09-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X-HI[EI][SI]&S6520-SI&S5560X-HI&S5000-EI&MS4600 Command References-R68xx-6W10009-Security Command Reference
02-802.1X commands
02-802.1X commands 556.88 KB
802.1X commands· 1
display dot1x· 1
display dot1x access-profile· 7
display dot1x connection· 10
display dot1x mac-address· 15
display dot1x unicast-trigger quiet-mac· 18
dot1x· 18
dot1x { ip-verify-source | ipv6-verify-source } enable· 19
dot1x access-profile· 20
dot1x access-profile name· 21
dot1x access-user log enable· 22
dot1x after-mac-auth max-attempt 23
dot1x authentication-method· 24
dot1x auth-fail eapol 25
dot1x auth-fail vlan· 26
dot1x auth-fail vsi 26
dot1x auth-server-unavailable escape· 27
dot1x critical eapol 28
dot1x critical microsegment 29
dot1x critical profile· 30
dot1x critical vlan· 31
dot1x critical vsi 32
dot1x critical-voice-vlan· 33
dot1x domain-delimiter 34
dot1x duplicate-eapol-start discard· 35
dot1x ead-assistant enable· 35
dot1x ead-assistant free-ip· 36
dot1x ead-assistant free-microsegment 37
dot1x ead-assistant permit authentication-escape· 38
dot1x ead-assistant url 39
dot1x eap-success post-authorization· 40
dot1x eap-tls-fragment to-server 41
dot1x eapol untag· 42
dot1x guest-vlan· 43
dot1x guest-vlan-delay· 44
dot1x guest-vsi 45
dot1x guest-vsi-delay· 46
dot1x handshake· 47
dot1x handshake reply enable· 48
dot1x handshake secure· 48
dot1x mac-binding· 49
dot1x mac-binding enable· 50
dot1x mandatory-domain· 51
dot1x max-user 52
dot1x max-user-alarm·· 52
dot1x multicast-trigger 54
dot1x packet-detect enable· 54
dot1x packet-detect retry· 56
dot1x port-control 57
dot1x port-method· 57
dot1x quiet-period· 58
dot1x re-authenticate· 59
dot1x re-authenticate manual 60
dot1x re-authenticate server-unreachable keep-online· 60
dot1x retry· 61
dot1x server-recovery online-user-sync· 62
dot1x timer 63
dot1x timer reauth-period· 66
dot1x unauthenticated-user aging enable· 67
dot1x unicast-trigger 68
dot1x user-ip freeze· 69
reset dot1x access-user 70
reset dot1x guest-vlan· 71
reset dot1x guest-vsi 71
reset dot1x statistics· 72
reset dot1x unicast-trigger quiet-mac· 72
snmp-agent trap enable dot1x· 73
802.1X commands
Only the S5560X-HI switch series and S6520X-HI switch series support microsegment-related commands and parameters.
display dot1x
Use display dot1x to display information about 802.1X.
display dot1x [ sessions | statistics ] [ interface interface-type interface-number ]
sessions: Displays 802.1X session information.
statistics: Displays 802.1X statistics.
interface interface-type interface-number: Specifies a port by its type and number.
If you do not specify the sessions keyword or the statistics keyword, this command displays all information about 802.1X, including session information, statistics, and settings.
If you do not specify the interface interface-type interface-number option, this command displays all global and port-specific 802.1X information.
# Display all information about 802.1X.
<Sysname> display dot1x
Global 802.1X parameters:
   802.1X authentication                      : Enabled
   M-LAG member configuration conflict        : Unknown
   EAP authentication                         : Enabled
   Max-tx period                              : 30 s
   Handshake period                           : 15 s
   Quiet timer                                : Disabled
         Quiet period                         : 60 s
   Supp timeout                               : 30 s
   Server timeout                             : 100 s
   Reauth period                              : 3600 s
   Unicast-trigger quiet period               : 0 s
   Max auth requests                          : 2
   User aging period for Auth-Fail VLAN       : 1000 s
   User aging period for Auth-Fail VSI        : 1000 s
   User aging period for critical VLAN        : 1000 s
   User aging period for critical VSI         : 1000 s
   User aging period for guest VLAN           : 1000 s
   User aging period for guest VSI            : 1000 s
   User aging period for critical microsegment: 1000 s
   EAD assistant function                     : Disabled
       Permit authentication-escape           : Disabled
       URL                                    : https://www.example.com
           Track                              : Not configured
       Secondary URL                          : https://www.example.com
           Track                              : 11  (Positive)
       Free IP                                : 6.6.6.0         255.255.255.0
       Free microsegment IDs                  : 1234
       EAD timeout                            : 30 min
   Domain delimiter                           : @
   Max EAP-TLS fragment (to-server)           : 400 bytes
   Max-user-alarm trigger threshold           : 100%
   Max-user-alarm clear threshold             : 50%
 Online 802.1X wired users                    : 1
 Ten-GigabitEthernet1/0/1  is link-up
   Access profile name                        : d1
   Handshake                                  : Enabled
   Handshake reply                            : Disabled
   Handshake security                         : Disabled
   Packet detection                           : Enabled(NOT effective)
   Unicast trigger                            : Disabled
   Periodic reauth                            : Enabled
       Reauth period                          : 120 s
   Port role                                  : Authenticator
   Authorization mode                         : Auto
   Port access control                        : MAC-based
   Multicast trigger                          : Enabled
   Mandatory auth domain                      : Not configured
   Guest VLAN                                 : 3
   Auth-Fail VLAN                             : Not configured
   Critical VLAN                              : Not configured
   Critical voice VLAN                        : Disabled
   Add Guest VLAN delay                       : Disabled
   Re-auth server-unreachable                 : Logoff
   Max online users                           : 4294967295
   Max online preauth-domain users            : 4294967295
   Max online Auth-Fail-domain users          : 4294967295
   User IP freezing                           : Disabled
   Reauth period                              : 0 s
   Send Packets Without Tag                   : Disabled
   Max Attempts Fail Number                   : Not configured
   Guest VSI                                  : Not configured
   Auth-Fail VSI                              : Not configured
   Critical VSI                               : Not configured
   Add Guest VSI delay                        : Disabled
   Critical microsegment ID                   : 123
   Critical profile                           : Not configured
   Unauthenticated-user aging                 : Enabled
   Server-recovery online-user-sync           : Enabled
   Auth-Fail EAPOL                            : Disabled
   Critical EAPOL                             : Disabled
   Discard duplicate EAPOL-Start              : No
   Auth-server-unavailable escape             : Enabled
   EAPOL packets: Tx 3, Rx 3
   Sent EAP Request/Identity packets : 1
        EAP Request/Challenge packets: 1
        EAP Success packets: 1
        EAP Failure packets: 0
   Received EAPOL Start packets : 1
            EAPOL LogOff packets: 1
            EAP Response/Identity packets : 1
            EAP Response/Challenge packets: 1
            Error packets: 0
   Online 802.1X users: 1
          MAC address         Auth state
          0001-0000-0000      Authenticated
Global 802.1X configuration.
Whether 802.1X is enabled globally.
M-LAG member configuration check result:
·     Conflicted—The configuration on one M-LAG member device conflicts with that on the other M-LAG member device.
·     Not conflicted—The configuration on one M-LAG member device does not conflict with that on the other M-LAG member device.
·     Unknown—The system cannot detect whether the configuration on one M-LAG member device conflicts with that on the other M-LAG member device.
CHAP authentication
Performs EAP termination and uses CHAP to communicate with the RADIUS server.
EAP authentication
Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
PAP authentication
Performs EAP termination and uses PAP to communicate with the RADIUS server.
Max-tx period
Username request timeout timer in seconds.
Handshake period
Handshake timer in seconds.
Quiet timer
Status of the quiet timer, enabled or disabled.
Quiet period
Quiet timer in seconds.
Supp timeout
Client timeout timer in seconds.
Server timeout
Server timeout timer in seconds.
Reauth period
Periodic reauthentication timer in seconds.
Unicast-trigger quiet timer. If this timer starts for an unknown source MAC address, the unicast trigger will not send requests to that MAC address until after this timer expires.
Max auth requests
Maximum number of attempts for sending an authentication request to a client.
Aging timer in seconds for users in Auth-Fail VLANs.
Aging timer in seconds for users in Auth-Fail VSIs.
Aging timer in seconds for users in critical VLANs.
Aging timer in seconds for users in critical VSIs.
Aging timer in seconds for users in guest VLANs.
Aging timer in seconds for users in the guest VSIs.
Aging timer in seconds for users in critical microsegments.
Whether EAD assistant is enabled.
Support for correctly using Auth-Fail VLANs or VSIs or critical VLANs or VSIs when 802.1X EAD assistant is enabled.
URL
Redirect URL for unauthenticated users using a Web browser to access the network.
Secondary URL
Secondary redirect URL for unauthenticated users using a Web browser to access the network.
Track
Number of the track entry associated with the redirect URL and the track entry state.
If the redirect URL is not associated with a track entry, this field displays Not configured.
Free IP
Network segment accessible to unauthenticated users.
IDs of the microsegments accessible to unauthenticated users.
EAD timeout
EAD rule timer in minutes.
Domain delimiter
Domain delimiters supported by the device.
Maximum size of EAP-TLS fragments sent in authentication packets to the server.
If no maximum size is set, this field displays N/A.
Alarm threshold for 802.1X user access ratio, in percentage.
Alarm clear threshold for 802.1X user access ratio, in percentage.
Number of wired online 802.1X users, including users that have passed 802.1X authentication and users that are performing 802.1X authentication.
Status of the port. In this example, Ten-GigabitEthernet 1/0/1 is up.
Whether 802.1X is enabled on the port.
Access profile name
Name of an 802.1X access profile. If no 802.1X access profile is applied to the port, this field displays Not configured.
Handshake
Whether the online user handshake feature is enabled on the port.
Handshake reply
Whether the online user handshake reply feature is enabled on the port.
Handshake security
Whether the online user handshake security feature is enabled on the port.
Packet detection
Status of packet detection for 802.1X authentication:
·     Enabled—This feature is enabled and effective.
·     Disabled—This feature is disabled.
·     Enabled(NOT effective)—This feature is enabled but it does not take effect. This state is displayed when the port access control mode is port-based.
Unicast trigger
Whether the 802.1X unicast trigger is enabled on the port.
Periodic reauth
Whether 802.1X periodic reauthentication is enabled on the port.
Reauth period
Periodic reauthentication timer on the port.
If no periodic reauthentication timer is configured on the port, this field displays N/A.
If 802.1X periodic reauthentication is not enabled on the port, this field is not available.
Port role
Role of the port. The port functions only as an Authenticator.
Authorization mode
Authorization state of the port, which can be Force-Authorized, Auto, or Force-Unauthorized.
Port access control
Access control method of the port:
·     MAC-based—MAC-based access control.
·     Port-based—Port-based access control.
Multicast trigger
Whether the 802.1X multicast trigger feature is enabled.
Mandatory authentication domain on the port.
Guest VLAN
802.1X guest VLAN configured on the port.
If no 802.1X guest VLAN is configured on the port, this field displays Not configured.
Auth-Fail VLAN
802.1X Auth-Fail VLAN configured on the port.
If no 802.1X Auth-Fail VLAN is configured on the port, this field displays Not configured.
Critical VLAN
802.1X critical VLAN configured on the port.
If no 802.1X critical VLAN is configured on the port, this field displays Not configured.
Critical voice VLAN
Whether the 802.1X critical voice VLAN feature is enabled on the port.
Status and mode of the 802.1X guest VLAN assignment delay feature on a port:
·     EAPOL—EAPOL-triggered 802.1X guest VLAN assignment delay is enabled.
·     NewMac—New MAC-triggered 802.1X guest VLAN assignment delay is enabled.
·     ALL—Both EAPOL-triggered and new MAC-triggered 802.1X guest VLAN assignment delays are enabled.
·     Disabled—802.1X guest VLAN assignment delay is disabled.
Whether to log off online 802.1X users or keep them online when no server is reachable for 802.1X reauthentication.
Max online users
Maximum number of concurrent 802.1X users on the port.
Maximum number of 802.1X users in the preauthentication domain on the port.
Maximum number of 802.1X users in the Auth-Fail domain on the port.
User IP freezing
Whether user IP freezing is enabled on the port.
Reauth period
Periodic reauthentication timer in seconds on the port.
Whether to remove the VLAN tags of all 802.1X protocol packets sent out of the port to 802.1X clients.
Maximum number of 802.1X authentication attempts for MAC authenticated users.
Guest VSI
802.1X guest VSI configured on the port.
If no 802.1X guest VSI is configured on the port, this field displays Not configured.
Auth-Fail VSI
802.1X Auth-Fail VSI configured on the port.
If no 802.1X Auth-Fail VSI is configured on the port, this field displays Not configured.
Critical VSI
802.1X critical VSI configured on the port.
