06-Device management commands | 725.03 KB |
display cpu-usage configuration
display device manuinfo chassis-only
display diagnostic-information
display hardware-failure-detection
display kernel memory alloc-failure
display kernel memory fragment free
display non-stop-routing status
display transceiver auto-laser-down
memory-threshold usage resend-interval
monitor cpu-usage statistics-interval core
monitor cpu-usage threshold core
monitor kernel memory fragment interval
monitor kernel memory fragment ratio
monitor resend cpu-usage core-interval
monitor resend memory-threshold
monitor resend memory-threshold dma
transceiver auto-laser-down restart
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The system time is UTC time 09:00:00 12/07/2013.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: This command changes the system time, which affects the execution of system time-related features (for example, scheduled tasks) and collaborative operations of the device with other devices (for example, log reporting and statistics collection). Before executing this command, make sure you fully understand its impact on your live network. |
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you set the time zone or daylight saving time after you execute this command, the device recalculates the system time. To view the system time, use the display clock command.
A device power cycling operation restores the local system time to the default. You must execute this command again to set the local system time.
# Set the system time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the system time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp | ptp }
undo clock protocol
The device obtains the UTC time from an NTP time source.
none: Uses the system time set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
This command is supported only on BRAS-VMs or FWD-VMs.
· If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
· If you execute the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
The system time calculated by using the UTC time from an NTP or PTP time source is more precise.
# Configure the device to use the local system time.
[Sysname] clock protocol none
[Sysname] switchto vm-net-setup
Enter password:
<Sysname-vm-net> system-view
[Sysname-vm-net] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
· MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
· month week day, where:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November, or December.
¡ week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡ day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
¡ month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time or local system time.
minus: Decreases the UTC time or local system time by an offset.
zone-offset: Specifies the offset in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time or local system time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down Ten-GigabitEthernet 2/0/0.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 2/0/0
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
copyright-info enable
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm
Use display alarm to display alarm information.
display alarm [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards.
If a power module, CPU, or fan is operating abnormally on the device, you can use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display alarm information.
<Sysname> display alarm
Slot CPU Level Info
1 0 ERROR faulty
Slot |
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-). |
Level |
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order of severity. |
Info |
Detailed alarm information: · faulty—The slot is starting up or faulty. · Fan n is absent—The specified fan is absent. · Power n is absent—The specified power module is absent. · The temperature of sensor n exceeds the lower limit—The temperature of the specified sensor is lower than the low-temperature alarm threshold. · The temperature of sensor n exceeds the upper limit—The temperature of the specified sensor is higher than the high-temperature alarm threshold. |
Use display alarm active to display information about active alarms.
display alarm active [ module module-name ] [ verbose ]
module module-name: Specifies a module by its name. If you do not specify a module, this command displays alarm information for all modules.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
# Display information about active alarms.
<Sysname> display alarm active
Seq Module Level Time Info
24 BGP Minor 2023-11-08 20:11:55 BGP peer 14.1.1.99 state changed to IDLE
23 IF Major 2023-11-08 20:33:10 Line protocol state on the interface
Seq |
Alarm sequence number, assigned when an alarm occurs. |
Module |
Alarm module name. |
Level |
Alarm severity. The values include Critical, Major, Minor, and Warning, in descending order of severity. |
Time |
Time when the alarm occurs. |
Info |
Detailed alarm information. The values include: · Board state changed to Fault on slot n—The state of the specified slot changed to Fault. The slot might be starting up or might be faulty. · Slot n fan n is absent—The specified fan is absent. · Slot n fan n is failed—The specified fan is abnormal. · Slot n power n is absent—The specified power module is absent. · Slot n power n failed—The specified power module is abnormal. · Temperature is higher than the high-temperature alarming threshold on slot n sensor inflow—The temperature of the specified sensor has exceeded the high-temperature warning threshold. · Memory minor threshold has been exceeded on slot n—The amount of free memory space on the specified slot has exceeded the minor alarm threshold. · CPU usage is in minor alarm state on slot n—The CPU usage on the specified slot has exceeded the minor alarm threshold. · Interface-name: RX power is high!—The optical power on the specified interface is too high. · Interface-name:The bit error ratio exceeds the upper threshold—The bit error rate of the specified interface has exceeded the upper limit. · SSH user username (IP: IP-Address) connected to the server successfully—The specified SSH user at the specified IP address has logged in to the server successfully. · Member port xx of aggregation group xx changed to the inactive state, because xx.—The specified member port of the specified aggregation group changed to inactive for a reason. · The mpls ldp session status changes. (SessionState=$1, DiscontinuityTime=$2, StatsUnknownMesTypeErrors=$3, StatsUnknownTlvErrors=$4)—The status of an LDP session changes: ¡ $1: LDP session status, including nonexistent, initialized, openrec, opensent, and operational. For more information about LDP sessions states, see LDP commands in MPLS Command Reference. ¡ $2: Duration when the LDP session is in the operational state. ¡ $3: Times that the LDP session received unknown messages. ¡ $4: Times that the LDP session received unknown TLVs. · The number of routes received from the BGP peer exceeded the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6) ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · BGP $1.$2: The number of routes from peer $3 ($4-$5) exceeds the limit $6. ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of route prefixes that can be received from the peer. · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has reached the threshold ($7). ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer exceeded the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · Address pool pool-name has run out of assignable subnets · Address pool pool-name has run out of IP addresses · Address pool group pool-group-name has run out of IP addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool pool-name has run out of IPv6 prefix ranges · IPv6 pool pool-name has run out of addresses · Address pool pool-name has run out of IPv6 prefixes · IPv6 pool group pool-group-name has run out of addresses · Address pool group pool-group-name has run out of assignable subnets · Address pool group pool-group-name has run out of IPv6 prefix ranges · Memory alert has been triggered for reaching the minor threshold |
# Display detailed information about active alarms.
<Sysname> display alarm active verbose
Seq 4
Module: IF
Alarm name: linkUpDown
Alarm source: interface Ten-GigabitEthernet2/0/0
Level: Major
Start time: 2023-11-09 09:31:25
Info: Line protocol state on the interface Ten-GigabitEthernet2/0/0 changed to down.
Seq |
Module |
Alarm source |
Location where the alarm occurs. |
Level |
Start time |
Info |
Detailed alarm information. |
display alarm
Use display alarm history to display information about historical alarms that have been cleared.
display alarm history [ module module-name ] [ verbose ]
If a power module, CPU, or fan is operating abnormally on the device, use the display alarm command to view the alarm information. To view historical alarms that have been cleared, use the display alarm history command. To view active alarms that were generated in the past and have not been cleared on the device, use the display alarm active command.
# Display brief information about historical alarms.
<Sysname> display alarm history
5 IF 2023-11-08 20:12:21 Line protocol state on the interface Ten-GigabitEthernet2/0/0 changed to up.
For information about the fields in the command output, see Table 2.
# Display detailed information about historical alarms.
<Sysname> display alarm history verbose
Seq 4
Module: IF
Alarm position: interface Ten-GigabitEthernet2/0/0
Level: Major
Recovery time:
2023-11-09 09:42:01
Info: Line protocol state on the interface Ten-GigabitEthernet2/0/0 changed to up.
Seq |
Alarm sequence number, assigned automatically by the system when an alarm occurs. |
Module |
AlarmPosition |
Start time |
Level |
Recovery time |
Time when an alarm is cleared. |
Info |
Detailed alarm information. The values include: · BGP $1.$2: The ratio of the number of routes received from peer $3 ($4-$5) to the number of allowed routes ($6) has fallen below the threshold ($7). ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that can be received from the peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer decreased below the alarm threshold. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNumber=$6, alarm threshold=$7). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. ¡ $7: The number of routes received by the device when the percentage of received routes to the maximum number of allowed routes reaches the alarm threshold. · The number of routes received from the BGP peer decreased below the max number of routes that can be received from the peer. (Instance=$1, AFI=$2, SAFI=$3, PeerAddrType=$4, PeerAddr=$5, MaxRouteNum=$6). ¡ $1: BGP instance name. ¡ $2: Address Family Identifier (AFI). ¡ $3: Subsequent Address Family Identifier (SAFI). ¡ $4: IP type of the BGP peer. ¡ $5: IP address of the BGP peer. ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · BGP $1.$2: The number of routes from peer $3 ($4-$5) fell below the limit $6. ¡ $1: BGP instance name. ¡ $2: VPN instance name. For a log message on public network, this field is null. ¡ $3: IP address of the BGP peer. ¡ $4: Address Family Identifier (AFI). ¡ $5: Subsequent Address Family Identifier (SAFI). ¡ $6: The maximum number of routes that the device can receive from a BGP peer. · The subnet usage of pool pool-name has descended to or dropped below 90%. · The IP address usage of pool pool-name has descended to 90%. · The IP address usage of pool group pool-group-name has descended to 90%. · The subnet usage of pool group pool-group-name has descended to or dropped below 90%. · The IPv6 prefix range usage of address pool pool-name has descended to or dropped below 90%. · The IPv6 address usage of pool pool-name has dropped to or below 90%. · The IPv6 prefix usage of pool pool-name has descended to 90%. · The IPv6 address usage of pool group pool-group-name has dropped to or below 90%. · The subnet usage of pool group pool-group-name has descended to or dropped below 90%. · The IPv6 prefix range usage of address pool group pool-group-name has descended to or dropped below 90%. · The memory usage has returned to a normal state. |
display alarm
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
control-plane: Displays CPU usage statistics for the control plane.
data-plane: Displays CPU usage statistics for the data plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards.
