16-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5805P11)-6W10116-Security Command Reference
17-Protocol packet rate limit commands
17-Protocol packet rate limit commands 103.83 KB
anti-attack enable
Use anti-attack enable to enable packet rate limit.
Use undo anti-attack enable to disable packet rate limit.
anti-attack enable
Packet rate limit is disabled.
To implement packet rate limit for a protocol, you must complete the following tasks:
·     Execute the anti-attack enable command to enable packet rate limit.
·     Execute the anti-attack protocol enable command to enable packet rate limit for the protocol.
# Enable packet rate limit.
[Sysname] anti-attack enable
Use anti-attack protocol enable to enable packet rate limit for protocols.
Use undo anti-attack protocol enable to disable packet rate limit for protocols.
anti-attack protocol { all | protocol } enable
undo anti-attack protocol { all | protocol } enable
Packet rate limit is disabled for all protocols.
all: Specifies all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. For more information about the supported protocol values, use the display anti-attack protocol command.
# Enable packet rate limit for ARP.
[Sysname] anti-attack protocol arp enable
anti-attack enable
anti-attack protocol flow-threshold
Use anti-attack protocol flow-threshold to enable flow-based packet rate limit for a protocol and set the maximum transmission rate per flow.
Use undo anti-attack protocol flow-threshold to disable flow-based packet rate limit for a protocol.
anti-attack protocol protocol flow-threshold flow-rate-limit
undo anti-attack protocol protocol flow-threshold
Flow-based packet rate limit is disabled for all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. For information about supported protocol values, use the display anti-attack protocol command.
flow-rate-limit: Specifies the maximum transmission rate per flow for the protocol in packets per second. The value range is 0 to 102400.
The device identifies flows of a protocol by source IP or MAC address. Protocol packets that are sourced from the same IP address or MAC address belong to the same flow.
You can configure both protocol-based and flow-based protocol packet rate limit for the same protocol. The device first performs flow-based protocol packet rate limit and then performs protocol-based packet rate limit. Excessive protocol packets are dropped.
After you change the settings, it takes about 10 seconds for the change to take effect.
# Enable flow-based packet rate limit for ARP and set the maximum transmission rate per flow to 50 packets per second.
[Sysname] anti-attack protocol arp flow-threshold 50
anti-attack protocol priority
Use anti-attack protocol priority to set the packet process priority for a protocol.
Use undo anti-attack protocol priority to restore the default.
anti-attack protocol protocol priority priority
undo anti-attack protocol protocol priority
The default settings vary by device model. To display the default setting for a protocol, execute the undo anti-attack protocol priority and display anti-attack protocol commands in turn.
priority: Specifies the packet process priority for the protocol, in the range of 0 to 4. A smaller value represents a higher priority.
When the maximum transmission rate is reached, the device determines packets to be dropped by priority. Packets of the lowest priority are dropped first.
# Set the packet process priority to 0 for ARP.
[Sysname] anti-attack protocol arp priority 0
anti-attack protocol threshold
Use anti-attack protocol threshold to set the maximum transmission rate for a protocol.
Use undo anti-attack protocol threshold to restore the default for a protocol.
anti-attack protocol protocol threshold rate-limit
undo anti-attack protocol protocol threshold
The default settings vary by device model. To display the default setting for a protocol, execute the undo anti-attack protocol threshold and display anti-attack protocol commands in turn.
rate-limit: Specifies the maximum transmission rate for the protocol in packets per second. The value range is 0 to 102400.
Excessive packets are dropped.
# Set the maximum transmission rate to 1000 packets per second for ARP.
[Sysname] anti-attack protocol arp threshold 1000
Use display anti-attack protocol to display packet rate limit information about protocols.
display anti-attack protocol [ protocol ]
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. If you do not specify a protocol, the command displays information about all protocols.
# Display packet rate limit information about all protocols.
<Sysname> display anti-attack protocol
                        Anti-attack statistics
Protocol            anti-attack    Priority Limit(pps)  Rate(pps) Passed
      Dropped
dot1x               disable        1        1024        0         0
      0
dhcp                disable        2        2000        0         0
      0
dhcpv6              disable        2        2000        0         0
      0
igmp                disable        2        1024        0         0
      0
ntp                 disable        2        512         0         0
      0
arp                 disable        1        1024        0         0
      0
snmp                disable        0        1024        0         0
      0
telnet              disable        0        1024        0         0
      0
icmp                disable        0        1024        0         0
      0
icmpv6_nd           disable        0        1024        0         0
      0
icmpv6_other        disable        0        1024        0         0
      0
iadtp               disable        1        2560        0         0
      0
acsei               disable        2        512         0         0
      0
http                disable        1        1024        0         0
      0
https               disable        1        1024        0         0
      0
openflow            disable        1        1024        0         0
      0
portal              disable        1        1024        0         0
      0
udp                 disable        2        2048        0         0
      0
tcp                 disable        2        1024        0         0
      0
ip                  disable        2        2560        0         0
      0
ipv6                disable        2        512         0         0
      0
ethernet            disable        2        512         0         0
      0
radius              disable        1        2048        0         0
      0
vrrp                disable        1        2048        0         0
      0
capwap_ctrl         disable        1        5120        0         0
      0
capwap_ctrl_dis     disable        1        2048        0         0
      0
capwap_data         disable        1        51200       0         0
      0
dot11_auth          disable        1        512         0         0
      0
dot11_assoc         disable        1        512         0         0
      0
dot11_reassoc       disable        1        512         0         0
      0
dot11_null          disable        1        1024        0         0
      0
dot11_disassoc      disable        1        512         0         0
      0
dot11_deauth        disable        1        512         0         0
      0
dot11_action        disable        1        512         0         0
      0
dot11_ctrl          disable        1        512         0         0
      0
lacp                disable        1        512         0         0
      0
Anti-attack
Status of protocol-based packet rate limit for the protocol:
·     EnabledThe feature is enabled.
·     DisabledThe feature is disabled.
Priority
Packet processing priority of the protocol. A smaller value represents a higher priority.
Limit(pps)
Maximum packet transmission rate of the protocol, in packets per second.
Rate(pps)
Current packet transmission rate of the protocol, in packets per second.
Passed
Number of protocol packets sent to the CPU.
Dropped
Number of dropped protocol packets.
# Display packet rate limit information about ARP. Both protocol-based protocol packet rate limit and flow-based protocol packet rate limit are enabled in this example.
<Sysname> display anti-attack protocol arp
Protocol       anti-attack Priority Limit(pps)  Rate(pps) Passed    Dropped
arp            enable      1        1024        0         17907     0
FlowSource              FlowLimit(pps)    FlowRate(pps)   Passed    Dropped
00e0-fc12-7723          1000              0               2         0
0011-e212-8801          1000              0               17905     0
FlowSource
Source IP or MAC address of the flow.
FlowLimit(pps)
Maximum transmission rate for the flow, in packets per second.
FlowRate(pps)
Current transmission rate of the flow, in packets per second.
