14-Network Management and Monitoring Configuration Guide
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration GuidesH3C CR16000-M Router Configuration Guides-R8630Pxx-6W10014-Network Management and Monitoring Configuration Guide
11-NETCONF configuration
11-NETCONF configuration 532.21 KB
Configuring NETCONF· 1
About NETCONF· 1
NETCONF structure· 1
Basic NETCONF concepts· 1
NETCONF message format 3
How to use NETCONF· 5
Protocols and standards· 5
NETCONF tasks at a glance· 5
Configuring NETCONF to use module-specific namespaces· 6
Establishing a NETCONF session· 7
Restrictions and guidelines for NETCONF session establishment 7
Setting NETCONF session attributes· 7
Establishing NETCONF over SOAP sessions· 7
Establishing NETCONF over SSH sessions· 8
Establishing NETCONF over Telnet or NETCONF over console sessions· 9
Exchanging capabilities· 9
Enabling the edit-config:replace operation to do full replacement 10
Retrieving device configuration information· 11
Restrictions and guidelines for device configuration retrieval 11
Retrieving device configuration and state information· 11
Retrieving non-default settings· 13
Retrieving NETCONF information· 14
Retrieving YANG file content 15
Retrieving NETCONF session information· 15
Example: Retrieving a data entry for the interface table· 16
Example: Retrieving syslog configuration data· 17
Example: Retrieving NETCONF session information· 18
Filtering data· 19
About data filtering· 19
Restrictions and guidelines for data filtering· 19
Table-based filtering· 19
Column-based filtering· 20
Example: Filtering data with regular expression match· 22
Example: Filtering data by conditional match· 23
Locking or unlocking the configuration· 25
About configuration locking and unlocking· 25
Restrictions and guidelines for configuration locking and unlocking· 25
Locking the configuration· 25
Unlocking the configuration· 25
Example: Locking the running configuration· 26
Modifying the configuration· 27
About the <edit-config> operation· 27
Procedure· 27
Example: Modifying the configuration· 28
Saving the running configuration· 29
About the <save> operation· 29
Restrictions and guidelines for configuration saving· 29
Procedure· 29
Example: Saving the running configuration· 30
Loading the configuration· 31
About the <load> operation· 31
Restrictions and guidelines for configuration loading· 31
Procedure· 31
Rolling back the configuration· 32
Restrictions and guidelines for configuration rollback· 32
Rolling back the configuration based on a configuration file· 32
Rolling back the configuration based on a rollback point 32
Managing the candidate configuration· 36
About this task· 36
Candidate configuration management tasks at a glance· 36
Creating a candidate configuration datastore· 37
Editing the candidate configuration datastore· 37
Committing the candidate configuration immediately· 38
Committing the candidate configuration only after confirmation· 38
Deleting the candidate configuration datastore· 39
Performing CLI operations· 40
About CLI operations· 40
Restrictions and guidelines for CLI operations· 40
Procedure· 40
Example: Performing CLI operations· 40
Subscribing to events· 41
About event subscription· 41
Restrictions and guidelines for event subscription· 41
Subscribing to syslog events· 42
Subscribing to events monitored by NETCONF· 43
Subscribing to events reported by modules· 44
Canceling an event subscription· 45
Example: Subscribing to syslog events· 46
Terminating NETCONF sessions· 47
About NETCONF session termination· 47
Procedure· 47
Example: Terminating another NETCONF session· 47
Returning to the CLI 48
Restrictions and guidelines for returning to the CLI 48
Procedure· 48
Example: Returning to the CLI 48
Enabling SNMP notifications for NETCONF· 49
Display and maintenance commands for NETCONF· 49
Supported NETCONF operations· 50
Candidate configuration datastore operations· 50
cancel-commit 50
commit (immediate commit) 50
commit (confirmation-required commit) 50
commit (commit confirmation) 51
copy-config· 51
delete-config· 52
discard-changes· 52
CLI operations· 52
CLI 52
VLAN termination operations· 53
createDot1qFlow· 53
deleteDot1qFlow· 54
Edit operations· 54
edit-config: create· 54
edit-config: delete· 55
edit-config: merge· 55
edit-config: remove· 56
edit-config: replace· 56
edit-config: test-option· 56
edit-config: default-operation· 57
edit-config: error-option· 58
edit-config: incremental 59
Get operations· 59
get 59
get-bulk· 60
get-bulk-config· 60
get-config· 61
get-sessions· 61
Other operations· 62
action· 62
close-session· 62
kill-session· 62
load· 63
lock· 63
rollback· 63
save· 64
unlock· 64
Configuring NETCONF
About NETCONF
Network Configuration Protocol (NETCONF) is an XML-based network management protocol. It provides programmable mechanisms to manage and configure network devices. Through NETCONF, you can configure device parameters, retrieve parameter values, and collect statistics. For a network that has devices from vendors, you can develop a NETCONF-based NMS system to configure and manage devices in a simple and effective way.
NETCONF structure
NETCONF has the following layers: content layer, operations layer, RPC layer, and transport protocol layer.
Table 1 NETCONF layers and XML layers
NETCONF layer
XML layer
Content
Configuration data, status data, and statistics information
Contains a set of managed objects, which can be configuration data, status data, and statistics information. For information about the operable data, see the NETCONF XML API references for the device.
Operations
<get>, <get-config>, <edit-config>…
Defines a set of base operations invoked as RPC methods with XML-encoded parameters. NETCONF base operations include data retrieval operations, configuration operations, lock operations, and session operations. For the device supported operations, see "Supported NETCONF operations."
RPC
<rpc> and <rpc-reply>
Provides a simple, transport-independent framing mechanism for encoding RPCs. The <rpc> and <rpc-reply> elements are used to enclose NETCONF requests and responses (data at the operations layer and the content layer).
Transport protocol
Console/Telnet/SSH/HTTP/HTTPS/TLS
Provides reliable, connection-oriented, serial data links.
The following transport layer sessions are available:
·     CLI sessions, including NETCONF over Telnet, NETCONF over SSH, and NETCONF over console.
·     NETCONF over HTTP sessions and NETCONF over HTTPS sessions.
·     NETCONF over SOAP sessions, including NETCONF over SOAP over HTTP and NETCONF over SOAP over HTTPS.
XML
eXtensible Markup Language (XML) is a simple, text-based data storage language. It describes the content and structure of data exchanged between entities on the Internet.
XML is case sensitive.
NETCONF uses XML-based data encoding for the configuration data and protocol messages. NETCONF messages are XML-based and comply with RFC 4741.
Element
Elements are the basic building blocks in an XML document. They act as containers to store various types of content, including text, child elements, and attributes.
An element encloses content in a pair of start and end tags, in <element-name>content</element-name> format. For example, the capability element is <capability>content</capability>.
If an element does not have content, that element is called an empty element. You can present an empty element in a self-closing empty tag in <element-name/> format, for example, <ok/>.
Attribute
Attributes provide meta-level information about an element. They are added in name=value format after the element name, within the start tag. For examples, the xmlns and operation attributes in the following element specify the namespace and operation type, respectively.
<Syslog xmlns="http://www.h3c.com/netconf/config:1.0" operation="create">
Namespace
A namespace is an abstract container or environment created to hold a logical group of unique identifiers or names. An identifier defined in a namespace is associated only with that namespace. Each data module must have a world-unique namespace to avoid element and attribute naming conflicts.
The device supports the following types of namespaces:
·     urn:ietf:params:xml:ns:netconf:base:1.0 namespace—This namespace defines all NETCONF elements. All NETCONF messages must declare this namespace in the RPC layer.
·     ietf-netconf namespace—The urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring namespace defined in a NETCONF protocol. NETCONF messages for the <get-schema> and <get><netconf-state/></get> operations must declare this namespace.
·     Common namespace—A namespace that defines elements across service modules. In a packet that uses a common namespace, the namespace is indicated in the <top> element, and the modules are listed under the <top> element.
·     H3C common namespaces—The http://www.h3c.com/netconf/ns:1.0 namespaces. The ns argument represents data, config, and action, which represent the data, configuration, and action namespaces, respectively. The common namespaces are shared by all modules. If used, a common namespace is typically specified for the xmlns attribute in the <top> element, and the modules are listed under the <top> element.
Example:
<rpc message-id="100" xmlns="urn:ietf:Params:xml:ns:netconf:base:1.0">
   <get-bulk>
      <filter type="subtree">
         <top xmlns="http://www.h3c.com/netconf/data:1.0">
            <Ifmgr>
               <Interfaces>
               </Interfaces>
            </Ifmgr>
         </top>
      </filter>
   </get-bulk>
</rpc>
·     Module-specific namespaces—A module has its own namespace to define module-specific elements. A packet that uses a module-specific namespace does not have the <top> element. The namespace follows the module name.
Example:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
   <get-bulk>
            <Ifmgr xmlns="http://www.h3c.com/netconf/data:1.0-Ifmgr">
               <Interfaces>
               </Interfaces>
            </Ifmgr>
      </filter>
   </get-bulk>
</rpc>
Node, module, table, row, and column
In H3C NETCONF XML AI references, elements are also called nodes. An element might be a module (or feature), table, row, or column node, as shown in Figure 1.
·     Module—A feature module defines a hierarchy of related nodes. The element name for a module node is the module name.
·     Table—A table contains rows and columns, with each row representing an object instance and each column containing a parameter for the instance. A table might also contains subtables.
