01-ACL commands | 410.56 KB |
acl resource threshold percent
display packet-filter statistics
display packet-filter statistics sum
packet-filter default hardware-count
ACL commands
acl
Use acl to create an ACL and enter its view, or enter the view of an existing ACL.
Use undo acl to delete the specified or all ACLs.
acl [ ipv6 ] { advanced | basic } { acl-number | name acl-name } [ match-order { auto | config } ]
acl mac { acl-number | name acl-name } [ match-order { auto | config } ]
undo acl [ ipv6 ] { all | { advanced | basic } { acl-number | name acl-name } }
undo acl mac { all | acl-number | name acl-name }
No ACLs exist.
ipv6: Specifies the IPv6 ACL type. To specify the IPv4 ACL type, do not use this keyword.
basic: Specifies the basic ACL type.
advanced: Specifies the advanced ACL type.
mac: Specifies the Layer 2 ACL type.
acl-number: Assigns a number to the ACL. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
· 4000 to 4999 for Layer 2 ACLs.
name acl-name: Assigns a name to the ACL. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
match-order: Specifies the order in which ACL rules are compared against packets.
· auto: Compares ACL rules in depth-first order.
· config: Compares ACL rules in ascending order of rule ID. The rule with a smaller ID has a higher priority. If you do not specify a match order, the config order applies by default.
all: Specifies all ACLs of the specified type.
You can change the match order only for ACLs that do not contain any rules.
# Create IPv4 basic ACL 2000 and enter its view.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000]
# Create IPv4 basic ACL flow and enter its view.
[Sysname] acl basic name flow
[Sysname-acl-ipv4-basic-flow]
# Create IPv4 advanced ACL 3000 and enter its view.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000]
# Create IPv6 basic ACL 2000 and enter its view.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000]
# Create IPv6 basic ACL flow and enter its view.
[Sysname] acl ipv6 basic name flow
[Sysname-acl-ipv6-basic-flow]
# Create IPv6 advanced ACL abc and enter its view.
[Sysname] acl ipv6 advanced name abc
[Sysname-acl-ipv6-adv-abc]
# Create Layer 2 ACL 4000 and enter its view.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000]
# Create Layer 2 ACL flow and enter its view.
[Sysname] acl mac name flow
[Sysname-acl-mac-flow]
display acl
acl copy
Use acl copy to create an ACL by copying an ACL that already exists.
acl [ ipv6 | mac ] copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
source-acl-number: Specifies an existing source ACL by its number. The following are available value ranges:
name source-acl-name: Specifies an existing source ACL by its name. The source-acl-name argument is a case-insensitive string of 1 to 63 characters.
dest-acl-number: Assigns a unique number to the new ACL. The following are available value ranges:
name dest-acl-name: Assigns a unique name to the new ACL. The dest-acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
The new ACL and the source ACL must be the same type.
The new ACL has the same properties and content as the source ACL, but uses a different number or name from the source ACL.
To specify the IPv4 ACL type, do not specify the ipv6 or mac keyword.
# Create IPv4 basic ACL 2002 by copying IPv4 basic ACL 2001.
[Sysname] acl copy 2001 to 2002
# Create IPv4 basic ACL paste by copying IPv4 basic ACL test.
[Sysname] acl copy name test to name paste
acl logging interval
Use acl logging interval to enable logging for packet filtering and set the interval.
Use undo acl logging interval to restore the default.
acl logging interval interval
The interval is 0. The device does not generate log entries for packet filtering.
interval: Specifies the interval at which log entries are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable the logging, set the value to 0.
The logging feature is available for IPv4 and IPv6 ACL rules that have the logging keyword.
The device generates log entries for packet filtering and output them to the information center at the output interval. The log entry records the number of matching packets and the matched ACL rules. Additionally, the first packet of a flow is recorded and sent to the information center. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering log entries every 10 minutes.
[Sysname] acl logging interval 10
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
acl resource log interval
Use acl resource log interval to set the interval for checking the ternary content addressable memory (TCAM) usage.
Use undo acl resource log interval to restore the default.
acl resource log interval interval
The device checks the TCAM usage every 5 minutes.
interval interval: Specifies the check interval in the range of 1 to 60 minutes.
The device checks the TCAM usage regularly. If the usage reaches or exceeds the threshold, the device sends a log message and a trap.
# Set the TCAM usage check interval to 10 minutes.
[Sysname] acl resource log interval 10
Use acl resource threshold percent to set the TCAM usage alarm threshold.
Use undo acl resource threshold percent to restore the default.
acl resource threshold percent percent
The TCAM usage alarm threshold is 0. TCAM usage alarm is disabled.
percent: Specifies the threshold in percentage in the range of 1 to 100.
The device checks the TCAM usage regularly. If the usage reaches or exceeds the threshold, the device sends a log message and a trap. If you change the threshold, the device restarts the TCAM usage check from the time the threshold is changed.
# Set the TCAM usage alarm threshold to 50%.
[Sysname] acl resource threshold percent 50
acl trap interval
Use acl trap interval to enable SNMP notifications for packet filtering and set the interval.
Use undo acl interval to restore the default.
acl trap interval interval
undo acl trap interval
The interval is 0. The device does not generate SNMP notifications for packet filtering.
interval: Specifies the interval at which SNMP notifications are generated and output. It must be a multiple of 5, in the range of 0 to 1440 minutes. To disable SNMP notifications, set the value to 0.
The SNMP notifications feature is available for IPv4 and IPv6 ACL rules that have the logging keyword.
The device generates SNMP notifications for packet filtering and output them to the SNMP module at the output interval. The notification records the number of matching packets and the matched ACL rules. Additionally, the first packet of a flow is recorded and sent to the SNMP module. For more information about SNMP, see Network Management and Monitoring Configuration Guide.
# Configure the device to generate and output packet filtering SNMP notifications every 10 minutes.
[Sysname] acl trap interval 10
acl whitelist
Use acl whitelist to configure an ACL whitelist.
Use undo acl whitelist to delete an ACL whitelist.
acl whitelist [ ipv6 | mac ] { acl-number | name acl-name }
undo acl whitelist [ ipv6 | mac ]
No ACL whitelist is configured.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, an IPv4 ACL is specified.
mac: Specifies a Layer 2 ACL. If you do not specify this keyword, an IPv4 ACL is specified.
acl-number: Specifies an ACL by its number in the range of 3000 to 3999 for IPv4 and IPv6 advanced ACLs and in the range of 4000 to 4999 for Layer 2 ACLs.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
Application scenarios
You can configure an IPv4 or IPv6 advanced ACL whitelist for network layer protocols and transport layer protocols, such as BGP. You can configure a Layer 2 ACL whitelist for link layer protocols, such as ARP/ND.
