12-WLAN Advanced Features Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(R1411P02)-6W10212-WLAN Advanced Features Command Reference
07-WLAN mesh commands
07-WLAN mesh commands 208.29 KB
WLAN mesh commands
akm mode sae
Use akm mode sae to set the authentication and key management mode to simultaneous authentication of equals (SAE).
Use undo akm mode to restore the default.
akm mode sae
undo akm mode
The authentication and key management mode is not set.
Mesh profile view
Make sure the mesh profile is disabled before you configure or remove its authentication and key management mode setting.
# Set the authentication and key management mode to SAE in mesh profile 1.
[Sysname] wlan mesh-profile 1
[Sysname-wlan-mesh-profile-1] akm mode sae
display wlan mesh-profile
auto-connect enable
Use auto-connect enable to enable automatic mesh link establishment.
Use undo auto-connect enable to to disable automatic mesh link establishment.
auto-connect enable
Automatic mesh link establishment is disabled.
Mesh policy view
With this feature enabled, the AC allows fit APs to share mesh-related configuration information with a CPE upon receiving an automatic connection request from the CPE. This enables the CPE not configured with a mesh profile to automatically establish a stable mesh link with the local end.
Use this feature together with the mesh auto-connect enable command.
# Enable automatic mesh link establishment.
[Sysname] wlan mesh-policy 1
[Sysname-wlan-mesh-policy-1] auto-connect enable
This operation will allow the device to share mesh configuration, which might cause security issues. Continue? [Y/N]:Y
comware5-compatibility enable
Use comware5-compatibility enable to enable Comware 7 APs to establish mesh connections with Comware 5 APs.
Use undo comware5-compatibility enable to disable Comware 7 APs from establishing mesh connections with Comware 5 APs.
Comware 7 APs cannot establish mesh connections with Comware 5 APs.
Mesh policy view
In a scenario where both Comware 7 and Comware 5 APs are deployed, execute this command on all Comware 7 APs that require mesh connections.
# Enable Comware 7 APs to establish mesh connections with Comware 5 APs.
[Sysname] wlan mesh-policy abc
[Sysname-wlan-mesh-policy-abc] comware5-compatibility enable
display wlan mesh-policy
display wlan mesh-link ap
Use display wlan mesh-link ap to display mesh link information for APs.
display wlan mesh-link ap [ name ap-name ] [ verbose ]
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain alphanumeric characters, underscores (_), dots (.), brackets ([]), slashes (/), and hyphens (-). If you do not specify an AP, this command displays mesh link information for all APs.
verbose: Displays detailed mesh link information. If you do not specify this keyword, the command displays brief mesh link information.
# Display brief mesh link information for AP ap1.
<Sysname> display wlan mesh-link ap name ap1
 AP name: ap1
 Peer            Local           Status      RSSI  Packets(Rx/Tx)
 4ab7-c78a-22ff  75bb-c36d-4ef8  Forwarding  22    0/0
Peer
MAC address of the peer MP.
Local
MAC address of the local AP.
Status
Status of the link. This field displays Forwarding if the mesh link is forwarding traffic.
RSSI
RSSI on the mesh link.
Packets(Rx/Tx)
Packet statistics for the mesh link:
·     Rx—Number of received packets.
·     Tx—Number of sent packets.