·     Row—Each row represents an object instance in the table.
·     Column—Each column contains a parameter for the instance.
Figure 1 Node, module, table, row, and column in NETCONF messages
In Figure 1, the Ifmgr element represents the interface management module (Ifmgr). The Interfaces element is a table node in the Ifmgr module and it contains a table of interfaces. The Interface element is a row node and it contains data about an interface in the interface table. The IfIndex and Description elements are column nodes that contain the interface index and description of the interface.
NETCONF
Any incoming NETCONF messages must pass XML Schema check before it can be processed. If a NETCONF message fails XML Schema check, the device sends an error message to the client.
For information about the NETCONF operations supported by the device and the operable data, see the NETCONF XML API reference for the device.
The following example shows a NETCONF message for getting all parameters of all interfaces on the device:
<?xml version="1.0" encoding="utf-8"?>
  <get-bulk>
        <Ifmgr>
          <Interfaces>
                 <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
NETCONF over SOAP
All NETCONF over SOAP messages are XML-based and comply with RFC 4741. NETCONF messages are contained in the <Body> element of SOAP messages. NETCONF over SOAP messages also comply with the following rules:
·     SOAP messages must use the SOAP Envelope namespaces.
·     SOAP messages cannot contain the following information:
¡     DTD reference.
¡     XML processing instructions.
The following example shows a NETCONF over SOAP message for getting all parameters of all interfaces on the device:
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
  <env:Header>
    <auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
      <auth:AuthInfo>10000162a5d9091c0667ec821fb954147a16</auth:AuthInfo>
    </auth:Authentication>
  </env:Header>
  <env:Body>
      <get-bulk>
            <Ifmgr>
              <Interfaces>
                <Interface/>
              </Interfaces>
            </Ifmgr>
          </top>
        </filter>
      </get-bulk>
    </rpc>
  </env:Body>
</env:Envelope>
How to use NETCONF
You can use NETCONF to manage and configure the device by using the methods in Table 2.
Table 2 NETCONF methods for configuring the device
Configuration tool
Login method
Remarks
CLI
·     Console port
·     SSH
·     Telnet
To perform NETCONF operations, copy valid NETCONF messages to the CLI in XML view.
Custom user interface
N/A
Use a configuration tool to establish a NETCONF over SOAP or NETCONF over SSH session with the device. Then, you can issue NETCONF operations to configure and manage the device.
To configure and manage the device through NECONF over SOAP, you must encapsulate NECONF messages in SOAP for transmission.
·     RFC 3339, Date and Time on the Internet: Timestamps
·     RFC 4741, NETCONF Configuration Protocol
·     RFC 4742, Using the NETCONF Configuration Protocol over Secure SHell (SSH)
·     RFC 4743, Using NETCONF over the Simple Object Access Protocol (SOAP)
·     RFC 5277, NETCONF Event Notifications
·     RFC 5381, Experience of Implementing NETCONF over SOAP
·     RFC 5539, NETCONF over Transport Layer Security (TLS)
·     RFC 6241, Network Configuration Protocol
To configure NETCONF, perform the following tasks:
1.     Configuring NETCONF to use module-specific namespaces
2.     Establishing a NETCONF session
a.     (Optional.) Setting NETCONF session attributes
b.     Establishing NETCONF over SOAP sessions
c.     Establishing NETCONF over SSH sessions
d.     Establishing NETCONF over Telnet or NETCONF over console sessions
e.     Exchanging capabilities
3.     (Optional.) Retrieving device configuration information
¡     Retrieving device configuration and state information
¡     Retrieving non-default settings
¡     Retrieving NETCONF information
¡     Retrieving YANG file content
¡     Retrieving NETCONF session information
4.     (Optional.) Enabling the edit-config:replace operation to do full replacement
5.     (Optional.) Filtering data
¡     Table-based filtering
¡     Column-based filtering
6.     (Optional.) Locking or unlocking the configuration
a.     Locking the configuration
b.     Unlocking the configuration
7.     (Optional.) Modifying the configuration
8.     (Optional.) Managing configuration files
¡     Saving the running configuration
¡     Loading the configuration
¡     Rolling back the configuration
9.     (Optional.) Managing the candidate configuration
10.     (Optional.) Performing CLI operations
11.     (Optional.) Subscribing to events
12.     (Optional.) Terminating NETCONF sessions
13.     (Optional.) Returning to the CLI
14.     (Optional.) Enabling SNMP notifications for NETCONF
By default, the device uses the common namespace in the NETCONF responses to the requests for YANG file information. Perform this task to configure the device to use module-specific namespaces in the response messages.
The client performs the <get-schema> and <get><netconf-state/></get> operations to obtain information about YANG files on the device. For more information about the operations, see "Retrieving YANG file content" and "Retrieving NETCONF information."
You do not need to perform this task if the client sends a hello message that includes the following capability during capability exchange:
<capability>urn:h3c:params:netconf:capability:module-specified-namespace:1.0</capability>
2.     Configure NETCONF to use module-specific namespaces in messages responding to the client request of retrieving YANG file information.
netconf capability specific-namespace
By default, the common namespace is used in messages responding to the client request of retrieving YANG file information.
After a NETCONF session is established, the device automatically sends its capabilities to the client. You must use a hello message to send the capabilities of the client to the device before you can perform any other NETCONF operations.
Before performing a NETCONF operation, make sure no other users are configuring or managing the device. If multiple users simultaneously configure or manage the device, the result might be different from what you expect.
You can use the aaa session-limit command to set the maximum number of NETCONF sessions that the device can support. If the upper limit is reached, new NETCONF users cannot access the device. For information about this command, see AAA in BRAS Services Configuration Guide.
2.     Set the NETCONF session idle timeout time.
netconf { agent | soap } idle-timeout minute
Parameter
agent
Specifies the following sessions:
·     NETCONF over SSH sessions.
·     NETCONF over Telnet sessions.
·     NETCONF over console sessions.
By default, the idle timeout time is 0, and the sessions never time out.
soap
·     NETCONF over SOAP over HTTP sessions.
·     NETCONF over SOAP over HTTPS sessions.
The default setting is 10 minutes.
3.     Enable NETCONF logging.
netconf log source { all | { agent | soap | web } * } { protocol-operation { all | { action | config | get | session | set | syntax | others } * } | row-operation | verbose }
By default, the device logs only row operations for <action> and <edit-config> operations. NETCONF logging is disabled for all the other types of operations..
You can use a custom user interface to establish a NETCONF over SOAP session to the device and perform NETCONF operations. The NETCONF messages are encapsulated into SOAP messages and transmitted over HTTP or HTTPS.
You can add an authentication domain to the <UserName> element of a SOAP request. The authentication domain takes effect only on the current request.
The mandatory authentication domain configured by using the netconf soap domain command takes precedence over the authentication domain specified in the <UserName> element of a SOAP request.
After the NETCONF over SOAP over HTTPS service is enabled, changes to the SSL server policy that is applied to the service do not take effect. For the changes to take effect, you must disable the service and then enable the service again.
2.     (Optional.) Apply an SSL server policy to the NETCONF over SOAP over HTTPS service.
netconf soap https ssl-server-policy policy-name
By default, no SSL server policy is applied to the NETCONF over SOAP over HTTPS service.
The NETCONF over SOAP over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
3.     Enable NETCONF over SOAP.
netconf soap { http | https } enable
By default, the NETCONF over SOAP feature is disabled.
4.     (Optional.) Set the DSCP value for NETCONF over SOAP packets.
netconf soap { http | https } dscp dscp-value
By default, the DSCP value is 0 for NETCONF over SOAP packets.
5.     (Optional.) Use an IPv4 ACL to control NETCONF over SOAP access.
netconf soap { http | https } acl { ipv4-acl-number | name ipv4-acl-name }
By default, no IPv4 ACL is applied to control NETCONF over SOAP access.
Only clients permitted by the IPv4 ACL can establish NETCONF over SOAP sessions.
6.     (Optional.) Specify a mandatory authentication domain for NETCONF users.
netconf soap domain domain-name
By default, no mandatory authentication domain is specified for NETCONF users. For information about authentication domains, see BRAS Services Configuration Guide.
7.     Use the custom user interface to establish a NETCONF over SOAP session with the device.
For information about the custom user interface, see the user guide for the interface.
Before establishing a NETCONF over SSH session, make sure the custom user interface can access the device through SSH.
2.     Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
3.     (Optional.) Specify the listening port for NETCONF over SSH packets.
netconf ssh server port port-number
By default, the listening port number is 830.
4.     Use the custom user interface to establish a NETCONF over SSH session with the device. For information about the custom user interface, see the user guide for the interface.
To ensure the format correctness of a NETCONF message, do not enter the message manually. Copy and paste the message.
While the device is performing a NETCONF operation, do not perform any other operations, such as pasting a NETCONF message or pressing Enter.
For the device to identify NETCONF messages, you must add end mark ]]>]]> at the end of each NETCONF message. Examples in this document do not necessarily have this end mark. Do add the end mark in actual operations.
To establish a NETCONF over Telnet session or a NETCONF over console session, first log in to the device through Telnet or the console port.
To enter XML view, execute the following command in user view:
xml
If the XML view prompt appears, the NETCONF over Telnet session or NETCONF over console session is established successfully.
