H3C WSG1808X-PWR Wireless Integrated Services Gateway Installation Guide-6W102
HomeSupportWirelessWSG1800X Wireless Integrated Services GatewayInstall & UpgradeInstallation GuidesH3C WSG1808X-PWR Wireless Integrated Services Gateway Installation Guide-6W102
07-Appendix B LEDs
07-Appendix B LEDs 105.11 KB
Appendix B  LEDs
LEDs
During startup of the device, the status LEDs for ports 1 to 4 being on for a while indicates that the chip is in self-test state.
Figure1-1 LEDs
(1) SFP+ port LED
(2) 1000BASE-T port LED
(3) and (4) 1000BASE-T-PoE+ autosensing port LEDs
(5) System status LED (SYS)
LED description
Table1-1 LED description
LED
Mark
Status
System status LED
SYS
Flashing green (4 Hz)
The system is starting up.
Flashing green (0.5 Hz)
The system is operating correctly.
Steady red
A critical alarm has occurred, such as a power supply alarm, fan tray alarm, high temperature alarm, or software missing alarm.
Off
The device has not started up.
100/1000M autosensing port LED (green)
1000BASE-T-PoE+
Steady green
A 100/1000 Mbps link is present on the port.
Flashing green
The port is receiving or sending data at 100/1000 Mbps.
Off
No link is present on the port.
1000M port LED (green)
1000BASE-T
Steady green
A 1000 Mbps link is present on the port.
Flashing green
The port is receiving or sending data at 1000 Mbps.
Off
SFP+ port LED (green)
SFP+
Steady green
A 1000 Mbps or 10 Gbps link is present on the port.
Flashing green
The port is receiving or sending data at 1000 Mbps or 10 Gbps.
Off
