20-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5805P11)-6W10120-Network Management and Monitoring Command Reference
12-UCC commands
12-UCC commands 174.29 KB
UCC commands
application enable
Use application enable to enable UCC for an audio or video application.
Use undo application enable to disable UCC for an audio or video application.
application app-name enable
undo application app-name enable
UCC is disabled for audio and video applications.
UCC profile view
app-name: Specifies an application name.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
# Enable UCC for Skype applications.
[Sysname] ucc profile ssidcompany
[Sysname-ucc-profile-ssidcompany] application skype enable
ucc profile
application flow-mark
Use application flow-mark to configure priority marking for traffic from an audio or video application.
Use undo application flow-mark to restore the default.
application app-name flow-mark
undo application app-name flow-mark
Priority marking is not configured for traffic from audio and video applications.
UCC profile view
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured.
# Configure priority marking for Tencent Meeting traffic.
[Sysname-ucc-profile-ssidcompany] application tencentmeeting flow-mark
ucc profile
apr wlan-signature update
Use apr wlan-signature update to bulk upgrade APR signature libraries for APs on the AC.
apr wlan-signature update { file-name | default }
file-name: Specifies the name of the compressed package file containing the APR signature library file and brief application information file, a string of 1 to 255 characters with the suffix .dat.
default: Restores the APR signature library of the AP to the factory default signature library.
For the audio and video feature of the UCC module to take effect on an AP, you also need to configure the DPI application identification feature. DPI application identification depends on the APR signature library. To ensure correct audio and video operation, upgrade the APR signature library on the AP in time. In a distributed AP network environment with AC + fit AP deployed, one AC might manage multiple APs. If the audio and video feature of the UCC module is enabled for multiple APs, use this command to upgrade the APR signature library for the APs in bulk.
# Bulk upgrade APR signature libraries for APs.
[Sysname] apr wlan-signature update tmp.dat
display wlan ap statistics file-update
dfi enable
Use dfi enable to enable Dynamic Flow Inspection (DFI).
Use undo dfi enable to disable DFI.
dfi enable
undo dfi enable
DFI is disabled.
UCC profile view
With this feature enabled, wireless services that bound with this UCC profile identify and categorize wireless client traffic and preferentially forward audio and video traffic. Compared with DPI-based per-packet inspection, DFI has lower requirements on ACs because DFI identifies traffic based on flow signatures.
This feature is available only in wireless networks configured with local forwarding.
# Enable DFI.
[Sysname-ucc-profile-ssidcompany] dfi enable
display ucc profile
Use display ucc profile to display configuration information for UCC profiles.
display ucc profile [ profile-name ]
profile-name: Specifies a UCC profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a UCC profile, this command displays configuration information for all UCC profiles.
# Display configuration information for all UCC profiles.
<Sysname> display ucc profile
UCC profile information:
  UCC profile name: ssidcompany1
    SIP: Enabled
    DFI: Enabled
    Skype4B: Disabled
      App sharing DSCP priority   : 2
      App sharing 802.1p priority : 2
      Video DSCP priority         : 2
      Video 802.1p priority       : 2
      Voice DSCP priority         : 2
      Voice 802.1p priority       : 2
    DFI: Enabled
    UCC-enabled applications: tencentmeeting
                              qq
    Traffic-marking enabled applications: tencentmeeting
                                          qq
Total UCC profiles: 1
SIP
Status of SIP-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
DFI
Status of DFI for the UCC profile:
·     Enabled.
·     Disabled.
Skype4B
Status of Skype4B-based UCC for the UCC profile:
·     Enabled.
·     Disabled.
DSCP priority for Skype4B application sharing packets.
802.1p priority for Skype4B application sharing packets.
Video DSCP priority
DSCP priority for Skype4B video packets.
802.1p priority for Skype4B video packets.
Voice DSCP priority
DSCP priority for Skype4B voice packets.
802.1p priority for Skype4B voice packets.
DFI
·     Enabled.