Operating mechanism
The following types of traffic to the control plane exist:
· Traffic matching the ACL whitelist—The device preferentially sends this type of traffic to the control plane through a dedicated protocol queue. The device uses a system-defined, fixed rate limit to police the traffic to the control plane. By default, ACL whitelist-based traffic policing is enabled.
· Traffic not matching the ACL whitelist—The device sends this type of traffic to the control plane through a data queue. You can configure traffic policing for this type of traffic by using the qos car command in control plane view. For the configuration commands, see QoS commands.
An ACL whitelist can be configured by using the acl whitelist command or dynamically generated based on the TCP connection or other protocol sessions. A dynamic ACL whitelist contains rules to match traffic. For example, the device will generate an ACL whitelist based on the BGP session address when establishing a session with a BGP peer.
You can use the display acl whitelist command to display the rules contained in a dynamic ACL whitelist.
# Configure ACL 3001 as a static ACL whitelist.
[Sysname] acl whitelist 3001
qos car (control plane view)
qos car whitelist enable
description
Use description to configure a description for an ACL.
Use undo description to delete an ACL description.
An ACL does not have a description.
IPv4 basic ACL view
IPv6 basic ACL view
Layer 2 ACL view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure a description for IPv4 basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] description This is an IPv4 basic ACL.
display acl
display acl
Use display acl to display ACL configuration and match statistics.
display acl [ ipv6 | mac ] { acl-number | all | name acl-name }
acl-number: Specifies an ACL by its number. The following are available value ranges:
This command displays ACL rules in config or auto order, whichever is configured.
# Display configuration and match statistics for IPv4 basic ACL 2001.
<Sysname> display acl 2001
Basic IPv4 ACL 2001, 2 rules, match-order is auto,
ACL's step is 5
rule 5 permit source 1.1.1.1 0 (5 times matched)
rule 5 comment This rule is used on Ten-GigabitEthernet0/0/15.
rule 10 permit source object-group permit (5 times matched)
Basic IPv4 ACL 2001 |
Type and number of the ACL. The following field information is about IPv4 basic ACL 2000. |
2 rules |
The ACL contains two rules. |
match-order is auto |
The match order for the ACL is auto, which sorts ACL rules in depth-first order. This field is not displayed when the match order is config. |
This is an IPv4 basic ACL. |
Description of the ACL. |
ACL's step is 5 |
The rule numbering step is 5. |
rule 5 permit source 1.1.1.1 0 |
Content of rule 5. The rule permits packets sourced from the IP address 1.1.1.1. |
rule 10 permit source object-group permit |
Content of rule 10. The rule permits packets sourced from the object group permit. |
5 times matched |
The rule has been matched five times. Only matches performed in software are counted. This field is not displayed when no packets matched the rule. |
rule 5 comment This rule is used on Ten-GigabitEthernet0/0/15. |
Comment of rule 5. |
Use display acl whitelist to display ACL rules in the ACL whitelist.
In standalone mode:
display acl whitelist [ ipv6 | mac ] slot slot-number
In IRF mode:
display acl whitelist [ ipv6 | mac ] chassis chassis-number slot slot-number
ipv6: Specifies the IPv6 ACL whitelist. If you do not specify this keyword, the command displays ACL rules in the IPv4 ACL whitelist.
mac: Specifies the Layer 2 ACL whitelist. If you do not specify this keyword, the command displays ACL rules in the IPv4 ACL whitelist.
slot slot-number: Specifies a card by its slot number. On this device, the slot-number argument represents the entire device and its value is fixed. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. On this device, the slot-number argument represents the entire device and its value is fixed. (In IRF mode.)
For ACL whitelist-based traffic policing, the system dynamically generates a whitelist according to existing TCP connections or other protocol sessions. The whitelist contains ACL rules used to match traffic. For information about the configuration command for whitelist-based traffic policing, see the qos car (control plane view) command in QoS commands.
# (In standalone mode.) Display ACL rules in the IPv4 dynamic whitelist for slot 2.
<Sysname> display acl whitelist slot 0
IPv4 ACL Whitelist, 2 rules
rule 2 permit tcp source 2.2.2.1 0 destination 2.2.2.2 0 source-port eq bgp destination-port eq 56197(static)
rule 65536 permit tcp source 1.1.1.1 0 destination 1.1.1.2 0 source-port eq bgp destination-port eq 56197(dynamic)
display qos car control-plane whitelist
Use display packet-filter to display ACL application information for packet filtering.
In standalone mode:
display packet-filter { { global | interface [ interface-type interface-number ] } [ inbound | outbound ] } [ slot slot-number ]
In IRF mode:
display packet-filter { { global | interface [ interface-type interface-number ] } [ inbound | outbound ] } [ chassis chassis-number slot slot-number ]
global: Specifies all physical interfaces.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command displays ACL application information for packet filtering on all interfaces.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ACL application information for packet filtering for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ACL application information for packet filtering for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If neither the inbound keyword nor the outbound keyword is specified, this command displays ACL application information for interface- or VLAN-based packet filtering in both directions.
The slot slot-number and chassis chassis-number slot slot-number options are supported only when you specify a logical interface to display ACL application information for packet filtering.
# Display ACL application information for inbound packet filtering on interface Ten-GigabitEthernet 0/0/15.
<Sysname> display packet-filter interface ten-gigabitethernet 0/0/15 inbound
Interface: Ten-GigabitEthernet0/0/15
Inbound policy:
IPv4 ACL 2001, Share-mode
IPv6 ACL 2002
MAC ACL 4003, Hardware-count
IPv4 ACL 2004, Hardware-count
IPv4 default action: Deny, Hardware-count
# Display ACL application information for inbound and outbound packet filtering on all physical interfaces.
<Sysname> display packet-filter global
Global:
Inbound policy:
IPv4 ACL 2001
IPv6 ACL 2001
MAC ACL 4001
IPv6 default action: Deny
MAC default action: Deny
Outbound policy:
MAC ACL 4001, Hardware-count
Interface to which the ACL applies. |
Global |
ACL application for packet filtering on all physical interfaces. |
Inbound policy |
ACL used for filtering incoming traffic. |
Outbound policy |
ACL used for filtering outgoing traffic. |
IPv4 ACL 2001 |
IPv4 basic ACL 2001 has been successfully applied. |
Share-mode |
Sharing mode for QoS and ACL resources. This field appears in the command output only if an ACL is applied with the share-mode keyword. |
Share-mode-both |
Direction-independent sharing mode for QoS and ACL resources. This field appears in the command output only if an ACL is applied with the share-mode-both keyword. |
Hardware-count |
ACL rule match counting in hardware has been successfully enabled. |
IPv4 default action |
Packet filter default action for packets that do not match any IPv4 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. |
IPv6 default action |
Packet filter default action for packets that do not match any IPv6 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. |
MAC default action |
Packet filter default action for packets that do not match any Layer 2 ACLs: · Deny—The default action deny has been successfully applied for packet filtering. · Permit—The default action permit has been successfully applied for packet filtering. · Hardware-count—The hardware-count feature has been successfully applied for the default action for packet filtering. |
Use display packet-filter statistics to display packet filtering statistics.