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
If you do not specify the control-plane or data-plane keyword, the command displays the total CPU usage statistics for the control plane.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# Display the current CPU usage statistics in table form.
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
Table 5 Command output
x% in last 5 seconds Last 5 sec |
Average CPU or CPU core usage during the most recent 5-second interval. |
y% in last 1 minute Last 1 min |
Average CPU or CPU core usage during the most recent 1-minute interval. |
z% in last 5 minutes Last 5 min |
Average CPU or CPU core usage during the most recent 5-minute interval. |
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current statistics interval is 60 seconds for the following cores: 0 to 3.
Table 6 Command output
CPU usage monitor is xxx. |
Whether CPU usage tracking is enabled. |
Current monitor interval is xxx. |
Sampling interval for CPU usage tracking. |
Current severe alarm threshold is xxx. |
Severe CPU usage alarm threshold. |
Current minor alarm threshold is xxx. |
Minor CPU usage alarm threshold. |
Current statistics interval is xxx seconds for the following cores: |
CPU core usage statistics interval. |
monitor cpu-usage enable
monitor cpu-usage interval
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
job job-id: Specifies a process by its ID in the range of 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards.
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
· The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
· The horizontal axis represents the time.
· Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
In an IRF 3.1 system, follow these guidelines:
· To display the historical CPU usage statistics for a process on a PEX, log in to the PEX, specify the process ID for the command, and execute the command.
· To display the historical CPU usage statistics for a PEX, use one of the following methods:
¡ Log in to the PEX and execute the command without specifying a process ID.
¡ (MDC-capable devices.) Log in to the MDC to which the PEX belongs and execute the command without specifying a process ID.
¡ (MDC-incapable devices.) Execute the command on the parent without specifying a process ID.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
· Process name. The name SYSTEM represents the entire system.
· CPU that is holding the process: CPU 0 in slot 1.
· Historical CPU usage statistics for the entire system during the last 60 minutes.
¡ 12 minutes ago—Approximately 5%.
¡ 13 minutes ago—Approximately 10%.
¡ 14 minutes ago—Approximately 15%.
¡ 15 minutes ago—Approximately 10%.
¡ 16 and 17 minutes ago—Approximately 5%.
¡ 18 minutes ago—Approximately 10%.
¡ 19 minutes ago—Approximately 5%.
¡ Other time—2% or lower.
display current energy-saving
Use display current energy-saving to display information about the current energy saving mode and energy saving policies.
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware |
MPU model |
Command compatibility |
RA5300, RA5300-X, RA5300-AC |
RSU-400, RSU-400S |
No |
RSU-400-G |
Yes |
# Display information about the current energy saving mode and policies.
<Sysname> display current energy-saving
Current energy-saving Mode: basic
Enable energy-saving policy including:
Fan-auto
Automatic-transceiver-laser-shutdown
Table 7 Command output
Current energy-saving mode |
Current energy saving policy name. |
Enabled energy-saving policy including |
Current energy saving policy that takes effect. Options include: · Fan-auto—Fan speed adjustment. · Automatic-transceiver-laser-shutdown—Transceiver module sleep. |
energy-saving mode
display device
Use display device to display device information.
display device [ cf-card ] [ slot slot-number | verbose ]
cf-card: Displays CF card information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the cf-card keyword, this command displays information about cards.
# Display device information.
<Sysname> display device
Slot No. Board Type Status Primary SubSlots
0 RSU-400 Normal Master 0
4 HRIC-GT8 Normal N/A 0
5 HRIC-CLGQ2 Normal N/A 0
Table 8 Command output
Board Type |
Hardware type of the card. |
Status |
Card status: · Absent—No card is installed in the slot. · Abnormal—The card is abnormal and cannot start up · Normal—The card is an interface card and is operating correctly. · Forbidden—The card is offline. · Illegal—The current software version does not support the card. The card cannot operate correctly. · Starting—The card is physically present, but is starting or is faulty. |
Primary |
Card role: · Standby—The card is the standby MPU. · Master—The card is the active MPU. |
# Display detailed device information.
<Sysname> display device verbose
Device Name: H3C RA5300
Slot 0: RSU-400
Subslot No. Board Type Status Max Ports
0 Fixed SubCard on Board Normal 2
Slot 4: HRIC-GT8
0 GT8 Normal 8
Slot 5: HRIC-CLGQ2
0 CLGQ2 Normal 21
Slot 0: RSU-400
Subslot 0
Status: Normal
Type: Fixed SubCard on Board
Hardware: 2.0
Driver: 1.0
CPLD: 1.0
FPGA: 241.0
Slot 4: HRIC-GT8
Subslot 0
Status: Normal
Type: GT8
Hardware: 2.0
Driver: 1.0
CPLD: 2.0
FPGA: 0.0
Slot 5: HRIC-CLGQ2
Subslot 0
Status: Normal
Type: CLGQ2
Hardware: 2.0
Driver: 1.0
CPLD: 3.0
FPGA: 6.0
Table 9 Command output
Board Type |
Status |
Primary |
Reason |
Cause for the current card status: · Initializing—The card is physically present, but the initialization of the software is not completed. · Unknown hardware—The card ID does not match the software version. · Failed to get manuinfo—Failed to obtain the electrical label information. · Failed to check manuinfo—The electrical label is invalid. · Power supply overload—The remaining power is insufficient in the system. · Vendor-Info does not match—The vendors are not consistent. · The <remove> command has been executed—The command for removing the card is executed. · Power-on failed—The card failed to be powered on. · Not support on this slot—The slot does not support the installed card. · Physical link check failed—The physical link is incorrect. · The <power-supply off> command has been executed—The card is powered off. · Limited by the master—The specifications are limited. · Physical card initialization failed—The initilization failed in the setrtinfo phase. · Physical port initialization failed—The initialization failed in the setdevlink phase. · Virtual card out operation failed—The reboot operation for virtual hot removal failed. · Virtual card out operation on standby MPU failed—The reboot operation for virtual removal on the standby MPU failed. · Physical card self-test failed—The self-check on the card failed. |
Type |
Hardware type. |
Hardware |
Hardware version. |
Driver |
Driver software version. |
CPLD |
CPLD version. |
FPGA |
FPGA version. |
Use display device manuinfo to display electronic label information for the device.
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays electronic label information of all cards.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Chassis self:
DEVICE_NAME : RA5300
DEVICE_SERIAL_NUMBER : 210235A3ECX2040000FQ
MAC_ADDRESS : 78AA-8212-3000
MANUFACTURING_DATE : 2020-04-10
VENDOR_NAME : H3C
PRODUCT ID : RT-RA5300
Slot 0 CPU 0:
Subslot 0:
DEVICE_NAME : RA5300-X
DEVICE_SERIAL_NUMBER : 210235A2PXA197000001
MAC_ADDRESS : 600B-0353-0400
MANUFACTURING_DATE : 2020-09-21
VENDOR_NAME : H3C
PRODUCT ID : RA5300-X
Slot 4:
Subslot 0:
DEVICE_NAME : RT-HRIC-GT8
DEVICE_SERIAL_NUMBER : 210231AC4FB19A000008
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2019-12-10
VENDOR_NAME : H3C
PRODUCT ID : RT-HRIC-GT8
Slot 5:
Subslot 0:
DEVICE_NAME : RT-HRIC-CLGQ2
DEVICE_SERIAL_NUMBER : 210231AC43P208000015
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2020-09-04
VENDOR_NAME : H3C
PRODUCT ID : RT-HRIC-CLGQ2
Fan 1:
DEVICE_NAME : FAN-60-6-A
DEVICE_SERIAL_NUMBER : 210212A07JX2040000J9
MAC_ADDRESS : NONE
VENDOR_NAME : H3C
PRODUCT ID : FAN-60-6-A
Power 1:
DEVICE_NAME : RT-PWR-RA5300-D
DEVICE_SERIAL_NUMBER : 210231AC49B19C001484
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2020-08-30
VENDOR_NAME : H3C
PRODUCT ID : RT-PWR-RA5300-D
Table 10 Command output
DEVICE_NAME |
Device name. |
DEVICE_SERIAL_NUMBER |
Serial number. |
MAC_ADDRESS |
MAC address. |
MANUFACTURING_DATE |
Manufacturing date. |
VENDOR_NAME |
Vendor name. |
Use display device manuinfo chassis-only to display electronic label information for the backplane.
# Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Chassis self:
VENDOR_NAME : H3C
display device manuinfo fan
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
Fan 1:
MAC_ADDRESS : NONE
VENDOR_NAME : H3C
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo power 1
Power 1:
MAC_ADDRESS : NONE
VENDOR_NAME : H3C
Use display diagnostic-information to display or save diagnostic information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info | verbose ] [ filename ] [ background ]
hardware: Specifies hardware-related diagnostic information.
infrastructure: Specifies diagnostic information for the fundamental features.
l2: Specifies diagnostic information for the Layer 2 features.
l3: Specifies diagnostic information for the Layer 3 features.
service: Specifies diagnostic information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical diagnostic information. The device might have a large amount of diagnostic information if an exception is present or after the device has run for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical diagnostic information. If you do not specify this keyword, the command displays or saves both critical and non-critical diagnostic information.
verbose: Saves detailed diagnostic information.
filename: Saves the information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
background: Saves diagnostic information in the background. If you do not specify this keyword, the system displays or saves diagnostic information in the CLI and you cannot execute other commands during the process. It is time consuming if a large amount of diagnostic information is to be collected. If you specify this keyword, the system saves diagnostic information in the background and users can execute other commands in the CLI during the process.
You can use one of the following methods to collect diagnostic statistics for diagnostics and troubleshooting:
· Use separate display commands to collect diagnostic information by feature or module by module.
· Use the display diagnostic-information command to collect diagnostic information for multiple or all features and hardware modules.
To save storage space, the display diagnostic-information command automatically compresses information before saving information to a file. To view the file content:
1. Use the tar extract command to extract the file.
2. Use the gunzip command to decompress the extracted file.
3. Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify any feature parameters, this command displays or saves the diagnostic information for all features and modules.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), and pipeline signs (|). For example, if the device name is A/B, the device name in the file name will be A_B, as in flash:/diag_A_B_20160101-000438.tar.gz.
This command does not support the |, >, or >> option.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected diagnostic information.
# Display the diagnostic information for all features and modules.
14:03:55 UTC Thu 01/05/2012
# Save the diagnostic information for all features and modules to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the diagnostic information for all features and modules to the test.tar.gz file.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
# Save the diagnostic information in the background to the default file.
<Sysname> display diagnostic-information background
Please input the file name (*.tar.gz)[flash:/diag_Sysname_20201215-163501.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20201215-163501.tar.gz in the background.
gunzip
more
tar extract
display dying-gasp host
Use display dying-gasp host to display poweroff alarm destination host settings.
# Display poweroff alarm destination host settings.
<Sysname> display dying-gasp host
IPv4 address: 1.1.1.0
Message type: SNMP Trap
Securityname: p1
Version: V1
IPv4 address: 1.1.1.1
Message type: Syslog
Table 11 Command output
IPv4 address |
IPv4 address of the poweroff alarm destination host. |
IPv6 address |
IPv6 address of the poweroff alarm destination host. |
VPN instance |
VPN instance to which the poweroff alarm destination host belongs. |
Message type |
Message types that the poweroff alarm destination host supports: · SNMP Trap—SNMP notification. · Syslog—Log message. |
Securityname |
SNMPv1 or SNMPv2c community name. This field is displayed when the message type is SNMP Trap. |
Version |
SNMP version: · v1—SNMPv1. · v2c—SNMPv2c. This field is displayed when the message type is SNMP Trap. |
dying-gasp host
display energy-saving mode
Use display energy-saving mode to display detailed information about the energy saving modes of the device.
display energy-saving mode [ standard | basic ]
Hardware |
MPU model |
RSU-400, RSU-400S |
No |
RSU-400-G |
Yes |
standard: Specifies the standard energy saving mode.
basic: Specifies the basic energy saving mode.
If you do not specify any keyword, this command displays detailed information about all energy saving modes.
# Display detailed information about all energy saving modes.
<Sysname> display energy-saving mode basic
Energy-saving Mode: basic
Fan-auto
Table 12 Command output
Energy-saving mode |
Current energy saving policy that takes effect, including: · Fan-auto—Fan speed adjustment. · Automatic-transceiver-laser-shutdown—Transceiver module sleep. |
energy-saving mode
display environment
Use display environment to display temperature information.
This command displays information about all temperature sensors on the device if you do not specify a card.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
Slot Subslot Sensor ID Temperature LowerLimit WarningLimit AlarmLimit Shutdown
0 0 inflow 1 32 -20 67 69 N/A
0 0 hotspot 1 52 -20 82 85 N/A
0 0 hotspot 2 51 -20 80 83 85
0 0 hotspot 3 58 -20 91 103 107
1 0 inflow 1 32 -20 67 69 N/A
1 0 hotspot 1 53 -20 82 85 N/A
1 0 hotspot 2 54 -20 80 83 85
1 0 hotspot 3 56 -20 91 103 107
Table 13 Command output
System Temperature information (degree centigrade) |
Temperature information (°C). |
Slot |
Slot number. |
Subslot |
Subslot number. |
sensor |
Temperature sensor |
ID |
Temperature sensor ID. |
Temperature |
Current temperature. |
LowerLimit |
Lower temperature limit. If the device does not support this field, this field displays NA. |
WarningLimit |
Warning temperature threshold. If the device does not support this field, this field displays NA. |
AlarmLimit |
Alarming temperature threshold. If the device does not support this field, this field displays NA. |
Shutdown |
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA. |
display fan
Use display fan to display fan tray operating status information.
display fan [ fan-id ]
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Index Status Speedlevel
1 Normal 24%
Table 14 Command output
Status |
Fan status: · Absent—No fan tray is installed in the slot. · Fault—The fan is faulty. · Normal—The fan is operating correctly. · FanDirectionFault—The actual airflow direction is not the preferred direction. |
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
The fix records are stored on the active MPU. You can use this command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
# Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
chip : isolate
board : isolate
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
There is no record.
--------------------------Slot 0 trapped records:-----------------------------
There is no record.
Table 15 Command output
Current level |
Fix actions specified for hardware failures. |
chip |
Fix action for hardware failures on components of cards. |
board |
Fix action for hardware failures on control paths. |
forwarding |
Fix action for hardware failures on the forwarding plane. |
Recent record |
Recent failure fix records. |
xxx executed records |
Fix records stored on an MPU. |
xxx trapped records |
Trap records stored on an MPU. |
display health
Use display health to display CPU and memory usage.
display health [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays CPU and memory usage on all cards.
# Display the CPU and memory usage on all cards.
<Sysname> display health
Slot CPU Role CPU Usage(%) Memory Usage(%) Used/Total(MB)
0 0 MPU(Master) 9 64 5007/7785
1 0 MPU(Standby) 9 61 4798/7785
Table 16 Command output
Role |
Card role: · MPU(Master)—Active MPU. · MPU(Standby)—Standby MPU. |
CPU Usage(%) |
Average CPU usage during the past 5 seconds, in percentage. |
Memory Usage(%) |
Memory usage in percentage. |
Used/Total(MB) |
Memory usage and total amount of memory in MB. |
Use display kernel memory alloc-failure to display kernel memory allocation failure information.
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory allocation failure information for the active MPU.
# Display kernel memory allocation failure information.
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
Table 17 Command output
kmalloc_tag failures |
Number of memory allocation failures on the use of kmalloc_tag. |
kcalloc_tag failures |
Number of memory allocation failures on the use of kcalloc_tag. |
kzalloc_tag failures |
Number of memory allocation failures on the use of kzalloc_tag. |
krealloc_tag failures |
Number of memory allocation failures on the use of krealloc_tag. |
kmem_cache_alloc_tag failures |
Number of memory allocation failures on the use of kmem_cache_alloc_tag. |
Use display kernel memory fragment free to display the kernel memory fragment statistics.
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel memory fragment statistics for the active MPU.
# Display the kernel memory fragment statistics.
<Sysname> display kernel memory fragment free
Kernel memory free ratio: 0.13%
cfq_io_context memory free (in kbytes): 0
LFIB_NhlfeEntryCache26 memory free (in kbytes): 0
LFIB_NhlfeEntryCache74 memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache memory free (in kbytes): 0
NAT_SESSION_EXT_INFO memory free (in kbytes): 0
ARP_VSISUP_Entry_cache memory free (in kbytes): 0
LFIB_NhlfeEntryCache1 memory free (in kbytes): 0
FVN_FwdCache19 memory free (in kbytes): 0
Table 18 Command output
Kernel memory free ratio |
Memory fragment ratio in the kernel space. |
cfq_io_context memory free (in kbytes) |
Memory fragment size in the slab named cfq_io_context, in KB. |
display memory
Use display memory to display memory usage information.