# Display detailed mesh link information for AP ap1.
<Sysname> display wlan mesh-link ap name ap1 verbose
AP name: ap1
 Peer MAC                  : 4ab7-c78a-22ff
 Local MAC                 : 75bb-c36d-4ef8
 Status                    : Forwarding
 Link mode                 : dot11an
 RSSI                      : 67
 SNR                       : 76
 Noise                     : 0 dBm
 Cost                      : 0
 Incorrect packets         : 0.00 %
 Packets
   Received                : 170
   Sent                    : 157
   Resent                  : 0
   Lost                    : 0
# Display detailed mesh link information for all APs.
<Sysname> display wlan mesh-link ap verbose
AP name: ap1
 Peer MAC                  : 84d9-317d-9710
 Local MAC                 : 70f9-6dd7-cf00
 Status                    : Forwarding
 Link mode                 : dot11an
 RSSI                      : 67
 SNR                       : 67
 Noise                     : 0 dBm
 Cost                      : 0
 Incorrect packet          : 0.00 %
 Packets
   Received                : 1508
   Sent                    : 14617
   Resent                  : 162
   Lost                    : 0
AP name: ap2
 Local MAC                 : 0606-e203-1111
 Status                    : Forwarding
 Link mode                 : dot11an
 RSSI                      : 62
 SNR                       : 62
 Noise                     : 0 dBm
 Cost                      : 0
 Incorrect packet          : 0.03 %
 Packets
   Received                : 2921
   Sent                    : 2877
   Resent                  : 178
   Lost                    : 1
Peer MAC
Local MAC
Status
Link mode
Radio mode.
RSSI
SNR
Signal to noise ratio.
Cost
Link cost.
Incorrect packets
Percentage of sent packets that encountered transmission errors.
Received
Total number of received packets.
Sent
Total number of sent packets.
Resent
Number of retransmitted packets.
Lost
Number of lost packets.
Use display wlan mesh-policy to display mesh policy information.
display wlan mesh-policy [ mesh-policy-name ]
mesh-policy-name: Specifies a mesh policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all mesh policies.
# Display information about all mesh policies.
<Sysname> display wlan mesh-policy
Mesh policy name                     : default_mesh_policy
Mesh link initiation                 : Enabled
Max links                            : 2
Probe request interval               : 1000 ms
Link hold RSSI                       : 15
Link saturation RSSI                 : 150
Link establish threshold             : 5
Temporary link establish             : Enabled
Transmission method                  : Air
Active link keepalive transmit level : 0
Location mode                        : 0
Comware5-compatibility               : Disabled
Multi-link transmit                  : Enabled (IPv4 ACL 3000)
Auto connection                      : Disabled
Status of the mesh link initiation feature:
·     Enabled.
·     Disabled.
Max links
Maximum number of links.
Link hold RSSI
Mesh link hold RSSI.
Mesh link saturation RSSI.
Mesh link establishment threshold.
Temporary link establishment:
·     Enabled.
·     Disabled.
Transmission method
Mesh signal transmission method:
·     Air.
·     Waveguide—Waveguides or LCX cables.
Level of interval for sending keepalive requests:
·     0Interval of 100 ms.
·     1Interval of 200 ms.
·     2Interval of 400 ms.
·     3Interval of 600 ms.
·     4Interval of 1000 ms.
Location mode
Location of the trackside AP:
·     0—Invalid.
·     7Garage.
Whether establishing mesh connections with Comware 5 APs is enabled:
·     Enabled.
·     Disabled.
Multi-link transmit
Enabling status of multi-transmission for mesh unicast packets:
·     Enabled.
·     Disabled.
·     (IPv4 ACL acl-number) specifies the number of the IPv4 ACL specified for multi-transmission for mesh unicast packets. If no ACL is specified, this parameter is not displayed.
Auto connection
Whether automatic mesh link establishment is enabled:
·     Enabled.
·     Disabled.
Use display wlan mesh-profile to display mesh profile information.
display wlan mesh-profile [ mesh-profile-number ]
mesh-profile-number: Specifies a mesh profile by its number in the range of 1 to 32. If you do not specify a mesh profile, this command displays information about all mesh profiles.
# Display information about all mesh profiles.
<Sysname> display wlan mesh-profile
Mesh profile number          : 1
Mesh ID                      : 11
Link keepalive interval      : 2 s
Link backhaul rate           : 18 Mbps
Mesh profile status          : Enabled
Link metric type             : Not Configured
Mesh forwarding-location     : AC
AKM mode                     : None
PSK status                   : Disabled
Mesh profile number          : 2
Mesh ID                      : 22
AKM mode                     : None
Mesh profile status
Status of the mesh profile:
·     Enabled.
·     Disabled.
Mesh forwarding location
Location of mesh forwarding:
·     ACCentralized forwarding mode.
·     APLocal forwarding mode.
AKM mode
Authentication and key management mode:
·     None—No authentication and key management mode is specified.
·     SAE—SAE mode is specified.
PSK status
Preshared key configuration status:
·     Enabled—A preshared key is configured.
·     Disabled—No preshared key is configured.
interface wlan-mesh
Use interface wlan-mesh to create a mesh interface and enter its view, or enter the view of an existing mesh interface.
Use undo interface wlan-mesh to remove a mesh interface.
interface wlan-mesh interface-number
undo interface wlan-mesh interface-number
No mesh interface exists.
AP view
AP group view
interface-number: Specifies the number of the mesh interface in the range of 0 to 1023.
Make sure the mesh interfaces created in AP view and AP group view have different interface numbers.
# Create mesh interface 1 for AP ap1 and enter WLAN-mesh interface view.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] interface wlan-mesh 1
[Sysname-wlan-ap-ap1-wlan-mesh-1]
# Create mesh interface 2 for APs in AP group g1 and enter AP group's WLAN-mesh interface view.
[Sysname] wlan ap-group g1
[Sysname-wlan-ap-group-g1] interface wlan-mesh 2
[Sysname-wlan-ap-group-g1-wlan-mesh-2]
mesh-interface
link-hold-rssi
Use link-hold-rssi to set the mesh link hold RSSI, the minimum signal strength for a mesh link to be retained.
Use undo link-hold-rssi to restore the default.
link-hold-rssi value
undo link-hold-rssi
The mesh link hold RSSI is 15.
Mesh policy view
value: Specifies the mesh link hold RSSI in the range of 5 to 100.
# Set the mesh link hold RSSI to 24 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-hold-rssi 24
link-initiation enable
Use link-initiation enable to enable mesh link initiation.
Use undo link-initiation enable to disable mesh link initiation.
Mesh link initiation is enabled.
Mesh policy view
Mesh link initiation enables the MP to send Link Open requests to a peer without having received a Link Open request from that peer. If this feature is disabled, the MP must wait for a Link Open request from its peer before it can send one.
# Disable mesh link initiation.
[Sysname-wlan-mesh-policy-abc] undo link-initiation enable
link-keepalive
Use link-keepalive to set the mesh link keepalive interval.
Use undo link-keepalive to restore the default.
link-keepalive keepalive-interval
undo link-keepalive
The mesh link keepalive interval is 2 seconds.
Mesh profile view
keepalive-interval: Specifies a keepalive interval in the range of 1 to 1800 seconds.
MPs on a mesh link use keepalive packets to detect mesh link status. The MP with a higher MAC address sends keepalive packets at the keepalive interval to the peer end. The sending MP disconnects the mesh link if it has not received a reply before three consecutive keepalive intervals expire. The receiving MP disconnects the mesh link if it has not received keepalive packets before three consecutive keepalive intervals expire. For correct link status detection, the keepalive interval at the sending end must be equal to or less than three times the keepalive interval at the receiving end.
# Set the mesh link keepalive interval to 6 seconds in mesh profile 1.
[Sysname-wlan-mesh-profile-1] link-keepalive 6
link-maximum-number
Use link-maximum-number to set the maximum number of mesh links on a radio.
Use undo link-maximum-number to restore the default.
link-maximum-number max-link-number
A maximum of two mesh links can be established on a radio.
Mesh policy view
max-link-number: Specifies a limit in the range of 1 to 8.
The MP will stop establishing new mesh links on a radio after the maximum number of mesh links is reached.
# Set the maximum number of mesh links to 5 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-maximum-number 5
mesh forwarding-location ac
Use mesh forwarding-location ac to enable centralized forwarding of mesh data packets.
Use undo mesh forwarding-location ac to restore the default.
The local forwarding method is used for mesh data packets.
Mesh profile view
Application scenarios
In MLSP scenarios, to enhance the reliability of mesh links and reduce the packet loss rate, you can enable multi-link transmission of unicast data packets on trackside APs and onboard APs, and enable centralized forwarding for mesh data packets on trackside APs.
Operating mechanism
After you enable multi-link transmission of mesh unicast data packets on trackside APs and onboard APs, the APs transmit the same mesh unicast data packets through multiple mesh links.
After you enable centralized forwarding of mesh data packets on trackside APs, the trackside APs pass the received mesh data packets through the CAPWAP tunnel to the AC for processing, facilitating the AC to eliminate duplicate mesh data packets.
You can change the forwarding location of mesh data packets only when the mesh profile is disabled.
# Enable centralized forwarding of mesh data packets.
<H3C> system-view
[H3C] wlan mesh-profile 1
[H3C-wlan-mesh-profile-1] mesh forwarding-location ac
mesh multi-link-transmit enable
Use mesh multi-link-transmit enable to enable multi-link transmission of mesh unicast data packets.
Use undo mesh multi-link-transmit enable to disable multi-link transmission of mesh unicast data packets.
mesh multi-link-transmit enable [ acl acl-number ]
undo mesh multi-link-transmit enable [ acl ]
Multi-link transmission of mesh unicast data packets is disabled.
Mesh policy view
acl acl-number: Specifies the number of an IPv4 advanced ACL, in the range of 3000 to 3999. If you do not specify this option, the command enables multi-link transmission on all mesh unicast data packets.
Operating mechanism
After you specify an ACL, any mesh unicast data packets that match the ACL will be transmitted over multiple mesh links, regardless of whether the packets are allowed or denied in the ACL.
# Enable multi-link transmission on all mesh unicast data packets.
[Sysname] wlan mesh-policy test
[Sysname-wlan-mesh-policy-test] mesh multi-link-transmit enable
mesh peer-mac-address
Use mesh peer-mac-address to add an MP to the mesh peer blacklist or whitelist.
Use mesh peer-mac-address disable to remove all MPs from the mesh peer blacklist or whitelist and configure the AP to not inherit the configuration in an AP group's radio views.
Use undo mesh peer-mac-address to remove MPs from the mesh peer blacklist or whitelist.
Radio view:
mesh peer-mac-address [ blacklist ] { mac-address | disable }
undo mesh peer-mac-address [ blacklist ] [ mac-address ]
AP group's radio view:
mesh peer-mac-address [ blacklist ] mac-address
In radio view, an AP uses the configuration in an AP group's radio view.
In an AP group's radio view, no mesh peer blacklist or whitelist exists.
Radio view
blacklist: Adds the MAC address of an MP to the mesh peer blacklist. If you do not specify this keyword, the command adds the MAC address to the mesh peer whitelist.
mac-address: Specifies the MAC address of a radio on an MP in H-H-H format.
If you configure both the blacklist and whitelist, only the whitelist takes effect.
If you execute the command multiple times to add the same MAC address to the whitelist or blacklist, the most recent configuration takes effect.
The configuration in radio view takes precedence over the configuration in an AP group's radio views.
# Add the MAC address of a radio on an MP to the mesh peer whitelist for AP ap1.
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] mesh peer-mac-address 4ab7-c78a-22ff
# Add the MAC address of radio on an MP to the mesh peer blacklist for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mesh peer-mac-address blacklist 4ab7-c78a-22ff
# Add the MAC address of a radio on an MP to the mesh peer whitelist for APs in AP group g1.
[Sysname-wlan-ap-group-g1] ap-model WA6320
[Sysname-wlan-ap-group-g1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-g1-ap-model-WA6320-radio-1] mesh peer-mac-address 4ab7-c78a-33ff
mesh-id
Use mesh-id to assign a mesh ID to a mesh profile.
Use undo mesh-id to restore the default.
mesh-id mesh-id
undo mesh-id
A mesh profile does not contain a mesh ID.
Mesh profile view
mesh-id: Specifies a mesh ID, a case-sensitive string of 1 to 32 characters.
The mesh ID in each mesh profile must be unique.
MPs on the same mesh network must use the same mesh ID.
# Assign mesh ID mesh to mesh profile 1.
[Sysname-wlan-mesh-profile-1] mesh-id mesh
mesh-interface
Use mesh-interface to bind a mesh interface to a radio.
Use mesh-interface disable to unbind a mesh interface from a radio and configure the AP to not inherit the configuration in AP group's radio views.
Use undo mesh-interface to restore the default.
Radio view:
mesh-interface { interface-number | disable }
undo mesh-interface
mesh-interface interface-number
undo mesh-interface
In an AP group's radio view, no mesh interface is bound to a radio.
Radio view
interface-number: Specifies the number of a mesh interface in the range of 0 to 1023.
You can bind only one mesh interface to a radio. If you execute this command multiple times, the most recent binding takes effect.
Mesh interfaces created in AP view can be bound to a radio only in radio view. Mesh interfaces created in AP group view can be bound to a radio in both radio view and AP group's radio view.
# Bind mesh interface 1 to radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mesh-interface 1
# Bind mesh interface 2 to radio 1 of APs in AP group g1.
[Sysname]wlan ap-group g1
[Sysname-wlan-ap-group-g1-ap-model-WA6320-radio-1] mesh-interface 2
interface wlan-mesh
mesh-peer intra-ac-mpp enable
Use mesh-peer intra-ac-mpp enable to enable MPPs associated with the same AC to become mesh peers.
Use undo mesh-peer intra-ac-mpp enable to restore the default.
To avoid loops, MPPs associated with the same AC cannot become mesh peers.
Global configuration view
Make sure the mesh links established between MPPs associated with the same AC are not in VLAN 1.
# Enable MPPs associated with the same AC to become mesh peers.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] mesh-peer intra-ac-mpp enable
mesh-policy
Use mesh-policy to bind a mesh policy to a radio.
Use undo mesh-policy to restore the default.
Radio view:
mesh-policy { default | name policy-name }
undo mesh-policy
mesh-policy name policy-name
undo mesh-policy
In an AP group's radio view, default mesh policy default_mesh_policy is bound to a radio.
Radio view
default: Specifies default mesh policy default_mesh_policy.
You can bind only one mesh policy to a radio. If you execute this command multiple times, the most recent binding takes effect.
The configuration in radio view takes precedence over the configuration in AP group's radio views.
# Bind mesh policy policy1 to radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mesh-policy name policy1
# Bind mesh policy policy2 to radio 1 of APs in AP group g1.
[Sysname-wlan-ap-group-g1-ap-model-WA6320-radio-1] mesh-policy name policy2
# Bind the default mesh policy to radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mesh-policy default
wlan mesh-policy
mesh-port access vlan
Use mesh-port access vlan to assign an access-type mesh interface to a VLAN.
Use undo mesh-port access vlan to restore the default.
mesh-port access vlan vlan-id
An access port belongs to VLAN 1.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Make sure the VLAN exists before you execute this command.
# Assign WLAN-mesh 1 of AP ap1 to VLAN 2.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port access vlan 2
# Assign WLAN-mesh 2 of APs in AP group g1 to VLAN 2.
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port access vlan 2
interface wlan-mesh
remote-configuration enable
mesh-port hybrid pvid
Use mesh-port hybrid pvid to set the PVID for a hybrid-type mesh interface.
Use undo mesh-port hybrid pvid to set the PVID for a hybrid-type mesh interface to VLAN 1.
mesh-port hybrid pvid vlan vlan-id
The PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can specify a non-existent VLAN as the port VLAN for a hybrid port.
Make sure the mesh interfaces used by two MPs to establish mesh links with each other have the same PVID.
To enable a hybrid port to transmit packets from its port VLAN, you must assign the hybrid port to the port VLAN.
