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is less than 1, the value of 1 is used. After you execute the bandwidth-reference command, OSPF re-calculates the cost value for each link with the configured reference bandwidth value, which affects route calculation and selection.
If multi-area adjacency interfaces exist in areas of an OSPF process, the bandwidth-reference command in the process takes effect for all the multi-area adjacency interfaces.
# Set the reference bandwidth value to 1000 Mbps.
[Sysname] ospf 100
[Sysname-ospf-100] bandwidth-reference 1000
ospf cost
ospf multi-area
Use database-filter peer to filter LSAs for the specified P2MP neighbor.
Use undo database-filter peer to restore the default.
database-filter peer ip-address { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
undo database-filter peer ip-address
The LSAs for the specified P2MP neighbor are not filtered.
OSPF view
ip-address: Specifies a P2MP neighbor by its IP address.
all: Filters all LSAs except the Grace LSAs.
ase: Filters Type-5 LSAs.
nssa: Filters Type-7 LSAs.
summary: Filters Type-3 LSAs.
acl ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
On a P2MP network, a router might have multiple OSPF neighbors with the P2MP type. Use this command to prevent the router from sending LSAs to the specified neighbor.
When you specify an ACL, follow these guidelines:
·     If the ACL does not exist or does not have any rules, OSPF does not filter the LSAs sent to the specified neighbor.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all of the LSAs sent to the specified neighbor.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·     To deny or permit LSAs with the specified link state ID, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny or permit LSAs with the specified link state ID and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the link state ID of an LSA and the destination keyword specifies the subnet mask of the LSA.
If the specified neighbor has already received an LSA, the LSA still exists in the LSDB of the neighbor after you execute the command.
# Filter all LSAs (except the Grace LSAs) for the P2MP neighbor with the IP address 121.20.20.121.
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 all
# Configure advanced ACL 3000 to filter Type-3 LSAs for the P2MP neighbor with the IP address 121.20.20.121.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 deny ip source 121.20.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 permit ip
[Sysname] ospf 1
[Sysname-ospf-1] database-filter peer 121.20.20.121 summary acl 3000
default
Use default to configure default parameters for redistributed routes.
Use undo default to remove the configuration.
default { cost cost-value | tag tag | type type } *
undo default { cost | tag | type } *
The cost is 1, the tag is 1, and the route type is 2.
OSPF view
cost cost-value: Specifies a default cost for redistributed routes, in the range of 0 to 16777214.
tag tag: Specifies a tag for redistributed routes, in the range of 0 to 4294967295.
type type: Specifies a type for redistributed routes: 1 or 2.
# Set the default cost, tag, and type to 10, 100, and 2 for redistributed external routes.
[Sysname] ospf 100
[Sysname-ospf-100] default cost 10 tag 100 type 2
import-route
default-cost
Use default-cost to set a cost for the default route advertised to the stub or NSSA area.
Use undo default-cost to restore the default value.
default-cost cost-value
undo default-cost
The cost is 1.
OSPF area view
cost-value: Specifies a cost for the default route advertised to the Stub or NSSA area, in the range of 0 to 16777214.
This command takes effect only on the ABR of a stub area or the ABR or ASBR of an NSSA area.
# Configure Area 1 as a stub area, and set the cost of the default route advertised to the stub area to 20.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
[Sysname-ospf-100-area-0.0.0.1] default-cost 20
nssa
stub
Use default-route-advertise to redistribute a default route into the OSPF routing domain.
Use undo default-route-advertise to restore the default.
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | type type ] *
default-route-advertise [ summary cost cost-value ]
No default route is redistributed into the OSPF routing domain.
OSPF view
always: Redistributes a default route in a Type-5 LSA into the OSPF routing domain regardless of whether a default route exists in the routing table. If you do not specify this keyword, the router redistributes a default route only when an active default route that does not belong to the current OSPF process exists in the IP routing table.
permit-calculate-other: Enables OSPF to calculate default routes received from other routers. If you do not specify this keyword, OSPF does not calculate default routes from other routers. If the router does not redistribute any default route in a Type-5 LSA into the OSPF routing domain, the router calculates default routes from other routers. It calculates these routes regardless of whether this keyword is specified.
cost cost-value: Specifies a cost for the default route, in the range of 0 to 16777214. If you do not specify this option, the default cost specified by the default-cost command applies.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When the routing policy is matched and one of the following conditions is met, the command redistributes a default route in a Type-5 LSA into the OSPF routing domain:
·     A default route exists in the routing table.
·     The always keyword is specified.
The routing policy modifies values in the Type-5 LSA.
type type: Specifies a type for the Type-5 LSA: 1 or 2. If you do not specify this option, the default type for the Type-5 LSA specified by the default type command applies.
summary: Advertises the specified default route in a Type-3 LSA. This keyword is available only for VPNs.
This command redistributes a default route in a Type-5 LSA, which cannot be redistributed with the import-route command. If the local routing table has no default route, you must specify the always keyword for the command.
The default-route-advertise summary cost command is applicable only to VPNs. It enables a PE router to redistribute a default external route in a Type-3 LSA to CE routers.
# Redistribute a default route into the OSPF routing domain, regardless of whether the default route exists in the local routing table.
[Sysname] ospf 100
[Sysname-ospf-100] default-route-advertise always
default
import-route
description
Use description to configure a description for an OSPF process or area.
No description is configured for an OSPF process or area.
OSPF view
OSPF area view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
The description specified by this command is used to identify an OSPF process or area.
# Describe OSPF process 100 as abc.
[Sysname] ospf 100
[Sysname-ospf-100] description abc
# Describe OSPF Area 0 as bone area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.0] description bone area
discard-route
Use discard-route to configure discard routes for summary networks.
Use undo discard-route to restore the default.
discard-route { external { preference | suppression } | internal { preference | suppression } } *
undo discard-route [ external | internal ] *
A device generates discard routes with preference 255 for summary networks.
OSPF view
external: Specifies discard routes for redistributed summary networks on the ASBR. These discard routes are external discard routes.
preference: Specifies a preference for external discard routes, in the range of 1 to 255.
suppression: Disables the ASBR from generating external discard routes for summary networks.
internal: Specifies discard routes for summary networks on the ABR. These discard routes are internal discard routes.
preference: Specifies a preference for internal discard routes, in the range of 1 to 255.
suppression: Disables the ABR from generating internal discard routes for summary networks.
# Generate external and internal discard routes with preference 100 and 200, respectively.
[Sysname] ospf 100
[Sysname-ospf-100] discard-route external 100 internal 200
display ospf
Use display ospf to display OSPF process information.
display ospf [ process-id ] [ verbose ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPF processes.
verbose: Displays detailed OSPF process information. If you do not specify this keyword, the command displays brief OSPF process information.
# Display detailed OSPF process information.
<Sysname> display ospf verbose
          OSPF Process 1 with Router ID 192.168.1.2
                  OSPF Protocol Information
 RouterID: 192.168.1.2      Router type:  NSSA
 Route tag: 0
 Ext-community type: Domain ID 0x105, Route Type 0x8000, Router ID 0x8001
 Domain ID: 0.0.0.0:23
 Opaque capable
 Isolation: Enabled
 Originating router-LSAs with maximum metric
    Condition: On startup while BGP is converging, State: Inactive
    Advertise stub links with maximum metric in router-LSAs
    Advertise summary-LSAs with metric 16711680
    Advertise external-LSAs with metric 16711680
 ISPF is enabled
 SPF-schedule-interval: 50 (in milliseconds)
 LSA generation interval: 5
 LSA arrival interval: 1000
 Route preference: 10
 ASE route preference: 150
 SPF computation count: 22
 RFC 1583 compatible
 Fast-reroute: LFA
 Fast-reroute: remote-LFA Enable
   Maximum cost: 4294967295
 Node-Protecting Preference: 40
 Lowest-cost Preference: 20
 SRLG Preference: 10
 Non-ECMP Preference: 15
 Fast-reroute: TI-LFA
 Microloop-avoidance: Enabled
 Microloop-avoidance RIB-update-delay: 20000 ms
 Graceful restart interval: 120
 SNMP trap rate limit interval: 2  Count: 300
 This process is currently bound to MIB
 Area count: 1   NSSA area count: 1
 Normal areas with up interfaces: 0
 NSSA areas with up interfaces: 1
 Up interfaces: 1
 ExChange/Loading neighbors: 0
 Description: OSPFProcess1
 Full neighbors:3
 Area0 full neighbors: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, L-N/A, C-N/A, R-N/A
 MPLS segment routing: Disabled
   Segment routing adjacency   : Disabled
   Effective SRGB              : 16000  24000
   Segment routing local block : 15000  15999
   Segment routing tunnel count: 0
   SR microloop-avoidance      : Enabled
   SR microloop-avoidance RIB-update-delay: 6 ms
   SR adjacency label deletion delay
       State                   : Enabled
       Delay time              : 1900 sec
 Metric-delay advertisement: Disabled
 Metric-delay advertisement suppression
   Timer                :120
   Percent Threshold    :10
   Absolute Threshold   :1000
 Metric-bandwidth advertisement: Disabled
 Metric-bandwidth advertisement suppression: 120
 Area: 0.0.0.1          (MPLS TE  not enabled)
 Authentication type: None    Area flag: NSSA
 SPF scheduled count: 5
 Description: area1
 Up interfaces: 1
 Interface: 192.168.1.2 (GigabitEthernet1/0/6)
 Cost: 1       State: DR        Type: Broadcast    MTU: 1500
 Cost source: Default
 Priority: 1
 Designated router: 192.168.1.2
 Backup designated router: 192.168.1.1
 Timers: Hello 10 , Dead 40 , Poll  40 , Retransmit 5 , Transmit Delay 1
 FRR backup: Enabled
 FRR remote-LFA: Enabled
 FRR TI-LFA: Enabled
 Enabled by network configuration
 Multi-area interface count: 1
 Peer flapping suppression:
  Flapping count: 0
  Threshold: 10
 Packet size: 1000
 Prefix-SID type: Index
   Value: 101
   Process ID: ospf 1
   Prefix-SID validity: Invalid
 Interface: 12.1.1.1 (GigabitEthernet1/0/7)
 Cost: 65535   State: Down      Type: Broadcast    MTU: 1500
 Cost source: Flapping
 Priority: 1
 Designated router: 0.0.0.0
 Backup designated router: 0.0.0.0
 Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit Delay 1
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 FRR remote-lfa: Enabled
  Mode: Hold-max-cost
  Remaining interval: 488 s
 Interface: 192.168.1.2 (GigabitEthernet1/0/6) --> 192.168.1.1
 Cost: 1       State: P-2-P     Type: PTP       MTU: 1500
 FRR backup: Enabled
 FRR TI-LFA: Enabled
         OSPF Process 100 with Router ID 10.1.1.2
 RouterID: 10.1.1.2         Router type:  ABR  ASBR
 Route tag: 0
 Route-tag-check: Enabled
 DN-bit-set: Summary LSA, ASE LSA, NSSA LSA
 DN-bit-check: Summary LSA, ASE LSA, NSSA LSA
 PE Router, Multi-VPN-Instance is enabled
 Ext-community type: Domain ID 0x5, Route Type 0x306, Router ID 0x107
 Domain ID: 0.0.0.0
 Opaque capable
 Isolation: Disabled
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5 50 200
 SPF calculation count: 2
 RFC 1583 compatible
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 1   NSSA area count: 0
 Area: 0.0.0.0          (MPLS TE  not enabled)
 Authentication type: None    Area flag: Normal
 SPF scheduled count: 2
 Interface: 10.1.1.2 (GigabitEthernet1/0/7)
 Cost: 1       State: Waiting    Type: Broadcast    MTU: 1500
 Priority: 1
 FRR backup: Enabled
OSPF process ID and OSPF router ID.
RouterID
Router ID.
Router type
Router type:
·     ABR.
·     ASBR.
·     NSSA.
·     Null.
Process state
OSPF process state. If you shut down the process by using the shutdown process command, this field displays Admin-down. If the process is not shut down, this field is not displayed.
Route tag
Tag of redistributed routes.
Route-tag-check
Whether the OSPF process checks the tags of redistributed routes in LSAs.
DN-bit-set
Whether the OSPF process sets the DN bit of LSAs:
·     Network Summary LSA—Sets the DN bit of Network Summary LSAs (Type-3 LSAs).
·     AS External LSA—Sets the DN bit of AS External LSAs (Type-5 LSAs).
·     NSSA External LSA—Sets the DN bit of NSSA External LSAs (Type-7 LSAs).
DN-bit-check
Whether the OSPF process checks the DN bit of LSAs:
·     Network Summary LSA—Checks the DN bit of Network Summary LSAs (Type-3 LSAs).
·     AS External LSA—Checks the DN bit of AS External LSAs (Type-5 LSAs).
·     NSSA External LSA—Checks the DN bit of NSSA External LSAs (Type-7 LSAs).
The OSPF process does not support multi-VPN-instance.
The multi-VPN instance feature is enabled on the PE router.
Ext-community type
OSPF extended community attribute type codes:
·     Domain ID—Domain ID code.
·     Route Type—Route type code.
·     Router ID—Router ID code.
Domain ID
OSPF domain ID (primary ID). This field displays Null if no domain ID is carried in the community attribute.
Opaque capable
Opaque LSA advertisement and reception capability is enabled.
Isolation
Whether OSPF isolation is enabled.
The maximum cost value for router LSAs (excluding stub links) is used.
Condition
Status of the stub router:
·     Always.
·     On startup while BGP is converging.
·     On startup while BGP is converging for xxx seconds, where xxx is specified by the user.
·     On startup for xxx seconds, where xxx is specified by the user.
Whether the stub router is active.
Interval for SPF calculations. If the SPF calculation interval is fixed, this field also displays in milliseconds enclosed with brackets.
LSA update interval.
LSA reception interval.
Transmit pacing
LSU packet transmit rate of the interface:
·     Interval—LSU transmit interval of the interface.
·     Count—Maximum number of LSU packets sent at each interval.
Default ASE parameters: Metric, Tag, and Type.
Route preference
Internal route preference.
External route preference.
SPF computation count of the OSPF process.
RFC1583 compatible
Compatible with RFC 1583.
Fast-reroute
FRR type:
·     LFA—LFA is enabled.
·     LFA ECMP-shared—LFA is enabled. OSPF FRR automatically calculates backup next hops for all routes, including ECMP routes. ECMP routes share one backup next hop.
·     Remote-LFA Disabled—Remote LFA is not enabled.
·     Remote-LFA Enabled—Remote LFA is enabled.
·     TI-LFA—TI-LFA is enabled.
Maximum-cost
Maximum cost from the source node of a protected link to a PQ node.
Node-protecting preference
Priority of the node protection backup path selection policy.
Lowest-cost preference
Priority of the lowest cost backup path selection policy.
SRLG preference
Priority of the shared risk link group (SRLG)-disjoint backup path selection policy.
Non-ECMP Preference
Priority of the non-ECMP backup path selection policy.
Microloop-avoidance
Microloop avoidance status: Disabled or Enabled.
Microloop avoidance delay timer in milliseconds.
SR adjacency label deletion delay:
·     The State field indicates the enabling status of the SR adjacency label deletion delay function. Options are:
¡     Enabled.
¡     Disabled.
·     The Delay time field indicates the SR adjacency label deletion delay timer in seconds.
SNMP notification sending interval.
Count
Number of sent SNMP notifications.
Neighbors in ExChange/Loading state.
Description of the process or area. This field is not displayed if no description is configured.
Full neighbors
Neighbors in Full state.
Neighbors in Full state in the backbone area.
Route calculation trigger type:
·     Full—Calculation of all routes is triggered.
·     Area topology change—Topology change in an area.
·     Intra router change—Incremental intra-area route change.
·     ASBR change—Incremental ASBR route change.
·     7to5 translator—Type-7-to-Type-5 LSA translator role change.
·     Full IP prefix—Calculation of all IP prefixes is triggered.
·     Full intra AS—Calculation of all intra-AS prefixes is triggered.
·     Inc intra AS—Calculation of incremental intra-AS prefixes is triggered.
·     Full inter AS—Calculation of all AS-external prefixes is triggered.
·     Inc inter AS—Calculation of incremental AS-external prefixes is triggered.
·     N/A—Route calculation is not triggered.
Current route calculation type:
·     SPF calculation.
·     Intra router calculation—Intra-area route calculation.
·     ASBR calculation—Inter-area ASBR route calculation.
·     Inc intra router—Incremental intra-area route calculation.
·     Inc ASBR calculation—Incremental inter-area ASBR route calculation.
·     7to5 translator—Type-7-to-Type-5 LSA calculation.
·     Full intra AS—Calculation of all intra-AS prefixes.
·     Inc intra AS—Calculation of incremental intra-AS prefixes.
·     Full inter AS—Calculation of all AS-external prefixes.
·     Inc inter AS—Calculation of incremental AS-external prefixes.
·     Forward address—Forwarding address calculation.
Current route calculation phase:
·     Calculation area topology—Calculating area topology.
·     Calculation router—Calculating routes on routers.
·     Calculation intra AS—Calculating intra-AS routes.
·     7to5 translator—Calculating Type-7-to-Type-5 LSAs.
·     Forward address—Calculating forwarding addresses.
·     Calculation inter AS—Calculating AS-external routes.
·     Calculation end—Ending phase of calculation.
Process reset state
·     N/A—The process is not reset.
·     Under reset—The process is in the reset progress.
·     Under RIB smooth—The process is synchronizing the RIB.
Current reset type
Current process reset type:
·     Normal—Normal reset.
·     Shutdown—Shutdown OSPF process.
·     GR quit—Normal reset when GR quits abnormally.
·     Delete—Delete OSPF process.
·     VPN delete—Delete VPN.
Next reset type
Next process reset type:
Modules that reply reset prepare messages:
·     P—Neighbor maintenance module.
·     L—LSDB synchronization module.
·     C—Route calculation module.
·     R—Route redistribution module.
Modules that reply reset process messages:
Reset phase of each module:
·     Main control module:
¡     N/ANot reset.
¡     Delete area.
¡     Delete process.
·     Neighbor maintenance (P) module:
¡     N/A—Not reset.
¡     Delete neighbor.
¡     Delete interface.
¡     Delete vlink—Delete virtual link.
·     LSDB synchronization (L) module:
¡     N/A—Not reset.
¡     Stop timer.
¡     Delete ASE—Delete all ASE LSAs.
¡     Delete ASE maps—Delete ASE LSA maps.
¡     Clear process data.
¡     Delete area LSA—Delete LSAs and maps from an area.
¡     Delete area interface—Delete interfaces from an area.
¡     Delete process—Delete process-related resources.
¡     Restart—Restart process-related resources.
·     Route calculation (C) module:
¡     N/A—Not reset.
¡     Delete topology—Delete area topology.
¡     Delete router—Delete routes of routers.
¡     Delete intra AS—Delete intra-AS routes
¡     Delete inter AS—Delete AS-external routes.
¡     Delete forward address—Delete forwarding address list.
¡     Delete advertise—Delete advertising router list.
·     Route redistribution (R) module:
¡     N/A—Not reset.
¡     Delete ABR summary—Delete summary routes of the ABR.
¡     Delete ASBR summary—Delete summary routes of the ASBR.
¡     Delete import—Delete redistributed routes.
SR-MPLS status: Disabled or Enabled.
Adjacency label allocation status: Disabled or Enabled.
Configured SRGB
Configured SRGB range. This field is displayed when SRGB is configured.
Effective SRGB
SRGB range that takes effect.
Segment routing global block
SRGB range.
SRLB range.
SR microloop avoidance status: Disabled or Enabled.
SR microloop avoidance RIB-update-delay timer in milliseconds.
Link delay advertisement status: Disabled or Enabled.
Information about link delay advertisement suppression:
·     Timer—Link delay advertisement suppression timer in seconds.
·     Percent threshold—Suppression threshold for the delay variation ratio in percentage.
·     Absolute threshold—Suppression threshold for the absolute value of the delay variation in microseconds.
Link bandwidth advertisement status: Disabled or Enabled.
Link bandwidth advertisement suppression timer in seconds.
Area
Area ID in the IP address format.
MPLS TE not enabled
MPLS TE status:
·     MPLS TE not enabled.
·     MPLS TE enabled.
Authentication type
Authentication type of the area:
·     None—No authentication.
·     Simple—Simple authentication.
·     Cryptographic—MD5, HMAC-MD5, or HMAC-SHA-256 authentication.
Area flag
Type of the area:
·     Normal.
·     Stub.
·     StubNoSummary (totally stub area).
·     NSSA.
·     NSSANoSummary (totally NSSA area).
State of the translator that translates Type-7 LSAs to Type-5 LSAs:
·     Enabled—The translator is specified through commands.
·     Elected—The translator is designated through election.
·     Disabled—The device is not a translator.
Stability interval for Type-7 LSA-to-Type-5 LSA translation.
SPF scheduled Count
SPF calculation count in the OSPF area.
Interface in the area.
Cost
Interface cost.
Interface state.
Interface network type.
MTU
Interface MTU.
Cost source
Link cost source of the interface:
·     Default—Default link cost.
·     Manual—Manually specified link cost.
·     IGP_LDP—Link cost advertised by LDP IGP.
·     LOW—Link cost applied when the link quality of the interface becomes LOW.
·     Fallback—Link cost applied when the bandwidth of the Layer 3 aggregate interface falls below the threshold.
·     Flapping—Link cost applied upon neighbor flapping suppression.
·     BFD—Link cost applied when the BFD session goes down.
Priority
Router priority.
Timers
OSPF timers:
·     Hello—Interval for sending hello packets.
·     Dead—Interval within which the neighbor is down.
·     Poll—Interval for sending hello packets.
·     Retransmit—Interval for retransmitting LSAs.
FRR backup
Whether Loop Free Alternate (LFA) calculation is enabled on an interface.
FRR TI-LFA
Whether TI-LFA calculation is enabled on an interface.
FRR remote-lfa
Whether remote LFA calculation is enabled on an interface.
Enabled by interface configuration (including secondary IP addresses)
OSPF is enabled on the interface. including secondary IP addresses indicates that OSPF advertises the direct routes to the primary and secondary addresses of the interface.
Number of multi-area adjacency interfaces. This field is displayed only under primary interfaces.
Multi-area adjacency interface, This field is displayed only afterOSPF is enabled for the multi-area adjacency interface by using the ospf multi-area command.
Neighbor flapping suppression information:
·     Flapping count—Number of flappings that have occurred.
·     Threshold—Threshold that triggers flapping suppression.
·     Mode—Flapping suppression mode. Supported modes are Hold-down and Hold-max-cost.
·     Remaining interval—Remaining time in seconds before the flapping suppression ends.
Packet size
The maximum length of OSPF packets that can be sent by an interface.
Prefix-SID type
Prefix SID type:
·     Absolute—Absolute value of the prefix SID.
·     Index—Index value of the prefix SID.
Value
Prefix SID value.
Prefix-SID validity
Whether the prefix SID is valid:
·     Invalid—The prefix SID is invalid. Possible reasons include:
¡     The prefix SID is out of the SRGB range.
¡     The OSPF process ID configured on the loopback interface is different from the OSPF process ID specified during prefix SID configuration.
·     Valid—The prefix SID is valid.
Use display ospf abr-asbr to display routes to the ABR or ASBR.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays routes to the ABR and ASBR for all OSPF processes.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you use this command on routers in a stub area, the commands displays no ASBR information.
# Display brief information about routes to the ABR or ASBR.
<Sysname> display ospf abr-asbr
                  Routing Table to ABR and ASBR
                Topology base (MTID 0)
 Type        Destination       Area       Cost  Nexthop         RtType
 Inter       3.3.3.3           0.0.0.0    3124  10.1.1.2        ASBR
 Intra       2.2.2.2           0.0.0.0    1562  10.1.1.2        ABR
# Display detailed information about routes to the ABR or ASBR.
<Sysname> display ospf abr-asbr verbose
          OSPF Process 10 with Router ID 101.1.1.11
 Destination: 1.1.1.1             RtType     : ASBR
 Area       : 0.0.0.1             Type       : Intra
 Nexthop    : 150.0.1.12          BkNexthop  : 0.0.0.0
  Interface  : GE1/0/6          BkInterface: N/A
 Cost       : 1000
 Remote-LFA Info:
    PQPrefix: 5.5.5.5                PQAdvID : 5.5.5.5
     LsIndex: 2
  LabelStack: {2301}
 TI-LFA backup info:
 PNodePrefix: 5.5.5.5             QNodeAdvID : 5.5.5.5
 BkInterface:GE1/0/6          BkNexthop  : 1.4.0.4
     LsIndex: 5
  LabelStack: {16005}
Type of the route to the ABR or ASBR:
·     Intra—Intra-area route.
·     Inter—Inter-area route.
Topology
Subtopologies are not supported in the current software version.
Topology name. If this field displays base, the topology is the base topology. If this field displays other values, the topology is a subtopology.
MTID
Topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology.
Destination
Router ID of an ABR or ASBR.
Area
ID of the area of the next hop.
Cost
Cost from the router to the ABR or ASBR.
MALsIndex
SR microloop avoidance label stack index.
MALabelStack
SR microloop avoidance label stack (from top to bottom).
Nexthop
Next hop address.
BkNexthop
Backup next hop address.
RtType
Router type: ABR or ASBR.
Output interface.
BkInterface
Backup output interface.
Remote-LFA back Info
Remote LFA backup information.
PQPrefix
PQ node prefix.
PQAdvID
Router ID of the PQ node.
TI-LFA backup Info
TI-LFA backup information.
PNodePrefix
P node prefix.
QNodeAdvID
Router ID of the Q node.
LsIndex
Label stack index.
LabelStack
Label stack.
Use display ospf abr-summary to display ABR summary route information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ABR summary routes for all OSPF processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays information about ABR summary routes for all OSPF areas.
ip-address: Specifies a summary route by its IP address.
verbose: Displays detailed ABR summary route information. If you do not specify this keyword, the command displays brief ABR summary route information.
If you do not specify an IP address, this command displays information about all summary routes on the ABR.
# Display brief information about summary routes on the ABR.
<Sysname> display ospf abr-summary
                  ABR Summary Addresses
                         Area: 0.0.0.1
 Total summary address count: 1
 Net             Mask            Status        Count      Cost
 100.0.0.0       255.0.0.0       Advertise     1          (Not Configured)
Topology
MTID
Area
Area to which the summary routes belong.
Total number of summary routes.
Net
Address of the summary route.
Mask
Mask of the summary route address.
Status
Advertisement status of the summary route: Advertise or Non-Advertise.
Count
Number of summarized routes.
Cost
Cost of the summary route.
# Display detailed information about summary routes on the ABR.
<Sysname> display ospf abr-summary verbose
                         Area: 0.0.0.1
 Net         : 100.0.0.0
 Mask        : 255.0.0.0
 Status      : Advertise
 Cost        : (Not Configured)
 Routes count: 1
   Destination            NetMask                 Metric
   100.1.1.0              255.255.255.0           1000
Topology
MTID
Destination
Destination address of a summarized route.
NetMask
Network mask of a summarized route.
Metric
Metric of a summarized route.
Use display ospf asbr-summary to display ASBR summary route information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ASBR summary routes for all OSPF processes.
ip-address: Specifies an IP address in dotted decimal notation.
If you do not specify an IP address, this command displays information about all ASBR summary routes.
# Display ASBR summary route information in OSPF process 1.
<Sysname> display ospf 1 asbr-summary
                  Summary Addresses
                  Summary Address
 Net         : 30.1.0.0
 Mask        : 255.255.0.0
 Tag         : 20
 Status      : Advertise
 Cost        : 10 (Configured)
 Route count : 2
 Destination     Net mask        Proto      Process   Type     Metric
 30.1.2.0        255.255.255.0   OSPF       2         2        1
 30.1.1.0        255.255.255.0   OSPF       2         2        1
Table 5 Command output
Topology
MTID
Net
Mask
Tag
Tag of the summary route.
Status
Advertisement status of the summary route.
Cost
Route count
Destination
Net mask
Proto
Routing protocol from which the route was redistributed.
Process
Process ID of the routing protocol from which the route was redistributed.
Type of a summarized route.
Metric
Use display ospf attribute to display route attribute information obtained through BGP route redistribution.
display ospf attribute [ attribute-id ]
attribute-id: Specifies a route attribute by its ID in the range of 0 to FFFFFFFFFFFFFFFF in hexadecimal notation. If you do not specify a route attribute ID, this command displays all route attribute information obtained through BGP route redistribution.
# Displays all route attribute information obtained through BGP route redistribution.
<Sysname> display ospf attribute
 Total number of attribute(s): 2
 AttributeID      : 0x0
 InstanceID       : 0x0
 Ext-communities  : <OSPF Router Id: 4.4.4.4>,
                    <OSPF AreaNum: 0.0.0.1 RouteType: 1 Option: 0>
 AttributeID      : 0x4
 InstanceID       : 0x0
                    <OSPF AreaNum: 0.0.0.0 RouteType: 7 Option: 1>
Table 6 Command output
InstanceID
BGP instance ID.
Ext-communities
Extended community attributes including:
·     OSPF Domain ID.
·     OSPF Router ID.
·     OSPF AreaNum.
·     RouteType:
¡     1—Stub route.
¡     2—Transit route.
¡     3—Inter-area route.
¡     5—External route.
¡     7—NSSA area external route.
·     Option:
¡     0—Default value.
¡     1—External Type-2 route.
Use display ospf event-log to display OSPF log information.
display ospf [ process-id ] event-log { lsa-flush | lsa-history [ verbose ] | peer | route | spf }
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF log information for all processes.
lsa-flush: Specifies LSA aging log information.
lsa-history: Specifies self-originated and received LSA log information.
verbose: Displays detailed self-originated and received LSA log information. If you do not specify this keyword, the command displays brief self-originated and received LSA log information.
peer: Specifies neighbor state change log information.
neighbor-id: Specifies a neighbor by its router ID. If you do not specify this argument, the command displays state change log information for all neighbors.
route: Specifies OSPF route log information.
spf: Specifies route calculation log information.
Route calculation logs show the number of routes newly installed in the IP routing table.
Neighbor logs include information about the following events:
·     The OSPF neighbor state goes down.
·     The OSPF neighbor state goes backward because the local end receives BadLSReq, SeqNumberMismatch, and 1-Way events.
# Display OSPF LSA aging log information for all processes.
<Sysname> display ospf event-log lsa-flush
                  LSA Flush Log
 Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.1.1
 Type: 1   LS ID: 2.2.2.2         AdvRtr: 2.2.2.2           Seq#: 80000001
 Date: 2013-09-22 Time: 14:47:33 Flushed MaxAge LSA by the self
 Type: 1   LS ID: 1.1.1.1         AdvRtr: 1.1.1.1           Seq#: 80000001
 Date: 2013-09-22 Time: 14:47:33 Received MaxAge LSA from 10.1.2.2
Table 7 Command output
Date/Time
Time when the device receives an LSA that has reached the maximum age.