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 984560 456128 528432 0 4 45616 53.7%
-/+ Buffers/Cache: 410508 574052
Swap: 0 0 0
LowMem: 739824 375552 364272 -- -- -- 49.2%
HighMem: 244736 80576 164160 -- -- -- 67.1%
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 984560 456128 528432 4 45616 53.7%
Low memory statistics are measured in KB:
1 0 739824 375552 364272 -- -- 49.2%
High memory statistics are measured in KB:
1 0 244736 80576 164160 -- -- 67.1%
Table 19 Command output
Mem |
Memory usage information. |
Total |
Total size of the physical memory space that can be allocated. The memory space is virtually divided into two parts. Part 1 is solely used for functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1. |
Used |
Used physical memory. |
Free |
Free physical memory. |
Shared |
Physical memory shared by processes. If this field is not supported, two hyphens (--) are displayed. |
Buffers |
Physical memory used for buffers. If this field is not supported, two hyphens (--) are displayed. |
Cached |
Physical memory used for caches. If this field is not supported, two hyphens (--) are displayed. |
Caches |
Physical memory used for caches. |
FreeRatio |
Free memory ratio. |
-/+ Buffers/Cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications. -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications. |
Swap |
Memory space for swapping. |
LowMem |
Low-memory usage information. |
HighMem |
High-memory usage information. |
display memory dma
Use display memory dma to display DMA memory usage information.
display memory dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory usage information for the active MPU.
# Display DMA memory usage information for slot 1.
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
Table 20 Command output
Total |
Total size of the DMA memory space, including the free and used DMA memory. |
Used |
Used DMA memory. |
Free |
Free DMA memory. |
FreeRatio |
Free DMA memory ratio. |
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 85%
Free-memory thresholds:
Minor: 0M
Severe: 0M
Critical: 0M
Normal: 0M
Current free-memory state: Normal
Free-memory event statistics:
[Back to normal state]
First notification: 0.0
Latest notification: 0.0
Total number of notifications sent: 0
[Entered minor alarm state]
First notification at: 0.0
Latest notification at: 0.0
[Back to minor alarm state]
[Entered severe alarm state]
[Back to severe alarm state]
[Entered critical alarm state]
Table 21 Command output
Free-memory thresholds Minor Severe Critical Normal |
Free-memory thresholds, including: · Minor—Minor alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the minor alarm threshold. · Severe—Severe alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the severe alarm threshold. · Critical—Critical alarm threshold in MB. If this field displays two hyphens (--), the device failed to obtain the critical alarm threshold. · Normal—Normal state threshold in MB. If this field displays two hyphens (--), the device failed to obtain the normal state threshold. |
Current free-memory state |
Current state of the free memory in the system: · Normal—Normal state. · Minor—Minor alarm threshold. · Severe—Severe alarm threshold. · Critical—Critical alarm threshold. |
display memory-threshold dma
Use display memory-threshold dma to display DMA memory alarm information.
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays DMA memory alarm information for the active MPU.
# Display DMA memory alarm information.
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
[Entered to critcal state]
First notificatio: 0.0
Use display non-stop-routing status to display nonstop routing (NSR) status information for modules that support the NSR feature.
# Display NSR status information for modules that support the NSR feature.
<Sysname> display non-stop-routing status
NSR status: Not ready
Module name(instance name/process ID) Status
MSDP Not ready
OSPF(1) Ready
OSPF(2) Ready
BGP(default) Ready
BGP(aaa) Ready
PIM Not configured
Table 22 Command output
NSR status |
Global NSR status: · Ready—NSR is in stable state for all NSR-enabled modules. · Not ready—NSR is not in stable state for one or more NSR-enabled modules. · Not configured—NSR is not enabled for any modules. · No standby—No backup hardware exists for NSR. |
Module name(instance name/process ID) |
Name of an NSR-capable module and the instance name or process ID, for example, BGP(default) and OSPF(1). If there is no instance name or process, this field displays only the module name. |
Status |
NSR status: · Ready—NSR is in stable state status for the module. · Not ready—NSR is not in stable state for the module. You cannot perform a process switchover or active/standby switchover. · Not configured—NSR is not enabled for the module. You cannot perform a process switchover or active/standby switchover. |
display power
Use display power to display power module information.
display power [ power-id | verbose ]
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief power module information.
<Sysname> display power
Index Status
PWR1 Normal
PWR2 Absent
Table 23 Command output
Index |
Index of the power module on the device. |
Status |
Power module status. Options include: · Absent—No power module is installed in the slot. · Fault—The power module is faulty. · Normal—The power module is operating correctly. |
# Display detailed power module information.
<Sysname> display power verbose
Index Status Type Description
PWR1 Normal DC 48V DC Power
PWR2 Absent DC 48V DC Power
Power supply information for chassis 0
Redundancy mode : 1 + 1
Redundancy status : Inactive
Rated system power : 1000 W
Current system power : 172 W
Rated power ratio : 17.2 %
Slot Card type Rated-Power(W) Current-Power(W) Rated-Power-Ratio
0 RSU-400 130 94 72.3%
1 N/A - - -
2 N/A - - -
3 N/A - - -
4 HRIC-GT8 14 8 57.1%
5 HRIC-CLGQ2 70 35 50.0%
6 N/A - - -
7 N/A - - -
8 N/A - - -
9 N/A - - -
- FAN-60-6-A 186 35 18.8%
Table 24 Command output
Index |
Slot number of the power module. |
Status |
Type |
Type of the power module. |
Description for the power module. |
Power supply information for chassis 0 |
Device where the power module resides. |
Redundancy mode |
Redundancy mode of the power module. |
Redundancy status |
Redundancy status of the power module. |
Rated system power |
Rated power of the power module. |
Current system power |
Current power of the power module. |
Rated power ratio |
Percentage of the current power of the power module to its rated power. |
Slot |
Slot number. |
Card type |
Card type. |
Rated-Power(W) |
Rated power. |
Current-Power(W) |
Current power. |
Rated-Power-Ratio |
Percentage of the current power to the rated power. |
display power-supply
Use display power-supply to display power supply management information.
display power-supply [ verbose ]
verbose: Displays detailed power supply management information. If you do not specify this keyword, this command displays the brief information.
# Display brief information of power supply management.
<Sysname> display power-supply
Index Status
PWR1 Normal
PWR2 Absent
Table 25 Command output
Index |
Status |
Status of the power module. Options include: · Absent—No power module is installed in the slot. · Fault—The power module is faulty. · Normal—The power module is operating correctly. |
# Display detailed information of power supply management.
<Sysname> display power-supply verbose
Current system power : 171 W
Rated power ratio : 17.1 %
1 N/A - - -
2 N/A - - -
3 N/A - - -
5 HRIC-CLGQ2 70 34 48.6%
6 N/A - - -
7 N/A - - -
8 N/A - - -
9 N/A - - -
Table 26 Command output
Index |
Index of the power module slot on the device. |
Status |
Status of the power module. Options include: · Absent—No power module is installed in the slot. · Failed—The power module is faulty. · Normal—The power module is operating correctly. |
Type |
Redundancy mode |
Redundancy status |
Rated power ratio |
Slot |
Slot number. |
Card type |
Card type. |
Rated-Power(W) |
Rated power. |
Current-Power(W) |
Current power. |
Rated-Power-Ratio |
display save-power
Use display save-power to display power saving information.
display save-power
Hardware compatibility
Hardware |
MPU model |
RSU-400, RSU-400S |
No |
RSU-400-G |
Yes |
# Display power saving information.
<Sysname> display save-power
Save-power state: enable
Table 27 Command output
Save-power state |
Power saving mode: · disabled—Power saving is disabled. · enabled—Power saving is enabled. |
display scheduler job
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: 123
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
display scheduler logfile
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 2/0/0 to ten-gigabitethernet 2/0/2
[Sysname-if-range]shutdown
Table 28 Command output
Logfile Size |
Size of the log file, in bytes. |
Schedule name |
Schedule to which the job belongs. |
Execution time |
Time when the job was started. |
Completion time |
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank. |
Job output |
Commands in the job and their output. |
reset scheduler logfile
display scheduler reboot
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
scheduler reboot at
scheduler reboot delay
display scheduler schedule
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2011
Last execution time : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts : 1
Job name Last execution status
shutdown Successful
Table 29 Command output
Schedule type |
Execution time setting of the schedule. If no execution time is specified, this field is not displayed. |
Start time |
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed. |
Last execution time |
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field. |
Last completion time |
Last time when the schedule was completed. If no execution time is specified, this field is not displayed. |
Execution counts |
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed. |
Job name |
Name of a job under the schedule. |
Last execution status |
Result of the most recent execution: · Successful. · Failed. · Waiting—The device is executing the schedule and the job is waiting to be executed. · In process—The job is being executed. · -NA-—The execution time has not arrived yet. To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command. |
display system stable state
Use display system stable state to display system stability and status information.
display system stable state[ summary ]
summary: Displays brief information about system stability and status, including system status, redundancy status, and NSR status. If you do not specify this keyword, the command displays detailed information about system status, redundancy status, and CPU role and status.
Before performing a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device/card/MDC/context startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices/cards/MDCs/contexts that are not in Stable state. You can also use other commands to identify the faulty components. For example:
· Use the display device command to identify the device operating status.
· Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
· Use the display system internal process state command in probe view to display service operating status.
