- 07-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-EIGRP configuration
- 07-BGP configuration
- 08-Policy-based routing configuration
- 09-IPv6 static routing configuration
- 10-RIPng configuration
- 11-OSPFv3 configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-MTR configuration
- 15-RIR configuration
08-Policy-based routing configuration | 293.89 KB |
Restrictions and guidelines: PBR configuration
Setting match criteria for a node
Configuring actions for a node
Specifying a policy for local PBR
Specifying a policy for interface PBR
Display and maintenance commands for PBR
Example: Configuring packet type-based local PBR
Example: Configuring packet type-based interface PBR
Example: Configuring packet length-based interface PBR
Example: Configuring source-IP-based interface PBR
Example: Configuring packet application-type-based interface PBR
Example: Configuring packet service-type-based interface PBR
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs or that have specific lengths. The parameters include the next hop, output interface, SRv6 TE policy, default next hop, default output interface, and default SRv6 TE policy.
Packet forwarding process
When the device receives a packet, the device searches the PBR policy for a matching node to forward that packet.
· If a matching node is found and its match mode is permit, the device performs the following operations:
a. Uses the next hops, output interfaces, or SRv6 TE policies specified on the node to forward the packet.
b. Searches the routing table for a route (except the default route) to forward the packet if one of the following conditions exists:
- No next hops, output interfaces, or SRv6 TE policies are specified on the node.
- Forwarding failed based on the next hops, output interfaces, or SRv6 TE policies.
c. Uses the default next hops, default output interfaces, or default SRv6 TE policies specified on the node to forward the packet if one of the following conditions exists:
- No matching route was found in the routing table.
- The routing table-based forwarding failed.
d. Uses the default route to forward the packet if one of the following conditions exists:
- No default next hops, default output interfaces, or default SRv6 TE policies are specified on the node.
- The forwarding failed based on the default next hops, default output interfaces, or default SRv6 TE policies.
· The device perfoms routing table lookup to forward the packet in either of the following conditions:
¡ No matching node is found.
¡ A matching node is found, but its match mode is deny.
PBR types
PBR includes the following types:
· Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
· Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses but only one if-match clause for each type.
To match a node, a packet must match all types of the if-match clauses for the node but only one if-match clause for each type.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node? |
Match mode |
Permit |
Deny |
Yes. |
· If the node contains apply clauses, PBR executes the apply clauses on the node. ¡ If PBR-based forwarding succeeds, PBR does not compare the packet with the next node. ¡ If PBR-based forwarding fails and the apply continue clause is not configured, PBR does not compare the packet with the next node. ¡ If PBR-based forwarding fails and the apply continue clause is configured, PBR compares the packet with the next node. · If the node does not contain apply clauses, the device performs a routing table lookup for the packet. |
The device performs a routing table lookup for the packet. |
No. |
PBR compares the packet with the next node. |
NOTE: A node that has no if-match clauses matches any packet. |
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, default next hop, or default output interface.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see Track in High Availability Configuration Guide.
If the device performs forwarding in software, PBR does not process IP packets destined for the local device.
If the device performs forwarding in hardware and a packet destined for it matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
The device that supports fast forwarding uses the high-speed cache to process packets, and identifies a data flow with one or multiple packet fields. If the first packet of a data flow is successfully forwarded through PBR, the associated forwarding information is generated in the high-speed cache. Subsequent packets of the data flow can then be forwarded through the PBR fast forwarding table. This greatly reduces packet forwarding time and improves packet forwarding rate. For more information about fast forwarding, see fast forwarding configuration in Layer 3—IP Services Configuration Guide.
If a permit-mode PBR policy node successfully forwards a packet, the device cannot generate a fast forwarding entry when the following conditions exist:
· The match rules other than packet 5-tuple are configured for the policy node, for example, the IP packet length match rule configured with the if-match packet-length clause.