Received MaxAge LSA from X.X.X.X
The device received an LSA that has reached the maximum age from X.X.X.X.
The device flushed the LSA that has reached the maximum age.
LSA type.
LS ID
LSA link state ID.
AdvRtr
Advertising router.
Seq#
LSA sequence number.
# Display OSPF LSA log information for process 1.
<Sysname> display ospf event-log lsa-history
                  LSA Log
Date:2016-06-06 Time:10:47:44:007923 Area 0.0.0.2  LSAs received from interface GE1/0/6 10.5.1.5
Type      LinkState ID     AdvRtr       Age  Length   Sequence
1         10.1.1.5         10.1.1.5     1    36       80000002
Table 8 Command output
Date/Time
Time when the device generated or received the LSA, which is accurate to microseconds.
LSAs received from interface XXX X.X.X.X
The device received an LSA from interface XXX with IP address X.X.X.X.
Self-originated or self-aged LSAs
The LSA is self-originated or self-aged.
LSA type.
LinkState ID
LSA link state ID.
AdvRtr
Advertising router.
Sequence
# Display OSPF route log information for process 1.
<Sysname> display ospf event-log route
                  Route Log
Date: 2013-09-22 Time: 14:47:33:070853  Modified 2.1.1.1/32,
Type:Stub
Interface: GE1/0/7, Nexthop:10.5.1.1, Rely NbrID:0x13000004, Flag:0x01
Table 9 Command output
Date/Time
Route calculation time, which is accurate to microseconds.
Added/Deleted/Modified
The route was newly added, deleted, or modified.
Route type, which can be Transit, Stub, Inter, Type1, or Type2.
Output interface of the route.
Nexthop
Next hop of the route.
Rely NbrID
Recursive neighbor router ID. If Rely is not displayed, the neighbor router is a non-recursive neighbor.
Flag
Route attribute flag.
# Display OSPF route calculation log information for all processes.
<Sysname> display ospf event-log spf
          OSPF Process 1 with Router ID 1.1.1.2
                  SPF Log
Date       Time     Duration   Intra Inter External Reason
2012-06-27 15:28:26 0.95       1     1     10000    Intra-area LSA
2012-06-27 15:28:23 0.2        0     0     0        Area 0 full neighbor
2012-06-27 15:28:19 0          0     0     0        Intra-area LSA
2012-06-27 15:28:19 0          0     0     0        external LSA
2012-06-27 15:28:19 0.3        0     0     0        Intra-area LSA
2012-06-27 15:28:12 0          1     0     0        Intra-area LSA
2012-06-27 15:28:11 0          0     0     0        Routing policy
2012-06-27 15:28:11 0          0     0     0        Intra-area LSA
Table 10 Command output
Topology
MTID
Date/Time
Time when the route calculation starts.
Duration
Duration of the route calculation, in seconds.
Intra
Number of intra-area routes newly installed in the IP routing table.
Inter
Number of inter-area routes newly installed in the IP routing table.
External
Number of external routes newly installed in the IP routing table.
Reason
Reasons why the route calculation is performed:
·     Intra-area LSA—Intra-area LSA changes.
·     Inter-area LSA—Inter-area LSA changes.
·     External LSA—External LSA changes.
·     Configuration—Configuration changes.
·     Area 0 full neighbor—Number of FULL-state neighbors in Area 0 changes.
·     Area 0 up interface—Number of interfaces in up state in Area 0 changes.
·     LSDB overflow state—Overflow status changes.
·     AS number—AS number changes.
·     ABR summarization—ABR summarization changes.
·     GR end—GR ends.
·     Routing policy—Routing policy changes.
·     Intra-area tunnel—Intra-area tunnel changes.
·     Others—Other reasons.
# Display OSPF neighbor log information for OSPF process 1.
<Sysname> display ospf 1 event-log peer
                  Neighbors Log
Date       Time     Local Address   Remote Address  Router ID       Reason
2012-12-31 12:35:45 197.168.1.1     197.168.1.2     2.2.2.2         IntPhyChange
2012-12-31 12:35:19 197.168.1.1     197.168.1.2     2.2.2.2         ConfNssaArea
2012-12-31 12:34:59 197.168.1.1     197.168.1.2     2.2.2.2         SilentInt
Table 11 Command output
Date/Time
Time when the neighbor state changes.
Local Address
Local address of the neighbor relationship.
Remote Address
Peer address of the neighbor relationship.
Router ID
Neighbor router ID.
Reason
Reasons for neighbor state changes:
·     ResetConnect—The connection is lost due to insufficient memory.
·     IntChange—The interface parameter has changed.
·     VlinkChange—The virtual link parameter has changed.
·     ResetOspf—The OSPF process is reset.
·     UndoOspf—The OSPF process is deleted.
·     UndoArea—The OSPF area is deleted.
·     UndoNetwork—The interface is disabled.
·     SilentInt—The interface is configured as a silent interface.
·     IntLogChange—The logical attribute of the interface has changed.
·     IntPhyChange—The physical attribute of the interface has changed.
·     IntVliChange—The virtual link attribute of the interface has changed.
·     VlinkDown—The virtual link goes down.
·     DeadExpired—The dead timer expires.
·     ConfStubArea—The interface is configured with stub area parameters.
·     ConfNssaArea—The interface is configured with NSSA area parameters.
·     AuthChange—The authentication type has changed.
·     OpaqueChange—The Opaque capability has changed.
·     Retrans—Excessive retransmissions.
·     LLSChange—The LLS capability has changed.
·     OOBChange—The OOB capability has changed.
·     GRChange—The GR capability has changed.
·     BFDDown—The interface is shut down by BFD.
·     BadLSReq—The interface receives BadLSReq events.
·     SeqMismatch—The interface receives SeqNumberMismatch events.
·     1-Way—The interface receives 1-Way events.
·     FilterLSA—Peer disconnection occurs because LSA filter settings have changed or the ACL used by the LSA filter has changed.
·     LocalNoLSA—The requested LSA does not exist.
·     SameLSAReq—The received LSA is in the local request queue.
·     OldLSAReq—The received LSA has a larger aging time than the requested LSA in the local request queue.
·     DdTimerOut—Receives a DD packet after the dead timer expires.
·     EAChange—The External Attribute bit has changed.
·     MTChange—The Multi-Topology bit has changed.
·     RecvNoDupPkt—Receives a non-duplicate DD packet in loading or full status.
·     EbitChange—The E bit has changed.
·     MSbitChange—The MS bit has changed.
·     IbitChange—The I bit has changed.
·     MSeqNumError—The primary router receives an unexpected serial number from the secondary router.
·     SSeqNumError—The secondary router receives an unexpected serial number from the primary router.
·     RecvOpqIntf—A DD packet that contains a type 9 LSA is received when the opaque LSA reception and advertisement capability is disabled.
·     RecvOpqArea—A DD packet that contains a type 10 LSA is received when the opaque LSA reception and advertisement capability is disabled.
·     RecvOpqAS—A DD packet that contains a type 11 LSA is received when the opaque LSA reception and advertisement capability is disabled.
·     RecvNSSA—A DD packet that contains a type 7 LSA is received in a non-NSSA area.
·     InvalidLSA—A DD packet that contains an invalid LSA is received.
·     RecvASE—A DD packet that contains a type 5 LSA is received on a virtual link or in a stub area.
·     shutdown—The shutdown process command is executed.
Use display ospf event-log hello to display OSPF log information about received or sent hello packets.
display ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } [ neighbor-id ]
received: Specifies log information for received hello packets.
sent: Specifies log information for sent hello packets.
abnormal: Specifies log information for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies log information for received hello packets that were dropped.
failed: Specifies log information for hello packets that failed to be sent.
neighbor-address: Specifies a neighbor by its IP address. If you do not specify this argument, the command displays received or sent hello packet log information for all neighbors.
# Display log information for sent hello packets.
<Sysname> display ospf event-log hello sent
         OSPF Process 1 with Router ID 5.5.5.5
                 Hello Log
Interface: GE1/0/6
Neighbor address: 10.1.1.2, NbrID: 1.0.0.2
First 4 hello packets sent:
  2019-09-05 20:10:10:121, failed, errno: 132
  2019-09-05 20:10:20:121, succeeded
  2019-09-05 20:10:30:121, succeeded
  2019-09-05 20:10:40:121, succeeded
Last 4 hello packets sent before Full->Down at 2019-09-06 14:52:10:121
  2019-09-06 14:51:40:021, succeeded
  2019-09-06 14:51:50:021, succeeded
  2019-09-06 14:52:00:021, failed, errno: 132
  2019-09-06 14:52:10:010, failed, errno: 132
Interface: GE1/0/6
Last 4 hello packets sent before Full->Init at 2019-09-06 11:16:20:171
  2019-09-06 11:15:20:121, succeeded
  2019-09-06 11:15:30:121, succeeded
  2019-09-06 11:15:40:121, succeeded
  2019-09-06 11:15:50:121, succeeded
Table 12 Command output
Interface that sends the hello packets.
Neighbor address
IP address of the neighbor.
NbrID
Router ID of the neighbor.
Time and result (succeeded or failed) for sending the first four hello packets. For a packet failed to be sent, an error code is displayed in the errno field.
Error codes and corresponding failure reasons are as follows:
·     4—EINTR. Interrupted system call.
·     9—EBADF. Bad file descriptor.
·     11—EAGAIN. Resource temporarily unavailable.
·     12—ENOMEM. Cannot allocate memory.
·     32—EPIPE. Broken pipe.
·     88—ENOTSOCK. Socket operation on non-socket.
·     90—EMSGSIZE. Message too long.
·     95—EOPNOTSUPP. Operation not supported.
·     104—ECONNRESET. Connection reset by peer.
·     107—ENOTCONN. Transport endpoint is not connected.
·     113—EHOSTUNREACH. No route to host.
·     132—ENOBUFS. No buffer space available.
Last 4 hello packets sent before Full->Down at 2018-01-06 14:52:10:121
Time and result (succeeded or failed) for sending the last four hello packets before neighbor state change. For a packet failed to be sent, an error code is displayed in the errno field.
# Display log information for hello packets that failed to be sent.
<Sysname> display ospf event-log hello sent failed
                 Hello Log
Date: 2019-09-06 Time: 14:51:20:121 Interface: GE1/0/6
Destination address: 224.0.0.5, sent failed, errno: 132
Date: 2019-09-06 Time: 11:20:20:116 Interface: GE1/0/7
Destination address: 10.1.1.2, sent failed, errno: 132
Table 13 Command output
Date
Date for the hello packet sending failure, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time for the hello packet sending failure, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that sends the hello packet.
Destination address
Destination IP address of the hello packet.
errno
Error code for the hello packet sending failure. Options include:
# Display log information for abnormal hello packets sent.
<Sysname> display ospf event-log hello sent abnormal
                 Hello Log
Date: 2019-09-06 Time: 11:21:12:121 Interface: GE1/0/7
Destination address: 224.0.0.5, last one sent: 2019-09-06 11:20:51:916
Date: 2019-09-06 Time: 11:56:21:312 Interface: GE1/0/7
Destination address: 10.1.1.2, last one sent: 2019-09-06 11:56:02:691
Table 14 Command output
Date
Date for sending the abnormal hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time for sending the abnormal hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that sends the abnormal hello packet.
Destination address
Destination IP address of the abnormal hello packet.
last one sent
Time for sending the last hello packet before sending the abnormal hello packet.
# Display log information for received hello packets.
<Sysname> display ospf event-log hello received
                 Hello Log
Interface: GE1/0/6
First 4 hello packets received:
  2019-09-05 20:11:10:121
  2019-09-05 20:11:20:121
  2019-09-05 20:11:30:121
  2019-09-05 20:11:40:121
Last 4 hello packets received before Exchange->Down at 2019-09-06 14:52:10:121
  2019-09-06 14:51:10:121
  2019-09-06 14:51:20:121
  2019-09-06 14:51:30:121
  2019-09-06 14:51:40:121
Interface: GE1/0/6
Neighbor address: 10.1.1.1, NbrID: 1.0.0.1
  2019-09-06 19:11:15:121
  2019-09-06 19:11:25:121
  2019-09-06 19:11:35:121
  2019-09-06 19:11:45:121
Last 4 hello packets received before Full->Init at 2019-09-06 21:16:20:171
  2019-09-06 21:15:45:121
  2019-09-06 21:15:55:121
  2019-09-06 21:16:05:121
  2019-09-06 21:16:15:121
Table 15 Command output
Interface that receives the hello packets.
Neighbor address
NbrID
Time for receiving the first four hello packets.
Time for receiving the last four hello packets before neighbor state change, in the format of YYYY-MM-DD hh:mm:ss:xxx. YYYY represents the year, MM represents the month, and DD represents the day. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
# Display log information for received hello packets that were dropped.
<Sysname> display ospf event-log hello received dropped
                 Hello Log
Date: 2019-09-06 Time: 14:51:22:791 Interface: GE1/0/6
Source address: 10.1.1.1, NbrID: 1.0.0.1, area: 0.0.0.1
Drop reason: Hello-time mismatch
Source address: 10.1.1.2, NbrID: 1.0.0.2, area: 0.0.0.1
Drop reason: NP-bit mismatch
Table 16 Command output
Date
Date for dropping the received hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time for dropping the received hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that receives the hello packet.
Source address
Source IP address of the received hello packet.
NbrID
area
Area to which the neighbor interface belongs.
Drop reason
Reason for dropping the hello packet:
·     Area under reset—The area is in the reset progress.
·     Router ID conflict—Route ID conflict.
·     Area mismatch—Area ID mismatch.
·     Unknown virtual link—The hello packet is from an unknown virtual link.
·     Authentication failure—Authentication check failure.
·     Peer address check failure—Neighbor address check failure.
·     Not DR or BDR—The destination IP address of the hello packet is 224.0.0.6, but the interface is not a DR or BDR.
·     Unknown unicast peer—The hello packet is from an unknown unicast neighbor.
·     Option mismatch—Option mismatch.
·     Subnet mask mismatch—Subnet mask mismatch.
·     Address mismatch—Address range mismatch.
·     Hello timer mismatch—Hello timer mismatch.
·     Dead timer mismatch—Dead timer mismatch.
·     Peer change—The source IP address or router ID has changed.
# Display log information for abnormal hello packets received.
<Sysname> display ospf event-log hello received abnormal
                 Hello Log
Date: 2019-09-06 Time: 10:12:22:121 Interface: GE1/0/6
Last one received: 2019-09-06 10:12:04:212
Last one received: 2019-09-06 14:51:05:113
Table 17 Command output
Date&Tme
Date for receiving the abnormal hello packet, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time for receiving the abnormal hello packet, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that receives the abnormal hello packet.
Source address
Source IP address of the received abnormal hello packet.
NbrID
area
Last one received
Time for receiving the last hello packet before receiving the abnormal hello packet.
display ospf fast-reroute lfa-candidate
Use display ospf fast-reroute lfa-candidate to display OSPF FRR backup next hop information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays FRR backup next hop information for all processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays FRR backup next hop information for all OSPF areas.
# Display OSPF FRR backup next hop information.
<Sysname> display ospf 1 area 0 fast-reroute lfa-candidate
                  LFA Candidate List
 Area: 0.0.0.0
 Candidate nexthop count: 2
 NextHop          IntIP            Interface
 10.0.1.1         10.0.1.2         GE1/0/7
 10.0.11.1        10.0.11.2        GE1/0/8
Table 18 Command output
Topology
MTID
Area
Area to which the backup next hops belong.
Number of backup next hops.
NextHop
IntIP
IP address of the output interface.
Output interface.
display ospf global-statistics
Use display ospf global-statistics to display global OSPF statistics.
display ospf global-statistics [ public | vpn-instance vpn-instance-name ]
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify the public keyword or the vpn-instance vpn-instance-name option, this command displays global OSPF statistics for the public network and all VPN instances.
# Display global OSPF statistics.
<Sysname> display ospf global-statistics
  OSPF global statistics
   Instance count   : 1
   Process count    : 1
   Interface information
    Down            : 0
    Up              : 1
   Neighbor information
    Down            : 0
    Init            : 0
    Attempt         : 0
    2-Way           : 0
    ExStart         : 0
    Exchange        : 0
    Loading         : 0
    Full            : 1
   Packets sent     : 26
   Packets received : 27
   LSA count        : 6
   Route count      : 2
Table 19 Command output
Instance count
This field displays the number of VPN instances and public network that are configured with OSPF.
·     If OSPF is configured only for the public network, the value is fixed at 1.
·     If OSPF is configured only for VPN instances, the value equals the number of the VPN instances.
·     If OSPF is configured for both the public network and VPN instances, the value equals the number of VPN instances plus 1.
Process count
Number of OSPF processes.
Statistics about interface status.
Down
Number of interfaces in Down status.
Up
Number of interfaces in Up status.
Statistics about neighbor status.
Down
Number of neighbor routers in Down status.
Attempt
Number of neighbor routers in Up status.
Init
Number of neighbor routers in Init status.
2-Way
Number of neighbor routers in 2-Way status.
ExStart
Number of neighbor routers in ExStart status.
Exchange
Number of neighbor routers in Exchange status.
Loading
Number of neighbor routers in Loading status.
Full
Number of neighbor routers in Full status.
Packets sent
Number of OSPF packets sent.
Packets received
Number of OSPF packets received.
LSA count
Total number of LSAs in the LSDB.
Route count
Total number of OSPF routes.
display ospf graceful-restart
Use display ospf graceful-restart to display GR information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays GR information for all processes.
verbose: Displays detailed GR information. If you do not specify this keyword, the command displays brief GR information.
# Display detailed GR information.
<Sysname> display ospf graceful-restart verbose
              Graceful Restart information
Graceful Restart capability     : Enable(IETF)
Graceful Restart support        : Planned and unplanned,Partial
Helper capability               : Enable(IETF)
Helper support                  : Planned and unplanned(IETF),Strict LSA check
Current GR state                : Normal
Graceful Restart period         : 40 seconds
Number of neighbors under Helper: 0
Number of restarting neighbors  : 0
Last exit reason:
  Restarter  : None
  Helper     : None
Area: 0.0.0.0
Area up Interface count: 2
Interface: 40.4.0.1 (GigabitEthernet1/0/7)
Restarter state: Normal  State: P-2-P     Type: PTP
Last exit reason:
  Restarter  : None
  Helper     : None
Neighbor count of this interface: 1
Neighbor        IP address      GR state     Last Helper exit reason
3.3.3.3         40.4.0.3        Normal       None
Virtual-link Neighbor-ID  -> 4.4.4.4, Neighbor-State: Full
Interface: 20.2.0.1 (Vlink)
Transit Area: 0.0.0.1
Last exit reason:
  Restarter  : None
  Helper     : None
4.4.4.4         20.2.0.4        Normal       Reset neighbor
Table 20 Command output
GR information for OSPF process 1 with router ID 1.1.1.1.
Whether GR is enabled:
·     Enable(IETF)—IETF GR is enabled.
·     Enable(Nonstandard)—Non-IETF GR is enabled.
·     Disable—GR is disabled.
GR modes that the process supports (displayed only when GR is enabled):
·     Planned and unplanned—Supports both planned and unplanned GR.
·     Planned only—Supports only planned GR.
·     Partial—Supports partial GR.
·     Global—Supports global GR.
Helper capability
Helper capability that the process supports:
·     Enable(IETF)—Supports IETF GR helper capability.
·     Enable(Nonstandard)—Supports non-IETF GR helper capability.
·     Enable(IETF and nonstandard)—Supports both IETF GR helper capability and non-IETF GR helper capability.
·     Disable—Does not support GR helper capability.
Helper support
This field is available only when the helper capability is enabled.
Policies that the helper supports:
·     Strict lsa check—The helper supports strict LSA checking.
·     Planned and unplanned—The helper supports planned and unplanned GR.
·     Planned only—The helper supports only planned GR.
Current GR state
GR state:
·     Normal—GR is not in progress or has completed.
·     Under GR—GR is in process.
·     Under Helper—The process is acting as GR helper.
Last exit reason
Last exit reason:
·     Restarter—Reason that the restarter exited most recently.
·     Helper—Reason that the helper exited most recently.
Area
Area ID in IP address format.
Authentication type
Area flag
Type of the area:
·     Normal.
·     Stub.
·     NSSA.
Number of up interfaces in the area.
Restarter state
Restarter state on the interface.
Interface state.
Neighbors of an interface.
Neighbor
Neighbor router ID.
IP address
Neighbor IP address.
GR state
Neighbor GR state:
Router ID of the virtual link's neighbor.
Neighbor-State
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, and Full.
Output interface of the virtual link.
display ospf hostname-table
Use display ospf hostname-table to display the router ID-to-host name mapping table.
display ospf [ process-id ] hostname-table
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify an OSPF process, this command displays the router ID-to-host name mapping tables for all OSPF processes.
# Display the router ID-to-host name mapping tables for all OSPF processes.
<RouterA> display ospf hostname-table
         OSPF Process 1 with Router ID 192.168.56.21
                 Hostname Table Information
                         Area: 0.0.0.1
Router ID            Hostname
192.168.56.21        RouterA
display ospf interface
Use display ospf interface to display OSPF interface information.
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF interface information for all OSPF processes.
verbose: Displays detailed OSPF information for all interfaces.
If you do not specify the interface-type interface-number argument or the verbose keyword, this command displays OSPF brief information for all interfaces.
# Display all OSPF interface brief information.
<Sysname> display ospf interface
 (M) Indicates MADJ interface
          OSPF Process 1 with Router ID 192.168.1.1
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type         State    Cost  Pri   DR              BDR
 192.168.1.1     PTP          P-2-P    1562  1     0.0.0.0         0.0.0.0
 Area: 0.0.0.1
 172.16.0.1      Broadcast    DR       1     1     172.16.0.1      0.0.0.0
 Area: 0.0.0.2
 12.1.1.1(M)        PTP       P-2-P    1     1     0.0.0.0         0.0.0.0
Table 21 Command output
The interface is a multi-area adjacency interface.
Area
Area ID of the interface.
IP Address
Interface IP address (regardless of whether TE is enabled or not).
Interface network type:
·     PTP (P2P).
·     PTMP (P2MP).
·     Broadcast.
·     NBMA.
Interface state:
·     Down—No protocol traffic can be sent or received on the interface.
·     Loopback—The interface is in loopback state and it cannot forward traffic.
·     Waiting—The interface starts sending and receiving Hello packets. The router is trying to determine the identity of the (Backup) designated router for the network.
·     P-2-P—The interface will send Hello packets at the hello interval, and try to establish an adjacency with the neighbor.
·     DR—The router is the designated router on the network.
·     BDR—The router is the backup designated router on the network.
·     DROther—The router is a DR Other router on the attached network.
Cost
Interface cost.
Pri
Router priority.
DR
DR on the interface's network segment.
BDR
BDR on the interface's network segment.
# Display detailed information about GigabitEthernet 1/0/6.
<Sysname> display ospf interface verbose
                  Interfaces
 Area: 0.0.0.0
 Interface: 172.16.0.1 (GigabitEthernet1/0/6)
 Priority: 1
 Designated router: 172.16.0.1
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 Primary path detection mode: BFD ctrl
 Virtual system: Disabled
  Flapping count: 0
  Threshold: 10
 BFD: control
 BFD adjust cost: 1000
 BFD suppress flapping: Detect interval 30s
                        Threshold 2
                        Resume interval 10s
 Cryptographic authentication: Enabled, inherited
    The last key is 3.
    The rollover is in progress, 2 neighbor(s) left.
 LDP state: No-LDP
 LDP sync state: Achieved
 Link quality: GOOD, cost adjusted at low quality: 50
 Packet size: 1000
   Value: 876, Explicit-null, N-flag-clear
   Process ID: ospf 1
   Static adjacency SID:
    Nexthop          Adjacency-SID     Type      Result
    100.100.100.100  15555             Absolute  Succeeded
    8.8.8.8          1000              Index     Conflicting
 Average delay  : 0 us
 Min delay      : 0 us
 Max delay      : 0 us
 Delay variation: 0 us
 MTID    Cost      Disabled    Topology name
 0       1         No          base
 Priority: 1
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 Virtual system: Enabled
 Virtual Router ID: 3.3.3.3
  Mode: Hold-max-cost
  Remaining interval: 420 s
 Min delay      : 0 us
 Max delay      : 0 us
 0       65535     No          base
 Area: 0.0.0.1
 Interface: 172.16.0.1 (GigabitEthernet1/0/6) --> 172.16.0.2
 FRR backup: Enabled
 FRR TI-LFA: Enabled
 Min delay      : 0 us
 Max delay      : 0 us
 0       1         No          base
Table 22 Command output
Information about the interface, such as the IP address.
Cost source
Priority
Router priority.
Designated router
Designated router in the network to which the interface belongs.
Backup designated router in the network to which the interface belongs.
Timers
OSPF timers (in seconds): Hello, Dead, Poll, and Retransmit.
Transmit Delay
LSA transmission delay on the interface, in seconds.
FRR backup
Whether LFA calculation is enabled on an interface.
FRR remote-LFA
FRR TI-LFA
Primary link detection mode:
·     BFD ctrl—BFD control packet mode.
·     BFD echo—BFD echo packet mode.
OSPF is enabled on the interface (including secondary IP addresses).
Number of multi-area adjacency interfaces for which OSPF is enabled by using the ospf multi-area command.
Virtual system
Whether the virtual system feature is enabled on the OSPF interface. If this feature is enabled, the interface can use a virtual OSPF node for neighbor relationship establishment.
Virtual Router ID
Router ID of the virtual OSPF node configured on the interface.
BFD
BFD session mode enabled on the interface:
·     ctrl—BFD control packet mode.
·     echo—BFD echo packet mode.
BFD adjust cost
Whether OSPF is enabled to adjust the interface cost according to the BFD session state:
·     Disabled.
·     A value in the 1 to 65534 indicates the value to be added to the interface cost.
·     Maximum—Sets the interface cost to the maximum value 65534.
This information is displayed only when the ospf bfd adjust-cost command is configured for the interface.
Suppress adjustment of the interface cost according to the BFD session state upon BFD session flapping:
·     Detect interval—Interval at which OSPF detects BFD session state changes, in seconds.
·     Threshold—Maximum number of BFD session down events. The number of BFD session down events is also displayed (in the BFD down times field) if it is smaller than the threshold within the specified detection interval.
·     Resume interval—Delay timer before OSPF resumes the original interface cost, in seconds. The remain field indicates the remaining time of the timer.
This information is displayed only when the ospf bfd adjust-cost suppress-flapping command is configured for the interface.
Simple authentication: Enabled, inherited
The interface uses the simple authentication mode. The inherited attribute indicates that the interface uses the authentication mode specified for the area to which the interface belongs.
Cryptographic authentication mode (MD5, HMAC-MD5, or HMAC-SHA-256) is used by the interface.
The last key
Most recent MD5, HMAC-MD5, or HMAC-SHA-256 authentication key ID.
Key rollover for MD5, HMAC-MD5, or HMAC-SHA-256 authentication is in progress, and two neighbors have not completed the key rollover.
LDP state
LDP state:
·     Init—Initialization state. LDP has not been delivered.
·     No-LDP—LDP is not configured.
·     Not ready—LDP sessions have not been established.
·     Ready—LDP sessions have been established.
LDP sync state
LDP IGP synchronization state:
·     Achieved—LDP has been synchronized.
·     Max cost—OSPF advertises the maximum cost in LSAs.
Link quality
Link quality:
·     GOOD—The bit error ratio is below the upper threshold or drops below the lower threshold.
·     LOW—The bit error ratio exceeds the upper threshold.
This field is displayed only when the interface is configured with the ospf link-quality adjust-cost command.
Interface cost adjustment parameters:
·     xx—Value added to the interface cost. When the link quality is LOW, the interface cost is xx plus the original interface cost.
·     Maximum—Sets the maximum interface cost when the link quality is LOW.
Packet size
Prefix-SID type
Prefix SID type:
Nexthop
Next hop address. This field displays 0.0.0.0 for a P2P network.
Adjacency SID type:
·     Absolute—Absolute value of the adjacency SID.
·     Index—Index value of the adjacency SID.
Result
Adjacency SID application result:
·     Succeeded—Applied for adjacency SID successfully.
·     Conflicting—Adjacency SID conflict occurred.
·     Init—Adjacency SID application is in progress or adjacency SID assignment is not enabled.
Value
Prefix SID value and flag information:
·     Explicit-null—The upstream neighbor uses an explicit null flag to replace the prefix SID.
·     N-flag-clear—The prefix SID is the SID to a group of SR nodes.
Prefix-SID validity
Average delay
Average link delay in microseconds.
Max delay
Maximum link delay in microseconds.
Min delay
Minimum link delay in microseconds.
Delay variation
Acceptable link delay variation in microseconds.
MTID
Cost
Cost of the interface route in the topology.
Disabled
Whether OSPF is disabled from advertising the topology for the interface: Yes or No.
Topology name
display ospf interface hello
Use display ospf interface hello to display information about hello packets sent by OSPF interfaces.
display ospf [ process-id ] interface [ interface-type interface-number ] hello
process-id: Specifies an OSPF process ID in the range of 1 to 65535. If you do not specify this argument, the command displays hello packet information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information about the hello packets sent by all OSPF interfaces.
This command displays information for only the hello packets sent in multicast.
# Display information about hello packets sent by all OSPF interfaces.
<Sysname> display ospf interface hello
                  Interfaces
 Area: 0.0.0.0
   2019-09-05 11:05:10:121, succeeded
   2019-09-05 11:05:20:121, succeeded
   2019-09-05 11:05:30:121, succeeded
   2019-09-05 11:05:40:121, succeeded
 Last 4 hello packets sent:
   2019-09-06 11:15:10:121, succeeded
Table 23 Command output
Area
Area to which the interface belongs.
IP address of the interface.
Time and result (succeeded or failed) for sending the last four hello packets when the command is executed.
display ospf lsdb
Use display ospf lsdb to display OSPF LSDB information.
display ospf [ process-id ] lsdb [ brief | originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb opaque-as [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb opaque-as [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb ase [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb ase [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { network | opaque-area | opaque-link } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | nssa | router | summary } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDB information for all OSPF processes.
age: Displays LSAs whose ages are in the specified range. If you do not specify this keyword, the command displays all LSAs in the LSDB.
max-value max-age-value: Specifies the maximum age of LSAs, in the range of 0 to 3600 seconds. The default value is 3600.
min-value min-age-value: Specifies the minimum age of LSAs, in the range of 0 to 3600 seconds. The default value is 0. The min-age-value cannot be greater than the max-age-value.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays LSDB information for all OSPF areas.
brief: Displays brief LSDB information.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
network: Displays Type-2 LSA (Network LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
opaque-area: Displays Type-10 LSA (Opaque-area LSA) information in the LSDB.
opaque-as: Displays Type-11 LSA (Opaque-AS LSA) information in the LSDB.
opaque-link: Displays Type-9 LSA (Opaque-link LSA) information in the LSDB.
router: Displays Type-1 LSA (Router LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
link-state-id: Specifies a link state ID in the IP address format.
originate-router advertising-router-id: Specifies an advertising router by its ID.
self-originate: Displays information about self-originated LSAs.
hostname host-name: Displays LSAs advertised by the router with the specified host name. If you do not specify this option, the command displays all LSAs in the OSPF LSDB.
resolve-hostname: Displays host names in OSPF LSDB information. If you do not specify this keyword, the OSPF LSDB information does not include host names.
