20-Segment Routing Configuration Guide
HomeSupportNFVH3C VSRConfigure & DeployConfiguration GuidesH3C VSR Series Virtual Services Routers Configuration Guides(V7)-R1362-6W10120-Segment Routing Configuration Guide
02-SRv6 configuration
02-SRv6 configuration 714.70 KB
Configuring SRv6· 1
About SRv6· 1
Basic concepts· 1
SRv6 packet format 7
SRv6 packet forwarding· 8
Directing traffic to an SRv6 tunnel 9
G-SRv6· 10
Background· 10
About G-SRv6· 10
G-SID format 11
G-SRv6 packet 11
BGP-EPE· 13
TI-LFA FRR· 14
TI-LFA FRR background· 14
TI-LFA FRR concepts· 15
TI-LFA FRR path calculation· 16
TI-LFA FRR forwarding process· 17
SR microloop avoidance after a network failure· 18
SR microloop avoidance after a failure recovery· 19
Protocols and standards· 20
Restrictions: Licensing requirements for SRv6· 20
SRv6 tasks at a glance· 20
Prerequisites for SRv6· 21
Configuring common SRv6 SIDs· 21
Configuring G-SIDs· 24
Configuring SRv6 SIDs on a COC32 locator 24
Configuring SRv6 SIDs on a COC-both locator 25
Using IGP to advertise SRv6 SIDs· 26
Configuring BGP to advertise SRv6 SIDs· 27
Configuring BGP-EPE· 27
Enabling SRv6 BGP-EPE· 27
Applying a locator to BGP-EPE· 28
Configuring a BGP-EPE SRv6 peer set 29
Configuring SRv6 tunneling· 30
Configuring an SID list 30
Specifying an SID list for an SRv6 tunnel interface· 30
Configuring a service class for an SRv6 tunnel interface· 30
Enabling BFD echo-mode detection on an SRv6 tunnel interface· 31
Configuring traffic forwarding· 32
Configuring a static route to direct traffic to an SRv6 tunnel 32
Configuring automatic static route advertisement to direct traffic to an SRv6 tunnel 32
Configuring automatic IGP route advertisement to direct traffic to an SRv6 tunnel 32
Configuring TI-LFA FRR· 33
Restrictions and guidelines for TI-LFA FRR· 33
TI-LFA FRR tasks at a glance· 34
Enabling TI-LFA FRR· 34
Disabling an interface from participating in TI-LFA calculation· 35
Enabling FRR microloop avoidance· 35
Configuring SR microloop avoidance· 36
Configuring the SRv6 MTU· 37
Display and maintenance commands for SRv6· 38
SRv6 configuration examples· 39
Example: Configuring SRv6 that uses End SIDs· 39
Example: Configuring SRv6 that uses End.X SIDs· 41
Example: Configuring IPv6 IS-IS TI-LFA FRR· 44
Configuring SRv6
About SRv6
Segment Routing (SR) is a source routing technology. The source node selects a path for packet forwarding, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by the Segment Identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SRv6 uses IPv6 addresses as SIDs to forward packets.
Basic concepts
SR node roles
The nodes on an SRv6 network can have one or multiple of the following roles:
·     Source node—Responsible for inserting an SRH into the IPv6 header of IPv6 packets, or encapsulating IPv6 packets with an outer IPv6 header and inserting an SRH into the outer IPv6 header. A source node steers traffic to the SRv6 path defined in the segment list in the SRH.
¡     If the segment list contains only one SID and the SRH is not required to include information or TLV, the source node only sets the SID as the destination address in the IPv6 header, without inserting an SRH.
¡     If the segment list contains multiple SIDs, the source node must insert an SRH to the packets.
A source node can be the originator of SRv6 packets or the edge device of an SRv6 domain.
·     Transit node—Forwards IPv6 packets along the SRv6 path. A transit node does not participate in SRv6 processing. It can be an SRv6-aware or SRv6-unaware node.
·     Endpoint node—Performs an SRv6 function for received SRv6 packets. The IPv6 destination address of the received SRv6 packets must be an SRv6 SID configured on the endpoint node. The endpoint node processes the packets based on the SRv6 SID and updates the SRH.
A node can be the source node in one SRv6 path and a transit node or endpoint node in another SRv6 path.
SID portions
SRv6 supports SRv6 SIDs that have specific functions.
An SRv6 SID is in the format of IPv6 address, but the IPv6 address does not belong to any interface on any device.
As shown in Figure 1, an SRv6 SID contains the Locator, Function, Arguments, and MBZ portions.
·     Locator—Identifies the network segment of the SID. An SRv6 node advertises IPv6 segments identified by locators to the network through routing protocols such as IGP, to help other devices forward packets to that SRv6 node. Therefore, locators are typically used for SRv6 routing and addressing. The locator of an SRv6 SID must be unique in the SR domain.
·     Function—Contains an opcode that identifies the network function (local instruction) bound to a SID. When an SRv6 node receives an SRv6 packet and detects that the IPv6 destination address matches an SRv6 SID in the local SID table, the node analyzes the Function field. Then, it locates and executes the local operation instruction for the function. For example, an SRv6 node is configured with the opcode 101 end-x interface A command for a SID. This command indicates that an opcode value of 101 in the Function field associates with the End.X behavior. If the destination address of an incoming SRv6 packet matches this local SRv6 SID, the node forwards the packet from interface A (the interface identified by End.X) as instructed.
·     Arguments—Defines flow and service parameters for SRv6 packets, an optional field in SRv6 SIDs.
·     MBZ (Must be zero)—Sets the remaining bits of the SID to zero if the total length of the Locator, Function, and Arguments is less than 128 bits.
Figure 1 SRv6 SID
All SRv6 SIDs are allocated from the locator configured by using the locator command. SRv6 SIDs are divided into different categories depending on the locator type and length. Typically, 128-bit SRv6 SIDs are encapsulated into SRv6 packets. This type of SRv6 SIDs are allocated from common locators.
·     Common locator
Figure 2 Common locator
Common locators can allocate common SRv6 SIDs, and common SRv6 SIDs include static and dynamic SRv6 SIDs. The formats are as follows:
¡     A static SRv6 SID is generated based on the following formula: static SRv6 SID = ipv6-prefix + 0 + opcode + 0.
-     The ipv6-prefix portion represents the IPv6 prefix specified by using the ipv6-address and prefix-length arguments in the locator command. The number of bits occupied by the IPv6 prefix is configured by using the prefix-length argument.
-     The number of bits occupied by 0s (following the ipv6-prefix portion) is 128 - prefix-length - static-length - args-length.
-     opcode represents the static portion in the Function field. The number of bits occupied by the opcode is the value of the static-length argument. The number of bits occupied by 0s (following the opcode portion) is the value of the args-length argument.
¡     A dynamic SRv6 SID is generated based on the following formula: dynamic SRv6 SID = ipv6-prefix + dynamic + static + 0.
-     dynamic represents the dynamic portion in the Function field. The value for this portion cannot be all zeros. The number of bits occupied by this portion is 128 - prefix-length - static-length - args-length.
-     static represents the static portion in the Function field. The number of bits occupied by this portion is static-length. This portion can use any value. The number of bits occupied by 0s is the value of the args-length argument.
For example, in the locator test1 ipv6-prefix 100:200:DB8:ABCD:: 64 static 24 args 32 command:
¡     The Locator portion is 100:200:DB8:ABCD::. This portion occupies 64 bits.
¡     The static opcode occupies 24 bits.
¡     The Args portion occupies 32 bits.
¡     The dynamic opcode occupies 8 bits.
The static SRv6 SID range and dynamic SRv6 SID range are as follows:
¡     The start static SRv6 SID is 100:200:DB8:ABCD:0:1::.
¡     The end static SRv6 SID is 100:200:DB8:ABCD:FF:FFFF::.
¡     The start dynamic SRv6 SID is 100:200:DB8:ABCD:100::.
¡     The end dynamic SRv6 SID is 100:200:DB8:ABCD:FFFF:FFFF::.
·     COC32 locators
Figure 3 COC32 locator
A COC locator can allocate SRv6 SIDs that carry COC flavors, End(COC32) SIDs and End.X(COC32) SIDs, and common SRv6 SIDs that do not carry COC flavors. These SRv6 SIDs can be either manually specified in the static opcode or dynamically allocated in the dynamic opcode through IGP.
For example, in the locator test1 ipv6-prefix 100:200:DB8:ABCD:: 64 common-prefix 48 coc32 static 8 args 16 command:
¡     The common prefix occupies 48 bits.
¡     The static opcode occupies 8 bits.
¡     The Args portion occupies 16 bits.
¡     The start static SRv6 SID is 100:200:DB8:ABCD:1::.
¡     The end static SRv6 SID is 100:200:DB8:ABCD:FF::.
¡     The end dynamic SRv6 SID is 100:200:DB8:ABCD:FFFF::.
·     COC-both locators
Figure 4 COC-both locator
For more flexible allocation of SRv6 SIDs, a new locator type COC-both has been introduced. In a COC-both locator, compressible SID portions and non-compressible SID portions are available. SIDs that carry COC flavors, for example, End(COC32) and End.X(COC32) SIDs are dynamically or statically allocated from the compressible SID portions. SIDs that do not carry COC flavors, for example, End(COCNONE) and End.X(COCNONE) SIDs are also dynamically or statically allocated from the compressible SID portions. Only common SIDs, such as End and End.X SIDs are allocated from the non-compressible SID portions. The SRv6 SIDs allocated from different portions are categorized as follows:
¡     SRv6 SIDs allocated from the static compressible portion.
¡     SRv6 SIDs allocated from the dynamic compressible portion.
¡     SRv6 SIDs allocated from the static non-compressible portion.
¡     SRv6 SIDs allocated from the dynamic non-compressible portion.
Assume that you configure the locator test1 ipv6-prefix 100:200:DB8:ABCD:: 64 common-prefix 48 coc-both non-compress-static 16 static 8 args 16 command.
¡     The locator is 100:200:DB8:ABCD::. The length is 64 bits.
¡     The common prefix length is 48 bits.
¡     The compressible static portion length is 8 bits.
¡     The compressible dynamic portion length is 8 bits. This value is calculated by using the following formula: 32 – (prefix-length – common-prefix-length) + compressible-static-length.
¡     The non-compressible static portion length is 16 bits.
¡     The non-compressible dynamic portion length is 16 bits. This value is calculated by using the following formula: 128 – common-prefix-length – args-length – 32 – non-compressible-static-length.
¡     The Args portion length is 16 bits.
In this example, the following static compressible SRv6 SID range and dynamic compressible SRv6 SID range are obtained on the locator:
¡     The start value for compressible static SRv6 SIDs is 100:200:DB8:ABCD:1::.
¡     The end value for compressible static SRv6 SIDs is 100:200:DB8:ABCD:FF::.
¡     The start value for compressible dynamic SRv6 SIDs is 100:200:DB8:ABCD:100::.
¡     The end value for compressible dynamic SRv6 SIDs is 100:200:DB8:ABCD:FFFF::.
