05-Layer 3—IP Routing Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5100[S5500]-D-G&S5130S-G[-V2] @CG@-R8336Pxx-6W10005-Layer 3—IP Routing Configuration Guide
07-Policy-based routing configuration
07-Policy-based routing configuration 197.92 KB
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop and default next hop .
Packet forwarding process
When the device receives a packet, the device searches the PBR policy for a matching node to forward that packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops specified on the node to forward the packet.
b.     Searches the routing table for a route to forward the packet if one of the following conditions exists:
-     No next hops are specified on the node.
-     Forwarding failed based on the next hops.
c.     Uses the default next hops specified on the node to forward the packet if one of the following conditions exists:
-     No matching route was found in the routing table.
-     The routing table-based forwarding failed.
d.     Uses the default route to forward the packet if one of the following conditions exists:
-     No default next hops are specified on the node.
-     The forwarding failed based on the default next hops.
·     The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
PBR types
PBR includes the following types:
·     Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
·     Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses but only one if-match clause for each type.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node contains apply clauses, PBR executes the apply clauses on the node.
¡     If PBR-based forwarding succeeds, PBR does not compare the packet with the next node.
¡     If PBR-based forwarding fails, PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device does not execute any apply clauses except the apply mirror-to-destination clause, and performs a routing table lookup for the packet.
No.
PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop or default next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: PBR configuration
If a packet destined for the local device matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
PBR tasks at a glance
To configure PBR, perform the following tasks:
1.     Configuring a policy
a.     Creating a node
b.     Setting match criteria for a node
c.     Configuring actions for a node
2.     Specifying a policy for PBR
¡     Specifying a policy for local PBR
¡     Specifying a policy for interface PBR
¡     Specifying a policy for global PBR
Creating a node
2.     Create a node for a policy, and enter its view.
3.     (Optional.) Configure a description for the policy node.
By default, no description is configured for a policy node.
2.     Enter policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
if-match acl [ user-defined ] { acl-number | name acl-name }
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, PBR ignores the action (permit or deny) and time range settings in the ACL. If the specified ACL does not exist, no packets will match this criterion.
¡     Set a local QoS ID match criterion.
if-match qos-local-id local-id-value
By default, no local QoS ID match criterion is set.
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
·     apply default-next-hop
PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in PBR
Clause
Meaning
Remarks
apply precedence
Sets an IP precedence.
This clause is always executed.
apply loadshare next-hop
Enables load sharing among multiple next hops.
Multiple next hop options operate in either primary/backup or load sharing mode.
·     Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
·     Load sharing mode—Matching traffic is distributed across the available options in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
By default, the primary/backup mode applies.
For the load sharing mode to take effect, make sure multiple next hops are set in the policy.
apply loadshare-mode next-hop robin
Specifies the load sharing mode for multiple next hops.
Specify one of the following load sharing modes for multiple next hops:
·     robin: Selects load-shared links randomly based on packets.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
If both clauses are configured, only the apply next-hop clause is executed.
Sets default next hops.
The configuration takes effect only in the following cases:
·     No next hops are set or the next hops and output interfaces are invalid.
·     The packet does not match any route in the routing table.
apply statistics
Counts successful matches and matching bytes on the policy node.
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command.
This clause is always executed for matching packets.
If you specify a next hop, PBR periodically performs FIB table lookup to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
If you configure the apply loadshare-mode command, you cannot specify next hop addresses as VXLAN tunnels.
In a policy node, if you configure per-packet forwarding with the apply loadshare-mode command, and apply the policy locally with the ip local policy-based-route command, per-packet forwarding does not take effect. Instead, per-flow forwarding still takes effect. As a best practice to have PBR take effect correctly, configure other PBR types with the policy.
Configuring actions to modify packet fields
3.     Set an IP precedence.
By default, no IP precedence is specified.
Configuring actions to direct packet forwarding
3.     Configure actions.
¡     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-8>
By default, no next hops are specified.
On a node, you can specify a maximum of eight next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
For the S5130S-EI-G, S5100-D-G, or S5500-D-G switch series, you can specify a maximum of four next hops in one command, and a maximum of four next hops for each node.
¡     Enable load sharing among multiple next hops.
By default, the next hops operate in primary/backup mode.
Only the S5130S-HI-G or S5130S-EI-G-V2 switch series supports load sharing among multiple next hops.