# Display OSPF LSDB information.
<Sysname> display ospf lsdb
         OSPF Process 1 with Router ID 192.168.0.1
                 Link State Database
                         Area: 0.0.0.0
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Metric
 Router    192.168.0.2     192.168.0.2        474  36    80000004   0
 Router    192.168.0.1     192.168.0.1        21   36    80000009   0
 Network   192.168.0.1     192.168.0.1        321  32    80000003   0
 Sum-Net   192.168.1.0     192.168.0.1        321  28    80000002   1
 Sum-Net   192.168.2.0     192.168.0.2        474  28    80000002   1
                         Area: 0.0.0.1
 Router    192.168.0.1     192.168.0.1        21   36    80000005   0
 Sum-Net   192.168.2.0     192.168.0.1        321  28    80000002   2
 Sum-Net   192.168.0.0     192.168.0.1        321  28    80000002   1
                         Type 9 Opaque (Link-Local Scope) Database
 Flags: * -Vlink interface LSA
 Type      LinkState ID    AdvRouter          Age  Len   Sequence   Interfaces
*Opq-Link  3.0.0.0         7.2.2.1            8    14    80000001   10.1.1.2
*Opq-Link  3.0.0.0         7.2.2.2            8    14    80000001   20.1.1.2
# Display OSPF LSDB information, including the host names of the advertising routers.
<Sysname> display ospf lsdb resolve-hostname
                 Link State Database
                         Area: 0.0.0.0
 Router    1.1.1.1         1.1.1.1         1419 36    80000004  0
 Router    2.2.2.2         RouterB         1420 36    80000004  0
 Network   192.168.12.2    RouterB         1420 32    80000001  0
 Sum-Net   192.168.13.0    1.1.1.1         1456 28    80000001  1
                         Area: 0.0.0.1
 Router    3.3.3.3         3.3.3.3         1416 36    80000003  0
 Router    1.1.1.1         1.1.1.1         1415 36    80000003  0
 Network   192.168.13.2    3.3.3.3         1416 32    80000001  0
 Sum-Net   192.168.12.0    1.1.1.1         1456 28    80000001  1
                 Type 10 Opaque (Area-Local Scope) Database
 Type      LinkState ID    AdvRouter       Age  Len   Sequence  Area
 Opq-Area  4.0.0.0         RouterB         470  32    80000001  0.0.0.0
Table 24 Command output
Area
LSDB information for the area.
LSA type.
LinkState ID
Link state ID.
AdvRouter
Advertising router or its host name.
Age
Age of the LSA.
Len
Length of the LSA.
Sequence
Sequence number of the LSA.
Metric
Cost of the LSA.
*Opq-Link
Opaque LSA generated by a virtual link.
Opq-Area
Received Type-10 LSA.
# Display OSPF brief LSDB information.
<Sysname> display ospf lsdb brief
                 LS Database Statistics
Area ID         Router   Network  S-Net    S-ASBR   Type-7   | SubTotal
 0.0.0.0         2        1        0        0        0        | 3
 0.0.0.1         0        0        0        0        0        | 0
 Total           2        1        0        0        0        |
 Area ID         Opq-9    Opq-10                              | SubTotal
 0.0.0.0         0        9                                   | 9
 0.0.0.1         0        1                                   | 1
 Total           0        10                                  |
                 ASE      Opq-11                              | SubTotal
 Total           0        0                                   | 0
                                                              | Total
                                                              | 13
Table 25 Command output
Router
Number of Type-1 LSAs.
Network
Number of Type-2 LSAs.
S-Net
Number of Type-3 LSAs.
S-ASBR
Number of Type-4 LSAs.
Type-7
Number of Type-7 LSAs.
Opq-9
Number of Type-9 LSAs.
Opq-10
Number of Type-10 LSAs.
ASE
Number of Type-5 LSAs.
Opq-11
Number of Type-11 LSAs.
SubTotal
Total number of LSAs in the same area.
Total
Total number of LSAs that are of the same type, or total number of LSAs.
# Display Type-2 LSA (Network LSA) information in the LSDB.
<Sysname> display ospf 1 lsdb network
                  Link State Database
                          Area: 0.0.0.0
    Type      : Network
    LS ID     : 192.168.0.2
    Adv Rtr   : 192.168.2.1
    LS age    : 922
    Len       : 32
    Options   :  E
    Seq#      : 80000003
    Checksum    : 0x8d1b
    Net mask  : 255.255.255.0
       Attached router    192.168.1.1
       Attached router    192.168.2.1
                          Area: 0.0.0.1
    Type      : Network
    LS ID     : 192.168.1.2
    Adv Rtr   : 192.168.1.2
    LS age    : 782
    Len       : 32
    Options   :  NP
    Seq#      : 80000003
    Checksum    : 0x2a77
       Attached router    192.168.1.2
# Display Type-2 LSA (Network LSA) information in the LSDB, including the host names of the advertising routers.
<Sysname> display ospf 1 lsdb network resolve-hostname
                 Link State Database
                         Area: 0.0.0.0
    Type      : Network
    LS ID     : 192.168.12.2
    Adv Rtr   : 2.2.2.2
    Hostname  : RouterB
    LS age    : 1552
    Len       : 32
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xbdd0
       Attached router    1.1.1.1
       Attached router    2.2.2.2
                         Area: 0.0.0.1
    Type      : Network
    LS ID     : 192.168.13.2
    Adv Rtr   : 3.3.3.3
    LS age    : 1548
    Len       : 32
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xc6be
       Attached router    3.3.3.3
Table 26 Command output
LSA type.
LS ID
DR IP address.
Adv Rtr
Router that advertised the LSA.
Hostname
Host name of the advertising router.
LS age
LSA age time.
Len
LSA length.
Options
LSA options:
·     O—Opaque LSA advertisement capability.
·     E—AS External LSA reception capability.
·     DC—On-demand link support.
·     NPN indicates support for NSSA external LSAs. P indicates the capability of an NSSA ABR to translate Type-7 LSAs into Type-5 LSAs.
Seq#
Checksum
LSA checksum.
Net mask
Network mask.
Attached router
ID of the router that established adjacency with the DR, and ID of the DR itself.
# Display Type-9 LSA information in the LSDB for OSPF process 1.
<Sysname> display ospf 1 lsdb opaque-link
                 Link State Database
                         Area: 0.0.0.0
    Type      : Opq-Link
    LS ID     : 3.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 2
    Len       : 44
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0x31cf
      Opaque type: 3(Grace LSA)
      Opaque ID: 0
      IETF Graceful Restart Period: 120
      Restart Reason:    1 - software restart
      Neighbor Interface Address  : 192.168.12.1
# Display Type-10 LSA information in the LSDB for OSPF process 1.
<Sysname> display ospf 1 lsdb opaque-area
                 Link State Database
                         Area: 0.0.0.0
    Type      : Opq-Area
    LS ID     : 4.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 1311
    Len       : 52
    Options   : O E
    Seq#      : 8000015c
    Checksum  : 0x4323
      Opaque type: 4(Router information)
      Opaque ID: 0
      Router information TLV:
        Length      : 4
        Capabilities:
          All Capability Bits: 0x60000000
          Graceful restart helper capable
          Stub router capable
      Segment routing algorithm TLV:
        Length   : 1
        Algorithm: 0
      Segment routing range TLV:
        Length: 12
        Range : 1001
        SID sub-TLV:
          Length: 3
          Label : 16000
      SR Node Maximum SID Depths:
         MPLS MSD         : 5
    Type      : Opq-Area
    LS ID     : 1.0.0.2
    Adv Rtr   : 1.1.1.1
    LS age    : 1239
    Len       : 192
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0x9412
      Opaque type: 1(Traffic Engineering)
      Opaque ID: 2
      Link Type                : Broadcast
      Link ID                  : 12.1.1.2
      Local Interface Address  : 12.1.1.1
      TE Metric                : 1
      Maximum Bandwidth        : 0 bytes/sec
      Maximum Reservable BW    : 0 bytes/sec
      Administrative Group     : 0x0
      IGP Metric               : 1
      Number of SRLGs :  3
        SRLG [1]:10
        SRLG [2]:20
        SRLG [3]:30
      Unreserved Bandwidth for each TE Class:
        TE class  0 = 0 bytes/sec
        TE class  1 = 0 bytes/sec
        TE class  2 = 0 bytes/sec
        TE class  3 = 0 bytes/sec
        TE class  4 = 0 bytes/sec
        TE class  5 = 0 bytes/sec
        TE class  6 = 0 bytes/sec
        TE class  7 = 0 bytes/sec
      Bandwidth Constraint Model: Prestandard DS-TE RDM
      Bandwidth Constraints:
        BC [ 0] = 0 bytes/sec
        BC [ 1] = 0 bytes/sec
      Flag: 0, Average delay: 100 us
      Flag: 0, Min delay: 10 us, Max delay: 1000 us
      Delay variation: 200 us
    Type      : Opq-Area
    LS ID     : 7.0.0.0
    Adv Rtr   : 1.1.1.1
    LS age    : 1311
    Len       : 44
    Options   : O E
    Seq#      : 8000012f
    Checksum  : 0xabcf
      Opaque type: 7(Extended prefix)
      Opaque ID: 0
         Extended prefix TLV:
           Length    : 20
           Route type: 1
           AF        : 0
           Flags     : N
           Prefix    : 23.1.1.1/32
           SID sub-TLV:
             Length    : 8
             Flags     : NP/-/E/-/-
             MTID      : 0
             Algorithm : 0
             SID index : 101
           LAN adj sub-TLV:
             Length : 11
             Flags (B/V/L/G/P): 0/1/1/0/0
             MTID   : 0
             Weight : 0
             Neighbor ID: 1.1.1.1
             Label  : 1279
# Display Type-11 LSA information in the LSDB for OSPF process 1.
<Sysname> display ospf 1 lsdb opaque-as
                 Link State Database
    Type      : Opq-AS
    LS ID     : 7.0.0.1
    Adv Rtr   : 3.3.3.3
    LS Age    : 78
    Len       : 44
    Options   : O E
    Seq#      : 80000001
    Checksum  : 0xc164
      Opaque Type: 7(Extended prefix)
      Opaque ID: 1
          Length    : 20
          Route type: 5
          AF        : 0
          Flags     : -
          Prefix    : 5.5.5.5/32
          SID sub-TLV:
            Length    : 8
            Flags     : NP/-/-/-/-
            MTID      : 0
            Algorithm : 0
            SID index : 50
Table 27 Command output
LSA type:
·     Opq-Link—Type-9 LSA, which is flooded on the local link.
·     Opq-Area—Type-10 LSA, which is flooded within an area.
·     Opq-AS—Type-11 LSA, which is flooded within an AS.
LS ID
LSA link state ID, a combination of the opaque type and the opaque ID. The first 8 bits indicates the opaque type and the last 24 bits indicates the opaque ID.
Adv Rtr
Hostname
Host name of the router that advertised the LSA.
LS age
LSA aging time.
Len
LSA length.
Options
LSA options:
Seq#
Checksum
LSA checksum.
Opaque type
Opaque type:
·     1(Traffic Engineering)—Opaque LSAs used for MPLS TE.
·     3(Grace LSA)—Opaque LSAs used for GR.
·     4(Router information)—Opaque LSAs used for route capability advertisement.
·     7(Extended prefix)—Opaque LSAs used for SID or MPLS label advertisement.
·     8(Extended link)—Opaque LSAs used for extended link information advertisement.
Opaque ID
Opaque ID.
GR restart interval in seconds.
Restart Reason
GR restart reason:
·     0 - unknown.
·     1 - software restart.
·     2 - software reload/upgrade.
·     3 - switch to redundant control processor.
IP address of the local interface used for neighbor relationship establishment.
Link Type
Link type:
·     Point to Point.
·     Point to Multi Point.
·     Broadcast.
·     NBMA.
Link ID
Link ID.
Primary IP address of the local interface.
TE Metric
TE metric.
Maximum Bandwidth
Maximum bandwidth of the link.
Maximum bandwidth that can be reserved for the link.
Administrative group attribute of the link.
IGP Metric
IGP metric.
Number of SRLGs
Number of SRLGs. The n argument in SRLG [n] represents the sequence number of the SRLG. For example, SRLG [1] represents the first SRLG.
Available bandwidth reserved for each TE class.
Bandwidth constraint model:
·     Prestandard DS-TE RDM.
·     IETF DS-TE RDM.
·     IETF DS-TE MAM.
Bandwidth constraint value. The Prestandard model supports 2 BCs, and the IETF models support a maximum of 4 BCs.
Flag
Whether the measured average link delay exceeds 16777215 microseconds.
·     0—The measured average link delay is shorter than 16777215 microseconds, indicating that the link is stable.
·     1—The measured average link delay is longer than or equivalent to 16777215 microseconds, indicating that the link is not stable.
Average delay
Flag
Whether the measured minimum or maximum link delay exceeds 16777215 microseconds.
·     0—The measured minimum or maximum link delay is shorter than 16777215 microseconds, indicating that the link is stable.
·     1—The measured minimum or maximum link delay is longer than or equivalent to 16777215 microseconds, indicating that the link is not stable.
Min delay
Max delay
Delay variation
Delay variation in microseconds.
Remaining bandwidth
Remaining bandwidth in bps. The data type of this field is 32-bit single precision floating point. Values with higher precision will be truncated or rounded, which might cause precision loss.
Available bandwidth
Available bandwidth in bps. The data type of this field is 32-bit single precision floating point. Values with higher precision will be truncated or rounded, which might cause precision loss.
Utilized bandwidth
Used bandwidth in bps. The data type of this field is 32-bit single precision floating point. Values with higher precision will be truncated or rounded, which might cause precision loss.
MPLS TE Router ID
Local LSR ID.
Route capability TLV information:
·     Length—TLV length in bytes.
·     Capabilities—Route capabilities:
¡     All Capability Bits—All capability bits, indicating the features that the device supports.
¡     Graceful restart helper capable—GR helper is supported.
¡     Stub router capable—Stub router is supported.
¡     Traffic Engineering enabled area—The OSPF area is enabled with MPLS TE.
SR algorithm TLV:
·     Algorithm—Prefix related algorithm.
SR label range TLV:
·     Range—Label range.
·     SID sub-TLV—Prefix SID sub-TLV.
¡     Length—TLV length in bytes.
¡     Label—Minimum label value.
Maximum SID depths (MSD) TLV information for SR-MPLS nodes. The MPLS MSD field displays the maximum number of SIDs that an SR-MPLS node can encapsulate in a packet.
Extended prefix TLV
·     Route type—Route type:
¡     1—Intra-area route.
¡     5—AS external route.
¡     7—NSSA external route.
·     AF—Address family.
·     Flags—Prefix SID flag:
¡     A—Attach flag (A-Flag). Inter-area prefix generated by the ABR.
¡     N—Node flag (N-Flag). The prefix SID is the SID to an SR node.
·     Prefix—Prefix information.
·     Length—Prefix SID sub-TLV length.
·     Flags—Flag carried in the prefix SID sub-TLV:
¡     NP—No-PHP flag. The penultimate node cannot pop the prefix SID.
¡     M—Mapping server flag. The SID is advertised by the mapping server.
¡     E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets.
¡     V—Value/Index flag. The value of the prefix SID is an absolute value.
¡     L—Local flag. The value/index in the prefix SID has local significance.
·     MTID—Multi-topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology.(Subtopologies are not supported in the current software version.)
·     SID index—Index value of the prefix SID.
LAN adj sub-TLV
LAN adjacency SID advertisement sub-TLV:
·     Length—Sub-TLV length in bytes.
·     Flags—Flag information:
¡     B—Backup flag. If this bit is set, the adjacency SID is used to protect other nodes.
¡     V—Value/index flag. This field displays V if this bit is set, which indicates that the adjacency SID carries the label value.
¡     L—Local/global flag. If this bit is set, the value/index in the adjacency SID has local significance.
¡     G—Group flag. If this bit is set, The adjacency SID represents an adjacency group.
¡     P—Persistent flag. If this bit is set, the ADJ-SID is valid permanently.
·     Weight—Weight.
·     Neighbor ID—Router ID of the neighbor.
·     Label—Label value.
SR Link Maximum SID Depths
Maximum SID depths (MSD) TLV information for SR-MPLS links. The MPLS MSD field displays the maximum number of SIDs that can be encapsulated in a packet.
display ospf nexthop
Use display ospf nexthop to display OSPF next hop information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays next hop information for all OSPF processes.
# Display OSPF next hop information.
<Sysname> display ospf nexthop
                  Neighbor Nexthop Information
 NbrID           Nexthop         Interface                Area            RefCount   Status
 12.1.1.1        0.0.0.0         GE1/0/6              0.0.0.0         4          Valid
 12.1.1.1        0.0.0.0         GE1/0/6              0.0.0.1         1          Valid
 12.1.1.2        12.1.1.2        GE1/0/6              0.0.0.1         3          Valid
 12.1.1.2        12.1.1.2        GE1/0/6              0.0.0.0         3          Valid
Table 28 Command output
NbrID
Neighbor router ID.
Nexthop
Next hop address.
Output interface.
Area
ID of the area to which the next hop belongs.
RefCount
Reference count (routes that use the next hop).
Status
Next hop status:
·     Valid.
·     Invalid.
·     Valid-SR—The next hop type is SR tunnel and the SR tunnel has taken effect.
·     Invalid-SR—The next hop type is SR tunnel and the SR tunnel does not take effect.
display ospf non-stop-routing status
Use display ospf non-stop-routing status to display OSPF NSR information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF NSR information for all OSPF processes.
# Display OSPF NSR information.
<Sysname> display ospf non-stop-routing status
                   OSPF Process 1 with Router ID 192.168.33.12
                          Non Stop Routing information
Non Stop Routing capability : Enabled
Upgrade phase : Normal
Table 29 Command output
NSR status: enabled or disabled.
Upgrade phase
Upgrade phase:
·     Prepare—Upgrade preparation phase.
·     Restore Smooth—Upgrade phase.
·     Preroute—Route pre-calculation phase.
·     Calculating—Route calculation phase.
·     Redisting—Route redistribution phase.
·     Original and age—LSA generation and aging phase.
·     Normal—Normal status.
display ospf peer
Use display ospf peer to display information about OSPF neighbors.
display ospf [ process-id ] peer [ hello | verbose ] [ interface-type interface-number ] [ [ neighbor-id ] [ resolve-hostname ] | hostname host-name ]
process-id: Specifies an OSPF process by ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF neighbor information for all OSPF processes.
hello: Displays information about the hello packets sent to and received from neighbor routers. In scenarios where hello packets are sent in multicast, the command displays information for only the hello packets received from neighbor routers.
verbose: Displays detailed neighbor information. If you do not specify this keyword, the command displays brief OSPF neighbor information.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays neighbor information for all interfaces.
neighbor-id: Specifies a neighbor router ID. If you do not specify this argument, the command displays information for all neighbors.
resolve-hostname: Resolves the host names of the neighbor routers. If you do not specify this keyword, the command cannot resolve the host names of the neighbor routers.
hostname host-name: Specifies a neighbor router by its host name, a case-sensitive string of 1 to 255 characters. If you do not specify this option, the command displays information for all neighbors.
# Display detailed OSPF neighbor information.
<Sysname> display ospf peer verbose
 (M) Indicates MADJ neighbor
                  Neighbors
 Area 0.0.0.0 interface 1.1.1.1(GigabitEthernet1/0/6)'s neighbors
 Router ID: 1.1.1.2          Address: 1.1.1.2          GR state: Normal
   DR: 1.1.1.2  BDR: 1.1.1.1  MTU: 0
   Dead timer due in 33  sec
   Neighbor is up for 02:03:35
   Authentication sequence: [ 0 ]
   BFD status: Disabled
   Adjacency SID: 24253
 Area 0.0.0.1 interface 1.1.1.1(GigabitEthernet1/0/6)'s neighbors
 Router ID: 1.1.1.2(M)         Address: 1.1.1.2         GR state: Normal
   DR: None   BDR: None   MTU: 0
   Options is 0x42 (-|O|-|-|-|-|E|-)
   Dead timer due in 37  sec
   Neighbor is up for 21:22:20
   Neighbor state change count: 5
 Last Neighbor Down Event:
 Router ID: 22.22.22.22
 Local Address: 11.11.11.11
 Remote Address: 22.22.22.22
 Time: Apr  9 03:18:19 2014
 Reason: Ospf_ifachange
# Display detailed OSPF neighbor information and resolve the host names of the neighbor routers.
<Sysname> display ospf peer verbose resolve-hostname
         OSPF Process 1 with Router ID 12.1.1.1
                 Neighbors
 Area 0.0.0.0 interface 12.1.1.1(GigabitEthernet1/0/6)'s neighbors
 Router ID: 12.1.1.2         Address: 12.1.1.2         GR state: Normal
   DR: 12.1.1.2  BDR: 12.1.1.1  MTU: 0
   Dead timer due in 36  sec
   Neighbor is up for 23:54:20
 Area 0.0.0.1 interface 12.1.1.1(GigabitEthernet1/0/6)'s neighbors
 Router ID: 12.1.1.2(M)         Address: 12.1.1.2         GR state: Normal
   Neighbor is up for 21:25:34
 Router ID: 12.1.1.2
 Local Address: 12.1.1.1
 Remote Address: 12.1.1.2
 Area ID: 0.0.0.1
 Time: Nov  8 17:22:09 2023
 Reason: Ospf Interface Parameters Changed
Table 30 Command output
The neighbor is established on a multi-area adjacency interface.
Area areaID interface IPAddress(InterfaceName)'s neighbors
Neighbor information for the interface in the specified area:
·     areaID—Area to which the neighbor belongs.
·     IPAddress—Interface IP address.
·     InterfaceName—Interface name.
Router ID
Neighbor router ID.
Address
Neighbor router address.
GR state
GR state:
·     Normal.
·     Restarter.
·     Complete.
·     Helper.
Hostname
Host name of the neighbor router.
Neighbor state:
·     Down—Initial state of a neighbor conversation.
·     Init—The router has received a Hello packet from the neighbor. However, the router has not established bidirectional communication with the neighbor. The router did not appear in the neighbor's hello packet.
·     Attempt—Available only in an NBMA network. In this state, the OSPF router has not received any information from a neighbor for a period. The router can send Hello packets at a longer interval to keep the neighbor relationship.
·     2-Way—Communication between the two routers is bidirectional. The local router appears in the neighbor's Hello packet.
·     Exstart—The goal of this state is to decide which router is the master, and to decide upon the initial Database Description (DD) sequence number.
·     Exchange—The router is sending DD packets to the neighbor, describing its entire link-state database.
·     Loading—The router sends LSRs packets to the neighbor, requesting more recent LSAs.
·     Full—The neighboring routers are fully adjacent.
Mode
Neighbor mode for LSDB synchronization.
Priority
Neighboring router priority.
DR
BDR
MTU
Interface MTU.
Options
LSA options:
This dead timer will expire in 33 seconds.
The neighbor has been up for 02:03:35.
Authentication sequence number.
Count of neighbor state changes.
BFD status
BFD status:
·     Disabled.
·     Enabled (Control mode).
·     Enabled (Echo mode).
Adjacency SID
SID advertised by the adjacency path.
The most recent neighbor down event.
Time
Time when the neighbor went down, in MM DD hh:mm:ss YYYY format.
·     MM—Represents the month.
·     DD—Represents the day.
·     hh—Represents the hours.
·     mm—Represents the minutes.
·     ss—Represents the seconds.
·     YYYY—Represents the year.
Reason
Reason for the neighbor down event:
·     Ospf_resetconnect—The neighbor relationship was down due to memory insufficiency.
·     Ospf Interface Parameters Changed—The interface settings were changed.
·     VLINK Interface Parameters Changed—The virtual link settings were changed.
·     Reset ospf command was performed—The reset ospf process command was executed.
·     Undo ospf command was performed—The undo ospf command was executed.
·     Undo area command was performed—The undo area command was executed.
·     Undo network—The undo network command was executed.
·     Silent Interface—The silent interface command was executed.
·     Ospf_iflchange—The logical attribute of the interface was changed.
·     Ospf_ifachange—The physical attribute of the interface was changed.
·     Ospf_ifvchange—The virtual link attribute of the interface was changed.
·     Vlink down—The virtual link went down.
·     DeadInterval timer expired—The dead timer expired.
·     Configuring stub area—The stub area settings were changed.
·     Configuring nssa area—The NSSA area settings were changed.
·     Area Authentication-mode changed—The area authentication mode was changed.
·     Opaque-Capability changed—The Opaque capability was changed.
·     Too many retransmissions—Excessive retransmissions.
·     Link-local-Signaling Capability changed—The LLS capability was changed.
·     Out-Of-Band Resynchronazition Capability changed—The OOB capability was changed.
·     Graceful-Restart Capability changed—The GR capability was changed.
·     BFD session down—The BFD session associated with OSPF went down.
·     Database-filter or referenced ACL changed—The LSA filter settings on the specified interface were changed or the ACL used by the LSA filter was changed.
# Display brief OSPF neighbor information.
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID          Address         Pri Dead-Time  State             Interface
 1.1.1.2            1.1.1.2         1   40         Full/DR           GE1/0/6
 Area: 0.0.0.1
 12.1.1.2(M)        1.1.1.2         1   35         Full/ -           GE1/0/6
# Display brief OSPF neighbor information and resolve the host names of the neighbor routers.
<Sysname> display ospf peer resolve-hostname
 Area: 0.0.0.0
 RouterA            1.1.1.2         1   34         Full/DR           GE1/0/6
 Area: 0.0.0.1
 12.1.1.2(M)        1.1.1.2         1   36         Full/ -           GE1/0/6
Table 31 Command output
Area
Neighbor area.
Router ID
ID or host name of the neighbor router. (M) indicates that the neighbor is established on a multi-area adjacency interface.
Address
Neighbor interface address.
Pri
Dead-Time
Dead interval remained.
Interface connected to the neighbor.
Neighbor state: Down, Init, Attempt, 2-Way, Exstart, Exchange, Loading, or Full.
# Display information about the hello packets sent to and received from neighbor routers.
<Sysname> display ospf peer hello
                  Neighbors
   2019-09-06 09:12:10:121
   2019-09-06 09:12:20:121
   2019-09-06 09:12:30:121
   2019-09-06 09:12:40:121
 Last 4 hello packets received:
   2019-09-06 09:12:12:121, failed, errno:132
   2019-09-06 09:12:22:121, succeeded
   2019-09-06 09:12:32:121, succeeded
   2019-09-06 09:12:42:121, succeeded
   2019-09-06 11:15:12:121, succeeded
   2019-09-06 11:15:22:121, succeeded
   2019-09-06 11:15:32:121, failed, errno:132
   2019-09-06 11:15:42:121, failed, errno:132
   2023-12-08 17:22:09:497
   2023-12-08 17:22:10:782
   2023-12-08 17:22:20:874
   2023-12-09 15:07:40:142
   2023-12-09 15:07:50:127
   2023-12-09 15:08:00:154
   2023-12-09 15:08:10:208
Table 32 Command output
Router ID
Router ID of the neighbor. (M) indicates that the neighbor is established on a multi-area adjacency interface.
Address
IP address of the neighbor interface.
Time for receiving the first four hello packets from neighbors.
Time for receiving the last four hello packets from neighbors.
Time and result (succeeded or failed) for sending the first four hello packets to neighbors. For a packet failed to be sent, an error code is displayed in the errno field.
This field is not displayed in scenarios where hello packets are sent in multicast.
Time and result (succeeded or failed) for sending the last four hello packets  to neighbors when the command is executed. For a packet failed to be sent, an error code is displayed in the errno field.
display ospf peer statistics
Use display ospf peer statistics to display OSPF neighbor statistics.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF neighbor statistics for all OSPF processes.
# Display OSPF neighbor statistics.
<Sysname> display ospf peer statistics
          OSPF Process 1 with Router ID 10.3.1.1
                    Neighbor Statistics
  Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
  0.0.0.0         0    0       0    0     0       0        0       1    1
  0.0.0.2         0    0       0    0     0       0        0       1    1
  Total           0    0       0    0     0       0        0       2    2
Table 33 Command output
Area ID
The state statistics for all the routers in the area to which the router belongs is displayed.
Down
Number of neighboring routers in Down state in the same area.
Attempt
Number of neighboring routers in Attempt state in the same area.
Init
Number of neighboring routers in Init state in the same area.
2-Way
Number of neighboring routers in 2-Way state in the same area.
ExStart
Number of neighboring routers in ExStart state in the same area.
Exchange
Number of neighboring routers in Exchange state in the same area.
Loading
Number of neighboring routers in Loading state in the same area.
Full
Number of neighboring routers in Full state in the same area.
Total
Total number of neighbors in the same state: Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, or Full.
display ospf request-queue
Use display ospf request-queue to display OSPF request queue information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF request queue information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays the OSPF request queue information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify this argument, the command displays the OSPF request queue information for all OSPF neighbors.
# Display OSPF request queue information.
<Sysname> display ospf request-queue
          OSPF Process 100 with Router ID 192.168.1.59
                  Link State Request List
  The Router's Neighbor is Router ID 2.2.2.2         Address 10.1.1.2
  Interface 10.1.1.1         Area 0.0.0.0
  Request list:
       Type       LinkState ID      AdvRouter         Sequence   Age
       Router     2.2.2.2           1.1.1.1           80000004   1
       Network    192.168.0.1       1.1.1.1           80000003   1
       Sum-Net    192.168.1.0       1.1.1.1           80000002   2
Table 34 Command output
Neighbor router ID.
Address
Neighbor interface IP address.
Local interface IP address.
Area
Area ID.
Request list
Request list information.
LSA type.
LinkState ID
Link state ID.
AdvRouter
Advertising router.
Sequence
LSA sequence number.
Age
LSA age.
display ospf retrans-queue
Use display ospf retrans-queue to display retransmission queue information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays retransmission queue information for all OSPF processes.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays retransmission queue information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify this argument, the command displays retransmission queue information for all neighbors.
# Display OSPF retransmission queue information.
<Sysname> display ospf retrans-queue
                  Link State Retransmission List
  Retransmit list:
       Router     2.2.2.2           2.2.2.2           80000004   1
       Network    12.18.0.1         2.2.2.2           80000003   1
       Sum-Net    12.18.1.0         2.2.2.2           80000002   2
Table 35 Command output
Neighbor router ID.
Address
Interface address of the router.
Area
Area ID.
Retransmit list
Retransmission list.
LSA type.
LinkState ID
Link state ID.
AdvRouter
Advertising router.
