04-Layer 3—IP Services Command Reference
HomeSupportSwitchesS5560X-EI SeriesReference GuidesCommand ReferencesH3C S5560X-EI&S5500V2-EI&MS4520V2&ES5500 Command References-R68xx-6W10004-Layer 3—IP Services Command Reference
11-IP performance optimization commands
11-IP performance optimization commands 371.91 KB
display icmp statistics
Use display icmp statistics to display ICMP statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays ICMP statistics for all member devices.
ICMP statistics include information about received and sent ICMP packets.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          175                 destination unreachable 0
         source quench 0                   redirects               0
         echo replies  201                 parameter problem       0
         timestamp     0                   information requests    0
         mask requests 0                   mask replies            0
         time exceeded 0                   invalid type            0
         router advert 0                   router solicit          0
         broadcast/multicast echo requests ignored            0
         broadcast/multicast timestamp requests ignored       0
 Output: echo          0                   destination unreachable 0
         echo replies  175                 parameter problem       0
         timestamp     0                   information replies     0
         time exceeded 0                   bad address             0
         packet error  1442                router advert           3
bad formats
Number of received messages with error format.
bad checksum
Number of received messages with checksum errors.
echo
Number of received or sent ICMP echo request messages.
Number of received or sent destination unreachable messages.
source quench
Number of received or sent source quench messages.
redirects
Number of received or sent redirect messages.
echo replies
Number of received or sent echo reply messages.
parameter problem
Number of received or sent parameter problem messages.
timestamp
Number of received timestamp request messages or number of sent timestamp reply messages.
Number of received information request messages.
mask requests
Number of received or sent mask request messages.
mask replies
Number of received or sent mask reply messages.
invalid type
Number of received messages with invalid type.
router solicit
Number of received RS messages.
Number of dropped incoming broadcast or multicast echo request messages.
Number of dropped incoming broadcast or multicast timestamp request messages.
information replies
Number of sent information reply messages.
time exceeded
Number of received or send ICMP time exceeded messages
bad address
Number of sent messages with invalid destination addresses.
packet error
Number of sent error messages.
router advert
Number of received or sent RA messages.
display ip statistics
Use display ip statistics to display IP packet statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IP packet statistics for all member devices.
IP statistics include information about received and sent packets, fragments, and reassembly.
# Display IP packet statistics.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Input
Statistics about received packets:
·     sum—Total number of packets received.
·     local—Total number of packets destined for the device.
·     bad protocol—Total number of unknown protocol packets.
·     bad format—Total number of packets with incorrect format.
·     bad checksum—Total number of packets with incorrect checksum.
·     bad options—Total number of packets with incorrect option.
Output
Statistics about sent packets:
·     forwarding—Total number of packets forwarded.
·     local—Total number of packets locally sent.
·     dropped—Total number of packets discarded.
·     no route—Total number of packets for which no route is available.
·     compress fails—Total number of packets failed to be compressed.
Fragment
Statistics about fragments:
·     input—Total number of fragments received.
·     output—Total number of fragments sent.
·     dropped—Total number of fragments dropped.
·     fragmented—Total number of packets successfully fragmented.
·     couldn't fragment—Total number of packets failed to be fragmented.
Reassembling
Statistics about reassembly:
·     sum—Total number of packets reassembled.
·     timeouts—Total number of reassembly timeouts.
display ip interface
reset ip statistics
statistics l3-packet enable
display rawip
Use display rawip to display brief information about RawIP connections.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays brief information about RawIP connections for all member devices.
Brief RawIP connection information includes local and peer addresses, protocol, and PCB.
# Display brief information about RawIP connections.
<Sysname> display rawip
 Local Addr       Foreign Addr     Protocol  Slot   PCB
 0.0.0.0          0.0.0.0          1         1      0x0000000000000009
 0.0.0.0          0.0.0.0          1         1      0x0000000000000008
Local Addr
Local IP address.
Foreign Addr
Peer IP address.
Protocol
Protocol number.
PCB
Protocol control block.
display rawip verbose
Use display rawip verbose to display detailed information about RawIP connections.
display rawip verbose [ slot slot-number [ pcb pcb-index ] ]
pcb pcb-index: Displays detailed RawIP connection information for the specified PCB. The pcb-index argument specifies the index of the PCB. The index value range is 1 to 16..
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays detailed information about RawIP connections for all member devices.
The detailed information includes socket creator, state, option, type, protocol number, and the source and destination IP addresses of RawIP connections.
# Display detailed information about RawIP connections.
<Sysname> display rawip verbose
Total RawIP socket number: 1
 Connection info: src = 0.0.0.0, dst = 0.0.0.0
 Creator: ping[320]
 State: N/A
 Options: N/A
 Error: 0
 Type: 3
 Protocol: 1
 Inpcb flags: N/A
 Inpcb extflag: INP_EXTRCVICMPERR INP_EXTFILTER
 Inpcb vflag: INP_IPV4
 TTL: 255(minimum TTL: 0)
 Send VRF: 0xffff
 Receive VRF: 0xffff
Total number of RawIP sockets.
Connection info
Connection information, including source IP address and destination IP address.
Location
Socket location.
Creator
Name of the operation that created the socket. The number in brackets is the process number of the creator.
Socket state:
·     NOFDREF—The user has closed the connection.
·     ISCONNECTED—The connection has been established.
·     ISCONNECTING—The connection is being established.
·     ISDISCONNECTING—The connection is being interrupted.
·     ASYNC—Asynchronous mode.
·     ISDISCONNECTED—The connection has been terminated.
·     ISSMOOTHING—Cross-card data smoothing is in progress.
·     CANBIND—The socket supports the bind operation.
·     PROTOREF—Indicates strong protocol reference.
·     ISPCBSYNCING—Cross-card PCB synchronization is in progress.
·     N/A—None of above state.
Options
Socket options:
·     SO_DEBUG—Records socket debugging information.
·     SO_ACCEPTCONN—Enables the server to listen connection requests.
·     SO_REUSEADDR—Allows the local address reuse.
·     SO_KEEPALIVE—Requires the protocol to test whether the connection is still alive.
·     SO_DONTROUTE—Bypasses the routing table query for outgoing packets because the destination is in a directly connected network.
·     SO_BROADCAST—Supports broadcast packets.
·     SO_LINGER—Closes the socket. The system can still send remaining data in the socket send buffer.
·     SO_OOBINLINE—Stores the out-of-band data in the input queue.
·     SO_REUSEPORT—Allows the local port reuse.
·     SO_TIMESTAMP—Records the timestamps of the incoming packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
·     SO_NOSIGPIPE—Disables the socket from sending data. As a result, a sigpipe cannot be established when a return failure occurs.
·     SO_FILTER—Supports setting the packet filter criterion. This option takes effect on the incoming packets.
