11-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X-HI[EI][SI]&S6520-SI&S5560X-HI&S5000-EI&MS4600 Command References-R68xx-6W10011-Network Management and Monitoring Command Reference
24-eMDI commands
24-eMDI commands 169.62 KB
eMDI commands
alarm suppression times
Use alarm suppression times to set the eMDI alarm logging threshold, that is, the number of consecutive alarms to be suppressed before logging the event.
Use undo alarm suppression times to restore the default.
alarm suppression times times-value
The eMDI alarm logging threshold is 3.
eMDI instance view
times-value: Specifies the number of consecutive alarms to be suppressed before logging the event, in the range of 0 to 60. To disable eMDI alarm logging, set this argument to 0.
A started eMDI instance monitors its data flow and periodically collects statistics on lost and out-of-order packets.
·     If a statistic is equal to or greater than the alarm threshold, the instance triggers an alarm. When the number of consecutive alarms of the same type exceeds the logging threshold, the device sends an alarm log message to the information center.
·     If a statistic is less than the alarm threshold, the instance records an alarm removal event. When the number of consecutive alarm removal events of the same type exceeds the logging threshold, the device sends an alarm-removed log message to the information center.
For more information about the information center, see "Configuring information center."
To change the eMDI alarm logging threshold for an eMDI instance that is already started, you must stop the instance first by executing the stop command.
# Set the eMDI alarm logging threshold to 5.
[Sysname] emdi
[Sysname-emdi] instance eMDI1
[Sysname-emdi-instance-eMDI1] flow ipv4 tcp source 10.0.0.1 destination 10.2.2.2
[Sysname-emdi-instance-eMDI1] alarm suppression times 5
flow ipv4 tcp
flow ipv4 udp
alarm threshold
Use alarm threshold to set alarm thresholds for an eMDI instance.
Use undo alarm threshold to restore the defaults.
alarm { dplr | rtp-lr | rtp-ser | uplr } threshold threshold-value
undo alarm { dplr | rtp-lr | rtp-ser | uplr } threshold
The alarm thresholds for an eMDI instance are all 100.
eMDI instance view
dplr: Sets the alarm threshold for the downstream TCP packet loss rate.
rtp-lr: Sets the alarm threshold for the RTP packet loss rate.
rtp-ser: Sets the alarm threshold for the RTP packet sequence error rate.
uplr: Sets the alarm threshold for the upstream TCP packet loss rate.
threshold-value: Specifies the alarm threshold value, which is the number of lost or out-of-order packets among 100000 packets. The value range is 1 to 100000.
To modify alarm thresholds for an eMDI instance that is already started, you must stop the instance first by executing the stop command.
# Set the downstream TCP packet loss rate to 1/100 for eMDI instance eMDI1.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] alarm dplr threshold 1000
flow ipv4 tcp
flow ipv4 udp
description
Use description to configure a description for an eMDI instance.
An eMDI instance does not have a description.
eMDI instance view
You can use this command to add, delete, or modify the description for a running instance.
# Set the description to eMDI1 for eMDI instance eMDI1.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] description eMDI1
display emdi instance
Use display emdi instance to display eMDI instance information.
display emdi instance [ name instance-name | id instance-id ] [ verbose ]
name instance-name: Specifies an eMDI instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an instance, this command displays information about all instances.
id instance-id: Specifies an eMDI instance by its ID. If you do not specify an instance, this command displays information about all instances.
verbose: Displays detailed instance information. If you do not specify this keyword, the command displays brief instance information.
# Display brief information about eMDI instance eMDI1.
<Sysname> display emdi instance name eMDI1
Status       Protocol     Type     Source IP/Port        Destination IP/Port
Active       TCP          Static   1.1.1.1/2001          2.2.2.2/2010
# Display brief information about all eMDI instances.
Brief information about all instances:
ID   Name                    Type       Instance status      Protocol
1    eMDI1                   Static     Active               TCP
2    -                       Dynamic    Inactive             UDP
# Display detailed information about eMDI instance eMDI1, which monitors a TCP data flow.
<Sysname> display emdi instance name eMDI1 verbose
Instance name                             : eMDI1
  Instance status                        : Active
  Protocol                               : TCP
  Type                                   : Static
  Destination IP                         : 2.2.2.2
  Destination port                       : 2010
  Source IP                              : 1.1.1.1
  Source port                            : 2001
  VLAN ID                                : 45
  VXLAN ID                               : -
  Monitoring period                      : 10 sec
  Monitoring periods that passed         : 30
  Lifetime                               : 10 hours
  Running time                           : 8 hours 20 min 30 sec
  Normal periods                         : 29
  Abnormal periods                       : 1
  UPLR                                   : 1000
  DPLR                                   : 1000
# Display detailed information about eMDI instance 2, which monitors a UDP data flow.
<Sysname> display emdi instance id 2 verbose
Instance name                             : -
  Instance status                        : Inactive
  Protocol                               : UDP
  Type                                   : Dynamic
  Source IP                              : 1.1.1.1
  Source port                            : 2001
  VLAN ID                                : 45
  VXLAN ID                               : -
  Payload type                           : -
  Clock rate                             : 90000 Hz
  Lifetime                               : 10 hours
  Normal periods                         : 29
  RTP-LR                                 : 100
  RTP-SER                                : 100
  FEC window                             : 100
  FEC threshold                          : 5
Status
Instance status
Instance status:
·     Active.
·     Inactive.
Protocol
Transport layer protocol of the data flow:
·     TCP.
·     UDP.
Instance creation method:
·     Static—The eMDI instance was manually configured at the CLI.
·     Dynamic—The eMDI instance was created by other features.
Source IP/Port
Source Port
Source IP address and source port of the data flow.
Destination IP/Port
Destination Port
Destination IP address and destination port of the data flow.
ID
Instance ID.
Name/Instance name
Instance name.
VLAN ID
VLAN ID of the data flow.
VXLAN ID
VXLAN ID of the data flow.
Monitoring period
Instance monitoring period, in seconds.
Number of passed monitoring periods.
If the device did not receive packets of the data flow within some monitoring periods, the number of passed monitoring periods is greater than the total number of normal periods and abnormal periods.
Lifetime
Instance lifetime.
Running time
Instance running time.
The value of this field might be slightly greater than the value of the lifetime field in the following situations:
·     The instance lifetime has expired but the current monitoring period has not. The instance will run until the current monitoring period expires.
·     The instance lifetime is long and the instance running time is reaching or has already reached the instance lifetime.
Normal periods
Number of periods when both the number of lost packets and the number of out-of-order packets were within the alarm thresholds.
Abnormal periods
Number of periods when the number of lost or out-of-order packets exceeded the alarm threshold.
UPLR
Alarm threshold for the upstream TCP packet loss rate.
DPLR
Alarm threshold for the downstream TCP packet loss rate.
Payload type
RTP packet payload type of the UDP data flow to be monitored.
Clock rate
RTP packet clock frequency of the UDP data flow to be monitored, in Hz.
RTP-LR
Alarm threshold for the RTP packet loss rate.
RTP-SER
Alarm threshold for the RTP sequence error rate.
FEC window
Sliding window size for UDP data flow quality monitoring.
FEC threshold
FEC packet loss threshold for UDP data flow quality monitoring.
display emdi resource
Use display emdi resource to display eMDI instance resource information.
# Display eMDI instance resource information.
<Sysname> display emdi resource
Specifications(Slot 1):
  Max instances                       : 8
  Max UDP instances                   : 8
  Max TCP instances                   : 4
  Max static instances                : 8
  Max dynamic instances               : 8
Configuration(Slot 1):
  Configured instances                : 0
  Running instances                   : 0
  Running UDP instances               : 0
  Running TCP instances               : 0
  Running static instances            : 0
  Running dynamic instances           : 0
Specifications
Supported eMDI specifications.
Max instances
Maximum number of instances that can run at the same time.
Max UDP instances
Maximum number of UDP instances that can run at the same time.
Max TCP instances
Maximum number of TCP instances that can run at the same time.
Maximum number of static instances that can run at the same time.
Maximum number of dynamic instances that can run at the same time.
Configuration
Current eMDI configuration.
Number of configured instances.
Running instances
Total number of running instances.
Total number of running instances = Number of running UDP instances + Number of running TCP instances = Number of running static instances + Number of running dynamic instances.