Sequence
Age
LSA age.
display ospf routing
Use display ospf routing to display OSPF routing information.
display ospf [ process-id ] routing [ ip-address { mask-length | mask } | priority { critical | high | low | medium } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the routing information for all OSPF processes.
ip-address: Specifies a destination IP address.
mask-length: Specifies mask length in the range of 0 to 32.
mask: Specifies the mask in dotted decimal notation.
priority { critical | high | low | medium }: Specifies a route convergence priority. Options include critical, high, low, and medium. If you do not specify this keyword, this command displays OSPF routing information for all convergence priorities.
interface interface-type interface-number: Displays routes passing the specified output interface. If you do not specify this option, the command displays OSPF routing information for all interfaces.
nexthop nexthop-address: Displays routes passing the specified next hop. If you do not specify this option, the command displays all OSPF routing information.
verbose: Displays detailed OSPF routing information. If you do not specify this keyword, the command displays brief OSPF routing information.
# Display OSPF routing information.
<Sysname> display ospf routing
          OSPF Process 1 with Router ID 192.168.1.2
                   Routing Table
                Topology base (MTID 0)
 Routing for network
 Destination        Cost  Type       NextHop         AdvRouter     Area
 192.168.1.0/24     1562  Stub       192.168.1.2     192.168.1.2   0.0.0.0
 172.16.0.0/16      1563  Inter      192.168.1.1     192.168.1.1   0.0.0.0
 Total nets: 2
 Intra area: 1  Inter area: 1  ASE: 0  NSSA: 0
Table 36 Command output
Topology
Topology name. If this field displays base, the topology is the base topology. If this field displays other values, the topology is a subtopology.
MTID
Topology ID. If this field displays 0, the topology is the base topology. If this field displays other values, the topology is a subtopology.
Destination
Destination network.
Cost
Cost to destination.
Route type: transit, stub, inter, Type-1, and Type-2. ECMP-backup indicates that the route is the backup route for ECMP routes.
NextHop
Next hop address.
AdvRouter
Advertising router.
Area
Area ID.
Total nets
Total networks.
Intra area
Total intra-area routes.
Inter area
Total inter-area routes.
ASE
Total ASE routes.
NSSA
Total NSSA routes.
# Display detailed OSPF routing information.
<Sysname> display ospf routing verbose
          OSPF Process 2 with Router ID 192.168.1.112
                   Routing Table
 Routing for network
  Destination: 192.168.1.0/24
     Priority: Low                     Type: Stub
    AdvRouter: 192.168.1.2             Area: 0.0.0.0
   SubProtoID: 0x1               Preference: 10
      NextHop: 192.168.1.2        BkNextHop: N/A
       IfType: Broadcast           BkIfType: N/A
    Interface: GE1/0/7       BkInterface: N/A
        NibID: 0x1300000c            Status: Normal
         Cost: 1562
      InLabel: 4294967295       Tunnel type: -
     OutLabel: 4294967295     OutLabel flag: -
   BkOutLabel: 4294967295   BkOutLabel flag: -
     LabelSrc: N/A               Delay flag: N/A
 Remote-LFA backup Info:
     PQPrefix: 44.44.44.44          PQAdvID: 44.44.44.44
      LsIndex: 1
   LabelStack: {2303}
 TI-LFA backup info:
  BkInterface: GE1/0/6        BkNextHop: 12.1.1.2
     BkIfType: Broadcast
  PNodePrefix: 3.3.3.3           QNodeAdvID: 2.2.2.2
      LsIndex: 2
   LabelStack: {19030, 2431}
  Destination: 172.16.0.0/16
     Priority: Low                     Type: Inter
    AdvRouter: 192.168.1.1             Area: 0.0.0.0
      NextHop: 192.168.1.1        BkNextHop: N/A
    Interface: GE1/0/8       BkInterface: N/A
         Cost: 1563
 Total nets: 2
 Intra area: 2  Inter area: 0  ASE: 0  NSSA: 0
Table 37 Command output
Topology
MTID
Priority
Prefix priority: critical, high, medium, and low.
AdvRouter
Advertising router.
Area
Area ID.
SubProtoID
Sub protocol ID.
Preference
OSPF route preference.
NextHop
Primary next hop IP address.
BkNextHop
Backup next hop IP address.
IfType
Type of the network to which the primary next hop belongs.
BkIfType
Type of the network to which the backup next hop belongs.
Output interface.
BkInterface
Backup output interface.
NibID
Next hop ID.
Status
Route status:
·     Local—The route is on the local end and is not sent to the route management module.
·     Invalid—The next hop is invalid.
·     Stale—The next hop is stale.
·     Normal—The route is available.
·     Delete—The route is deleted.
·     Host-Adv—The route is a host route.
·     Rely—The route is a recursive route.
Cost
SpfCost
SPF cost of the SR tunnel.
InLabel
Incoming label of the route. For invalid incoming labels, this field displays 4294967295.
Tunnel type
Tunnel type. Only SR tunnels are supported in the current software version.
OutLabel
Outgoing label of the route. For invalid outgoing labels, this field displays 4294967295.
OutLabel flag
Outgoing label flag:
·     E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets.
·     I—Implicit null flag. The upstream neighbor must replace the SID with an implicit null flag before forwarding the packets. This flag is not supported in the current software version.
·     N—Normal flag.
·     P—SR label preferred flag.
BkOutLabel
Backup outgoing label of the route. For invalid backup outgoing labels, this field displays 4294967295.
BkOutLabel flag
Backup outgoing label flag:
·     N—Normal flag.
LabelSrc
Label source:
·     SR—Assigned by an SR node.
·     SRMS—Assigned by the Segment Routing Mapping Server (SRMS).
Delay Flag
Microloop avoidance delay flag:
·     D—Microloop avoidance is configured. Route convergence is delayed.
·     N/A—Microloop avoidance is not configured or the microloop avoidance delay timer has expired. Route convergence is in progress.
MALsIndex
SR microloop avoidance label stack index.
MALabelStack
SR microloop avoidance label stack (from top to bottom).
Remote-LFA back Info
Remote LFA backup information.
PQPrefix
PQ node prefix.
PQAdvID
Router ID of the PQ node.
LsIndex
Label stack index.
LabelStack
Label stack.
TI-LFA backup info
TI-LFA backup information.
PNodePrefix
P node prefix.
QNodeAdvID
Router ID of the Q node.
display ospf spf-tree
Use display ospf spf-tree to display SPF tree information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command displays SPF tree information for all OSPF processes.
area area-id: Specifies an OSPF area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify an area, this command displays SPF tree information for all OSPF areas.
verbose: Displays detailed SPF tree information. If you do not specify this keyword, the command displays brief SPF tree information.
# Display brief SPF tree information for Area 0 in OSPF process 1.
<Sysname> display ospf 1 area 0 spf-tree
          OSPF Process 1 with Router ID 100.0.0.4
        Flags: S-Node is on SPF tree       R-Node is directly reachable
               I-Node or Link is init      D-Node or Link is to be deleted
               P-Neighbor is parent        A-Node is in candidate list
               C-Neighbor is child         T-Node is tunnel destination
               H-Nexthop changed           N-Link is a new path
               V-Link is involved          G-Link is in change list
                  Area: 0.0.0.0  Shortest Path Tree
 SpfNode         Type    Flag      SpfLink         Type   Cost  Flag
>192.168.119.130 Network S R
                                -->114.114.114.111 NET2RT 0     C
                                -->100.0.0.4       NET2RT 0     P
>114.114.114.111 Router  S
                                -->192.168.119.130 RT2NET 65535 P
>100.0.0.4       Router  S
                                -->192.168.119.130 RT2NET 10    C
Table 38 Command output
Topology
MTID
SpfNode
SPF node, represented by a router ID when the node type is Router, or the IP address of the DR when the node type is Network.
Node flag:
·     I—The node is in initialization state.
·     A—The node is on the candidate list.
·     S—The node is on the SPF tree.
·     R—The node is directly connected to the root node.
·     D—The node is to be deleted.
·     T—The node is the tunnel destination.
SpfLink
SPF link, representing the peer node.
Link type:
·     RT2RT—Router to router.
·     NET2RT—Network to router.
·     RT2NET—Router to network.
Link flag:
·     I—The link is in initialization state.
·     P—The peer is the parent node.
·     C—The peer is the child node.
·     D—The link is to be deleted.
·     H—The next hop is changed.
·     V—When the peer node is deleted or added, the peer node is not on the SPF tree or is deleted.
·     N—The link is newly added, and both end nodes are on the SPF tree.
·     G—The link is on the area change list.
# Display detailed SPF tree information for Area 0 in OSPF process 1.
<Sysname> display ospf 1 area 0 spf-tree verbose
>LsId(192.168.119.130)
 AdvId    : 100.0.0.4       NodeType     : Network
 Mask     : 255.255.255.0   SPFLinkCnt   : 2
 Distance : 10
 VlinkData: 0.0.0.0         ParentLinkCnt: 1           NodeFlag: S R
 NextHop  : 1
   192.168.119.130    Interface: GE1/0/7           Flag: -
 BkNextHop: 1
   0.0.0.0            Interface: GE1/0/7           Flag: -
 Remote-LFA:
  RLFAAdvId     : 11.11.11.11       RLFAInterface: GE1/0/8
  RLFANexthop   : 1.1.1.1
  PQNode AdvID  : 44.44.44.44       PQNode prefix: 44.44.44.44
  Protect       : Link
  Label stack   : {2303}
 TI-LFA:
  TiLfaAdvId   : 4.4.4.4           TiLfaInterface: GE1/0/7
  TiLfaNexthop : 14.1.1.4
  PNode AdvID  : 3.3.3.3              QNode AdvID: 2.2.2.2
  PNode prefix : 3.3.3.3           PNode SidIndex: 30
  Protect      : Link
  Label stack  : {19030, 2431}
 -->LinkId(114.114.114.111)
    AdvId   : 100.0.0.4       LinkType   : NET2RT
    LsId    : 192.168.119.130 LinkCost   : 0           NextHopCnt: 1
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : C
 -->LinkId(100.0.0.4)
    LinkData: 0.0.0.0         LinkNewCost: 0           LinkFlag  : P
Table 39 Command output
Topology
MTID
LsId
Link state ID.
AdvId
ID of the advertising router.
NodeType
Node type:
·     Network—Network node.
·     Router—Router node.
Mask
Network mask. Its value is 0 for a router node.
SPFLinkCnt
Number of SPF links.
Distance
Cost to the root node.
VlinkData
Destination address of virtual link packets.
ParentLinkCnt
Number of parent links.
NodeFlag
Node flag:
NextHop
Next hop.
Output interface.
MADuration
SR microloop avoidance duration in milliseconds.
MALStack
BkNextHop
Backup next hop.
Flag
Next hop type. SR indicates SR tunnel.
This field displays a hyphen (-) for other next hop types.
Remote-LFA
RLFAAdvId
Router ID of the remote LFA backup next hop.
RLFAaInterface
Output interface of the remote LFA backup next hop.
RLFaNexthop
Remote LFA backup next hop information.
PQNode AdvID
PQNode prefix
PQ node prefix.
TI-LFA
TI-LFA information.
TiLfaInterface
TI-LFA interface.
TiLfaNexthop
TI-LFA next hop address.
PNode AdvID
Router ID of the P node.
QNode AdvID
Protect
Traffic protection type: Link or Node.
LinkId
Link ID.
LinkType
Link type:
LinkCost
Link cost.
NextHopCnt
Number of next hops.
LinkData
Link data.
LinkNewCost
New link cost.
LinkFlag
Link flag:
display ospf statistics
Use display ospf statistics to display OSPF statistics.
display ospf [ process-id ] statistics [ error | packet [ hello | interface-type interface-number ] ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPF statistics for all OSPF processes.
error: Displays error statistics. If you do not specify this keyword, the command displays OSPF packet, LSA, and route statistics.
packet: Displays OSPF packet statistics.
hello: Displays statistics of the sent and received hello packets. If you do not specify this keyword, the command displays statistics of all types of sent and received packets.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays statistics for all interfaces.
# Display OSPF statistics.
<Sysname> display ospf statistics
                  Statistics
 I/O statistics
  Type                      Input     Output
  Hello                     61        122
  DB Description            2          3
  Link-State Req            1          1
  Link-State Update         3          3
  Link-State Ack            3          2
 LSAs originated by this router
  Router  : 4
  Network : 0
  Sum-Net : 0
  Sum-Asbr: 0
  External: 0
  NSSA    : 0
  Opq-Link: 0
  Opq-Area: 0
  Opq-As  : 0
 LSAs originated: 4  LSAs received: 7
 Routing table:
   Intra area: 2  Inter area: 3  ASE/NSSA: 0
Table 40 Command output
I/O statistics
Statistics about input/output packets and LSAs.
OSPF packet type.
Input
Packets received.
Output
Packets sent.
Hello
Hell packet.
DB Description
Database Description packet.
Link-State Req
Link-State Request packet.
Link-State Update
Link-State Update packet.
Link-State Ack
Link-State Acknowledge packet.
LSAs originated by this router.
Router
Number of Type-1 LSAs originated.
Network
Number of Type-2 LSAs originated.
Sum-Net
Number of Type-3 LSAs originated.
Sum-Asbr
Number of Type-4 LSAs originated.
External
Number of Type-5 LSAs originated.
NSSA
Number of Type-7 LSAs originated.
Opq-Link
Number of Type-9 LSAs originated.
Opq-Area
Number of Type-10 LSAs originated.
Opq-As
Number of Type-11 LSAs originated.
LSA originated
Number of LSAs originated.
LSA received
Number of LSAs received.
Routing table
Routing table information.
Intra area
Number of intra-area routes.
Inter area
Number of inter-area routes.
ASE/NSSA
Number of ASE/NSSA routes.
# Display OSPF error statistics.
<Sysname> display ospf statistics error
          OSPF Process 1 with Router ID 192.168.1.112
                  OSPF Packet Error Statistics
 0         : Router ID confusion         0         : Bad packet
 0         : Bad version                 0         : Bad checksum
 0         : Bad area ID                 0         : Drop on unnumbered link
 0         : Bad virtual link            0         : Bad authentication type
 0         : Bad authentication key      0         : Packet too small
 0         : Neighbor state low          0         : Transmit error
 0         : Interface down              0         : Unknown neighbor
 0         : HELLO: Netmask mismatch     0         : HELLO: Hello-time mismatch
 0         : HELLO: Dead-time mismatch   0         : HELLO: Ebit option mismatch
 0         : HELLO: Mbit option mismatch 0         : DD: MTU option mismatch
 0         : DD: Unknown LSA type        0         : DD: Ebit option mismatch
 0         : ACK: Bad ack                0         : ACK: Unknown LSA type
 0         : REQ: Empty request          0         : REQ: Bad request
 0         : UPD: LSA checksum bad       0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA
Table 41 Command output
Router ID confusion
Packets with duplicate router ID.
Bad packet
Packets illegal.
Bad version
Packets with wrong version.
Bad checksum
Packets with wrong checksum.
Bad area ID
Packets with invalid area ID.
Packets dropped on the unnumbered interface.
Bad virtual link
Packets on wrong virtual links.
Packets with invalid authentication type.
Packets with invalid authentication key.
Packet too small
Packets too small in length.
Neighbor state low
Packets received in low neighbor state.
Transmit error
Packets with error when being transmitted.
Interface down
Shutdown times of the interface.
Unknown neighbor
Packets received from unknown neighbors.
Hello packets with mismatched mask.
Hello packets with mismatched hello timer.
Hello packets with mismatched dead timer.
Hello packets with mismatched E-bit in the option field.
Hello packets with mismatched M-bit in the option field.
DD packets with mismatched MTU.
DD packets with unknown LSA type.
DD packets with mismatched E-bit in the option field.
ACK: Bad ack
Bad LSAck packets for LSU packets.
LSAck packets with unknown LSA type.
REQ: Empty request
LSR packets with no request information.
REQ: Bad request
Bad LSR packets.
LSU packets with wrong LSA checksum.
LSU packets with unknown LSA type.
LSU packets without the most recent LSA.
# Display OSPF packet statistics for all processes and interfaces.
<Sysname> display ospf statistics packet
                  Packet Statistics
 Waiting to send packet count: 0
         Hello      DD         LSR        LSU        ACK        Total
 Input : 489        6          2          44         40         581
 Output: 492        8          2          45         40         587
 Area: 0.0.0.1
 Interface: 20.1.1.1 (GigabitEthernet1/0/6)
 Input : 0          0          0          0          0
 Output: 0          0          0          0          0
 Interface: 100.1.1.1 (GigabitEthernet1/0/7)
 Input : 3          1          22         16         42
 Output: 2          1          19         20         42
Table 42 Command output
Number of packets waiting to be sent.
Total
Total number of packets.
Input
Number of received packets.
Output
Number of sent packets.
Area
Area ID.
Interface address and interface name.
# Display statistics of the sent and received hello packets.
<Sysname> display ospf statistics packet hello
         OSPF Process 1 with Router ID 100.1.1.1
                 Hello Statistics
 Total sent                             : 4
 Total sent failed                      : 0
 Sent after one and a half intervals    : 0
 Total received                         : 2
 Total received dropped                 : 0
 Received after one and a half intervals: 0
Table 43 Command output
Total sent
Total number of hello packets sent.
Total sent failed
Total number of hello packets that failed to be sent.
Total number of hello packets sent at intervals greater than 1.5 times the hello interval.
Total received
Total number of hello packets received.
Total number of received hello packets that were dropped.
Total number of hello packets received at intervals greater than 1.5 times the hello interval.
reset ospf statistics
display ospf topology-info
Use display ospf topology-info to display OSPF topology information.
display ospf [ process-id ] topology-info
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command displays topology information for all OSPF processes.
# Display topology information for all OSPF processes.
<Sysname> display ospf topology-info
 RouterID: 1.1.1.1          Router type:  ASBR
 Route tag: 0
 Originating router-LSAs with maximum metric
    Condition: Always, State: Active
 ISPF is enabled
 SPF-schedule-interval: 5 50 200
 Route preference: 10
 ASE route preference: 150
 SPF calculation count: 7
 Area count: 3   NSSA area count: 0
 Normal areas with up interfaces: 0
 NSSA areas with up interfaces: 0
 Up interfaces: 0
 Area0 full neighbors: 0
 Calculation trigger type: N/A
 Current calculation type: N/A
 Current calculation phase: N/A
 Process reset state: N/A
 Routing table:
   Intra area: 0  Inter area: 0  ASE/NSSA: 0
 Area: 0.0.0.0              Area flag: Normal
 SPF scheduled count: 3
 Up interfaces: 0
 Area: 0.0.0.1              Area flag: Normal
 Up interfaces: 0
 Area: 0.0.0.2              Area flag: Normal
 SPF scheduled count: 1
 Up interfaces: 0
Table 44 Command output
OSPF process ID and OSPF router ID.
Topology
MTID
RouterID
Local router ID.
Router Type
Router type:
·     ABR.
·     ASBR.
·     NSSA.
·     Null.
Route Tag
Tag of redistributed routes.
Interval for SPF calculations.
The maximum cost value for router LSAs (excluding stub links) is used.
Condition
Status of the stub router:
·     Always.
·     On startup while BGP is converging.
·     On startup while BGP is converging for xxx seconds, where xxx is specified by the user.
·     On startup for xxx seconds, where xxx is specified by the user.
Whether the stub router is active.
Default ASE parameters: Metric, Tag, and Type.
Route preference
Internal route preference.
External route preference.
SPF computation count
SPF computation count of the OSPF process.
Area count
Number of areas for the OSPF process.
Nssa area count
Number of NSSA areas for the OSPF process.
Number of neighbors in Full state in Area 0.
Route calculation trigger type:
·     Full—Calculation of all routes is triggered.
·     Area topology change—Topology change in an area.
·     Intra router change—Incremental intra-area route change.
·     ASBR change—Incremental ASBR route change.
·     7to5 translator—Type-7-to-Type-5 LSA translator role change.
·     Full IP prefix—Calculation of all IP prefixes is triggered.
·     Full intra AS—Calculation of all intra-AS prefixes is triggered.
·     Inc intra AS—Calculation of incremental intra-AS prefixes is triggered.
·     Full inter AS—Calculation of all AS-external prefixes is triggered.
·     Inc inter AS—Calculation of incremental AS-external prefixes is triggered.
·     N/A—Route calculation is not triggered.
Current route calculation type:
·     SPF calculation.
·     Intra router calculation—Intra-area route calculation.
·     ASBR calculation—Inter-area ASBR route calculation.
·     Inc intra router—Incremental intra-area route calculation.
·     Inc ASBR calculation—Incremental inter-area ASBR route calculation.
·     7to5 translator—Type-7-to-Type-5 LSA calculation.
·     Full intra AS—Calculation of all intra-AS prefixes.
·     Inc intra AS—Calculation of incremental intra-AS prefixes.
·     Full inter AS—Calculation of all AS-external prefixes.
·     Inc inter AS—Calculation of incremental AS-external prefixes.
·     Forward address—Forwarding address calculation.
Current route calculation phase:
·     Calculation area topology—Calculating area topology.
·     Calculation router—Calculating routes on routers.
·     Calculation intra AS—Calculating intra-AS routes.
·     7to5 translator—Calculating Type-7-to-Type-5 LSAs.
·     Forward address—Calculating forwarding addresses.
·     Calculation inter AS—Calculating AS-external routes.
·     Calculation end—Ending phase of calculation.
Process reset state
·     N/A—The process is not reset.
·     Under reset—The process is in the reset progress.
·     Under RIB smooth—The process is synchronizing the RIB.
Routing table
Total routes.
Intra area
Inter area
ASE/NSSA
Total ASE and NSSA routes.
Area
Area ID in the IP address format.
Area flag
Type of the area:
·     Normal.
·     Stub.
·     StubNoSummary (totally stub area).
·     NSSA.
·     NSSANoSummary (totally NSSA area).
7/5 translator state
State of the translator that translates Type-7 LSAs to Type-5 LSAs:
·     Enabled—The translator is specified through commands.
·     Elected—The translator is designated through election.
·     Disabled—The device is not a translator.
7/5 translate stability timer interval
Stability interval for Type-7 LSA-to-Type-5 LSA translation.
SPF scheduled count
SPF calculation count in the OSPF area.
Up interfaces
Up interfaces in the area.
display ospf
display ospf troubleshooting
Use display ospf troubleshooting to display OSPF neighbor relationship troubleshooting information.
# Display OSPF neighbor relationship troubleshooting information.
<Sysname> display ospf troubleshooting
                 OSPF troubleshooting Information
Total count: 3
Time                  Sequence  Description
2019-09-04 12:01:07   3         The state of OSPF 1 peer 12.1.1.2 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: GE1/0/6, peer address: 12.1.1.2).
2019-09-04 11:54:19   2         The state of OSPF 1 peer 12.1.1.2 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/6, peer address: 12.1.1.2; ping result: ping was not executed because of the disabled MTP; CPU usage: 29.0%; memory usage: 76.81%, memory state: normal).
2019-09-04 11:48:25   1         The state of OSPF 1 peer 12.1.1.2 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: GE1/0/6, peer address: 12.1.1.2).
Table 45 Command output
Total count
Total number of OSPF neighbor relationship troubleshooting entries.
Time
Time when the OSPF neighbor was disconnected. The most recent entry is displayed first.
Sequence
Sequence number of the OSPF neighbor relationship troubleshooting entry.
OSPF neighbor relationship troubleshooting information, including the OSPF process ID, neighbor ID, reason, and recommended action.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF interface parameters changed. Please check the interface parameters (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was reset.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF process was deleted.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the OSPF area was deleted.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF was disabled (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because OSPF packet receiving and sending are disabled (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface address was deleted or OSPF was disabled on interface. Please check the interface settings (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the interface went down or MTU changed. Please check the interface state and MTU settings (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link was deleted or the route it relies on was deleted. Please check the virtual link and the route it relies on (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the virtual link interface went down or the virtual link settings were deleted. Please check the virtual link and the route it relies on (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/6, peer address: 10.1.1.1; ping result: 5 packets in total, 5 packets timed out; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/6, peer address: 10.1.1.1; ping result: ping was not executed because of the disabled MTP; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the dead timer expired. Please check the connection to the peer (Interface: GE1/0/6, peer address: 10.1.1.1; ping result: waiting for the ping to execute; CPU usage: 25.37%; memory usage: 36.49%, memory state: normal).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the stub configuration changed in area 0.0.0.1.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the NSSA configuration changed in area 0.0.0.1.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the Opaque LSA capability configuration changed.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the out-of-band resynchronization capability configuration changed.
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because the BFD session went down. Please check the BFD session information.
·     The state of OSPF 1 peer 1.1.1.1 changed to INIT because a 1-way hello packet was received. Please check the OSPF peer state on the remote end. (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to DOWN because database-filter configuration changed or database-filter ACL configuration changed. Please check the OSPF database-filter and its ACL configuration (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a BadLSReq event was triggered upon the request for a nonexistent LSA. Please check the local OSPF LSDB and the OSPF request queue on the remote end (Interface: GE1/0/6, peer address: 10.1.1.1, LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is the same as that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: GE1/0/6, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because the LSA requested and then learned is older than that in local. Please check the OSPF request queue and the specified LSA on both ends (Interface: GE1/0/6, peer address: 10.1.1.1; LSA type: 5, LSID: 91.1.1.0, AdvRouter: 5.5.5.5).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a non-retransmitted DD packet from the Loading or Full peer during the DD retransmit interval. Please check the OSPF peer state and LSDB on the remote end (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to link-local signaling attribute. Please check the DD packets transmitted on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a retransmitted DD packet from the Loading or Full peer after the DD retransmit interval expired. Please check the OSPF peer state and LSDB on the remote end (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the change of the OSPF peer’s capability to receive AS external LSA. Please check the area configuration (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered by the master-slave relationship change. Please check the DD packets transmitted on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of an unexpected initial DD packet after DD transmission started. Please check the DD packets transmitted on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the slave. Please check the DD packets transmitted on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet with a wrong sequence number from the master. Please check the DD packets transmitted on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing local opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing area opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS opaque LSA without enabling the opaque capability. Please check the specified LSA on the remote end and the opaque capability configuration on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing NSSA external LSA in a non-NSSA area. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing invalid LSA. Please check the specified LSA on the remote end (Interface: GE1/0/6, peer address: 10.1.1.1).
·     The state of OSPF 1 peer 1.1.1.1 changed to EXSTART because a SeqNumberMismatch event was triggered upon the receipt of a DD packet containing AS external LSA in the stub area or on the virtual link. Please check the specified LSA on the remote end and the area configuration on both ends (Interface: GE1/0/6, peer address: 10.1.1.1).
reset ospf troubleshooting
display ospf vlink
Use display ospf vlink to display OSPF virtual link information.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPF virtual link information for all OSPF processes.
# Display OSPF virtual link information.
<Sysname> display ospf vlink
                  Virtual Links
 Virtual-link Neighbor-ID  -> 2.2.2.2, Neighbor-State: Full
 Interface: 10.1.2.1 (GigabitEthernet1/0/6)
 Cost: 1562  State: P-2-P  Type: Virtual
 Transit Area: 0.0.0.1
 Timers: Hello 10 , Dead 40 , Retransmit 5 , Transmit Delay 1
 Cryptographic authentication: Enabled, inherited
    The last key is 3.
    The rollover is in progress, 2 neighbor(s) left.
 MTID    Cost      Disabled    Topology name
 0       16777215  No          base
Table 46 Command output
ID of the neighbor on the virtual link.
Neighbor-State
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, Full.
IP address and name of the local interface on the virtual link.
Cost
Interface route cost.
Interface state.
Virtual link.
Transit Area
Transit area ID.
Timers
Values of timers (in seconds): Hello, Dead, and Retransmit.
Transmit Delay
LSA transmission delay on the interface, in seconds.
Simple authentication: Enabled, inherited
The virtual link uses the simple authentication mode. The inherited attribute indicates that the virtual link uses the authentication mode specified for the backbone area.
Cryptographic authentication mode (MD5, HMAC-MD5, or HMAC-SHA-256) is used by the virtual link.
The last key
Most recent MD5, HMAC-MD5, or HMAC-SHA-256 authentication key ID.
Key rollover for MD5, HMAC-MD5, or HMAC-SHA-256 authentication is in progress, and two neighbors have not completed the key rollover.
MTID
Cost
Cost of the interface route in the topology.
Disabled
Whether OSPF is disabled from advertising the topology for the virtual link: Yes or No.
Topology name
display router id
Use display router id to display the global router ID.
display router id
# Display the global router ID.
<Sysname> display router id
         Configured router ID is 1.1.1.1
distribute bgp-ls
Use distribute bgp-ls to advertise OSPF link state information to BGP.
Use undo distribute bgp-ls to restore the default.
distribute bgp-ls [ instance-id id ] [ strict-link-checking ]
OSPF link state information cannot be advertised to BGP.
OSPF view
instance-id id: Specifies an instance by its ID in the range of 0 to 65535. If you do not specify an instance, this command advertises OSPF link state information of instance 0 to BGP.
strict-link-checking: Enables strict checking on link state information advertised to BGP. If you specify this keyword, the IP addresses of the local and remote ends of a link must be in the same subnet. If you do not specify this keyword, the IP addresses of both ends can be in different subnets. This keyword applies only to P2P links.
After the device advertises OSPF link state information to BGP, BGP can advertise the information for intended applications.
If multiple OSPF processes have the same link state information and instance ID, only the link state information of the OSPF process with the smallest process ID is advertised.
To advertise the same link state information of different OSPF processes to BGP, specify a different instance ID for each OSPF process.
As a best practice, enable strict link state information checking when the following conditions exist:
·     The link state information advertised to BGP contains multiple equal-cost links.
·     The local and remote ends of each equal-cost link are in the same subnet.
With this feature enabled, error link state information is not advertised to BGP when the equal-cost links flap.
Strict link state information checking and prefix suppression are mutually exclusive. Before you enable strict link state information checking, make sure prefix suppression is disabled.
Strict link state information checking does not take effect when MPLS TE is enabled. For more information about MPLS TE, see MPLS TE configuration in MPLS Configuration Guide.
# Advertise link state information of OSPF process 1 to BGP.
[Sysname] ospf 1
[Sysname-ospf-1] distribute bgp-ls
dscp
Use dscp to set the DSCP value for outgoing OSPF packets.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value for outgoing OSPF packets is 48.
OSPF view
dscp-value: Specifies the DSCP value in the range of 0 to 63 for outgoing OSPF packets.
# Set the DSCP value for outgoing OSPF packets to 63 in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] dscp 63
enable link-local-signaling
Use enable link-local-signaling to enable the OSPF link-local signaling (LLS) capability.
Use undo enable link-local-signaling to disable the OSPF LLS capability.
OSPF link-local signaling capability is disabled.
OSPF view
# Enable link-local signaling for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable link-local-signaling
enable out-of-band-resynchronization
Use enable out-of-band-resynchronization to enable the OSPF out-of-band resynchronization (OOB-Resynch) capability.