In standalone mode:
display packet-filter statistics { { global | interface interface-type interface-number } { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] } [ brief ] [ slot slot-number ]
In IRF mode:
display packet-filter statistics { { global | interface interface-type interface-number } { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] } [ brief ] [ chassis chassis-number slot slot-number ]
global: Displays the statistics for all physical interfaces.
default: Displays the default action statistics for packet filtering.
brief: Displays brief statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays packet filtering statistics on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays packet filtering statistics on all cards in the IRF fabric. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If you do not specify any parameters, this command displays packet filtering statistics for all ACLs.
The slot slot-number and chassis chassis-number slot slot-number options are supported only when you specify a logical interface to display packet filtering statistics.
# Display packet filtering statistics for all ACLs on incoming packets of Ten-GigabitEthernet 0/0/15.
<Sysname> display packet-filter statistics interface ten-gigabitethernet 0/0/15 inbound
Inbound policy:
IPv4 ACL 2001, Hardware-count
From 2011-06-04 10:25:21 to 2011-06-04 10:35:57
rule 0 permit source 2.2.2.2 0 (2 packets)
rule 10 permit vpn-instance test (No resource)
Totally 2 packets permitted, 0 packets denied
Totally 100% permitted, 0% denied
IPv6 ACL 2000
MAC ACL 4000
From 2011-06-04 10:25:34 to 2011-06-04 10:35:57
rule 0 permit
Totally 7 packets
IPv6 default action: Deny, Hardware-count
From 2011-06-04 10:25:41 to 2011-06-04 10:35:57
Totally 0 packets
MAC default action: Deny, Hardware-count
Totally 0 packets
# Display packet filtering statistics for all ACLs on incoming packets of VLAN-interface 1 in slot 0.
<Sysname> display packet-filter statistics interface vlan-interface 1 inbound slot 0
Interface: Vlan-interface1
Inbound policy:
rule 0 permit source 2.2.2.2 0 (20 packets)
rule 5 permit source 1.1.1.1 0 (50 packets)
rule 10 permit vpn-instance test (30 packets)
Totally 100 packets permitted, 0 packets denied
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
Hardware-count |
From 2011-06-04 10:25:21 to 2011-06-04 10:35:57 |
Start time and end time of the statistics. The start time is the time when the packet filter was deployed to the card. |
2 packets |
Two packets matched the rule. This field is not displayed when no packets matched the rule. |
No resource |
Resources are not enough for counting matches for the rule. In packet filtering statistics, this field is displayed for a rule when resources are not sufficient for rule match counting. |
Totally 2 packets permitted, 0 packets denied |
Number of packets permitted and denied by the ACL. |
Totally 100% permitted, 0% denied |
Ratios of permitted and denied packets to all packets. |
Totally 7 packets |
The default action has been executed on seven packets. |
reset packet-filter statistics
Use display packet-filter statistics sum to display accumulated packet filtering statistics for an ACL.
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac ] { acl-number | name acl-name } [ brief ]
# Display accumulated packet filtering statistics for IPv4 basic ACL 2001 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2001
Sum:
Inbound policy:
IPv4 ACL 2001
# Display brief accumulated packet filtering statistics for IPv4 basic ACL 2000 on incoming packets.
<Sysname> display packet-filter statistics sum inbound 2000 brief
Sum:
Inbound policy:
IPv4 ACL 2000
Sum |
Accumulated packet filtering statistics. |
Inbound policy |
Accumulated packet filtering statistics in the inbound direction. |
Outbound policy |
Accumulated packet filtering statistics in the outbound direction. |
IPv4 ACL 2001 |
Accumulated packet filtering statistics of IPv4 basic ACL 2001. |
2 packets |
display packet-filter verbose
Use display packet-filter verbose to display ACL application details for packet filtering.
In standalone mode:
display packet-filter verbose { { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ] } [ slot slot-number ]
In IRF mode:
display packet-filter verbose { { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac ] { acl-number | name acl-name } ] } [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. The chassis chassis-number and slot slot-number options are not available for an Ethernet interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ACL application details for packet filtering for the active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ACL application details for packet filtering for the global active MPU. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
If acl-number, name acl-name, ipv6, or mac is not specified, this command displays application details of all ACLs for packet filtering.
The slot slot-number and chassis chassis-number slot slot-number options are supported only when you specify a logical interface to display ACL application details for packet filtering.
# Display application details of all ACLs for inbound packet filtering on Ten-GigabitEthernet 0/0/15.
<Sysname> display packet-filter verbose interface ten-gigabitethernet 0/0/15 inbound
Inbound policy:
rule 0 permit
IPv4 ACL 2002 (Failed), Hardware-count
IPv6 ACL 2000, Hardware-count
rule 0 permit
MAC ACL 4000, Hardware-count
# Display application details of all ACLs for inbound packet filtering on all physical interfaces.
<Sysname> display packet-filter verbose global inbound
Global:
Inbound policy:
IPv4 ACL 2001
rule 0 permit
rule 5 permit source 1.1.1.1 0 (Failed)
rule 10 permit vpn-instance test (Failed)
rule 0 permit
Table 5 Command output
Global |
ACL application details for packet filtering on all physical interfaces. |
Inbound policy |
Outbound policy |
IPv4 ACL 2001 |
IPv4 ACL 2002 (Failed) |
The device has failed to apply IPv4 basic ACL 2002. |
Hardware-count |
display qos-acl resource
Use display qos-acl resource to display QoS and ACL resource usage.
In standalone mode:
display qos-acl resource [ slot slot-number ]
In IRF mode:
display qos-acl resource [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ACL QoS and ACL resource usage on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays QoS and ACL resource usage on all cards. On this device, the slot-number argument represents the entire device and its value is fixed. This command applies to the entire device regardless of whether the slot-number argument is specified. (In IRF mode.)
This command does not display any usage data if the specified card does not support counting QoS and ACL resources.