·     SO_TIMESTAMPNS—Has a similar function with the timestamp, accurate to nanoseconds.
·     SO_SEQPACKET—Preserves the boundaries of packets sent to the socket buffer.
·     SO_FILLTWAMPTIME—Sets the timestamp for TWAMP.
·     SO_LOCAL—Local socket option.
·     SO_NBMAADDR—Obtains the remote NBMA address of the ADVPN tunnel.
·     SO_DONTDELIVER—Do not deliver the data to the application.
·     SO_UCM—Sets the IPoE enabling status. ‌
·     SO_RAWSLOT—Raw slot.
·     SO_LEASEDUSERID—Obtains a usable lease.
·     N/A—No options are set.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/drop/state)
Displays receive buffer information in the following order:
·     cc—Used space.
·     hiwat—Maximum space.
·     lowat—Minimum space.
·     drop—Number of dropped packets.
·     state—Buffer state:
¡     CANTSENDMORE—Unable to send data to the peer.
¡     CANTRCVMORE—Unable to receive data from the peer.
¡     CANTREDUCESIZE—Unable to shorten the receiving buffer.
¡     RCVATMARK—Receiving tag.
¡     N/A—None of the above states.
Sending buffer (cc/hiwat/lowat/state)
Displays send buffer information in the following order:
·     cc—Used space.
Socket type:
·     1SOCK_STREAM. This socket uses TCP to provide reliable transmission of byte streams.
·     2SOCK_DGRAM. This socket uses UDP to provide datagram transmission.
·     3SOCK_RAW. This socket allows an application to change the next upper-layer protocol header.
·     N/A—None of the above types.
Protocol
Number of the protocol using the socket.
Inpcb flags
Flags in the Internet PCB:
·     INP_RECVOPTS—Receives IP options.
·     INP_RECVRETOPTS—Receives replied IP options.
·     INP_RECVDSTADDR—Receives destination IP address.
·     INP_HDRINCL—Provides the entire IP header.
·     INP_REUSEADDR—Reuses the IP address.
·     INP_REUSEPORT—Reuses the port number.
·     INP_ANONPORT—Port number not specified.
·     INP_RECVIF—Records the input interface of the packet.
·     INP_RECVTTL—Receives TTL of the packet. Only UDP and RawIP support this flag.
·     INP_DONTFRAG—Sets the Don't Fragment flag.
·     INP_ROUTER_ALERT—Receives packets with the router alert option. Only RawIP supports this flag.
·     INP_PROTOCOL_PACKET—Identifies a protocol packet.
·     INP_RCVVLANID—Receives the VLAN ID of the packet. Only UDP and RawIP support this flag.
·     INP_RCVMACADDR—Receives the MAC address of the frame.
·     INP_RECVTOS—Receives TOS of the packet. Only UDP and RawIP support this flag.
·     INP_USEICMPSRC—Uses the specified IP address as the source IP address for outgoing ICMP packets.
·     INP_SYNCPCB—Waits until Internet PCB is synchronized.
·     INP_LOCAL—Preferentially matches the INPCB with this flag on the same card.
·     N/A—None of the above flags.
Inpcb extflag
Extension flags in the Internet PCB:
·     INP_EXTRCVPVCIDX—Records the PVC index of the received packet.
·     INP_RCVPWID—Records the PW ID of the received packet.
·     INP_EXTRCVICMPERR—Receives an ICMP error packet.
·     INP_EXTFILTER—Filters the contents in the received packet.
·     INP_EXTDONTDROP—Do not drop the received packet.
·     INP_EXLISTEN—Adds the INPCB carrying this flag to the listen hash table.
·     INP_SELECTMATCHSRCBYFIB—Uses the FIB table to select a matching source.
·     INP_EXTPRIVATESOCKET—Associates the INPCB with the NSR private socket.
·     INP_EXTNOCACHEPKT—Do not cache packets.
·     INP_EXTRCVVLANDOT1P—Obtains the Dot1p value of the VLAN tag in the received packet.
·     INP_EXTSNDDATAIF—Sets the output interface of data.
·     INP_EXTFREEBIND—The socket is not bound to an address or port.
·     INP_EXTRCVUPID—Obtains the UP ID from the received packet in the UCM control-/user-plane separated (CUPS) network.
·     INP_EXTINNERPROXY—Receives packets forwarded by the proxy.
·     INP_EXLISTENNET—Sets this flag when the connection information is added to the network segment linked list.
Inpcb vflag
IP version flags in the Internet PCB:
·     INP_IPV4—IPv4 protocol.
·     INP_TIMEWAIT—In TIMEWAIT state.
·     INP_ONESBCAST—Sends broadcast packets.
·     INP_DROPPED—Protocol dropped flag.
·     INP_SOCKREF—Strong socket reference.
·     INP_DONTBLOCK—Do not block synchronization of the Internet PCB.
TTL
TTL value in the Internet PCB.
Send VRF
VRF from which packets are sent.
Receive VRF
VRF from which packets are received.
display tcp
Use display tcp to display brief information about TCP connections.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays brief information about TCP connections for all member devices.
Brief TCP connection information includes local IP address, local port number, peer IP address, peer port number, and TCP connection state.
# Display brief information about TCP connections.
<Sysname> display tcp
 *: TCP connection with authentication
 Local Addr:port       Foreign Addr:port     State       Slot  PCB
*0.0.0.0:21            0.0.0.0:0             LISTEN      1     0x000000000000c387
 192.168.20.200:23     192.168.20.14:1284    ESTABLISHED 1     0x0000000000000009
 192.168.20.200:23     192.168.20.14:1283    ESTABLISHED 1     0x0000000000000002
Table 5 Command output
Indicates that the TCP connection uses authentication.
Local Addr:port
Local IP address and port number.
Foreign Addr:port
Peer IP address and port number.
TCP connection state:
·     CLOSED—The server receives a disconnection request's reply from the client.
·     LISTEN—The server is waiting for connection requests.
·     SYN_SENT—The client is waiting for the server to reply to the connection request.
·     SYN_RCVD—The server receives a connection request.
·     ESTABLISHED—The server and client have established connections and can transmit data bidirectionally.
·     CLOSE_WAIT—The server receives a disconnection request from the client.
·     FIN_WAIT_1—The client is waiting for the server to reply to a disconnection request.
·     CLOSING—The server and client are waiting for peer's disconnection reply when receiving disconnection requests from each other.
·     LAST_ACK—The server is waiting for the client to reply to a disconnection request.
·     FIN_WAIT_2—The client receives a disconnection reply from the server.
·     TIME_WAIT—The client receives a disconnection request from the server.
PCB
PCB index.
display tcp statistics
Use display tcp statistics to display TCP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays TCP traffic statistics for all member devices.
TCP traffic statistics include information about received and sent TCP packets and Syncache/syncookie.