# Display brief information about system stability and status.
<Sysname> display system stable state summary
System state : Stable
Redundancy state : No redundancy
NSR state : No standby
# Display system stability and status information.
Redundancy state : Stable
Slot CPU Role State
0 0 Active Stable
Table 30 Command output
System state |
Operating status of all cards: · Stable—All cards are operating stably. · Not ready—One or more cards are not operating stably. |
Redundancy state |
System redundancy status: · Stable—The MPUs are operating stably. You can perform a switchover. · No redundance—The system has only one MPU. You cannot perform a switchover. · Not ready—The system is not operating stably. You cannot perform a switchover. |
Role |
Role of the card in the system: · Active—The card is the active MPU. · Standby—The card is the standby MPU. · Other—The card is a service module. |
State |
Operating status of the card: · Stable—The card is operating stably. · Board inserted—The card has just been installed. · Kernel initiating—Card kernel is being initialized. · Service starting—Services are starting. · Service stopping—Services are stopping. · HA batch backup—An HA batch backup is going on. · Interface data batch backup—An interface data batch backup is in progress. |
The object is not operating stably. |
display device
display ha service-group (High Availability Command Reference)
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
You can use the display transceiver alarm command to display alarms present on transceiver modules.
If no error occurs, None is displayed. The following tables describe the alarm information that might be present on transceiver module.
Table 31 Command output on SFP/SFP28/SFP+ transceiver modules
RX signal loss |
Receive signal loss. |
RX power high alarm |
Alarm on a high receive optical power. |
RX power high warning |
Early warning on a high receive optical power. |
RX power low alarm |
Alarm on a low receive optical power. |
RX power low warning |
Early warning on a low receive optical power. |
TX fault |
Transmit fault. |
TX bias high alarm |
Alarm on a high transmit bias current. |
TX bias high warning |
Early warning on a high transmit bias current. |
TX bias low alarm |
Alarm on a low transmit bias current. |
TX power high warning |
Early warning on a high transmit optical power. |
TX power high alarm |
Alarm on a high transmit optical power. |
TX power low alarm |
Alarm on a low transmit optical power. |
TX power low warning |
Early warning on a low transmit optical power. |
Temp high alarm |
Alarm on a high temperature. |
Temp high warning |
Early warning on a high temperature. |
Temp low alarm |
Alarm on a low temperature. |
Temp low warning |
Early warning on a low temperature. |
Voltage high alarm |
Alarm on a high voltage. |
Voltage high warning |
Early warning on a high voltage. |
Voltage low alarm |
Alarm on a low voltage. |
Voltage low warning |
Early warning on a low voltage. |
Transceiver info I/O error |
N/A |
Transceiver info checksum error |
N/A |
Transceiver type and port configuration mismatch |
The transceiver type does not match port configuration. |
Transceiver type not supported by port hardware |
The transceiver type is not supported on the port. |
TEC error |
Thermoelectric Cooler (TEC) fault. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Wavelength unlocked |
Optical signal wavelength is out of lock. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Tx is not ready due to tunning |
The transmitter is not ready when the signal wavelength changes. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Received an ITU channel number request |
An ITU channel number request was received. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Requested ITU channel number is invalid |
The requested ITU channel number is invalid. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Tx dither not supported |
Transmit dithering is not supported. This field is available only for the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
RX CDR loss of lock |
Receive CDR loss of lock, indicating poor signal. |
TX CDR loss of lock |
Transmit CDR loss of lock, indicating poor signal. |
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 2/0/0.
<Sysname> display transceiver alarm interface ten-gigabitethernet 2/0/0
Ten-GigabitEthernet2/0/0 transceiver current alarm information:
RX signal loss
RX power low alarm
Table 32 Command output
transceiver current alarm information |
Alarms present on the transceiver module. |
RX signal loss |
Input signal loss occurred. |
display transceiver auto-laser-down
Use display transceiver auto-laser-down to display information about auto laser shutdown.
display transceiver auto-laser-down { controller | interface } [ interface-type interface-number ]
controller [ interface-type interface-number ]: Specifies a controller interface by its type and number. If no interface is specified, this command applies to all controller interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display information about auto laser shutdown for the transceiver module in interface Ten-GigabitEthernet 2/0/0.
<Sysname> display transceiver auto-laser-down interface ten-gigabitethernet 2/0/0
Interface Auto-laser-down Laser Restart Interval(s) Width(s)
status status mode
Ten-GigabitEthernet2/0/0 Enabled On Auto 100 2
Table 33 Command output
Auto-laser-down status |
Whether auto laser shutdown is enabled: · Enabled. · Disabled. |
Laser status |
Whether the transceiver laser is emitting light: · On—The laser is emitting light. · Off—The laser is not emitting light. |
Restart mode |
Restart mode of the transceiver laser: · Auto. · Manual. |
Interval(s) |
Pulse sending interval after the laser restarts, in seconds. |
Width(s) |
Pulse width (duration) of each light emission for detection after the laser restarts, in seconds. |
display transceiver brief
Use display transceiver brief to display information about all transceiver modules, including transceiver module types, receive power, and transmit power.
# Display transceiver module types, receive power, and transmit power of all transceiver modules on the device.
<Sysname> display transceiver brief
Table 34 Command output
Abbreviated Interface name. |
TransceiverInfo |
Type of the transceiver module, consisting of its speed, transmission distance, and form factor. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not provide access to its information. The system can display only the transceiver modules in the most common form factor for a speed, as follows: · 16 Gbps or lower—SFP transceiver module. · 25 Gbps—SFP28 transceiver module. · 50 Gbps—QSFP28 transceiver module. · 100 Gbps—QSFP28 transceiver module. The system cannot display information about the transceiver modules in a form factor not listed above. |
WaveL |
Wavelength of the interface. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining wavelength information. |
Mode |
Mode of the transceiver module: · MM—Multi-mode. · SM—Single mode. · Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining mode information. |
Rx(dBm) Current/Range |
Current receive power/normal receive power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid. |
Tx(dBm) Current/Range |
Current transmit power/normal transmit power range. Two hyphens (--) indicate that the device failed to obtain data or the transceiver module does not support obtaining power information. N/A indicates that the obtained power value is invalid. |
Status |
Current power status: · Normal—The power is in the normal range. · Beyond threshold—The power exceeds the normal range. · Unknown—The status is unknown. · Two hyphens (--)—The device failed to obtain data or the transceiver module does not support obtaining status information. |
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 2/0/0.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 2/0/0
Ten-GigabitEthernet2/0/0 transceiver diagnostic information:
Temp(C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
Table 35 Command output
transceiver diagnostic information |
Digital diagnosis information for the transceiver module in the interface. |
Wave.er(nm) |
Wavelength offset in nm, accurate to 0.001 nm. This field is supported only on the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Freq.er(GHz) |
Frequency offset in GHz, accurate to 0.1 GHz. This field is supported only on the HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A), SFP-XG-LH80-Tunable, and CFP2-200G-DCO-Tunable transceiver modules. |
Temp(C) |
Temperature in °C, accurate to 1°C. |
Voltage(V) |
Voltage in V, accurate to 0.01 V. |
Total RX power(dBm) |
Total receive power in dBm, accurate to 0.01 dBm. |
Total TX power(dBm) |
Total transmit power in dBm, accurate to 0.01 dBm. |
Bias(mA) |
Bias current in mA, accurate to 0.01 mA. |
RX power(dBm) |
Receive power in dBm, accurate to 0.01 dBm. |
TX power(dBm) |
Transmit power in dBm, accurate to 0.01 dBm. |
Total average launch power(dBm) |
Total average launch power on the multi-lane transceiver module in dBM, accurate to 0.01 dBm. |
Table 36 Command output for the CFP2-200G-DCO-Tunable transceiver module
TX power(dBm) |
RX power(dBm) |
Chromatic dispersion(ps/nm) |
Chromatic dispersion in ps/nm, accurate to 1 ps/nm. |
Differential group delay(ps) |
Differential group delay in ps, accurate to 1 ps. |
Q(dB) |
Q factor in dB, accurate to 0.1 dB. |
Carrier frequency(MHz) |
Carrier frequency offset in MHz, accurate to 1 MHz. |
SNR(dB) |
Signal noise ratio in dB, accurate to 0.1 dB. |
SNR of X polarization(dB) |
SNR of X polarization in dB, accurate to 0.1 dB. |
SNR of Y polarization (dB) |
SNR of Y polarization in dB, accurate to 0.1 dB. |
BER |
Bit error rate in scientific notation, accurate to 2 decimal places. |
OSNR(dB) |
Optical signal to noise ratio in dB, accurate to 0.1 dB. |
OSNR of X polarization(dB) |
OSNR of X polarization in dB, accurate to 0.1 dB. |
OSNR of Y polarization (dB) |
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 2/0/0.
