- 11-Security Command Reference
- 01-Security zone commands
- 02-AAA commands
- 03-Portal commands
- 04-User profile commands
- 05-Password control commands
- 06-Keychain commands
- 07-Public key management commands
- 08-PKI commands
- 09-IPsec commands
- 10-Group domain VPN commands
- 11-SSH commands
- 12-SSL commands
- 13-SSL VPN commands
- 14-APR commands
- 15-ASPF commands
- 16-Session management commands
- 17-Connection limit commands
- 18-Object group commands
- 19-Object policy commands
- 20-Attack detection and prevention commands
- 21-IP source guard commands
- 22-ARP attack protection commands
- 23-ND attack defense commands
- 24-uRPF commands
- 25-Crypto engine commands
- 26-FIPS commands
- 27-Security policy commands
04-User profile commands | 73.13 KB |
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
In standalone mode:
display user-profile [ session-group ] [ name profile-name ]
In IRF mode:
display user-profile [ session-group ] [ name profile-name ] [ slot slot-number ]
session-group: Specifies a session group profile.
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices. (In IRF mode.)
# (In standalone mode.) Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
User-Profile: aaa
Inbound:
Committed Access Rate:
Rule: If-match any
CIR 64 (kbps), CBS 512 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Rule: If-match acl 2000
CIR 3000 (kbps), CBS 187500 (Bytes), EBS 0 (Bytes)
Policy: p1
Outbound:
Rule: If-match acl 3000
CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
Rule: If-match any
Line Rate:
CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
Priority queuing: pql 1
General Traffic Shaping:
CIR 200 (kbps), CBS 12500 (Bytes), EBS 0 (Bytes)
Overhead compensation length: 18
User user_1:
Authentication type: Portal
Network attributes:
Interface : GigabitEthernet1/0
MAC address : 0000-1111-2222
Failed action list:
Inbound: Policy p1
Inbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
# (In IRF mode.) Display configuration and online user information for user profile aaa.
User-Profile: aaa
Inbound:
Rule: If-match any
Policy: p1
Outbound:
Rule: If-match any
Line Rate:
slot 1:
User user_1:
User ID: 0x10000002
Network attributes:
IP address : 172.16.187.16
Service VLAN : 100
# (In standalone mode.) Display configuration and online user information for all session group profiles.
<Sysname> display user-profile session-group
Session-Group-Profile: aaa
Outbound:
QMProfile: a
User user_1:
Network attributes:
Failed action list:
Outbound: CIR 64 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
QMProfile: a
User user_2:
Network attributes:
Interface : GigabitEthernet3/0
VPN : N/A
Service VLAN : 100
Session-Group-Profile: bbb
Outbound:
CIR 512 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
QMProfile: a
User user_4:
Network attributes:
Interface : GigabitEthernet2/0
IP address : 172.16.187.166
VPN : N/A
Service VLAN : 100
# (In IRF mode.) Display configuration and online user information for all session group profiles.
Outbound:
QMProfile: a
slot 1:
User user_1:
User ID: 0x0000000b
Network attributes:
Failed action list:
QMProfile: a
User-Profile |
User profile name. |
Inbound |
Policy applied to incoming traffic. |
Outbound |
Policy applied to outgoing traffic. |
Session-Group-Profile |
Session group profile name. |
CIR |
Committed information rate, in kbps. |
CBS |
Committed burst size, in bytes. |
EBS |
Excess burst size, in bytes. |
PIR |
Peak information rate, in kbps. |
Policy |
Policy name. |
Line Rate |
Information about user profile-based rate limiting. When the peer-advertise-bandwidth keyword is specified in the qos lr outbound command, this field displays the peer-advertise-bandwidth configuration information. |
Priority queuing |
Information about priority queuing applied to a user profile. |
General Traffic Shaping |
Information about GTS applied to a user profile. |
QMProfile |
Queue scheduling profile. |
User user_1 |
Username of a user account with which a user profile or session group profile is associated. |
Authentication type |
Authentication type: · 802.1X—802.1X authentication. · Portal—Portal authentication. · PPP—PPP authentication. · MACA—MAC authentication. |
Network attributes |
Online user information. |
Failed action list |
Actions that failed to be applied to the user. |
Overhead compensation length |
Packet compensation length in bytes for outbound traffic policing. |
Rule |
Match criteria. |
qos session-group identify
Use qos session-group identify to identify a session group on an interface.
Use undo qos session-group identify to restore the default.
qos session-group identify { customer-vlan | service-vlan | customer-service-vlan | subscriber-id }
No session group is identified on the interface.
Interface view
customer-vlan: Identifies a session group by CVLAN. A CVLAN is used by a customer on the private network.
service-vlan: Identifies a session group by SVLAN. An SVLAN is used by a service provider to transmit VLAN tagged traffic for customers.
customer-service-vlan: Identifies a session group by CVLAN and SVLAN.
subscriber-id: Identifies a session group by subscriber ID.
To configure a session group profile, you must first use the command.
# Configure GigabitEthernet 1/0 to identify a session group by an SVLAN.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] qos session-group identify service-vlan
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name [ type session-group ]
undo user-profile profile-name
No user profiles exist.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters (a-z, A-Z), digits (0-9), hyphens (-), and underscores (_). The name must start with an English letter or digit, and cannot contain only digits. The name must be globally unique.
type session-group: Specifies a session group profile.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
# Create session group profile a123 and enter the view of a123.
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123]
