| 01-Hardware Information and Specifications | 5.09 MB |
1 Product models and technical specifications
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q)
S5130S-36F-EI-G/S5130S-36S-EI-G/S5130S-54S-EI-G
S5130S-30C-EI-G/S5130S-54C-EI-G
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G)/S5130S-52MS-EI-G
S5130S-36S-PWR-EI-G/S5130S-54S-PWR-EI-G/S5130S-32MS-PWR-EI-G/S5130S-52MS-PWR-EI-G
3 FRUs and compatibility matrixes
SFP port (applicable to the S5130S-36F-EI-G switch)
10/100/1000BASE-T Ethernet port
Removable power supply status LED
10/100/1000BASE-T autosensing Ethernet port LED
Port LED on an interface module
Cloudnet management status LED
Product models
Table1-1 describes the S5130S-EI-G switch series models.
Table1-1 S5130S-EI-G switch series models
Switch series |
Product code (PID) |
Model |
S5130S-EI-G switch series |
Non-PoE models |
LS-5130S-10T4X-EI-Q-G3 |
S5130S-10T4X-EI-Q-G |
LS-5130S-36F-EI-G |
S5130S-36F-EI-G |
LS-5130S-36S-EI-G |
S5130S-36S-EI-G |
LS-5130S-54S-EI-G |
S5130S-54S-EI-G |
LS-5130S-30C-EI-G |
S5130S-30C-EI-G |
LS-5130S-54C-EI-G |
S5130S-54C-EI-G |
LS-5130S-32MS-EI-G |
S5130S-32MS-EI-G |
LS-5130S-32MS-EI-G-Q |
LS-5130S-52MS-EI-G |
S5130S-52MS-EI-G |
LS-5130S-28T4X-EI-Q-G3 |
S5130S-28T4X-EI-Q-G |
LS-5130S-16T4X-EI-Q-G3 |
S5130S-16T4X-EI-Q-G |
PoE models |
LS-5130S-36S-PWR-EI-G |
S5130S-36S-PWR-EI-G |
LS-5130S-54S-PWR-EI-G |
S5130S-54S-PWR-EI-G |
LS-5130S-32MS-PWR-EI-G |
S5130S-32MS-PWR-EI-G |
LS-5130S-52MS-PWR-EI-G |
S5130S-52MS-PWR-EI-G |
LS-5130S-10PT4X-EI-Q-G3 |
S5130S-10PT4X-EI-Q-G |
Technical specifications
Table1-2 Technical specifications for the S5130S-EI-G non-PoE switch models (1)
Item |
S5130S-30C-EI-G |
S5130S-54C-EI-G |
Dimensions (H × W × D) |
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in) |
Weight |
≤ 5.0 kg (11.02 lb) |
Console port |
· 1 × micro USB console port · 1 × serial console port Only the micro USB console port is available when you connect both ports. |
USB port |
1 |
Management Ethernet port |
1 |
SFP+ port |
4 |
10/100/1000BASE-T autosensing Ethernet port |
24 |
48 |
Interface module slot |
1, on the rear panel |
Power supply slot |
2, on the rear panel |
Fan module slot |
Input voltage |
AC input for the PSR150-A power supply: · Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 264 VAC @ 47 to 63 Hz DC input for the PSR150-D power supply: · Rated voltage range: –48 to –60 VDC · Max voltage range: –36 to –72 VDC You can use a –48 VDC power source in the equipment room or an H3C RPS. |
Power consumption (static) |
26 W |
35 W |
Power consumption (full load) |
61 W |
69 W |
Chassis leakage current compliance |
IEC60950-1/UL62368-1/EN62368-1/IEC62368-1/GB4943.1 |
Melting current of power supply fuse |
· PSR150-A: 5 A/250 V · PSR150-D: 8 A/250 V |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating humidity |
5% RH to 95% RH, noncondensing |
Fire resistance compliance |
Table1-3 Technical specifications for the S5130S-EI-G non-PoE switch models (2)
Item |
S5130S-36F-EI-G |
S5130S-36S-EI-G |
S5130S-54S-EI-G |
44 × 440 × 260 mm (1.73 × 17.32 × 10.24 in) |
Weight |
≤ 3.5 kg (7.72 lb) |
≤ 3.9 kg (8.60 lb) |
Console port |
1 × serial console port |
USB port |
1 |
1 |
SFP+ port |
8 |
8 |
6 |
SFP port |
28 (The four highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively) |
N/A |
N/A |
4 (each forms a combo interface with the corresponding SFP port) |
28 |
48 |
Input voltage |
· Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 264 VAC @ 47 to 63 Hz |
· Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 290 VAC @ 47 to 63 Hz |
Single AC input: 24 W Dual AC inputs: 25 W |
Single AC input: 22 W Dual AC inputs: 23 W |
Single AC input: 27 W Dual AC inputs: 27 W |
Single AC input: 63 W Dual AC inputs: 63 W |
Single AC input: 47 W Dual AC inputs: 47 W |