Number of running instances that monitors UDP data flows.
Number of running instances that monitors TCP data flows.
Number of running static instances.
emdi
display emdi statistics
Use display emdi statistics to display monitoring statistics for an eMDI instance.
display emdi statistics { instance-name instance-name | instance-id instance-id } [ number number ] [ abnormal | verbose ]
instance-name instance-name: Specifies an eMDI instance by its name, a case-sensitive string of 1 to 31 characters.
instance-id instance-id: Specifies an eMDI instance by its ID.
number number: Displays statistics for the specified number of monitoring periods. The number argument is in the range of the 1 to 60. The default value is 3.
abnormal: Displays statistics for periods with lost or out-of-order packets. If you do not specify this keyword, the command displays statistics for both normal periods and abnormal periods.
verbose: Displays detailed monitoring statistics for the data flow. If you do not specify this keyword, the command displays brief monitoring statistics.
The device stores only the monitoring statistics within the most recent 60 monitoring periods for each eMDI instance.
If you specify both the abnormal keyword and the number number option, this command displays statistics for the specified number of abnormal periods.
# Display brief monitoring statistics for eMDI instance eMDI1.
<Sysname> display emdi statistics instance-name eMDI1
Instance ID      : 1
Monitoring period: 10 sec
Protocol         : TCP
Unit for DPLR and UPLR is 1/100000
Timestamp            Status   Rate(bps)   DPLR    UPLR    DRTT(us)    URTT(us)
