07-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR610[810][830][1000S][2600][3600] Routers Command References(V7)-R6749-6W10207-Layer 3—IP Services Command Reference
03-DHCP commands
03-DHCP commands 713.72 KB
DHCP commands· 1
Common DHCP commands· 1
dhcp client-detect 1
dhcp dscp· 1
dhcp enable· 2
dhcp log enable· 2
dhcp select 3
DHCP server commands· 4
address range· 4
bims-server 5
bootfile-name· 6
class ip-pool 7
class option-group· 7
class range· 8
default ip-pool 9
dhcp apply-policy· 10
dhcp class· 11
dhcp option-group· 11
dhcp policy· 12
dhcp server always-broadcast 13
dhcp server apply ip-pool 13
dhcp server bootp ignore· 14
dhcp server bootp reply-rfc-1048· 15
dhcp server database filename· 15
dhcp server database update interval 17
dhcp server database update now· 18
dhcp server database update stop· 18
dhcp server forbidden-ip· 19
dhcp server ip-pool 20
dhcp server ping packets· 20
dhcp server ping timeout 21
dhcp server relay information enable· 22
dhcp server reply-exclude-option60· 22
display dhcp server conflict 23
display dhcp server database· 24
display dhcp server expired· 25
display dhcp server free-ip· 26
display dhcp server ip-in-use· 27
display dhcp server pool 28
display dhcp server statistics· 31
dns-list 33
domain-name· 33
expired· 34
forbidden-ip· 35
forbidden-ip-range· 36
gateway-list 36
if-match· 37
ip-in-use threshold· 40
lock· 41
nbns-list 42
netbios-type· 42
network· 43
next-server 44
option· 45
reset dhcp server conflict 46
reset dhcp server expired· 47
reset dhcp server ip-in-use· 48
reset dhcp server statistics· 48
static-bind· 49
tftp-server domain-name· 50
tftp-server ip-address· 51
valid class· 51
verify class· 52
voice-config· 53
vpn-instance· 53
DHCP relay agent commands· 54
dhcp relay check mac-address· 54
dhcp relay check mac-address aging-time· 55
dhcp relay client-information record· 56
dhcp relay client-information refresh· 56
dhcp relay client-information refresh enable· 57
dhcp relay forward reply by-option82· 58
dhcp relay gateway· 58
dhcp relay information circuit-id· 59
dhcp relay information enable· 61
dhcp relay information remote-id· 62
dhcp relay information strategy· 63
dhcp relay release ip· 64
dhcp relay server-address· 65
dhcp relay source-address· 65
dhcp smart-relay enable· 66
display dhcp relay check mac-address· 67
display dhcp relay client-information· 68
display dhcp relay information· 69
display dhcp relay server-address· 70
display dhcp relay statistics· 71
gateway-list 72
remote-server 73
reset dhcp relay client-information· 74
reset dhcp relay statistics· 74
DHCP client commands· 75
dhcp client dad enable· 75
dhcp client dscp· 75
dhcp client identifier 76
display dhcp client 77
ip address dhcp-alloc· 79
DHCP snooping commands· 80
dhcp snooping binding database filename· 82
dhcp snooping binding database update interval 83
dhcp snooping binding database update now· 84
dhcp snooping binding record· 85
dhcp snooping check mac-address· 85
dhcp snooping check request-message· 86
dhcp snooping deny· 87
dhcp snooping enable· 87
dhcp snooping information circuit-id· 88
dhcp snooping information enable· 91
dhcp snooping information remote-id· 92
dhcp snooping information strategy· 93
dhcp snooping log enable· 94
dhcp snooping max-learning-num·· 94
dhcp snooping rate-limit 95
dhcp snooping trust 97
display dhcp snooping binding· 98
display dhcp snooping binding database· 99
display dhcp snooping information· 100
display dhcp snooping packet statistics· 101
display dhcp snooping trust 102
reset dhcp snooping binding· 102
reset dhcp snooping packet statistics· 103
BOOTP client commands· 103
display bootp client 103
ip address bootp-alloc· 104
DHCP commands
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
dhcp client-detect
Use dhcp client-detect to enable client offline detection on the DHCP server or DHCP relay agent.
Use undo dhcp client-detect to disable client offline detection on the DHCP server or DHCP relay agent.
dhcp client-detect
Client offline detection is disabled on the DHCP server or DHCP relay agent.
Interface view
The client offline detection feature on the DHCP server reclaims an assigned IP address and deletes the binding entry when the ARP entry ages out for the IP address.
This feature on the DHCP relay agent deletes the related relay entry and sends a RELEASE message to the DHCP server when an ARP entry ages out.
# Enable client offline detection.
[Sysname-GigabitEthernet1/0/1] dhcp client-detect
dhcp dscp
Use dhcp dscp to set the DSCP value for DHCP packets sent by the DHCP server or the DHCP relay agent.
Use undo dhcp dscp to restore the default.
dhcp dscp dscp-value
undo dhcp dscp
The DSCP value is 56 in DHCP packets sent by the DHCP server or the DHCP relay agent.
dscp-value: Specifies the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCP packets sent by the DHCP server or the DHCP relay agent.
[Sysname] dhcp dscp 30
dhcp enable
Use dhcp enable to enable DHCP.
Use undo dhcp enable to disable DHCP.
dhcp enable
undo dhcp enable
DHCP is disabled.
DHCP related configuration takes effect only after you enable DHCP.
Enable DHCP before you configure the DHCP server or relay agent.
# Enable DHCP.
[Sysname] dhcp enable
dhcp log enable
Use dhcp log enable to enable DHCP server logging.
Use undo dhcp log enable to disable DHCP server logging.
dhcp log enable
DHCP server logging is disabled.
This command enables the DHCP server to generate DHCP logs and send them to the information center. The information helps administrators to locate and solve problems. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance or reduces the address allocation efficiency. For example, this situation might occur when a large number of clients frequently come online or go offline.
# Enable DHCP server logging.
[Sysname] dhcp log enable
dhcp select
Use dhcp select to enable the DHCP server or DHCP relay agent on an interface.
Use undo dhcp select to disable the DHCP server or DHCP relay agent on an interface. The interface will discard incoming DHCP packets.
dhcp select { relay [ proxy ] | server }
undo dhcp select { relay | server }
The interface operates in the DHCP server mode and responds to DHCP requests with configuration parameters.
Interface view
relay: Enables the DHCP relay agent on the interface.
proxy: Enables the DHCP server proxy on the relay agent.
server: Enables the DHCP server on the interface.
Before enabling a DHCP server to operate as a DHCP relay agent, use the reset dhcp server ip-in-use command to clear address bindings and authorized ARP entries. These authorized ARP entries might conflict with ARP entries that are created after the DHCP relay agent is enabled.
When DHCP server proxy is enabled on the DHCP relay agent, the proxy forwards packets between the DHCP clients and DHCP server.
·     When receiving DHCP requests from DHCP clients, the proxy forwards them to the DHCP server.
·     When receiving DHCP responses from the DHCP server, the proxy modifies the DHCP server's IP address in these responses as its own IP address.
# Enable the DHCP relay agent on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp select relay
address range
Use address range to configure an IP address range in a DHCP address pool for dynamic allocation.
Use undo address range to restore the default.
undo address range
No IP address range exists.
DHCP address pool view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address.
If no IP address range is specified, all IP addresses in the subnet specified by the network command in address pool view are assignable. If an IP address range is specified, only the IP addresses in the IP address range are assignable.
After you use the address range command, you cannot use the network secondary command to specify a secondary subnet in the address pool.
The address range specified by the address range command must be within the subnet specified by the network command. The addresses outside of the subnet cannot be assigned.
# Specify an address range of 192.168.8.1 through 192.168.8.150 in address pool 1.
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] network 192.168.8.1 mask 255.255.255.0
[Sysname-dhcp-pool-1] address range 192.168.8.1 192.168.8.150
class
dhcp class
network
bims-server
Use bims-server to specify the IP address, port number, and shared key of the BIMS server in a DHCP address pool.
Use undo bims-server to restore the default.
undo bims-server
No BIMS server information is specified.
ip ip-address: Specifies the IP address of the BIMS server.
port port-number: Specifies the port number of the BIMS server, in the range of 1 to 65534.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters. The DHCP client uses the shared key to encrypt packets sent to the BIMS server.
# Specify BIMS server IP address 1.1.1.1, port number 80, and shared key aabbcc in address pool 0.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
bootfile-name
Use bootfile-name to specify a configuration file name or URL.
Use undo bootfile-name to restore the default.
bootfile-name { bootfile-name | url }
undo bootfile-name
No configuration file name or URL is specified.
bootfile-name: Specifies the configuration file name, a case-sensitive string of 1 to 63 characters.
url: Specifies the HTTP URL of the configuration file. It is a case-sensitive string of 1 to 63 characters.
To specify a configuration file on a TFTP server, use the bootfile-name argument.
To specify a configuration file on an HTTP server, use the url argument.
# Specify configuration file name boot.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name boot.cfg
# Specify configuration file URL http://10.1.1.1/boot.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name http://10.1.1.1/boot.cfg
next-server
class ip-pool
Use class ip-pool to specify a DHCP address pool for a DHCP user class.
Use undo class ip-pool to remove the DHCP address pool specified for a DHCP user class.
undo class class-name ip-pool
No DHCP address pool is specified for a DHCP user class.
DHCP policy view
class-name: Specifies a DHCP user class by its name, a case-insensitive string of 1 to 63 characters.
pool-name: Specifies a DHCP address pool by its name, a case-insensitive string of 1 to 63 characters.
You can specify only one DHCP address pool for a DHCP user class in a DHCP policy. If you execute this command multiple times for a user class, the most recent configuration takes effect.
# Specify DHCP address pool pool1 for DHCP user class test in DHCP policy 1.
[Sysname] dhcp policy 1
[Sysname-dhcp-policy-1] class test ip-pool pool1
default ip-pool
dhcp policy
dhcp server ip-pool
class option-group
Use class option-group to specify a DHCP option group for a DHCP user class.
Use undo class option-group to remove the configuration.
undo class class-name option-group
No DHCP option group is specified for a DHCP user class.
option-group-number: Specifies a DHCP option group by its number in the range of 1 to 32768.
When receiving a DHCP-DISCOVER message, the server compares the client against the user classes in the order that they are specified by this command. If a match is found, the server assigns the client the DHCP options in the option group. If multiple matches are found, the server selects option groups by using the following methods:
·     If the option groups have options in common, the server selects the option group specified for the first matching user class.
·     If the option groups have different options, the server selects all the matching option groups.
You can specify only one option group for a DHCP user class in a DHCP address pool. If you execute this command multiple times for a user class, the most recent configuration takes effect.
# Specify DHCP option group 1 for user class user in DHCP address pool 0.
[Sysname-dhcp-pool-0] class user option-group 1
dhcp option-group
class range
Use class range to specify an IP address range for a DHCP user class.
Use undo class range to remove the IP address range for the DHCP user class.
undo class class-name range
No IP address range is specified for a DHCP user class.
class-name: Specifies a DHCP user class name, a case-insensitive string of 1 to 63 characters. If the specified user class does not exist, the DHCP server will not assign the addresses in the address range specified for the user class to any clients.
The class range command allows you to divide an address range into multiple address ranges for different DHCP user classes. The address range for a user class must be within the primary subnet specified by the network command. If the DHCP client does not match any DHCP user class, the DHCP server selects an address in the IP address range specified by the address range command. If the address range has no assignable IP addresses or no address range is configured, the address allocation fails.
After you specify an address range for a user class, you cannot use the network secondary command to specify a secondary subnet in the address pool.
You can specify only one address range for a DHCP user class in an address pool. If you execute this command multiple times for a DHCP user class, the most recent configuration takes effect.
# Specify an IP address range of 192.168.8.1 through 192.168.8.150 for DHCP user class user in DHCP address pool 1.
[Sysname-dhcp-pool-1] class user range 192.168.8.1 192.168.8.150
address range
dhcp class
default ip-pool
Use default ip-pool to specify the default DHCP address pool.
Use undo default ip-pool to restore the default.
default ip-pool pool-name
No default DHCP address pool is specified.
DHCP policy view
In a DHCP policy, the DHCP server uses the default DHCP address pool to assign IP addresses and other parameters to clients that do not match any user classes. If no default address pool is specified or the default address pool does not have assignable IP addresses, the address assignment fails.
You can specify only one default address pool in a DHCP policy. If you execute this command multiple times, the most recent configuration takes effect.
# Specify DHCP address pool pool1 as the default DHCP address pool in DHCP policy 1.
[Sysname-dhcp-policy-1] default ip-pool pool1
class ip-pool
dhcp policy
dhcp apply-policy
Use dhcp apply-policy to apply a DHCP policy to an interface.
Use undo dhcp apply-policy to restore the default.
dhcp apply-policy policy-name
No DHCP policy is applied to an interface.
Interface view
policy-name: Specifies a DHCP policy by its name, a case-insensitive string of 1 to 63 characters.
You can apply only one DHCP policy to an interface. If you execute this command multiple times, the most recent configuration takes effect.
# Apply DHCP policy test to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp apply-policy test
dhcp policy
dhcp class
Use dhcp class to create a DHCP user class and enter its view, or enter the view of an existing DHCP user class.
Use undo dhcp class to delete the specified DHCP user class.
dhcp class class-name
undo dhcp class class-name
No DHCP user classes exist.
class-name: Specifies the name of a DHCP user class, a case-insensitive string of 1 to 63 characters.
In the DHCP user class view, you can use the if-match command to configure match rules to group clients to the user class.
# Create DHCP user class test and enter DHCP user class view.
[Sysname] dhcp class test
[Sysname-dhcp-class-test]
address range
class ip-pool
class option-group
class range
dhcp policy
if-match
dhcp option-group
Use dhcp option-group to create a DHCP option group and enter its view, or enter the view of an existing DHCP option group.
Use undo dhcp option-group to delete a DHCP option group.
undo dhcp option-group option-group-number
No DHCP option groups exist.
option-group-number: Assigns a number to the DHCP option group, in the range of 1 to 32768.