Single AC input: 60 W Dual AC inputs: 61 W |
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1 |
3.15 A/250 V |
–5°C to +45°C (23°F to 113°F) |
Table1-4 Technical specifications for the S5130S-EI-G non-PoE switch models (3)
Item |
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) |
44 × 266 × 160 mm (1.73 × 10.47 × 6.30 in) |
Weight |
≤ 1.5 kg (3.31 lb) |
≤ 4.0 kg (8.82 lb) |
Console port |
1 |
USB port |
1 |
1 |
SFP+ port |
4 |
2 |
2.5G SFP port |
N/A |
2 |
10 |
28 |
Input voltage |
18 W |
22 W |
Power consumption (typical) |
24 W |
37 W |
28 W |
40 W |
2 A/250 V |
3.15 A/250 V |
Table1-5 Technical specifications for the S5130S-EI-G non-PoE switch models (4)
Item |
S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G) |
S5130S-52MS-EI-G |
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in) |
Weight |
≤ 3.4 kg (7.50 lb) |
≤ 3.7 kg (8.16 lb) |
Console port |
1 |
USB port |
1 |
1 |
2.5G SFP port |
2 |
SFP+ port |
4 |
28 |
48 |
Input voltage |
23 W |
26 W |
33 W |
49 W |
46 W |
59 W |
3.15 A/250 V |
Table1-6 Technical specifications for the S5130S-EI-G non-PoE switch models (5)
Item |
44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in) |
Weight |
≤ 5.2 kg (11.46 lb) |
≤ 3.8 kg (8.38 lb) |
Console port |
1 |
USB port |
1 |
1 |
SFP+ port |
4 |
28 |
16 |
Input voltage |
· Rated voltage range: 100 to 240 VAC · Max voltage range: 90 to 264 VAC |
20 W |
16 W |
34 W |
26 W |
43 W |
31 W |
Thermal consumption (static) |
69 BTU/h |
55 BTU/h |
Thermal consumption (typical) |
117 BTU/h |
89 BTU/h |
Thermal consumption (full load) |
147 BTU/h |
106 BTU/h |
3.15 A/250 V |
Heat dissipation method |
Fanless, passive cooling |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Table1-7 Technical specifications for the S5130S-EI-G PoE switch models (1)
Item |
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in) |
Weight |
≤ 2.5 kg (5.51 lb) |
≤ 4.5 kg (9.92 lb) |
≤ 4.8 kg (10.58 lb) |
Console port |
USB port |
1 |
1 |
SFP+ port |
4 |
8 |
6 |
10 Note: Only ports 1 to 8 support PoE |
28 |
48 |
Input voltage |
AC input · Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 264 VAC @ 47 to 63 Hz |
AC input · Rated voltage range: 100 to 240 VAC @ 50 or 60 Hz · Max voltage range: 90 to 290 VAC @ 47 to 63 Hz |
Max PoE power per port |
30 W |
30 W |
30 W |
Total PoE power |
120 W |
370 W |
370 W |
22 W |
Single AC input: 28 W |
Single AC input: 35 W |
99 W |
N/A |
N/A |
170 W |
Single AC input: 477 W |
Single AC input: 498 W |
6.3 A/250 V |
10 A/250 V |
10 A/250 V |
Table1-8 Technical specifications for the S5130S-EI-G PoE switch models (2)
Item |
Weight |
Console port |
USB port |
1 |
1 |
2.5G SFP port |
2 |
2 |
SFP+ port |
2 |
2 |
28 |
48 |
Input voltage |
30 W |
Total PoE power |
370 W |
Single AC input: 27 W |
Single AC input: 34 W |
Single AC input: 42 W |
Single AC input: 58 W |
10 A/250 V |
2 Chassis views
Front panels
S5130S-10T4X-EI-Q-G
Figure2-1 S5130S-10T4X-EI-Q-G front panel
(1) 10/100/1000BASE-T autosensing Ethernet port |
(2) SFP+ port |
(3) Management Ethernet port |
(4) Console port |
(5) USB port |
(6) Mode button (Cloudnet management status LED) |
(7) Mode LED (MODE) |
(8) System status LED (SYS) |
(9) Management Ethernet port LED (LINK/ACT) |
(10) SFP+ port LED |
(11) 10/100/1000BASE-T autosensing Ethernet port LED |
Figure2-2 S5130S-10PT4X-EI-Q-G front panel
(2) SFP+ port |
(4) Console port |
(5) USB port |
(7) Reset button (RESET) |
(8) Mode LED (MODE) |
(9) System status LED (SYS) |
(10) Management Ethernet port LED (LINK/ACT) |
(11) SFP+ port LED |
(12) 10/100/1000BASE-T autosensing Ethernet port LED |
S5130S-36F-EI-G
Figure2-3 S5130S-36F-EI-G front panel
(1) SFP port |
(2) SFP port LED |
(3) 10/100/1000BASE-T autosensing Ethernet port LED |
(4) SFP+ port |
(5) Management Ethernet port |
(6) Console port |
(7) Mode button |