2019/09/17 16:17:20  Normal   4539000     0       0       2694        2315
2019/09/17 16:17:10  Abnormal 4865656     46786   0       3656        3711
2019/09/17 16:17:00  Abnormal 4865656     12362   4568    69564       26965
# Display brief monitoring statistics for the most recent two monitoring periods of eMDI instance eMDI2.
<Sysname> display emdi statistics instance-name eMDI2 number 2
Instance name    : eMDI2
Instance ID      : 2
Protocol         : UDP
Unit for RTP-LR, RTP-SER and RTP-ELF is 1/100000
Timestamp            Status   RTP-LR  RTP-SER  Jitter(us)  RTP-LP      RTP-ELF
2019/09/17 16:17:20  Normal   0       0        4294        0           0
2019/09/17 16:17:10  Abnormal 36533   25365    6729        15          12566
# Display detailed monitoring statistics for eMDI instance eMDI3.
<Sysname> display emdi statistics instance-name eMDI3 verbose
Instance name                            : eMDI3
Instance ID                              : 3
Protocol                                 : UDP
Timestamp                                : 2019-09-17 17:02:00
  Service module                         : Slot 1
  Inbound interface                      : Ten-GigabitEthernet1/0/1
  Flow status                            : Abnormal
  Received packets                       : 3850
  Rate                                   : 128 pps
  Received bytes                         : 5390000
  Rate                                   : 1437333 bps
  Lost packets                           : 32261
  RTP-LR                                 : 89338/100000
  Packet out of sequence                 : 0
  RTP-SER                                : 0/100000
  RTP-LP                                 : 5
  RTP-ELF                                : 2/100000
  Maximum jitter                         : 8815 us
  Average jitter                         : 8540 us
  Minimum jitter                         : 8262 us
Timestamp                                : 2019-09-17 17:01:50
  Flow status                            : Normal
  Received packets                       : 3736
  Rate                                   : 128 pps
  Received bytes                         : 5145000
  Rate                                   : 1237333 bps
  Lost packets                           : 31481
  RTP-LR                                 : 81569/100000
  RTP-SER                                : 0/100000
  RTP-LP                                 : 5
  RTP-ELF                                : 2/100000
  Maximum jitter                         : 7885 us
  Average jitter                         : 7564 us
  Minimum jitter                         : 7242 us
Timestamp                                : 2019-09-17 17:01:40
  Rate                                   : 128 pps
  Rate                                   : 1237333 bps
  RTP-SER                                : 0/100000
  RTP-LP                                 : 5
  RTP-ELF                                : 2/100000
# Display detailed monitoring statistics for the most recent monitoring period of eMDI instance eMDI4.
<Sysname> display emdi statistics instance-name eMDI4 number 1 verbose
Instance name                            : eMDI4
Instance ID                              : 4
Protocol                                 : TCP
  Received packets                       : 95
  Rate                                   : 9 pps
  Received bytes                         : 12510
  Rate                                   : 10008 bps
  UPLC                                   : 0
  UPLR                                   : 0/100000
  DPLC                                   : 0
  DPLR                                   : 0/100000
  URTT                                   : 35 us
  DRTT                                   : 8354549 us
  Service module                         : Slot 2
  Inbound interface                      : GigabitEthernet2/0/1
  Rate                                   : 9 pps
  Rate                                   : 10008 bps
  UPLC                                   : 0
  UPLR                                   : 0/100000
  DPLC                                   : 0
  DPLR                                   : 0/100000
  URTT                                   : 35 us
  DRTT                                   : 8354549 us
# Display statistics for abnormal periods of eMDI instance eMDI5.
<Sysname> display emdi statistics instance-name eMDI5 abnormal
Instance name                            : eMDI5
Instance ID                              : 5
Protocol                                 : TCP
  Rate                                   : 9 pps
  Rate                                   : 10008 bps
  UPLC                                   : 0
  UPLR                                   : 0/100000
  DPLC                                   : 0
  DPLR                                   : 0/100000
  URTT                                   : 35 us
  DRTT                                   : 8354549 us
Timestamp                                : 2019-09-17 17:00:00
  Rate                                   : 9 pps
  Rate                                   : 10008 bps
  UPLC                                   : 0
  UPLR                                   : 0/100000
  DPLC                                   : 0
  DPLR                                   : 0/100000
  URTT                                   : 35 us
  DRTT                                   : 8354549 us
Timestamp                                : 2019-09-17 16:58:00
  Rate                                   : 9 pps
  Rate                                   : 10008 bps
  UPLC                                   : 0
  UPLR                                   : 0/100000
  DPLC                                   : 0
  DPLR                                   : 0/100000
  URTT                                   : 35 us
  DRTT                                   : 8354549 us
Monitoring period
Monitoring period of the eMDI instance, in seconds.
Protocol
·     TCP.
·     UDP.
Timestamp
Time when the statistics were recorded.
Status
Flow status
Flow status:
·     Normal.
·     Abnormal.
Rate
Packet input rate, in bps or pps.
If no packets of the data flow were received within the monitoring period, this field displays a hyphen (-).
DPLR
Downstream packet loss rate, in units of one hundred thousandth.
UPLR
Upstream packet loss rate, in units of one hundred thousandth.
DRTT
Average downstream round trip time, in microseconds.
URTT
Average upstream round trip time, in microseconds.
RTP-LR
RTP packet loss rate, in units of one hundred thousandth.
RTP-SER
RTP packet sequence error rate, in units of one hundred thousandth.
Jitter
RTP packet jitter, in microseconds.
RTP-LP
Maximum number of continuously lost RTP packets.
RTP-ELF
RTP effective loss factor for Forward Error Correct (FEC), in units of one hundred thousandth.
Service module
Number of the slot where the instance resides.
Inbound interface
Inbound interface of the packets.
Received packets
Number of received packets.
Received bytes
Bytes of received TCP or UDP packets.
Lost packets
Number of lost packets.
Number of out-of-order packets.
Maximum jitter
Maximum jitter in microseconds.
Average jitter
Average jitter in microseconds.
Minimum jitter
Minimum jitter in microseconds.
UPLC
Number of lost upstream packets.
DPLC
Number of lost downstream packets.
emdi
Use emdi to enable eMDI and enter its view.
Use undo emdi to restore the default.
emdi
undo emdi
eMDI is disabled.
The undo emdi command disables eMDI and deletes all eMDI settings.
# Enable eMDI and enter its view.
[Sysname] emdi
[Sysname-emdi]
fec
Use fec to specify the sliding window size and packet loss threshold for a UDP data flow to be monitored.
Use undo fec to restore the default.
fec { window window-size | threshold threshold-value } *
undo fec
The sliding window size and packet loss threshold for a UDP data flow are 100 and 5, respectively.
eMDI instance view
window window-size: Specifies the sliding window size in packets, in the range of 10 to 1000.
threshold threshold-value: Specifies the packet loss threshold in packets, in the range of 1 to 100.