·     Disabled.
dfi enable
sip enable
skype4b enable
display ucc table
Use display ucc table to display UCC entries.
display ucc table
# Display UCC entries.
<Sysname> display ucc table
UCC tuple5 entry info:
  Source IP/port           : 2.1.1.2/11111
  Destination IP/port      : 2.1.1.3/22222
  Transport layer protocol : UDP
  Flow type                : SIP
  Media type               : Audio
  Lifetime                 : 280
  Source IP/port           : 2.1.1.4/11113
  Destination IP/port      : 2.1.1.5/22224
  Flow type                : SIP
  Media type               : Video
  Lifetime                 : 260
UCC tuple3 entry info:
  Client IP/port           : 10.1.1.145/13454
  Transport layer protocol : TCP
  Flow type                : SKYPE4B
  Media type               : App-Share
  Lifetime                 : 62
  Client IP/port           : 10.1.1.155/8020
  Flow type                : SKYPE4B
  Lifetime                 : 62
Total tuple5 entries found : 2
Total tuple3 entries found : 2
Total entries found: 4
5-tuple entry information for UCC.
Source IP/port
Source IP address and port number in a UCC entry.
Destination IP/port
Destination IP address and port number in the UCC entry.
Flow type
Flow type:
·     App-Share.
·     SIP.
·     SKYPE4B.
Media type
Media type:
·     Audio.
·     Video.
Lifetime
Lifetime of the UCC entry, in seconds.
Triple entry information for UCC.
Client IP/port
Client IP address and port number in a UCC entry.
reset ucc table
sip enable
ucc profile
ucc-profile
display ucc whitelist ap
Use display ucc whitelist ap to display UCC AP whitelist.
# Display UCC AP whitelist.
<Sysname> display ucc whitelist ap
  AP Whitelist Entry Info:
    AP name: ap1, ap2, ap3
ucc whitelist ap
display ucc whitelist ap-group
Use display ucc whitelist ap-group to display UCC AP group whitelist.
# Display UCC AP group whitelist.
<Sysname> display ucc whitelist ap-group
  AP-group Whitelist Entry Info
    Group name: apg1, apg2
reset ucc table
Use reset ucc table to clear UCC entries.
reset ucc table [ sip | skype4b ]
sip: Specifies the SIP protocol.
skype4b: Specifies the Skype4B protocol.
If you do not specify any keywords, this command clears all UCC entries.
# Clear all UCC entries.
<Sysname> reset ucc table
display ucc table
sip enable
Use sip enable to enable SIP-based UCC.
Use undo sip enable to disable SIP-based UCC.
sip enable
undo sip enable
SIP-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio and video traffic, providing high-quality audio and video services.
This command takes effect only on audio and video services for wireless clients.
# Enable SIP-based UCC.
[Sysname-ucc-profile-ssidcompany] sip enable
ucc profile
skype4b app-share remark
Use skype4b app-share remark to configure priority marking for Skype4B application sharing packets.
Use undo skype4b app-share remark to restore the default.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b app-share remark { dscp | dot1p }
Priority marking is not configured for Skype4B application sharing packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B application sharing packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B application sharing packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B application sharing packets.
# Mark DSCP priority 6 for Skype4B application sharing packets.
[Sysname-ucc-profile-ssidcompany] skype4b app-share remark dscp 6
skype4b enable
Use skype4b enable to enable Skype4B-based UCC.
Use undo skype4b enable to disable Skype4B-based UCC.
skype4b enable
undo skype4b enable
Skype4B-based UCC is disabled.
UCC profile view
This command enables the service template or Layer 3 interface bound to a UCC profile to preferentially forward audio, video, and application sharing traffic, providing high-quality audio, video, and application sharing services.
This command takes effect only on audio, video, and application sharing services for wireless clients.
# Enable Skype4B-based UCC.
[Sysname-ucc-profile-ssidcompany] skype4b enable
display ucc profile
ucc profile
skype4b listener
Use skype4b listener to enable the device to communicate with the Skype4B server and specify the port number.
Use undo skype4b listener to disable the device from communicating with the Skype4B server.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
undo skype4b enable { http-port | https-port }
The device is disabled from communicating with the Skype4B server.
http-port http-port-num: Specifies the HTTP service port number in the range of 1025 to 55535.
https-port https-port-num: Specifies the HTTPS service port number in the range of 1025 to 55535.
ssl-policy ssl-policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 31 characters.