# Display QoS and ACL resource usage.
<Sysname> display qos-acl resource
Interfaces: XGE0/0/15 to XGE0/0/24 (slot 0)
Type Total Reserved Configured Remaining Usage
IPv4Acl 102400 0 70 102330 0%
IPv6Acl 32768 0 7 32761 0%
CAR&Cnt 131072 0 1 131071 0%
InBRAS Stat 65534 0 0 65534 0%
InL2TP Stat 65535 0 0 65535 0%
EgBRAS Stat 65534 0 0 65534 0%
EgL2TP Stat 65535 0 0 65535 0%
IngSubIf Stat 65536 0 0 63536 3%
EgSubIf Stat 65536 0 0 63536 3%
CAR Prof 500 0 1 499 0%
BRAS Prof 336 0 0 336 0%
Sampler 131072 1 0 131071 0%
INQPPB 32768 0 0 32768 0%
Table 6 Command output
Interfaces |
Interface range for the resources. |
Type |
Resource type: · IPv4Acl—IPv4 ACL rule resources. · IPv6Acl—IPv6 ACL rule resources. · Car&Cnt—Counter resources used by ACL resources. · InBRAS Stat—Inbound BRAS counter resources. · OutBRAS Stat—Outbound BRAS counter resources. · TCPCar—TCP connection counter resources. · Car Prof—Rate limit template resources. · Sampler—Sampler counter resources. · InL2TP Stat—Inbound counter resources for L2TP users. · EgBRAS Stat—Outbound BRAS counter resources. · EgL2TP Stat—Outbound counter resources for L2TP users. · IngSubIf Stat—Inbound counter resources for subinterface packet statistics collection and Layer 3 packet statistics collection. · EgSubIf Stat—Outbound counter resources for subinterface packet statistics collection and Layer 3 packet statistics collection. · BRAS Prof—User template resources. · INQPPB—Inbound QPPB entry resources. |
Total |
Total number of resources. |
Reserved |
Number of reserved resources. |
Configured |
Number of resources that has been applied. |
Remaining |
Number of resources that you can apply. |
Usage |
Configured and reserved resources as a percentage of total resources. If the percentage is not an integer, this field displays the integer part. For example, if the actual usage is 50.8%, this field displays 50%. |
packet-filter
Use packet-filter to apply an ACL to an interface to filter packets.
Use undo packet-filter to remove an ACL from an interface.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ] [ share-mode | share-mode-both ]
undo packet-filter [ ipv6 | mac ] { acl-number | name acl-name } { inbound | outbound }
No ACL is applied to an interface to filter packets.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
FlexE service interface view
VLAN interface view
Tunnel interface view
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
hardware-count: Enables counting ACL rule matches performed in hardware. If you do not specify this keyword, rule matches for the ACL are not counted in hardware.
share-mode: Applies the ACL in sharing mode. By default, an ACL is applied in non-sharing mode.
share-mode-both: Applies the ACL in direction-independent sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces on an interface card with the same ACL applied share one QoS and ACL resource.
When you reference an ACL, follow these restrictions and guidelines:
· If the ACL does not exist or contains no rules, it is not used to filter packets.
· If the vpn-instance vpn-instance-name option is specified in an ACL rule, the rule takes effect only on VPN packets. If the vpn-instance vpn-instance-name option is not specified in an ACL rule, the rule takes effect on both VPN packets and non-VPN packets.
The hardware-count keyword in this command enables match counting for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules.
To disable ACL rule match counting in hardware when resources are insufficient, you must execute the undo packet-filter command and then reconfigure the packet-filter command without specifying the hardware-count keyword.
To disable ACL rule match counting in hardware when resources are sufficient, you can directly reconfigure the packet-filter command without specifying the hardware-count keyword.
If you specify the share-mode or share-mode-both keyword when applying an ACL to an interface, follow these restrictions and guidelines:
· If you specify the share-mode keyword, all interfaces on an interface module with the ACL applied in one direction share one QoS and ACL resource. If you specify the share-mode-both keyword, all interfaces on an interface module with the ACL applied share one QoS and ACL resource.
If the share-mode or share-mode-both keyword is not specified, each interface uses one QoS and ACL resource in one direction.
· You cannot specify the share-mode or share-mode-both keyword when applying a QoS policy to the same direction of the interface. For more information about applying a QoS policy to an interface, see the qos apply policy (interface view) command in QoS policy commands.
· You can apply multiple ACLs to one direction of an interface. However, you can apply only one ACL with the share-mode keyword specified to one direction of an interface.
The display packet-filter statistics command output for an interface also contains statistics for all interfaces that share the QoS and ACL resource with the interface.
You cannot change the sharing mode dynamically after an ACL is applied to an interface. To change the sharing mode for an applied ACL, you must remove the ACL from the interface, and then reapply the ACL with or without the share-mode or share-mode-both keyword specified.
The device cannot filter incoming packets based on the destination MAC address and cannot filter outgoing packets based on the source MAC address.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on Ten-GigabitEthernet 0/0/15, and enable counting ACL rule matches performed in hardware.
[Sysname] interface ten-gigabitethernet 0/0/15
[Sysname-Ten-GigabitEthernet0/0/15] packet-filter 2001 inbound hardware-count
# Apply IPv4 basic ACL 2001 in sharing mode to filter outgoing traffic on Ten-GigabitEthernet 0/0/15, and enable counting ACL rule matches performed in hardware.
[Sysname-Ten-GigabitEthernet0/0/15] packet-filter 2001 outbound hardware-count share-mode
# Apply IPv4 basic ACL 2001 in direction-independent sharing mode to filter outgoing traffic on Ten-GigabitEthernet 0/0/15 and incoming packets on .
[Sysname-Ten-GigabitEthernet0/0/15] packet-filter 2001 outbound share-mode-both
[Sysname] interface
[Sysname-] packet-filter 2001 inbound share-mode-both
packet-filter default deny
Use packet-filter default deny to set the packet filtering default action to deny. The packet filter denies packets that do not match any ACL rule.
Use undo packet-filter default deny to restore the default.
The packet filtering default action is permit. The packet filter permits packets that do not match any ACL rule.
The packet filter applies the default action to all ACL applications for packet filtering. The default action appears in the display command output for packet filtering.
# Set the packet filter default action to deny.
[Sysname] packet-filter default deny
Use packet-filter default hardware-count to enable hardware-count for the packet filtering default action.
Use undo packet-filter default hardware-count to disable hardware-count for the packet filtering default action.
packet-filter default { inbound | outbound } hardware-count
undo packet-filter default { inbound | outbound } hardware-count
Hardware-count is disabled for the packet filtering default action.
Interface view
inbound: Specifies the incoming packets.
outbound: Specifies the outgoing packets.
To enable hardware-count for the packet filtering default action on an interface, make sure you have applied ACLs to the interface for packet filtering.
# Set the packet filtering default action to deny. Apply IPv4 basic ACL 2001 to Ten-GigabitEthernet 0/0/15 for filtering incoming packets, and enable hardware-count for the packet filtering default action on Ten-GigabitEthernet 0/0/15.
[Sysname-Ten-GigabitEthernet0/0/15] packet-filter default inbound hardware-count
packet-filter
Use packet-filter global to apply an ACL to filter packets globally.
Use undo packet-filter global to remove an ACL for global packet filtering.
packet-filter [ ipv6 | mac ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ]
undo packet-filter [ ipv6 | mac ] { acl-number | name acl-name } global { inbound | outbound }
No ACL is applied to filter packets globally.
# Apply IPv4 basic ACL 2001 to filter incoming traffic on all physical interfaces, and enable counting ACL rule matches performed in hardware.