# Create DHCP option group 1 and enter DHCP option group view.
[Sysname] dhcp option-group 1
[Sysname-dhcp-option-group-1]
class option-group
option
dhcp policy
Use dhcp policy to create a DHCP policy and enter its view, or enter the view of an existing DHCP policy.
Use undo dhcp policy to delete a DHCP policy.
dhcp policy policy-name
undo dhcp policy policy-name
No DHCP policies exist.
policy-name: Assigns a name to the DHCP policy. The policy name is a case-insensitive string of 1 to 63 characters.
In DHCP policy view, you can specify address pools for different user classes. Clients matching a user class will obtain IP addresses and other parameters from the specified address pool.
For a DHCP policy to take effect, you must apply it to an interface.
# Create DHCP policy test and enter its view.
[Sysname] dhcp policy test
[Sysname-dhcp-policy-test]
class ip-pool
default ip-pool
dhcp apply-policy
dhcp class
Use dhcp server always-broadcast to enable the DHCP server to broadcast all responses.
Use undo dhcp server always-broadcast to restore the default.
The DHCP server reads the broadcast flag in a DHCP request to decide whether to broadcast or unicast the response.
This command enables the DHCP server to ignore the broadcast flag in DHCP requests and broadcast all responses.
The DHCP server always unicasts a response in the following situations, regardless of whether this command is executed:
·     The DHCP request is from a DHCP client that has an IP address (the ciaddr field is not 0).
·     The DHCP request is forwarded by a DHCP relay agent from a DHCP client (the giaddr field is not 0).
# Enable the DHCP server to broadcast all responses.
[Sysname] dhcp server always-broadcast
Use dhcp server apply ip-pool to apply an address pool to an interface.
Use undo dhcp server apply ip-pool to restore the default.
No address pool is applied to an interface
Interface view
pool-name: Specifies the name of a DHCP address pool, a case-insensitive string of 1 to 63 characters.
Upon receiving a DHCP request from the interface, the DHCP server searches for a static binding for the client from all address pools. If no static binding is found, the server assigns configuration parameters from the address pool applied on the interface to the client. If the address pool has no assignable IP address or does not exist, the DHCP client cannot obtain an IP address.
# Apply DHCP address pool 0 to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp server apply ip-pool 0
dhcp server ip-pool
Use dhcp server bootp ignore to configure the DHCP server to ignore BOOTP requests.
Use undo dhcp server bootp ignore to restore the default.
The DHCP server does not ignore BOOTP requests.
The lease duration of IP addresses obtained by BOOTP clients is unlimited. For scenarios that do not allow unlimited leases, you can configure the DHCP server to ignore BOOTP requests.
# Configure the DHCP server to ignore BOOTP requests.
[Sysname] dhcp server bootp ignore
Use dhcp server bootp reply-rfc-1048 to enable the sending of BOOTP responses in RFC 1048 format.
Use undo dhcp server bootp reply-rfc-1048 to disable this feature.
This feature is disabled. The DHCP server does not process the Vend field of RFC 1048-incompliant requests but copies the Vend field into responses.
Not all BOOTP clients can send requests compliant with RFC 1048. This command enables the DHCP server to fill the Vend field in RFC 1048-compliant format in DHCP responses to RFC 1048-incompliant requests sent by BOOTP clients.
# Enable the sending of BOOTP responses in RFC 1048 format on the DHCP server.
[Sysname] dhcp server bootp reply-rfc-1048
Use dhcp server database filename to configure the DHCP server to back up the DHCP bindings to a file.
Use undo dhcp server database filename to restore the default.
The DHCP server does not back up the DHCP bindings.
filename: Specifies the name of a local backup file. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file, a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL.
username username: Specifies the username for accessing the URL of the remote backup file, a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL of the remote backup file.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
The command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCP server backs up its bindings immediately and runs auto backup. The server, by default, waits 300 seconds after a binding change to update the backup file. You can use the dhcp server database update interval command to change the waiting time. If no DHCP binding changes, the backup file is not updated.
As a best practice, back up the bindings to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCP server to malfunction.
When the backup file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
If the file is on an FTP server, enter URL in the following format: ftp://server address:port/file path, where the port number is optional.
If the file is on a TFTP server, enter URL in the following format: tftp://server address:port/file path, where the port number is optional.
·     The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
·     If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
·     You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCP server to back up its bindings to file database.dhcp.
[Sysname] dhcp server database filename database.dhcp
# Configure the DHCP server to back up its bindings to file database.dhcp in the working directory of the FTP server at 10.1.1.1.
[Sysname] dhcp server database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
Use dhcp server database update interval to set the waiting time for the DHCP server to update the backup file after a DHCP binding change.
Use undo dhcp server database update interval to restore the default.
The DHCP server waits 300 seconds to update the backup file after a DHCP binding change. If no DHCP binding changes, the backup file is not updated.
interval: Specifies the waiting time in the range of 60 to 864000 seconds.
When a DHCP binding is created, updated, or removed, the waiting period starts. The DHCP server updates the backup file when the waiting period is reached. All bindings changed during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCP binding auto backup by using the dhcp server database filename command.
# Set the waiting time to 10 minutes for the DHCP server to update the backup file.
[Sysname] dhcp server database update interval 600
Use dhcp server database update now to manually save the DHCP bindings to the backup file.
Each time this command is executed, the DHCP bindings are saved to the backup file.
For this command to take effect, you must configure the DHCP auto backup by using the dhcp server database filename command.
# Manually save the DHCP bindings to the backup file.
[Sysname] dhcp server database update now
Use dhcp server database update stop to terminate the download of DHCP bindings from the backup file.
The DHCP server does not provide services during the binding download process. If the connection disconnects during the process, the waiting timeout timer is 60 minutes. When the timer expires, the DHCP server stops waiting and starts providing address allocation services.
To enable the DHCP server to provide services without waiting for the connection to be repaired, use this command to terminate the download immediately. The IP addresses associated with the undownloaded bindings will be assigned to clients. Address conflicts might occur.
# Terminate the download of the backup DHCP bindings.
[Sysname] dhcp server database update stop
Use dhcp server forbidden-ip to exclude IP addresses from dynamic allocation globally.
Use undo dhcp server forbidden-ip to remove the configuration.
undo dhcp server forbidden-ip start-ip-address [ end-ip-address ] [ vpn-instance vpn-instance-name ]
No IP addresses are excluded from dynamic allocation globally.
end-ip-address: Specifies the end IP address, which cannot be lower than the start-ip-address. If you do not specify this argument, only the start-ip-address is excluded from dynamic allocation.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the excluded IP addresses belong to the public network, do not specify this option.
The IP addresses of some devices such as the gateway and FTP server cannot be assigned to clients. Use this command to exclude such addresses from dynamic allocation.
If the excluded IP address is in a static DHCP binding, the address can still be assigned to the client.
The address or address range specified in the undo dhcp server forbidden-ip command must be the same as that specified in the dhcp server forbidden-ip command. To remove an IP address from the specified address range, you must remove the entire address range.
You can execute this command multiple times to exclude multiple IP address ranges from dynamic allocation.
# Exclude the IP addresses of 10.110.1.1 through 10.110.1.63 from dynamic allocation globally.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
forbidden-ip
static-bind
dhcp server ip-pool
Use dhcp server ip-pool to create a DHCP address pool and enter its view, or enter the view of an existing DHCP address pool.
Use undo dhcp server ip-pool to delete the specified DHCP address pool.
dhcp server ip-pool pool-name
undo dhcp server ip-pool pool-name
No DHCP address pools exist.
pool-name: Specifies a DHCP address pool name, a case-insensitive string of 1 to 63 characters. The pool name uniquely identifies an address pool.
A DHCP address pool is used to store the configuration parameters to be assigned to DHCP clients.
# Create a DHCP address pool named pool1.
[Sysname] dhcp server ip-pool pool1
[Sysname-dhcp-pool-pool1]
class ip-pool
Use dhcp server ping packets to set the maximum number of ping packets.
Use undo dhcp server ping packets to restore the default.
The maximum number of ping packets is 1.
number: Sets the maximum number of ping packets, in the range of 0 to 10. To disable the address conflict detection, set the value to 0.
To avoid IP address conflicts, the DHCP server pings an IP address before assigning it to a DHCP client.
If a ping attempt succeeds, the server determines that the IP address is in use and picks a new IP address. If all the ping attempts fail, the server assigns the IP address to the requesting DHCP client.
# Set the maximum number of ping packets to 10.
[Sysname] dhcp server ping packets 10
Use dhcp server ping timeout to set the ping response timeout time on the DHCP server.
Use undo dhcp server ping timeout to restore the default.
The ping response timeout time is 500 milliseconds.
milliseconds: Specifies the timeout time in the range of 0 to 10000 milliseconds. To disable the ping operation for address conflict detection, set the value to 0 milliseconds.
# Set the response timeout time to 1000 milliseconds.
[Sysname] dhcp server ping timeout 1000
Use dhcp server relay information enable to enable the DHCP server to handle Option 82.
Use undo dhcp server relay information enable to configure the DHCP server to ignore Option 82.
The DHCP server handles Option 82.
Upon receiving a DHCP request that contains Option 82, the server copies the original Option 82 into the response. If the server is configured to ignore Option 82, the response will not contain Option 82.
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
Use dhcp server reply-exclude-option60 to disable the DHCP server from encapsulating Option 60 in DHCP replies.
Use undo dhcp server reply-exclude-option60 to restore the default.
The DHCP server can encapsulate Option 60 in DHCP replies.
If you do not disable the capability, the DHCP server encapsulates Option 60 in a DHCP reply in the following situations:
·     The received DHCP packet contains Option 60.
·     Option 60 is configured for the address pool.
If you disable the capability, the DHCP server does not encapsulate Option 60 in DHCP replies.
# Disable the DHCP server from encapsulating Option 60 in DHCP replies.
[Sysname] dhcp server reply-exclude-option60
Use display dhcp server conflict to display information about IP address conflicts.
display dhcp server conflict [ ip ip-address ] [ vpn-instance vpn-instance-name ]
ip ip-address: Displays conflict information about the specified IP address. If you do not specify this option, this command displays information about all IP address conflicts.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IP address conflict information for the public network.
The DHCP server generates IP address conflict information in the following situations:
·     Before assigning an IP address to a DHCP client, the DHCP server pings the IP address and discovers that another host is using the address.
·     The DHCP client sends a DECLINE packet to the DHCP server to inform the server of an IP address conflict.
·     The DHCP server discovers that the only assignable address in the address pool is its own IP address.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict
IP address          Detect time
4.4.4.1             Apr 25 16:57:20 2019
4.4.4.2             Apr 25 17:00:10 2019
IP address
Conflicted IP address.
Detect time
Time when the conflict was discovered.
Use display dhcp server database to display information about DHCP binding auto backup.
# Display information about DHCP binding auto backup.
<Sysname> display dhcp server database
 Username                :
 Password                :
 Latest write time       :   Feb  8 16:09:53 2014
File name
Name of the DHCP binding backup file.
Username
Username for accessing the URL of the remote backup file.
Password
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured.
Update interval
Waiting time in seconds after a DHCP binding change for the DHCP server to update the backup file.
Latest write time
Time of the latest update.
Status
Status of the update:
·     Writing—The backup file is being updated.
·     Last write succeeded—The backup file was successfully updated.
·     Last write failed—The backup file failed to be updated.
Use display dhcp server expired to display the lease expiration information.
display dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address: Displays lease expiration information about the specified IP address. If you do not specify an IP address, this command displays lease expiration information about all IP addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays lease expiration information about IP addresses for the public network.
pool pool-name: Displays lease expiration information about the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command displays lease expiration information about all address pools.
DHCP assigns these expired IP addresses to DHCP clients when all available addresses have been assigned.
# Display all lease expiration information.
<Sysname> display dhcp server expired
IP address       Client-identifier/Hardware address    Lease expiration
4.4.4.6          3030-3066-2e65-3230-302e-3130-3234    Apr 25 17:10:47 2019
                 -2d45-7468-6572-6e65-7430-2f31
IP address
Expired IP address.
Client ID or MAC address.
For the client ID:
·     If an ASCII string is used as the client ID value, the type value is 00.
·     If the MAC address of an interface is used as the client ID value, the type value is 01.
·     If a hexadecimal string is used as the client ID value, the type value is the first two digits of the string.
Lease expiration
Time when the lease expired.
Use display dhcp server free-ip to display information about assignable IP addresses.
pool pool-name: Displays assignable IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command displays all assignable IP addresses for all address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays assignable IP addresses in address pools for the public network.
# Display assignable IP addresses in all address pools.
<Sysname> display dhcp server free-ip
Pool name: 1
  Network: 10.0.0.0 mask 255.0.0.0
    IP ranges from 10.0.0.10 to 10.0.0.100
    IP ranges from 10.0.0.105 to 10.0.0.255
  Secondary networks:
    10.1.0.0 mask 255.255.0.0
      IP ranges from 10.1.0.0 to 10.1.0.255
    10.2.0.0 mask 255.255.0.0
      IP Ranges from 10.2.0.0 to 10.2.0.255
Pool name: 2
  Network: 20.1.1.0 mask 255.255.255.0
    IP ranges from 20.1.1.0 to 20.1.1.255
Pool name
Name of the address pool.
Network
Assignable network.
IP ranges
Assignable IP address range.
Secondary networks
Assignable secondary networks.
address range
dhcp server ip-pool
network
Use display dhcp server ip-in-use to display binding information about assigned IP addresses.
display dhcp server ip-in-use [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address: Displays binding information about the specified assigned IP address. If you do not specify an IP address, this command displays binding information about all assigned IP addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays binding information about assigned IP addresses for the public network.
pool pool-name: Displays binding information about assigned IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command displays binding information about assigned IP addresses in all address pools.
The binding information can be used by other security modules only when the DHCP server is configured on the gateway of DHCP clients.
If the lease deadline exceeds the year 2100, the lease expiration time is displayed as After 2100.