· Among the apply access-vpn, apply next-hop (with the inbound-vpn keyword), and apply output-interface (with broadcast or NBMA output interfaces specified) clauses, if one or multiple of the clauses are configured on the policy node, the device determines whether the following conditions are met in descending order of priority:
¡ Multiple VPN instances are specified with the apply access-vpn clause, and the first VPN instance is unavailable. If the clause is not configured, the device proceeds to the next condition.
¡ A next hop with the inbound-vpn keyword is specified in the apply next-hop clause, but the next hop is unreachable. In load sharing mode, a minimum of one next hop with the inbound-vpn keyword is required. In non-load-sharing mode, before you configure a next hop with the inbound-vpn keyword, no other available next hops without the inbound-vpn keyword are configured. If the clause is not configured, the device proceeds to the next condition.
¡ A broadcast or NBMA output interface is specified with the apply output-interface clause on the policy node, but the output interface is unavailable. In load sharing mode, a minimum of one broadcast or NBMA output interface is required. In non-load-sharing mode, before you specify a broadcast or NBMA output interface, no other available non-broadcast or non-NBMA output interfaces are specified.
· The apply access-vpn vpn-instance, apply next-hop, apply output-interface, and apply srv6-policy clauses are not configured, but one or multiple of the following clauses are configured on the policy node:
¡ apply default-next-hop
¡ apply default-output-interface
¡ apply default-srv6-policy
· The apply ip-df or apply precedence clause is configured on the policy node.
If the permit-mode PBR policy node fails to forward a packet, and the apply continue clause is configured on the policy node, the device cannot generate a fast forwarding entry.
PBR tasks at a glance
To configure PBR, perform the following tasks:
b. Setting match criteria for a node
c. Configuring actions for a node
2. Specifying a policy for PBR
¡ Specifying a policy for local PBR
¡ Specifying a policy for interface PBR
Configuring a policy
Creating a node
1. Enter system view.
2. Create a node for a policy, and enter its view.
2. Enter policy node view.
3. Set match criteria.
¡ Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
¡ Set a packet length match criterion.
if-match packet-length min-len max-len
By default, no packet length match criterion is set.
¡ Set a source IP address match criterion for local PBR.
if-match source-ip { interface interface-type interface-number | [ vpn-instance vpn-instance-name ] ip-address }
By default, no source IP address match criterion is set for local PBR.
¡ Set application group match criteria.
if-match app-group app-group-name&<1-6>
By default, no application group match criteria are set.
Application group match criteria apply only to interface PBR.
For more information about application groups, see APR configuration in Security Configuration Guide.
¡ Set service object group match criteria.
if-match object-group service object-group-name&<1-6>
By default, no service object group match criteria are set.
For more information about service object groups, see object group configuration in Security Configuration Guide.