<Sysname> display transceiver interface ten-gigabitethernet 2/0/0
Ten-GigabitEthernet2/0/0 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),275(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
Table 37 Command output
Connector Type |
Connector types: · SC—Fiber connector developed by NTT. · LC—1.25 mm/RJ-45 fiber connector developed by Lucent. · RJ-45. · CX 4. |
Wavelength(nm) |
Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma. For a copper cable, this field displays N/A. |
Transfer Distance(xx) |
Transmission distance, where xx indicates the distance unit: · km—Kilometers, for single-mode transceiver modules. · m—Meters, for other transceiver modules. If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form of transmission distance (medium type). Transmission medium types include: · 9 um—9/125 µm single-mode fiber. · 50 um—50/125 µm multi-mode OM2 fiber. · 62.5um—62.5/125 um multi-mode OM1 fiber. · CX4—CX4 cable. · OM3—50 um multi-mode OM3 fiber. · OM4—50 um multi-mode OM4 fiber. · OM5—50 um multi-mode OM5 fiber. · STACK—Stack cable. · TP—Twisted pair. |
Digital Diagnostic Monitoring |
Support for digital diagnosis: · YES—Supported. · NO—Not supported. |
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 2/0/0.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 2/0/0
Ten-GigabitEthernet2/0/0 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2012-09-01
Vendor Name : H3C
Table 38 Command output
Manu. Serial Number |
Serial number generated during production of the transceiver module. |
Manufacturing Date |
Date when the electronic label information was written to the transceiver module. |
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1 (updated on Aug 23 2023 at 09:44:33):
*Name : ra5300rsu4xx-cmw710-boot-e7752.bin
Version : 7.1.075 ESS 7752
Compile time: Jul 26 2023 11:00:00
*Name : ra5300rsu4xx-cmw710-system-e7752.bin
Record n |
Number of the startup software image upgrade record. Record 1 is the most recent record. |
Name |
Software image file name. |
The software image version changed during the upgrade. |
reset version-update-record
display voltage
Use display voltage to display voltage information.
display voltage [ slot slot-number ]
If you do not specify a card, this command displays voltage information for all cards.
If the voltage is lower than the lower limit or higher than the higher limit, the device sends a log message and a trap.
# Display voltage information.
<Sysname> display voltage
System voltage information (volt):
Slot Subslot Channel Status ReqVolta CurVolta LowThreshold HighThreshold
Major Fatal Major Fatal
1 0 1 Absent N/A N/A N/A N/A N/A N/A
1 0 2 Absent N/A N/A N/A N/A N/A N/A
1 0 3 Absent N/A N/A N/A N/A N/A N/A
1 0 4 Absent N/A N/A N/A N/A N/A N/A
1 0 5 Absent N/A N/A N/A N/A N/A N/A
1 0 6 Absent N/A N/A N/A N/A N/A N/A
1 0 7 Absent N/A N/A N/A N/A N/A N/A
1 0 8 Absent N/A N/A N/A N/A N/A N/A
Table 40 Command output
Slot |
Slot number. |
Subslot |
Subslot number. |
Channel |
Channel number. |
Status |
Status of the voltage sensor. |
ReqVolta |
Rated voltage of the voltage sensor. |
CurVolta |
Current voltage of the voltage sensor. |
LowThreshold |
Low voltage alarm threshold of the voltage sensor. |
HighThreshold |
High voltage alarm threshold of the voltage sensor. |
dying-gasp host
Use dying-gasp host to configure poweroff alarm destination host settings.
Use undo dying-gasp host to remove poweroff alarm destination host settings.
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] snmp-trap version { v1 | v2c } securityname security-string
dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] syslog
undo dying-gasp host { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] { snmp-trap | syslog }
No poweroff alarm destination host settings are configured.
ip-address: Specifies the IPv4 address of the destination host to which the device sends the poweroff alarm.
ipv6 ipv6-address: Specifies the IPv6 address of the destination host to which the device sends the poweroff alarm.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the destination host belongs to the public network, do not specify this option.
snmp-trap: Uses an SNMP notification to send the poweroff alarm.
version: Specifies the SNMP version.
v1: Uses SNMPv1.
v2c: Uses SNMPv2c.
securityname security-string: Specifies an SNMPv1 or SNMPv2c community name, a case-sensitive string of 1 to 32 characters.
syslog: Uses a log message to send the poweroff alarm.
The device can send the poweroff alarm by using either or both of an SNMP notification and a log message.
The device can send the poweroff alarm to multiple destination hosts at the same time.
# Configure the device to send the poweroff alarm to the host at 1.1.1.1 by using an SNMPv1 notification. The community name is public.
[Sysname] dying-gasp host 1.1.1.1 snmp-trap version v1 securityname public
dying-gasp source
dying-gasp source
Use dying-gasp source to specify the source interface for sending the poweroff alarm.
Use undo dying-gasp source to restore the default.
dying-gasp source interface-type { interface-number | interface-number.subnumber }
No source interface is specified. On an IPv4 network, the device uses the primary IPv4 address of the output interface for the route to the destination host as the source address. On an IPv6 network, the device selects a source IPv6 address as defined in RFC 3484.
interface-type { interface-number | interface-number.subnumber }: Specifies a Layer 3 interface or subinterface. The interface-type argument specifies the interface type. The interface-number argument specifies the interface number. The subnumber argument specifies the subinterface number and is in the range of 1 to 4094.
The device uses the IPv6 address or primary IPv4 address of the specified source interface as the source address for outgoing poweroff alarm packets. The destination hosts use this address to identify SNMP notifications or log messages received from the device.
If no address is configured for the specified source interface, this command does not take effect. For this command to take effect, assign an address to the source interface.
# Use the Loopback 1 interface as the source interface for sending the poweroff alarm.
[Sysname] dying-gasp source loopback 1
dying-gasp host
energy-saving mode
Use energy-saving mode to specify the energy saving mode for the device.
energy-saving mode { standard | basic }
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware |
MPU model |
Command compatibility |
RA5300, RA5300-X, RA5300-AC |
RSU-400, RSU-400S |
No |
RSU-400-G |
Yes |
The standard energy saving mode is specified for the device.
Table 41 shows the energy saving modes that are available for the device. An energy saving mode will takes effect immediately after you specify it.
Table 41 Energy saving modes on the device
Energy saving mode |
Standard |
Default energy saving mode in the factory-default configuration of the device. |
Basic |
Supports the following functions except for those in standard mode: · Fan-auto—Fan speed adjustment. · Automatic-transceiver-laser-shutdown—Transceiver module sleep. |
# Specify the basic energy saving mode for the device.
[Sysname] energy-saving mode basic
The system will enable automatic transceiver laser shutdown, energy saving for redundant power supplies, and interface auto sleep. Continue?[Y/N]:y
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
No banner is configured.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign the save-job job to the saveconfig schedule.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
line-card-mode
Use line-card-mode to specify an operating mode for an interface card.
line-card-mode slot slot-number mode-name
The HRIC-XP8-H interface card operates in Ethernet mode.
mode-name: Specifies an operating mode. Available operating modes depend on the interface card type. The following shows all operating mode values:
· ethernet: Specifies the Ethernet mode. All interfaces on the interface card act as Ethernet interfaces. For more information about Ethernet interfaces, see Interface Configuration Guide.
· flexe: Specifies the flexible Ethernet mode. All interfaces on the interface card act as FlexE interfaces. For more information about FlexE interfaces, see Interface Configuration Guide.
For a new operating mode to take effect, you must perform one of the following tasks to activate the new operating mode:
· Hot swap the interface card if the interface card are hot swappable.
· Restart the device.
This command is available only for the HRIC-XP8-H interface card. In addition, this card can switch to the flexible Ethernet mode only when installed in slot 4, 5, 6, or 7.
# Configure an interface card to operate in flexible Ethernet mode.
[Sysname] line-card-mode slot 5 flexe
Please reboot or hot-swap (if supported) the card for the configuration to take effect.
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 96 MB.
Severe alarm threshold: 64 MB.
Critical alarm threshold: 48 MB.
Normal state threshold: 128 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument. This threshold must be equal to or less than the total memory size.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU.
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
(On devices that do not support low memory.) You can use the display memory command to display memory usage information.
(On devices that support low memory.) The system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information.
(On devices with slots that support low memory.) For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
For more information about the alarm thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
Use memory-threshold dma to set DMA memory thresholds.
Use undo memory-threshold dma to restore the default.
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm threshold is 2048 KB, and the normal state threshold is 4096 KB.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets DMA memory thresholds for the active MPU.
ratio: Specifies DMA memory thresholds in percentage.
critical critical-value: Specifies the DMA memory alarm threshold. If the ratio keyword is specified, the value range for the critical-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, you can enter a question mark (?) in the place of the critical-value argument to view the value range for the threshold..
normal normal-value: Specifies the normal state threshold. If the ratio keyword is specified, the value range for the normal-value argument is 1 to 100 in percentage. If the ratio keyword is not specified, you can enter a question mark (?) in the place of the normal-value argument to view the value range.
To ensure correct operation of the services that require DMA memory, the system monitors the amount of free DMA memory space regularly. If the amount of free DMA memory space decreases to or below the alarm threshold, the system generates a notification indicating that the DMA memory space is insufficient. If the amount of free DMA memory space increases above the normal state threshold, the system generates a notification indicating that the DMA memory space is sufficient.
# Set the DMA memory alarm threshold and the normal state threshold to 32KB and 96 KB, respectively, for slot 1.
<System> system-view
[System] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
memory-threshold usage resend-interval
Use memory-threshold usage resend-interval to set the memory usage alarm resending interval.
