14-Cloud Connection Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1411P02)-6W10214-Cloud Connection Command Reference
01-Cloud connection commands
01-Cloud connection commands 113.34 KB
cloud-management backup-server domain
Use cloud-management backup-server domain to specify a backup cloud server by its domain name.
Use undo cloud-management backup-server domain to remove one or all backup cloud servers.
cloud-management backup-server [ ipv6 ] domain domain-name [ port port-number ] [ source-ip ip-address ]
undo cloud-management backup-server [ ipv6 ] domain [ domain-name [ port port-number ] ]
No backup cloud server is specified.
ipv6: Specifies an IPv6 backup cloud server by its domain name. If you do not specify this keyword, this command specifies an IPv4 backup cloud server by its domain name.
domain-name: Specifies a backup cloud server by its domain name, a case-sensitive string of 1 to 253 characters. If you do not specify this parameter in the undo cloud-management backup-server domain command, all backup cloud servers will be deleted.
port port-number: Specifies the TCP port number used by the device to initiate the authentication to the backup cloud server. The value range is 1 to 65535. If you do not specify this option, this command uses the port number specified by the cloud-management server port command.
source-ip ip-address: Specifies the source IP address for the device that connects to the backup cloud server. It must be the same as the IP address configured on the device. If you do not specify this option, the device uses the primary IP address of the egress interface to connect to the backup cloud server.
Before configuring this command, make sure a DNS server is configured to translate domain names.
You can specify a maximum of eight IPv4 and IPv6 backup servers by repeating the cloud-management backup-server domain command. Each server domain name supports a maximum of three port numbers. If you execute this command multiple times to configure a backup cloud server with the same domain name and the same port number, the most recent configuration takes effect.
When establishing a cloud connection, the device can connect to only one cloud server at one time according to the sequence in which the servers are stored. The server domain names are stored in alphabet order and port numbers are in descending order. To view the connected server, execute the display cloud-management state command.
If multiple servers exist in the intranet and the NAT device has only one public IP address, you can execute this command to specify different port numbers for one server domain name.
When establishing a cloud connection, the first specified server has the highest priority. When the connected server fails, the device switches to another server and does not switch back to the original server even if the original server recovers.
# Specify the server with domain name 123.com as an IPv4 backup cloud server.
[Sysname] cloud-management backup-server domain 123.com
cloud-management keepalive
Use cloud-management keepalive to set the keepalive interval for the local device to send keepalive packets to the cloud server.
Use undo cloud-management keepalive to restore the default.
cloud-management keepalive interval
The keepalive interval is 180 seconds.
interval: Specifies the keepalive interval in the range of 10 to 600 seconds.
If the device does not receive a response from the cloud server within three keepalive intervals, the device sends a registration request to re-establish the cloud connection.
# Set the keepalive interval to 360 seconds.
[Sysname] cloud-management keepalive 360
cloud-management keepalive count
Use cloud-management keepalive count to specify the maximum number of consecutive keepalive packets that the local device can send to the cloud server.
Use undo cloud-management keepalive count to restore the default.
cloud-management keepalive count count
A device can send three consecutive keepalive packets to the cloud server.
count: Specifies the maximum number of consecutive keepalive packets that the local device can send to the cloud server. The value range for this argument is 2 to 100.
After establishing the cloud connection, the local device sends keepalive packets to the cloud server at the interval specified by the cloud-management keepalive interval command. If the device does not receive a response from the cloud server after the number of keepalive packets sent reached the limit specified by the cloud-management keepalive count count command, the device sends a registration request to re-establish the cloud connection.
# Set the maximum number of consecutive keepalive packets that the local device can send to the cloud server to five.
[Sysname] cloud-management keepalive count 5
cloud-management ping
Use cloud-management ping to set the interval at which the local device sends ping packets to the cloud server.
Use undo cloud-management ping to restore the default.
cloud-management ping interval
The local device sends ping packets to the cloud server at intervals of 60 seconds.
interval: Specifies the interval at which the local device sends ping packets to the cloud server, in the range of 10 to 600 seconds.
After the connection to the cloud server is established, the local device sends ping packets to the server periodically to prevent NAT entry aging. Reduce the interval value if the network condition is poor or the NAT entry aging time is short.
The cloud server does not respond to ping packets.
# Configure the local device to send ping packets to the cloud server at intervals of 120 seconds.
[Sysname] cloud-management ping 120
cloud-management server connect enable
Use cloud-management server connect enable to enable cloud connection.
Use undo cloud-management server connect enable to disable cloud connection.
Cloud connection is enabled on a device.