This command enables you to monitor the packet loss conditions of the UDP data flow. After each window slide, the system identifies whether the number of lost data packets in the window within the monitoring period is greater than the threshold. If yes, the system increases RTP-ELF by 1. The window sliding stops when the monitoring period expires. If the total number of packet loss windows is greater than 0 within a monitoring period, a video fault exists.
This command is intended for a UDP data flow. Before executing this command, you must specify the UDP data flow for the eMDI instance to monitor.
The packet loss threshold must be smaller than the sliding window size.
To modify the FEC settings for an eMDI instance that is already started, you must stop the instance first by executing the stop command.
# Set the sliding window size and packet loss threshold for eMDI instance eMDI1 to 10 and 5, respectively.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] flow ipv4 udp source 10.0.0.1 destination 10.2.2.2
[Sysname-emdi-instance-eMDI1] fec window 10 threshold 5
flow ipv4 udp
flow ipv4 tcp
Use flow ipv4 tcp to specify a TCP data flow to be monitored.
Use undo flow to restore the default.
flow ipv4 tcp source source-ip-address destination destination-ip-address [ destination-port destination-port-number | source-port source-port-number | vlan vlan-id | vni vxlan-id ] *
undo flow
No TCP data flow is specified for an eMDI instance.
eMDI instance view
source source-ip address: Specifies the source IP address of the data flow in dotted-decimal notation.
destination destination-ip-address: Specifies the destination IP address of the data flow in dotted-decimal notation.
destination-port destination-port-number: Specifies the destination port number of the data flow, in the range of 1 to 65535.
source-port source-port-number: Specifies the source port number of the data flow, in the range of 1 to 65535.
vlan vlan-id: Specifies the VLAN ID of the data flow, in the range of 1 to 4094.
vni vxlan-id: Specifies the VXLAN ID of the data flow, in the range of 0 to 16777215.
You can specify a data flow by using any combination of the following items: source IP address, destination IP address, source port number, destination port number, VLAN ID, and VXLAN ID. Using more items defines a more granular data flow and provides more helpful monitoring data and analysis results.
For a VXLAN data flow, all parameters except VXLAN ID are used to match the fields in the inner packet header.
An eMDI instance can monitor only one data flow. A data flow can be monitored by only one eMDI instance.
If you execute this command multiple times when the eMDI instance is not started, the most recent configuration takes effect.
To modify the data flow configuration for an instance that is already started, you must stop the instance first by executing the stop command.
The undo flow command also restores the default eMDI alarm settings.
# Configure eMDI instance eMDI2 to monitor the TCP data flow from 10.0.0.1 to 10.0.0.2.
[Sysname] emdi
[Sysname-emdi] instance eMDI2
[Sysname-emdi-instance-eMDI2] flow ipv4 tcp source 10.0.0.1 destination 10.0.0.2
flow ipv4 udp
Use flow ipv4 udp to specify a UDP data flow to be monitored.
flow ipv4 udp source source-ip-address destination destination-ip-address [ destination-port destination-port-number | source-port source-port-number | vlan vlan-id | vni vxlan-id | pt pt-value | clock-rate clock-rate-value ] *
undo flow
No UDP data flow is specified for an eMDI instance.
eMDI instance view
pt pt-value: Specifies the RTP packet payload type of the data flow, in the range of 25 to 71 or 77 to 127.
clock-rate clock-rate-value: Specifies the RTP packet clock frequency. The available values include 8000 Hz, 16000 Hz, and 90000 Hz. The default value is 90000 Hz. The specified RTP packet clock frequency must be the sampling frequency of the data flow. If not, the calculated jitter values cannot reflect the actual situation.
The undo flow command also restores the default eMDI alarm settings and FEC settings.
# Configure eMDI instance eMDI1 to monitor the UDP data flow from 10.0.0.1 to 10.0.0.2.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] flow ipv4 udp source 10.0.0.1 destination 10.0.0.2
instance
Use instance to create an eMDI instance and enter its view, or enter the view of an existing eMDI instance.
