10-Segment Routing Configuration Guide
HomeSupportReference GuidesCommand ReferencesH3C SR6600[SR6600-X] Routers Configuration Guides(V7)-R8149-6W10110-Segment Routing Configuration Guide
04-SRv6 TE policy configuration
04-SRv6 TE policy configuration 1.10 MB
SRv6 TE policy introduction· 1
About SRv6 TE policies· 1
Basic concepts in SRv6 TE Policy· 1
SRv6 TE policy identification· 1
SRv6 TE policy contents· 1
SRv6 TE policy BSID·· 2
SRv6 TE policy group· 2
SRv6 TE policy creation and path calculation· 3
About SRv6 TE policy creation and path calculation· 3
SRv6 TE policy creation· 3
Traffic steering to an SRv6 TE policy· 4
BSID-based traffic steering· 4
Color-based traffic steering· 4
DSCP-based traffic steering· 5
APN ID-based traffic steering· 6
CBTS-based traffic steering· 7
Automatic route advertisement 8
Other traffic steering methods· 9
SRv6 TE policy-based traffic forwarding· 9
SRv6 TE policy path selection· 9
Data encapsulation and forwarding through SRv6 TE policies· 10
SRv6 TE policy reliability· 12
SRv6 TE policy hot standby· 12
BFD for SRv6 TE policy· 13
SRv6 TE policy transit node protection· 17
SRv6 egress protection· 20
SRv6 TE policy application in the APN6 network· 21
Configuring an SRv6 TE policy· 1
SRv6 TE policy tasks at a glance· 1
Configuring a SID list 2
Creating an SRv6 TE policy· 2
Manually creating an SRv6 TE policy and configuring its attributes· 2
Automatically creating SRv6 TE policies by using ODN· 3
Enabling the device to distribute SRv6 TE policy candidate path information to BGP-LS· 4
Shutting down an SRv6 TE policy· 4
Configuring a candidate path· 5
Configuring BGP to advertise BGP IPv6 SR policy routes· 5
Restrictions and guidelines for BGP IPv6 SR policy routes advertisement 5
Enabling BGP to advertise BGP IPv6 SR policy routes· 5
Configuring BGP to redistribute BGP IPv6 SR policy routes· 6
Enabling advertising BGP IPv6 SR policy routes to EBGP peers· 6
Enabling Router ID filtering· 7
Enabling validity check for BGP IPv6 SR policy routes· 7
Configuring BGP to control BGP IPv6 SR policy route selection and advertisement 8
Maintaining BGP sessions· 9
Configuring SRv6 TE policy traffic steering· 10
Configuring the SRv6 TE policy traffic steering mode· 10
Configuring color-based traffic steering· 10
Configuring tunnel policy-based traffic steering· 12
Configuring DSCP-based traffic steering· 13
Configuring APN ID-based traffic steering· 15
Configuring static route-based traffic steering· 18
Configuring QoS policy-based traffic steering· 19
Configuring Flowspec-based traffic steering· 20
Enabling automatic route advertisement for an SRv6 TE policy· 22
Configuring the SRv6 TE policy encapsulation mode· 22
Enabling SBFD for SRv6 TE policies· 24
Configuring the BFD echo packet mode for SRv6 TE policies· 26
Enabling hot standby for SRv6 TE policies· 26
Configuring path switchover and deletion delays for SRv6 TE policies· 27
Configuring SRv6 TE policy transit node protection· 27
Configuring SRv6 TE policy egress protection· 28
Restrictions and guidelines for SRv6 TE policy egress protection configuration· 28
Configuring an End.M SID·· 28
Enabling egress protection· 29
Configuring the deletion delay time for remote SRv6 SID mappings with VPN instances/cross-connects/VSIs  30
Configuring the TTL processing mode of SRv6 TE policies· 30
Configuring SRv6 TE policy CBTS· 31
Configuring a rate limit for an SRv6 TE policy· 31
Enabling the device to drop traffic when an SRv6 TE policy becomes invalid· 32
Specifying the packet encapsulation type preferred in optimal route selection· 32
Configuring traffic forwarding statistics for SRv6 TE policies· 33
Display and maintenance commands for SRv6 TE policies· 34
SRv6 TE policy configuration examples· 35
Example: Configuring SRv6 TE policy-based forwarding· 35
Example: Configuring SRv6 TE policy egress protection· 40
IPv6 Segment Routing Traffic Engineering (SRv6-TE) policies apply to scenarios where multiple paths exist between a source node and a destination node on an SRv6 network. The device can use an SRv6 TE policy to flexibly steer traffic to a proper forwarding path.
An SRv6 TE policy is uniquely identified by the following triplet:
·     HeadendIngress node (source node).
·     Color—Color attribute, which provides a mechanism for associating services with SRv6 TE policies. It is used to distinguish different SRv6 TE policies with the same source and destination nodes. SRv6 TE policies are colored by network administrators. You can use this attribute to implement service-specific traffic steering to SRv6 TE policies. For example, you can use an SRv6 TE policy with a color attribute of 10 to forward the traffic of a service that requires a link delay smaller than 10 ms.
·     Endpoint—IPv6 address of the egress node (destination node).
On an ingress node, you can uniquely identify an SRv6 TE policy by its color and egress node.
As shown in Figure 1, an SRv6 TE policy consists of candidate paths with different preferences. Each candidate path can have one or multiple subpaths identified by segment lists (also called SID lists).
·     Candidate path
An SRv6 TE policy can have multiple candidate paths. The device selects the candidate path with the greatest preference value as the primary path in that SRv6 TE policy. A candidate path is uniquely identified by the <Protocol-origin,Originator,Discriminator> triplet:
¡     Protocol-origin—Protocol or method through which the candidate path was generated.
¡     Originator—Node that generated the candidate path. This field always consists of two portions, AS number and node IP address.
¡     Discriminator—Candiate path ID, which is used to distinguish candidate paths with the same Protocol-origin and Originator values. For example, the controller deploys three candiate paths to the ingress node of an SRv6 TE policy through BGP. In this situation, the Protocol-origin and Originator values of those candiate paths are BGP and controller, respectively, but their Discriminator values are different.
Two SRv6 TE policies cannot share the same candidate path.
·     SID list
A SID list is a list of SIDs that indicates a packet forwarding path. Each SID is the IPv6 address of a node on the forwarding path.
A candidate path can have a single SID list or multiple SID lists that use different weight values. After an SRv6 TE policy chooses a candidate path with multiple SID lists, the traffic will be load shared among the SID lists based on weight values.
Figure 1 SRv6 TE policy contents
SRv6 TE policy BSID
SRv6 TE policies also support Binding SIDs (BSID). A BSID is typically an SRv6 SID, which represents a candidate path. If the destination address of a packet is a BSID, the packet will be steered to the related candidate path for further forwarding. Assume that an SRv6 TE policy is a network service and you want to forward traffic along a specific candidate path of that SRv6 TE policy. From a programming perspective, you can use the BSID of that candidate path as an interface to call that network service.
You can manually configure a BSID for an SRv6 TE policy or leave the SRv6 TE policy to automatically obtain a BSID from the specified locator. The SRv6 endpoint behavior for BSID is Endpoint Bound to an SRv6 TE Policy (End.B6), because they are SRv6 SIDs indeed. End.B6 behaviors include the End.B6.Insert and End.B6.Encaps behaviors. For more information about End.B6 SRv6 SIDs, see SRv6 configuration in Segment Routing Configuration Guide.
An SRv6 TE policy group is a group of SRv6 TE policies that have the same endpoint address. Upon receiving a packet destined for that endpoint address, the device searches for the SRv6 TE policy containing the color value mapped to the DSCP value of the packet. The device will use the SRv6 TE policy to forward the packet.
An SRv6 TE policy group is identified by its group ID. It also has the following attributes:
·     BSID—SID of the ingress node in the SRv6 TE policy group. It can steer traffic to the SRv6 TE policy group.
·     Color—Color extended attribute of the SRv6 TE policy group. BGP routes that carry the same color value as the SRv6 TE policy group are recursed to the SRv6 TE policy group.
·     Endpoint—IPv6 address of the egress node (destination node). If an SRv6 TE policy and an SRv6 TE policy group have the same value for the endpoint attribute, the SRv6 TE policy belongs to the SRv6 TE policy group.
You can create an SRv6 TE policy group by using the following methods:
·     Manual creation at the CLI
This method requires manually configuring the destination node address of the SRv6 TE policy group.
·     Automatic creation by ODN
When the device receives a BGP route, it compares the color extended attribute value of the BGP route with the color value of the ODN template. If the color values match, the device automatically generates an SRv6 TE policy group.
¡     The policy group uses the BGP route's next hop address as the endpoint address and the ODN template's color value as the color attribute value.
¡     The device will assign the smallest ID that is not in use to the SRv6 TE policy group.
The architecture of a complete and functional SRv6 TE policy is inherently complex. While the Headend, Color, and End-point tuple establishes the identity of the SRv6 TE policy, its forwarding behavior is governed by candidate paths and SID lists.
To create an SRv6 TE policy, the Headend, Color, and End-point tuple must be defined. Then, SRv6 TE policy path calculation can obtain the SID lists in the candidate paths. Therefore, the creation and path calculation of an SRv6 TE policy are two decoupled processes.
You can create an SRv6 TE policy by using the following methods:
·     Manually create an SRv6 TE policy and candidate paths through CLI or NETCONF.
·     Configure the device to learn an SRv6 TE policy and candidate paths from a BGP IPv6 SR policy route.
·     Configure the device to learn an SRv6 TE policy and candidate paths through PCEP.
·     Configure the device to automatically create an SRv6 TE policy and candidate paths through ODN.
You can create an SID list for a candidate path in the following methods:
·     Manually creation through CLI or NETCONF.
·     Creation based on dynamically calculated paths.
·     Creation based on PCE-calculated paths.
For example, after you manually configure the SRv6 TE policy's color, endpoint, candidate paths, the precedence of the candidate paths, the SID list of the candidate paths, and their weights, dynamically calculated paths can be used to establish SID lists for other candidate paths in the SRv6 TE policy.
To generate SRv6 TE policies and the path calculation function through BGP and PCEP, the control plane protocols PECP, BGP-LS, and BGP IPv6 SR policy have all been extended to support SRv6 TE policy.
An SRv6 TE policy can be created in the following modes:
·     Manual configuration from CLI
In this method, you need to manually configure the candidate settings for the SRv6 TE policy, such as candidate path preferences, SID lists and weights.
·     Learning from an SRv6 TE policy route
To support SRv6 TE policy, MP-BGP defines the BGP IPv6 SR address family and the SRv6 TE policy Network Layer Reachability Information (NLRI). The SRv6 TE policy NLRI is called the BGP IPv6 SR policy route. A BGP IPv6 SR policy route contains SRv6 TE policy settings, including the BSID, color, endpoint, candidate preferences, SID lists, and SID list weights.
The device can advertise its local SRv6 TE policy settings to its BGP IPv6 SR policy peer through a BGP IPv6 SR policy route. The peer device can create an SRv6 TE policy according to the received SRv6 TE policy settings.
After you create an On-Demand Next-Hop (ODN) template, if the color extended community attribute carried in a BGP route received by the device matches the color value in the ODN template, the device will automatically create an SRv6 TE policy. The next hop address of the BGP route is used as the destination address of the SRv6 TE policy, and the ODN template's color value is used as the color attribute of the SRv6 TE policy. This SRv6 TE policy will automatically request a BSID within the specified locator segment. Candidate paths can be manually created under the SRv6 TE policy that is automatically generated by the ODN function.
Path selection in SRv6 TE policy-oriented traffic steering can be divided into two modes: direct steering and indirect steering. The methods for direct traffic steering include:
·     BSID-based traffic steering
·     Color-based traffic steering
·     CBTS-based traffic steering
·     Automatic route advertisement
·     Other traffic steering methods
During indirect traffic steering, the device performs the following operations in sequence:
1.     Steers traffic to the matching SRv6 TE policy group.
2.     Based on the forward type and forwarding policy mappings of that SRv6 TE policy group, selects an SRv6 TE policy group for further forwarding.
The methods for indirect traffic steering include:
·     DSCP-based traffic steering
·     APN ID-based traffic steering
If the destination IPv6 address of a received packet is the BSID of an SRv6 TE policy, the device uses the SRv6 TE policy to forward the packet.
This traffic steering method is used in SID stitching scenarios. The BSID of an SRv6 TE policy is inserted into the segment list of another SRv6 TE policy, and the inserted BSID represents the segment lists of the optimal candidate path in the SRv6 TE policy. With this method, the SRH is shortened and different SRv6 TE policies can stitched together.
Traffic steering mechanism
In color-based traffic steering, the device searches for an SRv6 TE policy that has the same color and endpoint address as the color and next hop address of a BGP route. If a matching SRv6 TE policy exists, the device recurses the BGP route to that SRv6 TE policy. When the device receives packets that match the BGP route, it forwards those packets through the SRv6 TE policy.
Traffic steering workflow
Figure 2 shows the process of color-based traffic steering:
1.     The controller issues SRv6 TE policy 1 to Device A (source node). The color value and endpoint address of the SRv6 TE policy is 100 and 5::5 (IP address of Device H), respectively.
2.     Device H advertises BGP VPNv4 route 2.2.2.2/32 to Device A. The color value and next hop address of the route is 100 and 5::5, respectively.
3.     When Device A receives BGP VPNv4 route 2.2.2.2/32, it recurses this route to SRv6 TE policy 1 based on the route's color value and next hop address. Packets matching the BGP route will be forwarded through SRv6 TE policy 1.
Figure 2 Color-based traffic steering
DSCP-based traffic steering is available only after SRv6 TE policy groups are deployed on the device. Each SRv6 TE policy group consists of multiple SRv6 TE policies with different colors but the same endpoint address.
To achieve DSCP-based traffic steering, you can perform the following operations:
1.     Add multiple SRv6 TE policies with different colors to the same SRv6 TE policy group, and configure color-to-DSCP mappings for that SRv6 TE policy group.
2.     Use one of the following methods to steer traffic to the SRv6 TE policy group:
¡     Bind the desired destination address to the SRv6 TE policy group in a tunnel policy. Traffic destined for the destination address will be steered to the SRv6 TE policy group for further forwarding.
¡     Set SRv6 TE policy group as the preferred tunnel type in a tunnel policy. When the next hop address of a route is the endpoint address of the SRv6 TE policy group, the device preferentially steers traffic to the SRv6 TE policy group.
¡     Recurse BGP routes that can match the SRv6 TE policy group to the SRv6 TE policy group. A BGP route can match an SRv6 TE policy group only if its color value and next hop address can match the color value and endpoint address of that SRv6 TE policy group.
3.     Look up for the color value mapped to the DSCP value of a packet, and then use the color value to find the associated SRv6 TE policy in the SRv6 TE policy group.
The above task creates a DSCP > color > SRv6 TE policy mapping, enabling DSCP-based traffic steering to the desired SRv6 TE policy.
Figure 3 shows the process of DSCP-based traffic steering:
1.     The controller issues SRv6 TE policy 1 and SRv6 TE policy 2 to Device A (source node). SRv6 TE policy 1 to Device A (source node). The color values of SRv6 TE policy 1 and SRv6 TE policy 2 are 100 and 200, respectively. The two SRv6 TE policies both use 5::5 as endpoint address, which is the IP address of Device H.