The following static non-compressible SRv6 SID range and dynamic non-compressible SRv6 SID range are obtained on the locator:
¡     The start value for static non-compressible SRv6 SIDs is 100:200:DB8:ABCD::1:0.
¡     The end value for static non-compressible SRv6 SIDs is 100:200:DB8:ABCD::FFFF:0.
¡     The start value for dynamic non-compressible SRv6 SIDs is 100:200:DB8:ABCD:0:1::.
¡     The end value for dynamic non-compressible SRv6 SIDs is 100:200:DB8:ABCD:0:FFFF:FFFF:0.
·     PD locators
As shown in Figure 5, a PD locator contains only the PD prefix, subprefix, and static Function portions. It does not contain the dynamic Function portion or Args portion. If these three portions have a total length less than 128 bits, add 0s after the PD prefix and subprefix. Configure the subprefix and static Function portions properly to ensure that the total length does not exceed 128 bits. The locator becomes invalid if it exceeds 128 bits.
Figure 5 PD locator
In access networks, numerous CPE devices distributed across different locations connect to the service gateway through wireless connections or optical fibers. Manually configuring and planning SRv6 locators for each CPE device would require significant effort. Additionally, these CPE devices typically do not support IGP protocols, preventing them from advertising SRv6 locators to the service gateway through IGP. To address this issue, H3C uses DHCPv6 PD to obtain IPv6 prefixes and assigns them as the SRv6 locators for CPE devices. This approach greatly reduces the workload for planning and configuring SRv6 locators.
When you deploy Layer 2 services over SRv6 in an access network, you can connect a CPE to a service gateway through EVPN VPWS over SRv6. In this scenario, the CPE acts as a DHCPv6 client and dynamically obtains an IPv6 prefix through DHCPv6 PD. After you configure a PD locator on the CPE, the dynamically obtained IPv6 prefix can be used as its locator. This PD locator allocates SIDs to the CPE, with each SID uniquely mapped to a user service instance, implementing SID-as-a-Service (SlaaS).
A PD locator only statically allocates End.DX2 SIDs, and it does not support allocating other SIDs or dynamically allocating SIDs.
SRv6 endpoint behaviors
The local instruction identified by the Function field of an SRv6 SID is a node behavior that guides packet forwarding and processing. This local instruction is called SRv6 endpoint behavior. RFC 8986 defines opcode values for most types of node behaviors. From a network configuration perspective, different node forwarding behaviors are SRv6 SIDs with various functional types. The types of SRv6 SID include, but are not limited to the following:
·     End SID—Identifies a node in the network, representing the prefix of a destination address.
·     End.X SID—Identifies a link in the network.
·     End.DT4 SID—Similar to a private network label in an MPLS L3VPN network, it identifies an IPv4 VPN instance in the network. The function of an End.DT4 SID is decapsulating packets and searching the routing table of the corresponding IPv4 VPN instance to forward the packets. End.DT4 SIDs are applicable to IPv4 private network access scenarios.
·     End.DT6 SID—Similar to a private network label in an MPLS L3VPN network, it identifies an IPv6 VPN instance in the network. The function of an End.DT6 SID is decapsulating packets and searching the routing table of the corresponding IPv6 VPN instance to forward the packets. End.DT6 SIDs are applicable to IPv6 private network access scenarios.
·     End.DT46 SID—Similar to a private network label in an MPLS L3VPN network, it identifies an IPv4 or IPv6 VPN instance in the network. End.DT46 SIDs are applicable to IPv4 and IPv6 private network concurrent access scenarios.
·     End.DX4 SID—Identifies an IPv4 next hop from a PE to a CE in an IPv4 VPN instance in the network. The function of an End.DX4 SID is decapsulating packets and forwarding the decapsulated IPv4 packets out of the Layer 3 interface bound to the SID to a specific next hop. End.DX4 SIDs are applicable to IPv4 private network access scenarios.
·     End.DX6 SID—Identifies an IPv6 next hop from a PE to a CE in an IPv6 VPN instance in the network. The function of an End.DX6 SID is decapsulating packets and forwarding the decapsulated IPv6 packets out of the Layer 3 interface bound to the SID to a specific next hop. End.DX6 SIDs are applicable to IPv6 private network access scenarios.
·     End.DX2 SID—Identifies one end of a Layer 2 cross-connect in the EVPN VPWS over SRv6 scenario. The function of an End.DX2 SID is decapsulating packets and forwarding the decapsulated packets to the output interface of the SID.
·     End.DX2L SID—Identifies packets that come from a bypass SRv6 PW. The packets will not be forwarded back to the bypass SRv6 PW for loop prevention. The function of an End.DX2L SID is removing the outer IPv6 header and SRH of packets and forwarding the decapsulated packets to the output interface of the SID. End.DX2L SIDs are applicable to EVPN VPWS over SRv6 multihomed sites.
·     End.DT2M SID—Identifies one end of a Layer 2 cross-connect for EVPN VPLS over SRv6 BUM traffic and floods traffic. The function of an End.DT2M SID is decapsulating packets and flooding the decapsulated packets in the VSI.
·     End.DT2U SID—Identifies one end of a Layer 2 cross-connect and performs unicast forwarding. The function of an End.DT2U SID is removing the outer IPv6 header and SRH of packets, looking up the MAC address table for the destination MAC address, and forwarding the packets to the output interface based on the MAC address entry. End.DT2U SIDs are applicable to EVPN VPLS unicast traffic.
·     End.DT2UL SID—Identifies packets that come from a bypass SRv6 PW. The packets will not be forwarded back to the bypass SRv6 PW for loop prevention. The function of an End.DT2UL SID is removing the outer IPv6 header and SRH of packets and forwarding the packets to the output interface through destination MAC address lookup. End.DT2UL SIDs are applicable to EVPN VPLS over SRv6 multihomed sites.
·     End.OP SID—Applies to the SRv6 OAM scenario. For more information about End.OP SIDs, see "Configuring SRv6 OAM."
·     End.M SID—Applies to the SRv6 TE policy tailend protection scenario. For more information about End.M SIDs, see "Configuring SRv6 TE policies."
·     End.T SID—Applies to the inter-AS option B solution. For more information about End.T SIDs, see "Configuring IP L3VPN over SRv6" and "Configuring EVPN L3VPN over SRv6."
·     End.AS SID—Applies to the SRv6 service chain static proxy scenario. For more information about End.AS SIDs, see "Configuring SRv6 service chains."
·     End.AM SID—Applies to the SRv6 service chain masquerading scenario. For more information about End.AM SIDs, see "Configuring SRv6 service chains."
·     End.B6.Encaps—Applies to the scenario where an SRv6 ingress node steers traffic to an SRv6 TE policy or stitches an SRv6 TE policy by using a BSID. The node behavior is to encapsulate a new IPv6 header and SRH onto the received packet.
·     End.B6.Encaps.Red—Applies to the scenario where an SRv6 ingress node steers traffic to an SRv6 TE policy or stitches an SRv6 TE policy by using a BSID. The node behavior is to encapsulate the SIDs except for the first SID in the SRv6 TE policy’s SID list when it encapsulates an IPv6 header and SRH onto the received packet to reduce the SRH length.
·     End.B6.Insert—Applies to the scenario where an SRv6 ingress node steers traffic to an SRv6 TE policy or stitches an SRv6 TE policy by using a BSID. The node behavior is to encapsulate an SRH header onto the received packet.
·     End.B6.Insert.Red—Applies to the scenario where an SRv6 ingress node steers traffic to an SRv6 TE policy or stitches an SRv6 TE policy by using a BSID. The node behavior is to insert an SRH into the received IPv6 packet and to encapsulate the SIDs except for the first SID in the SRv6 TE policy’s SID list to reduce the SRH length.
Use IGP to advertise SRv6 SIDs for an SR node. The other SR nodes will generate route entries of that SR node based on the advertised information.
SRv6 SID flavors
Use SRv6 SID flavors to change the forwarding behaviors of SRv6 SIDs in order to meet multiple service requirements. The following SRv6 SID flavors are supported:
·     Penultimate Segment POP of the SRH (PSP)—The penultimate SRv6 node removes the SRH to reduce the workload of the end SRv6 node and improve the forwarding efficiency. The end SRv6 node does not read the SRH, and it only looks up the local SID table for the destination IPv6 address of packets to forward the packets.
·     NO PSP—The penultimate SRv6 node does not remove the SRH.
·     Continue of Compression (COC)—A COC flavor identifies the next SID as a compressed G-SID, either 16-bit or 32-bit, in packet encapsulation. In packet forwarding, SIDs that carry the COC flavor support the replace action. When an SRv6 packet is forwarded to an endpoint node, if the local SID of that node has the COC flavor and the current SID is the last SID or G-SID in the IPv6 destination address, the node extracts a 16-bit or 32-bit G-SID from the 128-bit address space of the encapsulated SID. This G-SID is then replaced in the IPv6 packet's destination address, forming a new SID with a common prefix. This new SID guides G-SRv6 packet forwarding.
Local SID forwarding table
An SRv6-enabled node maintains a local SID forwarding table that records the SRv6 SIDs generated on the local node. The local SID forwarding table has the following functions:
·     Stores local generated SRv6 SID forwarding information.
·     Stores SRv6 SID operation types.
Segment List
A Segment List is an ordered list of SIDs, which is also referred to as a Segment Identifier (SID) list in this document. The SR nodes forward packets based on the SIDs in the order that they are arranged in the SID list.
SRv6 tunnel
An SRv6 tunnel is a virtual point-to-point connection established between the SRv6 ingress node and egress node. IPv6 packets are encapsulated at the ingress node and de-encapsulated at the egress node.
SRv6 packet format
An outer IPv6 header and a Segment Routing Header (SRH) are added to the original Layer 3 data packet to form an SRv6 packet.
As shown in Figure 6, the value for the Next Header field is 43 in the outer IPv6 header, which indicates that the header next to the IPv6 header is a routing extension header. The value for the Routing Type field in the routing extension header is 4, which indicates that the routing extension header is an SRH. The SRH header contains the following fields:
·     8-bit Next Header—Identifies the type of the header next to the SRH.
·     8-bit Hdr Ext Len—Length of the SRH header in 8-octet units, not including the first 8 octets.
·     8-bit Routing Type—The value for this field is 4, which represents SRH.
·     8-bit Segments Left—Contains the index of the next segment to inspect in the Segment List. The Segments Left field is set to n-1 where n is the number of segments in the Segment List. Segments Left is decremented at each segment.
·     8-bit Last Entry—Contains the index of the first SID in the path used to forward the packet.
·     8-bit Flags—Contains flags.
·     16-bit Tag—Tags a packet as part of a class or group of packets, for example, packets sharing the same set of properties.
·     Segment List—Contains 128-bit IPv6 addresses representing the ordered segments. The Segment List is encoded starting from the last segment of the path. The first element of the segment list (Segment List [0]) contains the last segment of the path, the second element (Segment List [1]) contains the penultimate segment of the path and so on. The number enclosed in a pair of brackets is the index of a segment.
Figure 6 SRv6 packet format
As shown in Figure 7, an IPv6 packet is forwarded through an SRv6 tunnel as follows:
1.     Upon receiving an IPv6 packet, Device A finds in the routing table that the outgoing interface is an SRv6 tunnel interface. The packet is delivered to the tunnel interface.
