| 01-Hardware Information and Specifications | 3.20 MB |
1 Product models and technical specifications
3 Removable component compatibility matrix
2000W AC power supply (PSR2000-12A-C-A/PSR2000-12A-C-B)
2000W AC power supply (PSR2000-12A-S/PSR2000-12A-S-B)
2700W AC power supply (PSR2700-12A-A)
1600W AC power supply (PSR1600-12A-S/PSR1600-12A-S-B)
Product models
The H3C S9827 & S9857 switch series contains models listed in the following table:
Product model |
Product code |
S9827-128DH |
LS-9827-128DH |
S9827-64E |
LS-9827-64E |
S9827-64EP |
LS-9827-64EP |
S9857-24DH8EP |
LS-9857-24DH8EP |
NOTE: · To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/. · For information about product and software compatibility, see the release notes. |
Technical specifications
Table1-1 Technical specifications
Item |
LS-9827-128DH |
LS-9827-64E |
LS-9827-64EP |
LS-9857-24DH8EP |
Physical specifications |
Dimensions (H × W × D) |
175 × 442 × 760 mm (6.89 × 17.40 × 29.92 in) |
88.1 × 440 × 760 mm (3.47 × 17.32 × 29.92 in) |
44 × 442 × 550 mm (1.73 × 17.40 × 21.65 in) |
Dimensions (H × W × D, with package materials) |
391 × 655 × 1092 mm (15.39 × 25.79 × 42.99 in) |
225 × 570 × 1115 mm (8.86 × 22.44 × 43.90 in) |
361 × 635 × 1072 mm (14.21 × 25.00 × 42.20 in) |
150 × 575 × 775 mm (5.91 × 22.64 × 30.51 in) |
Weight (fully configured with fan modules, power supplies, and supervisor engine modules) |
≤ 41 kg (90.39 lb) |
≤ 30 kg (66.14 lb) |
≤ 45 kg (99.21 lb) |
≤ 13 kg (28.66 lb) |
Technical specifications |
Processor |
4 cores, 2.6 GHz |
DRAM memory |
16 GB |
NOR flash |
2 × 256 MB (primary and backup) |
NAND flash |
64 GB eMMC flash |
Port types and quantity |
Console port |
1 × serial console port |
Management Ethernet port |
1 × copper management Ethernet port |
USB port |
1 × USB port |
QSFP112 port |
128 |
N/A |
N/A |
24 |
OSFP800 port |
N/A |
N/A |
64 |
8 |
QSFP-DD800 port |
N/A |
64 |
N/A |
N/A |
SFP+ port |
2 |
2 |
2 |
2 |
Fan modules, power supplies, and supervisor engine modules (SEMs) |
Fan module slot |
8 |
4 |
8 |
6 |
Power supply slot |
4 |
2 |
4 |
2 |
SEM slot |
1 |
N/A |
1 |
N/A |
Power supply specifications |
Power input |
AC input and DC input |
Power consumption |
Typical power consumption (Fully configured with copper cables, at 50% load) |
850 W |
729 W |
743 W |
400 W |
Maximum power consumption (Fully configured with transceiver modules, at 100% load) |
3130 W |
3027 W |
3254 W |
1150 W |
Thermal consumption |
Typical thermal consumption |
Single AC input/dual AC inputs: 498 BTU/hr |
2487 BTU/hr |
2535 BTU/hr |
Single AC input/dual AC inputs: 1317 BTU/hr |
Maximum thermal consumption |
1464 BTU/hr |
6889 BTU/hr |
7664 BTU/hr |
3473 BTU/hr |
Heat dissipation |
Heat dissipation method |
Air cooling |
Ventilation aisles |
Front-to-rear |
Reliability and availability |
Power supply redundancy |
2+2 redundancy |
1+1 redundancy |
2+2 redundancy |
1+1 redundancy |
Fan module redundancy |
7+1 redundancy |
3+1 redundancy |
7+1 redundancy |
5+1 redundancy |
Hot swapping |
Supported |
Supported |
Supported |
Supported |
Mean time between failure (MTBF) (year) |
> 50 |
Mean time to repair (MTTR) (hour) |
< 1 |
Availability |
99.999927% |
Environment specifications |
Altitude |
0 to 5000 m (0 to 16404.20 ft) |
Operating temperature |
0°C to 40°C (32°F to 104°F) Note: The allowed maximum temperature decreases by 0.33 °C (0.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft). |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Humidity |