After a NETCONF session is established, the device sends its capabilities to the client. You must use a hello message to send the capabilities of the client to the device before you can perform any other NETCONF operations.
Hello message from the device to the client
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities>...</capabilities><session-id>1</session-id></hello>
The <capabilities> element carries the capabilities supported by the device.
The <session-id> element carries the unique ID assigned to the NETCONF session.
Hello message from the client to the device
After receiving the hello message from the device, copy the following hello message to notify the device of the capabilities supported by the client:
  <capabilities>
    <capability>
     capability-set
   </capability>
 </capabilities>
</hello>
Item
capability-set
Specifies a set of capabilities supported by the client.
Use a pair of <capability> and </capability> tags to enclose each user-defined capability set.
By default, the edit-config:replace operation does not do full replacement. This operation edits the specified columns and subtables in the target node and processes other columns and subtables as follows:
·     If the target node contains only index columns and subtables, this operation leaves other columns and subtables unchanged.
·     In other situations, this operation restores the unspecified columns to the default settings and leaves the unspecified subtables unchanged.
For example, the following XML request specifies only index columns VsiName, PeerAddr, and PWID and subtable TrafficPolicing in node LDPPeer. The edit-config:replace operation edits only subtable TrafficPolicing and leaves other columns and subtables of node LDPPeer unchanged.
<rpc message-id="3" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target><running/></target>
    <test-option>set</test-option>
    <error-option>continue-on-error</error-option>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns="http://www.h3c.com/netconf/config:1.0">
       <top>
          <VPLS>
             <LDPPeers>
                <LDPPeer  xc:operation="replace">
                   <VsiName>vsi-1</VsiName>
                   <PeerAddr>1.1.1.1</PeerAddr>
                   <PWID>30</PWID>
                   <TrafficPolicing>
                      <Policing>
                         <Direction>0</Direction>
                         <Type>4</Type>
                         <Value>0</Value>
                         <CIR>8</CIR>
                         <EBS>100</EBS>
                         <PIR>8</PIR>
                      </Policing>
                   </TrafficPolicing>
                </LDPPeer>
             </LDPPeers>
          </VPLS>
       </top>
    </config>
  </edit-config>
</rpc>
If full replacement is enabled, the edit-config:replace operation edits the specified columns and subtables in the target node and restores the unspecified columns and subtables to the default settings.
For more information about the edit-config:replace operation, see "Supported NETCONF operations."
2.     Enable the edit-config:replace operation to do full replacement.
netconf edit-config full-replace enable
When you perform a standard retrieval operation (<get> or <get-config>) or a bulk retrieval operation (<get-bulk> or <get-bulk-config>) operation, use the following restrictions and guidelines:
·     As a best practice to ensure retrieval performance, limit the number of data entries for each standard or bulk retrieval operation to 1000. If the number of data entries to retrieve exceeds 1000, use bulk retrieval operations as a best practice.
·     The NETCONF server replaces unidentifiable characters in the retrieved data with question marks (?) before it sends the data to the client.
·     If the process for a target module has not started yet, the NETCONF server returns the following message:
<?xml version="1.0"?>
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <data/>
</rpc-reply>
·     The <get><netconf-state/></get> operation does not support data filtering.
For more information about the NETCONF operations, see the NETCONF XML API references for the device.
You can use the following NETCONF operations to retrieve device configuration and state information:
·     <get> operation—Retrieves all device configuration and state information that match the specified conditions.
·     <get-bulk> operation—Retrieves data entries starting from the data entry next to the one with the specified index. One data entry contains a device configuration entry and a state information entry. The returned output does not include the index information.
The <get> message and <get-bulk> message share the following format:
  <getoperation>
    <filter>
          Specify the module, submodule, table name, and column name
      </top>
    </filter>
  </getoperation>
</rpc>
Item
getoperation
Operation name, get or get-bulk.
filter
Specifies the filtering conditions, such as the module name, submodule name, table name, and column name.
·     If you specify a module name, the operation retrieves the data for the specified module. If you do not specify a module name, the operation retrieves the data for all modules.
·     If you specify a submodule name, the operation retrieves the data for the specified submodule. If you do not specify a submodule name, the operation retrieves the data for all submodules.
·     If you specify a table name, the operation retrieves the data for the specified table. If you do not specify a table name, the operation retrieves the data for all tables.
·     If you specify only the index column, the operation retrieves the data for all columns. If you specify the index column and any other columns, the operation retrieves the data for the index column and the specified columns.
A <get-bulk> message can carry the count and index attributes. The following is a <get-bulk> message example:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get-bulk>
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:base="http://www.h3c.com/netconf/base:1.0">
        <Syslog>
          <Logs xc:count="5">
            <Log>
              <Index>10</Index>
           </Log>
             </Logs>
        </Syslog>
      </top>
    </filter>
  </get-bulk>
</rpc>
Attribute
index
Specifies the index.
If you do not specify this attribute, the index value starts with 1 by default.
count
Specifies the data entry quantity.
The count attribute complies with the following rules:
·     The count attribute can be placed in the module node and table node. In other nodes, it cannot be resolved.
·     When the count attribute is placed in the module node, a descendant node inherits this count attribute if the descendant node does not contain the count attribute.
·     The <get-bulk> operation retrieves all the rest data entries starting from the data entry next to the one with the specified index if either of the following conditions occurs:
¡     You do not specify the count attribute.
¡     The number of matching data entries is less than the value of the count attribute.
If the <get> or < get-bulk> operation succeeds, the device returns the retrieved data in the following format:
  <data>
     Device state and configuration data
  </data>
</rpc-reply>
The <get-config> and <get-bulk-config> operations are used to retrieve all non-default settings. The <get-config> and <get-bulk-config> messages can contain the <filter> element for filtering data.
The <get-config> and <get-bulk-config> messages are similar. The following is a <get-config> message example:
  <get-config>
    <source>
      <datastore/>
    </source>
    <filter>
      <top xmlns="http://www.h3c.com/netconf/config:1.0">
          Specify the module name, submodule name, table name, and column name
      </top>
    </filter>
  </get-config>
</rpc>
The value for datastore can be one of the following:
Value
running
Specifies the running configuration datastore.
candidate
Specifies the candidate configuration datastore.
If the <get-config> or <get-bulk-config> operation succeeds, the device returns the retrieved data in the following format:
  <data>
    Data matching the specified filter
  </data>
</rpc-reply>
Use the <get><netconf-state/></get> message to retrieve NETCONF information.
# Copy the following text to the client to retrieve NETCONF information:
  <rpc message-id="m-641" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
    <get>
      <filter type='subtree'>
        <netconf-state xmlns='urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring'>
             <getType/>
        </netconf-state>
      </filter>
    </get>
  </rpc>
If you do not specify a value for getType, the retrieval operation retrieves all NETCONF information.
The value for getType can be one of the following operations:
Operation
capabilities
Retrieves device capabilities.
datastores
Retrieves databases from the device.
schemas
Retrieves the list of the YANG file names from the device.
sessions
Retrieves session information from the device.
statistics
Retrieves NETCONF statistics.
If the <get><netconf-state/></get> operation succeeds, the device returns a response in the following format:
  <data>
     Retrieved NETCONF information
  </data>
</rpc-reply>
YANG files save the NETCONF operations supported by the device. You can identify the supported operations by retrieving and analyzing the content of YANG files.
YANG files are integrated in the device software and are named in the format of yang_identifier@yang_version.yang. You cannot view the YANG file names by executing the dir command. For information about retrieving the YANG file names, see "Retrieving NETCONF information."
# Copy the following text to the client to retrieve the YANG file named H3C-[email protected]:
  <get-schema xmlns='urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring'>
    <identifier>H3C-syslog-data</identifier>
    <version>2017-01-01</version>
    <format>yang</format>
  </get-schema>
</rpc>
The YANG file names used in this document are for illustration only.
# If the <get-schema> operation succeeds, the device returns a response in the following format:
  <data>
     Content of the specified YANG file
  </data>
</rpc-reply>
Use the <get-sessions> operation to retrieve NETCONF session information of the device.
# Copy the following message to the client to retrieve NETCONF session information from the device:
  <get-sessions/>
</rpc>
If the <get-sessions> operation succeeds, the device returns a response in the following format:
  <get-sessions>
    <Session>
      <SessionID>Configuration session ID</SessionID>
      <Line>Line information</Line>
      <UserName>Name of the user creating the session</UserName>
      <Since>Time when the session was created</Since>
      <LockHeld>Whether the session holds a lock</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
Retrieve a data entry for the interface table.
# Enter XML view.
<Sysname> xml
# Notify the device of the NETCONF capabilities supported on the client.
  <capabilities>
    <capability>urn:ietf:params:netconf:base:1.0</capability>
  </capabilities>
</hello>
# Retrieve a data entry for the interface table.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:web="http://www.h3c.com/netconf/base:1.0">
        <Ifmgr>
          <Interfaces web:count="1">
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
If the client receives the following text, the <get-bulk> operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <IfIndex>3</IfIndex>
            <Name>Ten-GigabitEthernet3/0/2</Name>
            <AbbreviatedName>XGE3/0/2</AbbreviatedName>
            <PortIndex>3</PortIndex>
            <ifTypeExt>22</ifTypeExt>
            <ifType>6</ifType>
            <Description>Ten-GigabitEthernet3/0/2 Interface</Description>
            <AdminStatus>2</AdminStatus>
            <OperStatus>2</OperStatus>
            <ConfigSpeed>0</ConfigSpeed>
            <ActualSpeed>100000</ActualSpeed>
            <ConfigDuplex>3</ConfigDuplex>
            <ActualDuplex>1</ActualDuplex>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
Retrieve configuration data for the Syslog module.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve configuration data for the Syslog module.