Use undo memory-threshold usage resend-interval to restore the default.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval
The memory usage alarm resending interval is 300 seconds.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU.
resend-interval interval-value: Specifies the memory usage alarm resending interval in the range of 1 to 3600, in minutes.
The device samples memory usage periodically, and compares the sampled value with the memory usage thresholds. If the sampled value exceeds an alarm threshold, the device enters alarm state and generates an alarm (log and trap) to notify the administrator. If the memory usage remains in the alarm state after the memory usage alarm resending interval is reached, the device outputs the alarm again.
# Set the memory usage alarm resending interval to 60 minutes for CPU 0 in slot 1.
[Sysname] memory-threshold slot 1 cpu 0 usage resend-interval 60
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage monitoring for the active MPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage statistics-interval core
Use monitor cpu-usage statistics-interval core to set the CPU core usage statistics interval.
Use undo monitor cpu-usage statistics-interval core to restore the default.
monitor cpu-usage statistics-interval interval slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage statistics-interval slot slot-number cpu cpu-number core core-id-list
The CPU core usage statistics interval is 60 seconds.
interval: Specifies the CPU core usage statistics interval, in seconds. The value range for this argument is 10 to 3600. As a best practice, set this argument to a multiple of the sampling interval, which is fixed at 5 seconds. If you do not do so, the effective statistics interval is the biggest multiple of the sampling interval that is smaller than the setting. For example, if you set this argument to 12 seconds, the effective statistics interval is 10 seconds.
core-id-list: Specifies a space-separated list of up to 10 CPU core items. Each item specifies a CPU core or a range of CPU cores in the form of core-id1 [ to core-id2 ]. The value for core-id2 must be equal to or greater than the value for core-id1.
The device samples CPU core usage at 5-second intervals and calculates the average value during each CPU core usage statistics interval. If the value during an interval is greater than a CPU core usage alarm threshold, the device issues an alarm and logs the event.
# Set the usage statistics interval to 60 seconds for a CPU core.
[Sysname] monitor cpu-usage statistics-interval 60 slot 1 cpu 0 core 0
monitor cpu-usage threshold core
monitor resend cpu-usage core-interval
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold ] [ slot slot-number [ cpu cpu-number ] ]
The severe CPU usage alarm threshold is 99%. The minor CPU usage alarm threshold is 79%.
cpu-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU.
CAUTION: If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal service processing will be affected. |
The device samples CPU usage at 1-minute intervals. If the sample is greater than a CPU usage alarm threshold, the device sends a trap. If the sample is equal to or less than the CPU usage recovery threshold, the device determines that the CPU usage is normal.
# Set the severe CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
Use monitor cpu-usage threshold core to set CPU core usage alarm thresholds.
Use undo monitor cpu-usage threshold core to restore the default.
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] slot slot-number cpu cpu-number core core-id-list
The severe CPU usage alarm threshold is 99%, and the minor CPU usage alarm threshold is 79%.
severe-threshold : Specifies the severe CPU core usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU core usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU core usage alarm threshold minus 1. If you do not specify this option, the minor CPU core usage alarm threshold is 80 percent of the severe CPU core usage alarm threshold.
recovery-threshold recovery-threshold: Specifies the CPU core usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU core usage alarm threshold minus 1. If you do not specify this option, the CPU core usage recovery threshold is 70 percent of the severe CPU core usage alarm threshold.
cpu cpu-number: Specifies a CPU by its slot number.
core core-id-list: Specifies a space-separated list of up to 10 CPU core items. Each item specifies a CPU core or a range of CPU cores in the form of core-id1 [ to core-id2 ]. The value for core-id2 must be equal to or greater than the value for core-id1.
# Set the severe CPU core usage alarm threshold to 90% for a CPU core.
[Sysname] monitor cpu-usage threshold 90 slot 1 cpu 0 core 0
monitor disk-usage disk
Use monitor disk-usage disk to set the disk usage threshold.
Use undo monitor disk-usage disk to restore the default.
monitor disk-usage [ slot slot-number ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number ] disk disk-name threshold
The disk usage threshold is 90%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command applies to the active MPU.
disk disk-name: Specifies a disk by its name. This option is case sensitive. The system will prompt a parameter error if you enter this option incorrectly.
threshold threshold-value: Specifies the disk usage threshold in percentage, in the range of 1 to 100.
After you set the disk usage threshold, the device compares the usage of the disk with the threshold at each sampling. If the usage exceeds the threshold, the device sends a high disk usage alarm to the NETCONF module. For more information about the NETCONF module see Network Management and Monitoring Configuration Guide.
# Set the disk usage threshold to 80%.
[Sysname] monitor disk-usage disk flash threshold 80
monitor disk-usage interval
Use monitor disk-usage interval to set the disk usage sampling interval.
Use undo monitor disk-usage interval to restore the default.
monitor disk-usage interval interval
The disk usage sampling interval is 300 seconds.
interval interval-time: Specifies the disk usage sampling interval in seconds, a multiple of 5 in the range of 5 to 1800.
After you set the disk usage sampling interval, the device samples the disk usage at the specified intervals.
# Set the disk usage sampling interval to 120 seconds.
[Sysname] monitor disk-usage interval 120
monitor kernel memory fragment interval
Use monitor kernel memory fragment interval to set the interval for collecting kernel memory fragment information.
Use undo monitor kernel memory fragment interval to restore the default.
monitor kernel memory fragment interval interval-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ slot slot-number [ cpu cpu-number ] ]
The interval is five minutes for collecting kernel memory fragment information.
interval-value: Specifies the interval in minutes. The value range is 1 to 65535.
The device collects kernel memory fragment statistics at the intervals specified by this command. To view the statistics and identify whether the kernel memory fragment ratio is normal, execute the display kernel memory fragment free command.
# Set the interval for collecting memory fragment information to 5 minutes.
[System] monitor kernel memory fragment interval 5
monitor kernel memory fragment ratio
Use monitor kernel memory fragment ratio to set the kernel memory fragment ratio alarm threshold.
Use undo monitor kernel memory fragment ratio to restore the default.
monitor kernel memory fragment ratio ratio-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ slot slot-number [ cpu cpu-number ] ]
The kernel memory fragment ratio alarm threshold is 20%.
ratio ratio-value: Specifies the kernel memory fragment ratio alarm threshold in percentage, in the range of 1 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the kernel memory fragment ratio alarm threshold for the active MPU.
A running kernel thread's process requires memory allocation from the system. The system allocates and releases this memory as a whole. If the process is still running and some memory blocks have been used but are no longer used, these memory blocks will not be released in advance. These free but currently unusable memory blocks are also referred to as memory fragments.
This command enables the device to monitor the kernel memory fragment ratio. If the kernel memory fragment ratio decreases to or below the alarm threshold, the kernel memory usage is low and an alarm notification is generated. If the kernel memory fragment ratio increases above the alarm threshold, the kernel memory usage returns to the normal state and a recovery notification is generated.
# Set the kernel memory fragment ratio alarm threshold to 80 for a slot.
[System] monitor kernel memory fragment ratio 80 slot 1
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# Set the minor CPU usage alarm resending interval to 60 seconds for a slot.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
Use monitor resend cpu-usage core-interval to set CPU core usage alarm resending intervals.
Use undo monitor resend cpu-usage core-interval to cancel the CPU core usage alarm resending interval settings.
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
The minor CPU core usage alarm resending interval is 300 seconds and severe CPU core usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the resending interval for minor CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the resending interval for severe CPU core usage alarms in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU core usage at intervals, and compares the samples with CPU core usage thresholds to identify the CPU core usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU core usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
# Set the resending interval for minor CPU core usage alarms to 100 seconds and the resending interval for severe CPU core usage alarms 60 seconds.
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold
Use monitor resend memory-threshold to set free memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
monitor resend memory-threshold { critical-interval critical-interval | minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
· Early warning resending interval: 1 hour.
· Minor alarm resending interval: 12 hours.
· Severe alarm resending interval: 3 hours.
· Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets alarm resending intervals for the active MPU.
The device samples the amount of free memory space periodically and compares the sampled value with free-memory thresholds. If the sampled value decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
# Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
monitor resend memory-threshold dma
Use monitor resend memory-threshold dma to set the DMA memory alarm resending interval.
Use undo monitor resend memory-threshold dma to restore the default.
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
The DMA memory alarm resending interval is 300 seconds.
critical-interval critical-interval: Specifies the resending interval for the DMA memory alarms in seconds, in the range of 10 to 3600.
The device samples DMA memory usage at intervals, and compares the samples with the DMA memory alarm threshold to identify the DMA memory usage status and send alarms or notifications accordingly.
# Set the resending interval for the DMA memory alarms to 100 seconds.
[Sysname] monitor resend memory-threshold dma critical-interval 100<Sysname> system-view
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
power sleep
Use power sleep to place a power module into sleeping state.
Use undo power sleep to wake up a sleeping power module.
