H3C U-Center CMDB 5.0 User Guide-E72xx-5W101
HomeSupportNetwork Operations & ManagementH3C U-Center 5.0Technical DocumentsConfigure & DeployUser ManualsH3C U-Center CMDB 5.0 User Guide-E72xx-5W101
01-Text
01-Text 5.30 MB
U-Center 5.0 overview·· 1
Product orientation· 1
Benefits· 1
Components· 1
Quick start 3
Access U-Center 5.0· 3
Explore the U-Center 5.0 GUI 3
Manage users· 5
Modify the default password of the admin account 5
Add a user 6
Manage roles· 8
Add a role· 8
Authorization wizard· 9
Resource management 10
Resource summary· 13
View resource summary· 13
Filter resources by site· 13
Filter resources by resource group· 14
Export resources· 14
Search for resources· 15
Add audit items· 15
Customize columns· 16
Export all matching resources· 17
Resource maintenance· 18
Add a resource· 18
View resource details· 18
View resource relationship· 19
View virtualization topology· 19
Edit a resource· 20
Add an audit item·· 20
Copy a resource· 21
Delete resources· 21
Advanced search· 22
Bulk edit resources· 23
Import operations· 24
Export operations· 25
Sync resource data· 26
Compare data sources· 26
Add relationships· 27
Print QR code· 27
Add or cancel a maintenance tag task· 28
Lock and unlock resources· 28
Manage data collection· 29
Set or roll back baseline· 30
Compare baselines and versions· 31
Customize columns· 32
Resource types· 34
Define resource attributes· 34
Add an attribute· 34
View resource types using this attribute· 35
Edit attribute definition· 36
Manage attribute groups· 37
Import attribute definitions· 39
Export attribute definitions· 40
Delete attribute definitions· 41
Resource type definition· 41
Add a resource type· 41
View resource type details· 43
Edit the resource type· 43
Import resource types· 44
Export resource types· 45
Hide/Display non-menu types· 45
Display QR code on details page· 46
Expand/Collapse the resource type list 46
Delete resource types· 47
Resource sync settings· 47
View the resource sync setting list 47
Configure auto sync· 48
Configure auto add· 49
Configure auto update· 50
Configure auto attribute update support for null values· 50
Auto delete entries without sync sources· 51
Forcibly delete entries without sync sources· 51
Configure sync data source settings· 52
Set the time interval 54
Add common attribute definitions· 54
Delete common attribute definitions· 55
Configure attribute relationship settings· 55
Add an attribute relationship· 55
Edit an attribute relationship· 56
Delete attribute relationships· 57
Resource relationships· 58
Manage resource relationships· 58
Add/view/edit a resource relationship· 58
Import resource relationships· 59
Export resource relationships· 60
Generate resource relationship· 61
View resource relationship· 61
Define relationship types· 61
Add a relationship type· 61
Edit a relationship type· 62
Delete relationship types· 62
Configure relationship sync settings· 62
View relationship sync settings· 63
Set the autogeneration interval 63
Specify whether to automatically generate resource relationships· 64
Audit management 65
Data differences· 65
View data differences· 65
Save and update differences· 65
Create tickets· 66
Configure process settings· 66
Audit results· 66
View audit result details· 66
Edit an audit item·· 67
Acknowledge and save differences· 67
Create tickets· 68
Configure process settings· 68
Delete audit results· 68
Baseline management 69
Add/View/Edit/Copy a baseline· 69
Associated resources· 70
Baseline comparison· 71
Delete baselines· 71
Global ops topologies· 72
View management 72
Add/Edit directory· 72
Add a view· 73
Import views· 73
Import organizations· 74
Edit a view· 75
Copy a view· 76
Search for a view· 76
Sort views/directories· 77
Delete a view/directory· 77
Edit a view· 78
Enter view edit mode· 78
Edit view operations· 79
Global settings· 85
Notification management 94
Notification settings· 94
Add or edit notification settings· 94
Delete notification settings· 95
Search for notifications· 95
View notifications that are about to expire· 95
View expired notifications· 95
View history notifications· 96
Attribute rule settings· 97
Add/view/edit an attribute rule· 97
Enable/disable an attribute rule· 97
View resources matching rules· 98
Delete attribute rules· 98
Change logs· 99
Resource attribute change logs· 99
View resource attribute change logs· 99
Export resource attribute change logs· 99
Delete resource attribute change logs· 100
Resource addition or deletion logs· 100
View resource addition or deletion logs· 100
Export resource addition or deletion logs· 101
Delete resource addition or deletion logs· 102
Parameter settings· 103
Asset processes· 103
Add/view/edit an asset process· 103
Delete asset processes· 104
Attribute collaboration rules· 104
Add/view/edit an attribute collaboration rule· 104
Delete attribute collaboration rules· 105
Product orientation
U-Center 5.0 is an enterprise-level unified operations solution that offers comprehensive functionality across five service domains: monitoring, management, control, service, and analysis. It enables unified management of all ICT resources, including cloud, network, endpoint, and security resources.
Benefits
U-Center 5.0 delivers the following benefits:
·     Comprehensive compliance with ITAI—Meets domestic Information Technology Application Innovation (ITAI) project requirements, and supports the uniform database and middleware products.
·     Resource slimming and downgrading—Reduces the resource consumption and significantly shortens the installation duration by parallel installation and deployment.
·     AIGC integrated—Integrates Artificial Intelligence Generated Content (AIGC) to enhance the Artificial Intelligence for IT Operations (AIOps) experience for users.
·     Unified resource and collection & control platform:
¡     Unified network management system and proxy solution—Enhances network monitoring and management capabilities.
¡     One agent for Automated Operations Management (AOM)—Implements automated operations to boost operational efficiency.
U-Center reshapes the AIOps mode, and helps customers accelerate business innovation, enhance operational efficiency, simplify operational complexity, and create greater business value.
Figure 1 Unified Ops solution
Components
This document primarily focuses on Configuration Management Database (CMDB).
For more information about the functions and usage of other components, see their user guides.
Quick start
H3C U-Center 5.0 provides users with an intuitive, interactive Web interface that can be accessed through a Web browser. On the U-Center 5.0 management page, you can configure settings for the whole network.
Access U-Center 5.0
U-Center 5.0 is developed based on the browser/server model. Users can access U-Center 5.0 directly by entering the URL of the U-Center server in the Web browser.
Table 1 lists the Web browsers supported by U-Center 5.0.
Table 1 Recommended Web browsers
Browser
Version
Chrome
Chrome 96 or later
Firefox
Firefox 97 or later
U-Center 5.0 can be accessed through both HTTP and HTTPS, by using URLs in the following formats:
·     http://<IP address>:<port>
·     https://<IP address>:<port>
The IP address is the virtual IP address configured in Matrix for northbound services. By default, the port number is 30000, which is configurable during installation.
·     You can use the predefined administrator account (with username admin) for initial access to U-Center 5.0. After login, change the default account password as soon as possible for security purposes.
·     To view the northbound service virtual IP address, navigate to the DEPLOY > Clusters > Cluster Parameters page in Matrix.
U-Center displays the overview page after you log in.
Click the  button in the top left corner of the page to display the function menus of U-Center 5.0, as shown in Figure 2. The figure displays some functions. See the actual environment for the specific functions.
Figure 2 U-Center 5.0 function menus
The U-Center 5.0 overview page contains the top navigation bar and Ops work pane, as shown in Figure 3.
Figure 3 U-Center 5.0 overview page
Table 2 U-Center 5.0 GUI areas
Item
Name
1
 button
Provides access to all function modules of U-Center 5.0.
2
Top navigation bar
Provides one-key access to the function modules of U-Center.
3
Ops work pane
Displays the objects managed by the system, as well as the alarm information in the network.
4
Left navigation pane
Provides access to all resources and functions pertaining to the function module selected on the top navigation bar.
5
Configuration page
Allows you to configure the objects added to the system.
Click a tab on the top navigation bar to open the operation interface of the corresponding function module. For example, to open the basic resource monitoring page, click Monitor on the top navigation bar, as shown in Figure 4.
Figure 4 Basic resource monitoring page
You can perform the following tasks on the basic resource monitoring and management page:
·     Add to favorites: Click  in the upper right corner. In the Add to Favorites window that opens, set the name and folder, and then click OK to add the menu item of the current page to the system favorites. You can quickly and easily find commonly used pages from the system favorites. To do that:
a.     On the top navigation bar, click System.
b.     From the navigation pane, select System Settings > Favorites.
c.     On this page, view the pages that have been added to favorites.
·     Open online help: Click  in the upper right corner. In the window that opens, you can access the online help for the current page.
Manage users
U-Center 5.0 implements role-based permission control on users. A user with a role has the operation and data permissions on a specific resource type. A role is a collection of permissions. To implement operation and data permission control for a user, assign permissions to a role, specify the role for a group, and then add the user to the group.
U-Center 5.0 provides various groups for you to add users and assign permissions to them for implementing secure Ops.
This section briefly describes how to modify the password of a user and add a user.
U-Center 5.0 provides a predefined account with login name admin. You can use the account for initial access to U-Center 5.0.
Upon logging in to the system for the first time, you must first change the password for the admin account to ensure system security. Use any of the following methods to change the user password:
·     Follow the guide that opens upon login to change the password:
a.     After you log in, the system will open the New Password dialog box.
b.     Click Change Password Now.
c.     In the New Password window that opens, change the password.
d.     Click OK.
·     Change the password of the current account:
a.     ‍Hover over the admin link in the upper right corner of the page.
b.     Select New Password from the drop-down menu.
d.     Click OK.
