01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9900)-6W10001-Fundamentals Command Reference
06-Software upgrade commands
06-Software upgrade commands 246.19 KB
As a best practice, store the startup images in the factory default file system. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
In standalone mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-30> ] { all | slot slot-number [ cpu cpu-number ] } { backup | main }
boot-loader file ipe-filename [ patch filename&<1-30> ] { all | slot slot-number [ cpu cpu-number ] } { backup | main }
In IRF mode:
boot-loader file boot filename system filename [ feature filename&<1-30> ] [ patch filename&<1-30> ] { all | chassis chassis-number slot slot-number [ cpu cpu-number ] } { backup | main }
boot-loader file ipe-filename [ patch filename&<1-30> ] { all | chassis chassis-number slot slot-number [ cpu cpu-number ] } { backup | main }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
patch: Specifies a space-separated list of up to 30 incremental patch image files or 16 non-incremental patch image files. Because the boot, system, and feature images each can have one non-incremental patch image file, you can specify a maximum of 16 non-incremental patch image files.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all hardware components to which the specified images apply.
slot slot-number: Specifies the slot number of an MPU or security card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU in the IRF fabric. The chassis-number argument represents the IRF member ID of the device that holds the MPU. The slot-number argument represents the slot number of the MPU. (In IRF mode.)
cpu cpu-number: Specifies the CPU number of the security engine on the specified security card. This option is dedicated for security engine upgrade.
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
Application scenarios
When the current software cannot meet the requirements of network operation or user services, you can use this command to upgrade the software to optimize device performance to meet the requirements.
Operating mechanism
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
If the upgrade images are not found in the file system on the slot specified to upgrade, the system automatically copies the images to that file system. The destination directory is the root directory of the file system. If the destination root directory already contains a startup image with the same name as an upgrade image, you must choose whether to overwrite the image.
The system verifies the digital signature of the specified images before it updates the startup image list with the specified images. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message.
To load the specified startup software images, you must reboot the system.
Incremental patches cannot be installed by using the boot-loader file command.
# (In standalone mode.) Specify flash:/all.ipe as the main startup image file for slot 1.
<Sysname> boot-loader file flash:/all.ipe slot 1 main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C SecPath M9000-X06 images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 1.
File flash:/boot.bin already exists on slot 1.
File flash:/system.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# (In standalone mode.) Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe all main
  Boot.bin
  System.bin
This command will set the main startup software images. Continue? [Y/N]:y
File flash:/Boot.bin already exists on slot 1.
File flash:/System.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:y
Decompressing file Boot.bin to flash:/Boot.bin........................Done.
Decompressing file System.bin to flash:/System.bin...............................Done.
File flash:/boot.bin already exists on slot 0.
Do you want to overwrite the file?
 Y: Overwrite the file.
 N: Not overwrite the file.
 A: From now on, overwrite or not overwrite without prompt.
Please make a choice. [Y/N/A]:a
What type of overwrite operation do you want to perform?
  Y: Overwrite without prompt.
  N: Not overwrite or display prompt.
  Q: Return to the previous step.
Please make a choice. [Y/N/Q]:y
An existing file will be overwritten without prompt if it has the same name as any upgrade file.
Loading......................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
Decompression completed.
Do you want to delete flash:/all.ipe now? [Y/N]:n
display boot-loader
boot-loader update
Use boot-loader update to synchronize startup images.
In standalone mode:
boot-loader update { all | slot slot-number }
In IRF mode:
boot-loader update { all | chassis chassis-number slot slot-number }
all: Synchronizes startup images from the active MPU to the standby MPU. (In standalone mode.)
all: Synchronizes startup images from the global active MPU to all standby MPUs. (In IRF mode.)
slot slot-number: Specifies the slot number of the standby MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a standby MPU. The chassis-number argument represents the IRF member ID of the device that holds the MPU. The slot-number argument represents the slot number of the MPU. (In IRF mode.)
You can use this command to synchronize startup images after adding new MPUs.
Operating mechanism
The images used for synchronization are in the main or backup startup software images list instead of the current software images list (see the display boot-loader command).
·     The main images list is used if the active MPU (in standalone mode) or global active MPU (in IRF mode) started up with the main startup images.
·     The backup image list is used if the active MPU (in standalone mode) or global active MPU (in IRF mode) started up with the backup startup images.