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
· apply access-vpn
· apply next-hop
· apply output-interface
· apply gateway
· apply srv6-policy
· apply default-next-hop
· apply default-output-interface
· apply default-gateway
· apply default-srv6-policy
PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in PBR
Clause |
Meaning |
Remarks |
apply precedence |
Sets an IP precedence. |
This clause is always executed. |
apply ip-df df-value |
Sets the Don't Fragment (DF) bit in the IP header. |
apply loadshare { default-next-hop | default-output-interface | default-srv6-policy | next-hop | output-interface | srv6-policy } |
Enables load sharing among multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies. |
Multiple next hop, output interface, SRv6 TE policy, default next hop, default output interface, or default SRv6 TE policy options operate in either primary/backup or load sharing mode. The following description uses multiple next hops as an example: · Primary/backup mode—A next hop is selected from all next hops in configuration order for packet forwarding, with all remaining next hops as backups. When the selected next hop fails, the next available next hop takes over. · Load sharing mode—Matching traffic is distributed across the available next hops. If the traffic does not match any fast forwarding entries, per-packet load sharing is performed. If the traffic matches a fast forwarding entry, per-flow load sharing is performed. By default, the primary/backup mode applies. For the load sharing mode to take effect, make sure multiple next hops, output interfaces, SRv6 TE policies, default next hops, default output interfaces, or default SRv6 TE policies are set in the policy. |
apply access-vpn |
Specifies the forwarding tables that can be used for the matching packets. |
Use this clause only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN. If a packet matches the forwarding table for a specified VPN instance, it is forwarded in the VPN. |
apply remark-vpn |
Enables VPN remark action. |
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of PBR handle the packets as belonging to the re-marked VPN instance. If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received. VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command. |
apply next-hop, apply output-interface, apply gateway, and apply srv6-policy |
Sets next hops, output interfaces, gateway addresses, and SRv6 TE policies. |
Only the apply clause with the highest priority is executed. |
apply default-next-hop, apply default-output-interface, apply default-gateway, and apply default-srv6-policy |
Sets default next hops, default output interfaces, default gateway addresses, and default SRv6 TE policies. |
Only the apply clause with the highest priority is executed. The clauses take effect only in the following cases: · No next hops, output interfaces, gateway addresses, or SRv6 TE polices are set or the next hops, output interfaces, gateway addresses, and SRv6 TE polices are invalid. · The packet does not match any route in the routing table. |
apply continue |
Compares packets with the next node upon failure on the current node. |
The apply continue clause applies when either of the following conditions exist: · None of the clauses that determine the packet forwarding paths is configured. · A clause that determines the packet forwarding paths is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet. NOTE: A clause might become invalid because the specified next hop is unreachable, the specified gateway address is unreachable, the specified SRv6 TE policy is unavailable, packets cannot be forwarded in the specified VPN instance, or the specified output interface is down. |
For outbound PBR, you can specify only one next hop and the next hop must be directly connected.
If you specify a next hop or default next hop, PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to modify packet fields
3. Set an IP precedence.
By default, no IP precedence is specified.
4. Set the DF bit in the IP header.
By default, the DF bit in the IP header is not set.
Configuring actions to direct packet forwarding
3. Configure actions.
¡ Specify the forwarding tables that can be used for the matching packets.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
By default, the device forwards matching packets by using the forwarding table for the network from which the packets are received.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
¡ Enable VPN remark action to mark the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command.
apply remark-vpn
By default, VPN remark action is not configured.
¡ Set next hops.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ] }&<1-4>
By default, no next hops are specified.
On a node, you can specify a maximum of four next hops for backup or load sharing in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡ Enable load sharing among multiple next hops.
apply loadshare next-hop
By default, the next hops operate in primary/backup mode.
¡ Set output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no output interfaces are specified.
On a node, you can specify a maximum of four output interfaces for backup or load sharing in one command line or by executing this command multiple times.
¡ Enable load sharing among multiple output interfaces.
apply loadshare output-interface
By default, the output interfaces operate in primary/backup mode.
¡ Set the next hop addresses for matching packets to the specified gateway addresses.
apply gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, the next hop addresses for matching packets are not set to gateway addresses.
¡ Set SRv6 TE policies.
apply srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
By default, no SRv6 TE policies are specified.
You can specify a maximum of 2 SRv6 TE policies in one command line or by executing this command multiple times. The first available SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡ Enable load sharing among multiple SRv6 TE policies.
apply loadshare srv6-policy
By default, the SRv6 TE policies operate in primary/backup mode.
¡ Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ip-address [ direct ] [ track track-entry-number ] }&<1-4>
By default, no default next hops are specified.
On a node, you can specify a maximum of four default next hops for backup or load sharing in one command line or by executing this command multiple times.
¡ Enable load sharing among multiple default next hops.
apply loadshare default-next-hop
By default, the default next hops operate in primary/backup mode.
¡ Set default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, no default output interfaces are specified.