# Display binding information about all assigned DHCP addresses.
<Sysname> display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
10.1.1.1         4444-4444-4444        Not used              Static(F)
10.1.1.2         0030-3030-302e-3030-  May 1 14:02:49 2015   Auto(C)
                 3066-2e30-3030-332d-
                 4574-6865-726e-6574
10.1.1.3         1111-1111-1111        After 2100            Static(C)
Table 5 Command output
IP address
IP address assigned.
Client identifier/Hardware address
Client ID or hardware address. Client ID is specified as a string of hexadecimal numbers, in which the first two characters represents the hardware type value.
·     If an ASCII string is used, the hardware type value is 00, which means no type.
·     If the hardware type is Ethernet, the type value is 01.
·     If the hardware type is token ring, the type value is 06.
Lease expiration
Lease expiration time:
·     Exact time (May 1 14:02:49 2015 in this example)—Time when the lease will expire.
·     Not used—The IP address of the static binding has not been assigned to the specific client.
·     Unlimited—Infinite lease expiration time.
·     After 2100—The lease will expire after 2100.
Binding types:
·     Static(F)—A free static binding whose IP address has not been assigned.
·     Static(O)—An offered static binding whose IP address has been selected and sent by the DHCP server in a DHCP-OFFER packet to the client. Static(C)—A committed static binding whose IP address has been assigned to the DHCP client.
·     Auto(O)—An offered dynamic binding whose IP address has been dynamically selected by the DHCP server and sent in a DHCP-OFFER packet to the DHCP client.
·     Auto(C)—A committed dynamic binding whose IP address has been dynamically assigned to the DHCP client.
Use display dhcp server pool to display information about a DHCP address pool.
display dhcp server pool [ pool-name | vpn-instance vpn-instance-name ]
pool-name: Displays information about the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify the pool-name argument, this command displays information about all address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about address pools for the public network.
# Display information about all DHCP address pools.
<Sysname> display dhcp server pool
Pool name: 0 (lock strict)
  Network 20.1.1.0 mask 255.255.255.0
  class a range 20.1.1.50 20.1.1.60
  bootfile-name abc.cfg
  dns-list 20.1.1.66 20.1.1.67 20.1.1.68
  domain-name www.aabbcc.com
  bims-server ip 192.168.0.51 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  option 2 ip-address 1.1.1.1
  expired day 1 hour 2 mimute 3 second 0
Pool name: 1
  Network 20.1.2.0 mask 255.255.255.0
  secondary networks:
    20.1.3.0 mask 255.255.255.0
    20.1.4.0 mask 255.255.255.0
  bims-server ip 192.168.0.51 port 50 sharekey cipher $c$3$K13OmQPi791YvQoF2Gs1E+65LOU=
  forbidden-ip 20.1.2.35 20.1.2.36 20.1.2.37
  forbidden-ip 20.1.2.22 20.1.2.23 20.1.2.24
  forbidden-ip-range 20.1.2.50 20.1.2.55
  gateway-list 20.1.2.1 20.1.2.2 20.1.2.4
  nbns-list 20.1.2.5 20.1.2.6 20.1.2.7
  netbios-type m-node
  expired day 1 hour 0 minute 0 second 0
Pool name: 2
  Network 20.1.3.0 mask 255.255.255.0
  address range 20.1.3.1 to 20.1.3.15
  class departmentA range 20.1.3.20 to 20.1.3.29
  class departmentB range 20.1.3.30 to 20.1.3.40
  next-server 20.1.3.33
  tftp-server domain-name www.example.org.cn
  tftp-server ip-address 192.168.0.120
  voice-config ncp-ip 20.1.3.2
  voice-config as-ip 20.1.3.5
  voice-config voice-vlan 3 enable
  voice-config fail-over 20.1.3.6 123*
  option 2 ip-address 20.1.3.10
Pool name: 3
  static bindings:
    ip-address 10.10.1.2 mask 255.0.0.0
      hardware-address 00e0-00fc-0001 ethernet
      description ClientA
    ip-address 10.10.1.3 mask 255.0.0.0
      client-identifier aaaa-bbbb
      description ClientB
  expired unlimited
Table 6 Command output
Pool name (lock strict)
Name of the IP pool. The field in parentheses represents the lock state of the IP pool.
·     lockLocked in loose mode. The server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool, but it does not assign IP addresses from the pool to new DHCP clients.
·     lock strict—Locked in strict mode. The server does not respond to the lease renewal requests from online DHCP clients for IP addresses in the pool or assign IP addresses from the pool to new DHCP clients.
If you do not lock the IP pool, this command will not display lock state information.
Network
Assignable network.
secondary networks
address range
Assignable address range.
DHCP user class and its address range.
static bindings
Static IP-to-MAC/client ID bindings.
ip-address mask
IP address and mask in the static binding.
hardware-address
Hardware address in the static binding.
client-identifier
Client ID in the static binding.
description
Description of the static binding.
option
Customized DHCP option.
expired
Lease duration.
bootfile-name
Boot file name
dns-list
DNS server IP address.
domain-name
Domain name suffix.
bims-server
BIMS server information.
forbidden-ip
IP addresses excluded from dynamic allocation.
forbidden-ip-range
IP address range excluded from dynamic allocation.
gateway-list
Gateway addresses.
nbns-list
WINS server addresses.
netbios-type
NetBIOS node type.
next-server
Next server IP address.
TFTP server name.
TFTP server address.
voice-config ncp-ip
Primary network calling processor address.
voice-config as-ip
Backup network calling processor address.
Voice VLAN.
Failover route.
Use display dhcp server statistics to display the DHCP server statistics.
pool pool-name: Specifies an address pool by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, this command displays information about all address pools.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays DHCP server statistics for the public network.
# Display the DHCP server statistics.
<Sysname> display dhcp server statistics
    Pool number:                       1
    Pool utilization:                  0.39%
    Bindings:
      Automatic:                       1
      Manual:                          0
      Expired:                         0
    Conflict:                          1
    Messages received:                10
      DHCPDISCOVER:                    5
      DHCPREQUEST:                     3
      DHCPDECLINE:                     0
      DHCPRELEASE:                     2
      DHCPINFORM:                      0
      BOOTPREQUEST:                    0
    Messages sent:                     6
      DHCPOFFER:                       3
      DHCPACK:                         3
      DHCPNAK:                         0
      BOOTPREPLY:                      0
    Bad Messages:                      0
Table 7 Command output
Pool number
Total number of address pools. This field is not displayed when you display statistics for a specific address pool.
Pool utilization
Pool usage rate:
·     If you display statistics for all address pools, this field displays the usage rate of all address pools.
·     If you display statistics for an address pool, this field displays the pool usage rate of the specified address pool.
Bindings
Bindings include the following types:
·     Automatic—Number of dynamic bindings.
·     Manual—Number of static bindings.
·     Expired—Number of expired bindings.
Conflict
Total number of conflict addresses. This field is not displayed if you display statistics for a specific address pool.
Messages received
DHCP packets received from clients:
·     DHCPDISCOVER.
·     DHCPREQUEST.
·     DHCPDECLINE.
·     DHCPRELEASE.
·     DHCPINFORM.
·     BOOTPREQUEST.
Messages sent
DHCP packets sent to clients:
·     DHCPOFFER.
·     DHCPACK.
·     DHCPNAK.
·     BOOTPREPLY.
This field is not displayed if statistics about a specific address pool are displayed.
Bad Messages
Number of bad messages. This field is not displayed if you display statistics for a specific address pool.
dns-list
Use dns-list to specify DNS server addresses in a DHCP address pool.
Use undo dns-list to remove DNS server addresses from a DHCP address pool.
dns-list ip-address&<1-8>
undo dns-list [ ip-address&<1-8> ]
No DNS server address is specified.
ip-address&<1-8>: Specifies a space-separated list of up to eight DNS servers.
If you do not specify any parameters, the undo dns-list command deletes all DNS server addresses in the DHCP address pool.
# Specify DNS server address 10.1.1.254 in DHCP address pool 0.
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name
Use domain-name to specify a domain name in a DHCP address pool.
Use undo domain-name to restore the default.
domain-name domain-name
undo domain-name
No domain name is specified.
domain-name: Specifies the domain name, a case-sensitive string of 1 to 50 characters.
# Specify domain name company.com in DHCP address pool 0.
[Sysname-dhcp-pool-0] domain-name company.com
expired
Use expired to set the lease duration in a DHCP address pool.
Use undo expired to restore the default lease duration for a DHCP address pool.
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
The lease duration of a dynamic DHCP address pool is one day.
day day: Specifies the number of days, in the range of 0 to 365.
hour hour: Specifies the number of hours, in the range of 0 to 23. The default is 0.
minute minute: Specifies the number of minutes, in the range of 0 to 59. The default is 0.
second second: Specifies the number of seconds, in the range of 0 to 59. The default is 0.
unlimited: Specifies the unlimited lease duration, which is actually 136 years.
The DHCP server assigns an IP address together with the lease duration to the DHCP client. Before the lease expires, the DHCP client must extend the lease duration.
·     If the lease extension operation succeeds, the DHCP client can continue to use the IP address.
·     If the lease extension operation does not succeed, both of the following events occur:
¡     The DHCP client cannot use the IP address after the lease duration expires.
¡     The DHCP server will label the IP address as an expired address.
# Set the lease duration to 1 day, 2 hours, 3 minutes, and 4 seconds in DHCP address pool 0.
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
forbidden-ip
Use forbidden-ip to exclude IP addresses from dynamic allocation in an address pool.
Use undo forbidden-ip to remove the configuration.
forbidden-ip ip-address&<1-8>
undo forbidden-ip [ ip-address&<1-8> ]
No IP addresses are excluded from dynamic allocation in an address pool.
ip-address&<1-8>: Specifies a space-separated list of up to eight excluded IP addresses.
The excluded IP addresses in an address pool are still assignable in other address pools.
You can exclude a maximum of 4096 IP addresses in an address pool by executing this command multiple times.
If you do not specify any parameters, the undo forbidden-ip command removes all excluded IP addresses.
# Exclude IP addresses 192.168.1.3 and 192.168.1.10 from dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
forbidden-ip-range
Use forbidden-ip-range to exclude an IP address range from dynamic allocation in an address pool.
Use undo forbidden-ip-range to remove the configuration.
forbidden-ip-range start-ip-address [ end-ip-address ]
undo forbidden-ip-range [ start-ip-address [ end-ip-address ] ]
No IP address ranges are excluded from dynamic allocation in an address pool.
start-ip-address: Specifies a start IP address.
end-ip-address: Specifies an end IP address. The end IP address cannot be lower than the start IP address. If you do not specify this argument, the excluded IP range includes only the start IP address.
The excluded IP address range in an address pool is still assignable in other address pools.
To specify multiple excluded IP address ranges, execute the forbidden-ip-range command multiple times. IP addresses in excluded IP address ranges can overlap.
If you do not specify any parameters, the undo forbidden-ip-range command removes all excluded IP address ranges.
If the undo command specifies an address range smaller than the existing excluded address range, the undo command removes only the specified address range. If the undo command specifies an address range broader than the existing excluded address range, the existing excluded range is removed.
# Exclude IP address range 192.168.1.3 to 192.168.1.10 from dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] forbidden-ip-range 192.168.1.3 192.168.1.10
gateway-list
Use gateway-list to specify gateway addresses in a DHCP address pool or a DHCP secondary subnet.
Use undo gateway-list to remove the specified gateway addresses from a DHCP address pool or a DHCP secondary subnet.
gateway-list ip-address&<1-63> [ export-route ]
undo gateway-list [ ip-address&<1-63> ] [ export-route ]
No gateway address is configured in a DHCP address pool or a DHCP secondary subnet.
DHCP secondary subnet view
ip-address&<1-64>: Specifies a space-separated list of up to 64 gateway addresses. Gateway addresses must reside on the same subnet as the assignable IP addresses.
export-route: Binds the gateways to the device's MAC address in the address management module. The ARP module will use the entries to reply to ARP requests from the DHCP clients. If you do not specify this keyword, the gateways will not be bound to the device's MAC address.
The DHCP server assigns gateway addresses to clients on a secondary subnet in the following ways:
·     If gateways are specified in both address pool view and secondary subnet view, DHCP assigns those specified in the secondary subnet view.
·     If gateways are specified in address pool view but not in secondary subnet view, DHCP assigns those specified in address pool view.
If you do not specify any parameters, the undo gateway-list command deletes all gateway addresses.
# Specify gateway address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] gateway-list 10.1.1.1
if-match
Use if-match to configure a match rule for a DHCP user class.
Use undo if-match to delete a match rule for a DHCP user class.
No match rules are configured for the DHCP user class.
rule rule-number: Assigns the match rule an ID in the range of 1 to 128. A smaller ID represents a higher match priority.
hardware-address hardware-address: Specifies a hardware address, a string of 4 to 39 characters. The string contains hyphen-separated hexadecimal numbers. The last hexadecimal number can be a two-digit or four-digit number, and the other hexadecimal numbers must be four-digit numbers. For example, aabb-ccdd-ee is valid, and aabb-c-dddd or aabb-cc-dddd is invalid.
mask hardware-address-mask: Specifies the mask to be ANDed with the specified hardware address for the match operation. The length of the mask must be the same as that of the hardware address.
option option-code: Specifies a DHCP option by its number in the range of 1 to 254.
ascii ascii-string: Specifies an ASCII string of 1 to 128 characters.
offset offset: Specifies the offset in bytes after which the match operation starts. The value range is 0 to 254. If you do not specify an offset value, the match starts from the first byte of the option content. If you specify an ASCII string, a packet matches the rule if the option content after the offset is the same as the ASCII string. If you specify a hexadecimal number, a packet matches the rule if the option content of the specified length after the offset is the same as the hexadecimal number.
partial: Enables partial match. A packet matches a rule if the specified option in the packet contains the ASCII string or hexadecimal number specified in the rule. For example, if you specify abc in the rule, option content xabc, xyzabca, xabcyz, and abcxyz all match the rule.
hex hex-string: Specifies a hexadecimal number. The length of the hexadecimal number must be an even number in the range of 2 to 256.
mask mask: Specifies a hexadecimal mask for the match operation. The mask length must be an even number in the range of 2 to 256 and be the same as the hex-string length. The DHCP server selects option content of the mask length from the start and ANDs the selected option content and the specified hexadecimal number with the mask. The packet matches the rule if the two AND operation results are the same.
length length: Specifies the length of the option content to be matched, in the range of 1 to 128 bytes. The length must be the same as the hex-string length.
relay-agent gateway-address: Specifies a giaddr field value. The value is an IPv4 address in the dotted decimal notation. A packet matches the rule if its giaddr field value is the same as that in the rule.