2.     Device H advertises BGP VPNv4 route 2.2.2.2/32 to Device A. The next hop address of the route is 5::5.
3.     SRv6 TE policy group 111 is created on Device A with its endpoint address as 5::5. Within the SRv6 TE policy group, color value 100 is mapped to DSCP value 10, and color value 200 is mapped to DSCP value 20. A tunnel policy is configured on Device A to bind the SRv6 TE policy group to destination address 2.2.2.2.
4.     Device A performs DSCP-based traffic steering for a received packet as follows:
a.     Finds the matching tunnel binding policy based on the packet's destination address, and then finds the related SRv6 TE policy group.
b.     Uses the packet's DSCP value (10 in this example) to find the mapped color value, and then matches an SRv6 TE policy inside the SRv6 TE policy group based on the color value.
c.     Uses the optimal candidate path in this SRv6 TE policy for packet forwarding. In this example, the packet is forwarded along the Device B > Device C > Device D > Device H path, which is in accordance with the SID list in the candidate path.
Figure 3 DSCP-based traffic steering
Once service traffic is steered to an SRv6 TE policy group for forwarding, the device matches the APN ID of the traffic with the color-to-APN ID mappings in the SRv6 TE policy group. If a match is found, the device forwards the traffic through the SRv6 TE policy associated with the color value in the matching mapping.
For more information about APN ID-based traffic steering, see "SRv6 TE policy application in the APN6 network."
CBTS-based traffic steering mechanism
SRv6 TE policy Class Based Tunnel Selection (CBTS) enables dynamic routing and forwarding of traffic with service class values over different SRv6 TE policy tunnels between the same tunnel headend and tailend. CBTS uses a dedicated tunnel for a certain class of service to implement differentiated forwarding for services.
Traffic steering based on CBTS is also achieved through the service-class identifier in packets. However, compared to service-class-based traffic steering, CBTS-based traffic steering does not require redirection to an SRv6 TE policy group.
SRv6 TE policy CBTS processes traffic mapped to a priority as follows:
1.     Uses a traffic behavior to set a service class value for the traffic.
2.     Compares the service class value of the traffic with the service class values of the SRv6 TE policy tunnels and forwards the traffic to a matching tunnel.
SRv6 TE policy CBTS uses the following rules to select an SRv6 TE policy for the traffic to be forwarded:
·     If an SRv6 TE policy has the same service class value as the traffic, CBTS uses this SRv6 TE policy.
·     If multiple SRv6 TE policies have the same service class value as the traffic, CBTS selects an SRv6 TE policy based on the flow identification and load sharing mode:
¡     If only one flow exists and flow-based load sharing is used, CBTS randomly selects a matching SRv6 TE policy for packets of the flow.
¡     If multiple flows exist or if only one flow exists but packet-based load sharing is used, CBTS uses all matching SRv6 TE policies to load share the packets.
·     If the traffic does not match any SRv6 TE policy by service class value, CBTS selects the SRv6 TE policy with the lowest forwarding priority. An SRv6 TE policy that has a smaller service class value has a lower forwarding priority. An SRv6 TE policy that is not configured with a service class value has the lowest priority.
As shown in Figure 4, CBTS selects SRv6 TE policies for traffic from Device A to Device B as follows:
·     Uses SRv6 TE policy B to forward traffic with service class value 3.
·     Uses SRv6 TE policy C to forward traffic with service class value 6.
·     Uses SRv6 TE policy A to forward traffic with service class value 4.
·     Uses SRv6 TE policy A to forward traffic with no service class value.
Figure 4 SRv6 TE Policy CBTS application
CBTS-based traffic steering process
CBTS-based traffic steering works as follows:
1.     The controller delivers an SRv6 TE policy to the ingress node A. SRv6 TE policy 1 has a color of 100, a service class of 1, and an endpoint of device H's address 5::5. SRv6 TE policy 2 has a color of 200, a service class of 2, and the same endpoint of device H's address 5::5.
2.     Device H sends the BGP VPNv4 route 2.2.2.2/32 to the ingress node device A, with the next hop address set to 5::5.
3.     At the ingress node A, the QoS policy marks the service class value of packets based on their five-tuple or other characteristics.
4.     Packets marked with service class 1 by ingress node A are forwarded through SRv6 TE policy 1, while packets marked with service class 2 are forwarded through SRv6 TE policy 2.
This feature advertises an SRv6 TE policy or an SRv6 TE policy group (a group of SRv6 TE policies) to IGP (IPv6 IS-IS or OSPFv3) for route computation. The device can then forward the matching traffic through the SRv6 TE policy or SRv6 TE policy group.
An SRv6 TE policy or SRv6 TE policy group supports only automatic route advertisement (also called autoroute announce) in IGP shortcut mode. With automatic route advertisement enabled, the device determines the SRv6 TE policy or SRv6 TE policy group as a link that connects the tunnel ingress and egress. The tunnel ingress includes the SRv6 TE policy or SRv6 TE policy group in IGP route computation.
After traffic is steered to an SRv6 TE policy group through automatic route advertisement, the device looks up for the matching SRv6 TE policy in the SRv6 TE policy group based on DSCP or 802.1p value. Then, the device forwards the traffic through the matching SRv6 TE policy.
As shown in Figure 5, an SRv6 TE policy tunnel is deployed between Device D and Device C. IGP Shortcut enables the source node, Device D, to utilize this tunnel during IGP route computation. Consequently, Device D can steer incoming packets to the SRv6 TE policy tunnel between Device D and Device C.
Figure 5 Automatic route advertisement
·     Tunnel policy—In an MPLS L3VPN, EVPN L3VPN, EVPN VPLS, or EVPN VPWS network, use an SRv6 TE policy as the public tunnel to carry the packets of a VPN instance. For more information about the tunnel policy configuration, see MPLS Configuration Guide.
·     Static route—Configures a static route that recurses to an SRv6 TE policy. The device uses the SRv6 TE policy to forward the packets that match the static route.
·     QoS policy—Redirects traffic to an SRv6 TE policy through a QoS policy. The device uses the SRv6 TE policy to forward the packets that match the traffic classes of the QoS policy. For more information about QoS policies, see the QoS configuration in ACL and QoS Configuration Guide.
·     Flowspec—Redirects traffic to an SRv6 TE policy through a Flowspec rule. The device uses the SRv6 TE policy to forward the packets that match the Flowspec rule. For more information about Flowspec, see ACL and QoS Configuration Guide.
After traffic is steered in to an SRv6 TE policy, the SRv6 TE policy selects a forwarding path for the traffic as follows:
1.     Selects the valid candidate path that has the highest preference.
2.     Performs Weighted ECMP (WECMP) load sharing among the SID lists of the selected candidate path. The load of SID list x is equal to Weight x/(Weight 1 + Weight 2 + … + Weight n).
For example, as shown in Figure 6, Device A first selects a valid SRv6 TE policy by BSID. Then, the device selects a candidate path by preference. The candidate path has two valid SID lists: SID list 1 and SID list 2. The weight value of SID list 1 is 20 and the weight value of SID list 2 is 80. One fifth of the traffic will be forwarded through the subpath identified by SID list 1. Four fifth of the traffic will be forwarded through the subpath identified by SID list 2.
Figure 6 SRv6 TE policy path selection
1.     For SRv6 TE policies, supported packet encapsulation methods include normal encapsulation and insert encapsulation. In normal encapsulation, the device adds a new IPv6 header and an SRH to each packet. In insert encapsulation, the device inserts an SRH extension header after the original IPv6 header.
2.     The packet forwarding process varies by packet encapsulation method.
SRv6 TE policy-based packet forwarding with the normal encapsulation method
1.     As shown in Figure 7, BSID-based traffic steering is used in the SID stitching scenario. The packet forwarding process is as follows:
2.     Device A steers traffic to SRv6 TE policy A for further forwarding. The SIDs of SRv6 TE policy A are stitched with the BSID of SRv6 TE policy B, 20::2. According to SRv6 TE policy A, the device encapsulates the packet with an SRH header that carries an SID list of {10::2, 20::2, 50::2}. 10::2 represents the End SID of Device B, and 50::2 represents the End SID of Device F.
3.     Device A transmits the encapsulated packet to the next hop, Device B.
4.     Device B obtains next hop information (Device C) from the SRH of the encapsulated packet, and transmits the packet to Device C.
5.     Device C finds that the encapsulated packet is heading for 20::2, which is the BSID of SRv6 TE policy B. The encapsulation method for SRv6 TE policy B is normal encapsulation. Therefore, Device C encapsulates the packet with an outer IPv6 header and an SRH according to SRv6 TE policy B. The SRH carries a SID list of {30::2, 40::2}, where 30::2 is the End SID for Device D, and 40::2 is the End SID for Device E. The destination address in the outer IPv6 header is updated to 30::2, with the next hop set to Device D. After packet encapsulation, Device C transmits the packet to Device D.
6.     Device D finds that the next hop pointed by the outer SRH of the encapsulated packet is Device E, and then transmits the packet to Device E.
7.     Device E finds that the SL value in the outer SRH of the encapsulated packet is 0, and thus perform the following operations:
a.     Decapsulates the packet by removing its outer IPv6 header and SRH.
b.     Transmits the packet to Device F, which is the destination address of the packet.
8.     Device F finds that the SL value in the outer SRH of the encapsulated packet is 0. As the egress node of SRv6 TE policy A, Device F decapsulates the packet by removing its outer IPv6 header and SRH.
Figure 7 SRv6 TE policy-based packet forwarding with the normal encapsulation method
SRv6 TE policy-based packet forwarding with the insert encapsulation method
1.     As shown in Figure 8, BSID-based traffic steering is used in the SID stitching scenario. The packet forwarding process is as follows:
2.     Device A steers traffic to SRv6 TE policy A for further forwarding. The SIDs of SRv6 TE policy A are stitched with the BSID of SRv6 TE policy B, 20::2. According to SRv6 TE policy A, the device encapsulates the packet with an SRH that carries an SID list of {10::2, 20::2, 50::2}. 10::2 represents the End SID of Device B, and 50::2 represents the End SID of Device F.
5.     Device C finds that the encapsulated packet is heading for 20::2, which is the BSID of SRv6 TE policy B. The encapsulation method for SRv6 TE policy B is insert encapsulation. Therefore, Device C inserts an SRH after the original IPv6 header of the packet according to SRv6 TE policy B. The SRH carries a SID list of {30::2, 40::2}, where 30::2 is the End SID for Device D, and 40::2 is the End SID for Device E. The destination address in the outer IPv6 header is updated to 30::2, with the next hop set to Device D. After packet encapsulation, Device C transmits the packet to Device D.
7.     Device E finds that the SL value in the outer SRH of the encapsulated packet is 0, and thus perform the following operations for the packet:
a.     Removes the outer SRH and updates the destination address in the outer IPv6 header to 50::2.
Figure 8 SRv6 TE policy-based packet forwarding with the insert encapsulation method
SRv6 TE policy ensures reliable traffic forwarding through the collaboration of multiple mechanisms, including:
·     Hot standby between candidate paths—SRv6 TE policy supports hot standby among multiple valid candidate paths and leverages BFD detection to trigger fast switchover between primary and backup paths.
·     Transit node protection through SRv6 TE FRR—It provides transit node protection to safeguard critical nodes or links along the path.
·     Egress node protection in dual-homing VPN scenarios—It ensures redundancy for egress nodes in dual-homed VPN networks.
Through the above reliability mechanisms, SRv6 TE policy delivers multi-layer and multi-level protection for traffic forwarding.
If an SRv6 TE policy has multiple valid candidate paths, the device chooses the candidate path with the greatest preference value. If the chosen path fails, the SRv6 TE policy must select another candidate path. During path reselection, packet loss might occur and thus affect service continuity.
The SRv6-TE hot standby feature can address this issue. This feature takes the candidate path with the greatest preference value as the primary path and that with the second greatest preference value as the backup path in hot standby state. As shown in Figure 9, when the forwarding paths corresponding to all SID lists of the primary path fails, the standby path immediately takes over to minimize service interruption.
Figure 9 SRv6 TE policy hot standby
You can configure both the hot standby and SBFD features for an SR-TE policy. Use SBFD to detect the availability of the primary and standby paths specified for hot standby. If all SID lists of the primary path become unavailable, the standby path takes over and a path recalculation is performed. The standby path becomes the new primary path, and a new standby path is selected. If both the primary and standby paths fail, the SR-TE policy will calculate new primary and standby paths.
Echo BFD for SRv6 TE policy
Echo BFD (BFD in echo packet mode) does not require the initiator and the reflector use the same discriminator for testing the connectivity of an SRv6 TE policy. As such, you do not need to plan local and remote discriminators. This makes echo BFD easier to configure than SBFD for SRv6 TE policy.
Echo BFD tests the connectivity of an SRv6 TE policy as follows:
1.     The source node sends BFD echo packets that each encapsulate a SID list of the SRv6 TE policy.
2.     After the endpoint node receives an BFD echo packet, it sends the BFD echo packet back to the source node along the shortest path selected through IPv6 routing table lookup.
3.     If the source node receives the BFD echo packet within the detection timeout time, it determines that the SID list (forwarding path) under test is available. If no BFD echo packet is received, the device determines that the SID list is faulty. If all the SID lists for the primary path are faulty, BFD triggers a primary-to-backup path switchover.
If multiple SID lists are present in the selected candidate path, the SRv6 TE policy establishes separate BFD sessions to monitor the forwarding path corresponding to each SID list.
When echo BFD is enabled for an SRv6 TE policy, BFD packets can be encapsulated in Insert or Encaps mode. By default, BFD packets use the Insert encapsulation mode.
As shown in Figure 10, configure an SRv6 TE policy on Device A and use echo BFD to detect the policy connectivity. If Insert encapsulation is used for BFD packets, Device A constructs a special BFD packet with its local IPv6 address (a) as the source address and inserts IPv6 address a to the SL=0 position in the SID list. When Device D receives the BFD packet, it updates the destination address in the IPv6 header to a, and uses IPv6 address a to look up the routing table to send the packet back to Device A.
For more information about selecting the source address for BFD packets, see "Configuring the BFD echo packet mode for SRv6 TE policies."
Figure 10 Echo BFD for SRv6 TE policy with Insert encapsulation
As shown in Figure 11, Device A configures an SRv6 TE policy and uses echo BFD to detect connectivity for this policy. If Encaps encapsulation is used for BFD packets, Device A first constructs a BFD packet with both source and destination addresses set to its local IPv6 address a. Then, Device A encapsulates the BFD packet with an additional IPv6 header and an SRH header. The outer IPv6 header's source address is specified by the encapsulation source-address command, and the SRH header contains the SID list of the SRv6 TE policy. When Device D receives the BFD packet, it performs decapsulation on the outer IPv6 and SRH headers, and then uses IPv6 address a to look up the IPv6 routing table to send the packet back to Device A.
Figure 11 Echo BFD for SRv6 TE policy with Encaps encapsulation
SRv6 use seamless BFD (SBFD) to detect path connectivity of SRv6 TE policies, instead of sending messages between nodes. SBFD enables an SRv6 TE policy to detect path failures in milliseconds for fast path switchover.
SBFD detects the connectivity of an SRv6 TE policy as follows:
1.     The source node (the initiator) sends SBFD packets that encapsulate the SID lists of the primary and backup candidate paths of the SRv6 TE policy.