·     Manage a user:
a.     ‍On the top navigation bar, click System.
b.     By default, the User Management page opens.
c.     Click the  icon in the Actions column for the admin user.
d.     Turn on the Change Password option , and then enter the new password in the Login Password and Confirm Password fields.
e.     Click OK.
Add a user
To manage a medium- or large-sized network, you can add multiple users with associated permissions for secure Ops.
To add a user:
1.     On the top navigation bar, click System.
2.     By default, the User Management page opens.
3.     Click Add to access the Add User page.
Figure 5 Adding a user
4.     Configure the basic user information:
¡     Username: Enter the login account name, a case-insensitive string of 2 to 32 characters that can contain only letters, digits, underscores (_), hyphens (-), dots (.), and backslashes (\).
¡     Organization: Organization to which the user belongs. Available options include the organization managed by the current logged-in user and its sub-organizations.
¡     Authentication Method: Select an authentication method. The system provides the following authentication methods:
-     Simple Password Authentication: Requires specifying a password when adding the user. The user uses local password authentication for login.
-     LDAP/RADIUS/TACACS Authentication: Requires the user to perform authentication with the associated authentication server for login.
-     Third-Party Authentication: Requires the user to log in through third-party authentication and custom modules. To use this authentication method, you must navigate to the System > System Settings > Authentication Settings page to configure third-party authentication settings.
-     UKEY Authentication: The user can securely perform identity authentication and create a digital signature online. To enable UKEY authentication, access the System > System Settings > Authentication Settings page.
¡     Login Password: If the simple password authentication method is selected, the login password field will appear. Enter the login password of the user in this field.
¡     Confirm Password: If the simple password authentication method is selected, the confirm password field will appear. Confirm the login password of the user in this field.
¡     Tel: Enter the phone number of the user. This field is optional.
¡     Email: Enter the email account of the user. This field is optional.
¡     Description: Enter a description of the user. This field is optional. The description information facilitates maintenance.
5.     Configure the advanced user information:
¡     Last Name: Enter the last name of the user. This field is optional.
¡     First Name: Enter the first name of the user. This field is optional.
¡     Full Name: Enter the full name of the user. This field is optional.
¡     Permitted Login Time Span: Specify a login time range for the user. The user is not allowed to log in to the system at a time out of this range.
¡     Password Validity Period: Specify whether to enable validity period settings for the password. This field is displayed if you select Simple Password Authentication as the authentication method.
-     Password Validity Period (Days): The user will be unable to use the password for login after password expiration.
-     Password Expiration Early Warning Period (Days): When the remaining validity period of the password reaches the threshold, the system sends an alarm to notify the user to change the password each time the user logs in. The system automatically clears the alarm when the password is changed.
¡     User Account Validity Period: Specify whether to enable validity period settings for the user.
-     User Account Expiration Time: After the user expires, the user will be disabled and cannot log in to the system.
-     User Account Expiration Early Warning Period (Days): When the remaining validity period for a user reaches the threshold, the system sends an alarm to notify the user of changing the account validity period each time the user logs in. The system automatically clears the alarm when the user account validity period is changed.
¡     Max Concurrent Logins: Set the maximum number of concurrent users that use this user account. A value of 0 indicates no limit on the maximum number of concurrent online users. The value is an integer in the range of 0 to 999.
6.     Configure the user access control list:
¡     Default access type: Access operation executed by default when the user does not match any rule. Options include Permit and Deny.
¡     Add a user access control rule:
-     Start/End IP Address: Define an IP address range by the start IP address and end IP address. If the IP address of a user belongs to the IP address range, the system determines that the user matches the rule.
¡     Access Type: Options include Permit and Deny.
7.     Click OK.
·     The configuration required varies by authentication method.
·     To use the RADIUS, LDAP, or TACACS authentication type, you must configure the authentication server settings.
Manage roles
A role is a collection of permissions. The system supports role-based access control by assigning permissions to each role. This section briefly describes how to add a role.
Add a role
2.     From the navigation pane, select User Management > Role Management.
3.     Click Add to access the Add Role page.
Figure 6 Adding a role
4.     Configure basic role information:
¡     Role Name: Name of the new role.
¡     Description: Enter a description of the role. This field is optional.
¡     Public or Not: Click  to configure the role as public. Only system administrators and tenant administrators can create public roles.
¡     Permission Configuration: Select the feature permissions for the role. The permission configuration includes a set of feature permissions that correspond to the menu structure in the current view.
¡     Quick Select: Quickly configure permissions for the role. You can select all feature permissions or view-only permissions for an individual component.
5.     Click OK.
You can view the newly added role in the role list.
This section briefly describes how to grant permissions to one or multiple users when users and roles already exist.
2.     From the navigation pane, select User Management > Authorization Wizard.
Figure 7 Authorization wizard
3.     User Information: Select users for feature authorization.
4.     Management scope: Select an organization for the users.
5.     Feature Authorization: Select one or more roles for the users.
6.     Resource Authorization: Select the scope of resources that the users can view or manage. You can directly specify resources or grant the permissions for all resources.
7.     Click OK.
Resource management
U-Center 5.0 CMDB provides comprehensive management functions for you to add resources to the system, and then centrally configure and manage the resources and view the resource information from the system. Resources are the fundament and core of the service application system.
CMDB provides a large number of built-in predefined resource types, and also supports customizing resource types as needed.
The predefined resource categories include virtualization, container, server, network, storage, security, server room environment, wireless, operating system, database, middleware, other applications, business service, basic data, IP, and cloud platform as shown in Table 3.
Table 3 Predefined resource types
Category
Virtualization
CAS
VMware
HyperV
KVM
HW FC
UIS
Citrix
LightCloud
Container
K8S
K8S node
K8S pod
K8S container
Docker
Docker container
Kubernetes container
Kubernetes Master
Server
Rack server
Network
Switch
Router
Load balancer
Other SNMP device
WAN site
IRF member
Transceiver module
AP
ONU
Optical splitter
Site
Fabric
Gateway group
Unidentified device
Storage
Storage device
Fiber switch
Storage volume
Storage pool
Security
Security device
Firewall
Intrusion prevention
Application delivery
Intrusion detection
Unified threat management
Web application firewall
Database firewall
Vulternability scanning system
Website security monitoring
Web page anti-tampering
Anti-Denial of Service (Anti-DoS)
Network gateway
Email security gateway
Data leakage prevention
Sandbox
VPN
Network traffic analysis
Database audit
Operation and maintenance audit
Security
Application control gateway
Server room environment
Server room
Rack
UPS
Firefighting
Air conditioning
CDU
Data center
Wireless
Wireless device
Operating system
N/A
Database
SQL Server
MySQL
Oracle
OraclePDB
OracleASM
DB2 v11
DB2 DPF
Informix
SAP HANA
Shentong
Other database
Middleware
Oracle GoldenGate
WebSphere MQ
Other middleware
Other applications
Other software
Application cluster
Process application
URL
Directory
File
Business service
Service system
Service relationship topology
Basic data
Link
VPN
Connection
Topology
Resource group
Service provider
Endpoint
PC
IP
IPv4 plan
IPv4 address
Cloud platform
CloudOS
CloudOS7
Resource summary
Resource summary displays the number of all resources in the system.
1.     On the top navigation bar, click Resource.
2.     From the navigation pane, select Resource Summary.
Figure 8 Resource summary
3.     On the page that opens, view resource summary. By default, the page displays data about resource categories. To view data about the resource types associated with a resource category, you can click the icon of that resource category. For a resource category without specific resource types in it, clicking the icon places you on the resource maintenance page.
If Unfiied Platform has the region feature enabled, you can filter resources by site.
3.     Select a site at the top right.
4.     The resource summary will display only the resources for that site.
Figure 9 Filter resources by site
3.     Click  at the top right.
4.     Select one or multiple groups, and click OK.
5.     The resource summary will display only the resources for that resource group.
Figure 10 Filter resources by resource group
Export resources
3.     Click  at the top right to export all resources.
This feature allows you to filter resources by the specified keyword.
To filter resources:
2.     From the navigation pane, select Search for Resources.
3.     Enter a keyword. The default search attributes are resource IP, name, and label. Click Search for All Attributes to search any keyword. To filter resources by resource type, select the target resource type.
4.     Click the  icon.
Figure 11 Search resources
5.     To view details about a resource, click the link in the Name column for the resource in the search result list.
Add audit items
3.     Enter a keyword. To filter resources by resource type, select the target resource type.
4.     Press Enter or click the  icon.
5.     Click  in the Actions column for a resource in the search result list to access the audit result management page.
Figure 12 Audit result management
6.     Edit the resource common property and basic information.
7.     Click OK. For more information about the added audit item, see "Audit results."
Customize columns
Use this feature to customize columns on the resource search page.
By default, the display columns include resource type, name, and details, whose order cannot be adjusted or deleted. You can add up to 20 additional attributes.
1.     On the top navigation bar, click Resource. From the navigation pane, select Search for Resources.
2.     Click  on the right of the page.
3.     Click Add to add an attribute.
¡     Click  in the display sequence column to move the column up one position. Click  to move the column down one position. Click  to display the column at the top of the custom columns window. Click  to display the column at the bottom of the custom columns window.
¡     To view the resource type that uses the attribute, click  in the Actions column.
¡     To delete the attribute, click  in the Actions column.
Figure 13 Customize columns
4.     Click OK.
2.     Enter a keyword. To filter resources by resource type, select the target resource type.
3.     Press Enter or click  to search for the matching resources.
4.     In the search result list, click Export All.
Figure 14 Export all matching resources
This feature allows you to manage resources by resource type.
The system displays all predefined or custom resource types, as well as the resources that are synced, manually added, or imported.