The startup images synchronized to a standby MPU are set as main startup images, regardless of whether the source startup images are main or backup.
Startup image synchronization fails if any software image being synchronized is not available or is corrupted.
# Synchronize startup images from the active MPU to the standby MPU in slot 1.
<Sysname> boot-loader update slot 1
This command will update the specified standby MPU. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Updating. Please wait...
Verifying the file flash:/BOOT.bin on slot 1.............Done.
Verifying the file flash:/SYSTEM.bin on slot 1.....................Done.
Successfully updated the startup software images of slot 1.
display boot-loader
bootrom backup
Use bootrom backup to back up the BootWare image in the Normal area to the Backup area on a BootWare.
In standalone mode:
bootrom backup slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
In IRF mode:
bootrom backup chassis chassis-number slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies a card by its slot number or a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In standalone mode.)
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
slot slot-number-list: Specifies a space-separated list of up to seven slot number items. An item specifies a card by its slot number or a range of cards in the form of start-slot-number to end-slot-number on the specified IRF member device. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
subslot subslot-number-list: Specifies a list of up to seven subslot number items. An item specifies a subcard by its subslot number or a range of subcards in the form of start-subslot-number to end-subslot-number. If you do not specify a subcard, this command backs up the BootWare image for the base card.
cpu cpu-number: Specifies a CPU by its number. The cpu cpu-number option is available only if multiple CPUs are available on the specified slot.
A BootWare is divided into a Normal area and a Backup area. The BootWare image is stored in the Normal area and backed up to the Backup area. At startup, the system reads the BootWare image automatically from the Normal area. If the image is inaccessible, the system reads the BootWare image from the Backup area.
If the BootWare image in the Normal area is corrupted or requires a version rollback, use the bootrom restore command to copy the BootWare image in the Backup area to the Normal area.
# Back up the entire BootWare image from the Normal area to the Backup area.
<Sysname> bootrom backup slot 1
Now backing up the Boot ROM, please wait...
......Done.
bootrom restore
bootrom restore
Use bootrom restore to replace the BootWare image in the Normal area with the BootWare image in the Backup area for image restoration or version rollback.
In standalone mode:
bootrom restore slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
In IRF mode:
bootrom restore chassis chassis-number slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
subslot subslot-number-list: Specifies a list of up to seven subslot number items. Each item specifies a subcard by its subslot number or a range of subcards in the form of start-subslot-number to end-subslot-number. If you do not specify a subcard, this command restores the BootWare image for the base card.
# (In standalone mode.) Restore the entire BootWare image.
<Sysname> bootrom restore slot 1
  This command will restore the Boot ROM file on the specified board(s), Continue? [Y/N]:y
  Now restoring the Boot ROM, please wait...
......Done.
bootrom backup
bootrom update
Use bootrom update to load the BootWare image from a file system to the Normal BootWare area.
In standalone mode:
bootrom update file file slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
In IRF mode:
bootrom update file file chassis chassis-number slot slot-number-list [ cpu cpu-number ] [ subslot subslot-number-list ]
file file: Specifies the file that contains the BootWare image. The file argument represents the file name, a string of 1 to 63 characters.
subslot subslot-number-list: Specifies a list of up to seven subslot number items. Each item specifies a subcard by its subslot number or a range of subcards in the form of start-subslot-number to end-subslot-number. If you do not specify a subcard, this command loads the BootWare image for the base card.
BootWare images are contained in the .bin Comware boot image file.  You can specify a Comware boot image file in this command to upgrade the BootWares in the system before you upgrade the Comware images. If you do not upgrade BootWares before upgrading Comware images, the system automatically upgrades BootWares as necessary when loading Comware images.
Operating mechanism
After you use this command, the system loads the specified BootWare image in the file system to the Normal area of BootWare. The system directly uses the BootWare image in the Normal area when it starts up. If the storage space is insufficient, you can delete the BootWare image file after the system has loaded the BootWare image.
The system verifies a BootWare image before it loads that image to the Normal area of BootWare. If the digital signature verification fails, the system will not load the image and you will receive a digital signature verification failure message.
The new BootWare images take effect after you reboot the card.