On a node, you can specify a maximum of four default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
¡ Enable load sharing among multiple default output interfaces.
apply loadshare default-output-interface
By default, the default output interfaces operate in primary/backup mode.
¡ Set the default next hop addresses for matching packets to the specified gateway addresses.
apply default-gateway { interface-type interface-number [ track track-entry-number ] }&<1-4>
By default, the default next hop addresses for matching packets are not set to gateway addresses.
¡ Set default SRv6 TE policies.
apply default-srv6-policy { endpoint color [ { sid | vpnsid } sid ] }&<1-2>
By default, no default SRv6 TE policies are specified.
You can specify a maximum of two default SRv6 TE policies in one command line or by executing this command multiple times. The first available default SRv6 TE policy selected according to configuration order will be used to forward matching packets.
¡ Enable load sharing among multiple default SRv6 TE policies.
apply loadshare default-srv6-policy
By default, the default SRv6 TE policies operate in primary/backup mode.
Comparing packets with the next node upon match failure on the current node
3. Compare packets with the next node upon match failure on the current node.
apply continue
By default, PBR does not compare packets with the next node upon match failure on the current node.
This command takes effect only when the match mode of the node is permit.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2. Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
2. Enter interface view.
3. Specify a policy for interface PBR.
ip policy-based-route policy-name
By default, no policy is applied to an interface.
Task |
Command |
Display PBR policy information. |
display ip policy-based-route [ policy policy-name ] |
Display interface PBR configuration and statistics. |
In standalone mode: display ip policy-based-route interface interface-type interface-number [ slot slot-number ] In IRF mode: display ip policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ] |
Display local PBR configuration and statistics. |
In standalone mode: display ip policy-based-route local [ slot slot-number ] In IRF mode: display ip policy-based-route local [ chassis chassis-number slot slot-number ] |
Display PBR configuration. |
display ip policy-based-route setup |
Clear PBR statistics. |
reset ip policy-based-route statistics [ policy policy-name ] |
PBR configuration examples
As shown in Figure 1, Router B and Router C do not have a route to reach each other.
Configure PBR on Router A to forward all TCP packets to the next hop 1.1.2.2 (Router B).
1. Configure Router A:
# Configure the IP addresses of GigabitEthernet 2/0/1 and GigabitEthernet 2/0/2.
[RouterA] interface gigabitethernet 2/0/1
[RouterA-GigabitEthernet2/0/1] ip address 1.1.2.1 24
[RouterA-GigabitEthernet2/0/1] quit
[RouterA] interface gigabitethernet 2/0/2
[RouterA-GigabitEthernet2/0/2] ip address 1.1.3.1 24
[RouterA-GigabitEthernet2/0/2] quit
# Configure ACL 3101 to match TCP packets.
[RouterA] acl advanced 3101
[RouterA-acl-ipv4-adv-3101] rule permit tcp
[RouterA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[RouterA] policy-based-route aaa permit node 5
[RouterA-pbr-aaa-5] if-match acl 3101
[RouterA-pbr-aaa-5] apply next-hop 1.1.2.2
[RouterA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Router A.
[RouterA] ip local policy-based-route aaa
2. On Router B, configure the IP address of GigabitEthernet 2/0/1.
<RouterB> system-view
[RouterB] interface gigabitethernet 2/0/1
[RouterB-GigabitEthernet2/0/1] ip address 1.1.2.2 24
3. On Router C, configure the IP address of GigabitEthernet 2/0/2.
<RouterC> system-view
[RouterC] interface gigabitethernet 2/0/2
[RouterC-GigabitEthernet2/0/2] ip address 1.1.3.2 24
1. Perform telnet operations to verify that local PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Router B), as follows:
# Verify that you can telnet to Router B from Router A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Router A. (Details not shown.)
2. Verify that Router A forwards packets other than TCP packets through GigabitEthernet 2/0/2. For example, verify that you can ping Router C from Router A. (Details not shown.)