[Sysname] packet-filter 2001 global inbound hardware-count
reset acl counter
Use reset acl counter to clear statistics for ACLs.
reset acl [ ipv6 | mac ] counter { acl-number | all | name acl-name }
all: Clears statistics for all ACLs of the specified type.
name acl-name: Clears statistics of an ACL specified by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters.
# Clear statistics for IPv4 basic ACL 2001.
display acl
Use reset packet-filter statistics to clear the packet filtering statistics for an ACL.
reset packet-filter statistics { { global | interface [ interface-type interface-number ] } { inbound | outbound } [ default | [ ipv6 | mac ] { acl-number | name acl-name } ] }
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command clears packet filtering statistics for all interfaces.
default: Clears the default action statistics for packet filtering.
If default, acl-number, name acl-name, ipv6, or mac is not specified, this command clears the packet filtering statistics for all ACLs.
# Clear IPv4 basic ACL 2001 statistics for inbound packet filtering on Ten-GigabitEthernet 0/0/15.
<Sysname> reset packet-filter statistics interface ten-gigabitethernet 0/0/15 inbound 2001
Use rule to create or edit an IPv4 advanced ACL rule.
Use undo rule to delete an entire IPv4 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group address-group-name | dest-address dest-wildcard | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | { dscp dscp1 [ to dscp2 ] | { precedence precedence | tos tos } * } | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | logging | packet-length operator length-value1 [ length-value2 ] | source { object-group address-group-name | source-address source-wildcard | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | ttl operator ttl-value1 [ ttl-value2 ] | { { user-group group-name | user-group-any } | { { source-user-group source-group-name | source-user-group-any } | { destination-user-group destination-group-name | destination-user-group-any } } * } | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | { dscp | { precedence | tos } * } | fragment | icmp-type | logging | packet-length | source | source-port | time-range | { { user-group | user-group-any } | { { source-user-group | source-user-group-any } | { destination-user-group | destination-user-group-any } } * } | vpn-instance | ttl ] *
undo rule { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group address-group-name | dest-address dest-wildcard | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | { dscp dscp1 [ to dscp2 ] | { precedence precedence | tos tos } * } | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | logging | packet-length operator length-value1 [ length-value2 ] | source { object-group address-group-name | source-address source-wildcard | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | ttl operator ttl-value1 [ ttl-value2 ] | { { user-group group-name | user-group-any } | { { source-user-group source-group-name | source-user-group-any } | { destination-user-group destination-group-name | destination-user-group-any } } * } | vpn-instance vpn-instance-name ] *
No IPv4 advanced ACL rules exist.
rule-id: Specifies a rule ID in the range of 0 to 65534. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from 5. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Denies matching packets to pass.
permit: Allows matching packets to pass.
protocol: Specifies one of the following values:
· A protocol number in the range of 0 to 255.
· A protocol by its name: gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), or udp (17). The ip keyword specifies all protocols.
Table 7 describes the parameters that you can specify regardless of the value for the protocol argument.
Table 7 Match criteria and other rule information for IPv4 advanced ACL rules
Parameters |
Function |
Specifies source IPv4 addresses. |
The address-group-name argument specifies an object group of source IPv4 addresses. The source-address source-wildcard arguments specify a source IPv4 address and a wildcard mask in dotted decimal notation. An all-zero wildcard mask represents a host address. The any keyword specifies any source IPv4 addresses. |
Specifies destination IPv4 addresses. |
The address-group-name argument specifies an object group of destination IPv4 addresses. The dest-address dest-wildcard arguments specify a destination IPv4 address and a wildcard mask in dotted decimal notation. An all-zero wildcard mask represents a host address. The any keyword represents any destination IPv4 addresses. |
counting |
Counts the times that the rule is matched. |
The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting in hardware for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted. |
Specifies an IP precedence value. |
The precedence argument can be a number in the range of 0 to 7, or in words: routine (0), priority (1), immediate (2), flash (3), flash-override (4), critical (5), internet (6), or network (7). |
tos tos |
Specifies a ToS preference. |
The tos argument can be a number in the range of 0 to 15, or in words: max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0). |
Specifies a DSCP priority. |
The DSCP value can be a number in the range of 0 to 63, or in words: af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46). The to dscp2 option is used to specify a DSCP value range. The value for the dscp2 argument must be greater than or equal to the value for the dscp1 argument. |
fragment |
It applies the rule only to fragments. |
If you do not specify this keyword, the rule applies to all fragments and non-fragments. |
logging |
Logs matching packets. |
This feature requires that the module (for example, packet filtering) that uses the ACL supports logging. |
Matches the packet length in the Total Length field in the IPv4 packet header. |
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range). The length-value1 and length-value2 arguments are packet length values in the range of 0 to 65535 bytes. The length-value2 argument is needed only when the operator argument is range. |
Specifies a time range for the rule. |
The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule. However, the rule using the time range can take effect only after you configure the time range. For more information about time range, see ACL and QoS Configuration Guide. |
Matches the TTL in the Time to Live field in the IPv4 packet header. |
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range). The ttl-value1 and ttl-value2 arguments are TTL values in the range of 1 to 255. The ttl-value2 argument is needed only when the operator argument is range. |
Matches packets from or to users in a user group. |
The group-name argument represents the user group name, a case-insensitive string of 1 to 32 characters. For more information about user groups, see AAA in BRAS Services Configuration Guide. This option can be used on the input interface to match the packets sent from users in a user group. This option can be used on the output interface to match the packets sent to users in a user group. This option takes effect only in ACLs used by QoS policy, packet filtering, and policy-based routing. This option takes effect on PPPoE, IPoE, and L2TP online users. |
user-group-any |
Matches packets from or to users in any user group. |
This option takes effect only in ACLs used by QoS policy, packet filtering, and policy-based routing. This option can be used on the input interface to match the packets sent from users in any user group. This option can be used on the output interface to match the packets sent to users in any user group. This option takes effect on PPPoE, IPoE, and L2TP online users. |
Matches packets from users in a user group. |
The source-group-name argument represents the user group name, a case-insensitive string of 1 to 32 characters. For more information about user groups, see AAA in BRAS Services Configuration Guide. This option can be used on the input or output interface to match the packets sent from users in a user group. This option takes effect only in ACLs used by QoS policy, packet filtering, and policy-based routing. This option takes effect on PPPoE, IPoE, and L2TP online users. |
source-user-group-any |
Matches packets from users in any user group. |
Matches packets to users in a user group. |
The destination-group-name argument represents the user group name, a case-insensitive string of 1 to 32 characters. For more information about user groups, see AAA in BRAS Services Configuration Guide. This option can be used on the input or output interface to match the packets sent to users in a user group. This option takes effect only in ACLs used by QoS policy, packet filtering, and policy-based routing. This option does not take effect in the inbound direction of interfaces. This option takes effect on PPPoE, IPoE, and L2TP online users. |
destination-user-group-any |
Matches packets to users in any user group. |
vpn-instance vpn-instance-name |
Applies the rule to an MPLS L3VPN instance. |
The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. For an ACL used to filter packets, if you do not specify a VPN instance, the rule applies to both non-VPN packets and VPN packets. For an ACL used by other features, if you do not specify a VPN instance, the implementation varies by feature. For more information, see the configuration guide of the feature. |
If the protocol argument is tcp (6) or udp (17), set the parameters shown in Table 8.