  <get-config>
    <source>
      <running/>
    </source>
        <Syslog/>
      </top>
    </filter>
  </get-config>
</rpc>
If the client receives the following text, the <get-config> operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
    <data>
            <Syslog>
                    <LogBuffer>
                        <BufferSize>120</BufferSize>
                    </LogBuffer>
            </Syslog>
        </top>
    </data>
</rpc-reply>
Get NETCONF session information.
# Enter XML view.
<Sysname> xml
# Copy the following message to the client to exchange capabilities with the device:
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Copy the following message to the client to get the current NETCONF session information on the device:
  <get-sessions/>
</rpc>
If the client receives a message as follows, the operation is successful:
    <get-sessions>
        <Session>
            <SessionID>1</SessionID>
            <Line>vty0</Line>
            <UserName></UserName>
            <Since>2017-01-07T00:24:57</Since>
            <LockHeld>false</LockHeld>
        </Session>
    </get-sessions>
</rpc-reply>
·     The session ID of an existing NETCONF session is 1.
·     The login user type is vty0.
·     The login time is 2017-01-07T00:24:57.
·     The user does not hold the lock of the configuration.
Filtering data
You can define a filter to filter information when you perform a <get>, <get-bulk>, <get-config>, or <get-bulk-config> operation. Data filtering includes the following types:
·     Table-based filtering—Filters table information.
·     Column-based filtering—Filters information for a single column.
For table-based filtering to take effect, you must configure table-based filtering before column-based filtering.
The namespace is http://www.h3c.com/netconf/base:1.0. The attribute name is filter. For information about the support for table-based match, see the NETCONF XML API references.
# Copy the following text to the client to retrieve the longest data with IP address 1.1.1.0 and mask length 24 from the IPv4 routing table:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0">
  <get>
        <Route>
         <Ipv4Routes>
           <RouteEntry h3c:filter="IP 1.1.1.0 MaskLen 24 longer"/>
         </Ipv4Routes>
        </Route>
      </top>
    </filter>
  </get>
</rpc>
To use table-based filtering, specify a match criterion for the filter row attribute.
Column-based filtering includes full match filtering, regular expression match filtering, and conditional match filtering. Full match filtering has the highest priority and conditional match filtering has the lowest priority. When more than one filtering criterion is specified, the one with the highest priority takes effect.
You can specify an element value in an XML message to implement full match filtering. If multiple element values are provided, the system returns the data that matches all the specified values.
# Copy the following text to the client to retrieve configuration data of all interfaces in UP state:
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <AdminStatus>1</AdminStatus>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
You can also specify an attribute name that is the same as a column name of the current table at the row to implement full match filtering. The system returns only configuration data that matches this attribute name. The XML message equivalent to the above element-value-based full match filtering is as follows:
  <get>
      <top xmlns="http://www.h3c.com/netconf/data:1.0"xmlns:data="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
            <Interface data:AdminStatus="1"/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
The above examples show that both element-value-based full match filtering and attribute-name-based full match filtering can retrieve the same index and column information for all UP interfaces.
Regular expression match filtering
To implement a complex data filtering with characters, you can add a regExp attribute for a specific element.
The supported data types include integer, date and time, character string, IPv4 address, IPv4 mask, IPv6 address, MAC address, OID, and time zone.
# Copy the following text to the client to retrieve the descriptions of interfaces, of which all the characters must be upper-case letters from A to Z:
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description h3c:regExp="^[A-Z]*$"/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
Conditional match filtering
To implement a complex data filtering with digits and character strings, you can add a match attribute for a specific element. Table 3 lists the conditional match operators.
Table 3 Conditional match operators
Operation
Operator
Remarks
More than
match="more:value"
More than the specified value. The supported data types include date, digit, and character string.
Less than
match="less:value"
Less than the specified value. The supported data types include date, digit, and character string.
Not less than
match="notLess:value"
Not less than the specified value. The supported data types include date, digit, and character string.
Not more than
match="notMore:value"
Not more than the specified value. The supported data types include date, digit, and character string.
Equal
match="equal:value"
Equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Not equal
match="notEqual:value"
Not equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL.
Include
match="include:string"
Includes the specified string. The supported data types include only character string.
Not include
match="exclude:string"
Excludes the specified string. The supported data types include only character string.
Start with
match="startWith:string"
Starts with the specified string. The supported data types include character string and OID.
End with
match="endWith:string"
Ends with the specified string. The supported data types include only character string.
# Copy the following text to the client to retrieve extension information about the entity whose CPU usage is more than 50%:
  <get>
        <Device>
          <ExtPhysicalEntities>
            <Entity>
              <CpuUsage h3c:match="more:50"></CpuUsage>
            </Entity>
          </ExtPhysicalEntities>
        </Device>
      </top>
    </filter>
  </get>
</rpc>
Retrieve all data including Gig in the Description column of the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve all data including Gig in the Description column of the Interfaces table under the Ifmgr module.
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description h3c:regExp="(Gig)+"/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
If the client receives the following text, the operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" message-id="100">
    <data>
            <Ifmgr>
                <Interfaces>
                    <Interface>
                        <IfIndex>2681</IfIndex>
                        <Description>Ten-GigabitEthernet3/0/1 Interface</Description>
                    </Interface>
                    <Interface>
                        <IfIndex>2685</IfIndex>
                    </Interface>
                    <Interface>
                        <IfIndex>2689</IfIndex>
                        <Description>Ten-GigabitEthernet3/0/3 Interface</Description>
                    </Interface>
                 <Interface>
            </Ifmgr>
        </top>
    </data>
</rpc-reply>
Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <IfIndex h3c:match="notLess:5000"/>
              <Name/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
    <data>
            <Ifmgr>
                <Interfaces>
                    <Interface>
                        <IfIndex>7241</IfIndex>
                        <Name>NULL0</Name>
                    </Interface>
                </Interfaces>
            </Ifmgr>
        </top>
    </data>
</rpc-reply>
Multiple methods are available for configuring the device, such as CLI, NETCONF, and SNMP. Before configuring, managing, or troubleshooting the device, you can lock the configuration to prevent other users from changing the device configuration. After you lock the configuration, only you can perform <edit-config> operations to change the configuration or unlock the configuration. Other users can only read the configuration.
If you close your NETCONF session, the system unlocks the configuration. You can also manually unlock the configuration.
The <lock> operation locks the configuration of the device. You cannot use it to lock the configuration for a specific module.
# Copy the following text to the client to lock the configuration:
    <lock>
      <target>
        <datastore/>
      </target>
    </lock>
  </rpc>
Value
running
candidate
If the <lock> operation succeeds, the device returns a response in the following format:
     <ok/>
</rpc-reply>
# Copy the following text to the client to unlock the configuration:
    <unlock>
      <target>
        <datastore/>
      </target>
    </unlock>
  </rpc>
Value
running
candidate
If the <unlock> operation succeeds, the device returns a response in the following format:
      <ok/>
</rpc-reply>
Lock the device configuration so other users cannot change the device configuration.
# Enter XML view.
<Sysname> xml
    <capabilities>
        <capability>
        </capability>
    </capabilities>
</hello>
# Lock the configuration.
    <lock>
      <target>
        <running/>
      </target>
    </lock>
  </rpc>
If the client receives the following response, the <lock> operation is successful:
      <ok/>
</rpc-reply>
If another client sends a lock request, the device returns the following response:
<rpc-error>
  <error-type>protocol</error-type>
  <error-tag>lock-denied</error-tag>
  <error-severity>error</error-severity>
  <error-message xml:lang="en"> Lock failed because the NETCONF lock is held by another session.</error-message>
  <error-info>
  </error-info>
  </rpc-error>
</rpc-reply>
The output shows that the <lock> operation failed. The client with session ID 1 is holding the lock,
The <edit-config> operation includes the following operations:  merge, create, replace, remove, delete, default-operation, error-option, test-option, and incremental. For more information about the operations, see "Supported NETCONF operations."
# Copy the following text to perform the <edit-config> operation:
  <edit-config>
    <target><datastore/></target>
    <error-option>
       error-option
    </error-option>
    <config>
      </top>
    </config>
  </edit-config>
</rpc>
Value
running
candidate
If you specify the running configuration datastore, you can also specify the <error-option> element. This element indicates the action to be taken in response to an error that occurs during the operation. It has the following values:
Value
stop-on-error
Stops the <edit-config> operation.
continue-on-error
Continues the <edit-config> operation.
rollback-on-error
Rolls back the configuration to the configuration before the <edit-config> operation was performed.
By default, an <edit-config> operation cannot be performed while the device is rolling back the configuration. If the rollback time exceeds the maximum time that the client can wait, the client determines that the <edit-config> operation has failed and performs the operation again. Because the previous rollback is not completed, the operation triggers another rollback. If this process repeats itself, CPU and memory resources will be exhausted and the device will reboot.
To allow an <edit-config> operation to be performed during a configuration rollback, perform an <action> operation to change the value of the DisableEditConfigWhenRollback attribute to false.