Use undo enable out-of-band-resynchronization to disable the OSPF out-of-band resynchronization capability.
The OSPF out-of-band resynchronization capability is disabled.
OSPF view
Before you configure this command, enable the link-local signaling capability.
# Enable the out-of-band resynchronization capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] enable out-of-band-resynchronization
event-log
Use event-log to configure the OSPF logging feature.
Use undo event-log to remove the configuration.
event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | route | spf } size count
event-log lsa-history { asbr | ase | include-duplicate | link-state-id | network | nssa | opaque-area | opaque-as | opaque-link | originate-router advertising-router-id | router | size count | summary | verbose } *
undo event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | route | spf } size
undo event-log lsa-history
The device can generate a maximum of 100 logs for each type.
OSPF view
hello: Specifies the number of logs for received or sent hello packets.
received: Specifies the number of logs for received hello packets.
sent: Specifies the number of logs for sent hello packets.
abnormal: Specifies the number of logs for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies the number of logs for received hello packets that were dropped.
failed: Specifies the number of logs for hello packets that failed to be sent.
lsa-flush: Specifies the number of LSA aging logs.
peer: Specifies the number of neighbor logs.
route: Specifies the number of OSPF route logs.
spf: Specifies the number of route calculation logs.
size count: Specifies the number of OSPF logs, in the range of 0 to 65535.
lsa-history: Logs self-originated and received LSA information.
include-duplicate: Specifies all LSAs including duplicate LSAs. Duplicate LSAs refer to LSAs that carry the same options and contents.
verbose: Logs detailed information about self-originated and received LSAs. If you do not specify this keyword, the command logs brief information about self-originated and received LSAs.
asbr: Logs Type-4 LSA (ASBR Summary LSA) information.
ase: Logs Type-5 LSA (AS External LSA) information.
network: Logs Type-2 LSA (Network LSA) information.
nssa: Logs Type-7 LSA (NSSA External LSA) information.
opaque-area: Logs Type-10 LSA (Opaque-area LSA) information.
opaque-as: Logs Type-11 LSA (Opaque-AS LSA) information.
opaque-link: Logs Type-9 LSA (Opaque-link LSA) information.
router: Logs Type-1 LSA (Router LSA) information.
summary: Logs Type-3 LSA (Network Summary LSA) information.
originate-router advertising-router-id: Specifies an advertising router by its ID.
link-state-id: Specifies a link state ID in the IP address format.
# Set the number of route calculation logs to 50 in OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] event-log spf size 50
fast-reroute
Use fast-reroute to configure OSPF FRR.
Use undo fast-reroute to disable OSPF FRR.
fast-reroute { lfa [ abr-only | ecmp-shared ] | route-policy route-policy-name }
undo fast-reroute
OSPF FRR is disabled.
OSPF view
lfa: Uses the LFA algorithm to calculate backup next hops for each route.
abr-only: Uses the next hop of the route to the ABR as the backup next hop.
ecmp-shared: Calculates backup next hops through LFA calculation for all routes, including ECMP routes. ECMP routes share one backup next hop.
route-policy route-policy-name: Uses a routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
When both OSPF FRR and PIC are configured, OSPF FRR takes effect.
To calculate backup next hops through LFA calculation for ECMP routes, execute this command with the ecmp-shared keyword specified. The calculated backup next hops are issued into the RIB as ECMP routes. You can execute the display ip routing-table command to view detailed route information. A route whose state values include Backup in the command output is a backup route for an ECMP route.
With the ecmp-shared keyword specified, OSPF calculates a shared backup next hop through LFA calculation for ECMP routes. If all next hops of ECMP routes fail, OSPF uses the shared backup next hop to forward packets. After routing convergence is completed, the device re-generates ECMP routes to forward packets.
If you do not specify the ecmp-shared keyword, OSPF calculates backup next hops through LFA calculation only for non-ECMP routes.
# Enable FRR to calculate a backup next hop for all routes by using LFA algorithm in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa ecmp-shared
fast-reroute remote-lfa maximum-cost
Use fast-reroute remote-lfa maximum-cost to set the maximum cost from the source node of a protected link to a PQ node.
Use undo fast-reroute remote-lfa maximum-cost to restore the default.
fast-reroute remote-lfa maximum-cost cost
The maximum cost from the source node of a protected link to a PQ node is 4294967295.
OSPF view
cost: Specifies a cost value in the range of 1 to 4294967295.
The cost values from different PQ nodes to the source node of a specific protected link might be different. You can use this command to filter PQ nodes based on the cost value.
# Set the maximum cost from the source node of a protected link to a PQ node to 200.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa maximum-cost 200
fast-reroute remote-lfa prefix-list
Use fast-reroute remote-lfa prefix-list to specify a prefix list to filter remote LFA PQ nodes.
Use undo fast-reroute remote-lfa prefix-list to restore the default.
fast-reroute remote-lfa prefix-list prefix-list-name
Any PQ node can be selected as the backup next hop by remote LFA FRR.
OSPF view
prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters.
Multiple PQ nodes might reach the source node of a specific protected link. You can use this command to specify a prefix list to filter PQ nodes.
# Use prefix list test1 to filter remote LFA PQ nodes.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa prefix-list 1
ip prefix-list
fast-reroute remote-lfa tunnel ldp
Use fast-reroute remote-lfa tunnel ldp to enable OSPF remote LFA FRR.
Use undo fast-reroute remote-lfa tunnel ldp to disable OSPF remote LFA FRR.
OSPF remote LFA FRR is disabled.
OSPF view
Configure remote LFA FRR to prevent traffic loss caused by link or node failures.
Before configuring remote LFA FRR, you must perform the following tasks:
·     Use the mpls ldp command to enable MPLS LDP globally.
·     Use the mpls ldp enable command to enable MPLS LDP on all interfaces participating in MPLS forwarding.
·     Use the fast-reroute lfa command to enable LFA FRR for OSPF.
# Enable remote LFA FRR.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute remote-lfa tunnel ldp
fast-reroute
mpls ldp (MPLS Command Reference)
mpls ldp enable (MPLS Command Reference)
fast-reroute tiebreaker
Use fast-reroute tiebreaker to set the priority for FRR backup path selection policies.
Use undo fast-reroute tiebreaker to restore the default.
fast-reroute tiebreaker { lowest-cost | node-protecting | non-ecmp | srlg-disjoint } preference preference
undo fast-reroute tiebreaker { lowest-cost | node-protecting | non-ecmp | srlg-disjoint }
The priority values of the node protection, lowest cost, non-ECMP, and SRLG disjoint backup path selection policies are 40, 20, 15, and 10, respectively.
OSPF view
lowest-cost: Sets a priority value for the lowest cost backup path selection policy.
node-protecting: Sets a priority value for the node protection backup path selection policy.
non-ecmp: Sets a priority value for the non-ECMP backup path selection policy. This policy preferentially selects a non-load-balancing path in the network as a backup path.
srlg-disjoint: Sets a priority value for the SRLG disjoint backup path selection policy.
preference preference: Specifies a priority value in the range of 1 to 255. A higher value indicates a higher priority.
OSPF FRR uses specific policies for backup path calculation. This command defines the priority for the backup path selection policy. The higher the value, the higher the priority of the associated backup path selection policy. Changing the backup path selection policy priority can affect the backup path calculation result for OSPF FRR. The backup paths can provide node protection or link protection for traffic, or provide both node protection and link protection.
OSPF FRR supports the following backup path selection policies that are used to generate different topologies for backup path calculation:
·     Node protection—OSPF FRR performs backup path calculation after excluding the primary next hop node.
·     Lowest cost—OSPF FRR performs backup path calculation after excluding the direct primary link.
·     SRLG disjoint—When one link in the SRLG fails, the other links in the SRLG might also fail. If you use a link in this SRLG as the backup link for the faulty link, protection does not take effect. To avoid this issue, OSPF FRR excludes the local links in the same SRLG as the direct primary link and then performs backup path calculation.
For OSPF FRR, the SRLG disjoint policy depends on the node protection and lowest cost policies.
The non-ECMP backup path selection policy selects an optimal backup path from the backup paths calculated by using the node protection or lowest cost policy. This policy preferentially selects a non-load-balancing path as the optimal backup path.
If multiple backup path selection policies exist in an OSPF process, the policy with the highest priority is used to calculate the backup path. If the policy fails to calculate the backup path, the policy with the highest priority in the remaining policies is used. OSPF performs backup path calculation by using the node protection and lowest cost policies as follows:
·     If the node protection policy has higher priority and fails to calculate the backup path, OSPF uses the lowest cost policy to calculate the backup path. If the lowest cost policy still fails to calculate the backup path, reliability cannot be ensured upon primary link failure.
·     If the lowest cost policy has higher priority and fails to calculate the backup path, OSPF does not perform further backup path calculation with the node protection policy. Reliability cannot be ensured upon primary link failure.
In a multi-active and multi-backup scenario, multiple load balancing paths exist between the source node and the destination node. You can enable OSPF FRR to calculate a backup path separately for each load balancing path. By default, OSPF FRR preferentially selects the path with the lowest cost as the backup path when it uses the node protection or lowest cost policy for backup path calculation. OSPF FRR does not identify whether the selected backup path is a load balancing path, except in the following situations:
·     OSPF FRR uses the node protection policy to calculate backup paths. Only if the non-ECMP policy takes precedence over the node protection policy, OSPF FRR prefers non-load-balancing paths during backup path selection. If no non-load-balancing path exists, OSPF FRR selects a load balancing path as the backup path. If the lowest cost policy fails to calculate the backup path, OSPF FRR uses the lowest cost policy for further calculation.
·     OSPF FRR uses the lowest cost policy to calculate backup paths. Only if the non-ECMP policy takes precedence over the lowest cost policy, OSPF FRR prefers non-load-balancing paths during backup path selection. If no non-load-balancing path exists, OSPF FRR selects a load balancing path as the backup path. If the lowest cost policy fails to calculate the backup path, OSPF FRR does not use the node protection policy to calculate backup paths.
# Set the priority value of the node protection backup path selection policy to 100.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute tiebreaker node-protecting preference 100
fast-reroute
filter
Use filter to configure OSPF to filter inbound/outbound Type-3 LSAs on an ABR.
Use undo filter to disable Type-3 LSA filtering.
filter { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
Type-3 LSAs are not filtered.
OSPF area view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter inbound/outbound Type-3 LSAs.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Type-3 LSAs.
export: Filters Type-3 LSAs advertised to other areas.
import: Filters Type-3 LSAs advertised into the local area.
This command applies only to an ABR.
When you specify an ACL, follow these guidelines:
·     If the ACL does not exist or does not have any rules, the ABR does not filter Type-3 LSAs.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all Type-3 LSAs.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·     To deny or permit Type-3 LSAs with the specified link state ID, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny or permit Type-3 LSAs with the specified link state ID and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the link state ID of a Type-3 LSA and the destination keyword specifies the subnet mask of the LSA.
# Use IP prefix list my-prefix-list to filter inbound Type-3 LSAs. Use basic ACL 2000 to filter outbound Type-3 LSAs in OSPF Area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospf-100-area-0.0.0.1] filter 2000 export
filter-policy export
Use filter-policy export to configure OSPF to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [ bgp | direct | eigrp [ eigrp-as ] | { isis | ospf | rip } [ process-id ] | static | unr ]
undo filter-policy export [ bgp | direct | eigrp [ eigrp-as ] | { isis | ospf | rip } [ process-id ] | static | unr ]
OSPF does not filter redistributed routes.
OSPF view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter redistributed routes by destination address.
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
bgp: Filters redistributed BGP routes.
direct: Filters redistributed direct routes.
eigrp: Filters redistributed EIGRP routes.
eigrp-as: Specifies an EIGRP process by its number in the range of 1 to 65535. The default value is 1.
isis: Filters redistributed IS-IS routes.
ospf: Filters redistributed OSPF routes.
rip: Filters redistributed RIP routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default value is 1.
static: Filters redistributed static routes.
unr: Filters redistributed user network routes.
If you do not specify any parameters, this command filters all redistributed routes.
·     If the ACL does not exist or does not have any rules, OSPF does not filter redistributed routes.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all redistributed routes.
·     To deny or permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny or permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the destination address.
# Configure OSPF process 100 to filter redistributed routes by using basic ACL 2000.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 export
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16. Configure OSPF process 100 to filter redistributed routes by using advanced ACL 3000.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 export
import-route
filter-policy import
Use filter-policy import to configure OSPF to filter routes calculated using received LSAs.
Use undo filter-policy import to restore the default.
filter-policy { ipv4-acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
OSPF does not filter routes calculated using received LSAs.
OSPF view
ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999 to filter received routes by destination.
gateway prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes by next hop.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter received routes by destination.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
·     If the ACL does not exist or does not have any rules, OSPF does not filter calculated routes.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all calculated routes.
The filter-policy import command filters only routes computed by OSPF. Routes that fail to pass the filter are not added to the RIB.
To use an advanced ACL (with a number from 3000 to 3999) in the command or in the specified routing policy, configure the ACL in one of the following ways:
# Use basic ACL 2000 to filter received routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 2000 import
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16. Use ACL 3000 to filter received routes.
[Sysname] ospf 100
[Sysname-ospf-100] filter-policy 3000 import
graceful-restart
Use graceful-restart to enable OSPF GR.
Use undo graceful-restart to disable OSPF GR.
graceful-restart [ ietf | nonstandard ] [ global | planned-only ] *
OSPF GR is disabled.
OSPF view
ietf: Enables IETF GR.
nonstandard: Enables non-IETF GR.
global: Enables global GR. In global GR mode, a GR process can be completed only when all GR helpers exist. A GR process fails if a GR helper fails (for example, the interface connected to the GR helper goes down). If you do not specify this keyword, the command enables partial GR. In partial GR mode, a GR process can be completed if a GR helper exists.
planned-only: Enables only planned GR. If you do not specify this keyword, the command enables both planned GR and unplanned GR.
GR includes planned GR and unplanned GR.
·     Planned GR—Manually restarts OSPF by using the reset ospf process command or performs an active/standby process switchover by using the placement reoptimize command. Before OSPF restart or active/standby switchover, the GR restarter sends Grace-LSAs to GR helpers.
·     Unplanned GR—OSPF restarts or an active/standby switchover occurs because of device failure. Before OSPF restart or active/standby switchover, the GR restarter does not send Grace-LSAs to GR helpers.
Before enabling IETF GR for OSPF, enable Opaque LSA advertisement and reception with the opaque-capability enable command.
Before enabling non-IETF GR for OSPF, enable OSPF LLS with the enable link-local-signaling command and OOB-Resynch with the enable out-of-band-resynchronization command.
If you do not specify the nonstandard or ietf keyword, this command enables non-IETF GR for OSPF.
# Enable IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] opaque-capability enable
[Sysname-ospf-1] graceful-restart ietf
# Enable non-IETF GR for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart nonstandard
graceful-restart helper enable
Use graceful-restart helper enable to enable OSPF GR helper capability.
Use undo graceful-restart helper enable to disable OSPF GR helper capability.
OSPF GR helper capability is enabled.
OSPF view
planned-only: Enables only planned GR for the GR helper. If you do not specify this keyword, the command enables both planned GR and unplanned GR for the GR helper.
The planned-only keyword is available only for the IETF GR helper.
# Enable GR helper capability for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper enable
graceful-restart helper strict-lsa-checking
Use graceful-restart helper strict-lsa-checking to enable strict LSA checking capability for GR helper.
Use undo graceful-restart helper strict-lsa-checking to disable strict LSA checking capability for GR helper.
Strict LSA checking capability for GR helper is disabled.
OSPF view
When an LSA change on the GR helper is detected, the GR helper device exits the GR helper mode.
# Enable strict LSA checking capability for GR helper in OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart helper strict-lsa-checking
graceful-restart interval
Use graceful-restart interval to set the GR interval.
Use undo graceful-restart interval to restore the default.
The GR interval is 120 seconds.
OSPF view
interval: Specifies the GR interval in the range of 40 to 1800 seconds.
For GR restart to succeed, the value of the GR restart interval cannot be smaller than the maximum OSPF neighbor dead time of all the OSPF interfaces.
# Set the GR interval for OSPF process 1 to 100 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] graceful-restart interval 100
ospf timer dead
host-advertise
Use host-advertise to advertise a host route.
Use undo host-advertise to remove a host route.
host-advertise ip-address cost-value
undo host-advertise ip-address
No host route is advertised.
OSPF area view
ip-address: Specifies the IP address of a host.
cost-value: Specifies a cost for the route, in the range of 1 to 65535.
# Advertise host route 1.1.1.1 with a cost of 100.
[Sysname] ospf 100
[Sysname-ospf-100] area 0
[Sysname-ospf-100-area-0.0.0.0] host-advertise 1.1.1.1 100
hostname
Use hostname to enable the OSPF dynamic host name mapping feature.
Use undo hostname disable the OSPF dynamic host name mapping feature.
hostname [ host-name ]
undo hostname
The OSPF dynamic host name mapping feature is disabled.
OSPF view
host-name: Specifies the host name mapped to the router ID of the OSPF process, a case-sensitive string of 1 to 255 characters. If you do not specify this argument, the device name is mapped to the router ID of the OSPF process.
OSPF uses Type-10 LSAs and Type-11 LSAs to carry information about the dynamic host name attribute. Before using this command, make sure the opaque LSA reception and advertisement capability is enabled.
# Enable the dynamic host name mapping feature for OSPF process 1, and specify the host name mapped to the router ID as red.
[Sysname] ospf 1
[Sysname-ospf-1] hostname red
display ospf hostname-table
import-route
Use import-route to enable route redistribution.
Use undo import-route to disable route redistribution.
import-route bgp [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | static | unr } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
undo import-route { bgp | direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static | unr }
OSPF does not redistribute routes.
OSPF view
bgp: Redistributes BGP routes.
as-number: Redistributes routes in an AS specified by its number in the range of 1 to 4294967295. This argument applies only to the BGP protocol. If you do not specify this argument, this command redistributes all IPv4 EBGP routes. As a best practice, specify an AS number to prevent the system from redistributing excessive IPv4 EBGP routes.
direct: Redistributes direct routes.
eigrp: Redistributes EIGRP routes.
all-as: Redistributes routes from all EIGRP processes.
isis: Redistributes IS-IS routes.
ospf: Redistributes OSPF routes.
rip: Redistributes RIP routes.
process-id: Specifies a process ID of IS-IS, RIP, or OSPF, in the range of 1 to 65535. The default is 1.
static: Redistributes static routes.
unr: Redistributes user network routes. User network routes are generated by access devices for online users.
all-processes: Redistributes routes from all the processes of the IS-IS, RIP, or OSPF routing protocol.
allow-ibgp: Redistributes IBGP routes.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. If you do not specify this keyword, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a route cost in the range of 0 to 16777214.
inherit-cost: Uses the original cost of redistributed routes.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. If you do not specify this keyword, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit is set to 0. This keyword applies to NSSA routers.
route-policy route-policy-name: Specifies a routing policy to filter redistributed routes. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag for external LSAs, in the range of 0 to 4294967295. The default is 1.
type type: Specifies a cost type, 1 or 2. The default is 2.
This command redistributes routes destined for other ASs from another protocol. AS external routes include the following types:
·     Type-1 external routes—Have high credibility. The cost of Type-1 external routes is comparable with the cost of OSPF internal routes. The cost of a Type-1 external route equals the cost from the router to the ASBR plus the cost from the ASBR to the external route's destination.
·     Type-2 external routes—Have low credibility. OSPF considers the cost from the ASBR to the destination of a Type-2 external route is much bigger than the cost from the ASBR to an OSPF internal router. The cost of a Type-2 external route equals the cost from the ASBR to the Type-2 external route's destination.
The import-route command redistributes only active routes. To display information about active routes, use the display ip routing-table protocol command. The import-route command cannot redistribute default external routes.
The import-route bgp command redistributes only EBGP routes when the OSPF process runs on the public network.
The import-route bgp command redistributes both EBGP and IBGP routes when the OSPF process meets the following requirements:
·     The OSPF process runs on a VPN instance.
·     Routing loop detection is not disabled.
The import-route nssa-only command redistributes AS-external routes in Type-7 LSAs only into the NSSA area.
If you specify neither the cost nor the inherit-cost keyword, the cost of a redistributed route is 1.
When you execute the undo form of the command, per-process setting has higher priority than the all-processes setting.
The undo import-route eigrp all-as command can remove the configuration of the import-route eigrp all-as comand only. To remove the configuration of the import-route eigrp eigrp-as command, use the undo form of the command.
The undo import-route protocol all-processes command can remove the configuration of the import-route protocol all-processes comand only. To remove the configuration of the import-route protocol process-id command, use the undo form of the command.
# Redistribute routes from RIP process 40 and specify the type, tag, and cost as 2, 33, and 50 for redistributed routes.
[Sysname] ospf 100
[Sysname-ospf-100] import-route rip 40 type 2 tag 33 cost 50
default-route-advertise
vpn-instance-capability simple (MPLS Command Reference)
import-route no-inherit-tag
Use import-route no-inherit-tag to disable OSPF from inheriting the tags of redistributed routes.
Use undo import-route no-inherit-tag to allow OSPF to inherit the tags of redistributed routes.
OSPF inherits the tags of redistributed routes.
OSPF view
Application scenarios
Use this command to resolve routing loop issues in the scenario meeting the following conditions:
·     The CE is dual-homed (connecting to two PEs) and uses OSPF to exchange private network routes with the PEs.
·     One of the two PEs is an H3C device and the other PE is from another vendor.
When a PE redistributes BGP routes into OSPF and advertises them to the CE in a Type 5 or 7 LSA, it adds an external-route tag to the LSA. On receipt of the Type 5 or 7 LSAs advertised by the CE, the other PE compares the external-route tag in the LSA against the local external-route tag. If they are the same, the PE ignores the LSA to avoid routing loops. Since different vendors use different external route tagging mechanisms, the PE might add the LSA into its LSDB and perform route calculation based on the LSA, thus causing loops.
Operating mechanism
After redistributing a BGP route into OSPF, a PE adds an external route tag to the generated Type-5 or Type-7 LSA. If you do not execute the import-route no-inherit-tag command, OSPF selects a tag for the redistributed route as follows:
1.     Tag specified by using the apply tag command in a routing policy.
2.     Tag specified by the tag option of the import-route command.
3.     Tag carried by the external route.
4.     Tag specified by the route-tag command.
5.     If the BGP AS number is less than or equal to 65535, the first two bytes of the external-route tag value are fixed at 0xD000, and the following two bytes are the local BGP AS number. If the BGP AS number is greater than 65535, the external-route tag value is 0. For example, if the local BGP AS number is 100, the default external-route tag value in decimal notation is 3489661028, which is 0xD0000000 (3489660928 in decimal notation) plus 100.
After you execute the import-route no-inherit-tag command, OSPF is disabled from inheriting the tag carried by the redistributed route. To ensure consistency with the external route tagging mechanisms of other vendors, OSPF selects a tag for the redistributed route as follows:
Table 1 Tag specified by using the apply tag command in a routing policy.
6.     Tag specified by the tag option of the import-route command.
7.     Tag specified by the route-tag command.
8.     If the BGP AS number is less than or equal to 65535, the first two bytes of the external-route tag value are fixed at 0xD000, and the following two bytes are the local BGP AS number. If the BGP AS number is greater than 65535, the external-route tag value is 0. For example, if the local BGP AS number is 100, the default external-route tag value in decimal notation is 3489661028, which is 0xD0000000 (3489660928 in decimal notation) plus 100.
# Disable multi-instance OSPF process 100 from inheriting the tags of redistributed routes.
[Sysname] ospf 100 vpn-instance vpn1
[Sysname-ospf-100] import-route no-inherit-tag
apply tag (Layer 3—IP Routing Command Reference)
route-tag (Layer 3—IP Routing Command Reference)
isolate enable
Use isolate enable to enable OSPF isolation.
Use undo isolate enable to disable OSPF isolation.
isolate enable
undo isolate enable
OSPF isolation is disabled.
OSPF view
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate a device before upgrading it. OSPF isolation works as follows:
1.     After OSPF isolation is enabled for a device, OSPF increases the link cost in LSAs advertised by the device based on the following rules:
¡     The link cost in Type-1 LSAs (Router LSAs) is increased to 65535.
¡     The link cost in the following LSAs is increased to 16711680:
-     Type-3 LSAs (Network summary LSAs).
-     Type-5 LSAs (AS external LSAs).
-     Type-7 LSAs (NSSA external LSAs).
2.     Each neighbor of the device reselects an optimal route based on the LSAs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3.     After the maintenance, disable OSPF isolation on the device to restore its link cost and gracefully add it back to the network.
Both the isolate enable and stub-router external-lsa 16711680 summary-lsa 16711680 include-stub commands can isolate the device from the network.
When you execute both the isolate enable and stub-router commands, follow these restrictions and guidelines:
·     If you specify the external-lsa and summary-lsa keywords in the stub-router command, the higher one of the two link costs provided by the isolation feature and the stub router feature takes effect.
·     If the on-startup keyword is specified in the stub-router command, traffic forwarding path selection is affected only by the isolation feature when the stub router does not take effect.
# Isolate the device from the network in OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] isolate enable
stub-router
ispf enable
Use ispf enable to enable OSPF incremental SPF (ISPF).
Use undo ispf enable to disable OSPF ISPF.
ispf enable
undo ispf enable
OSPF ISPF is enabled.
OSPF view
Upon topology changes, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Disable ISPF for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo ispf enable
log-peer-change
Use log-peer-change to enable logging for OSPF neighbor state changes.
Use undo log-peer-change to disable logging for OSPF neighbor state changes.
log-peer-change
Logging for OSPF neighbor state changes is enabled.
OSPF view
This command enables output of OSPF neighbor state changes to the information center. The information center processes the logs according to user-defined output rules (whether and where to output logs). For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Disable logging for neighbor state changes for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] undo log-peer-change
lsa-arrival-interval
Use lsa-arrival-interval to set the LSA reception interval.
Use undo lsa-arrival-interval to restore the default.
lsa-arrival-interval maximum-interval [ minimum-interval [ incremental-interval ] ]
The maximum interval, incremental interval, and minimum interval are 1000 milliseconds, 500 milliseconds, and 500 milliseconds, respectively.
OSPF view
maximum-interval: Specifies the maximum LSA reception interval in the range of 0 to 10000 milliseconds.
minimum-interval: Specifies the minimum LSA reception interval in the range of 0 to 1000 milliseconds.
incremental-interval: Specifies the incremental LSA reception interval in the range of 0 to 5000 milliseconds.
An LSA is a duplicate of a previous LSA if they have the same LSA type, LS ID, and router ID. OSPF drops any duplicate LSAs within an LSA reception interval.
Operating mechanism
The default LSA reception interval settings are as follows:
·     The reception interval for the first LSA is 500 milliseconds.
·     The reception interval for the nth (n ≥ 2) LSA is 500 + (500 x 2n-2) milliseconds, and cannot exceed 1000 milliseconds.
·     OSPF drops duplicate LSAs received within an LSA reception interval.
You can use the lsa-arrival-interval command to adjust the LSA reception interval settings, and the configuration functions as follows:
·     If the lsa-arrival-interval maximum-interval command is executed:
¡     The values for the minimum-interval and incremental-interval arguments are both 0.
¡     The LSA reception interval is fixed at maximum-interval.
·     If the lsa-arrival-interval maximum-interval minimum-interval command is executed:
¡     The value for the incremental-interval argument is 0.
¡     The reception interval for the first LSA is minimum-interval.
¡     The reception interval for subsequent LSAs is maximum-interval.
·     If the lsa-arrival-interval maximum-interval minimum-interval incremental-interval command is executed:
¡     The reception interval for the nth (n ≥ 2) LSA is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
Recommended configuration
On a stable network that requires fast convergence, you can set the LSA reception interval to 0 for OSPF. In this way, OSPF can learn the changes of the topology or routes immediately.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum, minimum, and incremental LSA reception intervals to 2000 milliseconds, 100 milliseconds, and 300 milliseconds, respectively.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval 2000 100 300
lsa-generation-interval
lsa-arrival-interval suppress-flapping
Use lsa-arrival-interval suppress-flapping to suppress incoming LSAs during route flapping.
Use undo lsa-arrival-interval suppress-flapping to restore the default.
lsa-arrival-interval suppress-flapping delay-interval [ threshold threshold-value ]
Incoming LSAs are not suppressed during route flapping.
OSPF view
delay-interval: Specifies the suppression interval, which is the minimum interval for accepting instances of the same LSA during route flapping. The value range is 0 to 65535 seconds.
threshold threshold-value: Specifies the suppression trigger threshold as the number of route flaps. When the number of route flaps reaches the threshold, OSPF suppresses instances of the same LSA. The value range for the threshold-value argument is 3 to 100. The default value is 5.
Instances of an LSA have the same LSA type, LS ID, and originating router ID.
If OSPF receives multiple instances of the same LSA during the suppression interval, OSPF discards all the instances except the first one.
# Configure OSPF to suppress incoming LSAs after 10 route flaps, and set the LSA suppression interval to 5 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-arrival-interval suppress-flapping 5 threshold 10
Use lsa-generation-interval to set the OSPF LSA update interval.
Use undo lsa-generation-interval to restore the default.
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF view
maximum-interval: Specifies the maximum LSA update interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum LSA update interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the LSA update incremental interval in the range of 10 to 60000 milliseconds.
If network changes become frequent, bandwidth resources and router resources might be overconsumed. To avoid this issue, use this command to adjust the LSA update interval settings for OSPF.
Operating mechanism
The default LSA update interval settings are as follows:
·     The update interval for the first LSA is 50 milliseconds.
·     The update interval for the nth (n ≥ 2) LSA is 50 + (200 x 2n-2) milliseconds, and cannot exceed 5 seconds.
The lsa-generation-interval command functions as follows:
·     If the lsa-generation-interval maximum-interval command is executed:
¡     The LSA update interval is fixed at maximum-interval.
·     If the lsa-generation-interval maximum-interval minimum-interval command is executed:
¡     The update interval for the first LSA is minimum-interval.
¡     The update interval for subsequent LSAs is maximum-interval.
·     If the lsa-generation-interval maximum-interval minimum-interval incremental-interval command is executed:
¡     The update interval for the nth (n ≥ 2) LSA is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
# Set the maximum LSA update interval to 2 seconds, minimum interval to 100 milliseconds, and incremental interval to 100 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsa-generation-interval 2 100 100
lsa-generation-interval suppress-flapping
Use lsa-generation-interval suppress-flapping to suppress the update of LSAs during route flapping.
Use undo lsa-generation-interval suppress-flapping to restore the default.
lsa-generation-interval suppress-flapping delay-interval [ threshold threshold-value ]
The update of LSAs is not suppressed during route flapping.