Table 8 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
Specifies UDP or TCP source ports. |
The port-group-name argument specifies an object group of ports. The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range). The port1 and port2 arguments are TCP or UDP port numbers in the range of 0 to 65535. The port2 argument is needed only when the operator argument is range. TCP port numbers can be represented as: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), dns (53), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80). UDP port numbers can be represented as: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177). |
Specifies UDP or TCP destination ports. |
Specifies TCP flags including ACK, FIN, PSH, RST, SYN, and URG. |
Parameters specific to TCP. The value for each argument can be 0 (flag bit not set) or 1 (flag bit set). The TCP flags in a rule are ANDed. For example, a rule configured with ack 0 psh 1 matches packets that have the ACK flag bit not set and the PSH flag bit set. |
established |
Specifies the flags for indicating the established status of a TCP connection. |
Parameter specific to TCP. The rule matches TCP connection packets with the ACK or RST flag bit set. |
If the protocol argument is icmp (1), set the parameters shown in Table 9.
Table 9 ICMP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
icmp-type { icmp-type icmp-code | icmp-message } |
Specifies the ICMP message type and code. |
The icmp-type argument is in the range of 0 to 255. The icmp-code argument is in the range of 0 to 255. The icmp-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 10. |
Table 10 ICMP message names supported in IPv4 advanced ACL rules
ICMP message name |
ICMP message type |
ICMP message code |
echo |
8 |
0 |
echo-reply |
0 |
0 |
fragmentneed-DFset |
3 |
4 |
host-redirect |
5 |
1 |
host-tos-redirect |
5 |
3 |
host-unreachable |
3 |
1 |
information-reply |
16 |
0 |
information-request |
15 |
0 |
net-redirect |
5 |
0 |
net-tos-redirect |
5 |
2 |
net-unreachable |
3 |
0 |
parameter-problem |
12 |
0 |
port-unreachable |
3 |
3 |
protocol-unreachable |
3 |
2 |
reassembly-timeout |
11 |
1 |
source-quench |
4 |
0 |
source-route-failed |
3 |
5 |
timestamp-reply |
14 |
0 |
timestamp-request |
13 |
0 |
ttl-exceeded |
11 |
0 |
Within an ACL, the permit or deny statement of each rule must be unique. If the rule you are creating or editing has the same deny or permit statement as another rule in the ACL, the rule will not be created or changed.
The object group you specify when creating or editing a rule must already exist. Otherwise, the rule will not be created or changed.
As a best practice, specify only one object group in a rule. If you specify multiple object groups in a rule, include no more than 64 address objects in each object group.
You can edit ACL rules only when the match order is config.
The counting keyword in this command enables match counting specific to rules, and the hardware-count keyword in the packet-filter command enables match counting for all rules in an ACL.
To view the existing IPv4 basic and advanced ACL rules, use the display acl all command.
The undo rule rule-id command without any optional parameters deletes an entire rule. If you specify optional parameters, the undo rule rule-id command deletes the specified attributes for the rule.
The undo rule { deny | permit } command can only be used to delete an entire rule. You must specify all the attributes of the rule for the command.
# Create an IPv4 advanced ACL rule to permit TCP packets with the destination port 80 from 129.9.0.0/16 to 202.38.160.0/24.
[Sysname-acl-ipv4-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80
# Create IPv4 advanced ACL rules to permit all IP packets but the ICMP packets destined for 192.168.1.0/24.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule deny icmp destination 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] rule permit ip
# Create IPv4 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl advanced 3002
[Sysname-acl-ipv4-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-ipv4-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-ipv4-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-ipv4-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv4 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl advanced 3003
[Sysname-acl-ipv4-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-ipv4-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-ipv4-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-ipv4-adv-3003] rule permit udp destination-port eq snmptrap
# Create an IPv4 advanced ACL rule to permit IP packets from users in the user group users.
[Sysname] acl advanced 3004
[Sysname-acl-ipv4-adv-3004] rule permit ip user-group users
# Create an IPv4 advanced ACL rule to permit IP packets from any user group.
[Sysname] acl advanced 3005
[Sysname-acl-ipv4-adv-3005] rule permit ip user-group-any
# Create an IPv4 advanced ACL rule to permit UDP packets with TTL value100.
[Sysname] acl advanced 3007
[Sysname-acl-adv-3007] rule permit udp ttl eq 100
acl
display acl
step
time-range
Use rule to create or edit an IPv4 basic ACL rule.
Use undo rule to delete an entire IPv4 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | source { object-group address-group-name | source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ counting | fragment | logging | source | time-range | vpn-instance ] *
undo rule { deny | permit } [ counting | fragment | logging | source { object-group address-group-name | source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv4 basic ACL rules exist.
IPv4 basic ACL view
counting: Counts the times that the rule is matched. If you do not specify this keyword, matches for the rule are not counted.
fragment: Applies the rule only to fragments. If you do not specify this keyword, the rule applies to both fragments and non-fragments.
logging: Logs matching packets. This feature is available only when the application module (for example, packet filtering) that uses the ACL supports the logging feature.
source { object-group address-group-name | source-address source-wildcard | any }: Matches source IPv4 addresses. The object-group address-group-name option specifies an object group of source IPv4 addresses. The source-address and source-wildcard arguments specify a source IPv4 address and a wildcard mask in dotted decimal notation. A wildcard mask of all zeros represents a host address. The any keyword represents any source IPv4 addresses.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule. However, the rule using the time range can take effect only after you configure the time range. For more information about time range, see ACL and QoS Configuration Guide.
vpn-instance vpn-instance-name: Applies the rule to an MPLS L3VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. For an ACL used to filter packets, if you do not specify a VPN instance, the rule applies to both non-VPN packets and VPN packets. For an ACL used by other features, if you do not specify a VPN instance, the implementation varies by feature. For more information, see the configuration guide of the feature.
The undo rule rule-id command without any optional parameters deletes an entire rule. If you specify optional parameters, the undo rule rule-id command deletes the specified attributes for a rule.
# Create a rule in IPv4 basic ACL 2000 to deny the packets from any source IP subnet but 10.0.0.0/8, 172.17.0.0/16, or 192.168.1.0/24.
[Sysname-acl-ipv4-basic-2000] rule permit source 10.0.0.0 0.255.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 172.17.0.0 0.0.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
acl
display acl
step
time-range
Use rule to create or edit an IPv6 advanced ACL rule.
