04-Interface Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(R5805P11)-6W10104-Interface Command Reference
04-PoE commands
04-PoE commands 122.21 KB
PoE commands
The following compatibility matrixes show the support of hardware platforms for PoE:
Hardware series
Model
Product code
PoE compatibility
WX2500X series
·     WX2560X
·     WX2580X
·     EWP-WX2560X
·     EWP-WX2580X
No:
·     EWP-WX2560X
·     EWP-WX2580X
WX2500X-E series
WX2508X-E
EWP-WX2508X-E
No: EWP-WX2508X-E
Hardware series
Model
Product code
PoE compatibility
WX2500X-LI series
·     WX2510X-LI
·     WX2510X-PWR-LI
·     WX2520X-LI
·     WX2540X-LI
·     WX2550X-LI
·     WX2560X-LI
·     WX2580X-LI
·     EWP-WX2510X-LI
·     EWP-WX2510X-PWR-LI
·     EWP-WX2520X-LI
·     EWP-WX2540X-LI
·     EWP-WX2550X-LI
·     EWP-WX2560X-LI
·     EWP-WX2580X-LI
Yes:EWP-WX2510X-PWR-LI
No:
·     EWP-WX2510X-LI
·     EWP-WX2520X-LI
·     EWP-WX2540X-LI
·     EWP-WX2550X-LI
·     EWP-WX2560X-LI
·     EWP-WX2580X-LI
Hardware series
Model
Product code
PoE compatibility
WX2800X series
·     WX2812X-PWR
·     WX2860X
·     WX2880X
·     EWP-WX2812X-PWR
·     EWP-WX2860X
·     EWP-WX2880X
·     Yes: EWP-WX2812X-PWR
·     No:
·     EWP-WX2860X
·     EWP-WX2880X
WSG1800X series
·     WSG1808X-PWR
·     WSG1808X-PWR
·     WSG1812X-PWR
·     WSG1840X
·     EWP-WSG1808X-PWR
·     EWP-WSG1808X-PWR-JP
·     EWP-WSG1812X-PWR
·     EWP-WSG1840X
Yes: EWP-WSG1808X-PWR, EWP-WSG1808X-PWR-JP, EWP-WX2812X-PWR
No: EWP-WSG1840X
display poe device
Use display poe device to display general PSE information.
display poe device
# Display general PSE information.
<Sysname> display poe device
PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 1         1           0          12         150.0            On      WX1812X-PWR POE
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet1/0/6.
<Sysname> display poe interface gigabitethernet 1/0/6
PoE Status                 : Enabled
 Power Priority             : Low
 Oper                       : Off
 IEEE Class                 : 0
 Detection Status           : Searching
 Power Mode                 : Signal
 Current Power              : 0        mW
 Average Power              : 0        mW
 Peak Power                 : 0        mW
 Max Power                  : 30000    mW
 Electric Current           : 5        mA
 Voltage                    : 0.0      V
 PD Description             :
PoE Status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority of the PI:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class by which the PI supplies power to the PD.
If the PI does not support supplying power to the PD, this field displays a hyphen (-).
Detection Status
Power detection status:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode:
·     Signal—Power is transmitted over the signal pairs of a twisted pair cable.
·     Spare—Power is transmitted over the spare pairs of a twisted pair cable.
Current Power
Current power, including PD consumption power and transmission loss.
Average Power
Average power.
Peak Power
Peak power.
Max Power
Maximum power.
Electric Current
Current.
Voltage
Voltage.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                  (W)                 Class Status
 GE1/0/3      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/4      Enabled   Low       0.0       Off       0     Searching
 GE1/0/5      Enabled   Low       0.0       Off       0     Searching
 GE1/0/6      Enabled   Low       0.0       Off       0     Searching
 GE1/0/7      Enabled   Low       0.0       Off       0     Searching
 GE1/0/8      Enabled   Low       0.0       Off       0     Searching
 GE1/0/9      Enabled   Low       0.0       Off       0     Searching
 GE1/0/10     Enabled   Low       0.0       Off       0     Searching
 GE1/0/11     Enabled   Low       0.0       Off       0     Searching
 GE1/0/12     Enabled   Low       0.0       Off       0     Searching
 GE1/0/13     Enabled   Low       0.0       Off       0     Searching
 GE1/0/14     Enabled   Low       0.0       Off       0     Searching
   ---  On State Ports: 0; Used: 0.0(W); Remaining: 150.0(W)  ---
Interface name.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority:
·     High.