5% RH to 95% RH, noncondensing |
Compliance |
Product compliance |
· Safety standards · EMC standards · Environmental and eco-friendly standards |
2 Chassis views
LS-9827-128DH
(1) QSFP112 fiber Ethernet port |
(2) QSFP112 port LED |
(3) System status LED (SYS) |
(4) Location LED (ID) |
(5) Fan module status LED (FAN) |
(6) SFP+ port LED |
(7) SFP+ fiber Ethernet port |
(8) Reset button (RESET) |
(9) Power status LED (PSU) |
(10) USB port |
(11) Serial console port |
(12) Copper management Ethernet port |
(1) Fan module 1 |
(2) Fan module 2 |
(3) Fan module 3 |
(4) Fan module 4 |
(5) Power supply 1 |
(6) Power supply 2 |
(7) Power supply 3 |
(8) Power supply 4 |
(9) Fan module 5 |
(10) Fan module 6 |
(11) Fan module 7 |
(12) Power supply 8 |
(13) Grounding screw 2 |
(14) Grounding screw 1 |
The switch has four power supply slots at the rear panel and comes with a power supply installed in each power supply slot. You can install two to four power supplies for the switch as needed. In Figure2-2, PSR2000-12A-C-A AC power supplies are installed in the four power supply slots.
The switch comes with eight fan module slots empty. You must install eight fan modules of the same model for the switch. In Figure2-2, FAN-80B-1-C fan modules are installed in the eight fan module slots.
The switch supports shipping with fan modules and power supplies installed. To purchase a switch preinstalled with fan modules and power supplies, contact marketing staff.
Figure2-3 Left view
(1) Power supply latch |
(2) Mounting bracket installation position at the port side |
(3) Fan module handle |
LS-9827-64E
Figure2-4 Front panel
(1) System status LED (SYS) |
(2) Location LED (ID) |
(3) QSFP-DD800 Ethernet fiber port |
(4) QSFP-DD800 port LED |
(5) Reset button (RESET) |
(6) USB port |
(7) SFP+ port LED |
(8) SFP+ Ethernet fiber port |
(10) Fan module status LED (FAN) |
(11) Copper management Ethernet port |
(12) Serial console port |
(1) Fan module 1 |
(2) Fan module 2 |
(3) Fan module 3 |
(4) Fan module 4 |
(7) Grounding screw 2 |
(8) Grounding screw 1 |
The switch has two power supply slots at the rear panel and comes with a power supply installed in each power supply slot. In Figure2-5, PSR2700-12A-A AC power supplies are installed in the two power supply slots.
The switch comes with four fan module slots empty. You must install four fan modules of the same model for the switch. In Figure2-5, FAN-80B-1-D fan modules are installed in the four fan module slots.
Figure2-6 Left view
(2) Fan module handle |
(3) Mounting bracket installation position at the port side |
LS-9827-64EP
Figure2-7 Front panel
(1) OSFP800 fiber Ethernet port |
(2) OSFP800 port LED |
(6) SFP+ port LED |
(10) USB port |
(1) Fan module 1 |
(2) Fan module 3 |
(3) Fan module 5 |
(4) Fan module 7 |
(9) Fan module 8 |
(10) Fan module 6 |
(11) Fan module 4 |
(12) Power supply 2 |
The switch has four power supply slots at the rear panel and comes with a power supply installed in each power supply slot. You can install two to four power supplies for the switch as needed. In Figure2-8, PSR2000-12A-S AC power supplies are installed in the four power supply slots.
The switch comes with eight fan module slots empty. You must install eight fan modules of the same model for the switch. In Figure2-8, FAN-80B-1-D fan modules are installed in the eight fan module slots.
