- 12-Layer 3—IP Routing Configuration Guide
- 01-IS-IS configuration
- 02-OSPF configuration
- 03-RIP configuration
- 04-RIPng configuration
- 05-Guard route configuration
- 06-RIR configuration
- 07-BGP configuration
- 08-Routing policy configuration
- 09-IPv6 policy-based routing configuration
- 10-OSPFv3 configuration
- 11-Policy-based routing configuration
- 12-Basic IP routing configuration
- 13-Static routing configuration
- 14-IPv6 static routing configuration
00-Preface | 110.52 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device, It includes the following feature modules: Basic IP routing, Static routing, RIP, OSPF, IS-IS , BGP, Policy-based routing, IPv6 static routing, IPv6 policy-based routing, RIPng, OSPFv3, Routing policy ,Guard route and RIR.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