(8) USB port |
(10) Mode LED (MODE) |
(11) AC power supply status LED (PWR2) |
(12) AC power supply status LED (PWR1) |
(13) Management Ethernet port LED (LINK/ACT) |
(14) SFP+ port LED |
(15) 10/100/1000BASE-T autosensing Ethernet port |
S5130S-36S-EI-G
Figure2-4 S5130S-36S-EI-G front panel
(2) 10/100/1000BASE-T autosensing Ethernet port LED |
(3) SFP+ port |
(4) Management Ethernet port |
(5) Console port |
(6) Mode button |
(7) USB port |
(9) Mode LED (MODE) |
(10) AC power supply status LED (PWR2) |
(11) AC power supply status LED (PWR1) |
(12) Management Ethernet port LED (LINK/ACT) |
(13) SFP+ port LED |
S5130S-54S-EI-G
Figure2-5 S5130S-54S-EI-G front panel
(3) Console port |
(4) Mode LED (MODE) |
(5) System status LED (SYS) |
(6) AC power supply status LED 1 (PWR1) |
(7) AC power supply status LED 2 (PWR2) |
(8) Mode button |
(9) USB port |
(11) Management Ethernet port |
(12) SFP+ port LED |
(13) SFP+ port |
S5130S-30C-EI-G
Figure2-6 S5130S-30C-EI-G front panel
(3) Management Ethernet port LED (ACT/LINK) |
(5) Console port |
(6) Micro USB console port |
(7) Mode button |
(8) USB port |
(10) SFP+ port |
(11) SFP+ port mode LED (MODE) |
(12) Interface module status LED (SLOT) |
(13) Power supply 2 status LED (PWR2) |
(14) Power supply 1 status LED (PWR1) |
(15) SFP+ port LED |
S5130S-54C-EI-G
Figure2-7 S5130S-54C-EI-G front panel
(5) Console port |
(7) Mode button |
(8) USB port |
(10) SFP+ port |
S5130S-32MS-EI-G
Figure2-8 S5130S-32MS-EI-G front panel
(3) 2.5G SFP port |
(4) Management Ethernet port (MGMT) |
(5) AC power supply status LED (PWR) |
(6) Console port |
(7) Mode button |
(8) USB port |
(12) SFP+ port |
(14) 2.5G SFP port LED |
S5130S-52MS-EI-G
Figure2-9 S5130S-52MS-EI-G front panel
(3) 2.5G SFP port |
(4) SFP+ port |
(5) Console port |
(6) System status LED (SYS) |
(7) AC power supply status LED (PWR) |
(9) Mode button |
(10) USB port |
(11) Management Ethernet port LED (LINK/ACT) |
(12) Management Ethernet port (MGMT) |
S5130S-28T4X-EI-Q-G
Figure2-10 S5130S-28T4X-EI-Q-G front panel
(2) SFP+ port |
(3) Management Ethernet port (MGMT) |
(4) Console port |
(5) USB port |
(10) Management Ethernet port LED (LINK) |
S5130S-16T4X-EI-Q-G
Figure2-11 S5130S-16T4X-EI-Q-G front panel
(2) SFP+ port |
(3) Console port |
(4) USB port |
(5) Mode button (Cloudnet management status LED) |
(6) Reset button (RESET) |
(10) Management Ethernet port (MGMT) |
S5130S-36S-PWR-EI-G
Figure2-12 S5130S-36S-PWR-EI-G front panel
(3) SFP+ port |
(5) Console port |
(6) Mode button |
(7) USB port |
(10) AC power supply status LED (PWR) |
S5130S-54S-PWR-EI-G
Figure2-13 S5130S-54S-PWR-EI-G front panel
(3) SFP+ port |
(4) SFP+ port LED |
(5) Console port |
(9) Mode button |
(10) USB port |
(12) Management Ethernet port |
Figure2-14 S5130S-32MS-PWR-EI-G front panel
(3) 2.5G SFP port |
(6) Console port |
(7) Mode button |
(8) USB port |
(12) SFP+ port |
Figure2-15 S5130S-52MS-PWR-EI-G front panel
(3) 2.5G SFP port |
(4) SFP+ port |
(5) Console port |
(9) Mode button |
(10) USB port |
Rear panels
S5130S-10T4X-EI-Q-G
Figure2-16 S5130S-10T4X-EI-Q-G rear panel
(1) Grounding screw |
(2) AC power receptacle |
(3) Reset button (RESET) |
Figure2-17 S5130S-32MS-EI-G rear panel
(1) AC power receptacle |
(2) Grounding screw |
Figure2-18 S5130S-54S-EI-G rear panel
(1) AC power receptacle 1 |
(2) AC power receptacle 2 |
(3) Grounding screw |
The rear views of the S5130S-36F-EI-G, S5130S-36S-EI-G, and S5130S-54S-EI-G switches are similar. This figure uses the S5130S-54S-EI-G switch as an example.
Figure2-19 S5130S-54C-EI-G rear panel
(2) Interface module |
(3) Fan module 1 |
(4) Fan module 2 |
(5) Power supply 1 |
(6) Power supply 2 |
The rear views of the S5130S-30C-EI-G and S5130S-54C-EI-G switches are similar. This figure uses the S5130S-54C-EI-G switch as an example.
The switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. For information about installing and removing power supplies, see H3C S5130S-EI-G Switch Series Installation Guide.
The switch came with the two fan module slots empty. In Figure2-19, two LSPM1FANSB fan modules are installed in the fan module slots. For information about installing and removing fan modules, see H3C S5130S-EI-G Switch Series Installation Guide.
The switch came with the interface module slot installed with a filler panel. You can select an interface module for the switch as required. For information about installing and removing interface modules, see H3C S5130S-EI-G Switch Series Installation Guide.
Figure2-20 S5130S-32MS-EI-G rear panel
The rear views of the S5130S-32MS-EI-G and S5130S-52MS-EI-G switches are similar. This figure uses the S5130S-32MS-EI-G switch as an example.
S5130S-28T4X-EI-Q-G
Figure2-21 S5130S-28T4X-EI-Q-G rear panel
S5130S-16T4X-EI-Q-G
Figure2-22 S5130S-16T4X-EI-Q-G rear panel
Figure2-23 SS5130S-54S-PWR-EI-G rear panel
The rear views of the S5130S-36S-PWR-EI-G, S5130S-54S-PWR-EI-G, S5130S-32MS-EI-G, S5130S-32MS-PWR-EI-G, S5130S-52MS-EI-G, and S5130S-52MS-PWR-EI-G switches are similar. This figure uses the S5130S-54S-PWR-EI-G switch as an example.
Only the S5130S-30C-EI-G and S5130S-54C-EI-G switches use modular design and support FRUs.
Table3-1 FRUs and compatibility matrixes
FRUs |
S5130S-30C-EI-G |
S5130S-54C-EI-G |
Removable power supplies |
PSR150-A |
Supported |
Supported |
PSR150-D |
Supported |
Supported |
Removable fan modules |
LSPM1FANSA |
Supported |
Supported |
LSPM1FANSB |
Supported |
Supported |
Interface modules |
LSWM2SP4P |
Supported |
Supported |
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supplies you have installed on the switch.
On an S5130S-30C-EI-G or S5130S-54C-EI-G switch, you can install one power supply, or two power supplies for 1+1 redundancy. The switch supports installation of both an AC power supply and a DC power supply.
Table3-2 Removable power supplies
Power supply model |
Item |
Specification |
PSR150-A |
41.1 × 101.6 × 177 mm (1.62 × 4.00 × 6.97 in) |
AC input |
Rated input voltage range |
100 to 240 VAC @ 50 or 60 Hz |
Max input current |
2 A |
HVDC input |
Rated input voltage |
240 VDC |
Max input current |
2 A |
Output voltage |
12 V |
Max output current |
12.5 A |
Max power |
150 W |
PSR150-D |
–48 to –60 VDC |
Max input current |
6 A |
Output voltage |
12 V |
12.5 A |
Max power |
150 W |
Table3-3 Removable fan modules
Item |
LSPM1FANSA |
LSPM1FANSB |
Number of fans |
1 |
1 |
Dimensions (H × W × D, including the handle) |
41 × 40 × 105 mm (1.61 × 1.57 × 4.13 in) |
Max fan speed |
20000 R.P.M |
20000 R.P.M |
Max air flow rate |
20 CFM (0.57 m3/min) |
Input voltage |
12 V |
12 V |
Max power consumption |
9.8 W |
9.8 W |
Airflow direction |
Blows air from the power supply side to the port side |
Draws air from the port side to the power supply side |
Interface modules
Interface module model |
Item |
Specification |
LSWM2SP4P |
Name |
4-port 10GE SFP+ interface module |
Port quantity and type |
Four 1/10 Gbps SFP+ fiber ports |
Available transceiver modules and cables |
10GE SFP+ transceiver modules and SFP+ cables |
Reference |
H3C LSWM2SP4P Interface Card User Manual |
To connect cables to the ports on interface modules, follow these guidelines:
· Use category 6A or above cables and connectors.
· Do not bundle cables in their first 20 m (65.62 ft).
· Separate power cords and twisted pair cables at and around the distribution frame.
· For ports adjacent to one another on the device, the peer ports on the distribution frame is preferably not adjacent, for example:
¡ If the device connects to one distribution frame, connect port 1 on the device to port 1 on the distribution frame and port 2 on the device to port 3 on the distribution frame.
¡ If the device connects to two distribution frames, connect port 1 on the device to port 1 on distribution frame 1 and port 2 on the device to port 1 on distribution frame 2.
· Keep the device and cables away from the interference source.