2.     The SRv6 tunnel interface encapsulates the IPv6 packet as follows:
¡     Adds an SRH header. The Segments Left (SL) value is the number of segments minus one. The path from ingress to egress has three segments, so the SL value is set to 2. The encapsulated SID list is Segment List [0]=D, Segment List [1]=C, Segment List [2]=B. The Segment List is encoded starting from the last segment of the path to the first segment of the path.
¡     Adds an outer IPv6 header. The source address is the tunnel source, and the destination address is determined by the SL value. On Device A, the SL value is 2, which points to the IPv6 address of Device B, so the destination address is the IPv6 address of Device B.
3.     Device A searches the routing table for the destination address in the newly encapsulated IPv6 header, and forwards the packet to Device B.
4.     Device B first checks the destination address and SID type in the outer IPv6 header.
¡     If the SID type is End.X, the device obtains the output interface and next hop information based on the End.X SID.
¡     If the SID is not End.X, the device does not perform any operation.
Then, the device checks the SL value in the SRH header and decreases the value by one. Then, the device searches for the IPv6 address pointed by Segment List [1] and uses the IPv6 address of Device C to replace the destination address of the outer IPv6 header.
5.     Device B performs one of the following operations depending on the SID type:
¡     For an End.X SID, the device forwards the encapsulated packet to Device C based on the obtained output interface and next hop information.
¡     For an SID of the other type, the device searches the routing table for the destination address in the outer IPv6 header and forwards the packet to Device C.
6.     Device C performs the same operations as what Device B has done in steps 4 and 5, and then forwards the packet to Device D.
7.     Device D checks the SL value in the SRH header and finds that the value has decreased to 0. The device performs the following operations:
a.     De-encapsulates the packet by removing the outer IPv6 header and the SRH header.
b.     Forwards the original IP data packet to the destination based on the destination address.
Figure 7 SRv6 tunnel packet forwarding
After an SRv6 tunnel is established, traffic is not forwarded on the tunnel automatically. You must direct the traffic to the tunnel by configuring a static route or automatic route advertisement.
Static routing
You can direct traffic to an SRv6 tunnel by creating a static route that reaches the destination through the tunnel interface on the source node. This is the easiest way to implement SRv6 tunnel forwarding. When traffic to multiple networks is to be forwarded through the SRv6 tunnel, you must configure multiple static routes, resulting in increased configuration and maintenance workloads.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
Automatic route advertisement
Automatic route advertisement distributes the SRv6 tunnel to the IGP (OSPF or IS-IS), so the SRv6 tunnel can participate in IGP route calculation. Automatic route advertisement is easy to configure and maintain.
Automatic route advertisement can be implemented by using the following methods:
·     IGP shortcut—Also known as AutoRoute Announce. It considers the SRv6 tunnel as a link that directly connects the tunnel ingress node and the egress node. Only the ingress node uses the SRv6 tunnel during IGP route calculation.
·     Forwarding adjacency—Considers the SRv6 tunnel as a link that directly connects the tunnel ingress node and the egress node, and advertises the link to the network through an IGP. Every node in the network uses the SRv6 tunnel during IGP route calculation.
IMPORTANT
IMPORTANT:
Only IGP shortcut is supported in the current software version.
As shown in Figure 8, an SRv6 tunnel exists from Device D to Device C. IGP shortcut enables only the ingress node Device D to use the SRv6 tunnel in IGP route calculation. Device A cannot use this tunnel to reach Device C. With forwarding adjacency enabled, Device A can learn this SRv6 tunnel and transfer traffic to Device C by forwarding the traffic to Device D.
Figure 8 IGP shortcut and forwarding adjacency diagram
G-SRv6
Background
In an SRv6 TE policy scenario, the administrator needs to add the 128-bit SRv6 SIDs of SRv6 nodes on the packet forwarding path into the SID list of the SRv6 TE policy. If the packet forwarding path is long, a large number of SRv6 SIDs will be added to the SID list of the SRv6 TE policy. This greatly increases the size of the SRv6 packet header, resulting in low device forwarding efficiency and reduced chip processing speed. The situation might be worse in a scenario that spans across multiple ASs where a much greater number of end-to-end SRv6 SIDs exist.
Generalized SRv6 (G-SRv6) encapsulates shorter SRv6 SIDs (G-SIDs) in the segment list of SRH by compressing the 128-bit SRv6 SIDs. This reduces the size of the SRv6 packet header and improves the efficiency for forwarding SRv6 packets. In addition, G-SRv6 supports both 128-bit SRv6 SIDs and G-SIDs in a segment list.
About G-SRv6
Typically, an address space is reserved for SRv6 SID allocation in an SRv6 subnet. This address space is called an SID space. In the SRv6 subnet, all SIDs are allocated from the SID space. The SIDs have the same prefix (common prefix). The SID common prefix is redundant information in the SRH.
G-SRv6 removes the common prefix and carries only the variable portion of SRv6 SIDs (G-SIDs) in the segment list, effectively reducing the SRv6 packet header size. To forward a packet according to routing table lookup, SRv6 replaces the destination IP address of the packet with the combination of the G-SID and common prefix in the segment list of the SRH.
With the compression efficiency and network scale taken into consideration, the ideal length of SRv6 SIDs is 32 bits after compression through G-SRv6.
G-SID format
As shown in Figure 9, the locator portion of an SRv6 SID contains the Common Prefix and Node ID portions. The Common Prefix portion represents the address of the common prefix. The Node ID portion identifies a node. G-SRv6 can compress all SIDs with the same common prefix into 32-bit G-SIDs. A G-SID contains the Node ID and Function portions of a 128-bit SRv6 SID. A 128-bit SRv6 SID is formed by the Common Prefix portion, a 32-bit G-SID, and the 0 (Args&MBZ) portion.
Figure 9 Compressible SRv6 SID
G-SRv6 packet
G-SRv6 packet format
As shown in Figure 10, G-SRv6 can encapsulate both G-SIDs and 128-bit SRv6 SIDs in the segment list of the SRH. It needs to encapsulate four G-SIDs in a group to the original location of a 128-bit SRv6 SID. If the location contains fewer than four G-SIDs (less than 128 bits), G-SRv6 pads the remaining bits with 0s. Multiple consecutive G-SIDs form a compressed path, called a G-SID list. A G-SID list can contain one or more groups of G-SIDs.
Figure 10 G-SRv6 packet format
If the SRv6 SID of the next node requires compression, the routing protocol adds the Continue of Compression (COC) flag to the advertised SRv6 SID of the local node. The COC flag indicates that the next SRv6 SID is a G-SID. A COC flag only identifies the forwarding behavior of an SRv6 SID, and is not actually carried in the packet. The COC flags in Figure 10 are for illustration purposes only.
The G-SIDs in the segment list are arranged as follows:
·     The SRv6 SID before the G-SID list is a 128-bit SRv6 SID with the COC flag, indicating that the next SID is a 32-bit G-SID.
·     Except the last G-SID, all G-SIDs in the G-SID list must carry the COC flag to indicate that the next SID is a 32-bit G-SID.
·     The last G-SID in the G-SID list must be a 32-bit G-SID without the COC flag, indicating that the next SID is a 128-bit SRv6 SID.
·     The next SRv6 SID after the G-SID list is a 128-bit SRv6 SID that can carry the COC flag or does not carry the COC flag.
Calculating the destination address with G-SID
As shown in Figure 11, G-SRv6 combines the G-SID and Common Prefix in the segment list to form a new destination address.
·     Common Prefix—Common prefix address manually configured by the administrator.
·     G-SID—Compressed 32-bit SID obtained from the SRH.
·     SID Index (SI)—Index that identifies a G-SID in a group of G-SIDs. This field is the least significant two bits of the destination IPv6 address. The value range is 0 to 3. The SI value decreases by 1 at each node that performs SID compression. If the SI value becomes 0, the SL value decreases by 1. In a group of G-SIDs in the segment list, the G-SIDs are arranged from left to right based on SI values. The SI value is 0 for the leftmost G-SID, and is 3 for the rightmost G-SID.
·     0—If the total length of the Common Prefix, G-SID, and SI portions is less than 128 bits, the deficient bits are padded with 0s before the SI portion.
Figure 11 Destination address calculated with G-SID
Suppose the following conditions exist:
·     The Common Prefix deployed on the SRv6 node is A:0:0:0::/64.
·     The G-SID in the SRv6 packet is 1:1.
·     The SI value associated with the G-SID is 3.
Based on the previous conditions, the device calculates the destination address as A:0:0:0:1:1::3.
Upon receiving the G-SRv6 packet, the SRv6 node calculates the destination address for the packet as follows:
·     If the destination address of the packet is a 128-bit SRv6 SID with the COC flag in the segment list, the next SID is a G-SID. The device decreases the SI value by 1 and searches for the G-SID group corresponding to [SI-1]. Then, the device calculates the destination address based on the 32-bit G-SID identified by SI value 3.
·     If the destination address of the packet is a 32-bit SRv6 SID with the COC flag in the segment list, the next SID is a G-SID.
¡     If the SI value is larger than 0, the device decreases the SI value by 1 and searches for the G-SID group corresponding to SL value of the packet. Then, the device calculates the destination address based on the 32-bit G-SID identified by [SI-1].
¡     If the SI value is equal to 0, the device decreases the SL value by 1, resets the SI value to 3, and searches for the G-SID group corresponding to the SL value of the packet. Then, the device calculates the destination address based on the 32-bit G-SID identified by SI value 3.
·     If the destination address of the packet is a 32-bit SRv6 SID without the COC flag in the segment list, the device decreases the SL value by 1 and searches for the 128-bit SRv6 SID corresponding to [SL-1]. Then, the device replaces the destination address in the IPv6 header with the SRv6 SID.
·     If the destination address of the packet is a 128-bit SRv6 SID without the COC flag in the segment list, the device decreases the SL value by 1 and searches for the 128-bit SRv6 SID corresponding to [SL-1]. Then, the device replaces the destination address in the IPv6 header with the SRv6 SID.
BGP-EPE
Advertising SRv6 SIDs through IGP can only implement orchestration of SIDs within an AS for optimal traffic forwarding based on the SID list. However, in large-scale networks across multiple ASs, using IGP for SRv6 cannot orchestrate SIDs to form a complete inter-AS traffic forwarding path across ASs. At this point, an extension of BGP for SRv6 is required for inter-AS SID allocation and advertisement.
BGP Egress Peer Engineering (BGP-EPE) is an extension of BGP for SRv6. It can allocate BGP peer SIDs to inter-AS segments. Peer SIDs are advertised to the SDN controller through extended BGP LS messages. The SDN controller orchestrates the IGP SIDs and BGP peer SIDs to generate inter-AS packet forwarding paths. Typically, in an inter-AS network, each AS requires at least one but not all forwarding devices to establish a BGP LS peer relationship with the SDN controller. The forwarding devices that have established a BGP LS peer relationship with the SDN controller collect all IGP SIDs and BGP peer SIDs within the AS and advertise them to the SDN controller through BGP LS messages, completing collection of network-wide information.