Figure2-9 Left view
LS-9857-24DH8EP
Figure2-10 Front panel
(1) Location LED (ID) |
(2) System status LED (SYS) |
(3) Fan module status LED (FAN) |
(4) SFP+ port LED |
(5) QSFP112 port LED |
(6) QSFP112 fiber Ethernet port |
(7) OSFP800 fiber Ethernet port |
(8) OSFP800 port LED |
(9) SFP+ fiber Ethernet port |
(10) Reset button (RESET) |
(11) Power status LED (PSU) |
Figure2-11 Left view
(1) Mounting bracket installation position at the power supply side |
(2) Switch grounding point 1 |
(3) Switch grounding point 2 |
(4) Mounting bracket installation position at the port side |
(5) Power supply handle |
(6) Power supply latch |
Figure2-12 Rear panel
(1) Power supply 1 |
(2) Copper management Ethernet port LED (ACT) |
(3) Copper management Ethernet port |
(4) Copper management Ethernet port LED (LINK) |
(5) Fan module 1 |
(6) Fan module 2 |
(7) Fan module 3 |
(8) Fan module 4 |
(9) Fan module 5 |
(10) Fan module 6 |
(11) Power supply 2 |
(12) USB port |
(13) Console port |
The switch uses modular design. Table3-1 describes the FRUs available for the switch.
Table3-1 FRUs available for the switch
FRUs |
Product code |
LS-9827-128DH |
LS-9827-64E |
LS-9827-64EP |
LS-9857-24DH8EP |
Power supplies |
PSR2000-12A-C-A |
9803A0D9 9803A0DA |
Yes |
No |
No |
No |
PSR2000-12A-C-B |
9803A1PF 9803A1PG |
Yes |
No |
No |
No |
PSR2000-12A-S |
0231AMP0 0231AMP2 |
No |
No |
Yes |
No |
PSR2000-12A-S-B |
0231AMNU 0231AMNW |
No |
No |
Yes |
No |
PSR2700-12A-A |
0231ANGS 0231ANGT |
No |
Yes |
No |
No |
PSR1600-12A-S |
0231AMP1 0231AMNX |
No |
No |
No |
Yes |
PSR1600-12A-S-B |
0231AMNV 0231AMNY |
No |
No |
No |
Yes |
Fan modules |
FAN-80B-1-C |
9803A0DB 9803A0DC |
Yes |
No |
No |
No |
FAN-80B-1-D |
0231AMNR 0231AMNP |
No |
Yes |
Yes |
No |
FAN-40B-1-G |
0231AMRJ 0231AMRK |
No |
No |
No |
Yes |
SEMs |
LSWM1SUPD1 |
9803A1N8 9803A1N9 |
Yes |
No |
No |
No |
LSWM1SUPX1 |
0231AMNQ 0231AMNS |
No |
No |
Yes |
No |
LSWM3SUPD1 |
0231AQKS 0231AQKT |
Yes |
No |
No |
No |
LSWM3SUPX1 |
0231AQKQ 0231AQKR |
No |
No |
Yes |
No |
The S9827-128DH or S9827-64EP switch can operate correctly with two power supplies. You can install three power supplies for 2+1 redundancy or four power supplies for 2+2 redundancy.
The S9827-64E and S9857-24DH8EP switches can operate correctly with one power supply. You can install two power supplies for 1+1 redundancy.
To ensure heat dissipation, make sure all fan module slots are installed with fan modules and install fan modules of the same model on the switch as a best practice.
Power supplies on a switch must be the same model.
4 Power supplies
WARNING! When the switch has power supplies in redundancy, you can replace a power supply without powering off the switch. To avoid device damage and personal injury, make sure the power supply is powered off before you replace it. |
You can select power supplies as needed for the switch.
Figure4-1 PSR2000-12A-C-A/PSR2000-12A-C-B power supply
(1) AC power input receptacle |
(2) Status LED |
(3) Latch |
(4) Handle |
For information about the status LED, see "Power supply status LED."
Features
PSR2000-12A-C-A/PSR2000-12A-C-B is a power supply with AC or HVDC input and DC output. It can provide up to 2000 W of output. Table4-1 describes the features provided by the PSR2000-12A-C-A/PSR2000-12A-C-B power supply.