¡     Specify the load sharing mode for multiple next hops.
By default, multiple next hops load share traffic in round robin manner, starting from the first configured next hop. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
¡     Set output interfaces.
apply output-interface NULL 0
By default, no output interfaces are specified.
¡     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ]  { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hops are specified.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times. You can specify a maximum of eight default next hops for a policy node.
This command is available only on the S5130S-HI-G or S5130S-EI-G-V2 switch series.
Collecting policy node statistics
3.     Count successful matches and matching bytes on the policy node.
apply statistics
By default, match counting is disabled on policy nodes.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2.     Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2.     Enter interface view.
3.     Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no interface policy is applied to an interface.
Perform this task to apply a policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one policy for global PBR and the specified policy must already exist. Before you can apply a new policy, you must first remove the current policy.
Interface PBR takes precedence over global PBR on an interface. When they are both configured and packets fail to match the interface PBR policy, global PBR applies.
2.     Specify a policy for global PBR.
ip global policy-based-route policy-name
By default, no policy is specified for global PBR.
Display and maintenance commands for PBR
Display PBR policy information.
display ip policy-based-route [ policy policy-name ]
Display global PBR configuration and statistics.
display ip policy-based-route global [ slot slot-number ]
Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
Display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
Display PBR configuration.
display ip policy-based-route setup
Clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
PBR configuration examples
Example: Configuring packet type-based local PBR
As shown in Figure 1, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2 (Switch B).
Figure 1 Network diagram
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-ipv4-adv-3101] rule permit tcp
[SwitchA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
[SwitchC-Vlan-interface20] quit
1.     Perform telnet operations to verify that local PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Switch A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Switch A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Switch A. (Details not shown.)
Example: Configuring packet type-based interface PBR
As shown in Figure 2, Switch B and Switch C do not have a route to reach each other.
Configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2 (Switch B).
Figure 2 Network diagram
1.     Configure IP addresses and unicast routing protocol settings to make sure Switch B and Switch C can reach Host A. (Details not shown.)
2.     Configure Switch A:
# Configure interface PBR by applying the policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip policy-based-route aaa
1.     Perform telnet operations to verify that interface PBR on Switch A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Switch B), as follows:
# Verify that you can telnet to Switch B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C from Host A. (Details not shown.)
2.     Verify that Switch A forwards packets other than TCP packets through VLAN-interface 20. For example, verify that you can ping Switch C from Host A. (Details not shown.)
Example: Configuring packet type-based global PBR
As shown in Figure 3, Switch E and Switch F do not have a route to reach each other.
Configure global PBR on Switch D to forward TCP packets to the next hop 1.1.4.2 (Switch E).
Figure 3 Network diagram
1.     Assign IP addresses to the interfaces, as shown in Figure 3. (Details not shown.)
2.     Configure unicast routing protocol settings to make sure Switch A, B and C can communicate with Switch E and Switch F, respectively. (Details not shown.)
3.     Configure Switch D:
# Configure ACL 3101 to match TCP packets sourced from networks 1.1.1.0/24, 1.1.2.0/24, and 1.1.3.0/24.
<SwitchD> system-view
[SwitchD] acl advanced 3101
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.1.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.2.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.3.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] quit
# Configure node 5 in PBR policy aaa to forward TCP packets that match ACL 3101 to next hop 1.1.4.2.
[SwitchD] policy-based-route aaa permit node 5
[SwitchD-pbr-aaa-5] if-match acl 3101
[SwitchD-pbr-aaa-5] apply next-hop 1.1.4.2
[SwitchD-pbr-aaa-5] quit
# Specify PBR policy aaa as the global PBR policy.
[SwitchD] ip global policy-based-route aaa
1.     Perform telnet operations to verify that global PBR on Switch D operates as configured to forward the matching TCP packets to the next hop 1.1.4.2 (Switch E), as follows:
# Verify that you can telnet to Switch E from Switch A, Switch B, and Switch C successfully. (Details not shown.)
# Verify that you cannot telnet to Switch F from Switch A, Switch B, or Switch C. (Details not shown.)
2.     Verify that Switch D forwards packets other than TCP packets as long as a route is available. For example, verify that you can ping Switch F from Switch A, Switch B, and Switch C. (Details not shown.)