OSPF view
delay-interval: Specifies the suppression interval, which is the minimum interval for generating LSAs during route flapping. The value range is 0 to 65535 seconds.
threshold threshold-value: Specifies the suppression trigger threshold as the number of route flaps. When the number of route flaps reaches the threshold, OSPF suppresses the update of LSAs. The value range for the threshold-value argument is 3 to 100. The default value is 5.
# Configure OSPF to suppress the LSA update after 10 route flaps, and set the suppression interval to 3 seconds.
[Sysname] ospf 1
[Sysname-ospf-1] lsa-generation-interval suppress-flapping 3 threshold 10
lsdb-overflow-interval
Use lsdb-overflow-interval to set the interval that OSPF exits overflow state.
Use undo lsdb-overflow-interval to restore the default.
The OSPF exit overflow interval is 300 seconds.
OSPF view
interval: Specifies the interval that OSPF exits overflow state, in the range of 0 to 2147483647 seconds.
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. In this state, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself to save system resources.
You can configure the interval that OSPF exits overflow state. An interval of 0 indicates that the timer is not started and OSPF does not exit overflow state.
# Set the OSPF exit overflow interval to 10 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-interval 10
lsdb-overflow-limit
Use lsdb-overflow-limit to set the upper limit of external LSAs in the LSDB.
Use undo lsdb-overflow-limit to restore the default.
lsdb-overflow-limit number
The number of external LSAs is not limited.
OSPF view
number: Specifies the upper limit of external LSAs in the LSDB, in the range of 1 to 1000000.
# Set the upper limit of external LSAs to 400000.
[Sysname] ospf 100
[Sysname-ospf-100] lsdb-overflow-limit 400000
maxage-lsa route-calculate-delay
Use maxage-lsa route-calculate-delay to set the delay for route calculation triggered by router LSAs with max age.
Use undo maxage-lsa route-calculate-delay to restore the default.
maxage-lsa route-calculate-delay delay-interval
The delay is 10 seconds for route calculation triggered by router LSAs with max age.
OSPF view
delay-interval: Specifies the delay for route calculation triggered by router LSAs with max age, in the range of 0 to 65535 seconds.
When a router receives a router LSA with max age, it immediately computes routes with the SPF algorithm rather than with the router LSA. During route flapping, such a route calculation can make the situation worse. You can use this command to suppress frequent route flaps by setting the routing calculation delay.
# Set the delay to 20 seconds for route calculation triggered by router LSAs with max age.
[Sysname] ospf 1
[Sysname-ospf-1] maxage-lsa route-calculate-delay 20
maximum load-balancing
Use maximum load-balancing to set the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of OSPF ECMP routes equals the maximum number of ECMP routes, which is configurable by using the max-ecmp-num command.
OSPF view
number: Specifies the maximum number of ECMP routes. No ECMP load balancing is available when the number is set to 1.
# Set the maximum number of ECMP routes to 2.
[Sysname] ospf 100
[Sysname-ospf-100] maximum load-balancing 2
metric-bandwidth advertisement enable
Use metric-bandwidth advertisement enable to enable OSPF to advertise link bandwidth information.
Use undo metric-bandwidth advertisement enable to disable OSPF from advertising link bandwidth information.
A device does not advertise link bandwidth information.
OSPF view
Perform this task to enable OSPF to advertise link bandwidth information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link bandwidth information.
If multi-area adjacency interfaces exist in areas of an OSPF process, the metric-bandwidth advertisement enable command in the process takes effect for all the multi-area adjacency interfaces.
# Enable OSPF process 1 to advertise link bandwidth information.
[Sysname] ospf 1
[Sysname-ospf-1] metric-bandwidth advertisement enable
distribute bgp-ls
ospf multi-area
metric-bandwidth suppression
Use metric-bandwidth suppression to set the suppression interval for OSPF to suppress link bandwidth information advertisement.
Use undo metric-bandwidth suppression to restore the default.
metric-bandwidth suppression timer timer-value
The suppression interval is 120 seconds for OSPF to suppress link bandwidth information advertisement.
OSPF view
timer timer-value: Specifies the suppression timer in the range of 0 to 600 seconds. To disable OSPF from suppressing link bandwidth information advertisement, set the timer to 0.
By suppressing link bandwidth information advertisement, you can prevent device resources from being over consumed due to frequent bandwidth changes.
Operating mechanism
Link bandwidth advertisement suppression works as follows:
·     The interface reports link bandwidth information to OSPF at negotiated intervals.
·     OSPF advertises link bandwidth information through BGP-LS at specified intervals. OSPF does not advertise link bandwidth information within the specified interval.
As a best practice, the suppression interval you specified should not be less than the Ethernet interface measurement interval. For more information about Ethernet interfaces, see Ethernet interface configuration in Interface Configuration Guide.
This command takes effect only after you enable link bandwidth information advertisement by executing the metric-bandwidth advertisement enable command.
If multi-area adjacency interfaces exist in areas of an OSPF process, the metric-bandwidth suppression command in the process takes effect for all the multi-area adjacency interfaces.
# Set the suppression interval to 100 seconds for OSPF process 1 to suppress link bandwidth information advertisement.
[Sysname] ospf 1
[Sysname-ospf-1] metric-bandwidth suppression timer 100
ospf multi-area
metric-delay advertisement enable
Use metric-delay advertisement enable to enable OSPF to advertise link delay information.
Use undo metric-delay advertisement enable to disable OSPF from advertising link delay information.
Link delay information advertisement is disabled.
OSPF view
Perform this task to enable OSPF to advertise link delay information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link delay information.
If multi-area adjacency interfaces exist in areas of an OSPF process, the metric-delay advertisement enable command in the process takes effect for all the multi-area adjacency interfaces.
# Enable OSPF process 1 to advertise link delay information.
[Sysname] ospf 1
[Sysname-ospf-1] metric-delay advertisement enable
distribute bgp-ls
metric-delay suppression
Use metric-delay suppression to configure the suppression settings for OSPF to suppress link delay information advertisement.
Use undo metric-delay suppression to restore the default.
metric-delay suppression timer timer-value percent-threshold percent-value absolute-threshold absolute-value
The suppression interval is 120 seconds, the suppression threshold for the delay variation ratio is 10%, and the suppression threshold for the absolute value of the delay variation is 1000 microseconds.
OSPF view
timer timer-value: Specifies the suppression interval in the range of 0 to 600 seconds. When the suppression is disabled, the interval is 0.
percent-value: Specifies the suppression threshold for the link delay variation ratio in the range of 0 to 100%. If this argument is unnecessary, you can set it to 0.
absolute-value: Specifies the suppression threshold for the absolute value of the link delay variation in the range of 0 to 10000 microseconds. If this argument is unnecessary, you can set it to 0.
By suppressing link delay information advertisement, you can prevent device resources from being over consumed due to frequent link delay changes.
Operating mechanism
Link delay advertisement suppression works as follows:
·     The interface reports link delay information to OSPF at the specified interval.
·     OSPF advertises link delay information through BGP-LS at intervals specified by the timer-value argument. OSPF does not advertise link delay information within the specified interval except for the following conditions:
¡     The variation ratio between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the delay variation ratio.
¡     The absolute value of the difference between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the absolute value of the delay variation.
This command takes effect only when you execute the metric-delay advertisement enable command.
As a best practice, the  suppression interval you specified should not be less than the NQA measurement interval. For more information about NQA, see NQA configuration in Network Management and Monitoring Configuration Guide.
If multi-area adjacency interfaces exist in areas of an OSPF process, the metric-delay suppression command in the process takes effect for all the multi-area adjacency interfaces.
# For OSPF process 1 to suppress link delay information advertisement, set the following parameters:
·     Suppression interval: 100 seconds.
·     Suppression threshold for the link delay variation ratio: 50%.
·     Suppression threshold for the absolute value of the link delay variation: 200 microseconds.
[Sysname] ospf 1
[Sysname-ospf-1] metric-delay suppression timer 100 percent-threshold 50 absolute-threshold 200
ospf multi-area
network
Use network to enable OSPF on the interface attached to the specified network in the area.
Use undo network to disable OSPF for the interface attached to the specified network in the area.
undo network ip-address wildcard-mask
OSPF is not enabled for any interface.
OSPF area view
ip-address: Specifies the IP address of a network.
wildcard-mask: Specifies the wildcard mask of the IP address. For example, the wildcard mask of mask 255.0.0.0 is 0.255.255.255.
This command enables OSPF on the interface attached to the specified network. The interface's primary IP address must be in the specified network. If only the interface's secondary IP address is on the network, the interface cannot run OSPF.
# Specify the interface whose primary IP address is on network 131.108.20.0/24 to run OSPF in Area 2.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] network 131.108.20.0 0.0.0.255
ospf
non-stop-routing
Use non-stop-routing to enable OSPF NSR.
Use undo non-stop-routing to disable OSPF NSR.
non-stop-routing
OSPF NSR is disabled.
OSPF view
This command takes effect only for the current process. As a best practice, enable OSPF NSR for each process if multiple OSPF processes exist.
# Enable NSR for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] non-stop-routing
nssa
Use nssa to configure an area as an NSSA area.
Use undo nssa to restore the default.
In OSPF area view:
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
undo nssa [ default-route-advertise [ cost | nssa-only | route-policy | type ] * | no-import-route | no-summary | suppress-fa | [ translate-always | translate-never ] | translator-stability-interval ] *
No area is configured as an NSSA area.
OSPF area view
default-route-advertise: Used on an NSSA ABR or an ASBR only. With this keyword, an NSSA ABR redistributes a default route in a Type-7 LSA into the NSSA area. The ABR redistributes a default route regardless of whether a default route exists in the routing table. With this keyword, an ASBR redistributes a default route in a Type-7 LSA only when the default route exists in the routing table.
cost cost-value: Specifies a cost for the default route, in the range of 0 to 16777214. If you do not specify this option, the default cost specified by the default-cost command applies.
nssa-only: Limits the default route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. By default, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit is set to 0.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When a default route exists in the routing table and the routing policy is matched, the command redistributes a default route in a Type-7 LSA into the OSPF routing domain. The routing policy modifies values in the Type-7 LSA.
type type: Specifies a type for the Type-7 LSA, 1 or 2. If you do not specify this option, the default type specified by the default type command applies.
no-import-route: Used on an NSSA ABR to control the import-route command to not redistribute routes into the NSSA area.
no-summary: Used only on an ABR to advertise a default route in a Type-3 summary LSA into the NSSA area and to not advertise other summary LSAs into the area. The area is a totally NSSA area.
suppress-fa: Suppresses the forwarding address in the Type-7 LSAs from being placed in the Type-5 LSAs.
translate-always: Always translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
translate-ignore-checking-backbone: Ignores checking for FULL state neighbors in the backbone area during the translator election in the NSSA area.
translate-never: Never translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
translator-stability-interval value: Specifies the stability interval of the translator. During the interval, the translator can maintain its translating capability after another device becomes the new translator. The value argument is the stability interval in the range of 0 to 900 seconds and defaults to 0. A value of 0 means the translator does not maintain its translating capability when a new translator arises.
All routers attached to an NSSA area must be configured with the nssa command in area view.
If you specify the translate-ignore-checking-backbone keyword for an ABR, you must also specify the keyword for other ABRs in the NSSA area. This ensures that a translator can be elected among the ABRs.
# Configure Area 1 as an NSSA area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] nssa
default-cost
Use opaque-capability enable to enable opaque LSA advertisement and reception.
Use undo opaque-capability to disable opaque LSA advertisement and reception.
The feature is enabled.
OSPF view
After the opaque LSA advertisement and reception capability is enabled, OSPF can receive and advertise Type-9, Type-10, and Type-11 opaque LSAs.
To disable this capability, make sure the following requirements are met:
·     The OSPF dynamic host name mapping feature is disabled.
·     The OSPF process is not enabled with the IETF standard GR capability.
# Disable opaque LSA advertisement and reception.
[Sysname] ospf 100
[Sysname-ospf-100] undo opaque-capability
hostname
graceful-restart
ospf
Use ospf to enable OSPF and enter OSPF view.
Use undo ospf to disable OSPF.
ospf [ process-id | router-id { auto-select | router-id } | vpn-instance vpn-instance-name ] *
undo ospf [ process-id ] [ router-id ]
OSPF is disabled.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535.
router-id: Specifies an OSPF router ID. If you do not specify an OSPF router ID, the global router ID is used.
auto-select: Automatically obtains an OSPF router ID.
router-id: Manually specifies an OSPF router ID in dotted decimal notation. The value range is from 0.0.0.1 to 255.255.255.255.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the OSPF process runs on the public network.
You can enable multiple OSPF processes on a router and specify different router IDs for them.
Enable an OSPF process before performing other tasks.
If you specify the auto-select keyword, the OSPF process obtains a router ID in the following ways:
·     During the startup of the OSPF process, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
·     During the reboot of the router, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
·     During the restart of the OSPF process, the highest primary IPv4 address of the loopback interface that runs the process is specified as the router ID. If no loopback address is available, the highest primary IPv4 address of the interface that runs the process is used, regardless of the interface state (up or down).
If you do not specify the router-id keyword, the undo ospf command shuts down an OSPF process. If you specify the router-id keyword, the undo ospf command specifies the global router ID as the router ID. The setting takes effect after the OSPF process restarts.
# Enable OSPF process 100 and specify router ID 10.10.10.1.
[Sysname] ospf 100 router-id 10.10.10.1
[Sysname-ospf-100]
ospf area
Use ospf area to enable OSPF on an interface.
Use undo ospf area to disable OSPF on an interface.
undo ospf process-id area [ exclude-subip ]
OSPF is not enabled on an interface.
Interface view
area-id: Specifies an area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format.
exclude-subip: Excludes secondary IP addresses. If you do not specify this keyword, the command enables OSPF also on secondary IP addresses.
The ospf area command has a higher priority than the network command.
If the specified process and area do not exist, the command creates the process and area. Disabling an OSPF process on an interface does not delete the OSPF process or the area.
# Enable OSPF process 1 on GigabitEthernet 1/0/7 that is in Area 2 and exclude secondary IP addresses.
[Sysname] interface gigabitethernet 1/0/7
[Sysname-GigabitEthernet1/0/7] ospf 1 area 2 exclude-subip
network
ospf authentication-mode
Use ospf authentication-mode to set the authentication mode and key on an interface.
Use undo ospf authentication-mode to remove specified configuration.
For MD5/HMAC-MD5/HMAC-SHA-256 authentication:
ospf authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
undo ospf authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id
For simple authentication:
ospf authentication-mode simple { cipher | plain } string
undo ospf authentication-mode simple
No authentication is performed for an interface.
Interface view
hmac-md5: Specifies HMAC-MD5 authentication.
hmac-sha-256: Specifies HMAC-SHA-256 authentication.
md5: Specifies MD5 authentication.
simple: Specifies simple authentication.
key-id: Specifies a key by its ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
·     In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
·     In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
·     In HMAC-SHA-256 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
To establish or maintain adjacencies, interfaces attached to the same network segment must have the same authentication mode and key.
If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string. To minimize the risk of key compromise, use only one key for an interface and delete the old key after key replacement.
To replace the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication on an interface, you must configure the new key before removing the old key from each router. OSPF uses the key rollover mechanism to ensure that the routers can pass authentication before the replacement is complete on the interface. After you configure a new key on a router, the router sends copies of the same packet, each authenticated by a different key, including the new key and the keys in use. This practice continues until the router detects that all its neighbors have the new key.
# On GigabitEthernet 1/0/6, enable MD5 authentication, and set the interface key ID to 15 and the key to 123456 in plaintext form.
[Sysname] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] ospf authentication-mode md5 15 plain 123456
# On GigabitEthernet 1/0/6, enable simple authentication, and set the key to 123456 in plaintext form.
[Sysname-GigabitEthernet1/0/6] ospf authentication-mode simple plain 123456
authentication-mode
ospf bfd adjust-cost
Use ospf bfd adjust-cost to enable OSPF to adjust the interface cost according to the BFD session state.
Use undo ospf bfd adjust-cost to restore the default.
ospf bfd adjust-cost { cost-offset | max }
OSPF does not adjust the link cost according to the BFD session state.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the BFD session goes down. The value range for this argument is 1 to 65534. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost, and cannot exceed 65535.
max: Sets the interface cost to the maximum value 65535 when the BFD session goes down.
After you enable BFD for OSPF, the OSPF neighbor relationship goes down when the BFD session is down and comes up when the BFD session is up. When the BFD session state changes frequently, OSPF neighbor relationship flapping will occur and traffic forwarding might be affected.
To resolve this issue, enable OSPF to adjust the interface cost according to the BFD session state.
Operating mechanism
After you execute this command on an interface, OSPF adjusts the interface cost as follows:
·     When the BFD session on the interface goes down, OSPF increases the cost value for the interface.
·     When the BFD session on the interface comes up, OSPF restores the cost value for the interface.
The ospf bfd adjust-cost command does not take effect for multi-area adjacency interfaces.
# Enable OSPF to adjust the cost of interface GigabitEthernet 1/0/6 according to the BFD session state, and set the value to be added to the interface cost to 100.
[Sysname-GigabitEthernet1/0/6] ospf bfd enable
[Sysname-GigabitEthernet1/0/6] ospf bfd adjust-cost 100
display ospf interface
ospf bfd enable
ospf multi-area
ospf bfd adjust-cost suppress-flapping
Use ospf bfd adjust-cost suppress-flapping to suppress adjustment of the interface cost according to the BFD session state upon BFD session flapping.
Use undo ospf bfd adjust-cost suppress-flapping to restore the default.
ospf bfd adjust-cost suppress-flapping { detect-interval detect-interval | resume-interval resume-interval | threshold threshold } *
undo ospf bfd adjust-cost suppress-flapping [ detect-interval | resume-interval | threshold ] *
OSPF does not suppress adjustment of the interface cost according to the BFD session state upon BFD session flapping.
Interface view
detect-interval detect-interval: Specifies the interval at which OSPF detects BFD session state changes, in the range of 1 to 600 seconds. The default value is 60.
resume-interval resume-interval: Specifies the delay timer before OSPF resumes the original interface cost, in the range of 0 to 600 seconds. The default value is 0.
threshold threshold: Specifies the maximum number of BFD session down events, in the range of 1 to 100. The default value is 1.
After you enable OSPF to adjust the interface cost according to the BFD session state, if BFD session flaps frequently, the following conditions might occur:
·     The OSPF interface cost changes frequently, resulting in repeated route calculations that greatly consume device resources.
·     When the BFD session state changes from down to up, OSPF immediately resumes the original interface cost. If the link becomes unavailable again in a short time, packet loss will occur on this link before route convergence.
Operating mechanism
You can configure this feature to address the previous issues. When the BFD session state changes, OSPF performs the following operations instead of immediately adjusting the interface cost:
·     When the BFD session state changes from up to down, OSPF starts a BFD session state detection timer, and records one BFD session down event. If the number of BFD session down events crosses the threshold within the detection interval, OSPF adjusts the interface cost based on configuration of the ospf bfd adjust-cost command. (The threshold is specified with the threshold keyword. The detection interval is specified with the detect-interval argument.) If this condition is not met, OSPF does not adjust the interface cost.
·     After OSPF adjusts the interface cost (based on the configuration of the ospf bfd adjust-cost command), it starts a delay timer when the BFD session state changes from down to up. Before expiration of the delay timer (specified with the resume-interval argument), the following conditions will occur:
¡     If the BFD session remains up, OSPF resumes the original interface cost when the delay timer expires.
¡     If the BFD session state changes from up to down, OSPF deletes the delay timer and does not resume the original interface cost.
Follow these restrictions and guidelines when you configure this command:
·     This command takes effect only after you configure the ospf bfd adjust-cost command.
·     You can repeat this command to edit the settings for the detect-interval, threshold, resume-interval keywords. Upon modification, the detection timer (detect-interval), delay timer (resume-interval), and threshold counter (threshold) will restart.
The ospf bfd adjust-cost suppress-flapping command does not take effect for multi-area adjacency interfaces.
# Suppress adjustment of the cost for interface GigabitEthernet 1/0/6 according to the BFD session state upon BFD session flapping. Set the BFD session state detection timer to 60 seconds, threshold to 10, and delay timer to 10 seconds.
[Sysname-GigabitEthernet1/0/6] ospf bfd adjust-cost suppress-flapping detect-interval 60 threshold 10 resume-interval 10
ospf bfd enable
ospf multi-area
ospf bfd enable
Use ospf bfd enable to enable BFD on an OSPF interface.
Use undo ospf bfd enable to disable BFD on an OSPF interface.
ospf bfd enable [ echo ]
BFD for OSPF is disabled.
Interface view
echo: Enables BFD single-hop echo detection. If you do not specify this keyword, the command enables BFD bidirectional control detection.
OSPF sends hello packets to neighbors at specific intervals to detect their state. If OSPF does not receive a hello packet from a neighbor within a specific period, OSPF considers the neighbor stale. Such a failure detection method cannot achieve high data reliability, because it takes a long time and causes data loss.
To resolve this issue, configure Bidirectional Forwarding Detection (BFD) for OSPF. This feature improves the route convergence speed against link state changes through fast link state detection.
After you enable BFD for an OSPF interface, it establishes BFD sessions only with neighbors in Full state.
A multi-area adjacency interface can establish neighbor relationships with devices in different areas. In this case, the following rules apply:
·     OSPF establishes the BFD session when the first neighbor relationship enters Full state.
·     OSPF deletes the BFD session only after all neighbor relationships enter Down state.
When the BFD session goes down, all OSPF neighbor relationships of the interface are torn down.
# Enable BFD for OSPF on GigabitEthernet 1/0/6.
ospf cost
Use ospf cost to set an OSPF cost for an interface.
Use undo ospf cost to restore the default.
ospf cost cost-value
undo ospf cost
An interface computes its OSPF cost according to the interface bandwidth. For a loopback interface, the cost is 0.
Interface view
cost-value: Specifies an OSPF cost in the range of 0 to 65535 for a loopback interface, and in the range of 1 to 65535 for other interfaces.
If you do not execute this command, the interface automatically computes its OSPF cost.
# Set the OSPF cost on GigabitEthernet 1/0/6 to 65.
[Sysname-GigabitEthernet1/0/6] ospf cost 65
bandwidth-reference
ospf cost-fallback
Use ospf cost-fallback to change the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold.
Use undo ospf cost-fallback to remove the configuration.
ospf cost-fallback cost-value threshold bandwidth-value
A Layer 3 aggregate interface uses the original link cost.
cost-value: Specifies a link cost in the range of 1 to 65535. As a best practice, set the link cost to a value higher than the original link cost of the interface.
threshold bandwidth-value: Specifies the bandwidth threshold in the range of 1 to 4294967295 Mbps.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, execute this command to change the link cost of a Layer 3 aggregate interface as follows:
·     When the bandwidth of the Layer 3 aggregate interface falls below the bandwidth threshold, the aggregate interface uses the specified link cost. Then, OSPF can select an optimal path for traffic forwarding.
·     When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original link cost.
# Change the link cost of interface Route-Aggregation 1 to 100 when its bandwidth falls below 300 Mbps.
[Sysname] interface Route-Aggregation 1
[Sysname-Route-Aggregation1] ospf cost-fallback 100 threshold 300
ospf database-filter
Use ospf database-filter to filter outbound LSAs on an interface.
Use undo ospf database-filter to restore the default.
ospf database-filter { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
The outbound LSAs are not filtered on the interface.
Interface view
all: Filters all outbound LSAs except the Grace LSAs.
ase: Filters outbound Type-5 LSAs.
nssa: Filters outbound Type-7 LSAs.
summary: Filters outbound Type-3 LSAs.
acl ipv4-acl-number: Specifies an IPv4 ACL by its number in the range of 2000 to 3999.
When multiple links exist between two devices, you can filter outbound LSAs on interfaces to reduce the number of LSAs sent to neighbors. This reduces the size of neighbor LSDBs and improves network convergence speed.
When you specify an ACL, follow these guidelines:
·     If the ACL does not exist or does not have any rules, OSPF does not filter outbound LSAs.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all outbound LSAs.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·     To deny or permit LSAs with the specified link state ID, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny or permit LSAs with the specified link state ID and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the link state ID of an LSA and the destination keyword specifies the subnet mask of the LSA.
If the neighbor has already received an LSA to be filtered, the LSA still exists in the LSDB of the neighbor after you execute the command.
The ospf database-filter command does not take effect for multi-area adjacency interfaces. LSA filtering is not available in multi-area adjacency scenarios.
# Filter all outbound LSAs (except the Grace LSAs) on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf database-filter all
# On GigabitEthernet 1/0/7, configure ACL 2000, 2100, and 2200 to filter outbound Type-5, Type-7, and Type-3 LSAs, respectively.
[Sysname-GigabitEthernet1/0/7] ospf database-filter ase acl 2000 nssa acl 2100 summary acl 2200
database-filter peer
ospf multi-area
ospf dr-priority
Use ospf dr-priority to set the router priority for DR/BDR election on an interface.
Use undo ospf dr-priority to restore the default value.
ospf dr-priority priority
The router priority is 1.
Interface view
priority: Specifies the router priority for the interface, in the range of 0 to 255.
The greater the value, the higher the priority for DR/BDR election. If a device has a priority of 0, it will not be elected as a DR or BDR.
# Set the router priority on GigabitEthernet 1/0/6 to 8.
[Sysname-GigabitEthernet1/0/6] ospf dr-priority 8
ospf fast-reroute lfa-backup
Use ospf fast-reroute lfa-backup to enable LFA on an interface.
Use undo ospf fast-reroute lfa-backup to disable LFA on an interface.
LFA is enabled on an interface.
Interface view
An interface enabled with LFA can be selected as a backup interface. After you disable LFA on the interface, it cannot be selected as a backup interface.
The ospf fast-reroute lfa-backup command does not take effect for multi-area adjacency interfaces.
# Disable GigabitEthernet 1/0/6 from calculating a backup next hop by using the LFA algorithm.
[Sysname-GigabitEthernet1/0/6] undo ospf fast-reroute lfa-backup
ospf fast-reroute remote-lfa disable
Use ospf fast-reroute remote-lfa disable to disable remote LFA calculation on an interface.
Use undo ospf fast-reroute remote-lfa disable to enable remote LFA calculation on an interface.
Remote LFA calculation is enabled on an interface.
Interface view
Use this command to disable remote LFA calculation on an interface to prevent it from participating in the calculation.
The ospf fast-reroute remote-lfa disable command does not take effect for multi-area adjacency interfaces.
# Disable remote LFA calculation on interface GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf 1 area 0
[Sysname-GigabitEthernet1/0/6] ospf fast-reroute remote-lfa disable
ospf multi-area
ospf link-delay
Use ospf link-delay to configure link delay settings on an OSPF interface.
Use undo ospf link-delay to remove link delay settings on an OSPF interface.
ospf link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } *
undo ospf link-delay [ average | min | variation ]
No link delay settings are configured on an OSPF interface.
Interface view
average average-delay-value: Specifies the average link delay on an interface in the range of 1 to 16777215 microseconds. The average-delay-value parameter represents the average link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the average link delay reported by the interface.
min min-delay-value max max-delay-value: Specifies the minimum and maximum link delays on an interface in the range of 1 to 16777215 microseconds. The min-delay-value parameter represents the minimum link delay for the interface to send a packet to its directly-connected peer. The max-delay-value parameter represents the maximum link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the minimum and maximum link delays reported by the interface will be used.
variation variation-value: Sets the acceptable delay variation on an interface in the range of 1 to 16777215 microseconds. The variation-value parameter represents the difference between two consecutive average link delays. If you do not specify this option, the delay variation value is the variation reported by the interface.
Perform either of the following tasks to obtain link delay information of an interface:
·     Static configuration—Execute the ospf link-delay command to manually configure link delay parameters on the interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link delay information to the interface, and the interface will report the link delay information to OSPF at periodic intervals. For more information about TWAMP, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
For an instance, the ospf link-delay command takes precedence over the test-session bind interface command.
The specified minimum link delay must be lower than the maximum link delay.
# Set the average link delay, minimum link delay, maximum link delay, and acceptable link delay variation to 100, 10, 1000, and 20 microseconds, respectively.
[Sysname-GigabitEthernet1/0/6] ospf link-delay average 100 min 10 max 1000 variation 20
test-session bind interface (Network Management and Monitoring Command Reference)
ospf link-quality adjust-cost
Use ospf link-quality adjust-cost to enable link quality-based interface cost adjustment for OSPF and set the cost adjustment value.
Use undo ospf link-quality adjust-cost to disable link quality-based interface cost adjustment for OSPF.
ospf link-quality adjust-cost { cost-offset | max }
OSPF does not adjust the interface cost according to the link quality.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the link quality changes to LOW. The value range for this argument is 1 to 65534. When the link quality changes to LOW, the interface cost is cost-offset plus the original interface cost, and cannot exceed 65535.
max: Sets the interface cost to the maximum value 65535 when the link quality changes to LOW.
If the device forwards OSPF packets along low-quality links, slow packet transmission and packet loss might occur. To minimize the impact of low-quality links on the OSPF network, you can enable OSPF to adjust the interface cost according to the link quality.
The following items affect the quality level of links:
·     Error codes—Error codes refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption. The link quality detection module adjusts the quality level of links based on the bit error ratio. For more information about bit errors, see error code detection configuration in High Availability Configuration Guide.
·     Card health—The health of a card is downgraded when the card fails. The link quality detection module adjusts the quality level of links based on the card health. For more information about hardware failure detection, see device management configuration in Fundamentals Configuration Guide.
Operating mechanism
After you configure this command on an interface, OSPF adjusts the interface cost as follows:
·     When the link quality detection module detects that the link quality of the interface becomes poor, the module performs the following operations:
¡     Changes the link quality level from GOOD to LOW.
¡     Reports an error code event to the OSPF module.
Upon receiving the error code event, OSPF increases the cost value for the interface.
·     When the link quality detection module detects that the link quality of the interface restores to GOOD, the module performs the following operations:
¡     Changes the link quality level from LOW to GOOD.
¡     Reports an error code clearing event to the OSPF module.
Upon receiving the error code clearing event, OSPF restores the cost value for the interface to the original value.
This interface cost adjustment mechanism enables OSPF to select good-quality forwarding links, minimizing the impact of low-quality links on the OSPF network.
This feature affects the route selection results on only one side, because it only adjusts the cost values for interfaces on the local device.
# Enable OSPF to adjust the cost of interface GigabitEthernet 1/0/6 according to the link quality, and set the value to be added to the interface cost to 200.
[Sysname-GigabitEthernet1/0/6] ospf link-quality adjust-cost 200
ospf lsu-flood-control
Use the ospf lsu-flood-control to enable OSPF to limit the LSU packet transmission rate of the device.
Use undo ospf lsu-flood-control to restore the default.
ospf lsu-flood-control { interval max-count-value | disable }
OSPF limits the LSU flooding rate of the whole device.
interval: Specifies the interval at which OSPF sends LSU packets, in milliseconds. The value range for this argument is 10 to 1000.
max-count-value: Specifies the maximum number of LSU packets that OSPF can send at each interval. The value range for this argument is 10 to 50000.
disable: Disables OSPF from limiting the LSU packet transmission rate.
