12-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Command Reference(V7)-R8149-6W10112-Security Command Reference
16-mGRE commands
16-mGRE commands 157.71 KB
mGRE commands
display mgre session
Use display mgre session to display mGRE session information.
display mgre session [ count | [ interface tunnel interface-number [ peer ipv4-address ] [ dynamic | static ] ] [ verbose ] ]
count: Displays mGRE session statistics.
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays mGRE session information for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command displays all mGRE session information for the specified mGRE tunnel interface.
dynamic: Displays detailed information about dynamic mGRE sessions.
static: Displays detailed information about static mGRE sessions.
verbose: Displays detailed information about IPv4 mGRE sessions. If you do not specify this keyword, the command displays brief information about mGRE sessions.
If you do not specify any parameters, this command displays brief information about all mGRE sessions on all tunnel interfaces.
# Display brief information about all mGRE sessions.
<Sysname> display mgre session
Interface        : Tunnel1
Number of sessions: 2
Peer NBMA address  Peer protocol address    Type   State         State duration
10.0.0.3           192.168.180.136          C-S    Succeeded     00:30:01
10.0.1.4           192.168.180.137          C-C    Establishing  00:30:02
# Display brief information about the mGRE session with the specified peer address.
<Sysname> display mgre session interface tunnel 1 peer 10.0.0.3
Interface         : Tunnel1
Number of sessions: 1
Name of the mGRE tunnel interface.
Number of sessions
Total number of mGRE sessions on the tunnel interface.
Peer NBMA address
Public address of the peer.
IP address of the peer tunnel interface.
mGRE session type:
·     C-S—The local end is an NHC, and the peer end is the NHS.
·     C-C—Both the local and peer ends are NHCs.
·     UNKNOWN—The local end is an NHC, and the peer end type is unknown.
mGRE session state:
·     Succeeded.
·     Establishing.
State duration
Duration of the current session state, in the format of hh:mm:ss.
# Display mGRE session statistics.
<Sysname> display mgre session count
Type               Count
Dynamic            3
Static             0
Total              3
NHRP session type:
·     Dynamic.
·     Static.
Count
Number of NHRP sessions.
Total
Total number of NHRP sessions.
# Display detailed information about all mGRE sessions.
<Sysname> display mgre session verbose
Interface         : Tunnel1
Link protocol     : GRE
  Peer NBMA address    : 10.0.1.3
  Peer protocol address: 192.168.180.136
  Session type         : C-S
  State                : Succeeded
  State duration       : 00:30:01
  Input : 2201 packets, 218 data packets, 3 control packets
          2191 multicasts, 0 errors
  Output: 2169 packets, 2168 data packets, 1 control packets
          2163 multicasts, 0 errors
  Peer NBMA address    : 10.0.1.4
  Peer protocol address: 192.168.180.137
  Session type         : C-S
  State                : Succeeded
  State duration       : 00:31:01
  Input : 1 packets, 0 data packets, 1 control packets
          0 multicasts, 0 errors
  Output: 16 packets, 0 data packets, 16 control packets
Interface         : Tunnel2
Link protocol     : IPsec-GRE
  Peer NBMA address     : 20.0.0.3
  Peer protocol address : 192.168.181.137
  Behind NAT            : No
  Session type          : C-C
  SA's SPI              :
      Inbound : 187199087 (0xb286e6f) [ESP]
      Outbound: 3562274487 (0xd453feb7) [ESP]
  State                 : Establishing
  Input : 0 packets, 0 data packets, 0 control packets
  Output: 1 packets, 0 data packets, 1 control packets
Link protocol
Encapsulation protocol used by the mGRE tunnel:
·     GRE.
·     IPsec-GRE.
Number of sessions
Peer NBMA address
SA's SPI
SPI of the inbound and outbound SAs. This field is available when the mGRE tunnel is carried over IPsec.
Behind NAT
Whether the peer NHC has traversed a NAT device.
Session type
mGRE session type:
·     S-C—The local end is an NHS, and the peer end is an NHC.
mGRE session state:
·     Succeeded.
·     Establishing.
State duration
If the duration exceeds 99:59:59, the format is dd:hh:mm.
Input
Statistics on received packets:
·     packets—Total number of packets.
·     data packets—Number of data packets.