If a DHCP request sent by a DHCP client matches a rule in a DHCP user class, the DHCP client matches the user class.
You can configure multiple match rules for a DHCP user class. Each match rule is uniquely identified by a rule ID within its type (hardware address, option, or relay agent address).
·     If the rule that you are configuring has the same ID and type as an existing rule, the new rule overwrites the existing rule.
·     If the rule that you are configuring has the same ID as an existing rule but a different type, the new rule takes effect and coexists with the existing rule. As a best practice, do not assign the same ID to rules of different types.
·     Rules of different IDs cannot have the same rule content.
When you configure an if-match hardware-address rule, follow these guidelines:
·     The hardware address type supports only the MAC address. A rule does not match clients with hardware addresses of other types.
·     The specified hardware address must be of the same length as the client hardware addresses to be matched. To match MAC addresses, the specified hardware address must be six bytes long.
·     The fs and 0s in the mask for the hardware match operation can be noncontiguous. For example, the rule if-match rule 1 hardware-address 0094-0000-1100 mask ffff-0000-ff00 matches hardware addresses in which the first two bytes are 0094 and the fifth byte is 11.
When you configure an if-match option rule, follow these guidelines:
·     To match packets that contain an option, specify only the option-code argument.
·     To match a hexadecimal number by AND operations, specify the option option-code hex hex-string mask mask options.
·     To match a hexadecimal number directly, specify the option option-code hex hex-string [ offset offset length length | partial ] options. If you do not specify the offset, length, or partial parameter, a packet matches a rule if the option content starts with the hexadecimal number.
·     To match an ASCII string, specify the option option-code ascii ascii-string [ offset offset | partial ] options. If you do not specify the offset or partial parameter, a packet matches a rule if the option content starts with the ASCII string.
# Configure match rule 1 for DHCP user class exam to match DHCP requests in which the hardware address is six bytes long and begins with 0094.
[Sysname] dhcp class exam
[Sysname-dhcp-class-exam] if-match rule 1 hardware-address 0094-0000-0101 mask ffff-0000-0000
# Configure match rule 2 for DHCP user class exam to match DHCP requests that contain Option 82.
[Sysname-dhcp-class-exam] if-match rule 2 option 82
# Configure match rule 3 for DHCP user class exam. The rule matches DHCP requests in which the highest bit of the fourth byte in Option 82 is the hexadecimal number 1.
[Sysname-dhcp-class-exam] if-match rule 3 option 82 hex 00000080 mask 00000080
# Configure match rule 4 for DHCP user class exam. The rule matches DHCP requests in which the first three bytes of Option 82 are the hexadecimal number 13ae92.
[Sysname-dhcp-class-exam] if-match rule 4 option 82 hex 13ae92 offset 0 length 3
# Configure match rule 5 for DHCP user class exam. The rule matches DHCP requests in which the Option 82 contains the hexadecimal number 13ae.
[Sysname-dhcp-class-exam] if-match rule 5 option 82 hex 13ae partial
# Configure match rule 6 for DHCP user class exam to match DHCP requests in which the giaddr field is 10.1.1.1.
[Sysname-dhcp-class-exam] if-match rule 6 relay-agent 10.1.1.1
dhcp class
ip-in-use threshold
Use ip-in-use threshold to set the IP address usage threshold for an IP address pool.
Use undo ip-in-use threshold to restore the default.
The IP address usage threshold for an IP address pool is 100%.
threshold-value: Specifies an IP address usage threshold, in percentage. The value range is 1 to 100.
If you execute this command in the same address pool view multiple times, the most recent configuration takes effect.
When the IP address usage of an IP address pool exceeds the threshold, the system sends notifications to the SNMP module. For DHCP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Set the the IP address usage threshold to 85% fpr address pool p1.
[Sysname] dhcp server ip-pool p1
[Sysname-dhcp-pool-p1] ip-in-use threshold 85
lock
Use lock to lock a DHCP address pool.
Use undo lock to restore the default.
lock [ strict ]
undo lock
DHCP address pools are not locked.
strict: Locks the DHCP address pool in strict mode. If a DHCP address pool is locked in strict mode, the server does not perform the following tasks:
·     Respond to the lease renewal requests from online DHCP clients for IP addresses in the pool.
·     Assign IP addresses from the pool to new DHCP clients.
If you do not specify this keyword, the DHCP address pool is locked in loose mode. When the DHCP address pool is locked in loose mode, the server responds to the lease renewal requests from online DHCP clients for IP addresses in the pool. However, it does not assign IP addresses from the pool to new DHCP clients.
Lock a DHCP address pool in loose mode or strict mode depending on the DHCP address pool management requirements.
·     Lock a DHCP address pool in loose mode if you are using that pool only to assign addresses to existing DHCP clients on the network.
·     Lock a DHCP address pool in strict mode if you are deleting or changing the IP space assigned to the DHCP address pool. You can delete or change the IP space for a DHCP address pool only when the DHCP address pool does not contain assigned IP addresses. Locking the DHCP address pool in strict mode ensures that you can perform the delete or change operation as soon as all assigned IP addresses in the pool are reclaimed.
# Lock DHCP address pool 1 in loose mode.
[Sysname-dhcp-pool-1] lock
The IP pool will answer only renewal requests of online users but will not assign addresses to new users. Continue? [Y/N]:
# Lock DHCP address pool 1 in strict mode.
[Sysname-dhcp-pool-1] lock strict
The IP pool will not answer renewal requests of online users or assign addresses to new users. Continue? [Y/N]:
nbns-list
Use nbns-list to specify WINS server addresses in a DHCP address pool.
Use undo nbns-list to remove the specified WINS server addresses.
nbns-list ip-address&<1-8>
undo nbns-list [ ip-address&<1-8> ]
No WINS server address is specified.
ip-address&<1-8>: Specifies a space-separated list of up to eight WINS server IP addresses.
If you do not specify any parameters, the undo nbns-list command deletes all WINS server addresses.
# Specify WINS server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] nbns-list 10.1.1.1
netbios-type
netbios-type
Use netbios-type to specify the NetBIOS node type in a DHCP address pool.
Use undo netbios-type to restore the default.
undo netbios-type
No NetBIOS node type is specified.
b-node: Specifies the broadcast node. A b-node client sends the destination name in a broadcast message to get the name-to-IP mapping from a server.
h-node: Specifies the hybrid node. An h-node client unicasts the destination name to a WINS server. If it does not receive a response, the h-node client broadcasts the destination name to get the mapping from a server.
m-node: Specifies the mixed node. An m-node client broadcasts the destination name. If it does not receive a response, the m-node client unicasts the destination name to the WINS server to get the mapping.
p-node: Specifies the peer-to-peer node. A p-node client sends the destination name in a unicast message to get the mapping from the WINS server.
# Specify the NetBIOS node type as p-node in DHCP address pool 0.
[Sysname-dhcp-pool-0] netbios-type p-node
nbns-list
network
Use network to specify the subnet for dynamic allocation in a DHCP address pool.
Use undo network to remove the specified subnet.
network network-address [ mask-length | mask mask ] [ secondary ] [ export-route ]
undo network network-address [ mask-length | mask mask ] [ secondary ]
No subnet is specified in a DHCP address pool.
network-address: Specifies the subnet for dynamic allocation. If no mask length or mask is specified, the natural mask will be used.
mask-length: Specifies the mask length in the range of 1 to 30.
mask mask: Specifies the mask in dotted decimal format.
secondary: Specifies the subnet as a secondary subnet. If you do not specify this keyword, this command specifies the primary subnet. If the addresses in the primary subnet are used up, the DHCP server can select addresses from a secondary subnet for clients.
export-route: Advertises the subnet assigned to DHCP clients. If you do not specify this keyword, the subnet will not be advertised.
You can use the secondary keyword to specify a secondary subnet and enter its view. In secondary subnet view, you can specify gateways by using the gateway-list command for DHCP clients in the secondary subnet.
You can specify only one primary subnet for a DHCP address pool. If you execute the network command multiple times, the most recent configuration takes effect.
You can specify up to 32 secondary subnets for a DHCP address pool.
The primary subnet and secondary subnets in a DHCP address pool must not have the same network address and mask.
If you have used the address range or class command in an address pool, you cannot specify a secondary subnet in the same address pool.
Modifying or removing the network configuration deletes the assigned addresses from the current address pool.
If you execute the network export-route command multiple times, the most recent configuration takes effect.
# Specify primary subnet 192.168.8.0/24 and secondary subnet 192.168.10.0/24 in DHCP address pool 0.
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
[Sysname-dhcp-pool-0] network 192.168.10.0 mask 255.255.255.0 secondary
[Sysname-dhcp-pool-0-secondary]
gateway-list
next-server
Use next-server to specify the IP address of a server in a DHCP address pool.
Use undo next-server to restore the default.
next-server ip-address
undo next-server
No server's IP address is specified in a DHCP address pool.
DHCP address pool view
ip-address: Specifies the IP address of a server.
Upon startup, the DHCP client obtains an IP address and the specified server IP address. Then it contacts the specified server, such as a TFTP server, to get other boot information.
# Specify a server's IP address 10.1.1.254 in DHCP address pool 0.
[Sysname-dhcp-pool-0] next-server 10.1.1.254
option
Use option to customize a DHCP option.
Use undo option to remove a customized DHCP option.
undo option code
No DHCP option is customized.
code: Specifies the number of the customized option, in the range of 2 to 254, excluding 50 through 54, 56, 58, 59, 61, and 82.
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 255 characters as the option content.
hex hex-string: Specifies a hexadecimal number as the option content. The length of the hexadecimal number must be an even number in the range of 2 to 256.
ip-address ip-address&<1-8>: Specifies a space-separated list of up to eight IP addresses as the option content.
The DHCP server fills the customized option with the specified ASCII string, hexadecimal number, or IP addresses, and sends it in a response to the client.
You can customize options for the following purposes:
·     Add newly released options.
·     Add options for which the vendor defines the contents, for example, Option 43.
·     Add options for which the CLI does not provide a dedicated configuration command. For example, you can use the option 4 ip-address 1.1.1.1 command to define the time server address 1.1.1.1 for DHCP clients.
·     Add all option values if the actual requirement exceeds the limit for a dedicated option configuration command. For example, the dns-list command can specify up to eight DNS servers. To specify more than eight DNS server, you must use the option 6 command to define all DNS servers.
DHCP options specified by dedicated commands take precedence over those specified by the option commands. For example, if a DNS server address is specified by both the dns-list command and the option 6 command, the server uses the address specified by the dns-list command.
DHCP options specified in DHCP option groups take precedence over those specified in DHCP address pools.
If you execute this command multiple times with the same code specified, the most recent configuration takes effect.
# Configure Option 7 to specify log server address 2.2.2.2 in DHCP address pool 0.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] option 7 ip-address 2.2.2.2
reset dhcp server conflict
Use reset dhcp server conflict to clear IP address conflict information.
ip ip-address: Clears conflict information about the specified IP address. If you do not specify this option, this command clears all address conflict information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears conflict information about IP addresses for the public network.
Address conflicts occur when dynamically assigned IP addresses have been statically configured for other hosts. After you modify the address pool configuration, the conflicted addresses might become assignable. To assign these addresses, use the reset dhcp server conflict command to clear the conflict information first.
# Clear all IP address conflict information.
<Sysname> reset dhcp server conflict
reset dhcp server expired
Use reset dhcp server expired to clear binding information about expired IP addresses.
reset dhcp server expired [ [ ip ip-address ] [ vpn-instance vpn-instance-name ] | pool pool-name ]
ip ip-address: Clears binding information about the specified expired IP address. If you do not specify an IP address, this command clears binding information about all expired IP addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears lease expiration information about IP addresses for the public network.
pool pool-name: Clears binding information about the expired IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command clears binding information about expired IP addresses in all address pools.
# Clear binding information about all expired IP addresses.
<Sysname> reset dhcp server expired
reset dhcp server ip-in-use
Use reset dhcp server ip-in-use to clear binding information about assigned IP addresses.
ip ip-address: Clears binding information about the specified assigned IP address. If you do not specify an IP address, this command clears binding information about all assigned IP addresses.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears binding information for the public network.
pool pool-name: Clears binding information about assigned IP addresses in the specified address pool. The pool name is a case-insensitive string of 1 to 63 characters. If you do not specify an address pool, this command clears binding information about assigned IP addresses in all address pools.
If you use this command to clear information about an assigned static binding, the static binding becomes a free static binding.
# Clear binding information about IP address 10.110.1.1.
<Sysname> reset dhcp server ip-in-use ip 10.110.1.1
reset dhcp server statistics
Use reset dhcp server statistics to clear DHCP server statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears DHCP server statistics for the public network.
# Clear DHCP server statistics.
<Sysname> reset dhcp server statistics
static-bind
Use static-bind to statically bind a client ID or MAC address to an IP address.
Use undo static-bind to remove a static binding.
static-bind ip-address ip-address [ mask-length | mask mask ] { client-identifier client-identifier | hardware-address hardware-address [ ethernet | token-ring ] } [ description description-text ]
undo static-bind ip-address ip-address
No static binding is specified in a DHCP address pool.
ip-address ip-address: Specifies the IP address of the static binding. The natural mask is used if no mask length or mask is specified.
mask mask: Specifies the mask, in dotted decimal format.
client-identifier client-identifier: Specifies the client ID of the static binding, a string of 4 to 254 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct.
hardware-address hardware-address: Specifies the client hardware address of the static binding, a string of 4 to 39 characters. The string can contain only hexadecimal numbers and hyphen (-), in the format of H-H-H…. The last H can be a two-digit or four-digit hexadecimal number while the other Hs must be all four-digit hexadecimal numbers. For example, aabb-cccc-dd is correct, and aabb-c-dddd and aabb-cc-dddd are not correct.
ethernet: Specifies the client hardware address type as Ethernet. The default type is Ethernet.
token-ring: Specifies the client hardware address type as token ring.
description description-text: Specifies a description for the static binding, a case-sensitive string of 1 to 255 characters.
