12-High Availability Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1362-6W10112-High Availability Command Reference
03-DLDP commands
03-DLDP commands 92.67 KB
DLDP commands
display dldp
Use display dldp to display DLDP configuration.
display dldp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays global and port-specific DLDP configuration.
# Display global and port-specific DLDP configuration.
<Sysname> display dldp
 DLDP global status: Enabled
 DLDP advertisement interval: 5s
 DLDP authentication-mode: Simple
 DLDP authentication-password: ******
 DLDP unidirectional-shutdown mode: Auto
 DLDP delaydown-timer value: 1s
 Number of enabled ports: 2
Interface GigabitEthernet1/0
 DLDP port state: Bidirectional
 Number of the port’s neighbors: 1
  Neighbor MAC address: 0023-8956-3600
  Neighbor port index: 79
  Neighbor state: Confirmed
  Neighbor aged time: 13s
Interface GigabitEthernet2/0
 DLDP port state: Inactive
 Number of the port’s neighbors: 0 (Maximum number ever detected: 1)
# Display the DLDP configuration of GigabitEthernet 1/0.
<Sysname> display dldp interface gigabitethernet 1/0
DLDP global status
Global DLDP state (Enabled or Disabled).
Interval for sending Advertisement packets (in seconds) to maintain neighbor relations.
DLDP authentication mode (None, Simple, or MD5).
Password for DLDP authentication:
·     ******—The password has been configured.
·     Not configured—The authentication mode has been configured but no password is configured.
Global port shutdown mode (auto or manual) after unidirectional links are detected.
Setting of the DelayDown timer, in seconds.
Number of the DLDP-enabled ports.
Index of a DLDP-enabled port.
DLDP port state
DLDP state on a port:
·     Bidirectional.
·     Inactive.
·     Initial.
·     Unidirectional.
Current number of neighbors.
Maximum number of neighbors once detected on the port. This field appears only when the current number of neighbors is different from the maximum number of neighbors once detected.
Bridge MAC address of the device where the neighbor resides.
Neighbor port index
Neighbor port index.
Neighbor state
Neighbor state (Confirmed or Unconfirmed).
Neighbor aged time
Neighbor aging time.
display dldp statistics
Use display dldp statistics to display DLDP packet statistics.
display dldp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays DLDP packet statistics for all interfaces.
# Display DLDP packet statistics for all interfaces.
<Sysname> display dldp statistics
 Packets sent: 6
 Packets received: 5
 Invalid packets received: 2
 Loopback packets received: 0
 Authentication-failed packets received: 0
 Valid packets received: 3
 Packets sent: 7
 Packets received: 7
 Invalid packets received: 3
 Valid packets received: 4
Port index.
Packets sent
Total number of DLDP packets sent.
Packets received
Total number of DLDP packets received.
Number of the invalid packets received.
Loop packets received
Number of the loopback packets received.
Authentication failed packets received
Number of the received packets that failed to pass the authentication.
Number of the valid packets received.
reset dldp statistics
dldp authentication-mode
Use dldp authentication-mode to configure DLDP authentication.
Use undo dldp authentication-mode to restore the default.
dldp authentication-mode { md5 | none | simple }
DLDP authentication mode is none.
md5: Specifies the MD5 authentication mode.
none: Specifies not to perform authentication.
simple: Specifies the plaintext authentication mode.
To enable DLDP to operate correctly, make sure the DLDP authentication modes and the passwords configured on the two ends of a link are the same.
If you do not configure the authentication password after you configure the authentication mode, the authentication mode is none no matter which authentication mode you configure.
# Configure to perform plaintext authentication and set the password to abc (assuming that Device A and Device B are connected by a DLDP link).
·     Configure Device A:
[DeviceA] dldp authentication-mode simple
[DeviceA] dldp authentication-password simple abc
·     Configure Device B:
[DeviceB] dldp authentication-mode simple
[DeviceB] dldp authentication-password simple abc
display dldp
Use dldp authentication-password to configure the password for DLDP authentication.
Use undo dldp authentication-password to restore the default.
dldp authentication-password { cipher | simple } string
No DLDP authentication password is configured.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 1 to 53 characters.
display dldp
dldp delaydown-timer
Use dldp delaydown-timer to set the DelayDown timer.
Use undo dldp delaydown-timer to restore the default.
dldp delaydown-timer time
The setting of the DelayDown timer is 1 second.
time: Specifies the DelayDown timer in the range of 1 to 5 seconds.
The DelayDown timer configured by using this command applies to all DLDP-enabled ports.
# Set the DelayDown timer to 2 seconds.
[Sysname] dldp delaydown-timer 2
display dldp
dldp enable
Use dldp enable to enable DLDP on a port.
Use undo dldp enable to disable DLDP on a port.
dldp enable
undo dldp enable
DLDP is disabled on a port.
DLDP can take effect only after you enable it globally and on a port.
# Enable DLDP globally, and then enable DLDP on GigabitEthernet 1/0.
[Sysname] dldp global enable
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] dldp enable
display dldp
dldp global enable
dldp global enable
Use dldp global enable to enable DLDP globally.
Use undo dldp global enable to disable DLDP globally.
dldp global enable
DLDP is disabled globally.
# Enable DLDP globally.
display dldp
dldp enable
dldp interval
Use dldp interval to set the interval for sending Advertisement packets.
Use undo dldp interval to restore the default.
dldp interval interval
undo dldp interval
The interval for sending Advertisement packets is 5 seconds.
interval: Specifies Advertisement packets sending interval in the range of 1 to 100 seconds.
This command applies to all DLDP-enabled ports.
To enable DLDP to operate correctly, make sure the intervals for sending Advertisement packets configured on the two ends of a link are the same.
# Set the interval for sending Advertisement packets to 20 seconds.
[Sysname] dldp interval 20
display dldp
dldp unidirectional-shutdown
Use dldp unidirectional-shutdown to set the global port shutdown mode.
Use undo dldp unidirectional-shutdown to restore the default.
dldp unidirectional-shutdown { auto | manual }
The global port shutdown mode is auto mode.
auto: Specifies the auto mode. In this mode, when DLDP detects a unidirectional link, it shuts down the unidirectional port. When the link becomes bidirectional, DLDP brings up the port that was shut down.
manual: Specifies the manual mode. In this mode, when DLDP detects a unidirectional link, it does not shut down the involved port. You must manually shut it down. To verify the link status, use the undo shutdown command to bring up the port. If the link becomes bidirectional, the port becomes bidirectional.
If DLDP detects a unidirectional link, you must troubleshoot the interface and cabling faults.
# Set the global port shutdown mode to manual mode.
[Sysname] dldp unidirectional-shutdown manual
display dldp
Use reset dldp statistics to clear DLDP packet statistics.
reset dldp statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears DLDP packet statistics for all interfaces.
# Clear DLDP packet statistics for all interfaces.
<Sysname> reset dldp statistics