·     control packets—Number of control packets.
·     multicasts—Number of multicast packets.
·     errors—Number of error packets.
Output
Statistics on sent packets:
reset mgre session
display nhrp history-map
Use display nhrp history-map to display NHRP mapping entries that were cleared or have expired.
display nhrp history-map [ count count-number ]
count count-number: Displays the specified number of NHRP mapping entries that were cleared or have expired. The value range for the count-number argument is 1 to 2000. If you do not specify this option, the command displays all NHRP mapping entries that were cleared or have expired.
Use this command to display the following NHRP mapping entries:
·     NHRP mapping entries that were cleared by using the reset nhrp dynamic map command.
·     NHRP mapping entries that have expired because their storage time exceeded the value set by using the nhrp holdtime command.
The display nhrp history-map command can display a maximum of 2000 entries. A new entry will overwrite the oldest entry for this command when the maximum number is reached.
# Display the most recent two NHRP mapping entries that were cleared or have expired.
<Sysname> display nhrp history-map count 2
Number of off-line map: 1984. Alloc memory: 214272
Interface   : Tunnel634
  Destination/mask: 182.134.3.1/32
  Next hop        : 182.134.3.1
  Creation time   : Mon Apr 12 10:23:31 2022
  Delete time     : Mon Apr 12 13:04:28 2022
  Delete reason   : expire
  Hold time       : 7200
  Type            : dynamic
  NBMA address    : 20.1.1.1
Interface   : Tunnel311
  Destination/mask: 182.61.2.1/32
  Next hop        : 182.61.2.1
  Creation time   : Mon Apr 12 10:23:36 2022
  Delete time     : Mon Apr 12 13:04:23 2022
  Hold time       : 7200
  Type            : dynamic
Number of recorded history NHRP mapping entries that were deleted.
Alloc memory
Amount of memory used by the entries, in bytes.
Name of an mGRE tunnel interface.
Destination/mask
Protocol address of an NHRP peer NHC.
Next hop
Tunnel address of the NHRP peer NHC.
Creation time
Time when the mapping entry was created.
Delete time
Time when the mapping entry was deleted.
Delete reason
Reason why the mapping entry was deleted:
·     Expire—The mapping entry holdtime expired.
·     Tunnel down—Exceptions occurred for the tunnel or public network.
·     Client purge—The NHC sent purge packets.
·     Unknown—Other unknown errors.
Hold time
Mapping entry holdtime, in seconds.
Mapping entry type:
·     static—The entry is statically configured.
·     cached—The entry is dynamically obtained.
·     Incomplete—The entry is dynamic and incomplete.
·     dynamic—The entry is dynamically negotiated.
NBMA address
NBMA network address.
display nhrp map
display nhrp map
Use display nhrp map to display information about NHRP mapping entries.
display nhrp map [ statistics | [ interface tunnel interface-number [ peer ipv4-address ] ] [ dynamic | static ] [ verbose ] ]
statistics: Displays statistics about NHRP mapping entries.
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays NHRP mapping table information for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command displays NHRP mapping entries for all peers.
dynamic: Displays detailed information about dynamic NHRP mapping entries.
static: Displays detailed information about static NHRP mapping entries.
verbose: Displays detailed information about NHRP mapping entries. If you do not specify this keyword, the command displays brief information about NHRP mapping entries.
If you do not specify any parameters, this command displays brief information about all NHRP mapping entries.
# Display brief information about all NHRP mapping entries.
<Sysname> display nhrp map
Destination/mask   Next hop       NBMA address    Type     Interface
172.16.1.1/32      172.16.1.1     105.112.100.4   cached   Tunnel0
172.16.1.2/32      172.16.1.2     105.112.100.92  cached   Tunnel0
# Display detailed information about all NHRP mapping entries.
<Sysname> display nhrp map verbose
Interface   : Tunnel0
  Destination/mask    : 172.16.1.1/32
  Next hop            : 172.16.1.1
  Creation time       : 00:38:44
  Expiration time     : 01:21:15
  Type                : cached
  Flags               : unique up used
  NBMA address        : 105.112.100.4
Interface   : Tunnel0
  Destination/mask    : 172.16.1.2/32
  Next hop            : 172.16.1.2
  Creation time       : 00:25:53
  Expiration time     : 01:34:06
  Type                : cached
  Flags               : unique up used ipsec
  NBMA address        : 105.112.100.92
Table 5 Command output
Destination/mask
Destination tunnel interface address and mask.