BGP-EPE supports automatic peer SID allocation and static peer SID allocation. As shown in Figure 12, BGP-EPE can allocate the following peer SIDs:
·     PeerNode SID—A BGP-EPE peer that identifies a peer node. BGP-EPE allocates a PeerNode SID to each BGP peer. If the device establishes EBGP peer relationship with a peer through a loopback interface, multiple physical links might exist between BGP-EPE peers. In this case, the PeerNode SID for this peer is associated with multiple output interfaces. Traffic destined for this peer based on the PeerNode SID will be distributed among these output interfaces.
·     PeerAdj SID—Identifies an adjacency link that can reach a BGP-EPE peer. If the device establishes EBGP peer relationship with a peer through a loopback interface, multiple physical links might exist between BGP-EPE peers. Each link is allocated a PeerAdj SID. When the device forwards traffic based on a PeerAdj SID, the traffic is forwarded out of the interface that is attached to the link identified by the PeerAdj SID.
·     PeerNode-Adj SID—Identifies a peer node and identifies one or multiple adjacency links that can reach a peer node.
·     PeerSet SID—Identifies a group of peer nodes in a BGP-EPE SRv6 peer set. A PeerSet SID corresponds to multiple PeerNode SIDs and PeerAdj SIDs. When the device forwards traffic based on a PeerSet SID, it distributes the traffic among multiple peers.
Figure 12 BGP-EPE network diagram
As shown in Figure 12, BGP-EPE allocates peer SIDs as follows:
·     ASBR 1 and ASBR 3 have two direct physical links. They establish EBGP peer relationship through loopback interfaces. On ASBR 1, BGP-EPE allocates PeerNode SID 100:AB::1 to ASBR 3 and allocates PeerAdj SIDs 100:AB:1::2 and 100:AB:1::3 to the physical links. When ASBR 1 forwards traffic to ASBR 3 based on the PeerNode SID, the two physical links load share the traffic.
·     EBGP peer relationship has been established between ASBR 1 and ASBR 5, between ARBR 2 and ASBR 4, and between ASBR 2 and ASBR 5 through directly connected physical interfaces. On ASBR 1, BGP-EPE allocates PeerNode SID 100:AB::2 to ASBR 5. On ASBR 2, BGP-EPE allocates PeerNode SIDs 100:AB::4 and 100:AB::5 to ASBR 4 and ASBR 5, respectively.
·     ASBR 4 and ASBR 5 each has established EBGP peer relationship with ASBR 2. On ASBR 2, peers ASBR 4 and ASBR 5 are added to a peer set. BGP-EPE allocates PeerSet SID 100:AB::3 to the peer set. When ASBR 2 forwards traffic based on the PeerSet SID, the traffic is distributed to both ASBR 4 and ASBR 5 for load sharing.
The SIDs allocated to peers by BGP-EPE are not advertised to the peers. Route types used by the peers do not affect BGP-EPE.
TI-LFA FRR
Topology-Independent Loop-Free Alternate Fast Re-Route (TI-LFA FRR) provides link and node protection for SRv6 tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
To minimize traffic loss during the route reconvergence process in SR-MPLS, you can enable the FRR feature on the device directly connected to the protected link or node. The device enabled with FRR is called the Point of Local Repair (PLR). The PLR calculates the shortest path to the destination and calculates an FRR backup path at the same time, and then writes the information into the FIB table. When a protected link or node fails, traffic is rerouted through the FRR backup path on the PLR node, without the need for the network topology to reconverge, significantly reducing traffic loss. FRR has the following mechanisms:
·     Loop-Free Alternate Fast Reroute (LFA FRR)—To calculate the backup path, LFA FRR identifies a protected neighboring node (LFA node) of the PLR, enabling traffic to be forwarded to the destination node without passing through the protected link or node. In some scenarios, especially in a ring network, LFA FRR cannot calculate a backup path, making it topology dependent. According to RFC 6571, LFA FRR has a topology coverage of 80% to 90%.
·     Remote Loop-Free Alternate Fast Reroute (RLFA FRR)—To improve the topology coverage of LFA FRR, RFC 7490 defines RLFA FRR, which enables traffic to be forwarded from the PLR to an RLFA FRR node and reach the destination node without passing through the protected link or node. Compared to LFA FRR, RLFA FRR does not restrict the protective node to being a neighbor of the PLR, providing more protection possibilities and increasing the topology coverage to 95% to 99%.
·     TI-LFA FRR suitable for SRv6 and SR-MPLS—Compared to LFA FRR and RLFA FRR, TI-LFA FRR is topology independent, meaning FRR backup path calculation is not restricted by the network topology. PLR can automatically calculate a TI-LFA FRR backup path as long as a bypass forwarding path is available.
As shown in Figure 13, node A sends data packets to node F. When the link between node B and node E fails, node B forwards the data packets to node C. The cost of the link between node C and node D is 100 (which is greater than the cost of the link between node C and node D) and the routes on node C have not converged. As a result, node C determines that the next hop of the optimal path to reach node F is node B. Then, node C forwards the data packets back to node B, which causes a loop.
Figure 13 TI-LFA application scenario
To resolve this issue, deploy TI-FLA on the SRv6 network. As shown in Figure 14, when the link between node B and node E fails, node B uses the backup path calculated by TI-LFA to forward the data packets along the B->C->D->E path.
Figure 14 TI-LFA forwarding network diagram
TI-LFA FRR concepts
TI-LFA FRR uses the concepts of RLFA FRR defined in RFC 7490:
·     P space—A set of nodes reachable (using pre-convergence paths) from the PLR without using the protected link or node (including equal-cost path splits). Nodes in the P space are called P nodes.Calculation of P nodes typically involves building an SPF tree with the PLR as the root node, and then identifying nodes on the SPF tree that meet the loop-free requirement.
·     Extended P space—A set of nodes reachable (using pre-convergence paths) from the neighbors of the PLR (except for the protected node) without using the protected link or node (including equal-cost path splits). The P space is a subset of the extended P space. Nodes in the extended P space are also called P nodes. Neighbor nodes of the PLR are N nodes. As shown in Figure 15, the expanded P space contains nodes Src, B, C, and D. The P nodes meet the following loop-free requirement: Distance (N, P) < Distance (N, PLR) + Distance (PLR, P).
·     Q space—A set of nodes that can reach (using pre-convergence paths) the destination without using the protected link or node (including equal-cost path splits). Nodes in the Q space are called Q nodes.
Figure 15 TI-LFA FRR concepts
As shown in Figure 16, PE 1 is the source node. P 1 is the faulty node. PE 2 is the destination node. The numbers on links represent the link costs. A data flow traverses PE 1, P 1, and PE 2. To protect data against P 1 failure, TI-LFA FRR calculates the extended P space, Q space, shortest path tree converged after P 1 fails, repair list, and backup output interface, and creates the backup forwarding entry.
TI-LFA FRR calculates the backup path by using the following steps:
1.     Calculates the extended P space: P 2.
2.     Calculates the Q space: PE 2 and P 4.
3.     Calculates the shortest path tree converged after P 1 fails: PE 1 --> P 2 --> P 4 --> PE 2.
4.     Calculates the repair list: End.X SID C of the link between P 2 and P 3 and End.X SID D of the link between P 3 and P 4.
5.     Calculates the backup output interface, that is, the output interface to the next hop after the link from PE 1 to P 1 fails.
Figure 16 TI-LFA FRR diagram
After TI-LFA FRR finishes backup path calculation, traffic will be switched to the backup path in response to a primary path failure.
As shown in Figure 17, P 2 is a P node and P 4 and PE 2 are Q nodes. When the next hop on the primary path (P 1) fails, TI-LFA FRR switches the traffic to the backup path. The following are the detailed steps:
1.     PE 1 looks up the IPv6 routing table for the destination IPv6 address of a packet and finds that the next hop is P 2. PE 1 encapsulates the packet according to the repair list.
¡     Adds an SRH header. The SID list is Segment List [0]=D and Segment List [1]=C. The SIDs are arranged from the farthest node to the nearest node.
¡     Adds an outer IPv6 header. The source address is address A on source node PE 1 and the destination address is the address pointed by SL. Because the SL is 1, the destination address is C as pointed by Segment List [1].
2.     After P2 receives the packet, it performs the following operations:
a.     Checks the SL value in the SRH header and decreases the value by 1.
b.     Searches for the address pointed by Segment List [0] and finds that the address is End.X SID D between P 3 and P 4.
c.     Replaces the destination address in the outer IPv6 header with End.X SID D.
d.     Obtains the output interface and next hop according to End.X SID C and forwards the encapsulated packet to P 3.
3.     After P3 receives the packet, it performs the following operations:
a.     Checks the SL value in the SRH header and finds that the SL value is 0.
b.     Decapsulates the packet.
c.     Obtains the output interface and next hop according to End.X SID D and forwards the packet to P 4.
4.     After P4 receives the packet, it searches the IP routing table for the destination IP address of the packet and forwards the packet to PE 2.
Figure 17 Data forwarding over the TI-LFA FRR backup path
As shown in Figure 18, when Device B fails, traffic to Device C will be switched to the backup path calculated by TI-LFA. After Device A finishes route convergence, traffic will be switched to the post-convergence path. If Device D and Device F have not finished route convergence and still forward traffic along the pre-convergence path, a loop is formed between Device A and Device F. The loop exists until Device D and Device F finish route convergence.
SR microloop avoidance can resolve this issue. After you configure TI-LFA, Device A first switches traffic to the backup path calculated by TI-LFA when Device B fails. Then, Device A waits for Device D and Device F to finish route convergence before starting route convergence. After Device A also finishes route convergence, Device A switches the traffic to the converged route.
Figure 18 Diagram for SR microloop avoidance after a network failure
As shown in Figure 19, before the link between Device B and Device C recovers, traffic traverses along the backup path. After the link recovers, Device A forwards the traffic to Device B if Device A finishes route convergence before Device B. With route convergence unfinished, Device B still forwards the traffic along the backup path. A loop is formed between Device A and Device B.
SR microloop avoidance can resolve this issue. After the link recovers, SR microloop avoidance automatically calculates the optimal path from Device A to Device C and forwards traffic along the path. To forward a packet along the newly calculated path, Device A adds, for example, the adjacency SID from Device B to Device C, to the packet and then sends the packet to Device B. Then, Device B forwards the packet to Device C based on the path information.
Upon expiration of the microloop avoidance RIB-update-delay timer and completion of route convergence on Device B, Device A does not add path information to packets anymore. It will forward packets to Device C as usual.
Figure 19 Diagram for SR microloop avoidance after a failure recovery
·     draft-previdi-6man-segment-routing-header
·     draft-ietf-6man-segment-routing-header
·     draft-filsfils-spring-segment-routing
·     draft-filsfils-spring-srv6-network-programming
The SRv6 feature requires a license. For more information about licensing, see Fundamentals Configuration Guide.
To configure SRv6, perform the following tasks:
1.     Configuring common SRv6 SIDs
2.     Configuring G-SIDs
3.     Using IGP to advertise SRv6 SIDs
4.     Configuring BGP for SRv6
¡     Configuring BGP to advertise SRv6 SIDs
¡     Configuring BGP-EPE
This task is required in an inter-AS network.