# (In standalone mode.) Use the file a.bin in the root directory of the flash memory to upgrade the BootWare image.
<Sysname> bootrom update file flash:/a.bin slot 1
   This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
   Now updating the Boot ROM, please wait................Done.
boot-loader file
bootrom-update security-check enable
Use bootrom-update security-check enable to enable BootWare image validity check.
Use undo bootrom-update security-check enable to disable BootWare image validity check.
BootWare image validity check is enabled.
Before a BootWare image upgrade starts, this feature examines the upgrade BootWare image for file validity and incompatibility with hardware. If the BootWare image passes the check, the upgrade process starts. If the check fails, the system does not perform the upgrade.
# Enable BootWare image validity check.
[Sysname] bootrom-update security-check enable
display boot-loader
Use display boot-loader to display current software images and startup software images.
In standalone mode:
display boot-loader [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display boot-loader [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] ] ]
slot slot-number: Specifies the slot number of an MPU. If you do not specify an MPU, this command displays the software images on each MPU. (In standalone mode.)
chassis chassis-number [ slot slot-number ]: Specifies an IRF member device or an MPU in an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the MPU on the device. If you do not specify an IRF member device, this command displays the software images on each MPU in the IRF fabric. If you specify an IRF member device without specifying an MPU, this command displays the software images on each MPU on the specified member device. (In IRF mode.)
This command displays both the current and startup images for the device and the security engines.
# (In standalone mode.) Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
  flash:/boot_backup.bin
  flash:/system_backup.bin
Comware images that have been loaded.
Primary Comware images for the next startup.
Backup Comware images for the next startup.
If the backup startup software images are not specified, this field displays None.
boot-loader file
display install active
Use display install active to display active software images.
In standalone mode:
display install active [ slot slot-number ] [ verbose ]
In IRF mode:
display install active [ chassis chassis-number slot slot-number ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards on the device. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards on the IRF fabric. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only image names.
# (In standalone mode.) Display brief information about active software images.
<Sysname> display install active
Active packages on slot 1:
  flash:/boot.bin
  flash:/system.bin
  flash:/feature1.bin
# (In standalone mode.) Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: boot
 Platform version: 7.1.070
 Product version: Test 0001015
 Supported board: mpu
 [Component]
 Component: boot
 Description: boot package
flash:/system.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: system
 [Component]
 Component: system
 Description: system package
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: test
 [Component]
 Component: test
 Description: test package
[Package]
Detailed information about the software image.
Service name
Image type:
·     bootBoot image.
·     boot-patchBoot image patch.
·     systemSystem image.
·     system-patchSystem image patch.
·     Any other value indicates a feature image.
Platform version
Platform software version.
Product version
Product software version.
Supported board
Card type supported by the software image:
·     mpu—MPU.
·     spu or spe—Service card.
[Component]
Information about components included in the image file.
Component
Component name.
Component description.
install active
display install backup
Use display install backup to display backup startup software images.
In standalone mode:
display install backup [ slot slot-number ] [ verbose ]
In IRF mode:
display install backup [ chassis chassis-number slot slot-number ] [ verbose ]
If any main image does not exist or is invalid, the system loads the backup startup software images.
You can use the boot-loader file command to modify the backup startup software image list.
# (In standalone mode.) Display brief information about backup startup software images.
<Sysname> display install backup
Backup startup software images on slot 1:
  flash:/boot.bin
  flash:/system.bin
# (In standalone mode.) Display detailed information about backup startup software images.
<Sysname> display install backup verbose
 flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: boot
 [Component]
 Component: boot
 flash:/system.bin
 [Package]
 Vendor: H3C
 Product: M9006
 [Component]
 Component: system
boot-loader file
display install committed
Use display install committed to display main startup software images.
In standalone mode:
display install committed [ slot slot-number ] [ verbose ]
In IRF mode:
display install committed [ chassis chassis-number slot slot-number ] [ verbose ]
Some install commands modify the current software image list but do not modify the main startup image list. For the software image changes to take effect after a reboot, you must execute the install commit command to update the main startup image list with the image changes. You can use the display install committed command to verify the operation results.
Both the install commit and boot-loader file commands modify the main startup software image list.