Add a resource
Use this feature to add or edit a resource on the resource maintenance page.
1.     On the top navigation bar, click Resource. From the navigation pane, select Maintain Resources.
2.     Select a resource type from a resource category, and click Add.
Figure 15 Add a resource
3.     Configure common property and basic information, and then click OK.
2.     Select a resource type from a resource category.
3.     Click a name link or  in the Actions column for a resource in the resource list to view its details.
Figure 16 View resource details
2.     Select a resource type.
3.     Click  in the Actions column for a resource to view its relationship topology.
Figure 17 View resource relationship topology
Virtualization topology only displays node data related to virtualization.
3.     Click  in the Actions column for a resource to view its virtualization topology.
Figure 18 View the resource virtualization topology
Edit a resource
3.     Click  in the Actions column for a resource.
4.     Edit the resource common property, basic information, and change reason, and then click OK.
Figure 19 Edit a resource
Add an audit item
3.     Click  in the Actions column for a resource in the search result list to access the audit result management page, where you can edit the audit item.
After modification, click OK. For more information about the added audit item, see "Audit results."
Figure 20 Add an audit item
Copy a resource
3.     Hover over  in the Actions column, and select Copy.
4.     Edit the resource property as needed, and then click OK.
Figure 21 Copy a resource
Delete resources
3.     Delete resources:
¡     To delete a single resource, click  in the Actions column for that resource, and select the Delete option. In the dialog box that opens, click OK.
¡     To delete resources in bulk, select one or multiple resources, and then click Delete. In the dialog box that opens, click OK.
¡     To delete all resources, click More > Delete All. In the dialog box that opens, click OK.
Figure 22 Delete specific resources
Figure 23 Delete all resources
Advanced search
You can perform advanced search for a specific type of resources by ID, name, and IP address on the resource maintenance page.
2.     Select a resource category.
3.     Select a resource type.
4.     Click the drop-down arrow on the right side of the search box in the upper right corner of the page to expand the advanced search area and search for resources of the resource type.
5.     Click the drop-down box to select the search attribute and search criteria in sequence, and then enter the search parameters. If multiple search criteria exist, the resources that meet all the search criteria are displayed.
¡     Click  to add a search box.
¡     Click  to delete a search box.
6.     Click Search to search for matching resources.
Figure 24 Advanced search
Bulk edit resources
You can bulk edit resource attributes by editing selected items or all items at once. To edit selected items:
3.     Select multiple resources, and then click Edit.
4.     Select the edit selected items option, and then select one or more attributes to edit in the window that opens. To edit all items, simply select the edit all option without selecting any resources.
Before editing the resource group attribute, you must first edit the organization attribute.
5.     After editing the attribute value, click OK.
Figure 25 Bulk edit resources
Import operations
Use this feature to import resources on the resource maintenance page. You can import resources or audit data for resources. To import resources:
3.     Click Import. Select Import Resources.
To import audit data for resources, select Import Audit Data.
4.     Click Upload File and select a local Excel file.
5.     In the Action on Duplicate Primary Keys field, select an option as needed to deal with duplicate data in the system and the Excel file. By default, the option is Overwrite.
¡     To overwrite data in the system with data in the Excel file, select Overwrite.
¡     To retain data in the system and ignore data in the Excel file, select Ignore.
6.     Click Import.
Figure 26 Import resources
Export operations
On the resource maintenance page, you can export selected resources, only the customized columns of the selected resources, all resources, or customized columns of all resources.
3.     Select one or multiple entries, and click Export.
4.     Select an option from the list. The system will export all attributes of the selected entries.
¡     Export Selected Entries: Export information about all columns of the selected resources.
¡     Export Selected Customize Columns: Export only the columns displayed on the page for the selected entries.
¡     Export All: Export all attributes of all entries.
¡     Export All Customize Columns: Export only the columns displayed on the page for all entries.
Figure 27 Export resources
When the total number of entries exceeds 10000, you must select a portion of resources in the window that opens.
Sync resource data
3.     Click More > Sync to sync resource data.
Figure 28 Sync resource data
Use this feature to compare data sources for resources on the resource maintenance page.
3.     Select one or multiple target entries, and then click More > Compare Data Sources.
4.     The window that opens displays difference entries. To update one or multiple difference entries, select them and then click Update. To update all entries, click Update All.
5.     Click Cancel.
Figure 29 Compare data sources
Add relationships
Use this feature to add relationships on the resource maintenance page.
3.     Select one or multiple target entries.
4.     Click More > Add CI Relation.
5.     From the list, select the resource type, resource relationship type, and one or multiple resources.
6.     Click OK. Click Add Relationships with All Resources for the resource type to add relationships for all resources of the resource type.
Figure 30 Add relationships
Print QR code
Use this feature to print the QR code on the resource maintenance page. Scan the QR code in the manual to view resource attribute information.
4.     Click More > Print QR Code.
5.     Select a printer, and then click Print.
Use this feature to configure a maintenance tag task on the resource maintenance page.
3.     Select one or multiple resources, and click More > Add Maintenance Tag.
4.     In the window that opens, configure the maintenance tag information.
5.     Click OK.
6.     To cancel a maintenance tag task, hover over  in the Actions column for the resource, and select the option to cancel the maintenance tag task.
Figure 31 Add a maintenance tag task
Use this feature to lock resources on the resource maintenance page.
¡     To lock the resources, click More > Lock.
¡     To unlock the resources, click More > Unlock.
Figure 32 Lock and unlock resources
On the resource management page, you can immediately collect data, enable data collection, and disable data collection.
Data collection is supported for only the resource types with data in "Resource relationship", and where the maintenance data is monitoring data. Network resources do not support collection.
4.     Click More and select an option.
¡     Polling: Trigger configuration polling to immediately collect data.
¡     Enable Collect: Collect data for the resources to be incorporated. Certain resource types do not support this operation, for example, predefined CAS VMs, CAS host clusters, and CAS pools.
¡     Disable Collect: Disable data collection for the resources with collection enabled.
Figure 33 Data collection
1.     Supported operations include setting a baseline and rolling back to the baseline for selected resources.
·     You cannot set the baseline for locked resources.
·     You cannot roll back the baseline for locked resources or the resources without baseline set.
2.     On the top navigation bar, click Resource. From the navigation pane, select Maintain Resources.
4.     Select one or multiple target entries.
5.     Click More > Set Baseline or Roll Back Baseline to set the baseline for resources in bulk or roll back the baseline.
Figure 34 Set or roll back baseline
Use this feature to compare baseline for resources on the resource detailed information page.
3.     Click the name link for the target resource, or click  in the Actions column for the target resource.
4.     On the Basic Info tab that opens by default, view the common attributes, basic information, and MAC address table of the resource.
5.     Click the Version Info tab to view the version information list of the resource.
6.     Select a version, and then click Compare Baselines. If the selected version is configured with the baseline, a window opens to show the changed attributes and their values before and after the change. If the selected version is not configured with the baseline, a message appears to inform you that the version is not configured with the baseline.
To compare version data, select two target versions, and then click Compare Versions. The window that opens shows the changed attributes and their values before and after the change.
Figure 35 Compare baselines and versions
Customize columns
Use this feature to customize columns on the resource maintenance page.
3.     Click  on the right of the page.
¡     Add/remove custom columns: Click the checkbox in the upper-left corner of the list to select or deselect all columns at once, or select/deselect one or multiple display columns individually.
¡     Adjust custom column order: Click  in the display sequence column to move the column up one position. Click  to move the column down one position. Click  to display the column at the top of the custom columns window. Click  to display the column at the bottom of the custom columns window.
4.     Click OK.
Figure 36 Customize columns
Resource types
A resource type is a collection of resources with common attributes. You can use predefined resource types or add resource types as needed.
This feature allows you to manage resource attributes.
Add an attribute
Use this feature to add attribute definitions.
1.     On the top navigation bar, click Resource. From the navigation pane, select Resource Type > Define Resource Attributes.
2.     The left side of the page displays grouped resource attributes. You can select a group to view specific attributes. After entering a specific attribute group page, click Add to open the window for adding an attribute .
Figure 37 Add an attribute
3.     Configure the following parameters:
¡     Group: Select an attribute group for the attribute.
¡     Abbreviation: Specify a unique identifier for the attribute. The value can contain only letters and underscores (_). The valid length is 1 to 32 characters.
¡     Attribute Name: Enter the name of the attribute. Valid characters include only Chinese characters, letters, digits, parentheses in Chinese and English, slashes (/), underscores (_), and hyphens (-), and cannot contain only spaces. The valid length is 1 to 30 characters.
¡     Data Type: Select a data type for the attribute, which can be Text, Text Area, Dropdown Text, Tree Dropdown Text, Integer, Decimal, IP Address, MAC Address, Date & Tme, Attachment, Ciphertext, Table, Form, URL, Array, Operator, and Organization. Attachment attributes support file upload and download, and support online preview of the files whose format is supported by the browser.
¡     Multi-Select: This option is available when the data type is Dropdown Text or Tree Dropdown Text.
¡     Maximum Length: Specify the maximum length for the attribute value when the data type of the Text, Text Area, Dropdown Text, Tree Dropdown Text, IP Address, MAC Address, or Ciphertext. The value range for the maximum length is 16 to 999999999.
¡     Available Values: Specify the available values for the attribute when the data type is Dropdown Text or Tree Dropdown Text,.
¡     Time Format: Specify the date and time format when the data type is Date & Tme. Y, M, D, H, M, and S represent year, month, day, hour, minute, and second, respectively.
¡     Default Value: Specify the default value for the attribute.
¡     Description: Enter the description of the attribute to facilitate maintenance.
