- 12-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-802.1X commands
- 04-MAC authentication commands
- 05-Portal commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-Group domain VPN commands
- 14-SSH commands
- 15-SSL commands
- 16-SSL VPN commands
- 17-ASPF commands
- 18-APR commands
- 19-mGRE commands
- 20-Session management commands
- 21-Connection limit commands
- 22-Object group commands
- 23-Object policy commands
- 24-Security policy commands
- 25-Attack detection and prevention commands
- 26-IP source guard commands
- 27-ARP attack protection commands
- 28-ND attack defense commands
- 29-uRPF commands
- 30-SAVA commands
- 31-Crypto engine commands
- 32-FIPS commands
- 33-MACsec commands
| 28-ND attack defense commands | 60.82 KB |
The following compatibility matrixes show the support of hardware platforms for ND attack defense:
Hardware |
ND attack defense compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
Yes |
MSR810-SI, MSR810-LM-SI |
Yes |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G, MSR1004S-5G-CN |
Yes |
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR-iMC |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
MSR3620-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
Source MAC consistency check commands
ipv6 nd check log enable
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