4 Ports, LEDs, and buttons
Ports
Console port
Table4-1 Console port specifications
Item |
Connector type |
Serial console port |
RJ-45 |
USB micro-type B |
Compliant standard |
EIA/TIA-232 |
USB 2.0 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Supported services |
· Provides connection to an ASCII terminal. · Provides connection to the serial port of a local or remote terminal running a terminal emulation program |
· Provides connection to an ASCII terminal. · Provides connection to the USB port of a local terminal running a terminal emulation program |
Compatible switch models |
All switch models |
S5130S-30C-EI-G, S5130S-54C-EI-G |
Restrictions and guidelines |
The switch has one management Ethernet port on the front panel. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications
Item |
Connector type |
RJ-45 |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X autosensing |
Transmission medium |
Category 5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, 802.3ab |
Functions and services |
Connects to a computer or remote network management station for upgrading and managing applications and Boot ROM |
USB port
Table4-3 USB port specifications
Item |
Port type |
USB2.0 |
OHC |
Uploads and downloads data at a rate up to 480 Mbps |
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files |
All switch models |
NOTE: USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor. |
Table4-4 SFP port specifications
Item |
Port type |
SFP port |
· FE SFP transceiver modules described in Table4-5. · GE SFP transceiver modules and cables described in Table4-6. |
S5130S-36F-EI-G |
· When you use the SFP-GE-T or SFP-GE-T-D copper transceiver module, the ports can operate only at 1000 Mbps. · The S5130S-36F-EI-G switch supports a maximum of 14 GE copper transceiver modules (SFP-GE-T and SFP-GE-T-D). · The S5130S-36F-EI-G switch does not support the SFP-GE-LH100-SM1550, SFP-GE-LH40-SM1310-BIDI, SFP-GE-LH40-SM1550-BIDI, SFP-GE-LH70-SM1490-BIDI, and SFP-GE-LH70-SM1550-BIDI transceiver modules. |
Table4-5 FE SFP transceiver modules available for the SFP ports
Transceiver module model |
Central wavelength (nm) |
Connector type |
Cable/fiber type and diameter (µm) |
SFP-FE-SX-MM1310-A |
1310 |
LC |
50/125, MMF |
2 km (1.24 miles) |
62.5/125, MMF |
SFP-FE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
15 km (9.32 miles) |
SFP-FE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
40 km (24.86 miles) |
SFP-FE-LX-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
SFP-FE-LX-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
IMPORTANT: The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-FE-LX-SM1550-BIDI transceiver module. |
Table4-6 GE SFP transceiver modules and cables available for the SFP ports
Transceiver module/cable type |
Transceiver module/cable model |
Connector type |
Mode bandwidth (MHz*km) |
SFP copper transceiver module |
SFP-GE-T |
N/A |
RJ-45 |
Twisted pair cable |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP optical transceiver module |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
550 m (1804.46 ft) |
400 |
500 m (1640.42 ft) |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
N/A |
10 km (6.21 miles) |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
SFP-GE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
80 km (49.71 miles) |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH100-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-BIDI |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1550-BIDI |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH70-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
70 km (43.50 miles) |
SFP-GE-LH70-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module. |
NOTE: · As a best practice, use H3C transceiver modules and cables for the switch. · The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff. · For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
2.5G SFP port
Table4-7 SFP port specifications
Item |
Port type |
SFP port |
· GE SFP transceiver modules and cables described in Table4-6. · 2.5G SFP transceiver modules and cables described in Table4-8. |
· S5130S-52MS-EI-G · S5130S-32MS-EI-G · S5130S-52MS-PWR-EI-G · S5130S-32MS-PWR-EI-G |
Table4-8 2.5G SFP transceiver modules and cables available for the 2.5G SFP ports
Connector type |
2.5G SFP transceiver module |
SFP-2.5G-LX10-SM1310-DR-I |
1310 |
LC |
9/125, SMF |
N/A |
SFP+ port
Table4-9 SFP+ port specifications (1)
Item |
Port type |
SFP+ port |
· GE SFP transceiver modules and cables described in Table4-6. · 10GE SFP+ transceiver modules and cables described in Table4-11. |
All switch models except the S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q, S5130S-16T4X-EI-Q-G, and S5130S-28T4X-EI-Q-G |
· To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-36S-PWR-EI-G, or S5130S-54S-PWR-EI-G switch, follow these guidelines: ¡ Make sure the ambient temperature does not exceed 40°C (104°F). ¡ You can install a maximum of two such transceiver modules on the switch. ¡ Do not install the transceiver modules in adjacent ports. · The S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-30C-EI-G, S5130S-54C-EI-G, S5130S-36S-PWR-EI-G, and S5130S-54S-PWR-EI-G switches do not support the following transceiver modules: ¡ SFP-10GE-T. ¡ SFP-XG-CPRI-IR-SM1310. ¡ SFP-XG-CPRI-LR-SM1310. ¡ SFP-XG-LH40-SM1270-BIDI. ¡ SFP-XG-LH40-SM1330-BIDI. ¡ SFP-XG-LH80-SM1490-BIDI. ¡ SFP-XG-LH80-SM1550-BIDI. |
Table4-10 SFP+ port specifications (2)
Item |
Port type |
SFP+ port |
· GE SFP transceiver modules and cables described in Table4-13. · 10GE SFP+ transceiver modules and cables described in Table4-12. |
· S5130S-10T4X-EI-Q-G · S5130S-10PT4X-EI-Q-G · S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) · S5130S-16T4X-EI-Q-G · S5130S-28T4X-EI-Q-G |