OSPF might send a large number of LSU packets during LSDB synchronization with neighbors (especially when the local device establishes has many OSPF neighbors). In this situation, the neighbors are so busy with processing the received LSU packets that they might drop hello packets, causing neighbor relationship termination. To re-establish the neighbor relationships, the devices must exchange a larger number of LSU packets with neighboring devices, which worsens the issue.
To avoid the issue, use this command to set the maximum LSU transmission rate on the device. The LSU packet transmission rate of each OSPF interface on the device will be limited.
Operating mechanism
After you configure the ospf lsu-flood-control interval max-count-value command, the maximum LSU packet transmission rate for each OSPF interface is X/N, rounded down. N is the total number of OSPF interfaces on the device, and X is the maximum LSU packet transmission rate specified by this command. Each OSPF interface running in an OSPF process should transmit LSU packets at a rate that is not larger than X/N. OSPF limits the LSU packet transmission rate of the OSPF process as follows:
·     If the total LSU packet transmission rate of the OSPF process exceeds the upper limit specified by the transmit-pacing command, the system performs the following operations:
a.     Within the interval specified by the interval argument of the transmit-pacing command, the system no longer processes the LSU packet transmission requests initiated by the process.
b.     After the specified interval, if the process still has LSU packets to transmit, the system processes LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
·     If the total LSU packet transmission rate in the OSPF process does not exceed the upper limit specified by the transmit-pacing command, the system processes the subsequent LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
The above mechanism can limit the LSU packet transmission rate of the whole device and evenly process the LSU packet transmission requests of OSPF processes.
Recommended Configuration
Configure the LSU packet transmission rate with caution, because inappropriate configuration might cause route anomalies. As a best practice in most cases, use the default setting.
# Enable OSPF to limit the LSU packet transmission rate of the device and set the maximum LSU packet transmission rate to 60 LSU packets per 40 milliseconds.
[Sysname] ospf lsu-flood-control 40 60
transmit-pacing
ospf mib-binding
Use ospf mib-binding to bind an OSPF process to MIB.
Use undo ospf mib-binding to restore the default.
ospf mib-binding process-id
MIB is bound to the OSPF process with the smallest process ID.
To access information or data about an OSPF process in RFC4750-OSPF.MIB, use this command. To access information or data about an OSPF process in a Comware MIB for the device, you do not need to use this command. You can access information or data about all OSPF processes in the Comware MIBs.
If the specified process ID does not exist, a notification is displayed to report that the MIB binding configuration has failed.
Deleting an OSPF process that has been bound to MIB unbinds the OSPF process from MIB, and re-binds MIB to the OSPF process with the smallest process ID.
If multi-area adjacency interfaces exist in an OSPF process, MIB cannot obtain information about multi-area adjacency interfaces after the process is bound to MIB.
# Bind OSPF process 100 to MIB.
[Sysname] ospf mib-binding 100
ospf multi-area
ospf mtu-enable
Use ospf mtu-enable to enable an interface to add the interface MTU into DD packets.
Use undo ospf mtu-enable to restore the default.
ospf mtu-enable
The MTU in DD packets is 0.
Interface view
After a virtual link is established through a Virtual-Template or Tunnel, two devices on the link from different vendors might have different MTU values. To make them consistent, restore the interfaces' MTU to the default value 0.
After you configure this command, the interface checks whether the MTU in a received DD packet is greater than its own MTU. If yes, the interface discards the packet.
# Enable GigabitEthernet 1/0/6 to add the interface MTU value into DD packets.
[Sysname-GigabitEthernet1/0/6] ospf mtu-enable
ospf multi-area
Use ospf multi-area to enable OSPF on a multi-area adjacency interface.
Use undo ospf multi-area to disable OSPF on a multi-area adjacency interface.
ospf multi-area area-id
undo ospf multi-area area-id
OSPF is not enabled on a multi-area adjacency interface.
Interface view
area-id: Specifies an OSPF area by its ID, an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format.
Application scenarios
According to OSPF protocols, intra-area paths have higher priority than inter-area paths. Assume an area contains a high-speed link. Devices in other areas cannot use it for data transmission, because the interface belongs to only one area. To address this issue, you can configure multiple subinterfaces and enable them in different areas. However, this method requires assigning a unique IP address to each subinterface, which increases the total number of routes released by the device.
OSPF multi-area adjacency can enable an OSPF interface into multiple areas, allowing a single path to be shared among multiple areas.
Operating mechanism
You can use the network command or the ospf area command to enable an OSPF interface as the primary interface. Then, use the ospf multi-area command to add more areas to the primary interface. The additional OSPF logical interfaces are multi-area adjacency interfaces.
Multi-area adjacency provides the following features:
·     Multi-area adjacency interfaces and the primary interface belong to different OSPF areas.
·     The network type for multi-area adjacency interfaces must be P2P, and they run independent OSPF interface state machines and OSPF neighbor state machines.
·     Multi-area adjacency interfaces and the primary interface have the same interface type and number, sharing the same packet transmission channel. You can identify whether a packet is sent from a multi-area adjacency interface based on the area ID in the OSPF packet header and the configuration.
After OSPF is enabled for a multi-area adjacency interface, it runs an independent OSPF interface state machine and a independent neighbor state machine. Since the multi-area adjacency interface uses the link of the primary interface, devices in the area to which the multi-area adjacency interface belongs can use that link for route calculation.
This command takes effect only when the OSPF is enabled for the interface by using the network or ospf area command and when the corresponding area exists for multi-area adjacency.
If a multi-area adjacency interface is in the same area as the primary interface's enabled area, the multi-area adjacency interface becomes ineffective.
You cannot establish virtual links between multi-area adjacency neighbors.
The ospf multi-area command is not supported in the following interface views:
·     Loopback interfaces.
·     Virtual template (VT) interfaces.
·     Virtual access (VA) interfaces.
# Enable OSPF process 1 on GigabitEthernet 1/0/7 that is in Area 0. Specify Area 1 for multi-area adjacency.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] quit
[Sysname-ospf-1] area 1
[Sysname-ospf-1-area-0.0.0.1] quit
[Sysname-ospf-1] quit
[Sysname-GigabitEthernet1/0/7] ospf 1 area 0
[Sysname-GigabitEthernet1/0/7] ospf multi-area 1
ospf multi-area authentication-mode
Use ospf multi-area authentication-mode to set the authentication mode and key on a multi-area adjacency interface.
Use undo ospf multi-area authentication-mode to remove the configuration.
ospf multi-area area-id  authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
undo ospf multi-area area-id authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id
ospf multi-area area-id authentication-mode simple { cipher | plain } string
undo ospf multi-area area-id authentication-mode simple
No authentication is performed for a multi-area adjacency interface.
Interface view
On networks with high security requirements, use this command to configure OSPF interface authentication.
Key rollover mechanism
To replace the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication on a multi-area adjacency interface, you must configure the new key before removing the old key from each router. OSPF uses the key rollover mechanism to ensure that the routers can pass authentication before the replacement is complete on the interface. After you configure a new key on a router, the router sends copies of the same packet, each authenticated by a different key, including the new key and the keys in use. This practice continues until the router detects that all its neighbors have the new key.
This command takes effect only after you configure the ospf multi-area command.
The ospf multi-area authentication-mode command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
If MD5, HMAC-MD5, HMAC-SHA-256, simple, or keychain authentication is configured, you can configure multiple keys, each having a unique key ID and key string. To minimize the risk of key compromise, use only one key for an interface and delete the old key after key replacement.
# On multi-area adjacency interface GigabitEthernet 1/0/6, enable MD5 authentication, and set the interface key ID to 15 and the key to 123456 in plaintext form.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 authentication-mode md5 15 plain 123456
# On multi-area adjacency interface GigabitEthernet 1/0/6, enable simple authentication, and set the key to 123456 in plaintext form.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 authentication-mode simple plain 123456
ospf multi-area
ospf multi-area cost
Use ospf multi-area cost set an OSPF cost for a multi-area adjacency interface.
Use undo ospf multi-area cost to restore the default.
ospf multi-area area-id cost cost-value
undo ospf multi-area area-id cost
A multi-area adjacency interface calculates its OSPF cost according to the interface bandwidth.
Interface view
Use this command to manually set a cost for a multi-area adjacency interface. If you do not configure this command, the interface calculates its OSPF cost according to the interface bandwidth.
The ospf multi-area cost command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the OSPF cost on multi-area adjacency interface GigabitEthernet 1/0/6 to 65.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 cost 65
bandwidth-reference
ospf multi-area
ospf multi-area link-quality adjust-cost
Use ospf multi-area link-quality adjust-cost to enable link quality-based interface cost adjustment for an OSPF multi-area adjacency interface.
Use undo ospf multi-area link-quality adjust-cost to restore the default.
ospf multi-area area-id link-quality adjust-cost { cost-offset | max }
undo ospf multi-area area-id link-quality adjust-cost
OSPF does not adjust the multi-area adjacency interface cost according to the link quality.
Interface view
cost-offset: Specifies the value to be added to the multi-area adjacency interface cost when the link quality changes to LOW. The value range for this argument is 1 to 65534. When the link quality changes to LOW, the multi-area adjacency interface cost is cost-offset plus the original interface cost, and cannot exceed 65535.
max: Sets the multi-area adjacency interface cost to the maximum value 65535 when the link quality changes to LOW.
Operating mechanism
After you configure this command on a multi-area adjacency interface, OSPF adjusts the interface cost as follows:
This command takes effect only on the local end and affects the route selection only in one direction.
The ospf multi-area link-quality adjust-cost command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Enable OSPF to adjust the cost of multi-area adjacency interface GigabitEthernet 1/0/6 according to the link quality, and set the value to be added to the interface cost to 200.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 link-quality adjust-cost 200
ospf multi-area
ospf multi-area mtu-enable
Use ospf multi-area mtu-enable to enable a multi-area adjacency interface to add the interface MTU into DD packets.
Use undo ospf multi-area mtu-enable to restore the default.
ospf multi-area area-id mtu-enable
undo ospf multi-area area-id mtu-enable
The MTU in DD packets sent from a multi-area adjacency interface is 0.
Interface view
Two devices on the link from different vendors might send DD packets with different MTU values. To make them consistent, restore the MTU value in DD packets sent by the interfaces to the default value 0.
After you execute this command, the interface checks the MTU in a received DD packet. If the MTU is greater than its own MTU, the interface discards the packet.
Use the ospf multi-area mtu-enable command with caution, because it will cause OSPF to re-establish neighbor relationships.
The ospf multi-area mtu-enable command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Enable multi-area adjacency interface GigabitEthernet 1/0/6 to add the interface MTU value into DD packets.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 mtu-enable
ospf multi-area
ospf multi-area packet-size
Use ospf multi-area packet-size to set the maximum length of OSPF packets that can be sent by a multi-area adjacency interface.
Use undo ospf multi-area packet-size to restore the default.
ospf multi-area area-id packet-size value
undo ospf multi-area area-id packet-size
The maximum length of OSPF packets that a multi-area adjacency interface can send equals the interface's MTU.
Interface view
value Specifies the maximum length of OSPF packets that can be sent by an interface, in the range of 500 to 10000 bytes.
Use this command to limit the length of OSPF packets that can be sent by a multi-area adjacency interface.
Operating mechanism
The multi-area adjacency interface chooses the smaller one between the value set by using the ospf multi-area packet-size command and the interface MTU, and uses it as the maximum length of OSPF packets that can be sent.
The ospf multi-area packet-size command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the maximum length of OSPF packets that can be sent by multi-area adjacency interface GigabitEthernet 1/0/6 to 1000 bytes.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 packet-size 1000
ospf multi-area
ospf multi-area timer dead
Use ospf multi-area timer dead  to set the neighbor dead interval on a multi-area adjacency interface.
Use undo ospf multi-area timer dead to restore the default.
ospf multi-area area-id timer dead seconds
undo ospf multi-area area-id timer dead
The dead interval is 40 seconds on a multi-area adjacency interface.
Interface view
seconds: Specifies the dead interval in the range of 1 to 2147483647 seconds.
If an interface receives no hello packet from a neighbor within the dead interval, the interface considers the neighbor down. The dead interval on an interface is a minimum of four times the hello interval. Interfaces attached to the same segment must have the same dead interval.
By default, the multi-area adjacency neighbor dead interval is four times longer than the hello interval. If you specify a hello interval and do not specify a dead interval, the default dead interval is four times longer than the specified hello interval. To specify a hello interval, use the ospf multi-area timer hello command.
When you use the ospf multi-area timer dead command on an interface, follow these guidelines:
·     The specified neighbor dead interval can be issued to and can take effect on the interface only when it is not shorter than the hello interval.
·     To avoid neighbor flapping, do not set a short dead interval.
The ospf multi-area timer dead command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the dead interval for multi-area adjacency interface GigabitEthernet 1/0/6 to 60 seconds.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 timer dead 60
ospf multi-area
Use ospf multi-area timer hello to set the hello interval on a multi-area adjacency interface.
Use undo ospf multi-area timer hello to restore the default.
ospf multi-area area-id timer hello seconds
undo multi-area area-id ospf timer hello
The hello interval is 10 seconds on a multi-area adjacency interface.
Interface view
seconds: Specifies the hello interval in the range of 1 to 65535 seconds.
The shorter the hello interval, the faster the topology converges, and the more resources are consumed. Interfaces attached to the same segment must have the same hello interval.
The ospf multi-area timer hello command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the hello interval on multi-area adjacency interface GigabitEthernet 1/0/6 to 20 seconds.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 timer hello 20
ospf multi-area
ospf multi-area timer retransmit
Use ospf multi-area timer retransmit to set the LSA retransmission interval on a multi-area adjacency interface.
Use undo ospf multi-area timer retransmit to restore the default.
ospf multi-area area-id timer retransmit seconds
undo ospf multi-area area-id timer retransmit
The LSA retransmission interval is 5 seconds on a multi-area adjacency interface.
Interface view
seconds: Specifies the LSA retransmission interval in the range of 1 to 3600 seconds.
After sending an LSA, an interface waits for an acknowledgment packet. If the interface receives no acknowledgment within the retransmission interval, it retransmits the LSA.
Recommended configuration
To avoid unnecessary retransmissions, set an appropriate retransmission interval. For example, you can set a large retransmission interval value on a low-speed link.
The ospf multi-area timer retransmit command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the LSA retransmission interval to 8 seconds on multi-area adjacency interface GigabitEthernet 1/0/6.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 timer retransmit 8
ospf multi-area
ospf multi-area trans-delay
Use ospf multi-area trans-delay to set the LSA transmission delay on a multi-area adjacency interface.
Use undo ospf multi-area trans-delay to restore the default.
ospf multi-area area-id trans-delay seconds
undo ospf multi-area area-id trans-delay
The LSA transmission delay is 1 second on a multi-area adjacency interface.
Interface view
seconds: Specifies the LSA transmission delay in the range of 1 to 3600 seconds.
Each LSA in the LSDB has an age that increases by 1 every second, but the age does not change during transmission. Adding a transmission delay into the age time is important in low speed networks.
The ospf multi-area trans-delay command is not supported in the following interface views:
·     VT interfaces.
·     VA interfaces.
# Set the LSA transmission delay to 3 seconds on multi-area adjacency interface GigabitEthernet 1/0/6.
[Sysname] ospf
[Sysname-GigabitEthernet1/0/6] ospf multi-area 1 trans-delay 3
ospf multi-area
ospf network-type
Use ospf network-type to specify the network type for an interface.
Use undo ospf network-type to restore the default.
ospf network-type { broadcast | nbma | p2mp [ unicast ] | p2p [ peer-address-check ] * }
The network type of an OSPF interface is broadcast.
Interface view
broadcast: Specifies the network type as broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
unicast: Specifies the P2MP interface to unicast OSPF packets. By default, a P2MP interface multicasts OSPF packets.
p2p: Specifies the network type as P2P.
peer-address-check: Checks whether the peer interface and the local interface are on the same network segment. Two P2P interfaces can establish a neighbor relationship only when they are on the same network segment.
If a router on a broadcast network does not support multicast, configure the network type for the connected interfaces as NBMA.
If any two routers on an NBMA network are directly connected through a virtual link, the network is fully meshed. You can configure the network type for the connected interfaces as NBMA. If two routers are not directly connected, configure the P2MP network type so that the two routers can exchange routing information through another router.
When the network type of an interface is NBMA or P2MP unicast, you must use the peer command to specify the neighbor.
If only two routers run OSPF on a network, you can configure the network type for the connected interfaces as P2P.
When the network type of an interface is P2MP unicast, all OSPF packets are unicast by the interface.
# Specify the OSPF network type for GigabitEthernet 1/0/6 as NBMA.
[Sysname-GigabitEthernet1/0/6] ospf network-type nbma
ospf dr-priority
ospf packet-size
Use ospf packet-size to set the maximum length of OSPF packets that can be sent by an interface.
Use undo ospf packet-size to restore the default.
ospf packet-size value
The maximum length of OSPF packets that an interface can send equals the interface's MTU.
Interface view
value: Specifies the maximum length of OSPF packets that can be sent by an interface, in the range of 500 to 10000 bytes.
The interface chooses the smaller one between the value set in this command and the interface MTU, and uses it as the maximum length of OSPF packets that can be sent.
When you establish OSPF neighbors over a tunnel, you can use this command to prevent OSPF packet fragmentation on the outgoing tunnel interface. Make sure the maximum length of OSPF packets plus the encapsulated header length is no greater than the outgoing tunnel interface's MTU. For more information about tunnels, see Layer 3—IP Services Configuration Guide.
# Set the maximum length of OSPF packets that can be sent by GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf packet-size 1000
ospf peer hold-max-cost duration
Use ospf peer hold-max-cost duration to enable OSPF to advertise the maximum link cost to neighbors within the specified period of time.
Use undo ospf peer hold-max-cost duration to restore the default.
ospf peer hold-max-cost duration time
OSPF advertises the original link cost to neighbors during route convergence.
Interface view
time: Specifies the time period during which OSPF advertises the maximum link cost to neighbors, in the range of 100 to 1000000 milliseconds.
On an OSPF network, when a link recovers from failures or the state of an interface changes, OSPF will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, use this command to make sure the traffic forwarding path remains unchanged during route convergence.
Operating mechanism
After you execute this command, the timer specified by the time  argument starts when the OSPF neighbor enters Full state. Within the specified period of time, the interface advertises the maximum link cost (65535) to neighbors within the specified period of time, so the traffic forwarding path remains unchanged. After the specified period of time, OSPF advertises the original link cost to neighbors and performs optimal route selection again.
The ospf peer hold-max-cost duration command does not take effect for multi-area adjacency interfaces.
# On interface GigabitEthernet1/0/6, enable OSPF to advertise the maximum link cost to neighbors within 1000 milliseconds.
[Sysname-GigabitEthernet1/0/6] ospf peer hold-max-cost duration 1000
display ospf interface verbose
ospf multi-area
ospf peer suppress-flapping
Use ospf peer suppress-flapping to configure detection parameters for OSPF neighbor flapping suppression.
Use undo ospf peer suppress-flapping to remove the configuration.
ospf peer suppress-flapping { detect-interval detect-interval | threshold threshold | resume-interval resume-interval } *
undo ospf peer suppress-flapping { detect-interval | threshold | resume-interval } *
The detect interval is 60 seconds, the threshold value is 10, and the resume interval is 120 seconds.
Interface view
detect-interval detect-interval: Specifies the interval to detect OSPF neighbor flapping events, in the range of 1 to 300 seconds. The default value is 60. If the time interval between two consecutive neighbor state changes (from Full to another state) is less than the specified detect interval, a neighbor flapping event has occurred.
threshold threshold: Specifies the threshold value that triggers neighbor flapping suppression, in the range of 1 to 1000. The default value is 10.
resume-interval resume-interval: Specifies the resume interval of neighbor flapping suppression, in the range of 2 to 1000 seconds. The default value is 120.
Before executing this command, make sure OSPF neighbor flapping suppression is enabled by using the suppress-flapping hold-down or ospf peer suppress-flapping hold-max-cost command.
The OSPF neighbor flapping suppression mechanism is as follows:
·     The interface starts a flapping counter to count neighbor flapping events. When the device detects a neighbor flapping event, it increases the flapping counter by 1.
A neighbor flapping event occurs when the time interval between two consecutive neighbor state changes (from Full to another state) is less than the specified detect interval.
·     If the time interval between two consecutive neighbor state changes (from Full to another state) is greater than the specified resume interval, the flapping counter is reset.
·     If the flapping counter reaches or exceeds the specified threshold, OSPF starts flapping suppression for all neighbors on the interface.
·     During the flapping suppression period, if the device detects another neighbor flapping event, it resets the resume interval.
The resume interval value must be greater than the detect interval value.
The resume interval specifies the suppression period during which the maximum cost is used for neighbor flapping suppression enabled by using the ospf peer suppress-flapping hold-max-cost command.
# Set the detect interval, threshold, and resume interval values to 5, 40, and 20 for OSPF neighbor flapping suppression on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf peer suppress-flapping detect-interval 5 threshold 40 resume-interval 20
display ospf
ospf peer suppress-flapping hold-down
Use ospf peer suppress-flapping hold-down to enable OSPF neighbor flapping suppression and set the suppression timer.
Use undo ospf peer suppress-flapping to disable OSPF neighbor flapping suppression.
ospf peer suppress-flapping hold-down interval
undo ospf peer suppress-flapping hold-down
OSPF neighbor flapping suppression is disabled.
Interface view
interval: Specifies the neighbor flapping suppression timer in the range of 1 to 600 seconds. OSPF can establish neighbor relationships only when the suppression timer expires.
Neighbor state changes will cause neighbor relationship reestablishment, LSDB synchronization, and route calculation. A large number of packets will be exchanged, which affects stability of existing neighbors and operation of OSPF and relevant services. To resolve this issue, enable OSPF neighbor flapping suppression to delay neighbor relationship establishment or traffic forwarding through neighbor links.
Use this command to avoid frequent flooding and topology changes during neighbor relationship establishment. Before the specified neighbor flapping suppression timer expires, OSPF does not establish neighbor relationships.
If you execute both the suppress-flapping hold-down and ospf peer suppress-flapping hold-max-cost commands for an interface, the suppress-flapping hold-down command applies first. When neighbor suppression starts, OSPF performs the following operations in sequence:
1.     Disables neighbor relationship establishment until the specified suppression timer expires.
2.     Allows neighbor relationship establishment and sets the maximum cost for neighbor links until the specified resume interval expires.
3.     Resumes the original link cost when the specified resume interval expires.
Neighbor flapping suppression applies to all neighbors attached to the interface.
The ospf peer suppress-flapping hold-down command does not take effect for multi-area adjacency interfaces.
# Enable OSPF neighbor flapping suppression and set the suppression timer to 200 seconds on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf peer suppress-flapping hold-down 200
display ospf
ospf multi-area
Use ospf peer suppress-flapping hold-max-cost to enable OSPF neighbor flapping suppression and set the maximum cost for flapping links.
Use undo ospf peer suppress-flapping hold-max-cost to disable OSPF neighbor flapping suppression.
Interface view
Frequent neighbor state changes will cause neighbor relationship reestablishment, LSDB synchronization, and route calculation. A large number of packets will be exchanged, which affects stability of existing neighbors and operation of OSPF and relevant services. To resolve this issue, enable OSPF neighbor flapping suppression to delay neighbor relationship establishment or traffic forwarding through neighbor links.
After you execute this command, OSPF sets the cost of all neighbor links to the maximum value 65535 within the neighbor flapping suppression period (resume interval). When the resume interval expires, OSPF resumes the original link cost.
The ospf peer suppress-flapping hold-max-cost command does not take effect for multi-area adjacency interfaces.
# Enable OSPF neighbor flapping suppression and set the maximum cost for neighbor links on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf peer suppress-flapping hold-max-cost
display ospf
ospf multi-area
ospf prefix-suppression
Use ospf prefix-suppression to disable an OSPF interface from advertising all its IP prefixes, except for the prefixes of secondary IP addresses.
Use undo ospf prefix-suppression to restore the default.
Prefix suppression is disabled.
Interface view
disable: Disables prefix suppression for an interface.
To disable prefix suppression for an interface associated with an OSPF process that has been enabled with prefix suppression, use the ospf prefix-suppression disable command on that interface.
# Enable prefix suppression for GigabitEthernet 1/0/7.
[Sysname-GigabitEthernet1/0/7] ospf prefix-suppression
prefix-suppression
ospf primary-path-detect bfd
Use ospf primary-path-detect bfd to enable BFD for OSPF FRR or OSPF PIC.
Use undo ospf primary-path-detect bfd to disable BFD for OSPF FRR or OSPF PIC.
ospf primary-path-detect bfd { ctrl | echo }
BFD is disabled for OSPF FRR or OSPF PIC.
Interface view
ctrl: Enables BFD control packet mode.
echo: Enables BFD echo packet mode.
This command enables OSPF PIC or OSPF FRR to use BFD to detect primary link failures.
A multi-area adjacency interface can establish multiple OSPF neighbor relationships with devices in different areas. When BFD detects a primary link failure in an area, it triggers active/standby switchover only in that area.
# On GigabitEthernet 1/0/6, enable BFD control packet mode for OSPF FRR.
[Sysname] ospf 1
[Sysname-ospf-1] fast-reroute lfa
[Sysname-GigabitEthernet1/0/6] ospf primary-path-detect bfd ctrl
# On GigabitEthernet 1/0/7, enable BFD echo packet mode for OSPF PIC.
[Sysname] ospf 1
[Sysname-ospf-1] pic additional-path-always
[Sysname-GigabitEthernet1/0/7] ospf primary-path-detect bfd echo
ospf multi-area
ospf silent
Use ospf silent to disable the interface from receiving and sending OSPF packets.
Use undo ospf silent to restore the default.
ospf silent
undo ospf silent
The interface can receive and send OSPF packets.
Interface view
Use this command to achieve the following purposes:
·     Disable the local device from receiving route updates advertised by other devices in the network through the interface.
·     Disable the local device from advertising route updates to other devices in the network through the interface.
Operating mechanism
After you configure this command, the OSPF interface performs the following operations:
·     Sends a one-way hello packet to its neighbor. The neighbor terminates the neighbor relationship with the sending interface upon receiving the one-way hello packet.
·     No longer establishes neighbor relationship.
You can execute either the silent-interface or ospf silent command or both commands for an interface to achieve the same effect. Choose an appropriate configuration method as needed.
The ospf silent command does not take effect for multi-area adjacency interfaces. To disable a multi-area adjacency interface from receiving and sending OSPF packets, execute the silent-interface command for the OSPF process running on the interface.
# Disable GigabitEthernet 1/0/6 from receiving and sending OSPF packets.
[Sysname-GigabitEthernet1/0/6] ospf silent
ospf multi-area
silent-interface
ospf timer dead
Use ospf timer dead to set the neighbor dead interval.
Use undo ospf timer dead to restore the default.
ospf timer dead seconds
The dead interval is 40 seconds for broadcast and P2P interfaces. The dead interval is 120 seconds for P2MP and NBMA interfaces.
Interface view
The dead interval on an interface is a minimum of four times the hello interval. Routers attached to the same segment must have the same dead interval.
By default, the neighbor dead interval is four times longer than the hello interval. If you specify a hello interval and do not specify a dead interval, the default dead interval is four times longer than the specified hello interval. To specify a hello interval, use the ospf timer hello command.
When you use the ospf timer dead command on an interface, follow these guidelines:
# Set the dead interval for GigabitEthernet 1/0/6 to 60 seconds.
[Sysname-GigabitEthernet1/0/6] ospf timer dead 60
ospf timer hello
ospf timer hello
Use ospf timer hello to set the hello interval on an interface.
Use undo ospf timer hello to restore the default.
ospf timer hello seconds
The hello interval is 10 seconds for P2P and broadcast interfaces, and is 30 seconds for P2MP and NBMA interfaces.
Interface view
The shorter the hello interval, the faster the topology converges, and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Set the hello interval on GigabitEthernet 1/0/6 to 20 seconds.
[Sysname-GigabitEthernet1/0/6] ospf timer hello 20
ospf timer dead
ospf timer poll
Use ospf timer poll to set the poll interval on an NBMA interface.
Use undo ospf timer poll to restore the default.
ospf timer poll seconds
The poll interval is 120 seconds on an interface.
Interface view
seconds: Specifies the poll interval in the range of 1 to 2147483647 seconds.
When an NBMA interface finds its neighbor is down, it sends hello packets at the poll interval.
The poll interval must be a minimum of four times the hello interval.
# Set the poll timer interval on GigabitEthernet 1/0/6 to 130 seconds.
[Sysname-GigabitEthernet1/0/6] ospf timer poll 130
ospf timer hello
ospf timer retransmit
Use ospf timer retransmit to set the LSA retransmission interval on an interface.
Use undo ospf timer retransmit to restore the default.
ospf timer retransmit seconds
The LSA retransmission interval is 5 seconds on an interface.
Interface view
# Set the LSA retransmission interval to 8 seconds on GigabitEthernet 1/0/6.
[Sysname-GigabitEthernet1/0/6] ospf timer retransmit 8
ospf trans-delay
Use ospf trans-delay to set the LSA transmission delay on an interface.
Use undo ospf trans-delay to restore the default.
ospf trans-delay seconds
The LSA transmission delay is 1 second.
Interface view
# Set the LSA transmission delay to 3 seconds on GigabitEthernet 1/0/6.
[Sysname] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] ospf trans-delay 3
ospf troubleshooting max-number
Use ospf troubleshooting max-number to set the maximum number of OSPF neighbor relationship troubleshooting entries.
Use undo ospf troubleshooting max-number to restore the default.
ospf troubleshooting max-number number
The maximum number of OSPF neighbor relationship troubleshooting entries is 100.
number: Specifies the maximum number of OSPF neighbor relationship troubleshooting entries, in the range of 0 to 65535. The value 0 means OSPF does not record neighbor relationship troubleshooting entries.
# Set the maximum number of OSPF neighbor relationship troubleshooting entries to 50.
[Sysname] ospf troubleshooting max-number 50
ospf ttl-security
Use ospf ttl-security to enable OSPF GTSM for an interface.
Use ospf ttl-security disable to disable OSPF GTSM for an interface.
Use undo ospf ttl-security to restore the default.
ospf ttl-security [ hops hop-count | disable ]
An interface uses the GTSM configuration of the area to which the interface belongs.
Interface view
hops hop-count: Specifies the hop limit for checking OSPF packets, in the range of 1 to 254. The default hop limit is 1 for packets from common neighbors, and is 255 for packets from virtual link neighbors.
disable: Disables OSPF GTSM for the interface.
The Generalized TTL Security Mechanism (GTSM) is a simple and feasible security mechanism used to protect upper-layer services based on the IP protocol.
Operating mechanism
GTSM checks OSPF packets from common neighbors and virtual link neighbors.