Use undo rule to delete an entire IPv6 advanced ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group address-group-name | dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | logging | packet-length operator length-value1 [ length-value2 ] | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { object-group address-group-name | source-address source-prefix | source-address/source-prefix | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | ttl operator ttl-value1 [ ttl-value2 ] | { { user-group group-name | user-group-any } | { { source-user-group source-group-name | source-user-group-any } | { destination-user-group destination-group-name | destination-user-group-any } } * } | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | dscp | flow-label | fragment | icmp6-type | logging | packet-length | routing | hop-by-hop | source | source-port | time-range | ttl | { { user-group | user-group-any } | { { source-user-group | source-user-group-any } | { destination-user-group | destination-user-group-any } } * } | vpn-instance ] *
undo rule { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group address-group-name | dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | logging | packet-length operator length-value1 [ length-value2 ] | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { object-group address-group-name | source-address source-prefix | source-address/source-prefix | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | ttl operator ttl-value1 [ ttl-value2 ] | { { user-group group-name | user-group-any } | { { source-user-group source-group-name | source-user-group-any } | { destination-user-group destination-group-name | destination-user-group-any } } * } | vpn-instance vpn-instance-name ] *
No IPv6 advanced ACL rules exist.
· A protocol name: gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50), ospf (89), tcp (6), or udp (17). The ipv6 keyword specifies all protocols.
Table 11 describes the parameters that you can specify regardless of the value for the protocol argument.
Table 11 Match criteria and other rule information for IPv6 advanced ACL rules
Parameters |
Function |
Specifies source IPv6 addresses. |
The address-group-name argument specifies an object group of source IPv6 addresses. The source-address argument specifies an IPv6 source address. The source-prefix argument specifies a prefix length in the range of 1 to 128. The any keyword represents any IPv6 source addresses. |
Specifies destination IPv6 addresses. |
The address-group-name argument specifies an object group of destination IPv6 addresses. The dest-address argument specifies a destination IPv6 address. The dest-prefix argument specifies a prefix length in the range of 1 to 128. The any keyword represents any IPv6 destination addresses. |
counting |
The counting keyword enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting in hardware for all rules in an ACL. If the counting keyword is not specified, matches for the rule are not counted. |
dscp dscp |
Specifies a DSCP preference. |
The dscp argument can be a number in the range of 0 to 63, or in words, af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46). |
Specifies a flow label value in an IPv6 packet header. |
The flow-label-value argument is in the range of 0 to 1048575. |
fragment |
logging |
Specifies an IPv6 routing header type. |
routing-type: Value of the IPv6 routing header type, in the range of 0 to 255. If you specify the type routing-type option, the rule applies to the specified type of IPv6 routing header. If you do not specify the type routing-type option, the rule applies to all types of IPv6 routing headers. |
Specifies an IPv6 Hop-by-Hop Options header type. |
hop-type: Value of the IPv6 Hop-by-Hop Options header type, in the range of 0 to 255. If you specify the type hop-type option, the rule applies to the specified type of IPv6 Hop-by-Hop Options header. If you do not specify the type hop-type option, the rule applies to all types of IPv6 Hop-by-Hop Options header. |
The group-name argument represents the user group name, a case-insensitive string of 1 to 32 characters. For more information about user groups, see AAA in BRAS Services Configuration Guide. This option can be used on the input interface to match the packets sent from users in a user group. This option can be used on the output interface to match the packets sent to users in a user group. This option takes effect in ACLs used by QoS policy, packet filtering, and policy-based routing. This option takes effect on PPPoE, IPoE, and L2TP online users. |
user-group-any |
The destination-group-name argument represents the user group name, a case-insensitive string of 1 to 32 characters. For more information about user groups, see AAA in BRAS Services Configuration Guide. This option can be used on the input or output interface to match the packets sent to users in a user group. This option does not take effect in the inbound direction of interfaces. This option takes effect only in ACLs used by QoS policy, packet filtering, and policy-based routing. This option takes effect on PPPoE, IPoE, and L2TP online users. |
Matches the packet length, including the IPv6 basic header, IPv6 extension header, and payload. |
Matches the TTL in the Hot Limit field in the IPv6 packet header. |
If the protocol argument is tcp (6) or udp (17), set the parameters shown in Table 12.
Table 12 TCP/UDP-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
Specifies TCP flags, including ACK, FIN, PSH, RST, SYN, and URG. |
established |
If the protocol argument is icmpv6 (58), set the parameters shown in Table 13.
Table 13 ICMPv6-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
Specifies the ICMPv6 message type and code. |
The icmp6-type argument is in the range of 0 to 255. The icmp6-code argument is in the range of 0 to 255. The icmp6-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 14. |
Table 14 ICMPv6 message names supported in IPv6 advanced ACL rules
ICMPv6 message name |
ICMPv6 message type |
ICMPv6 message code |
echo-reply |
129 |
0 |
echo-request |
128 |
0 |
err-Header-field |
4 |
0 |
frag-time-exceeded |
3 |
1 |
hop-limit-exceeded |
3 |
0 |
host-admin-prohib |
1 |
1 |
host-unreachable |
1 |
3 |
neighbor-advertisement |
136 |
0 |
neighbor-solicitation |
135 |
0 |
network-unreachable |
1 |
0 |
packet-too-big |
2 |
0 |
port-unreachable |
1 |
4 |
redirect |
137 |
0 |
router-advertisement |
134 |
0 |
router-solicitation |
133 |
0 |
unknown-ipv6-opt |
4 |
2 |
unknown-next-hdr |
4 |
1 |
To view the existing IPv6 basic and advanced ACL rules, use the display acl ipv6 all command.
An IPv6 advanced ACL used to match the extension headers of IPv6 packets cannot match the IPv6 packets that have more than two extension headers or have the Encapsulating Security Payload Header.
An object group in a rule does not take effect if the object group does not contain objects.
If an IPv6 advanced ACL is for outbound QoS traffic classification or outbound packet filtering, do not specify the routing or flow-label keyword.
# Create an IPv6 advanced ACL rule to permit TCP packets with the destination port 80 from 2030:5060::/64 to FE80:5060::/96.
[Sysname-acl-ipv6-adv-3000] rule permit tcp source 2030:5060::/64 destination fe80:5060::/96 destination-port eq 80
# Create IPv6 advanced ACL rules to permit all IPv6 packets but the ICMPv6 packets destined for FE80:5060:1001::/48.
[Sysname] acl ipv6 advanced 3001
[Sysname-acl-ipv6-adv-3001] rule deny icmpv6 destination fe80:5060:1001:: 48
[Sysname-acl-ipv6-adv-3001] rule permit ipv6
# Create IPv6 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl ipv6 advanced 3002
[Sysname-acl-ipv6-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-ipv6-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-ipv6-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-ipv6-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv6 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl ipv6 advanced 3003
[Sysname-acl-ipv6-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-ipv6-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-ipv6-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-ipv6-adv-3003] rule permit udp destination-port eq snmptrap
# Create IPv6 advanced ACL 3004, and configure two rules: one permits packets with the Hop-by-Hop Options header type as 5, and the other one denies packets with other Hop-by-Hop Options header types.