If no 802.1X critical VSI is configured on the port, this field displays Not configured.
Add Guest VSI delay
Status and mode of the 802.1X guest VSI assignment delay feature on a port:
·     EAPOL only—EAPOL-triggered 802.1X guest VSI assignment delay is enabled.
·     NewMAC only—New MAC-triggered 802.1X guest VSI assignment delay is enabled.
·     EAPOL or NewMAC—Both EAPOL-triggered and new MAC-triggered 802.1X guest VSI assignment delays are enabled.
·     Disabled—802.1X guest VSI assignment delay is disabled.
802.1X critical microsegment ID configured on the port.
If no 802.1X critical microsegment is configured on the port, this field displays Not configured.
Critical profile
Critical profile for users that fail 802.1X authentication because no RADIUS servers are reachable.
If no critical profile is configured for 802.1X users on the port, this field displays Not configured.
Status of 802.1X unauthenticated user aging on a port:
·     Enabled.
·     Disabled.
Status of 802.1X online user synchronization:
·     Enabled.
·     Disabled.
Auth-Fail EAPOL
This field displays whether the device sends EAP-Success packets to 802.1X clients on their assignment to the 802.1X Auth-Fail VLAN or VSI on the port.
Critical EAPOL
This field displays whether the device sends EAP-Success packets to 802.1X clients on their assignment to the 802.1X critical VLAN or VSI on the port.
Whether the device discards duplicate EAPOL-Start requests on the port.
Whether the online 802.1X users can escape from offline detection to stay online when all RADIUS servers are unreachable.
Available options:
·     Enabled—Online 802.1X users can escape from offline detection to stay online when all RADIUS servers are unreachable.
·     Disabled—Online 802.1X users cannot escape from offline detection when all RADIUS servers are unreachable.
EAPOL packets
Number of sent (Tx) and received (Rx) EAPOL packets.
Number of sent EAP-Request/Identity packets.
Number of sent EAP-Request/MD5-Challenge packets.
EAP Success packets
Number of sent EAP-Success packets.
EAP Failure packets
Number of sent EAP-Failure packets.
Number of received EAPOL-Start packets.
Number of received EAPOL-LogOff packets.
Number of received EAP-Response/Identity packets.
Number of received EAP-Response/MD5-Challenge packets.
Error packets
Number of received error packets.
Online 802.1X users
Number of online 802.1X users on the port, including users that have passed 802.1X authentication and users that are performing 802.1X authentication.
MAC address
MAC addresses of the online 802.1X users.
Auth state
Authentication status of the online 802.1X users.
Use display dot1x access-profile to display information about 802.1X access profiles.
display dot1x access-profile [ name profile-name ]
name profile-name: Specifies an 802.1X access profile by its name, a case-insensitive string of 1 to 31 characters. If you do not specify an 802.1X access profile, this command displays brief information for all 802.1X access profiles.
Use this command to verify the configuration of 802.1X access profiles.
# Display brief information for all 802.1X access profiles.
<Sysname> display dot1x access-profile
Total number: 2
Profile name                     Packet detection
aaa                              Disabled
bbb                              Disabled
# Display information about 802.1X access profile profile1.
<Sysname> display dot1x access-profile name profile1
Handshake                                  : Enabled
Guest VLAN                                 : 3
Packet detection retry times               : 2
Total auth-profiles bound to the access profile: 3
   Authprofile1
   Authprofile2
   Authprofile3
Profile name
Handshake
Status of online user handshake:
·     Enabled.
·     Disabled.
Unicast trigger
Status of unicast trigger:
·     Enabled.
·     Disabled.
Guest VLAN
Guest VLAN configured in the 802.1X access profile. If no guest VLAN is configured, this field displays Not configured.
Auth-Fail VLAN
Auth-Fail VLAN configured in the 802.1X access profile. If no Auth-Fail VLAN is configured, this field displays Not configured.
Critical VLAN
Critical VLAN configured in the 802.1X access profile. If no critical VLAN is configured, this field displays Not configured.
Max online users
Maximum number of concurrent 802.1X users on a port.
Maximum number of 802.1X users in the preauthentication domain on a port.
Maximum number of 802.1X users in the Auth-Fail domain on a port.
Packet detection
Status of the packet detection feature for 802.1X authentication:
·     Enabled.
·     Disabled.
Maximum number of attempts for sending a detection packet to a user.
Number of port security authentication profiles to which the 802.1X access profile is bound.
Guest VSI
Guest VSI configured in the 802.1X access profile. If no guest VSI is configured, this field displays Not configured.
Auth-Fail VSI
Auth-Fail VSI configured in the 802.1X access profile. If no Auth-Fail VSI is configured, this field displays Not configured.
Critical VSI
Critical VSI configured in the 802.1X access profile. If no critical VSI is configured, this field displays Not configured.
Add Guest VSI delay
Critical microsegment ID configured in the 802.1X access profile. If no critical microsegment ID is configured, this field displays Not configured.
Critical profile
Critical profile for users that fail 802.1X authentication because no RADIUS servers are reachable. If no critical profile is configured for 802.1X users, this field displays Not configured.
Use display dot1x connection to display information about online 802.1X users.
display dot1x connection [ open ] [ [ m-lag [ local | peer ] ] [ interface interface-type interface-number | online-type { auth-fail-domain | critical-domain | preauth-domain | success } | slot slot-number | user-name name-string ] | user-mac mac-address ]
open: Displays information only about 802.1X users that use nonexistent usernames or incorrect passwords for network access in open authentication mode. If you do not specify this keyword, the command displays information about all online 802.1X users.
m-lag [ local | peer ]: Specifies online 802.1X users on M-LAG interfaces. If you do not specify these keywords, the command does not distinguish online 802.1X users on M-LAG interfaces and non-M-LAG interfaces. If you specify the m-lag keyword without the local or peer keyword, the command displays information about online 802.1X users on both the local and peer M-LAG member devices.
·     local: Displays information about online 802.1X users on the local M-LAG member device.
·     peer: Displays information about online 802.1X users on the peer M-LAG member device.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays online 802.1X user information for all ports.
online-type: Specifies a type of online 802.1X users.
·     auth-fail-domain: Specifies 802.1X users in the Auth-Fail domain.
·     critical-domain: Specifies 802.1X users in the critical domain.
·     preauth-domain: Specifies 802.1X users in the preauthentication domain.
·     success: Specifies users that have passed 802.1X authentication.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays online 802.1X user information for all member devices.
user-mac mac-address: Specifies an 802.1X user by MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an 802.1X user, this command displays all online 802.1X user information.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters. If you do not specify an 802.1X user, this command displays all online 802.1X user information.
# Display information about all online 802.1X users.
<Sysname> display dot1x connection
Total connections: 1
Slot ID: 1
Username: ias
User access state: Successful
Authentication domain: aaa
IPv4 address: 192.168.1.1
IPv4 address source: User packet
IPv6 address source: User packet
EAP packet identifier: 4
Authentication method: CHAP
AAA authentication method: RADIUS
Initial VLAN: 1
Authorization untagged VLAN: 6
Authorization tagged VLAN list: 1 to 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 29 31 33
                                35 37 40 to 100
Authorization VSI: N/A
Authorization microsegment ID: N/A
Authorization dynamic ACL name: N/A
Authorization CAR: N/A
Authorization URL: N/A
Authorization IPv6 URL: N/A
Authorization temporary redirect: Disabled
Start accounting: Successful
Real-time accounting-update failures: 0
Termination action: Default
Session timeout period: 2 sec
Offline detection: 100 sec (command-configured)
Remaining reauth attempts: 2
Packet detection:
  Max attempts: 5
  Remaining attempts: 3
  Source IPv4 address: 192.168.1.3
  Source IPv4 mask: 255.255.0.0
Topology change detection:
  Max attempts: 5
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
User MAC address: 0015-e9a6-abcd
M-LAG NAS-IP type: Local
M-LAG user state: Active
Access interface: Bridge-Aggregation1
Username: luser (UserLoginMab)
Initial VLAN: 1
                                35 37 40 to 100
Authorization CAR:
  Average input rate: 102400 kbps
  Peak input rate: 204800 kbps
  Average output rate: 102400 kbps
  Peak output rate: 204800 kbps
  Max attempts: 5
Online from: 2020/12/02  13:14:15
Online duration: 0h 7m 15s
Total connections
Number of online 802.1X users.
User MAC address
MAC address of the user.
M-LAG NAS-IP type
NAS-IP address type for the user if the user is authenticated on an M-LAG interface of the M-LAG system.
·     Local—Local NAS-IP address. The source IP address of outgoing RADIUS packets is an IP address on the local M-LAG member device.
·     Peer—Peer NAS-IP address. The source IP address of outgoing RADIUS packets is an IP address on the peer M-LAG member device.
M-LAG user state
Local state of the user on the M-LAG interface:
·     Active—The local M-LAG member device exchanges user authentication information with the AAA server.
·     Inactive—The peer M-LAG member device exchanges user authentication information with the AAA server.
Access interface
Interface through which the user access the device.
Username
Username. If the user came online through 802.1X MAC bypass authentication, this field also displays UserLoginMab. If the user came online through standard 802.1X authentication, this field does not displays UserLoginMab.
User access state
Access state of the user.
·     Auth-Fail domain—The user is in the Auth-Fail domain.
·     Critical domain—The user is in the critical domain.
·     Preauth domain—The user is in the preauthentication domain.
·     Successful—The user passes 802.1X authentication and comes online.
·     Open—The user uses a nonexistent username or an incorrect password to come online in open authentication mode.
ISP domain used for 802.1X authentication.
IPv4 address
IPv4 address of the user.
If the device does not get the IPv4 address of the user, this field is not available.
IPv6 address
IPv6 address of the user.
If the device does not get the IPv6 address of the user, this field is not available.
IPv4 address source
Source of the user IPv4 address:
·     User packet—The IPv4 address was obtained from a user packet.
·     IP Source Guard—The IPv4 address was received from the IP source guard module.
IPv6 address source
Source of the user IPv6 address:
·     User packet—The IPv6 address was obtained from a user packet.
·     IP Source Guard—The IPv6 address was received from the IP source guard module.
EAP packet identifier of the user.
EAP message handling method in 802.1X:
·     CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server.
AAA authentication method used for the user to come online:
·     Local—Local authentication.
·     RADIUS—RADIUS authentication.
·     None—No authentication was performed.
·     N/A—User came online with restricted access because of an unsuccessful authentication attempt. For example, the user might have been placed in a critical domain or authen-fail domain.
Initial VLAN
VLAN to which the user belongs before 802.1X authentication.
Untagged VLAN authorized to the user.
The VLAN assigned by the server to a user as an authorization VLAN might have been configured on the user access port but with a different tagging mode. For example, the server assigns an authorization VLAN with a tagged attribute, but the same VLAN configured on the port has an untagged attribute. In this situation, if the link type of the port is hybrid, the VLAN settings configured on the port take effect on the user. For more information, see 802.1X in Security Configuration Guide.
Tagged VLANs authorized to the user.
Authorization VSI
VSIs authorized to the user.
Microsegment ID authorized to the user.
Number or name of the static ACL authorized to the user.
If no static ACL has been authorized to the user, this field displays N/A.
If ACL authorization failed, this field displays (NOT effective) next to the ACL number or name.
Name of the dynamic ACL authorized to the user.
If no dynamic ACL has been authorized to the user, this field displays N/A.
If ACL authorization failed, this field displays (NOT effective) next to the ACL name.
User profile authorized to the user.
Authorization CAR
Authorization CAR attributes assigned by the server.
·     Average input rate—Average rate of inbound traffic in kbps.
·     Peak input rate—Peak rate of inbound traffic in kbps.
·     Average output rate—Average rate of outbound traffic in kbps.
·     Peak output rate—Peak rate of outbound traffic in kbps.
If the device fails to assign the CAR attributes to the user, the Authorization CAR field displays (NOT effective).
If the server does not assign the peak rates, the peak rates by default are the same as the assigned average rates. In the current software version, the device does not support exclusive assignment of peak rates from the server.
If no authorization CAR attributes are assigned, this field displays N/A.
Authorization URL
Redirect URL authorized to the user.
IPv6 redirect URL authorized to the user.
State of temporary redirection authorization:
·     Enabled—Temporary redirection is authorized. The HTTP or HTTPS redirection packets sent to the user include state code 302.
·     Disabled—Temporary redirection is not authorized. The HTTP or HTTPS redirection packets sent to the user include state code 200.
Start accounting
Start-accounting request result:
·     Successful.
·     Failed.
The device does not support accounting for users in the preauthentication domain. For such users, this field displays N/A.
Number of consecutive real-time accounting-update failures.
Termination action
Action attribute assigned by the server to terminate the user session:
·     Default—Logs off the online authenticated 802.1X user when the server-assigned session timeout timer expires. This attribute does not take effect when 802.1X periodic reauthentication is enabled and the periodic reauthentication timer is shorter than the server-assigned session timeout timer.