¡     Comma-Separated List of Attributes: Specify the attribute for the table or form when the data type is Table or Form. The value is a comma-separated string that can contain only Chinese characters, letters, digits, underscore (_), hyphens (-), parentheses, and spaces. The valid length is 0 to 32 characters. Each of the attributes cannot exceeded the maximum length setting.
4.     Click OK.
5.     You can view the added attributes in the attribute list. The attribute list has the following tabs: Common Attributes, Pre-Defined Attributes, Storage Attributes, Network Device Attributes, Database Attributes, and Server Attributes. The Common Attributes tab is displayed by default.
Figure 38 Resource attribute definition list
2.     Click  in the Actions column for an attribute to view the resource types using this attribute.
Figure 39 View resource types using this attribute
2.     Click  in the Actions column for an attribute to edit the attribute.
Figure 40 Edit the attribute
Use this feature to add and manage attribute groups.
Add an attribute group
2.     Click Add.
Figure 41 Add an attribute group
¡     Group Name: Enter the name of attribute group, which can contain only Chinese characters, letters, digits, underscores (_), hyphens (-), and parentheses.
¡     Group Name: Enter the description of the attribute group to facilitate maintenance.
4.     Click OK.
1.     On left navigation bar, click the Resource tab. From the navigation pane, select Resource Type > Define Resource Attributes.
2.     Click Manage.
3.     Click  in the Actions column of the group list.
4.     Click  in the display sequence column to move group up one position. Click  to move the group down one position. Click  to display the group at the top of the window. Click  to display the group at the bottom of the window.
Figure 42 Manage attribute groups
5.     Click Close.
Use this feature to import attribute definitions.
1.     On the top navigation bar, click Resourcethe top navigation bar, click Resource. From the navigation pane, select Resource Type > Define Resource Attributes.
2.     The left side of the page displays grouped resource attributes. You can select a group to view specific attributes. After entering a specific attribute group page, click Import to open the window for importing resource attributes.
Figure 43 Import resource attributes
3.     Click Upload File, and follow the prompts in the window to select the file you want to import. Supported Excel file types are .xlsx and .xls. Each sheet within the file represents a group. Please delete any unnecessary sheets.
4.     Click Import.
Use this feature to export attribute definitions, including selected entries, the current group, or all.
2.     The left side of the page displays grouped resource attributes. You can select a group to view specific attributes. After entering a specific attribute group page, select one or more attributes to export, then click Export.
¡     Export Selected Entries: Export the attributes of the selected entries.
¡     Export Current Group: Export all attributes in the current attribute group.
¡     Export All: Export all attributes.
Figure 44 Export attribute definitions
2.     Delete attribute definitions:
¡     To delete a single attribute, click  in the Actions column for that attribute. In the dialog box that opens, click OK.
¡     To bulk delete attributes, select or more attributes, and click Delete. In the dialog box that opens, click OK.
The resource type definition module provides unified management of resource types.
Add a resource type
Use this feature to add resource types.
1.     On the top navigation bar, click the Resource tab. From the navigation pane, select Resource Types > Define Resource Types.
2.     Click Add to access the page for adding a resource type.
Figure 45 Add a resource type
3.     When adding resource types:
¡     In the basic information area, click Select or click Root Type to specify the parent type. Then, specify the fixed code, name, and description.
¡     In the attribute information area, click Select to select the target attributes. Then, click OK.
¡     In the attribute information area, click Add Resource Attribute. In the window that opens, configure the parameters, and then click OK.
¡     In the attribute information area, click Layout. In the window that opens, you can perform the following operations and then click OK:
-     To add an attribute field, drag and drop that attribute in the navigation tree to the right pane.
-     To expand the attributes under a group in the navigation tree, click the group name. If the right pane already has an attribute, you cannot drag it from the navigation tree to the right pane.
-     To add an attribute to the navigation tree, click the <+> button.
-     To collapse or expand data in an attribute area on the right pane, click the  or  icon next to the attribute area name.
-     To add an attribute area on the right pane, click the  icon next to an attribute area name.
-     To edit the name of an attribute area on the right pane, click the  icon next to the attribute area name.
-     To delete an attribute area on the right pane, click the  icon next to the attribute area name.
-     To delete an attribute on the right pane, click the  icon next to the attribute field.
¡     In the attribute grouping information section, select the attribute grouping.
¡     In the attribute uniqueness validation section, select the attribute uniqueness validation information. The uniqueness validation consists of one or multiple attributes, indicating that the values of this set of attributes are unique across all resource data.
4.     In the attribute permission section, configure the permission settings for this attribute, such as restricting the scope of user or organizational access to view or modify it. Click the <OK> button to complete the operation of adding a resource type.
List contents
¡     Name: Name of the resource type.
¡     Description: Description of the resource type.
¡     Abstract or Not: Whether the resource type is abstract. An abstract resource type does not have subtypes. A non-abstract resource type has subtypes.
¡     User-Defined: Whether the resource type is user-defined.
¡     Menu or Not: Whether the resource type is a menu.
¡     Display QR Code on Details Page: Whether to display QR code on the details page for the resource type.
¡     Asset: Whether the resource type is managed as an asset in the system.
¡     Icon: Icon for the resource type.
¡     Display Order: Adjust the sequence of resource types. Click  to move the resource type up one position. Click  to move it down one position.
Figure 46 Resource type definition list
2.     Click  in the Actions column to access the resource type details page, where you can view its basic and attribute information.
Figure 47 View resource type details
When editing a resource type definition, the attribute form, attachment, table, ciphertext, operator, and organization cannot be set as primary keys or used as unique attribute validation information.
2.     Click  in the Actions column to access the resource type details page, where you can view basic and attribute information.
Figure 48 Edit the resource type
Use this feature to import resource types.
2.     Click Import.
Figure 49 Import resource types
3.     Click Upload File, and follow the prompts in the window to select the file you want to import. The system supports only ZIP files, which might contain Excel files in .xlsx or .xls format or JSON files in .json format.
4.     Click Import.
The feature allows exporting resource types, including selected entries, all, selected entries (JSON), and all (JSON).
2.     Select one or more resource types, and then click Export.
3.     From the drop-down menu, select Export Selected Entries or Export All.
¡     Export Selected Entries: Export the selected resource types as a ZIP file, which contains Excel files in .xlsx and .xls formats.
¡     Export All: Export all resource types as a ZIP file containing Excel files in .xlsx and .xls formats.
¡     Export Selected Entries to JSON: Export the selected resource types as a ZIP file containing .json files.
¡     Export All to JSON: Export all resource types as a ZIP file containing JSON files.
Figure 50 Export resource types
Use this feature to select whether to display or hide non-menu resources on the resource type definition page.
In the resource type list, you can click the value in the Menu or Not column for a resource type to specify whether that resource type is the menu type or not. If Hide Non-Menu Types is selected, the current page does not display resource types that are not the menu type. The system also hides all data related to these resource types in the relationship topology.
2.     Click More, and then select Hide Non-Menu Types or Display Non-Menu Types from the list to hide or display non-menu type resources.
Figure 51 Display/hide non-menu resources
2.     Configure QR code display settings on the details page as follows:
¡     Select one or more resource types, click Display QR Code on Details Page, choose Yes or No to set whether to display the QR code on the details page of the selected resource types.
¡     Click Yes or No in the Display QR Code on Details Page column for a resource type to configure whether its details page shows a QR code.
Figure 52 Display QR code on the details page
2.     Expand/Collapse resource type list:
¡     Expand/Collapse all: Click More, select Expand All or Collapse All to expand or collapse the entire resource type list.
¡     Expand/collapse a single resource: Click / to the left of the parent resource type name to expand or collapse its sub-list.
Figure 53 Expand/Collapse the resource type list
·     Deleting a resource type will automatically remove its subtypes, all associated resource data, and related resource relationship types and relationships.
·     Only user-defined resource types can be deleted.
2.     Delete resource types:
¡     To delete a single resource type, click  in the Actions column of a resource type, and then click OK window that opens.
¡     To delete resource types in bulk, select one or multiple resources types, and then click Delete. In the dialog box that opens, click OK.
The system can automatically synchronize resources and update resource attributes at the specified sync intervals. It also supports null values in attribute auto update and can automatically delete entries without sync sources.
CAUTION
CAUTION:
Abstract resources or resources not allowed to be synced do not support the automatic sync or audit feature.
To automatic sync/audit/delete resources:
For an abstract resource category, the bulk edit operation applies to all resources of the associated non-abstract types.
2.     From the navigation pane, select Resource Type > Resource Sync Settings.
3.     The list of resource synchronization configurations is as follows:
¡     Resource Type: Resource type to which the resource sync setting applies.
¡     Auto Sync: Whether autosync is enabled for the resource sync setting.
¡     Auto Add: Whether the resource sync configuration supports auto-add, and whether resources can be added to the CMDB side.
¡     Auto Update: Whether to automatically update resource attributes.
¡     Auto Attribute Update Support for Null Values: Whether to support null values in attribute auto update.
¡     Auto Delete Source-Missing Entries: Whether to automatically delete entries without sync sources.
¡     Force Delete Source-Missing Entries: When a read operation detects a resource entry whose data source no longer exists, the system will automatically delete that resource entry.
¡     Sync Data Source Settings: To manage the sync data sources of a resource type, click  in the Sync Data Source Settings column for that resource type.
¡     Sync Logs: To view the latest sync logs for a resource type, click  in the Sync Logs column for that resource type.
Figure 54 Resource sync settings
Configure auto sync
Use this feature to set up auto synchronization.
1.     On top navigation bar, click the Resource tab. From the navigation pane, select Resource Types > Resource Sync Settings.