# Display TCP traffic statistics.
<Sysname> display tcp statistics
Received packets:
    Total: 4150
    packets in sequence: 1366 (134675 bytes)
    window probe packets: 0, window update packets: 0
    checksum error: 0, offset error: 0, short error: 0
    packets dropped for lack of memory: 0
    packets dropped due to PAWS: 0
    duplicate packets: 12 (36 bytes), partially duplicate packets: 0 (0 bytes)
    out-of-order packets: 0 (0 bytes)
    packets with data after window: 0 (0 bytes)
    packets after close: 0
    ACK packets: 3531 (795048 bytes)
    duplicate ACK packets: 33, ACK packets for unsent data: 0
Sent packets:
    Total: 4058
    urgent packets: 0
    control packets: 50
    window probe packets: 3, window update packets: 11
    data packets: 3862 (795012 bytes), data packets retransmitted: 0 (0 bytes)
    ACK-only packets: 150 (52 delayed)
    unnecessary packet retransmissions: 0
Syncache/syncookie related statistics:
    entries added to syncache: 12
    syncache entries retransmitted: 0
    duplicate SYN packets: 0
    reply failures: 0
    successfully build new socket: 12
    bucket overflows: 0
    zone failures: 0
    syncache entries removed due to RST: 0
    syncache entries removed due to timed out: 0
    ACK checked by syncache or syncookie failures: 0
    syncache entries aborted: 0
    syncache entries removed due to bad ACK: 0
    syncache entries removed due to ICMP unreachable: 0
    SYN cookies sent: 0
    SYN cookies received: 0
SACK related statistics:
    SACK recoveries: 1
    SACK retransmitted segments: 0 (0 bytes)
    SACK blocks (options) received: 0
    SACK blocks (options) sent: 0
    SACK scoreboard overflows: 0
Other statistics:
    retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
    persist timeout: 0
    keepalive timeout: 21, keepalive probe: 0
    keepalive timeout, so connections disconnected: 0
    fin_wait_2 timeout, so connections disconnected: 0
    initiated connections: 29, accepted connections: 12, established connections:
23
    closed connections: 50051 (dropped: 0, initiated dropped: 0)
    bad connection attempt: 0
    ignored RSTs in the window: 0
    listen queue overflows: 0
    RTT updates: 3518(attempt segment: 3537)
    correct ACK header predictions: 0
    correct data packet header predictions: 568
    resends due to MTU discovery: 0
    packets dropped due to MD5 authentication failure: 0
    packets that passed MD5 authentication: 0
    sent Keychain-encrypted packets: 0
    packets that passed Keychain authentication: 0
    packets dropped due to Keychain authentication failure: 0
reset tcp statistics
display tcp verbose
Use display tcp verbose to display detailed information about TCP connections.
pcb pcb-index: Displays detailed TCP connection information for the specified PCB. The index range is 1 to 16.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays detailed information about TCP connections for all member devices.
The detailed TCP connection information includes socket creator, state, option, type, protocol number, source IP address and port number, destination IP address and port number, and connection state.
# Display detailed information about TCP connections.
<Sysname> display tcp verbose
 Connection info: src = 192.168.20.200:179 ,  dst = 192.168.20.14:4181
 NSR standby: N/A
 Creator: ping[320]
 State: ISCONNECTED
 Options: N/A
 Error: 0
 Receiving buffer(cc/hiwat/lowat/state): 0 / 65700 / 1 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 65700 / 512 / N/A
 Type: 1
 Protocol: 6
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Connection state: ESTABLISHED
 NSR state: READY(M)
 Send VRF: 0x0
 Receive VRF: 0x0
 Error count in abnormal-packet-defend period: 0
 Checksum errors: 0
 Duplicate packets: 0
 Part-Duplicate packets: 0
 Out-of-order packets: 0
 Duplicate ACK packets: 0
 Out-of-order ACK packets: 0
 Packets with data out of window: 0
 MD5 authentication errors: 0
 Keychain authentication errors: 0
 Timestamp errors: 0
Maximum Segment Size (MSS): 512
 Window Scale (wscale): 0
 Retransmission Timeout (rto): 3000000.0ms
 Retransmission Count/Total: 0/0
 Round-trip Time (rtt/rtvar): 0.0ms/12000000.0ms
 Delayed Ack Timeout (ato): 100000.0ms
 Congestion Window (cwnd): 1073725440
 TCP Throughput: 0.00 Mbps
 sendpps/sendkbps/recvpps/recvkbps/: 0/0.000/0/0.000
 iss/unack/next/max/wnd: 0/0/0/0/0
 irs/undeliver/next/adv/wnd: 0/0/0/0/0
 NSR Info:
 Total Recv/Send Count(history Recv/history Send): 41/43(41/43)
 EnableMsg Recv/Send Count(history Recv/history Send): 1/2(1/2)
 DisableMsg Recv/Send Count(history Recv/history Send): 0/1(0/1)
 SlotchangeMsg Recv/Send Count(history Recv/history Send): 0/1(0/1)
 ReadyMsg Recv/Send Count(history Recv/history Send): 2/1(2/1)
 PullMsg Recv/Send Count(history Recv/history Send): 2/1(2/1)
 BriefdataMsg Recv/Send Count(history Recv/history Send): 1/2(1/2)
 PktMsg Recv/Send Count(history Recv/history Send): 35/35(35/35)
 CmdMsg Recv/Send Count(history Recv/history Send): 0/0(0/0)
 Recent Recv/Send Seq: 41/43
 Recent Recv/Send Time: 11:14:44:469624 May 23 2022/11:14:44:467624 May 23 2022
 Option Value:
 rcvsb_timeo/sndsb_timeo/pd_type/pd_len: 0/0/0/0
 so_linger: 1
 ka_idle/ka_intval/ka_count: 0/0/0
 so_accept_filter_str: filter1
 Md5 Password:123
 Tcp Key Chain: key123
 Out Interface/NextHop/Local Address: 0/0.0.0.0/0.0.0.0
 Filter Offset/Length/Value/Mask: 0/0/00 00 00 00 00 00 00 00 /00 00 0 00 00 00 00 00
 Ip Tos/McastTTL/McastLoop/ Mcast Interface Index: 192/0/0/0
 Acl Index/MacIndex: 4294967295/4294967295
 Mpls Flag/Label: 0/4294967295
 Kernel Event ID: 0
 Send Mac: 0000-0000-0000
 Bier TTL/Entropy/TunnelID: 0/0/0
Ip Option Hdr: 0x01 02 03
Table 6 Command output
TCP inpcb number
Number of TCP IP PCBs.
Connection info
Connection information, including source IP address, source port number, destination IP address, and destination port number.
Location
Socket location.