Table4-1 Features provided by the PSR2000-12A-C-A/PSR2000-12A-C-B power supply
Feature |
Protection function |
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output shortcircuit, and overtemperature conditions. |
Support for redundancy |
Multiple power supplies can be connected in parallel to achieve N+1 or N+N redundancy and load balancing. |
Support for hot swapping |
You can remove one of the power supplies in redundancy when the device is operating. |
Table4-2 Technical specifications
Item |
Specification |
Dimensions (H × W × D) (handle included) |
40 × 73.5 × 185 mm (1.57 × 2.89 × 7.28 in) |
Weight |
0.75 kg (1.65 lb) |
Rated AC input voltage range |
100 VAC to 240 VAC @ 50 or 60 Hz |
Max AC input voltage range |
90 VAC to 264 VAC |
Rated HVDC input voltage |
240 VDC |
Max HVDC input voltage range |
180 VDC to 320 VDC |
Rated input current |
12A Max @ 100 VAC to 240 VAC 10A Max @ 240 VDC |
Rated output current |
164 A |
Rated output voltage |
12.2 V |
Rated output power |
2000 W |
Melting current of power supply fuse |
15 A |
Max output current |
164 A |
Max power |
2000 W |
Figure4-2 PSR2000-12A-S/PSR2000-12A-S-B power supply
(2) Status LED |
(3) Latch |
(4) Handle |
Features
PSR2000-12A-S/PSR2000-12A-S-B is a power supply with AC or HVDC input and DC output. It can provide up to 2000 W of output. Table4-3 describes the features provided by the PSR2000-12A-S/PSR2000-12A-S-B power supply.
Table4-3 Features provided by the PSR2000-12A-S/PSR2000-12A-S-B power supply
Feature |
Table4-4 Technical specifications
Item |
PSR2000-12A-S |
PSR2000-12A-S-B |
Weight |
0.935 kg (2.06 lb) |
0.945 kg (2.08 lb) |
100 VAC to 240 VAC |
90 VAC to 264 VAC |
240 VDC |
10 A |
164 A |
12.2 V |
2000 W |
15 A |
164 A |
Max power |
2000 W |
Figure4-3 PSR2700-12A-A power supply
(2) Status LED |
(3) Latch |
(4) Handle |
Features
PSR2700-12A-A is a power supply with AC or HVDC input and DC output. It can provide up to 2700 W of output. Table4-5 describes the features provided by the PSR2700-12A-A power supply.
Table4-5 Features provided by the PSR2700-12A-A power supply
Feature |
Table4-6 Technical specifications
Item |
Specification |
Weight |
0.94 kg (2.07 lb) |
90 VAC to 264 VAC |
240 VDC |
16 A |
221.4 A |
12.2 V |
2700 W |
20 A |
221.4 A |
Max power |
2700 W |
Figure4-4 PSR1600-12A-S/PSR1600-12A-S-B power supply
(2) Status LED |
(3) Latch |
(4) Handle |
Features
PSR1600-12A-S/PSR1600-12A-S-B is a power supply with AC or HVDC input and DC output. It can provide up to 1600 W of output. Table4-7 describes the features provided by the PSR1600-12A-S/PSR1600-12A-S-B power supply.
Table4-7 Features provided by the PSR1600-12A-S/PSR1600-12A-S-B power supply
Feature |
Table4-8 Technical specifications
Item |
Specification |
Weight |
1 kg (2.20 lb) |
90 VAC to 264 VAC |
240 VDC |
180 VDC to 310 VDC |
12 A Max @ 100 VAC to 240 VAC 10 A Max @ 240 VDC |
132 A |
12.2 V |
1600 W |
15 A |
132 A |
Max power |
1600 W |
5 Fan modules
CAUTION: The S9827-128DH and S9827-64EP switches each have eight fan module slots. The S9827-64E switch has four fan module slots. The S9857-24DH8EP switch has six fan module slots. To ensure good ventilation of the switch, follow these guidelines to install and remove fan modules: · The switch comes with the fan module slots empty. As a best practice to ensure adequate heat dissipation, install fan modules of the same model on the switch. Before powering on the switch, make sure the number of installed fan modules meets the minimum requirement. · Make sure all slots have a module or filler panel installed when the switch is operating. · If multiple fan modules fail on an operating switch, do not remove the fan modules at the same time. Replace the fan modules one after another and finish replacing each fan module within 3 minutes. |
FAN-80B-1-C
Figure5-1 FAN-80B-1-C fan module
For information about the alarm LED, see "Fan module alarm LED."