2.     Enable auto synchronization as follows:
¡     Select one or more resource types, click Auto Sync, and select Yes or No to specify whether the resources of the selected types are auto synchronized.
3.     Click the value in the Auto Sync column of a resource type to specify whether its resources are auto synchronized.
Figure 55 Configure auto sync
Configure auto add
Use this feature to configure automatic add settings.
2.     Configure auto add setting as follows:
3.     Select one or more resource types, click Auto Add, and select Yes or No to specify whether the resources of the selected types are auto added.
¡     Click the value in the Auto Add column of a resource type to configure whether its resources are auto added.
Figure 56 Configure auto add
Use this feature to configure automatic resource updates.
2.     Enable automatic updates as follows:
¡     Select one or more resource types, click Auto Update, and choose Yes or No to specify whether resources of the selected types are automatically updated.
¡     Click the value in the Auto Update column of a resource type to specify whether its resources are automatically updated.
Figure 57 Configure auto update
The feature enables automatic attribute update support for null values.
2.     Configure auto attribute update support for null values as follows:
¡     Select one or more resource types, click Auto Attribute Update Support for Null Values, and choose Yes or No to specify whether the resource attribute of the selected types supports null values in auto update.
¡     Click the value in the Auto Attribute Update Support for Null Values column for a resource type to specify whether its attributes support null values in auto update.
Figure 58 Configure auto attribute update support for null values
The features enables automatic deletion of entries without sync sources.
2.     Enable auto-deletion of entries without sync sources as follows:
¡     Select one or more resource types, click Auto Delete Source-Missing Entries, and select Yes or No to specify whether resources of the selected types automatically delete entries without sync sources.
¡     Click the value in the Auto Delete Source-Missing Entries column for a resource type to specify whether its resources automatically delete entries without sync sources.
Figure 59 Auto delete entries without sync sources
The feature is used to forcibly delete entries without sync sources.
2.     Click the value in the Force Delete Source-Missing Entries column for a resource type to specify whether to forcibly delete entries without sync sources of that resource type.
Figure 60 Forcibly delete entries without sync sources
You can access the data source synchronization configuration page through this function, where the module enables unified management of resource-type synchronized data sources.
·     Abstract types do not support the synchronized data source configuration function.
·     The system's pre-defined data sources do not support modification or deletion.
Add/Modify Synchronization Data Source
You can use this function to add or modify a data source on the sync data source configuration page.
2.     Click  in the Sync Data Source Settings column for the target resource type.
Figure 61 Sync data source settings
3.     To add a data source for the target resource type, click Add. To edit an existing data source for the target resource type, click  in the Actions column for that data source.
Figure 62 Add a synchronous data source
4.     In the basic information section, configure details such as the data source name, precedence, and resource type.
5.     Configure the protocol, host address, full data URL, and other information in the REST section.
6.     In the value mapping section, configure the attribute name or default value corresponding to the JSON data returned by the REST interface. Click the drill down link to enter drill-down configuration in the pop-up window.
7.     Click OK to complete the operation of adding or modifying a synchronized data source.
View synchronized data source details
You can use this function to view detailed information of synchronized data sources on the configuration page.
3.     Click  in the Actions column for the target data source.
Figure 63 View sync data source details
Copy a sync data source
3.     Select the data source to be copied, click Copy, and then click OK to quickly create a new data source with identical attributes and a specific name.
Figure 64 Copy a sync data source
Delete sync data sources
3.     Delete sync data sources as follows:
¡     To delete a specific data source, click  in the Actions column of the sync data source, and then click OK in the dialog box that opens.
¡     To delete sync data sources in bulk, select one or more sync data sources, click Delete, and then click OK in the dialog box that opens.
This setting applies to all sync configurations on this page.
2.     Click the set time interval button in the upper right corner and select a time interval.
3.     Define common attributes
This feature allows you to manage the common attributes inherited by all resource types.
Use this feature to add common attribute definitions.
1.     On the top navigation bar, click the Resource tab. From the navigation pane, select Resource Types > Define Common Attributes page.
2.     Click Select to open the attribute selection window.
3.     Select the desired attributes and click OK. In the window that opens, click OK.
4.     The window for attribute adding result opens, displaying the progress, success/failure status, and the resource type of the added common attributes. Click Close to complete the operation.
Figure 65 Add common attributes
¡     Set multidimensional navigation
Only attributes with the dropdown text data type can be configured for multidimensional navigation.
¡     On the top navigation bar, click the Resource tab. From the navigation pane, select Resource Types > Define Common Attributes page.
5.     Click the value in the Navigational column of the common attribute to specify whether this attribute is displayed as a left-tree menu on the resource maintenance page.
Figure 66 Set multidimensional navigation
2.     Select one or more attributes, click Delete, and then click OK in the dialog box that opens.
This feature allows you to manage attribute relationships.
Use this feature to add an attribute relationship.
1.     On the top navigation bar, click the Resource tab. From the navigation pane, select Resource Types > Attribute Relationship Settings page.
2.     Click Add.
List contents
¡     Resource Type A: Name of resource type A.
¡     Related Attribute A: Name of related attribute A.
¡     Multi-Select: Whether to allow each value of related attribute A to be associated with only one resource.
¡     Resource Type B: Name of resource type B.
¡     Related Attribute B: Name of related attribute B.
¡     Priority: Priority of the attribute relationship.
¡     Related view attributes: Attributes displayed in the related view.
¡     Cascading attributes: The cascading attribute of attribute association configuration.
¡     Attributes to Display: Attributes displayed in the list.
Figure 67 Configure attribute relationship settings
3.     Click OK.
4.     To view details about the added relationship, click the  in the Actions column for that relationship.
2.     Click  in the Actions column for a relationship to edit parameters such as Resource Type B and Related Attribute B in the window that opens.
Figure 68 Edit an attribute relationship
2.     Delete attribute relationships:
¡     To delete an attribute relationship, click  in the Actions column for that relationship. In the dialog box that opens, click OK.
¡     To bulk delete attribute relationships, select or more relationships, and click Delete. In the dialog box that opens, click OK.
This feature allows you to manage relationships between resource types.
Perform this task to add, view, or edit a resource relationship.
1.     On the top navigation bar, click Resource. From the navigation pane, click Resource Relationships > Resource Relationships.
2.     Click Add.
Figure 69 Add a resource relationship
3.     When you add a resource relationship, specify resource type A, relationship name, resource type B, whether to enable unidirectional match, and description.
4.     Click Add.
Figure 70 Add a match rule
5.     In the dialog box that opens, select match field A, match field B, and the match condition, and then click OK.
6.     Select a logical operator. If you select OTHER, you must enter an expression.
7.     Click OK.
8.     To view details about a resource relationship, click  in the Actions column for that resource relationship.
9.     To edit a resource relationship, click  in the Actions column for that resource relationship.
Use this feature to import resource relationships.
2.     Click Import.
3.     Click Upload File, and follow the prompts in the window to select the file you want to import. The import of Excel files is supported. See the template file for the content format. Click the download template link to get the template file.
4.     Click Import.
Figure 71 Import resource relationships
Use this feature to export resource relationships.
3.     Select Export Selected Entries or Export All to export resource relationships.
¡     Export Selected Entries: Export the selected resource relationships.
¡     Export All: Export all resource relationships.
Figure 72 Export resource relationships
The system bulk generates resource relationships according to the match rules defined in the resource relationship type.
2.     Select the resource relationship type to be generated, and click Generate Resource Relationship.
3.     In the window that opens, click OK.
Figure 73 Generate resource relationship
2.     Click  in Actions column for a resource relationship to view the resource relationship.
Figure 74 View resource relationship
This feature allows you to manage relationships types.
Use this feature to add a relationship type.
1.     On the top navigation bar, click Resource. From the navigation pane, select Resource relationship > Define Relationship Types.
2.     Click Add.
Figure 75 Add relationship type
3.     Enter the name and description.
4.     Click OK.
1.     On the top navigation bar, click Resource. From the navigation pane, select Resource Relationship > Define Relationship Types.
2.     Click  in the Actions column for a relationship type to edit it in the window that opens.
·     Only user-defined relationship types can be deleted.
·     Relationships in relationship type definitions cannot be deleted if they are specified for resource relationships or used in service topologies.
2.     Delete relationship types as follows:
¡     To delete a single relationship type, click  in the Actions column of that relationship type, and then click OK in the window that opens.
¡     To delete relationship types in bulk, select one or multiple relationship types, and then click Delete. In the dialog box that opens, click OK.
Perform this task to automatically generate resource relationships based on the specified interval.
On the top navigation bar, click Resource. From the navigation pane, select Resource Relationship > Relationship Sync Settings.
List contents
·     Resource Type A: Name of resource type A.
·     Resource Type B: Name of resource type B.
·     Relationship Name: Name of the relationship between resource type A and resource type B.
·     Auto Generate Resource Relationships: Whether the resource relationship is auto generated.
Figure 76 View relationship sync settings
Use this feature to set the automatic generation interval.
1.     On the top navigation bar, click Resource. From the navigation pane, select Resource Relationship > Relationship Sync Settings.
2.     Click the set time interval button and select the time interval from the drop-down list.
Figure 77 Set the time interval
After enabling automatic resource relationship generation, if newly added resources match the rules defined in the resource relationships, the corresponding two resources will automatically establish a relationship.
2.     Set the automatic generation status of resource relationship types as follows:
3.     Select one or multiple target entries, click Auto Generate Resource Relationships, and then select Yes or No.
4.     Click a value in the Auto Generate Resource Relationships column.
Figure 78 Set the automatic generation status of resource relationship types
Audit management
This feature allows you to view resource audit information.
