H3C New Generation Lossless Network Solution Based on DDC Architecture
2025-07-10 3 min read
Topics:
    You may also like
    In-Depth Analysis of H3C's Next-Generation Lossless Network Solution Based on DDC Architecture
    2025-08-26
    H3C's next-generation lossless network solution based on the DDC (Diversified dynamic-Connectivity) architecture and its computing cluster switch, the H3C S12500AI, directly addresses the demands of AI data centers for large-scale, 10,000-cards-level interconnect scenarios.
    From 30% Idling to 100% Throughput: DDC Pushes the Limits of Intelligent Computing Performance
    2025-07-25
    In the realm of Artificial Intelligence (AI) large model training, tech giants are facing a significant waste of computing power, with GPU clusters idling up to 30% of the time, costing millions daily. This inefficiency is due to the gap between network transmission latency and GPU processing speeds. However, the Diversified Dynamic-Connectivity (DDC) network technology, aims to eliminate this waste.
    DDC Evolution - Agile Network for the AI Era
    2025-07-15
    The emergence of Distributed Disaggregated Chassis (DDC) technology signifies a major shift in network architectures amid ongoing digital transformation. Introduced in 2019 for Data Center Interconnect (DCI), DDC has evolved significantly, becoming standardized in 2024 and applicable in diverse scenarios. This five-year journey from concept to industry implementation heralds a new era of disaggregated network design and operation.