Features
The FAN-80B-1-C fan module draws air from the port side to the fan module faceplate side. The fan module is small, hot swappable, and can automatically adjust the fan speed according to the device temperature.
Table5-1 FAN-80B-1-C fan module specifications
Item |
Specification |
80 × 80 × 136 mm (3.15 × 3.15 × 5.35 in) |
Weight |
0.5 kg (1.10 lb) |
Airflow direction |
Air exhausted from the fan module faceplate |
Max fan speed |
Inlet: 16000 R.P.M Outlet: 14000 R.P.M |
Max airflow |
163.92 CFM (4.64 m3/min) |
Input voltage |
12 V |
Max power consumption |
105.6 W |
FAN-80B-1-D
Figure5-2 FAN-80B-1-D fan module
Features
The FAN-80B-1-D fan module draws air from the port side to the fan module faceplate side. The fan module is small, hot swappable, and can automatically adjust the fan speed according to the device temperature.
Table5-2 FAN-80B-1-D fan module specifications
Item |
Specification |
80 × 80 × 175.6 mm (3.15 × 3.15 × 6.91 in) |
Weight |
0.6 kg (1.32 lb) |
Airflow direction |
Max fan speed |
16900 R.P.M |
Max airflow |
128 CFM (3.62 m3/min) |
Input voltage |
12 V |
158 W |
FAN-40B-1-G
Figure5-3 FAN-40B-1-G fan module
Features
The FAN-40B-1-G fan module draws air from the port side to the fan module faceplate side. The fan module is small, hot swappable, and can automatically adjust the fan speed according to the device temperature.
Table5-3 FAN-40B-1-G fan module specifications
Item |
Specification |
40 × 40 × 135.9 mm (1.57 × 1.57 × 5.35 in) |
Weight |
0.5 kg (1.10 lb) |
Airflow direction |
Max fan speed |
Inlet: 34000 R.P.M Outlet: 32000 R.P.M |
Max airflow |
44.28 CFM (1.25 m3/min) |
Input voltage |
12 V |
48 W |
6 SEMs
LSWM1SUPD1
Figure6-1 LSWM1SUPD1 SEM
Table6-1 LSWM1SUPD1 SEM specifications
Item |
Specification |
Weight |
1.90 kg (4.19 lb) |
151 × 33.5 × 309 mm (5.94 × 1.32 × 12.17 in) |
Power consumption |
45 W |
Processor |
4 cores, 2.6 GHz |
SDRAM |
16 GB |
Flash |
64 GB |
NVRAM |
N/A |
Connector type |
· RJ-45 · USB (Type A) |
Ports |
· 1 × console port · 1 × USB port · 1 × RJ-45 network management port |
Port transmission speed |
· Console port: 9600 (default) to 115200 bps · RJ-45 network management port: 10/100/1000 Mbps, half/full duplex |
Hot swapping |
Supported |
Compatible switch model |
S9827-128DH |
Front view
Figure6-2 LSWM1SUPD1 SEM front view
(1) Copper management Ethernet port |
(2) Serial console port |
(3) USB port |
(4) System status LED (SYS) |
(5) Power status LED (PSU) |
(6) Fan module status LED (FAN) |
(7) Location LED (ID) |
(9) Copper management Ethernet port LED (LINK) |
(10) Copper management Ethernet port LED (ACT) |
LSWM1SUPX1
Figure6-3 LSWM1SUPX1 SEM
Table6-2 LSWM1SUPX1 SEM specifications
Item |
Specification |
Weight |
1.90 kg (4.19 lb) |
Power consumption |
45 W |
Processor |
4 cores, 2.6 GHz |
SDRAM |
16 GB |
Flash |
64 GB |
NVRAM |
N/A |
Connector type |
Ports |
Hot swapping |
Supported |
S9827-64EP |
Front view
Figure6-4 LSWM1SUPX1 SEM front view
(3) USB port |
(5) Location LED (ID) |
(6) Power status LED (PSU) |
(7) Fan module status LED (FAN) |
(9) Copper management Ethernet port LED (ACT) |
(10) Copper management Ethernet port LED (LINK) |
LSWM3SUPD1
Figure6-5 LSWM3SUPD1 SEM