# Enable the device to communicate with the Skype4B server and specify the port number as 3000.
[Sysname] skype4b listener http-port 3000
ssl server-policy (Security Command Reference)
skype4b video remark
Use skype4b video remark to configure priority marking for Skype4B video packets.
Use undo skype4b video remark to restore the default.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b video remark { dscp | dot1p }
The DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B video packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B video packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B video packets.
# Mark DSCP priority 6 for Skype4B video packets.
[Sysname-ucc-profile-ssidcompany] skype4b video remark dscp 6
skype4b voice remark
Use skype4b voice remark to configure priority marking for Skype4B voice packets.
Use undo skype4b voice remark to restore the default.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
undo skype4b voice remark { dscp | dot1p }
The DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
UCC profile view
dscp dscp-value: Specifies the DSCP value to be marked for Skype4B voice packets, in the range of 0 to 63.
dot1p dot1p-value: Specifies the 802.1p priority to be marked for Skype4B voice packets, in the range of 0 to 7.
You can execute this command multiple times to configure different DSCP or 802.1p priorities for Skype4B voice packets.
# Mark DSCP priority 6 for Skype4B voice packets.
[Sysname-ucc-profile-ssidcompany] skype4b voice remark dscp 6
ucc profile
Use ucc profile to create a UCC profile and enter its view, or enter the view of an existing UCC profile.
Use undo ucc profile to delete a UCC profile.
ucc profile profile-name
undo ucc profile profile-name
No UCC profiles exist.
profile-name: Specifies the name of a UCC profile, a case-insensitive string of 1 to 31 characters. The UCC profile name can contain hyphens (-), underscores (_), left brackets ([), right brackets (]), and slashes (/).
# Create UCC profile ssidcompany and enter its view.
display ucc profile
ucc-profile
ucc whitelist ap
Use ucc whitelist ap to configure the UCC AP whitelist.
Use undo ucc whitelist ap to delete table entries from the UCC AP whitelist.
ucc whitelist ap ap-name
undo ucc whitelist ap [ ap-name ]
The UCC AP whitelist is not specified, and the UCC information of an AC can be reported to AC.
ap-name: Specifies an AP name, a case-sensitive string of 1 to 64 characters. Only letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), slashes (/), and hyphens (-) are allowed. If you do not specify this argument, this command deletes all table entries from the UCC AP white list.
Perform this task to allow only APs that belong to the UCC AP or AP group white list to collect and report UCC statistics to AC, reducing AC pressure from too many AP reports. In this way, pressure is also released for APs that do not belong to the UCC AP or AP group white list, because they no longer collect or report UCC statistics to AC.
Only UCC APs for audio and video traffic are restricted by the white list.
# Add AP ap1 to the UCC AP whitelist.
[Sysname] ucc whitelist ap ap1
Use ucc whitelist ap-group to configure the UCC AP group whitelist.
Use undo ucc whitelist ap-group to delete table entries from the UCC AP group whitelist.
ucc whitelist ap-group group-name
undo ucc whitelist ap-group [ group-name ]
UCC AP group whitelist is not specified.
group-name: Specifies an AP group name, a case-insensitive string of 1 to 31 characters. If you do not specify this argument, this command deletes all table entries from the UCC AP group white list.
Only UCC APs for audio and video traffic are restricted by the whitelist.
# Add AP group apg1 to the UCC AP group whitelist.
[Sysname] ucc whitelist ap-group apg1
ucc whitelist ap
ucc-profile
Use ucc-profile to bind a UCC profile.
Use undo ucc-profile to remove the binding of a UCC profile.
ucc-profile profile-name
undo ucc-profile
No UCC profile is bound.
Service template view
Layer 3 interface view
If the client traffic forwarder is the AC and the clients are in different subnets, bind a UCC profile to both a service template and a Layer 3 interface.
If the client traffic forwarder is an AP, bind a UCC profile to a service template.
# Bind UCC profile ssidcompany to service template service.
[Sysname-ucc-profile-ssidcompany] quit
[Sysname] wlan service-template service
[Sysname-wlan-st-service] ucc-profile ssidcompany
# Bind UCC profile ssidcompany to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ucc-profile ssidcompany
# Bind UCC profile ssidcompany to VLAN-interface 2.
[Sysname-Vlan-interface2] ucc-profile ssidcompany
application enable
ucc profile