# (In standalone mode.) Display brief information about main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
 flash:/boot.bin
 flash:/system.bin
 flash:/feature1.bin
# (In standalone mode.) Display detailed information about main startup software images.
<Sysname> display install committed verbose
 flash:/boot.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: boot
 [Component]
 Component: boot
 flash:/system.bin
 [Package]
 Vendor: H3C
 Product: M9006
 [Component]
 Component: system
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: M9006
 Service name: feature1
 [Component]
 Component: feature1
 Description: feature1 package
boot-loader file
install commit
display install inactive
Use display install inactive to display inactive software images.
In standalone mode:
display install inactive [ slot slot-number ] [ verbose ]
In IRF mode:
display install inactive [ chassis chassis-number slot slot-number ] [ verbose ]
# (In standalone mode.) Display brief information about inactive software images.
<Sysname> display install inactive
Inactive packages on slot 1:
 flash:/feature1.bin
# (In standalone mode.) Display detailed information about inactive software images.
<Sysname> display install inactive verbose
flash:/feature1.bin
 [Package]
 Vendor: H3C
 Product: M9006
 [Component]
 Component: feature1
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe-filename: Specifies an .ipe file in the filesystemname/filename.ipe format. The file must be saved in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
# (In standalone mode.) Display information about .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying the file flash:/test.ipe on slot 1................Done.
H3C M9006 images in IPE:
  boot.bin
  system.bin
display install package
display install job
Use display install job to display ongoing activate and deactivate operations.
display install job
# (In standalone mode.) Display activate and deactivate operations.
<Sysname> display install job
 JobID:5
  Action:install activate flash:/feature1.bin on slot 1
The output shows that the device is executing the install activate flash:/feature1.bin slot 1 command.
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be saved in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all software image files in the root directories of the active MPU's file systems. (In standalone mode.)
all: Specifies all software image files in the root directories of the file systems on the global active MPU. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information.
# Display information about system.bin.
<Sysname> display install package flash:/system.bin
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: M9006
# Display detailed information about system.bin.
<Sysname> display install package flash:/system.bin verbose
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: M9006
  [Component]
  Component: system
display install which
Use display install which to display all software image files that include a specific component or file.
In standalone mode:
display install which { component name | file filename } [ slot slot-number ]
In IRF mode:
display install which { component name | file filename } [ chassis chassis-number slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file in the filename.extension format, a case-insensitive string of up to 63 characters. It cannot contain path information.
A component is a collection of features. The features of a component are installed or uninstalled at the same time.
When the system displays a component or file error, use this command to identify the image files that include the component or file. Then, you can use the install verify command to identify image file problems.
This command searches only the root directories of the file systems at the specified location.
# (In standalone mode.) Display the software image file that includes pkg_ctr.
<Sysname> display install which file pkg_ctr
Verifying the file flash:/system-t0001015.bin on slot 1..........................Done.
Found pkg_ctr in flash:/system-t0001015.bin on slot 1.
  [Package]
  Vendor: H3C
  Product: M9006
Verifying the file flash:/boot-d2601007.bin on slot 1.....Done.
Verifying the file
The system was verifying the validity of the file.
[Package]
Service name
Image type:
·     boot—Boot image.
·     system—System image.
·     patch—Patch image.
Supported board
Hardware types supported by the software image:
·     mpu—MPU.
install activate
Use install activate to activate software images.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number
install activate patch filename { all | slot slot-number }
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number
install activate patch filename { all | chassis chassis-number slot slot-number }
patch: Specifies a patch image file. You can specify only one patch image file for the command at a time. However, you can execute the command multiple times to activate multiple patch image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. The value string excluding the file system location section (if any) can have a maximum of 63 characters. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
all: Specifies all cards on the device. (In standalone mode.)
all: Specifies all cards on the IRF fabric. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
Before you use this command to activate a software image, read the release notes to identify the licensing requirements for the image. If the image requires a license, make sure the device has a valid license installed for the image.
Images run in memory immediately after they are activated. However, only images activated by using the install activate patch filename all command still run in memory after a reboot. For other images to take effect after a reboot, you must commit the software change by using the install commit command.
If the specified files are not stored on the MPU to be upgraded, the command copies the files to the MPU automatically.
If the specified files are not stored on the security engine to be upgraded, the command copies the files to the security engine automatically.
(In standalone mode.) If you specify the active MPU for the slot slot-number option, the command takes effect on the active MPU and all LPUs. If you specify the standby MPU for the slot slot-number option, the command takes effect only on the standby MPU.