Table6-3 LSWM3SUPD1 SEM specifications
Item |
Specification |
Weight |
1.40 kg (3.09 lb) |
33.5 × 151 × 304 mm (1.32 × 5.94 × 11.97 in) |
Power consumption |
42 W to 44 W |
Processor |
4 cores, 2.6 GHz |
SDRAM |
16 GB |
Flash |
64 GB |
NVRAM |
N/A |
Connector type |
Ports |
· 1 × console port · 1 × USB port · 1 × RJ-45 network management port · 2 × SFP+ fiber ports |
· Console port: 9600 bps and 115200 bps · RJ-45 network management port: 10/100/1000 Mbps, half/full duplex · SFP+ fiber port: 10 Gbps |
Hot swapping |
Supported |
S9827-128DH |
Front view
Figure6-6 LSWM3SUPD1 SEM front view
(3) USB port |
(9) SFP+ port (SFP+ 1) |
(10) SFP+ port LED |
(11) SFP+ port (SFP+ 2) |
(12) SFP+ port LED |
(13) Copper management Ethernet port LED (ACT) |
(14) Copper management Ethernet port LED (LINK) |
LSWM3SUPX1
Figure6-7 LSWM3SUPX1 SEM
Table6-4 LSWM3SUPX1 SEM specifications
Item |
Specification |
Weight |
1.40 kg (3.09 lb) |
Power consumption |
39 W to 40 W |
Processor |
4 cores, 2.6 GHz |
SDRAM |
16 GB |
Flash |
64 GB |
NVRAM |
N/A |
Connector type |
Ports |
· Console port: 9600 bps · RJ-45 network management port: 100/1000 Mbps, half/full duplex · SFP+ port: 10 Gbps |
Hot swapping |
Supported |
S9827-64EP |
Front view
Figure6-8 LSWM3SUPX1 SEM front view
(3) USB port |
(13) Copper management Ethernet port LED (LINK) |
(14) Copper management Ethernet port LED (ACT) |
7 Ports
As a best practice, use H3C transceiver modules and cables for the switch. H3C transceiver modules and cables are subject to change over time. For the most up-to-date list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
For information about the specifications of H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Console port
The switch has a serial console port.
Table7-1 Console port specifications
Item |
Connector type |
RJ-45 |
Compliant standard |
EIA/TIA-232 |
Operating mode |
Duplex Universal Asynchronous Receiver/Transmitter (duplex UART) |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Services |
· Provides connection to an ASCII terminal. · Provides connection to the serial port of a local terminal (a PC for example) running a terminal emulation program. |
The switch has one copper management Ethernet port. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table7-2 Management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Connector count |
1 × 10/100/1000BASE-T management port |
10/100/1000BASE-T management port: IEEE802.3ab |
Port transmission rate, duplex mode, and auto MDI/MDI-X |
· 10/100 Mbps, half/full duplex, auto MDI/MDI-X. · 1000 Mbps, full duplex, auto MDI/MDI-X. |
Transmission medium and max transmission distance |
10/100/1000BASE-T management port: 100 m (328.08 ft) over category-5 UTP cable. |
Functions and services |
Software upgrade and network management. |
USB port
The switch has one OHCI-compliant USB 2.0 port or USB 3.0 port. The USB 2.0 port can upload and download data at a rate up to 480 Mbps. The USB 3.0 port can upload and download data at a rate up to 5 Gbps. You can use this USB port to access the file system on the flash of the switch, for example, to upload or download application and configuration files.