5.     Configuring SRv6 tunneling
Perform the following tasks on the source node of an SRv6 tunnel:
a.     Configuring an SID list
b.     Specifying an SID list for an SRv6 tunnel interface
c.     (Optional.) Configuring a service class for an SRv6 tunnel interface
d.     (Optional.) Enabling BFD echo-mode detection on an SRv6 tunnel interface
6.     (Optional.) Configuring traffic forwarding
7.     (Optional.) Configuring TI-LFA FRR
8.     (Optional.) Configuring the SRv6 MTU
Before you configure an SRv6 tunnel, perform the following tasks:
·     Determine the ingress node, transit nodes, and egress node of the SRv6 tunnel.
·     Plan the IPv6 address of each SR node.
An SRv6 SID is in the format of IPv6 address and it contains 128 bits. An SRv6 SID contains the Locator, Function, and Args portions.
·     The Locator portion is determined by the ipv6-prefix ipv6-address prefix-length parameter. The portion length is determined by the prefix-length argument. A locator is an IPv6 subnet. All IPv6 addresses in the subnet can be used as SRv6 SIDs.
·     The Function portion contains an opcode. The opcode can be a static opcode or a dynamic opcode.
¡     Static opcode—Manually configured by using the opcode command. SRv6 SIDs generated based on a static opcode are static SRv6 SID. The length of a static opcode is determined by the static static-length option, and it determines the number of static SRv6 SIDs on the locator.
¡     Dynamic opcode—Dynamically allocated by IGP or BGP. SRv6 SIDs generated based on a dynamic opcode are dynamic SRv6 SID. When dynamically allocating SRv6 SIDs, IGP or BGP applies for SIDs outside the static opcode range to avoid SRv6 SID conflicts.
·     The Args portion contains traffic flow and service information. This portion is determined by the args args-length option.
The length of a dynamic opcode is calculated by using the following formula: dynamic-length = 128 - (prefix-length + static-length + args-length).
·     The ipv6-prefix portion represents the IPv6 prefix specified by using theipv6-address and prefix-length arguments in the locator command. The number of bits occupied by the IPv6 prefix is configured by using the prefix-length argument.
·     The number of bits occupied by 0s (following the ipv6-prefix portion) is the value of the dynamic-length argument.
·     The opcode portion represents the opcode. The number of bits occupied by the opcode is configured by using the static-length argument in the locator command.
·     The number of bits occupied by 0s (following the opcode portion) is the value of the args-length argument.
A dynamic SRv6 SID is generated based on the following formula: dynamic SRv6 SID = ipv6-prefix + dynamic + 0.
·     The ipv6-prefix portion represents the IPv6 prefix specified by using the ipv6-address and prefix-length arguments in the locator command. The number of bits occupied by the IPv6 prefix is configured by using the prefix-length argument.
·     The dynamic portion is dynamically allocated by IGP or BGP. The number of bits occupied by this portion is the value of the dynamic-length argument.
·     The number of bits occupied by 0s is the sum value of the static-length and args-length arguments.
·     The Locator portion is 100:200:DB8:ABCD::. This portion occupies 64 bits.
·     The static opcode occupies 24 bits.
·     The Args portion occupies 32 bits.
·     The dynamic opcode occupies 8 bits.
·     The start static SRv6 SID is 100:200:DB8:ABCD:0:1::.
·     The end static SRv6 SID is 100:200:DB8:ABCD:FF:FFFF::.
·     The start dynamic SRv6 SID is 100:200:DB8:ABCD:100::.
·     The end dynamic SRv6 SID is 100:200:DB8:ABCD:FFFF:FFFF::.
Each locator must have a unique name.
Do not configure the same IPv6 address prefix and prefix length for different locators. In addition, the IPv6 address prefixes of different locators cannot overlap.
You cannot disable SRv6 or delete a locator in SRv6 view if the locator has dynamic SRv6 SIDs that are being used.
Configuring SID allocation from a common locator
2.     Enable SRv6 and enter SRv6 view.
segment-routing ipv6
3.     Configure a common locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4.     Configure an opcode. Perform one of the following tasks:
¡     Configure an End SID.
opcode opcode end
¡     Configure an End.X SID.
opcode opcode end-x interface interface-type interface-number nexthop nexthop-ipv6-address
¡     Configure an End.DT4 SID.
opcode opcode end-dt4 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
The specified VPN instance must exist. An End.DT4 SID cannot be configured in different VPN instances.
¡     Configure an End.DT6 SID.
opcode opcode end-dt6 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
The specified VPN instance must exist. An End.DT6 SID cannot be configured in different VPN instances.
¡     Configure an End.DT46 SID.
opcode opcode end-dt46 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
The specified VPN instance must exist. An End.DT46 SID cannot be configured in different VPN instances.
¡     Configure an End.DX4 SID.
opcode opcode end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address [ vpn-instance vpn-instance-name [ evpn ] ]
The specified VPN instance must exist. An End.DX4 SID cannot be configured with different output interfaces or next hops.
¡     Configure an End.DX6 SID.
opcode opcode end-dx6 interface interface-type interface-number nexthop nexthop-ipv6-address [ vpn-instance vpn-instance-name [ evpn ] ]
The specified VPN instance must exist. An End.DX6 SID cannot be configured with different output interfaces or next hops.
¡     Configure an End.DX2 SID.
opcode { opcode | hex hex-opcode } end-dx2 xconnect-group group-name connection connection-name
The specified cross-connect group and cross-connect must exist.
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number
The specified VSI must exist.
¡     Configure an End.DX2L SID.
opcode { opcode | hex hex-opcode } end-dx2l xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2l vsi vsi-name interface interface-type interface-number
¡     Configure an End.DT2M SID.
opcode { opcode | hex hex-opcode } end-dt2m vsi vsi-name
The specified VSI must exist. An End.DT2M SID cannot be configured in different VSIs.
¡     Configure an End.DT2U SID.
opcode { opcode | hex hex-opcode } end-dt2u vsi vsi-name
The specified VSI must exist. An End.DT2U SID cannot be configured in different VSIs.
¡     Configure an End.DT2UL SID.
opcode { opcode | hex hex-opcode } end-dt2ul vsi vsi-name
The specified VSI must exist. An End.DT2UL SID cannot be configured in different VSIs.
¡     Configure an End.OP SID.
opcode opcode end-op
¡     Configure an End.M SID.
opcode { opcode | hex hex-opcode } end-m mirror-locator ipv6-address prefix-length
Configuring SID allocation from a PD locator
3.     Configure a PD locator and enter SRv6 locator view.
locator locator-name [ pd prefix-number sub-prefix sub-prefix-length static static-length ]
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number service-instance instance-id
Configuring G-SIDs
A COC32 locator can allocate both SRv6 SIDs that carry a COC flavor (End(COC32) SIDs and End.X(COC32) SIDs) and common SRv6 SIDs that do not carry a COC flavor. The IPv6 prefix length must be longer than the common prefix length.
3.     Enable SRv6 compression.
srv6 compress enable
By default, SRv6 compression is disabled.
4.     Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc32 [ args args-length | static static-length ] * ]
5.     Configure an opcode. Perform one of the following tasks:
¡     Configure common SRv6 SIDs. For more information, see "Configuring common SRv6 SIDs."
opcode opcode end-coc32 [ no-psp ]
opcode opcode end-x-coc32 interface interface-type interface-number nexthop nexthop-address [ no-psp ]
For a COC-both locator that has both compressible and non-compressible SRv6 SIDs, you can set the same opcode for the compressible and non-compressible hybrid SRv6 SIDs.
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc-both [ non-compress-static non-compress-static-length ] [ args args-length | static static-length ] * ]
5.     (Optional.) Reserve SRv6 SIDs.
reserved-sid-start sid-value count reserved-sid-count
By default, no SRv6 SIDs are reserved.
When the device generates an SRv6 TE policy based on received SRv6 TE policy routes, it must assign a BSID to the SRv6 TE policy. Use this command to reserve SRv6 SIDs that can be assigned to SRv6 TE policies as BSIDs. The reserved SRv6 SIDs cannot be used by other protocols.
6.     Configure an opcode. Perform one of the following tasks:
¡     Configure an opcode for End (COCNONE) SIDs.
opcode { opcode | hex hex-opcode } end-coc-none [ no-psp ]
End (COCNONE) SIDs are allocated from compressible SRv6 SID space. The SIDs have the same function as End SIDs.
¡     Configure an opcode for End.X (COCNONE) SIDs.
opcode { opcode | hex hex-opcode } end-x-coc-none interface interface-type interface-number nexthop nexthop-ipv6-address [ no-psp ]
End.X (COCNONE) SIDs are allocated from compressible SRv6 SID space. The SIDs have the same function as End.X SIDs.
Use an IGP to advertise the SRv6 SID of a locator by applying the locator to the IGP.
To use an IGP to advertise G-SIDs to neighbors, enable SRv6 compression for that IGP.
If IS-IS is used to advertise SRv6 SIDs, make sure the cost style of IS-IS is wide, compatible, or wide-compatible. For more information about the cost styles of IS-IS, see Layer 3—IP Routing Configuration Guide.
Using IS-IS to advertise SRv6 SIDs
2.     Enter IS-IS process view.
3.     Enter IS-IS IPv6 address family view.
4.     Apply a locator to IS-IS IPv6 address family.
segment-routing ipv6 locator locator-name [ level-1 | level-2 ] [ auto-sid-disable ]
By default, no locators are applied to IS-IS IPv6 address family.
Repeat this command to apply multiple locators to IS-IS IPv6 address family for the family to advertise multiple SRv6 SIDs.
5.     Enable SRv6 compression for IPv6 IS-IS.
srv6 compress enable [ level-1 | level-2 ]
By default, SRv6 compression is disabled for IPv6 IS-IS.
Use this command only when IPv6 IS-IS is used to advertise G-SIDs.
Using OSPFv3 to advertise SRv6 SIDs
2.     Enter OSPFv3 process view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
3.     Apply a locator to the OSPFv3 process.
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
By default, no locators are applied to an OSPFv3 process.
Repeat this command to apply multiple locators to the OSPFv3 process for the process to advertise multiple SRv6 SIDs.
4.     (Optional.) Configure the TLVs and flag bits in the OSPFv3 extensions for SRv6 to be compatible with the private protocol.
segment-routing ipv6 private-srv6-extensions compatible
By default, the SRv6 Capabilities TLV type values, Sub TLV type values, and flag bits in OSPFv3 packets follow the definitions in draft-ietf-lsr-ospfv3-srv6-extensions-09. For a successful advertisement of SRv6 locators and SRv6 SIDs, make sure OSPFv3 neighbors follow the same standard.
5.     (Optional.) Enable compatibility of the Locator field in SRv6 Locator TLVs with earlier drafts.
segment-routing ipv6 compatible locator-fixed-length
By default, the Locator field in SRv6 locator LSAs is of variable length, with a maximum of 128 bytes.