·     Low.
CurPower
Current power.
Oper
Operating status:
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of the system.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/6.
<Sysname> display poe interface power gigabitethernet 1/0/6
Interface    Current   Peak      Max       PD Description
              (W)       (W)       (W)
 GE1/0/6      0.0       0.0       30.0
# Display power information for all PIs.
              (W)       (W)       (W)
 GE1/0/3      0.0       0.0       30.0
 GE1/0/4      0.0       0.0       30.0
 GE1/0/5      0.0       0.0       30.0
 GE1/0/7      0.0       0.0       30.0
 GE1/0/8      0.0       0.0       30.0
 GE1/0/9      0.0       0.0       30.0
 GE1/0/10     0.0       0.0       30.0
 GE1/0/11     0.0       0.0       30.0
 GE1/0/12     0.0       0.0       30.0
 GE1/0/13     0.0       0.0       30.0
 GE1/0/14     0.0       0.0       30.0
Interface name.
CurPower
Current power.
PeakPower
Peak power.
MaxPower
Maximum power.
PD Description
Type and location description for the PD connected to a PI.
On State Ports
Used
Power consumed by all PIs.
Remaining
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse
# Display detailed PSE information.
<Sysname> display poe pse
PSE ID                           : 1
 Slot No.                         : 1
 SSlot No.                        : 0
 PSE Model                        : WX1812X-PWR POE
 Current Power                    : 0.0      W
 Average Power                    : 0.0      W
 Peak Power                       : 0.0      W
 Max Power                        : 150.0    W
 Remaining Guaranteed Power       : 150.0    W
 PSE CPLD Version                 : -
 PSE Software Version             : 0
 PSE Hardware Version             : -
 Legacy PD Detection              : Disabled
 Power Utilization Threshold      : 80
 PD Power Policy                  : Disabled
 PD Disconnect-Detection Mode     : DC
Table 5 Command output
PSE ID
ID of the PSE.
Slot No.
SSlot No.
Sublsot number of the PSE.
Current Power
Current power of the PSE.
Average Power
Average power of the PSE.
Peak Power
Peak power of the PSE.
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname] interface gigabitethernet 1/0/6
[Sysname-GigabitEthernet1/0/6] poe enable
poe max-power (interface view)
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
DefaultHardware series
Model
Product code
PoE compatibility
WX2800X series
·     WX2812X-PWR
·     WX2860X
·     WX2880X
·     EWP-WX2812X-PWR
·     EWP-WX2860X
·     EWP-WX2880X
·     WX2812X-PWR: The maximum PI power is 30000 milliwatts.
·     WX2860X, WX2880X: This command is not supported.
PI view
max-power: Sets the maximum PI power in milliwatts.
The following compatibility matrixes show the value ranges for the maximum PI power:
Hardware series
Model
Product code
PoE compatibility
WX2800X series
·     WX2812X-PWR
·     WX2860X
·     WX2880X
·     EWP-WX2812X-PWR
·     EWP-WX2860X
·     EWP-WX2880X
·     WX2812X-PWR: 1000 to 30000, in increments of 1
·     WX2860X, WX2880X: Not supported.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/6] poe max-power 12000
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-Gigabitethernet 1/0/1] poe pd-description IP Phone For Room 101
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
Only the default MDC supports this command.
You can upgrade the PSE firmware in service in either of the following modes:
·     Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
·     Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the PSE firmware in service.
[Sysname] poe update refresh POE-168.bin
This command will refresh the PSE firmware. Continue? [Y/N]:y
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of the PSE to 90%.
[Sysname] poe utilization-threshold 90