·     RADIUS-request—Reauthenticates the online user when the server-assigned session timeout timer expires, regardless of whether the 802.1X periodic reauthentication feature is enabled or not.
If the device performs local authentication, this field displays Default.
Session timeout timer assigned by the server.
Offline detection
Offline detection method for the user:
·     timer (command-configured)—The offline detection timer value configured from the CLI. The timer argument represents the timer value.
·     Ignore (server-assigned)—The RADIUS server instructed the device to detect the offfline state of the user.
·     timer (server-assigned)—The offline detection timer value assigned by the RADIUS server. The timer argument represents the timer value.
Remaining number of reauthentication attempts.
Packet detection
Information about the packet detection feature.
Information about ARP or NS packet detection after a topology change.
Max attempts
Maximum number of attempts for sending a detection packet to the user.
Remaining attempts
Remaining number of attempts for sending a detection packet to the user. The device decreases the number by 1 each time it makes an attempt to send the detection packet to the user.
Source IPv4 address
IP address specified for calculating the source IP address of ARP detection packets.
If no IP address is specified, this field displays 0.0.0.0.
Source IPv4 mask
Mask specified for calculating the source IP address of ARP detection packets.
If no mask is specified, this field displays 0.0.0.0.
Online from
Time from which the 802.1X user came online.
Online duration
Online duration of the 802.1X user.
Use display dot1x mac-address to display the MAC addresses of 802.1X users in a type of 802.1X microsegment, VLAN, or VSI.
display dot1x mac-address { auth-fail-vlan | auth-fail-vsi | critical-microsegment | critical-vlan | critical-vsi | guest-vlan | guest-vsi } [ interface interface-type interface-number ]
auth-fail-vlan: Specifies 802.1X Auth-Fail VLANs.
auth-fail-vsi: Specifies 802.1X Auth-Fail VSIs.
critical-microsegment: Specifies 802.1X critical microsegments.
critical-vlan: Specifies 802.1X critical VLANs.
critical-vsi: Specifies 802.1X critical VSIs.
guest-vlan: Specifies 802.1X guest VLANs.
guest-vsi: Specifies 802.1X guest VSIs.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays the MAC addresses of 802.1X users in the specified type of 802.1X microsegment, VLAN, or VSI on all ports.
The displayed MAC addresses and MAC address count might not include all MAC addresses if a large number of 802.1X users are performing authentication frequently.
# Display the MAC addresses of 802.1X users in the 802.1X Auth-Fail VLANs on all ports.
<Sysname> display dot1x mac-address auth-fail-vlan
Total MAC addresses: 10
Interface: Ten-GigabitEthernet1/0/1        Auth-Fail VLAN: 3    Aging time: N/A
MAC addresses: 8
  0800-2700-9427    0800-2700-2341    0800-2700-2324    0800-2700-2351
  0800-2700-5627    0800-2700-2251    0800-2700-8624    0800-2700-3f51
Interface: Ten-GigabitEthernet1/0/2        Auth-Fail VLAN: 5    Aging time: 30 sec
MAC addresses: 2
  0801-2700-9427    0801-2700-2341
# Display the MAC addresses of 802.1X users in the 802.1X Auth-Fail VSIs on all ports.
<Sysname> display dot1x mac-address auth-fail-vsi
Interface: Ten-GigabitEthernet1/0/3        Auth-Fail VSI: text-vsi   Aging time: N/A
MAC addresses: 8
Interface: Ten-GigabitEthernet1/0/4        Auth-Fail VSI: text1-vsi   Aging time: 30 sec
MAC addresses: 2
# Display the MAC addresses of 802.1X users in the 802.1X critical microsegments on all ports.
<Sysname> display dot1x mac-address critical-microsegment
Interface: Ten-GigabitEthernet1/0/1        Critical microsegment: 1   Aging time: N/A
MAC addresses: 8
Interface: Ten-GigabitEthernet1/0/2        Critical microsegment: 1   Aging time: 30 sec
MAC addresses: 2
Total MAC addresses
Total number of MAC addresses in the specified type of microsegment, VLAN, or VSI on the specified port or all ports.
Access port of 802.1X users.
Type microsegment/VLAN/VSI
Microsegment, VLAN, or VSI that contains the 802.1X users.
Available microsegment, VLAN, and VSI types:
·     Auth-Fail VLAN.
·     Auth-Fail VSI.
·     Critical microsegment.
·     Critical VLAN.
·     Critical VSI.
·     Guest VLAN.
·     Guest VSI.
Aging time
MAC address aging time in seconds.
This field displays N/A if the MAC addresses do not age out.
MAC addresses
Number of matching MAC addresses on a port.
xxxx-xxxx-xxxx
MAC address.
dot1x auth-fail vsi
dot1x critical vlan
dot1x critical vsi
dot1x guest-vlan
dot1x guest-vsi
Use display dot1x unicast-trigger quiet-mac to display unknown source MAC addresses in the unicast-trigger quiet period.
display dot1x unicast-trigger quiet-mac [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays all unknown source MAC addresses in the unicast-trigger quiet period.
After the unicast-trigger quiet timer starts for an unknown source MAC address, that MAC address will stay in the unicast-trigger quiet period until the timer expires.
# Display all unknown source MAC addresses in the unicast-trigger quiet period
<Sysname> display dot1x unicast-trigger quiet-mac
Total unicast-trigger quiet MAC addresses: 1
 MAC address           VLAN ID         Interface
 0800-2700-a4f7        1               GE1/0/1
Table 5 Command output
Current total number of source MAC addresses in the unicast-trigger quiet period.
MAC address
Source MAC address in the unicast-trigger quiet period.
VLAN ID
VLAN in which the MAC address is located.
Port to which the MAC address is attached.
dot1x timer
dot1x
Use dot1x to enable 802.1X globally or on a port.
Use undo dot1x to disable 802.1X globally or on a port.
dot1x
undo dot1x
802.1X is neither enabled globally nor enabled for any port.
For the 802.1X feature to take effect on a port, you must enable the feature both globally and on the port.
# Enable 802.1X globally.
[Sysname] dot1x
# Enable 802.1X on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x
display dot1x
Use dot1x { ip-verify-source | ipv6-verify-source } enable to enable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users.
Use undo dot1x { ip-verify-source | ipv6-verify-source } enable to disable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users.
Generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users is enabled.
IMPORTANT
IMPORTANT:
This feature must operate in conjunction with the IP source guard (IPSG) feature.
The dot1x { ip-verify-source | ipv6-verify-source } enable command takes effect only on 802.1X users that come online after the command is used. If the IP address of an online 802.1X user changes, the device will update the dynamic IPv4SG or IPv6SG binding entry for the user.
The undo dot1x { ip-verify-source | ipv6-verify-source } enable command does not delete the existing dynamic IPv4SG or IPv6SG binding entries for online 802.1X users. If the IP address of an online 802.1X user changes after the command is used, the device will delete the dynamic IPv4SG or IPv6SG binding entry for the user.
# Disable generation of dynamic IPv4SG or IPv6SG binding entries for 802.1X authenticated users on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo dot1x ip-verify-source enable
Use dot1x access-profile to bind an 802.1X access profile to a port security authentication profile.
Use undo dot1x access-profile to restore the default.
dot1x access-profile profile-name
undo dot1x access-profile profile-name
No 802.1X access profile is bound to a port security authentication profile.
Port security authentication profile view
Operating mechanism
After you bind a port security authentication profile to an interface:
·     For settings that can be configured both in interface view and 802.1X access profile view (the command lines might differ in the views), the system automatically deletes the settings in interface view regardless of whether the port security authentication profile has been bound to an 802.1X access profile. To use these settings, configure them in the 802.1X access profile bound to the port security authentication profile.
·     For settings that can be configured in interface view but cannot be configured in 802.1X access profile view, they can still take effect after you apply an 802.1X access profile to that interface.
After you bind an 802.1X access profile to a port security authentication profile, the interfaces to which the port security authentication profile is applied will use the settings in the 802.1X access profile to authenticate access users.
To successfully bind an 802.1X access profile to a port security authentication profile, you must first create that 802.1X access profile by using the dot1x access-profile name command in system view.
An 802.1X access profile can be bound to multiple port security authentication profiles, but a port security authentication profile can bind only one 802.1X access profile. To change the 802.1X access profile bound to a port security authentication profile, you must first remove the original binding.
# Bind 802.1X access profile bbb to port security authentication profile aaa.
[Sysname] port-security authentication-profile name aaa
[Sysname-portsec-auth-profile-aaa] dot1x access-profile bbb
Use dot1x access-profile name to create an 802.1X access profile and enter its view, or enter the view of an existing 802.1X access profile.
Use undo dot1x access-profile name to delete an 802.1X access profile.
dot1x access-profile name profile-name
undo dot1x access-profile name profile-name
No 802.1X access profiles exist.
profile-name: Specifies a name for the 802.1X access profile, which is a case-insensitive string of 1 to 31 characters.
Application scenarios
The device uses 802.1X access profiles to manage 802.1X access settings in a unified manner. After you bind an 802.1X access profile to a port security authentication profile, the interfaces to which the port security authentication profile is applied will use the settings in the 802.1X access profile to authenticate access users.
Repeat this command to create multiple 802.1X access profiles.
Deleting the 802.1X access profile bound to a port security authentication profile will cause online users to go offline abnormally if the access profile has taken effect.
# Create an 802.1X access profile named bbb and enter its view.
[Sysname] dot1x access-profile name bbb
[Sysname-dot1x-acc-prof-bbb]
Use dot1x access-user log enable to enable 802.1X user logging.
Use undo dot1x access-user log enable to disable 802.1X user logging.
dot1x access-user log enable [ abnormal-logoff | failed-login | ip-change | maxnum-clear-threshold | maxnum-trigger-threshold | normal-logoff | successful-login ] *
undo dot1x access-user log enable [ abnormal-logoff | failed-login | ip-change | maxnum-clear-threshold | maxnum-trigger-threshold | normal-logoff | successful-login ] *
802.1X user logging is disabled.
abnormal-logoff: Logs exceptional logoffs of 802.1X users, such as logoffs caused by real-time accounting failures or reauthentication failures.
failed-login: Logs 802.1X user login failures.
ip-change: Logs IP address changes of 802.1X users.
maxnum-clear-threshold: Logs alarm clear threshold reaching for 802.1X user access ratio.
maxnum-trigger-threshold: Logs alarm threshold reaching for 802.1X user access ratio.
normal-logoff: Logs logoffs requested by 802.1X users.
successful-login: Logs successful 802.1X user logins.
To prevent excessive 802.1X user log entries, use this feature only if you need to analyze abnormal 802.1X user logins or logouts.
If you do not specify any parameters, this command enables all types of 802.1X user logs.
# Enable logging 802.1X user login failures.
[Sysname] dot1x access-user log enable failed-login
info-center source dot1x logfile deny (Network Management and Monitoring Command Reference)
Use dot1x after-mac-auth max-attempt to set the maximum number of 802.1X authentication attempts for MAC authenticated users on a port.
Use undo dot1x after-mac-auth max-attempt to restore the default.
dot1x after-mac-auth max-attempt max-attempts
The number of 802.1X authentication attempts for MAC authenticated users is not limited on a port.
max-attempts: Specifies a number in the range of 1 to 50.
The device denies 802.1X authentication requests of a MAC authenticated user after the maximum number of 802.1X authentication attempts has been made.
The device will recount the number of 802.1X authentication attempts made by a MAC authenticated user if a user logoff or device reboot event occurs.
On an M-LAG system, one M-LAG member device will recount the number of 802.1X authentication attempts made by a MAC authenticated user if the following conditions exist:
·     The peer link fails.
·     The user's packets are switched to this M-LAG member device after the user fails the maximum number of 802.1X authentication attempts on the other M-LAG member device.
# Configure Ten-GigabitEthernet 1/0/1 to allow a maximum of 10 802.1X authentication attempts made by a MAC authenticated user.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x after-mac-auth max-attempt 10
display dot1x
Use dot1x authentication-method to specify an EAP message handling method.
Use undo dot1x authentication-method to restore the default.
The access device performs EAP termination and uses CHAP to communicate with the RADIUS server.
chap: Configures the access device to perform Extensible Authentication Protocol (EAP) termination and use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
eap: Configures the access device to relay EAP packets, and supports any of the EAP authentication methods to communicate with the RADIUS server.
pap: Configures the access device to perform EAP termination and use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The access device terminates or relays EAP packets.
·     In EAP termination mode—The access device re-encapsulates and sends the authentication data from the client in standard RADIUS packets to the RADIUS server. The device performs either CHAP or PAP authentication with the RADIUS server. In this mode, the RADIUS server supports only MD5-Challenge EAP authentication and the username and password EAP authentication initiated by an iNode client.