· The S5130S-10PT4X-EI-Q-G switch does not support copper transceiver modules or transceiver modules with a maximum transmission distance greater than or equal to 40 km (24.86 miles). · To install copper transceiver modules or transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5130S-10T4X-EI-Q-G or S5130S-32MS-EI-G switch, make sure the ambient temperature does not exceed 40°C (104°F). · To install transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S5130S-28T4X-EI-Q-G or S5130S-16T4X-EI-Q-G switch, make sure the ambient temperature does not exceed 40°C (104°F). |
NOTE: The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide four fixed SFP+ ports on the front panel. To connect peer SFP+ ports over a long distance, use SFP+ transceiver modules and fibers. To connect peer SFP+ ports over a short distance, use H3C SFP+ cables. Select 10GE SFP+ transceiver modules and cables as required. For information about the transceiver modules and cables available for the SFP+ ports on the S5130S-30C-EI-G and S5130S-54C-EI-G switches, see H3C S5130S-EI-G Switch Series Transceiver Module Compatibility Matrix. For information about the transceiver modules and cables available for the SFP+ ports on the other switch models, see Table4-11, Table4-12, and Table4-13. For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide. |
Table4-11 10GE SFP+ transceiver modules and cables available for the SFP+ ports (1)
Connector type |
SFP+ copper transceiver module |
SFP-10GE-T |
N/A |
RJ-45 |
N/A |
30 m (98.43 ft) |
SFP+ optical transceiver module |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-E |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-CPRI-IR-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1.4 km (0.87 miles) |
SFP-XG-CPRI-LR-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1270-BIDI |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1330-BIDI |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1490-BIDI |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550-BIDI |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cable |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
IMPORTANT: The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and the SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-12 10GE SFP+ transceiver modules and cables available for the SFP+ ports (2)
Connector type |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-SX-MM850-H |
850 |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
500 |
82 m (269.03 ft) |
400 |
66 m (216.54 ft) |
62.5/125, MMF |
200 |
33 m (108.27 ft) |
160 |
26 m (85.30 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-F |
1310 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH40-SM1550-S |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-XG-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1270-BIDI-S |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
SFP-XG-LX-SM1330-BIDI-S |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1270 RX: 1330 |
LC |
9/125, SMF |
N/A |
TX: 1330 RX: 1270 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP+ copper cable |
LSWM1STK |
N/A |
N/A |
SFP+ copper cable |
N/A |
0.65 m (2.13 ft) |
LSWM2STK |
1.2 m (3.94 ft) |
LSWM3STK |
3 m (9.84 ft) |
LSTM1STK |
5 m (16.40 ft) |
LSTM2STK |
7 m (22.97 ft) |
SFP+ fiber cable |
SFP-XG-D-AOC-7M |
N/A |
N/A |
SFP+ fiber cable |
N/A |
7 m (22.97 ft) |
SFP-XG-D-AOC-7M-H |
7 m (22.97 ft) |
SFP-XG-D-AOC-10M |
10 m (32.81 ft) |
SFP-XG-D-AOC-10M-H |
10 m (32.81 ft) |
SFP-XG-D-AOC-20M |
20 m (65.62 ft) |
SFP-XG-D-AOC-20M-H |
20 m (65.62 ft) |
IMPORTANT: The following transceiver modules must be used in pairs: · SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules. · SFP-XG-LX-SM1270-BIDI-S and SFP-XG-LX-SM1330-BIDI-S transceiver modules. · SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules. · SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module. |
Table4-13 GE SFP transceiver modules and cables available for the SFP+ ports
Connector type |
Maximum transmission distance |
SFP-GE-T |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-T-S |
N/A |
RJ-45 |
N/A |
100 m (328.08 ft) |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
SFP-GE-SX-MM850-S |
850 |
LC |
50/125, MMF |
500 |
400 |
62.5/125, MMF |
200 |
275 m (902.23 ft) |
160 |
220 m (721.78 ft) |
1310 |
LC |
9/125, SMF |
N/A |
50/125, MMF |
500/400 |
62.5/125, MMF |
500 |
SFP-GE-LX10-SM1310 |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-F |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH20-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
20 km (12.43 miles) |
1310 |
LC |
9/125, SMF |
N/A |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-I |
1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LH40-SM1310-S |
1310 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
1550 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-BIDI-S |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI-S |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1310 Rx: 1490 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1310-BIDI-I |
TX: 1310 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP-GE-LX-SM1490-BIDI-I |
TX: 1490 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1310 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1310 |
LC |
9/125, SMF |
N/A |
TX: 1490 RX: 1550 |
LC |
9/125, SMF |
N/A |
TX: 1550 RX: 1490 |
LC |
9/125, SMF |
N/A |
SFP cable |
SFP-STACK-Kit |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
SFP-STACK-Kit-S |
N/A |
N/A |
SFP cable |
N/A |
1.5 m (4.92 ft) |
IMPORTANT: The following transceiver modules must be used in pairs: · SFP-GE-LX-SM1310-BIDI-S and SFP-GE-LX-SM1490-BIDI-S transceiver modules. · SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules. · SFP-GE-LX-SM1310-BIDI-I and SFP-GE-LX-SM1490-BIDI-I transceiver modules. · SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules. · SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules. For example, if one end uses an SFP-GE-LX-SM1310-BIDI-S transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI-S transceiver module. |
(1) Connector |
(2) Pull latch |
The switch provides 10/100/1000BASE-T Ethernet ports.