NSR standby
IRF member ID and slot number where the NSR standby resides. If no NSR standby exists, this field displays N/A.
tcpcb number
Number of TCP PCBs. This field is not displayed if the state of the TCP connection is TIME_WAIT.
Creator
Socket state:
Options
Socket options:
·     SO_KEEPALIVETIME—Sets a keepalive time.
·     SO_USCBINDEX—Obtains the user profile index from the received packets.
Error
Error code.
Receiving buffer (cc/hiwat/lowat/state)
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb extflag
·     INP_EXTDONTDROP—Does not drop the received packet.
·     INP_EXTFILTER—Filters the contents in the received packets.
Inpcb vflag
TTL
Connection state
TCP options
TCP options:
·     TF_DELACK—Delays sending ACK packets.
·     TF_SENTFIN—A FIN packet has been sent.
·     TF_RCVD_SCALE—Requests the receive window size scale factor.
·     TF_RCVD_TSTMP—A timestamp was received in the SYN packet.
·     TF_NEEDSYN—Sends a SYN packet.
·     TF_NEEDFIN—Sends a FIN packet.
·     TF_MORETOCOME—More data is to be added to the socket.
·     TF_LQ_OVERFLOW—The listening queue overflows.
·     TF_LASTIDLE—Idle connection.
·     TF_RXWIN0SENT—A reply with receive window size 0 was sent.
·     TF_FASTRECOVERY—Enters NewReno fast recovery mode.
·     TF_WASFRECOVERY—In NewReno fast recovery mode.
·     TF_SIGNATURE—MD5 signature.
·     TF_FORCEDATA—Forces to send one byte.
·     TF_TSO—TSO is enabled.
·     TF_PMTU—Supports RFC 1191.
·     TF_PMTUD—Starts Path MTU discovery.
·     TF_PASSIVE_CONN—Passive connection.
·     TF_APP_SEND—The application sends data.
·     TF_NODELAY—Disables the Nagle algorithm that buffers the sent data inside the TCP.
·     TF_NOOPT—No TCP options.
·     TF_NOPUSH—Forces TCP to delay sending any TCP data until a full sized segment is buffered in the TCP buffers.
·     TF_NSR—Enables TCP NSR.
·     TF_REQ_SCALE—Enables the TCP window scale option.
·     TF_REQ_TSTMP—Enables the time stamp option.
·     TF_SACK_PERMIT—Enables the TCP selective acknowledgement option.
·     TF_ENHANCED_AUTH—Enables the enhanced authentication option.
NSR state
NSR state of the TCP connection:
·     CLOSED—Closed (initial) state.
·     CLOSING—The connection is to be closed.
·     ENABLED—The connection backup is enabled.
·     OPEN—The connection synchronization has started.
·     PENDING—The connection backup is not ready.
·     READY—The connection backup is ready.
·     SMOOTH—The connection data is being smoothed.
Between the parentheses is the role of the connection:
·     M—Main connection.
·     S—Standby connection.
Send VRF
Receive VRF
Number of error packets received in one abnormal-packet-defend period if attack prevention is enabled for TCP connections.
Checksum errors
Number of received packets with checksum errors.
Duplicate packets
Number of received duplicate packets.
Number of received partially duplicate packets.
Number of received out-of-order packets.
Number of received duplicate ACK packets.
Number of received out-of-order ACK packets.
Number of received packets whose serial number is out of the sliding window range.
Number of packets with failed MD5 authentication.
Number of packets with failed Keychain authentication.
Timestamp errors
Number of packets with timestamp errors.
Maximum segment size.
Window scale.
Retransmission timeout in milliseconds.
Current number retransmissions/total number of retransmissions.
Average round-trip time in milliseconds.
Delayed acknowledgement timeout in milliseconds.
Sequence number of the packet at the congestion window.
TCP Throughput
TCP throughput in Mbps.
sendpps/sendbps/recvpps/recvbps
·     sendpps—Number of packets sent per second.
·     sendbps—Bytes sent per second.
·     recvpps—Number of packets received per second.
·     recvbps—Bytes received per second.
Iss/unack/next/max/wnd
·     Iss—Local initial sequence number.
·     unack—Sequence number of sent packet that has not been acknowledged.
·     next—Sequence number for next sending.
·     max—Maximum sequence number for sending.
·     wnd—Sequence number of the packet at the sending window.
Irs/undeliver/next/adv/wnd
·     Irs—Peer initial sequence number.
·     undeliver—Sequence number of the packet that has not been reported.
·     adv—Size of the receiving buffer.
·     wnd—Sequence number of the packet at the notification receiving window.
Total number of received/sent packets through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent EnableMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent DisableMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent SlotchangeMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent ReadyMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent PullMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent BriefdataMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent PktMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent CmdMsg messages through the LIPC connection between TCP NSR active and standby connections.
Number of received/sent history messages through the LIPC connection between TCP NSR active and standby connections.
Sequence number of the message received/sent most recently between TCP NSR active and standby connections.
Absolute time of the most recent message receiving/sending between TCP NSR active and standby connections.
·     rcvsb_timeo—Socket receiving buffer timeout.
·     sndsb_timeo—Socket sending buffer timeout in jiffies.
·     pd_type—Socket private data type.
·     pd_len—Socket private data length in bytes.
so_linger
Socket linger value.
ka_idle/ka_interval/ka_cout
·     ka_idle—Socket keepalive idle timeout.
·     ka_interval—Socket keepalive interval.
·     ka_cout—Socket keepalive count.
Name of the socket packet receiving filter.
Md5 Password
TCP MD5 password.
Tcp Key Chain
TCP keychain name.
·     Out Interface—Outgoing interface.
·     NextHop.
·     Local Address.
Pcb filter offset, length, value, and mask.
Ip Tos/McastTTL/McastLoop/Mcast Interface Index:
·     Ip Tos—IP TOS value.
·     McastTTL—Multicast TTL.
·     McastLoop—Multicast loop.
·     Mcast Interface Index—Multicast interface index.
Acl Index/MacIndex
·     Acl Index—ACL filtering parameters.
·     MacIndex—Layer 2 ACL parameters.
Mpls Flag/Label
‌MPLS flag and MPLS label.
Send Mac
Peer MAC address specified for packet sending of upper-layer applications.
·     Bier TTL.
·     Entropy—BIER grouping flag.
·     TunnelID—BIER tunnel ID.
Ip Option Hdr
IP options required in a TCP packet.
display udp
Use display udp to display brief information about UDP connections.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays brief information about UDP connections for all member devices.
Brief UDP connection information includes local IP address and port number, and peer IP address and port number.
# Display brief information about UDP connections.
<Sysname> display udp
 Local Addr:port        Foreign Addr:port     Slot  PCB
 0.0.0.0:69             0.0.0.0:0             1     0x0000000000000003
Table 7 Command output
Local Addr:port
Foreign Addr:port
PCB
PCB index.
display udp statistics
Use display udp statistics to display UDP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays UDP traffic statistics for all member devices.