The length of the Locator field in SRv6 Locator TLVs is defined as variable in draft-ietf-lsr-ospfv3-srv6-extensions-12 and later drafts and can be up to 128 bits. The length of the Locator field can vary based on the configured locator segment length. However, the length is fixed at 128 bits in draft-ietf-lsr-ospfv3-srv6-extensions-11 and earlier drafts.
Perform this task to apply an SRv6 locator to BGP for BGP to use IPv4 or IPv6 unicast routes to advertise SRv6 SIDs in the locator.
3.     Enter BGP IPv6 unicast address family view.
4.     Apply a locator to the view.
By default, no locators are applied.
Configuring BGP-EPE
BGP-EPE allocates BGP peer SIDs to inter-AS segments. The device advertises the peer SIDs to a network controller through BGP LS messages. The controller orchestrates the IGP SIDs and BGP peer SIDs to realize optimal inter-AS traffic forwarding.
With this feature, the device can allocate SRv6 SIDs to its connected BGP peers or peer groups to identify its connected BGP peers or links.
If you do not specify any parameters for the peer egress-engineering srv6 command, the device will dynamically allocate SRv6 SIDs to peers. The SRv6 SIDs belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view. To identify whether the static SRv6 SID takes effect, use the display bgp egress-engineering ipv6 command. If the static SRv6 SID does not take effect, the static SRv6 SID has been used by other protocols. After the static SRv6 SID is released, first use the undo peer egress-engineering srv6 command to remove the original static SRv6 SID configuration. Then, use the peer egress-engineering srv6 command to reconfigure the static SRv6 SID.
When you use the peer egress-engineering srv6 command for a peer, follow these restrictions and guidelines:
·     If you use this command to specify multiple locators for that peer, only the most recent configuration takes effect.
·     If you use this command to specify multiple static SRv6 SIDs and the SIDs belong to different types, all types of SRv6 SIDs can take effect. For the same type of SRv6 SIDs, only the most recent configuration takes effect.
If you specify a static SRv6 SID for a peer, the specified static SRv6 SID must belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
The static SRv6 SIDs specified by using the following commands cannot be the same in a BGP instance:
·     peer egress-engineering srv6.
·     egress-engineering srv6 peer-set.
3.     Enable SRv6 BGP-EPE.
peer group-name egress-engineering srv6
peer ipv6-address [ prefix-length ] egress-engineering srv6 [ locator locator-name | static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
By default, SRv6 BGP-EPE is disabled.
Applying a locator to BGP-EPE
Perform this task to restrict the range of End.X SIDs that can be allocated to BGP-EPE SRv6 peer sets and BGP-EPE-enabled peers in a BGP instance. All static SRv6 SIDs configured for the BGP-EPE SRv6 peer sets and peers must belong to the locator specified by performing this task.
To dynamically allocate End.X SIDs from the specified locator:
·     Do not configure a static SRv6 SID when you create a BGP-EPE SRv6 peer set by using the egress-engineering srv6 peer-set command.
·     Do not specify a locator or configure a static SRv6 SID when you enable SRv6 BGP-EPE for a peer by using the peer egress-engineering srv6 command.
3.     Apply a locator to BGP-EPE.
segment-routing ipv6 egress-engineering locator locator-name
By default, no locator is applied to BGP-EPE.
Configuring a BGP-EPE SRv6 peer set
If the device establishes BGP peer relationship with multiple devices, perform this task to add the peer devices to a peer set and allocate a PeerSet SID to the peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers for load sharing.
Enable SRv6 BGP-EPE on all peers that will be added to the BGP-EPE SRv6 peer set.
Use the segment-routing ipv6 egress-engineering locator command in BGP instance view to apply a locator to BGP-EPE.
·     If automatic SID allocation is used, the device dynamically allocates an SRv6 SID to the BGP-EPE SRv6 peer set from the specified locator.
·     If you specify a static SRv6 SID for the BGP-EPE SRv6 peer set, the specified static SRv6 SID must belong to the specified locator.
If you execute the egress-engineering srv6 peer-set command to specify multiple SRv6 SIDs for one peer set, the effective configuration depends on whether the SRv6 SIDs are the same type.
·     If all the SRv6 SIDs belong to the same type, only the most recent configuration takes effect.
·     If the SRv6 SIDs belong to different types, the configuration for all the SRv6 SID types takes effect. For the SRv6 SIDs that belong to the same type, only the most recent configuration takes effect. Make sure each SRv6 SID is unique among all the SRv6 SID types.
The static SRv6 SIDs configured by using the following commands cannot be the same in a BGP instance:
3.     Create a BGP-EPE SRv6 peer set.
egress-engineering srv6 peer-set peer-set-name [ static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
4.     Add a peer to the BGP-EPE SRv6 peer set.
peer { ipv6-address [ prefix-length ] } peer-set srv6-peer-set-name
By default, no peers are added to a BGP-EPE SRv6 peer set.
To change the BGP-EPE SRv6 peer set for a peer, you must first use undo peer peer-set command to remove that peer from the original BGP-EPE SRv6 peer set.
An SR node is uniquely identified by an SID index in an SID list. The SID list forms a forwarding path. The SR nodes in the list are arranged by SID index in ascending sort order. When the device encapsulates the Segment List, SRv6 automatically assigns a segment index to each SR node based on their SID indexes. The smallest SID index corresponds to the largest segment index, and the largest SID index corresponds to the smallest segment index.
If you do not specify an SID index for an SR node, SRv6 automatically assigns an SID index to the node. The assigned SID index is the largest index that has been assigned plus an increment.
Make sure the node nearest to the source node is assigned the smallest SID index. The nearer a node is to the source node, the smaller the SID index value of the node must be.
If changing settings for an SID list will cause the tunnel that uses this SID list to go down, the device does not issue the changed settings until route convergence is complete.
2.     Create an SID list and enter its view.
ipv6 segment-routing sid-list list-name
3.     Configure an SR node in the SID list.
sid [ index index-number ] ipv6-address
To make the node reachable by other nodes, configure IGP on the node to advertise the SRv6 SID of the node.
2.     Create an SRv6 tunnel interface and enter its view.
interface tunnel tunnel-number mode sr ipv6
3.     Specify an SID list for the tunnel interface.
tunnel sid-list list-name [ backup ]
By default, no SID lists are specified for an SRv6 tunnel interface.
Class Based Tunnel Selection (CBTS) compares the service class value of the traffic with the service class values of SRv6 tunnels. CBTS uses the following rules to select a tunnel to forward the traffic:
·     If the traffic matches an SRv6 tunnel, CBTS uses this tunnel.
·     If the traffic matches multiple SRv6 tunnels, CBTS selects a tunnel based on the flow forwarding mode set on the tunnel interface.
¡     If flow-based forwarding is set, CBTS randomly selects a matching tunnel for packets of the same flow.
¡     If packet-based forwarding is set, CBTS uses all matching tunnels to load share the packets.
·     If the traffic does not match any SRv6 tunnels, CBTS selects an SRv6 tunnel from all tunnels with a service class value smaller than the traffic. Among these tunnels, the one with the largest service class value is used. If all SRv6 tunnels have a service class value greater than the traffic, CBTS uses the tunnel with the smallest service class value.
2.     Enter SRv6 tunnel interface view.
interface tunnel tunnel-number [ mode sr ipv6 ]
3.     Configure a service class for the tunnel interface.
service-class class-value
By default, no service class is configured for an SRv6 tunnel interface.
Perform this task on an SRv6 tunnel interface to use BFD sessions for quick link connectivity detection of the SRv6 tunnel. If a link failure is detected along the path, the device can quickly handle the issue, for example, it can direct the traffic to the backup path to ensure traffic forwarding continuity.
If the BFD session of a path is down, the path is unavailable. If the BFD session of a path is up, the path is available.
2.     Configure the source IPv6 address of BFD echo packets.
By default, no source IPv6 address is configured for BFD echo packets.
As a best practice, do not configure the source IPv6 address to be on the same network segment as any local interfaces. If you configure such a source IPv6 address, a large number of ICMPv6 redirect packets might be sent from the peer, resulting in link congestion. For more information about this command, see BFD in High Availability Configuration Guide.
3.     Enter SRv6 tunnel interface view.
4.     Enable BFD echo-mode detection.
tunnel bfd enable echo
By default, BFD echo-mode detection is disabled on an SRv6 tunnel interface.
Configuring a static route to direct traffic to an SRv6 tunnel
For information about the command to configure a static route, see Layer 3—IP Routing Command Reference. The interface specified in this command must be an SRv6 tunnel interface.
Configuring automatic static route advertisement to direct traffic to an SRv6 tunnel
Perform this task on an SRv6 tunnel interface to create a static route whose destination address and output interface are the tunnel destination address and the tunnel interface, respectively.
3.     Configure automatic static route advertisement.
tunnel route-static [ preference preference-value ]
By default, automatic static route advertisement is not configured.
Configuring automatic IGP route advertisement to direct traffic to an SRv6 tunnel
To direct traffic to an SRv6 tunnel, you can distribute the SRv6 tunnel to the IGP and make the SRv6 tunnel participate in IGP route calculation. To achieve these purposes, deploy the following functionalities:
·     IPv6 router ID.
The IPv6 router ID determines the source and destination addresses of the SRv6 tunnel distributed to the IGP. The destination address of the SRv6 tunnel must be the same as the IPv6 router ID of the destination node.
Configuring an IPv6 route ID on a router also enables the IPv6 TE feature on that router. After the SRv6 tunnel participates in IGP route calculation, traffic can be directed to the SRv6 tunnel.
·     Automatic route advertisement.
This functionality distributes the SRv6 tunnel to the IGP and makes the SRv6 tunnel participate in IGP route calculation.
Restrictions and guidelines for directing traffic to an SRv6 tunnel
The IPv6 router ID must be unique in the IPv6 network.
To avoid routing loops in a ring topology when a link on the SRv6 tunnel is down, set the SIDs in the SID list of the SRv6 tunnel to have 128-bit prefixes. IGP does not set the output interface of a host route to the SRv6 tunnel interface.
Prerequisites for directing traffic to an SRv6 tunnel
Before you configure the IPv6 router ID for IS-IS, make sure the cost style of IS-IS is wide, compatible, or wide-compatible. For more information about the cost styles of IS-IS, see Layer 3—IP Routing Configuration Guide.
Before you configure automatic route advertisement, you must enable IPv6 capability for the IGP on the SRv6 tunnel interface.
Configuring the IPv6 router ID and enabling IPv6 TE
2.     Enter IS-IS view.
4.     Configure the IPv6 router ID for IS-IS and enable IPv6 TE.
router-id ipv6-address
By default, no IPv6 router ID is configured for IS-IS and IPv6 TE is disabled.
Configuring IGP shortcut
3.     Enable IGP shortcut.
srv6 igp shortcut [ isis | ospf ]
By default, IGP shortcut is disabled.
Only IS-IS supports IGP shortcut in the current software version.
4.     Assign a metric to the SRv6 tunnel.
srv6 igp metric { absolute value | relative value }
By default, the metric of an SRv6 tunnel equals its IGP metric.
Restrictions and guidelines for TI-LFA FRR
By default, no backup path can be calculated by TI-LFA FRR if the next hops of equal-cost primary paths on the source node are different. To address this issue, you can add all equal-cost primary paths on the source node to the same SRLG.