Data differences
This feature allows you to manage automatically saved data differences for resource types with Auto Sync enabled and Auto Update disabled on the Resource Sync Settings page.
1.     On the top navigation bar, click Resource. From the navigation pane, select Audit Management > Data Differences.
2.     Click  for the target entry in the list. In windows that opens, you can see the difference details for the resource.
Figure 79 View difference details
1.     ‍On the top navigation bar, click Resource. From the navigation pane, select Audit Management > Data Differences.
2.     Save and update differences:
¡     To save and update multiple entries, select them from the list, and then click Save & Update. In the window that opens, click OK.
¡     To save and update a single entry, click  in the Actions column for it. In the window that opens, click OK.
Figure 80 Save and update differences
Create tickets
Use this feature to create support tickets.
2.     Select one or more audit items that support ticket creation, click Create Ticket to access the ticket creation page.
3.     Select a ticket type that supports resource changes, such as a predefined change ticket.
4.     Click OK.
5.     After creating a ticket, you can view its details under the process records tab in the corresponding resource details.
2.     Click Add Process, and then configure the service process and data template in the window that opens.
3.     Click OK.
Audit results
Audit result management supports saving imported audit results.
2.     From the navigation pane, select Audit Management > Audit Results.
List contents:
¡     Difference Found At: Time when the difference was found.
¡     Resource Types: Audit result management type information.
¡     Resource: Resource information for audit result management.
¡     Audited By: The name of the auditor responsible for managing audit results.
¡     Expired: Whether the audit period of the audit result management has expired.
¡     Audit Result: The audit result information managed by audit result management.
¡     Processing Result: The processing result information in audit result management.
¡     Data Source: Data source for the audit result. Values can be Fill in page or Import.
3.     Click  in the resource list to open the audit detail differences window and view detailed differences.
Figure 81 View audit result details
Edit an audit item
3.     Click  in the Actions column for an audit item to edit it.
4.     Click OK.
Figure 82 Edit an audit item
1.
2.     Acknowledge and save differences:
¡     Select one or more resources to acknowledge and update, click the Acknowledge and Save Differences, and then click OK in the pop-up window to complete the operation.
¡     Click  in the Actions column of an entry, and then click OK in the pop-up window to confirm and save the changes.
Figure 83 Acknowledge and save differences
Create tickets
3.     Select one or more audit items that support ticket creation, click Create Ticket, and the ticket creation window opens.
4.     Select a ticket type that supports resource changes, such as a predefined change ticket.
5.     Click OK.
6.     After the ticket is created, you can view the ticket details under the process records tab in the corresponding resource details.
3.     Click Add Process, and then configure the service process and data template in the window that opens.
4.     Click OK.
Figure 84 Configure process settings
3.     Delelte audit results:
¡     Click  in the operation column of an audit result, then click OK in the dialog box that opens.
¡     Select one or more audit results, click Delete above the list, and then click OK in the dialog box that opens.
Figure 85 Delete audit results
Baseline management
Use this feature to perform baseline management for resources, including adding and editing baselines and displaying baseline details. You can also bind baselines to resources and view baseline comparison results.
2.     From the navigation pane, select Audit Management > Baseline Management.
3.     Click Add.
4.     Configure the baseline name, baseline resource type, and other common attributes and basic information, and then click OK.
Figure 86 Add a baseline
5.     After the baseline is successfully added, you can view, edit, and copy it.
¡     View baseline details: Click the  in the Actions column of the baseline list to access the baseline details page. Here, you can view detailed baseline information and associated resources. For specific operations on baseline-associated resources, see "Associated resources."
¡     Edit baseline: Click  in the Actions column of the baseline list to access the baseline modification page. Edit the baseline name, common attributes, and basic information, then click OK to complete the baseline modification.
¡     Copy baseline: Click  in the Actions column of the baseline list to enter the copy baseline page. Configure the baseline name, common attributes, and basic information as needed, and then click OK to complete the baseline copy operation.
Bind a resource
If a resource is already bound to another baseline, binding it again will update the resource baseline to the currently bound baseline.
3.     Click  in the Actions column of the baseline list to access the baseline details page.
4.     On the Associated Resources tab, click Bind Resource to open the resource selection window.
5.     Select the resource corresponding to the baseline resource type, and then click OK to complete the binding operation.
Figure 87 Bind a resource
Unbind a resource
4.     On the Associated Resources tab, select the bound resource, click Unbind Resource, and then click OK in the dialog box that opens.
Figure 88 Unbind a resource
Baseline comparison
The function compares the current value of a resource with its baseline and displays the comparison results.
3.     Select one or more baselines, click the baseline comparison button at the top of the page to open the baseline comparison results window.
Figure 89 Baseline comparison results
4.     If the comparison results differ, click Different in the comparison results column to view the differing items and values in the dialog box that opens.
Delete baselines
Bound resources cannot be deleted from the baseline.
3.     Delete baselines:
¡     Select one or more resources, click Delete, and then click OK in the dialog box that opens.
¡     Click  in the Actions column in the baseline list, and then click OK in the dialog box that opens.
Global ops topologies
The global ops topologies feature enables topology display and orchestration of network-wide resources, offering unified management for resource views. Users can view and edit CI-related information through the graphical interface, including CI data and alarm data. The component registers capabilities such as toolbar buttons, right-click menus, node link tips, and node link styles through the extended interface, meeting personalized needs across various scenarios and delivering a clear, visually appealing viewing and editing experience for users.
The main functions of the global ops topologies are as follows:
·     Unified display: Components import resources to achieve centralized presentation of all controllers on the global ops topologies, displaying alarm status, device online/offline states, link tips, and other information.
·     Topology framework customization: Supports extended functions such as importing resources, toolbar, node and link tips, and right-click menu.
¡     Each component registers with the toolbar to implement its specific topology functions, such as displaying terminals or presenting overlay links.
¡     Components can expand node and link tip information as needed for personalized display.
¡     Components register with the CMDB and node types in the global ops topologies to expand the range of device types within it.
·     View hierarchy and group editing function: Group and sort by attributes such as view type, function, or priority.
·     Visual editing for view content: Graphically add nodes and create physical links or logical connections within the view.
·     CI and monitoring information one-stop solution: Enables adding and viewing CIs and monitoring information on the same page without switchover between different components.
Some common operations of the global ops topologies are as follows:
View management
Add/Edit directory
1.     Navigate to the Monitor > Global Ops Topologies page.
2.     Hover over a directory in the left navigation tree, and a  button will appear on the right.
3.     Hover over the  button, and then select Add Menu or Modify from the menu list that appears.
4.     Enter the directory name in the input/modification field that appears.
5.     Click the blank space or press Enter to add/edit the directory.
Figure 90 Add/Edit a directory
Add a view
3.     Hover over the  button, and then select Add View from the menu list that appears.
4.     Configure basic information, expansion information, and resource group.
5.     Click OK.
Figure 91 Add a view
Import views
·     The global ops topologies directory imports topology views from the Resource > Maintain Resources > Basic Data > TOPO list.
·     The service topology directory imports topology views from the Resource > Maintain Resources > Business Service > Business System list.
·     The service relationship topology directory imports topology views from the Resource > Maintain Resources > Business Service > Business Relation TOPO list.
3.     Hover over the  button, and then select Import View from the menu list that appears.
4.     Select the topology views to import in window that opens.
5.     Click OK. You can view the import results in the window that opens.
Figure 92 Import views
Import organizations
The global ops topologies support importing resources from organizational resource groups in a tree structure, displaying both the organization and its subgroups. It allows filtering resources by type within selected organizations, with resources presented in corresponding views or cloud views.
1.     ‍Navigate to the Monitor > Global Ops Topologies page.
2.     Hover over the root directory, and a  button will appear on the right.
3.     Hover over the  button, then select Import Organizations from the menu list that appears.
4.     In the pop-up window, you can select resource types to filter, then select one or more organizations or groups, and click OK.
5.     After successful import, the imported organization or group will appear in the left tree.
Figure 93 Import organizations
Edit a view
2.     Hover the mouse over a view in the left navigation tree, and a  button will appear on the right.
3.     Hover the mouse over the  button and select Modify from the menu list that appears.
4.     Configure basic information, expansion information, and change reason.
5.     Click OK.
Figure 94 Edit a view
Copy a view
3.     Hover the mouse over the  button, then select Copy from the menu list that appears.
4.     Enter the copied view name in the input box that appears.
5.     Click the blank space or press Enter to complete view copying.
Figure 95 Copy a view
Search for a view
2.     Select a search mode.
¡     In-page search: After selecting a topology view, click the  button in the upper-right search box to perform a search, which obtains CIs matching the search criteria within the current view.
¡     Global search: Click  button in the search field at the top right to search and obtain CIs matching the search criteria across all views.
¡     View search: In the search box above the left directory, you can obtain views that meet the search criteria across all views.
Sort views/directories
3.     Hover the mouse over the  button, and select Sort from the menu list that appears to and enter sort mode.
Drag and drop the view or directory to the desired location with the mouse to customize the order of the topology view or directory.
4.     Click  to then save the operation and exit sort mode.
Figure 96 Sort views/directories
Delete a view/directory
2.     Hover the mouse over a directory or view in the left navigation tree, and a  button will appear on the right.
3.     Hover the mouse over the  button, and then select the corresponding delete action from the menu list that appears.
¡     Delete from Resource: Delete the global ops topologies view and remove the corresponding configuration item from the resource. The operation will permanently delete the view data.
¡     Delete from Topology: Delete the global ops topologies directory or view. The deleted view can be re-imported.