[Sysname] acl ipv6 advanced 3004
[Sysname-acl-ipv6-adv-3004] rule permit ipv6 hop-by-hop type 5
[Sysname-acl-ipv6-adv-3004] rule deny ipv6 hop-by-hop
# Create an IPv6 advanced ACL rule to permit IPv6 packets from users in the user group users.
[Sysname] acl ipv6 advanced 3005
[Sysname-acl-ipv6-adv-3005] rule permit ipv6 user-group users
# Create an IPv6 advanced ACL rule to permit IPv6 packets from any user group.
[Sysname] acl ipv6 advanced 3006
[Sysname-acl-ipv6-adv-3006] rule permit ipv6 user-group-any
# Create an IPv6 advanced ACL rule to permit UDP packets with TTL value100.
[Sysname] acl ipv6 advanced 3007
[Sysname-acl-ipv6-adv-3007] rule permit udp ttl eq 100
acl
acl logging interval
display acl
step
time-range
rule (IPv6 basic ACL view)
Use rule to create or edit an IPv6 basic ACL rule.
Use undo rule to delete an entire IPv6 basic ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | routing [ type routing-type ] | source { object-group address-group-name | source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ counting | fragment | logging | routing | source | time-range | vpn-instance ] *
undo rule { deny | permit } [ counting | fragment | logging | routing [ type routing-type ] | source { object-group address-group-name | source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
No IPv6 basic ACL rules exist.
IPv6 basic ACL view
routing [ type routing-type ]: Applies the rule to the specified type of IPv6 routing header or all types of IPv6 routing headers. The routing-type argument specifies the value of the IPv6 routing header type, in the range of 0 to 255. If you do not specify the type routing-type option, the rule applies to all types of IPv6 routing headers.
source { object-group address-group-name | source-address source-prefix | source-address/source-prefix | any }: Matches source IPv6 addresses. The object-group address-group-name option specifies an object group of source IPv6 addresses. The source-address argument specifies a source IPv6 address. The source-prefix argument specifies an address prefix length in the range of 1 to 128. The any keyword represents any IPv6 source addresses.
The counting keyword in this command enables match counting specific to rules, and the hardware-count keyword in the packet-filter ipv6 command enables match counting for all rules in an ACL.
# Create an IPv6 basic ACL rule to deny the packets from any source IP subnet but 1001::/16, 3124:1123::/32, or FE80:5060:1001::/48.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 1001:: 16
[Sysname-acl-ipv6-basic-2000] rule permit source 3124:1123:: 32
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:5060:1001:: 48
[Sysname-acl-ipv6-basic-2000] rule deny source any
acl
display acl
step
time-range
rule (Layer 2 ACL view)
Use rule to create or edit a Layer 2 ACL rule.
Use undo rule to delete an entire Layer 2 ACL rule or some attributes in the rule.
rule [ rule-id ] { deny | permit } [ cos dot1p | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
undo rule rule-id [ counting | time-range ] *
undo rule { deny | permit } [ cos dot1p | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
No Layer 2 ACL rules exist.
cos dot1p: Matches an 802.1p priority. The 802.1p priority can be specified by one of the following values:
· A priority number in the range of 0 to 7.
· A priority name: best-effort (0), background (1), spare (2), excellent-effort (3), controlled-load (4), video (5), voice (6), or network-management (7).
dest-mac dest-address dest-mask: Matches a destination MAC address range. The dest-address and dest-mask arguments represent a destination MAC address and a mask in the H-H-H format.
lsap lsap-type lsap-type-mask: Matches the DSAP and SSAP fields in LLC encapsulation. The lsap-type argument is a hexadecimal number that represents the encapsulation format. The value range for the lsap-type argument is 0 to ffff. The lsap-type-mask argument is a hexadecimal number that represents the LSAP mask. The value range for the lsap-type-mask argument is 0 to ffff. This option is not supported in the current software version.
type protocol-type protocol-type-mask: Matches link layer protocols. The protocol-type argument is a hexadecimal number that represents a protocol type in Ethernet_II and Ethernet_SNAP frames. The value range for the protocol-type argument is 0 to ffff. The protocol-type-mask argument is a hexadecimal number that represents a protocol type mask. The value range for the protocol-type-mask argument is 0 to ffff.
source-mac source-address source-mask: Matches a source MAC address range. The source-address argument represents a source MAC address, and the source-mask argument represents a mask in the H-H-H format.
To view the existing Layer 2 ACL rules, use the display acl mac all command.
# Create a rule in Layer 2 ACL 4000 to permit ARP packets and deny RARP packets.
[Sysname] acl mac 4000
[Sysname-acl-mac-4000] rule permit type 0806 ffff
[Sysname-acl-mac-4000] rule deny type 8035 ffff
acl
display acl
step
time-range
rule comment
Use rule comment to configure a comment for an ACL rule.
Use undo rule comment to delete an ACL rule comment.
rule rule-id comment text
undo rule rule-id comment
An ACL rule does not have a comment.
IPv4 basic ACL view
IPv4 advanced ACL view
IPv6 basic ACL view
IPv6 advanced ACL view
Layer 2 ACL view
rule-id: Specifies an ACL rule ID in the range of 0 to 65534. The ACL rule must already exist.
text: Specifies a comment about the ACL rule, a case-sensitive string of 1 to 127 characters.
This command adds a comment to a rule if the rule does not have a comment. It modifies the comment for a rule if the rule already has a comment.
# Create a rule for IPv4 basic ACL 2000, and add a comment about the rule.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-ipv4-basic-2000] rule 0 comment This rule is used on ten-gigabitethernet 0/0/15.
display acl
step
Use step to set a rule numbering step for an ACL.
Use undo step to restore the default.
step step-value
undo step
The rule numbering step for an ACL is 5, and the start rule ID is 0.
IPv4 basic/advanced ACL view
IPv6 basic ACL view
Layer 2 ACL view
step-value: Specifies the ACL rule numbering step in the range of 1 to 20.
The rule numbering step sets the increment by which the system numbers rules automatically. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from the start rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 12, the rule is numbered 15.
The wider the numbering step, the more rules you can insert between two rules. Whenever the step changes, the rules are renumbered, starting from the start rule ID. For example, if there are five rules numbered 0, 5, 9, 10, and 15, changing the step from 5 to 2 causes the rules to be renumbered 5, 7, 9, 11, and 13.
# Set the rule numbering step to 2 for IPv4 basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] step 2
display acl