UDP traffic statistics include information about received and sent UDP packets.
# Display UDP traffic statistics.
<Sysname> display udp statistics
Received packets:
     Total: 240
     checksum error: 0, no checksum: 0
     shorter than header: 0, data length larger than packet: 0
     no socket on port(unicast): 0
     no socket on port(broadcast/multicast): 240
     not delivered, input socket full: 0
Sent packets:
     Total: 0
reset udp statistics
display udp verbose
Use display udp verbose to display detailed information about UDP connections.
pcb pcb-index: Displays detailed UDP connection information for the specified PCB. The value range for the pcb-index argument is 1 to 16.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays detailed information about UDP connections for all member devices.
The detailed information includes socket creator, status, option, type, protocol number, source IP address and port number, and destination IP address and port number for UDP connections.
# Display detailed UDP connection information.
<Sysname> display udp verbose
Total UDP socket number: 1
 Connection info: src = 0.0.0.0:69, dst = 0.0.0.0:0
 Creator: sock_test_mips[250]
 State: N/A
 Options: N/A
 Error: 0
 Type: 2
 Protocol: 17
 Inpcb flags: N/A
 Inpcb extflag: N/A
 Send VRF: 0xffff
 Receive VRF: 0xffff
Table 8 Command output
Total number of UDP sockets.
Connection info
Location
Socket location.
Creator
Socket state:
Options
Socket options:
·     SO_OOBINLINE—Stores the out-o-band data in the input queue.
·     SO_TIMESTAMP—Records the timestamps of the input packets, accurate to milliseconds. This option is applicable to protocols that are not connection orientated.
Error
Error code.
·     cc—Used space.
·     cc—Used space.
Socket type:
Protocol
Inpcb flags
Inpcb extflag
Inpcb vflag
TTL
Send VRF
Receive VRF
management-port isolate enable
Use management-port isolate enable to enable IP packet isolation between management port and service port.
Use undo management-port isolate enable to restore the default.
IP packet isolation between management port and service port is disabled.
With this feature enabled, the device discards IP packets received and sent on different types of ports (management or service), for example, packets received on the management port but sent out of the service port. This isolates management IP traffic and service IP traffic from each other, preventing attacks against the management network through the service network.
In scenarios where the management port forwards IP service traffic, do not enable this feature as a best practice.
# Enable IP packet isolation between management port and service port.
[Sysname] management-port isolate enable
ip forward-broadcast
Use ip forward-broadcast to enable an interface to forward directed broadcast packets destined for the directly connected network.
Use undo ip forward-broadcast to disable an interface from forwarding directed broadcast packets destined for the directly connected network.
ip forward-broadcast [ acl acl-number ]
An interface cannot forward directed broadcasts destined for the directly connected network.
Interface view
acl acl-number: Specifies an ACL by its number. The interface forwards only the directed broadcasts permitted by the ACL. The value range for basic ACLs is 2000 to 2999. The value range for advanced ACLs is 3000 to 3999.
A directed broadcast packet is destined for all hosts on a specific network. In the destination IP address of the directed broadcast, the network ID identifies the target network, and the host ID is made up of all ones.
If an interface is allowed to forward directed broadcasts destined for the directly connected network, hackers can exploit this vulnerability to attack the target network. In some scenarios, however, an interface must send such directed broadcast packets to support UDP helper and Wake on LAN.
The command enables the interface to forward directed broadcast packets that are destined for the directly connected network and are received from another subnet to support Wake on LAN. Wake on LAN sends the directed broadcasts to wake up the hosts on the target network.
When you specify an ACL, follow these guidelines:
·     If the specified ACL does not exist or has no rules, the interface cannot forward any directed broadcast packets that are destined for the directly connected network.
·     If a rule in the specified ACL is applied to a VPN instance, the rule takes effect only on VPN packets.
·     If a rule in the specified ACL is not applied to any VPN instance, the rule takes effect only on public-network packets.
# Enable VLAN-interface 2 to forward directed broadcast packets destined for the directly connected network.
[Sysname-Vlan-interface2] ip forward-broadcast
ip icmp broadcast-echo-reply enable
Use ip icmp broadcast-echo-reply enable to enable the device to respond to broadcast echo requests.
Use undo ip icmp broadcast-echo-reply enable to disable the device from responding to broadcast echo requests.
The device responds to broadcast echo requests.
When you use the ping command to ping a broadcast address, all devices that have received the ICMP echo request must respond to the request. Attackers might exploit this mechanism to launch an ICMP flood attack. The victims will respond to ICMP echo requests frequently, which degrades their forwarding performance. To resolve this issue, use this command to disable the device from responding to broadcast echo requests.
You can also disable response to broadcast echo requests in the following scenarios:
·     The device has received too many broadcast packets.
·     The CPU usage of the device is too high.
# Disable response to broadcast echo requests.
[Sysname] undo ip icmp broadcast-echo-reply enable
ip icmp error-interval
Use ip icmp error-interval to set the interval for tokens to arrive in the bucket and the bucket size for ICMP error messages.
Use undo ip icmp error-interval to restore the default.
A token is placed in the bucket every 100 milliseconds, and the bucket allows a maximum of 10 tokens.
interval: Specifies the interval for tokens to arrive in the bucket. The value range is 0 to 2147483647 milliseconds. To disable the ICMP rate limit, set the value to 0.
bucketsize: Specifies the maximum number of tokens allowed in the bucket. The value range is 1 to 200.
This command limits the rate at which ICMP error messages are sent. Use this command to avoid sending excessive ICMP error messages within a short period that might cause network congestion. A token bucket algorithm is used with one token representing one ICMP error message.
A token is placed in the bucket at intervals until the maximum number of tokens that the bucket can hold is reached.
A token is removed from the bucket when an ICMP error message is sent. When the bucket is empty, ICMP error messages are not sent until a new token is placed in the bucket.
# Set the interval to 200 milliseconds for tokens to arrive in the bucket and the bucket size to 40 tokens for ICMP error messages.
[Sysname] ip icmp error-interval 200 40
ip icmp fragment discarding
Use ip icmp fragment discarding to disable forwarding of ICMP fragments.
Use undo ip icmp fragment discarding to enable forwarding of ICMP fragments.
Forwarding of ICMP fragments is enabled.
Disabling forwarding of ICMP fragments can prevent ICMP fragment attacks.
# Disable forwarding of ICMP fragments.
[Sysname] ip icmp fragment discarding
ip icmp receive enable
Use ip icmp receive enable to enable the device to receive a specific type of ICMP messages.