4.     Click OK in the dialog box that opens.
Figure 97 Delete a view
Figure 98 Delete a directory
Edit a view
Enter view edit mode
IMPORTANT
IMPORTANT:
·     View service topology: Navigate to the Analysis > Service Health > Service List page, and then click the  button in the Actions column to view the service topology.
·     View service relationship topology: Navigate to the Analysis > Service Health > Service Relation Topology page, and click the topology name to view the topology page.
2.     Click a topology view in the left navigation tree.
3.     Click Edit in the upper right corner of the page to enter view edit mode.
Figure 99 View edit mode
Edit view operations
Node types
After entering the view editing mode, you can drag the required nodes from the type selection area on the left to the canvas. The system provides default group types, such as network device and server. You can also customize group types. This section introduces four types of nodes:
·     Cloud view: Except for business topology, a topology can be split into several topologies, or a topology can consist of several topologies.
·     Cluster: A cluster contains nodes with the same service functions. The nodes are in strong relevance to each other.
·     Group: A group contains nodes with similar attributes. The nodes do not need to have service associations.
·     Service: Displays relationships between services. A service node can be associated with only one service view. Service nodes apply only to service relationship topology configuration.
View configuration
·     View operations: For example, show grids, top-down view, and flashing switch.
Figure 100 View operations
·     Node operations: For example, show names, IPs, and maintenance tags.
Figure 101 Node operations
·     Map operations: For example, hide map, and select map (World map, GIS map, China map, Beijing map).
Figure 102 Map operations
·     Line operations: For example, show line name, show lines, and show virtual paths.
Figure 103 Line operations
Configuration
¡     Advanced settings: Modify the label colors and other attributes of nodes and connections in the current view.
¡     Background settings: Customize the background image of the current view.
¡     Traffic topology: Configure monitoring metrics for resources added to the current view.
¡     Alarm settings: Includes alarm messages for View/Cluster, Node, and Link.
-     Click the  button in the Actions column to edit configuration.
-     Select multiple alarm messages, and then click the bulk configuration button to edit the settings. View/Cluster can only be edited individually, not in bulk.
¡     Global configuration: See "Global settings."
Node edit operations
·     To add a resource for the node, click the Add Resource icon  in the top left corner of the node. On the window that opens, enter the resource information and then click OK. To also add a monitor for the node, click Next, configure the monitor information and then click OK.
·     To select a resource for the node, click the Select Resource icon  in the top right corner of the node. On the page that opens, search the target resource, and then click OK. To perform basic search, enter a filter keyword in the search box. To perform advanced search, click the favicon next to the search box to expand the advanced search area, specify the filter criteria, and then click Search.
·     To add a monitor for the node, click the Add Monitor icon  in the bottom right corner of the node. On the window that opens, configure the monitor information, and then click OK.
·     To view resource information about the node, click the Resource Info icon  in the top left corner of the node. You can view the warning messages, resource information, associated resources, resource topologies, and group information.
·     To view alarm information about the node, click the Alarm Info icon  in the bottom left corner of the node.
·     To view resource details about the node, click the Resource Details icon  in the bottom right corner of the node.
·     To add a line between the node and another node, click the Add Line icon  in the top right corner of the node, and drag the line to the target node.
Right-click operations
·     Right-click on a blank area of the view to add remarks, bulk add resources, and adjust node distance.
Figure 104 View right-click operations in the blank area
·     Right-click a node to delete from this view, edit resource information, view associations, and create virtual path.
Figure 105 Node right-click operations
·     Right-click a link to add point, delete line, and edit link.
Figure 106 Link right-click operations
Node double-click operations
·     Double-click a service node to automatically create a service view.
·     Double-click a cloud view node to automatically create a cloud view.
Export views
The system support exporting views in the formats of image, PDF, and HTML, but do not support exporting views with GIS map backgrounds.
1.     Click Export in the upper-right corner of the view, and then select Export Image, Export PDF, or Export HTML.
2.     After exporting the view file in the corresponding format, you can view it locally.
Figure 107 Export views
Global settings
This feature allows you to manage associations between topology resource types and resource component types and monitor component types.
Management resource mappings
1.     Click Setting above the view, and select Global Settings from the dropdown menu. The global settings window opens.
2.     On the Resource Mappings tab, click Add, and then enter the name and resource type on the page that opens.
3.     Click OK.
4.     Click  in the Actions column to edit resource information. Some fields cannot be edited due to page restrictions.
5.     Select one or more resources, and then click Delete above the list to remove resource mappings.
Figure 108 Management resource mappings
Resource mapping tip configuration
You can configure resource type tips with this feature. The tip configuration for resource mappings takes effect globally. If a tip configuration item has been set in the topology resource group, the configuration applies to the topology resource group.
1.     ‍Click Setting above the view, and select Global Settings from the dropdown menu. The global settings window opens.
2.     On the Resource Mappings tab, click Tip Config.
¡     Click  in the Actions column, and then select one or more nodes to display in the tip configuration dropdown field. After selection, click  to temporarily save the modified tip configuration. Click  to restore the default tip configuration.
¡     Select multiple entries, and then click the bulk configure button below the list, and choose the information to display for one or more nodes in the window that opens.
Figure 109 Resource mapping tip configuration
3.     Click Save.
Resource groups
This feature allows you configure resource groups (categories) based on registered components, as well as the resource types for each category. The system predefines multiple resource groups, including general area, network device, server, storage, virtualization, container, database, operating system, middleware, other resource, and equipment room environment. You can add new resource groups as needed. The system also predefines multiple resource types. You can add or delete resources types as needed.
Manage resource groups
Use this feature to add, edit, or delete resource groups and add or delete resource types.
2.     Click the Resource Groups tab and perform the following operations.
¡     Add a resource group: Click Add. In the window that opens, enter the resource group name to add a resource group to the current type of topology view. Click OK.
¡     Add a resource type: Click  in a group. In the window that opens, select the resource type and click OK.
¡     Edit or delete a resource group: Click  or  to edit or delete a resource group.
¡     Delete a resource type: Hover over a resource type under the group, and click  to delete the resource type.
3.     Click Save.
Figure 110 Manage resource groups
Resource group tip configuration
You can configure information displayed for nodes within the resource topology, with default settings preconfigured for multiple resource types.
2.     Click the Resource Groups tab, and click Tip Config. The tip configuration window opens.
3.     Select multiple entries, and then click the bulk configure button below the list, and choose the information to display for one or more nodes in the window that opens.
4.     Click Save.
Figure 111 Resource group tip configuration
Alarm settings
The concerned and aggregated alarms might vary by view based on service demands. In addition, the concerned alarms on a node might vary by view. You can configure the global, cloud view/cluster, node, and link alarm levels, specify alarms, and filter alarm information.
Manage global alarm settings
Global alarm settings are the default alarm settings for the global ops topology, and apply to views/clusters, nodes, or links without specific settings configured. By default, global alarm settings focus on critical and major alarms, as well as disconnection alarms for devices and applications.
2.     Click the Alarm Settings tab. The contents of the global alarm configuration list are as follows:
¡     Alarm Severity Level Configuration Type: Displays the user-defined alarm severity configuration type.
¡     Alarm Severity Level: Displays the user-defined alarm severity.
¡     Alarm Trap Configuration Type: Displays the user-defined trap configuration type.
¡     Alarm Trap: Displays the user-defined trap.
3.     To edit an existing alarm setting, click  in the Actions column for the alarm setting. In the window that opens, edit relevant parameters as needed.
4.     Click OK.
Figure 112 Alarm settings
Management view/cluster alarm settings
A view or cluster alarm setting applies to nodes and links in a view or cluster. For a view, view-specific alarm settings take precedence over global alarm settings.
2.     Click the Alarm Settings tab, and click the View/Cluster tab.
4.     Click OK.
Figure 113 Manage view/cluster alarm settings
Manage node alarm settings
A node alarm setting applies to a node, such as a device or application. For a node, node-specific alarm settings take precedence over global alarm settings.
2.     Click the Alarm Settings tab, and click the Node tab.
4.     Click OK.
Figure 114 Manage node alarm settings
Manage link alarm settings
A link alarm setting applies to a physical link. For a view, view-specific alarm settings take precedence over global alarm settings.
2.     Click the Alarm Settings tab, and click the Link tab.
4.     Click OK.
Figure 115 Manage link alarm settings
Layer settings
You can configure layer settings for displaying the edited layers in the view.
The feature is supported only by service topologies.
2.     Click the Layer Settings tab.
The contents of this page are as follows:
¡     Layers: Number of layers.
¡     Layer Name: Name of the layer.
¡     Category: Category of the layer.
¡     Layer Icon: Icon of the layer.
¡     Order: Order of layers, which is configurable.
3.     To add a layer, click  in the Actions column for a layer to add a layer below it.
4.     To edit a layer, click  in the Actions column for the layer. Edit layer information as needed, and then click .
5.     To change the order of layers, perform the following actions for the target layer:
¡     To switch its position with the layer above, click  in the Order column.
¡     To move it to the top, click  in the Order column.
¡     To switch its position with the layer below, click  in the Order column.
¡     To move it to the bottom, click  in the Order column.
6.     To restore the predefined layer settings, click Predefined Settings. In the window that opens, click OK.
Service topology generation settings
Perform this task to configure the relationship between two resources for automatically generating a service topology in the resource topology.
2.     Click the Service Topo Generation Settings tab, and click Add. In the window that opens, configure a relation between two resources. Select the start and end resources that have not been used in existing relationships.
3.     Click OK.
4.     The content of the service topology generation configuration list is as follows:
¡     Start Resource: Start resource of the service topology.