If the <edit-config> operation succeeds, the device returns a response in the following format:
<?xml version="1.0">
  <ok/>
</rpc-reply>
# Perform the <get> operation to verify that the current element value is the same as the value specified through the <edit-config> operation.
Change the log buffer size for the Syslog module to 512.
# Enter XML view.
<Sysname> xml
  <capabilities>
  </capabilities>
</hello>
# Change the log buffer size for the Syslog module to 512.
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
      <top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
        <Syslog>
          <LogBuffer>
            <BufferSize>512</BufferSize>
          </LogBuffer>
        </Syslog>
      </top>
    </config>
  </edit-config>
</rpc>
If the client receives the following text, the <edit-config> operation is successful:
    <ok/>
</rpc-reply>
A <save> operation saves the running configuration to a configuration file and specifies the file as the next-startup configuration file.
The <save> operation is resource intensive. Do not perform this operation when system resources are heavily occupied.
# Copy the following text to the client:
  <save OverWrite="false" Safely="false">
    <file>Configuration file name</file>
  </save>
</rpc>
Item
file
Specifies the name of a configuration file. The name must start with the storage media name and end with the .cfg extension.
If the text includes the file column, you must specify the file name. If the text does not include the file column, the configuration is automatically saved to the default main next-startup configuration file.
OverWrite
Determines whether the specified configuration file overwrites the original configuration file when the name of the specified configuration file already exists. The following values are available:
·     true—The specified configuration file overwrites the original file.
·     false—The running configuration cannot be saved, and the system displays an error message.
The default value is true.
Safely
Determines whether to save the configuration file in safe mode or fast mode.
Available values:
·     true—Saves the configuration in safe mode. In this mode, the system saves the configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a disruptive event such as a reboot or power failure occurs during the save operation, the device can still start up with the original next-startup configuration file.
·     false—Saves the configuration in fast mode. In this mode, the system directly overwrites the target next-startup configuration file. If a disruptive event such as a reboot, power failure, out-of-memory, out-of-storage event occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots.
By default, the Safely attribute is set to false if you do not specify a value for it.
Safe mode is slower than fast mode, but more secure. As a best practice, use the safe mode if the power source is not reliable or you are remotely configuring the device.
If the <save> operation succeeds, the device returns a response in the following format:
      <ok/>
</rpc-reply>
Save the running configuration to the config.cfg file.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Save the running configuration of the device to the config.cfg file.
  <save>
    <file>config.cfg</file>
  </save>
</rpc>
If the client receives the following response, the <save> operation is successful:
      <ok/>
</rpc-reply>
The <load> operation merges the configuration from a configuration file into the running configuration as follows:
·     Loads settings that do not exist in the running configuration.
·     Overwrites settings that already exist in the running configuration.
When you perform a <load> operation, follow these restrictions and guidelines:
·     The <load> operation is resource intensive. Do not perform this operation when the system resources are heavily occupied.
·     Some settings in a configuration file might conflict with the existing settings. For the settings in the file to take effect, delete the existing conflicting settings, and then load the configuration file.
# Copy the following text to the client to load a configuration file for the device:
  <load>
  </load>
</rpc>
The configuration file name must start with the storage media name and end with the.cfg extension.
If the <load> operation succeeds, the device returns a response in the following format:
      <ok/>
</rpc-reply>
The <rollback> operation is resource intensive. Do not perform this operation when the system resources are heavily occupied.
By default, an <edit-config> operation cannot be performed while the device is rolling back the configuration. To allow an <edit-config> operation to be performed while the device is rolling back the configuration, perform an <action> operation to change the value of the DisableEditConfigWhenRollback attribute to false.
# Copy the following text to the client to roll back the running configuration to the configuration in a configuration file:
  <rollback>
    <file>Specify the configuration file name</file>
  </rollback>
</rpc>
If the <rollback> operation succeeds, the device returns a response in the following format:
      <ok/>
</rpc-reply>
You can roll back the running configuration based on a rollback point when one of the following situations occurs:
·     A NETCONF client sends a rollback request.
·     The NETCONF session idle time is longer than the rollback idle timeout time.
·     A NETCONF client is unexpectedly disconnected from the device.
Multiple users might simultaneously configure the device. As a best practice, lock the system before rolling back the configuration to prevent other users from modifying the running configuration.
1.     Lock the running configuration. For more information, see "Locking or unlocking the configuration."
2.     Enable configuration rollback based on a rollback point.
# Copy the following text to the client to perform a <save-point>/<begin> operation:
      <save-point>
        <begin>
          <confirm-timeout>100</confirm-timeout>
       </begin>
      </save-point>
</rpc>
Item
confirm-timeout
Specifies the rollback idle timeout time in the range of 1 to 65535 seconds. The default is 600 seconds. This item is optional.
If the <save-point/begin> operation succeeds, the device returns a response in the following format:
  <data>
    <save-point>
       <commit>
          <commit-id>1</commit-id>
       </commit>
    </save-point>
  </data>
</rpc-reply>
3.     Modify the running configuration. For more information, see "Modifying the configuration."
4.     Mark the rollback point.
The system supports a maximum of 50 rollback points. If the limit is reached, specify the force attribute for the <save-point>/<commit> operation to overwrite the earliest rollback point.
# Copy the following text to the client to perform a <save-point>/<commit> operation:
  <save-point>
    <commit>
      <label>SUPPORT VLAN<label>
      <comment>vlan 1 to 100 and interfaces.</comment>
     </commit>
  </save-point>
</rpc>
The <label> and <comment> elements are optional.
If the <save-point>/<commit> operation succeeds, the device returns a response in the following format:
  <data>
    <save-point>
       <commit>
          <commit-id>2</commit-id>
       </commit>
    </save-point>
  </data>
</rpc-reply>
5.     Retrieve the rollback point configuration records.
The following text shows the message format for a <save-point/get-commits> request:
  <save-point>
    <get-commits>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </get-commits>
  </save-point>
</rpc>
Specify the <commit-id/>, <commit-index/>, or <commit-label/> element to retrieve the specified rollback point configuration records. If no element is specified, the operation retrieves records for all rollback point settings.
# Copy the following text to the client to perform a <save-point>/<get-commits> operation:
  <save-point>
    <get-commits>
      <commit-label>SUPPORT VLAN</commit-label>
    </get-commits>
  </save-point>
</rpc>
If the <save-point/get-commits> operation succeeds, the device returns a response in the following format:
   <data>
      <save-point>
         <commit-information>
           <CommitID>2</CommitID>
           <TimeStamp>Sun Jan 1 11:30:28 2017</TimeStamp>
           <UserName>test</UserName>
           <Label>SUPPORT VLAN</Label>
         </commit-information>
    </save-point>
  </data>
</rpc-reply>
6.     Retrieve the configuration data corresponding to a rollback point.
The following text shows the message format for a <save-point>/<get-commit-information> request:
  <save-point>
         <commit-id/>
         <commit-index/>
         <commit-label/>
      <compare-information>
         <commit-id/>
         <commit-index/>
         <commit-label/>
      </compare-information>
    </get-commit-information>
  </save-point>
</rpc>
Specify one of the following elements: <commit-id/>, <commit-index/>, and <commit-label/>. The <compare-information> element is optional.
Item
commit-id
Uniquely identifies a rollback point.
commit-index
Specifies 50 most recently configured rollback points. The value of 0 indicates the most recently configured one and 49 indicates the earliest configured one.
commit-label
Specifies a unique label for a rollback point.
Retrieves the configuration data corresponding to the most recently configured rollback point.
# Copy the following text to the client to perform a <save-point>/<get-commit-information> operation:
  <save-point>
  </save-point>
</rpc>
If the <save-point/get-commit-information> operation succeeds, the device returns a response in the following format:
   <data>
     <save-point>
           <content>
              interface vlan 1
           </content>
     </save-point>
   </data>
</rpc-reply>
7.     Roll back the configuration based on a rollback point.
The configuration can also be automatically rolled back based on the most recently configured rollback point when the NETCONF session idle timer expires.
# Copy the following text to the client to perform a <save-point>/<rollback> operation:
  <save-point>
    <rollback>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </rollback>
  </save-point>
</rpc>
Specify one of the following elements: <commit-id/>, <commit-index/>, and <commit-label/>. If no element is specified, the operation rolls back configuration based on the most recently configured rollback point.
Item
commit-id
commit-index
commit-label
Specifies the unique label of a rollback point.
If the <save-point/rollback> operation succeeds, the device returns a response in the following format:
  <ok></ok>
</rpc-reply>
8.     End the rollback configuration.
# Copy the following text to the client to perform a <save-point>/<end> operation:
  <save-point>
    <end/>
  </save-point>
</rpc>
If the <save-point/end> operation succeeds, the device returns a response in the following format:
   <ok/>
</rpc-reply>
9.     Unlock the configuration. For more information, see "Locking or unlocking the configuration."
The candidate configuration datastore can be used to store or edit configuration data to be committed without impacting the device's running configuration. A commit operation commits the candidate configuration to the running configuration. After a successful commit operation, the system creates a configuration rollback point.
The candidate configuration datastore is globally unique.
To manage the candidate configuration, perform the following tasks:
1.     Creating a candidate configuration datastore
2.     Editing the candidate configuration datastore
3.     Commit the candidate configuration
¡     Committing the candidate configuration immediately
¡     Committing the candidate configuration only after
4.     (Optional.) Deleting the candidate configuration datastore
Perform this task to release system resources.