¡     PAP transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security. To use PAP, the client can be an iNode 802.1X client.
¡     CHAP transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
·     In EAP relay mode—The access device relays EAP messages between the client and the RADIUS server. The EAP relay mode supports multiple EAP authentication methods, such as MD5-Challenge, EAP-TLS, and PEAP. To use this mode, make sure the RADIUS server meets the following requirements:
¡     Supports the EAP-Message and Message-Authenticator attributes.
¡     Uses the same EAP authentication method as the client.
If this mode is used, the user-name-format command configured in RADIUS scheme view does not take effect. For more information about the user-name-format command, see "RADIUS commands."
If RADIUS authentication is used, you must configure the access device to use the same authentication method (PAP, CHAP, or EAP) as the RADIUS server.
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Sysname] dot1x authentication-method pap
display dot1x
Use dot1x auth-fail eapol to enable the device to send an EAP-Success packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN or VSI on a port.
Use undo dot1x auth-fail eapol to restore the default.
The device sends an EAP-Failure packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN or VSI on a port.
Some 802.1X clients cannot send DHCP requests for IP addresses after they receive EAP-Failure packets. To have these clients obtain IP addresses to access authorized resources after they are assigned to the 802.1X Auth-Fail VLAN or VSI, use this feature.
# Enable the device to send an EAP-Success packet to a client when the client user is assigned to the 802.1X Auth-Fail VLAN or VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x auth-fail eapol
dot1x auth-fail vsi
Use dot1x auth-fail vlan to configure an 802.1X Auth-Fail VLAN on a port.
Use undo dot1x auth-fail vlan to restore the default.
dot1x auth-fail vlan authfail-vlan-id
No 802.1X Auth-Fail VLAN exists on a port.
authfail-vlan-id: Specifies the ID of the 802.1X Auth-Fail VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the Auth-Fail VLAN is not in the tagged VLAN list on the port.
An 802.1X Auth-Fail VLAN accommodates users that have failed 802.1X authentication for any reason other than unreachable servers. Users in the Auth-Fail VLAN can access a limited set of network resources.
You cannot specify a VLAN as both a super VLAN and an 802.1X Auth-Fail VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
On a port, the 802.1X Auth-Fail VLAN configuration is mutually exclusive with the 802.1X guest VSI, 802.1X Auth-Fail VSI, and 802.1X critical VSI settings.
To delete a VLAN that has been configured as an 802.1X Auth-Fail VLAN, you must first use the undo dot1x auth-fail vlan command.
# Configure VLAN 100 as the Auth-Fail VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x auth-fail vlan 100
display dot1x
dot1x auth-fail vsi
Use dot1x auth-fail vsi to configure an 802.1X Auth-Fail VSI on a port.
Use undo dot1x auth-fail vsi to restore the default.
dot1x auth-fail vsi authfail-vsi-name
No 802.1X Auth-Fail VSI exists on a port.
authfail-vsi-name: Specifies the name of the 802.1X Auth-Fail VSI on the port, a case-sensitive string of 1 to 31 characters.
This command is supported only on 802.1X-enabled ports that perform MAC-based access control.
An 802.1X Auth-Fail VSI accommodates users that have failed 802.1X authentication for any reason other than unreachable servers. Users in the 802.1X Auth-Fail VSI can access a limited set of network resources in the VXLAN associated with this VSI.
You can configure only one 802.1X Auth-Fail VSI on a port. The 802.1X Auth-Fail VSIs on different ports can be different.
On a port, the 802.1X Auth-Fail VSI configuration is mutually exclusive with the 802.1X guest VLAN, 802.1X Auth-Fail VLAN, and 802.1X critical VLAN settings.
# Specify VSI vsiuser as the Auth-Fail VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x auth-fail vsi vsiuser
display dot1x
Use dot1x auth-server-unavailable escape to enable online 802.1X users to escape offline detection and stay online when no reachable RADIUS authentication servers are available.
Use undo dot1x auth-server-unavailable escape to disable online 802.1X users from escaping from offline detection when no reachable RADIUS authentication servers are available.
Online 802.1X users cannot escape offline detection (if enabled) to maintain its online status when no reachable RADIUS authentication servers are available.
The 802.1X offline detection feature logs off an online 802.1X user if it has not detected traffic from that user before the offline-detect timer expires. To prevent online 802.1X users on a port from being forced offline by the 802.1X offline detection feature and stay online when none of the RADIUS servers in their ISP domain is reachable, use this command.
Use this feature only when RADIUS scheme authentication is configured for the 802.1X users on a port. If local or no authentication is also configured, offline detection might be undesirably disabled for the 802.1X users when they come online through local authentication or without authentication.
# Enable the online 802.1X users on port Ten-GigabitEthernet 1/0/1 to escape from offline detection and stay online when no reachable RADIUS servers are available.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x auth-server-unavailable escape
dot1x offline-detect enable
Use dot1x critical eapol to enable the sending of an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN or VSI on a port.
Use undo dot1x critical eapol to restore the default.
The device sends an EAP-Failure packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN or VSI on a port.
By default, the device sends EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN or VSI. Some 802.1X clients, for example, Windows built-in 802.1X clients, cannot respond to the EAP-Request/Identity packets from the device for reauthentication if they have received an EAP-Failure packet. As a result, reauthentication for these clients will fail after the authentication server becomes reachable.
To avoid this situation, enable the device to send EAP-Success packets instead of EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN or VSI.
# Send an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN or VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical eapol
dot1x critical vlan
dot1x critical vsi
Use dot1x critical microsegment to configure an 802.1X critical microsegment on a port.
Use undo dot1x critical microsegment to restore the default.
dot1x critical microsegment microsegment-id [ vsi vsi-name ]
No 802.1X critical microsegment is configured on a port.
microsegment-id: Specifies a microsegment by its ID. The value range for the microsegment ID is 1 to 65535.
vsi vsi-name: Specifies a VSI for the microsegment. The vsi-name argument is a case-sensitive string of 1 to 31 characters. This option is applicable only to VXLAN networks.
The 802.1X critical microsegment accommodates users that have failed 802.1X authentication because all the remote servers in their ISP domains are unreachable. Users in the critical microsegment can access network resources in the critical microsegment.
You can specify the same or different 802.1X critical microsegments on different ports. A port supports only one 802.1X critical microsegment. You can specify only one VSI for the 802.1X critical microsegment on a port.
On a port, the 802.1X critical microsegment configuration is mutually exclusive with the following settings:
·     802.1X guest, Auth-Fail, and critical VLAN settings.
·     802.1X guest, Auth-Fail, and critical VSI settings.
·     802.1X critical profile settings.
If you execute this command multiple times on a port, the most recent configuration takes effect.
The VSI specified for the 802.1X critical microsegment does not take effect on users already in a VSI.
The 802.1X critical microsegment does not take effect on a port that performs port-based access control.
# Configure microsegment 1 as the 802.1X critical microsegment on Ten-GigabitEthernet 1/0/1 and specify VSI vpna for the critical microsegment.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical microsegment 1 vsi vpna
display dot1x
dot1x guest vlan
dot1x guest vsi
dot1x critical vlan
dot1x critical vsi
Use dot1x critical profile to specify a critical profile for 802.1X users on a port.
Use undo dot1x critical profile to restore the default.
dot1x critical profile profile-name
No critical profile is specified for 802.1X users on a port.
profile-name: Specifies a critical profile by its name, a case-sensitive string of 1 to 31 characters.
The 802.1X critical profile on a port allows users that fail 802.1X authentication because no RADIUS authentication servers are reachable to access network resources defined in the critical profile.
On a port, the 802.1X critical profile settings are mutually exclusive with the 802.1X critical VLAN, critical VSI, and critical microsegment settings.
# Specify critical profile abc for 802.1X users on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical profile abc
aaa critical-profile
display dot1x
dot1x critical vlan
Use dot1x critical vlan to configure an 802.1X critical VLAN on a port.
Use undo dot1x critical vlan to restore the default.
dot1x critical vlan critical-vlan-id
No 802.1X critical VLAN exists on a port.
critical-vlan-id: Specifies the ID of the 802.1X critical VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the critical VLAN is not in the tagged VLAN list on the port.
An 802.1X critical VLAN accommodates users that fail 802.1X authentication because all the RADIUS servers in their ISP domains are unreachable. Users in the critical VLAN can access a limited set of network resources depending on the configuration.
You cannot specify a VLAN as both a super VLAN and an 802.1X critical VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
On a port, the 802.1X critical VLAN configuration is mutually exclusive with the following 802.1X settings:
To delete a VLAN that has been configured as an 802.1X critical VLAN, you must first use the undo dot1x critical vlan command.
# Specify VLAN 100 as the 802.1X critical VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical vlan 100
display dot1x
dot1x critical vsi
Use dot1x critical vsi to configure an 802.1X critical VSI on a port.
Use undo dot1x critical vsi to restore the default.
dot1x critical vsi critical-vsi-name
No 802.1X critical VSI exists on a port.
critical-vsi-name: Specifies the name of the 802.1X critical VSI on the port, a case-sensitive string of 1 to 31 characters.
An 802.1X critical VSI accommodates users that have failed 802.1X authentication because all the RADIUS servers in their ISP domains are unreachable. Users in the 802.1X critical VSI can access a limited set of network resources in the VXLAN associated with this VSI.
You can configure only one 802.1X critical VSI on a port. The 802.1X critical VSIs on different ports can be different.
On a port, the 802.1X critical VSI configuration is mutually exclusive with the following 802.1X settings:
# Specify VSI vsiuser as the 802.1X critical VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical vsi vsiuser
display dot1x
Use dot1x critical-voice-vlan to enable the 802.1X critical voice VLAN feature on a port.
Use undo dot1x critical-voice-vlan to restore the default.
The 802.1X critical voice VLAN feature is disabled on a port.
The 802.1X critical voice VLAN on a port accommodates 802.1X voice users that have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
Before you enable the 802.1X critical voice VLAN feature on the port, make sure the following requirements are met:
·     The port is configured with the voice VLAN.
To configure a voice VLAN on a port, use the voice-vlan enable command (see Layer 2—LAN Switching Command Reference).
·     LLDP is enabled both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP commands, see Layer 2—LAN Switching Command Reference.
·     An 802.1X critical VLAN is configured on the port. This setting ensures that a voice user is assigned to the critical VLAN if it has failed authentication for unreachability of RADIUS servers before the device recognizes it as a voice user. If an 802.1X critical VLAN is not available, the voice user might be logged off instead.
# Enable the 802.1X critical voice VLAN feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x critical-voice-vlan
display dot1x
lldp enable (Layer 2—LAN Switching Command Reference)
lldp global enable (Layer 2—LAN Switching Command Reference)
voice-vlan enable (Layer 2—LAN Switching Command Reference)
Use dot1x domain-delimiter to specify a set of domain name delimiters supported by the device.
Use undo dot1x domain-delimiter to restore the default.
dot1x domain-delimiter string
The device supports only the at sign (@) delimiter for 802.1X users.
string: Specifies a set of 1 to 16 domain name delimiters for 802.1X users. No space is required between delimiters. Available delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
Any character in the configured set can be used as the domain name delimiter for 802.1X authentication users. Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
The delimiter set you configured overrides the default setting. If the at sign (@) is not included in the delimiter set, the device does not support the 802.1X users that use this sign as the domain name delimiter.
If a username string contains multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For example, if you configure the forward slash (/), dot (.), and backslash (\) as delimiters, the domain name delimiter for the username string 121.123/22\@abc is the backslash (\). The username is @abc and the domain name is 121.123/22.
# Specify the at sign (@) and forward slash (/) as domain name delimiters.
[Sysname] dot1x domain-delimiter @/
display dot1x
Use dot1x duplicate-eapol-start discard to discard duplicate EAPOL-Start requests on an interface.
Use undo dot1x duplicate-eapol-start discard to restore the default.
The device does not discard duplicate EAPOL-Start requests on an interface if the requests are legal.
During 802.1X authentication, the device might receive duplicate EAPOL-Start requests from an 802.1X user. By default, the device delivers the duplicate EAPOL-Start requests to the authentication server as long as they are legal. However, this mechanism might result in authentication failure if the authentication server cannot respond to duplicate EAPOL-Start requests. To resolve this issue, use this command on the user access interface to discard duplicate EAPOL-Start requests.
As a best practice, use this command only if the server cannot respond to duplicate EAPOL-Start requests. Do not use this command in other situations.
# Discard duplicate EAPOL-Start requests on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x duplicate-eapol-start discard
display dot1x
dot1x ead-assistant enable
Use dot1x ead-assistant enable to enable the EAD assistant feature.
Use undo dot1x ead-assistant enable to disable the EAD assistant feature.
The EAD assistant feature is disabled.