Next hop
Next hop address to reach the destination network.
Creation time
Period of time for which the mapping entry has been created, in the format of hh:mm:ss.
If the period exceeds 99:59:59, the format is dd:hh:mm.
Expiration time
Period of time in which the mapping entry will expire, in the format of hh:mm:ss.
Mapping entry type:
Flags
Mapping entry flags:
·     unique—The mapping entry in the registration request cannot be overwritten by a mapping entry that has the same private address and different public addresses. A client can register the new entry with the server only after the mapping entry on the server expires.
·     used—This mapping entry is used for packet forwarding.
·     up—This mapping entry can be used for packet forwarding.
·     ipsec—IPsec negotiation succeeded. Packets will be protected by IPsec.
·     init—Initialization state.
# Display statistics about NHRP mapping entries.
<Sysname> display nhrp map statistics
Type               Count
Dynamic map:       3
Static  map:       0
Total   map:       3
Dynamic peer:      3
Local   peer:      0
Cache   peer:      0
All     peer:      3
Table 6 Command output
Dynamic map
Number of dynamic NHRP mapping entries.
Static map
Number of static NHRP mapping entries.
Total map
Total number of NHRP mapping entries.
Dynamic peer
Number of dynamic NHRP mapping entries for peers.
Local peer
Number of local NHRP mapping entries for peers.
Cache peer
Number of NHRP mapping entries dynamically obtained among NHCs in a full mesh network.
All peer
Total number of NHRP mapping entries for peers.
display nhrp statistics
Use display nhrp statistics to display NHRP packet statistics for a tunnel interface.
display nhrp statistics [ interface tunnel interface-number ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command displays NHRP packet statistics for all tunnel interfaces.
# Display NHRP packet statistics.
<Sysname> display nhrp statistics
Tunnel0:
  NHRP packets sent       : 815
    Resolution requests   : 15
    Resolution replies    : 1
    Registration requests : 0
    Registration replies  : 797
    Purge requests        : 2
    Purge replies         : 0
    Error indications     : 0
    Traffic indications   : 0
  NHRP packets received   : 1453
    Registration requests : 1435
    Registration replies  : 2
    Purge requests        : 0
    Purge replies         : 0
Tunnel1:
  NHRP packets sent       : 3
    Resolution Requests   : 0
    Resolution replies    : 0
    Registration replies  : 3
    Purge requests        : 0
    Purge replies         : 0
  NHRP packets received   : 3
    Resolution requests   : 0
    Registration requests : 3
    Registration replies  : 0
    Purge requests        : 0
    Purge replies         : 0
reset nhrp statistics
nhrp authentication
Use nhrp authentication to configure an NHRP packet authentication key.
Use undo nhrp authentication to restore the default.
nhrp authentication { cipher | simple } string
No NHRP packet authentication key is configured. NHRP nodes do not authenticate NHRP packets received from each other.
mGRE tunnel interface view
cipher: Specifies an authentication key in encrypted form.
simple: Specifies an authentication key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key string. Its plaintext form is a case-sensitive string of 1 to 8 characters. Its encrypted form is a case-sensitive string of 1 to 41 characters.
After an NHRP packet authentication key is configured for a tunnel interface, the tunnel interface adds the key in packets sent to the peer. The tunnel interface also uses the key to authenticate NHRP packets it receives. If a packet fails the authentication, the packet will be dropped.
For mGRE tunnels to be established successfully, configure the same NHRP authentication key for all NHCs and NHSs in the same mGRE network.
# On interface Tunnel1, set the NHRP packet authentication key to 123456.
[Sysname] interface tunnel 1 mode mgre
[Sysname-Tunnel1] nhrp authentication simple 123456
nhrp dscp
Use nhrp dscp to specify a DSCP value for the outgoing NHRP packets on an NHS or NHC.
Use undo nhrp dscp to restore the default.
nhrp dscp dscp-value
undo nhrp dscp
The DSCP value is 48.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
In an mGRE scenario, if the DSCP value of NHRP packets is too small when network congestion occurs, the NHRP packets might be dropped. As a result, mGRE tunnel interruption occurs. You can use this command to adjust the DSCP value of NHRP packets to ensure that NHRP packets are preferentially transmitted.