As shown in Figure 20, three equivalent paths Link 1, Link 2, and Link 3 are available from source node Device A to destination node Device E, with their next hops different. For TI-LFA FRR to calculate backup paths, you must add Link 1, Link 2, and Link 3 to the same SRLG.
Figure 20 Using TI-LFA FRR to calculate backup paths in the IS-IS ECMP scenario
TI-LFA FRR tasks at a glance
To configure TI-LFA FRR, perform the following tasks:
1.     Enabling TI-LFA FRR
2.     (Optional.) Disabling an interface from participating in TI-LFA calculation
On the source node, disable TI-LFA on the route's output interface to the next hop on the primary path.
3.     (Optional.) Configuring SR microloop avoidance
Enabling TI-LFA FRR
Enabling IPv6 IS-IS TI-LFA FRR
isis process-id
3.     Enter IS-IS IPv6 unicast address family view.
address-family ipv6
4.     Enable LFA FRR for IPv6 IS-IS.
fast-reroute lfa [ level-1 | level-2 ]
By default, LFA FRR is disabled for IPv6 IS-IS.
5.     Enable TI-LFA FRR for IPv6 IS-IS.
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
By default, TI-LFA FRR is disabled for IPv6 IS-IS.
6.     (Optional.) Set the priority for an FRR backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference [ level-1 | level-2 ]
By default, the priority values of the lowest-cost and node-protection backup path selection policies are 20 and 40, respectively.
Enabling OSPFv3 TI-LFA FRR
2.     Enter OSPFv3 view.
3.     Enable LFA FRR for OSPFv3.
fast-reroute { lfa [ abr-only ] | route-policy route-policy-name }
By default, LFA FRR is disabled for OSPFv3.
4.     Enable TI-LFA FRR for OSPFv3.
By default, TI-LFA FRR is disabled for OSPFv3.
Disabling an IPv6 IS-IS interface from participating in TI-LFA calculation
2.     Enter the view of IPv6 IS-IS interface.
3.     Disable the interface from participating in TI-LFA calculation.
isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
By default, an IPv6 IS-IS interface participates in TI-LFA calculation.
Disabling an OSPFv3 interface from participating in TI-LFA calculation
2.     Enter the view of OSPFv3 interface.
ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
By default, an OSPFv3 interface participates in TI-LFA calculation.
Enabling FRR microloop avoidance
FRR microloop avoidance provides microloop avoidance after a network failure.
On a network deployed with TI-LFA FRR, when a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. If devices on the backup path have not finished route convergence, a loop is formed between the source node (failed node or the previous node along the link) and a device on the backup path. The loop exists until the devices on the backup path finish route convergence.
To resolve this issue, configure this feature on a node enabled with TI-LFA FRR. FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA to avoid packet loss after a node or link failure on the optimal path. Then, that node starts an FRR microloop avoidance RIB-update-delay timer configured by the fast-reroute microloop-avoidance rib-update-delay command after it finishes route convergence. The node performs the following operations only after all nodes on the backup path finish route convergence and the timer times out:
·     Issues the forwarding path after route convergence to the FIB.
·     Switches traffic from the backup path calculated by TI-LFA to the forwarding path after route convergence.
If you configure both FRR microloop avoidance and SR microloop avoidance, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
·     If the FRR microloop avoidance RIB-update-delay timer is equal to or greater than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path immediately when the former timer times out.
·     If the FRR microloop avoidance RIB-update-delay timer is smaller than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path until after the latter timer times out.
Configuring IPv6 IS-IS FRR microloop avoidance
isis process-id
address-family ipv6
4.     Enable FRR microloop avoidance for IS-IS.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
By default, FRR microloop avoidance is disabled for IS-IS.
5.     (Optional.) Set the FRR microloop avoidance RIB-update-delay time.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the FRR microloop avoidance RIB-update-delay time is 5000 ms.
SR microloop avoidance provides microloop avoidance after both a network failure and a failure recovery.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of nonsimultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
To ensure sufficient time for IGP to complete route convergence, set the SR microloop avoidance RIB-update-delay time. Before the timer expires, faulty relevant devices will forward traffic along the specified path. Upon expiration of the timer and completion of IGP route convergence, traffic will traverse along the IGP-calculated path.
Configuring IPv6 IS-IS SR microloop avoidance
isis process-id
address-family ipv6
4.     Enable SR microloop avoidance for IPv6 IS-IS.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
By default, SR microloop avoidance is disabled for IPv6 IS-IS.
5.     (Optional.) Set the SR microloop avoidance RIB-update-delay time.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
By default, the SR microloop avoidance RIB-update-delay time is 5000 ms.
Configuring OSPFv3 SR microloop avoidance
3.     Enable SR microloop avoidance for OSPFv3.
By default, SR microloop avoidance is disabled for OSPFv3.
4.     (Optional.) Set the SR microloop avoidance RIB-update-delay time.
Perform this task to configure one of the following MTUs:
·     Path MTU—The maximum IPv6 MTU along the path from the source node to the destination node. The transit nodes do not fragment SRv6 tunneled packets. If a packet is larger than the MTU of the output interface, the packet will be discarded. If the MTU is too small, the bandwidth is not sufficiently used. To address these issues, configure an appropriate SRv6 path MTU.
·     Reserved MTU—Reserved MTU on the source node for TI-LFA. When packets are switched to the backup path after the primary path fails, the device reconstructs an IPv6 header and SRH for the packets. As a result, packet drop might occur because the packet size has exceeded the MTU. To resolve this issue, configure a reserved MTU on the source node to reserve bytes for adding a new SRH to SRv6 packets in case of primary path failure.
The SRv6 path MTU minus the reserved MTU is the active MTU. The effective MTU for SRv6 packets on the source node is the smaller value from the following values:
·     The active MTU.
·     The IPv6 MTU of the physical output interface.
Make sure the active MTU is equal to or greater than 1280 bytes.
2.     Enter SRv6 view.
3.     Specify a reserved MTU for SRv6 path MTU.
path-mtu reserved [ reserved-value ]
By default, no reserved MTU is specified for SRv6 path MTU.
4.     Configure the SRv6 path MTU.
path-mtu mtu-value
By default, the SRv6 path MTU is 1500 bytes.
Display and maintenance commands for SRv6
Display BGP-EPE information for IPv6 peers.
display bgp [ instance instance-name ] egress-engineering ipv6 [ ipv6-address ]
Display information about BGP-EPE SRv6 peer sets.
display bgp egress-engineering srv6 peer-set [ srv6-peer-set-name ]
Display SID list information.
display ipv6 segment-routing sid-list [ list-name ]
Display IS-IS SRv6 capability information.
display isis segment-routing ipv6 capability [ level-1 | level-2 ] [ process-id ]
Display IS-IS SRv6 locator routing information.
display isis segment-routing ipv6 locator [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS SRv6 tunnel interface information.
display isis srv6 tunnel [ level-1 | level-2 ] [ process-id ]
Display OSPFv3 SRv6 capability information.
display ospfv3 [ process-id ] segment-routing ipv6 capability
Display OSPFv3 SRv6 tunnel interface information.
display ospfv3 [ process-id ] srv6 tunnel [ interface-number ]
Display SRv6 forwarding entries.
In standalone mode:
display segment-routing ipv6 forwarding [ entry-id ]
In IRF mode:
display segment-routing ipv6 forwarding [ entry-id ] [ slot slot-number ]
Display information about the SRv6 local SID forwarding table.
display segment-routing ipv6 local-sid { end | end-am | end-as | end-b6encaps | end-b6encapsred | end-b6insert | end-b6insertred | end-coc32 | end-dt2m | end-dt2u | end-dt2ul | end-dx2 | end-dx2l | end-m | end-op | end-t | end-x-coc32 } [ sid ]
display segment-routing ipv6 local-sid { end-dt4 | end-dt46 | end-dt6 | end-dx4 | end-dx6 } [ sid | vpn-instance vpn-instance-name ]
display segment-routing ipv6 local-sid end-x [ sid | interface interface-type interface-number [ nexthop nexthop-ipv6-address ] ]
Display SRv6 locator information.
display segment-routing ipv6 locator [ locator-name ]
Display information about PD prefixes obtained by an SRv6 locator through DHCPv6.
display segment-routing ipv6 pd-info
SRv6 configuration examples
Example: Configuring SRv6 that uses End SIDs
As shown in Figure 21, run OSPFv3 on Router A, Router B, and Router C. Set up an SRv6 tunnel between Router A and Router C.
Figure 21 Network diagram
Device
IP address
Device
IP address
Router A
Loop0
1::9/128
Router C
Loop0
5::9/128
GE2/0
1::1/64
GE2/0
2::2/64
Router B
Loop0
2::9/128
GE1/0
1::2/64
GE2/0
2::1/64
1.     Configure IPv6 addresses and masks for the interfaces. (Details not shown.)
2.     Configure OSPFv3 to advertise routes for the interfaces, including the loopback interfaces. (Details not shown.)
Execute the display ipv6 routing-table command on each router to verify that they have obtained routes to reach one another, including the host routes of loopback interfaces.
3.     Configure Router A:
# Configure SRv6 End SIDs.
[RouterA] segment-routing ipv6
[RouterA-segment-routing-ipv6] locator aa ipv6-prefix 100:1::1 120 static 8
[RouterA-segment-routing-ipv6-locator-aa] opcode 1 end
[RouterA-segment-routing-ipv6-locator-aa] quit
[RouterA-segment-routing-ipv6] quit
# Configure OSPFv3 to advertise the SRv6 SIDs.
[RouterA] ospfv3 1
[RouterA-ospfv3-1] segment-routing ipv6 locator aa
[RouterA-ospfv3-1] quit
# Configure SID list a and specify Router B and Router C as nodes in the list.
[RouterA] ipv6 segment-routing sid-list a
[RouterA-srv6-sid-list-a] sid 200:1::1
[RouterA-srv6-sid-list-a] sid 300:1::1
[RouterA-srv6-sid-list-a] quit
# Create SRv6 tunnel interface Tunnel 0 on Router A. Specify Loopback 0 as the source interface, specify the IP address of Loopback 0 on Router C as the destination, configure an IPv6 address for the tunnel interface, and apply SID list a to the SRv6 tunnel.