GTSM protects the device by comparing the TTL value in the IP header of incoming OSPF packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
If a virtual link exists in an area, you can enable GTSM for the interfaces on the virtual link. If you do not know the interfaces on the virtual link, enable GTSM in area view to prevent packet loss.
When GTSM is configured, the OSPF packets sent by the device have a TTL of 255. To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
The GTSM configuration in OSPF area view applies to all OSPF interfaces in the area. The GTSM configuration in interface view takes precedence over the configuration in OSPF area view.
If you configure the ospf multi-area command for a primary interface after enabling OSPF for the interface by using the network or ospf area command, follow these restrictions and guidelines:
·     The ospf ttl-security configured for the primary interface takes effect for the primary interface and the multi-area adjacency interface.
·     The ttl-security configured for the area to which the primary interface belongs takes effect only for the primary interface.
·     The ttl-security configured for the area to which the multi-area adjacency interface belongs takes effect only for the multi-area adjacency interface.
# Enable OSPF GTSM for GigabitEthernet 1/0/6 and set the hop limit to 254.
[Sysname-GigabitEthernet1/0/6] ospf ttl-security hops 254
# Enable GTSM in OSPF area view and disable OSPF GTSM for GigabitEthernet 1/0/6.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] ttl-security
[Sysname-ospf-100-area-0.0.0.1] quit
[Sysname-ospf-100] quit
[Sysname-GigabitEthernet1/0/6] ospf ttl-security disable
ospf multi-area
ttl-security
ospf virtual-system
Use ospf virtual-system to enable the virtual system feature on an OSPF interface.
Use undo ospf virtual-system to disable the virtual system feature on an OSPF interface.
ospf virtual-system router-id router-id
undo opsf virtual-system
The virtual system feature is disabled on an OSPF interface.
Interface view
router-id: Specifies a router ID for the virtual OSPF node in dotted decimal notation. The value range for this argument is 0.0.0.1 to 255.255.255.254.
After you enable the virtual system feature on an OSPF interface, the interface can use a virtual OSPF node for neighbor relationship establishment. To enable this feature on an OSPF interface, perform the following tasks:
1.     Use the virtual-system enable command to enable the virtual system feature globally in the OSPF process to which the OSPF interface belongs.
2.     Use the ospf virtual-system command to enable the virtual system feature on the OSPF interface.
When you configure the virtual node of an OSPF interface, follow these guidelines:
·     The router ID of the virtual node must be different from that of any other virtual node.
·     The router ID of the virtual node must be different from that of the OSPF process to which the OSPF interface belongs.
·     If you use the ospf virtual-system command multiple times, the most recent configuration takes effect.
# Enable the virtual system feature on GigabitEthernet 1/0/6.
[Sysname] ospf
[Sysname-ospf-1] virtual-system enable
[Sysname-ospf-1] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] ospf virtual-system router-id 1.1.1.1
peer
Use peer to specify a neighbor in an NBMA or P2MP network.
Use undo peer to remove a neighbor in an NBMA or P2MP network.
In OSPF view:
peer ip-address [ cost cost-value | dr-priority priority ]
undo peer ip-address
No neighbor is specified.
OSPF view
ip-address: Specifies a neighbor by its IP address.
cost cost-value: Specifies the cost to reach the neighbor, in the range of 1 to 65535.
dr-priority priority: Specifies the DR priority for the neighbor, in the range of 0 to 255. The default neighbor DR priority is 1.
On an NBMA or P2MP network, OSPF packets are sent in unicast, so you must use this command to specify neighbors.
The cost set with the peer command applies only to P2MP neighbors. If no cost is specified, the cost to the neighbor equals the local interface's cost.
A router uses the priority set with the peer command to determine whether to send a hello packet to the neighbor rather than for DR election. The DR priority set with the ospf dr-priority command is used for DR election.
# Specify the neighbor 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] peer 1.1.1.1
ospf dr-priority
pic
Use pic to enable OSPF PIC.
Use undo pic to disable OSPF PIC.
undo pic
OSPF PIC is enabled.
OSPF view
additional-path-always: Enables support for using an indirect suboptimal route as the backup route. If you specify this keyword, the device can select a suboptimal route as the backup route from routes that were learned from different indirect advertisement sources and have the same prefix.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes. PIC applies only to inter-area routes and external routes.
When both OSPF PIC and OSPF FRR are configured, OSPF FRR takes effect.
# Configure OSPF PIC to support the suboptimal route as the backup route.
[Sysname] ospf 1
preference
Use preference to set a preference for OSPF.
Use undo preference to remove the configuration.
undo preference [ ase ]
The preference is 10 for OSPF internal routes and 150 for OSPF external routes (ASE routes).
OSPF view
ase: Specifies a preference for OSPF external routes. If you do not specify this keyword, the command sets a preference for OSPF internal routes.
preference: Specifies the preference value in the range of 1 to 255. A smaller value represents a higher preference.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a preference for the specified routes.
If multiple routing protocols find routes to the same destination, the router uses the route found by the protocol with the highest preference.
When the route-policy route-policy-name option is specified, the following preferences take effect:
·     For routes matching the routing policy, the preference set in the routing policy takes effect.
·     For other routes, the preference set with the preference command takes effect.
# Set a preference of 200 for OSPF external routes.
[Sysname] ospf 100
[Sysname-ospf-100] preference ase 200
# Set a preference of 100 for OSPF internal routes matching routing policy policy1, and set a preference of 150 for other routes.
[Sysname] ip prefix-list test index 10 permit 100.1.1.0 24
[Sysname-route-policy-policy1-10] if-match ip address prefix-list test
[Sysname-route-policy-policy1-10] apply preference 100
[Sysname-route-policy-policy1-10] quit
[Sysname] ospf 100
[Sysname-ospf-100] preference route-policy policy1 150
prefix-priority
Use prefix-priority to enable prefix prioritization.
Use undo prefix-priority to disable prefix prioritization.
Prefix prioritization is disabled.
OSPF view
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a priority for the specified route prefixes.
OSPF calculates intra-area routes, inter-area routes, and AS external routes in descending convergence priority order: critical, high, medium, and low. When a route has multiple prefix priorities, it uses the highest priority.
To prioritize the convergence of specific routes, use the prefix prioritization feature to set a higher convergence priority value for those routes.
# Use routing policy policy1 to assign the medium priority to the specified route prefixes.
[Sysname-route-policy-policy1-10] apply prefix-priority medium
[Sysname] ospf 100
[Sysname-ospf-100] prefix-priority route-policy policy1
prefix-suppression
Use prefix-suppression to disable an OSPF process from advertising all IP prefixes except for the prefixes of loopback interfaces, secondary IP addresses, and passive interfaces.
Use undo prefix-suppression to restore the default.
prefix-suppression
An OSPF process advertises all prefixes.
OSPF view
By default, an OSPF interface advertises all of its prefixes in LSAs. To speed up OSPF convergence, you can suppress interfaces from advertising all their prefixes. This feature helps improve network security by preventing IP routing to the suppressed networks.
As a best practice, configure prefix suppression on all OSPF routers if you want to use prefix suppression.
To disable an OSPF process from advertising the prefixes of loopback and passive interfaces, configure prefix suppression on the interfaces by using the ospf prefix-suppression command.
When prefix suppression is enabled:
·     On P2P and P2MP networks, OSPF does not advertise Type-3 links in Type-1 LSAs. Other routing information can still be advertised to ensure traffic forwarding.
·     On broadcast and NBMA networks, the DR generates Type-2 LSAs with a mask length of 32 to suppress network routes. Other routing information can still be advertised to ensure traffic forwarding. If no neighbors exist, the DR also does not advertise the primary IP addresses of interfaces in Type-1 LSAs.
# Enable prefix suppression for OSPF process 1.
[Sysname] ospf 1
[Sysname-ospf-1] prefix-suppression
reset ospf event-log
Use reset ospf event-log to clear OSPF log information.
reset ospf [ process-id ] event-log [ lsa-flush | lsa-history | peer | route | spf ]
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears OSPF log information for all OSPF processes.
lsa-flush: Clears LSA aging log information.
lsa-history: Clears self-originated and received LSA log information.
peer: Clears neighbor state change log information.
route: Clears OSPF route log information.
spf: Clears route calculation log information.
If you do not specify a log type, this command clears all log information.
# Clear OSPF route calculation log information for all OSPF processes.
<Sysname> reset ospf event-log spf
display ospf event-log
reset ospf event-log hello
Use reset ospf event-log hello to clear OSPF log information about received or sent hello packets.
reset ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] }
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears OSPF log information for all processes.
received: Specifies log information for received hello packets.
sent: Specifies log information for sent hello packets.
abnormal: Specifies log information for abnormal hello packets received or sent at intervals greater than or equal to 1.5 times the hello interval.
dropped: Specifies log information for received hello packets that were dropped.
failed: Specifies log information for hello packets that failed to be sent.
# Clear sent hello packet log information for all OSPF processes.
<Sysname> reset ospf event-log hello sent
display ospf event-log hello
reset ospf process
Use reset ospf process to restart all OSPF processes or a specified process.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command restarts all OSPF processes.
graceful-restart: Resets the OSPF process by using GR.
The reset ospf process command performs the following actions:
·     Clears all invalid LSAs without waiting for their timeouts.
·     Makes a newly configured router ID take effect.
·     Starts a new DR/BDR election.
·     Keeps previous OSPF configurations.
The system prompts you to select whether to restart OSPF process upon execution of this command.
# Restart all OSPF processes.
<Sysname> reset ospf process
Reset OSPF process? [Y/N]:y
reset ospf redistribution
Use reset ospf redistribution to restart route redistribution.
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. If you do not specify a process, this command restarts route redistribution for all OSPF processes.
# Restart route redistribution.
<Sysname> reset ospf redistribution
reset ospf statistics
Use reset ospf statistics to clear OSPF statistics.
process-id: Clears the statistics for an OSPF process specified by its ID in the range of 1 to 65535.
# Clear OSPF statistics for all processes.
<Sysname> reset ospf statistics
display ospf statistics
reset ospf troubleshooting
Use reset ospf troubleshooting to clear OSPF neighbor relationship troubleshooting information.
# Clear OSPF neighbor relationship troubleshooting information.
<Sysname> reset ospf troubleshooting
display ospf troubleshooting
rfc1583 compatible
Use rfc1583 compatible to enable compatibility with RFC 1583.
Use undo rfc1583 compatible to disable compatibility with RFC 1583.
rfc1583 compatible
Compatibility with RFC 1583 is enabled.
OSPF view
RFC 1583 specifies a different method than RFC 2328 for selecting the optimal route to a destination in another AS. When multiple routes are available to the ASBR, OSPF selects the optimal route by using the following procedure:
1.     Selects the route with the highest preference.
¡     If RFC 2328 is compatible with RFC 1583, all these routes have equal preference.
¡     If RFC 2328 is not compatible with RFC 1583, the intra-area route in a non-backbone area is preferred to reduce the burden of the backbone area. The inter-area route and intra-area route in the backbone area have equal preference.
2.     Selects the route with lower cost if two routes have equal preference.
3.     Selects the route with larger originating area ID if two routes have equal cost.
To avoid routing loops, set identical RFC 1583-compatibility on all routers in a routing domain.
# Disable compatibility with RFC 1583.
[Sysname] ospf 100
[Sysname-ospf-100] undo rfc1583 compatible
router id
Use router id to configure a global router ID.
Use undo router id to restore the default.
router id router-id
undo router id
No global router ID is configured.
router-id: Specifies the global router ID in dotted decimal format. The value range for this argument is 0.0.0.1 to 255.255.255.254.
OSPF uses a router ID to identify a device. If no router ID is specified, the global router ID is used.
If no global router ID is configured, the highest loopback interface IP address is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status (up or down).
During an active/standby switchover, the new active main processing unit (MPU) checks whether the previously backed up router ID is valid. If not, it selects a new router ID.
A new router ID is selected only when the interface IP address used as the router ID is removed or changed. Other events will not trigger a router ID re-selection. For example, router ID re-selection is not triggered in the following situations:
·     The interface goes down.
·     You change the router ID to the address of a loopback interface after a physical interface address is selected as the router ID.
·     A higher interface IP address is configured as the router ID.
After a router ID is changed, you must use the reset command to enable it.
# Configure a global router ID as 1.1.1.1.
[Sysname] router id 1.1.1.1
shutdown process
Use shutdown process to shut down an OSPF process.
Use undo shutdown process to start an OSPF process.
shutdown process
An OSPF process is not shut down.
OSPF view
Both this feature and OSPF isolation can be used for OSPF maintenance.
After you execute the shutdown process command for an OSPF process, the process performs the following operations:
·     Sends 1-way hello packets to its neighbors.
On receipt of the packets, the neighbors disconnect from the OSPF process.
·     Stops receiving and sending OSPF packets.
·     Clears its neighbor, LSDB, and OSPF route information.
After maintenance, you can use the undo shutdown process command to restart the process for neighbor relationship re-establishment.
# Shut down OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] shutdown process
isolate enable
silent-interface
Use silent-interface to disable an interface or all interfaces from receiving and sending OSPF packets.
Use undo silent-interface to remove the configuration.
An interface can receive and send OSPF packets.
OSPF view
all: Specifies all interfaces.
Operating mechanism
Multiple processes can disable the same interface from receiving and sending OSPF packets. However, the silent-interface command takes effect only on interfaces enabled with the current process.
The silent-interface command takes effect for all interfaces running the OSPF process, including the multi-area adjacency interfaces.
[Sysname] ospf 100
[Sysname-ospf-100] silent-interface gigabitethernet 1/0/6
ospf multi-area
ospf silent
snmp trap rate-limit
Use snmp trap rate-limit to set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
Use undo snmp trap rate-limit to restore the default.
OSPF outputs a maximum of seven SNMP notifications within 10 seconds.
OSPF view
interval trap-interval: Specifies the SNMP notification output interval in the range of 2 to 60 seconds.
count trap-number: Specifies the number of SNMP notifications output by OSPF at each interval, in the range of 0 to 300. The value of 0 indicates that OSPF does not output SNMP notifications.
# Configure OSPF to output a maximum of 10 SNMP notifications within 5 seconds.
[Sysname] ospf 100
[Sysname-ospf-100] snmp trap rate-limit interval 5 count 10
snmp-agent trap enable ospf
Use snmp-agent trap enable ospf to enable SNMP notifications for OSPF.
Use undo snmp-agent trap enable ospf to disable SNMP notifications for OSPF.
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | dr-ip-address-conflict | grhelper-status-change | grrestarter-status-change | if-state-change | intra-area-router-id-conflict | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | peer-flapping-suppress-status-change | retransmit | sr-prefix-sid-conflict | sr-prefix-sid-conflict-clear | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | dr-ip-address-conflict | grhelper-status-change | grrestarter-status-change | if-state-change | intra-area-router-id-conflict | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | peer-flapping-suppress-status-change | retransmit | sr-prefix-sid-conflict | sr-prefix-sid-conflict-clear | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
SNMP notifications for OSPF are enabled.
authentication-failure: Specifies notifications about authentication failures on an interface.
bad-packet: Specifies notifications about error messages received on an interface.
config-error: Specifies notifications about error configuration of an interface.
dr-ip-address-conflict: Specifies notifications about DR IP address conflicts within an area.
grhelper-status-change: Specifies notifications about GR helper state change.
grrestarter-status-change: Specifies notifications about GR restarter state change.
if-state-change: Specifies notifications about interface state change.
intra-area-router-id-conflict: Specifies notifications about router ID conflicts within an area.
lsa-maxage: Specifies LSA max age notifications.
lsa-originate: Specifies notifications about locally generated LSAs.
lsdb-approaching-overflow: Specifies notifications about approaching LSDB overflows.
lsdb-overflow: Specifies LSDB overflow notifications.
neighbor-state-change: Specifies notifications about neighbor state change.
nssatranslator-status-change: Specifies notifications about NSSA translator state change.
peer-flapping-suppress-status-change: Specifies notifications about neighbor flapping suppression status change.
retransmit: Specifies notifications about packets that are received and forwarded on an interface.
sr-prefix-sid-conflict: Specifies notifications about SR prefix SID conflicts.
sr-prefix-sid-conflict-clear: Specifies notifications about recoveries from SR prefix SID conflict conditions.
virt-authentication-failure: Specifies notifications about authentication failures on a virtual interface.
virt-bad-packet: Specifies notifications about error messages received on a virtual interface.
virt-config-error: Specifies notifications about error configuration of a virtual interface.
virt-retransmit: Specifies notifications about packets that are received and forwarded on a virtual interface.
virtgrhelper-status-change: Specifies notifications about neighbor GR helper state changes of a virtual interface.
virtif-state-change: Specifies notifications about virtual interface state change.
virtneighbor-state-change: Specifies notifications about the neighbor state change of a virtual interface.
If you do not specify any parameters, the command enables all types of SNMP notifications for OSPF.
You can enable SNMP notifications only when OSPF processes exist. If you delete all OSPF processes after enabling SNMP notifications, the SNMP notifications feature will not take effect.
# Disable SNMP notifications for OSPF.
[Sysname] undo snmp-agent trap enable ospf
snmp-agent trap ospf neighbor-state-change extended
Use snmp-agent trap ospf neighbor-state-change extended to extend the format of SNMP notifications for neighbor state changes.
Use undo snmp-agent trap ospf neighbor-state-change extended to restore the default.
OSPF does not extend the format of SNMP notifications for neighbor state changes.
After you execute this command, OSPF generates a notification in extended format when the state of a neighbor changes. Compared with notifications in standard format, notifications in extended format include interface names additionally. This setting enables the network administrator to quickly locate problems.
The NMS might fail to parse the notifications in extended format if it does not support this format.
# Extend the format of SNMP notifications for neighbor state changes.
[Sysname] snmp-agent trap ospf neighbor-state-change extended
spf-schedule-interval
Use spf-schedule-interval to set the OSPF SPF calculation interval.
Use undo spf-schedule-interval to restore the default.
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond interval }
The maximum calculation interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF view
maximum-interval: Specifies the maximum OSPF SPF calculation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental OSPF SPF calculation interval in the range of 10 to 60000 milliseconds.
conservative: Keeps the maximum interval when route flapping occurs. If you do not specify this keyword, the OSPF SPF calculation is performed at the maximum interval for three consecutive times and then performed at the minimum interval.
millisecond interval: Specifies the fixed OSPF SPF calculation interval in the range of 0 to 10000 milliseconds.
Application scenarios
Based on the LSDB, an OSPF router uses SPF to calculate a shortest path tree with itself as the root. OSPF uses the shortest path tree to determine the next hop to a destination. By adjusting the SPF calculation interval, you can prevent overconsumption of bandwidth and router resources due to frequent topology changes.
Operating mechanism
The default SPF calculation interval settings are as follows:
·     The interval for the first SPF calculation is 50 milliseconds.
·     The interval for the nth (n ≥ 2) SPF calculation is 50 + (200 x 2n-2) milliseconds, and cannot exceed 5 seconds.
The spf-schedule-interval command functions as follows:
·     If the spf-schedule-interval maximum-interval command is executed:
¡     The values for the minimum-interval and incremental-interval arguments are both 0.
¡     The SPF calculation interval is fixed at maximum-interval.
·     If the spf-schedule-interval maximum-interval minimum-interval command is executed:
¡     The value for the incremental-interval argument is 0.
¡     The interval for the first SPF calculation is minimum-interval.
¡     The interval for subsequent SPF calculations is maximum-interval.
-     If the conservative keyword is not specified, OSPF performs SPF calculation at the maximum interval for three consecutive times, and then performs SPF calculation at the minimum interval.
-     If the conservative keyword is specified, OSPF always performs SPF calculation at the maximum interval.
·     If the spf-schedule-interval maximum-interval minimum-interval incremental-interval command is executed:
¡     The interval for the nth (n ≥ 2) SPF calculation is minimum-interval + incremental-interval x 2n-2, and cannot exceed maximum-interval.
·     If the spf-schedule-interval millisecond interval command is executed, OSPF performs SPF calculation at intervals of interval milliseconds.
For a network that requires fast route convergence, use the spf-schedule-interval millisecond interval command to set a short SPF calculation interval.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum SPF calculation interval to 10 seconds, minimum interval to 500 milliseconds, and incremental interval to 300 milliseconds.
[Sysname] ospf 100
[Sysname-ospf-100] spf-schedule-interval 10 500 300
stub
Use stub to configure an area as a stub area.
Use undo stub to restore the default.
In OSPF area view:
undo stub
No area is a stub area.
OSPF area view
default-route-advertise-always: Enables the ABR to advertise a default route in a Type-3 LSA into the stub area regardless of whether FULL-state neighbors exist in the backbone area. If you do not specify this keyword, the ABR advertises a default route in a Type-3 LSA into the stub area only when a minimum of one FULL-state neighbor exists in the backbone area.
no-summary: Enables the ABR to advertise only a default route in a Type-3 LSA into the stub area without advertising any other Type-3 LSAs. The area is a totally stub area.
To configure an area as a stub area, use the stub command on all routers attached to the area.
# Configure Area 1 as a stub area.
[Sysname] ospf 100
[Sysname-ospf-100-area-0.0.0.1] stub
default-cost
stub-router
Use stub-router to configure a router as a stub router.
Use undo stub-router to restore the default.
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] }| summary-lsa [ max-metric-value ] ] *
undo stub-router
The router is not configured as a stub router.
OSPF view
external-lsa max-metric-value: Specifies a cost for the external LSAs, in the range of 1 to 16777215. The default is 16711680.
include-stub: Specifies the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535.
on-startup seconds: Specifies the router as a stub router during reboot, and specifies the timeout time in the range of 5 to 86400 seconds.
wait-for-bgp seconds: Specifies the router as a stub router during BGP route convergence after reboot, and specifies the timeout time in the range of 5 to 86400 seconds. The default timeout time is 600 seconds.
summary-lsa max-metric-value: Specifies a cost for the Type-3 LSAs, in the range of 1 to 16777215. The default cost value is 16711680.
The router LSAs sent by the stub router over different links contain different link type values. A value of 3 represents a link to a stub network, and the cost of the link is not changed. A value of 1, 2, or 4 represents a point-to-point link, a link to a transit network, or a virtual link. The cost of these links is set to 65535. Neighbors on such links will not send packets to the stub router as long as they have a route with a smaller cost.
# Configure a stub router.
[Sysname] ospf 100
[Sysname-ospf-100] stub-router
transmit-pacing
Use transmit-pacing to set the LSU packet transmission interval and the maximum number of LSU packets that can be sent at each interval.
Use undo transmit-pacing to restore the default.
All OSPF interfaces in an OSPF process send a maximum of 3 LSU packets every 20 milliseconds.
OSPF view
interval interval: Specifies an interval at which LSU packets are sent in an OSPF process, in the range of 0 to 1000 milliseconds. If the router has multiple OSPF interfaces, increase this interval to reduce the total number of LSU packets sent by the router every second. As a best practice to maintain network stability, do not set the interval to 0 milliseconds when the OSPF LSDB is large or network changes are frequent.
count count: Specifies the maximum number of LSU packets sent by an interface at each interval, in the range of 1 to 200. If a large number of OSPF interfaces run in the OSPF process, decrease the value for this argument to reduce the total number of LSU packets sent by these interfaces per second.
Sending a great number of LSU packets during LSDB synchronization with neighbors might affect the device performance and consume excessive network bandwidths. To avoid this issue, you can configure the device to send LSU packets at intervals and limit the maximum number of LSU packets that can be sent at each interval.
Operating mechanism
If this command is executed in conjunction with the ospf lsu-flood-control disable command, the system only limits the total LSU packet transmission rate of all interfaces running in the related OSPF process. It does not limit the total LSU packet transmission rate of all OSPF interfaces on the device.
After you configure the ospf lsu-flood-control interval max-count-value command, the maximum LSU packet transmission rate for each OSPF interface is X/N, rounded down. N is the total number of OSPF interfaces on the device, and X is the maximum LSU packet transmission rate specified by this command. Each OSPF interface running in an OSPF process should transmit LSU packets at a rate that is not larger than X/N. OSPF limits the LSU packet transmission rate of the OSPF process as follows:
·     If the total LSU packet transmission rate of the OSPF process exceeds the upper limit specified by the transmit-pacing command, the system performs the following operations:
a.     Within the interval specified by the interval argument of the transmit-pacing command, the system no longer processes the LSU packet transmission requests initiated by the process.
b.     After the specified interval, if the process still has LSU packets to transmit, the system processes LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
·     If the total LSU packet transmission rate in the OSPF process does not exceed the upper limit specified by the transmit-pacing command, the system processes the subsequent LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
The above mechanism can limit the LSU packet transmission rate of the whole device and evenly process the LSU packet transmission requests of OSPF processes.
# Configure all the interfaces running OSPF process 1 to send a maximum of 10 LSU packets every 30 milliseconds.
[Sysname] ospf 1
[Sysname-ospf-1] transmit-pacing interval 30 count 10
ttl-security
Use ttl-security to enable OSPF GTSM for an area.
Use undo ttl-security to disable OSPF GTSM for an area.
ttl-security [ hops hop-count ]
undo ttl-security
OSPF GTSM is disabled for an OSPF area.
OSPF area view
Operating mechanism
After you enable GTSM in area view, GTSM checks OSPF packets from common neighbors and virtual link neighbors.
As a best practice, set the hop limit if a virtual link exists in an area. You can enable GTSM for the interfaces on the virtual link. If you do not know the interfaces on the virtual link, enable GTSM in area view to prevent packet loss.
# Enable OSPF GTSM for OSPF area 1.
[Sysname] ospf 100
ospf multi-area
ospf ttl-security
Use virtual-system enable to enable the virtual system feature globally.
Use undo virtual-system enable to disable the virtual system feature globally.
The virtual system feature is disabled.
OSPF view
In an AS, each OSPF node has a unique router ID and can manage multiple OSPF interfaces. The IP addresses of the interfaces managed by the same OSPF node cannot reside on the same network segment. When a vUP establishes neighbor relationships through the interfaces of the LPU-VMs in the auto scaling group, the IP addresses of those interfaces cannot belong to the same network segment. This requirement will cause the following issues when you add LPU-VMs to the vUP:
·     You need to perform network replanning and configure new network segments for the vUP.
·     You need to add new network segments for the vUP's neighbors, which is not supported in some networks.
To resolve these issues, use the virtual-system enable and ospf virtual-system commands together to enable the virtual system feature for the vUP. The virtual system feature functions as follows:
·     In the vUP auto scaling group, the OSPF interfaces of each LPU-VM separately generates a virtual OSPF node.
·     The IP addresses of virtual OSPF nodes belong to the same network segment, but their router IDs are different. They can establish neighbor relationships in the same way as the real OSPF nodes.
The mechanism above can facilitate adding LPU-VMs to a vUP auto scaling group.
For more information about vUPs and vUP auto scaling, see CP and UP separation basics configuration and vUP auto scaling configuration in CP and UP Separation Configuration Guide.
After you enable the virtual system feature for a vUP, the following rules apply to neighbor relationship establishment and route calculation:
·     A virtual OSPF node in the vUP advertises virtual Router LSAs. It can establish a neighbor relationship with the remote device, but does not calculate any routes.
·     A real OSPF node in the vUP advertises real Router LSAs. It calculates routes and maintain an LSDB, but does not establish any neighbor relationship with the remote device.
An OSPF interface in the vUP auto scaling group can use a virtual OSPF node to establish a neighbor relationship with the remote device only you perform the following tasks:
1.     Execute the virtual-system enable command for the vUP.
2.     Execute the ospf virtual-system command on that interface.
# Enable the virtual system feature globally.
[Sysname] ospf
[Sysname-opsf-1] virtual-system enable
ospf virtual-system
vlink-peer
Use vlink-peer to configure a virtual link.
Use undo vlink-peer to remove a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | simple { cipher | plain } string } | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | { hmac-md5 | hmac-sha-256 | md5 } key-id | retransmit | simple | trans-delay ] *
No virtual links exist.
OSPF area view
router-id: Specifies the router ID of the neighbor on the virtual link.
dead seconds: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40. The dead interval must be identical with that on the virtual link neighbor, and a minimum of four times the hello interval.
hello seconds: Specifies the hello interval in the range of 1 to 8192 seconds. The default is 10. It must be identical with the hello interval on the virtual link neighbor.
hmac-md5: Specifies the HMAC-MD5 authentication mode.
hmac-sha-256: Specifies the HMAC-SHA-256 authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
key-id: Specifies the key ID for MD5 or HMAC-MD5 authentication, in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
·     In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
·     In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
·     In HMAC-SHA-256 authentication mode, the plaintext form of the key is a string of 1 to 255 characters. The encrypted form of the key is a string of 33 to 373 characters.
retransmit seconds: Specifies the retransmission interval in the range of 1 to 3600 seconds. The default is 5.
trans-delay seconds: Specifies the transmission delay interval in the range of 1 to 3600 seconds. The default is 1.
As defined in RFC 2328, all non-backbone areas must maintain connectivity to the backbone. You can use the vlink-peer command to configure a virtual link to connect an area to the backbone. In this case, you can use the vlink-peer command to configure a virtual link to connect an area to the backbone.
Recommended configuration
When you configure this command, follow these guidelines:
·     The smaller the hello interval is, the faster the network converges, and the more network resources are consumed.
·     A retransmission interval that is too small can cause unnecessary retransmissions. A large value is appropriate for a low speed link.
·     Specify an appropriate transmission delay with the trans-delay keyword.
Key rollover mechanism
To modify the key used for MD5, HMAC-MD5, or HMAC-SHA-256 authentication for a virtual link, perform the following task:
1.     Configure a new MD5/HMAC-MD5/HMAC-SHA-256 authentication key for the virtual link on the local device. If the new key is not configured on the neighbor device, MD5/HMAC-MD5/HMAC-SHA-256 authentication key rollover is triggered. During key rollover, OSPF sends multiple packets that contain both the new and old MD5/HMAC-MD5/HMAC-SHA-256 authentication keys to ensure that the neighbor device can pass the authentication.
2.     Configure the new MD5/HMAC-MD5/HMAC-SHA-256 authentication key on the neighbor device. When the local device receives packets with the new key from the neighbor device, it exits the key rollover.
3.     Delete the old MD5/HMAC-MD5/HMAC-SHA-256 authentication key from the local device and the neighbor. This step helps prevent attacks from devices that use the old key for communication and reduces system resources and bandwidth consumption caused by key rollover.
You can configure only one of the MD5, HMAC-MD5, HMAC-SHA-256, simple authentication. If MD5, HMAC-MD5, or HMAC-SHA-256 authentication is configured, you can configure multiple keys, each having a unique key ID and key string.
To successfully establish a virtual link, make sure no multi-area adjacency interface exists in the area.
# Configure a virtual link to the neighbor with router ID 1.1.1.1.
[Sysname] ospf 100
[Sysname-ospf-100] area 2
[Sysname-ospf-100-area-0.0.0.2] vlink-peer 1.1.1.1
authentication-mode
display ospf vlink