# On tunnel interface Tunnel 1, configure the DSCP value of outgoing NHRP packets as 50.
[Sysname-Tunnel1] nhrp dscp 50
nhrp holdtime
Use nhrp holdtime to configure the holdtime for NHRP mapping entries.
Use undo nhrp holdtime to restore the default.
nhrp holdtime seconds
undo nhrp holdtime
The holdtime of NHRP mapping entries is 7200 seconds.
seconds: Specifies the holdtime in the range of 1 to 65535 seconds.
After the holdtime is configured, the local NHRP holdtime carried in outgoing packets is updated to the configured holdtime. To display information about NHRP mapping entries that have expired, use the display nhrp history-map command.
# On interface Tunnel1, set the holdtime of NHRP mapping entries to 600 seconds
[Sysname-Tunnel1] nhrp holdtime 600
interface tunnel (Layer 3—IP Services Command Reference)
nhrp network-id
Use nhrp network-id to configure an NHRP network ID for an mGRE tunnel.
Use undo nhrp network-id to restore the default.
nhrp network-id number
No NHRP network ID is configured for an mGRE tunnel.
number: Specifies an NHRP network ID in the range of 1 to 4294967295.
A network ID is only locally significant. You can configure different NHRP network IDs for different tunnel interfaces on the device. The NHC and NHS can have different NHRP network IDs.
# Set the NHRP network ID to 10 for mGRE tunnel interface Tunnel1.
[Sysname-Tunnel1] nhrp network-id 10
nhrp nhs
Use nhrp nhs to configure a private address-to-public DNS name mapping or a private-to-public address mapping for an NHS.
Use undo nhrp nhs to delete a private address-to-public DNS name mapping or a private-to-public address mapping for an NHS.
nhrp nhs nhs-address nbma { dns-name | nbma-address }
undo nhrp nhs nhs-address nbma { dns-name | nbma-address }
No private address-to-public DNS name mapping or private-to-public address mapping is configured for an NHS.
nhs-address: Specifies the private address of an NHS.
dns-name: Specifies the public DNS name of the NHS, a case-sensitive string of 1 to 253 characters. The string cannot contain a space.
nbma-address: Specifies the public address (NBMA address) of the NHS.
You can execute this command multiple times to configure multiple NHSs for redundancy. If multiple NHSs are configured, NHCs register with all the NHSs.
If you execute this command multiple times for the same NHS private address, the most recently configured public address or DNS name takes effect.
# On interface Tunnel 1, configure the NHS private address as 1.1.1.1 and public address as 120.1.1.120.
[Sysname-Tunnel1] nhrp nhs 1.1.1.1 nbma 120.1.1.120
# On interface Tunnel 2, configure the NHS private address as 2.2.2.2 and public DNS name as dns.
[Sysname] interface tunnel 2 mode mgre
[Sysname-Tunnel1] nhrp nhs 2.2.2.2 nbma dns
nhrp registration no-unique
Use nhrp registration no-unique to configure an NHC to include the no-unique flag into outgoing NHRP packets.
Use undo nhrp registration no-unique to restore the default.
An outgoing NHRP packet does not include the no-unique flag on an NHC.
When an NHC is registering NHRP information with an NHS, the NHS generates an NHRP mapping entry for the NHC. When the public address of the NHC is changed, the NHC reregisters its latest NHRP information with the NHS. As a result, NHRP mapping entry conflict occurs on the NHS for the NHC. The NHS denies the reregistration of the NHC.
To resolve the issue, use this command on the NHC. With this command, the NHC includes the no-unique flag into NHRP registration and response packets to notify the NHS to overwrite the conflicting NHRP mapping entry with the latest NHC information.
As a best practice to ensure successful NHC reregistration with an NHS in scenarios where the NHCs dynamically obtain addresses, for example, through DHCP, use this command on the NHCs.
# On tunnel interface Tunnel 1, configure mGRE tunnel registration packets to include the no-unique flag.
[Sysname-Tunnel1] nhrp registration no-unique
nhrp registration time-out
Use nhrp registration time-out to set the interval at which an NHC sends NHRP registration packets.