The USB port supplies power as per USB 2.0 or USB 3.0 specifications. Use only USB 2.0-compliant or USB 3.0-compliant USB devices for the USB port. The port might not identify USB devices that are not compliant with USB 2.0 or USB 3.0.
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices of all vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
OSFP800 port
Table7-3 OSFP800 port specifications
Item |
Specification |
Port name |
800GE OSFP800 fiber port |
Product compatibility |
· The S9827-64EP switch provides 64 OSFP800 ports on the front panel · The S9857-24DH8EP switch provides eight OSFP800 ports on the front panel |
Connector |
· MPO · LC |
The 800GE OSFP800 fiber ports are mainly used for transmitting and receiving 800GE fiber port services and are compatible with 800 Gbps and 400 Gbps rates |
IEEE802.3ck |
Fiber port attribute |
Depends on the transceiver module or cable installed |
Operating mode |
Full duplex |
Available transceiver modules and cables |
See H3C S9827 & S9857 Switch Series Transceiver Module Compatibility Matrix |
Support for interface splitting |
See H3C Data Center Fixed-Port Switches Support for Interface Splitting |
Restrictions and guidelines |
N/A |
QSFP112 port
Table7-4 QSFP112 port specifications
Item |
Specification |
Port name |
400GE QSFP112 fiber port |
· The S9827-128DH switch provides 128 QSFP112 ports on the front panel · The S9857-24DH8EP switch provides 24 QSFP112 ports on the front panel |
Connector |
· MPO · LC |
The 400GE QSFP112 fiber ports are mainly used for transmitting and receiving 400GE fiber port services and are compatible with 200 Gbps and 100 Gbps rates |
· IEEE802.3ba · IEEE802.3ck · IEEE802.3bm |
Operating mode |
Full duplex |
N/A |
QSFP-DD800 port
Table7-5 QSFP-DD800 port specifications
Item |
Specification |
Port name |
800GE QSFP-DD800 fiber port |
The S9827-64E switch provides 64 QSFP-DD800 ports on the front panel |
Connector |
· MPO · LC |
The 800GE QSFP-DD800 fiber ports are mainly used for transmitting and receiving 800GE fiber port services and are compatible with 800 Gbps, 400 Gbps, 200 Gbps, and 100 Gbps rates |
Operating mode |
Full duplex |
N/A |
SFP+ port
Table7-6 SFP+ port specifications
Item |
Specification |
Port name |
10GE SFP+ fiber port |
The S9827-64E switch provides two SFP+ ports on the front panel |
Connector |
LC |
The 10GE SFP+ fiber ports are mainly used for transmitting and receiving GE/10GE fiber port services |
IEEE802.3ae |
Operating mode |
Full duplex |
· 10G SFP+ modules · 10G SFP+ copper cables · 10G SFP+ AOC cables · 1G SFP modules For more information, see H3C S9827 & S9857 Switch Series Transceiver Module Compatibility Matrix |
N/A |
8 LEDs
System status LED
The system status LED shows the operating status of the switch.
Table8-1 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch is operating correctly. |
Flashing green |
The switch is performing power-on self-test (POST). |
Steady red |
The system has failed to pass POST or a fault has occurred. |
Steady yellow |
Some ports have failed to pass POST and cannot operate correctly. |
Flashing blue (3 Hz) |
Helps identify the switch. The S9827-128DH switch uses the ID LED to locate the device with the LED in flashing blue at 2 Hz. To identify the switch location, execute the locator blink blink-time command. This LED will flash blue at 3 Hz. |
Off |
The switch is powered off or has failed to start up. |
OSFP800 port LED
Table8-2 OSFP800 port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 800 Gbps. |
Flashing green |
The port is sending or receiving data at 800 Gbps. |
Steady yellow |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 400 Gbps. |
Flashing yellow |
The port is sending or receiving data at 400 Gbps. |
Off |
No transceiver module or cable has been installed in the port, or no link is present on the port. |
QSFP112 port LED
Table8-3 QSFP112 port LED description
LED status |
Steady green |
Flashing green |
Steady yellow |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at non-400 Gbps. |
Flashing yellow (3 Hz) |
The port is sending or receiving data at non-400 Gbps. |
Off |
QSFP-DD800 port LED
Table8-4 QSFP-DD800 port LED description
LED status |
Steady green |
Flashing green |
Steady yellow |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 400/200/100 Gbps. |
Flashing yellow |
The port is sending or receiving data at 400/200/100 Gbps. |
Off |
SFP+ port LED
Table8-5 SFP+ port LED description
LED status |
Steady green |
A transceiver module or cable has been correctly installed in the port. The port has a link and is operating at 1/10 Gbps. |
Flashing green |
The port is sending or receiving data at 1/10 Gbps. |
Off |
Management Ethernet port LEDs
The switch provides a LINK/ACT LED for the copper management Ethernet port to indicate its operating status.