¡     End Resource: End resource of the service topology.
¡     One-Way Relation: Whether the relation is a one-way relation.
¡     Relation Diagram: Diagram that illustrates the relationship.
¡     Predefined: Whether the configuration is predefined.
5.     To view the relationship topology for all resource relationships, click Relation Topology.
6.     To view the relationship topology for a specific resource relationship, click  in the Actions column for the target resource relationship.
Custom topology relationship profiles
You can configure the tree relationship between resources and generate custom topology in the resource topology based on the relationship.
2.     Click the Custom Topology Relationship Profiles tab, and then click Add.
3.     Enter basic information. In the Configure Displayed Info area, drag and drop topology layers and icons to the area to define the resource topology relationship. From the fourth layer, you can select whether to display the layer.
4.     Click OK.
5.     To edit or delete a custom topology relationship profile, click  or   in the Actions column for the custom topology relationship profile. The system does not allow editing certain custom topology relationship profiles.
6.     To view a custom topology relationship profile, click  in the Actions column for the custom topology relationship profile.
¡     To fast generate a new relationship by copying an existing custom topology relationship, click  in the Actions column for that resource.
Figure 116 Custom topology relationship profiles
GIS map settings
Use this feature to pre-configure Google Maps, Baidu Maps, and Gaode Maps for quick map view selection.
2.     Click the GIS Map Settings tab to configure the API address and key value of the desired map.
3.     Click OK.
Figure 117 GIS map settings
Display settings
Use this feature to specify whether the view background of the node type has padding.
Figure 118 Display settings
Notification management
Notification settings
This feature allows you to configure notification parameters.
Add or edit notification settings
2.     From the navigation pane, select Notification Management > Notification Settings.
3.     To add a notification setting, click Add.
4.     In the window that opens, specify the resource type, attribute name, and threshold settings.
Figure 119 Add notification
5.     Click OK.
List contents
¡     Resource Type: Type of the resource associated with the notification setting.
¡     Attribute Name: Name of the attribute associated with the notification setting.
¡     Alarm Level: Alarm severities for the notification setting.
¡     Threshold (1 to 90 Days): Time thresholds for the notification setting. The value range for a threshold is 1 to 90 days.
6.     To edit a notification setting, click the  icon in the Actions column for it. The system does not allow editing certain notification settings.
Delete notification settings
3.     Delete notification settings:
¡     To delete notifications in bulk, select one or multiple notifications, and then click Delete. In the dialog box that opens, click OK.
¡     To delete a single notification, click  in the Actions column for that notification. In the dialog box that opens, click OK.
Search for notifications
This feature allows you to view notifications that are about to expire, expired notifications, and history notifications.
View notifications that are about to expire
2.     From the navigation pane, select Notification Management > Search for Notifications. The system is placed at the Notifications to Expire tab.
List contents
¡     Resource Type: Resource type associated with the notification.
¡     Resources: Resources associated with the notification.
¡     Expiration Date: Time when the notification will expire.
¡     Alarm Level: Alarm severity of the notification.
¡     Notification Info: Information about the notification.
¡     Notified At: Time when the notification was generated.
Figure 120 View notifications that are about to expire
3.     To move notifications to history notifications, select the target notifications, and then click Move to History Notifications.
4.     To view details about a notification, click  in the Actions column for that notification.
5.     To edit a notification, click  in the Actions column for that notification.
View expired notifications
3.     Click the Expired Notifications tab.
List contents
¡     Expiration Date: Time when the notification expired.
Figure 121 View expired notifications
4.     To move notifications to history notifications, select the target notifications, and then click Move to History Notifications.
5.     To view details about an expired notification, click  in the Actions column for that notification.
6.     To edit an expired notification, click  in the Actions column for that notification.
View history notifications
3.     Click the History Notifications tab.
List contents
Figure 122 View history notifications
4.     To delete history notifications in bulk, select the notifications, and then click Delete. You can also click  in the Actions column for a history notification to delete it.
5.     To view details about a history notification, click  in the Actions column for that notification.
Attribute rule settings
This feature allows you to configure attribute rules for resource types. When an attribute matches the rules, the system sends an alarm.
Add/view/edit an attribute rule
·     When adding an attribute rule, specify attributes of the same type.
·     To enable or disable a rule, click Enable or Disable on the attribute rule settings list.
·     The system will ignore a match rule with empty text attributes.
2.     From the navigation pane, select Notification Management > Attribute Rule Settings.
3.     Click Add.
Figure 123 Add an attribute rule
4.     Configure the rule name, resource type, and state.
5.     Click OK.
List contents
¡     Resource Type: Resource type associated with the attribute rule.
¡     Rule Name: Name of the attribute rule.
¡     State: State of the rule.
6.     To view details about an attribute rule, click the  icon in the Actions column for the attribute rule.
7.     To edit an attribute rule, click the  icon in the Actions column for the attribute rule.
Enable/disable an attribute rule
3.     Click Enable or Disable in the State column for an attribute rule.
Figure 124 Enable/disable an attribute rule
View resources matching rules
3.     Click the  icon in the Actions column for an attribute rule to view resources matching the attribute rule.
Figure 125 View resources matching rules
Delete attribute rules
3.     Select one or multiple attribute rules, and then click Delete. In the dialog box that opens, click OK
Change logs
This feature allows you to view resource attribute change logs and resource addition or deletion logs.
Resource attribute change logs
View resource attribute change logs
2.     From the navigation pane, select Change Logs. The system is placed at the Resource Attribute Change Logs tab.
List contents
¡     Changed At: Time when the resource attribute changed.
¡     Type: Type of the resource attribute.
¡     Resource: Name of the resource with which the attribute is associated.
¡     Changed Attribute: Name of the changed attribute.
¡     Data Before Change: Data of the resource attribute before the change.
¡     Data After Change: Data of the resource attribute after the change.
¡     Changed By: User who changed the resource attribute.
¡     Change Reason: Cause of the resource attribute change.
3.     Click a resource link to view details about the resource.
Figure 126 View resource attribute change log
Export resource attribute change logs
You can export selected resource attribute change logs or all resource attribute change logs.
3.     On the page that opens, select one or multiple entries, and then click Export and select Export Selected Entries or Export All.
¡     Export Selected Entries: Export selected resource attribute change logs.
¡     Export All: Export all resource attribute change logs.
Figure 127 Export resource attribute change logs
Delete resource attribute change logs
3.     Delete logs:
¡     Select one or multiple entries, and then click Delete to delete the selected logs.
¡     Click Delete to delete the logs from the list. You can search for logs by filter criterion and bulk delete the logs. The system can delete a maximum of 10000 matching entries.
Resource addition or deletion logs
View resource addition or deletion logs
3.     Click the Resource Addition/Deletion Logs tab.
List contents
¡     Type: Type of the resource.
¡     Resource: Name of the resource.
¡     Resource Added At: Time when the resource was added.
¡     Resource Added By: User who added the resource.
¡     Resource Deleted At: Time when the resource was deleted.
¡     Resource Deleted By: User who deleted the resource.
Figure 128 View resource addition or deletion logs
4.     To view basic information about a resource, click the  icon in the Actions column for the resource.
5.     To restore a resource that has been deleted, click the  icon in the Actions column for the resource.
Export resource addition or deletion logs
You can export selected resource addition or deletion logs or all resource addition or deletion logs.
4.     On the page that opens, select one or multiple entries, and then click Export and select Export Selected Entries or Export All.
¡     Export Selected Entries: Export selected resource addition or deletion logs.
¡     Export All: Export all resource addition or deletion logs.
Figure 129 Export resource addition or deletion logs
Delete resource addition or deletion logs
4.     Delete logs:
Parameter settings
This feature manages asset process settings in a unified manner.
Asset processes
Use this feature to configure asset-related processes.
Add/view/edit an asset process
2.     From the navigation pane, select Parameter Settings > Asset Processes.
List contents
¡     Operation Name: Operation name of an asset process.
¡     Resource Type: Resource types of the asset process.
¡     Service Process: Service process of the asset process.
¡     Whether to Enable: Whether the asset process is enabled. To change the enabling state, you can click the value in this column.
3.     Click Add.
Figure 130 Add an asset process
4.     In the window that opens, enter an operation name, select the resource types, service process, and data template.
5.     Click OK.
6.     To view details about the asset, click the  icon.
7.     Click the  icon in the Actions column for an existing asset process.
Delete asset processes
3.     Delete asset processes:
¡     To delete a single entry, click  in the Actions column for that entry. In the dialog box that opens, click OK.
¡     To delete entries in bulk, select one or multiple entries, and then click Delete. In the dialog box that opens, click OK.
Attribute collaboration rules
This function enables collaboration between different attributes of different resources.
Add/view/edit an attribute collaboration rule
2.     From the navigation pane, select Parameter Settings > Attribute Collaboration Rules.
List contents
¡     Rule Name: Name of the attribute collaboration rule.
¡     Resource Type: Resource type of the attribute collaboration rule.
¡     Related Resource Type: Resource type associated with the attribute collaboration rule.
3.     Enabling Status: Specify whether to enable the attribute collaboration rule.
4.     Click Add, and specify the rule name and enabling status in the dialog box that opens.
Figure 131 Add an attribute collaboration rule
5.     In the attribute relations section, specify the Update Attribute and Related Resource Attribute fields.
¡     Click  to add an attribute relation.
¡     Click  to delete an attribute relation.
6.     Click OK.
7.     To view details about the attribute collaboration rule, click  in the Actions column for the rule.
8.     To edit the attribute collaboration rule, click  in the Actions column for the rule.
Delete attribute collaboration rules
3.     Delete attribute collaboration rules:
