05-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9141-6W10005-Layer 2—LAN Switching Command Reference
06-VLAN termination commands
06-VLAN termination commands 108.63 KB
dot1q ethernet-type
Use dot1q ethernet-type to set the TPID value in the outermost VLAN tag of packets received and sent by an interface.
Use undo dot1q ethernet-type to restore the default.
dot1q ethernet-type hex-value
The TPID value for the outermost VLAN tag of a VLAN-tagged packet received and sent by the interface is 0x8100.
hex-value: Sets a hexadecimal TPID value in the range of 600 to ffff, excluding the common protocol type values listed in Table 1.
Table 1 Common protocol type values
Protocol
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88CC
802.1X
0x888E
802.1ag
0x8902
Cluster
0x88A7
Reserved on the device
0xFFFD/0xFFFE/0xFFFF
After you execute this command, only packets whose TPID in the outermost VLAN tag is 0x8100 or the configured value are processed as VLAN-tagged packets.
When sending a packet, the interface sets the TPID value in the outermost VLAN tag to the configured value. If the packet includes two or more layers of VLAN tags, the interface sets the TPID values in the other VLAN tags to 0x8100.
Do not use this command in subinterface view.
Configurations made in Layer 3 Ethernet interface view take effect on all subinterfaces.
# Set the TPID value to 0x9100 in the outermost VLAN tag of VLAN-tagged packets received and sent by the subinterfaces of GigabitEthernet 0/0/1.
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] dot1q ethernet-type 9100
second-dot1q
Use second-dot1q to enable QinQ termination on an interface, and specify the Layer 2 VLAN IDs of the VLAN-tagged packets that can be terminated by the interface.
Use undo second-dot1q to disable QinQ termination on an interface.
second-dot1q { vlan-id-list | any } [ loose ]
undo second-dot1q { vlan-id-list | any } [ loose ]
QinQ termination is disabled on an interface.
VLAN interface view
vlan-id-list: Specifies a space-separated list of up to 10 Layer 2 VLAN ID items. Each item specifies a Layer 2 VLAN ID or a range of Layer 2 VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
any: Specifies all values between 1 and 4094.
loose: Configures the interface to receive and terminate packets that include two or more layers of VLAN tags.
When you execute this command, the Layer 1 VLAN ID of VLAN-tagged packets that can be terminated by the interface is the interface number. This Layer 1 VLAN ID is not configurable.
# Configure VLAN-interface 10 to terminate VLAN-tagged packets with Layer 2 VLAN IDs in the range of 10 to 20. Configure VLAN-interface 12 to terminate VLAN-tagged packets with Layer 2 VLAN ID 100. Configure VLAN-interface 100 to terminate VLAN-tagged packets with any Layer 2 VLAN IDs.
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] quit
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
[Sysname-Vlan-interface12] quit
[Sysname-Vlan-interface100] second-dot1q any
The following table describes the configuration results:
VLAN interface
Layer 1 VLAN ID of VLAN-tagged packets that the VLAN interface can terminate
Layer 2 VLAN IDs of VLAN-tagged packets that the VLAN interface can terminate
VLAN-interface 10
10
10–20
VLAN-interface 12
12
100
VLAN-interface 100
100
1–4094
vlan-termination broadcast enable
Use vlan-termination broadcast enable to enable an interface to transmit broadcasts and multicasts.
Use undo vlan-termination broadcast enable to disable an interface from transmitting broadcasts and multicasts.
Broadcast and multicast packets are dropped on an interface configured with Dot1q/QinQ termination to terminate packets of multiple VLANs.
VLAN interface view
IMPORTANT
IMPORTANT:
This command affects system performance. If system performance is seriously affected by this command, execute the undo form of this command to remove the command configuration.
To transmit a broadcast or multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
·     Configure GigabitEthernet 0/0/1.10 to tag a multicast or broadcast packet with each VLAN tag in the range of 10 to 20.
# Enable Dot1q termination on GigabitEthernet 0/0/1.10 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 10 to 20.
[Sysname] interface gigabitethernet 0/0/1.10
[Sysname-GigabitEthernet0/0/1.10] vlan-type dot1q vid 10 to 20
# Enable GigabitEthernet 0/0/1.10 to transmit broadcast and multicast packets.
[Sysname-GigabitEthernet0/0/1.10] vlan-termination broadcast enable
·     Configure GigabitEthernet 0/0/1.10 to tag a multicast or broadcast packet with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
# Configure GigabitEthernet 0/0/1.10 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname-GigabitEthernet0/0/1.10] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
vlan-termination broadcast ra
Use vlan-termination broadcast ra to enable an interface to transmit router advertisement (RA) multicast packets.
Use undo vlan-termination broadcast ra to disable an interface from transmitting RA multicast packets.
VLAN interface view
To transmit an RA multicast packet, the interface starts a traversal over all the VLAN IDs specified for Dot1q/QinQ termination. It copies the packet and tags each copy with VLAN IDs, until all combinations of VLAN IDs are traversed.
On an IPv6 network, you must use this command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
·     Configure GigabitEthernet 0/0/1.10 to tag RA multicast packets with each VLAN tag in the range of 10 to 20.
# Enable GigabitEthernet 0/0/1.10 to transmit RA multicast packets.
[Sysname-GigabitEthernet0/0/1.10] vlan-termination broadcast ra
·     Configure GigabitEthernet 0/0/1.10 to tag RA multicast packets with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
vlan-type dot1q default
Use vlan-type dot1q default to enable default termination on a subinterface.
Use undo vlan-type dot1q default to disable default termination on a subinterface.
Default termination is disabled on a subinterface.
This command enables the subinterface to process packets that cannot be terminated by other subinterfaces on the same main interface.