Table4-14 10/100/1000BASE-T Ethernet port specifications
Item |
Connector type |
RJ-45 |
· 10 Mbps, half/full duplex · 100 Mbps, half/full duplex · 1000 Mbps, full duplex · MDI/MDI-X, autosensing |
100 m (328.08 ft) |
LEDs
System status LED
The system status LED shows the operating status of the switch, as shown in Table4-15.
Table4-15 System status LED description
LED mark |
Status |
SYS |
Steady green |
The switch has started up correctly. |
Flashing green (1 Hz) |
The switch is performing power-on self test (POST). |
Steady red |
The switch has failed POST or the switch is faulty. |
Off |
The switch is powered off. |
S5130S-EI-G switches (except the S5130S-30C-EI-G and S5130S-54C-EI-G) each provide an AC power receptacle on the rear panel.
The power supply status LEDs on the front panel of S5130S-EI-G switches (except the S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-28T4X-EI-Q-G, and S5130S-16T4X-EI-Q-G) indicate the power supply operating status.
Table4-16 AC power supply status LED description
LED mark |
Status |
PWR/PWR1/PWR2 |
Steady green |
Normal AC power input. |
Off |
Abnormal or no AC power input. |
The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide two removable power supply slots on the rear panel. The power supply status LEDs on the front panel indicate the operating status of the power supplies.
Table4-17 Removable power supply status LED description
LED mark |
Status |
PWR1/PWR2 |
Steady green |
A power supply is installed in the power supply slot, and the power supply is outputting power correctly. |
Steady yellow |
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on. |
Off |
No power supply is installed in the power supply slot. |
Mode LED
The mode LED (MODE) works in conjunction with the port status LEDs to show more information about the switch.
· The mode LED indicates the type of information that the port status LEDs are showing.
· You can use the mode button to change the indication of the mode LED.
¡ S5130S-30C-EI-G and S5130S-54C-EI-G switches—The mode LED changes in color and indication after you press the mode button and keeps that state until you press the mode button again.
¡ Other switch models—After you press the mode button to change the mode LED status into flashing green or flashing yellow, the mode LED keeps in that state for only 45 seconds and then turns steady green automatically.
Table4-18 Mode LED description (applicable to the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
LED mark |
Status |
MODE |
Steady green |
The port LEDs are showing the link state of the ports. |
Steady yellow |
The port LEDs are showing the duplex mode of the ports. |
Table4-19 Mode LED description (applicable to the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-28T4X-EI-Q-G, S5130S-16T4X-EI-Q-G, S5130S-36S-PWR-EI-G, S5130S-54S-PWR-EI-G, S5130S-52MS-EI-G, S5130S-32MS-EI-G, S5130S-52MS-PWR-EI-G, and S5130S-32MS-PWR-EI-G switches)
LED mark |
Status |
MODE |
Steady green |
Flashing green (only for PoE models) |
The port LEDs are showing the PoE status of the ports. |
Flashing yellow |
The port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4. |
Table4-20 Management Ethernet port LED description
LED mark |
Status |
LINK/ACT |
Steady green |
A link is present on the port. |
Flashing yellow |
The port is receiving or sending data. |
Off |
No link is present on the port. |
The 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating status of the Ethernet ports and the switch from different aspects.
Mode LED status |
Ethernet port LED status |
Steady green (rate mode) |
Steady green |
A link is present on the port and the port is operating at 1000 Mbps. |
Flashing green |
The port is receiving or sending data at 1000 Mbps. |
Steady yellow |
A link is present on the port and the port is operating at 10/100 Mbps. |
Flashing yellow |
The port is receiving or sending data at 10/100 Mbps. |
Off |
Steady yellow (duplex mode) |
Steady green |
A link is present on the port and the port is operating in full duplex mode. |
Steady yellow |
A link is present on the port and the port is operating in half duplex mode. |
Off |
Table4-22 10/100/1000BASE-T autosensing Ethernet port LED description (applicable to the S5130S-36F-EI-G, S5130S-36S-EI-G, S5130S-54S-EI-G, S5130S-36S-PWR-EI-G, S5130S-54S-PWR-EI-G, S5130S-52MS-EI-G, S5130S-32MS-EI-G, S5130S-52MS-PWR-EI-G, and S5130S-32MS-PWR-EI-G switches)
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 10/100/1000 Mbps. |
Flashing green |
The port is receiving or sending data at 10/100/1000 Mbps. |
Off |
Steady green |
PoE power supply is normal. |
· The maximum PoE power provided by the port fails to meet the power requirement of the PD. · PoE power supply overcurrent, overvoltage, or shortcircuit occurs. · The remaining power of the switch fails to meet the power supply requirement of the port. |
Off |
The port is not connected to a PD or PoE is not enabled on the port. |
Flashing yellow (IRF mode) |
Steady green |
SFP port LED
The SFP port LEDs work in conjunction with the mode LED to indicate the operating status of the SFP ports and the switch from different aspects.