Use undo instance to delete an eMDI instance.
instance instance-name
undo instance instance-name
No eMDI instance exists.
eMDI view
instance-name: Specifies the name for the eMDI instance, a case-sensitive string of 1 to 31 characters.
eMDI instances are fundamental elements of the eMDI feature. Each eMDI instance monitors one data flow as defined by its parameters, including the lifetime, monitoring period, and alarm thresholds.
To view the maximum number of eMDI instances that the device can run at the same time, execute the display emdi resource command.
# Create an eMDI instance named eMDI1.
[Sysname] emdi
lifetime
Use lifetime to specify the eMDI instance lifetime.
Use undo lifetime to restore the default.
lifetime { seconds seconds | minutes minutes | hours hours | days days }
undo lifetime
The eMDI instance lifetime is 1 hour.
eMDI instance view
seconds seconds: Specifies the lifetime in seconds. The value range is 300 to 604800.
minutes minutes: Specifies the lifetime in minutes. The value range is 5 to 10080.
hours hours: Specifies the lifetime in hours. The value range is 1 to 168.
days days: Specifies the lifetime in days. The value range is 1 to 7.
An eMDI instance starts to operate after you use the start command to start it, and it stops when its lifetime expires.
To change the lifetime for an eMDI instance that is already started, you must stop the instance first by executing the stop command.
# Set the lifetime to 300 seconds for eMDI instance eMDI1.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] lifetime seconds 300
monitor-period
Use monitor-period to specify the monitoring period for an eMDI instance.
Use undo monitor-period to restore the default.
monitor-period period-value
undo monitor-period
The monitoring period for an eMDI instance is 60 seconds.
eMDI instance view
period-value: Specifies the monitoring period, which can be 10, 30, or 60 seconds.
The eMDI instance obtains monitoring data from the device periodically.
To change the monitoring period for an eMDI instance that is already started, you must stop the instance first by executing the stop command.
# Set the monitoring period to 10 seconds for eMDI instance eMDI1.
[Sysname] emdi
[Sysname-emdi-instance-eMDI1] monitor-period 10
reset emdi statistics
Use reset emdi statistics to clear eMDI statistics.
reset emdi statistics [ instance-name instance-name | instance-id instance-id-value ]
instance instance-name: Specifies an instance by its name, a case-sensitive string of 1 to 31 characters.
instance-id instance-id: Specifies an instance by its ID. If you do not specify this option, this command displays information about all instances.
If you do not specify the instance instance-name or instance-id instance-id option, this command clears statistics about all static instances.
The dynamic instance is identified only by its ID. With the instance instance-name option specified, this command clears statistics about the specified static instance.
With the instance-id instance-id option specified, this command clears statistics about the specified instances whatever the instance is static or dynamic.
# Clear statistics about eMDI instance eMDI1.
<Sysname> reset emdi statistics instance-name eMDI1
snmp-agent trap enable emdi
Use snmp-agent trap enable emdi to enable SNMP notifications for eMDI.
Use undo snmp-agent trap enable emdi to disable SNMP notifications for eMDI.
SNMP notifications are disabled for eMDI.
With SNMP notifications enabled for the eMDI module, this module can generate alarms to report important events of this module. The generated alarms are sent to the SNMP module of the device. You can specify how the alarms are output through setting the alarm output parameters in SNMP. For more information about configuring SNMP, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for the eMDI module.
[Sysname] snmp-agent trap enable emdi
start
Use start to start an eMDI instance.
start
eMDI instance view
A started eMDI instance automatically stops upon a master/subordinate or active/standby switchover. You must execute this command again to start the instance.
To modify the configuration for an eMDI instance that is already started, stop the instance first by executing the stop command.
# Start eMDI instance eMDI2.
[Sysname] emdi
[Sysname-emdi-instance-eMDI2] flow ipv4 udp source 10.0.0.1 destination 10.0.0.2
[Sysname-emdi-instance-eMDI2] start
flow ipv4 tcp
flow ipv4 udp
stop
Use stop to stop an eMDI instance.
stop
eMDI instance view
# Stop eMDI instance eMDI2.
[Sysname] emdi
[Sysname-emdi-instance-eMDI2] stop
stop all
Use stop all to stop all eMDI instances.
stop all
eMDI view
This command stops all running static instances.
# Stop all eMDI instances.
[Sysname] emdi
[Sysname-emdi] stop all