On a main interface, you can execute this command only on one subinterface.
# Enable default termination on GigabitEthernet 0/0/1.1.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q default
[Sysname-GigabitEthernet0/0/1.1] quit
vlan-type dot1q untagged
Use vlan-type dot1q untagged to enable untagged termination on a subinterface.
Use undo vlan-type dot1q untagged to disable untagged termination on a subinterface.
Untagged termination is disabled on a subinterface.
This command enables the subinterface to process untagged packets.
# Enable untagged termination on GigabitEthernet 0/0/1.1.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q untagged
vlan-type dot1q vid
Use vlan-type dot1q vid to enable Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid to disable Dot1q termination on a subinterface.
vlan-type dot1q vid vlan-id-list [ loose ]
undo vlan-type dot1q vid vlan-id-list [ loose ]
Dot1q termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 outermost VLAN ID items. Each item specifies an outermost VLAN ID or a range of outermost VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
loose: Configures the subinterface to terminate packets that include one or more layers of VLAN tags.
The outermost VLAN ID ranges specified by the vlan-id-list argument for different subinterfaces of a main interface cannot overlap.
# Configure GigabitEthernet 0/0/1.1 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q vid 2 to 100
# Configure GigabitEthernet 0/0/1.1 to terminate VLAN-tagged packets that include one or more layers of VLAN tags with the outermost VLAN ID 2.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q vid 2 loose
# Configure GigabitEthernet 0/0/1.2 to terminate VLAN-tagged packets whose outermost VLAN ID is 3.
[Sysname] interface gigabitethernet 0/0/1.2
[Sysname-GigabitEthernet0/0/1.2] vlan-type dot1q vid 3
Subinterface
Outermost VLAN ID of packets that can be terminated
Whether packets to be terminated include more than one layer of VLAN tags
2
Yes
3
No
vlan-type dot1q vid second-dot1q
Use vlan-type dot1q vid second-dot1q to enable QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs of VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid second-dot1q to disable QinQ termination on a subinterface.
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any } [ loose ]
undo vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any } [ loose ]
QinQ termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
loose: Configures the subinterface to receive and terminate packets that include two or more layers of VLAN tags.
Two subinterfaces of the same main interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
# Enable QinQ termination on the Layer 3 Ethernet subinterfaces, and configure each subinterface to terminate VLAN-tagged packets with the specified Layer 1 and Layer 2 VLAN IDs.
·     Configure GigabitEthernet 0/0/1.1 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 100.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q vid 100 second-dot1q 100
·     Configure GigabitEthernet 0/0/1.2 to terminate VLAN-tagged packets with Layer 1 VLAN ID 100 and Layer 2 VLAN IDs in the range of 200 to 300.
[Sysname-GigabitEthernet0/0/1.2] vlan-type dot1q vid 100 second-dot1q 200 to 300
[Sysname-GigabitEthernet0/0/1.2] quit
·     Configure GigabitEthernet 0/0/1.3 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is any value between 1 and 4094.
[Sysname] interface gigabitethernet 0/0/1.3
[Sysname-GigabitEthernet0/0/1.3] vlan-type dot1q vid 100 second-dot1q any
[Sysname-GigabitEthernet0/0/1.3] quit
·     Configure GigabitEthernet 0/0/1.4 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 0/0/1.4
[Sysname-GigabitEthernet0/0/1.4] vlan-type dot1q vid 100 second-dot1q 500 to 600
[Sysname-GigabitEthernet0/0/1.4] quit
·     Configure GigabitEthernet 0/0/1.5 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 200 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 0/0/1.5
[Sysname-GigabitEthernet0/0/1.5] vlan-type dot1q vid 200 second-dot1q 500 to 600
[Sysname-GigabitEthernet0/0/1.5] quit
·     Configure GigabitEthernet 0/0/1.6 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is in the range of 300 to 400 and Layer 2 VLAN ID is 100.
[Sysname] interface gigabitethernet 0/0/1.6
[Sysname-GigabitEthernet0/0/1.6] vlan-type dot1q vid 300 to 400 second-dot1q 100
[Sysname-GigabitEthernet0/0/1.6] quit
·     Configure GigabitEthernet 0/0/1.7 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname] interface gigabitethernet 0/0/1.7
[Sysname-GigabitEthernet0/0/1.7] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
[Sysname-GigabitEthernet0/0/1.7] quit
·     Configure GigabitEthernet 0/0/1.8 to terminate VLAN-tagged packets with a Layer 1 VLAN ID in the range of 300 to 400 and any Layer 2 VLAN ID.
[Sysname] interface gigabitethernet 0/0/1.8
[Sysname-GigabitEthernet0/0/1.8] vlan-type dot1q vid 300 to 400 second-dot1q any
Layer 1 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
Layer 2 VLAN IDs of VLAN-tagged packets that the subinterface can terminate
100
100
100
200–300
100
1–99, 101–199, 301–499, and 601–4094
100
500–600
200
500–600
300–400
100
300–400
500–600
300–400
1–99, 101–499, and 601–4094
# Configure GigabitEthernet 0/0/1.1 to terminate VLAN-tagged packets that include two or more layers of VLAN tags, with the Layer 1 VLAN ID 10 and Layer 2 VLAN ID 100.
[Sysname-GigabitEthernet0/0/1.1] vlan-type dot1q vid 10 second-dot1q 100 loose
# Configure GigabitEthernet 0/0/1.2 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 20.
[Sysname-GigabitEthernet0/0/1.2] vlan-type dot1q vid 20 second-dot1q 20
Subinterface
Whether the packets to be terminated include two or more layers of VLAN tags
10
100
Yes
20
20
No