Table4-23 SFP port LED description
Mode LED status |
SFP port LED status |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Steady green |
The SFP port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 4 is steady green, the IRF member ID of the switch is 4. |
2.5G SFP port LED
Table4-24 2.5G SFP port LED description
Mode LED status |
2.5G SFP port LED status |
Steady green |
A link is present on the port and the port is operating at 2500 Mbps. |
Flashing green |
The port is receiving or sending data at 2500 Mbps. |
Steady yellow |
Flashing yellow |
Off |
Off |
The mode LED is operating in IRF mode. |
Flashing green (PoE mode) |
Off |
The mode LED is operating in PoE mode (available only for PoE switch models). |
SFP+ port LED
Table4-25 SFP+ port LED description (applicable to the S5130S-30C-EI-G and S5130S-54C-EI-G switches)
Mode LED status |
SFP+ port LED status |
Steady green |
A link is present on the port and the port is operating at 10 Gbps. |
Flashing green |
The port is receiving or sending data at 10 Gbps. |
Steady yellow |
A link is present on the port and the port is operating at 1 Gbps. |
Flashing yellow |
The port is receiving or sending data at 1 Gbps. |
Off |
Steady green |
Steady yellow |
Off |
Table4-26 SFP+ port LED description (applicable to switch models except the S5130S-30C-EI-G and S5130S-54C-EI-G)
Mode LED status |
Steady green |
A link is present on the port and the port is operating at 1/10 Gbps. |
Flashing green |
The port is receiving or sending data at 1/10 Gbps. |
Off |
Off |
Off |
The S5130S-30C-EI-G and S5130S-54C-EI-G switches each provide an interface module slot on the rear panel. The interface module status LED on the front panel indicates the operating status of the interface module.
Table4-27 Interface module status LED description
LED mark |
Status |
SLOT |
Steady green |
The interface module is operating correctly. |
Flashing yellow |
The interface module in the slot is not supported or the interface module is faulty. |
Off |
No interface module is installed. |
An interface module provides a LED for each port. For more information about the LEDs, see the manual for the interface module.
Status LED on a fan module
The LSPM1FANSA and LSPM1FANSB fan modules each provide a LED to indicate the fan module operating status.
After you execute the push-button mode enable command on an S5130S-10T4X-EI-Q-G, S5130S-10PT4X-EI-Q-G, S5130S-16T4X-EI-Q-G, or S5130S-28T4X-EI-Q-G switch, the operations that can be performed by pressing the mode button depend on the duration of the press.
· 5 to 10 seconds—Connect the switch to or disconnect the switch from Cloudnet.
· Less than 5 seconds—Change the type of information that the port LEDs are showing.
· More than 10 seconds—Invalid operation.
Table4-28 Cloudnet management status LED description
LED status |
Steady blue |
The switch has been managed by Cloudnet. |
Flashing blue (1 Hz) |
The switch is being connected to Cloudnet. |
Flashing blue (3 Hz) |
Invalid operation. |
Off |
The switch is not connected to Cloudnet. |
Buttons
Mode button
You can use the mode button to change the indication of the mode LED and cloud management status LED. For more information about the mode LED, see "Mode LED." For more information about the cloud management status LED, see "Cloudnet management status LED."
Reset button
The S5130S-10PT4X-EI-Q-G, S5130S-28T4X-EI-Q-G, and S5130S-16T4X-EI-Q-G switch each provide a reset button on the front panel. The S5130S-10T4X-EI-Q-G switch provides a reset button on the rear panel. Table4-29 shows the description for the reset button.
Table4-29 Reset button description
Button |
To reset and reboot the switch, press the reset button. |
5 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
CAUTION: To ensure adequate heat dissipation for an S5130S-30C-EI-G or S5130S-54C-EI-G switch, follow these guidelines: · You must install two fan modules of the same model for the switch. · If a fan module operates abnormally (for example, it is in the absent, fault, inconsistent airflow direction, or being just inserted state), the other fan module will operate at the highest speed. |
Table5-1 Cooling system
Switch model |
Fan module type |
Airflow direction |
S5130S-30C-EI-G S5130S-54C-EI-G |
LSPM1FANSA |
From the power supply side to the port side and chassis two sides (S5130S-54C-EI-G switch as an example) |
LSPM1FANSB |
From the port side and chassis two sides to the power supply side (S5130S-54C-EI-G switch as an example) |
S5130S-36F-EI-G S5130S-36S-EI-G S5130S-54S-EI-G S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G) S5130S-52MS-EI-G S5130S-36S-PWR-EI-G S5130S-54S-PWR-EI-G S5130S-32MS-PWR-EI-G S5130S-52MS-PWR-EI-G |
Fixed fan modules |
From the left side to the right side (S5130S-54S-PWR-EI-G switch as an example) |
S5130S-10T4X-EI-Q-G S5130S-10PT4X-EI-Q-G S5130S-32MS-EI-G (product code: LS-5130S-32MS-EI-G-Q) S5130S-28T4X-EI-Q-G S5130S-16T4X-EI-Q-G |
N/A |