2.     After the endpoint node (the reflector) receives an SBFD packet, it checks whether the remote discriminator carried the packet is the same as the local discriminator. If yes, the reflector sends the SBFD response packet to the initiator by using the IPv6 routing table. If not, the reflector drops the SBFD packet.
3.     If the source node can receive the SBFD response within the detection timeout time, it determines the corresponding SID list (forwarding path) of the SRv6 TE policy is available. If no response is received, the source node determines that the SID list is faulty.
If multiple SID lists are present in the selected candidate path, the SRv6 TE policy establishes separate SBFD sessions to monitor the forwarding path corresponding to each SID list.
When SBFD is enabled for an SRv6 TE policy, SBFD packets can be encapsulated in Insert or Encaps mode. By default, SBFD packets use the Insert encapsulation mode.
As shown in Figure 12, Device A configures an SRv6 TE policy and uses SBFD to detect connectivity for this policy. When using Insert encapsulation for SBFD packets, Device A constructs an SBFD packet with its local IPv6 address a as the source address and inserts the endpoint address e of the SRv6 TE policy to the SL=0 position in the SID list. When Device D receives the SBFD packet, it performs decapsulation on the IPv6 and SRH headers. Then, it uses IPv6 address a to look up the IPv6 routing table, reconstructs the SBFD packet, and returns the SBFD packet to Device A.
Figure 12 SBFD for SRv6 TE policy with Insert encapsulation
As shown in Figure 13, Device A configures an SRv6 TE policy and uses SBFD to detect connectivity for this policy. When using Encaps encapsulation for SBFD packets, Device A constructs an SBFD packet with its local IPv6 address a as the source address and the endpoint address e of the SRv6 TE policy as the destination address. Additionally, it encapsulates the SBFD packet with an outer IPv6 header and an SRH header, using IPv6 address a as the IPv6 header's source address. When Device D receives the SBFD packet, it performs decapsulation on the outer IPv6 and SRH headers. Then, it uses IPv6 address a to look up the IPv6 routing table, reconstructs the SBFD packet, and returns the SBFD packet to Device A.
Figure 13 SBFD for SRv6 TE policy with Encaps encapsulation
Because SBFD responses are forwarded according to the IPv6 routing table lookup, all SBFD sessions for the SRv6 TE policies that have the same source and destination nodes use the same path to send responses. A failure of the SBFD response path will cause all the SBFD sessions to be down and packets cannot be forwarded through the SRv6 TE policies.
SBFD for SRv6 TE policy by using specific reverse path
By default, the SBFD return packets used for SRv6 TE policy connectivity detection are forwarded based on the IP forwarding path. If a transit node fails, all the return packets will be discarded, and the SBFD sessions will go down as a result. If multiple SRv6 TE policies exist between the source and endpoint nodes, SBFD will mistakenly determine that the SID lists of all SRv6 TE policies are faulty.
To resolve this issue, you can enable SBFD return packets to be forwarded based on the specified SID list. Generally for SRv6 TE policies, the path specified for SBFD return packets (reverse path) is consistent with the path for forwarding SBFD packets (forward path). This scenario is known as SBFD forward and reverse path consistency.
You can specify the SBFD reverse path by specifying a reverse BSID.
As shown in Figure 14, the reverse BSID method is implemented as follows (using the Insert encapsulation mode):
1.     Create an SRv6 TE policy on both Device A and Device D, named AtoD and DtoA, respectively. The forwarding path for SRv6 TE policy AtoD is A > B > C > D and that for SRv6 TE policy DtoA is D > F > E > A. On Device D, assign local BSID x to SID list D > F > E > A.
2.     Enable SBFD for SRv6 TE policy AtoD on Device A, and set the reverse BSID for SBFD return packets to x, which is the same as the local BSID specified on Device D. When Device A sends an SBFD packet, it encapsulates an Aux Path TLV (TLV for the backup path) in the packet, which includes the reverse BSID.
3.     When Device D receives the SBFD packet, it compares the reverse BSID in the packet with the local BSID. If they are the same, Device D re-encapsulates the IPv6 header and SRH for the return SBFD packet, where the SRH contains the SID list associated with the local BSID.
4.     The return packet will then follow path D > F > E > A in the SID list back to Device A.
Figure 14 SBFD for SRv6 TE policy by using specific reverse path (reverse BSID)
Protection path failure
The SID list of an SRv6 TE policy specifies the nodes or links that packets must traverse. As shown in Figure 15, node A forwards packets to node F through an SRv6 TE policy. The optimal candidate path's SID list in the SRv6 TE policy includes the End.SID of node D and the End.SID of the egress node F. Therefore, forwarded packets must pass through node D before reaching node F. When node D fails, even if TI-LFA FRR is enabled on the upstream node B, the backup path calculated by TI-LFA FRR still uses node D's End.SID as the destination address. As a result, the backup path cannot bypass node D, failing to achieve the intended protection effect.
Figure 15 Protection path failure
Transit node protection (SRv6 TE FRR)
By enabling the transit node protection (SRv6 TE FRR) feature on upstream node B (the node preceding the mandatory node D), node B can perform proxy forwarding to bypass the failed transit node D and complete packet forwarding. This resolves the issue where TI-LFA FRR cannot circumvent failures of mandatory transit nodes. The upstream node is called a proxy forwarding node.
After SRv6 TE FRR is enabled on a node, upon receiving a packet that contains an SRH and the SL in the SRH is greater than 0 (SL>0), the node will act as a proxy forwarding node in any of the following scenarios:
·     The node does not find a matching forwarding entry in the IPv6 FIB.
·     The next hop address of the packet is the destination address of the packet, and the outgoing interface for the destination address is in DOWN state.
·     The matching local SRv6 SID is an END.X SID, and the outgoing interface for the END.X SID is in DOWN state.
·     The outgoing interface in the matching route is NULL0.
A proxy forwarding node forwards packets as follows:
·     Decrements the SL value in the SRH of a packet by 1.
·     Copies the next SID to the DA field in the outer IPv6 header, so as to use the SID as the destination address of the packet.
·     Looks up the forwarding table by the destination address and then forwards the packet.
In this way, the proxy forwarding node bypasses the fault node. This transit node failure protection technology is referred to as SRv6 TE FRR.
Figure 16 SRv6 TE FRR for transit node failure protection
As shown in Figure 16, after a packet is steered into an SRv6 TE policy, the packet is forwarded as instructed by the SID list {d, f}.
When node D fails, the node failure protection process is as follows:
1.     Upstream node B detects that the next hop of the packet is faulty. In this situation, the output interface for the destination address of the packet is in DOWN state, and the SL value is greater than 0. Therefore, node B performs the proxy forwarding behavior: Decrements the SL value by 1, copies the next SID to the DA field in the outer IPv6 header, and then forwards the packet according to the SID (destination address of the packet). Because the SL value is now 0, node B can remove the SRH and then search the corresponding table to forward the packet based on the destination address (f).
2.     Node B forwards the packet as follows:
¡     If the route to node F is converged (the next hop in the route is node C), node B uses the converged shortest path to forward the packet to node C.
¡     If the route to node F is not converged (the primary next hop in the route is node D), node B uses the TI-LFA computed backup path to forward packet. The backup path's repair list is <c1>. Therefore, node B encapsulates an SRH to the packet to add backup path Segment List c1, and then forwards the packet over the backup path to node F.
Special processing on the source node
If source node A (ingress node) of the SRv6 TE policy detects the failure of node D (the first SID in the SID list is unreachable), node A then places the SRv6 TE policy to the down state. The device cannot forward packets through the SRv6 TE policy or trigger SRv6 TE FRR.
To resolve this issue, enable the bypass feature for the SRv6 TE policy on the source node. This feature enables the source node to generate a route that uses the first SID as the destination address and the NULL0 interface as the outgoing interface. The route ensures that the SRv6 TE policy is in up state when the first SID is unreachable, so as to trigger SRv6 TE FRR.
After node A triggers SRv6 TE FRR, node A decrements the SL value by 1, copies the next SID (f) to the DA field in the outer IPv6 header, and then forwards the packet to node B according to the SID (destination address of the packet).
When node B receives the packet, it processes the packet as follows:
·     If the route to node F is converged (the next hop in the route is node C), node B uses the converged shortest path to forward the packet to node C.
·     If the route to node F is not converged (the primary next hop in the route is node D), node B uses the TI-LFA computed backup path to forward the packet to node F.
In IP L3VPN over SRv6/EVPN L3VPN over SRv6/EVPN VPLS over SRv6/EVPN VPWS over SRv6/public IP over SRv6 networks, when the public tunnel is an SRv6 tunnel, a failure at the egress node of the SRv6 tunnel prevents packets from being forwarded by the egress PE device to the CE device. Therefore, protection for the egress node of the SRv6 tunnel is necessary.
SRv6 egress node protection is achieved by dual-homing the CE to PE devices. As a result, this mechanism is only applicable to dual-homing network scenarios and requires the egress PE and the backup PE (providing protection for the egress node) to maintain identical forwarding entries.
IMPORTANT
IMPORTANT:
SRv6 TE policy egress protection is not supported in EVPN VPLS over SRv6 and EVPN VPWS over SRv6 networks if dual homing is configured in the networks and the redundancy mode is single-active.
SRv6 egress node protection is not only effective for scenarios where SRv6 TE policy serves as the tunnel, but also works in network deployments using SRv6 BE forwarding mode.
Deploy an SRv6 TE policy between PE 1 and PE 3. PE 3 is the egress node (endpoint node) of the SRv6 TE policy. To improve forwarding reliability, CE 2 is dual-homed to PE 3 and PE 4.
End.M SID
In SRv6 TE policy egress protection, an End.M SID is used to protect the SRv6 SIDs in a specific locator. If an SRv6 SID advertised by the remote device (PE 3 in this example) is within the locator, the protection node (PE 4) uses the End.M SID to protect that SRv6 SID (remote SRv6 SID).
PE 4 takes different actions as instructed by an End.M SID in different network scenarios:
·     MPLS/EVPN L3VPN over SRv6 TE policy scenario
a.     Removes the outer IPv6 header to obtain the remote SRv6 SID from the inner packet.
b.     Searches the remote SRv6 SID and VPN instance mapping table to find the VPN instance mapped to the remote SRv6 SID.
c.     Forwards the packet by looking up the routing table of the VPN instance.
·     EVPN VPWS over SRv6 TE policy scenario
b.     Searches the remote SRv6 SID and cross-connect mapping table to find the cross-connect mapped to the remote SRv6 SID.
c.     Forwards the packet to the AC associated with the cross-connect.
In this scenario, the remote SRv6 SID can only be an End.DX2 SID.
·     EVPN VPLS over SRv6 TE policy scenario
b.     Searches the remote SRv6 SID and VSI mapping table to find the VSI mapped to the remote SRv6 SID.
c.     Forwards the packet according to the MAC address forwarding table of the VSI.
In this scenario, the remote SRv6 SID can only be an End.DT2U SID.
Remote SRv6 SID
PE 4 receives a BGP route from PE 3. If the SRv6 SID in the BGP route is within the locator protected by the End.M SID on PE 4, PE 4 regards the SRv6 SID as a remote SRv6 SID and generates a mapping between the remote SRv6 SID and the VPN instance, cross-connect, or VSI.
When the adjacency between PE 4 and PE 3 breaks, PE 4 deletes the BGP route received from PE 3. As a result, the remote SRv6 SID and VPN instance/cross-connect/VSI mapping will be deleted, resulting in packet loss. To avoid this issue, you can configure the mappings deletion delay time on PE 4 to ensure that traffic is forwarded through PE 4 before PE 1 knows the PE 3 failure and computes a new forwarding path.
Route advertisement
The route advertisement procedure is similar in IP L3VPN, EVPN L3VPN, EVPN VPWS, or EVPN VPLS over SRv6 TE policy egress protection scenarios. The following example describes the route advertisement in an IP L3VPN over SRv6 TE policy egress protection scenario.
The FRR path is generated on P 1 as follows:
1.     PE 4 advertises the End.M SID and the protected locator to P 1 through an IS-ISv6 route. Meanwhile, PE 4 generates a local SID entry for the End.M SID.
2.     After P1 receives the End.M SID and the route for the protected locator from PE4, P1 installs a mirror FRR backup path for the protected locator, with PE4 as the next hop. To ensure that traffic does not pass through the faulty PE3 and arrives at PE4 without a loop, a TI-LFA FRR backup path is typically calculated, and the End.M SID is pushed to the end of the SID list for the TI-LFA FRR backup path.
On PE 4, a <remote SRv6 SID, VPN instance > mapping entry is generated as follows:
1.     Upon receiving the private route from CE 2, PE 3 encapsulates the route as a VPNv4 route and sends it to PE 4. The VPNv4 route carries the SRv6 SID, RT, and RD information.
2.     After PE 4 receives the VPNv4 route, it obtains the SRv6 SID and the VPN instance. Then, PE 4 performs longest matching of the SRv6 SID against the locators protected by End.M SIDs. If a match is found, PE 4 uses the SRv6 SID as a remote SRv6 SID and generates a <remote SRv6 SID, VPN instance> mapping entry.
Packet forwarding
The packet forwarding procedure is similar in IP L3VPN, EVPN L3VPN, EVPN VPWS, or EVPN VPLS over SRv6 TE policy egress protection scenarios. The following example describes the packet forwarding in an IP L3VPN over SRv6 TE policy egress protection scenario.
Typically, traffic is forwarded along the CE 1-PE 1-P 1-PE 3-CE 2 path. When the egress node PE 3 fails, a packet is forwarded as follows:
Upon detecting that the next hop PE 3 is unreachable, P 1 switches to the mirror FRR path. In this example, the optimal link from P 1 to PE 4 does not require traversing PE 3, eliminating the need to encapsulate the TI-LFA FRR SID list. Instead, P 1 directly encapsulates the packet with an IPv6 header, sets the destination address to the End.M SID, and forwards it to PE 4.
PE 4 identifies the destination address as its local End.M SID. Following the forwarding instruction associated with the End.M SID, PE 4 removes the outer IPv6 header to access the inner packet. It then queries the remote SRv6 SID-to-VPN instance mapping table based on the inner packet’s destination address to locate the corresponding VPN instance 1. Finally, PE 4 consults the routing table of VPN instance 1 to forward the traffic to CE 2.
About APN6
Application-aware IPv6 networking (APN6) is a new type of network. APN6 uses the Destination Option Header (DOH) in IPv6 packets to carry application information for the network to identify applications, perceive application requirements, and provide precise and differentiated network services for various application services.
IETF defines the DOH to carry the following application information:
·     APN ID—ID of an application. A network device differentiates the service flows of different applications based on their APN IDs.
·     APN parameters—Parameters that represent the network quality requirements of an application’s service flows, including bandwidth, latency, jitter, and packet loss rate. A network device uses these parameters to perceive the network quality requirements of the application's service flows.
In the APN6 network, you can apply the SRv6 TE policy, SRv6 network slicing, SRv6 SFC (or SRv6 service chain), and iFiT technologies for the device to flexibly select paths based on the application information in packets and monitor network quality for critical application services in real time.
APN ID-based traffic forwarding
This section uses the IPv6 L3VPN over SRv6 TE policy network as an example to describe APN ID-based traffic forwarding in SRv6 TE policy scenarios, as shown in Figure 17.