(In IRF mode.) If you specify the global active MPU for the chassis chassis-number slot slot-number option, the command takes effect on the global active MPU and all LPUs. If you specify a standby MPU for the chassis chassis-number slot slot-number option, the command takes effect on the standby MPU.
(In IRF mode.) At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
# (In standalone mode.) Activate the system image in system.bin and the feature images in feature1.bin on the standby MPU (in slot 1).
<Sysname> install activate system flash:/system.bin feature flash:/feature1.bin slot 1
Copying file flash:/system.bin to slot1#flash:/system.bin......Done.
Verifying the file flash:/system.bin on slot 1.....Done.
Copying file flash:/feature1.bin to slot1#flash:/feature1.bin......Done.
Verifying the file flash:/feature1.bin on slot 1.....Done.
flash:/system.bin
  Running Version             New Version
  Test 0001015                Test 0001016
flash:/feature1.bin
  None                        Test 0001016
  Slot                        Upgrade Way
  1                           Service Upgrade
This operation might take several minutes, please wait...Done.
Verifying the file
Upgrade summary.
Running Version
Version number of the running software.
New Version
Version number of the new software.
Upgrade Way
Upgrade methods:
·     Service Upgrade.
·     File Upgrade.
·     Reboot.
This field is displayed only for an upgrade to a compatible version.
Influenced service according to following table
Services influenced by the upgrade.
install commit
install deactivate
install commit
Use install commit to commit software changes.
install commit
Before you use this command, read the release notes to identify software image licensing requirements. Make sure the device has valid licenses for all license-based images.
This command adds the patch image file to the startup software image list that the device used at startup.
·     If the device used the main startup software image list at startup, this command adds the patch image file to the main startup software image list.
·     If the device used the backup startup software image list at startup, this command adds the patch image file to the backup startup software image list.
Both the install commit and boot-loader file commands modify the main startup software image list. To modify the backup startup image list or add inactive images as main startup images, however, you must use the boot-loader file command.
# Commit software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
install activate
install deactivate
install rollback
install deactivate
Use install deactivate to deactivate feature images and patch images.
In standalone mode:
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename { all | slot slot-number }
In IRF mode:
install deactivate feature filename&<1-30> chassis chassis-number slot slot-number
install deactivate patch filename { all | chassis chassis-number slot slot-number }
feature: Specifies feature image files. You can specify a space-separated list of up to 30 feature image files.
patch: Specifies a patch image file. You can specify only one patch image file for the command at a time. However, you can execute the command multiple times to deactivate multiple patch image files.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To identify whether the synchronization is complete, use the display system stable state command. The synchronization is complete if the System State field displays Stable.
You can deactivate only active feature and patch images.
Images deactivated by using the install deactivate patch filename all command do not run after a reboot. To prevent other deactivated images from running after a reboot, you must commit the software change by using the install commit command.
# (In standalone mode.) Deactivate the patch images in the route-patch.bin file for a slot.
<Sysname> install deactivate patch flash:/route-patch.bin slot 1
install remove
Use install remove to delete an inactive software image file.
In standalone mode:
install remove [ slot slot-number ] { filename | inactive }
In IRF mode:
install remove [ chassis chassis-number slot slot-number ] { filename | inactive }
filename: Specifies a .bin file in the filesystemname/filename.bin format. The value string can have a maximum of 63 characters. The file must be stored in the root directory of a file system on the device. The file system name cannot contain file system location information. For more information about specifying a file, see file system management in Fundamentals Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command deletes inactive software images from all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes inactive software images from all cards. (In IRF mode.)
inactive: Deletes all inactive software image files in the root directories of the specified file systems.
This command permanently deletes the image files from the device. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
# Delete inactive software image file flash:/feature1.bin.
<Sysname> install remove flash:/feature1.bin
install verify
Use install verify to verify the software change commit status, image integrity, and image consistency.
install verify
To make sure the system can start up and operate correctly after an upgrade performed by using install commands, execute this command to verify the following items:
·     Integrity—Verify that the boot, system, and feature images are integral.
·     Consistency—Verify that the same active images are running across the entire system.
·     Software commit status—Verify that the active images are committed as needed.
If a software image fails the verification, perform the following tasks to resolve the problem:
·     To ensure software integrity, download and install the software images again.