By default, the candidate configuration datastore does not exist. To create a candidate configuration datastore, perform the <copy-config> operation. This operation will create the candidate configuration datastore and copy the running configuration to the candidate configuration datastore. If the candidate configuration datastore already exists, the <copy-config> operation will overwrite existing candidate configuration in the datastore.
# Copy the following text to the client to create a candidate configuration datastore and copy the running configuration to the candidate configuration datastore:
  <copy-config>
    <source>
      <running/>
    </source>
    <target>
     <candidate/>
    </target>
  </copy-config>
</rpc>
If the <copy-config> operation succeeds, the device returns a response in the following format:
   <ok/>
</rpc-reply>
As a best practice to prevent other users from changing the candidate configuration and to avoid configuration conflicts, lock the candidate configuration before editing it.
1.     Lock the candidate configuration. For more information, see "Locking or unlocking the configuration." Make sure you specify the candidate configuration datastore.
2.     (Optional.) Retrieve non-default settings through a <get-config> or <get-bulk-config> operation. For more information, see "Retrieving non-default settings."
Skip this step if you know the non-default settings.
3.     Edit the candidate configuration datastore through a <edit-config> operation. For more information, see "Modifying the configuration." Make sure you specify the candidate configuration datastore.
4.     (Optional.) Restore the candidate configuration to the running configuration through a <discard-changes> operation. To perform a <discard-changes> operation, copy the following text to the client:
  <discard-changes/>
</rpc>
# Copy the following text to the client to commit the candidate configuration to the running configuration immediately:
  <commit/>
</rpc>
If the <commit> operation succeeds, the device returns a response in the following format:
   <ok/>
</rpc-reply>
A confirmation-required commit supports automatic rollback. If you require confirmation in the commit operation, the system will start a confirmation timeout timer.
·     Before the timer expires, you can choose to commit the candidate configuration to the running configuration immediately or roll back the running configuration to the previously committed configuration.
·     After the timer expires, the device automatically rolls back the running configuration to the previously committed configuration.
1.     ‍Copy the following text to the client to commit the candidate configuration to the running configuration only after confirmation:
  <commit>
    <confirmed/>
    <confirm-timeout>confirm-timeout</confirm-timeout>
    <persist>config-name</persist>
  </commit>
</rpc>
Element
confirm-timeout
Specifies the confirmation timeout timer, in seconds. The default is 600 seconds.
config-name
Specifies the name of the candidate configuration to be committed.
The <persist> element enables the candidate configuration to survive after the NETCONF session terminates.
·     If you include the <persist> element in the commit operation, you can confirm the commit in any NETCONF session. Make sure you specify the <persist-id> element with the same candidate configuration name in the commit confirmation operation.
·     If you do not include the <persist> element in this commit operation, you can confirm the commit only in the current NETCONF session.
2.     Choose one of the following tasks before the confirmation timeout timer expires:
¡     Commit the candidate configuration to the running configuration immediately by copying the following text to the client:
  <commit>
    <persist-id>config-name</persist-id>
  </commit>
</rpc>
Item
config-name
Specifies the name of the candidate configuration to be committed. The name must be the same as that specified in the <persist> element.
If you do not include the <persist> element in the commit operation, you do not need to include the <persist-id> element in the confirmation.
¡     Cancel the commit and roll back the running configuration to the previously committed configuration by copying the following text to the client:
  <cancel-commit/>
</rpc>
If the operation succeeds, the device returns a response in the following format:
   <ok/>
</rpc-reply>
# Copy the following text to the client to delete the candidate configuration datastore:
  <delete-config>
    <target>
      <candidate/>
    </target>
  </delete-config>
</rpc>
If the <delete-config> operation succeeds, the device returns a response in the following format:
   <ok/>
</rpc-reply>
You can enclose command lines in XML messages to configure the device.
Performing CLI operations through NETCONF is resource intensive. As a best practice, do not perform the following tasks:
·     Enclose multiple command lines in one XML message.
·     Use NETCONF to perform a CLI operation when other users are performing NETCONF CLI operations.
# Copy the following text to the client to execute the commands:
  <CLI>
    <Execution>
      Commands
    </Execution>
  </CLI>
</rpc>
The <Execution> element can contain multiple commands, with one command on one line.
If the CLI operation succeeds, the device returns a response in the following format:
  <CLI>
    <Execution>
      <![CDATA[Responses to the commands]]>
    </Execution>
  </CLI>
</rpc-reply>
Send the display vlan command to the device.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Copy the following text to the client to execute the display vlan command:
  <CLI>
    <Execution>
          display vlan
    </Execution>
  </CLI>
</rpc>
  <CLI>
    <Execution><![CDATA[
<Sysname>display vlan
 Total VLANs: 1
 The VLANs include:
 1(default)
   </Execution>
  </CLI>
</rpc-reply>
When an event takes place on the device, the device sends information about the event to NETCONF clients that have subscribed to the event.
Event subscription is not supported for NETCONF over SOAP sessions.
A subscription takes effect only on the current session. It is canceled when the session is terminated.
If you do not specify the event stream to be subscribed to, the device sends syslog event notifications to the NETCONF client.
# Copy the following message to the client to complete the subscription:
  <create-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
    <stream>NETCONF</stream>
      <filter>
        <event xmlns="http://www.h3c.com/netconf/event:1.0">
          <Code>code</Code>
          <Group>group</Group>
          <Severity>severity</Severity>
        </event>
      </filter>
      <startTime>start-time</startTime>
      <stopTime>stop-time</stopTime>
   </create-subscription>
</rpc>
Item
stream
Specifies the event stream. The name for the syslog event stream is NETCONF.
event
Specifies the event. For information about the events to which you can subscribe, see the system log message references for the device.
code
Specifies the mnemonic symbol of the log message.
group
Specifies the module name of the log message.
severity
Specifies the severity level of the log message.
start-time
Specifies the start time of the subscription.
stop-time
Specifies the end time of the subscription.
If the subscription succeeds, the device returns a response in the following format:
<rpc-reply message-id="100" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
    <ok/>
</rpc-reply>
If the subscription fails, the device returns an error message in the following format:
<rpc-error>
   <error-type>error-type</error-type>
   <error-tag>error-tag</error-tag>
   <error-severity>error-severity</error-severity>
   <error-message xml:lang="en">error-message</error-message>
</rpc-error>
</rpc-reply>
For more information about error messages, see RFC 4741.
Subscribing to events monitored by NETCONF
After you subscribe to events as described in this section, NETCONF regularly polls the subscribed events and sends the events that match the subscription condition to the NETCONF client.
<create-subscription xmlns='urn:ietf:params:xml:ns:netconf:notification:1.0'>
  <stream>NETCONF_MONITOR_EXTENSION</stream>
  <filter>
    <NetconfMonitor xmlns='http://www.h3c.com/netconf/monitor:1.0'>
      <XPath>XPath</XPath>
      <Interval>interval</Interval>
      <ColumnConditions>
        <ColumnCondition>
          <ColumnName>ColumnName</ColumnName>
          <ColumnValue>ColumnValue</ColumnValue>
          <ColumnCondition>ColumnCondition</ColumnCondition>
        </ColumnCondition>
      </ColumnConditions>
      <MustIncludeResultColumns>
        <ColumnName>columnName</ColumnName>
      </MustIncludeResultColumns>
    </NetconfMonitor>
  </filter>
</rpc>
Item
stream
Specifies the event stream. The name for the event stream is NETCONF_MONITOR_EXTENSION.
NetconfMonitor
Specifies the filtering information for the event.
XPath
Specifies the path of the event in the format of ModuleName[/SubmoduleName]/TableName.
interval
Specifies the interval for NETCONF to obtain events that matches the subscription condition. The value range is 1 to 4294967 seconds. The default value is 300 seconds.
ColumnName
Specifies the name of a column in the format of [GroupName.]ColumnName.
ColumnValue
Specifies the baseline value.
ColumnCondition
Specifies the operator:
·     more.
·     less.
·     notLess.
·     notMore.
·     equal.
·     notEqual.
·     include.
·     exclude.
·     startWith.
·     endWith.
Choose an operator according to the type of the baseline value.
start-time
stop-time
    <ok/>
</rpc-reply>
Subscribing to events reported by modules
After you subscribe to events as described in this section, the specified modules report subscribed events to NETCONF. NETCONF sends the events to the NETCONF client.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xs="http://www.h3c.com/netconf/base:1.0">
<stream>XXX_STREAM</stream>
<event xmlns="http://www.h3c.com/netconf/event:1.0/xxx-features-list-name:1.0">
       <ColumnName xs:condition="Condition">value</ColumnName>
</event>
</filter>
</rpc>
Item
stream
event
Specifies the event name. An event stream includes multiple events. The events use the same namespaces as the event stream.
ColumnName
Specifies the name of a column.
Condition
·     more.
·     less.
·     notLess.
·     notMore.
·     equal.
·     notEqual.
·     include.
·     exclude.
·     startWith.