Figure 17 Diagram for APN ID-based traffic forwarding
The operating mechanism for APN ID-based traffic forwarding is as follows:
1.     Create an SRv6 TE policy group on Device A, and create multiple SRv6 TE policies with different color attribute values but the same endpoint address in this group. Configure color-to-APN ID mappings in the SRv6 TE policy group.
2.     Steer traffic to the SRv6 TE policy group by using one of the following methods:
¡     Configure a tunnel policy and bind the SRv6 TE policy group to a destination address in the tunnel policy. The configuration ensures that the traffic destined for the specified destination address will be steered to the SRv6 TE policy group for forwarding.
¡     Configure a tunnel policy and configure the SRv6 TE policy group as the preferred tunnel in the tunnel policy. When traffic matches a route whose next hop address is the endpoint address of the SRv6 TE policy group, the device preferentially steers the traffic to the SRv6 TE policy group for forwarding.
¡     The device searches for an SRv6 TE policy group with color and endpoint address matching the color extended community attribute and next hop in a BGP route, and recurses the BGP route to the SRv6 TE policy group.
3.     In the SRv6 TE policy group, specify the forward type as APN ID-based forwarding and create mappings between APN IDs and forwarding policies. The device supports the following types of mappings:
¡     Color-to-APN ID mapping—Device A steers packets with a specific APN ID to the SRv6 TE policy associated with the color attribute value mapped to that VPN ID. As shown in Figure 17, APN 10 establishes a mapping relationship with SRv6 TE policy 1, and APN 20 establishes a mapping relationship with SRv6 TE policy 2. In this way, mappings are established among APN IDs, colors, and SRv6 TE policies to forward packets carrying specific APN IDs through specific SRv6 TE policies.
¡     SRv6 BE-to-APN ID mapping—The device forwards packets with specific APN IDs in SRv6 BE mode. In SRv6 BE mode, Device A encapsulates the packets with a new IPv6 header. The destination address in the IPv6 header is the VPN SID assigned by the egress node of the SRv6 TE policy group to the public network or to a VPN instance. Then, the device looks up the IPv6 routing table for a matching route and forwards the packets through the output interface.
IMPORTANT
IMPORTANT:
For APN ID-based traffic forwarding, compared with SRv6 BE forwarding, SRv6 TE policy forwarding has controllable paths and provides higher availability, and can be combined with iFIT measurement methods to detect the network quality of end-to-end fixed forwarding paths. As a best practice, use SRv6 TE policy tunnels to forward traffic for critical application services and use SRv6 BE forwarding to forward traffic for non-critical services or services without SLA requirements. In addition, you can specify SRv6 BE forwarding as a backup forwarding method for SRv6 TE policy forwarding.
To configure an SRv6 TE policy, perform the following tasks:
1.     Configuring IGP-based SID advertisement
Perform this task on each SRv6 node. For more information, see "Configuring IPv6 Segment Routing."
2.     Configuring a SID list
3.     Configuring an SRv6 TE policy
a.     Creating an SRv6 TE policy
b.     Configuring a candidate path
c.     Enter system view.
d.     system-view
e.     (Optional.) Enabling the device to distribute SRv6 TE policy candidate path information to BGP-LS
f.     (Optional.) Shutting down an SRv6 TE policy
4.     (Optional.) Configuring BGP to advertise BGP IPv6 SR policy routes
a.     Enabling BGP to advertise BGP IPv6 SR policy routes
b.     Configuring BGP to redistribute BGP IPv6 SR policy routes
c.     (Optional.) Enabling advertising BGP IPv6 SR policy routes to EBGP peers
d.     (Optional.) Enabling Router ID filtering
e.     (Optional.) Enabling validity check for BGP IPv6 SR policy routes
f.     (Optional.) Configuring BGP to control BGP IPv6 SR policy route selection and advertisement
g.     (Optional.) Maintaining BGP sessions
5.     Configuring SRv6 TE policy traffic steering
6.     (Optional.) Configuring the SRv6 TE policy encapsulation mode
7.     (Optional.) Configuring high availability features for SRv6 TE policy
¡     Enabling SBFD for SRv6 TE policies
¡     Configuring the BFD echo packet mode for SRv6 TE policies
¡     Enabling hot standby for SRv6 TE policies
¡     Configuring path switchover and deletion delays for SRv6 TE policies
¡     Configuring SRv6 TE policy egress protection
8.     (Optional.) Configuring advanced SRv6 TE policy features
¡     Configuring the TTL processing mode of SRv6 TE policies
¡     Configuring SRv6 TE policy CBTS
¡     Configuring a rate limit for an SRv6 TE policy
¡     Enabling the device to drop traffic when an SRv6 TE policy becomes invalid
¡     Specifying the packet encapsulation type preferred in optimal route selection
9.     (Optional.) Configuring traffic forwarding statistics for SRv6 TE policies
Before you specify a SID list for a candidate path in an SRv6 TE policy, you need to create the SID list and add nodes to the SID list.
After you add nodes to a SID list, the system will sort the nodes in ascending order of node index. The node with the smallest index represents the next hop of the source node on the forwarding path.
To reduce the SRH cost, you can use four 32-bit G-SIDs to represent one normal 128-bit SRv6 SID. In a SID list, you can add a 128-bit SRv6 SID with a COC flavor, indicating that the next node of the current node is a 32-bit G-SID. For more information about G-SIDs, see IPv6 Segment Routing configuration.
When you add a G-SID to the SID list, follow these restrictions and guidelines:
·     The SRv6 SID corresponding to the previous node of the G-SID must be an End(COC32) SID or End.X(COC32) SID.
·     The SRv6 SID corresponding to the last node in the SID list cannot carry the COC flavor.
2.     Enable SRv6 and enter SRv6 view.
segment-routing ipv6
By default, SRv6 is disabled.
3.     Create and enter the SRv6 TE view.
traffic-engineering
4.     Create a SID list and enter its view.
segment-list segment-list-name
5.     Add a node to the SID list.
¡     Add a normal 128-bit SRv6 SID.
index index-number ipv6 ipv6-address
¡     Add a 128-bit SRv6 SID with the COC flavor and specify the length of the common prefix of the next G-SID.
index index-number coc32 ipv6 ipv6-address common-prefix-length
An SRv6 TE policy is identified by the following items: BSID, color, and endpoint.
You can bind a BSID to the policy manually, or set only the color and endpoint attributes of the policy so the system automatically assigns a BSID to the policy. If you use both methods, the manually bound BSID takes effect.
The configured BSID must be on the locator specified for SRv6 TE policies in SRv6 TE view. Otherwise, the SRv6 TE policy cannot forward packets. For more information about the locator configuration, see "Configuring IPv6 Segment Routing."
Different SRv6 TE policies cannot have the same color or endpoint IP address.
2.     Enter SRv6 view.
3.     Enter SRv6 TE view.
traffic-engineering
4.     Specify a locator for SRv6 TE.
srv6-policy locator locator-name
By default, no locator is specified for SRv6 TE.
5.     Enter SRv6 TE policy view.
policy policy-name
6.     Configure a BSID for the policy.
binding-sid ipv6 ipv6-address
7.     Set the color and endpoint attributes.
color color-value end-point ipv6 ipv6-address
By default, the color and endpoint attributes of an SRv6 TE policy are not configured.
When the device receives a BGP route, if the color extended attribute value of the BGP route is the same as the color value of an ODN template, the device automatically creates an SRv6 TE policy and two candidate paths for the policy. The automatically created candidate paths use preferences 100 and 200.
You can specify an IPv6 prefix list to filter BGP routes. The BGP routes permitted by the specified IPv6 prefix list can trigger ODN to create SRv6 TE policies. The BGP routes denied by the specified IPv6 prefix list cannot trigger ODN to create SRv6 TE policies.
An ODN-created SRv6 TE policy is deleted immediately when the matching BGP route is deleted. To avoid packet loss before the new forwarding path is computed, you can configure a proper deletion delay time for the SRv6 TE policy.
You must configure candidate paths for an ODN-created SRv6 TE policy as follows:
1.     Manually create candidate paths that use preferences other than 100 and 200.
2.     Configure the SID lists for the candidate paths.
2.     Enter SRv6 view.
traffic-engineering
5.     Create an ODN template and enter SRv6 TE ODN view.
on-demand color color-value
6.     (Optional.) Configure the ODN SRv6 TE policy generation policy.
restrict prefix-list-name
By default, a BGP route can trigger ODN to create an SRv6 TE policy when the route's color attribute value is the same as the ODN color.
After this feature is enabled, the device distributes SRv6 TE policy candidate path information to BGP-LS. BGP-LS advertises the SRv6 TE policy candidate path information in routes to meet application requirements.
Before you configure this feature, enable the device to exchange LS information with the related peer or peer group. For more information about the LS exchange capability, see the BGP LS configuration in Layer 3—IP Routing Configuration Guide.
2.     Enter SRv6 view.
traffic-engineering
4.     Enable the device to distribute SRv6 TE policy candidate path information to BGP-LS.
distribute bgp-ls
By default, the device cannot distribute SRv6 TE policy candidate path information to BGP-LS.
This feature controls the administrative state of an SRv6 TE policy.
If multiple SRv6 TE policies exist on the device, you can shut down unnecessary SRv6 TE policies to prevent them from affecting traffic forwarding.
2.     Enter SRv6 view.
traffic-engineering
4.     Enter SRv6 TE policy view.
policy policy-name
5.     Shut down the SRv6 TE policy.
shutdown
By default, an SRv6 TE policy is not administratively shut down.
2.     Enter SRv6 view.
traffic-engineering
policy policy-name
5.     Create and enter SRv6 TE policy candidate path view.
candidate-paths
6.     Set the preference for a candidate path and enter SRv6 TE policy path preference view.
preference preference-value
By default, no candidate path preferences are set.
Each preference represents a candidate path.
7.     Specify an explicit path for the candidate path.
explicit segment-list segment-list-name [ weight weight-value ]
A candidate path can have multiple SID lists.
For more information about BGP commands, see Layer 3—IP Routing Commands.
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured.
3.     Enable a BGP instance and enter its view.
By default, BGP is disabled and no BGP instances exist.
4.     Configure a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
5.     Create the BGP IPv6 SR policy address family and enter its view.
address-family ipv6 sr-policy
6.     Enable BGP to exchange BGP IPv6 SR policy routing information with the peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, the device cannot use BGP to exchange BGP IPv6 SR policy routing information with a peer or peer group.
After you configure BGP to redistribute BGP IPv6 SR policy routes, the system will redistribute the local BGP IPv6 SR policy routes to the BGP routing table and advertise the routes to peers. Then, the peers can forward traffic based on the SRv6 TE policy.
3.     Enter BGP IPv6 SR policy address family view.
4.     Enable BGP to redistribute routes from BGP IPv6 SR policies.
import-route sr-policy
By default, BGP does not redistribute BGP IPv6 SR policy routes.
By default, BGP IPv6 SR policy routes are advertised among IBGP peers. To advertise BGP IPv6 SR policy routes to EBGP peers, you must perform this task to enable the advertisement capability.
4.     Enable advertising BGP IPv6 SR policy routes to EBGP peers.
advertise ebgp enable
By default, BGP IPv6 SR policy routes are not advertised to EBGP peers.
For the device to process only part of the received BGP IPv6 SR policy routes, you can perform this task to enable filtering the routes by Router ID.
This feature enables the device to check the Route Target attribute of a received BGP IPv6 SR policy route.
·     If the Route Target attribute contains the Router ID of the local device, the device accepts the route and generates an SRv6 TE policy accordingly.
·     If the Route Target attribute does not contain the Router ID of the local device, the device processes the route as follows:
¡     If the bgp-rib-only keyword is not specified in the command, the device drops the route.
¡     If the bgp-rib-only keyword is specified in the command, the device accepts the route but does not generate the corresponding SRv6 TE policy.
When the controller advertises a BGP IPv6 SR policy route to the source node, the transit nodes between the controller and the source node only need to forward the BGP IPv6 SR policy route. They do not need to generate the SRv6 TE policy. In this case, you can execute the router-id filter bgp-rib-only command on the transit nodes. Then, when a transit node receives a BGP IPv6 SR policy route, it forwards the route even if the route's Route Target attribute does not contain the Router ID of the local device. Meanwhile, it does not generate an SRv6 TE policy in order to not affect packet forwarding.
To use Router ID filtering, make sure you add Route Target attributes to BGP IPv6 SR policy routes properly by using routing policy or other methods. Otherwise, Router ID filtering might learn or drop BGP IPv6 SR policy routes incorrectly.
4.     Enable Router ID filtering.
router-id filter [ bgp-rib-only ]
By default, Router ID filtering is disabled.
After validity check is enabled for BGP IPv6 SR policy routes, the device determines that a BGP IPv6 SR policy route is invalid and will not preferentially select the route if the route does not contain the IPv4 address format RT extended community attribute or the NO_ADVERTISE community attribute.
You can configure this feature on the RR in networks where the controller and the RR establish BGP peer relationship and the RR establishes BGP peer relationship with the source nodes of multiple SRv6 TE policies.
The RR checks whether the BGP IPv6 SR policy routes issued by the controller carry the IPv4 address format RT attribute or the NO_ADVERTISE attribute. If yes, the RR accepts the routes and reflects the routes that do not carry the NO_ADVERTISE attribute to the source nodes of the SRv6 TE policies.
On the source nodes, you can use the router-id filter command to enable BGP IPv6 SR policy route filtering by router ID. After a source node receives a BGP IPv6 SR policy route, it compares the local router ID with the IPv4 address in the RT attribute of the route. If they are the same, the source node accepts the route. If they are different, the source node drops the route.
4.     Enable validity check for BGP IPv6 SR policy routes.
validation-check enable
By default, validity check for BGP IPv6 SR policy routes is disabled. The device does not check the validity of the BGP IPv6 SR policy routes received from peers or peer groups.
4.     Specify the local router as the next hop for routes sent to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } next-hop-local
By default, BGP sets the local router as the next hop for all routes sent to an EBGP peer or peer group. BGP does not set the local router as the next hop for routes sent to an IBGP peer or peer group.
5.     Allow a local AS number to exist in the AS_PATH attribute of routes from a peer or peer group, and to set the number of times the local AS number can appear.
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
By default, the local AS number is not allowed to exist in the AS_PATH attribute of routes from a peer or peer group.
6.     Specify a preferred value for routes received from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } preferred-value value
By default, the preferred value is 0 for routes received from a peer or peer group.
7.     Set the maximum number of routes that can be received from a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that can be received from a peer or peer group is not limited.
8.     Configure the device as a route reflector and specify a peer or peer group as a client.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
By default, neither the route reflector nor the client is configured.
9.     Specify an IPv6 prefix list to filter routes received from or advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } prefix-list ipv6-prefix-list-name { export | import }
By default, no prefix list based filtering is configured.
10.     Apply a routing policy to routes incoming from or outgoing to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } route-policy route-policy-name { export | import }
By default, no routing policy is applied to routes incoming from or outgoing to a peer or peer group.
11.     Advertise the COMMUNITY attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-community
By default, no COMMUNITY attribute is advertised to any peers or peer groups.
12.     Advertise the extended community attribute to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise-ext-community
By default, no extended community attribute is advertised to any peers or peer groups.
13.     Assign a peer or peer group a high priority in BGP route selection.
peer { group-name | ipv6-address [ prefix-length ] } high-priority [ preferred ]
By default, a peer or peer group does not have a high priority in BGP route selection.
14.     Enable the nexthop IP type-based route selection rule.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hops during optimal route selection.