·     To guarantee software image consistency or change software commit status, use the install activate, install deactivate, and install commit commands as appropriate.
# Verify the software change confirmation status and software image integrity and consistency.
<Sysname> install verify
Active packages on the device are the reference packages.
Packages will be compared with the reference packages.
  Verifying packages on the device:
  Start to check active package completeness.
Verifying the file flash:/boot-t0001015.bin on the device...........Done.
   flash:/boot-t0001015.bin verification successful.
Verifying the file flash:/system-t0001015.bin on the device............Done.
   flash:/system-t0001015.bin verification successful.
  Start to check active package consistency.
    Active packages are consistent with committed packages on their own board.
    Active packages are consistent with the reference packages.
Verification is done.
# (In standalone mode.) Verify the software change confirmation status and software image integrity and consistency.
Active packages on slot 1 are the reference packages.
  Verifying packages on slot 0:
Verifying the file flash:/boot-t0001015.bin on slot 0.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 0.....................Done.
  Verifying packages on slot 1:
Verifying the file flash:/boot-t0001015.bin on slot 1.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 1.....................Done.
  Verifying packages on slot 2:
Verifying the file flash:/boot-t0001015.bin on slot 2.....................Done.
Verifying the file flash:/system-t0001015.bin on slot 2.....................Done.
version auto-update enable
Use version auto-update enable to enable software synchronization from active MPU to standby MPU at startup.
Use undo version auto-update enable to disable this feature.
The following compatibility matrix shows the support of hardware platforms for this command:
Series
Models
Command compatibility
M9000 series
M9006, M9010, M9014, M9016-V
Yes
M9000-S series
M9008-S, M9008-S-V
No
M9000-AK series
M9000-AK001
Yes
M9000-AI-E series
M9000-AI-E4
Yes
M9000-AI-E8, M9000-AI-E16
No
M9000-X series
M9000-X06, M9000-X06-B, M9000-X06-B-G, M9000-X06-G, M9000-X10
Yes
M9000-AI-X series
M9000-AI-X06, M9000-AI-X10
Yes
M9000-CN series
M9000-CN04
Yes
Software synchronization from active MPU to standby MPU is enabled. If software inconsistency is detected at startup, the standby MPU loads the current software images of the active MPU.
Operating mechanism
To make sure the standby MPU always runs the same software images as the active MPU, use both the version auto-update enable command and the undo version check ignore command.
The startup software version check feature examines the standby MPU's startup software images for version inconsistency with the active MPU's current software images at startup. If their software versions are different, the standby MPU copies the current software images of the active MPU, specifies them as main startup software images, and reboots with these images.
Use the undo version auto-update enable and version check ignore commands with caution. Configured with these two commands, the system will not examine the standby MPU's startup software images for version inconsistency with the active MPU's current software images. The standby MPU can start up with a different software version than the active MPU. This might cause the device to malfunction.
This command is available in standalone mode.
To ensure a successful synchronization in a multiuser environment, make sure no one reboots or swaps MPUs during the software synchronization process. You can configure the information center to output the synchronization status to configuration terminals (see Network Management and Monitoring Configuration Guide).
# Enable software auto-update for the standby MPU.
[Sysname] version auto-update enable
Use version check ignore to disable startup software version check for the standby MPU at startup.
Use undo version check ignore to enable this feature.
Series
Models
M9000 series
Yes
M9000-S series
M9008-S, M9008-S-V
No
M9000-AK series
M9000-AK001
Yes
M9000-AI-E series
M9000-AI-E4
Yes
No
M9000-X series
Yes
M9000-AI-X series
Yes
M9000-CN series
M9000-CN04
Yes
The startup software images on the standby MPU are checked for version inconsistency with the current software images on the active MPU.
Operating mechanism
When the standby MPU starts up, this command disables the system to examine the standby MPU's startup software images for version inconsistency with the active MPU's current software images. The standby MPU can start up with a different software version than the active MPU.
If you enable startup software version check for the standby MPU, the system will prevent the standby MPU from starting up with a different software version than the active MPU.
To avoid anomalies, do not disable startup software version check for the standby MPU unless for software upgrade. The device might malfunction if the standby MPU starts up with a different software version than the active MPU.
# Enable startup software version check for the standby MPU.
[Sysname] undo version check ignore