As shown in Figure 2, Router B and Router C do not have a route to reach each other.
Configure PBR on Router A to forward all TCP packets received on GigabitEthernet 2/0/1 to the next hop 1.1.2.2 (Router B).
1. Configure IP addresses and unicast routing protocol settings to make sure Router B and Router C can reach Host A. (Details not shown.)
2. Configure Router A:
# Configure interface PBR by applying the policy aaa to GigabitEthernet 2/0/1.
[RouterA-GigabitEthernet2/0/1] ip policy-based-route aaa
1. Perform telnet operations to verify that interface PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Router B), as follows:
# Verify that you can telnet to Router B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Host A. (Details not shown.)
2. Verify that Router A forwards packets other than TCP packets through GigabitEthernet 2/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
As shown in Figure 3, configure interface PBR to guide the forwarding of packets received on GigabitEthernet 2/0/1 of Router A as follows:
· Set the next hop of packets with a length of 64 to 300 bytes to 150.1.1.2/24.
· Set the next hop of packets with a length of 301 to 1000 bytes to 151.1.1.2/24.
1. Configure IP addresses and unicast routing protocol settings to make sure the devices each have a route to reach one another. (Details not shown.)
# Configure Node 10 for the policy lab1 to forward packets with a length of 64 to 300 bytes to the next hop 150.1.1.2.
[RouterA] policy-based-route lab1 permit node 10
[RouterA-pbr-lab1-10] if-match packet-length 64 300
[RouterA-pbr-lab1-10] apply next-hop 150.1.1.2
[RouterA-pbr-lab1-10] quit
# Configure Node 20 for the policy lab1 to forward packets with a length of 301 to 1000 bytes to the next hop 151.1.1.2.
[RouterA] policy-based-route lab1 permit node 20
[RouterA-pbr-lab1-20] if-match packet-length 301 1000
[RouterA-pbr-lab1-20] apply next-hop 151.1.1.2
[RouterA-pbr-lab1-20] quit
# Configure interface PBR by applying the policy lab1 to GigabitEthernet 2/0/1.
[RouterA-GigabitEthernet2/0/1] ip policy-based-route lab1
# Execute the debugging ip policy-based-route command on Router A.
<RouterA> debugging ip policy-based-route
<RouterA> terminal logging level 7
<RouterA> terminal monitor
# Ping Loopback 0 of Router B from Host A, and set the data length to 64 bytes. In this way, the total length of the data packet is in the range of 64 to 300 bytes.
C:\>ping –n 1 -l 64 10.1.1.1
Pinging 10.1.1.1 with 64 bytes of data:
Reply from 10.1.1.1: bytes=64 time=1ms TTL=64
Ping statistics for 10.1.1.1:
Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
The debugging information about PBR displayed on Router A is as follows:
<RouterA>
*Jun 26 12:04:33:519 2012 RouterA PBR4/7/PBR Forward Info: -MDC=1; Policy:lab1, Node:
10,match succeeded.
*Jun 26 12:04:33:519 2012 RouterA PBR4/7/PBR Forward Info: -MDC=1; apply next-hop 150
.1.1.2.
The output shows that Router A sets the next hop for the received packets to 150.1.1.2 according to PBR. The packets are forwarded through GigabitEthernet 2/0/2.
# Ping Loopback 0 of Router B from Host A, and set the data length to 300 bytes. In this way, the total length of the data packet is in the range of 301 to 1000 bytes.
C:\> ping –n 1 -l 300 10.1.1.1
Pinging 10.1.1.1 with 300 bytes of data:
Reply from 10.1.1.1: bytes=300 time=1ms TTL=64
<RouterA>
*Jun 26 12:20:33:610 2012 RouterA PBR4/7/PBR Forward Info: -MDC=1; Policy:lab1, Node:
20,match succeeded.
*Jun 26 12:20:33:610 2012 RouterA PBR4/7/PBR Forward Info: -MDC=1; apply next-hop 151
.1.1.2.