The EAD assistant feature enables the access device to redirect the HTTP or HTTPS requests of a user to a URL to download and install EAD client. This feature eliminates the tedious job of the administrator to deploy EAD clients.
For the EAD assistant feature to take effect on a port, you must set the port authorization mode to auto.
If you enable EAD assistant in conjunction with port security, EAD assistant cannot take effect on ports operating in autoLearn port security mode.
When you use both EAD assistant and MAC authentication on the device, follow these restrictions and guidelines:
·     If both EAD assistant and MAC authentication are configured, the device does not mark the MAC address of a user that has failed MAC authentication as a silent MAC address. If the user has never passed MAC authentication, packets from the user can trigger MAC authentication again only after the user's EAD entry ages out.
·     As a best practice, do not configure MAC authentication guest VSIs, guest VLANs, critical VSIs, or critical VLANs. The VLANs or VSIs might fail to work correctly when both EAD assistant and MAC authentication are configured on the device.
·     As a best practice, do not configure the Web authentication or IP source guard feature. These features might fail to work correctly when both EAD assistant and MAC authentication are configured on the device.
·     If the MAC address of a user has been marked as a silent MAC address before you enable EAD assistant, packets from the user can trigger 802.1X or MAC authentication only after the quiet timer expires.
If you configure both EAD assistant and 802.1X unicast trigger on a port that performs port-based access control, 802.1X unicast trigger cannot take effect.
To redirect the HTTPS requests of 802.1X users, you must execute the dot1x ead-assistant url command. By default, the device listens to port 6654 for HTTPS requests to be redirected. To change the redirect listening port number, see configuring HTTP redirect in Layer 3—IP Services Configuration Guide.
# Enable the EAD assistant feature.
[Sysname] dot1x ead-assistant enable
display dot1x
dot1x ead-assistant free-ip
http-redirect https-port (Layer 3—IP Services Command Reference)
Use dot1x ead-assistant free-ip to configure a free IP.
Use undo dot1x ead-assistant free-ip to remove the specified or all free IP addresses.
dot1x ead-assistant free-ip ip-address { mask-address | mask-length }
undo dot1x ead-assistant free-ip { ip-address { mask-address | mask-length } | all }
No free IPs exist. Users cannot access any segments before they pass 802.1X authentication.
ip-address: Specifies a freely accessible IP address segment, also called a free IP.
mask: Specifies an IP address mask.
mask-length: Specifies IP address mask length in the range of 1 to 32.
all: Removes all free IP addresses.
With EAD assistant enabled on the device, unauthenticated 802.1X users can access the network resources in the free IP segments before they pass 802.1X authentication.
Execute this command multiple times to configure multiple free IPs.
# Configure 192.168.1.1/16 as a free IP.
[Sysname] dot1x ead-assistant free-ip 192.168.1.1 255.255.0.0
display dot1x
dot1x ead-assistant free-microsegment
Use dot1x ead-assistant free-microsegment to configure a free microsegment.
Use undo dot1x ead-assistant free-microsegment to remove free microsegments.
dot1x ead-assistant free-microsegment microsegment-id
undo dot1x ead-assistant free-microsegment { microsegment-id | all }
No free microsegments exist. Users cannot access a microsegment before they pass 802.1X authentication.
microsegment-id: Specifies a free microsegment by its ID, in the range of 1 to 65535.
all: Removes all free microsegments.
With EAD assistant enabled on the device, unauthenticated 802.1X users can access the network resources in the free microsegments before they pass 802.1X authentication.
Execute this command multiple times to configure a maximum of 20 free microsegments.
# Configure microsegment 1 as a free microsegment.
[Sysname] dot1x ead-assistant free-microsegment 1
dot1x ead-assistant permit authentication-escape
Use dot1x ead-assistant permit authentication-escape to enable support for correctly using Auth-Fail VLANs or VSIs or critical VLANs or VSIs when 802.1X EAD assistant is enabled.
Use undo dot1x ead-assistant permit authentication-escape to restore the default.
802.1X Auth-Fail VLANs or VSIs or critical VLANs or VSIs cannot function correctly when 802.1X EAD assistant is enabled.
By default, the device allows 802.1X users who have not passed authentication to access certain network resources if they match EAD rules when EAD assistant is enabled. As a result, the device cannot correctly assign users to 802.1X Auth-Fail VLANs or VSIs or critical VLANs or VSIs after the users fail authentication.
This command enables the device to remove EAD entries for users who have failed authentication to ensure that the device can correctly assign the users to Auth-Fail VLANs or VSIs or critical VLANs or VSIs.
This command cannot take effect on ports in port-based access control.
# Enable support for correctly using Auth-Fail VLANs or VSIs or critical VLANs or VSIs when 802.1X EAD assistant is enabled.
[Sysname] dot1x ead-assistant permit authentication-escape
Use dot1x ead-assistant url to configure a redirect URL for EAD assistant.
Use undo dot1x ead-assistant url to restore the default.
dot1x ead-assistant url url-string [ secondary ] [ track track-entry-number ]
undo dot1x ead-assistant url [ secondary ]
No redirect URL exists for EAD assistant.
url-string: Specifies the redirect URL, a case-sensitive string of 1 to 64 characters in the format http://string or https://string. If the specified URL does not start with http:// or https://, the device prefixes the specified URL with http://. Because the URL string can contain question marks (?), you cannot obtain help information by entering a question mark at the position of this argument.
secondary: Specifies the URL as the secondary redirect URL. If you do not specify this keyword, the URL is the primary redirect URL.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024. If you do not specify a track entry number, the specified redirect URL is not associated with a track entry.
When an unauthenticated user uses a Web browser to access any network other than the free IP, the device redirects the HTTP or HTTPS requests of the user to a redirect URL.
The redirect URLs must be on the free IP subnet.
You can specify only one primary redirect URL and one secondary redirect URL.
You can associate a track entry with a redirect URL. The 802.1X module can determine whether the Web redirect server providing the URL is reachable, depending on the status of the track entry. If the server providing the primary redirect URL is unreachable, the device can redirect HTTP or HTTPS requests to the secondary redirect URL.
As a best practice, configure the track entry associated with a redirect URL to collaborate with an HTTP NQA operation. The redirect URL-Track-NQA collaboration can detect the connectivity of the Web redirect server and server performance. For more information about Track, see High Availability Configuration Guide. For more information about NQA, see Network Management and Monitoring Configuration Guide.
The device selects a redirect URL as follows:
·     If both the primary and secondary redirect URLs are configured and the URLs are not associated with track entries, the primary redirect URL takes precedence over the secondary redirect URL.
·     If only the primary or secondary redirect URL is configured and the URL is not associated with a track entry, the redirect URL takes effect.
·     The primary redirect URL takes effect if it is not associated with a track entry or the track entry associated with the URL is in Positive or NotReady state. If the primary redirect URL is not available, the secondary redirect URL takes effect.
·     If the primary redirect URL is not configured or the state of the track entry associated with the primary redirect URL changes to Negative, the device checks the secondary redirect URL.
¡     The secondary redirect URL takes effect if it is not associated with a track entry or its associated track entry is in Positive or NotReady state.
¡     No redirect URL is available if no secondary redirect URL is configured or the track entry associated with the secondary redirect URL is in Negative state.
# Configure the redirect URL as https://example.com.
[Sysname] dot1x ead-assistant url https://example.com
display dot1x
dot1x eap-success post-authorization
Use dot1x eap-success post-authorization to configure the device to send EAP-Success packets to 802.1X clients after authorization for the users of the clients succeeds.
Use undo dot1x eap-success post-authorization to configure the device to send EAP-Success packets to 802.1X clients immediately after authentication for the users of the clients succeeds.
The device sends EAP-Success packets to 802.1X clients immediately after authentication for the users of the clients succeeds.
By default, the device sends an EAP-Success packet to a client after it receives a RADIUS Access-Accept packet sent by the RADIUS server for the user of that client. After that, the device grants the user access to the network through the user's access port. Upon receiving the EAP-Success packet, the client immediately initiates a DHCP request to obtain an IP address. However, if the device has not yet received authorization information assigned by the RADIUS server, the client directly obtains an IP address from its access network segment. If its access network segment is different from its authorization network segment after the RADIUS server assigns the authorization information, the client will be unable to come online.
Operating mechanism
To ensure that each 802.1X client obtains an IP address from the authorization network segment, use this feature to configure the device to send EAP-Success packets to 802.1X clients after authorization for the users of the clients succeeds.
When this feature is configured, authentication for some users might fail due to untimely authorization if the RADIUS server or device needs to process a large number of authentication processes, resulting in authentication response timeout. As a best practice, use this feature based on the service processing capabilities of the device and the RADIUS server in the actual application scenario.
# Configure the device to send EAP-Success packets to 802.1X clients after authorization for the users of the clients succeeds.
[Sysname] dot1x eap-success post-authorization
dot1x eap-tls-fragment to-server
Use dot1x eap-tls-fragment to-server to enable 802.1X EAP-TLS fragmentation and set the maximum EAP-TLS fragment size.
Use undo dot1x eap-tls-fragment to-server to restore the default.
dot1x eap-tls-fragment to-server eap-tls-max-length
EAP-TLS messages are not fragmented.
eap-tls-max-length: Sets the maximum EAP-TLS fragment size in bytes. The value range is 100 to 1500.
802.1X EAP-TLS fragmentation takes effect only when EAP relay mode is used.
When the device uses EAP-TLS authentication method in EAP relay mode, the RADIUS packets might exceed the maximum packet size supported by the RADIUS server. This situation typically occurs when long EAP-TLS messages are encapsulated in the EAP-Message attribute of the RADIUS packet sent to the RADIUS server.
To avoid authentication failures caused by oversized packets, fragment the EAP-TLS messages depending on the maximum RADIUS packet size supported by the remote RADIUS server.
For example, the maximum packet length allowed by the server is 1200 bytes and the length of a RADIUS packet (excluding the EAP-Message attribute) is 800 bytes. To make sure the maximum length of a RADIUS packet does not exceed 1200 bytes, you must set the maximum length of an EAP-TLS fragment to a value less than 400 bytes.
# Set the maximum EAP-TLS fragment size to 400 bytes.
[Sysname] dot1x eap-tls-fragment to-server 400
display dot1x
dot1x eapol untag
Use dot1x eapol untag to enable the device to remove the VLAN tags of all 802.1X protocol packets sent out of a port to 802.1X clients.
Use undo dot1x eapol untag to restore the default.
dot1x eapol untag
Whether the device removes the VLAN tags of all 802.1X protocol packets sent out of a port to 802.1X clients depends on the configuration in the VLAN module.
CAUTION
CAUTION:
This command removes the VLAN tags of all 802.1X protocol packets sent out of the port to 802.1X clients. Do not use this command if VLAN-aware 802.1X clients are attached to the port. As a best practice, use this command only in the scenario described in the command usage guidelines.
This command operates on a hybrid port to have it send 802.1X protocol packets with their VLAN tags removed, regardless of whether the port is a tagged or untagged member of a VLAN.
Use this command if the 802.1X-enabled hybrid port is a tagged member of its PVID and the attached 802.1X clients cannot recognize VLAN-tagged 802.1X protocol packets.
# Enable the device to remove the VLAN tags of all 802.1X protocol packets sent out of Ten-GigabitEthernet 1/0/1 to 802.1X clients.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x eapol untag
display dot1x
dot1x guest-vlan
Use dot1x guest-vlan to configure an 802.1X guest VLAN on a port.
Use undo dot1x guest-vlan to restore the default.
dot1x guest-vlan guest-vlan-id
No 802.1X guest VLAN exists on a port.
guest-vlan-id: Specifies the ID of the 802.1X guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created. If the port type is hybrid, verify that the VLAN to be specified as the guest VLAN is not in the tagged VLAN list on the port.
An 802.1X guest VLAN accommodates users that have not performed 802.1X authentication. In the guest VLAN, users can access a limited set of network resources, such as a software server, to download anti-virus software and system patches.
You cannot specify a VLAN as both a super VLAN and an 802.1X guest VLAN on a port. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
On a port, the 802.1X guest VLAN configuration is mutually exclusive with the 802.1X guest VSI, 802.1X Auth-Fail VSI, and 802.1X critical VSI settings.
To delete a VLAN that has been configured as a guest VLAN, you must use the undo dot1x guest-vlan command first.
# Specify VLAN 100 as the 802.1X guest VLAN on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x guest-vlan 100
display dot1x
dot1x guest-vlan-delay
Use dot1x guest-vlan-delay to enable 802.1X guest VLAN assignment delay on a port.
Use undo dot1x guest-vlan-delay to disable the specified 802.1X guest VLAN assignment delay on a port.
dot1x guest-vlan-delay { eapol | new-mac }
undo dot1x guest-vlan-delay [ eapol | new-mac ]
802.1X guest VLAN assignment delay is disabled on a port.
eapol: Specifies EAPOL-triggered 802.1X guest VLAN assignment delay. This keyword takes effect if 802.1X authentication is triggered by EAPOL-Start packets.
new-mac: Specifies new MAC-triggered 802.1X guest VLAN assignment delay. This keyword takes effect if 802.1X authentication is triggered by packets from unknown MAC addresses.
