06-Layer 3—IP Services Configuration Guide
HomeSupportNFVH3C VSRConfigure & DeployConfiguration GuidesH3C VSR Series Virtual Services Routers Configuration Guides(V7)-R1362-6W10106-Layer 3—IP Services Configuration Guide
07-IP forwarding basics configuration
07-IP forwarding basics configuration 113.95 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Enabling last hop holding················································································································ 1
Enabling last hop backup················································································································ 3
Enabling the DSCP setting for packets····························································································· 3
Enabling the FIB-based EXP setting for MPLS packets····································································· 4
Enabling IPv4 packet forwarding on an interface with no IPv4 address configured······························ 4
Enabling IPv6 packet forwarding on an interface with no IPv6 address configured······························ 4
Display and maintenance commands for FIB table············································································ 5
Configuring load sharing··················································································· 6
About load sharing·························································································································· 6
Configuring load sharing mode········································································································ 6
Enabling local-first load sharing······································································································· 6
Loading sharing configuration examples··························································································· 7
Example: Configuring load sharing based on source and destination addresses·························· 7
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Layer 3—IP Routing Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Route destination count: 4
Directly-connected host count: 4
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
10.2.0.0/16        10.2.1.1        U        GE1/0                    Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
Last hop holding implements symmetric routing.
When the interface enabled with this feature receives the first IP packet of a forward flow, this feature implements the following operations:
·     Obtains the forward flow information and last hop information of the packet.
·     Based on the obtained information, creates a fast forwarding entry for the return flow.
When packets of the return flow arrive at the device, the device forwards those packets according to the entry.
As is shown in Figure 1, when the external server sends a request to the internal server, the packet travels through ISP 1 to Interface A on the device. The last hop holding feature on the device ensures that the reply packet follows the same route as the request packet back to ISP 1. If last hop holding is disabled, the reply packet might be sent out of Interface B or Interface C to the external network.
Figure 1 Last hop holding application
This feature relies on fast forwarding entries. If the MAC address of a last hop changes on an Ethernet link, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
This feature is not applicable to an MPLS network.
In an IRF fabric, this feature is not supported for those packets that are forwarded between member devices.
This feature is not applicable to asymmetric-path traffic forwarding in an RBM-based hot backup system. For more information about RBM-based hot backup, see high availability group configuration in High Availability Configuration Guide.
On a device that supports deployment of multiple security service modules, this feature does not take effect on the external traffic destined for that device.
2.     Enter Layer 3 Ethernet interface view or subinterface view.
3.     Enable last hop holding.
ip last-hop hold
By default, last hop holding is disabled.
This feature enables the system to transmit the forward flow and return flow between the local device and a peer device over the same path in an IRF fabric.
With this feature configured, the IRF master device performs the following operations when receiving the first IP packet of a forward flow on an interface enabled with last hop holding:
1.     Saves the last hop information of the packet.
2.     Synchronizes the last hop information to subordinate devices in the IRF fabric.
The last hop information can be used for guiding the return flow when the flow arrives at the master device or is forwarded through a subordinate device.
This feature takes effect only when the session synchronization is enabled by using the session synchronization enable command. For more information about this command, see Security Command Reference.
This feature is also applicable to multi-module devices enabled with service backup. If this feature is enabled on such a device, a device module performs the following operations when receiving the first IP packet of a forward flow on an interface enabled with last hop holding:
2.     Synchronizes the last hop information to other modules in the device.
The last hop information can be used for guiding the backward flow when the flow arrives at one of these modules.
For this feature to take effect on a multi-module device, you must also enable session flow redirection by using the session flow-redirect enable command. For more information about the session flow-redirect enable command, see Security Command Reference.
2.     Enable last hop backup.
last-hop backup enable
By default, last hop backup is enabled.
This feature enables the device to use the DSCP value in the FIB table for packets to be forwarded. The DSCP value in FIB table is set along with the routing information.
This command must be used together with the apply dscp command. For more information about the command, see routing policy commands in Layer 3—IP Routing Command Reference.