·     endWith.
value
Specifies the baseline value for the column.
start-time
stop-time
    <ok/>
</rpc-reply>
Canceling an event subscription
# Copy the following message to the client to cancel a subscription:
  <cancel-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
  </cancel-subscription>
</rpc>
Item
stream
If the cancelation succeeds, the device returns a response in the following format:
    <ok/>
</rpc-reply>
If the subscription to be canceled does not exist, the device returns an error message in the following format:
<rpc-error>
<error-message xml:lang="en">The subscription stream to be canceled doesn't exist: Stream name=XXX_STREAM.</error-message>
</rpc-error>
</rpc-reply>
Example: Subscribing to syslog events
Configure a client to subscribe to syslog events with no time limitation. After the subscription, all events on the device are sent to the client before the session between the device and client is terminated.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Subscribe to syslog events with no time limitation.
</rpc>
# If the client receives the following response, the subscription is successful:
    <ok/>
</rpc-reply>
# When another client (192.168.100.130) logs in to the device, the device sends a notification to the client that has subscribed to all events:
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
    <eventTime>2011-01-04T12:30:52</eventTime>
        <Group>SHELL</Group>
        <Code>SHELL_LOGIN</Code>
        <Slot>1</Slot>
        <Severity>Notification</Severity>
        <context>VTY logged in from 192.168.100.130.</context>
    </event>
</notification>
About NETCONF session termination
NETCONF allows one client to terminate the NETCONF sessions of other clients. A client whose session is terminated returns to user view.
# Copy the following message to the client to terminate a NETCONF session:
  <kill-session>
    <session-id>
      Specified session-ID
    </session-id>
  </kill-session>
</rpc>
If the <kill-session> operation succeeds, the device returns a response in the following format:
      <ok/>
</rpc-reply>
Example: Terminating another NETCONF session
The user whose session's ID is 1 terminates the session with session ID 2.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Terminate the session with session ID 2.
  <kill-session>
    <session-id>2</session-id>
  </kill-session>
</rpc>
If the client receives the following text, the NETCONF session with session ID 2 has been terminated, and the client with session ID 2 has returned from XML view to user view:
    <ok/>
</rpc-reply>
Restrictions and guidelines for returning to the CLI
Before returning from XML view to the CLI, you must first complete capability exchange between the device and the client.
# Copy the following text to the client to return from XML view to the CLI:
   <close-session/>
</rpc>
When the device receives the close-session request, it sends the following response and returns to CLI's user view:
   <ok/>
</rpc-reply>
Example: Returning to the CLI
After entering XML view, return to the CLI.
# Enter XML view.
<Sysname> xml
  <capabilities>
  </capabilities>
</hello>]]>]]>
# Return to the CLI.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <close-session/>
</rpc>]]>]]>
If the user view prompt appears on the client, you have returned to the CLI.
<Sysname>
To report critical NETCONF events to an SNMP NMS, enable SNMP notifications for NETCONF. For NETCONF SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see Network Management and Monitoring Configuration Guide.
To disable SNMP notifications for NETCONF successfully, make sure SNMP agent is enabled. To enable SNMP agent, execute the snmp-agent command. For more information about this command, see SNMP commands in Network Management and Monitoring Command Reference.
2.     Enable SNMP notifications for NETCONF.
snmp-agent trap enable netconf
By default, SNMP notifications are disabled for NETCONF.
Display and maintenance commands for NETCONF
Display current NETCONF service status and global NETCONF service statistics.
display netconf service
Display NETCONF session status and statistics.
display netconf session
Clear NETCONF service statistics.
reset netconf service statistics
Clear NETCONF session statistics.
reset netconf session statistics
This chapter describes NETCONF operations available with Comware 7.
NETCONF packet strings are case sensitive.
Candidate configuration datastore operations
This section describes operations specific to the candidate configuration datastore. Besides these operations, you can also perform the following operations on the candidate configuration datastore:
·     edit-config: create, edit-config: delete, edit-config: merge, edit-config: remove, and edit-config: replace.
·     get-bulk-config and get-config.
·     lock and unlock.
cancel-commit
This operation cancels an ongoing confirmed commit and roll back the running configuration to the previously committed configuration. Perform this task before the confirmation timeout timer expires.
XML example
# Cancel an ongoing commit and roll back the running configuration to the previously committed configuration.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <cancel-commit/>
</rpc>
commit (immediate commit)
This operation commits the candidate configuration to the running configuration immediately.
XML example
# Commit the candidate configuration to the running configuration immediately.
  <commit/>
</rpc>
commit (confirmation-required commit)
This operation commits the candidate configuration to the running configuration only after the user confirms the commit. If the user does not confirm the commit, the device automatically rolls back the running configuration to the previously committed configuration.
When you perform this operation, you must specify the <confirmed> node and can specify the following columns:
·     <confirm-timeout>—Specifies the confirmation timeout timer, in seconds. The default is 600 seconds.
·     <persist>—Specifies the name of the candidate configuration and enable the candidate configuration to survive after the NETCONF session terminates. If you do not include the <persist> element in this commit operation, you can confirm the commit only in the current NETCONF session.
XML example
# Configure name test for the candidate configuration and commit the candidate configuration to the running configuration only after a confirmation. Set the confirmation timeout time to 600 seconds.
  <commit>
    <confirmed/>
    <confirm-timeout>600</confirm-timeout>
    <persist>test</persist>
  </commit>
</rpc>
commit (commit confirmation)
This operation confirms to commit the candidate configuration to the running configuration.
You must confirm the commit operation before the confirmation timeout timer expires.
If you include the <persist> element in the confirming commit operation, you must include the <persist-id> element in the confirmation operation. Make sure the value for the <persist-id> element is the same as that specified in the <persist> element.
If you do not include the <persist> element, the commit confirmation operation is the same as the immediate commit operation.
XML example
# Confirm to commit the candidate configuration with name test to the running configuration.
  <commit>
    <persist-id>test</persist-id>
  </commit>
</rpc>
copy-config
This operation copies the running configuration to a target configuration datastore. If the target configuration datastore does not exist, this operation creates the datastore.
In the current software version, this operation can only copy the running configuration to the candidate configuration store.
XML example
# Copy the running configuration to the candidate configuration datastore.
  <copy-config>
    <source>
      <running/>
    </source>
    <target>
     <candidate/>
    </target>
  </copy-config>
</rpc>
delete-config
This operation deletes a configuration datastore.
In the current software version, this operation can only delete the candidate configuration store.
XML example
# Delete the candidate configuration datastore.
  <delete-config>
    <target>
      <candidate/>
    </target>
  </delete-config>
</rpc>
discard-changes
This operation restores the candidate configuration to the previously committed configuration.
XML example
# Restore the candidate configuration to the previously committed configuration.
  <discard-changes/>
</rpc>
CLI operations
CLI
This operation executes Comware CLI commands.
A request message encloses commands in the <CLI> element. A response message encloses the command output in the <CLI> element.
You can use the following elements to execute commands:
·     Execution—Executes commands in user view.
·     Configuration—Executes commands in system view.
To use this element, include the exec-use-channel attribute and specify a value for the attribute:
¡     false—Executes commands without using a channel.
¡     true—Executes commands by using a temporary channel. The channel is automatically closed after the execution.
¡     persist—Executes commands by using the persistent channel for the session.
To use the persistent channel, first perform an <Open-channel> operation to open the persistent channel. If you do not do so, the system will automatically open the persistent channel.
After using the persistent channel, perform a <Close-channel> operation to close the channel and return to system view. If you do not perform an <Open-channel> operation, the system stays in the view and will execute subsequent commands in the view.
You can also specify the error-when-rollback attribute in the <Configuration> element to indicate whether CLI operations are allowed during a configuration error-triggered configuration rollback. This attribute takes effect only if the value of the <error-option> element in <edit-config> operations is set to rollback-on-error. It has the following values:
¡     true—Rejects CLI operation requests and returns error messages.
¡     false (the default)—Allows CLI operations.
For CLI operations to be correctly performed, set the value of the error-when-rollback attribute to true.
To execute commands in a lower-level view of the system view, use the <Configuration> element to enter the view first.
A NETCONF session can have multiple temporary channels, but it can have only one persistent channel.
NETCONF does not support executing interactive commands.
You cannot use the quit command by using a channel to exit user view.
XML example
# Execute the vlan 3 command in system view without using a channel.
  <CLI>
     <Configuration exec-use-channel="false" error-when-rollback="true">vlan 3</Configuration>
  </CLI>
</rpc>
VLAN termination operations
createDot1qFlow
This operation enables user VLAN Dot1q termination on a subinterface, and specifies the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface. For more information about Dot1q termination, see VLAN termination configuration in Layer 2—LAN Switching Configuration Guide.
You must use <ifName> to specify the subinterface.
Use <vlanIdBgn> and <vlanldEnd> to specify the range of the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface. If you specify the same value for these two columns, the subinterface terminates only packets that use the value as the outermost VLAN ID.
The value range for the <groupId> column is 1 to 16. To use the device together with a third-party device, make sure this column uses the same value as the third-party device.
XML example
# Enable user VLAN Dot1q termination on Ten-GigabitEthernet 3/0/1.1. Configure the subinterface to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 1 to 100.
  <createDot1qFlow xmlns="http://www.gsta.com/netconf/gsta-ethernet">
    <ifName>Ten-GigabitEthernet3/0/1.1</ifName>
    <vlanIdBgn>1</vlanIdBgn>
    <vlanIdEnd>100</vlanIdEnd>
    <groupId>1</groupId>
  </createDot1qFlow>
</rpc>
deleteDot1qFlow
This operation deletes Dot1q termination configuration from a subinterface.