To maintain BGP sessions, execute the following commands in user view:
·     Reset BGP sessions for the BGP IPv6 SR policy address family.
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 sr-policy
·     Soft-reset BGP sessions for the BGP IPv6 SR policy address family.
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } ipv6 sr-policy
Configuring the SRv6 TE policy traffic steering mode
This feature does not take effect on L2VPN networks.
To use color-based traffic steering, you need to add the color extended community to IPv6 unicast routes by using routing policy or other methods. For information about the routing policy configuration, see Layer 3—IP Routing Configuration Guide.
To use tunnel policy-based traffic steering, you need to configure a bound tunnel, preferred tunnel, or load sharing tunnel policy that uses an SRv6 TE policy. For more information about the tunnel policy configuration, see MPLS Configuration Guide.
3.     Configure the traffic steering mode for SRv6 TE policies.
sr-policy steering { disable | policy-based }
By default, the device steers data packets to SRv6 TE policies based on colors of the packets.
If you specify the policy-based keyword, the device steers traffic to an SRv6 TE policy based on the bound policy, color, and load sharing tunnel policy in a descending order of priority.
Configuring color-based traffic steering
To steer traffic to an SRv6 TE policy based on colors, you can configure a color extended community for routes that do not carry a color extended community in the following methods:
·     Configure a routing policy to add a color value to routes.
·     Configure a default color value.
The color value specified in the routing policy is preferred.
The default color value applies only to the VPN routes or public network routes learned from a remote PE.
The default color value is used only for SRv6 TE policy traffic steering. It does not used in route advertisement.
Configuring a routing policy to add a color value to routes
2.     Enter routing policy node view.
3.     Set the color extended community attribute for BGP routes.
apply extcommunity color color [ additive ]
By default, no color extended community attribute is set for BGP routes.
4.     Return to system view.
5.     Enter BGP instance view.
6.     Enter a BGP address family view as needed:
¡     Enter BGP IPv4 unicast address family view.
¡     Enter BGP IPv6 unicast address family view
¡     Enter BGP VPNv4 address family view.
address-family vpnv4
¡     Enter BGP VPNv6 address family view.
address-family vpnv6
¡     Enter BGP EVPN address family view.
address-family l2vpn evpn
7.     Apply the routing policy to filter routes advertised to or received from a peer or peer group.
By default, no routing policy is applied to a peer or peer group.
Configuring a default color value for VPN routes
2.     Enter VPN instance view.
ip vpn-instance vpn-instance-name [ index vpn-index ]
3.     Enter IPv4 address family view or IPv6 address family view of the VPN instance.
¡     Enter VPN instance IPv4 address family view.
address-family ipv4
¡     Enter VPN instance IPv6 address family view.
address-family ipv6
4.     Configure a default color value for L3VPN route recursion to an SRv6 TE policy.
default-color color-value [ evpn ]
By default, no default color is configured for L3VPN route recursion to an SRv6 TE policy.
Configuring a default color value for public network routes
2.     Enter pubic instance view.
ip public-instance
3.     Enter public instance IPv4 or IPv6 address family view.
¡     Enter public instance IPv4 address family view
address-family ipv4
¡     Enter public instance IPv6 address family view.
address-family ipv6
4.     Configure a default color value for public network route recursion to an SRv6 TE policy.
By default, no default color value is configured for public network route recursion to an SRv6 TE policy.
Configuring tunnel policy-based traffic steering
Configuring a tunnel policy
2.     Create a tunnel policy and enter tunnel policy view.
tunnel-policy tunnel-policy-name [ default ]
3.     Configure the tunnel policy. Choose the following tasks as needed:
¡     Specify an SRv6 TE policy to be bound with the specified destination IPv6 address.
binding-destination dest-ipv6-address srv6-policy { name policy-name | end-point ipv6 ipv6-address color color-value } [ ignore-destination-check ] [ down-switch ]
By default, no SRv6 TE policy is specified for a tunnel policy.
¡     Specify an SRv6 TE policy as a preferred tunnel of the tunnel policy.
preferred-path srv6-policy name sr-policy-name
By default, no preferred tunnel is specified for a tunnel policy.
¡     Configuring SRv6 TE policy load sharing for the tunnel policy.
select-seq srv6-policy load-balance-number number
By default, no load sharing tunnel policy is configured.
For more information about the tunnel policy commands, see MPLS Command Reference.
Specifying the tunnel policy for a VPN instance
2.     Enter a VPN instance view as needed.
¡     Enter VPN instance view.
¡     Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
¡     Execute the following commands in sequence to enter VPN instance IPv6 address family view:
address-family ipv6
3.     Specify a tunnel policy for the VPN instance.
tnl-policy tunnel-policy-name
By default, no tunnel policy is specified for a VPN instance.
For more information about this command, see MPLS L3VPN commands in MPLS Command Reference.
Configuring DSCP-based traffic steering
Each SRv6 TE policy in an SRv6 TE policy group has a different color attribute value. By configuring color-to-DSCP mappings for an SRv6 TE policy group, you associate DSCP values to SRv6 TE policies. This allows IPv6 packets containing a specific DSCP value to be steered to the corresponding SRv6 TE policy for further forwarding.
After a packet is steered to an SRv6 TE policy group, the device searches for a matching forwarding policy for the packet based on the DSCP value in the packet and the configuration status of the color match dscp and drop-upon-mismatch enable commands. If the device finds a matching forwarding policy by a match criterion and the forwarding policy is valid, it uses the forwarding policy to forward the packet. If no matching forwarding policy is found or the matching forwarding policy is invalid, the device proceeds to use the next match criterion to find a matching forwarding policy. The procedure to find a matching forwarding policy is as follows:
1.     Matches the DSCP value in the packet with the mappings configured by using the color match dscp command for the address family of the packet. If a match is found, the device uses the matching SRv6 TE policy to forward the packet.
2.     Uses the default SRv6 TE policy specified by using the color match dscp default command for the address family of the packet to forward the packet.
3.     Uses the default SRv6 TE policy specified by using the color match dscp default command for the other address family to forward the packet.
4.     Handles the packet according to whether the drop-upon-mismatch enable command is used.
¡     If the drop-upon-mismatch enable command is used, the device discards the packet.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether the SRv6 TE policy group is configured with color-to-DSCP mappings in the current address family:
-     If yes, the device searches the current address family for a mapping with the smallest DSCP value and a valid SRv6 TE policy. The device will use that SRv6 TE policy to forward the packet.
-     If not, the device turns to other address families (where the SRv6 TE policy group is configured with color-to-DSCP mappings) for a mapping with the smallest DSCP value and a valid SRv6 TE policy. The device will use that SRv6 TE policy to forward the packet.
You can map the color values of only valid SRv6 TE policies to DSCP values.
You can configure color-to-DSCP mappings separately for the IPv4 address family and IPv6 address family. For a specific address family, a DSCP value can be mapped to only one color value.
Use the color match dscp default command to specify the default SRv6 TE policy for an address family. If no SRv6 TE policy in an SRv6 TE policy group matches a specific DSCP value, the default SRv6 TE policy is used to forward packets containing the DSCP value. Only one default SRv6 TE policy can be specified for an address family.
Manually creating an SRv6 TE policy group
2.     Enter SRv6 view.
traffic-engineering
4.     Create an SRv6 TE policy group and enter its view.
policy-group group-id
5.     Configure the endpoint IPv6 address for the SRv6 TE policy group.
By default, no endpoint IPv6 address is configured for the SRv6 TE policy group.
The destination node address of each color-associated SRv6 TE policy in the SRv6 TE policy group must be the same as the endpoint IPv6 address of the SRv6 TE policy group.
6.     (Optional.) Create the color value for the SRv6 TE policy group.
group-color color-value
By default, the color value is not configured for an SRv6 TE policy group.
7.     (Optional.) Configure a BSID for the SRv6 TE policy group.
By default, no BSID is configured for an SRv6 TE policy group.
8.     (Optional.) Enable the feature of discarding packets that do not match any valid SRv6 TE policy.
9.     Create color-to-DSCP mappings for the SRv6 TE policy group.
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
color color-value match dscp { ipv4 | ipv6 } default
By default, no color-to-DSCP mappings are created for the SRv6 TE policy group.
DSCP-based traffic steering cannot function if no color-to-DSCP mappings are created.
10.     Return to system view.
11.     Create a tunnel policy and enter tunnel policy view.
12.     Bind the SRv6 TE policy group to a destination IP address.
binding-destination dest-ip-address sr-policy group sr-policy-group-id [ ignore-destination-check ] [ down-switch ]
By default, a tunnel policy does not bind any SRv6 TE policy group to a destination IP address.
For more information about the command, see tunnel policy commands in MPLS Command Reference.
Automatically creating an SRv6 TE policy group by ODN
2.     Enter SRv6 view.
traffic-engineering
4.     Create an ODN template for creating SRv6 TE policy groups and enter SRv6 TE ODN policy group view.
on-demand-group color color-value
5.     (Optional.) Configure the description of the SRv6 TE policy group ODN template.
By default, the description of the SRv6 TE policy group ODN template is not configured.
6.     (Optional.) Enable the feature of discarding packets that do not match any valid SRv6 TE policy.
7.     Create the DSCP forward type and enter its view.
forward-type dscp
8.     Create color-to-DSCP mappings for the SRv6 TE policy group ODN template.
By default, no color-to-DSCP mappings are created for the SRv6 TE policy group ODN template.
This command is required to implement DSCP-based traffic steering.
Steering traffic to an SRv6 TE policy group
2.     Configure traffic steering to an SRv6 TE policy group.
a.     Create a tunnel policy and enter tunnel policy view.
b.     Bind the SRv6 TE policy group to a destination IP address.
binding-destination dest-ipv6-address srv6-policy group srv6-policy-group-id [ ignore-destination-check ] [ down-switch ]
c.     Configure color-based traffic steering.
For more information, see "Configuring color-based traffic steering."
Specify a color value as the color extended community attribute of BGP routes in the routing policy according to the creation method of the SRv6 TE policy group.
-     If the SRv6 TE policy group is manually created, the specified color value must be the color value of the SRv6 TE policy group.
-     If the SRv6 TE policy group is automatically created by ODN, the specified color value must be the color value of the ODN template.
Configuring APN ID-based traffic steering
Each SRv6 TE policy in an SRv6 TE policy group has a different color value. Once service traffic is steered to an SRv6 TE policy group for further forwarding, the device matches the APN ID value in IPv6 packets with the APN ID mappings in the SRv6 TE policy group. If a matching mapping is found, the device forwards the traffic through the SRv6 TE policy associated with the color value in the mapping or forwards the traffic in SRv6 BE mode.
An APN ID can establish a mapping relationship with an SRv6 TE policy only if that SRv6 TE policy is valid. Only after the mapping relationship is established, traffic that carries the APN ID can be forwarded through that SRv6 TE policy.
An APN ID can establish a mapping relationship with the SRv6 BE mode only when the SRv6 BE mode is valid. The SRv6 BE mode is valid only if the IPv6 routing table on the device contains a route destined for the VPN SID that the egress node of the SRv6 TE policy group assigned to public- or private-network routes. Only after the mapping relationship is established, traffic that carries the APN ID can be forwarded in SRv6 BE mode.
For an SRv6 TE policy group, an APN ID value can be mapped only to the SRv6 BE mode or to one SRv6 TE policy associated with a color value.
In traffic steering to an SRv6 TE policy group, the device might receive a packet that does not carry an APN ID or carries one of the following ARN IDs:
·     APN ID that does not match any APN ID mapping.
·     APN ID that matches an invalid SRv6 TE policy or SRv6 BE mode.
In this situation, the device forwards that packet as follows:
1.     If the default match command is used to specify a default SRv6 TE policy and the specified default SRv6 TE policy is valid, the device uses the default SRv6 TE policy to forward the packet.
2.     If the default match command is used to configure packet forwarding in SRv6 BE mode and the SRv6 BE mode is valid, the device forwards the packet in SRv6 BE mode.
3.     If the default match command is not executed, or the forwarding policy configured by using the default match command is invalid, the device handles the packet depending on whether the drop-upon-mismatch enable command is used.
¡     If the drop-upon-mismatch enable command is not used, the device identifies whether APN ID-to-forwarding policy mappings are configured by using the index apn-id match command. If yes, the device searches for a mapping with the smallest APN ID and a valid forwarding policy. The device will use the SRv6 TE policy pointed by the mapping to forward the packet or forward the packet in SRv6 BE mode.
2.     Enter SRv6 view.
traffic-engineering
By default, no endpoint IPv6 address is configured for an SRv6 TE policy group.
The SRv6 TE policy associated with each color value in the SRv6 TE policy group must use the same endpoint IPv6 address as the SRv6 TE policy group.
6.     (Optional.) Configure the color value for the SRv6 TE policy group.
By default, no color value is configured for an SRv6 TE policy group.
8.     (Optional.) Enable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
9.     Specify the APN ID forward type for the SRv6 TE policy group.
forward-type apn-id
By default, DSCP-based traffic steering is used for packets that match an SRv6 TE policy group.
10.     Configure a mapping between an APN ID and a forwarding policy.
index index-value apn-id instance instance-name match { best-effort | srv6-policy color color-value }
By default, no mapping is configured between an APN ID and a forwarding policy.
11.     (Optional.) Configure the default forwarding policy for APN ID-based traffic forwarding.
default match best-effort
default match srv6-policy color color-value
By default, no default forwarding policy is configured for APN ID-based traffic forwarding.
You can specify both SRv6 TE policy-based forwarding and SRv6 BE-based forwarding in the default forwarding policy. The device preferentially uses SRv6 TE policy forwarding.
2.     Enter SRv6 view.
traffic-engineering
By default, no description is configured for an SRv6 TE policy group ODN template.
6.     (Optional.) Enable the feature of discarding packets that do not match any valid SRv6 TE policy or SRv6 BE path.
7.     Create the APN ID forward type and enter its view.
forward-type apn-id
8.     Configure a mapping between an APN ID and a forwarding policy.
9.     (Optional.) Configure the default forwarding policy for APN ID-based traffic forwarding.
¡     Execute the following commands in sequence to configure a tunnel policy to steer traffic to an SRv6 TE policy group:
-     Create a tunnel policy and enter tunnel policy view.
-     Bind an SRv6 TE policy group to a destination IP address.
For more information about the commands, see tunnel policy commands in MPLS Command Reference.
¡     Configure color-based traffic steering.
Configuring static route-based traffic steering
After configuring this feature in the IP public network over SRv6 network, execute the route-replicate command in public instance IPv4/IPv6 address family view. Use this command to replicate routes from the specified VPN instance to the public network for forwarding user traffic.
2.     Configure static-route based traffic steering to an SRv6 TE policy.
¡     Configure an IPv4 static route for steering matching traffic to an SRv6 TE policy.
Public network:
ip route-static dest-address { mask-length | mask } srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv4 static routes are configured.
For more information about this command, see static routing configuration in Layer 3—IP Routing Configuration Guide.
¡     Configure an IPv6 static route for steering matching traffic to an SRv6 TE policy.
Public network:
ipv6 route-static ipv6-address prefix-length srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv6 static routes are configured.
For more information about this command, see IPv6 static routing configuration in Layer 3—IP Routing Configuration Guide.