When this feature is disabled, the device is not allowed to establish any cloud connections and existing cloud connections on the device are disconnected.
# Disable cloud connection.
[Sysname] undo cloud-management server connect enable
cloud-management server domain
Use cloud-management server domain to configure the domain name of the cloud server.
Use undo cloud-management server domain to restore the default.
cloud-management server [ ipv6 ] domain domain-name [ port port-number ] [ source-ip ip-address ]
undo cloud-management server [ ipv6 ] domain
The domain name of the cloud server is not configured.
ipv6: Specifies an IPv6 primary cloud server by its domain name. if you do not specify this keyword, this command specifies an IPv4 primary cloud server by its domain name.
domain-name: Specifies the domain name of the cloud server, a case-sensitive string of 1 to 253 characters.
port port-number: Specifies the TCP port number used by the device to initiate the authentication to the primary cloud server. The value range is 1 to 65535. If you do not specify this option, this command uses the port number specified by the cloud-management server port command.
source-ip ip-address: Specifies the source IP address for the device that connects to the primary cloud server. It must be the same as the IP address configured on the device. If you do not specify this option, the device uses the primary IP address of the egress interface to connect to the primary cloud server.
Only one primary cloud server is supported. If you execute the command multiple times, the most recent configuration takes effect.
# Configure the domain name of the cloud server as abc.com.
[Sysname] cloud-management server domain abc.com
cloud-management server password
Use cloud-management server password to set the password for establishing cloud connections to the cloud server.
Use cloud-management server password to restore the default.
cloud-management server password { cipher | simple } string
undo cloud-management server password
No password is set for establishing cloud connections to the cloud server.
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext form is a case-sensitive string of 1 to 63 characters. The encrypted form is a case-sensitive string of 1 to 117 characters.
After you change the password, the device terminates the cloud connections that have been established (if any) and uses the new password to establish cloud connections.
# Set the password for establishing cloud connections to the cloud server to 12345678 in plaintext format.
[Sysname] cloud-management server password simple 12345678
Use cloud-management server port to specify the TCP port number used by the device to initiate the authentication to a cloud server.
Use undo cloud-management server port to restore the default.
cloud-management server port port-number
TCP port number 19443 is used by the device to initiate the authentication to a cloud server.
port-number: Specifies a TCP port number used by the device to initiate the authentication to a cloud server. The value range is 1 to 65535.
If you configure the primary cloud server or a backup cloud server without specifying a TCP port number, the device uses the port number specified by this command to initiate the authentication to a cloud server.
# Specify the TCP port number used by the device to initiate the authentication to a cloud server as 80.
[Sysname] cloud-management server port 80
cloud-management token
Use cloud-management token to set the token for establishing cloud connections to the cloud server.
Use undo cloud-management token to restore the default.
cloud-management token { cipher | simple } string
No token is set for establishing cloud connections to the cloud server.
cipher: Specifies the token in cipher text.
simple: Specifies the token in plain text. The token will be stored in cipher text for security purposes.
string: Specifies the token string. The token in plain text form is a case-sensitive string of 1 to 63 characters. The token in cipher text form is a case-sensitive string of 1 to 117 characters.
If the cloud server verifies the token of a device before establishing a cloud connection to the device, you must configure the token on the device. To avoid authentication failure, make sure the token configured on the device is consistent with that specified for the device on the cloud server.
After you change the token, the device terminates the cloud connections that have been established (if any) and uses the new token to re-establish cloud connections.
# Set the token for establishing cloud connections to 12345678 in plain text form.
[Sysname] cloud-management token simple 12345678
cloud-management unbinding-code
Use cloud-management unbinding-code to send the verification code for device unbinding to the cloud server.
cloud-management unbinding-code code
code: Specifies the verification code obtained from the cloud server. The verification code is a case-sensitive string of 16 characters.
A device can be registered on the cloud server by only one user.
To register a device that has been registered by another user, you need to take the following steps:
1.     Obtain a verification code for device unbinding from the cloud server.
2.     Execute this command on the device to send the verification code to the cloud server.
3.     Register the device on the cloud server.
# Send the verification code for device unbinding to the cloud server.
[Sysname] cloud-management unbinding-code A6B9C3C2D5A8Z1S7
Use display cloud-management state to display cloud connection state information.