Table8-6 Copper management Ethernet port LED description
LED mark |
Status |
LINK |
Off |
No link is present on the port. |
Steady green |
The port is operating at 10/100/1000 Mbps. |
ACT |
Off |
The port is not receiving or sending data. |
Flashing yellow |
The port is receiving or sending data. |
A power supply provides a status LED to indicate the status of power input and power output.
Table8-7 Description for the status LED on a power supply
Status |
Steady green |
The power supply is operating correctly. |
Flashing green at 1 Hz |
The power supply has power input, and the system is in standby state and has not been powered on. |
Flashing green at 0.33 Hz |
The power supply is in cold standby state with no power output. |
Flashing green at 2 Hz |
The power supply firmware is being upgraded. |
Steady amber |
· A severe fault occurs on the power supply · The power supply has no power input but the other power supply has power input. |
Steady amber at 1 Hz |
An alarm occurs on the power supply. |
Off |
The power supply does not have power input due to one of the following conditions: · The power cable is connected incorrectly. · The external power system is powered off. |
Each fan module has an alarm LED.
Table8-8 Description for the alarm LED on a fan module
Status |
Steady green |
The fan module is operating correctly. |
Steady red |
The fan module is faulty. |
Off |
The fan module is operating correctly or no power is present. |
Power status LED
The switch provides a power status LED on the panel to indicate the operating status of the power supplies in the chassis.
Table8-9 Description for the power status LED on the S9827-128DH switch
LED mark |
Status |
PSU |
Steady green |
The power supplies are operating correctly. |
Steady yellow |
The number of the faulty or absent power supplies is 1 |
Steady red |
The number of the faulty or absent power supplies is equal to or greater than 2. |
Off |
The switch is powered off. |
Table8-10 Description for the power status LED on the S9827-64EP switch
LED mark |
Status |
PSU |
Steady green |
Steady yellow |
The number of the faulty or absent power supplies is equal to or less than 2. |
Steady red |
The number of the faulty or absent power supplies is greater than 2. |
Off |
Table8-11 Description for the power status LED on the S9827-64E or S9857-24DH8EP switch
LED mark |
Status |
PSU |
Steady green |
Steady yellow |
The number of the faulty or absent power supplies is 1. |
Off |
The number of the faulty or absent power supplies is 2 or the switch is powered off. |
The switch provides a fan module status LED on the panel to indicate the operating status of the fan modules in the chassis.
Table8-12 Fan module status LED
LED mark |
Status |
FAN |
Steady green |
The fan modules are operating correctly. |
Steady yellow |
The number of the faulty or absent fan modules is 1 |
Steady red |
The number of the faulty or absent fan modules is equal to or greater than 2. |
9 Cooling system
CAUTION: The chassis and power supplies use separate air aisles. Make sure the two aisles are not blocked when the switch is operating. |
The switch uses a highly efficient front-rear air aisle cooling system to ensure adequate heat dissipation and improve system reliability. Consider the ventilation design at the installation site when you plan the installation location for the switch.
Table9-1 Fan module options for the switch
Switch model |
Available fan module |
Airflow direction of the chassis |
S9827-128DH |
FAN-80B-1-C |
From the port side to the power supply side The following figure uses the LS-9827-128DH switch as an example. |
S9827-64E S9827-64EP |
FAN-80B-1-D |
S9857-24DH8EP |
FAN-40B-1-G |