Use undo ip icmp receive enable to disable the device from receiving a specific type of ICMP messages.
ip icmp { name icmp-name | type icmp-type code icmp-code } receive enable
undo ip icmp { name icmp-name | type icmp-type code icmp-code } receive enable
The device can receive all types of ICMP messages.
name icmp-name: Specifies an ICMP message name, a case-insensitive string of 1 to 20 characters.
type icmp-type: Specifies an ICMP message type. The value range for the icmp-type argument is 0 to 255.
code icmp-code: Specifies an ICMP message code. The value range for the icmp-code argument is 0 to 255.
CAUTION
CAUTION:
Disabling receiving ICMP messages of a specific type might affect network operation. Please use this feature with caution.
By default, the device receives all types of ICMP messages. Such a setting might affect device performance if a large number of ICMP responses are received within a short time. To solve this issue, you can use this command to disable the device from receiving a specific type of ICMP messages.
Table 9 shows common ICMP messages and their meanings.
Table 9 Common ICMP messages
Name
Code
echo
8
0
Echo request used to ping a target node.
echo-reply
0
0
Echo reply sent by a target node after receiving an echo request.
fragmentneed-dfset
3
4
Packets that need fragmentation but have the DF bit set.
host-redirect
5
1
Host redirection.
host-tos-redirect
5
3
Host ToS redirection.
host-unreachable
3
1
Unreachable host.
information-reply
16
0
Information reply.
information-request
15
0
Information request.
net-redirect
5
0
Network redirection.
net-tos-redirect
5
2
Network ToS redirection.
net-unreachable
3
0
Unreachable network.
parameter-problem
12
0
Invalid parameter.
port-unreachable
3
3
Unreachable port.
protocol-unreachable
3
2
Unreachable protocol.
reassembly-timeout
11
1
Fragment reassembly timeout.
source-quench
4
0
Source quench message.
source-route-failed
3
5
Source route failure.
timestamp-reply
14
0
Timestamp reply.
timestamp-request
13
0
Timestamp request.
ttl-exceeded
11
0
TTL exceeded in transit.
# Enable the device to receive ICMP echo reply messages.
[Sysname] ip icmp name echo-reply receive enable
ip icmp send enable
Use ip icmp send enable to enable the device to send a specific type of ICMP messages.
Use undo ip icmp send enable to disable the device from sending a specific type of ICMP messages.
ip icmp { name icmp-name | type icmp-type code icmp-code } send enable
undo ip icmp { name icmp-name | type icmp-type code icmp-code } send enable
The device sends all types of ICMP messages except Destination Unreachable, Time Exceeded, and Redirect messages.
CAUTION
CAUTION:
Disabling sending ICMP messages of a specific type might affect network operation. Please use this feature with caution.
By default, the device sends all types of ICMP messages except Destination Unreachable, Time Exceeded, and Redirect messages. Attackers might obtain information from specific types of ICMP messages, causing security issues.
For security purposes, you can use this command to disable the device from sending ICMP messages of specific types.
To enable sending Destination Unreachable, Time Exceeded, or Redirect messages, you can perform one of the following tasks:
·     Execute the ip icmp send enable command.
·     Execute one of the following commands as needed:
¡     ip unreachables enable
¡     ip ttl-expires enable
¡     ip redirects enable
# Enable the device to send ICMP echo reply messages.
[Sysname] ip icmp name echo-reply send enable
ip redirects enable
ip icmp source
Use ip icmp source to specify the source address for outgoing ICMP packets.
Use undo ip icmp source to remove the specified source address for outgoing ICMP packets.
undo ip icmp source [ vpn-instance vpn-instance-name ]
No source address is specified for outgoing ICMP packets. The default source IP addresses for different types of ICMP packets vary as follows:
·     For an ICMP error message, the source IP address is the IP address of the receiving interface of the packet that triggers the ICMP error message. ICMP error messages include Time Exceeded, Port Unreachable, and Parameter Problem messages.
·     For an ICMP echo request, the source IP address is the IP address of the sending interface.
·     For an ICMP echo reply, the source IP address is the destination IP address of the ICMP echo request specific to this reply.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the specified address belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If you do not specify a VPN instance, the ip-address argument specifies an IP address on the public network.
ip-address: Specifies an IP address.
It is a good practice to specify the IP address of the loopback interface as the source IP address for outgoing ping echo request and ICMP error messages. This feature helps users to locate the sending device easily.
# Specify 1.1.1.1 as the source address for outgoing ICMP packets.
[Sysname] ip icmp source 1.1.1.1
ip mtu
Use ip mtu to set the interface MTU for IPv4 packets. The setting defines the largest size of an IPv4 packet that an interface can transmit without fragmentation.
Use undo ip mtu to restore the default.
ip mtu mtu-size
undo ip mtu
The interface MTU is not set.
Interface view
mtu-size: Specifies the MTU in bytes. The value range for the mtu-size argument is 128 to 9216.
When a packet exceeds the MTU of the sending interface, the device processes the packet in one of the following ways:
·     If the packet disallows fragmentation, the device discards it.
·     If the packet allows fragmentation, the device fragments it and forwards the fragments.
Fragmentation and reassembling consume system resources, so set an appropriate MTU to avoid fragmentation.
If an interface supports both the mtu and ip mtu commands, the device fragments a packet based on the MTU set by the ip mtu command.
# Set the interface MTU for IPv4 packets to 1280 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] ip mtu 1280
ip option
Use ip option to enable the device to process IP options in IP packets.
Use undo ip option to disable the device from processing IP options in IP packets.
ip option { drop | forward }
undo ip option
The device delivers IP packets carrying IP options to the CPU for processing.
drop: Drops IP packets that carry IP options and are not destined for the device.
forward: Performs hardware forwarding for IP packets that carry IP options and are not destined for the device. The device will not process the IP options of those IP packets.
IP options are typically used for network path diagnosis or temporary transmission of specific services.
By default, when a packet with IP options arrives at an intermediate device, the device sends the packet to CPU to process IP options before forwarding it out. In a network with excessive packet exchanges, processing IP options will prevent the intermediate device from processing packets in a timely manner and cause packet loss. To avoid this situation, you can perform either of the following operations:
·     Execute the ip option forward command. This command disables the device from processing IP options in packets that are not destined for the device. Then, those packets will be forwarded through hardware.
·     Execute the ip option drop command. This command enables the device to drop IP packets that carry IP options and are not destined for the device.
CAUTION
CAUTION:
As a best practice, execute this command only when IP options are not used in the network.
When IP options are required and the device does not support hardware forwarding, you can execute the undo ip option command. The device will then deliver IP packets carrying IP options to the CPU for processing.
# Enable the device to process IP options in IP packets.
[Sysname] ip option forward
ip reassemble local enable
Use ip reassemble local enable to enable IPv4 local fragment reassembly.
Use undo ip reassemble local enable to disable local fragment reassembly.
IPv4 local fragment reassembly is disabled.