The IP address and domain name of the cloud server here are for illustration only.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state                      : Established
Device state                                : Request_success
Cloud server address                        : 52.163.242.100
Cloud server domain name                    : oasiscloud.h3c.com
Cloud connection mode                       : Https
Cloud server authentication port            : 19443
Cloud server connection port                : 443
Connected at                                : Wed Jan 27 14:18:40 2019
Duration                                    : 00d 00h 02m 01s
Process state                               : Message received
Failure reason                              : N/A
Last down reason                            : socket connection error (Details:N/A)
Last down at                                : Wed Jan 27 13:18:40 2019
Last report failure reason                  : N/A
Last report failure at                      : N/A
Dropped packets after reaching buffer limit : 0
Total dropped packets                       : 1
Last report incomplete reason               : N/A
Last report incomplete at                   : N/A
Buffer full count                           : 0
Cloud connection state: Unconnected, Request, and Established.
Device state
Local device state:
·     Idle—In idle state.
·     Connecting—Connecting to the cloud server.
·     Request_CAS_url—Sent a central authentication service (CAS) URL request.
·     Request_CAS_url_success—Requesting CAS URL succeeded.
·     Request_CAS_TGT—Sent a ticket granting ticket (TGT) request.
·     Request_CAS_TGT_success—Requesting TGT succeeded.
·     Request_CAS_ST—Sent a service ticket (ST) request.
·     Request_CAS_ST_success—Requesting ST succeeded.
·     Request_cloud_auth—Sent an authentication request.
·     Request_cloud_auth_success—Authentication succeeded.
·     Register—Sent a registration request.
·     Register_success—Registration succeeded.
·     Request—Sent a handshake request.
·     Request_success—Handshake succeeded.
IP address of the cloud server. This field displays N/A if the cloud server is not configured with a domain name or the system fails to resolve the domain name into an IP address.
Domain name of the cloud server. If the domain name is not specified, this field displays N/A.
TCP port number used by the device to initiate the authentication to a cloud server. If the authentication port is not specified, this field displays N/A.
TCP port number used to establish cloud connections. If the connection port is not specified, this field displays N/A.
Connected at
Time when the cloud connection was established. This field displays N/A if no connection is established.
Duration
Duration since the establishment of the cloud connection.
Process state
Cloud connection process state:
·     DNS not parsed.
·     DNS parsed.
·     Message not sent.
·     Message sent.
·     Message not received.
·     Message received.
This field displays N/A if the cloud connection is not in any process state.
Failure reason
Cloud connection failure reason:
·     DNS parse failed.
·     Socket connection failed.
·     SSL creation failed.
·     Sending CAS url request failed.
·     Sending CAS TGT failed.
·     Sending CAS ST failed.
·     Sending cloud auth failed.
·     Sending register failed.
·     Processing CAS url response failed.
·     Processing CAS TGT response failed.
·     Processing CAS ST response failed.
·     Processing cloud auth response failed.
·     Processing register response failed.
·     Sending handshake request failed.
·     Processing handshake failed.
·     Sending websocket request failed.
·     Processing websocket packet failed.
·     Insufficient or expired license.
This field displays N/A if no failure reason is present.
Last down reason
Reason for the most recent cloud connection interruption:
·     Device or process rebooted.
·     Socket connection error.
·     Configuration changed.
·     Received websocket close packet from cloud.
·     Keepalive expired.
·     Packet processing failed.
·     Main connection went down.
·     Cloud reset connection.
·     Memory reached threshold.
This field displays N/A if no last failure reason is present. If no details is available for the most recent connection down, the details field displays N/A.
Last down at
Time when the cloud connection went down most recently. This field displays N/A if no cloud connection has been established or no connection has been terminated.
Reason for the most recent cloud connection packet sending failure:
·     Tunnel is being deleted.
·     Tunnel socket is invalid.
·     Failed to convert string to json.
·     Failed to convert json to string.
·     Failed to create message node.
·     Tunnel is not ready.
·     Failed to create packet buffer.
·     SSL sending failure.
This field displays N/A if no last report failure reason is present. If no details is available for the most recent report failure, the details field displays N/A.
If the reason is SSL sending failure, one of the following detailed reason will be displayed:
·     ssl error none.
·     ssl error ssl.
·     ssl error read.
·     ssl error write.
·     ssl error x509 lookup.
·     ssl error syscall.
·     ssl error zero return.
·     ssl error connect.
·     ssl error accept.
Time when the most recent cloud connection packet sending failure occurred. This field displays N/A if packet sending failure has never occurred.
Number of packets that are dropped because the CMTNL buffer limit is reached.
Total number of dropped packets.
Reason for the most recent unfinished packet sending:
·     Interrupted system call.
·     Socket buffer is full.
This field displays N/A if no last report incomplete reason is present.
Time when the most recent unfinished packet sending occurred. This field displays N/A if no unfinished packet sending occurs.
Buffer full count
Number of times that the buffer becomes full.