This command enables the device to delay assigning an 802.1X-enabled port to the 802.1X guest VLAN when 802.1X authentication is triggered on the port.
To use this feature, the 802.1X-enabled port must perform MAC-based access control.
When 802.1X authentication is triggered on a port, the device performs the following operations:
1.     Sends a unicast EAP-Request/Identity packet to the MAC address that triggers the authentication.
2.     Retransmits the packet if no response has been received within the username request timeout interval set by using the dot1x timer tx-period command.
3.     Assigns the port to the 802.1X guest VLAN after the maximum number of request attempts set by using the dot1x retry command is reached.
If you use the undo command without any keyword, the command disables both EAPOL-triggered and new MAC-triggered 802.1X guest VLAN assignment delay on a port.
# Enable EAPOL-triggered 802.1X guest VLAN assignment delay on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x guest-vlan-delay eapol
display dot1x
dot1x guest-vlan
dot1x retry
dot1x guest-vsi
Use dot1x guest-vsi to configure an 802.1X guest VSI on a port.
Use undo dot1x guest-vsi to restore the default.
dot1x guest-vsi guest-vsi-name
No 802.1X guest VSI exists on a port.
guest-vsi-name: Specifies the name of the 802.1X guest VSI on the port, a case-sensitive string of 1 to 31 characters.
An 802.1X guest VSI accommodates users that have not performed 802.1X authentication. Users in the 802.1X guest VSI can access a limited set of network resources in the VXLAN associated with this VSI. For example, an 802.1X user can access a software server to download anti-virus software and system patches.
You can configure only one 802.1X guest VSI on a port. The 802.1X guest VSIs on different ports can be different.
On a port, the 802.1X guest VSI configuration is mutually exclusive with the 802.1X guest VLAN, 802.1X Auth-Fail VLAN, and 802.1X critical VLAN settings.
# Specify VSI vsiuser as the 802.1X guest VSI on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x guest-vsi vsiuser
display dot1x
reset dot1x guest-vsi
dot1x guest-vsi-delay
Use dot1x guest-vsi-delay to enable 802.1X guest VSI assignment delay on a port.
Use undo dot1x guest-vsi-delay to disable the specified 802.1X guest VSI assignment delay on a port.
dot1x guest-vsi-delay { eapol | new-mac }
undo dot1x guest-vsi-delay [ eapol | new-mac ]
802.1X guest VSI assignment delay is disabled on a port.
eapol: Specifies EAPOL-triggered 802.1X guest VSI assignment delay. This keyword takes effect if 802.1X authentication is triggered by EAPOL-Start packets.
new-mac: Specifies new MAC-triggered 802.1X guest VSI assignment delay. This keyword takes effect if 802.1X authentication is triggered by packets from unknown MAC addresses.
This command enables the device to delay assigning an 802.1X-enabled port to the 802.1X guest VSI when 802.1X authentication is triggered on the port.
3.     Assigns the port to the 802.1X guest VSI after the maximum number of request attempts set by using the dot1x retry command is reached.
If you use the undo command without any keyword, the command disables both EAPOL-triggered and new MAC-triggered 802.1X guest VSI assignment delays on a port.
# Enable EAPOL-triggered 802.1X guest VSI assignment delay on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x guest-vsi-delay eapol
display dot1x
dot1x guest-vsi
dot1x retry
dot1x handshake
Use dot1x handshake to enable the online user handshake feature.
Use undo dot1x handshake to disable the online user handshake feature.
dot1x handshake
The online user handshake feature is enabled.
The online user handshake feature enables the device to periodically send EAP-Request/Identity packets to the client for verifying the connectivity status of online 802.1X users. The device sets a user to the offline state if it does not receive an EAP-Response/Identity packet from the user after making the maximum attempts within the handshake period. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
As a best practice to ensure online user handshake and new user authentication when a large number of users are present, set the following parameters to a large value:
·     Handshake timer (set by using the dot1x timer handshake-period command).
·     Maximum number of attempts to send an authentication request to a client (set by using the dot1x retry command).
# Enable the online user handshake feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x handshake
display dot1x
dot1x retry
dot1x handshake reply enable
Use dot1x handshake reply enable to enable the 802.1X online user handshake reply feature.
Use undo dot1x handshake reply enable to disable the 802.1X online user handshake reply feature.
The 802.1X online user handshake reply feature is disabled.
This command enables the device to reply to 802.1X clients' EAP-Response/Identity packets with EAP-Success packets during the online handshake process.
Use this command only if 802.1X clients will go offline without receiving EAP-Success packets from the device.
# Enable the 802.1X online user handshake reply feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x handshake reply enable
dot1x handshake
dot1x handshake secure
Use dot1x handshake secure to enable the online user handshake security feature.
Use undo dot1x handshake secure to disable the online user handshake security feature.
The online user handshake security feature is disabled.
The online user handshake security feature is applicable only to the network that deploys the iNode client and IMC server for 802.1X authentication. It prevents users from using illegal client software to bypass iNode security check.
To have this feature take effect, make sure the online user handshake feature is enabled.
# Enable the online user handshake security feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x handshake secure
display dot1x
dot1x handshake
port trunk permit vlan (Layer 2—LAN Switching Command Reference)
dot1x mac-binding
Use dot1x mac-binding to add an 802.1X MAC address binding entry.
Use undo dot1x mac-binding to delete the specified 802.1X MAC address binding entries.
dot1x mac-binding mac-address
undo dot1x mac-binding { mac-address | all }
No 802.1X MAC address binding entries exist on a port.
mac-address: Specifies a MAC address in the format of H-H-H, excluding broadcast, multicast, and all-zero MAC addresses.
all: Specifies all MAC addresses that are bound to a port.
This command takes effect only when the 802.1X MAC address binding feature takes effect.
802.1X MAC address binding entries, both manually added and automatically generated, never age out. They can survive a user logoff or a device reboot. To delete an entry, you must use the undo dot1x mac-binding mac-address command. An 802.1X MAC address binding entry cannot be deleted when the user in the entry is online.
After the number of 802.1X MAC address binding entries reaches the upper limit of concurrent 802.1X users (set by using the dot1x max-user command), the following restrictions exist:
·     Users not in the binding entries will fail authentication even after users in the binding entries go offline.
·     New 802.1X MAC address binding entries are not allowed.
# Add an 802.1X MAC address binding entry on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x mac-binding 000a-eb29-75f1
dot1x
dot1x mac-binding enable
dot1x port-method
Use dot1x mac-binding enable to enable the 802.1X MAC address binding feature.
Use undo dot1x mac-binding enable to disable the 802.1X MAC address binding feature.
The 802.1X MAC address binding feature is disabled.
This command takes effect only on a port that performs MAC-based access control.
The 802.1X MAC address binding feature automatically binds MAC addresses of authenticated 802.1X users to the users' access port and generates 802.1X MAC address binding entries.
802.1X MAC address binding entries, both automatically generated and manually added, never age out. They can survive a user logoff or a device reboot. To delete an entry, you must use the undo dot1x mac-binding mac-address command. An 802.1X MAC address binding entry cannot be deleted when the user in the entry is online.
# Enable 802.1X MAC address binding on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x mac-binding enable
dot1x
dot1x mac-binding
dot1x port-method
dot1x mandatory-domain
Use dot1x mandatory-domain to specify a mandatory 802.1X authentication domain on a port.
Use undo dot1x mandatory-domain to restore the default.
No mandatory 802.1X authentication domain is specified on a port.
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 255 characters.
When the system authenticates an 802.1X user trying to access a port, it selects an authentication domain in the following order:
1.     Mandatory domain.
2.     ISP domain specified in the username.
3.     Default ISP domain.
# Specify my-domain as the mandatory authentication domain for 802.1X users on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x mandatory-domain my-domain
display dot1x
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X users on a port.
Use undo dot1x max-user to restore the default.
dot1x max-user [ preauth-domain | auth-fail-domain ] max-number
undo dot1x max-user [ preauth-domain | auth-fail-domain ]
A port allows a maximum of 4294967295 concurrent 802.1X users.
preauth-domain: Specifies the preauthentication domain.
auth-fail-domain: Specifies the Auth-Fail domain.
max-number: Specifies the maximum number of concurrent 802.1X users on a port. The value range is 1 to 4294967295.
If you do not specify the preauth-domain or auth-fail-domain keyword, this command sets the maximum number of concurrent 802.1X users on a port for 802.1X users using all access types. The 802.1X users include 802.1X users in the preauthentication domain, Auth-Fail domain, and critical domain, and 802.1X users that have passed authentication.
Set the maximum number of concurrent 802.1X users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent 802.1X users.
# Set the maximum number of concurrent 802.1X users to 32 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x max-user 32
display dot1x
dot1x max-user-alarm
Use dot1x max-user-alarm to set the alarm threshold and alarm clear threshold for 802.1X user access ratio.
Use undo dot1x max-user-alarm to restore the default.
dot1x max-user-alarm trigger-threshold trigger-threshold clear-threshold clear-threshold
The alarm threshold and alarm clear threshold for 802.1X user access ratio in percentage is 100 and 50, respectively.
trigger-threshold trigger-threshold: Sets the alarm threshold in percentage, in the range of 1 to 100.
clear-threshold clear-threshold: Sets the alarm clear threshold in percentage, in the range of 0 to 99. The alarm clear threshold must be lower than the alarm threshold.
The 802.1X user access ratio on an interface is the percentage of current online 802.1X users to the maximum number of concurrent 802.1X users on the interface (configured by using the dot1x max-user command).
After you use the snmp-agent trap enable dot1x command to enable SNMP notifications for 802.1X user access ratio and use the dot1x max-user-alarm command to set the alarm threshold and alarm clear threshold:
·     If the percentage of 802.1X user access ratio on an interface reaches the specified alarm threshold for the first time, or increases to the alarm threshold from a value below or equal to the alarm clear threshold, the device sends an alarm notification.
·     If the percentage of 802.1X user access ratio on the interface drops to the alarm clear threshold from a value above or equal to the alarm threshold, the device sends an alarm clear notification.
If the user access ratio on an interface has reached or exceeded the alarm threshold before SNMP notifications is enabled, the alarm is triggered in the following conditions after SNMP notifications is enabled:
·     A user comes online and the alarm threshold is exceeded.
·     A user goes offline and the alarm threshold is reached or exceeded.
As a best practice, set the alarm threshold and alarm clear threshold with a value difference of 50 or so.
# Set the alarm threshold and alarm clear threshold for 802.1X user access ratio in percentage to 90 and 40, respectively.
[Sysname] dot1x max-user-alarm trigger-threshold 90 clear-threshold 40
dot1x max-user
dot1x multicast-trigger
Use dot1x multicast-trigger to enable the 802.1X multicast trigger feature.
Use undo dot1x multicast-trigger to disable the 802.1X multicast trigger feature.
The 802.1X multicast trigger feature is enabled.
The multicast trigger feature enables the device to act as the initiator. The device periodically multicasts EAP-Request/Identity packets out of a port to detect 802.1X clients and trigger authentication. You can use the dot1x timer tx-period command to set the interval for sending multicast EAP-Request/Identity packets.
As a best practice to conserve link bandwidth, disable the multicast trigger if a lot of VLANs are configured on the port.
# Enable the multicast trigger feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x multicast-trigger
display dot1x
dot1x packet-detect enable
Use dot1x packet-detect enable to enable packet detection for 802.1X authentication.
Use undo dot1x packet-detect enable to restore the default.
Packet detection for 802.1X authentication is disabled.
Packet detection for 802.1X authentication takes effect on both of the following types of users:
·     Users in preauthentication domains, authentication domains, critical domains, and Auth-Fail domains.
·     Users assigned to guest VLANs or VSIs, Auth-Fail VLANs or VSIs, and critical VLANs, VSIs, or microsegments.
Operating mechanism
When packet detection for 802.1X authentication is enabled on a port, the device sends detection packets to 802.1X users connected to that port at offline detection intervals set by using the dot1x timer offline-detect command. If the device does not receive a response from a user after it has made the maximum packet transmission attempts within an offline detection interval, it logs off that user and requests the RADIUS server to stop accounting for the user.
When packet detection for 802.1X authentication and 802.1X offline detection are both enabled, the device processes an 802.1X user as follows:
·     If 802.1X offline detection determines that a user is online, the device does not send detection packets to that user.
·     If 802.1X offline detection determines that a user is offline, the device does not immediately logs off that user. Instead, the device sends a detection packet to that user. It will log off that user if it does not receive a response from that user after it has made the maximum packet transmission attempts within an offline detection interval.