# Set the PVID of WLAN-mesh 1 to VLAN 100, and assign WLAN-mesh 1 to VLAN 100 as an untagged member for AP ap1.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port link-type hybrid
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port hybrid pvid vlan 100
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port hybrid vlan 100 untagged
# Set the PVID of WLAN-mesh 2 to VLAN 100, and assign WLAN-mesh 2 to VLAN 100 as an untagged member for APs in AP group g1.
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port link-type hybrid
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port hybrid pvid vlan 100
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port hybrid vlan 100 untagged
mesh-port link-type
Use mesh-port hybrid vlan to assign a hybrid-type mesh interface to the specified VLANs.
Use undo mesh-port hybrid vlan to remove a hybrid-type mesh interface from the specified VLANs.
mesh-port hybrid vlan vlan-id-list { tagged | untagged }
undo mesh-port hybrid vlan vlan-id-list
A hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# Configure WLAN-mesh 1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member for AP ap1.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port hybrid vlan 2 4 50 to 100 tagged
# Configure WLAN-mesh 2 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member for APs in AP group g1.
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port hybrid vlan 2 4 50 to 100 tagged
mesh-port link-type
mesh-port link-type
Use mesh-port link-type to set the link type for a mesh interface.
Use undo mesh-port link-type to restore the default.
mesh-port link-type { access | hybrid | trunk }
A mesh interface is an access port.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of a port between trunk and hybrid, first set the link type to access.
# Configure WLAN-mesh 1 as a trunk port for AP ap1.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port link-type trunk
# Configure WLAN-mesh 2 as a trunk port for APs in AP group g1.
mesh-port trunk permit vlan
Use mesh-port trunk permit vlan to assign a trunk-type mesh interface to the specified VLANs.
Use undo mesh-port trunk permit vlan to remove a trunk-type mesh interface from the specified VLANs.
mesh-port trunk permit vlan { vlan-id-list | all }
undo mesh-port trunk permit vlan { vlan-id-list | all }
A trunk port allows packets only from VLAN 1 to pass through.
all: Specifies all VLANs.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, only packets from the PVID can pass through untagged.
# Configure WLAN-mesh 1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 for AP ap1.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port trunk permit vlan 2 4 50 to 100
# Configure WLAN-mesh 2 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 for APs in AP group g1.
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port link-type trunk
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port trunk permit vlan 2 4 50 to 100
mesh-port link-type
mesh-port trunk pvid
Use mesh-port trunk pvid to set the PVID for a trunk-type mesh interface.
Use undo mesh-port trunk pvid to restore the default.
mesh-port trunk pvid vlan vlan-id
The PVID of a trunk port is VLAN 1.
To enable a trunk port to transmit packets from its port VLAN, you must assign the trunk port to the port VLAN.
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port trunk pvid vlan 100
[Sysname-wlan-ap-ap1-wlan-mesh-1] mesh-port trunk permit vlan 100
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port trunk pvid vlan 100
[Sysname-wlan-ap-group-g1-wlan-mesh-2] mesh-port trunk permit vlan 100
mesh-port link-type
mesh-profile
Use mesh-profile to bind a mesh profile to a radio.
Use mesh-profile disable to unbind a mesh profile from a radio and configure the AP to not inherit the configuration in an AP group's radio views.
Use undo mesh-profile to restore the default.
Radio view:
mesh-profile { mesh-profile-number | disable }
undo mesh-profile
mesh-profile mesh-profile-number
undo mesh-profile
In an AP group's radio view, no mesh profile is bound to a radio.
Radio view
When you bind a mesh profile to a radio, the AC first checks the current forwarding mode of the online AP. If the AP is in NSS hardware forwarding mode, it must be restarted to switch to data-path (DP) mode before the mesh profile can be successfully bound. If the AP is offline, the AC device will check the forwarding mode after the AP comes online.