The IP address of a static binding must not be an interface address of the DHCP server. Otherwise, an IP address conflict occurs, and the bound client cannot obtain the IP address.
You can specify multiple static bindings in an address pool. The total number of static bindings in all address pools cannot exceed 8192.
An IP address can be bound to only one DHCP client. To modify the binding for a DHCP client, first execute the undo form of the command to delete the existing binding and then create a new binding.
If an online user attempts to use a static address to come online, it must release the current used IP address.
This command is not supported in IP address pools that are configured with the remote-server command and act as DHCP relay address pools.
# Bind IP address 10.1.1.1/24 to client ID 00aa-aabb in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0 client-identifier 00aa-aabb
Use tftp-server domain-name to specify a TFTP server name in a DHCP address pool.
Use undo tftp-server domain-name to restore the default.
No TFTP server name is specified.
domain-name: Specifies the TFTP server name, a case-sensitive string of 1 to 63 characters.
# Specify TFTP server name aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
Use tftp-server ip-address to specify a TFTP server address in a DHCP address pool.
Use undo tftp-server ip-address to restore the default.
No TFTP server address is specified.
ip-address: Specifies the IP address of a TFTP server.
# Specify TFTP server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
valid class
Use valid class to add DHCP user classes to the whitelist.
Use undo valid class to remove DHCP user classes from the whitelist.
valid class class-name&<1-8>
undo valid class class-name&<1-8>
No DHCP user class is listed on the whitelist.
class-name&<1-8>: Specifies a space-separated list of up to eight DHCP user classes by their names, a case-insensitive string of 1 to 63 characters.
For this command to take effect, you must enable the DHCP user class whitelist.
# Add DHCP user classes test1 and test2 to the whitelist in DHCP address pool 0.
[Sysname-dhcp-pool-0] valid class test1 test2
dhcp class
verify class
verify class
Use verify class to enable the DHCP user class whitelist.
Use undo verify class to disable the DHCP user class whitelist.
verify class
undo verify class
The DHCP user class whitelist is disabled.
After you enable the DHCP user class whitelist, the DHCP server processes requests only from clients on the DHCP user class whitelist.
The DHCP user class whitelist does not take effect on clients that request static IP addresses, and the server always processes their requests.
# Enable the DHCP user class whitelist in DHCP address pool 0.
[Sysname] system-view
[Sysname-dhcp-pool-0] verify class
valid class
voice-config
Use voice-config to configure the content for Option 184 in a DHCP address pool.
Use undo voice-config to remove the Option 184 content from a DHCP address pool.
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
No Option 184 content is configured in a DHCP address pool.
as-ip ip-address: Specifies the IP address of the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters. Valid characters are digits and asterisk (*).
ncp-ip ip-address: Specifies the IP address of the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID in the range of 2 to 4094.
·     disable: Disables the specified VLAN. DHCP clients will not take this VLAN as their voice VLAN.
·     enable: Enables the specified VLAN. DHCP clients will take this VLAN as their voice VLAN.
# Configure Option 184 in DHCP address pool 0. The primary and backup network calling processors are at 10.1.1.1 and 10.2.2.2, respectively. The voice VLAN 3 is enabled. The failover IP address is 10.3.3.3. The dialer string is 99*.
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
vpn-instance
Use vpn-instance to apply a DHCP address pool to a VPN instance.
Use undo vpn-instance to restore the default.
undo vpn-instance
The DHCP address pool is not applied to any VPN instance.
If a DHCP address pool is applied to a VPN instance, the DHCP server assigns IP addresses in this address pool to clients in the specified VPN instance.
The DHCP server identifies the VPN instance to which a DHCP client belongs according to the following information:
·     The client's VPN information stored in authentication modules.
·     The VPN information of the DHCP server's interface that receives DHCP packets from the client.
The VPN information from authentication modules takes priority over the VPN information of the receiving interface.
# Apply DHCP address pool 0 to VPN instance abc.
[Sysname-dhcp-pool-0] vpn-instance abc
DHCP relay agent commands
dhcp relay check mac-address
Use dhcp relay check mac-address to enable MAC address check on the relay agent.
Use undo dhcp relay check mac-address to disable MAC address check on the relay agent.
The MAC address check feature is disabled.
Interface view
This feature enables the DHCP relay agent to compare the chaddr field of a received DHCP request with the source MAC address in the frame header. If they are the same, the DHCP relay agent forwards the request to the DHCP server. If they are not the same, the DHCP relay agent discards the request.
The MAC address check feature takes effect only when the dhcp select relay command has already been configured on the interface.
Enable the MAC address check feature only on the DHCP relay agent directly connected to the DHCP clients. A DHCP relay agent changes the source MAC address of DHCP packets before sending them.
# Enable MAC address check on the DHCP relay agent.
[Sysname-GigabitEthernet1/0/1] dhcp relay check mac-address
dhcp select relay
dhcp relay check mac-address aging-time
Use dhcp relay check mac-address aging-time to set the aging time for MAC address check entries on the DHCP relay agent.
Use undo dhcp relay check mac-address aging-time to restore the default.
The aging time is 30 seconds.
time: Specifies the aging time for MAC address check entries, in the range of 30 to 600 seconds.
This command takes effect only after you execute the dhcp relay check mac-address command.
# Set the aging time to 60 seconds for MAC address check entries on the DHCP relay agent.
[Sysname] dhcp relay check mac-address aging-time 60
dhcp relay client-information record
Use dhcp relay client-information record to enable recording client information in relay entries.
Use undo dhcp relay client-information record to disable the feature.
The DHCP relay agent does not record client information in relay entries.
Client information is recorded only when the DHCP relay agent is configured on the gateway of DHCP clients. A relay entry contains information about a client such as the client's IP and MAC addresses.
Disabling the recording of client information deletes all recorded relay entries.
# Enable the recording of relay entries on the relay agent.
[Sysname] dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
Use dhcp relay client-information refresh to set the interval at which the DHCP relay agent refreshes relay entries.
Use undo dhcp relay client-information refresh to restore the default.
dhcp relay client-information refresh { auto | interval interval }
The refresh interval is automatically calculated based on the number of relay entries.
auto: Automatically calculates the refresh interval. The more the entries, the shorter the refresh interval. The shortest interval is 50 ms.
interval interval: Specifies the refresh interval in the range of 1 to 120 seconds.
# Set the refresh interval to 100 seconds.
[Sysname] dhcp relay client-information refresh interval 100
Use dhcp relay client-information refresh enable to enable the DHCP relay agent to periodically refresh dynamic relay entries.
Use undo dhcp relay client-information refresh enable to disable the DHCP relay agent to periodically refresh dynamic relay entries.
The DHCP relay agent periodically refreshes relay entries.
A DHCP client unicasts a DHCP-RELEASE message to the DHCP server to release its IP address. The DHCP relay agent conveys the message to the DHCP server and does not remove the IP-to-MAC entry of the client.
With this feature, the DHCP relay agent uses a client's IP address to periodically send a DHCP-REQUEST message to the DHCP server.
·     If the server returns a DHCP-ACK message or does not return any message within an interval, the DHCP relay agent performs the following operations:
¡     Removes the relay entry.
¡     Sends a DHCP-RELEASE message to the DHCP server to release the IP address.
·     If the server returns a DHCP-NAK message, the relay agent keeps the entry.
With this feature disabled, the DHCP relay agent does not remove relay entries automatically. After a DHCP client releases its IP address, you must use the reset dhcp relay client-information on the relay agent to remove the corresponding relay entry.
# Disable periodic refresh of relay entries.
[Sysname] undo dhcp relay client-information refresh enable
dhcp relay forward reply by-option82
Use dhcp relay forward reply by-option82 to configure the DHCP relay agent to forward DHCP replies based on Option 82.
Use undo dhcp relay forward reply by-option82 to restore the default.
The DHCP relay agent does not forward DHCP replies based on Option 82.
Interface view
This command takes effect only after you execute the dhcp relay information enable and dhcp relay information circuit-id commands.
# Configure the DHCP relay agent to forward DHCP replies based on Option 82.
[Sysname-GigabitEthernet1/0/1] dhcp relay forward reply by-option82
dhcp relay gateway
Use dhcp relay gateway to specify the DHCP relay agent address to be inserted in DHCP requests.
Use undo dhcp relay gateway to restore the default.
dhcp relay gateway ip-address
The primary IP address of the interface is inserted in DHCP requests as the DHCP relay agent address.
Interface view
ip-address: Specifies the DHCP relay agent address. It must be an IP address of the interface.
The DHCP relay agent uses the specified IP address instead of the primary IP address of the relay interface as the DHCP relay agent address.
# Specify 10.1.1.1 as the DHCP relay agent address to be inserted in DHCP requests on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp relay gateway 10.1.1.1
gateway-list
Use dhcp relay information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option of Option 82.
Use undo dhcp relay information circuit-id to restore the default.
dhcp relay information circuit-id { bas [ sub-interface-vlan ] | string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] [ interface ] } [ sub-interface-vlan ] [ format { ascii | hex } ] }
The padding mode is normal and the padding format is hex.
Interface view
bas: Specifies the bas mode that fills in the Circuit ID sub-option with the interface and VLAN information. The device fills the information in the format of interface-type slot/subslot/port vxlan_id.vlan_id.subvlan_id.
sub-interface-vlan: Specifies the VLAN ID of the L2VE subinterface as the content for the Circuit ID sub-option. If you do not specify this keyword, the VLAN ID of the interface on which you configure this command is written to the sub-option. This keyword is available only for L3VE interfaces.
string circuit-id: Specifies the string mode that uses a case-sensitive string of 3 to 63 characters as the content of the Circuit ID sub-option.
normal: Specifies the normal mode, in which the padding content consists of the VLAN ID and port number.
verbose: Specifies the verbose mode. The padding content includes the node identifier, interface information, and VLAN ID. The default node identifier is the MAC address of the access node. The default interface information consists of the Ethernet type (fixed to eth), chassis number, slot number, sub-slot number, and interface number.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies the access node identifier.
·     mac: Uses the MAC address of the access node as the node identifier.
·     sysname: Uses the device name as the node identifier. You can set the device name by using the sysname command in system view. The padding format for the device name is always ASCII regardless of the specified padding format. If you specify this keyword, do not include any spaces when you set the device name. Otherwise, the DHCP relay agent fails to add or replace Option 82.
·     user-defined node-identifier: Uses a case-sensitive string of 1 to 50 characters as the node identifier. The padding format for the specified character string is always ASCII regardless of the specified padding format.
interface: Uses the interface name as the interface information. The padding format for the interface name is always ASCII regardless of the specified padding format.
format: Specifies the padding format for the Circuit ID sub-option.
ascii: Specifies the ASCII padding format.
hex: Specifies the hex padding format.
The Circuit ID sub-option cannot carry information about interface splitting or subinterfaces. For more information about interface splitting and subinterfaces, see Interface Configuration Guide.
The padding format for the string mode, the normal mode, or the verbose mode varies by command configuration. Table 8 shows how the padding format is determined for different modes.
Table 8 Padding format for different modes
Keyword (mode)
If no padding format is set
If the padding format is ascii
If the padding format is hex
string circuit-id
The padding format is ASCII, and is not configurable.
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
Hex for the VLAN ID.
ASCII for the node identifier, Ethernet type, chassis number, slot number, sub-slot number, and interface number.
ASCII.
ASCII for the node identifier and Ethernet type.
Hex for the chassis number, slot number, sub-slot number, interface number, and VLAN ID.
# Specify the content mode as verbose, node identifier as the device name, and the padding format as ASCII for the Circuit ID sub-option.
[Sysname-GigabitEthernet1/0/1] dhcp relay information enable
[Sysname-GigabitEthernet1/0/1] dhcp relay information strategy replace
[Sysname-GigabitEthernet1/0/1] dhcp relay information circuit-id verbose node-identifier sysname format ascii
display dhcp relay information
Use dhcp relay information enable to enable the DHCP relay agent to support Option 82.
Use undo dhcp relay information enable to disable Option 82 support.
The DHCP relay agent does not support Option 82.
Interface view
This command enables the DHCP relay agent to add Option 82 to DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp relay information circuit-id and dhcp relay information remote-id commands. If the DHCP requests contain Option 82, the relay agent handles the requests according to the strategy configured with the dhcp relay information strategy command.
If this feature is disabled, the relay agent forwards requests that contain or do not contain Option 82 to the DHCP server.
# Enable Option 82 support on the relay agent.
Use dhcp relay information remote-id to configure the padding mode and padding format for the Remote ID sub-option of Option 82.
Use undo dhcp relay information remote-id to restore the default.
dhcp relay information remote-id { { ap-mac | ap-mac-ssid | normal } [ format { ascii | hex } ] | ap-name | ap-name-ssid | string remote-id | sysname }
Interface view
ap-mac: Specifies to pad the Remote ID sub-option with the MAC address of an AP.
ap-mac-ssid: Specifies to pad the Remote ID sub-option with the MAC address and SSID of an AP, which are separated by the colon (:). For more information about the SSID, see WLAN access configuration in WLAN Configuration Guide.
normal: Specifies the normal mode in which the padding content is the MAC address of the receiving interface.
format: Specifies the padding format for the Remote ID sub-option. The default padding format is hex.
ap-name: Specifies to pad the Remote ID sub-option with the name of an AP. For more information about AP names, see AP management in WLAN Configuration Guide.
ap-name-ssid: Specifies to pad the Remote ID sub-option with the name and SSID of an AP, which are separated by the colon (:).
string remote-id: Specifies the string mode that uses a case-sensitive string of 1 to 63 characters as the content of the Remote ID sub-option.
sysname: Specifies the sysname mode that uses the device name as the content of the Remote ID sub-option. You can set the device name by using the sysname command.