Configuring QoS policy-based traffic steering
When some public IPv6 flows are congested, you can configure traffic classification to identify the flows and redirect the traffic to SRv6 TE policies to resolve the congestion. Traffic redirection to SRv6 TE policies is based on endpoint and color. If traffic cannot match the redirect rule or the redirect SRv6 TE policy fails, the traffic cannot be forwarded through an SRv6 TE policy but through normal IPv6 forwarding.
For more information about QoS policy commands, see ACL and QoS Command Reference.
1.     Define a traffic class:
a.     Enter system view.
b.     Create a traffic class and enter traffic class view.
c.     Configure a match criterion.
if-match [ not ] match-criteria
By default, no match criterion is configured.
For more information, see the if-match command in ACL and QoS Command Reference.
2.     Define a traffic behavior:
a.     Create a traffic behavior and enter traffic behavior view.
b.     Redirect the matching traffic to an SRv6 TE policy.
redirect srv6-policy endpoint color [ { sid | vpnsid } sid ]
By default, no traffic behavior is configured.
3.     Define and apply a QoS policy:
a.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
b.     Associate a traffic class with a traffic behavior to create a class-behavior association in the QoS policy.
classifier classifier-name behavior behavior-name
By default, a traffic class is not associated with a traffic behavior.
c.     Return to system view.
d.     Apply the QoS policy.
For more information, see QoS policy configuration in ACL and QoS Configuration Guide.
By default, no QoS policy is applied.
Configuring Flowspec-based traffic steering
Creating and activating an IPv6 Flowspec rule
2.     Create an IPv6 Flowspec rule and enter IPv6 Flowspec rule view.
flow-route flowroute-name ipv6
3.     Configure a match criterion.
if-match match-criteria
4.     Redirect packets to an SRv6 TE policy.
apply redirect next-hop ipv6-address color color [ sid sid-value ]
By default, no action is configured.
5.     Commit match criteria and actions.
commit
By default, match criteria and actions are not committed.
Applying the IPv6 Flowspec rule to the public network
2.     Enter Flowspec view.
flowspec
3.     Create a Flowspec IPv6 address family for the public network and enter its view.
address-family ipv6
4.     Apply the created IPv6 Flowspec rule to the public network.
By default, no IPv6 Flowspec rule is applied to the public network.
Applying the IPv6 Flowspec rule to a VPN instance
2.     Configure a VPN instance.
a.     Create a VPN instance and enter VPN instance view.
b.     Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
c.     Configure route targets for the VPN instance.
vpn-target { vpn-target&<1-8> [ both | export-extcommunity | import-extcommunity ] }
By default, no route targets are configured.
For more information about the ip vpn-instance, route-distinguisher, and vpn-target commands, see MPLS L3VPN commands in MPLS Command Reference.
3.     Enter the IPv6 Flowspec address family view of the VPN instance.
address-family ipv6 flowspec
4.     Configure an RD for the IPv6 Flowspec address family.
By default, no RD is configured for the IPv6 Flowspec address family.
5.     Configure route targets for the IPv6 Flowspec address family.
By default, no route targets are configured for the IPv6 Flowspec address family.
The route targets configured must be the same as the route targets configured previously for the VPN instance.
6.     Execute the quit command twice to return to system view.
7.     Enter Flowspec view.
flowspec
8.     Create a Flowspec IPv6 address family and associate the address family with the VPN instance.
address-family ipv6 vpn-instance vpn-instance-name
9.     Apply the created IPv6 Flowspec rule to the Flowspec IPv6 VPN instance address family.
By default, no IPv6 Flowspec rule is applied to a Flowspec IPv6 VPN instance address family.
Enabling BGP to distribute IPv6 Flowspec rules
3.     Enter BGP IPv6 Flowspec address family view, BGP-VPN IPv6 Flowspec address family view, or BGP VPNv6 Flowspec address family view:
¡     Enter BGP IPv6 Flowspec address family view to advertise public network IPv6 Flowspec rules.
¡     Execute the following commands in sequence to enter BGP-VPN IPv6 Flowspec address family view to advertise private network IPv6 Flowspec rules:
¡     Enter BGP VPNv6 Flowspec address family view to advertise VPNv6 Flowspec rules.
address-family vpnv6 flowspec
4.     Enable BGP Flowspec peers to exchange routing information.
peer { group-name | ipv6-address [ mask-length ] | ipv6-address [ prefix-length ] } enable
By default, BGP Flowspec peers cannot exchange routing information.
Enabling automatic route advertisement for an SRv6 TE policy
2.     Enter SRv6 view.
traffic-engineering
policy policy-name
5.     Enable automatic route advertisement for the SRv6 TE policy.
autoroute enable [ isis | ospfv3 ]
By default, automatic route advertisement is disabled for an SRv6 TE policy.
6.     Configure an autoroute metric for the SRv6 TE policy.
autoroute metric { absolute value | relative value }
By default, the autoroute metric of an SRv6 TE policy equals its IGP metric.
7.     Return to system view.
8.     Include the SRv6 TE policy in IGP computation:
¡     Execute the following commands in sequence to enable automatic route advertisement for IS-IS SRv6 TE policies.
srv6-policy autoroute enable [ level-1 | level-2 ]
By default, automatic route advertisement for SRv6 TE policies is disabled.
If the traffic steering mode is BSID, packets whose destination IPv6 address is the same as the BSID of an SRv6 TE policy will be forwarded by the SRv6 TE policy. In this case, the device needs to encapsulate the SID list of the SRv6 TE policy into the packets. The following encapsulation modes are available:
·     Encaps—Normal encapsulation mode. It adds a new IPv6 header and an SRH to the original packets. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
·     Encaps.Red—Reduced mode of normal encapsulation. It adds a new IPv6 header and an SRH to the original packets. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH.
·     Insert—Insertion mode. It inserts an SRH after the original IPv6 header. All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
·     Insert.Red—Reduced insertion mode. It inserts an SRH after the original IPv6 header. The first SID in the SID list of the SRv6 TE policy is not encapsulated in the SRH to reduce the SRH length. All other SIDs in the SID list are encapsulated in the SRH.
In Encaps or Encaps.Red encapsulation mode, the destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
In Insert or Insert.Red encapsulation mode, the destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address in the original IPv6 header is not changed.
If the traffic steering mode is BSID and the SRv6 SID of the ingress node is an End.X SID, the device does not encapsulate the End.X SID into the SRH by default.
To obtain complete SRv6 forwarding path information from the SRH of packets, you can configure the device to encapsulate the local End.X SID in the SRH.
You can configure the encapsulation mode for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The normal encapsulation modes are exclusive with the insertion modes. If you configure both a normal encapsulation mode and an insertion mode for an SRv6 TE policy, the most recent configuration takes effect.
If you configure the Insert or Insert.Red mode for an SRv6 TE policy, it uses the Encaps mode to encapsulate received IPv4 packets.
In SRv6 TE view, if you execute both the srv6-policy encapsulation-mode encaps reduced command and the srv6-policy encapsulation-mode encaps include local-end.x command, the srv6-policy encapsulation-mode encaps include local-end.x command takes effect.
In SRv6 TE view, if you execute both the srv6-policy encapsulation-mode insert reduced command and the srv6-policy encapsulation-mode insert include local-end.x command, the srv6-policy encapsulation-mode insert include local-end.x command takes effect.
In SRv6 TE policy view, if you execute both the encapsulation-mode encaps reduced command and the encapsulation-mode encaps include local-end.x command, the encapsulation-mode encaps include local-end.x command takes effect.
In SRv6 TE policy view, if you execute both the encapsulation-mode insert reduced command and the encapsulation-mode insert include local-end.x command, the encapsulation-mode insert include local-end.x command takes effect.
2.     Enter SRv6 view.
traffic-engineering
4.     Configure the encapsulation mode globally for all SRv6 TE policies. Choose one option as needed:
¡     Specify the Encaps.Red encapsulation mode globally for all SRv6 TE policies.
¡     Specify the Insert or Insert.Red encapsulation mode globally for all SRv6 TE policies.
By default, an SRv6 TE policy uses the Encaps encapsulation mode.
5.     Enable the device to include the local End.X SID in the SRH of the packets forwarded by SRv6 TE policies. Choose one option as needed:
¡     Enable this feature for SRv6 TE policies with a normal encapsulation mode
¡     Enable this feature for SRv6 TE policies with an insertion encapsulation mode
By default, the device does not include the local End.X SID in the SRH of the packets forwarded by SRv6 TE policies.
6.     Enter SRv6 TE policy view.
policy policy-name
7.     Configure the encapsulation mode for the SRv6 TE policy. Choose one option as needed:
¡     Specify the Encaps.Red encapsulation mode for the SRv6 TE policy.
encapsulation-mode encaps reduced [ disable ]
encapsulation-mode insert reduced [ disable ]
By default, the encapsulation mode is not configured for an SRv6 TE policy, and the encapsulation mode configured in SRv6 TE view applies.
8.     Configure local End.X SID encapsulation in the SRH of the packets forwarded by the SRv6 TE policy.
¡     Configure this feature when the SRv6 TE policy uses a normal encapsulation mode.
encapsulation-mode encaps include local-end.x [ disable ]
¡     Configure this feature when the SRv6 TE policy uses an insertion encapsulation mode.
encapsulation-mode insert include local-end.x [ disable ]
By default, local End.X SID encapsulation is not configured for an SRv6 TE policy, and the local End.X SID encapsulation setting configured in SRv6 TE view applies.
To use SBFD to detect an SRv6 TE policy, the device needs to encapsulate the SID list of the SRv6 TE policy for the SBFD packets. The following encapsulation modes are available:
¡     The destination IPv6 address in the new IPv6 header is the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
¡     All SIDs in the SID list of the SRv6 TE policy are encapsulated in the SRH.
¡     The destination IPv6 address in the original IPv6 header is changed to the first SID in the SID list of the SRv6 TE policy. The source IPv6 address is the IPv6 address specified by using the encapsulation source-address command.
You can enable SBFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The remote discriminator specified in this command must be the same as that specified in the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not send responses to the initiator.
The device supports the echo packet mode BFD and the SBFD for an SRv6 TE policy. If both modes are configured for the same SRv6 TE policy, the SBFD takes effect.
2.     Configure the source IPv6 address used by the initiator to send SBFD packets.
sbfd source-ipv6 ipv6-address
By default, no source IPv6 address is configured for SBFD packets.
3.     Enter SRv6 view.
4.     Enter SRv6 TE view.
traffic-engineering
5.     Enable SBFD for all SRv6 TE policies and configure the SBFD session parameters.
srv6-policy sbfd remote remote-id [ template template-name ] [ backup-template backup-template-name ]
By default, SBFD is disabled for all SRv6 TE policies.
policy policy-name
7.     Configure SBFD for the SRv6 TE policy.
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] }
By default, SBFD is not configured for an SRv6 TE policy.
You can configure the echo packet mode BFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
2.     Enter SRv6 view.
traffic-engineering
4.     Enable echo packet mode BFD for all SRv6 TE policies and configure the BFD session parameters.
srv6-policy bfd echo source-ipv6 ipv6-address [ template template-name ] [ backup-template backup-template-name ]
By default, the echo packet mode BFD is disabled for all SRv6 TE policies.
policy policy-name
6.     Configure the echo packet mode BFD for the SRv6 TE policy.
bfd echo { disable | enable [ source-ipv6 ipv6-address ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] }
By default, the echo packet mode BFD is not configured for an SRv6 TE policy. An SRv6 TE policy uses the echo BFD settings configured in SRv6 TE view.
You can enable hot standby for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
2.     Enter SRv6 view.
traffic-engineering
4.     Enable hot standby for all SRv6 TE policies.
srv6-policy backup hot-standby enable
By default, hot standby is disabled for all SRv6 TE policies.
policy policy-name
6.     Configure hot standby for the SRv6 TE policy.
backup hot-standby { disable | enable }
By default, hot standby is not configured for an SRv6 TE policy, and the hot standby configuration in SRv6 TE view applies.
The switchover delay and deletion delay mechanism is used to avoid traffic forwarding failure during a forwarding path (SID list) switchover.
When updating an SRv6 TE policy forwarding path, the device first establishes the new forwarding path before it deletes the old one. During the new path setup process, the device uses the old path to forward traffic until the switchover delay timer expires. When the switchover delay timer expires, the device switches traffic to the new path. The old path is deleted when the deletion delay timer expires.
2.     Enter SRv6 view.
traffic-engineering
4.     Configure the switchover delay time and deletion delay time for the SRv6 TE policy forwarding path.
srv6-policy switch-delay switch-delay-time delete-delay delete-delay-time
By default, the switchover delay time and deletion delay time for the SRv6 TE policy forwarding path is 5000 milliseconds and 20000 milliseconds, respectively.
Configuring SRv6 TE policy transit node protection
The transit node protection technology is referred to as SRv6 TE FRR. After SRv6 TE FRR is enabled, when a transit node of an SRv6 TE policy fails, the upstream node of the faulty node can take over to forward packets. The upstream node is called a proxy forwarding node that bypasses the faulty transit node to implement node failure protection.
In a complex network, any node might act as a transit node. As a best practice to improve the whole network security, enable SRv6 TE FRR on all nodes and enable the bypass feature on the ingress node.
2.     Enter SRv6 view.
3.     Enable SRv6 TE FRR.
sr-te frr enable
By default, SRv6 TE FRR is disabled.
traffic-engineering
policy policy-name
6.     Enable the bypass feature for the SRv6 TE policy.
bypass enable
By default, the SRv6 TE policy bypass feature is disabled.
Execute this command only on the ingress node.
Restrictions and guidelines for SRv6 TE policy egress protection configuration
To configure SRv6 TE policy egress protection, all nodes that the packets will traverse must support SRv6.
Configuring an End.M SID
Perform this task on protection node for the egress node.
For more information about the commands used in this task, see IPv6 Segment Routing commands in Segment Routing Command Reference.
2.     Enter SRv6 view.
3.     Create a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4.     Configure an End.M SID and specify the locator to be protected by the End.M SID.
opcode opcode end-m mirror-locator ipv6-address prefix-length
Enabling egress protection
This task enables the SRv6 node to compute a backup path (mirror FRR path) for the egress node based on the End.M SID carried in a received IS-ISv6 or OSPFv3 route. When the egress node fails, the transit node can forward traffic to the node that protects the egress node according to the End.M SID.
In an egress protection scenario, the transit node deletes the mirror FRR path after completing route convergence. If the deletion occurs before the ingress node switches traffic back from the mirror FRR path, the traffic will be dropped because of no mirror FRR path.
To resolve this issue, you can configure a proper mirror FRR deletion delay time on the transit node to delay the deletion of the mirror FRR route. So, packets can be forwarded over the mirror FRR path before the ingress finishes the path switchover.
Enabling IS-IS egress protection
2.     Enter IS-IS view.
3.     Enter IS-IS IPv6 address family view.
4.     Enable IS-IS egress protection.
fast-reroute mirror enable
By default, IS-IS egress protection is disabled.
5.     (Optional.) Configure the mirror FRR deletion delay time.
fast-reroute mirror delete-delay delete-delay-time
By default, the mirror FRR deletion delay time is 60 seconds.
Enabling OSPFv3 egress protection
2.     Enter OSPFv3 view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
3.     Enable OSPFv3 egress protection.
By default, OSPFv3 egress protection is disabled.
4.     (Optional.) Configure the mirror FRR deletion delay time.