Use undo nhrp registration time-out to restore the default.
nhrp registration time-out seconds
An NHC sends NHRP registration packets at intervals of 2400 seconds.
seconds: Sets the NHRP registration interval, in seconds. The value range is 1 to 65535.
To prevent an NHS from failing to update NHC information in time after the public address of an NHC is modified or the NHRP mapping entry for an NHC on the NHS ages out, use this command on the NHC. To ensure that the NHS can update NHC information in time, make sure the interval at which the NHC sends registration packets is shorter than the holdtime of NHRP mapping entries on the NHS.
# On tunnel interface Tunnel 1, configure the device to send NHRP registration packets at intervals of 300 seconds.
[Sysname-Tunnel1] nhrp registration time-out 300
nhrp holdtime
nhrp server-only
Use nhrp server-only to enable the NHS-only feature.
Use undo nhrp server-only to disable the NHS-only feature.
nhrp server-only
The NHS-only feature is disabled.
When this feature is enabled, the device can act as only an NHS.
When this feature is enabled, the mappings configured by using the nhrp nhs command for an NHS cannot take effect. In addition, the device no longer sends registration request packets.
As a best practice, enable this feature only when the device only acts as an NHS.
# On Tunnel interface tunnel 1, enable the NHS-only feature.
[Sysname-Tunnel1] nhrp server-only
reset mgre session
Use reset mgre session to reset dynamic mGRE sessions.
reset mgre session [ interface tunnel interface-number [ peer ipv4-address ] ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command resets dynamic mGRE sessions for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command resets all dynamic mGRE sessions for the specified mGRE tunnel interface.
When an mGRE session is reset, the NHC reregisters with the NHS.
# Reset the mGRE sessions on interface Tunnel1.
<Sysname> reset mgre session interface tunnel 1
# Reset the mGRE session with peer address 202.12.12.12 on interface Tunnel1.
<Sysname> reset mgre session interface tunnel 1 peer 202.12.12.12
reset mgre statistics
Use reset mgre statistics to clear mGRE session statistics.
reset mgre statistics [ interface tunnel interface-number [ peer ipv4-address ] ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command clears mGRE session statistics for all mGRE tunnel interfaces.
peer ipv4-address: Specifies a peer public address. If you do not specify this option, the command clears statistics about all mGRE sessions on the specified mGRE tunnel interface.
# Clear statistics about mGRE sessions on interface Tunnel1.
<Sysname> reset mgre statistics interface tunnel 1
# Clear statistics about the mGRE session with peer public address 192.168.1.200 on interface Tunnel1.
<Sysname> reset mgre statistics interface tunnel 1 peer 192.168.1.200
Use reset nhrp dynamic map to clear dynamically negotiated NHRP mapping entries.
reset nhrp dynamic map [ protocol-address [ mask ] ]
protocol-address: Specifies a network layer protocol address in dotted decimal notation.
mask: Specifies the mask of the network layer protocol address, in dotted decimal notation.
If you do not specify any parameters, this command clears all dynamic NHRP mapping entries.
To prevent existing dynamic NHRP mapping entries from affecting diagnostic results in debugging operations or in node interaction diagnostic tests, clear the entries before they age out.
Use this command with caution. After this command clears the specified dynamic NHRP mapping entries, the device does not generate these entries until the peer devices register the information again.
To display dynamic NHRP mapping entries that were cleared, use the display nhrp history-map command.
# Clear dynamic NHRP mapping entry with IP address 20.20.20.1.
[Sysname-Tunnel1] reset nhrp dynamic map 20.20.20.1
reset nhrp history-map
Use reset nhrp history-map to clear NHRP mapping entries recorded on the device.
Use this command to clear NHRP mapping entries recorded by the display nhrp history-map command.
# Clear NHRP mapping entries recorded on the device.
<Sysname> reset nhrp history-map
Use reset nhrp statistics to clear NHRP packet statistics.
reset nhrp statistics [ interface tunnel interface-number ]
interface tunnel interface-number: Specifies an mGRE tunnel interface by its number. The value range for the interface-number argument is 0 to 10239. If you do not specify this option, the command clears NHRP packet statistics for all mGRE tunnel interfaces.
# Clear NHRP packet statistics for interface Tunnel1.
<Sysname> reset nhrp statistics interface tunnel 1