2.     Enable the DSCP setting for packets.
ip forwarding apply dscp enable
By default, the DSCP setting for packets is disabled.
This feature modifies the EXP field value of MPLS packets based on the EXP value in the FIB entry that matches the packets. It must be used together with the apply mpls-exp command. For more information about the apply mpls-exp command, see routing policy commands in Layer 3—IP Routing Command Reference.
2.     Enable the FIB-based EXP setting for MPLS packets.
ip forwarding apply mpls-exp enable
By default, the FIB-based EXP setting for MPLS packets is disabled.
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To solve this problem, enable this feature on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
You can configure this feature in any view in which an IPv4 address can be configured.
2.     Enter interface view.
3.     Enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
By default, IPv4 packet forwarding is disabled on an interface that has no IPv4 address configured.
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv6 address configured, the interface cannot forward the IPv6 packet. To solve this problem, enable this feature on the interface. This feature allows the interface to forward IPv6 packets even though the interface has no IPv6 address configured.
You can configure this feature in any view in which an IPv6 address can be configured.
3.     Enable IPv6 packet forwarding on an interface that has no IPv6 address configured.
ipv6 forwarding
By default, IPv6 packet forwarding is disabled on an interface that has no IPv4 address configured.
Display FIB entries.
display fib [ topology topology-name | vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
About load sharing
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. You can configure the device to identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
In the per-packet load sharing mode, the device forwards packets over equal-cost routes.
Per-packet load sharing does not take effect on packets that are fast forwarded. It takes effect only on those packets that are delivered to the CPU. For more information about configuring load balancing for fast forwarding, see fast forwarding configuration in Layer 3IP Services Configuration Guide.
2.     Configure load sharing.
In standalone mode:
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * ] | per-packet } global
In IRF mode:
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * ] | per-packet } { global | slot slot-number }
By default, the device performs per-flow load sharing.
Local-first load sharing distributes traffic preferentially across the output interfaces on the receiving IRF member device if output interfaces for multiple equal-cost routes are on different members. This feature enhances packets forwarding efficiency.
2.     Enable local-first load sharing.
ip load-sharing local-first enable
By default, local-first load sharing is enabled.
As shown in Figure 2, Switch A has two equal-cost routes to Switch B. Configure load sharing on Switch A to forward packets through Switch B to the destination IP address 1.2.3.4/24.
Figure 2 Network diagram
# On Switch A, assign GigabitEthernet 1/0 to VLAN 10, and GigabitEthernet 2/0 to VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 2/0
[SwitchA-vlan20] quit
# On Switch A, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# On Switch B, assign GigabitEthernet 1/0 to VLAN 10, and GigabitEthernet 2/0 to VLAN 20.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] port gigabitethernet 2/0
[SwitchB-vlan20] quit
# On Switch B, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchB-Vlan-interface10] ip address 10.1.1.2 24
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] ip address 20.1.1.2 24
[SwitchB-Vlan-interface20] quit
# On Switch A, configure two static routes to the destination IP address.
[SwitchA] ip route-static 1.2.3.4 24 10.1.1.2
[SwitchA] ip route-static 1.2.3.4 24 20.1.1.2
[SwitchA] quit
# On Switch A, display FIB entries matching the destination IP address 1.2.3.4.
<SwitchA> display fib 1.2.3.4
Destination count: 1 FIB entry count: 2
Flag:
  R:Relay     F:FRR
1.2.3.0/24         10.1.1.2        USGR     Vlan10                   Null
1.2.3.0/24         20.1.1.2        USGR     Vlan20                   Null
# On Switch A, configure per-flow load sharing based on the source IP address and destination IP address.
[SwitchA] ip load-sharing mode per-flow dest-ip src-ip global
# Verify that Switch A implements load sharing.
<SwitchA> display counters outbound interface GigabitEthernet
Interface         Total (pkts)   Broadcast (pkts)   Multicast (pkts)  Err (pkts)
GE1/0                  1045                  0                  0           0
GE2/0                  1044                  0                  0           0