Configuring the deletion delay time for remote SRv6 SID mappings with VPN instances/cross-connects/VSIs
In an egress protection scenario, if the egress node and the egress node's protection node are disconnected, the protection node will delete the BGP routes received from the egress node. The remote SRv6 SID and VPN instance/cross-connect/VSI mappings will then be deleted as a result. To avoid this issue, you can configure the mappings deletion delay time on the protection node. This ensures that traffic is forwarded through the protection node before the ingress detects the egress failure and computes a new forwarding path.
Perform this task on the protection node for the egress node.
2.     Enter SRv6 view.
3.     Configure the deletion delay time for remote SRv6 SID mappings with VPN instances/cross-connects/VSIs.
mirror remote-sid delete-delay delete-delay-time
By default, the deletion delay time for remote SRv6 SID and VPN instance/cross-connect/VSI mappings is 60 seconds.
An SRv6 TE policy used as a public tunnel supports the following TTL processing modes:
·     Uniform—When the ingress node adds a new IPv6 header to an IP packet, it copies the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet copies the remaining Hop Limit value back to the original IP packet when it removes the new IPv6 header. The TTL value can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
·     Pipe—When the ingress node adds a new IPv6 header to an IP packet, it does not copy the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. It sets the Hop Limit value in the new IPv6 header to 255. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet does not change the IPv6 Hop Limit value according to the remaining Hop Limit value in the new IPv6 header. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
2.     Enter SRv6 view.
3.     Configure the TTL processing mode of SRv6 TE policies.
ttl-mode { pipe | uniform }
By default, the TTL processing mode of SRv6 TE policies is pipe.
Before configuring CBTS, you must create QoS traffic behaviors to mark the MPLS TE service class values for packets. For more information, see QoS configuration in ACL and QoS Configuration Guide.
2.     Enter SRv6 view.
traffic-engineering
policy policy-name
5.     Set a service class value for the SRv6 TE policy.
service-class service-class-value
By default, no service class value is set for an SRv6 TE policy.
When the rate of the packets forwarded by an SRv6 TE policy exceeds the rate limit, the device drops the packets that exceed the rate limit.
2.     Enter SRv6 view.
traffic-engineering
policy policy-name
5.     Set a rate limit for the SRv6 TE policy.
rate-limit kbps
By default, no rate limit is set for an SRv6 TE policy.
Enable this feature for an SRv6 TE policy if you want to use only the SRv6 TE policy to forward traffic.
By default, if all forwarding paths of an SRv6 TE policy become invalid, the device forwards the packets through IPv6 routing table lookup based on the packet destination IPv6 addresses.
After you execute the drop-upon-invalid enable command, the device drops the packets if all forwarding paths of the SRv6 TE policy become invalid.
The drop-upon-invalid enable command does not take effect in the following cases:
·     BSID request failed or BSID conflict occurred for the SRv6 TE policy. To view the BSID request state, see the Request state field in the display segment-routing ipv6 te policy command output.
·     The SRv6 TE policy is invalid. To check the SRv6 TE policy validity, see the Forwarding index field in the display segment-routing ipv6 te policy command output. If the value is 0, the SRv6 TE policy is invalid.
2.     Enter SRv6 view.
traffic-engineering
policy policy-name
5.     Enable the device to drop traffic when an SRv6 TE policy becomes invalid.
By default, the drop-upon-invalid feature is disabled for an SRv6 TE policy. The device does not drop traffic when the SRv6 TE policy becomes invalid.
As shown in Figure 18, PE 4 is the RR, and it establishes an IBGP connection with PE 1, PE 2, and PE 3, respectively. PE 1 and PE 3 support SRv6. PE 2 does not support SRv6. Both an MPLS L3VPN connection and an EVPN L3VPN over SRv6 connection exist between PE 1 and PE 3.
In this case, you can perform this task to specify the preferred encapsulation type (SRv6 encapsulation or MPLS encapsulation) for BGP optimal route selection in the L3VPN. For more information about the priority order of this feature in BGP route selection steps, see BGP overview in Layer 3—IP Routing Configuration Guide.
Figure 18 MPLS L3VPN and EVPN L3VPN over SRv6 coexist
3.     Enter BGP-VPN instance view.
4.     Specify the packet encapsulation type preferred in optimal route selection.
bestroute encap-type { mpls | srv6 } [ preferred ]
By default, BGP does not select optimal routes according to the packet encapsulation type.
This feature collects statistics on the traffic forwarded by SRv6 TE policies.
You can configure traffic forwarding statistics for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
2.     Enter SRv6 view.
traffic-engineering
4.     Enable traffic forwarding statistics for all SRv6 TE policies.
srv6-policy forwarding statistics [ service-class ] enable
By default, traffic forwarding statistics is disabled for all SRv6 TE policies.
5.     (Optional.) Set the traffic forwarding statistics interval for all SRv6 TE policies.
srv6-policy forwarding statistics interval interval
By default, the SRv6 TE policy forwarding statistics interval is 30 seconds.
policy policy-name
7.     Configure traffic forwarding statistics for the SRv6 TE policy.
forwarding statistics { disable | [ service-class ] enable }
By default, an SRv6 TE policy uses the traffic forwarding statistics configuration in SRv6 TE view.
Display and maintenance commands for SRv6 TE policies
Execute display commands in any view. Execute reset commands in user view.
Display remote SRv6 SIDs protected by mirror SIDs.
display bgp [ instance instance-name ] mirror remote-sid [ end-dt4 | end-dt46 | end-dt6 ] [ sid ]
Display BGP peer or peer group information.
display bgp [ instance instance-name ] peer ipv6 [ sr-policy ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
Display BGP SRv6 TE policy routing information.
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ] | peer ipv6-address { advertised-routes | received-routes } [ statistics ] | statistics ]
Display BGP peer group information.
display bgp [ instance instance-name ] group ipv6 sr-policy [ group-name group-name ]
Display BGP update group information.
display bgp [ instance instance-name ] update-group ipv6 sr-policy [ ipv6-address ]
Display BFD information for SRv6 TE policies.
display segment-routing ipv6 te bfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
Display SRv6 TE forwarding information.
display segment-routing ipv6 te forwarding [ policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } ] [ verbose ]
Display SRv6 TE policy information.
display segment-routing ipv6 te policy [ name policy-name | down | up | { color color-value | end-point ipv6 ip-address } * ]
Display information about the most recent down event for SRv6 TE policies.
display segment-routing ipv6 te policy last-down-reason [ binding-sid bsid | color color-value endpoint ipv6 ipv6-address | policy-name policy-name ]
Display the reason why the specified or all SRv6 TE policy groups went down most recently.
display segment-routing ipv6 te policy-group last-down-reason [ group-id | endpoint ipv6-address color color-value ]
Display SRv6 TE policy statistics.
display segment-routing ipv6 te policy statistics
Display SRv6 TE policy group statistics.
display segment-routing ipv6 te policy-group statistics
Display status information about SRv6 TE policies.
display segment-routing ipv6 te policy status [ policy-name policy-name ]
Display information about SRv6 TE policy groups.
display segment-routing ipv6 te policy-group [ odn ] [ group-id | { color color-value | end-point ipv6 ipv6-address } * ] [ verbose ]
Display SBFD information for SRv6 TE policies.
display segment-routing ipv6 te sbfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
Display SRv6-TE SID list information.
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
Display APN ID instance information for SRv6 TE policies.
display segment-routing ipv6 te policy-group apn-id-ipv6 instance [ name inatnce-name ]
Clear traffic forwarding statistics of SRv6 TE policies.
reset segment-routing ipv6 te forwarding statistics [ binding-sid binding-sid | color color-value endpoint endpoint-ipv6 | name name-value ]
SRv6 TE policy configuration examples
Example: Configuring SRv6 TE policy-based forwarding
As shown in Figure 19, perform the following tasks on the devices to implement SRv6 TE policy-based forwarding over a specific path:
·     Configure Device A through Device D to run IS-IS to implement Layer 3 connectivity.
·     Configure basic SRv6 on Device A through Device D.
·     Configure an SRv6 TE policy on Device A to forward user packets along path Device A > Device B > Device C > Device D.
Figure 19 Network diagram
Device
IP address
Device
IP address
Device A
Loop1
1::1/128
Device B
Loop1
2::2/128
GE2/0/1
1000::1/64
GE2/0/1
1000::2/64
GE2/0/2
4000::1/64
GE2/0/2
2000::2/64
Device C
Loop1
3::3/128
Device D
Loop1
4::4/128
GE2/0/1
3000::3/64
GE2/0/1
3000::4/64
GE2/0/2
2000::3/64
GE2/0/2
4000::4/64
1.     Configure IP addresses and masks for interfaces. (Details not shown.)
2.     Configure Device A:
# Configure an SRv6 SID list.
[DeviceA] segment-routing ipv6
[DeviceA-segment-routing-ipv6] encapsulation source-address 1::1
[DeviceA-segment-routing-ipv6] locator a ipv6-prefix 5000:: 64 static 32
[DeviceA-segment-routing-ipv6-locator-a] opcode 1 end
[DeviceA-segment-routing-ipv6-locator-a] quit
[DeviceA-segment-routing-ipv6] traffic-engineering
[DeviceA-srv6-te] srv6-policy locator a
[DeviceA-srv6-te] segment-list s1
[DeviceA-srv6-te-sl-s1] index 10 ipv6 6000::1
[DeviceA-srv6-te-sl-s1] index 20 ipv6 7000::1
[DeviceA-srv6-te-sl-s1] index 30 ipv6 8000::1
[DeviceA-srv6-te-sl-s1] quit
# Create an SRv6 TE policy and set the attributes.
[DeviceA-srv6-te] policy p1
[DeviceA-srv6-te-policy-p1] binding-sid ipv6 5000::2
[DeviceA-srv6-te-policy-p1] color 10 end-point ipv6 4::4
[DeviceA-srv6-te-policy-p1] candidate-paths
[DeviceA-srv6-te-policy-p1-path] preference 10
[DeviceA-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[DeviceA-srv6-te-policy-p1-path-pref-10] quit
[DeviceA-srv6-te-policy-p1-path] quit
[DeviceA-srv6-te-policy-p1] quit
[DeviceA-srv6-te] quit
[DeviceA-segment-routing-ipv6] quit
# Configure IS-IS and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] address-family ipv6 unicast
[DeviceA-isis-1-ipv6] segment-routing ipv6 locator a
[DeviceA-isis-1-ipv6] quit
[DeviceA-isis-1] quit
[DeviceA] interface gigabitethernet 2/0/1
[DeviceA-GigabitEthernet2/0/1] isis ipv6 enable 1
[DeviceA-GigabitEthernet2/0/1] quit
[DeviceA] interface gigabitethernet 2/0/2
[DeviceA-GigabitEthernet2/0/2] isis ipv6 enable 1
[DeviceA-GigabitEthernet2/0/2] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis ipv6 enable 1
[DeviceA-LoopBack1] quit
3.     Configure Device B:
# Configure the SRv6 End.SID.
[DeviceB] segment-routing ipv6
[DeviceB-segment-routing-ipv6] locator b ipv6-prefix 6000:: 64 static 32
[DeviceB-segment-routing-ipv6-locator-b] opcode 1 end
[DeviceB-segment-routing-ipv6-locator-b] quit
[DeviceB-segment-routing-ipv6] quit
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] address-family ipv6 unicast
[DeviceB-isis-1-ipv6] segment-routing ipv6 locator b
[DeviceB-isis-1-ipv6] quit
[DeviceB-isis-1] quit
[DeviceB] interface gigabitethernet 2/0/1
[DeviceB-GigabitEthernet2/0/1] isis ipv6 enable 1
[DeviceB-GigabitEthernet2/0/1] quit
[DeviceB] interface gigabitethernet 2/0/2
[DeviceB-GigabitEthernet2/0/2] isis ipv6 enable 1
[DeviceB-GigabitEthernet2/0/2] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis ipv6 enable 1
[DeviceB-LoopBack1] quit
4.     Configure Device C:
[DeviceC] segment-routing ipv6
[DeviceC-segment-routing-ipv6] locator c ipv6-prefix 7000:: 64 static 32
[DeviceC-segment-routing-ipv6-locator-c] opcode 1 end
[DeviceC-segment-routing-ipv6-locator-c] quit
[DeviceC-segment-routing-ipv6] quit
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] address-family ipv6 unicast
[DeviceC-isis-1-ipv6] segment-routing ipv6 locator c
[DeviceC-isis-1-ipv6] quit
[DeviceC-isis-1] quit
[DeviceC] interface gigabitethernet 2/0/1
[DeviceC-GigabitEthernet2/0/1] isis ipv6 enable 1
[DeviceC-GigabitEthernet2/0/1] quit
[DeviceC] interface gigabitethernet 2/0/2
[DeviceC-GigabitEthernet2/0/2] isis ipv6 enable 1
[DeviceC-GigabitEthernet2/0/2] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis ipv6 enable 1
[DeviceC-LoopBack1] quit
5.     Configure Device D:
[DeviceD] segment-routing ipv6
[DeviceD-segment-routing-ipv6] locator d ipv6-prefix 8000:: 64 static 32
[DeviceD-segment-routing-ipv6-locator-d] opcode 1 end
[DeviceD-segment-routing-ipv6-locator-d] quit
[DeviceD-segment-routing-ipv6] quit
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] address-family ipv6 unicast
[DeviceD-isis-1-ipv6] segment-routing ipv6 locator d
[DeviceD-isis-1-ipv6] quit
[DeviceD-isis-1] quit
[DeviceD] interface gigabitethernet 2/0/1
[DeviceD-GigabitEthernet2/0/1] isis ipv6 enable 1
[DeviceD-GigabitEthernet2/0/1] quit
[DeviceD] interface gigabitethernet 2/0/2
[DeviceD-GigabitEthernet2/0/2] isis ipv6 enable 1
[DeviceD-GigabitEthernet2/0/2] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] isis ipv6 enable 1
[DeviceD-LoopBack1] quit
# Display SRv6 TE policy information on Device A.
[DeviceA] display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 Endpoint: 4::4
 Name from BGP
 BSID:
  Mode: Explicit           Type: Type_2              Request state: Succeeded
  Current BSID: 5000::2    Explicit BSID: 5000::2    Dynamic BSID: -
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Not configured
 Up time: 2020-04-02 16:08:03
 Down time: 2020-04-02 16:03:48
 Hot backup: Not configured
 Statistics: Not configured
  Statistics by service class: Not configured
 Drop-upon-invalid: Disabled
 BFD trigger path-down: Disabled
 SBFD: Not configured
 BFD Echo: Not configured
 Forwarding index: 2150629377
 Service-class: -
 Rate-limit: -
 Service-class: -
 Encaps reduced: Not configured
 Encaps include local End.X: Not configured
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1          BGP paths: 0          PCEP paths: 0
 Candidate paths:
  Preference : 10
   CPathName:
   Instance ID: 0          ASN: 0          Node address: 0.0.0.0
   Peer address:  ::
   Optimal: Y              Flags: V/A
   Explicit SID list:
    ID: 1                     Name: s1
    Weight: 1                 Forwarding index: 2149580801
    State: Up                 State(SBFD): -
    Active path MTU: 1428 bytes
The output shows that the SRv6 TE policy is in up state. The device can use the SRv6 TE policy to forward packets.