Use this feature on a multichassis IRF fabric to improve fragment reassembly efficiency. If this feature is disabled, all IPv4 fragments are delivered to the master for reassembly. With this feature enabled, a subordinate performs fragment reassembly for an IPv4 packet destined for the IRF fabric if it receives fragments of that packet.
This feature fails to reassemble an IPv4 packet if fragments of the packet are received by different subordinates.
# Enable IPv4 local fragment reassembly.
[Sysname] ip reassemble local enable
ip redirects enable
Use ip redirects enable to enable sending ICMP redirect messages.
Use undo ip redirects enable to disable sending ICMP redirect messages.
ip redirects enable
Sending ICMP redirect messages is disabled.
ICMP redirect messages simplify host management and enable hosts to gradually optimize their routing tables.
A host that has only one route destined for the default gateway sends all packets to the default gateway. The default gateway sends an ICMP redirect message to inform the host of a correct next hop when the following conditions are met:
·     The receiving and sending interfaces are the same.
·     The packet source IP address and the IP address of the packet receiving interface are on the same segment.
·     There is no source route option in the received packet.
# Enable sending ICMP redirect messages.
[Sysname] ip redirects enable
Use ip ttl-expires enable to enable sending ICMP time exceeded messages.
Use undo ip ttl-expires enable to disable sending ICMP time exceeded messages.
Sending ICMP time exceeded messages is disabled.
A device sends ICMP time exceeded messages by following these rules:
·     The device sends an ICMP TTL exceeded in transit message to the source when the following conditions are met:
¡     The received packet is not destined for the device.
¡     The TTL field of the packet is 1.
·     When the device receives the first fragment of an IP datagram destined for the device itself, it starts a timer. If the timer expires before all the fragments of the datagram are received, the device sends an ICMP fragment reassembly time exceeded message to the source.
A device disabled from sending ICMP time exceeded messages does not send ICMP TTL exceeded in transit messages but can still send ICMP fragment reassembly time exceeded messages.
# Enable sending ICMP time exceeded messages.
[Sysname] ip ttl-expires enable
ip ttl-expired drop-rate alarm enable
Use ip ttl-expired drop-rate alarm enable to enable the device to generate TTL expiry alarms.
Use undo ip ttl-expired drop-rate alarm enable to disable the device from generating TTL expiry alarms.
ip ttl-expired drop-rate alarm enable [ interval interval-value ] [ threshold threshold-value ] [ no-drop-notify [ cycles resume-value ] ]
The device supports generating TTL expiry alarms.
interval interval-value: Specifies the interval at which the device checks for the number of bytes in TTL expiry packets. The value range is 5 to 3600 seconds and the default interval is 60 seconds.
threshold threshold-value: Specifies the alarm threshold in the range of 1 to 100. The default threshold is 10. The alarm threshold represents the multiple of TTL-expiry packet bytes. If the number of bytes in TTL expiry packets received during an interval equals or exceeds that during the previous interval multiplied by the specified alarm threshold, the device will generate a TTL expiry alarm.
no-drop-notify: Exits the TTL expiry alarm state if no TTL expiry packets are received during the specified period.
cycles resume-value: Specifies the number of consecutive intervals that triggers TTL expiry alarm clearance. The value range is 1 to 65535 and the default value is 1. For example, you can set the value for the resume-value argument to 2. The device will exit the TTL expiry alarm state and generate an alarm clearance message if no TTL expiry packets are received during two consecutive intervals.
A TTL expiry packet is an IP packet with a TTL value less than or equal to one.
When the device has a loop or is under TTL expiry attacks, it receives a large number of TTL expiry packets in a short period. The number of TTL expiry packets might grow exponentially. Processing those packets will occupy the resources used for processing service packets.
To avoid the above issue, use this command to check for loops or TTL expiry attacks. The device periodically obtains the number of packet bytes with TTL expiry errors at the specified intervals. If the number of bytes in TTL expiry packets received during an interval equals or exceeds that during the previous interval multiplied by the specified alarm threshold, the device will generate a TTL expiry alarm. To enable TTL expiry alarm clearance, specify the no-drop-notify keyword.
# Enable the device to generate TTL expiry alarms. The check interval is 30 seconds, the alarm threshold is 20, and the alarm clearance threshold is 5.
[Sysname] ip ttl-expired drop-rate alarm enable interval 30 threshold 20 no-drop-notify resume-cycles 5
Use ip unreachables enable to enable sending ICMP destination unreachable messages.
Use undo ip unreachables enable to disable sending ICMP destination unreachable messages.
Sending ICMP destination unreachable messages is disabled.
A device sends ICMP destination unreachable messages by following these rules:
·     The device sends the source an ICMP network unreachable message when the following conditions are met:
¡     The received packet does not match any route.
¡     No default route exists in the routing table.
·     The device sends the source an ICMP protocol unreachable message when the following conditions are met:
¡     The received packet is destined for the device.
¡     The transport layer protocol of the packet is not supported by the device.
·     The device sends the source an ICMP port unreachable message when the following conditions are met:
¡     The received UDP packet is destined for the device.
¡     The packet's port number does not match the running process.
·     The device sends the source an ICMP source route failed message when the following conditions are met:
¡     The source uses Strict Source Routing to send packets.
¡     The intermediate device finds that the next hop specified by the source is not directly connected.
·     The device sends the source an ICMP fragmentation needed and DF set message when the following conditions are met:
¡     The MTU of the sending interface is smaller than the packet.
¡     The packet has Don't Fragment set.
# Enable sending ICMP destination unreachable messages.
[Sysname] ip unreachables enable
reset ip statistics
Use reset ip statistics to clear IP traffic statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears IP traffic statistics for all member devices.
Use this command to clear history IP traffic statistics before you collect IP traffic statistics for a time period.
# Clear IP traffic statistics.
<Sysname> reset ip statistics
Use reset tcp statistics to clear TCP traffic statistics.
# Clear TCP traffic statistics.
<Sysname> reset tcp statistics
Use reset udp statistics to clear UDP traffic statistics.
# Clear UDP traffic statistics.
<Sysname> reset udp statistics
snmp-agent trap enable port-attack
Use snmp-agent trap enable port-attack to enable SNMP notifications for attack events on ports.
Use undo snmp-agent trap enable port-attack to disable SNMP notifications for attack events on ports.
SNMP notifications are disabled for attack events on ports.
This feature enables the port attack module to generate SNMP notifications for critical events, such as ICMP packet reception overspeeding on a port. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for attack events on ports.
[Sysname] snmp-agent trap enable port-attack
snmp-agent trap enable tcp
Use snmp-agent trap enable tcp to enable SNMP notifications for TCP events.
Use undo snmp-agent trap enable tcp to disable SNMP notifications for TCP events.
SNMP notifications for TCP events are enabled.