To ensure that the device is aware of user IP address changes, enable ARP snooping and ND snooping in conjunction with packet detection for 802.1X authentication. If you do not enable ARP snooping or ND snooping, the device is unaware of user IP address changes. As a result, the device still sends detection packets to the users' original IP addresses and falsely log off these users.
The packet detection feature takes effect only when the port performs MAC-based access control. If you change the port access control mode to Port-based when the packet detection feature is enabled, the packet detection feature will no longer be effective.
Both the 802.1X packet detection and 802.1X unauthenticated user aging features can take effect on users assigned to guest VLANs or VSIs, Auth-Fail VLANs or VSIs, and critical VLANs, VSIs, or microsegments. With both features enabled, a user is forced offline if the device determines that the user is offline after packet detection or the 802.1X user entry ages out. You can configure the 802.1X unauthenticated user aging feature using the dot1x unauthenticated-user aging enable command.
# Enable packet detection for 802.1X authentication.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x packet-detect enable
port-security packet-detect arp-source-ip factor
dot1x packet-detect retry
Use dot1x packet-detect retry to set the maximum number of attempts for sending a detection packet to an 802.1X user.
Use undo dot1x packet-detect retry to restore the default.
dot1x packet-detect retry retries
The device sends a detection packet to an 802.1X user for a maximum of two times.
retries: Sets the maximum number of attempts for sending a detection packet to an 802.1X user. The value range is 1 to 10.
When packet detection for 802.1X authentication is enabled on a port, the device sends detection packets to 802.1X users connected to that port at offline detection intervals set by using the offline detection timer. If the device does not receive a response from a user after it has made the maximum packet transmission attempts within an offline detection interval, it logs off that user and requests the RADIUS server to stop accounting for the user.
If the device fails to send a detection packet to an 802.1X user because it does not obtain the IP address of that user when that user just comes online, the device still decreases the maximum packet transmission attempts by 1. To prevent an 802.1X user from being logged off because the device does not obtain the IP address of that user when that user just comes online, the device increases the maximum number of packet transmission attempts by 10 on the basis of the original configuration.
# Set the maximum number of attempts to 8 for sending a detection packet to an 802.1X user.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x packet-detect retry 8
dot1x port-control
Use dot1x port-control to set the authorization state for the port.
Use undo dot1x port-control to restore the default.
dot1x port-control { authorized-force | auto | unauthorized-force }
The default port authorization state is auto.
authorized-force: Places the port in authorized state, enabling users on the port to access the network without authentication.
auto: Places the port initially in unauthorized state to allow only EAPOL packets to pass, and places the port in authorized state after a user passes authentication. You can use this option in most scenarios.
unauthorized-force: Places the port in unauthorized state, denying any access requests from users on the port.
You can use this command to set the port authorization state to determine whether a client is granted access to the network.
# Set the authorization state of Ten-GigabitEthernet 1/0/1 to unauthorized-force.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x port-control unauthorized-force
display dot1x
dot1x port-method
Use dot1x port-method to specify an access control method for the port.
Use undo dot1x port-method to restore the default.
dot1x port-method { macbased | portbased }
MAC-based access control applies.
macbased: Uses MAC-based access control on the port to separately authenticate each user attempting to access the network. Using this method, when an authenticated user logs off, no other online users are affected.
portbased: Uses port-based access control on the port. Using this method, once an 802.1X user passes authentication on the port, any subsequent user can access the network through the port without authentication. When the authenticated user logs off, all other users are logged off.
If online 802.1X users are present on a port, changing its access control method will cause the online users to go offline.
To avoid authentication anomalies, do not execute the dot1x port-method portbased command on an interface that is bound to a port security authentication profile.
To avoid feature conflicts, do not use 802.1X port-based access control in conjunction with MAC authentication, Web authentication, or static user authentication.
# Configure Ten-GigabitEthernet 1/0/1 to implement port-based access control.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x port-method portbased
display dot1x
dot1x quiet-period
Use dot1x quiet-period to enable the quiet timer.
Use undo dot1x quiet-period to disable the quiet timer.
dot1x quiet-period
The quiet timer is disabled.
When a client fails 802.1X authentication, the device must wait a period of time before it can process authentication requests from the client. You can use the dot1x timer quiet-period command to set the quiet timer.
# Enable the quiet timer and set the quiet timer to 100 seconds.
[Sysname] dot1x quiet-period
[Sysname] dot1x timer quiet-period 100
display dot1x
dot1x timer
dot1x re-authenticate
Use dot1x re-authenticate to enable the 802.1X periodic reauthentication feature.
Use undo dot1x re-authenticate to disable the 802.1X periodic reauthentication feature.
The 802.1X periodic reauthentication feature is disabled.
Periodic reauthentication enables the access device to periodically authenticate online 802.1X users on a port. This feature tracks the connection status of online users and updates the authorization attributes assigned by the server, such as the ACL and VLAN.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
If periodic reauthentication is triggered for a user while that user is waiting for online synchronization, the system performs online synchronization and does not perform reauthentication for the user.
# Enable the 802.1X periodic reauthentication feature on Ten-GigabitEthernet 1/0/1, and set the periodic reauthentication interval to 1800 seconds.
[Sysname] dot1x timer reauth-period 1800
[Sysname-Ten-GigabitEthernet1/0/1] dot1x re-authenticate
display dot1x
dot1x server-recovery online-user-sync
dot1x timer
dot1x re-authenticate manual
Use dot1x re-authenticate manual to manually reauthenticate all online 802.1X users on a port.
After this command is executed, this device reauthenticates all online 802.1X users on a port. The command takes effect regardless of the server-assigned reauthentication attribute and the periodic reauthentication feature.
# Manually reauthenticate all online 802.1X users on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x re-authenticate manual
dot1x re-authenticate server-unreachable keep-online
Use dot1x re-authenticate server-unreachable keep-online to enable the keep-online feature on a port.
Use undo dot1x re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online 802.1X authenticated users if no server is reachable for 802.1X reauthentication.
This feature keeps authenticated 802.1X users online when no server is reachable for 802.1X reauthentication.
# Enable the keep-online feature on Ten-GigabitEthernet 1/0/1 for 802.1X reauthentication.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x re-authenticate server-unreachable keep-online
display dot1x
dot1x retry
Use dot1x retry to set the maximum number of attempts for sending an authentication request to a client.
Use undo dot1x retry to restore the default.
dot1x retry retries
undo dot1x retry
A maximum of two attempts are made to send an authentication request to a client.
retries: Specifies the maximum number of attempts for sending an authentication request to a client. The value range is 1 to 10.
The access device retransmits an authentication request to a client in any of the following situations:
·     The device does not receive any responses from the client within the username request timeout interval. The timer is set by using the dot1x timer tx-period tx-period-value command for the EAP-Request/Identity packet.
·     The device does not receive any responses from the client within the client timeout interval. The timer is set by using the dot1x timer supp-timeout supp-timeout-value command for the EAP-Request/MD5-Challenge packet.
The access device stops retransmitting the request, if it has made the maximum number of request transmission attempts but still received no response.
# Set the maximum number of attempts to 9 for sending an authentication request to a client.
[Sysname] dot1x retry 9
display dot1x
dot1x timer
Use dot1x server-recovery online-user-sync to enable 802.1X online user synchronization.
Use undo dot1x server-recovery online-user-sync to disable 802.1X online user synchronization.
802.1X online user synchronization is disabled. The device does not synchronize online 802.1X user information on a port with a RADIUS server after the RADIUS server recovers from the unreachable state.
IMPORTANT
IMPORTANT:
This command takes effect only when the device uses an IMC RADIUS server to authenticate 802.1X users.
To ensure that the RADIUS server maintains the same online 802.1X user information as the device after the server state changes from unreachable to reachable, use this feature.
This feature synchronizes online 802.1X user information between the device and the RADIUS server when the RADIUS server state is detected having changed from unreachable to reachable.
When synchronizing online 802.1X user information on a port with the RADIUS server, the device initiates 802.1X authentication in turn for each authenticated online 802.1X user to the RADIUS server.
If synchronization fails for an online user, the device logs off that user unless the failure occurs because the server has become unreachable again.
The amount of time required to complete online user synchronization increases as the number of online users grows. This might result in an increased delay for new 802.1X users and users in the critical VLAN or VSI to authenticate or reauthenticate to the RADIUS server and come online.
To have this feature take effect, you must use it in conjunction with the RADIUS server status detection feature, which is configurable with the radius-server test-profile command. When you configure this feature, make sure the detection interval is shorter than the RADIUS server quiet timer configured by using the timer quiet command in RADIUS scheme view. The server state changes to active on expiration of the quiet timer regardless of its actual reachability. Setting a shorter detection interval than the quiet timer prevents the RADIUS server status detection feature from falsely reporting the server reachability.
For more information about the RADIUS server status detection feature, see AAA configuration in Security Configuration Guide.
# Enable 802.1X online user synchronization on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x server-recovery online-user-sync
display dot1x
timer quiet (RADIUS scheme view)
dot1x timer
Use dot1x timer to set an 802.1X timer.
Use undo dot1x timer to restore the default of an 802.1X timer.
dot1x timer { ead-timeout ead-timeout-value | handshake-period handshake-period-value | quiet-period quiet-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value | unicast-trigger quiet-period quiet-period-value | user-aging { auth-fail-vlan | auth-fail-vsi | critical-microsegment | critical-vlan | critical-vsi | guest-vlan | guest-vsi } aging-time-value }
undo dot1x timer { ead-timeout | handshake-period | quiet-period | reauth-period | server-timeout | supp-timeout | tx-period | unicast-trigger quiet-period | user-aging { auth-fail-vlan | auth-fail-vsi | critical-microsegment | critical-vlan | critical-vsi | guest-vlan | guest-vsi } }
The following 802.1X timers apply:
·     EAD rule timer: 30 minutes.
·     Handshake timer: 15 seconds.
·     Quiet timer: 60 seconds.
·     Periodic reauthentication timer: 3600 seconds.
·     Server timeout timer: 100 seconds.
·     Client timeout timer: 30 seconds.
·     Username request timeout timer: 30 seconds.
·     Unicast-trigger quiet timer: 0 seconds. The unicast-trigger quiet timer is disabled.
·     User aging timers for all applicable types of 802.1X microsegments, VLANs, and VSIs: 1000 seconds.
ead-timeout ead-timeout-value: Sets the EAD rule timer in minutes. The value range for the ead-timeout-value argument is 1 to 1440.
handshake-period handshake-period-value: Sets the handshake timer in seconds. The value range for the handshake-period-value argument is 5 to 1024.
quiet-period quiet-period-value: Sets the quiet timer in seconds. The value range for the quiet-period-value argument is 10 to 120.
reauth-period reauth-period-value: Sets the periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 86400.
server-timeout server-timeout-value: Sets the server timeout timer in seconds. The value range for the server-timeout-value argument is 100 to 300.
supp-timeout supp-timeout-value: Sets the client timeout timer in seconds. The value range for the supp-timeout-value argument is 1 to 120.
tx-period tx-period-value: Sets the username request timeout timer, in seconds. The value range for the tx-period-value argument is 1 to 120.
unicast-trigger quiet-period quiet-period-value: Sets the unicast-trigger quiet timer, in seconds. The vaue range for the quiet-period-value argument is 0 to 3600. The default timer value is 0, which indicates that the unicast-trigger timer is not enabled.
user-aging: Sets the user aging timer for a type of 802.1X VLAN or VSI.
auth-fail-vlan: Specifies 802.1X Auth-Fail VLANs.
auth-fail-vsi: Specifies 802.1X Auth-Fail VSIs.
critical-microsegment: Specifies 802.1X critical microsegments.
critical-vlan: Specifies 802.1X critical VLANs.
critical-vsi: Specifies 802.1X critical VSIs.
guest-vlan: Specifies 802.1X guest VLANs.
guest-vsi: Specifies 802.1X guest VSIs.
aging-time-value: Sets the user aging timer. The value range is 60 to 2147483647 seconds.
In most cases, the default settings are sufficient. You can edit the timers, depending on the network conditions.
·     In a low-speed network, increase the client timeout timer.
·     In a vulnerable network, set the quiet timer to a high value.
·     In a high-performance network with quick authentication response, set the quiet timer to a low value.
·     In a network with authentication servers of different performance, adjust the server timeout timer.
The network device uses the following 802.1X timers:
·     EAD rule timer (ead-timeout)—Sets the lifetime of each EAD rule. When the timer expires or the user passes authentication, the rule is removed. If users fail to download the EAD client or fail to pass authentication before the timer expires, they must reconnect to the network to access the free IP.
·     Handshake timer (handshake-period)—Sets the interval at which the access device sends client handshake requests to check the online status of a client that has passed authentication. If the device does not receive a response after sending the maximum number of handshake requests, it considers that the client has logged off.