The output shows that Router A sets the next hop for the received packets to 151.1.1.2 according to PBR. The packets are forwarded through GigabitEthernet 2/0/3.
As shown in Figure 4, Router B and Router C do not have a route to reach each other.
Configure interface PBR to guide the forwarding of packets received on GigabitEthernet 2/0/1 of Router A as follows:
· Set the next hop of packets sourced from 192.168.10.2 to 4.1.1.2/24.
· Set the next hop of other packets to 5.1.1.2/24.
1. Configure IP addresses and unicast routing protocol settings to make sure Router B can reach Host A and Host B, and Router C can reach Host A and Host B. (Details not shown.)
# Configure ACL 2000 to match packets sourced from 192.168.10.2.
[RouterA] acl basic 2000
[RouterA-acl-ipv4-basic-2000] rule 10 permit source 192.168.10.2 0
[RouterA-acl-ipv4-basic-2000] quit
# Configure Node 0 for the policy aaa to forward packets sourced from 192.168.10.2 to next hop 4.1.1.2. Configure Node 1 for the policy aaa to forward other packets to next hop 5.1.1.2.
[RouterA] policy-based-route aaa permit node 0
[RouterA-pbr-aaa-0] if-match acl 2000
[RouterA-pbr-aaa-0] apply next-hop 4.1.1.2
[RouterA-pbr-aaa-0] quit
[RouterA] policy-based-route aaa permit node 1
[RouterA-pbr-aaa-1] apply next-hop 5.1.1.2
[RouterA-pbr-aaa-1] quit
1. Verify that interface PBR on Router A operates as configured to forward packets sourced from 192.168.10.2 to the next hop 4.1.1.2 and packets sourced from 192.168.10.3 to the next hop 5.1.1.2:
# Configure IP address 192.168.10.3/24 for Host B, and specify its gateway address as 192.168.10.1. (Details not shown.)
# Verify that you can ping Router B from Host A. (Details not shown.)
# Verify that you can ping Router C from Host B. (Details not shown.)
# Verify that you cannot ping Router B from Host B. (Details not shown.)
# Verify that you cannot ping Router C from Host A. (Details not shown.)
As shown in Figure 5, Router B and Router C do not have a route to reach each other.
Configure interface PBR on Router A to forward all HTTP packets received on GigabitEthernet 2/0/1 to the next hop 1.1.2.2/24 (Router B).
# Create the application group http to match HTTP packets.
[RouterA] app-group http
[RouterA-app-group-http] include application http
[RouterA-app-group-http] quit
# Configure Node 5 for the policy aaa, and specify the application group http for the policy node to forward HTTP packets to next hop 1.1.2.2.
[RouterA-pbr-aaa-5] if-match app-group http
1. Perform Web logins to verify that interface PBR on Router A operates as configured to forward the matching HTTP packets to the next hop 1.1.2.2 (Router B), as follows:
# Verify that you can log in to Router B from Host A successfully. (Details not shown.)
# Verify that you cannot log in to Router C from Host A. (Details not shown.)
2. Verify that Router A forwards packets other than HTTP packets through GigabitEthernet 2/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
As shown in Figure 6, Router B and Router C do not have a route to reach each other.
Configure interface PBR on Router A to forward all FTP packets received on GigabitEthernet 2/0/1 to the next hop 1.1.2.2/24 (Router B).
# Configure Node 5 for the policy aaa, and specify the system-predefined service object group ftp for the policy node to forward FTP packets to next hop 1.1.2.2.
[RouterA-pbr-aaa-5] if-match object-group service ftp
1. Perform logins through FTP to verify that interface PBR on Router A operates as configured to forward the matching FTP packets to the next hop 1.1.2.2 (Router B), as follows:
2. Verify that Router A forwards packets other than FTP packets through GigabitEthernet 2/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