[RouterA] interface tunnel 0 mode sr ipv6
[RouterA-Tunnel0] source loopback 0
[RouterA-Tunnel0] destination 5::9
[RouterA-Tunnel0] ipv6 address 6::6 64
[RouterA-Tunnel0] tunnel sid-list a
[RouterA-Tunnel0] quit
# Configure a static route to direct traffic destined for Router C to the SRv6 tunnel.
[RouterA] ipv6 route-static 99::1 64 tunnel 0
4.     Configure Router B:
[RouterB] segment-routing ipv6
[RouterB-segment-routing-ipv6] locator bb ipv6-prefix 200:1::1 120 static 8
[RouterB-segment-routing-ipv6-locator-bb] opcode 1 end
[RouterB-segment-routing-ipv6-locator-bb] quit
[RouterB-segment-routing-ipv6] quit
[RouterB] ospfv3 1
[RouterB-ospfv3-1] segment-routing ipv6 locator bb
[RouterB-ospfv3-1] quit
5.     Configure Router C:
[RouterC] segment-routing ipv6
[RouterC-segment-routing-ipv6] locator cc ipv6-prefix 300:1::1 120 static 8
[RouterC-segment-routing-ipv6-locator-cc] opcode 1 end
[RouterC-segment-routing-ipv6-locator-cc] quit
[RouterC-segment-routing-ipv6] quit
[RouterC] ospfv3 1
[RouterC-ospfv3-1] segment-routing ipv6 locator cc
[RouterC-ospfv3-1] quit
# Configure an SID list, SRv6 tunnel, and static route on Router C in the same way as the settings are configured on Router A. The SID list, SRv6 tunnel, and static route on Router C are from Router C to Router A. (Details not shown.)
# Verify the SID list information on Router A.
[RouterA] display ipv6 segment-routing sid-list
SID list name: a
  SID information:
    SID index              Address
    5                      200:1::1
    9                      300:1::1
  SID list usage on tunnels:
    Tunnel number          SID list role
    0                      Primary
Verify that the traffic destined for 99::1 is forwarded through the SRv6 tunnel.
[Router A] display ipv6 fib 99::1
FIB entry count: 1
Flag:
  R:Relay     F:FRR
Destination: 99::                                           Prefix length: 64
Nexthop    : ::                                             Flags: US
Time stamp : 0x10                                           Label: Null
Interface  : Tun0                                           Token: Invalid
Example: Configuring SRv6 that uses End.X SIDs
As shown in Figure 22, run OSPFv3 on Router A, Router B, and Router C. Set up an SRv6 tunnel between Router A and Router C.
Figure 22 Network diagram
Device
IP address
Device
IP address
Router A
Loop0
1::9/128
Router C
Loop0
5::9/128
GE2/0
1::1/64
GE2/0
2::2/64
Router B
Loop0
2::9/128
GE1/0
1::2/64
GE2/0
2::1/64
# Configure SRv6 End.X SIDs.
[RouterA-segment-routing-ipv6] locator a1 ipv6-prefix 100:1::1:0 120 static 8
[RouterA-segment-routing-ipv6-locator-a1] opcode 1 end-x interface gigabitethernet 2/0 nexthop 1::2
[RouterA-segment-routing-ipv6-locator-a1] quit
[RouterA] ospfv3 1
[RouterA-ospfv3-1] segment-routing ipv6 locator a1
# Configure SID list A and specify Router B and Router C as nodes in the list.
[RouterA] ipv6 segment-routing sid-list A
[RouterA-srv6-sid-list-A] sid 200:1::1
[RouterA-srv6-sid-list-A] sid 300:1::1
[RouterA-srv6-sid-list-A] quit
# Create SRv6 tunnel interface Tunnel 0 on Router A. Specify Loopback 0 as the source interface, specify the IP address of Loopback 0 on Router C as the destination, configure an IPv6 address for the tunnel interface, and apply SID list A to the SRv6 tunnel.
[RouterA-Tunnel0] ipv6 address 7::7 64
[RouterA-Tunnel0] tunnel sid-list A
[RouterA] ipv6 route-static 199::1 64 tunnel 0
[RouterB-segment-routing-ipv6] locator b1 ipv6-prefix 200:1::1:0 120 static 8
[RouterB-segment-routing-ipv6-locator-b1] opcode 1 end-x interface gigabitethernet 2/0 nexthop 2::2
[RouterB-segment-routing-ipv6-locator-b1] quit
[RouterB] ospfv3 1
[RouterB-ospfv3-1] segment-routing ipv6 locator b1
[RouterC-segment-routing-ipv6] locator c1 ipv6-prefix 300:1::1:0 120 static 8
[RouterC-segment-routing-ipv6-locator-c1] opcode 1 end
[RouterC-segment-routing-ipv6-locator-c1] quit
[RouterC] ospfv3 1
[RouterC-ospfv3-1] segment-routing ipv6 locator c1
SID list name: A
  SID information:
    SID index              Address
    5                      200:1::1
    9                      300:1::1
    0                      Primary
Verify that the traffic destined for 199::1 is forwarded through the SRv6 tunnel.
[Router A] display ipv6 fib 199::1
FIB entry count: 1
Flag:
  R:Relay     F:FRR
Destination: 199::                                          Prefix length: 64
Time stamp : 0x17                                           Label: Null
Example: Configuring IPv6 IS-IS TI-LFA FRR
As shown in Figure 23, complete the following tasks to implement TI-LFA FRR:
·     Configure IPv6 IS-IS on Device A, Device B, Device C, and Device D to achieve network level connectivity.
·     Configure IS-IS SRv6 on Device A, Device B, Device C, and Device D.
·     Configure TI-LFA FRR to remove the loop on Link B and to implement fast traffic switchover to Link B when Link A fails.
Figure 23 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Device A
Loop1
1::1/128
Device B
Loop1
2::2/128
GE1/0
2000:1::1/64
GE1/0
2000:1::2/64
GE2/0
2000:4::1/64
GE2/0
2000:2::2/64
Device C
Loop1
3::3/128
Device D
Loop1
4::4/128
GE1/0
2000:3::3/64
GE1/0
2000:3::4/64
GE2/0
2000:2::3/64
GE2/0
2000:4::4/64
1.     Configure IPv6 addresses and prefixes for interfaces. (Details not shown.)
2.     Configure Device A:
# Configure IPv6 IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] address-family ipv6
[DeviceA-isis-1-ipv6] quit
[DeviceA-isis-1] quit
[DeviceA] interface gigabitethernet 1/0
[DeviceA-GigabitEthernet1/0] isis ipv6 enable 1
[DeviceA-GigabitEthernet1/0] isis cost 10
[DeviceA-GigabitEthernet1/0] quit
[DeviceA] interface gigabitethernet 2/0
[DeviceA-GigabitEthernet2/0] isis ipv6 enable 1
[DeviceA-GigabitEthernet2/0] isis cost 10
[DeviceA-GigabitEthernet2/0] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis ipv6 enable 1
[DeviceA-LoopBack1] quit
# Enable SRv6 and configure a locator.
[DeviceA] segment-routing ipv6
[DeviceA-segment-routing-ipv6] locator aaa ipv6-prefix 11:: 64 static 32
[DeviceA-segment-routing-ipv6-locator-aaa] quit
[DeviceA-segment-routing-ipv6] quit
# Configure IPv6 IS-IS TI-LFA FRR.
[DeviceA] isis 1
[DeviceA-isis-1-ipv6] fast-reroute lfa
[DeviceA-isis-1-ipv6] fast-reroute ti-lfa
# Apply the locator to the IPv6 IS-IS process.
[DeviceA-isis-1-ipv6] segment-routing ipv6 locator aaa
3.     Configure Device B:
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] address-family ipv6
[DeviceB-isis-1-ipv6] quit
[DeviceB-isis-1] quit
[DeviceB] interface gigabitethernet 1/0
[DeviceB-GigabitEthernet1/0] isis ipv6 enable 1
[DeviceB-GigabitEthernet1/0] isis cost 10
[DeviceB-GigabitEthernet1/0] quit
[DeviceB] interface gigabitethernet 2/0
[DeviceB-GigabitEthernet2/0] isis ipv6 enable 1
[DeviceB-GigabitEthernet2/0] isis cost 10
[DeviceB-GigabitEthernet2/0] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis ipv6 enable 1
[DeviceB-LoopBack1] quit
[DeviceB] segment-routing ipv6
[DeviceB-segment-routing-ipv6] locator bbb ipv6-prefix 22:: 64 static 32
[DeviceB-segment-routing-ipv6-locator-bbb] quit
[DeviceB-segment-routing-ipv6] quit
[DeviceB] isis 1
[DeviceB-isis-1-ipv6] fast-reroute lfa
[DeviceB-isis-1-ipv6] fast-reroute ti-lfa
[DeviceB-isis-1-ipv6] segment-routing ipv6 locator bbb
4.     Configure Device C:
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] address-family ipv6
[DeviceC-isis-1-ipv6] quit
[DeviceC-isis-1] quit
[DeviceC] interface gigabitethernet 1/0
[DeviceC-GigabitEthernet1/0] isis ipv6 enable 1
[DeviceC-GigabitEthernet1/0] isis cost 100
[DeviceC-GigabitEthernet1/0] quit
[DeviceC] interface gigabitethernet 2/0
[DeviceC-GigabitEthernet2/0] isis ipv6 enable 1
[DeviceC-GigabitEthernet2/0] isis cost 10
[DeviceC-GigabitEthernet2/0] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis ipv6 enable 1
[DeviceC-LoopBack1] quit
[DeviceC] segment-routing ipv6
[DeviceC-segment-routing-ipv6] locator ccc ipv6-prefix 33:: 64 static 32
[DeviceC-segment-routing-ipv6-locator-ccc] quit
[DeviceC-segment-routing-ipv6] quit
[DeviceC] isis 1
[DeviceC-isis-1-ipv6] fast-reroute lfa
[DeviceC-isis-1-ipv6] fast-reroute ti-lfa
[DeviceC-isis-1-ipv6] segment-routing ipv6 locator ccc
5.     Configure Device D:
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] address-family ipv6
[DeviceD-isis-1-ipv6] quit
[DeviceD-isis-1] quit
[DeviceD] interface gigabitethernet 1/0
[DeviceD-GigabitEthernet1/0] isis ipv6 enable 1
[DeviceD-GigabitEthernet1/0] isis cost 100
[DeviceD-GigabitEthernet1/0] quit
[DeviceD] interface gigabitethernet 2/0
[DeviceD-GigabitEthernet2/0] isis ipv6 enable 1
[DeviceD-GigabitEthernet2/0] isis cost 10
[DeviceD-GigabitEthernet2/0] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] isis ipv6 enable 1
[DeviceD-LoopBack1] quit
[DeviceD] segment-routing ipv6
[DeviceD-segment-routing-ipv6] locator ddd ipv6-prefix 44:: 64 static 32
[DeviceD-segment-routing-ipv6-locator-ddd] quit
[DeviceD-segment-routing-ipv6] quit
[DeviceD] isis 1
[DeviceD-isis-1-ipv6] fast-reroute lfa
[DeviceD-isis-1-ipv6] fast-reroute ti-lfa
[DeviceD-isis-1-ipv6] segment-routing ipv6 locator ddd
# Display IPv6 IS-IS routing information for 3::3/128.
[DeviceA] display isis route ipv6 3::3 128 verbose
                         Level-1 IPv6 forwarding table
 IPv6 dest   : 3::3/128
 Flag        : R/L/-                       Cost        : 20
 Admin tag   : -                           Src count   : 2
 Nexthop     : FE80::4449:7CFF:FEE0:206
 Interface   : GE1/0
 TI-LFA:
  Interface : GE2/0
  BkNextHop : FE80::4449:91FF:FE42:407
  LsIndex    : 0x80000001
  Backup label stack(top->bottom): {44::1:0:1}
 Nib ID      : 0x24000006
The output shows TI-LFA backup next hop information.