Power modules are in operating state.
power-id: Specifies a power module by its ID.
Use this command with caution. This command does not identify whether or not the remaining power is greater than the rated power of the power module. Executing this command might cause power insufficiency on cards.
Before placing a power module into sleeping state, make sure the remaining power is greater than the rated power of the power module. To view the remaining power, execute the display power verbose command.
A sleeping power module cannot wake up automatically. To wake up a sleeping power module, use the undo power sleep command.
# Place power module 1 into sleeping state.
[Sysname] power sleep 1
Power module will enter sleep module. Continue?[Y/N]:y
power-supply off
Use power-supply off to power off a card.
power-supply off slot slot-number
CAUTION: A card will not send or receive packets after you power off it. Before executing this command, make sure you fully understand its impact on your live network. |
When power is insufficient, you can power off interface cards that are idle or connected to unimportant network nodes to ensure power supply to critical interface cards.
# Power off a card.
<Sysname> power-supply off slot 2
power-supply on
Use power-supply on to power on a card or subcard.
power-supply on slot slot-number
# Power on a card.
<Sysname> power-supply on slot 2
reboot
Use reboot to reboot the device.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command reboots the entire device.
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION: · A reboot might interrupt network services. · Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection. |
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
If the device does not have a standby MPU, rebooting the active MPU reboots the entire device. If the device has a standby MPU and the standby MPU is operating correctly, rebooting the active MPU triggers a switchover.
To ensure correct operation of the system and cards, do not trigger a switchover by rebooting the active MPU if the standby MPU is not in Stable state. To view the status of the standby MPU, execute the display system stable state command.
# Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset alarm active
Use reset alarm active to clear active alarm information on the device.
reset alarm active { all | sequence-number sequence-number }
The active alarm information on the device is not cleared.
Parameter
all: Specifies all active alarms.
sequence-number sequence-number: Specifies an active alarm by its sequence number, in the range of 1 to 4294967295.
When the system has information about active alarms, you can execute this command to manually clear these alarms. After clearance, the system will not display information about these alarms.
# Clear the active alarm with sequence number 1.
[Sysname] reset alarm active sequence-number 1
display alarm active
display alarm history
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION: This command restores the device to the factory default settings. Before using this command, make sure you fully understand its impact on your live network. |
Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
The command takes effect after the device reboots.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
save-power enable
Use save-power enable to enable the power saving feature.
Use undo save-power enable to disable the power saving feature.
save-power enable
Hardware compatibility
Hardware |
MPU model |
RSU-400, RSU-400S |
No |
RSU-400-G |
Yes |
The power saving feature is disabled.
# Enable the power saving feature.
[Sysname] save-power enable
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
display scheduler logfile
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION: This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network. |
When the date argument is not specified, the system uses the following rules to determine the reboot time:
· If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
· If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1. Use the scheduler job command to create a job and enter job view.
2. Use the command command to assign commands to the job.
3. Use the scheduler schedule command to create a schedule and enter schedule view.
4. Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5. Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6. Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
shutdown-interval
Use shutdown-interval to set the port state detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port state detection timer setting is 30 seconds.
interval: Specifies the port state detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port state manually.
Application scenarios
If loop detection is enabled with the loop protection action set to shutdown on a port, the device shuts down the port automatically and starts a port state detection timer when a loop is detected on the port. For more information about loop detection, see Layer 2—LAN Switching Configuration Guide.
If BPDU guard is enabled, the device shuts down an edge port and notifies the NMS of the shutdown event when the edge port receives configuration BPDUs. For more information about BPDU guard, see spanning tree configuration in Layer 2—LAN Switching Configuration Guide.
Operating mechanism
If the port remains in down state when the timer expires, the device sets the port state to the port's real physical state.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
· If T < T1, the port will be brought up after T1 – T seconds.
· If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds after the port has been shut down by the spanning tree feature for 2 seconds (T=2), the port will come up 8 seconds later. If you change the timer setting to 2 seconds after the port has been shut down by the spanning tree feature for 10 seconds, the port will come up immediately.
# Set the port state detection timer to 100 seconds.
[Sysname] shutdown-interval 100
loopback-detection action (Layer 2—LAN Switching Command Reference)
loopback-detection global action (Layer 2—LAN Switching Command Reference)
stp bpdu-protection (Layer 2—LAN Switching Command Reference)
stp port bpdu-protection (Layer 2—LAN Switching Command Reference)
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite each other. The most recently executed command takes effect.
# Configure the device to execute the saveconfig schedule at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute the saveconfig schedule once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute the saveconfig schedule once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute the saveconfig schedule at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute the saveconfig schedule after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite each other, whichever is executed most recently takes effect.
# Configure the device to execute the saveconfig schedule once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute the saveconfig schedule at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute the saveconfig schedule at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute the saveconfig schedule at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver auto-laser-down
Use transceiver auto-laser-down to configure auto laser shutdown.
Use undo transceiver auto-laser-down to restore the default.
transceiver auto-laser-down { enable | disable }
The auto laser shutdown is disabled.
Ethernet interface view
enable: Enables auto laser shutdown.
disable: Disables auto laser shutdown.
Auto laser shutdown is available only for fiber interfaces that are used for bidirectional communications. It does not apply to fiber interfaces used for unidirectional communication or copper interfaces.
This feature does not take effect if you connect a fiber interface to a high-speed cable or install a fiber-to-copper transceiver module. The system will clear all laser auto shutdown related commands (if any) from a fiber interface if you connect it to a high-speed cable or install a fiber-to-copper transceiver module in it.
After auto laser shutdown is enabled, the transceiver laser on an interface automatically shuts down when the interface goes down. You can use the transceiver auto-laser-down restart-mode command to set the laser restart mode to the manual or auto mode. In auto restart mode, the laser sends pulses at intervals (100 seconds by default) until the interface comes up. Then, the laser resumes its operation.
# Enable auto laser shutdown for interface Ten-GigabitEthernet 2/0/0.
[Sysname] interface ten-gigabitethernet 2/0/0
[Sysname-Ten-GigabitEthernet2/0/0] transceiver auto-laser-down enable
display transceiver auto-laser-down
energy-saving mode
Use transceiver auto-laser-down restart to restart the laser for the transceiver module in a fiber interface.
To manually restart the laser of the transceiver module in a fiber interface after the interface recovers from a link failure, use this command. Before you can do this, enable auto laser shutdown and specify the manual laser restart mode.
# Manually restart the laser of the transceiver module in interface Ten-GigabitEthernet 2/0/0.
[Sysname-Ten-GigabitEthernet2/0/0] transceiver auto-laser-down restart
Use transceiver auto-laser-down restart-mode to specify the restart mode for the laser of a transceiver module.
Use undo transceiver auto-laser-down restart-mode to restore the default.
transceiver auto-laser-down restart-mode { auto [ pulse-interval interval ] | manual } [ pulse-width width ]
The auto laser restart mode applies.
auto [ pulse-interval interval ]: Specifies the auto restart mode. In this mode, the laser sends pulses at intervals after the laser restarts. The pulse-interval interval option sets the pulse interval, in seconds. The value range for the interval argument is 100 to 20000. If you do not specify a pulse interval, the pulse interval is set to 100 seconds.
manual: Specifies the manual restart mode.
pulse-width width: Specifies the pulse width (duration) for optical detection after the laser restarts, in seconds. The value range for the width argument is 10 to 200 seconds. If you do not specify this option, the pulse width is set to 10 seconds.
Before you execute this command for the transceiver module in a fiber interface, enable auto laser shutdown on that interface.
If the auto restart mode is specified for a laser, the laser sends pulses at intervals as configured to detect whether the link has recovered.
To quickly restore data communication when you have real-time access to fiber link state changes, you can specify the manual restart mode. In this mode, you can execute the transceiver auto-laser-down restart command for the laser to send a pulse as soon as the fiber link recovers.
# Specify the manual restart mode for the laser of the transceiver module in Ten-GigabitEthernet 2/0/0.
[Sysname-Ten-GigabitEthernet2/0/0] transceiver auto-laser-down restart-mode manual
# Specify the auto restart mode for the laser of the transceiver module in Ten-GigabitEthernet 2/0/0. Set the interval for sending pulses to 150 seconds and set the pulse width to 3 seconds.
[Sysname-Ten-GigabitEthernet2/0/0] transceiver auto-laser-down restart-mode auto pulse-interval 150 pulse-width 3
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
The security log manager user role is mutually exclusive with other user roles. That is, if the security log manager user role has been assigned, the system will automatically remove the existing other user roles. If the other user roles have been assigned, the system will automatically remove the existing security log manager user role.
# Assign the rolename user role to the test schedule.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
# Assign the security-audit user role to the test schedule.
[Sysname-schedule-test]user-role security-audit
This operation will delete all other user roles for the schedule. Are you sure? [Y/N]:y
# Change the user role assigned to the test schedule from security-audit to network-admin.
[Sysname-schedule-test]user-role network-admin
This operation will delete security auditor user role for the schedule. Are you sure? [Y/N]:y
command
scheduler schedule