Use <vlanIdBgn> and <vlanldEnd> to specify the range of the outermost VLAN IDs in the VLAN-tagged packets that you do not want to terminate on the subinterface. If you specify the same value for these two columns, you disable the subinterface from terminating packets that use the value as the outermost VLAN ID.
XML example
# Delete the Dot1q termination configuration for VLAN-tagged packets with outermost VLAN IDs in the range of 1 to 100 on Ten-GigabitEthernet 3/0/1.1.
  <deleteDot1qFlow xmlns="http://www.gsta.com/netconf/gsta-ethernet">
  </deleteDot1qFlow>
</rpc>
Edit operations
edit-config: create
This operation creates target configuration items.
To use the create attribute in an <edit-config> operation, you must specify the target configuration item.
·     If the table supports creating a target configuration item and the item does not exist, the operation creates the item and configures the item.
·     If the specified item already exists, a data-exist error message is returned.
XML example
# Set the buffer size to 120.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
        <Syslog xmlns="http://www.h3c.com/netconf/config:1.0" xc:operation="create">
           <LogBuffer>
          </LogBuffer>
        </Syslog>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: delete
This operation deletes the specified configuration.
·     If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself.
·     If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target.
·     If the specified target does not exist, an error message is returned, showing that the target does not exist.
XML example
The syntax is the same as the edit-config message with the create attribute. Change the operation attribute from create to delete.
edit-config: merge
This operation commits target configuration items to the running configuration.
To use the merge attribute in an <edit-config> operation, you must specify the target configuration item (on a specific level):
·     If the specified item exists, the operation directly updates the setting for the item.
·     If the specified item does not exist, the operation creates the item and configures the item.
·     If the specified item does not exist and it cannot be created, an error message is returned.
XML example
The XML data format is the same as the edit-config message with the create attribute. Change the operation attribute from create to merge.
edit-config: remove
This operation removes the specified configuration.
·     If the specified target does not exist, or the XML message does not specify any targets, a success message is returned.
XML example
The syntax is the same as the edit-config message with the create attribute. Change the operation attribute from create to remove.
This operation replaces the specified configuration.
·     If the specified target exists, the operation replaces the configuration of the target with the configuration carried in the message.
·     If the specified target does not exist but is allowed to be created, the operation creates the target and then applies the configuration.
·     If the specified target does not exist and is not allowed to be created, the operation is not conducted and an invalid-value error message is returned.
XML example
The syntax is the same as the edit-config message with the create attribute. Change the operation attribute from create to replace.
edit-config: test-option
This operation determines whether to commit a configuration item in an <edit-configure> operation. The <test-option> element has the following values:
·     test-then-set—Performs a syntax check, and commits an item if the item passes the check. If the item fails the check, the item is not committed. This is the default test-option value.
·     set—Commits the item without performing a syntax check.
·     test-only—Performs only a syntax check. If the item passes the check, a success message is returned. Otherwise, an error message is returned.
XML example
# Test the configuration for an interface.
  <edit-config>
    <target>
      <running/>
    </target>
    <test-option>test-only</test-option>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
        <Ifmgr xc:operation="merge">
          <Interfaces>
            <Interface>
              <IfIndex>262</IfIndex>
              <Description>222</Description>
                <ConfigSpeed>2</ConfigSpeed>
                <ConfigDuplex>1</ConfigDuplex>
               </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: default-operation
This operation modifies the current configuration of the device by using the default operation method.
NETCONF uses one of the following operation attributes to modify configuration: merge, create, delete, and replace If you do not specify an operation attribute for an edit-config message, NETCONF uses the default operation method. Your setting of the value for the <default-operation> element takes effect only once. If you do not specify an operation attribute or the default operation method for an <edit-config> message, merge always applies.
The <default-operation> element has the following values:
·     merge—Default value for the <default-operation> element.
·     replace—Value used when the operation attribute is not specified and the default operation method is specified as replace.
·     none—Value used when the operation attribute is not specified and the default operation method is specified as none. If this value is specified, the edit-config operation is used only for schema verification rather than issuing a configuration. If the schema verification is passed, a successful message is returned. Otherwise, an error message is returned.
XML example
# Issue an empty operation for schema verification purposes.
  <edit-config>
    <target>
      <running/>
    </target>
    <default-operation>none</default-operation>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description>222222</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: error-option
This operation determines the action to take in case of a configuration error.
The <error-option> element has the following values:
·     stop-on-error—Stops the operation and returns an error message. This is the default error-option value.
·     continue-on-error—Continues the operation and returns an error message.
·     rollback-on-error—Rolls back the configuration.
XML example
# Issue the configuration for two interfaces with the <error-option> element value as continue-on-error.
  <edit-config>
    <target>
      <running/>
    </target>
    <error-option>continue-on-error</error-option>
          <Interfaces>
            <Interface>
                <ConfigSpeed>1024</ConfigSpeed>
            </Interface>
            <Interface>
              <IfIndex>263</IfIndex>
              <Description>333</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: incremental
This operation adds configuration data to a column without affecting the original data.
The incremental attribute applies to a list column such as the vlan permitlist column.
You can use the incremental attribute for <edit-config> operations except the <replace> operation.
Support for the incremental attribute varies by module. For more information, see NETCONF XML API documents.
XML example
# Add VLANs 1 through 10 to an untagged VLAN list that has untagged VLANs 12 through 15.
  <edit-config>
    <target>
      <running/>
    </target>
        <VLAN xc:operation="merge">
          <HybridInterfaces>
            <Interface>
              <UntaggedVlanList  h3c:incremental="true">1-10</UntaggedVlanList>
               </Interface>
          </HybridInterfaces>
        </VLAN>
      </top>
    </config>
  </edit-config>
</rpc>
Get operations
get
This operation retrieves device configuration and state information.
XML example
# Retrieve device configuration and state information for the Syslog module.
  <get>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <Syslog>
        </Syslog>
      </top>
    </filter>
  </get>
</rpc>
get-bulk
This operation retrieves a number of data entries (including device configuration and state information) starting from the data entry next to the one with the specified index.
XML example
# Retrieve device configuration and state information for all interfaces.
  <get-bulk>
        <Ifmgr>
          <Interfaces xc:count="5" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
            <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
get-bulk-config
This operation retrieves a number of non-default configuration data entries starting from the data entry next to the one with the specified index.
XML example
# Retrieve non-default configuration for all interfaces.
  <get-bulk-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk-config>
</rpc>
get-config
This operation retrieves non-default configuration data. If no non-default configuration data exists, the device returns a response with empty data.
XML example
# Retrieve non-default configuration data for the interface table.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
           <Interfaces>
              <Interface/>
            </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
get-sessions
This operation retrieves information about all NETCONF sessions in the system. You cannot specify a session ID to retrieve information about a specific NETCONF session.
XML example
# Retrieve information about all NETCONF sessions in the system.
<get-sessions/>
</rpc>
Other operations
action
This operation issues actions for non-default settings, for example, reset action.
XML example
# Clear statistics information for all interfaces.
  <action>
    <top xmlns="http://www.h3c.com/netconf/action:1.0">
      <Ifmgr>
        <ClearAllIfStatistics>
                <Clear>
                </Clear>
        </ClearAllIfStatistics>
      </Ifmgr>
    </top>
  </action>
</rpc>
close-session
This operation terminates the current NETCONF session, unlock the configuration, and release the resources (for example, memory) used by the session. After this operation, you exit the XML view.
XML example
# Terminate the current NETCONF session.
<close-session/>
</rpc>
kill-session
This operation terminates the NETCONF session for another user. This operation cannot terminate the NETCONF session for the current user.
XML example
# Terminate the NETCONF session with session ID 1.
  <kill-session>
    <session-id>1</session-id>
  </kill-session>
</rpc>
load
This operation loads the configuration. After the device finishes a <load> operation, the configuration in the specified file is merged into the current configuration of the device.
XML example
# Merge the configuration in file a1.cfg to the current configuration of the device.
  <load>
    <file>a1.cfg</file>
  </load>
</rpc>
lock
This operation locks the configuration. After the configuration is locked, you cannot perform <edit-config> operations. Other operations are allowed.
After a user locks the configuration, other users cannot use NETCONF or any other configuration methods such as CLI and SNMP to configure the device.
XML example
 <lock>
    <target>
        <running/>
    </target>
</lock>
</rpc>
rollback
This operation rolls back the configuration. To do so, you must specify the configuration file in the <file> element. After the device finishes the <rollback> operation, the current device configuration is totally replaced with the configuration in the specified configuration file.
XML example
# Roll back the current configuration to the configuration in file 1A.cfg.
  <rollback>
    <file>1A.cfg</file>
  </rollback>
</rpc>
save
This operation saves the running configuration. You can use the <file> element to specify a file for saving the configuration. If the text does not include the file column, the running configuration is automatically saved to the main next-startup configuration file.
The OverWrite attribute determines whether the current configuration overwrites the original configuration file when the specified file already exists.
The Safely attribute determines whether to save the configuration file in safe mode or fast mode.
XML example
# Save the running configuration to file test.cfg.
    <file>test.cfg</file>
  </save>
</rpc>
unlock
This operation unlocks the configuration, so other users can configure the device.
Terminating a NETCONF session automatically unlocks the configuration.
XML example
# Unlock the configuration.
<unlock>
    <target>
        <running/>
    </target>
</unlock>
</rpc>