This feature enables the TCP module to generate SNMP notifications for critical TCP events, such as MD5 authentication failure for TCP connection. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for TCP events.
[Sysname] undo snmp-agent trap enable tcp
Use statistics l3-packet enable to enable Layer 3 packet statistics collection.
Use undo statistics l3-packet enable to disable Layer 3 packet statistics collection.
statistics l3-packet enable [ inbound | outbound ]
undo statistics l3-packet enable [ inbound | outbound ]
Layer 3 packet statistics collection is disabled.
Interface view
inbound: Enables statistics collection for incoming Layer 3 packets.
outbound: Enables statistics collection for outgoing Layer 3 packets.
With this feature enabled on an interface, the device counts incoming and outgoing IP packets on the interface. To display the collected statistics, execute the display interface command.
When the interface is processing a large number of packets, enabling this feature will cause high CPU usage and degrade forwarding performance. If the statistics are not necessary, disable this feature to ensure device performance.
To enable statistics collection for both incoming and outgoing Layer 3 packets, do not specify the inbound or outbound keyword.
To disable statistics collection for both incoming and outgoing Layer 3 packets, do not specify the inbound or outbound keyword.
After you use the ip verify source command to enable IPv4SG on an interface, statistics collection for incoming Layer 3 packets does not take effect on that interface.
# Enable Layer 3 packet statistics collection on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] statistics l3-packet enable
display ip interface (Layer 3—IP Services Command Reference)
display interface (Layer 2LAN Switching Command Reference)
tcp mss
Use tcp mss to set the TCP maximum segment size (MSS).
Use undo tcp mss to restore the default.
tcp mss value
undo tcp mss
The TCP MSS is not set.
Interface view
value: Specifies the TCP MSS in bytes. The value range for this argument is 128 to 9176.
The MSS option informs the receiver of the largest segment that the sender can accept. Each end announces its MSS during TCP connection establishment. If the size of a TCP segment is smaller than the MSS of the receiver, TCP sends the TCP segment without fragmentation. If not, TCP fragments the segment according to the receiver's MSS.
If you set the TCP MSS on an interface, the size of each TCP segment received or sent on the interface cannot exceed the MSS value.
This configuration takes effect only on TCP connections that are established after the configuration and not on the TCP connections that already exist.
This configuration is effective only on IP packets. If MPLS is enabled on the interface, do not set the TCP MSS on the interface.
# Set the TCP MSS to 300 bytes on VLAN-interface 100.
[Sysname-Vlan-interface100] tcp mss 300
tcp path-mtu-discovery
Use tcp path-mtu-discovery to enable TCP path MTU discovery.
Use undo tcp path-mtu-discovery to disable TCP path MTU discovery.
TCP path MTU discovery is disabled.
aging age-time: Specifies the aging time for the path MTU, in the range of 10 to 30 minutes. The default aging time is 10 minutes.
no-aging: Does not age out the path MTU.
After you enable TCP path MTU discovery, all new TCP connections detect the path MTU. The device uses the path MTU to calculate the MSS to avoid IP fragmentation.
After you disable TCP path MTU discovery, the system stops all path MTU timers. The TCP connections established later do not detect the path MTU, but the TCP connections previously established still can detect the path MTU.
# Enable TCP path MTU discovery and set the path MTU aging time to 20 minutes.
[Sysname] tcp path-mtu-discovery aging 20
tcp syn-cookie enable
Use tcp syn-cookie enable to enable SYN Cookie to protect the device from SYN flood attacks.
Use undo tcp syn-cookie enable to disable SYN Cookie.
SYN Cookie is disabled.
A TCP connection is established through a three-way handshake:
1.     The sender sends a SYN packet to the server.
2.     The server receives the SYN packet, establishes a TCP semi-connection in SYN_RECEIVED state, and replies with a SYN ACK packet to the sender.
3.     The sender receives the SYN ACK packet and replies with an ACK packet. Then, a TCP connection is established.
An attacker can exploit this mechanism to mount SYN flood attacks. The attacker sends a large number of SYN packets, but they do not respond to the SYN ACK packets from the server. As a result, the server establishes a large number of TCP semi-connections and cannot handle normal services.
SYN Cookie can protect the server from SYN flood attacks. When the server receives a SYN packet, it responds to the request with a SYN ACK packet without establishing a TCP semi-connection.
The server establishes a TCP connection and enters ESTABLISHED state only when it receives an ACK packet from the sender.
# Enable SYN Cookie.
[Sysname] tcp syn-cookie enable
tcp timer fin-timeout
Use tcp timer fin-timeout to set the TCP FIN wait timer.
Use undo tcp timer fin-timeout to restore the default.
The TCP FIN wait timer is 675 seconds.
time-value: Specifies the TCP FIN wait timer in the range of 76 to 3600 seconds.
TCP starts the FIN wait timer when the state of a TCP connection changes to FIN_WAIT_2. If no FIN packet is received within the timer interval, the TCP connection is terminated.
If a FIN packet is received, TCP changes the connection state to TIME_WAIT. If a non-FIN packet is received, TCP restarts the timer and tears down the connection when the timer expires.
# Set the TCP FIN wait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
tcp timer syn-timeout
Use tcp timer syn-timeout to set the TCP SYN wait timer.
Use undo tcp timer syn-timeout to restore the default.
The TCP SYN wait timer is 75 seconds.
time-value: Specifies the TCP SYN wait timer in the range of 2 to 600 seconds.
TCP starts the SYN wait timer after sending a SYN packet. Within the SYN wait timer if no response is received or the upper limit on TCP connection tries is reached, TCP fails to establish the connection.
# Set the TCP SYN wait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
tcp timestamps enable
Use tcp timestamps enable to enable the device to encapsulate the TCP Timestamps option in outgoing TCP packets.
Use undo tcp timestamps enable to disable the device from encapsulating the TCP Timestamps option in outgoing TCP packets.
The TCP Timestamps option is encapsulated in outgoing TCP packets.
Devices at each end of the TCP connection can calculate the RTT value by using the TCP Timestamps option carried in TCP packets. For security purpose in some networks, you can disable the TCP Timestamps option encapsulation at one end of the TCP connection to prevent intermediate devices from obtaining the option information.
This command takes effect only on new connections that are established after you execute the command. Existing TCP connections are not affected.
# Enable the device to encapsulate the TCP Timestamps option in outgoing TCP packets.
[Sysname] undo tcp timestamps enable
tcp window
Use tcp window to set the size of the TCP receive/send buffer.
Use undo tcp window to restore the default.
tcp window window-size
undo tcp window
The size of the TCP receive/send buffer is 63 KB.
window-size: Specifies the size of the TCP receive/send buffer, in the range of 1 to 64 KB.
# Set the size of the TCP receive/send buffer to 3 KB.
[Sysname] tcp window 3