The padding format is always ASCII for the AP name (ap-name), AP name and SSID (ap-name-ssid), the specified character string (string), and the device name (sysname).
The padding format for the AP MAC address (ap-mac), AP MAC address and SSID (ap-mac-ssid), and the normal mode is determined by the command.
# Specify the padding content for the Remote ID sub-option of Option 82 as device001.
[Sysname-GigabitEthernet1/0/1] dhcp relay information remote-id string device001
Use dhcp relay information strategy to configure the strategy for the DHCP relay agent to handle messages containing Option 82.
Use undo dhcp relay information strategy to restore the default handling strategy.
The handling strategy for messages that contain Option 82 is replace.
Interface view
drop: Drops DHCP messages that contain Option 82 messages.
keep: Keeps the original Option 82 intact and forwards the DHCP messages.
replace: Replaces the original Option 82 with the configured Option 82 before forwarding the DHCP messages.
This command takes effect only on DHCP requests that contain Option 82.
For DHCP requests that do not contain Option 82, the DHCP relay agent always adds Option 82 to the requests before forwarding the requests to the DHCP server.
If the handling strategy is replace, configure a padding mode and padding format for Option 82. If the handling strategy is keep or drop, you do not need to configure any padding mode or padding format. The settings do not take effect even if you configure them.
# Specify the handling strategy for Option 82 as keep.
[Sysname-GigabitEthernet1/0/1] dhcp relay information strategy keep
dhcp relay release ip
Use dhcp relay release ip to release a client IP address.
ip-address: Specifies the IP address to be released.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command releases the IP address on the public network.
After you execute this command, the relay agent sends a DHCP-RELEASE packet to the DHCP server and removes the relay entry of the IP address. Upon receiving the packet, the server removes binding information about the specified IP address to release the IP address.
# Release IP address 1.1.1.1.
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay server-address
Use dhcp relay server-address to specify DHCP servers on the DHCP relay agent.
Use undo dhcp relay server-address to remove DHCP servers.
dhcp relay server-address ip-address
undo dhcp relay server-address [ ip-address ]
No DHCP server is specified on the DHCP relay agent.
Interface view
ip-address: Specifies the IP address of a DHCP server. The DHCP relay agent forwards DHCP packets received from DHCP clients to this DHCP server.
The specified IP address of the DHCP server must not reside on the same subnet as the IP address of the DHCP relay agent interface. Otherwise, the DHCP clients might fail to obtain IP addresses.
You can specify a maximum of eight DHCP servers on an interface. After receiving a DHCP request, the DHCP relay agent forwards the packets to all the specified DHCP servers.
If you do not specify an IP address, the undo dhcp relay server-address command removes all DHCP servers on the interface.
# Specify DHCP server address 1.1.1.1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp relay server-address 1.1.1.1
dhcp select relay
display dhcp relay interface
dhcp relay source-address
Use dhcp relay source-address to specify the source IP address for relayed DHCP requests.
Use undo dhcp relay source-address to restore the default.
dhcp relay source-address { ip-address | gateway | relay-interface }
The relay agent chooses the default source IP address for relayed requests depending on whether its server-side interface and the DHCP server belong to the same VPN instance:
·     If they belong to the same VPN instance, the relay agent uses the IP address of the output interface for relayed requests as the default source IP address.
·     If they belong to different VPN instances, the relay agent uses the lowest IP address that is in the same VPN instance as the DHCP server as the default source address.
Interface view
ip-address: Specifies the source IP address.
gateway: Uses the IP address in the giaddr field as the source IP address of the relayed DHCP requests. If the giaddr field is empty, the relay agent follows the default rule to specify the source IP address for relayed DHCP requests.
relay-interface: Uses the primary IP address of the relay interface as the source IP address. If this interface does not have an IP address, the relay agent follows the default rule to specify the source IP address for relayed DHCP requests.
This command is required if multiple relay interfaces share the same IP address or if a relay interface does not have routes to DHCP servers. You can use this command to specify the IP address of another interface, typically the loopback interface, on the DHCP relay agent as the source IP address for DHCP requests. The relay interface inserts the source IP address in the source IP address field as well as the giaddr field in DHCP requests.
If multiple relay interfaces share the same IP address, you must also configure the relay interface to support Option 82. Upon receiving a DHCP request, the relay interface inserts the subnet information in sub-option 5 in Option 82. The DHCP server assigns an IP address according to sub-option 5. The DHCP relay agent looks up the output interface in the MAC address table to forward the DHCP reply.
# Specify 1.1.1.1 as the source IP address for relayed DHCP requests on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp relay source-address 1.1.1.1
dhcp select relay
dhcp smart-relay enable
Use dhcp smart-relay enable to enable the DHCP smart relay feature.
Use undo dhcp smart-relay enable to disable the DHCP smart relay feature.
The DHCP smart relay feature is disabled.
The smart relay feature allows the relay agent to use secondary IP addresses as the gateway address when the DHCP server does not reply the DHCP-OFFER message. The relay agent initially inserts its primary IP address in the giaddr field before forwarding a request to the DHCP server. If no DHCP-OFFER is returned after two retries, the relay agent switches to secondary IP addresses.
Without this feature, the relay agent always uses the primary IP address as the gateway address.
# Enable the DHCP smart relay feature.
[Sysname] dhcp smart-relay enable
dhcp select
gateway-list
display dhcp relay check mac-address
Use display dhcp relay check mac-address to display MAC address check entries on the relay agent.
# Display MAC address check entries on the DHCP relay agent.
<Sysname> display dhcp relay check mac-address
Source-MAC        Interface                 Aging-time
23f3-1122-adf1    GE1/0/1                   10
23f3-1122-2230    GE1/0/2                   30
Table 9 Command output
Source MAC
Source MAC address of the attacker.
Interface where the attack comes from.
Aging-time
Aging time of the MAC address check entry, in seconds.
display dhcp relay client-information
Use display dhcp relay client-information to display relay entries on the relay agent.
interface interface-type interface-number: Displays relay entries on the specified interface. If you do not specify an interface, this command displays relay entries on all interfaces.
ip ip-address: Displays the relay entry for the specified IP address. If you do not specify an IP address, this command displays relay entries for all IP addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays the relay entry for the specified IP address on the public network.
The DHCP relay agent records relay entries only after you configure the dhcp relay client-information record command.
# Display all relay entries on the relay agent.
<Sysname> display dhcp relay client-information
Total number of client-information items: 2
Total number of dynamic items: 1
Total number of temporary items: 1
IP address       MAC address      Type        Interface            VPN name
10.1.1.1         00e0-0000-0001   Dynamic     GE1/0/1              N/A
10.1.1.5         00e0-0000-0000   Temporary   GE1/0/1              N/A
Table 10 Command output
Total number of relay entries.
Total number of dynamic relay entries.
Total number of temporary relay entries.
IP address
IP address of the DHCP client.
MAC address
MAC address of the DHCP client.
Relay entry type:
·     Dynamic—The relay agent creates a dynamic relay entry upon receiving an ACK response from the DHCP server.
·     Temporary—The relay agent creates a temporary relay entry upon receiving a REQUEST packet from a DHCP client.
Layer 3 interface connected to the DHCP client. N/A is displayed for relay entries without interface information.
VPN name
Name of the VPN instance to which the DHCP client belongs. If the DHCP client does not belong to any VPN, this field displays N/A.
Use display dhcp relay information to display Option 82 configuration information for the DHCP relay agent.
interface interface-type interface-number: Displays Option 82 configuration information for the specified interface. If you do not specify an interface, this command displays Option 82 configuration information about all interfaces.
# Display Option 82 configuration information for all interfaces.
<Sysname> display dhcp relay information
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: Verbose
   Remote ID Pattern: Sysname
   Circuit ID format: Undefined
   Remote ID format: ASCII
   Node identifier: aabbcc
   Status: Enable
   Strategy: Replace
   Circuit ID Pattern: User Defined
   Remote ID Pattern: User Defined
   Circuit ID format: ASCII
   User defined:
   Circuit ID: vlan100
   Remote ID: device001
Table 11 Command output
Interface name.
Status
Option 82 states:
·     Enable—DHCP relay agent support for Option 82 is enabled.
·     Disable—DHCP relay agent support for Option 82 is disabled.
Strategy
Handling strategy for request messages containing Option 82, Drop, Keep, or Replace.
Circuit ID Pattern
Padding content mode of the Circuit ID sub-option, Verbose, Normal, or User Defined.
Remote ID Pattern
Padding content mode of the Remote ID sub-option: Sysname, Normal, AP-MAC, AP-MAC-ssid, AP-name, AP-name-ssid, or User Defined.
Circuit ID format-type
Padding format of the Circuit ID sub-option, ASCII, Hex, or Undefined.
Remote ID format-type
Padding format of the Remote ID sub-option, ASCII, Hex, or Undefined.
Node identifier
Access node identifier.
User defined
Content of the user-defined sub-options.
Circuit ID
User-defined content of the Circuit ID sub-option.
Remote ID
User-defined content of the Remote ID sub-option.
display dhcp relay server-address
Use display dhcp relay server-address to display DHCP server addresses configured on an interface.
interface interface-type interface-number: Displays DHCP server addresses on the specified interface. If you do not specify an interface, this command displays DHCP server addresses on all interfaces.
# Display DHCP server addresses on all interfaces.
<Sysname> display dhcp relay server-address
Interface name                 Server IP address
GE1/0/1                        2.2.2.2
GE1/0/1                        2.2.2.3
Table 12 Command output
Interface name
Interface name.
Server IP address
DHCP server IP address.
display dhcp relay statistics
Use display dhcp relay statistics to display DHCP packet statistics on the DHCP relay agent.
interface interface-type interface-number: Displays DHCP packet statistics on the specified interface. If you do not specify an interface, this command displays all DHCP packet statistics on the DHCP relay agent.
# Display all DHCP packet statistics on the DHCP relay agent.
<Sysname> display dhcp relay statistics
DHCP packets dropped:                  0
DHCP packets received from clients:    0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets received from servers:    0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets relayed to servers:       0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets relayed to clients:       0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
DHCP packets sent to servers:          0
   DHCPDISCOVER:                       0
   DHCPREQUEST:                        0
   DHCPINFORM:                         0
   DHCPRELEASE:                        0
   DHCPDECLINE:                        0
   BOOTPREQUEST:                       0
DHCP packets sent to clients:          0
   DHCPOFFER:                          0
   DHCPACK:                            0
   DHCPNAK:                            0
   BOOTPREPLY:                         0
reset dhcp relay statistics
gateway-list
Use gateway-list to specify gateway addresses for DHCP clients in a DHCP address pool.
Use undo gateway-list to remove gateway addresses from a DHCP address pool.
No gateway address is specified in a DHCP address pool.
ip-address&<1-64>: Specifies a space-separated list of up to 64 addresses.
DHCP clients of the same access type can be classified into different types by their locations. In this case, the relay interface typically has no IP address configured. You can use the gateway-list command to specify gateway addresses for clients matching the same DHCP address pool and bind the gateway addresses to the device's MAC address.
Upon receiving a DHCP DISCOVER or REQUEST from a client that matches a DHCP address pool, the relay agent processes the packet as follows:
1.     Fills the giaddr field of the packet with the specified gateway address.
2.     Forwards the packet to all DHCP servers in the matching DHCP address pool.
The DHCP servers select a DHCP address pool according to the gateway address.
remote-server
Use remote-server to specify DHCP servers for a DHCP relay address pool.
Use undo remote-server to remove DHCP servers from a DHCP relay address pool.
remote-server ip-address&<1-8>
undo remote-server [ ip-address&<1-8> ]
No DHCP server is specified for the DHCP relay address pool.
ip-address&<1-8>: Specifies a space-separated list of up to eight DHCP server addresses.
If you do not specify a DHCP server address, the undo remote-server command removes all DHCP servers in the DHCP address pool.
# Specify DHCP server 10.1.1.1 for DHCP address pool 0.
[Sysname-dhcp-pool-0] remote-server 10.1.1.1
Use reset dhcp relay client-information to clear relay entries on the DHCP relay agent.
interface interface-type interface-number: Clears relay entries on the specified interface. If you do not specify an interface, this command clears relay entries on all interfaces.
ip ip-address: Clears the relay entry for the specified IP address. If you do not specify an IP address, this command clears relay entries for all IP addresses.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the specified IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears the relay entry for the specified IP address on the public network.
# Clear all relay entries on the DHCP relay agent.
<Sysname> reset dhcp relay client-information
Use reset dhcp relay statistics to clear relay agent statistics.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears all DHCP relay agent statistics.
# Clear all DHCP relay agent statistics.
<Sysname> reset dhcp relay statistics
DHCP client commands
dhcp client dad enable
Use dhcp client dad enable to enable duplicate address detection.
Use undo dhcp client dad enable to disable duplicate address detection.
Duplicate address detection is enabled.
DHCP client detects IP address conflict through ARP packets. An attacker can act as the IP address owner to send an ARP reply. This makes the client unable to use the IP address assigned by the server. As a best practice, disable duplicate address detection when ARP attacks exist on the network.
# Disable the duplicate address.
[Sysname] undo dhcp client dad enable
dhcp client dscp
Use dhcp client dscp to set the DSCP value for DHCP packets sent by the DHCP client.
Use undo dhcp client dscp to restore the default.
dhcp client dscp dscp-value
The DSCP value is 56 in DHCP packets sent by the DHCP client.
dscp-value: Sets the DSCP value for DHCP packets, in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for DHCP packets sent by the DHCP client.
[Sysname] dhcp client dscp 30
dhcp client identifier
Use dhcp client identifier to configure a DHCP client ID for an interface.
Use undo dhcp client identifier to restore the default.
An interface generates the DHCP client ID based on its MAC address. If the interface has no MAC address, it uses the MAC address of the first Ethernet interface to generate its client ID.