·     Offline detection timer (offline-detect)—Sets the interval that the device must wait for traffic from a user before the device determines that the user is idle and sets the offline detection interval for the packet detection feature.
¡     If the device has not received traffic from a user before the timer expires when the 802.1X offline detection feature is enabled, the device logs off that user and requests the accounting server to stop accounting for the user. This timer takes effect only when the 802.1X offline detection feature is enabled.
¡     When packet detection for 802.1X authentication is enabled on a port, the device sends detection packets to 802.1X users connected to that port at offline detection intervals set by using the offline detection timer. If the device does not receive a response from a user after it has made the maximum packet transmission attempts within an offline detection interval, it logs off that user and requests the RADIUS server to stop accounting for the user. To set the maximum packet transmission attempts, use the dot1x packet-detect retry command.
·     Quiet timer (quiet-period)—Starts when a client fails authentication. The access device must wait the time period before it can process the authentication attempts from the client.
·     Periodic reauthentication timer (reauth-period)—Sets the interval at which the network device periodically reauthenticates online 802.1X users. To enable 802.1X periodic reauthentication on a port, use the dot1x re-authenticate command.
·     Server timeout timer (server-timeout)—Starts when the access device sends a RADIUS Access-Request packet to the authentication server. If no response is received when this timer expires, the 802.1X authentication fails.
To avoid forced logoff before the server timeout timer expires, set the server timeout timer to a value that is lower than or equal to the product of the following values:
¡     The maximum number of RADIUS packet transmission attempts set by using the retry command in RADIUS scheme view.
¡     The RADIUS server response timeout timer set by using the timer response-timeout command in RADIUS scheme view.
For information about setting the maximum number of RADIUS packet transmission attempts and the RADIUS server response timeout timer, see AAA configuration in Security Configuration Guide.
·     Client timeout timer (supp-timeout)—Starts when the access device sends an EAP-Request/MD5-Challenge packet to a client. If no response is received when this timer expires, the access device retransmits the request to the client.
·     Username request timeout timer (tx-period)—Starts when the device sends an EAP-Request/Identity packet to a client in response to an authentication request. If the device does not receive a response before this timer expires, it retransmits the request. The timer also sets the interval at which the network device sends multicast EAP-Request/Identity packets to detect clients that cannot actively request authentication.
·     Unicast-trigger quiet timer (unicast-trigger quiet-period)—Sets the duration that the unicast trigger is suppressed from sending EAP-Request/Identity requests to an unknown MAC address. This timer starts when the device fails to receive a response from an unknown MAC address after the number of unicast EAP-Request/Identity requests sent to that MAC address has reached the limit. The limit is configurable with the dot1x retry command.
·     User aging timer (user-aging)—Sets the user aging timer for a type of 802.1X microsegment, VLAN, or VSI when 802.1X unauthenticated user aging is enabled.
You can set a user aging timer for critical microsegments, Auth-Fail VLANs or VSIs, critical VLANs or VSIs, or guest VLANs or VSIs. The user aging timer for a type of 802.1X microsegment, VLAN, or VSI determines how long a user can stay in that type of microsegment, VLAN, or VSI.
For more information about how user aging operates, see the usage guidelines for the dot1x unauthenticated-user aging enable command.
Do not set a user aging timer to a multiple of the username request timeout timer (the dot1x timer tx-period command). If you do so, the aging timer will not take effect.
The change to the periodic reauthentication timer applies to the users that have been online only after the old timer expires. Other timer changes take effect immediately on the device.
The network access delay introduced by the unicast-trigger quiet timer increases as the timer value increases. When you set the unicast-trigger quiet timer, make sure its value does not introduce undesired delay for 802.1X authentication users to come online.
# Set the server timeout timer to 150 seconds.
[Sysname] dot1x timer server-timeout 150
display dot1x
retry
timer response-timeout (RADIUS scheme view)
Use dot1x timer reauth-period to set the 802.1X periodic reauthentication timer on a port.
Use undo dot1x timer reauth-period to restore the default.
No 802.1X periodic reauthentication timer is configured on a port. The port uses the global 802.1X periodic reauthentication timer.
reauth-period-value: Sets the 802.1X periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 86400.
The device reauthenticates online 802.1X users on a port at the specified periodic reauthentication interval when the port is enabled with periodic reauthentication. To enable periodic reauthentication on a port, use the dot1x re-authenticate command.
A change to the periodic reauthentication timer applies to online users only after the old timer expires.
The device selects a periodic reauthentication timer for 802.1X reauthentication in the following order:
1.     Server-assigned reauthentication timer.
2.     Port-specific reauthentication timer.
3.     Global reauthentication timer.
4.     Default reauthentication timer.
# Set the 802.1X periodic reauthentication timer to 60 seconds on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x timer reauth-period 60
dot1x timer
Use dot1x unauthenticated-user aging enable to enable 802.1X unauthenticated user aging.
Use undo dot1x unauthenticated-user aging enable to disable 802.1X unauthenticated user aging.
User aging is enabled for 802.1X users that have not been authenticated or have not passed authentication.
802.1X unauthenticated user aging applies to 802.1X users that have not been authenticated or have failed authentication.
If the port uses port-based access control, the 802.1X unauthenticated user aging timer starts when the port is assigned to one of the following access control segment:
·     Critical microsegment.
·     Auth-Fail VLAN or VSI.
·     Critical VLAN or VSI.
When the aging timer expires, the port is removed from the access control segment and all MAC address entries for users in that segment are also removed. To adjust the user aging timer, use the dot1x timer user-aging command.
If the port uses MAC-based access control, an 802.1X unauthenticated user aging timer starts for each 802.1X user when they are assigned to one of the following access control segment:
·     Guest VLAN or VSI.
When the aging timer for a user expires, the device removes that user from the access control segment. To adjust the user aging timer, use the dot1x timer user-aging command.
For users in one of those access control segments on one port to be authenticated successfully and come online on another port, enable this feature. In any other scenarios, disable this feature as a best practice.
The removed users will be unable to access any network resources until after another authentication is triggered.
# Disable 802.1X unauthenticated user aging on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] undo dot1x unauthenticated-user aging enable
dot1x timer
dot1x unicast-trigger
Use dot1x unicast-trigger to enable the 802.1X unicast trigger feature.
Use undo dot1x unicast-trigger to disable the 802.1X unicast trigger feature.
The 802.1X unicast trigger feature is disabled.
802.1X access profile view
The unicast trigger feature enables the access device to initiate 802.1X authentication when the device receives a data frame from an unknown source MAC address. The device sends a unicast EAP-Request/Identity packet to the unknown source MAC address. It will retransmit the packet if it does not receive any responses within a period of time (set by using the dot1x timer tx-period command). This process continues until the maximum number of request attempts (set by using the dot1x retry command) is reached.
As a best practice, do not use the unicast trigger on a port that performs port-based access control. If you do so, users on the port might fail to come online correctly.
# Enable the unicast trigger feature on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x unicast-trigger
display dot1x
dot1x port-method
dot1x retry
dot1x timer
dot1x user-ip freeze
Use dot1x user-ip freeze to enable 802.1X user IP freezing.
Use undo dot1x user-ip freeze to disable 802.1X user IP freezing.
802.1X user IP freezing is disabled.
This command prevents 802.1X-generated IPSG bindings from being updated because of user IP changes. For information about IP source guard commands, see "IP source guard commands."
# Enable 802.1X user IP freezing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] dot1x user-ip freeze
reset dot1x access-user
Use reset dot1x access-user to log off 802.1X users.
reset dot1x access-user [ interface interface-type interface-number | mac mac-address | microsegment microsegment-id | online-type { auth-fail-domain | critical-domain | preauth-domain | success } | username username | vlan vlan-id | vsi vsi-name ]
interface interface-type interface-number: Specifies a port by its type and number.
mac mac-address: Specifies an 802.1X user by its MAC address. The mac-address argument is in the format of H-H-H.
microsegment microsegment-id: Specifies a microsegment by its ID, in the range of 1 to 65535.
online-type: Specifies a type of online 802.1X users.
·     auth-fail-domain: Specifies 802.1X users in the Auth-Fail domain.
·     critical-domain: Specifies 802.1X users in the critical domain.
·     preauth-domain: Specifies 802.1X users in the preauthentication domain.
·     success: Specifies users that have passed 802.1X authentication.
username username: Specifies an 802.1X user by its name. The username argument is a case-sensitive string of 1 to 253 characters.
vlan vlan-id: Specifies a VLAN by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
vsi vsi-name: Specifies a VSI by its name. The vsi-name argument is a case-sensitive string of 1 to 31 characters.
Use this command to log off the specified 802.1X users and clear information about these users from the device. These users must perform 802.1X authentication to come online again.
With a microsegment specified, this command logs off an authenticated 802.1X user if its authorization microsegment is the specified microsegment.
With a VSI specified, this command logs off an authenticated 802.1X user if its authorization VSI is the specified VSI.
With a VLAN specified, this command logs off the following 802.1X users:
·     Users that have passed 802.1X authentication and have been assigned the specified VLAN as the authorization VLAN by the server.
·     Users that stay in the specified VLAN after they have passed 802.1X authentication, because they have not been assigned an authorization VLAN yet.
·     Users that are performing 802.1X authentication in the specified VLAN.
To identify the VLAN in which a user is staying, use the display mac-address command.
If you do not specify any parameters, the reset dot1x access-user command logs off all 802.1X users on the device.
# Log off all 802.1X users on Ten-GigabitEthernet 1/0/1.
<Sysname> reset dot1x access-user interface ten-gigabitethernet 1/0/1
display dot1x connection
reset dot1x guest-vlan
Use reset dot1x guest-vlan to remove users from the 802.1X guest VLAN on a port.
reset dot1x guest-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of an 802.1X user in the guest VLAN. If you do not specify this option, the command removes all 802.1X users from the 802.1X guest VLAN on the port.
# Remove the 802.1X user with MAC address 1-1-1 from the 802.1X guest VLAN on Ten-GigabitEthernet 1/0/1.
<Sysname> reset dot1x guest-vlan interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
dot1x guest-vlan
Use reset dot1x guest-vsi to remove users from the 802.1X guest VSI on a port.
reset dot1x guest-vsi interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of an 802.1X user in the guest VSI. If you do not specify this option, the command removes all 802.1X users from the 802.1X guest VSI on the port.
# Remove the 802.1X user with MAC address 1-1-1 from the 802.1X guest VSI on Ten-GigabitEthernet 1/0/1.
<Sysname> reset dot1x guest-vsi interface ten-gigabitethernet 1/0/1 mac-address 1-1-1
dot1x guest-vsi
reset dot1x statistics
Use reset dot1x statistics to clear 802.1X statistics.
reset dot1x statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears 802.1X statistics on all ports.
# Clear 802.1X statistics on Ten-GigabitEthernet 1/0/1.
<Sysname> reset dot1x statistics interface ten-gigabitethernet 1/0/1
display dot1x
reset dot1x unicast-trigger quiet-mac
Use reset dot1x unicast-trigger quiet-mac to remove the records of unknown source MAC addresses in the unicast-trigger quiet period.
reset dot1x unicast-trigger quiet-mac [ interface interface-type interface-number ] [ mac-address mac-address ]
mac-address mac-address: Specifies a MAC address in H-H-H format.
This command removes all records of unknown source MAC addresses in the unicast-trigger quiet period if you execute it without specifying any parameters.
# Remove the records of unknown source MAC addresses in the unicast-trigger quiet period for interface Ten-GigabitEthernet 1/0/1.
<Sysname> reset dot1x unicast-trigger quiet-mac interface ten-gigabitethernet 1/0/1
display dot1x unicast-trigger quiet-mac
Use snmp-agent trap enable dot1x to enable SNMP notifications for 802.1X.
Use undo snmp-agent trap enable dot1x to disable SNMP notifications for 802.1X.
snmp-agent trap enable dot1x [ dot1x-not-support | resource-not-enough | unicast-not-support | user-maxnum ] *
undo snmp-agent trap enable dot1x [ dot1x-not-support | resource-not-enough | unicast-not-support | user-maxnum ] *
SNMP notifications for 802.1X are disabled.
dot1x-not-support: Enables SNMP notifications about unavailability of 802.1X on interfaces.
resource-not-enough: Enables SNMP notifications about insufficient ACL resources.
unicast-not-support: Enables SNMP notifications about unavailability of 802.1X unicast trigger on interfaces.
user-maxnum: Enables SNMP notifications about 802.1X user access ratio.
If you do not specify any parameters, this command enables all types of 802.1X SNMP notifications.
After you execute this command with the user-maxnum keyword to enable SNMP notifications for 802.1X user access ratio and use the dot1x max-user-alarm command to set the alarm threshold and alarm clear threshold:
# Enable SNMP notifications for 802.1X user access ratio.
[Sysname] snmp-agent trap enable dot1x user-maxnum
dot1x max-user