# Display SRv6 TE forwarding information on Device A.
[DeviceA] display segment-routing ipv6 te forwarding verbose
Total forwarding entries: 1
Policy name/ID: p1/0
 Binding SID: 5000::2
 Policy forwording index: 2150629377
 Main path:
   Seglist ID: 1
     Seglist forwording index: 2149580801
     Weight: 1
     Outgoing forwording index: 2148532225
       Interface: GE2/0/1
       Nexthop: FE80::54CB:70FF:FE86:316
         Path ID: 0
         SID list: {6000::1, 7000::1, 8000::1}
# Display SRv6 forwarding information on Device A.
[DeviceA] display segment-routing ipv6 forwarding
Total SRv6 forwarding entries: 3
Flags: T - Forwarded through a tunnel
       N - Forwarded through the outgoing interface to the nexthop IP address
       A - Active forwarding information
       B - Backup forwarding information
ID            FWD-Type      Flags   Forwarding info
2148532225    SRv6PSIDList  NA      GE2/0/1
2149580801    SRv6PCPath    TA      2148532225
2150629377    SRv6Policy    TA      2149580801
Example: Configuring SRv6 TE policy egress protection
As shown in Figure 20, deploy an SRv6 TE policy in both directions between PE 1 and PE 2 to carry the L3VPN service. PE 2 is the egress node of the SRv6 TE policy. To improve the forwarding reliability, configure PE 3 to protect PE 2.
Figure 20 Network diagram
Table 1 Interface and IP address
Device
IP Address
Device
IP Address
CE 1
GE2/0/1
10.1.1.2/24
PE 2
Loop0
3::3/128
PE 1
Loop0
1::1/128
GE2/0/1
10.2.1.1/24
GE2/0/1
10.1.1.1/24
GE2/0/2
2002::1/64
GE2/0/2
2001::1/96
GE2/0/3
2004::2/96
P
Loop0
2::2/128
PE 3
Loop0
4::4/128
GE2/0/1
2001::2/96
GE2/0/1
10.3.1.1/24
GE2/0/2
2002::2/64
GE2/0/2
2003::1/96
GE2/0/3
2003::2/96
GE2/0/3
2004::1/96
CE 2
GE2/0/1
10.2.1.2/24
GE2/0/2
10.3.1.2/24
Configure interface addresses as shown in Table 1.
1.     Configure CE 1:
# Establish an EBGP peer relationship with PE 1 and redistribute the VPN routes.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.1 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.1 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
2.     Configure PE 1:
# Configure IPv6 IS-IS for backbone network connectivity.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] is-level level-1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 10.1111.1111.1111.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 0
[PE1-LoopBack0] ipv6 address 1::1 128
[PE1-LoopBack0] isis ipv6 enable 1
[PE1-LoopBack0] quit
[PE1] interface gigabitethernet 2/0/2
[PE1-GigabitEthernet2/0/2] ipv6 address 2001::1 96
[PE1-GigabitEthernet2/0/2] isis ipv6 enable 1
[PE1-GigabitEthernet2/0/2] quit
# Configure a VPN instance and bind it to the CE-facing interface.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface gigabitethernet 2/0/1
[PE1-GigabitEthernet2/0/1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet2/0/1] ip address 10.1.1.1 24
[PE1-GigabitEthernet2/0/1] quit
# Establish an EBGP peer relationship with the connected CE to redistribute the VPN routes.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default-vpn1] peer 10.1.1.2 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.2 enable
[PE1-bgp-default-vpn1] quit
# Establish MP-IBGP peer relationships with the peer PEs.
[PE1] bgp 100
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 4::4 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
[PE1-bgp-default] peer 4::4 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 3::3 enable
[PE1-bgp-default-vpnv4] peer 4::4 enable
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
# Configure L3VPN over SRv6 TE policy.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 1:2::1:0 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] opcode 1 end-dt4 vpn-instance vpn1
[PE1-segment-routing-ipv6-locator-aaa] quit
[PE1-segment-routing-ipv6] quit
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 3::3 prefix-sid
[PE1-bgp-default-vpnv4] peer 4::4 prefix-sid
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering best-effort
[PE1-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator aaa
[PE1-isis-1] quit
# Configure an SRv6 TE policy.
[PE1-segment-routing-ipv6] traffic-engineering
[PE1-srv6-te] srv6-policy locator aaa
[PE1-srv6-te] segment-list s1
[PE1-srv6-te-s1-s1] index 10 ipv6 100:abc:1::1
[PE1-srv6-te-s1-s1] index 20 ipv6 6:5::1:2
[PE1-srv6-te-s1-s1] quit
[PE1-srv6-te] policy p1
[PE1-srv6-te-policy-p1] binding-sid ipv6 1:2::1:2
[PE1-srv6-te-policy-p1] color 10 end-point ipv6 3::3
[PE1-srv6-te-policy-p1] candidate-paths
[PE1-srv6-te-policy-p1-path] preference 10
[PE1-srv6-te-policy-p1-path-pref-10] explicit segment-list s1
[PE1-srv6-te-policy-p1-path-pref-10] quit
[PE1-srv6-te-policy-p1-path] quit
[PE1-srv6-te-policy-p1] quit
[PE1-srv6-te] quit
3.     Configure the P device:
<P> system-view
[P] isis 1
[P-isis-1] is-level level-1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 10.2222.2222.2222.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 0
[P-LoopBack0] ipv6 address 2::2 128
[P-LoopBack0] isis ipv6 enable 1
[P-LoopBack0] quit
[P] interface gigabitethernet 2/0/1
[P-GigabitEthernet2/0/1] ipv6 address 2001::2 96
[P-GigabitEthernet2/0/1] isis ipv6 enable 1
[P-GigabitEthernet2/0/1] quit
[P] interface gigabitethernet 2/0/2
[P-GigabitEthernet2/0/2] ipv6 address 2002::2 96
[P-GigabitEthernet2/0/2] isis ipv6 enable 1
[P-GigabitEthernet2/0/2] quit
[P] interface gigabitethernet 2/0/3
[P-GigabitEthernet2/0/3] ipv6 address 2003::2 96
[P-GigabitEthernet2/0/3] isis ipv6 enable 1
[P-GigabitEthernet2/0/3] quit
# Configure SRv6.
[P] segment-routing ipv6
[P-segment-routing-ipv6] locator p ipv6-prefix 100:abc:1::0 96 static 8
[P-segment-routing-ipv6-locator-p] opcode 1 end
[P-segment-routing-ipv6-locator-p] quit
[P-segment-routing-ipv6] quit
[P] isis 1
[P-isis-1-ipv6] segment-routing ipv6 locator p
# Configure the FRR backup nexthop information and enable egress protection.
[P-isis-1-ipv6] fast-reroute lfa level-1
[P-isis-1-ipv6] fast-reroute ti-lfa
[P-isis-1-ipv6] fast-reroute mirror enable
[P-isis-1] quit
4.     Configure PE 2:
<PE2> system-view
[PE2] isis 1
[PE2-isis-1] is-level level-1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 10.3333.3333.3333.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ipv6 address 3::3 128
[PE2-LoopBack0] isis ipv6 enable 1
[PE2-LoopBack0] quit
[PE2] interface gigabitethernet 2/0/2
[PE2-GigabitEthernet2/0/2] ipv6 address 2002::1 96
[PE2-GigabitEthernet2/0/2] isis ipv6 enable 1
[PE2-GigabitEthernet2/0/2] quit
[PE2] interface gigabitethernet 2/0/3
[PE2-GigabitEthernet2/0/3] ipv6 address 2004::2 96
[PE2-GigabitEthernet2/0/3] isis ipv6 enable 1
[PE2-GigabitEthernet2/0/3] quit
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] interface gigabitethernet 2/0/1
[PE2-GigabitEthernet2/0/1] ip binding vpn-instance vpn1
[PE2-GigabitEthernet2/0/1] ip address 10.2.1.1 24
[PE2-GigabitEthernet2/0/1] quit
[PE2] bgp 100
[PE2-bgp-default] router-id 2.2.2.2
[PE2-bgp-default-vpn1] peer 10.2.1.2 as-number 65420
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.2 enable
[PE2-bgp-default-vpn1] quit
[PE2] bgp 100
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 4::4 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default] peer 4::4 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1::1 enable
[PE2-bgp-default-vpnv4] peer 4::4 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
[PE2-segment-routing-ipv6] locator bbb ipv6-prefix 6:5::1:0 96 static 8
[PE2-segment-routing-ipv6-locator-bbb] opcode 1 end-dt4 vpn-instance vpn1
[PE2-segment-routing-ipv6-locator-bbb] opcode 2 end
[PE2-segment-routing-ipv6-locator-bbb] quit
[PE2-segment-routing-ipv6] quit
[PE2] bgp 100
[PE2-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE2-bgp-default-vpnv4] peer 4::4 prefix-sid
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 traffic-engineering best-effort
[PE2-bgp-default-ipv4-vpn1] segment-routing ipv6 locator bbb
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator bbb
[PE2-isis-1] quit
5.     Configure PE 3:
<PE3> system-view
[PE3] isis 1
[PE3-isis-1] is-level level-1
[PE3-isis-1] cost-style wide
[PE3-isis-1] network-entity 10.4444.4444.4444.00
[PE3-isis-1] address-family ipv6 unicast
[PE3-isis-1-ipv6] quit
[PE3-isis-1] quit
[PE3] interface loopback 0
[PE3-LoopBack0] ipv6 address 4::4 128
[PE3-LoopBack0] isis ipv6 enable 1
[PE3-LoopBack0] quit
[PE3] interface gigabitethernet 2/0/2
[PE3-GigabitEthernet2/0/2] ipv6 address 2003::1 96
[PE3-GigabitEthernet2/0/2] isis ipv6 enable 1
[PE3-GigabitEthernet2/0/2] quit
[PE3] interface gigabitethernet 2/0/3
[PE3-GigabitEthernet2/0/3] ipv6 address 2004::1 96
[PE3-GigabitEthernet2/0/3] isis ipv6 enable 1
[PE3-GigabitEthernet2/0/3] quit
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 111:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface gigabitethernet 2/0/1
[PE3-GigabitEthernet2/0/1] ip binding vpn-instance vpn1
[PE3-GigabitEthernet2/0/1] ip address 10.3.1.1 24
[PE3-GigabitEthernet2/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] router-id 3.3.3.3
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 10.3.1.2 as-number 65420
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 10.3.1.2 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3] bgp 100
[PE3-bgp-default] peer 1::1 as-number 100
[PE3-bgp-default] peer 3::3 as-number 100
[PE3-bgp-default] peer 1::1 connect-interface loopback 0
[PE3-bgp-default] peer 3::3 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 1::1 enable
[PE3-bgp-default-vpnv4] peer 3::3 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default] quit
# Configure the source address in the outer IPv6 header of SRv6 VPN packets.
[PE3] segment-routing ipv6
[PE3-segment-routing-ipv6] encapsulation source-address 4::4
# Configure an End.M SID to protect PE 2.
[PE3-segment-routing-ipv6] locator ccc ipv6-prefix 9:7::1:0 96 static 8
[PE3-segment-routing-ipv6-locator-ccc] opcode 1 end-m mirror-locator 6:5::1:0 96
[PE3-segment-routing-ipv6-locator-ccc] quit
[PE3-segment-routing-ipv6] quit
# Recurse the VPN routes to the End.M SID route.
[PE3] bgp 100
[PE3-bgp-default-vpnv4] peer 1::1 prefix-sid
[PE3-bgp-default-vpnv4] peer 3::3 prefix-sid
[PE3-bgp-default-ipv4-vpn1] segment-routing ipv6 locator ccc
[PE3] isis 1
[PE3-isis-1-ipv6] segment-routing ipv6 locator ccc
[PE3-isis-1] quit
6.     Configure CE 2:
# Establish an EBGP peer relationship with PEs and redistribute the VPN routes.
<CE2> system-view
[CE2] bgp 65420
[CE2-bgp-default] peer 10.2.1.1 as-number 100
[CE2-bgp-default] peer 10.3.1.1 as-number 100
[CE2-bgp-default-ipv4] peer 10.2.1.1 enable
[CE2-bgp-default-ipv4] peer 10.3.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Display the SRv6 TE policy configuration. The output shows that the SRv6 TE policy is up for traffic forwarding.
[PE1] display segment-routing ipv6 te policy
Name/ID: p1/0
 Color: 10
 End-point: 3::3
 Name from BGP:
 BSID:
  Current BSID: 1:2::1:2    Explicit BSID: 1:2::1:2   Dynamic BSID: -
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 Up time: 2020-10-28 09:10:33
 Down time: 2020-10-28 09:09:32
 Service-class: -
 Rate-limit: -
 Service-class: -
 Candidate paths:
  Preference : 10
   CPathName:
   Peer address:  ::
   Explicit SID list:
    ID: 1                     Name: s1
    State: Up                 State(-): -
# Display SRv6 TE policy forwarding information on PE 1.
[PE1] display segment-routing ipv6 te forwarding verbose
 Binding SID: 1:2::1:2
 Main path:
   Seglist ID: 1
     Seglist forwarding index: 2149580801
     Weight: 1
     Outgoing forwarding index: 2148532225
       Interface: GE2/0/2
       Nexthop: FE80::988A:B5FF:FED9:316
         Path ID: 0
         SID list: {100:ABC:1::1, 6:5::1:2}
# Display SRv6 TE policy forwarding path information on PE 1.
[PE1] display segment-routing ipv6 forwarding
              Attri-Val             Attri-Val
2148532225    SRv6PSIDList  NA      GE2/0/2
              p1
# Display remote SRv6 SIDs protected by End.M SIDs on PE 3.
[PE3] display bgp mirror remote-sid
Remote SID: 6:5::1:1
Remote SID type: End.DT4
Mirror locator: 6:5::1:0/96
Vpn instance name: vpn1
# Display the End.M SID carried in the IS-IS IPv6 route on the P device.
[P] display isis route ipv6 6:5::1:0 96 verbose
                         Level-1 IPv6 forwarding table
 IPv6 dest   : 6:5::/96
 Flag        : R/-/-                       Cost        : 10
 Admin tag   : -                           Src count   : 3
 Nexthop     : FE80::988A:BDFF:FEB6:417
 Interface   : GE2/0/2
 Mirror FRR:
  Interface : GE2/0/3
  BkNextHop : FE80::988A:C6FF:FE0D:517
  LsIndex    : 0x80000001
  Backup label stack(top->bottom): {9:7::1:1}
 Nib ID      : 0x24000006
Typically, VPN traffic from CE 1 to CE 2 is forwarded over the CE 1-PE 1-P-PE 2-CE 2 path. When PE 2 fails, the P device switches traffic to the mirror FRR path for the SRv6 TE policy when it detects that the next hop (PE 2) is unreachable.
# Shut down the interface that connects P to PE 2.
[P-GigabitEthernet2/0/2] shut
# Display the IS-IS IPv6 route information. The output shows that the nexthop interface becomes the backup interface.
 Flag        : R/-/-                       Cost        : 20
 Nexthop     : FE80::988A:C6FF:FE0D:517
 Interface   : GE2/0/3
 Nib ID      : 0x24000007
# Display SRv6 TE policy information on PE 1. The output shows that the SRv6 TE policy is still up.
Name/ID: p1/0
 Color: 10
 End-point: 3::3
 Name from BGP:
 BSID:
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 Service-class: -
 Rate-limit: -
 Service-class: -
 Candidate paths:
  Preference : 10
   CPathName:
   Peer address:  ::
   Explicit SID list:
    ID: 1                     Name: s1