Interface view
ascii ascii-string: Specifies a case-sensitive ASCII string of 1 to 63 characters as the client ID.
hex hex-string: Specifies a hexadecimal number of 4 to 64 characters as the client ID.
mac interface-type interface-number: Uses the MAC address of the specified interface as a DHCP client ID. The interface-type interface-number argument specifies an interface by its type and number.
A DHCP client ID is added to the DHCP option 61. A DHCP server can specify IP addresses for clients based on the DHCP client ID. You can specify a DHCP client ID by performing one of the following operations:
·     Naming an ASCII string or hexadecimal number as the client ID.
·     Using the MAC address of an interface to generate a client ID.
Whichever method you use, make sure the IDs for different DHCP clients are unique.
# Use the MAC address of GigabitEthernet 1/0/2 as the DHCP client ID for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp client identifier mac gigabitethernet 1/0/2
display dhcp client
display dhcp client
Use display dhcp client to display DHCP client information.
verbose: Displays detailed DHCP client information. If you do not specify this keyword, the command displays brief DHCP client information.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays DHCP client information on all interfaces.
# Display brief DHCP client information on all interfaces.
<Sysname> display dhcp client
GigabitEthernet1/0/1 DHCP client information:
 Current state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display detailed DHCP client information on all interfaces.
<Sysname> display dhcp client verbose
 Transaction ID: 0x1c09322d
Classless static routes:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS servers: 44.1.1.11 44.1.1.12
 Domain name: ddd.com
 Boot servers: 200.200.200.200  1.1.1.1
 ACS parameter:
   URL: http://192.168.1.1:7547/acs
   Username: bims
   Password: ******
 Client ID value: 000c.29d3.8659-GE1/0/1
                            6433-2e38-3635-392d-
                            4574-6830-2f30-2f32
 T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 13 Command output
Information about the interface that acts as the DHCP client.
Current state
Current state of the DHCP client:
·     HALT—The client stops applying for an IP address.
·     INIT—The initialization state.
·     SELECTING—The client has sent out a DHCP-DISCOVER message in search for a DHCP server and is waiting for the response from DHCP servers.
·     REQUESTING—The client has sent out a DHCP-REQUEST message requesting for an IP address and is waiting for the response from DHCP servers.
·     BOUND—The client has received the DHCP-ACK message from a DHCP server and obtained an IP address successfully.
·     RENEWING—The T1 timer expires.
·     REBOUNDING—The T2 timer expires.
Allocated IP
IP address allocated by the DHCP server.
Allocated lease
Allocated lease time.
T1
1/2 lease time (in seconds) of the DHCP client IP address.
T2
7/8 lease time (in seconds) of the DHCP client IP address.
Lease from….to….
Start and end time of the lease.
DHCP server
DHCP server IP address that assigned the IP address.
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
Gateway address assigned to the client.
Classless static routes assigned to the client.
Static routes
Classful static routes assigned to the client.
DNS servers
DNS server address assigned to the client.
Domain name
Domain name suffix assigned to the client.
Boot servers
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43.
ACS parameter
Parameters about the ACS.
URL
URL of the ACS.
Username
Username for logging in to the ACS.
Password
Password for logging in to the ACS. If a password is configured, this field displays ******. If no password is configured, this field is not displayed.
Client ID type
DHCP client ID type:
·     If an ASCII string is used as the client ID value, the type value is 00.
·     If the MAC address of a specific interface is used as the client ID value, the type value is 01.
·     If a hexadecimal number is used as the client ID value, the type value is the first two characters in the string.
Client ID value
Value of the DHCP client ID.
DHCP client ID with the type field, a hexadecimal number.
How long the T1 (1/2 lease time) timer will timeout.
ip address dhcp-alloc
Use ip address dhcp-alloc to configure an interface to use DHCP for IP address acquisition.
Use undo ip address dhcp-alloc to cancel an interface from using DHCP.
If the device starts up with the initial configuration, the default setting of this feature takes effect. An interface does not use DHCP for IP address acquisition.
If the device starts up with the factory defaults, the factory default setting of this feature takes effect.
·     For versions earlier than R6749, an interface does not use DHCP for IP address acquisition by default.
·     For R6749 and later versions, only certain Layer 3 interfaces of the following device models use DHCP for IP address acquisition by default: MSR810-LM-WiNet/MSR810-W-WiNet/MSR830-6EI-WiNet/MSR830-5BEI-WiNet/MSR830-10BEI-WiNet/MSR830-6BHI-WiNet/MSR830-10BHI-WiNet/MSR2600-6-WiNet/MSR2600-10-X1-WiNet
Other interfaces do not use DHCP for IP address acquisition by default.
For more information about initial configuration and factory defaults, see configuration file management configuration in Fundamentals Configuration Guide.
Interface view
When you execute the undo ip address dhcp-alloc command, the interface sends a DHCP-RELEASE message to release the IP address obtained through DHCP. If the interface is down, the message cannot be sent out. This situation can occur when a subinterface obtained an IP address through DHCP, and the shutdown command is executed on its primary interface. The subinterface will fail to send a DHCP-RELEASE message.
# Configure GigabitEthernet 1/0/1 to use DHCP for IP address acquisition.
[Sysname-GigabitEthernet1/0/1] ip address dhcp-alloc
DHCP snooping commands
DHCP snooping works between the DHCP client and the DHCP server or between the DHCP client and the relay agent. DHCP snooping does not work between the DHCP server and the DHCP relay agent.
The following compatibility matrixes show the support of hardware platforms for DHCP snooping:
Hardware
DHCP snooping compatibility (only on Layer 2 Ethernet interfaces)
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
No
MSR2600-10-X1
No
MSR2630
No
MSR3600-28, MSR3600-51
No
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR-iMC
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
Yes
MSR3610, MSR3620, MSR3620-DP, MSR3640, MSR3660
Yes
MSR3610-G, MSR3620-G
No
MSR3640-G
Yes
MSR3640-X1-HI
No
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3620-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
Yes
MSR3640-XS
Yes
MSR3660-XS
No
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
Yes
dhcp snooping binding database filename
Use dhcp snooping binding database filename to configure the DHCP snooping device to back up DHCP snooping entries to a file.
Use undo dhcp snooping binding database filename to restore the default.
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
The DHCP snooping device does not back up DHCP snooping entries.
filename: Specifies the name of a local backup file. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file, a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL. Supported path format type varies by server.
username username: Specifies the username for accessing the URL of the remote backup file, a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
This command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCP snooping device backs up DHCP snooping entries immediately and runs auto backup. The DHCP snooping device, by default, waits 300 seconds after a DHCP snooping entry change to update the backup file. To change the waiting period, use the dhcp snooping binding database update interval command. If no DHCP snooping entry changes, the backup file is not updated.
As a best practice, back up the DHCP snooping entries to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCP snooping device to malfunction.
When the file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
If the file is on an FTP server, enter URL in the following format: ftp://server address:port/file path, where the port number is optional.
If the file is on a TFTP server, enter URL in the following format: tftp://server address:port/file path, where the port number is optional.
·     The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
·     If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
·     You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp.
[Sysname] dhcp snooping binding database filename database.dhcp
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp in the working directory of the FTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename url ftp://10.1.1.1/database.dhcp username 1 password simple 1
# Configure the DHCP snooping device to back up DHCP snooping entries to file database.dhcp in the working directory of the TFTP server at 10.1.1.1.
[Sysname] dhcp snooping binding database filename tftp://10.1.1.1/database.dhcp
Use dhcp snooping binding database update interval to set the waiting time for the DHCP snooping device to update the backup file after a DHCP snooping entry change.
Use undo dhcp snooping binding database update interval to restore the default.
dhcp snooping binding database update interval interval
The DHCP snooping device waits 300 seconds to update the backup file after a DHCP snooping entry change. If no DHCP snooping entry changes, the backup file is not updated.
interval: Specifies the waiting time in seconds, in the range of 60 to 864000.
When a DHCP snooping entry is learned, updated, or removed, the waiting period starts. The DHCP snooping device updates the backup file when the waiting period is reached. All changed entries during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCP snooping entry auto backup by using the dhcp snooping binding database filename command.
# Set the waiting time to 600 seconds for the DHCP snooping device to update the backup file.
[Sysname] dhcp snooping binding database update interval 600
dhcp snooping binding database update now
Use dhcp snooping binding database update now to manually save DHCP snooping entries to the backup file.
Each time this command is executed, the DHCP snooping entries are saved to the backup file.
This command takes effect only after you configure the DHCP snooping auto backup by using the dhcp snooping binding database filename command.
# Manually save DHCP snooping entries to the backup file.
[Sysname] dhcp snooping binding database update now
dhcp snooping binding record
Use dhcp snooping binding record to enable recording of client information in DHCP snooping entries.
Use undo dhcp snooping binding record to disable recording of client information in DHCP snooping entries.
DHCP snooping does not record client information.
Layer 2 Ethernet interface/Layer 2 aggregate interface view
This command enables DHCP snooping on the port directly connecting to the clients to record client information in DHCP snooping entries.
# Enable the recording of client information in DHCP snooping entries on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dhcp snooping binding record
dhcp snooping check mac-address
Use dhcp snooping check mac-address to enable MAC address check for DHCP snooping.
Use undo dhcp snooping check mac-address to disable MAC address check for DHCP snooping.
MAC address check for DHCP snooping is disabled.
With MAC address check enabled, DHCP snooping compares the chaddr field of a received DHCP request with the source MAC address field in the frame header. If they are the same, DHCP snooping considers this request valid and forwards it to the DHCP server. If they are not the same, DHCP snooping discards the DHCP request.
# Enable MAC address check for DHCP snooping.
[Sysname-GigabitEthernet1/0/1] dhcp snooping check mac-address
dhcp snooping check request-message
Use dhcp snooping check request-message to enable DHCP-REQUEST check for DHCP snooping.
Use undo dhcp snooping check request-message to disable DHCP-REQUEST check for DHCP snooping.
DHCP-REQUEST check for DHCP snooping is disabled.
DHCP-REQUEST packets include lease renewal packets, DHCP-DECLINE packets, and DHCP-RELEASE packets. This feature prevents unauthorized clients that forge DHCP-REQUEST packets from attacking the DHCP server.
With this feature enabled, DHCP snooping looks for a matching DHCP snooping entry for each received DHCP-REQUEST message.
·     If a match is found, DHCP snooping compares the entry with the message. If they have consistent information, DHCP snooping considers the packet valid and forwards it to the DHCP server. If they have different information, DHCP snooping considers the message invalid and discards it.
·     If no match is found, DHCP snooping forwards the message to the DHCP server.
# Enable DHCP-REQUEST check for DHCP snooping.
[Sysname-GigabitEthernet1/0/1] dhcp snooping check request-message
dhcp snooping deny
Use dhcp snooping deny to configure a port as DHCP packet blocking port.
Use undo dhcp snooping deny to restore the default.
dhcp snooping deny
A port does not block DHCP requests.
CAUTION
CAUTION:
To avoid IP address acquisition failure, configure a port to block DHCP packets only if no DHCP clients are attached to it.
To enable a port on the snooping device to drop all incoming DHCP requests, configure that port as a DHCP packet blocking port.
# Configure GigabitEthernet 1/0/1 as a DHCP packet blocking port.
[Sysname-GigabitEthernet1/0/1] dhcp snooping deny
dhcp snooping enable
Use dhcp snooping enable to enable DHCP snooping.
Use undo dhcp snooping enable to disable DHCP snooping.
After you enable DHCP snooping on the device, trusted ports forward responses from DHCP servers and untrusted ports discard responses. This mechanism ensures that DHCP clients obtain IP addresses from authorized DHCP servers.
When DHCP snooping is disabled, all ports on the device can forward responses from DHCP servers.
# Enable DHCP snooping.
[Sysname] dhcp snooping enable
dhcp snooping information circuit-id
Use dhcp snooping information circuit-id to configure the padding mode and padding format for the Circuit ID sub-option.
Use undo dhcp snooping information circuit-id to restore the default.
In Layer 2 Ethernet interface view/Layer 2 aggregate interface view:
dhcp snooping information circuit-id { [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
undo dhcp snooping information circuit-id [ vlan vlan-id ]
In virtual Ethernet bridge (VEB) interface view:
dhcp snooping information circuit-id wlan-private [ encoded ] [ apmac apmac | bssid bssid | ssid ssid ] * [ format { ascii | hex } ]
In wireless service template view:
dhcp snooping information circuit-id { normal | wlan-private } [ format { ascii | hex } ]
VEB interface view
Wireless service template view
vlan vlan-id: Pads the Circuit ID sub-option for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the Circuit ID sub-option for packets received from the default VLAN.
string circuit-id: Specifies the string mode, in which the padding content for the Circuit ID sub-option is a case-sensitive string of 3 to 63 characters.
normal: Specifies the normal mode. The padding content includes the VLAN ID and interface number.
If the sysname keyword is specified, do not include any spaces when you set the device name. Otherwise, the DHCP snooping device fails to add or replace Option 82.
wlan-private: Specifies the WLAN-private mode. The padding content includes "WIRE", interface type and number, VLAN ID, SSID, BSSID, host name, and AP MAC address. For more information about SSID and BSSID, see WLAN access configuration in WLAN Configuration Guide.
encoded: Transcodes the special characters padded to the SSID, BSSID, and HOSTNAME fields in the WLAN-private mode. Special characters include space, !, #, and $. For example, you can transform the special characters padded to the SSID, BSSID, and HOSTNAME fields into hexadecimal values. If you do not specify this keyword, the device does not transcode the special characters padded to the SSID, BSSID, and HOSTNAME fields in the WLAN-private mode.
apmac apmac: Specify an AP MAC address that is a 48-bit string of hexadecimal numbers in the format of HH:HH:HH:HH:HH:HH.
bssid bssid: Specify a basic service set by its ID. A BSSID is a 48-bit string of hexadecimal numbers in the format of HH-HH-HH-HH-HH-HH.
ssid ssid: Specify a service set by its ID. A SSID is a case-sensitive string of 1 to 32 characters.