# Bind mesh profile 1 to radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] mesh-profile 1
# Bind mesh profile 2 to radio 1 of APs in AP group g1.
[Sysname-wlan-ap-group-g1-ap-model-WA6320-radio-1] mesh-profile 2
mesh-profile enable
wlan mesh-profile
mesh-profile enable
Use mesh-profile enable to enable a mesh profile.
Use undo mesh-profile enable to disable a mesh profile.
mesh-profile enable
A mesh profile is disabled.
Mesh profile view
Before you enable a mesh profile, you must assign it a mesh ID.
# Enable mesh profile 1.
[Sysname-wlan-mesh-profile-1] mesh-profile enable
mesh-id
portal-service enable
Use portal-service enable to disable an MPP from sending probe requests.
Use portal-service disable to enable an MPP to send probe requests and configure the AP to not inherit the configuration in AP group view or global configuration view.
Use undo portal-service to restore the default.
AP view or AP group view:
portal-service { disable | enable }
undo portal-service
Global configuration view:
undo portal-service
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration global configuration view.
In global configuration view, MPPs can send probe requests.
AP view
AP group view
As the mesh point that connects the WLAN mesh network to a wired network, an MPP might need to establish a large number of mesh links. To maintain its performance, you can disable the MPP from sending probe requests for neighbor discovery. The MPP will only respond to the probe requests from other MPs.
# Disable an MPP from sending probe requests for AP ap1.
[Sysname-wlan-ap-ap1] portal-service enable
# Disable an MPP from sending probe requests for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] portal-service enable
# Disable the MPPs from sending probe requests globally.
[Sysname-wlan-global-configuration] portal-service enable
preshared-key
Use preshared-key to add a preshared key to a mesh profile.
Use undo preshared-key to restore the default.
preshared-key { pass-phrase | raw-key } { cipher | simple } string
undo preshared-key
A mesh profile does not contain a preshared key.
Mesh profile view
pass-phrase: Sets the key in character string form.
raw-key: Sets the key in hexadecimal form.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies a case-sensitive key string. The following are the key length ranges:
·     pass-phrase plaintext—8 to 63 characters.
·     pass-phrase ciphertext—41 to 117 characters.
·     raw-key plaintext—64 hexadecimal digits.
·     raw-key ciphertext—117 characters.
Make sure the mesh profile is disabled before you use this command.
You can configure only one preshared key in a mesh profile. If you execute this command multiple times, the most recent configuration takes effect.
# Add preshared key abcdefghig in plain text to mesh profile 1.
[Sysname-wlan-mesh-profile-1] preshared-key pass-phrase simple abcdefghig
probe-request-interval
Use probe-request-interval to set the probe request interval.
Use undo probe-request-interval to restore the default.
probe-request-interval interval-value
The probe request interval is 1000 milliseconds.
Mesh policy view
interval-value: Specifies an interval in the range of 100 to 8191 milliseconds. As a best practice, set the value to a multiple of 100.
# Set the probe request interval to 500 milliseconds for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] probe-request-interval 500
wlan mesh-policy
Use wlan mesh-policy to create a mesh policy and enter its view, or enter the view of an existing mesh policy.
Use undo wlan mesh-policy to delete a mesh policy.
wlan mesh-policy policy-name
undo wlan mesh-policy policy-name
A system-defined mesh policy exists. The policy name is default_mesh_policy.
Before you can modify or delete attribute settings in the mesh policy that is used on a radio, you must disable the mesh profile that is bound to that radio.
You cannot delete or modify the system-defined mesh policy.
# Create mesh policy abc and enter mesh policy view.
wlan mesh-profile
Use wlan mesh-profile to create a mesh profile and enter its view, or enter the view of an existing mesh profile.
Use undo wlan mesh-profile to delete a mesh profile.
wlan mesh-profile mesh-profile-number
undo wlan mesh-profile mesh-profile-number
No mesh profiles exist.
To modify attribute settings in a mesh profile, you must first disable the mesh profile.
# Create mesh profile 1 and enter its view.
mesh-profile enable