You can configure the Circuit ID sub-option padding mode and padding format for an AP in one of the following views (listed in descending order of priority): Interface view on the AP > wireless service template view on the AP > AP view on the AC. For more information about configuring Circuit ID sub-option in AP view, see AP management configuration in WLAN Configuration Guide.
Table 14 shows how the padding format is determined for different modes.
Table 14 Padding format for different modes
Keyword (mode)
string circuit-id
The padding format is always ASCII, and is not configurable.
N/A
N/A
normal
Hex.
ASCII.
Hex.
verbose
ASCII.
wlan-private
ASCII.
ASCII.
ASCII for the "WIRE", interface number, SSID, and host name.
Hex for the VLAN ID, BSSID, and AP MAC address.
# In Layer 2 Ethernet interface view, configure verbose as the padding mode, device name as the node identifier, and ASCII as the padding format for the Circuit ID sub-option.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information enable
[Sysname-GigabitEthernet1/0/1] dhcp snooping information strategy replace
[Sysname-GigabitEthernet1/0/1] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
# In VEB interface view, configure wlan-private as the padding mode and ASCII as the padding format for the Circuit ID sub-option.
[Sysname] interface ve-bridge 1
[Sysname-VE-Bridge1] dhcp snooping information circuit-id wlan-private format ascii
# In wireless service template view, configure normal as the padding mode and ASCII as the padding format for the Circuit ID sub-option.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] service-template enable
[Sysname-wlan-st-service1] dhcp snooping information circuit-id normal format ascii
display dhcp snooping information
Use dhcp snooping information enable to enable DHCP snooping to support Option 82.
Use undo dhcp snooping information enable to disable this feature.
DHCP snooping does not support Option 82.
VEB interface view
This command enables DHCP snooping to add Option 82 into DHCP requests that do not contain Option 82 before forwarding the requests to the DHCP server. The content of Option 82 is determined by the dhcp snooping information circuit-id and dhcp snooping information remote-id commands. If the received DHCP request packets contain Option 82, DHCP snooping handles the packets according to the strategy configured by the dhcp snooping information strategy command.
# Enable DHCP snooping to support Option 82 in Layer 2 Ethernet interface view.
# Enable DHCP snooping to support Option 82 in VEB interface view.
[Sysname-VE-Bridge1] dhcp snooping information enable
# Enable DHCP snooping to support Option 82 in wireless service template view.
[Sysname-wlan-st-service1] dhcp snooping information enable
Use dhcp snooping information remote-id to configure the padding mode and padding format for the Remote ID sub-option.
Use undo dhcp snooping information remote-id to restore the default.
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { string remote-id | sysname } }
undo dhcp snooping information remote-id [ vlan vlan-id ]
VEB interface view
vlan vlan-id: Pads the Remote ID sub-option for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the Remote ID sub-option for packets received from the default VLAN.
sysname: Specifies the sysname mode that uses the device name as the Remote ID sub-option. You can configure the device name by using the sysname command in system view.
normal: Specifies the normal mode. The padding content is the bridge MAC address of the device.
DHCP snooping uses ASCII to pad the specified string or device name for the Remote ID sub-option. The padding format for the normal padding mode is determined by the command configuration.
# Pad the Remote ID sub-option with a character string of device001.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information remote-id string device001
# In VEB interface view, configure normal as the padding mode and ASCII as the padding format for the Remote ID sub-option.
[Sysname-VE-Bridge1] dhcp snooping information remote-id normal format ascii
Use dhcp snooping information strategy to configure the handling strategy for Option 82 in request messages.
Use undo dhcp snooping information strategy to restore the default.
dhcp snooping information strategy { drop | keep | replace }
The handling strategy for Option 82 in request messages is replace.
VEB interface view
drop: Drops DHCP messages that contain Option 82.
replace: Replaces the Option 82 with the configured Option 82 before forwarding the DHCP messages. If the DHCP messages do not carry Option 82, the device adds Option 82 according to the padding configuration before forwarding the DHCP messages.
This command takes effect only on DHCP requests that contain Option 82. For DHCP requests that do not contain Option 82, the DHCP snooping device always adds Option 82 into the requests before forwarding them to the DHCP server.
If the handling strategy is replace, configure a padding mode and a padding format for Option 82. If the handling strategy is keep or drop, you do not need to configure a padding mode or padding format for Option 82.
# Specify the handling strategy for Option 82 in request messages as keep.
[Sysname-GigabitEthernet1/0/1] dhcp snooping information strategy keep
dhcp snooping log enable
Use dhcp snooping log enable to enable DHCP snooping logging.
Use undo dhcp snooping log enable to disable DHCP snooping logging.
DHCP snooping logging is disabled.
This command enables the DHCP snooping device to generate DHCP snooping logs and send them to the information center. The information helps administrators locate and solve problems. For information about the log destination and output rule configuration in the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
# Enable DHCP snooping logging.
[Sysname] dhcp snooping log enable
dhcp snooping max-learning-num
Use dhcp snooping max-learning-num to set the maximum number of DHCP snooping entries that an interface can learn.
Use undo dhcp snooping max-learning-num to restore the default.
dhcp snooping max-learning-num max-number
The maximum number of DHCP snooping entries for an interface to learn is unlimited.
max-number: Specifies the maximum number of DHCP snooping entries for an interface to learn. The value range for this argument is 1 to 4294967295.
When an interface learns the maximum number of DHCP snooping entries, the interface stops learning DHCP snooping entries. This does not affect the operating of the DHCP snooping feature.
# Allow Layer 2 Ethernet interface GigabitEthernet 1/0/1 to learn a maximum of 10 DHCP snooping entries.
[Sysname-GigabitEthernet1/0/1] dhcp snooping max-learning-num 10
dhcp snooping rate-limit
Use dhcp snooping rate-limit to enable DHCP snooping packet rate limit on an interface and set the limit value.
Use undo dhcp snooping rate-limit to disable DHCP snooping packet rate limit.
dhcp snooping rate-limit rate
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware
Command compatibility
MSR610
No
No
No
No
No
No
No
No
MSR2600-10-X1
No
MSR 2630
No
No
No
No
No
No
No
No
Yes
MSR3640-G
Yes
MSR3640-X1-HI
No
Hardware
No
MSR830-4LM-WiNet
No
No
No
MSR2600-6-WiNet
No
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
No
MSR3600-28-WiNet
No
MSR3610-X1-WiNet
No
No
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
No
MSR3600-28-XS
No
MSR3610-XS
No
MSR3620-XS
No
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
No
MSR3640-XS
No
MSR3660-XS
No
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
No
MSR3600-28-SI-GL
No
The DHCP snooping packet rate limit is disabled on an interface.
rate: Specifies the maximum rate in Kbps. The value range varies by device model.
This command takes effect only when DHCP snooping is enabled.
With the rate limit feature, the interface discards DHCP packets that exceed the maximum rate.
The rate configured on a Layer 2 aggregate interface applies to all members of the aggregate interface. If a member interface leaves the aggregation group, it uses the rate configured in its Ethernet interface view.
The maximum rate that takes effect can only be an integer multiple of a certain value because of the chip capability. Here is an example. The device-supported maximum rate is an integer multiple of eight. If you set the maximum rate to 67, the value 64 or 72 takes effect.
# Set the maximum rate to 64 Kbps at which Layer 2 Ethernet interface GigabitEthernet 1/0/1 can receive DHCP packets.
[Sysname-GigabitEthernet1/0/1] dhcp snooping rate-limit 64
dhcp snooping trust
Use dhcp snooping trust to configure a port as a trusted port.
Use undo dhcp snooping trust to restore the default state of a port.
dhcp snooping trust
After you enable DHCP snooping, all ports are untrusted.
VEB interface view
Specify the ports facing the DHCP server as trusted ports and specify the other ports as untrusted ports so DHCP clients can obtain valid IP addresses.
# Specify Layer 2 Ethernet interface GigabitEthernet 1/0/1 as a trusted port.
[Sysname-GigabitEthernet1/0/1] dhcp snooping trust
display dhcp snooping trust
display dhcp snooping binding
Use display dhcp snooping binding to display DHCP snooping entries.
display dhcp snooping binding [ ip ip-address [ vlan vlan-id ] ]
ip ip-address: Displays the DHCP snooping entry for the specified IP address.
vlan vlan-id: Specifies the VLAN ID where the IP address resides.
If you do not specify any parameters, this command displays all DHCP snooping entries.
# Display information about all DHCP snooping entries.
<Sysname> display dhcp snooping binding
 2 DHCP snooping entries found
 IP address      MAC address    Lease        VLAN  SVLAN Interface
 1.1.1.7         0000-0101-0107 16907533     2     3     GE1/0/1
 1.1.1.11        0000-0101-010b 16907537     2     3     GE1/0/3
Table 15 Command output
Number of DHCP snooping entries.
IP address
IP address assigned to the DHCP client.
MAC address
Lease
Remaining lease duration in seconds.
VLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCP client resides.
SVLAN
When both DHCP snooping and QinQ are enabled or the DHCP packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A.
Port connected to the DHCP client.
reset dhcp snooping binding
display dhcp snooping binding database
Use display dhcp snooping binding database to display information about DHCP snooping entry auto backup.
# Display information about DHCP snooping entry auto backup.
<Sysname> display dhcp snooping binding database
Username                :
Password                :
Latest write time       :   Feb 27 18:48:04 2012
Table 16 Command output
File name
Name of the DHCP snooping entry backup file.
Username
Username for accessing the URL of the remote backup file.
Password
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured.
Update interval
Waiting time in seconds after a DHCP snooping entry change for the DHCP snooping device to update the backup file.
Latest write time
Time of the latest update.
Status
Status of the update:
·     Writing—The backup file is being updated.
·     Last write succeeded—The backup file was successfully updated.
·     Last write failed—The backup file failed to be updated.
Use display dhcp snooping information to display Option 82 configuration on the DHCP snooping device.
display dhcp snooping information { all | interface interface-type interface-number }
all: Displays Option 82 configuration on all Layer 2 Ethernet interfaces.
# Display Option 82 configuration on all interfaces.
<Sysname> display dhcp snooping information all
Interface: Bridge-Aggregation1
   Status: Disable
   Strategy: Drop
   Circuit ID:
     Padding format: User Defined
       User defined: abcd
     Format: ASCII
   Remote ID:
     Padding format: Normal
     Format: ASCII
   VLAN 10:
     Circuit ID: abcd
     Remote ID: company
Table 17 Command output
Interface name.
Status
Option 82 status, Enable or Disable.
Strategy
Handling strategy for DHCP requests that contain Option 82, Drop, Keep, or Replace.
Circuit ID
Content of the Circuit ID sub-option.
Padding format
Padding format of Option 82:
·     For Circuit ID sub-option, the padding format can be Normal, User Defined, Verbose (sysname), Verbose (MAC), or Verbose (user defined).
·     For Remote ID sub-option, the padding format can be Normal, Sysname, or User Defined.
Node identifier
Access node identifier. For the Circuit ID and Remote ID sub-options, this field displays the user-defined node identifier.
User defined
Content of the user-defined sub-option.
Format
Code type of Option 82 sub-option:
·     For Circuit ID sub-option, the code type can be ASCII, Default, or Hex.
·     For Remote ID sub-option, the code type can be ASCII or Hex.
Remote ID
Content of the Remote ID sub-option.
VLAN
Pads Circuit ID and Remote ID sub-options in the DHCP packets received in the specified VLAN.
display dhcp snooping packet statistics
Use display dhcp snooping packet statistics to display DHCP packet statistics for DHCP snooping.
In standalone mode:
In IRF mode:
display dhcp snooping packet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DHCP packet statistics for the master device. (In IRF mode.)
# Display DHCP packet statistics for DHCP snooping.
<Sysname> display dhcp snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Invalid DHCP packets dropped           : 0
reset dhcp snooping packet statistics
Use display dhcp snooping trust to display information about trusted ports.
# Display information about trusted ports.
<Sysname> display dhcp snooping trust
 Interface                                       Trusted
 GigabitEthernet1/0/1                            Trusted
Table 18 Command output
Interface name.
Trusted
The port is a trusted port.
dhcp snooping trust
Use reset dhcp snooping binding to clear DHCP snooping entries.
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
all: Clears all DHCP snooping entries.
ip ip-address: Clears the DHCP snooping entry for the specified IP address.
vlan vlan-id: Clears DHCP snooping entries for the specified VLAN. If you do not specify a VLAN, this command clears DHCP snooping entries for the default VLAN.
# Clear all DHCP snooping entries.
<Sysname> reset dhcp snooping binding all
Use reset dhcp snooping packet statistics to clear DHCP packet statistics for DHCP snooping.
In standalone mode:
In IRF mode:
reset dhcp snooping packet statistics [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears DHCP packet statistics for the master device. (In IRF mode.)
# Clear DHCP packet statistics for DHCP snooping.
<Sysname> reset dhcp snooping packet statistics
BOOTP client commands
display bootp client
Use display bootp client to display information about a BOOTP client.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays BOOTP client information on all interfaces.
# Display BOOTP client information on GigabitEthernet 1/0/1.
<Sysname> display bootp client interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 BOOTP client information:
Allocated IP: 169.254.0.2 255.255.0.0
Transaction ID: 0x3d8a7431
MAC Address: 00e0-fc0a-c3ef
Table 19 Command output
Information about the interface that acts as a BOOTP client.
Allocated IP
BOOTP client's IP address allocated by the BOOTP server.
Transaction ID
Value of the XID field in a BOOTP message. The BOOTP client chooses a random number for the XID field when sending a BOOTP request to the BOOTP server. It is used to match a response message from the BOOTP server. If the values of the XID field are different in the BOOTP response and request, the BOOTP client drops the BOOTP response.
Mac Address
MAC address of a BOOTP client.
ip address bootp-alloc
Use ip address bootp-alloc to configure an interface to use BOOTP for IP address acquisition.
Use undo ip address bootp-alloc to cancel an interface from using BOOTP.
An interface does not use BOOTP for IP address acquisition.
Interface view
# Configure GigabitEthernet 1/0/1 to use BOOTP for IP address acquisition.
[Sysname-GigabitEthernet1/0/1] ip address bootp-alloc
